Julius Werner (jwerner@chromium.org) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/16274
commit d956f0bb758b494edbe379c47ecafecc303447de Author: Julius Werner jwerner@chromium.org Date: Fri Aug 19 16:35:22 2016 -0700
gru: Make SDRAM parameters individual struct files in CBFS
This patch changes Gru SDRAM parameters from structures that just get compiled into the romstage to individual CBFS files. This allows us to only load the parameter set we need for the board we're booting from flash, which reduces our boot time and the SRAM memory footprint required to hold the romstage.
Change-Id: Ie88a515cbdb19a794ca0a230a56bcc82bed1e550 Signed-off-by: Julius Werner jwerner@chromium.org --- src/mainboard/google/gru/Makefile.inc | 2 + src/mainboard/google/gru/sdram_configs.c | 38 +- src/mainboard/google/gru/sdram_inf/Makefile.inc | 30 + .../gru/sdram_inf/sdram-lpddr3-hynix-4GB-200.c | 1565 ++++++++++++++++++++ .../gru/sdram_inf/sdram-lpddr3-hynix-4GB-200.inc | 1563 ------------------- .../sdram_inf/sdram-lpddr3-hynix-4GB-666-no-odt.c | 1565 ++++++++++++++++++++ .../sdram-lpddr3-hynix-4GB-666-no-odt.inc | 1563 ------------------- .../gru/sdram_inf/sdram-lpddr3-hynix-4GB-666.c | 1565 ++++++++++++++++++++ .../gru/sdram_inf/sdram-lpddr3-hynix-4GB-666.inc | 1563 ------------------- .../sdram_inf/sdram-lpddr3-hynix-4GB-800-no-odt.c | 1565 ++++++++++++++++++++ .../sdram-lpddr3-hynix-4GB-800-no-odt.inc | 1563 ------------------- .../gru/sdram_inf/sdram-lpddr3-hynix-4GB-800.c | 1565 ++++++++++++++++++++ .../gru/sdram_inf/sdram-lpddr3-hynix-4GB-800.inc | 1563 ------------------- .../gru/sdram_inf/sdram-lpddr3-hynix-4GB-933.c | 1565 ++++++++++++++++++++ .../gru/sdram_inf/sdram-lpddr3-hynix-4GB-933.inc | 1563 ------------------- src/soc/rockchip/rk3399/include/soc/sdram.h | 4 +- 16 files changed, 9437 insertions(+), 9405 deletions(-)
diff --git a/src/mainboard/google/gru/Makefile.inc b/src/mainboard/google/gru/Makefile.inc index a0839e0..2711a50 100644 --- a/src/mainboard/google/gru/Makefile.inc +++ b/src/mainboard/google/gru/Makefile.inc @@ -13,6 +13,8 @@ ## GNU General Public License for more details. ##
+subdirs-y += sdram_inf/ + bootblock-y += bootblock.c bootblock-y += chromeos.c bootblock-y += memlayout.ld diff --git a/src/mainboard/google/gru/sdram_configs.c b/src/mainboard/google/gru/sdram_configs.c index f34ebf1..33fc6ea 100644 --- a/src/mainboard/google/gru/sdram_configs.c +++ b/src/mainboard/google/gru/sdram_configs.c @@ -15,31 +15,24 @@
#include <arch/io.h> #include <boardid.h> +#include <cbfs.h> #include <console/console.h> #include <gpio.h> #include <soc/sdram.h> #include <string.h> #include <types.h>
-static struct rk3399_sdram_params sdram_configs[] = { -#include "sdram_inf/sdram-lpddr3-hynix-4GB-200.inc" - -/* 666MHz, enable odt 120o */ -#include "sdram_inf/sdram-lpddr3-hynix-4GB-666.inc" - -/* 800MHz, enable odt 120o */ -#include "sdram_inf/sdram-lpddr3-hynix-4GB-800.inc" - -/* 666MHz, disable odt */ -#include "sdram_inf/sdram-lpddr3-hynix-4GB-666-no-odt.inc" - -/* 800MHz, disable odt */ -#include "sdram_inf/sdram-lpddr3-hynix-4GB-800-no-odt.inc" - -/* 933MHz, enable odt 120o */ -#include "sdram_inf/sdram-lpddr3-hynix-4GB-933.inc" +static const char *sdram_configs[] = { + "sdram-lpddr3-hynix-4GB-200", + "sdram-lpddr3-hynix-4GB-666", + "sdram-lpddr3-hynix-4GB-800", + "sdram-lpddr3-hynix-4GB-666-no-odt", + "sdram-lpddr3-hynix-4GB-800-no-odt", + "sdram-lpddr3-hynix-4GB-933", };
+struct rk3399_sdram_params params; + enum dram_speeds { dram_200MHz = 0, dram_666MHz = 1, @@ -80,11 +73,8 @@ static enum dram_speeds get_sdram_index(void)
const struct rk3399_sdram_params *get_sdram_config() { - - enum dram_speeds speed = get_sdram_index(); - - printk(BIOS_INFO, "Using SDRAM configuration for %d MHz\n", - sdram_configs[speed].ddr_freq / (1000 * 1000)); - - return &sdram_configs[speed]; + if (cbfs_boot_load_struct(sdram_configs[get_sdram_index()], + ¶ms, sizeof(params)) != sizeof(params)) + die("Cannot load SDRAM parameter file!"); + return ¶ms; } diff --git a/src/mainboard/google/gru/sdram_inf/Makefile.inc b/src/mainboard/google/gru/sdram_inf/Makefile.inc new file mode 100644 index 0000000..c217265 --- /dev/null +++ b/src/mainboard/google/gru/sdram_inf/Makefile.inc @@ -0,0 +1,30 @@ +## +## This file is part of the coreboot project. +## +## Copyright 2016 Rockchip Inc. +## +## This program is free software; you can redistribute it and/or modify +## it under the terms of the GNU General Public License as published by +## the Free Software Foundation; version 2 of the License. +## +## This program is distributed in the hope that it will be useful, +## but WITHOUT ANY WARRANTY; without even the implied warranty of +## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +## GNU General Public License for more details. +## + +sdram-configs := + +sdram-configs += sdram-lpddr3-hynix-4GB-200 +sdram-configs += sdram-lpddr3-hynix-4GB-666 +sdram-configs += sdram-lpddr3-hynix-4GB-666-no-odt +sdram-configs += sdram-lpddr3-hynix-4GB-800 +sdram-configs += sdram-lpddr3-hynix-4GB-800-no-odt +sdram-configs += sdram-lpddr3-hynix-4GB-933 + +$(foreach config,$(sdram-configs), \ + $(eval cbfs-files-y += $(config)) \ + $(eval $(config)-file := $(config).c:struct) \ + $(eval $(config)-type := struct) \ + $(eval $(config)-compression := $(CBFS_COMPRESS_FLAG)) \ +) diff --git a/src/mainboard/google/gru/sdram_inf/sdram-lpddr3-hynix-4GB-200.c b/src/mainboard/google/gru/sdram_inf/sdram-lpddr3-hynix-4GB-200.c new file mode 100644 index 0000000..dda6d98 --- /dev/null +++ b/src/mainboard/google/gru/sdram_inf/sdram-lpddr3-hynix-4GB-200.c @@ -0,0 +1,1565 @@ +/* + * This file is part of the coreboot project. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <soc/sdram.h> + +struct rk3399_sdram_params params = { + { + { + .rank = 0x2, + .col = 0xA, + .bk = 0x3, + .bw = 0x2, + .dbw = 0x2, + .row_3_4 = 0x0, + .cs0_row = 0xF, + .cs1_row = 0xF, + .ddrconfig = 1, + { + {0x0e080807}, + {0x05010605}, + {0x00000002}, + {0x00006076}, + {0x00000054}, + 0x00000000 + } + }, + { + .rank = 0x2, + .col = 0xA, + .bk = 0x3, + .bw = 0x2, + .dbw = 0x2, + .row_3_4 = 0x0, + .cs0_row = 0xF, + .cs1_row = 0xF, + .ddrconfig = 1, + { + {0x0e080807}, + {0x05010605}, + {0x00000002}, + {0x00006076}, + {0x00000054}, + 0x00000000 + } + } + }, + .ddr_freq = 200*MHz, + .dramtype = LPDDR3, + .num_channels = 2, + .stride = 13, + .odt = 1, + { + { + 0x00000700, /* DENALI_CTL_00_DATA */ + 0x00000000, /* DENALI_CTL_01_DATA */ + 0x00000000, /* DENALI_CTL_02_DATA */ + 0x00000000, /* DENALI_CTL_03_DATA */ + 0x00000000, /* DENALI_CTL_04_DATA */ + 0x00000014, /* DENALI_CTL_05_DATA */ + 0x00009c40, /* DENALI_CTL_06_DATA */ + 0x000000c8, /* DENALI_CTL_07_DATA */ + 0x000007d0, /* DENALI_CTL_08_DATA */ + 0x00000014, /* DENALI_CTL_09_DATA */ + 0x00009c40, /* DENALI_CTL_10_DATA */ + 0x000000c8, /* DENALI_CTL_11_DATA */ + 0x000007d0, /* DENALI_CTL_12_DATA */ + 0x00000014, /* DENALI_CTL_13_DATA */ + 0x00009c40, /* DENALI_CTL_14_DATA */ + 0x000000c8, /* DENALI_CTL_15_DATA */ + 0x010007d0, /* DENALI_CTL_16_DATA */ + 0x00000000, /* DENALI_CTL_17_DATA */ + 0x00000101, /* DENALI_CTL_18_DATA */ + 0x00020100, /* DENALI_CTL_19_DATA */ + 0x00000028, /* DENALI_CTL_20_DATA */ + 0x00000064, /* DENALI_CTL_21_DATA */ + 0x00000000, /* DENALI_CTL_22_DATA */ + 0x030c0000, /* DENALI_CTL_23_DATA */ + 0x00030c00, /* DENALI_CTL_24_DATA */ + 0x0400030c, /* DENALI_CTL_25_DATA */ + 0x0d020004, /* DENALI_CTL_26_DATA */ + 0x0a040409, /* DENALI_CTL_27_DATA */ + 0x090d0200, /* DENALI_CTL_28_DATA */ + 0x000a0404, /* DENALI_CTL_29_DATA */ + 0x04090d02, /* DENALI_CTL_30_DATA */ + 0x04000a04, /* DENALI_CTL_31_DATA */ + 0x00000a0a, /* DENALI_CTL_32_DATA */ + 0x030036b0, /* DENALI_CTL_33_DATA */ + 0x0a0a0403, /* DENALI_CTL_34_DATA */ + 0x030036b0, /* DENALI_CTL_35_DATA */ + 0x0a0a0403, /* DENALI_CTL_36_DATA */ + 0x030036b0, /* DENALI_CTL_37_DATA */ + 0x02030003, /* DENALI_CTL_38_DATA */ + 0x04040400, /* DENALI_CTL_39_DATA */ + 0x04040404, /* DENALI_CTL_40_DATA */ + 0x14000a0a, /* DENALI_CTL_41_DATA */ + 0x01010a0a, /* DENALI_CTL_42_DATA */ + 0x00010001, /* DENALI_CTL_43_DATA */ + 0x030a0a0a, /* DENALI_CTL_44_DATA */ + 0x00050505, /* DENALI_CTL_45_DATA */ + 0x00000000, /* DENALI_CTL_46_DATA */ + 0x03010000, /* DENALI_CTL_47_DATA */ + 0x0304002a, /* DENALI_CTL_48_DATA */ + 0x0304002a, /* DENALI_CTL_49_DATA */ + 0x0304002a, /* DENALI_CTL_50_DATA */ + 0x00000000, /* DENALI_CTL_51_DATA */ + 0x00030003, /* DENALI_CTL_52_DATA */ + 0x000a0003, /* DENALI_CTL_53_DATA */ + 0x000a000a, /* DENALI_CTL_54_DATA */ + 0x00040404, /* DENALI_CTL_55_DATA */ + 0x00000000, /* DENALI_CTL_56_DATA */ + 0x00000000, /* DENALI_CTL_57_DATA */ + 0x00000000, /* DENALI_CTL_58_DATA */ + 0x002c0000, /* DENALI_CTL_59_DATA */ + 0x002c002c, /* DENALI_CTL_60_DATA */ + 0x002c002c, /* DENALI_CTL_61_DATA */ + 0x0000002c, /* DENALI_CTL_62_DATA */ + 0x00000000, /* DENALI_CTL_63_DATA */ + 0x00000000, /* DENALI_CTL_64_DATA */ + 0x00000000, /* DENALI_CTL_65_DATA */ + 0x00000000, /* DENALI_CTL_66_DATA */ + 0x00000000, /* DENALI_CTL_67_DATA */ + 0x00000000, /* DENALI_CTL_68_DATA */ + 0x00000301, /* DENALI_CTL_69_DATA */ + 0x00000001, /* DENALI_CTL_70_DATA */ + 0x00000000, /* DENALI_CTL_71_DATA */ + 0x00000000, /* DENALI_CTL_72_DATA */ + 0x01000000, /* DENALI_CTL_73_DATA */ + 0x80104002, /* DENALI_CTL_74_DATA */ + 0x00040003, /* DENALI_CTL_75_DATA */ + 0x00040005, /* DENALI_CTL_76_DATA */ + 0x00030000, /* DENALI_CTL_77_DATA */ + 0x00050004, /* DENALI_CTL_78_DATA */ + 0x00000004, /* DENALI_CTL_79_DATA */ + 0x00040003, /* DENALI_CTL_80_DATA */ + 0x00040005, /* DENALI_CTL_81_DATA */ + 0x0c100000, /* DENALI_CTL_82_DATA */ + 0x00000608, /* DENALI_CTL_83_DATA */ + 0x06080c10, /* DENALI_CTL_84_DATA */ + 0x0c100000, /* DENALI_CTL_85_DATA */ + 0x00000608, /* DENALI_CTL_86_DATA */ + 0x00000000, /* DENALI_CTL_87_DATA */ + 0x00000000, /* DENALI_CTL_88_DATA */ + 0x00000000, /* DENALI_CTL_89_DATA */ + 0x00000000, /* DENALI_CTL_90_DATA */ + 0x00000000, /* DENALI_CTL_91_DATA */ + 0x02020200, /* DENALI_CTL_92_DATA */ + 0x00020202, /* DENALI_CTL_93_DATA */ + 0x00030200, /* DENALI_CTL_94_DATA */ + 0x00040700, /* DENALI_CTL_95_DATA */ + 0x00000302, /* DENALI_CTL_96_DATA */ + 0x02000407, /* DENALI_CTL_97_DATA */ + 0x00000003, /* DENALI_CTL_98_DATA */ + 0x00030f04, /* DENALI_CTL_99_DATA */ + 0x00070004, /* DENALI_CTL_100_DATA */ + 0x00000000, /* DENALI_CTL_101_DATA */ + 0x00000000, /* DENALI_CTL_102_DATA */ + 0x00000000, /* DENALI_CTL_103_DATA */ + 0x00000000, /* DENALI_CTL_104_DATA */ + 0x00000000, /* DENALI_CTL_105_DATA */ + 0x00000000, /* DENALI_CTL_106_DATA */ + 0x00000000, /* DENALI_CTL_107_DATA */ + 0x00010000, /* DENALI_CTL_108_DATA */ + 0x20040020, /* DENALI_CTL_109_DATA */ + 0x00200400, /* DENALI_CTL_110_DATA */ + 0x01000400, /* DENALI_CTL_111_DATA */ + 0x00000b80, /* DENALI_CTL_112_DATA */ + 0x00000000, /* DENALI_CTL_113_DATA */ + 0x00000001, /* DENALI_CTL_114_DATA */ + 0x00000002, /* DENALI_CTL_115_DATA */ + 0x0000000e, /* DENALI_CTL_116_DATA */ + 0x00000000, /* DENALI_CTL_117_DATA */ + 0x00000000, /* DENALI_CTL_118_DATA */ + 0x00000000, /* DENALI_CTL_119_DATA */ + 0x00000000, /* DENALI_CTL_120_DATA */ + 0x00000000, /* DENALI_CTL_121_DATA */ + 0x00280000, /* DENALI_CTL_122_DATA */ + 0x00320014, /* DENALI_CTL_123_DATA */ + 0x00320000, /* DENALI_CTL_124_DATA */ + 0x00140028, /* DENALI_CTL_125_DATA */ + 0x00000032, /* DENALI_CTL_126_DATA */ + 0x00280032, /* DENALI_CTL_127_DATA */ + 0x00320014, /* DENALI_CTL_128_DATA */ + 0x00320000, /* DENALI_CTL_129_DATA */ + 0x00000000, /* DENALI_CTL_130_DATA */ + 0x00000000, /* DENALI_CTL_131_DATA */ + 0x00000000, /* DENALI_CTL_132_DATA */ + 0x00830000, /* DENALI_CTL_133_DATA */ + 0x00000004, /* DENALI_CTL_134_DATA */ + 0x00040083, /* DENALI_CTL_135_DATA */ + 0x00830000, /* DENALI_CTL_136_DATA */ + 0x00000004, /* DENALI_CTL_137_DATA */ + 0x00010001, /* DENALI_CTL_138_DATA */ + 0x07000001, /* DENALI_CTL_139_DATA */ + 0x00000707, /* DENALI_CTL_140_DATA */ + 0x00000000, /* DENALI_CTL_141_DATA */ + 0x00000000, /* DENALI_CTL_142_DATA */ + 0x00000000, /* DENALI_CTL_143_DATA */ + 0x00000000, /* DENALI_CTL_144_DATA */ + 0x00000000, /* DENALI_CTL_145_DATA */ + 0x00000000, /* DENALI_CTL_146_DATA */ + 0x00830000, /* DENALI_CTL_147_DATA */ + 0x00000004, /* DENALI_CTL_148_DATA */ + 0x00040083, /* DENALI_CTL_149_DATA */ + 0x00830000, /* DENALI_CTL_150_DATA */ + 0x00000004, /* DENALI_CTL_151_DATA */ + 0x00010001, /* DENALI_CTL_152_DATA */ + 0x07000001, /* DENALI_CTL_153_DATA */ + 0x00000707, /* DENALI_CTL_154_DATA */ + 0x00000000, /* DENALI_CTL_155_DATA */ + 0x00000000, /* DENALI_CTL_156_DATA */ + 0x00000000, /* DENALI_CTL_157_DATA */ + 0x00000000, /* DENALI_CTL_158_DATA */ + 0x00000000, /* DENALI_CTL_159_DATA */ + 0x00000000, /* DENALI_CTL_160_DATA */ + 0x01000000, /* DENALI_CTL_161_DATA */ + 0x00000000, /* DENALI_CTL_162_DATA */ + 0x00000000, /* DENALI_CTL_163_DATA */ + 0x18151100, /* DENALI_CTL_164_DATA */ + 0x0000000c, /* DENALI_CTL_165_DATA */ + 0x00000000, /* DENALI_CTL_166_DATA */ + 0x00000000, /* DENALI_CTL_167_DATA */ + 0x00000000, /* DENALI_CTL_168_DATA */ + 0x00000000, /* DENALI_CTL_169_DATA */ + 0x00000000, /* DENALI_CTL_170_DATA */ + 0x00000000, /* DENALI_CTL_171_DATA */ + 0x00000000, /* DENALI_CTL_172_DATA */ + 0x00000000, /* DENALI_CTL_173_DATA */ + 0x00000000, /* DENALI_CTL_174_DATA */ + 0x00000000, /* DENALI_CTL_175_DATA */ + 0x00000000, /* DENALI_CTL_176_DATA */ + 0x00000000, /* DENALI_CTL_177_DATA */ + 0x00000000, /* DENALI_CTL_178_DATA */ + 0x0000c803, /* DENALI_CTL_179_DATA */ + 0x00120048, /* DENALI_CTL_180_DATA */ + 0x00000000, /* DENALI_CTL_181_DATA */ + 0x004800c8, /* DENALI_CTL_182_DATA */ + 0x00000012, /* DENALI_CTL_183_DATA */ + 0x0000c800, /* DENALI_CTL_184_DATA */ + 0x00120048, /* DENALI_CTL_185_DATA */ + 0x00000000, /* DENALI_CTL_186_DATA */ + 0x000a0000, /* DENALI_CTL_187_DATA */ + 0x000a000a, /* DENALI_CTL_188_DATA */ + 0x01010100, /* DENALI_CTL_189_DATA */ + 0x01000202, /* DENALI_CTL_190_DATA */ + 0x0a000002, /* DENALI_CTL_191_DATA */ + 0x01000f0f, /* DENALI_CTL_192_DATA */ + 0x00000000, /* DENALI_CTL_193_DATA */ + 0x00000000, /* DENALI_CTL_194_DATA */ + 0x00010003, /* DENALI_CTL_195_DATA */ + 0x00000c03, /* DENALI_CTL_196_DATA */ + 0x00000100, /* DENALI_CTL_197_DATA */ + 0x00010000, /* DENALI_CTL_198_DATA */ + 0x01000000, /* DENALI_CTL_199_DATA */ + 0x00010000, /* DENALI_CTL_200_DATA */ + 0x00000001, /* DENALI_CTL_201_DATA */ + 0x00000000, /* DENALI_CTL_202_DATA */ + 0x00000000, /* DENALI_CTL_203_DATA */ + 0x00000000, /* DENALI_CTL_204_DATA */ + 0x00000000, /* DENALI_CTL_205_DATA */ + 0x00000000, /* DENALI_CTL_206_DATA */ + 0x00000000, /* DENALI_CTL_207_DATA */ + 0x00000000, /* DENALI_CTL_208_DATA */ + 0x00000000, /* DENALI_CTL_209_DATA */ + 0x00000000, /* DENALI_CTL_210_DATA */ + 0x00010000, /* DENALI_CTL_211_DATA */ + 0x01010101, /* DENALI_CTL_212_DATA */ + 0x01000707, /* DENALI_CTL_213_DATA */ + 0x02020001, /* DENALI_CTL_214_DATA */ + 0x05050502, /* DENALI_CTL_215_DATA */ + 0x02080808, /* DENALI_CTL_216_DATA */ + 0x02050202, /* DENALI_CTL_217_DATA */ + 0x02010202, /* DENALI_CTL_218_DATA */ + 0x00010202, /* DENALI_CTL_219_DATA */ + 0x00020202, /* DENALI_CTL_220_DATA */ + 0x02010200, /* DENALI_CTL_221_DATA */ + 0x00010201, /* DENALI_CTL_222_DATA */ + 0x00000000, /* DENALI_CTL_223_DATA */ + 0x00000000, /* DENALI_CTL_224_DATA */ + 0x0d000001, /* DENALI_CTL_225_DATA */ + 0x00010028, /* DENALI_CTL_226_DATA */ + 0x00010000, /* DENALI_CTL_227_DATA */ + 0x00000003, /* DENALI_CTL_228_DATA */ + 0x00000000, /* DENALI_CTL_229_DATA */ + 0x00000000, /* DENALI_CTL_230_DATA */ + 0x00000000, /* DENALI_CTL_231_DATA */ + 0x00000000, /* DENALI_CTL_232_DATA */ + 0x00000000, /* DENALI_CTL_233_DATA */ + 0x00000000, /* DENALI_CTL_234_DATA */ + 0x00000000, /* DENALI_CTL_235_DATA */ + 0x00000000, /* DENALI_CTL_236_DATA */ + 0x00010100, /* DENALI_CTL_237_DATA */ + 0x01000000, /* DENALI_CTL_238_DATA */ + 0x00000001, /* DENALI_CTL_239_DATA */ + 0x00000303, /* DENALI_CTL_240_DATA */ + 0x00000000, /* DENALI_CTL_241_DATA */ + 0x00000000, /* DENALI_CTL_242_DATA */ + 0x00000000, /* DENALI_CTL_243_DATA */ + 0x00000000, /* DENALI_CTL_244_DATA */ + 0x00000000, /* DENALI_CTL_245_DATA */ + 0x00000000, /* DENALI_CTL_246_DATA */ + 0x00000000, /* DENALI_CTL_247_DATA */ + 0x00000000, /* DENALI_CTL_248_DATA */ + 0x00000000, /* DENALI_CTL_249_DATA */ + 0x00000000, /* DENALI_CTL_250_DATA */ + 0x00000000, /* DENALI_CTL_251_DATA */ + 0x00000000, /* DENALI_CTL_252_DATA */ + 0x00000000, /* DENALI_CTL_253_DATA */ + 0x00000000, /* DENALI_CTL_254_DATA */ + 0x00000000, /* DENALI_CTL_255_DATA */ + 0x000556aa, /* DENALI_CTL_256_DATA */ + 0x000aaaaa, /* DENALI_CTL_257_DATA */ + 0x000aa955, /* DENALI_CTL_258_DATA */ + 0x00055555, /* DENALI_CTL_259_DATA */ + 0x000b3133, /* DENALI_CTL_260_DATA */ + 0x0004cd33, /* DENALI_CTL_261_DATA */ + 0x0004cecc, /* DENALI_CTL_262_DATA */ + 0x000b32cc, /* DENALI_CTL_263_DATA */ + 0x00010300, /* DENALI_CTL_264_DATA */ + 0x03000100, /* DENALI_CTL_265_DATA */ + 0x00000000, /* DENALI_CTL_266_DATA */ + 0x00000000, /* DENALI_CTL_267_DATA */ + 0x00000000, /* DENALI_CTL_268_DATA */ + 0x00000000, /* DENALI_CTL_269_DATA */ + 0x00000000, /* DENALI_CTL_270_DATA */ + 0x00000000, /* DENALI_CTL_271_DATA */ + 0x00000000, /* DENALI_CTL_272_DATA */ + 0x00000000, /* DENALI_CTL_273_DATA */ + 0x00ffff00, /* DENALI_CTL_274_DATA */ + 0x14140000, /* DENALI_CTL_275_DATA */ + 0x08000014, /* DENALI_CTL_276_DATA */ + 0x00000608, /* DENALI_CTL_277_DATA */ + 0x00000200, /* DENALI_CTL_278_DATA */ + 0x00000200, /* DENALI_CTL_279_DATA */ + 0x00000200, /* DENALI_CTL_280_DATA */ + 0x00000200, /* DENALI_CTL_281_DATA */ + 0x00000608, /* DENALI_CTL_282_DATA */ + 0x00003c50, /* DENALI_CTL_283_DATA */ + 0x06080205, /* DENALI_CTL_284_DATA */ + 0x00000200, /* DENALI_CTL_285_DATA */ + 0x00000200, /* DENALI_CTL_286_DATA */ + 0x00000200, /* DENALI_CTL_287_DATA */ + 0x00000200, /* DENALI_CTL_288_DATA */ + 0x00000608, /* DENALI_CTL_289_DATA */ + 0x00003c50, /* DENALI_CTL_290_DATA */ + 0x06080205, /* DENALI_CTL_291_DATA */ + 0x00000200, /* DENALI_CTL_292_DATA */ + 0x00000200, /* DENALI_CTL_293_DATA */ + 0x00000200, /* DENALI_CTL_294_DATA */ + 0x00000200, /* DENALI_CTL_295_DATA */ + 0x00000608, /* DENALI_CTL_296_DATA */ + 0x00003c50, /* DENALI_CTL_297_DATA */ + 0x02020205, /* DENALI_CTL_298_DATA */ + 0x03030202, /* DENALI_CTL_299_DATA */ + 0x00000018, /* DENALI_CTL_300_DATA */ + 0x00000000, /* DENALI_CTL_301_DATA */ + 0x00000000, /* DENALI_CTL_302_DATA */ + 0x00001403, /* DENALI_CTL_303_DATA */ + 0x00000000, /* DENALI_CTL_304_DATA */ + 0x00000000, /* DENALI_CTL_305_DATA */ + 0x00000000, /* DENALI_CTL_306_DATA */ + 0x00030000, /* DENALI_CTL_307_DATA */ + 0x0008001a, /* DENALI_CTL_308_DATA */ + 0x0008001a, /* DENALI_CTL_309_DATA */ + 0x0008001a, /* DENALI_CTL_310_DATA */ + 0x00000000, /* DENALI_CTL_311_DATA */ + 0x00000000, /* DENALI_CTL_312_DATA */ + 0x01000000, /* DENALI_CTL_313_DATA */ + 0x01010101, /* DENALI_CTL_314_DATA */ + 0x00050101, /* DENALI_CTL_315_DATA */ + 0x00000000, /* DENALI_CTL_316_DATA */ + 0x00000000, /* DENALI_CTL_317_DATA */ + 0x00000000, /* DENALI_CTL_318_DATA */ + 0x00000000, /* DENALI_CTL_319_DATA */ + 0x00000000, /* DENALI_CTL_320_DATA */ + 0x00000000, /* DENALI_CTL_321_DATA */ + 0x00000000, /* DENALI_CTL_322_DATA */ + 0x00000000, /* DENALI_CTL_323_DATA */ + 0x01000101, /* DENALI_CTL_324_DATA */ + 0x01010101, /* DENALI_CTL_325_DATA */ + 0x01000101, /* DENALI_CTL_326_DATA */ + 0x01000100, /* DENALI_CTL_327_DATA */ + 0x00010001, /* DENALI_CTL_328_DATA */ + 0x00010002, /* DENALI_CTL_329_DATA */ + 0x00020100, /* DENALI_CTL_330_DATA */ + 0x00000002 /* DENALI_CTL_331_DATA */ + } + }, + { + { + 0x00000700, /* DENALI_PI_00_DATA */ + 0x00000000, /* DENALI_PI_01_DATA */ + 0x00000c10, /* DENALI_PI_02_DATA */ + 0x00000608, /* DENALI_PI_03_DATA */ + 0x00000c10, /* DENALI_PI_04_DATA */ + 0x00000608, /* DENALI_PI_05_DATA */ + 0x00000c10, /* DENALI_PI_06_DATA */ + 0x06080608, /* DENALI_PI_07_DATA */ + 0x00000200, /* DENALI_PI_08_DATA */ + 0x00000200, /* DENALI_PI_09_DATA */ + 0x00000200, /* DENALI_PI_10_DATA */ + 0x00000200, /* DENALI_PI_11_DATA */ + 0x00000608, /* DENALI_PI_12_DATA */ + 0x00000200, /* DENALI_PI_13_DATA */ + 0x00000200, /* DENALI_PI_14_DATA */ + 0x00000200, /* DENALI_PI_15_DATA */ + 0x00000200, /* DENALI_PI_16_DATA */ + 0x00000608, /* DENALI_PI_17_DATA */ + 0x00000200, /* DENALI_PI_18_DATA */ + 0x00000200, /* DENALI_PI_19_DATA */ + 0x00000200, /* DENALI_PI_20_DATA */ + 0x00000200, /* DENALI_PI_21_DATA */ + 0x00010000, /* DENALI_PI_22_DATA */ + 0x00000007, /* DENALI_PI_23_DATA */ + 0x81000001, /* DENALI_PI_24_DATA */ + 0x0f0003f0, /* DENALI_PI_25_DATA */ + 0x3fffffff, /* DENALI_PI_26_DATA */ + 0x0f0000a0, /* DENALI_PI_27_DATA */ + 0x377ff000, /* DENALI_PI_28_DATA */ + 0x0f000020, /* DENALI_PI_29_DATA */ + 0x377ff000, /* DENALI_PI_30_DATA */ + 0x0f000030, /* DENALI_PI_31_DATA */ + 0x377ff000, /* DENALI_PI_32_DATA */ + 0x0f0000b0, /* DENALI_PI_33_DATA */ + 0x377ff000, /* DENALI_PI_34_DATA */ + 0x0f000100, /* DENALI_PI_35_DATA */ + 0x377ff000, /* DENALI_PI_36_DATA */ + 0x0f000110, /* DENALI_PI_37_DATA */ + 0x377ff000, /* DENALI_PI_38_DATA */ + 0x0f000010, /* DENALI_PI_39_DATA */ + 0x377ff000, /* DENALI_PI_40_DATA */ + 0x03000101, /* DENALI_PI_41_DATA */ + 0x041f1f1f, /* DENALI_PI_42_DATA */ + 0x030c0003, /* DENALI_PI_43_DATA */ + 0x00030c00, /* DENALI_PI_44_DATA */ + 0x0000000c, /* DENALI_PI_45_DATA */ + 0x0304002a, /* DENALI_PI_46_DATA */ + 0x0304002a, /* DENALI_PI_47_DATA */ + 0x0304002a, /* DENALI_PI_48_DATA */ + 0x00000500, /* DENALI_PI_49_DATA */ + 0x00000000, /* DENALI_PI_50_DATA */ + 0x00000000, /* DENALI_PI_51_DATA */ + 0x00000000, /* DENALI_PI_52_DATA */ + 0x00000000, /* DENALI_PI_53_DATA */ + 0x00000000, /* DENALI_PI_54_DATA */ + 0x00000000, /* DENALI_PI_55_DATA */ + 0x00000000, /* DENALI_PI_56_DATA */ + 0x00000000, /* DENALI_PI_57_DATA */ + 0x04040000, /* DENALI_PI_58_DATA */ + 0x0d000004, /* DENALI_PI_59_DATA */ + 0x00000128, /* DENALI_PI_60_DATA */ + 0x00000000, /* DENALI_PI_61_DATA */ + 0x00030003, /* DENALI_PI_62_DATA */ + 0x00000018, /* DENALI_PI_63_DATA */ + 0x00000000, /* DENALI_PI_64_DATA */ + 0x00000000, /* DENALI_PI_65_DATA */ + 0x01060002, /* DENALI_PI_66_DATA */ + 0x01010101, /* DENALI_PI_67_DATA */ + 0x01070701, /* DENALI_PI_68_DATA */ + 0x04020201, /* DENALI_PI_69_DATA */ + 0x01080804, /* DENALI_PI_70_DATA */ + 0x00000000, /* DENALI_PI_71_DATA */ + 0x02020000, /* DENALI_PI_72_DATA */ + 0x05050502, /* DENALI_PI_73_DATA */ + 0x00000000, /* DENALI_PI_74_DATA */ + 0x00000000, /* DENALI_PI_75_DATA */ + 0x00000000, /* DENALI_PI_76_DATA */ + 0x00030300, /* DENALI_PI_77_DATA */ + 0x00000014, /* DENALI_PI_78_DATA */ + 0x00000000, /* DENALI_PI_79_DATA */ + 0x01010300, /* DENALI_PI_80_DATA */ + 0x00000000, /* DENALI_PI_81_DATA */ + 0x00000000, /* DENALI_PI_82_DATA */ + 0x01000000, /* DENALI_PI_83_DATA */ + 0x00000101, /* DENALI_PI_84_DATA */ + 0x55555a5a, /* DENALI_PI_85_DATA */ + 0x55555a5a, /* DENALI_PI_86_DATA */ + 0x55555a5a, /* DENALI_PI_87_DATA */ + 0x55555a5a, /* DENALI_PI_88_DATA */ + 0x05050001, /* DENALI_PI_89_DATA */ + 0x02020005, /* DENALI_PI_90_DATA */ + 0x01010002, /* DENALI_PI_91_DATA */ + 0x00000101, /* DENALI_PI_92_DATA */ + 0x00030000, /* DENALI_PI_93_DATA */ + 0x17030000, /* DENALI_PI_94_DATA */ + 0x0008001a, /* DENALI_PI_95_DATA */ + 0x0008001a, /* DENALI_PI_96_DATA */ + 0x0008001a, /* DENALI_PI_97_DATA */ + 0x00000000, /* DENALI_PI_98_DATA */ + 0x00000000, /* DENALI_PI_99_DATA */ + 0x00000100, /* DENALI_PI_100_DATA */ + 0x140a0000, /* DENALI_PI_101_DATA */ + 0x000a010a, /* DENALI_PI_102_DATA */ + 0x01000a01, /* DENALI_PI_103_DATA */ + 0x010a000a, /* DENALI_PI_104_DATA */ + 0x00000100, /* DENALI_PI_105_DATA */ + 0x01000000, /* DENALI_PI_106_DATA */ + 0x00000000, /* DENALI_PI_107_DATA */ + 0x00000100, /* DENALI_PI_108_DATA */ + 0x1e1a0000, /* DENALI_PI_109_DATA */ + 0x10010204, /* DENALI_PI_110_DATA */ + 0x06060605, /* DENALI_PI_111_DATA */ + 0x20000202, /* DENALI_PI_112_DATA */ + 0x00201000, /* DENALI_PI_113_DATA */ + 0x00201000, /* DENALI_PI_114_DATA */ + 0x04041000, /* DENALI_PI_115_DATA */ + 0x0a0a0100, /* DENALI_PI_116_DATA */ + 0x0001010a, /* DENALI_PI_117_DATA */ + 0x004b004a, /* DENALI_PI_118_DATA */ + 0x1a030000, /* DENALI_PI_119_DATA */ + 0x0102041e, /* DENALI_PI_120_DATA */ + 0x34000000, /* DENALI_PI_121_DATA */ + 0x00000000, /* DENALI_PI_122_DATA */ + 0x00000000, /* DENALI_PI_123_DATA */ + 0x00000000, /* DENALI_PI_124_DATA */ + 0x00008300, /* DENALI_PI_125_DATA */ + 0x00010004, /* DENALI_PI_126_DATA */ + 0x004d4d07, /* DENALI_PI_127_DATA */ + 0x00040083, /* DENALI_PI_128_DATA */ + 0x4d070001, /* DENALI_PI_129_DATA */ + 0x0000834d, /* DENALI_PI_130_DATA */ + 0x00010004, /* DENALI_PI_131_DATA */ + 0x004d4d07, /* DENALI_PI_132_DATA */ + 0x00040083, /* DENALI_PI_133_DATA */ + 0x4d070001, /* DENALI_PI_134_DATA */ + 0x0000834d, /* DENALI_PI_135_DATA */ + 0x00010004, /* DENALI_PI_136_DATA */ + 0x004d4d07, /* DENALI_PI_137_DATA */ + 0x00040083, /* DENALI_PI_138_DATA */ + 0x4d070001, /* DENALI_PI_139_DATA */ + 0x0023004d, /* DENALI_PI_140_DATA */ + 0x00010004, /* DENALI_PI_141_DATA */ + 0x004d4d07, /* DENALI_PI_142_DATA */ + 0x00040023, /* DENALI_PI_143_DATA */ + 0x4d070001, /* DENALI_PI_144_DATA */ + 0x0000234d, /* DENALI_PI_145_DATA */ + 0x00010004, /* DENALI_PI_146_DATA */ + 0x004d4d07, /* DENALI_PI_147_DATA */ + 0x00040023, /* DENALI_PI_148_DATA */ + 0x4d070001, /* DENALI_PI_149_DATA */ + 0x0000234d, /* DENALI_PI_150_DATA */ + 0x00010004, /* DENALI_PI_151_DATA */ + 0x004d4d07, /* DENALI_PI_152_DATA */ + 0x00040023, /* DENALI_PI_153_DATA */ + 0x4d070001, /* DENALI_PI_154_DATA */ + 0x0100004d, /* DENALI_PI_155_DATA */ + 0x00320032, /* DENALI_PI_156_DATA */ + 0x04040032, /* DENALI_PI_157_DATA */ + 0x04040405, /* DENALI_PI_158_DATA */ + 0x09003624, /* DENALI_PI_159_DATA */ + 0x0a032002, /* DENALI_PI_160_DATA */ + 0x0405040a, /* DENALI_PI_161_DATA */ + 0x00000404, /* DENALI_PI_162_DATA */ + 0x09003624, /* DENALI_PI_163_DATA */ + 0x0a032002, /* DENALI_PI_164_DATA */ + 0x0405040a, /* DENALI_PI_165_DATA */ + 0x00000404, /* DENALI_PI_166_DATA */ + 0x09003624, /* DENALI_PI_167_DATA */ + 0x0a032002, /* DENALI_PI_168_DATA */ + 0x0200020a, /* DENALI_PI_169_DATA */ + 0x02000200, /* DENALI_PI_170_DATA */ + 0x02000200, /* DENALI_PI_171_DATA */ + 0x02000200, /* DENALI_PI_172_DATA */ + 0x02000200, /* DENALI_PI_173_DATA */ + 0x00000000, /* DENALI_PI_174_DATA */ + 0x00000000, /* DENALI_PI_175_DATA */ + 0x00000000, /* DENALI_PI_176_DATA */ + 0x00000000, /* DENALI_PI_177_DATA */ + 0x00000000, /* DENALI_PI_178_DATA */ + 0x00000000, /* DENALI_PI_179_DATA */ + 0x00000000, /* DENALI_PI_180_DATA */ + 0x00000000, /* DENALI_PI_181_DATA */ + 0x00000000, /* DENALI_PI_182_DATA */ + 0x00000000, /* DENALI_PI_183_DATA */ + 0x00000000, /* DENALI_PI_184_DATA */ + 0x00000000, /* DENALI_PI_185_DATA */ + 0x01000300, /* DENALI_PI_186_DATA */ + 0x00060800, /* DENALI_PI_187_DATA */ + 0x00003c50, /* DENALI_PI_188_DATA */ + 0x00000608, /* DENALI_PI_189_DATA */ + 0x00003c50, /* DENALI_PI_190_DATA */ + 0x00000608, /* DENALI_PI_191_DATA */ + 0x00003c50, /* DENALI_PI_192_DATA */ + 0x08000000, /* DENALI_PI_193_DATA */ + 0x00000100, /* DENALI_PI_194_DATA */ + 0x00000000, /* DENALI_PI_195_DATA */ + 0x00000000, /* DENALI_PI_196_DATA */ + 0x00000000, /* DENALI_PI_197_DATA */ + 0x00000000, /* DENALI_PI_198_DATA */ + 0x00000002 /* DENALI_PI_199_DATA */ + } + }, + { + { + 0x76543210, /* DENALI_PHY_00_DATA */ + 0x0004c008, /* DENALI_PHY_01_DATA */ + 0x00000080, /* DENALI_PHY_02_DATA */ + 0x00000000, /* DENALI_PHY_03_DATA */ + 0x00000000, /* DENALI_PHY_04_DATA */ + 0x00010000, /* DENALI_PHY_05_DATA */ + 0x01665555, /* DENALI_PHY_06_DATA */ + 0x00665555, /* DENALI_PHY_07_DATA */ + 0x00010f00, /* DENALI_PHY_08_DATA */ + 0x04000100, /* DENALI_PHY_09_DATA */ + 0x00000001, /* DENALI_PHY_10_DATA */ + 0x001700c0, /* DENALI_PHY_11_DATA */ + 0x00cc0101, /* DENALI_PHY_12_DATA */ + 0x00030066, /* DENALI_PHY_13_DATA */ + 0x00000000, /* DENALI_PHY_14_DATA */ + 0x00000000, /* DENALI_PHY_15_DATA */ + 0x00000000, /* DENALI_PHY_16_DATA */ + 0x00000000, /* DENALI_PHY_17_DATA */ + 0x00000000, /* DENALI_PHY_18_DATA */ + 0x00000000, /* DENALI_PHY_19_DATA */ + 0x00000000, /* DENALI_PHY_20_DATA */ + 0x00000000, /* DENALI_PHY_21_DATA */ + 0x04080000, /* DENALI_PHY_22_DATA */ + 0x04080400, /* DENALI_PHY_23_DATA */ + 0x08000000, /* DENALI_PHY_24_DATA */ + 0x0c00c007, /* DENALI_PHY_25_DATA */ + 0x00000100, /* DENALI_PHY_26_DATA */ + 0x00000100, /* DENALI_PHY_27_DATA */ + 0x55555555, /* DENALI_PHY_28_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_29_DATA */ + 0x55555555, /* DENALI_PHY_30_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_31_DATA */ + 0x00005555, /* DENALI_PHY_32_DATA */ + 0x00000000, /* DENALI_PHY_33_DATA */ + 0x00000000, /* DENALI_PHY_34_DATA */ + 0x00000000, /* DENALI_PHY_35_DATA */ + 0x00000000, /* DENALI_PHY_36_DATA */ + 0x00000000, /* DENALI_PHY_37_DATA */ + 0x00000000, /* DENALI_PHY_38_DATA */ + 0x00000000, /* DENALI_PHY_39_DATA */ + 0x00000000, /* DENALI_PHY_40_DATA */ + 0x00000000, /* DENALI_PHY_41_DATA */ + 0x00000000, /* DENALI_PHY_42_DATA */ + 0x00000000, /* DENALI_PHY_43_DATA */ + 0x00000000, /* DENALI_PHY_44_DATA */ + 0x00000000, /* DENALI_PHY_45_DATA */ + 0x00000000, /* DENALI_PHY_46_DATA */ + 0x00000000, /* DENALI_PHY_47_DATA */ + 0x00000000, /* DENALI_PHY_48_DATA */ + 0x00000000, /* DENALI_PHY_49_DATA */ + 0x00000000, /* DENALI_PHY_50_DATA */ + 0x00000000, /* DENALI_PHY_51_DATA */ + 0x00200000, /* DENALI_PHY_52_DATA */ + 0x00000000, /* DENALI_PHY_53_DATA */ + 0x00000000, /* DENALI_PHY_54_DATA */ + 0x00000000, /* DENALI_PHY_55_DATA */ + 0x00000000, /* DENALI_PHY_56_DATA */ + 0x00000000, /* DENALI_PHY_57_DATA */ + 0x00000000, /* DENALI_PHY_58_DATA */ + 0x02800280, /* DENALI_PHY_59_DATA */ + 0x02800280, /* DENALI_PHY_60_DATA */ + 0x02800280, /* DENALI_PHY_61_DATA */ + 0x02800280, /* DENALI_PHY_62_DATA */ + 0x00000280, /* DENALI_PHY_63_DATA */ + 0x00000000, /* DENALI_PHY_64_DATA */ + 0x00000000, /* DENALI_PHY_65_DATA */ + 0x00000000, /* DENALI_PHY_66_DATA */ + 0x00000000, /* DENALI_PHY_67_DATA */ + 0x00800000, /* DENALI_PHY_68_DATA */ + 0x00800080, /* DENALI_PHY_69_DATA */ + 0x00800080, /* DENALI_PHY_70_DATA */ + 0x00800080, /* DENALI_PHY_71_DATA */ + 0x00800080, /* DENALI_PHY_72_DATA */ + 0x00800080, /* DENALI_PHY_73_DATA */ + 0x00800080, /* DENALI_PHY_74_DATA */ + 0x00800080, /* DENALI_PHY_75_DATA */ + 0x00800080, /* DENALI_PHY_76_DATA */ + 0x00800080, /* DENALI_PHY_77_DATA */ + 0x01900001, /* DENALI_PHY_78_DATA */ + 0x00000000, /* DENALI_PHY_79_DATA */ + 0x00000000, /* DENALI_PHY_80_DATA */ + 0x00000200, /* DENALI_PHY_81_DATA */ + 0x00000000, /* DENALI_PHY_82_DATA */ + 0x51315152, /* DENALI_PHY_83_DATA */ + 0xc0003150, /* DENALI_PHY_84_DATA */ + 0x010000c0, /* DENALI_PHY_85_DATA */ + 0x00100000, /* DENALI_PHY_86_DATA */ + 0x0c044208, /* DENALI_PHY_87_DATA */ + 0x000f0c18, /* DENALI_PHY_88_DATA */ + 0x01000140, /* DENALI_PHY_89_DATA */ + 0x00000c20, /* DENALI_PHY_90_DATA */ + 0x00000000, /* DENALI_PHY_91_DATA */ + 0x00000000, /* DENALI_PHY_92_DATA */ + 0x00000000, /* DENALI_PHY_93_DATA */ + 0x00000000, /* DENALI_PHY_94_DATA */ + 0x00000000, /* DENALI_PHY_95_DATA */ + 0x00000000, /* DENALI_PHY_96_DATA */ + 0x00000000, /* DENALI_PHY_97_DATA */ + 0x00000000, /* DENALI_PHY_98_DATA */ + 0x00000000, /* DENALI_PHY_99_DATA */ + 0x00000000, /* DENALI_PHY_100_DATA */ + 0x00000000, /* DENALI_PHY_101_DATA */ + 0x00000000, /* DENALI_PHY_102_DATA */ + 0x00000000, /* DENALI_PHY_103_DATA */ + 0x00000000, /* DENALI_PHY_104_DATA */ + 0x00000000, /* DENALI_PHY_105_DATA */ + 0x00000000, /* DENALI_PHY_106_DATA */ + 0x00000000, /* DENALI_PHY_107_DATA */ + 0x00000000, /* DENALI_PHY_108_DATA */ + 0x00000000, /* DENALI_PHY_109_DATA */ + 0x00000000, /* DENALI_PHY_110_DATA */ + 0x00000000, /* DENALI_PHY_111_DATA */ + 0x00000000, /* DENALI_PHY_112_DATA */ + 0x00000000, /* DENALI_PHY_113_DATA */ + 0x00000000, /* DENALI_PHY_114_DATA */ + 0x00000000, /* DENALI_PHY_115_DATA */ + 0x00000000, /* DENALI_PHY_116_DATA */ + 0x00000000, /* DENALI_PHY_117_DATA */ + 0x00000000, /* DENALI_PHY_118_DATA */ + 0x00000000, /* DENALI_PHY_119_DATA */ + 0x00000000, /* DENALI_PHY_120_DATA */ + 0x00000000, /* DENALI_PHY_121_DATA */ + 0x00000000, /* DENALI_PHY_122_DATA */ + 0x00000000, /* DENALI_PHY_123_DATA */ + 0x00000000, /* DENALI_PHY_124_DATA */ + 0x00000000, /* DENALI_PHY_125_DATA */ + 0x00000000, /* DENALI_PHY_126_DATA */ + 0x00000000, /* DENALI_PHY_127_DATA */ + 0x76543210, /* DENALI_PHY_128_DATA */ + 0x0004c008, /* DENALI_PHY_129_DATA */ + 0x00000080, /* DENALI_PHY_130_DATA */ + 0x00000000, /* DENALI_PHY_131_DATA */ + 0x00000000, /* DENALI_PHY_132_DATA */ + 0x00010000, /* DENALI_PHY_133_DATA */ + 0x01665555, /* DENALI_PHY_134_DATA */ + 0x00665555, /* DENALI_PHY_135_DATA */ + 0x00010f00, /* DENALI_PHY_136_DATA */ + 0x04000100, /* DENALI_PHY_137_DATA */ + 0x00000001, /* DENALI_PHY_138_DATA */ + 0x001700c0, /* DENALI_PHY_139_DATA */ + 0x00cc0101, /* DENALI_PHY_140_DATA */ + 0x00030066, /* DENALI_PHY_141_DATA */ + 0x00000000, /* DENALI_PHY_142_DATA */ + 0x00000000, /* DENALI_PHY_143_DATA */ + 0x00000000, /* DENALI_PHY_144_DATA */ + 0x00000000, /* DENALI_PHY_145_DATA */ + 0x00000000, /* DENALI_PHY_146_DATA */ + 0x00000000, /* DENALI_PHY_147_DATA */ + 0x00000000, /* DENALI_PHY_148_DATA */ + 0x00000000, /* DENALI_PHY_149_DATA */ + 0x04080000, /* DENALI_PHY_150_DATA */ + 0x04080400, /* DENALI_PHY_151_DATA */ + 0x08000000, /* DENALI_PHY_152_DATA */ + 0x0c00c007, /* DENALI_PHY_153_DATA */ + 0x00000100, /* DENALI_PHY_154_DATA */ + 0x00000100, /* DENALI_PHY_155_DATA */ + 0x55555555, /* DENALI_PHY_156_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_157_DATA */ + 0x55555555, /* DENALI_PHY_158_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_159_DATA */ + 0x00005555, /* DENALI_PHY_160_DATA */ + 0x00000000, /* DENALI_PHY_161_DATA */ + 0x00000000, /* DENALI_PHY_162_DATA */ + 0x00000000, /* DENALI_PHY_163_DATA */ + 0x00000000, /* DENALI_PHY_164_DATA */ + 0x00000000, /* DENALI_PHY_165_DATA */ + 0x00000000, /* DENALI_PHY_166_DATA */ + 0x00000000, /* DENALI_PHY_167_DATA */ + 0x00000000, /* DENALI_PHY_168_DATA */ + 0x00000000, /* DENALI_PHY_169_DATA */ + 0x00000000, /* DENALI_PHY_170_DATA */ + 0x00000000, /* DENALI_PHY_171_DATA */ + 0x00000000, /* DENALI_PHY_172_DATA */ + 0x00000000, /* DENALI_PHY_173_DATA */ + 0x00000000, /* DENALI_PHY_174_DATA */ + 0x00000000, /* DENALI_PHY_175_DATA */ + 0x00000000, /* DENALI_PHY_176_DATA */ + 0x00000000, /* DENALI_PHY_177_DATA */ + 0x00000000, /* DENALI_PHY_178_DATA */ + 0x00000000, /* DENALI_PHY_179_DATA */ + 0x00200000, /* DENALI_PHY_180_DATA */ + 0x00000000, /* DENALI_PHY_181_DATA */ + 0x00000000, /* DENALI_PHY_182_DATA */ + 0x00000000, /* DENALI_PHY_183_DATA */ + 0x00000000, /* DENALI_PHY_184_DATA */ + 0x00000000, /* DENALI_PHY_185_DATA */ + 0x00000000, /* DENALI_PHY_186_DATA */ + 0x02800280, /* DENALI_PHY_187_DATA */ + 0x02800280, /* DENALI_PHY_188_DATA */ + 0x02800280, /* DENALI_PHY_189_DATA */ + 0x02800280, /* DENALI_PHY_190_DATA */ + 0x00000280, /* DENALI_PHY_191_DATA */ + 0x00000000, /* DENALI_PHY_192_DATA */ + 0x00000000, /* DENALI_PHY_193_DATA */ + 0x00000000, /* DENALI_PHY_194_DATA */ + 0x00000000, /* DENALI_PHY_195_DATA */ + 0x00800000, /* DENALI_PHY_196_DATA */ + 0x00800080, /* DENALI_PHY_197_DATA */ + 0x00800080, /* DENALI_PHY_198_DATA */ + 0x00800080, /* DENALI_PHY_199_DATA */ + 0x00800080, /* DENALI_PHY_200_DATA */ + 0x00800080, /* DENALI_PHY_201_DATA */ + 0x00800080, /* DENALI_PHY_202_DATA */ + 0x00800080, /* DENALI_PHY_203_DATA */ + 0x00800080, /* DENALI_PHY_204_DATA */ + 0x00800080, /* DENALI_PHY_205_DATA */ + 0x01900001, /* DENALI_PHY_206_DATA */ + 0x00000000, /* DENALI_PHY_207_DATA */ + 0x00000000, /* DENALI_PHY_208_DATA */ + 0x00000200, /* DENALI_PHY_209_DATA */ + 0x00000000, /* DENALI_PHY_210_DATA */ + 0x51315152, /* DENALI_PHY_211_DATA */ + 0xc0003150, /* DENALI_PHY_212_DATA */ + 0x010000c0, /* DENALI_PHY_213_DATA */ + 0x00100000, /* DENALI_PHY_214_DATA */ + 0x0c044208, /* DENALI_PHY_215_DATA */ + 0x000f0c18, /* DENALI_PHY_216_DATA */ + 0x01000140, /* DENALI_PHY_217_DATA */ + 0x00000c20, /* DENALI_PHY_218_DATA */ + 0x00000000, /* DENALI_PHY_219_DATA */ + 0x00000000, /* DENALI_PHY_220_DATA */ + 0x00000000, /* DENALI_PHY_221_DATA */ + 0x00000000, /* DENALI_PHY_222_DATA */ + 0x00000000, /* DENALI_PHY_223_DATA */ + 0x00000000, /* DENALI_PHY_224_DATA */ + 0x00000000, /* DENALI_PHY_225_DATA */ + 0x00000000, /* DENALI_PHY_226_DATA */ + 0x00000000, /* DENALI_PHY_227_DATA */ + 0x00000000, /* DENALI_PHY_228_DATA */ + 0x00000000, /* DENALI_PHY_229_DATA */ + 0x00000000, /* DENALI_PHY_230_DATA */ + 0x00000000, /* DENALI_PHY_231_DATA */ + 0x00000000, /* DENALI_PHY_232_DATA */ + 0x00000000, /* DENALI_PHY_233_DATA */ + 0x00000000, /* DENALI_PHY_234_DATA */ + 0x00000000, /* DENALI_PHY_235_DATA */ + 0x00000000, /* DENALI_PHY_236_DATA */ + 0x00000000, /* DENALI_PHY_237_DATA */ + 0x00000000, /* DENALI_PHY_238_DATA */ + 0x00000000, /* DENALI_PHY_239_DATA */ + 0x00000000, /* DENALI_PHY_240_DATA */ + 0x00000000, /* DENALI_PHY_241_DATA */ + 0x00000000, /* DENALI_PHY_242_DATA */ + 0x00000000, /* DENALI_PHY_243_DATA */ + 0x00000000, /* DENALI_PHY_244_DATA */ + 0x00000000, /* DENALI_PHY_245_DATA */ + 0x00000000, /* DENALI_PHY_246_DATA */ + 0x00000000, /* DENALI_PHY_247_DATA */ + 0x00000000, /* DENALI_PHY_248_DATA */ + 0x00000000, /* DENALI_PHY_249_DATA */ + 0x00000000, /* DENALI_PHY_250_DATA */ + 0x00000000, /* DENALI_PHY_251_DATA */ + 0x00000000, /* DENALI_PHY_252_DATA */ + 0x00000000, /* DENALI_PHY_253_DATA */ + 0x00000000, /* DENALI_PHY_254_DATA */ + 0x00000000, /* DENALI_PHY_255_DATA */ + 0x76543210, /* DENALI_PHY_256_DATA */ + 0x0004c008, /* DENALI_PHY_257_DATA */ + 0x00000080, /* DENALI_PHY_258_DATA */ + 0x00000000, /* DENALI_PHY_259_DATA */ + 0x00000000, /* DENALI_PHY_260_DATA */ + 0x00010000, /* DENALI_PHY_261_DATA */ + 0x01665555, /* DENALI_PHY_262_DATA */ + 0x00665555, /* DENALI_PHY_263_DATA */ + 0x00010f00, /* DENALI_PHY_264_DATA */ + 0x04000100, /* DENALI_PHY_265_DATA */ + 0x00000001, /* DENALI_PHY_266_DATA */ + 0x001700c0, /* DENALI_PHY_267_DATA */ + 0x00cc0101, /* DENALI_PHY_268_DATA */ + 0x00030066, /* DENALI_PHY_269_DATA */ + 0x00000000, /* DENALI_PHY_270_DATA */ + 0x00000000, /* DENALI_PHY_271_DATA */ + 0x00000000, /* DENALI_PHY_272_DATA */ + 0x00000000, /* DENALI_PHY_273_DATA */ + 0x00000000, /* DENALI_PHY_274_DATA */ + 0x00000000, /* DENALI_PHY_275_DATA */ + 0x00000000, /* DENALI_PHY_276_DATA */ + 0x00000000, /* DENALI_PHY_277_DATA */ + 0x04080000, /* DENALI_PHY_278_DATA */ + 0x04080400, /* DENALI_PHY_279_DATA */ + 0x08000000, /* DENALI_PHY_280_DATA */ + 0x0c00c007, /* DENALI_PHY_281_DATA */ + 0x00000100, /* DENALI_PHY_282_DATA */ + 0x00000100, /* DENALI_PHY_283_DATA */ + 0x55555555, /* DENALI_PHY_284_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_285_DATA */ + 0x55555555, /* DENALI_PHY_286_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_287_DATA */ + 0x00005555, /* DENALI_PHY_288_DATA */ + 0x00000000, /* DENALI_PHY_289_DATA */ + 0x00000000, /* DENALI_PHY_290_DATA */ + 0x00000000, /* DENALI_PHY_291_DATA */ + 0x00000000, /* DENALI_PHY_292_DATA */ + 0x00000000, /* DENALI_PHY_293_DATA */ + 0x00000000, /* DENALI_PHY_294_DATA */ + 0x00000000, /* DENALI_PHY_295_DATA */ + 0x00000000, /* DENALI_PHY_296_DATA */ + 0x00000000, /* DENALI_PHY_297_DATA */ + 0x00000000, /* DENALI_PHY_298_DATA */ + 0x00000000, /* DENALI_PHY_299_DATA */ + 0x00000000, /* DENALI_PHY_300_DATA */ + 0x00000000, /* DENALI_PHY_301_DATA */ + 0x00000000, /* DENALI_PHY_302_DATA */ + 0x00000000, /* DENALI_PHY_303_DATA */ + 0x00000000, /* DENALI_PHY_304_DATA */ + 0x00000000, /* DENALI_PHY_305_DATA */ + 0x00000000, /* DENALI_PHY_306_DATA */ + 0x00000000, /* DENALI_PHY_307_DATA */ + 0x00200000, /* DENALI_PHY_308_DATA */ + 0x00000000, /* DENALI_PHY_309_DATA */ + 0x00000000, /* DENALI_PHY_310_DATA */ + 0x00000000, /* DENALI_PHY_311_DATA */ + 0x00000000, /* DENALI_PHY_312_DATA */ + 0x00000000, /* DENALI_PHY_313_DATA */ + 0x00000000, /* DENALI_PHY_314_DATA */ + 0x02800280, /* DENALI_PHY_315_DATA */ + 0x02800280, /* DENALI_PHY_316_DATA */ + 0x02800280, /* DENALI_PHY_317_DATA */ + 0x02800280, /* DENALI_PHY_318_DATA */ + 0x00000280, /* DENALI_PHY_319_DATA */ + 0x00000000, /* DENALI_PHY_320_DATA */ + 0x00000000, /* DENALI_PHY_321_DATA */ + 0x00000000, /* DENALI_PHY_322_DATA */ + 0x00000000, /* DENALI_PHY_323_DATA */ + 0x00800000, /* DENALI_PHY_324_DATA */ + 0x00800080, /* DENALI_PHY_325_DATA */ + 0x00800080, /* DENALI_PHY_326_DATA */ + 0x00800080, /* DENALI_PHY_327_DATA */ + 0x00800080, /* DENALI_PHY_328_DATA */ + 0x00800080, /* DENALI_PHY_329_DATA */ + 0x00800080, /* DENALI_PHY_330_DATA */ + 0x00800080, /* DENALI_PHY_331_DATA */ + 0x00800080, /* DENALI_PHY_332_DATA */ + 0x00800080, /* DENALI_PHY_333_DATA */ + 0x01900001, /* DENALI_PHY_334_DATA */ + 0x00000000, /* DENALI_PHY_335_DATA */ + 0x00000000, /* DENALI_PHY_336_DATA */ + 0x00000200, /* DENALI_PHY_337_DATA */ + 0x00000000, /* DENALI_PHY_338_DATA */ + 0x51315152, /* DENALI_PHY_339_DATA */ + 0xc0003150, /* DENALI_PHY_340_DATA */ + 0x010000c0, /* DENALI_PHY_341_DATA */ + 0x00100000, /* DENALI_PHY_342_DATA */ + 0x0c044208, /* DENALI_PHY_343_DATA */ + 0x000f0c18, /* DENALI_PHY_344_DATA */ + 0x01000140, /* DENALI_PHY_345_DATA */ + 0x00000c20, /* DENALI_PHY_346_DATA */ + 0x00000000, /* DENALI_PHY_347_DATA */ + 0x00000000, /* DENALI_PHY_348_DATA */ + 0x00000000, /* DENALI_PHY_349_DATA */ + 0x00000000, /* DENALI_PHY_350_DATA */ + 0x00000000, /* DENALI_PHY_351_DATA */ + 0x00000000, /* DENALI_PHY_352_DATA */ + 0x00000000, /* DENALI_PHY_353_DATA */ + 0x00000000, /* DENALI_PHY_354_DATA */ + 0x00000000, /* DENALI_PHY_355_DATA */ + 0x00000000, /* DENALI_PHY_356_DATA */ + 0x00000000, /* DENALI_PHY_357_DATA */ + 0x00000000, /* DENALI_PHY_358_DATA */ + 0x00000000, /* DENALI_PHY_359_DATA */ + 0x00000000, /* DENALI_PHY_360_DATA */ + 0x00000000, /* DENALI_PHY_361_DATA */ + 0x00000000, /* DENALI_PHY_362_DATA */ + 0x00000000, /* DENALI_PHY_363_DATA */ + 0x00000000, /* DENALI_PHY_364_DATA */ + 0x00000000, /* DENALI_PHY_365_DATA */ + 0x00000000, /* DENALI_PHY_366_DATA */ + 0x00000000, /* DENALI_PHY_367_DATA */ + 0x00000000, /* DENALI_PHY_368_DATA */ + 0x00000000, /* DENALI_PHY_369_DATA */ + 0x00000000, /* DENALI_PHY_370_DATA */ + 0x00000000, /* DENALI_PHY_371_DATA */ + 0x00000000, /* DENALI_PHY_372_DATA */ + 0x00000000, /* DENALI_PHY_373_DATA */ + 0x00000000, /* DENALI_PHY_374_DATA */ + 0x00000000, /* DENALI_PHY_375_DATA */ + 0x00000000, /* DENALI_PHY_376_DATA */ + 0x00000000, /* DENALI_PHY_377_DATA */ + 0x00000000, /* DENALI_PHY_378_DATA */ + 0x00000000, /* DENALI_PHY_379_DATA */ + 0x00000000, /* DENALI_PHY_380_DATA */ + 0x00000000, /* DENALI_PHY_381_DATA */ + 0x00000000, /* DENALI_PHY_382_DATA */ + 0x00000000, /* DENALI_PHY_383_DATA */ + 0x76543210, /* DENALI_PHY_384_DATA */ + 0x0004c008, /* DENALI_PHY_385_DATA */ + 0x00000080, /* DENALI_PHY_386_DATA */ + 0x00000000, /* DENALI_PHY_387_DATA */ + 0x00000000, /* DENALI_PHY_388_DATA */ + 0x00010000, /* DENALI_PHY_389_DATA */ + 0x01665555, /* DENALI_PHY_390_DATA */ + 0x00665555, /* DENALI_PHY_391_DATA */ + 0x00010f00, /* DENALI_PHY_392_DATA */ + 0x04000100, /* DENALI_PHY_393_DATA */ + 0x00000001, /* DENALI_PHY_394_DATA */ + 0x001700c0, /* DENALI_PHY_395_DATA */ + 0x00cc0101, /* DENALI_PHY_396_DATA */ + 0x00030066, /* DENALI_PHY_397_DATA */ + 0x00000000, /* DENALI_PHY_398_DATA */ + 0x00000000, /* DENALI_PHY_399_DATA */ + 0x00000000, /* DENALI_PHY_400_DATA */ + 0x00000000, /* DENALI_PHY_401_DATA */ + 0x00000000, /* DENALI_PHY_402_DATA */ + 0x00000000, /* DENALI_PHY_403_DATA */ + 0x00000000, /* DENALI_PHY_404_DATA */ + 0x00000000, /* DENALI_PHY_405_DATA */ + 0x04080000, /* DENALI_PHY_406_DATA */ + 0x04080400, /* DENALI_PHY_407_DATA */ + 0x08000000, /* DENALI_PHY_408_DATA */ + 0x0c00c007, /* DENALI_PHY_409_DATA */ + 0x00000100, /* DENALI_PHY_410_DATA */ + 0x00000100, /* DENALI_PHY_411_DATA */ + 0x55555555, /* DENALI_PHY_412_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_413_DATA */ + 0x55555555, /* DENALI_PHY_414_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_415_DATA */ + 0x00005555, /* DENALI_PHY_416_DATA */ + 0x00000000, /* DENALI_PHY_417_DATA */ + 0x00000000, /* DENALI_PHY_418_DATA */ + 0x00000000, /* DENALI_PHY_419_DATA */ + 0x00000000, /* DENALI_PHY_420_DATA */ + 0x00000000, /* DENALI_PHY_421_DATA */ + 0x00000000, /* DENALI_PHY_422_DATA */ + 0x00000000, /* DENALI_PHY_423_DATA */ + 0x00000000, /* DENALI_PHY_424_DATA */ + 0x00000000, /* DENALI_PHY_425_DATA */ + 0x00000000, /* DENALI_PHY_426_DATA */ + 0x00000000, /* DENALI_PHY_427_DATA */ + 0x00000000, /* DENALI_PHY_428_DATA */ + 0x00000000, /* DENALI_PHY_429_DATA */ + 0x00000000, /* DENALI_PHY_430_DATA */ + 0x00000000, /* DENALI_PHY_431_DATA */ + 0x00000000, /* DENALI_PHY_432_DATA */ + 0x00000000, /* DENALI_PHY_433_DATA */ + 0x00000000, /* DENALI_PHY_434_DATA */ + 0x00000000, /* DENALI_PHY_435_DATA */ + 0x00200000, /* DENALI_PHY_436_DATA */ + 0x00000000, /* DENALI_PHY_437_DATA */ + 0x00000000, /* DENALI_PHY_438_DATA */ + 0x00000000, /* DENALI_PHY_439_DATA */ + 0x00000000, /* DENALI_PHY_440_DATA */ + 0x00000000, /* DENALI_PHY_441_DATA */ + 0x00000000, /* DENALI_PHY_442_DATA */ + 0x02800280, /* DENALI_PHY_443_DATA */ + 0x02800280, /* DENALI_PHY_444_DATA */ + 0x02800280, /* DENALI_PHY_445_DATA */ + 0x02800280, /* DENALI_PHY_446_DATA */ + 0x00000280, /* DENALI_PHY_447_DATA */ + 0x00000000, /* DENALI_PHY_448_DATA */ + 0x00000000, /* DENALI_PHY_449_DATA */ + 0x00000000, /* DENALI_PHY_450_DATA */ + 0x00000000, /* DENALI_PHY_451_DATA */ + 0x00800000, /* DENALI_PHY_452_DATA */ + 0x00800080, /* DENALI_PHY_453_DATA */ + 0x00800080, /* DENALI_PHY_454_DATA */ + 0x00800080, /* DENALI_PHY_455_DATA */ + 0x00800080, /* DENALI_PHY_456_DATA */ + 0x00800080, /* DENALI_PHY_457_DATA */ + 0x00800080, /* DENALI_PHY_458_DATA */ + 0x00800080, /* DENALI_PHY_459_DATA */ + 0x00800080, /* DENALI_PHY_460_DATA */ + 0x00800080, /* DENALI_PHY_461_DATA */ + 0x01900001, /* DENALI_PHY_462_DATA */ + 0x00000000, /* DENALI_PHY_463_DATA */ + 0x00000000, /* DENALI_PHY_464_DATA */ + 0x00000200, /* DENALI_PHY_465_DATA */ + 0x00000000, /* DENALI_PHY_466_DATA */ + 0x51315152, /* DENALI_PHY_467_DATA */ + 0xc0003150, /* DENALI_PHY_468_DATA */ + 0x010000c0, /* DENALI_PHY_469_DATA */ + 0x00100000, /* DENALI_PHY_470_DATA */ + 0x0c044208, /* DENALI_PHY_471_DATA */ + 0x000f0c18, /* DENALI_PHY_472_DATA */ + 0x01000140, /* DENALI_PHY_473_DATA */ + 0x00000c20, /* DENALI_PHY_474_DATA */ + 0x00000000, /* DENALI_PHY_475_DATA */ + 0x00000000, /* DENALI_PHY_476_DATA */ + 0x00000000, /* DENALI_PHY_477_DATA */ + 0x00000000, /* DENALI_PHY_478_DATA */ + 0x00000000, /* DENALI_PHY_479_DATA */ + 0x00000000, /* DENALI_PHY_480_DATA */ + 0x00000000, /* DENALI_PHY_481_DATA */ + 0x00000000, /* DENALI_PHY_482_DATA */ + 0x00000000, /* DENALI_PHY_483_DATA */ + 0x00000000, /* DENALI_PHY_484_DATA */ + 0x00000000, /* DENALI_PHY_485_DATA */ + 0x00000000, /* DENALI_PHY_486_DATA */ + 0x00000000, /* DENALI_PHY_487_DATA */ + 0x00000000, /* DENALI_PHY_488_DATA */ + 0x00000000, /* DENALI_PHY_489_DATA */ + 0x00000000, /* DENALI_PHY_490_DATA */ + 0x00000000, /* DENALI_PHY_491_DATA */ + 0x00000000, /* DENALI_PHY_492_DATA */ + 0x00000000, /* DENALI_PHY_493_DATA */ + 0x00000000, /* DENALI_PHY_494_DATA */ + 0x00000000, /* DENALI_PHY_495_DATA */ + 0x00000000, /* DENALI_PHY_496_DATA */ + 0x00000000, /* DENALI_PHY_497_DATA */ + 0x00000000, /* DENALI_PHY_498_DATA */ + 0x00000000, /* DENALI_PHY_499_DATA */ + 0x00000000, /* DENALI_PHY_500_DATA */ + 0x00000000, /* DENALI_PHY_501_DATA */ + 0x00000000, /* DENALI_PHY_502_DATA */ + 0x00000000, /* DENALI_PHY_503_DATA */ + 0x00000000, /* DENALI_PHY_504_DATA */ + 0x00000000, /* DENALI_PHY_505_DATA */ + 0x00000000, /* DENALI_PHY_506_DATA */ + 0x00000000, /* DENALI_PHY_507_DATA */ + 0x00000000, /* DENALI_PHY_508_DATA */ + 0x00000000, /* DENALI_PHY_509_DATA */ + 0x00000000, /* DENALI_PHY_510_DATA */ + 0x00000000, /* DENALI_PHY_511_DATA */ + 0x00000000, /* DENALI_PHY_512_DATA */ + 0x00800000, /* DENALI_PHY_513_DATA */ + 0x00000000, /* DENALI_PHY_514_DATA */ + 0x00000000, /* DENALI_PHY_515_DATA */ + 0x00000000, /* DENALI_PHY_516_DATA */ + 0x00000000, /* DENALI_PHY_517_DATA */ + 0x00000000, /* DENALI_PHY_518_DATA */ + 0x00000001, /* DENALI_PHY_519_DATA */ + 0x00000000, /* DENALI_PHY_520_DATA */ + 0x00000000, /* DENALI_PHY_521_DATA */ + 0x00000000, /* DENALI_PHY_522_DATA */ + 0x00400320, /* DENALI_PHY_523_DATA */ + 0x00000040, /* DENALI_PHY_524_DATA */ + 0x00806420, /* DENALI_PHY_525_DATA */ + 0x00917531, /* DENALI_PHY_526_DATA */ + 0x00806420, /* DENALI_PHY_527_DATA */ + 0x01917531, /* DENALI_PHY_528_DATA */ + 0x00020003, /* DENALI_PHY_529_DATA */ + 0x00000000, /* DENALI_PHY_530_DATA */ + 0x00000000, /* DENALI_PHY_531_DATA */ + 0x00000000, /* DENALI_PHY_532_DATA */ + 0x000556aa, /* DENALI_PHY_533_DATA */ + 0x000aaaaa, /* DENALI_PHY_534_DATA */ + 0x000aa955, /* DENALI_PHY_535_DATA */ + 0x00055555, /* DENALI_PHY_536_DATA */ + 0x000b3133, /* DENALI_PHY_537_DATA */ + 0x0004cd33, /* DENALI_PHY_538_DATA */ + 0x0004cecc, /* DENALI_PHY_539_DATA */ + 0x000b32cc, /* DENALI_PHY_540_DATA */ + 0x0a418820, /* DENALI_PHY_541_DATA */ + 0x103f0000, /* DENALI_PHY_542_DATA */ + 0x0000003f, /* DENALI_PHY_543_DATA */ + 0x00038055, /* DENALI_PHY_544_DATA */ + 0x03800380, /* DENALI_PHY_545_DATA */ + 0x03800380, /* DENALI_PHY_546_DATA */ + 0x00000380, /* DENALI_PHY_547_DATA */ + 0x42080010, /* DENALI_PHY_548_DATA */ + 0x00000003, /* DENALI_PHY_549_DATA */ + 0x00000000, /* DENALI_PHY_550_DATA */ + 0x00000000, /* DENALI_PHY_551_DATA */ + 0x00000000, /* DENALI_PHY_552_DATA */ + 0x00000000, /* DENALI_PHY_553_DATA */ + 0x00000000, /* DENALI_PHY_554_DATA */ + 0x00000000, /* DENALI_PHY_555_DATA */ + 0x00000000, /* DENALI_PHY_556_DATA */ + 0x00000000, /* DENALI_PHY_557_DATA */ + 0x00000000, /* DENALI_PHY_558_DATA */ + 0x00000000, /* DENALI_PHY_559_DATA */ + 0x00000000, /* DENALI_PHY_560_DATA */ + 0x00000000, /* DENALI_PHY_561_DATA */ + 0x00000000, /* DENALI_PHY_562_DATA */ + 0x00000000, /* DENALI_PHY_563_DATA */ + 0x00000000, /* DENALI_PHY_564_DATA */ + 0x00000000, /* DENALI_PHY_565_DATA */ + 0x00000000, /* DENALI_PHY_566_DATA */ + 0x00000000, /* DENALI_PHY_567_DATA */ + 0x00000000, /* DENALI_PHY_568_DATA */ + 0x00000000, /* DENALI_PHY_569_DATA */ + 0x00000000, /* DENALI_PHY_570_DATA */ + 0x00000000, /* DENALI_PHY_571_DATA */ + 0x00000000, /* DENALI_PHY_572_DATA */ + 0x00000000, /* DENALI_PHY_573_DATA */ + 0x00000000, /* DENALI_PHY_574_DATA */ + 0x00000000, /* DENALI_PHY_575_DATA */ + 0x00000000, /* DENALI_PHY_576_DATA */ + 0x00000000, /* DENALI_PHY_577_DATA */ + 0x00000000, /* DENALI_PHY_578_DATA */ + 0x00000000, /* DENALI_PHY_579_DATA */ + 0x00000000, /* DENALI_PHY_580_DATA */ + 0x00000000, /* DENALI_PHY_581_DATA */ + 0x00000000, /* DENALI_PHY_582_DATA */ + 0x00000000, /* DENALI_PHY_583_DATA */ + 0x00000000, /* DENALI_PHY_584_DATA */ + 0x00000000, /* DENALI_PHY_585_DATA */ + 0x00000000, /* DENALI_PHY_586_DATA */ + 0x00000000, /* DENALI_PHY_587_DATA */ + 0x00000000, /* DENALI_PHY_588_DATA */ + 0x00000000, /* DENALI_PHY_589_DATA */ + 0x00000000, /* DENALI_PHY_590_DATA */ + 0x00000000, /* DENALI_PHY_591_DATA */ + 0x00000000, /* DENALI_PHY_592_DATA */ + 0x00000000, /* DENALI_PHY_593_DATA */ + 0x00000000, /* DENALI_PHY_594_DATA */ + 0x00000000, /* DENALI_PHY_595_DATA */ + 0x00000000, /* DENALI_PHY_596_DATA */ + 0x00000000, /* DENALI_PHY_597_DATA */ + 0x00000000, /* DENALI_PHY_598_DATA */ + 0x00000000, /* DENALI_PHY_599_DATA */ + 0x00000000, /* DENALI_PHY_600_DATA */ + 0x00000000, /* DENALI_PHY_601_DATA */ + 0x00000000, /* DENALI_PHY_602_DATA */ + 0x00000000, /* DENALI_PHY_603_DATA */ + 0x00000000, /* DENALI_PHY_604_DATA */ + 0x00000000, /* DENALI_PHY_605_DATA */ + 0x00000000, /* DENALI_PHY_606_DATA */ + 0x00000000, /* DENALI_PHY_607_DATA */ + 0x00000000, /* DENALI_PHY_608_DATA */ + 0x00000000, /* DENALI_PHY_609_DATA */ + 0x00000000, /* DENALI_PHY_610_DATA */ + 0x00000000, /* DENALI_PHY_611_DATA */ + 0x00000000, /* DENALI_PHY_612_DATA */ + 0x00000000, /* DENALI_PHY_613_DATA */ + 0x00000000, /* DENALI_PHY_614_DATA */ + 0x00000000, /* DENALI_PHY_615_DATA */ + 0x00000000, /* DENALI_PHY_616_DATA */ + 0x00000000, /* DENALI_PHY_617_DATA */ + 0x00000000, /* DENALI_PHY_618_DATA */ + 0x00000000, /* DENALI_PHY_619_DATA */ + 0x00000000, /* DENALI_PHY_620_DATA */ + 0x00000000, /* DENALI_PHY_621_DATA */ + 0x00000000, /* DENALI_PHY_622_DATA */ + 0x00000000, /* DENALI_PHY_623_DATA */ + 0x00000000, /* DENALI_PHY_624_DATA */ + 0x00000000, /* DENALI_PHY_625_DATA */ + 0x00000000, /* DENALI_PHY_626_DATA */ + 0x00000000, /* DENALI_PHY_627_DATA */ + 0x00000000, /* DENALI_PHY_628_DATA */ + 0x00000000, /* DENALI_PHY_629_DATA */ + 0x00000000, /* DENALI_PHY_630_DATA */ + 0x00000000, /* DENALI_PHY_631_DATA */ + 0x00000000, /* DENALI_PHY_632_DATA */ + 0x00000000, /* DENALI_PHY_633_DATA */ + 0x00000000, /* DENALI_PHY_634_DATA */ + 0x00000000, /* DENALI_PHY_635_DATA */ + 0x00000000, /* DENALI_PHY_636_DATA */ + 0x00000000, /* DENALI_PHY_637_DATA */ + 0x00000000, /* DENALI_PHY_638_DATA */ + 0x00000000, /* DENALI_PHY_639_DATA */ + 0x00000000, /* DENALI_PHY_640_DATA */ + 0x00800000, /* DENALI_PHY_641_DATA */ + 0x00000000, /* DENALI_PHY_642_DATA */ + 0x00000000, /* DENALI_PHY_643_DATA */ + 0x00000000, /* DENALI_PHY_644_DATA */ + 0x00000000, /* DENALI_PHY_645_DATA */ + 0x00000000, /* DENALI_PHY_646_DATA */ + 0x00000001, /* DENALI_PHY_647_DATA */ + 0x00000000, /* DENALI_PHY_648_DATA */ + 0x00000000, /* DENALI_PHY_649_DATA */ + 0x00000000, /* DENALI_PHY_650_DATA */ + 0x00400320, /* DENALI_PHY_651_DATA */ + 0x00000040, /* DENALI_PHY_652_DATA */ + 0x00008eca, /* DENALI_PHY_653_DATA */ + 0x00009fdb, /* DENALI_PHY_654_DATA */ + 0x00008eca, /* DENALI_PHY_655_DATA */ + 0x01009fdb, /* DENALI_PHY_656_DATA */ + 0x00020003, /* DENALI_PHY_657_DATA */ + 0x00000000, /* DENALI_PHY_658_DATA */ + 0x00000000, /* DENALI_PHY_659_DATA */ + 0x00000000, /* DENALI_PHY_660_DATA */ + 0x000556aa, /* DENALI_PHY_661_DATA */ + 0x000aaaaa, /* DENALI_PHY_662_DATA */ + 0x000aa955, /* DENALI_PHY_663_DATA */ + 0x00055555, /* DENALI_PHY_664_DATA */ + 0x000b3133, /* DENALI_PHY_665_DATA */ + 0x0004cd33, /* DENALI_PHY_666_DATA */ + 0x0004cecc, /* DENALI_PHY_667_DATA */ + 0x000b32cc, /* DENALI_PHY_668_DATA */ + 0x0004a0e6, /* DENALI_PHY_669_DATA */ + 0x080f0000, /* DENALI_PHY_670_DATA */ + 0x0000000f, /* DENALI_PHY_671_DATA */ + 0x00038055, /* DENALI_PHY_672_DATA */ + 0x03800380, /* DENALI_PHY_673_DATA */ + 0x03800380, /* DENALI_PHY_674_DATA */ + 0x00000380, /* DENALI_PHY_675_DATA */ + 0x42080010, /* DENALI_PHY_676_DATA */ + 0x00000003, /* DENALI_PHY_677_DATA */ + 0x00000000, /* DENALI_PHY_678_DATA */ + 0x00000000, /* DENALI_PHY_679_DATA */ + 0x00000000, /* DENALI_PHY_680_DATA */ + 0x00000000, /* DENALI_PHY_681_DATA */ + 0x00000000, /* DENALI_PHY_682_DATA */ + 0x00000000, /* DENALI_PHY_683_DATA */ + 0x00000000, /* DENALI_PHY_684_DATA */ + 0x00000000, /* DENALI_PHY_685_DATA */ + 0x00000000, /* DENALI_PHY_686_DATA */ + 0x00000000, /* DENALI_PHY_687_DATA */ + 0x00000000, /* DENALI_PHY_688_DATA */ + 0x00000000, /* DENALI_PHY_689_DATA */ + 0x00000000, /* DENALI_PHY_690_DATA */ + 0x00000000, /* DENALI_PHY_691_DATA */ + 0x00000000, /* DENALI_PHY_692_DATA */ + 0x00000000, /* DENALI_PHY_693_DATA */ + 0x00000000, /* DENALI_PHY_694_DATA */ + 0x00000000, /* DENALI_PHY_695_DATA */ + 0x00000000, /* DENALI_PHY_696_DATA */ + 0x00000000, /* DENALI_PHY_697_DATA */ + 0x00000000, /* DENALI_PHY_698_DATA */ + 0x00000000, /* DENALI_PHY_699_DATA */ + 0x00000000, /* DENALI_PHY_700_DATA */ + 0x00000000, /* DENALI_PHY_701_DATA */ + 0x00000000, /* DENALI_PHY_702_DATA */ + 0x00000000, /* DENALI_PHY_703_DATA */ + 0x00000000, /* DENALI_PHY_704_DATA */ + 0x00000000, /* DENALI_PHY_705_DATA */ + 0x00000000, /* DENALI_PHY_706_DATA */ + 0x00000000, /* DENALI_PHY_707_DATA */ + 0x00000000, /* DENALI_PHY_708_DATA */ + 0x00000000, /* DENALI_PHY_709_DATA */ + 0x00000000, /* DENALI_PHY_710_DATA */ + 0x00000000, /* DENALI_PHY_711_DATA */ + 0x00000000, /* DENALI_PHY_712_DATA */ + 0x00000000, /* DENALI_PHY_713_DATA */ + 0x00000000, /* DENALI_PHY_714_DATA */ + 0x00000000, /* DENALI_PHY_715_DATA */ + 0x00000000, /* DENALI_PHY_716_DATA */ + 0x00000000, /* DENALI_PHY_717_DATA */ + 0x00000000, /* DENALI_PHY_718_DATA */ + 0x00000000, /* DENALI_PHY_719_DATA */ + 0x00000000, /* DENALI_PHY_720_DATA */ + 0x00000000, /* DENALI_PHY_721_DATA */ + 0x00000000, /* DENALI_PHY_722_DATA */ + 0x00000000, /* DENALI_PHY_723_DATA */ + 0x00000000, /* DENALI_PHY_724_DATA */ + 0x00000000, /* DENALI_PHY_725_DATA */ + 0x00000000, /* DENALI_PHY_726_DATA */ + 0x00000000, /* DENALI_PHY_727_DATA */ + 0x00000000, /* DENALI_PHY_728_DATA */ + 0x00000000, /* DENALI_PHY_729_DATA */ + 0x00000000, /* DENALI_PHY_730_DATA */ + 0x00000000, /* DENALI_PHY_731_DATA */ + 0x00000000, /* DENALI_PHY_732_DATA */ + 0x00000000, /* DENALI_PHY_733_DATA */ + 0x00000000, /* DENALI_PHY_734_DATA */ + 0x00000000, /* DENALI_PHY_735_DATA */ + 0x00000000, /* DENALI_PHY_736_DATA */ + 0x00000000, /* DENALI_PHY_737_DATA */ + 0x00000000, /* DENALI_PHY_738_DATA */ + 0x00000000, /* DENALI_PHY_739_DATA */ + 0x00000000, /* DENALI_PHY_740_DATA */ + 0x00000000, /* DENALI_PHY_741_DATA */ + 0x00000000, /* DENALI_PHY_742_DATA */ + 0x00000000, /* DENALI_PHY_743_DATA */ + 0x00000000, /* DENALI_PHY_744_DATA */ + 0x00000000, /* DENALI_PHY_745_DATA */ + 0x00000000, /* DENALI_PHY_746_DATA */ + 0x00000000, /* DENALI_PHY_747_DATA */ + 0x00000000, /* DENALI_PHY_748_DATA */ + 0x00000000, /* DENALI_PHY_749_DATA */ + 0x00000000, /* DENALI_PHY_750_DATA */ + 0x00000000, /* DENALI_PHY_751_DATA */ + 0x00000000, /* DENALI_PHY_752_DATA */ + 0x00000000, /* DENALI_PHY_753_DATA */ + 0x00000000, /* DENALI_PHY_754_DATA */ + 0x00000000, /* DENALI_PHY_755_DATA */ + 0x00000000, /* DENALI_PHY_756_DATA */ + 0x00000000, /* DENALI_PHY_757_DATA */ + 0x00000000, /* DENALI_PHY_758_DATA */ + 0x00000000, /* DENALI_PHY_759_DATA */ + 0x00000000, /* DENALI_PHY_760_DATA */ + 0x00000000, /* DENALI_PHY_761_DATA */ + 0x00000000, /* DENALI_PHY_762_DATA */ + 0x00000000, /* DENALI_PHY_763_DATA */ + 0x00000000, /* DENALI_PHY_764_DATA */ + 0x00000000, /* DENALI_PHY_765_DATA */ + 0x00000000, /* DENALI_PHY_766_DATA */ + 0x00000000, /* DENALI_PHY_767_DATA */ + 0x00000000, /* DENALI_PHY_768_DATA */ + 0x00800000, /* DENALI_PHY_769_DATA */ + 0x00000000, /* DENALI_PHY_770_DATA */ + 0x00000000, /* DENALI_PHY_771_DATA */ + 0x00000000, /* DENALI_PHY_772_DATA */ + 0x00000000, /* DENALI_PHY_773_DATA */ + 0x00000000, /* DENALI_PHY_774_DATA */ + 0x00000001, /* DENALI_PHY_775_DATA */ + 0x00000000, /* DENALI_PHY_776_DATA */ + 0x00000000, /* DENALI_PHY_777_DATA */ + 0x00000000, /* DENALI_PHY_778_DATA */ + 0x00400320, /* DENALI_PHY_779_DATA */ + 0x00000040, /* DENALI_PHY_780_DATA */ + 0x00008eca, /* DENALI_PHY_781_DATA */ + 0x00009fdb, /* DENALI_PHY_782_DATA */ + 0x00008eca, /* DENALI_PHY_783_DATA */ + 0x01009fdb, /* DENALI_PHY_784_DATA */ + 0x00020003, /* DENALI_PHY_785_DATA */ + 0x00000000, /* DENALI_PHY_786_DATA */ + 0x00000000, /* DENALI_PHY_787_DATA */ + 0x00000000, /* DENALI_PHY_788_DATA */ + 0x000556aa, /* DENALI_PHY_789_DATA */ + 0x000aaaaa, /* DENALI_PHY_790_DATA */ + 0x000aa955, /* DENALI_PHY_791_DATA */ + 0x00055555, /* DENALI_PHY_792_DATA */ + 0x000b3133, /* DENALI_PHY_793_DATA */ + 0x0004cd33, /* DENALI_PHY_794_DATA */ + 0x0004cecc, /* DENALI_PHY_795_DATA */ + 0x000b32cc, /* DENALI_PHY_796_DATA */ + 0x1ee6b16a, /* DENALI_PHY_797_DATA */ + 0x10000000, /* DENALI_PHY_798_DATA */ + 0x00000000, /* DENALI_PHY_799_DATA */ + 0x00038055, /* DENALI_PHY_800_DATA */ + 0x03800380, /* DENALI_PHY_801_DATA */ + 0x03800380, /* DENALI_PHY_802_DATA */ + 0x00000380, /* DENALI_PHY_803_DATA */ + 0x42080010, /* DENALI_PHY_804_DATA */ + 0x00000003, /* DENALI_PHY_805_DATA */ + 0x00000000, /* DENALI_PHY_806_DATA */ + 0x00000000, /* DENALI_PHY_807_DATA */ + 0x00000000, /* DENALI_PHY_808_DATA */ + 0x00000000, /* DENALI_PHY_809_DATA */ + 0x00000000, /* DENALI_PHY_810_DATA */ + 0x00000000, /* DENALI_PHY_811_DATA */ + 0x00000000, /* DENALI_PHY_812_DATA */ + 0x00000000, /* DENALI_PHY_813_DATA */ + 0x00000000, /* DENALI_PHY_814_DATA */ + 0x00000000, /* DENALI_PHY_815_DATA */ + 0x00000000, /* DENALI_PHY_816_DATA */ + 0x00000000, /* DENALI_PHY_817_DATA */ + 0x00000000, /* DENALI_PHY_818_DATA */ + 0x00000000, /* DENALI_PHY_819_DATA */ + 0x00000000, /* DENALI_PHY_820_DATA */ + 0x00000000, /* DENALI_PHY_821_DATA */ + 0x00000000, /* DENALI_PHY_822_DATA */ + 0x00000000, /* DENALI_PHY_823_DATA */ + 0x00000000, /* DENALI_PHY_824_DATA */ + 0x00000000, /* DENALI_PHY_825_DATA */ + 0x00000000, /* DENALI_PHY_826_DATA */ + 0x00000000, /* DENALI_PHY_827_DATA */ + 0x00000000, /* DENALI_PHY_828_DATA */ + 0x00000000, /* DENALI_PHY_829_DATA */ + 0x00000000, /* DENALI_PHY_830_DATA */ + 0x00000000, /* DENALI_PHY_831_DATA */ + 0x00000000, /* DENALI_PHY_832_DATA */ + 0x00000000, /* DENALI_PHY_833_DATA */ + 0x00000000, /* DENALI_PHY_834_DATA */ + 0x00000000, /* DENALI_PHY_835_DATA */ + 0x00000000, /* DENALI_PHY_836_DATA */ + 0x00000000, /* DENALI_PHY_837_DATA */ + 0x00000000, /* DENALI_PHY_838_DATA */ + 0x00000000, /* DENALI_PHY_839_DATA */ + 0x00000000, /* DENALI_PHY_840_DATA */ + 0x00000000, /* DENALI_PHY_841_DATA */ + 0x00000000, /* DENALI_PHY_842_DATA */ + 0x00000000, /* DENALI_PHY_843_DATA */ + 0x00000000, /* DENALI_PHY_844_DATA */ + 0x00000000, /* DENALI_PHY_845_DATA */ + 0x00000000, /* DENALI_PHY_846_DATA */ + 0x00000000, /* DENALI_PHY_847_DATA */ + 0x00000000, /* DENALI_PHY_848_DATA */ + 0x00000000, /* DENALI_PHY_849_DATA */ + 0x00000000, /* DENALI_PHY_850_DATA */ + 0x00000000, /* DENALI_PHY_851_DATA */ + 0x00000000, /* DENALI_PHY_852_DATA */ + 0x00000000, /* DENALI_PHY_853_DATA */ + 0x00000000, /* DENALI_PHY_854_DATA */ + 0x00000000, /* DENALI_PHY_855_DATA */ + 0x00000000, /* DENALI_PHY_856_DATA */ + 0x00000000, /* DENALI_PHY_857_DATA */ + 0x00000000, /* DENALI_PHY_858_DATA */ + 0x00000000, /* DENALI_PHY_859_DATA */ + 0x00000000, /* DENALI_PHY_860_DATA */ + 0x00000000, /* DENALI_PHY_861_DATA */ + 0x00000000, /* DENALI_PHY_862_DATA */ + 0x00000000, /* DENALI_PHY_863_DATA */ + 0x00000000, /* DENALI_PHY_864_DATA */ + 0x00000000, /* DENALI_PHY_865_DATA */ + 0x00000000, /* DENALI_PHY_866_DATA */ + 0x00000000, /* DENALI_PHY_867_DATA */ + 0x00000000, /* DENALI_PHY_868_DATA */ + 0x00000000, /* DENALI_PHY_869_DATA */ + 0x00000000, /* DENALI_PHY_870_DATA */ + 0x00000000, /* DENALI_PHY_871_DATA */ + 0x00000000, /* DENALI_PHY_872_DATA */ + 0x00000000, /* DENALI_PHY_873_DATA */ + 0x00000000, /* DENALI_PHY_874_DATA */ + 0x00000000, /* DENALI_PHY_875_DATA */ + 0x00000000, /* DENALI_PHY_876_DATA */ + 0x00000000, /* DENALI_PHY_877_DATA */ + 0x00000000, /* DENALI_PHY_878_DATA */ + 0x00000000, /* DENALI_PHY_879_DATA */ + 0x00000000, /* DENALI_PHY_880_DATA */ + 0x00000000, /* DENALI_PHY_881_DATA */ + 0x00000000, /* DENALI_PHY_882_DATA */ + 0x00000000, /* DENALI_PHY_883_DATA */ + 0x00000000, /* DENALI_PHY_884_DATA */ + 0x00000000, /* DENALI_PHY_885_DATA */ + 0x00000000, /* DENALI_PHY_886_DATA */ + 0x00000000, /* DENALI_PHY_887_DATA */ + 0x00000000, /* DENALI_PHY_888_DATA */ + 0x00000000, /* DENALI_PHY_889_DATA */ + 0x00000000, /* DENALI_PHY_890_DATA */ + 0x00000000, /* DENALI_PHY_891_DATA */ + 0x00000000, /* DENALI_PHY_892_DATA */ + 0x00000000, /* DENALI_PHY_893_DATA */ + 0x00000000, /* DENALI_PHY_894_DATA */ + 0x00000000, /* DENALI_PHY_895_DATA */ + 0x00000001, /* DENALI_PHY_896_DATA */ + 0x00000000, /* DENALI_PHY_897_DATA */ + 0x01000005, /* DENALI_PHY_898_DATA */ + 0x04000f00, /* DENALI_PHY_899_DATA */ + 0x00020040, /* DENALI_PHY_900_DATA */ + 0x00020055, /* DENALI_PHY_901_DATA */ + 0x00000000, /* DENALI_PHY_902_DATA */ + 0x00000000, /* DENALI_PHY_903_DATA */ + 0x00000000, /* DENALI_PHY_904_DATA */ + 0x00000050, /* DENALI_PHY_905_DATA */ + 0x00000000, /* DENALI_PHY_906_DATA */ + 0x00010100, /* DENALI_PHY_907_DATA */ + 0x00000601, /* DENALI_PHY_908_DATA */ + 0x00000000, /* DENALI_PHY_909_DATA */ + 0x00006400, /* DENALI_PHY_910_DATA */ + 0x05221502, /* DENALI_PHY_911_DATA */ + 0x00000000, /* DENALI_PHY_912_DATA */ + 0x00051f01, /* DENALI_PHY_913_DATA */ + 0x051f051f, /* DENALI_PHY_914_DATA */ + 0x051f051f, /* DENALI_PHY_915_DATA */ + 0x00030003, /* DENALI_PHY_916_DATA */ + 0x03000300, /* DENALI_PHY_917_DATA */ + 0x00000300, /* DENALI_PHY_918_DATA */ + 0x05221502, /* DENALI_PHY_919_DATA */ + 0x00000000, /* DENALI_PHY_920_DATA */ + 0x00000000, /* DENALI_PHY_921_DATA */ + 0x01020000, /* DENALI_PHY_922_DATA */ + 0x00000001, /* DENALI_PHY_923_DATA */ + 0x00000011, /* DENALI_PHY_924_DATA */ + 0x00000011, /* DENALI_PHY_925_DATA */ + 0x00000400, /* DENALI_PHY_926_DATA */ + 0x00000000, /* DENALI_PHY_927_DATA */ + 0x00000011, /* DENALI_PHY_928_DATA */ + 0x00000011, /* DENALI_PHY_929_DATA */ + 0x00004410, /* DENALI_PHY_930_DATA */ + 0x00004410, /* DENALI_PHY_931_DATA */ + 0x00004410, /* DENALI_PHY_932_DATA */ + 0x00004410, /* DENALI_PHY_933_DATA */ + 0x00004410, /* DENALI_PHY_934_DATA */ + 0x00000011, /* DENALI_PHY_935_DATA */ + 0x00004410, /* DENALI_PHY_936_DATA */ + 0x00000011, /* DENALI_PHY_937_DATA */ + 0x00004410, /* DENALI_PHY_938_DATA */ + 0x00000011, /* DENALI_PHY_939_DATA */ + 0x00004410, /* DENALI_PHY_940_DATA */ + 0x00000000, /* DENALI_PHY_941_DATA */ + 0x00000000, /* DENALI_PHY_942_DATA */ + 0x00000000, /* DENALI_PHY_943_DATA */ + 0x04000000, /* DENALI_PHY_944_DATA */ + 0x00000000, /* DENALI_PHY_945_DATA */ + 0x00000000, /* DENALI_PHY_946_DATA */ + 0x00000308, /* DENALI_PHY_947_DATA */ + 0x00000000, /* DENALI_PHY_948_DATA */ + 0x00000000, /* DENALI_PHY_949_DATA */ + 0x00000000, /* DENALI_PHY_950_DATA */ + 0x00000000, /* DENALI_PHY_951_DATA */ + 0x00000000, /* DENALI_PHY_952_DATA */ + 0x00000000, /* DENALI_PHY_953_DATA */ + 0xe4000000, /* DENALI_PHY_954_DATA */ + 0x00000000, /* DENALI_PHY_955_DATA */ + 0x00000000, /* DENALI_PHY_956_DATA */ + 0x01010000, /* DENALI_PHY_957_DATA */ + 0x00000000 /* DENALI_PHY_958_DATA */ + } + }, +}; diff --git a/src/mainboard/google/gru/sdram_inf/sdram-lpddr3-hynix-4GB-200.inc b/src/mainboard/google/gru/sdram_inf/sdram-lpddr3-hynix-4GB-200.inc deleted file mode 100644 index 2533640..0000000 --- a/src/mainboard/google/gru/sdram_inf/sdram-lpddr3-hynix-4GB-200.inc +++ /dev/null @@ -1,1563 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -{ - { - { - .rank = 0x2, - .col = 0xA, - .bk = 0x3, - .bw = 0x2, - .dbw = 0x2, - .row_3_4 = 0x0, - .cs0_row = 0xF, - .cs1_row = 0xF, - .ddrconfig = 1, - { - {0x0e080807}, - {0x05010605}, - {0x00000002}, - {0x00006076}, - {0x00000054}, - 0x00000000 - } - }, - { - .rank = 0x2, - .col = 0xA, - .bk = 0x3, - .bw = 0x2, - .dbw = 0x2, - .row_3_4 = 0x0, - .cs0_row = 0xF, - .cs1_row = 0xF, - .ddrconfig = 1, - { - {0x0e080807}, - {0x05010605}, - {0x00000002}, - {0x00006076}, - {0x00000054}, - 0x00000000 - } - } - }, - .ddr_freq = 200*MHz, - .dramtype = LPDDR3, - .num_channels = 2, - .stride = 13, - .odt = 1, - { - { - 0x00000700, /* DENALI_CTL_00_DATA */ - 0x00000000, /* DENALI_CTL_01_DATA */ - 0x00000000, /* DENALI_CTL_02_DATA */ - 0x00000000, /* DENALI_CTL_03_DATA */ - 0x00000000, /* DENALI_CTL_04_DATA */ - 0x00000014, /* DENALI_CTL_05_DATA */ - 0x00009c40, /* DENALI_CTL_06_DATA */ - 0x000000c8, /* DENALI_CTL_07_DATA */ - 0x000007d0, /* DENALI_CTL_08_DATA */ - 0x00000014, /* DENALI_CTL_09_DATA */ - 0x00009c40, /* DENALI_CTL_10_DATA */ - 0x000000c8, /* DENALI_CTL_11_DATA */ - 0x000007d0, /* DENALI_CTL_12_DATA */ - 0x00000014, /* DENALI_CTL_13_DATA */ - 0x00009c40, /* DENALI_CTL_14_DATA */ - 0x000000c8, /* DENALI_CTL_15_DATA */ - 0x010007d0, /* DENALI_CTL_16_DATA */ - 0x00000000, /* DENALI_CTL_17_DATA */ - 0x00000101, /* DENALI_CTL_18_DATA */ - 0x00020100, /* DENALI_CTL_19_DATA */ - 0x00000028, /* DENALI_CTL_20_DATA */ - 0x00000064, /* DENALI_CTL_21_DATA */ - 0x00000000, /* DENALI_CTL_22_DATA */ - 0x030c0000, /* DENALI_CTL_23_DATA */ - 0x00030c00, /* DENALI_CTL_24_DATA */ - 0x0400030c, /* DENALI_CTL_25_DATA */ - 0x0d020004, /* DENALI_CTL_26_DATA */ - 0x0a040409, /* DENALI_CTL_27_DATA */ - 0x090d0200, /* DENALI_CTL_28_DATA */ - 0x000a0404, /* DENALI_CTL_29_DATA */ - 0x04090d02, /* DENALI_CTL_30_DATA */ - 0x04000a04, /* DENALI_CTL_31_DATA */ - 0x00000a0a, /* DENALI_CTL_32_DATA */ - 0x030036b0, /* DENALI_CTL_33_DATA */ - 0x0a0a0403, /* DENALI_CTL_34_DATA */ - 0x030036b0, /* DENALI_CTL_35_DATA */ - 0x0a0a0403, /* DENALI_CTL_36_DATA */ - 0x030036b0, /* DENALI_CTL_37_DATA */ - 0x02030003, /* DENALI_CTL_38_DATA */ - 0x04040400, /* DENALI_CTL_39_DATA */ - 0x04040404, /* DENALI_CTL_40_DATA */ - 0x14000a0a, /* DENALI_CTL_41_DATA */ - 0x01010a0a, /* DENALI_CTL_42_DATA */ - 0x00010001, /* DENALI_CTL_43_DATA */ - 0x030a0a0a, /* DENALI_CTL_44_DATA */ - 0x00050505, /* DENALI_CTL_45_DATA */ - 0x00000000, /* DENALI_CTL_46_DATA */ - 0x03010000, /* DENALI_CTL_47_DATA */ - 0x0304002a, /* DENALI_CTL_48_DATA */ - 0x0304002a, /* DENALI_CTL_49_DATA */ - 0x0304002a, /* DENALI_CTL_50_DATA */ - 0x00000000, /* DENALI_CTL_51_DATA */ - 0x00030003, /* DENALI_CTL_52_DATA */ - 0x000a0003, /* DENALI_CTL_53_DATA */ - 0x000a000a, /* DENALI_CTL_54_DATA */ - 0x00040404, /* DENALI_CTL_55_DATA */ - 0x00000000, /* DENALI_CTL_56_DATA */ - 0x00000000, /* DENALI_CTL_57_DATA */ - 0x00000000, /* DENALI_CTL_58_DATA */ - 0x002c0000, /* DENALI_CTL_59_DATA */ - 0x002c002c, /* DENALI_CTL_60_DATA */ - 0x002c002c, /* DENALI_CTL_61_DATA */ - 0x0000002c, /* DENALI_CTL_62_DATA */ - 0x00000000, /* DENALI_CTL_63_DATA */ - 0x00000000, /* DENALI_CTL_64_DATA */ - 0x00000000, /* DENALI_CTL_65_DATA */ - 0x00000000, /* DENALI_CTL_66_DATA */ - 0x00000000, /* DENALI_CTL_67_DATA */ - 0x00000000, /* DENALI_CTL_68_DATA */ - 0x00000301, /* DENALI_CTL_69_DATA */ - 0x00000001, /* DENALI_CTL_70_DATA */ - 0x00000000, /* DENALI_CTL_71_DATA */ - 0x00000000, /* DENALI_CTL_72_DATA */ - 0x01000000, /* DENALI_CTL_73_DATA */ - 0x80104002, /* DENALI_CTL_74_DATA */ - 0x00040003, /* DENALI_CTL_75_DATA */ - 0x00040005, /* DENALI_CTL_76_DATA */ - 0x00030000, /* DENALI_CTL_77_DATA */ - 0x00050004, /* DENALI_CTL_78_DATA */ - 0x00000004, /* DENALI_CTL_79_DATA */ - 0x00040003, /* DENALI_CTL_80_DATA */ - 0x00040005, /* DENALI_CTL_81_DATA */ - 0x0c100000, /* DENALI_CTL_82_DATA */ - 0x00000608, /* DENALI_CTL_83_DATA */ - 0x06080c10, /* DENALI_CTL_84_DATA */ - 0x0c100000, /* DENALI_CTL_85_DATA */ - 0x00000608, /* DENALI_CTL_86_DATA */ - 0x00000000, /* DENALI_CTL_87_DATA */ - 0x00000000, /* DENALI_CTL_88_DATA */ - 0x00000000, /* DENALI_CTL_89_DATA */ - 0x00000000, /* DENALI_CTL_90_DATA */ - 0x00000000, /* DENALI_CTL_91_DATA */ - 0x02020200, /* DENALI_CTL_92_DATA */ - 0x00020202, /* DENALI_CTL_93_DATA */ - 0x00030200, /* DENALI_CTL_94_DATA */ - 0x00040700, /* DENALI_CTL_95_DATA */ - 0x00000302, /* DENALI_CTL_96_DATA */ - 0x02000407, /* DENALI_CTL_97_DATA */ - 0x00000003, /* DENALI_CTL_98_DATA */ - 0x00030f04, /* DENALI_CTL_99_DATA */ - 0x00070004, /* DENALI_CTL_100_DATA */ - 0x00000000, /* DENALI_CTL_101_DATA */ - 0x00000000, /* DENALI_CTL_102_DATA */ - 0x00000000, /* DENALI_CTL_103_DATA */ - 0x00000000, /* DENALI_CTL_104_DATA */ - 0x00000000, /* DENALI_CTL_105_DATA */ - 0x00000000, /* DENALI_CTL_106_DATA */ - 0x00000000, /* DENALI_CTL_107_DATA */ - 0x00010000, /* DENALI_CTL_108_DATA */ - 0x20040020, /* DENALI_CTL_109_DATA */ - 0x00200400, /* DENALI_CTL_110_DATA */ - 0x01000400, /* DENALI_CTL_111_DATA */ - 0x00000b80, /* DENALI_CTL_112_DATA */ - 0x00000000, /* DENALI_CTL_113_DATA */ - 0x00000001, /* DENALI_CTL_114_DATA */ - 0x00000002, /* DENALI_CTL_115_DATA */ - 0x0000000e, /* DENALI_CTL_116_DATA */ - 0x00000000, /* DENALI_CTL_117_DATA */ - 0x00000000, /* DENALI_CTL_118_DATA */ - 0x00000000, /* DENALI_CTL_119_DATA */ - 0x00000000, /* DENALI_CTL_120_DATA */ - 0x00000000, /* DENALI_CTL_121_DATA */ - 0x00280000, /* DENALI_CTL_122_DATA */ - 0x00320014, /* DENALI_CTL_123_DATA */ - 0x00320000, /* DENALI_CTL_124_DATA */ - 0x00140028, /* DENALI_CTL_125_DATA */ - 0x00000032, /* DENALI_CTL_126_DATA */ - 0x00280032, /* DENALI_CTL_127_DATA */ - 0x00320014, /* DENALI_CTL_128_DATA */ - 0x00320000, /* DENALI_CTL_129_DATA */ - 0x00000000, /* DENALI_CTL_130_DATA */ - 0x00000000, /* DENALI_CTL_131_DATA */ - 0x00000000, /* DENALI_CTL_132_DATA */ - 0x00830000, /* DENALI_CTL_133_DATA */ - 0x00000004, /* DENALI_CTL_134_DATA */ - 0x00040083, /* DENALI_CTL_135_DATA */ - 0x00830000, /* DENALI_CTL_136_DATA */ - 0x00000004, /* DENALI_CTL_137_DATA */ - 0x00010001, /* DENALI_CTL_138_DATA */ - 0x07000001, /* DENALI_CTL_139_DATA */ - 0x00000707, /* DENALI_CTL_140_DATA */ - 0x00000000, /* DENALI_CTL_141_DATA */ - 0x00000000, /* DENALI_CTL_142_DATA */ - 0x00000000, /* DENALI_CTL_143_DATA */ - 0x00000000, /* DENALI_CTL_144_DATA */ - 0x00000000, /* DENALI_CTL_145_DATA */ - 0x00000000, /* DENALI_CTL_146_DATA */ - 0x00830000, /* DENALI_CTL_147_DATA */ - 0x00000004, /* DENALI_CTL_148_DATA */ - 0x00040083, /* DENALI_CTL_149_DATA */ - 0x00830000, /* DENALI_CTL_150_DATA */ - 0x00000004, /* DENALI_CTL_151_DATA */ - 0x00010001, /* DENALI_CTL_152_DATA */ - 0x07000001, /* DENALI_CTL_153_DATA */ - 0x00000707, /* DENALI_CTL_154_DATA */ - 0x00000000, /* DENALI_CTL_155_DATA */ - 0x00000000, /* DENALI_CTL_156_DATA */ - 0x00000000, /* DENALI_CTL_157_DATA */ - 0x00000000, /* DENALI_CTL_158_DATA */ - 0x00000000, /* DENALI_CTL_159_DATA */ - 0x00000000, /* DENALI_CTL_160_DATA */ - 0x01000000, /* DENALI_CTL_161_DATA */ - 0x00000000, /* DENALI_CTL_162_DATA */ - 0x00000000, /* DENALI_CTL_163_DATA */ - 0x18151100, /* DENALI_CTL_164_DATA */ - 0x0000000c, /* DENALI_CTL_165_DATA */ - 0x00000000, /* DENALI_CTL_166_DATA */ - 0x00000000, /* DENALI_CTL_167_DATA */ - 0x00000000, /* DENALI_CTL_168_DATA */ - 0x00000000, /* DENALI_CTL_169_DATA */ - 0x00000000, /* DENALI_CTL_170_DATA */ - 0x00000000, /* DENALI_CTL_171_DATA */ - 0x00000000, /* DENALI_CTL_172_DATA */ - 0x00000000, /* DENALI_CTL_173_DATA */ - 0x00000000, /* DENALI_CTL_174_DATA */ - 0x00000000, /* DENALI_CTL_175_DATA */ - 0x00000000, /* DENALI_CTL_176_DATA */ - 0x00000000, /* DENALI_CTL_177_DATA */ - 0x00000000, /* DENALI_CTL_178_DATA */ - 0x0000c803, /* DENALI_CTL_179_DATA */ - 0x00120048, /* DENALI_CTL_180_DATA */ - 0x00000000, /* DENALI_CTL_181_DATA */ - 0x004800c8, /* DENALI_CTL_182_DATA */ - 0x00000012, /* DENALI_CTL_183_DATA */ - 0x0000c800, /* DENALI_CTL_184_DATA */ - 0x00120048, /* DENALI_CTL_185_DATA */ - 0x00000000, /* DENALI_CTL_186_DATA */ - 0x000a0000, /* DENALI_CTL_187_DATA */ - 0x000a000a, /* DENALI_CTL_188_DATA */ - 0x01010100, /* DENALI_CTL_189_DATA */ - 0x01000202, /* DENALI_CTL_190_DATA */ - 0x0a000002, /* DENALI_CTL_191_DATA */ - 0x01000f0f, /* DENALI_CTL_192_DATA */ - 0x00000000, /* DENALI_CTL_193_DATA */ - 0x00000000, /* DENALI_CTL_194_DATA */ - 0x00010003, /* DENALI_CTL_195_DATA */ - 0x00000c03, /* DENALI_CTL_196_DATA */ - 0x00000100, /* DENALI_CTL_197_DATA */ - 0x00010000, /* DENALI_CTL_198_DATA */ - 0x01000000, /* DENALI_CTL_199_DATA */ - 0x00010000, /* DENALI_CTL_200_DATA */ - 0x00000001, /* DENALI_CTL_201_DATA */ - 0x00000000, /* DENALI_CTL_202_DATA */ - 0x00000000, /* DENALI_CTL_203_DATA */ - 0x00000000, /* DENALI_CTL_204_DATA */ - 0x00000000, /* DENALI_CTL_205_DATA */ - 0x00000000, /* DENALI_CTL_206_DATA */ - 0x00000000, /* DENALI_CTL_207_DATA */ - 0x00000000, /* DENALI_CTL_208_DATA */ - 0x00000000, /* DENALI_CTL_209_DATA */ - 0x00000000, /* DENALI_CTL_210_DATA */ - 0x00010000, /* DENALI_CTL_211_DATA */ - 0x01010101, /* DENALI_CTL_212_DATA */ - 0x01000707, /* DENALI_CTL_213_DATA */ - 0x02020001, /* DENALI_CTL_214_DATA */ - 0x05050502, /* DENALI_CTL_215_DATA */ - 0x02080808, /* DENALI_CTL_216_DATA */ - 0x02050202, /* DENALI_CTL_217_DATA */ - 0x02010202, /* DENALI_CTL_218_DATA */ - 0x00010202, /* DENALI_CTL_219_DATA */ - 0x00020202, /* DENALI_CTL_220_DATA */ - 0x02010200, /* DENALI_CTL_221_DATA */ - 0x00010201, /* DENALI_CTL_222_DATA */ - 0x00000000, /* DENALI_CTL_223_DATA */ - 0x00000000, /* DENALI_CTL_224_DATA */ - 0x0d000001, /* DENALI_CTL_225_DATA */ - 0x00010028, /* DENALI_CTL_226_DATA */ - 0x00010000, /* DENALI_CTL_227_DATA */ - 0x00000003, /* DENALI_CTL_228_DATA */ - 0x00000000, /* DENALI_CTL_229_DATA */ - 0x00000000, /* DENALI_CTL_230_DATA */ - 0x00000000, /* DENALI_CTL_231_DATA */ - 0x00000000, /* DENALI_CTL_232_DATA */ - 0x00000000, /* DENALI_CTL_233_DATA */ - 0x00000000, /* DENALI_CTL_234_DATA */ - 0x00000000, /* DENALI_CTL_235_DATA */ - 0x00000000, /* DENALI_CTL_236_DATA */ - 0x00010100, /* DENALI_CTL_237_DATA */ - 0x01000000, /* DENALI_CTL_238_DATA */ - 0x00000001, /* DENALI_CTL_239_DATA */ - 0x00000303, /* DENALI_CTL_240_DATA */ - 0x00000000, /* DENALI_CTL_241_DATA */ - 0x00000000, /* DENALI_CTL_242_DATA */ - 0x00000000, /* DENALI_CTL_243_DATA */ - 0x00000000, /* DENALI_CTL_244_DATA */ - 0x00000000, /* DENALI_CTL_245_DATA */ - 0x00000000, /* DENALI_CTL_246_DATA */ - 0x00000000, /* DENALI_CTL_247_DATA */ - 0x00000000, /* DENALI_CTL_248_DATA */ - 0x00000000, /* DENALI_CTL_249_DATA */ - 0x00000000, /* DENALI_CTL_250_DATA */ - 0x00000000, /* DENALI_CTL_251_DATA */ - 0x00000000, /* DENALI_CTL_252_DATA */ - 0x00000000, /* DENALI_CTL_253_DATA */ - 0x00000000, /* DENALI_CTL_254_DATA */ - 0x00000000, /* DENALI_CTL_255_DATA */ - 0x000556aa, /* DENALI_CTL_256_DATA */ - 0x000aaaaa, /* DENALI_CTL_257_DATA */ - 0x000aa955, /* DENALI_CTL_258_DATA */ - 0x00055555, /* DENALI_CTL_259_DATA */ - 0x000b3133, /* DENALI_CTL_260_DATA */ - 0x0004cd33, /* DENALI_CTL_261_DATA */ - 0x0004cecc, /* DENALI_CTL_262_DATA */ - 0x000b32cc, /* DENALI_CTL_263_DATA */ - 0x00010300, /* DENALI_CTL_264_DATA */ - 0x03000100, /* DENALI_CTL_265_DATA */ - 0x00000000, /* DENALI_CTL_266_DATA */ - 0x00000000, /* DENALI_CTL_267_DATA */ - 0x00000000, /* DENALI_CTL_268_DATA */ - 0x00000000, /* DENALI_CTL_269_DATA */ - 0x00000000, /* DENALI_CTL_270_DATA */ - 0x00000000, /* DENALI_CTL_271_DATA */ - 0x00000000, /* DENALI_CTL_272_DATA */ - 0x00000000, /* DENALI_CTL_273_DATA */ - 0x00ffff00, /* DENALI_CTL_274_DATA */ - 0x14140000, /* DENALI_CTL_275_DATA */ - 0x08000014, /* DENALI_CTL_276_DATA */ - 0x00000608, /* DENALI_CTL_277_DATA */ - 0x00000200, /* DENALI_CTL_278_DATA */ - 0x00000200, /* DENALI_CTL_279_DATA */ - 0x00000200, /* DENALI_CTL_280_DATA */ - 0x00000200, /* DENALI_CTL_281_DATA */ - 0x00000608, /* DENALI_CTL_282_DATA */ - 0x00003c50, /* DENALI_CTL_283_DATA */ - 0x06080205, /* DENALI_CTL_284_DATA */ - 0x00000200, /* DENALI_CTL_285_DATA */ - 0x00000200, /* DENALI_CTL_286_DATA */ - 0x00000200, /* DENALI_CTL_287_DATA */ - 0x00000200, /* DENALI_CTL_288_DATA */ - 0x00000608, /* DENALI_CTL_289_DATA */ - 0x00003c50, /* DENALI_CTL_290_DATA */ - 0x06080205, /* DENALI_CTL_291_DATA */ - 0x00000200, /* DENALI_CTL_292_DATA */ - 0x00000200, /* DENALI_CTL_293_DATA */ - 0x00000200, /* DENALI_CTL_294_DATA */ - 0x00000200, /* DENALI_CTL_295_DATA */ - 0x00000608, /* DENALI_CTL_296_DATA */ - 0x00003c50, /* DENALI_CTL_297_DATA */ - 0x02020205, /* DENALI_CTL_298_DATA */ - 0x03030202, /* DENALI_CTL_299_DATA */ - 0x00000018, /* DENALI_CTL_300_DATA */ - 0x00000000, /* DENALI_CTL_301_DATA */ - 0x00000000, /* DENALI_CTL_302_DATA */ - 0x00001403, /* DENALI_CTL_303_DATA */ - 0x00000000, /* DENALI_CTL_304_DATA */ - 0x00000000, /* DENALI_CTL_305_DATA */ - 0x00000000, /* DENALI_CTL_306_DATA */ - 0x00030000, /* DENALI_CTL_307_DATA */ - 0x0008001a, /* DENALI_CTL_308_DATA */ - 0x0008001a, /* DENALI_CTL_309_DATA */ - 0x0008001a, /* DENALI_CTL_310_DATA */ - 0x00000000, /* DENALI_CTL_311_DATA */ - 0x00000000, /* DENALI_CTL_312_DATA */ - 0x01000000, /* DENALI_CTL_313_DATA */ - 0x01010101, /* DENALI_CTL_314_DATA */ - 0x00050101, /* DENALI_CTL_315_DATA */ - 0x00000000, /* DENALI_CTL_316_DATA */ - 0x00000000, /* DENALI_CTL_317_DATA */ - 0x00000000, /* DENALI_CTL_318_DATA */ - 0x00000000, /* DENALI_CTL_319_DATA */ - 0x00000000, /* DENALI_CTL_320_DATA */ - 0x00000000, /* DENALI_CTL_321_DATA */ - 0x00000000, /* DENALI_CTL_322_DATA */ - 0x00000000, /* DENALI_CTL_323_DATA */ - 0x01000101, /* DENALI_CTL_324_DATA */ - 0x01010101, /* DENALI_CTL_325_DATA */ - 0x01000101, /* DENALI_CTL_326_DATA */ - 0x01000100, /* DENALI_CTL_327_DATA */ - 0x00010001, /* DENALI_CTL_328_DATA */ - 0x00010002, /* DENALI_CTL_329_DATA */ - 0x00020100, /* DENALI_CTL_330_DATA */ - 0x00000002 /* DENALI_CTL_331_DATA */ - } - }, - { - { - 0x00000700, /* DENALI_PI_00_DATA */ - 0x00000000, /* DENALI_PI_01_DATA */ - 0x00000c10, /* DENALI_PI_02_DATA */ - 0x00000608, /* DENALI_PI_03_DATA */ - 0x00000c10, /* DENALI_PI_04_DATA */ - 0x00000608, /* DENALI_PI_05_DATA */ - 0x00000c10, /* DENALI_PI_06_DATA */ - 0x06080608, /* DENALI_PI_07_DATA */ - 0x00000200, /* DENALI_PI_08_DATA */ - 0x00000200, /* DENALI_PI_09_DATA */ - 0x00000200, /* DENALI_PI_10_DATA */ - 0x00000200, /* DENALI_PI_11_DATA */ - 0x00000608, /* DENALI_PI_12_DATA */ - 0x00000200, /* DENALI_PI_13_DATA */ - 0x00000200, /* DENALI_PI_14_DATA */ - 0x00000200, /* DENALI_PI_15_DATA */ - 0x00000200, /* DENALI_PI_16_DATA */ - 0x00000608, /* DENALI_PI_17_DATA */ - 0x00000200, /* DENALI_PI_18_DATA */ - 0x00000200, /* DENALI_PI_19_DATA */ - 0x00000200, /* DENALI_PI_20_DATA */ - 0x00000200, /* DENALI_PI_21_DATA */ - 0x00010000, /* DENALI_PI_22_DATA */ - 0x00000007, /* DENALI_PI_23_DATA */ - 0x81000001, /* DENALI_PI_24_DATA */ - 0x0f0003f0, /* DENALI_PI_25_DATA */ - 0x3fffffff, /* DENALI_PI_26_DATA */ - 0x0f0000a0, /* DENALI_PI_27_DATA */ - 0x377ff000, /* DENALI_PI_28_DATA */ - 0x0f000020, /* DENALI_PI_29_DATA */ - 0x377ff000, /* DENALI_PI_30_DATA */ - 0x0f000030, /* DENALI_PI_31_DATA */ - 0x377ff000, /* DENALI_PI_32_DATA */ - 0x0f0000b0, /* DENALI_PI_33_DATA */ - 0x377ff000, /* DENALI_PI_34_DATA */ - 0x0f000100, /* DENALI_PI_35_DATA */ - 0x377ff000, /* DENALI_PI_36_DATA */ - 0x0f000110, /* DENALI_PI_37_DATA */ - 0x377ff000, /* DENALI_PI_38_DATA */ - 0x0f000010, /* DENALI_PI_39_DATA */ - 0x377ff000, /* DENALI_PI_40_DATA */ - 0x03000101, /* DENALI_PI_41_DATA */ - 0x041f1f1f, /* DENALI_PI_42_DATA */ - 0x030c0003, /* DENALI_PI_43_DATA */ - 0x00030c00, /* DENALI_PI_44_DATA */ - 0x0000000c, /* DENALI_PI_45_DATA */ - 0x0304002a, /* DENALI_PI_46_DATA */ - 0x0304002a, /* DENALI_PI_47_DATA */ - 0x0304002a, /* DENALI_PI_48_DATA */ - 0x00000500, /* DENALI_PI_49_DATA */ - 0x00000000, /* DENALI_PI_50_DATA */ - 0x00000000, /* DENALI_PI_51_DATA */ - 0x00000000, /* DENALI_PI_52_DATA */ - 0x00000000, /* DENALI_PI_53_DATA */ - 0x00000000, /* DENALI_PI_54_DATA */ - 0x00000000, /* DENALI_PI_55_DATA */ - 0x00000000, /* DENALI_PI_56_DATA */ - 0x00000000, /* DENALI_PI_57_DATA */ - 0x04040000, /* DENALI_PI_58_DATA */ - 0x0d000004, /* DENALI_PI_59_DATA */ - 0x00000128, /* DENALI_PI_60_DATA */ - 0x00000000, /* DENALI_PI_61_DATA */ - 0x00030003, /* DENALI_PI_62_DATA */ - 0x00000018, /* DENALI_PI_63_DATA */ - 0x00000000, /* DENALI_PI_64_DATA */ - 0x00000000, /* DENALI_PI_65_DATA */ - 0x01060002, /* DENALI_PI_66_DATA */ - 0x01010101, /* DENALI_PI_67_DATA */ - 0x01070701, /* DENALI_PI_68_DATA */ - 0x04020201, /* DENALI_PI_69_DATA */ - 0x01080804, /* DENALI_PI_70_DATA */ - 0x00000000, /* DENALI_PI_71_DATA */ - 0x02020000, /* DENALI_PI_72_DATA */ - 0x05050502, /* DENALI_PI_73_DATA */ - 0x00000000, /* DENALI_PI_74_DATA */ - 0x00000000, /* DENALI_PI_75_DATA */ - 0x00000000, /* DENALI_PI_76_DATA */ - 0x00030300, /* DENALI_PI_77_DATA */ - 0x00000014, /* DENALI_PI_78_DATA */ - 0x00000000, /* DENALI_PI_79_DATA */ - 0x01010300, /* DENALI_PI_80_DATA */ - 0x00000000, /* DENALI_PI_81_DATA */ - 0x00000000, /* DENALI_PI_82_DATA */ - 0x01000000, /* DENALI_PI_83_DATA */ - 0x00000101, /* DENALI_PI_84_DATA */ - 0x55555a5a, /* DENALI_PI_85_DATA */ - 0x55555a5a, /* DENALI_PI_86_DATA */ - 0x55555a5a, /* DENALI_PI_87_DATA */ - 0x55555a5a, /* DENALI_PI_88_DATA */ - 0x05050001, /* DENALI_PI_89_DATA */ - 0x02020005, /* DENALI_PI_90_DATA */ - 0x01010002, /* DENALI_PI_91_DATA */ - 0x00000101, /* DENALI_PI_92_DATA */ - 0x00030000, /* DENALI_PI_93_DATA */ - 0x17030000, /* DENALI_PI_94_DATA */ - 0x0008001a, /* DENALI_PI_95_DATA */ - 0x0008001a, /* DENALI_PI_96_DATA */ - 0x0008001a, /* DENALI_PI_97_DATA */ - 0x00000000, /* DENALI_PI_98_DATA */ - 0x00000000, /* DENALI_PI_99_DATA */ - 0x00000100, /* DENALI_PI_100_DATA */ - 0x140a0000, /* DENALI_PI_101_DATA */ - 0x000a010a, /* DENALI_PI_102_DATA */ - 0x01000a01, /* DENALI_PI_103_DATA */ - 0x010a000a, /* DENALI_PI_104_DATA */ - 0x00000100, /* DENALI_PI_105_DATA */ - 0x01000000, /* DENALI_PI_106_DATA */ - 0x00000000, /* DENALI_PI_107_DATA */ - 0x00000100, /* DENALI_PI_108_DATA */ - 0x1e1a0000, /* DENALI_PI_109_DATA */ - 0x10010204, /* DENALI_PI_110_DATA */ - 0x06060605, /* DENALI_PI_111_DATA */ - 0x20000202, /* DENALI_PI_112_DATA */ - 0x00201000, /* DENALI_PI_113_DATA */ - 0x00201000, /* DENALI_PI_114_DATA */ - 0x04041000, /* DENALI_PI_115_DATA */ - 0x0a0a0100, /* DENALI_PI_116_DATA */ - 0x0001010a, /* DENALI_PI_117_DATA */ - 0x004b004a, /* DENALI_PI_118_DATA */ - 0x1a030000, /* DENALI_PI_119_DATA */ - 0x0102041e, /* DENALI_PI_120_DATA */ - 0x34000000, /* DENALI_PI_121_DATA */ - 0x00000000, /* DENALI_PI_122_DATA */ - 0x00000000, /* DENALI_PI_123_DATA */ - 0x00000000, /* DENALI_PI_124_DATA */ - 0x00008300, /* DENALI_PI_125_DATA */ - 0x00010004, /* DENALI_PI_126_DATA */ - 0x004d4d07, /* DENALI_PI_127_DATA */ - 0x00040083, /* DENALI_PI_128_DATA */ - 0x4d070001, /* DENALI_PI_129_DATA */ - 0x0000834d, /* DENALI_PI_130_DATA */ - 0x00010004, /* DENALI_PI_131_DATA */ - 0x004d4d07, /* DENALI_PI_132_DATA */ - 0x00040083, /* DENALI_PI_133_DATA */ - 0x4d070001, /* DENALI_PI_134_DATA */ - 0x0000834d, /* DENALI_PI_135_DATA */ - 0x00010004, /* DENALI_PI_136_DATA */ - 0x004d4d07, /* DENALI_PI_137_DATA */ - 0x00040083, /* DENALI_PI_138_DATA */ - 0x4d070001, /* DENALI_PI_139_DATA */ - 0x0023004d, /* DENALI_PI_140_DATA */ - 0x00010004, /* DENALI_PI_141_DATA */ - 0x004d4d07, /* DENALI_PI_142_DATA */ - 0x00040023, /* DENALI_PI_143_DATA */ - 0x4d070001, /* DENALI_PI_144_DATA */ - 0x0000234d, /* DENALI_PI_145_DATA */ - 0x00010004, /* DENALI_PI_146_DATA */ - 0x004d4d07, /* DENALI_PI_147_DATA */ - 0x00040023, /* DENALI_PI_148_DATA */ - 0x4d070001, /* DENALI_PI_149_DATA */ - 0x0000234d, /* DENALI_PI_150_DATA */ - 0x00010004, /* DENALI_PI_151_DATA */ - 0x004d4d07, /* DENALI_PI_152_DATA */ - 0x00040023, /* DENALI_PI_153_DATA */ - 0x4d070001, /* DENALI_PI_154_DATA */ - 0x0100004d, /* DENALI_PI_155_DATA */ - 0x00320032, /* DENALI_PI_156_DATA */ - 0x04040032, /* DENALI_PI_157_DATA */ - 0x04040405, /* DENALI_PI_158_DATA */ - 0x09003624, /* DENALI_PI_159_DATA */ - 0x0a032002, /* DENALI_PI_160_DATA */ - 0x0405040a, /* DENALI_PI_161_DATA */ - 0x00000404, /* DENALI_PI_162_DATA */ - 0x09003624, /* DENALI_PI_163_DATA */ - 0x0a032002, /* DENALI_PI_164_DATA */ - 0x0405040a, /* DENALI_PI_165_DATA */ - 0x00000404, /* DENALI_PI_166_DATA */ - 0x09003624, /* DENALI_PI_167_DATA */ - 0x0a032002, /* DENALI_PI_168_DATA */ - 0x0200020a, /* DENALI_PI_169_DATA */ - 0x02000200, /* DENALI_PI_170_DATA */ - 0x02000200, /* DENALI_PI_171_DATA */ - 0x02000200, /* DENALI_PI_172_DATA */ - 0x02000200, /* DENALI_PI_173_DATA */ - 0x00000000, /* DENALI_PI_174_DATA */ - 0x00000000, /* DENALI_PI_175_DATA */ - 0x00000000, /* DENALI_PI_176_DATA */ - 0x00000000, /* DENALI_PI_177_DATA */ - 0x00000000, /* DENALI_PI_178_DATA */ - 0x00000000, /* DENALI_PI_179_DATA */ - 0x00000000, /* DENALI_PI_180_DATA */ - 0x00000000, /* DENALI_PI_181_DATA */ - 0x00000000, /* DENALI_PI_182_DATA */ - 0x00000000, /* DENALI_PI_183_DATA */ - 0x00000000, /* DENALI_PI_184_DATA */ - 0x00000000, /* DENALI_PI_185_DATA */ - 0x01000300, /* DENALI_PI_186_DATA */ - 0x00060800, /* DENALI_PI_187_DATA */ - 0x00003c50, /* DENALI_PI_188_DATA */ - 0x00000608, /* DENALI_PI_189_DATA */ - 0x00003c50, /* DENALI_PI_190_DATA */ - 0x00000608, /* DENALI_PI_191_DATA */ - 0x00003c50, /* DENALI_PI_192_DATA */ - 0x08000000, /* DENALI_PI_193_DATA */ - 0x00000100, /* DENALI_PI_194_DATA */ - 0x00000000, /* DENALI_PI_195_DATA */ - 0x00000000, /* DENALI_PI_196_DATA */ - 0x00000000, /* DENALI_PI_197_DATA */ - 0x00000000, /* DENALI_PI_198_DATA */ - 0x00000002 /* DENALI_PI_199_DATA */ - } - }, - { - { - 0x76543210, /* DENALI_PHY_00_DATA */ - 0x0004c008, /* DENALI_PHY_01_DATA */ - 0x00000080, /* DENALI_PHY_02_DATA */ - 0x00000000, /* DENALI_PHY_03_DATA */ - 0x00000000, /* DENALI_PHY_04_DATA */ - 0x00010000, /* DENALI_PHY_05_DATA */ - 0x01665555, /* DENALI_PHY_06_DATA */ - 0x00665555, /* DENALI_PHY_07_DATA */ - 0x00010f00, /* DENALI_PHY_08_DATA */ - 0x04000100, /* DENALI_PHY_09_DATA */ - 0x00000001, /* DENALI_PHY_10_DATA */ - 0x001700c0, /* DENALI_PHY_11_DATA */ - 0x00cc0101, /* DENALI_PHY_12_DATA */ - 0x00030066, /* DENALI_PHY_13_DATA */ - 0x00000000, /* DENALI_PHY_14_DATA */ - 0x00000000, /* DENALI_PHY_15_DATA */ - 0x00000000, /* DENALI_PHY_16_DATA */ - 0x00000000, /* DENALI_PHY_17_DATA */ - 0x00000000, /* DENALI_PHY_18_DATA */ - 0x00000000, /* DENALI_PHY_19_DATA */ - 0x00000000, /* DENALI_PHY_20_DATA */ - 0x00000000, /* DENALI_PHY_21_DATA */ - 0x04080000, /* DENALI_PHY_22_DATA */ - 0x04080400, /* DENALI_PHY_23_DATA */ - 0x08000000, /* DENALI_PHY_24_DATA */ - 0x0c00c007, /* DENALI_PHY_25_DATA */ - 0x00000100, /* DENALI_PHY_26_DATA */ - 0x00000100, /* DENALI_PHY_27_DATA */ - 0x55555555, /* DENALI_PHY_28_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_29_DATA */ - 0x55555555, /* DENALI_PHY_30_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_31_DATA */ - 0x00005555, /* DENALI_PHY_32_DATA */ - 0x00000000, /* DENALI_PHY_33_DATA */ - 0x00000000, /* DENALI_PHY_34_DATA */ - 0x00000000, /* DENALI_PHY_35_DATA */ - 0x00000000, /* DENALI_PHY_36_DATA */ - 0x00000000, /* DENALI_PHY_37_DATA */ - 0x00000000, /* DENALI_PHY_38_DATA */ - 0x00000000, /* DENALI_PHY_39_DATA */ - 0x00000000, /* DENALI_PHY_40_DATA */ - 0x00000000, /* DENALI_PHY_41_DATA */ - 0x00000000, /* DENALI_PHY_42_DATA */ - 0x00000000, /* DENALI_PHY_43_DATA */ - 0x00000000, /* DENALI_PHY_44_DATA */ - 0x00000000, /* DENALI_PHY_45_DATA */ - 0x00000000, /* DENALI_PHY_46_DATA */ - 0x00000000, /* DENALI_PHY_47_DATA */ - 0x00000000, /* DENALI_PHY_48_DATA */ - 0x00000000, /* DENALI_PHY_49_DATA */ - 0x00000000, /* DENALI_PHY_50_DATA */ - 0x00000000, /* DENALI_PHY_51_DATA */ - 0x00200000, /* DENALI_PHY_52_DATA */ - 0x00000000, /* DENALI_PHY_53_DATA */ - 0x00000000, /* DENALI_PHY_54_DATA */ - 0x00000000, /* DENALI_PHY_55_DATA */ - 0x00000000, /* DENALI_PHY_56_DATA */ - 0x00000000, /* DENALI_PHY_57_DATA */ - 0x00000000, /* DENALI_PHY_58_DATA */ - 0x02800280, /* DENALI_PHY_59_DATA */ - 0x02800280, /* DENALI_PHY_60_DATA */ - 0x02800280, /* DENALI_PHY_61_DATA */ - 0x02800280, /* DENALI_PHY_62_DATA */ - 0x00000280, /* DENALI_PHY_63_DATA */ - 0x00000000, /* DENALI_PHY_64_DATA */ - 0x00000000, /* DENALI_PHY_65_DATA */ - 0x00000000, /* DENALI_PHY_66_DATA */ - 0x00000000, /* DENALI_PHY_67_DATA */ - 0x00800000, /* DENALI_PHY_68_DATA */ - 0x00800080, /* DENALI_PHY_69_DATA */ - 0x00800080, /* DENALI_PHY_70_DATA */ - 0x00800080, /* DENALI_PHY_71_DATA */ - 0x00800080, /* DENALI_PHY_72_DATA */ - 0x00800080, /* DENALI_PHY_73_DATA */ - 0x00800080, /* DENALI_PHY_74_DATA */ - 0x00800080, /* DENALI_PHY_75_DATA */ - 0x00800080, /* DENALI_PHY_76_DATA */ - 0x00800080, /* DENALI_PHY_77_DATA */ - 0x01900001, /* DENALI_PHY_78_DATA */ - 0x00000000, /* DENALI_PHY_79_DATA */ - 0x00000000, /* DENALI_PHY_80_DATA */ - 0x00000200, /* DENALI_PHY_81_DATA */ - 0x00000000, /* DENALI_PHY_82_DATA */ - 0x51315152, /* DENALI_PHY_83_DATA */ - 0xc0003150, /* DENALI_PHY_84_DATA */ - 0x010000c0, /* DENALI_PHY_85_DATA */ - 0x00100000, /* DENALI_PHY_86_DATA */ - 0x0c044208, /* DENALI_PHY_87_DATA */ - 0x000f0c18, /* DENALI_PHY_88_DATA */ - 0x01000140, /* DENALI_PHY_89_DATA */ - 0x00000c20, /* DENALI_PHY_90_DATA */ - 0x00000000, /* DENALI_PHY_91_DATA */ - 0x00000000, /* DENALI_PHY_92_DATA */ - 0x00000000, /* DENALI_PHY_93_DATA */ - 0x00000000, /* DENALI_PHY_94_DATA */ - 0x00000000, /* DENALI_PHY_95_DATA */ - 0x00000000, /* DENALI_PHY_96_DATA */ - 0x00000000, /* DENALI_PHY_97_DATA */ - 0x00000000, /* DENALI_PHY_98_DATA */ - 0x00000000, /* DENALI_PHY_99_DATA */ - 0x00000000, /* DENALI_PHY_100_DATA */ - 0x00000000, /* DENALI_PHY_101_DATA */ - 0x00000000, /* DENALI_PHY_102_DATA */ - 0x00000000, /* DENALI_PHY_103_DATA */ - 0x00000000, /* DENALI_PHY_104_DATA */ - 0x00000000, /* DENALI_PHY_105_DATA */ - 0x00000000, /* DENALI_PHY_106_DATA */ - 0x00000000, /* DENALI_PHY_107_DATA */ - 0x00000000, /* DENALI_PHY_108_DATA */ - 0x00000000, /* DENALI_PHY_109_DATA */ - 0x00000000, /* DENALI_PHY_110_DATA */ - 0x00000000, /* DENALI_PHY_111_DATA */ - 0x00000000, /* DENALI_PHY_112_DATA */ - 0x00000000, /* DENALI_PHY_113_DATA */ - 0x00000000, /* DENALI_PHY_114_DATA */ - 0x00000000, /* DENALI_PHY_115_DATA */ - 0x00000000, /* DENALI_PHY_116_DATA */ - 0x00000000, /* DENALI_PHY_117_DATA */ - 0x00000000, /* DENALI_PHY_118_DATA */ - 0x00000000, /* DENALI_PHY_119_DATA */ - 0x00000000, /* DENALI_PHY_120_DATA */ - 0x00000000, /* DENALI_PHY_121_DATA */ - 0x00000000, /* DENALI_PHY_122_DATA */ - 0x00000000, /* DENALI_PHY_123_DATA */ - 0x00000000, /* DENALI_PHY_124_DATA */ - 0x00000000, /* DENALI_PHY_125_DATA */ - 0x00000000, /* DENALI_PHY_126_DATA */ - 0x00000000, /* DENALI_PHY_127_DATA */ - 0x76543210, /* DENALI_PHY_128_DATA */ - 0x0004c008, /* DENALI_PHY_129_DATA */ - 0x00000080, /* DENALI_PHY_130_DATA */ - 0x00000000, /* DENALI_PHY_131_DATA */ - 0x00000000, /* DENALI_PHY_132_DATA */ - 0x00010000, /* DENALI_PHY_133_DATA */ - 0x01665555, /* DENALI_PHY_134_DATA */ - 0x00665555, /* DENALI_PHY_135_DATA */ - 0x00010f00, /* DENALI_PHY_136_DATA */ - 0x04000100, /* DENALI_PHY_137_DATA */ - 0x00000001, /* DENALI_PHY_138_DATA */ - 0x001700c0, /* DENALI_PHY_139_DATA */ - 0x00cc0101, /* DENALI_PHY_140_DATA */ - 0x00030066, /* DENALI_PHY_141_DATA */ - 0x00000000, /* DENALI_PHY_142_DATA */ - 0x00000000, /* DENALI_PHY_143_DATA */ - 0x00000000, /* DENALI_PHY_144_DATA */ - 0x00000000, /* DENALI_PHY_145_DATA */ - 0x00000000, /* DENALI_PHY_146_DATA */ - 0x00000000, /* DENALI_PHY_147_DATA */ - 0x00000000, /* DENALI_PHY_148_DATA */ - 0x00000000, /* DENALI_PHY_149_DATA */ - 0x04080000, /* DENALI_PHY_150_DATA */ - 0x04080400, /* DENALI_PHY_151_DATA */ - 0x08000000, /* DENALI_PHY_152_DATA */ - 0x0c00c007, /* DENALI_PHY_153_DATA */ - 0x00000100, /* DENALI_PHY_154_DATA */ - 0x00000100, /* DENALI_PHY_155_DATA */ - 0x55555555, /* DENALI_PHY_156_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_157_DATA */ - 0x55555555, /* DENALI_PHY_158_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_159_DATA */ - 0x00005555, /* DENALI_PHY_160_DATA */ - 0x00000000, /* DENALI_PHY_161_DATA */ - 0x00000000, /* DENALI_PHY_162_DATA */ - 0x00000000, /* DENALI_PHY_163_DATA */ - 0x00000000, /* DENALI_PHY_164_DATA */ - 0x00000000, /* DENALI_PHY_165_DATA */ - 0x00000000, /* DENALI_PHY_166_DATA */ - 0x00000000, /* DENALI_PHY_167_DATA */ - 0x00000000, /* DENALI_PHY_168_DATA */ - 0x00000000, /* DENALI_PHY_169_DATA */ - 0x00000000, /* DENALI_PHY_170_DATA */ - 0x00000000, /* DENALI_PHY_171_DATA */ - 0x00000000, /* DENALI_PHY_172_DATA */ - 0x00000000, /* DENALI_PHY_173_DATA */ - 0x00000000, /* DENALI_PHY_174_DATA */ - 0x00000000, /* DENALI_PHY_175_DATA */ - 0x00000000, /* DENALI_PHY_176_DATA */ - 0x00000000, /* DENALI_PHY_177_DATA */ - 0x00000000, /* DENALI_PHY_178_DATA */ - 0x00000000, /* DENALI_PHY_179_DATA */ - 0x00200000, /* DENALI_PHY_180_DATA */ - 0x00000000, /* DENALI_PHY_181_DATA */ - 0x00000000, /* DENALI_PHY_182_DATA */ - 0x00000000, /* DENALI_PHY_183_DATA */ - 0x00000000, /* DENALI_PHY_184_DATA */ - 0x00000000, /* DENALI_PHY_185_DATA */ - 0x00000000, /* DENALI_PHY_186_DATA */ - 0x02800280, /* DENALI_PHY_187_DATA */ - 0x02800280, /* DENALI_PHY_188_DATA */ - 0x02800280, /* DENALI_PHY_189_DATA */ - 0x02800280, /* DENALI_PHY_190_DATA */ - 0x00000280, /* DENALI_PHY_191_DATA */ - 0x00000000, /* DENALI_PHY_192_DATA */ - 0x00000000, /* DENALI_PHY_193_DATA */ - 0x00000000, /* DENALI_PHY_194_DATA */ - 0x00000000, /* DENALI_PHY_195_DATA */ - 0x00800000, /* DENALI_PHY_196_DATA */ - 0x00800080, /* DENALI_PHY_197_DATA */ - 0x00800080, /* DENALI_PHY_198_DATA */ - 0x00800080, /* DENALI_PHY_199_DATA */ - 0x00800080, /* DENALI_PHY_200_DATA */ - 0x00800080, /* DENALI_PHY_201_DATA */ - 0x00800080, /* DENALI_PHY_202_DATA */ - 0x00800080, /* DENALI_PHY_203_DATA */ - 0x00800080, /* DENALI_PHY_204_DATA */ - 0x00800080, /* DENALI_PHY_205_DATA */ - 0x01900001, /* DENALI_PHY_206_DATA */ - 0x00000000, /* DENALI_PHY_207_DATA */ - 0x00000000, /* DENALI_PHY_208_DATA */ - 0x00000200, /* DENALI_PHY_209_DATA */ - 0x00000000, /* DENALI_PHY_210_DATA */ - 0x51315152, /* DENALI_PHY_211_DATA */ - 0xc0003150, /* DENALI_PHY_212_DATA */ - 0x010000c0, /* DENALI_PHY_213_DATA */ - 0x00100000, /* DENALI_PHY_214_DATA */ - 0x0c044208, /* DENALI_PHY_215_DATA */ - 0x000f0c18, /* DENALI_PHY_216_DATA */ - 0x01000140, /* DENALI_PHY_217_DATA */ - 0x00000c20, /* DENALI_PHY_218_DATA */ - 0x00000000, /* DENALI_PHY_219_DATA */ - 0x00000000, /* DENALI_PHY_220_DATA */ - 0x00000000, /* DENALI_PHY_221_DATA */ - 0x00000000, /* DENALI_PHY_222_DATA */ - 0x00000000, /* DENALI_PHY_223_DATA */ - 0x00000000, /* DENALI_PHY_224_DATA */ - 0x00000000, /* DENALI_PHY_225_DATA */ - 0x00000000, /* DENALI_PHY_226_DATA */ - 0x00000000, /* DENALI_PHY_227_DATA */ - 0x00000000, /* DENALI_PHY_228_DATA */ - 0x00000000, /* DENALI_PHY_229_DATA */ - 0x00000000, /* DENALI_PHY_230_DATA */ - 0x00000000, /* DENALI_PHY_231_DATA */ - 0x00000000, /* DENALI_PHY_232_DATA */ - 0x00000000, /* DENALI_PHY_233_DATA */ - 0x00000000, /* DENALI_PHY_234_DATA */ - 0x00000000, /* DENALI_PHY_235_DATA */ - 0x00000000, /* DENALI_PHY_236_DATA */ - 0x00000000, /* DENALI_PHY_237_DATA */ - 0x00000000, /* DENALI_PHY_238_DATA */ - 0x00000000, /* DENALI_PHY_239_DATA */ - 0x00000000, /* DENALI_PHY_240_DATA */ - 0x00000000, /* DENALI_PHY_241_DATA */ - 0x00000000, /* DENALI_PHY_242_DATA */ - 0x00000000, /* DENALI_PHY_243_DATA */ - 0x00000000, /* DENALI_PHY_244_DATA */ - 0x00000000, /* DENALI_PHY_245_DATA */ - 0x00000000, /* DENALI_PHY_246_DATA */ - 0x00000000, /* DENALI_PHY_247_DATA */ - 0x00000000, /* DENALI_PHY_248_DATA */ - 0x00000000, /* DENALI_PHY_249_DATA */ - 0x00000000, /* DENALI_PHY_250_DATA */ - 0x00000000, /* DENALI_PHY_251_DATA */ - 0x00000000, /* DENALI_PHY_252_DATA */ - 0x00000000, /* DENALI_PHY_253_DATA */ - 0x00000000, /* DENALI_PHY_254_DATA */ - 0x00000000, /* DENALI_PHY_255_DATA */ - 0x76543210, /* DENALI_PHY_256_DATA */ - 0x0004c008, /* DENALI_PHY_257_DATA */ - 0x00000080, /* DENALI_PHY_258_DATA */ - 0x00000000, /* DENALI_PHY_259_DATA */ - 0x00000000, /* DENALI_PHY_260_DATA */ - 0x00010000, /* DENALI_PHY_261_DATA */ - 0x01665555, /* DENALI_PHY_262_DATA */ - 0x00665555, /* DENALI_PHY_263_DATA */ - 0x00010f00, /* DENALI_PHY_264_DATA */ - 0x04000100, /* DENALI_PHY_265_DATA */ - 0x00000001, /* DENALI_PHY_266_DATA */ - 0x001700c0, /* DENALI_PHY_267_DATA */ - 0x00cc0101, /* DENALI_PHY_268_DATA */ - 0x00030066, /* DENALI_PHY_269_DATA */ - 0x00000000, /* DENALI_PHY_270_DATA */ - 0x00000000, /* DENALI_PHY_271_DATA */ - 0x00000000, /* DENALI_PHY_272_DATA */ - 0x00000000, /* DENALI_PHY_273_DATA */ - 0x00000000, /* DENALI_PHY_274_DATA */ - 0x00000000, /* DENALI_PHY_275_DATA */ - 0x00000000, /* DENALI_PHY_276_DATA */ - 0x00000000, /* DENALI_PHY_277_DATA */ - 0x04080000, /* DENALI_PHY_278_DATA */ - 0x04080400, /* DENALI_PHY_279_DATA */ - 0x08000000, /* DENALI_PHY_280_DATA */ - 0x0c00c007, /* DENALI_PHY_281_DATA */ - 0x00000100, /* DENALI_PHY_282_DATA */ - 0x00000100, /* DENALI_PHY_283_DATA */ - 0x55555555, /* DENALI_PHY_284_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_285_DATA */ - 0x55555555, /* DENALI_PHY_286_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_287_DATA */ - 0x00005555, /* DENALI_PHY_288_DATA */ - 0x00000000, /* DENALI_PHY_289_DATA */ - 0x00000000, /* DENALI_PHY_290_DATA */ - 0x00000000, /* DENALI_PHY_291_DATA */ - 0x00000000, /* DENALI_PHY_292_DATA */ - 0x00000000, /* DENALI_PHY_293_DATA */ - 0x00000000, /* DENALI_PHY_294_DATA */ - 0x00000000, /* DENALI_PHY_295_DATA */ - 0x00000000, /* DENALI_PHY_296_DATA */ - 0x00000000, /* DENALI_PHY_297_DATA */ - 0x00000000, /* DENALI_PHY_298_DATA */ - 0x00000000, /* DENALI_PHY_299_DATA */ - 0x00000000, /* DENALI_PHY_300_DATA */ - 0x00000000, /* DENALI_PHY_301_DATA */ - 0x00000000, /* DENALI_PHY_302_DATA */ - 0x00000000, /* DENALI_PHY_303_DATA */ - 0x00000000, /* DENALI_PHY_304_DATA */ - 0x00000000, /* DENALI_PHY_305_DATA */ - 0x00000000, /* DENALI_PHY_306_DATA */ - 0x00000000, /* DENALI_PHY_307_DATA */ - 0x00200000, /* DENALI_PHY_308_DATA */ - 0x00000000, /* DENALI_PHY_309_DATA */ - 0x00000000, /* DENALI_PHY_310_DATA */ - 0x00000000, /* DENALI_PHY_311_DATA */ - 0x00000000, /* DENALI_PHY_312_DATA */ - 0x00000000, /* DENALI_PHY_313_DATA */ - 0x00000000, /* DENALI_PHY_314_DATA */ - 0x02800280, /* DENALI_PHY_315_DATA */ - 0x02800280, /* DENALI_PHY_316_DATA */ - 0x02800280, /* DENALI_PHY_317_DATA */ - 0x02800280, /* DENALI_PHY_318_DATA */ - 0x00000280, /* DENALI_PHY_319_DATA */ - 0x00000000, /* DENALI_PHY_320_DATA */ - 0x00000000, /* DENALI_PHY_321_DATA */ - 0x00000000, /* DENALI_PHY_322_DATA */ - 0x00000000, /* DENALI_PHY_323_DATA */ - 0x00800000, /* DENALI_PHY_324_DATA */ - 0x00800080, /* DENALI_PHY_325_DATA */ - 0x00800080, /* DENALI_PHY_326_DATA */ - 0x00800080, /* DENALI_PHY_327_DATA */ - 0x00800080, /* DENALI_PHY_328_DATA */ - 0x00800080, /* DENALI_PHY_329_DATA */ - 0x00800080, /* DENALI_PHY_330_DATA */ - 0x00800080, /* DENALI_PHY_331_DATA */ - 0x00800080, /* DENALI_PHY_332_DATA */ - 0x00800080, /* DENALI_PHY_333_DATA */ - 0x01900001, /* DENALI_PHY_334_DATA */ - 0x00000000, /* DENALI_PHY_335_DATA */ - 0x00000000, /* DENALI_PHY_336_DATA */ - 0x00000200, /* DENALI_PHY_337_DATA */ - 0x00000000, /* DENALI_PHY_338_DATA */ - 0x51315152, /* DENALI_PHY_339_DATA */ - 0xc0003150, /* DENALI_PHY_340_DATA */ - 0x010000c0, /* DENALI_PHY_341_DATA */ - 0x00100000, /* DENALI_PHY_342_DATA */ - 0x0c044208, /* DENALI_PHY_343_DATA */ - 0x000f0c18, /* DENALI_PHY_344_DATA */ - 0x01000140, /* DENALI_PHY_345_DATA */ - 0x00000c20, /* DENALI_PHY_346_DATA */ - 0x00000000, /* DENALI_PHY_347_DATA */ - 0x00000000, /* DENALI_PHY_348_DATA */ - 0x00000000, /* DENALI_PHY_349_DATA */ - 0x00000000, /* DENALI_PHY_350_DATA */ - 0x00000000, /* DENALI_PHY_351_DATA */ - 0x00000000, /* DENALI_PHY_352_DATA */ - 0x00000000, /* DENALI_PHY_353_DATA */ - 0x00000000, /* DENALI_PHY_354_DATA */ - 0x00000000, /* DENALI_PHY_355_DATA */ - 0x00000000, /* DENALI_PHY_356_DATA */ - 0x00000000, /* DENALI_PHY_357_DATA */ - 0x00000000, /* DENALI_PHY_358_DATA */ - 0x00000000, /* DENALI_PHY_359_DATA */ - 0x00000000, /* DENALI_PHY_360_DATA */ - 0x00000000, /* DENALI_PHY_361_DATA */ - 0x00000000, /* DENALI_PHY_362_DATA */ - 0x00000000, /* DENALI_PHY_363_DATA */ - 0x00000000, /* DENALI_PHY_364_DATA */ - 0x00000000, /* DENALI_PHY_365_DATA */ - 0x00000000, /* DENALI_PHY_366_DATA */ - 0x00000000, /* DENALI_PHY_367_DATA */ - 0x00000000, /* DENALI_PHY_368_DATA */ - 0x00000000, /* DENALI_PHY_369_DATA */ - 0x00000000, /* DENALI_PHY_370_DATA */ - 0x00000000, /* DENALI_PHY_371_DATA */ - 0x00000000, /* DENALI_PHY_372_DATA */ - 0x00000000, /* DENALI_PHY_373_DATA */ - 0x00000000, /* DENALI_PHY_374_DATA */ - 0x00000000, /* DENALI_PHY_375_DATA */ - 0x00000000, /* DENALI_PHY_376_DATA */ - 0x00000000, /* DENALI_PHY_377_DATA */ - 0x00000000, /* DENALI_PHY_378_DATA */ - 0x00000000, /* DENALI_PHY_379_DATA */ - 0x00000000, /* DENALI_PHY_380_DATA */ - 0x00000000, /* DENALI_PHY_381_DATA */ - 0x00000000, /* DENALI_PHY_382_DATA */ - 0x00000000, /* DENALI_PHY_383_DATA */ - 0x76543210, /* DENALI_PHY_384_DATA */ - 0x0004c008, /* DENALI_PHY_385_DATA */ - 0x00000080, /* DENALI_PHY_386_DATA */ - 0x00000000, /* DENALI_PHY_387_DATA */ - 0x00000000, /* DENALI_PHY_388_DATA */ - 0x00010000, /* DENALI_PHY_389_DATA */ - 0x01665555, /* DENALI_PHY_390_DATA */ - 0x00665555, /* DENALI_PHY_391_DATA */ - 0x00010f00, /* DENALI_PHY_392_DATA */ - 0x04000100, /* DENALI_PHY_393_DATA */ - 0x00000001, /* DENALI_PHY_394_DATA */ - 0x001700c0, /* DENALI_PHY_395_DATA */ - 0x00cc0101, /* DENALI_PHY_396_DATA */ - 0x00030066, /* DENALI_PHY_397_DATA */ - 0x00000000, /* DENALI_PHY_398_DATA */ - 0x00000000, /* DENALI_PHY_399_DATA */ - 0x00000000, /* DENALI_PHY_400_DATA */ - 0x00000000, /* DENALI_PHY_401_DATA */ - 0x00000000, /* DENALI_PHY_402_DATA */ - 0x00000000, /* DENALI_PHY_403_DATA */ - 0x00000000, /* DENALI_PHY_404_DATA */ - 0x00000000, /* DENALI_PHY_405_DATA */ - 0x04080000, /* DENALI_PHY_406_DATA */ - 0x04080400, /* DENALI_PHY_407_DATA */ - 0x08000000, /* DENALI_PHY_408_DATA */ - 0x0c00c007, /* DENALI_PHY_409_DATA */ - 0x00000100, /* DENALI_PHY_410_DATA */ - 0x00000100, /* DENALI_PHY_411_DATA */ - 0x55555555, /* DENALI_PHY_412_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_413_DATA */ - 0x55555555, /* DENALI_PHY_414_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_415_DATA */ - 0x00005555, /* DENALI_PHY_416_DATA */ - 0x00000000, /* DENALI_PHY_417_DATA */ - 0x00000000, /* DENALI_PHY_418_DATA */ - 0x00000000, /* DENALI_PHY_419_DATA */ - 0x00000000, /* DENALI_PHY_420_DATA */ - 0x00000000, /* DENALI_PHY_421_DATA */ - 0x00000000, /* DENALI_PHY_422_DATA */ - 0x00000000, /* DENALI_PHY_423_DATA */ - 0x00000000, /* DENALI_PHY_424_DATA */ - 0x00000000, /* DENALI_PHY_425_DATA */ - 0x00000000, /* DENALI_PHY_426_DATA */ - 0x00000000, /* DENALI_PHY_427_DATA */ - 0x00000000, /* DENALI_PHY_428_DATA */ - 0x00000000, /* DENALI_PHY_429_DATA */ - 0x00000000, /* DENALI_PHY_430_DATA */ - 0x00000000, /* DENALI_PHY_431_DATA */ - 0x00000000, /* DENALI_PHY_432_DATA */ - 0x00000000, /* DENALI_PHY_433_DATA */ - 0x00000000, /* DENALI_PHY_434_DATA */ - 0x00000000, /* DENALI_PHY_435_DATA */ - 0x00200000, /* DENALI_PHY_436_DATA */ - 0x00000000, /* DENALI_PHY_437_DATA */ - 0x00000000, /* DENALI_PHY_438_DATA */ - 0x00000000, /* DENALI_PHY_439_DATA */ - 0x00000000, /* DENALI_PHY_440_DATA */ - 0x00000000, /* DENALI_PHY_441_DATA */ - 0x00000000, /* DENALI_PHY_442_DATA */ - 0x02800280, /* DENALI_PHY_443_DATA */ - 0x02800280, /* DENALI_PHY_444_DATA */ - 0x02800280, /* DENALI_PHY_445_DATA */ - 0x02800280, /* DENALI_PHY_446_DATA */ - 0x00000280, /* DENALI_PHY_447_DATA */ - 0x00000000, /* DENALI_PHY_448_DATA */ - 0x00000000, /* DENALI_PHY_449_DATA */ - 0x00000000, /* DENALI_PHY_450_DATA */ - 0x00000000, /* DENALI_PHY_451_DATA */ - 0x00800000, /* DENALI_PHY_452_DATA */ - 0x00800080, /* DENALI_PHY_453_DATA */ - 0x00800080, /* DENALI_PHY_454_DATA */ - 0x00800080, /* DENALI_PHY_455_DATA */ - 0x00800080, /* DENALI_PHY_456_DATA */ - 0x00800080, /* DENALI_PHY_457_DATA */ - 0x00800080, /* DENALI_PHY_458_DATA */ - 0x00800080, /* DENALI_PHY_459_DATA */ - 0x00800080, /* DENALI_PHY_460_DATA */ - 0x00800080, /* DENALI_PHY_461_DATA */ - 0x01900001, /* DENALI_PHY_462_DATA */ - 0x00000000, /* DENALI_PHY_463_DATA */ - 0x00000000, /* DENALI_PHY_464_DATA */ - 0x00000200, /* DENALI_PHY_465_DATA */ - 0x00000000, /* DENALI_PHY_466_DATA */ - 0x51315152, /* DENALI_PHY_467_DATA */ - 0xc0003150, /* DENALI_PHY_468_DATA */ - 0x010000c0, /* DENALI_PHY_469_DATA */ - 0x00100000, /* DENALI_PHY_470_DATA */ - 0x0c044208, /* DENALI_PHY_471_DATA */ - 0x000f0c18, /* DENALI_PHY_472_DATA */ - 0x01000140, /* DENALI_PHY_473_DATA */ - 0x00000c20, /* DENALI_PHY_474_DATA */ - 0x00000000, /* DENALI_PHY_475_DATA */ - 0x00000000, /* DENALI_PHY_476_DATA */ - 0x00000000, /* DENALI_PHY_477_DATA */ - 0x00000000, /* DENALI_PHY_478_DATA */ - 0x00000000, /* DENALI_PHY_479_DATA */ - 0x00000000, /* DENALI_PHY_480_DATA */ - 0x00000000, /* DENALI_PHY_481_DATA */ - 0x00000000, /* DENALI_PHY_482_DATA */ - 0x00000000, /* DENALI_PHY_483_DATA */ - 0x00000000, /* DENALI_PHY_484_DATA */ - 0x00000000, /* DENALI_PHY_485_DATA */ - 0x00000000, /* DENALI_PHY_486_DATA */ - 0x00000000, /* DENALI_PHY_487_DATA */ - 0x00000000, /* DENALI_PHY_488_DATA */ - 0x00000000, /* DENALI_PHY_489_DATA */ - 0x00000000, /* DENALI_PHY_490_DATA */ - 0x00000000, /* DENALI_PHY_491_DATA */ - 0x00000000, /* DENALI_PHY_492_DATA */ - 0x00000000, /* DENALI_PHY_493_DATA */ - 0x00000000, /* DENALI_PHY_494_DATA */ - 0x00000000, /* DENALI_PHY_495_DATA */ - 0x00000000, /* DENALI_PHY_496_DATA */ - 0x00000000, /* DENALI_PHY_497_DATA */ - 0x00000000, /* DENALI_PHY_498_DATA */ - 0x00000000, /* DENALI_PHY_499_DATA */ - 0x00000000, /* DENALI_PHY_500_DATA */ - 0x00000000, /* DENALI_PHY_501_DATA */ - 0x00000000, /* DENALI_PHY_502_DATA */ - 0x00000000, /* DENALI_PHY_503_DATA */ - 0x00000000, /* DENALI_PHY_504_DATA */ - 0x00000000, /* DENALI_PHY_505_DATA */ - 0x00000000, /* DENALI_PHY_506_DATA */ - 0x00000000, /* DENALI_PHY_507_DATA */ - 0x00000000, /* DENALI_PHY_508_DATA */ - 0x00000000, /* DENALI_PHY_509_DATA */ - 0x00000000, /* DENALI_PHY_510_DATA */ - 0x00000000, /* DENALI_PHY_511_DATA */ - 0x00000000, /* DENALI_PHY_512_DATA */ - 0x00800000, /* DENALI_PHY_513_DATA */ - 0x00000000, /* DENALI_PHY_514_DATA */ - 0x00000000, /* DENALI_PHY_515_DATA */ - 0x00000000, /* DENALI_PHY_516_DATA */ - 0x00000000, /* DENALI_PHY_517_DATA */ - 0x00000000, /* DENALI_PHY_518_DATA */ - 0x00000001, /* DENALI_PHY_519_DATA */ - 0x00000000, /* DENALI_PHY_520_DATA */ - 0x00000000, /* DENALI_PHY_521_DATA */ - 0x00000000, /* DENALI_PHY_522_DATA */ - 0x00400320, /* DENALI_PHY_523_DATA */ - 0x00000040, /* DENALI_PHY_524_DATA */ - 0x00806420, /* DENALI_PHY_525_DATA */ - 0x00917531, /* DENALI_PHY_526_DATA */ - 0x00806420, /* DENALI_PHY_527_DATA */ - 0x01917531, /* DENALI_PHY_528_DATA */ - 0x00020003, /* DENALI_PHY_529_DATA */ - 0x00000000, /* DENALI_PHY_530_DATA */ - 0x00000000, /* DENALI_PHY_531_DATA */ - 0x00000000, /* DENALI_PHY_532_DATA */ - 0x000556aa, /* DENALI_PHY_533_DATA */ - 0x000aaaaa, /* DENALI_PHY_534_DATA */ - 0x000aa955, /* DENALI_PHY_535_DATA */ - 0x00055555, /* DENALI_PHY_536_DATA */ - 0x000b3133, /* DENALI_PHY_537_DATA */ - 0x0004cd33, /* DENALI_PHY_538_DATA */ - 0x0004cecc, /* DENALI_PHY_539_DATA */ - 0x000b32cc, /* DENALI_PHY_540_DATA */ - 0x0a418820, /* DENALI_PHY_541_DATA */ - 0x103f0000, /* DENALI_PHY_542_DATA */ - 0x0000003f, /* DENALI_PHY_543_DATA */ - 0x00038055, /* DENALI_PHY_544_DATA */ - 0x03800380, /* DENALI_PHY_545_DATA */ - 0x03800380, /* DENALI_PHY_546_DATA */ - 0x00000380, /* DENALI_PHY_547_DATA */ - 0x42080010, /* DENALI_PHY_548_DATA */ - 0x00000003, /* DENALI_PHY_549_DATA */ - 0x00000000, /* DENALI_PHY_550_DATA */ - 0x00000000, /* DENALI_PHY_551_DATA */ - 0x00000000, /* DENALI_PHY_552_DATA */ - 0x00000000, /* DENALI_PHY_553_DATA */ - 0x00000000, /* DENALI_PHY_554_DATA */ - 0x00000000, /* DENALI_PHY_555_DATA */ - 0x00000000, /* DENALI_PHY_556_DATA */ - 0x00000000, /* DENALI_PHY_557_DATA */ - 0x00000000, /* DENALI_PHY_558_DATA */ - 0x00000000, /* DENALI_PHY_559_DATA */ - 0x00000000, /* DENALI_PHY_560_DATA */ - 0x00000000, /* DENALI_PHY_561_DATA */ - 0x00000000, /* DENALI_PHY_562_DATA */ - 0x00000000, /* DENALI_PHY_563_DATA */ - 0x00000000, /* DENALI_PHY_564_DATA */ - 0x00000000, /* DENALI_PHY_565_DATA */ - 0x00000000, /* DENALI_PHY_566_DATA */ - 0x00000000, /* DENALI_PHY_567_DATA */ - 0x00000000, /* DENALI_PHY_568_DATA */ - 0x00000000, /* DENALI_PHY_569_DATA */ - 0x00000000, /* DENALI_PHY_570_DATA */ - 0x00000000, /* DENALI_PHY_571_DATA */ - 0x00000000, /* DENALI_PHY_572_DATA */ - 0x00000000, /* DENALI_PHY_573_DATA */ - 0x00000000, /* DENALI_PHY_574_DATA */ - 0x00000000, /* DENALI_PHY_575_DATA */ - 0x00000000, /* DENALI_PHY_576_DATA */ - 0x00000000, /* DENALI_PHY_577_DATA */ - 0x00000000, /* DENALI_PHY_578_DATA */ - 0x00000000, /* DENALI_PHY_579_DATA */ - 0x00000000, /* DENALI_PHY_580_DATA */ - 0x00000000, /* DENALI_PHY_581_DATA */ - 0x00000000, /* DENALI_PHY_582_DATA */ - 0x00000000, /* DENALI_PHY_583_DATA */ - 0x00000000, /* DENALI_PHY_584_DATA */ - 0x00000000, /* DENALI_PHY_585_DATA */ - 0x00000000, /* DENALI_PHY_586_DATA */ - 0x00000000, /* DENALI_PHY_587_DATA */ - 0x00000000, /* DENALI_PHY_588_DATA */ - 0x00000000, /* DENALI_PHY_589_DATA */ - 0x00000000, /* DENALI_PHY_590_DATA */ - 0x00000000, /* DENALI_PHY_591_DATA */ - 0x00000000, /* DENALI_PHY_592_DATA */ - 0x00000000, /* DENALI_PHY_593_DATA */ - 0x00000000, /* DENALI_PHY_594_DATA */ - 0x00000000, /* DENALI_PHY_595_DATA */ - 0x00000000, /* DENALI_PHY_596_DATA */ - 0x00000000, /* DENALI_PHY_597_DATA */ - 0x00000000, /* DENALI_PHY_598_DATA */ - 0x00000000, /* DENALI_PHY_599_DATA */ - 0x00000000, /* DENALI_PHY_600_DATA */ - 0x00000000, /* DENALI_PHY_601_DATA */ - 0x00000000, /* DENALI_PHY_602_DATA */ - 0x00000000, /* DENALI_PHY_603_DATA */ - 0x00000000, /* DENALI_PHY_604_DATA */ - 0x00000000, /* DENALI_PHY_605_DATA */ - 0x00000000, /* DENALI_PHY_606_DATA */ - 0x00000000, /* DENALI_PHY_607_DATA */ - 0x00000000, /* DENALI_PHY_608_DATA */ - 0x00000000, /* DENALI_PHY_609_DATA */ - 0x00000000, /* DENALI_PHY_610_DATA */ - 0x00000000, /* DENALI_PHY_611_DATA */ - 0x00000000, /* DENALI_PHY_612_DATA */ - 0x00000000, /* DENALI_PHY_613_DATA */ - 0x00000000, /* DENALI_PHY_614_DATA */ - 0x00000000, /* DENALI_PHY_615_DATA */ - 0x00000000, /* DENALI_PHY_616_DATA */ - 0x00000000, /* DENALI_PHY_617_DATA */ - 0x00000000, /* DENALI_PHY_618_DATA */ - 0x00000000, /* DENALI_PHY_619_DATA */ - 0x00000000, /* DENALI_PHY_620_DATA */ - 0x00000000, /* DENALI_PHY_621_DATA */ - 0x00000000, /* DENALI_PHY_622_DATA */ - 0x00000000, /* DENALI_PHY_623_DATA */ - 0x00000000, /* DENALI_PHY_624_DATA */ - 0x00000000, /* DENALI_PHY_625_DATA */ - 0x00000000, /* DENALI_PHY_626_DATA */ - 0x00000000, /* DENALI_PHY_627_DATA */ - 0x00000000, /* DENALI_PHY_628_DATA */ - 0x00000000, /* DENALI_PHY_629_DATA */ - 0x00000000, /* DENALI_PHY_630_DATA */ - 0x00000000, /* DENALI_PHY_631_DATA */ - 0x00000000, /* DENALI_PHY_632_DATA */ - 0x00000000, /* DENALI_PHY_633_DATA */ - 0x00000000, /* DENALI_PHY_634_DATA */ - 0x00000000, /* DENALI_PHY_635_DATA */ - 0x00000000, /* DENALI_PHY_636_DATA */ - 0x00000000, /* DENALI_PHY_637_DATA */ - 0x00000000, /* DENALI_PHY_638_DATA */ - 0x00000000, /* DENALI_PHY_639_DATA */ - 0x00000000, /* DENALI_PHY_640_DATA */ - 0x00800000, /* DENALI_PHY_641_DATA */ - 0x00000000, /* DENALI_PHY_642_DATA */ - 0x00000000, /* DENALI_PHY_643_DATA */ - 0x00000000, /* DENALI_PHY_644_DATA */ - 0x00000000, /* DENALI_PHY_645_DATA */ - 0x00000000, /* DENALI_PHY_646_DATA */ - 0x00000001, /* DENALI_PHY_647_DATA */ - 0x00000000, /* DENALI_PHY_648_DATA */ - 0x00000000, /* DENALI_PHY_649_DATA */ - 0x00000000, /* DENALI_PHY_650_DATA */ - 0x00400320, /* DENALI_PHY_651_DATA */ - 0x00000040, /* DENALI_PHY_652_DATA */ - 0x00008eca, /* DENALI_PHY_653_DATA */ - 0x00009fdb, /* DENALI_PHY_654_DATA */ - 0x00008eca, /* DENALI_PHY_655_DATA */ - 0x01009fdb, /* DENALI_PHY_656_DATA */ - 0x00020003, /* DENALI_PHY_657_DATA */ - 0x00000000, /* DENALI_PHY_658_DATA */ - 0x00000000, /* DENALI_PHY_659_DATA */ - 0x00000000, /* DENALI_PHY_660_DATA */ - 0x000556aa, /* DENALI_PHY_661_DATA */ - 0x000aaaaa, /* DENALI_PHY_662_DATA */ - 0x000aa955, /* DENALI_PHY_663_DATA */ - 0x00055555, /* DENALI_PHY_664_DATA */ - 0x000b3133, /* DENALI_PHY_665_DATA */ - 0x0004cd33, /* DENALI_PHY_666_DATA */ - 0x0004cecc, /* DENALI_PHY_667_DATA */ - 0x000b32cc, /* DENALI_PHY_668_DATA */ - 0x0004a0e6, /* DENALI_PHY_669_DATA */ - 0x080f0000, /* DENALI_PHY_670_DATA */ - 0x0000000f, /* DENALI_PHY_671_DATA */ - 0x00038055, /* DENALI_PHY_672_DATA */ - 0x03800380, /* DENALI_PHY_673_DATA */ - 0x03800380, /* DENALI_PHY_674_DATA */ - 0x00000380, /* DENALI_PHY_675_DATA */ - 0x42080010, /* DENALI_PHY_676_DATA */ - 0x00000003, /* DENALI_PHY_677_DATA */ - 0x00000000, /* DENALI_PHY_678_DATA */ - 0x00000000, /* DENALI_PHY_679_DATA */ - 0x00000000, /* DENALI_PHY_680_DATA */ - 0x00000000, /* DENALI_PHY_681_DATA */ - 0x00000000, /* DENALI_PHY_682_DATA */ - 0x00000000, /* DENALI_PHY_683_DATA */ - 0x00000000, /* DENALI_PHY_684_DATA */ - 0x00000000, /* DENALI_PHY_685_DATA */ - 0x00000000, /* DENALI_PHY_686_DATA */ - 0x00000000, /* DENALI_PHY_687_DATA */ - 0x00000000, /* DENALI_PHY_688_DATA */ - 0x00000000, /* DENALI_PHY_689_DATA */ - 0x00000000, /* DENALI_PHY_690_DATA */ - 0x00000000, /* DENALI_PHY_691_DATA */ - 0x00000000, /* DENALI_PHY_692_DATA */ - 0x00000000, /* DENALI_PHY_693_DATA */ - 0x00000000, /* DENALI_PHY_694_DATA */ - 0x00000000, /* DENALI_PHY_695_DATA */ - 0x00000000, /* DENALI_PHY_696_DATA */ - 0x00000000, /* DENALI_PHY_697_DATA */ - 0x00000000, /* DENALI_PHY_698_DATA */ - 0x00000000, /* DENALI_PHY_699_DATA */ - 0x00000000, /* DENALI_PHY_700_DATA */ - 0x00000000, /* DENALI_PHY_701_DATA */ - 0x00000000, /* DENALI_PHY_702_DATA */ - 0x00000000, /* DENALI_PHY_703_DATA */ - 0x00000000, /* DENALI_PHY_704_DATA */ - 0x00000000, /* DENALI_PHY_705_DATA */ - 0x00000000, /* DENALI_PHY_706_DATA */ - 0x00000000, /* DENALI_PHY_707_DATA */ - 0x00000000, /* DENALI_PHY_708_DATA */ - 0x00000000, /* DENALI_PHY_709_DATA */ - 0x00000000, /* DENALI_PHY_710_DATA */ - 0x00000000, /* DENALI_PHY_711_DATA */ - 0x00000000, /* DENALI_PHY_712_DATA */ - 0x00000000, /* DENALI_PHY_713_DATA */ - 0x00000000, /* DENALI_PHY_714_DATA */ - 0x00000000, /* DENALI_PHY_715_DATA */ - 0x00000000, /* DENALI_PHY_716_DATA */ - 0x00000000, /* DENALI_PHY_717_DATA */ - 0x00000000, /* DENALI_PHY_718_DATA */ - 0x00000000, /* DENALI_PHY_719_DATA */ - 0x00000000, /* DENALI_PHY_720_DATA */ - 0x00000000, /* DENALI_PHY_721_DATA */ - 0x00000000, /* DENALI_PHY_722_DATA */ - 0x00000000, /* DENALI_PHY_723_DATA */ - 0x00000000, /* DENALI_PHY_724_DATA */ - 0x00000000, /* DENALI_PHY_725_DATA */ - 0x00000000, /* DENALI_PHY_726_DATA */ - 0x00000000, /* DENALI_PHY_727_DATA */ - 0x00000000, /* DENALI_PHY_728_DATA */ - 0x00000000, /* DENALI_PHY_729_DATA */ - 0x00000000, /* DENALI_PHY_730_DATA */ - 0x00000000, /* DENALI_PHY_731_DATA */ - 0x00000000, /* DENALI_PHY_732_DATA */ - 0x00000000, /* DENALI_PHY_733_DATA */ - 0x00000000, /* DENALI_PHY_734_DATA */ - 0x00000000, /* DENALI_PHY_735_DATA */ - 0x00000000, /* DENALI_PHY_736_DATA */ - 0x00000000, /* DENALI_PHY_737_DATA */ - 0x00000000, /* DENALI_PHY_738_DATA */ - 0x00000000, /* DENALI_PHY_739_DATA */ - 0x00000000, /* DENALI_PHY_740_DATA */ - 0x00000000, /* DENALI_PHY_741_DATA */ - 0x00000000, /* DENALI_PHY_742_DATA */ - 0x00000000, /* DENALI_PHY_743_DATA */ - 0x00000000, /* DENALI_PHY_744_DATA */ - 0x00000000, /* DENALI_PHY_745_DATA */ - 0x00000000, /* DENALI_PHY_746_DATA */ - 0x00000000, /* DENALI_PHY_747_DATA */ - 0x00000000, /* DENALI_PHY_748_DATA */ - 0x00000000, /* DENALI_PHY_749_DATA */ - 0x00000000, /* DENALI_PHY_750_DATA */ - 0x00000000, /* DENALI_PHY_751_DATA */ - 0x00000000, /* DENALI_PHY_752_DATA */ - 0x00000000, /* DENALI_PHY_753_DATA */ - 0x00000000, /* DENALI_PHY_754_DATA */ - 0x00000000, /* DENALI_PHY_755_DATA */ - 0x00000000, /* DENALI_PHY_756_DATA */ - 0x00000000, /* DENALI_PHY_757_DATA */ - 0x00000000, /* DENALI_PHY_758_DATA */ - 0x00000000, /* DENALI_PHY_759_DATA */ - 0x00000000, /* DENALI_PHY_760_DATA */ - 0x00000000, /* DENALI_PHY_761_DATA */ - 0x00000000, /* DENALI_PHY_762_DATA */ - 0x00000000, /* DENALI_PHY_763_DATA */ - 0x00000000, /* DENALI_PHY_764_DATA */ - 0x00000000, /* DENALI_PHY_765_DATA */ - 0x00000000, /* DENALI_PHY_766_DATA */ - 0x00000000, /* DENALI_PHY_767_DATA */ - 0x00000000, /* DENALI_PHY_768_DATA */ - 0x00800000, /* DENALI_PHY_769_DATA */ - 0x00000000, /* DENALI_PHY_770_DATA */ - 0x00000000, /* DENALI_PHY_771_DATA */ - 0x00000000, /* DENALI_PHY_772_DATA */ - 0x00000000, /* DENALI_PHY_773_DATA */ - 0x00000000, /* DENALI_PHY_774_DATA */ - 0x00000001, /* DENALI_PHY_775_DATA */ - 0x00000000, /* DENALI_PHY_776_DATA */ - 0x00000000, /* DENALI_PHY_777_DATA */ - 0x00000000, /* DENALI_PHY_778_DATA */ - 0x00400320, /* DENALI_PHY_779_DATA */ - 0x00000040, /* DENALI_PHY_780_DATA */ - 0x00008eca, /* DENALI_PHY_781_DATA */ - 0x00009fdb, /* DENALI_PHY_782_DATA */ - 0x00008eca, /* DENALI_PHY_783_DATA */ - 0x01009fdb, /* DENALI_PHY_784_DATA */ - 0x00020003, /* DENALI_PHY_785_DATA */ - 0x00000000, /* DENALI_PHY_786_DATA */ - 0x00000000, /* DENALI_PHY_787_DATA */ - 0x00000000, /* DENALI_PHY_788_DATA */ - 0x000556aa, /* DENALI_PHY_789_DATA */ - 0x000aaaaa, /* DENALI_PHY_790_DATA */ - 0x000aa955, /* DENALI_PHY_791_DATA */ - 0x00055555, /* DENALI_PHY_792_DATA */ - 0x000b3133, /* DENALI_PHY_793_DATA */ - 0x0004cd33, /* DENALI_PHY_794_DATA */ - 0x0004cecc, /* DENALI_PHY_795_DATA */ - 0x000b32cc, /* DENALI_PHY_796_DATA */ - 0x1ee6b16a, /* DENALI_PHY_797_DATA */ - 0x10000000, /* DENALI_PHY_798_DATA */ - 0x00000000, /* DENALI_PHY_799_DATA */ - 0x00038055, /* DENALI_PHY_800_DATA */ - 0x03800380, /* DENALI_PHY_801_DATA */ - 0x03800380, /* DENALI_PHY_802_DATA */ - 0x00000380, /* DENALI_PHY_803_DATA */ - 0x42080010, /* DENALI_PHY_804_DATA */ - 0x00000003, /* DENALI_PHY_805_DATA */ - 0x00000000, /* DENALI_PHY_806_DATA */ - 0x00000000, /* DENALI_PHY_807_DATA */ - 0x00000000, /* DENALI_PHY_808_DATA */ - 0x00000000, /* DENALI_PHY_809_DATA */ - 0x00000000, /* DENALI_PHY_810_DATA */ - 0x00000000, /* DENALI_PHY_811_DATA */ - 0x00000000, /* DENALI_PHY_812_DATA */ - 0x00000000, /* DENALI_PHY_813_DATA */ - 0x00000000, /* DENALI_PHY_814_DATA */ - 0x00000000, /* DENALI_PHY_815_DATA */ - 0x00000000, /* DENALI_PHY_816_DATA */ - 0x00000000, /* DENALI_PHY_817_DATA */ - 0x00000000, /* DENALI_PHY_818_DATA */ - 0x00000000, /* DENALI_PHY_819_DATA */ - 0x00000000, /* DENALI_PHY_820_DATA */ - 0x00000000, /* DENALI_PHY_821_DATA */ - 0x00000000, /* DENALI_PHY_822_DATA */ - 0x00000000, /* DENALI_PHY_823_DATA */ - 0x00000000, /* DENALI_PHY_824_DATA */ - 0x00000000, /* DENALI_PHY_825_DATA */ - 0x00000000, /* DENALI_PHY_826_DATA */ - 0x00000000, /* DENALI_PHY_827_DATA */ - 0x00000000, /* DENALI_PHY_828_DATA */ - 0x00000000, /* DENALI_PHY_829_DATA */ - 0x00000000, /* DENALI_PHY_830_DATA */ - 0x00000000, /* DENALI_PHY_831_DATA */ - 0x00000000, /* DENALI_PHY_832_DATA */ - 0x00000000, /* DENALI_PHY_833_DATA */ - 0x00000000, /* DENALI_PHY_834_DATA */ - 0x00000000, /* DENALI_PHY_835_DATA */ - 0x00000000, /* DENALI_PHY_836_DATA */ - 0x00000000, /* DENALI_PHY_837_DATA */ - 0x00000000, /* DENALI_PHY_838_DATA */ - 0x00000000, /* DENALI_PHY_839_DATA */ - 0x00000000, /* DENALI_PHY_840_DATA */ - 0x00000000, /* DENALI_PHY_841_DATA */ - 0x00000000, /* DENALI_PHY_842_DATA */ - 0x00000000, /* DENALI_PHY_843_DATA */ - 0x00000000, /* DENALI_PHY_844_DATA */ - 0x00000000, /* DENALI_PHY_845_DATA */ - 0x00000000, /* DENALI_PHY_846_DATA */ - 0x00000000, /* DENALI_PHY_847_DATA */ - 0x00000000, /* DENALI_PHY_848_DATA */ - 0x00000000, /* DENALI_PHY_849_DATA */ - 0x00000000, /* DENALI_PHY_850_DATA */ - 0x00000000, /* DENALI_PHY_851_DATA */ - 0x00000000, /* DENALI_PHY_852_DATA */ - 0x00000000, /* DENALI_PHY_853_DATA */ - 0x00000000, /* DENALI_PHY_854_DATA */ - 0x00000000, /* DENALI_PHY_855_DATA */ - 0x00000000, /* DENALI_PHY_856_DATA */ - 0x00000000, /* DENALI_PHY_857_DATA */ - 0x00000000, /* DENALI_PHY_858_DATA */ - 0x00000000, /* DENALI_PHY_859_DATA */ - 0x00000000, /* DENALI_PHY_860_DATA */ - 0x00000000, /* DENALI_PHY_861_DATA */ - 0x00000000, /* DENALI_PHY_862_DATA */ - 0x00000000, /* DENALI_PHY_863_DATA */ - 0x00000000, /* DENALI_PHY_864_DATA */ - 0x00000000, /* DENALI_PHY_865_DATA */ - 0x00000000, /* DENALI_PHY_866_DATA */ - 0x00000000, /* DENALI_PHY_867_DATA */ - 0x00000000, /* DENALI_PHY_868_DATA */ - 0x00000000, /* DENALI_PHY_869_DATA */ - 0x00000000, /* DENALI_PHY_870_DATA */ - 0x00000000, /* DENALI_PHY_871_DATA */ - 0x00000000, /* DENALI_PHY_872_DATA */ - 0x00000000, /* DENALI_PHY_873_DATA */ - 0x00000000, /* DENALI_PHY_874_DATA */ - 0x00000000, /* DENALI_PHY_875_DATA */ - 0x00000000, /* DENALI_PHY_876_DATA */ - 0x00000000, /* DENALI_PHY_877_DATA */ - 0x00000000, /* DENALI_PHY_878_DATA */ - 0x00000000, /* DENALI_PHY_879_DATA */ - 0x00000000, /* DENALI_PHY_880_DATA */ - 0x00000000, /* DENALI_PHY_881_DATA */ - 0x00000000, /* DENALI_PHY_882_DATA */ - 0x00000000, /* DENALI_PHY_883_DATA */ - 0x00000000, /* DENALI_PHY_884_DATA */ - 0x00000000, /* DENALI_PHY_885_DATA */ - 0x00000000, /* DENALI_PHY_886_DATA */ - 0x00000000, /* DENALI_PHY_887_DATA */ - 0x00000000, /* DENALI_PHY_888_DATA */ - 0x00000000, /* DENALI_PHY_889_DATA */ - 0x00000000, /* DENALI_PHY_890_DATA */ - 0x00000000, /* DENALI_PHY_891_DATA */ - 0x00000000, /* DENALI_PHY_892_DATA */ - 0x00000000, /* DENALI_PHY_893_DATA */ - 0x00000000, /* DENALI_PHY_894_DATA */ - 0x00000000, /* DENALI_PHY_895_DATA */ - 0x00000001, /* DENALI_PHY_896_DATA */ - 0x00000000, /* DENALI_PHY_897_DATA */ - 0x01000005, /* DENALI_PHY_898_DATA */ - 0x04000f00, /* DENALI_PHY_899_DATA */ - 0x00020040, /* DENALI_PHY_900_DATA */ - 0x00020055, /* DENALI_PHY_901_DATA */ - 0x00000000, /* DENALI_PHY_902_DATA */ - 0x00000000, /* DENALI_PHY_903_DATA */ - 0x00000000, /* DENALI_PHY_904_DATA */ - 0x00000050, /* DENALI_PHY_905_DATA */ - 0x00000000, /* DENALI_PHY_906_DATA */ - 0x00010100, /* DENALI_PHY_907_DATA */ - 0x00000601, /* DENALI_PHY_908_DATA */ - 0x00000000, /* DENALI_PHY_909_DATA */ - 0x00006400, /* DENALI_PHY_910_DATA */ - 0x05221502, /* DENALI_PHY_911_DATA */ - 0x00000000, /* DENALI_PHY_912_DATA */ - 0x00051f01, /* DENALI_PHY_913_DATA */ - 0x051f051f, /* DENALI_PHY_914_DATA */ - 0x051f051f, /* DENALI_PHY_915_DATA */ - 0x00030003, /* DENALI_PHY_916_DATA */ - 0x03000300, /* DENALI_PHY_917_DATA */ - 0x00000300, /* DENALI_PHY_918_DATA */ - 0x05221502, /* DENALI_PHY_919_DATA */ - 0x00000000, /* DENALI_PHY_920_DATA */ - 0x00000000, /* DENALI_PHY_921_DATA */ - 0x01020000, /* DENALI_PHY_922_DATA */ - 0x00000001, /* DENALI_PHY_923_DATA */ - 0x00000011, /* DENALI_PHY_924_DATA */ - 0x00000011, /* DENALI_PHY_925_DATA */ - 0x00000400, /* DENALI_PHY_926_DATA */ - 0x00000000, /* DENALI_PHY_927_DATA */ - 0x00000011, /* DENALI_PHY_928_DATA */ - 0x00000011, /* DENALI_PHY_929_DATA */ - 0x00004410, /* DENALI_PHY_930_DATA */ - 0x00004410, /* DENALI_PHY_931_DATA */ - 0x00004410, /* DENALI_PHY_932_DATA */ - 0x00004410, /* DENALI_PHY_933_DATA */ - 0x00004410, /* DENALI_PHY_934_DATA */ - 0x00000011, /* DENALI_PHY_935_DATA */ - 0x00004410, /* DENALI_PHY_936_DATA */ - 0x00000011, /* DENALI_PHY_937_DATA */ - 0x00004410, /* DENALI_PHY_938_DATA */ - 0x00000011, /* DENALI_PHY_939_DATA */ - 0x00004410, /* DENALI_PHY_940_DATA */ - 0x00000000, /* DENALI_PHY_941_DATA */ - 0x00000000, /* DENALI_PHY_942_DATA */ - 0x00000000, /* DENALI_PHY_943_DATA */ - 0x04000000, /* DENALI_PHY_944_DATA */ - 0x00000000, /* DENALI_PHY_945_DATA */ - 0x00000000, /* DENALI_PHY_946_DATA */ - 0x00000308, /* DENALI_PHY_947_DATA */ - 0x00000000, /* DENALI_PHY_948_DATA */ - 0x00000000, /* DENALI_PHY_949_DATA */ - 0x00000000, /* DENALI_PHY_950_DATA */ - 0x00000000, /* DENALI_PHY_951_DATA */ - 0x00000000, /* DENALI_PHY_952_DATA */ - 0x00000000, /* DENALI_PHY_953_DATA */ - 0xe4000000, /* DENALI_PHY_954_DATA */ - 0x00000000, /* DENALI_PHY_955_DATA */ - 0x00000000, /* DENALI_PHY_956_DATA */ - 0x01010000, /* DENALI_PHY_957_DATA */ - 0x00000000 /* DENALI_PHY_958_DATA */ - } - }, -}, diff --git a/src/mainboard/google/gru/sdram_inf/sdram-lpddr3-hynix-4GB-666-no-odt.c b/src/mainboard/google/gru/sdram_inf/sdram-lpddr3-hynix-4GB-666-no-odt.c new file mode 100644 index 0000000..9b0bfe7 --- /dev/null +++ b/src/mainboard/google/gru/sdram_inf/sdram-lpddr3-hynix-4GB-666-no-odt.c @@ -0,0 +1,1565 @@ +/* + * This file is part of the coreboot project. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <soc/sdram.h> + +struct rk3399_sdram_params params = { + { + { + .rank = 0x2, + .col = 0xA, + .bk = 0x3, + .bw = 0x2, + .dbw = 0x2, + .row_3_4 = 0x0, + .cs0_row = 0xF, + .cs1_row = 0xF, + .ddrconfig = 1, + { + {0x19151115}, + {0x10030806}, + {0x00000002}, + {0x00006206}, + {0x00000054}, + 0x00000000 + } + }, + { + .rank = 0x2, + .col = 0xA, + .bk = 0x3, + .bw = 0x2, + .dbw = 0x2, + .row_3_4 = 0x0, + .cs0_row = 0xF, + .cs1_row = 0xF, + .ddrconfig = 1, + { + {0x19151115}, + {0x10030806}, + {0x00000002}, + {0x00006206}, + {0x00000054}, + 0x00000000 + } + } + }, + .ddr_freq = 666*MHz, + .dramtype = LPDDR3, + .num_channels = 2, + .stride = 13, + .odt = 1, + { + { + 0x00000700, /* DENALI_CTL_00_DATA */ + 0x00000000, /* DENALI_CTL_01_DATA */ + 0x00000000, /* DENALI_CTL_02_DATA */ + 0x00000000, /* DENALI_CTL_03_DATA */ + 0x00000000, /* DENALI_CTL_04_DATA */ + 0x00000043, /* DENALI_CTL_05_DATA */ + 0x000208d6, /* DENALI_CTL_06_DATA */ + 0x0000029b, /* DENALI_CTL_07_DATA */ + 0x00001a0b, /* DENALI_CTL_08_DATA */ + 0x00000028, /* DENALI_CTL_09_DATA */ + 0x00013880, /* DENALI_CTL_10_DATA */ + 0x00000190, /* DENALI_CTL_11_DATA */ + 0x00000fa0, /* DENALI_CTL_12_DATA */ + 0x00000043, /* DENALI_CTL_13_DATA */ + 0x000208d6, /* DENALI_CTL_14_DATA */ + 0x0000029b, /* DENALI_CTL_15_DATA */ + 0x01001a0b, /* DENALI_CTL_16_DATA */ + 0x00000000, /* DENALI_CTL_17_DATA */ + 0x00000101, /* DENALI_CTL_18_DATA */ + 0x00020100, /* DENALI_CTL_19_DATA */ + 0x00000086, /* DENALI_CTL_20_DATA */ + 0x0000014e, /* DENALI_CTL_21_DATA */ + 0x00000000, /* DENALI_CTL_22_DATA */ + 0x06140000, /* DENALI_CTL_23_DATA */ + 0x00061400, /* DENALI_CTL_24_DATA */ + 0x04000614, /* DENALI_CTL_25_DATA */ + 0x2a070004, /* DENALI_CTL_26_DATA */ + 0x220c051c, /* DENALI_CTL_27_DATA */ + 0x111a0400, /* DENALI_CTL_28_DATA */ + 0x00140804, /* DENALI_CTL_29_DATA */ + 0x051c2a07, /* DENALI_CTL_30_DATA */ + 0x0500220c, /* DENALI_CTL_31_DATA */ + 0x00000a0a, /* DENALI_CTL_32_DATA */ + 0x0500b64a, /* DENALI_CTL_33_DATA */ + 0x0a0a040a, /* DENALI_CTL_34_DATA */ + 0x03006d60, /* DENALI_CTL_35_DATA */ + 0x0a0a0506, /* DENALI_CTL_36_DATA */ + 0x0500b64a, /* DENALI_CTL_37_DATA */ + 0x0203000a, /* DENALI_CTL_38_DATA */ + 0x080a0c00, /* DENALI_CTL_39_DATA */ + 0x040a0c06, /* DENALI_CTL_40_DATA */ + 0x14000a0a, /* DENALI_CTL_41_DATA */ + 0x02020a0a, /* DENALI_CTL_42_DATA */ + 0x00010002, /* DENALI_CTL_43_DATA */ + 0x03160e16, /* DENALI_CTL_44_DATA */ + 0x000e090e, /* DENALI_CTL_45_DATA */ + 0x00000000, /* DENALI_CTL_46_DATA */ + 0x03010000, /* DENALI_CTL_47_DATA */ + 0x0a20008c, /* DENALI_CTL_48_DATA */ + 0x06100054, /* DENALI_CTL_49_DATA */ + 0x0a20008c, /* DENALI_CTL_50_DATA */ + 0x00000000, /* DENALI_CTL_51_DATA */ + 0x00030005, /* DENALI_CTL_52_DATA */ + 0x00100005, /* DENALI_CTL_53_DATA */ + 0x0010000a, /* DENALI_CTL_54_DATA */ + 0x000c080c, /* DENALI_CTL_55_DATA */ + 0x00000000, /* DENALI_CTL_56_DATA */ + 0x00000000, /* DENALI_CTL_57_DATA */ + 0x00000000, /* DENALI_CTL_58_DATA */ + 0x00930000, /* DENALI_CTL_59_DATA */ + 0x00580093, /* DENALI_CTL_60_DATA */ + 0x00930058, /* DENALI_CTL_61_DATA */ + 0x00000093, /* DENALI_CTL_62_DATA */ + 0x00000000, /* DENALI_CTL_63_DATA */ + 0x00000000, /* DENALI_CTL_64_DATA */ + 0x00000000, /* DENALI_CTL_65_DATA */ + 0x00000000, /* DENALI_CTL_66_DATA */ + 0x00000000, /* DENALI_CTL_67_DATA */ + 0x00000000, /* DENALI_CTL_68_DATA */ + 0x00000301, /* DENALI_CTL_69_DATA */ + 0x00000001, /* DENALI_CTL_70_DATA */ + 0x00000000, /* DENALI_CTL_71_DATA */ + 0x00000000, /* DENALI_CTL_72_DATA */ + 0x01000000, /* DENALI_CTL_73_DATA */ + 0x80104002, /* DENALI_CTL_74_DATA */ + 0x00040003, /* DENALI_CTL_75_DATA */ + 0x00040005, /* DENALI_CTL_76_DATA */ + 0x00030000, /* DENALI_CTL_77_DATA */ + 0x00050004, /* DENALI_CTL_78_DATA */ + 0x00000004, /* DENALI_CTL_79_DATA */ + 0x00040003, /* DENALI_CTL_80_DATA */ + 0x00040005, /* DENALI_CTL_81_DATA */ + 0x28800000, /* DENALI_CTL_82_DATA */ + 0x00001440, /* DENALI_CTL_83_DATA */ + 0x0c201840, /* DENALI_CTL_84_DATA */ + 0x28800000, /* DENALI_CTL_85_DATA */ + 0x00001440, /* DENALI_CTL_86_DATA */ + 0x00000000, /* DENALI_CTL_87_DATA */ + 0x00000000, /* DENALI_CTL_88_DATA */ + 0x00000000, /* DENALI_CTL_89_DATA */ + 0x00000000, /* DENALI_CTL_90_DATA */ + 0x00000000, /* DENALI_CTL_91_DATA */ + 0x02020200, /* DENALI_CTL_92_DATA */ + 0x00020202, /* DENALI_CTL_93_DATA */ + 0x00030200, /* DENALI_CTL_94_DATA */ + 0x00040700, /* DENALI_CTL_95_DATA */ + 0x00000302, /* DENALI_CTL_96_DATA */ + 0x02000407, /* DENALI_CTL_97_DATA */ + 0x00000003, /* DENALI_CTL_98_DATA */ + 0x00030f04, /* DENALI_CTL_99_DATA */ + 0x00070004, /* DENALI_CTL_100_DATA */ + 0x00000000, /* DENALI_CTL_101_DATA */ + 0x00000000, /* DENALI_CTL_102_DATA */ + 0x00000000, /* DENALI_CTL_103_DATA */ + 0x00000000, /* DENALI_CTL_104_DATA */ + 0x00000000, /* DENALI_CTL_105_DATA */ + 0x00000000, /* DENALI_CTL_106_DATA */ + 0x00000000, /* DENALI_CTL_107_DATA */ + 0x00010000, /* DENALI_CTL_108_DATA */ + 0x20040020, /* DENALI_CTL_109_DATA */ + 0x00200400, /* DENALI_CTL_110_DATA */ + 0x01000400, /* DENALI_CTL_111_DATA */ + 0x00000b80, /* DENALI_CTL_112_DATA */ + 0x00000000, /* DENALI_CTL_113_DATA */ + 0x00000001, /* DENALI_CTL_114_DATA */ + 0x00000002, /* DENALI_CTL_115_DATA */ + 0x0000000e, /* DENALI_CTL_116_DATA */ + 0x00000000, /* DENALI_CTL_117_DATA */ + 0x00000000, /* DENALI_CTL_118_DATA */ + 0x00000000, /* DENALI_CTL_119_DATA */ + 0x00000000, /* DENALI_CTL_120_DATA */ + 0x00000000, /* DENALI_CTL_121_DATA */ + 0x00860000, /* DENALI_CTL_122_DATA */ + 0x00a70043, /* DENALI_CTL_123_DATA */ + 0x00a70000, /* DENALI_CTL_124_DATA */ + 0x00280050, /* DENALI_CTL_125_DATA */ + 0x00000064, /* DENALI_CTL_126_DATA */ + 0x00860064, /* DENALI_CTL_127_DATA */ + 0x00a70043, /* DENALI_CTL_128_DATA */ + 0x00a70000, /* DENALI_CTL_129_DATA */ + 0x00000000, /* DENALI_CTL_130_DATA */ + 0x00000000, /* DENALI_CTL_131_DATA */ + 0x00000000, /* DENALI_CTL_132_DATA */ + 0x00030000, /* DENALI_CTL_133_DATA */ + 0x00000018, /* DENALI_CTL_134_DATA */ + 0x00080083, /* DENALI_CTL_135_DATA */ + 0x00030000, /* DENALI_CTL_136_DATA */ + 0x00000018, /* DENALI_CTL_137_DATA */ + 0x00010001, /* DENALI_CTL_138_DATA */ + 0x07000001, /* DENALI_CTL_139_DATA */ + 0x00000707, /* DENALI_CTL_140_DATA */ + 0x00000000, /* DENALI_CTL_141_DATA */ + 0x00000000, /* DENALI_CTL_142_DATA */ + 0x00000000, /* DENALI_CTL_143_DATA */ + 0x00000000, /* DENALI_CTL_144_DATA */ + 0x00000000, /* DENALI_CTL_145_DATA */ + 0x00000000, /* DENALI_CTL_146_DATA */ + 0x00030000, /* DENALI_CTL_147_DATA */ + 0x00000018, /* DENALI_CTL_148_DATA */ + 0x00080083, /* DENALI_CTL_149_DATA */ + 0x00030000, /* DENALI_CTL_150_DATA */ + 0x00000018, /* DENALI_CTL_151_DATA */ + 0x00010001, /* DENALI_CTL_152_DATA */ + 0x07000001, /* DENALI_CTL_153_DATA */ + 0x00000707, /* DENALI_CTL_154_DATA */ + 0x00000000, /* DENALI_CTL_155_DATA */ + 0x00000000, /* DENALI_CTL_156_DATA */ + 0x00000000, /* DENALI_CTL_157_DATA */ + 0x00000000, /* DENALI_CTL_158_DATA */ + 0x00000000, /* DENALI_CTL_159_DATA */ + 0x00000000, /* DENALI_CTL_160_DATA */ + 0x01000000, /* DENALI_CTL_161_DATA */ + 0x00000000, /* DENALI_CTL_162_DATA */ + 0x00000000, /* DENALI_CTL_163_DATA */ + 0x18151100, /* DENALI_CTL_164_DATA */ + 0x0000000c, /* DENALI_CTL_165_DATA */ + 0x00000000, /* DENALI_CTL_166_DATA */ + 0x00000000, /* DENALI_CTL_167_DATA */ + 0x00000000, /* DENALI_CTL_168_DATA */ + 0x00000000, /* DENALI_CTL_169_DATA */ + 0x00000000, /* DENALI_CTL_170_DATA */ + 0x00000000, /* DENALI_CTL_171_DATA */ + 0x00000000, /* DENALI_CTL_172_DATA */ + 0x00000000, /* DENALI_CTL_173_DATA */ + 0x00000000, /* DENALI_CTL_174_DATA */ + 0x00000000, /* DENALI_CTL_175_DATA */ + 0x00000000, /* DENALI_CTL_176_DATA */ + 0x00000000, /* DENALI_CTL_177_DATA */ + 0x00000000, /* DENALI_CTL_178_DATA */ + 0x00029b03, /* DENALI_CTL_179_DATA */ + 0x003c00f0, /* DENALI_CTL_180_DATA */ + 0x00000000, /* DENALI_CTL_181_DATA */ + 0x00900190, /* DENALI_CTL_182_DATA */ + 0x00000024, /* DENALI_CTL_183_DATA */ + 0x00029b00, /* DENALI_CTL_184_DATA */ + 0x003c00f0, /* DENALI_CTL_185_DATA */ + 0x00000000, /* DENALI_CTL_186_DATA */ + 0x00220000, /* DENALI_CTL_187_DATA */ + 0x00220014, /* DENALI_CTL_188_DATA */ + 0x01010100, /* DENALI_CTL_189_DATA */ + 0x01000202, /* DENALI_CTL_190_DATA */ + 0x0a000002, /* DENALI_CTL_191_DATA */ + 0x01000f0f, /* DENALI_CTL_192_DATA */ + 0x00000000, /* DENALI_CTL_193_DATA */ + 0x00000000, /* DENALI_CTL_194_DATA */ + 0x00010003, /* DENALI_CTL_195_DATA */ + 0x00000c03, /* DENALI_CTL_196_DATA */ + 0x00000100, /* DENALI_CTL_197_DATA */ + 0x00010000, /* DENALI_CTL_198_DATA */ + 0x01000000, /* DENALI_CTL_199_DATA */ + 0x00010000, /* DENALI_CTL_200_DATA */ + 0x00000001, /* DENALI_CTL_201_DATA */ + 0x00000000, /* DENALI_CTL_202_DATA */ + 0x00000000, /* DENALI_CTL_203_DATA */ + 0x00000000, /* DENALI_CTL_204_DATA */ + 0x00000000, /* DENALI_CTL_205_DATA */ + 0x00000000, /* DENALI_CTL_206_DATA */ + 0x00000000, /* DENALI_CTL_207_DATA */ + 0x00000000, /* DENALI_CTL_208_DATA */ + 0x00000000, /* DENALI_CTL_209_DATA */ + 0x00000000, /* DENALI_CTL_210_DATA */ + 0x00010000, /* DENALI_CTL_211_DATA */ + 0x03020301, /* DENALI_CTL_212_DATA */ + 0x01000808, /* DENALI_CTL_213_DATA */ + 0x04030001, /* DENALI_CTL_214_DATA */ + 0x08080803, /* DENALI_CTL_215_DATA */ + 0x02080808, /* DENALI_CTL_216_DATA */ + 0x02050203, /* DENALI_CTL_217_DATA */ + 0x02010303, /* DENALI_CTL_218_DATA */ + 0x00010203, /* DENALI_CTL_219_DATA */ + 0x00020202, /* DENALI_CTL_220_DATA */ + 0x03020400, /* DENALI_CTL_221_DATA */ + 0x00020401, /* DENALI_CTL_222_DATA */ + 0x00000000, /* DENALI_CTL_223_DATA */ + 0x00000000, /* DENALI_CTL_224_DATA */ + 0x0d000001, /* DENALI_CTL_225_DATA */ + 0x00010028, /* DENALI_CTL_226_DATA */ + 0x00010000, /* DENALI_CTL_227_DATA */ + 0x00000003, /* DENALI_CTL_228_DATA */ + 0x00000000, /* DENALI_CTL_229_DATA */ + 0x00000000, /* DENALI_CTL_230_DATA */ + 0x00000000, /* DENALI_CTL_231_DATA */ + 0x00000000, /* DENALI_CTL_232_DATA */ + 0x00000000, /* DENALI_CTL_233_DATA */ + 0x00000000, /* DENALI_CTL_234_DATA */ + 0x00000000, /* DENALI_CTL_235_DATA */ + 0x00000000, /* DENALI_CTL_236_DATA */ + 0x00010100, /* DENALI_CTL_237_DATA */ + 0x01000000, /* DENALI_CTL_238_DATA */ + 0x00000001, /* DENALI_CTL_239_DATA */ + 0x00000303, /* DENALI_CTL_240_DATA */ + 0x00000000, /* DENALI_CTL_241_DATA */ + 0x00000000, /* DENALI_CTL_242_DATA */ + 0x00000000, /* DENALI_CTL_243_DATA */ + 0x00000000, /* DENALI_CTL_244_DATA */ + 0x00000000, /* DENALI_CTL_245_DATA */ + 0x00000000, /* DENALI_CTL_246_DATA */ + 0x00000000, /* DENALI_CTL_247_DATA */ + 0x00000000, /* DENALI_CTL_248_DATA */ + 0x00000000, /* DENALI_CTL_249_DATA */ + 0x00000000, /* DENALI_CTL_250_DATA */ + 0x00000000, /* DENALI_CTL_251_DATA */ + 0x00000000, /* DENALI_CTL_252_DATA */ + 0x00000000, /* DENALI_CTL_253_DATA */ + 0x00000000, /* DENALI_CTL_254_DATA */ + 0x00000000, /* DENALI_CTL_255_DATA */ + 0x000556aa, /* DENALI_CTL_256_DATA */ + 0x000aaaaa, /* DENALI_CTL_257_DATA */ + 0x000aa955, /* DENALI_CTL_258_DATA */ + 0x00055555, /* DENALI_CTL_259_DATA */ + 0x000b3133, /* DENALI_CTL_260_DATA */ + 0x0004cd33, /* DENALI_CTL_261_DATA */ + 0x0004cecc, /* DENALI_CTL_262_DATA */ + 0x000b32cc, /* DENALI_CTL_263_DATA */ + 0x00010300, /* DENALI_CTL_264_DATA */ + 0x03000100, /* DENALI_CTL_265_DATA */ + 0x00000000, /* DENALI_CTL_266_DATA */ + 0x00000000, /* DENALI_CTL_267_DATA */ + 0x00000000, /* DENALI_CTL_268_DATA */ + 0x00000000, /* DENALI_CTL_269_DATA */ + 0x00000000, /* DENALI_CTL_270_DATA */ + 0x00000000, /* DENALI_CTL_271_DATA */ + 0x00000000, /* DENALI_CTL_272_DATA */ + 0x00000000, /* DENALI_CTL_273_DATA */ + 0x00ffff00, /* DENALI_CTL_274_DATA */ + 0x181b0000, /* DENALI_CTL_275_DATA */ + 0x0800001b, /* DENALI_CTL_276_DATA */ + 0x00001440, /* DENALI_CTL_277_DATA */ + 0x00000200, /* DENALI_CTL_278_DATA */ + 0x00000200, /* DENALI_CTL_279_DATA */ + 0x00000200, /* DENALI_CTL_280_DATA */ + 0x00000200, /* DENALI_CTL_281_DATA */ + 0x00001440, /* DENALI_CTL_282_DATA */ + 0x0000ca80, /* DENALI_CTL_283_DATA */ + 0x0c200509, /* DENALI_CTL_284_DATA */ + 0x00000200, /* DENALI_CTL_285_DATA */ + 0x00000200, /* DENALI_CTL_286_DATA */ + 0x00000200, /* DENALI_CTL_287_DATA */ + 0x00000200, /* DENALI_CTL_288_DATA */ + 0x00000c20, /* DENALI_CTL_289_DATA */ + 0x00007940, /* DENALI_CTL_290_DATA */ + 0x14400509, /* DENALI_CTL_291_DATA */ + 0x00000200, /* DENALI_CTL_292_DATA */ + 0x00000200, /* DENALI_CTL_293_DATA */ + 0x00000200, /* DENALI_CTL_294_DATA */ + 0x00000200, /* DENALI_CTL_295_DATA */ + 0x00001440, /* DENALI_CTL_296_DATA */ + 0x0000ca80, /* DENALI_CTL_297_DATA */ + 0x02020509, /* DENALI_CTL_298_DATA */ + 0x03030202, /* DENALI_CTL_299_DATA */ + 0x00000018, /* DENALI_CTL_300_DATA */ + 0x00000000, /* DENALI_CTL_301_DATA */ + 0x00000000, /* DENALI_CTL_302_DATA */ + 0x00001403, /* DENALI_CTL_303_DATA */ + 0x00000000, /* DENALI_CTL_304_DATA */ + 0x00000000, /* DENALI_CTL_305_DATA */ + 0x00000000, /* DENALI_CTL_306_DATA */ + 0x00030000, /* DENALI_CTL_307_DATA */ + 0x000d001f, /* DENALI_CTL_308_DATA */ + 0x000a001c, /* DENALI_CTL_309_DATA */ + 0x000d001f, /* DENALI_CTL_310_DATA */ + 0x00000000, /* DENALI_CTL_311_DATA */ + 0x00000000, /* DENALI_CTL_312_DATA */ + 0x01000000, /* DENALI_CTL_313_DATA */ + 0x00050005, /* DENALI_CTL_314_DATA */ + 0x00050005, /* DENALI_CTL_315_DATA */ + 0x00000000, /* DENALI_CTL_316_DATA */ + 0x00000000, /* DENALI_CTL_317_DATA */ + 0x00000000, /* DENALI_CTL_318_DATA */ + 0x00000000, /* DENALI_CTL_319_DATA */ + 0x00000000, /* DENALI_CTL_320_DATA */ + 0x00000000, /* DENALI_CTL_321_DATA */ + 0x00000000, /* DENALI_CTL_322_DATA */ + 0x00000000, /* DENALI_CTL_323_DATA */ + 0x01000101, /* DENALI_CTL_324_DATA */ + 0x01010101, /* DENALI_CTL_325_DATA */ + 0x01000101, /* DENALI_CTL_326_DATA */ + 0x01000100, /* DENALI_CTL_327_DATA */ + 0x00010001, /* DENALI_CTL_328_DATA */ + 0x00010002, /* DENALI_CTL_329_DATA */ + 0x00020100, /* DENALI_CTL_330_DATA */ + 0x00000002 /* DENALI_CTL_331_DATA */ + } + }, + { + { + 0x00000700, /* DENALI_PI_00_DATA */ + 0x00000000, /* DENALI_PI_01_DATA */ + 0x00002880, /* DENALI_PI_02_DATA */ + 0x00001440, /* DENALI_PI_03_DATA */ + 0x00002880, /* DENALI_PI_04_DATA */ + 0x00001440, /* DENALI_PI_05_DATA */ + 0x00002880, /* DENALI_PI_06_DATA */ + 0x14401440, /* DENALI_PI_07_DATA */ + 0x00000200, /* DENALI_PI_08_DATA */ + 0x00000200, /* DENALI_PI_09_DATA */ + 0x00000200, /* DENALI_PI_10_DATA */ + 0x00000200, /* DENALI_PI_11_DATA */ + 0x00001440, /* DENALI_PI_12_DATA */ + 0x00000200, /* DENALI_PI_13_DATA */ + 0x00000200, /* DENALI_PI_14_DATA */ + 0x00000200, /* DENALI_PI_15_DATA */ + 0x00000200, /* DENALI_PI_16_DATA */ + 0x00001440, /* DENALI_PI_17_DATA */ + 0x00000200, /* DENALI_PI_18_DATA */ + 0x00000200, /* DENALI_PI_19_DATA */ + 0x00000200, /* DENALI_PI_20_DATA */ + 0x00000200, /* DENALI_PI_21_DATA */ + 0x00010000, /* DENALI_PI_22_DATA */ + 0x00000007, /* DENALI_PI_23_DATA */ + 0x81000001, /* DENALI_PI_24_DATA */ + 0x0f0003f0, /* DENALI_PI_25_DATA */ + 0x3fffffff, /* DENALI_PI_26_DATA */ + 0x0f0000a0, /* DENALI_PI_27_DATA */ + 0x377ff000, /* DENALI_PI_28_DATA */ + 0x0f000020, /* DENALI_PI_29_DATA */ + 0x377ff000, /* DENALI_PI_30_DATA */ + 0x0f000030, /* DENALI_PI_31_DATA */ + 0x377ff000, /* DENALI_PI_32_DATA */ + 0x0f0000b0, /* DENALI_PI_33_DATA */ + 0x377ff000, /* DENALI_PI_34_DATA */ + 0x0f000100, /* DENALI_PI_35_DATA */ + 0x377ff000, /* DENALI_PI_36_DATA */ + 0x0f000110, /* DENALI_PI_37_DATA */ + 0x377ff000, /* DENALI_PI_38_DATA */ + 0x0f000010, /* DENALI_PI_39_DATA */ + 0x377ff000, /* DENALI_PI_40_DATA */ + 0x03000101, /* DENALI_PI_41_DATA */ + 0x042a2a2a, /* DENALI_PI_42_DATA */ + 0x06140006, /* DENALI_PI_43_DATA */ + 0x00061400, /* DENALI_PI_44_DATA */ + 0x00000014, /* DENALI_PI_45_DATA */ + 0x0a20008c, /* DENALI_PI_46_DATA */ + 0x0a20008c, /* DENALI_PI_47_DATA */ + 0x0a20008c, /* DENALI_PI_48_DATA */ + 0x00000500, /* DENALI_PI_49_DATA */ + 0x00000000, /* DENALI_PI_50_DATA */ + 0x00000000, /* DENALI_PI_51_DATA */ + 0x00000000, /* DENALI_PI_52_DATA */ + 0x00000000, /* DENALI_PI_53_DATA */ + 0x00000000, /* DENALI_PI_54_DATA */ + 0x00000000, /* DENALI_PI_55_DATA */ + 0x00000000, /* DENALI_PI_56_DATA */ + 0x00000000, /* DENALI_PI_57_DATA */ + 0x04040000, /* DENALI_PI_58_DATA */ + 0x0d000004, /* DENALI_PI_59_DATA */ + 0x00000128, /* DENALI_PI_60_DATA */ + 0x00000000, /* DENALI_PI_61_DATA */ + 0x00030003, /* DENALI_PI_62_DATA */ + 0x00000018, /* DENALI_PI_63_DATA */ + 0x00000000, /* DENALI_PI_64_DATA */ + 0x00000000, /* DENALI_PI_65_DATA */ + 0x03060002, /* DENALI_PI_66_DATA */ + 0x03010301, /* DENALI_PI_67_DATA */ + 0x01080801, /* DENALI_PI_68_DATA */ + 0x04020201, /* DENALI_PI_69_DATA */ + 0x01080804, /* DENALI_PI_70_DATA */ + 0x00000000, /* DENALI_PI_71_DATA */ + 0x03030000, /* DENALI_PI_72_DATA */ + 0x08080803, /* DENALI_PI_73_DATA */ + 0x00000000, /* DENALI_PI_74_DATA */ + 0x00000000, /* DENALI_PI_75_DATA */ + 0x00000000, /* DENALI_PI_76_DATA */ + 0x00030300, /* DENALI_PI_77_DATA */ + 0x00000014, /* DENALI_PI_78_DATA */ + 0x00000000, /* DENALI_PI_79_DATA */ + 0x01010300, /* DENALI_PI_80_DATA */ + 0x00000000, /* DENALI_PI_81_DATA */ + 0x00000000, /* DENALI_PI_82_DATA */ + 0x01000000, /* DENALI_PI_83_DATA */ + 0x00000101, /* DENALI_PI_84_DATA */ + 0x55555a5a, /* DENALI_PI_85_DATA */ + 0x55555a5a, /* DENALI_PI_86_DATA */ + 0x55555a5a, /* DENALI_PI_87_DATA */ + 0x55555a5a, /* DENALI_PI_88_DATA */ + 0x09090001, /* DENALI_PI_89_DATA */ + 0x05050009, /* DENALI_PI_90_DATA */ + 0x00000005, /* DENALI_PI_91_DATA */ + 0x00000100, /* DENALI_PI_92_DATA */ + 0x00030000, /* DENALI_PI_93_DATA */ + 0x17030000, /* DENALI_PI_94_DATA */ + 0x000d001f, /* DENALI_PI_95_DATA */ + 0x000d001f, /* DENALI_PI_96_DATA */ + 0x000d001f, /* DENALI_PI_97_DATA */ + 0x00000000, /* DENALI_PI_98_DATA */ + 0x00000000, /* DENALI_PI_99_DATA */ + 0x00000100, /* DENALI_PI_100_DATA */ + 0x140a0000, /* DENALI_PI_101_DATA */ + 0x000a020a, /* DENALI_PI_102_DATA */ + 0x02000a02, /* DENALI_PI_103_DATA */ + 0x010a000a, /* DENALI_PI_104_DATA */ + 0x00000100, /* DENALI_PI_105_DATA */ + 0x01000000, /* DENALI_PI_106_DATA */ + 0x00000000, /* DENALI_PI_107_DATA */ + 0x00000100, /* DENALI_PI_108_DATA */ + 0x1e1a0000, /* DENALI_PI_109_DATA */ + 0x10010204, /* DENALI_PI_110_DATA */ + 0x07070705, /* DENALI_PI_111_DATA */ + 0x20000202, /* DENALI_PI_112_DATA */ + 0x00201000, /* DENALI_PI_113_DATA */ + 0x00201000, /* DENALI_PI_114_DATA */ + 0x04041000, /* DENALI_PI_115_DATA */ + 0x0f0f0100, /* DENALI_PI_116_DATA */ + 0x0001010f, /* DENALI_PI_117_DATA */ + 0x004b004a, /* DENALI_PI_118_DATA */ + 0x1a030000, /* DENALI_PI_119_DATA */ + 0x0102041e, /* DENALI_PI_120_DATA */ + 0x34000000, /* DENALI_PI_121_DATA */ + 0x00000000, /* DENALI_PI_122_DATA */ + 0x00000000, /* DENALI_PI_123_DATA */ + 0x00000000, /* DENALI_PI_124_DATA */ + 0x00000300, /* DENALI_PI_125_DATA */ + 0x00010018, /* DENALI_PI_126_DATA */ + 0x004d4d07, /* DENALI_PI_127_DATA */ + 0x00180003, /* DENALI_PI_128_DATA */ + 0x4d070001, /* DENALI_PI_129_DATA */ + 0x0000034d, /* DENALI_PI_130_DATA */ + 0x00010018, /* DENALI_PI_131_DATA */ + 0x004d4d07, /* DENALI_PI_132_DATA */ + 0x00180003, /* DENALI_PI_133_DATA */ + 0x4d070001, /* DENALI_PI_134_DATA */ + 0x0000034d, /* DENALI_PI_135_DATA */ + 0x00010018, /* DENALI_PI_136_DATA */ + 0x004d4d07, /* DENALI_PI_137_DATA */ + 0x00180003, /* DENALI_PI_138_DATA */ + 0x4d070001, /* DENALI_PI_139_DATA */ + 0x0003004d, /* DENALI_PI_140_DATA */ + 0x00010018, /* DENALI_PI_141_DATA */ + 0x004d4d07, /* DENALI_PI_142_DATA */ + 0x00180003, /* DENALI_PI_143_DATA */ + 0x4d070001, /* DENALI_PI_144_DATA */ + 0x0000034d, /* DENALI_PI_145_DATA */ + 0x00010018, /* DENALI_PI_146_DATA */ + 0x004d4d07, /* DENALI_PI_147_DATA */ + 0x00180003, /* DENALI_PI_148_DATA */ + 0x4d070001, /* DENALI_PI_149_DATA */ + 0x0000034d, /* DENALI_PI_150_DATA */ + 0x00010018, /* DENALI_PI_151_DATA */ + 0x004d4d07, /* DENALI_PI_152_DATA */ + 0x00180003, /* DENALI_PI_153_DATA */ + 0x4d070001, /* DENALI_PI_154_DATA */ + 0x0100004d, /* DENALI_PI_155_DATA */ + 0x00a700a7, /* DENALI_PI_156_DATA */ + 0x050400a7, /* DENALI_PI_157_DATA */ + 0x0a050c0e, /* DENALI_PI_158_DATA */ + 0x1c00b477, /* DENALI_PI_159_DATA */ + 0x0a0a2004, /* DENALI_PI_160_DATA */ + 0x0c0e050a, /* DENALI_PI_161_DATA */ + 0x00000a05, /* DENALI_PI_162_DATA */ + 0x1c00b477, /* DENALI_PI_163_DATA */ + 0x0a0a2004, /* DENALI_PI_164_DATA */ + 0x0c0e050a, /* DENALI_PI_165_DATA */ + 0x00000a05, /* DENALI_PI_166_DATA */ + 0x1c00b477, /* DENALI_PI_167_DATA */ + 0x0a0a2004, /* DENALI_PI_168_DATA */ + 0x0200020a, /* DENALI_PI_169_DATA */ + 0x02000200, /* DENALI_PI_170_DATA */ + 0x02000200, /* DENALI_PI_171_DATA */ + 0x02000200, /* DENALI_PI_172_DATA */ + 0x02000200, /* DENALI_PI_173_DATA */ + 0x00000000, /* DENALI_PI_174_DATA */ + 0x00000000, /* DENALI_PI_175_DATA */ + 0x00000000, /* DENALI_PI_176_DATA */ + 0x00000000, /* DENALI_PI_177_DATA */ + 0x00000000, /* DENALI_PI_178_DATA */ + 0x00000000, /* DENALI_PI_179_DATA */ + 0x00000000, /* DENALI_PI_180_DATA */ + 0x00000000, /* DENALI_PI_181_DATA */ + 0x00000000, /* DENALI_PI_182_DATA */ + 0x00000000, /* DENALI_PI_183_DATA */ + 0x00000000, /* DENALI_PI_184_DATA */ + 0x00000000, /* DENALI_PI_185_DATA */ + 0x01000300, /* DENALI_PI_186_DATA */ + 0x00144000, /* DENALI_PI_187_DATA */ + 0x0000ca80, /* DENALI_PI_188_DATA */ + 0x00001440, /* DENALI_PI_189_DATA */ + 0x0000ca80, /* DENALI_PI_190_DATA */ + 0x00001440, /* DENALI_PI_191_DATA */ + 0x0000ca80, /* DENALI_PI_192_DATA */ + 0x08000000, /* DENALI_PI_193_DATA */ + 0x00000100, /* DENALI_PI_194_DATA */ + 0x00000000, /* DENALI_PI_195_DATA */ + 0x00000000, /* DENALI_PI_196_DATA */ + 0x00000000, /* DENALI_PI_197_DATA */ + 0x00000000, /* DENALI_PI_198_DATA */ + 0x00000002 /* DENALI_PI_199_DATA */ + } + }, + { + { + 0x76543210, /* DENALI_PHY_00_DATA */ + 0x0004c008, /* DENALI_PHY_01_DATA */ + 0x000001c4, /* DENALI_PHY_02_DATA */ + 0x00000000, /* DENALI_PHY_03_DATA */ + 0x00000000, /* DENALI_PHY_04_DATA */ + 0x00010000, /* DENALI_PHY_05_DATA */ + 0x01665555, /* DENALI_PHY_06_DATA */ + 0x00665555, /* DENALI_PHY_07_DATA */ + 0x00010f00, /* DENALI_PHY_08_DATA */ + 0x05000100, /* DENALI_PHY_09_DATA */ + 0x00000002, /* DENALI_PHY_10_DATA */ + 0x001700c0, /* DENALI_PHY_11_DATA */ + 0x00cc0101, /* DENALI_PHY_12_DATA */ + 0x00030066, /* DENALI_PHY_13_DATA */ + 0x00000000, /* DENALI_PHY_14_DATA */ + 0x00000000, /* DENALI_PHY_15_DATA */ + 0x00000000, /* DENALI_PHY_16_DATA */ + 0x00000000, /* DENALI_PHY_17_DATA */ + 0x00000000, /* DENALI_PHY_18_DATA */ + 0x00000000, /* DENALI_PHY_19_DATA */ + 0x00000000, /* DENALI_PHY_20_DATA */ + 0x00000000, /* DENALI_PHY_21_DATA */ + 0x04080000, /* DENALI_PHY_22_DATA */ + 0x04080400, /* DENALI_PHY_23_DATA */ + 0x08000000, /* DENALI_PHY_24_DATA */ + 0x0c00c007, /* DENALI_PHY_25_DATA */ + 0x00000100, /* DENALI_PHY_26_DATA */ + 0x00000100, /* DENALI_PHY_27_DATA */ + 0x55555555, /* DENALI_PHY_28_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_29_DATA */ + 0x55555555, /* DENALI_PHY_30_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_31_DATA */ + 0x00005555, /* DENALI_PHY_32_DATA */ + 0x00000000, /* DENALI_PHY_33_DATA */ + 0x00000000, /* DENALI_PHY_34_DATA */ + 0x00000000, /* DENALI_PHY_35_DATA */ + 0x00000000, /* DENALI_PHY_36_DATA */ + 0x00000000, /* DENALI_PHY_37_DATA */ + 0x00000000, /* DENALI_PHY_38_DATA */ + 0x00000000, /* DENALI_PHY_39_DATA */ + 0x00000000, /* DENALI_PHY_40_DATA */ + 0x00000000, /* DENALI_PHY_41_DATA */ + 0x00000000, /* DENALI_PHY_42_DATA */ + 0x00000000, /* DENALI_PHY_43_DATA */ + 0x00000000, /* DENALI_PHY_44_DATA */ + 0x00000000, /* DENALI_PHY_45_DATA */ + 0x00000000, /* DENALI_PHY_46_DATA */ + 0x00000000, /* DENALI_PHY_47_DATA */ + 0x00000000, /* DENALI_PHY_48_DATA */ + 0x00000000, /* DENALI_PHY_49_DATA */ + 0x00000000, /* DENALI_PHY_50_DATA */ + 0x00000000, /* DENALI_PHY_51_DATA */ + 0x00200000, /* DENALI_PHY_52_DATA */ + 0x00000000, /* DENALI_PHY_53_DATA */ + 0x00000000, /* DENALI_PHY_54_DATA */ + 0x00000000, /* DENALI_PHY_55_DATA */ + 0x00000000, /* DENALI_PHY_56_DATA */ + 0x00000000, /* DENALI_PHY_57_DATA */ + 0x00000000, /* DENALI_PHY_58_DATA */ + 0x02800280, /* DENALI_PHY_59_DATA */ + 0x02800280, /* DENALI_PHY_60_DATA */ + 0x02800280, /* DENALI_PHY_61_DATA */ + 0x02800280, /* DENALI_PHY_62_DATA */ + 0x00000280, /* DENALI_PHY_63_DATA */ + 0x00000000, /* DENALI_PHY_64_DATA */ + 0x00000000, /* DENALI_PHY_65_DATA */ + 0x00000000, /* DENALI_PHY_66_DATA */ + 0x00000000, /* DENALI_PHY_67_DATA */ + 0x00800000, /* DENALI_PHY_68_DATA */ + 0x00800080, /* DENALI_PHY_69_DATA */ + 0x00800080, /* DENALI_PHY_70_DATA */ + 0x00800080, /* DENALI_PHY_71_DATA */ + 0x00800080, /* DENALI_PHY_72_DATA */ + 0x00800080, /* DENALI_PHY_73_DATA */ + 0x00800080, /* DENALI_PHY_74_DATA */ + 0x00800080, /* DENALI_PHY_75_DATA */ + 0x00800080, /* DENALI_PHY_76_DATA */ + 0x01c40080, /* DENALI_PHY_77_DATA */ + 0x01900002, /* DENALI_PHY_78_DATA */ + 0x00000000, /* DENALI_PHY_79_DATA */ + 0x00020000, /* DENALI_PHY_80_DATA */ + 0x00000200, /* DENALI_PHY_81_DATA */ + 0x00000000, /* DENALI_PHY_82_DATA */ + 0x51315152, /* DENALI_PHY_83_DATA */ + 0xc0013150, /* DENALI_PHY_84_DATA */ + 0x010000c0, /* DENALI_PHY_85_DATA */ + 0x00100000, /* DENALI_PHY_86_DATA */ + 0x0c054208, /* DENALI_PHY_87_DATA */ + 0x000f0c18, /* DENALI_PHY_88_DATA */ + 0x01000140, /* DENALI_PHY_89_DATA */ + 0x00000c20, /* DENALI_PHY_90_DATA */ + 0x00000000, /* DENALI_PHY_91_DATA */ + 0x00000000, /* DENALI_PHY_92_DATA */ + 0x00000000, /* DENALI_PHY_93_DATA */ + 0x00000000, /* DENALI_PHY_94_DATA */ + 0x00000000, /* DENALI_PHY_95_DATA */ + 0x00000000, /* DENALI_PHY_96_DATA */ + 0x00000000, /* DENALI_PHY_97_DATA */ + 0x00000000, /* DENALI_PHY_98_DATA */ + 0x00000000, /* DENALI_PHY_99_DATA */ + 0x00000000, /* DENALI_PHY_100_DATA */ + 0x00000000, /* DENALI_PHY_101_DATA */ + 0x00000000, /* DENALI_PHY_102_DATA */ + 0x00000000, /* DENALI_PHY_103_DATA */ + 0x00000000, /* DENALI_PHY_104_DATA */ + 0x00000000, /* DENALI_PHY_105_DATA */ + 0x00000000, /* DENALI_PHY_106_DATA */ + 0x00000000, /* DENALI_PHY_107_DATA */ + 0x00000000, /* DENALI_PHY_108_DATA */ + 0x00000000, /* DENALI_PHY_109_DATA */ + 0x00000000, /* DENALI_PHY_110_DATA */ + 0x00000000, /* DENALI_PHY_111_DATA */ + 0x00000000, /* DENALI_PHY_112_DATA */ + 0x00000000, /* DENALI_PHY_113_DATA */ + 0x00000000, /* DENALI_PHY_114_DATA */ + 0x00000000, /* DENALI_PHY_115_DATA */ + 0x00000000, /* DENALI_PHY_116_DATA */ + 0x00000000, /* DENALI_PHY_117_DATA */ + 0x00000000, /* DENALI_PHY_118_DATA */ + 0x00000000, /* DENALI_PHY_119_DATA */ + 0x00000000, /* DENALI_PHY_120_DATA */ + 0x00000000, /* DENALI_PHY_121_DATA */ + 0x00000000, /* DENALI_PHY_122_DATA */ + 0x00000000, /* DENALI_PHY_123_DATA */ + 0x00000000, /* DENALI_PHY_124_DATA */ + 0x00000000, /* DENALI_PHY_125_DATA */ + 0x00000000, /* DENALI_PHY_126_DATA */ + 0x00000000, /* DENALI_PHY_127_DATA */ + 0x76543210, /* DENALI_PHY_128_DATA */ + 0x0004c008, /* DENALI_PHY_129_DATA */ + 0x000001c4, /* DENALI_PHY_130_DATA */ + 0x00000000, /* DENALI_PHY_131_DATA */ + 0x00000000, /* DENALI_PHY_132_DATA */ + 0x00010000, /* DENALI_PHY_133_DATA */ + 0x01665555, /* DENALI_PHY_134_DATA */ + 0x00665555, /* DENALI_PHY_135_DATA */ + 0x00010f00, /* DENALI_PHY_136_DATA */ + 0x05000100, /* DENALI_PHY_137_DATA */ + 0x00000002, /* DENALI_PHY_138_DATA */ + 0x001700c0, /* DENALI_PHY_139_DATA */ + 0x00cc0101, /* DENALI_PHY_140_DATA */ + 0x00030066, /* DENALI_PHY_141_DATA */ + 0x00000000, /* DENALI_PHY_142_DATA */ + 0x00000000, /* DENALI_PHY_143_DATA */ + 0x00000000, /* DENALI_PHY_144_DATA */ + 0x00000000, /* DENALI_PHY_145_DATA */ + 0x00000000, /* DENALI_PHY_146_DATA */ + 0x00000000, /* DENALI_PHY_147_DATA */ + 0x00000000, /* DENALI_PHY_148_DATA */ + 0x00000000, /* DENALI_PHY_149_DATA */ + 0x04080000, /* DENALI_PHY_150_DATA */ + 0x04080400, /* DENALI_PHY_151_DATA */ + 0x08000000, /* DENALI_PHY_152_DATA */ + 0x0c00c007, /* DENALI_PHY_153_DATA */ + 0x00000100, /* DENALI_PHY_154_DATA */ + 0x00000100, /* DENALI_PHY_155_DATA */ + 0x55555555, /* DENALI_PHY_156_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_157_DATA */ + 0x55555555, /* DENALI_PHY_158_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_159_DATA */ + 0x00005555, /* DENALI_PHY_160_DATA */ + 0x00000000, /* DENALI_PHY_161_DATA */ + 0x00000000, /* DENALI_PHY_162_DATA */ + 0x00000000, /* DENALI_PHY_163_DATA */ + 0x00000000, /* DENALI_PHY_164_DATA */ + 0x00000000, /* DENALI_PHY_165_DATA */ + 0x00000000, /* DENALI_PHY_166_DATA */ + 0x00000000, /* DENALI_PHY_167_DATA */ + 0x00000000, /* DENALI_PHY_168_DATA */ + 0x00000000, /* DENALI_PHY_169_DATA */ + 0x00000000, /* DENALI_PHY_170_DATA */ + 0x00000000, /* DENALI_PHY_171_DATA */ + 0x00000000, /* DENALI_PHY_172_DATA */ + 0x00000000, /* DENALI_PHY_173_DATA */ + 0x00000000, /* DENALI_PHY_174_DATA */ + 0x00000000, /* DENALI_PHY_175_DATA */ + 0x00000000, /* DENALI_PHY_176_DATA */ + 0x00000000, /* DENALI_PHY_177_DATA */ + 0x00000000, /* DENALI_PHY_178_DATA */ + 0x00000000, /* DENALI_PHY_179_DATA */ + 0x00200000, /* DENALI_PHY_180_DATA */ + 0x00000000, /* DENALI_PHY_181_DATA */ + 0x00000000, /* DENALI_PHY_182_DATA */ + 0x00000000, /* DENALI_PHY_183_DATA */ + 0x00000000, /* DENALI_PHY_184_DATA */ + 0x00000000, /* DENALI_PHY_185_DATA */ + 0x00000000, /* DENALI_PHY_186_DATA */ + 0x02800280, /* DENALI_PHY_187_DATA */ + 0x02800280, /* DENALI_PHY_188_DATA */ + 0x02800280, /* DENALI_PHY_189_DATA */ + 0x02800280, /* DENALI_PHY_190_DATA */ + 0x00000280, /* DENALI_PHY_191_DATA */ + 0x00000000, /* DENALI_PHY_192_DATA */ + 0x00000000, /* DENALI_PHY_193_DATA */ + 0x00000000, /* DENALI_PHY_194_DATA */ + 0x00000000, /* DENALI_PHY_195_DATA */ + 0x00800000, /* DENALI_PHY_196_DATA */ + 0x00800080, /* DENALI_PHY_197_DATA */ + 0x00800080, /* DENALI_PHY_198_DATA */ + 0x00800080, /* DENALI_PHY_199_DATA */ + 0x00800080, /* DENALI_PHY_200_DATA */ + 0x00800080, /* DENALI_PHY_201_DATA */ + 0x00800080, /* DENALI_PHY_202_DATA */ + 0x00800080, /* DENALI_PHY_203_DATA */ + 0x00800080, /* DENALI_PHY_204_DATA */ + 0x01c40080, /* DENALI_PHY_205_DATA */ + 0x01900002, /* DENALI_PHY_206_DATA */ + 0x00000000, /* DENALI_PHY_207_DATA */ + 0x00020000, /* DENALI_PHY_208_DATA */ + 0x00000200, /* DENALI_PHY_209_DATA */ + 0x00000000, /* DENALI_PHY_210_DATA */ + 0x51315152, /* DENALI_PHY_211_DATA */ + 0xc0013150, /* DENALI_PHY_212_DATA */ + 0x010000c0, /* DENALI_PHY_213_DATA */ + 0x00100000, /* DENALI_PHY_214_DATA */ + 0x0c054208, /* DENALI_PHY_215_DATA */ + 0x000f0c18, /* DENALI_PHY_216_DATA */ + 0x01000140, /* DENALI_PHY_217_DATA */ + 0x00000c20, /* DENALI_PHY_218_DATA */ + 0x00000000, /* DENALI_PHY_219_DATA */ + 0x00000000, /* DENALI_PHY_220_DATA */ + 0x00000000, /* DENALI_PHY_221_DATA */ + 0x00000000, /* DENALI_PHY_222_DATA */ + 0x00000000, /* DENALI_PHY_223_DATA */ + 0x00000000, /* DENALI_PHY_224_DATA */ + 0x00000000, /* DENALI_PHY_225_DATA */ + 0x00000000, /* DENALI_PHY_226_DATA */ + 0x00000000, /* DENALI_PHY_227_DATA */ + 0x00000000, /* DENALI_PHY_228_DATA */ + 0x00000000, /* DENALI_PHY_229_DATA */ + 0x00000000, /* DENALI_PHY_230_DATA */ + 0x00000000, /* DENALI_PHY_231_DATA */ + 0x00000000, /* DENALI_PHY_232_DATA */ + 0x00000000, /* DENALI_PHY_233_DATA */ + 0x00000000, /* DENALI_PHY_234_DATA */ + 0x00000000, /* DENALI_PHY_235_DATA */ + 0x00000000, /* DENALI_PHY_236_DATA */ + 0x00000000, /* DENALI_PHY_237_DATA */ + 0x00000000, /* DENALI_PHY_238_DATA */ + 0x00000000, /* DENALI_PHY_239_DATA */ + 0x00000000, /* DENALI_PHY_240_DATA */ + 0x00000000, /* DENALI_PHY_241_DATA */ + 0x00000000, /* DENALI_PHY_242_DATA */ + 0x00000000, /* DENALI_PHY_243_DATA */ + 0x00000000, /* DENALI_PHY_244_DATA */ + 0x00000000, /* DENALI_PHY_245_DATA */ + 0x00000000, /* DENALI_PHY_246_DATA */ + 0x00000000, /* DENALI_PHY_247_DATA */ + 0x00000000, /* DENALI_PHY_248_DATA */ + 0x00000000, /* DENALI_PHY_249_DATA */ + 0x00000000, /* DENALI_PHY_250_DATA */ + 0x00000000, /* DENALI_PHY_251_DATA */ + 0x00000000, /* DENALI_PHY_252_DATA */ + 0x00000000, /* DENALI_PHY_253_DATA */ + 0x00000000, /* DENALI_PHY_254_DATA */ + 0x00000000, /* DENALI_PHY_255_DATA */ + 0x76543210, /* DENALI_PHY_256_DATA */ + 0x0004c008, /* DENALI_PHY_257_DATA */ + 0x000001c4, /* DENALI_PHY_258_DATA */ + 0x00000000, /* DENALI_PHY_259_DATA */ + 0x00000000, /* DENALI_PHY_260_DATA */ + 0x00010000, /* DENALI_PHY_261_DATA */ + 0x01665555, /* DENALI_PHY_262_DATA */ + 0x00665555, /* DENALI_PHY_263_DATA */ + 0x00010f00, /* DENALI_PHY_264_DATA */ + 0x05000100, /* DENALI_PHY_265_DATA */ + 0x00000002, /* DENALI_PHY_266_DATA */ + 0x001700c0, /* DENALI_PHY_267_DATA */ + 0x00cc0101, /* DENALI_PHY_268_DATA */ + 0x00030066, /* DENALI_PHY_269_DATA */ + 0x00000000, /* DENALI_PHY_270_DATA */ + 0x00000000, /* DENALI_PHY_271_DATA */ + 0x00000000, /* DENALI_PHY_272_DATA */ + 0x00000000, /* DENALI_PHY_273_DATA */ + 0x00000000, /* DENALI_PHY_274_DATA */ + 0x00000000, /* DENALI_PHY_275_DATA */ + 0x00000000, /* DENALI_PHY_276_DATA */ + 0x00000000, /* DENALI_PHY_277_DATA */ + 0x04080000, /* DENALI_PHY_278_DATA */ + 0x04080400, /* DENALI_PHY_279_DATA */ + 0x08000000, /* DENALI_PHY_280_DATA */ + 0x0c00c007, /* DENALI_PHY_281_DATA */ + 0x00000100, /* DENALI_PHY_282_DATA */ + 0x00000100, /* DENALI_PHY_283_DATA */ + 0x55555555, /* DENALI_PHY_284_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_285_DATA */ + 0x55555555, /* DENALI_PHY_286_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_287_DATA */ + 0x00005555, /* DENALI_PHY_288_DATA */ + 0x00000000, /* DENALI_PHY_289_DATA */ + 0x00000000, /* DENALI_PHY_290_DATA */ + 0x00000000, /* DENALI_PHY_291_DATA */ + 0x00000000, /* DENALI_PHY_292_DATA */ + 0x00000000, /* DENALI_PHY_293_DATA */ + 0x00000000, /* DENALI_PHY_294_DATA */ + 0x00000000, /* DENALI_PHY_295_DATA */ + 0x00000000, /* DENALI_PHY_296_DATA */ + 0x00000000, /* DENALI_PHY_297_DATA */ + 0x00000000, /* DENALI_PHY_298_DATA */ + 0x00000000, /* DENALI_PHY_299_DATA */ + 0x00000000, /* DENALI_PHY_300_DATA */ + 0x00000000, /* DENALI_PHY_301_DATA */ + 0x00000000, /* DENALI_PHY_302_DATA */ + 0x00000000, /* DENALI_PHY_303_DATA */ + 0x00000000, /* DENALI_PHY_304_DATA */ + 0x00000000, /* DENALI_PHY_305_DATA */ + 0x00000000, /* DENALI_PHY_306_DATA */ + 0x00000000, /* DENALI_PHY_307_DATA */ + 0x00200000, /* DENALI_PHY_308_DATA */ + 0x00000000, /* DENALI_PHY_309_DATA */ + 0x00000000, /* DENALI_PHY_310_DATA */ + 0x00000000, /* DENALI_PHY_311_DATA */ + 0x00000000, /* DENALI_PHY_312_DATA */ + 0x00000000, /* DENALI_PHY_313_DATA */ + 0x00000000, /* DENALI_PHY_314_DATA */ + 0x02800280, /* DENALI_PHY_315_DATA */ + 0x02800280, /* DENALI_PHY_316_DATA */ + 0x02800280, /* DENALI_PHY_317_DATA */ + 0x02800280, /* DENALI_PHY_318_DATA */ + 0x00000280, /* DENALI_PHY_319_DATA */ + 0x00000000, /* DENALI_PHY_320_DATA */ + 0x00000000, /* DENALI_PHY_321_DATA */ + 0x00000000, /* DENALI_PHY_322_DATA */ + 0x00000000, /* DENALI_PHY_323_DATA */ + 0x00800000, /* DENALI_PHY_324_DATA */ + 0x00800080, /* DENALI_PHY_325_DATA */ + 0x00800080, /* DENALI_PHY_326_DATA */ + 0x00800080, /* DENALI_PHY_327_DATA */ + 0x00800080, /* DENALI_PHY_328_DATA */ + 0x00800080, /* DENALI_PHY_329_DATA */ + 0x00800080, /* DENALI_PHY_330_DATA */ + 0x00800080, /* DENALI_PHY_331_DATA */ + 0x00800080, /* DENALI_PHY_332_DATA */ + 0x01c40080, /* DENALI_PHY_333_DATA */ + 0x01900002, /* DENALI_PHY_334_DATA */ + 0x00000000, /* DENALI_PHY_335_DATA */ + 0x00020000, /* DENALI_PHY_336_DATA */ + 0x00000200, /* DENALI_PHY_337_DATA */ + 0x00000000, /* DENALI_PHY_338_DATA */ + 0x51315152, /* DENALI_PHY_339_DATA */ + 0xc0013150, /* DENALI_PHY_340_DATA */ + 0x010000c0, /* DENALI_PHY_341_DATA */ + 0x00100000, /* DENALI_PHY_342_DATA */ + 0x0c054208, /* DENALI_PHY_343_DATA */ + 0x000f0c18, /* DENALI_PHY_344_DATA */ + 0x01000140, /* DENALI_PHY_345_DATA */ + 0x00000c20, /* DENALI_PHY_346_DATA */ + 0x00000000, /* DENALI_PHY_347_DATA */ + 0x00000000, /* DENALI_PHY_348_DATA */ + 0x00000000, /* DENALI_PHY_349_DATA */ + 0x00000000, /* DENALI_PHY_350_DATA */ + 0x00000000, /* DENALI_PHY_351_DATA */ + 0x00000000, /* DENALI_PHY_352_DATA */ + 0x00000000, /* DENALI_PHY_353_DATA */ + 0x00000000, /* DENALI_PHY_354_DATA */ + 0x00000000, /* DENALI_PHY_355_DATA */ + 0x00000000, /* DENALI_PHY_356_DATA */ + 0x00000000, /* DENALI_PHY_357_DATA */ + 0x00000000, /* DENALI_PHY_358_DATA */ + 0x00000000, /* DENALI_PHY_359_DATA */ + 0x00000000, /* DENALI_PHY_360_DATA */ + 0x00000000, /* DENALI_PHY_361_DATA */ + 0x00000000, /* DENALI_PHY_362_DATA */ + 0x00000000, /* DENALI_PHY_363_DATA */ + 0x00000000, /* DENALI_PHY_364_DATA */ + 0x00000000, /* DENALI_PHY_365_DATA */ + 0x00000000, /* DENALI_PHY_366_DATA */ + 0x00000000, /* DENALI_PHY_367_DATA */ + 0x00000000, /* DENALI_PHY_368_DATA */ + 0x00000000, /* DENALI_PHY_369_DATA */ + 0x00000000, /* DENALI_PHY_370_DATA */ + 0x00000000, /* DENALI_PHY_371_DATA */ + 0x00000000, /* DENALI_PHY_372_DATA */ + 0x00000000, /* DENALI_PHY_373_DATA */ + 0x00000000, /* DENALI_PHY_374_DATA */ + 0x00000000, /* DENALI_PHY_375_DATA */ + 0x00000000, /* DENALI_PHY_376_DATA */ + 0x00000000, /* DENALI_PHY_377_DATA */ + 0x00000000, /* DENALI_PHY_378_DATA */ + 0x00000000, /* DENALI_PHY_379_DATA */ + 0x00000000, /* DENALI_PHY_380_DATA */ + 0x00000000, /* DENALI_PHY_381_DATA */ + 0x00000000, /* DENALI_PHY_382_DATA */ + 0x00000000, /* DENALI_PHY_383_DATA */ + 0x76543210, /* DENALI_PHY_384_DATA */ + 0x0004c008, /* DENALI_PHY_385_DATA */ + 0x000001c4, /* DENALI_PHY_386_DATA */ + 0x00000000, /* DENALI_PHY_387_DATA */ + 0x00000000, /* DENALI_PHY_388_DATA */ + 0x00010000, /* DENALI_PHY_389_DATA */ + 0x01665555, /* DENALI_PHY_390_DATA */ + 0x00665555, /* DENALI_PHY_391_DATA */ + 0x00010f00, /* DENALI_PHY_392_DATA */ + 0x05000100, /* DENALI_PHY_393_DATA */ + 0x00000002, /* DENALI_PHY_394_DATA */ + 0x001700c0, /* DENALI_PHY_395_DATA */ + 0x00cc0101, /* DENALI_PHY_396_DATA */ + 0x00030066, /* DENALI_PHY_397_DATA */ + 0x00000000, /* DENALI_PHY_398_DATA */ + 0x00000000, /* DENALI_PHY_399_DATA */ + 0x00000000, /* DENALI_PHY_400_DATA */ + 0x00000000, /* DENALI_PHY_401_DATA */ + 0x00000000, /* DENALI_PHY_402_DATA */ + 0x00000000, /* DENALI_PHY_403_DATA */ + 0x00000000, /* DENALI_PHY_404_DATA */ + 0x00000000, /* DENALI_PHY_405_DATA */ + 0x04080000, /* DENALI_PHY_406_DATA */ + 0x04080400, /* DENALI_PHY_407_DATA */ + 0x08000000, /* DENALI_PHY_408_DATA */ + 0x0c00c007, /* DENALI_PHY_409_DATA */ + 0x00000100, /* DENALI_PHY_410_DATA */ + 0x00000100, /* DENALI_PHY_411_DATA */ + 0x55555555, /* DENALI_PHY_412_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_413_DATA */ + 0x55555555, /* DENALI_PHY_414_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_415_DATA */ + 0x00005555, /* DENALI_PHY_416_DATA */ + 0x00000000, /* DENALI_PHY_417_DATA */ + 0x00000000, /* DENALI_PHY_418_DATA */ + 0x00000000, /* DENALI_PHY_419_DATA */ + 0x00000000, /* DENALI_PHY_420_DATA */ + 0x00000000, /* DENALI_PHY_421_DATA */ + 0x00000000, /* DENALI_PHY_422_DATA */ + 0x00000000, /* DENALI_PHY_423_DATA */ + 0x00000000, /* DENALI_PHY_424_DATA */ + 0x00000000, /* DENALI_PHY_425_DATA */ + 0x00000000, /* DENALI_PHY_426_DATA */ + 0x00000000, /* DENALI_PHY_427_DATA */ + 0x00000000, /* DENALI_PHY_428_DATA */ + 0x00000000, /* DENALI_PHY_429_DATA */ + 0x00000000, /* DENALI_PHY_430_DATA */ + 0x00000000, /* DENALI_PHY_431_DATA */ + 0x00000000, /* DENALI_PHY_432_DATA */ + 0x00000000, /* DENALI_PHY_433_DATA */ + 0x00000000, /* DENALI_PHY_434_DATA */ + 0x00000000, /* DENALI_PHY_435_DATA */ + 0x00200000, /* DENALI_PHY_436_DATA */ + 0x00000000, /* DENALI_PHY_437_DATA */ + 0x00000000, /* DENALI_PHY_438_DATA */ + 0x00000000, /* DENALI_PHY_439_DATA */ + 0x00000000, /* DENALI_PHY_440_DATA */ + 0x00000000, /* DENALI_PHY_441_DATA */ + 0x00000000, /* DENALI_PHY_442_DATA */ + 0x02800280, /* DENALI_PHY_443_DATA */ + 0x02800280, /* DENALI_PHY_444_DATA */ + 0x02800280, /* DENALI_PHY_445_DATA */ + 0x02800280, /* DENALI_PHY_446_DATA */ + 0x00000280, /* DENALI_PHY_447_DATA */ + 0x00000000, /* DENALI_PHY_448_DATA */ + 0x00000000, /* DENALI_PHY_449_DATA */ + 0x00000000, /* DENALI_PHY_450_DATA */ + 0x00000000, /* DENALI_PHY_451_DATA */ + 0x00800000, /* DENALI_PHY_452_DATA */ + 0x00800080, /* DENALI_PHY_453_DATA */ + 0x00800080, /* DENALI_PHY_454_DATA */ + 0x00800080, /* DENALI_PHY_455_DATA */ + 0x00800080, /* DENALI_PHY_456_DATA */ + 0x00800080, /* DENALI_PHY_457_DATA */ + 0x00800080, /* DENALI_PHY_458_DATA */ + 0x00800080, /* DENALI_PHY_459_DATA */ + 0x00800080, /* DENALI_PHY_460_DATA */ + 0x01c40080, /* DENALI_PHY_461_DATA */ + 0x01900002, /* DENALI_PHY_462_DATA */ + 0x00000000, /* DENALI_PHY_463_DATA */ + 0x00020000, /* DENALI_PHY_464_DATA */ + 0x00000200, /* DENALI_PHY_465_DATA */ + 0x00000000, /* DENALI_PHY_466_DATA */ + 0x51315152, /* DENALI_PHY_467_DATA */ + 0xc0013150, /* DENALI_PHY_468_DATA */ + 0x010000c0, /* DENALI_PHY_469_DATA */ + 0x00100000, /* DENALI_PHY_470_DATA */ + 0x0c054208, /* DENALI_PHY_471_DATA */ + 0x000f0c18, /* DENALI_PHY_472_DATA */ + 0x01000140, /* DENALI_PHY_473_DATA */ + 0x00000c20, /* DENALI_PHY_474_DATA */ + 0x00000000, /* DENALI_PHY_475_DATA */ + 0x00000000, /* DENALI_PHY_476_DATA */ + 0x00000000, /* DENALI_PHY_477_DATA */ + 0x00000000, /* DENALI_PHY_478_DATA */ + 0x00000000, /* DENALI_PHY_479_DATA */ + 0x00000000, /* DENALI_PHY_480_DATA */ + 0x00000000, /* DENALI_PHY_481_DATA */ + 0x00000000, /* DENALI_PHY_482_DATA */ + 0x00000000, /* DENALI_PHY_483_DATA */ + 0x00000000, /* DENALI_PHY_484_DATA */ + 0x00000000, /* DENALI_PHY_485_DATA */ + 0x00000000, /* DENALI_PHY_486_DATA */ + 0x00000000, /* DENALI_PHY_487_DATA */ + 0x00000000, /* DENALI_PHY_488_DATA */ + 0x00000000, /* DENALI_PHY_489_DATA */ + 0x00000000, /* DENALI_PHY_490_DATA */ + 0x00000000, /* DENALI_PHY_491_DATA */ + 0x00000000, /* DENALI_PHY_492_DATA */ + 0x00000000, /* DENALI_PHY_493_DATA */ + 0x00000000, /* DENALI_PHY_494_DATA */ + 0x00000000, /* DENALI_PHY_495_DATA */ + 0x00000000, /* DENALI_PHY_496_DATA */ + 0x00000000, /* DENALI_PHY_497_DATA */ + 0x00000000, /* DENALI_PHY_498_DATA */ + 0x00000000, /* DENALI_PHY_499_DATA */ + 0x00000000, /* DENALI_PHY_500_DATA */ + 0x00000000, /* DENALI_PHY_501_DATA */ + 0x00000000, /* DENALI_PHY_502_DATA */ + 0x00000000, /* DENALI_PHY_503_DATA */ + 0x00000000, /* DENALI_PHY_504_DATA */ + 0x00000000, /* DENALI_PHY_505_DATA */ + 0x00000000, /* DENALI_PHY_506_DATA */ + 0x00000000, /* DENALI_PHY_507_DATA */ + 0x00000000, /* DENALI_PHY_508_DATA */ + 0x00000000, /* DENALI_PHY_509_DATA */ + 0x00000000, /* DENALI_PHY_510_DATA */ + 0x00000000, /* DENALI_PHY_511_DATA */ + 0x00000000, /* DENALI_PHY_512_DATA */ + 0x00800000, /* DENALI_PHY_513_DATA */ + 0x00000000, /* DENALI_PHY_514_DATA */ + 0x00000000, /* DENALI_PHY_515_DATA */ + 0x00000000, /* DENALI_PHY_516_DATA */ + 0x00000000, /* DENALI_PHY_517_DATA */ + 0x00000000, /* DENALI_PHY_518_DATA */ + 0x00000001, /* DENALI_PHY_519_DATA */ + 0x00000000, /* DENALI_PHY_520_DATA */ + 0x00000000, /* DENALI_PHY_521_DATA */ + 0x00000000, /* DENALI_PHY_522_DATA */ + 0x00400320, /* DENALI_PHY_523_DATA */ + 0x00000040, /* DENALI_PHY_524_DATA */ + 0x00806420, /* DENALI_PHY_525_DATA */ + 0x00917531, /* DENALI_PHY_526_DATA */ + 0x00806420, /* DENALI_PHY_527_DATA */ + 0x01917531, /* DENALI_PHY_528_DATA */ + 0x00020003, /* DENALI_PHY_529_DATA */ + 0x00000000, /* DENALI_PHY_530_DATA */ + 0x00000000, /* DENALI_PHY_531_DATA */ + 0x00000000, /* DENALI_PHY_532_DATA */ + 0x000556aa, /* DENALI_PHY_533_DATA */ + 0x000aaaaa, /* DENALI_PHY_534_DATA */ + 0x000aa955, /* DENALI_PHY_535_DATA */ + 0x00055555, /* DENALI_PHY_536_DATA */ + 0x000b3133, /* DENALI_PHY_537_DATA */ + 0x0004cd33, /* DENALI_PHY_538_DATA */ + 0x0004cecc, /* DENALI_PHY_539_DATA */ + 0x000b32cc, /* DENALI_PHY_540_DATA */ + 0x0a418820, /* DENALI_PHY_541_DATA */ + 0x103f0000, /* DENALI_PHY_542_DATA */ + 0x0000003f, /* DENALI_PHY_543_DATA */ + 0x00038055, /* DENALI_PHY_544_DATA */ + 0x03800380, /* DENALI_PHY_545_DATA */ + 0x03800380, /* DENALI_PHY_546_DATA */ + 0x00000380, /* DENALI_PHY_547_DATA */ + 0x42080010, /* DENALI_PHY_548_DATA */ + 0x00000003, /* DENALI_PHY_549_DATA */ + 0x00000000, /* DENALI_PHY_550_DATA */ + 0x00000000, /* DENALI_PHY_551_DATA */ + 0x00000000, /* DENALI_PHY_552_DATA */ + 0x00000000, /* DENALI_PHY_553_DATA */ + 0x00000000, /* DENALI_PHY_554_DATA */ + 0x00000000, /* DENALI_PHY_555_DATA */ + 0x00000000, /* DENALI_PHY_556_DATA */ + 0x00000000, /* DENALI_PHY_557_DATA */ + 0x00000000, /* DENALI_PHY_558_DATA */ + 0x00000000, /* DENALI_PHY_559_DATA */ + 0x00000000, /* DENALI_PHY_560_DATA */ + 0x00000000, /* DENALI_PHY_561_DATA */ + 0x00000000, /* DENALI_PHY_562_DATA */ + 0x00000000, /* DENALI_PHY_563_DATA */ + 0x00000000, /* DENALI_PHY_564_DATA */ + 0x00000000, /* DENALI_PHY_565_DATA */ + 0x00000000, /* DENALI_PHY_566_DATA */ + 0x00000000, /* DENALI_PHY_567_DATA */ + 0x00000000, /* DENALI_PHY_568_DATA */ + 0x00000000, /* DENALI_PHY_569_DATA */ + 0x00000000, /* DENALI_PHY_570_DATA */ + 0x00000000, /* DENALI_PHY_571_DATA */ + 0x00000000, /* DENALI_PHY_572_DATA */ + 0x00000000, /* DENALI_PHY_573_DATA */ + 0x00000000, /* DENALI_PHY_574_DATA */ + 0x00000000, /* DENALI_PHY_575_DATA */ + 0x00000000, /* DENALI_PHY_576_DATA */ + 0x00000000, /* DENALI_PHY_577_DATA */ + 0x00000000, /* DENALI_PHY_578_DATA */ + 0x00000000, /* DENALI_PHY_579_DATA */ + 0x00000000, /* DENALI_PHY_580_DATA */ + 0x00000000, /* DENALI_PHY_581_DATA */ + 0x00000000, /* DENALI_PHY_582_DATA */ + 0x00000000, /* DENALI_PHY_583_DATA */ + 0x00000000, /* DENALI_PHY_584_DATA */ + 0x00000000, /* DENALI_PHY_585_DATA */ + 0x00000000, /* DENALI_PHY_586_DATA */ + 0x00000000, /* DENALI_PHY_587_DATA */ + 0x00000000, /* DENALI_PHY_588_DATA */ + 0x00000000, /* DENALI_PHY_589_DATA */ + 0x00000000, /* DENALI_PHY_590_DATA */ + 0x00000000, /* DENALI_PHY_591_DATA */ + 0x00000000, /* DENALI_PHY_592_DATA */ + 0x00000000, /* DENALI_PHY_593_DATA */ + 0x00000000, /* DENALI_PHY_594_DATA */ + 0x00000000, /* DENALI_PHY_595_DATA */ + 0x00000000, /* DENALI_PHY_596_DATA */ + 0x00000000, /* DENALI_PHY_597_DATA */ + 0x00000000, /* DENALI_PHY_598_DATA */ + 0x00000000, /* DENALI_PHY_599_DATA */ + 0x00000000, /* DENALI_PHY_600_DATA */ + 0x00000000, /* DENALI_PHY_601_DATA */ + 0x00000000, /* DENALI_PHY_602_DATA */ + 0x00000000, /* DENALI_PHY_603_DATA */ + 0x00000000, /* DENALI_PHY_604_DATA */ + 0x00000000, /* DENALI_PHY_605_DATA */ + 0x00000000, /* DENALI_PHY_606_DATA */ + 0x00000000, /* DENALI_PHY_607_DATA */ + 0x00000000, /* DENALI_PHY_608_DATA */ + 0x00000000, /* DENALI_PHY_609_DATA */ + 0x00000000, /* DENALI_PHY_610_DATA */ + 0x00000000, /* DENALI_PHY_611_DATA */ + 0x00000000, /* DENALI_PHY_612_DATA */ + 0x00000000, /* DENALI_PHY_613_DATA */ + 0x00000000, /* DENALI_PHY_614_DATA */ + 0x00000000, /* DENALI_PHY_615_DATA */ + 0x00000000, /* DENALI_PHY_616_DATA */ + 0x00000000, /* DENALI_PHY_617_DATA */ + 0x00000000, /* DENALI_PHY_618_DATA */ + 0x00000000, /* DENALI_PHY_619_DATA */ + 0x00000000, /* DENALI_PHY_620_DATA */ + 0x00000000, /* DENALI_PHY_621_DATA */ + 0x00000000, /* DENALI_PHY_622_DATA */ + 0x00000000, /* DENALI_PHY_623_DATA */ + 0x00000000, /* DENALI_PHY_624_DATA */ + 0x00000000, /* DENALI_PHY_625_DATA */ + 0x00000000, /* DENALI_PHY_626_DATA */ + 0x00000000, /* DENALI_PHY_627_DATA */ + 0x00000000, /* DENALI_PHY_628_DATA */ + 0x00000000, /* DENALI_PHY_629_DATA */ + 0x00000000, /* DENALI_PHY_630_DATA */ + 0x00000000, /* DENALI_PHY_631_DATA */ + 0x00000000, /* DENALI_PHY_632_DATA */ + 0x00000000, /* DENALI_PHY_633_DATA */ + 0x00000000, /* DENALI_PHY_634_DATA */ + 0x00000000, /* DENALI_PHY_635_DATA */ + 0x00000000, /* DENALI_PHY_636_DATA */ + 0x00000000, /* DENALI_PHY_637_DATA */ + 0x00000000, /* DENALI_PHY_638_DATA */ + 0x00000000, /* DENALI_PHY_639_DATA */ + 0x00000000, /* DENALI_PHY_640_DATA */ + 0x00800000, /* DENALI_PHY_641_DATA */ + 0x00000000, /* DENALI_PHY_642_DATA */ + 0x00000000, /* DENALI_PHY_643_DATA */ + 0x00000000, /* DENALI_PHY_644_DATA */ + 0x00000000, /* DENALI_PHY_645_DATA */ + 0x00000000, /* DENALI_PHY_646_DATA */ + 0x00000001, /* DENALI_PHY_647_DATA */ + 0x00000000, /* DENALI_PHY_648_DATA */ + 0x00000000, /* DENALI_PHY_649_DATA */ + 0x00000000, /* DENALI_PHY_650_DATA */ + 0x00400320, /* DENALI_PHY_651_DATA */ + 0x00000040, /* DENALI_PHY_652_DATA */ + 0x00008eca, /* DENALI_PHY_653_DATA */ + 0x00009fdb, /* DENALI_PHY_654_DATA */ + 0x00008eca, /* DENALI_PHY_655_DATA */ + 0x01009fdb, /* DENALI_PHY_656_DATA */ + 0x00020003, /* DENALI_PHY_657_DATA */ + 0x00000000, /* DENALI_PHY_658_DATA */ + 0x00000000, /* DENALI_PHY_659_DATA */ + 0x00000000, /* DENALI_PHY_660_DATA */ + 0x000556aa, /* DENALI_PHY_661_DATA */ + 0x000aaaaa, /* DENALI_PHY_662_DATA */ + 0x000aa955, /* DENALI_PHY_663_DATA */ + 0x00055555, /* DENALI_PHY_664_DATA */ + 0x000b3133, /* DENALI_PHY_665_DATA */ + 0x0004cd33, /* DENALI_PHY_666_DATA */ + 0x0004cecc, /* DENALI_PHY_667_DATA */ + 0x000b32cc, /* DENALI_PHY_668_DATA */ + 0x0004a0e6, /* DENALI_PHY_669_DATA */ + 0x080f0000, /* DENALI_PHY_670_DATA */ + 0x0000000f, /* DENALI_PHY_671_DATA */ + 0x00038055, /* DENALI_PHY_672_DATA */ + 0x03800380, /* DENALI_PHY_673_DATA */ + 0x03800380, /* DENALI_PHY_674_DATA */ + 0x00000380, /* DENALI_PHY_675_DATA */ + 0x42080010, /* DENALI_PHY_676_DATA */ + 0x00000003, /* DENALI_PHY_677_DATA */ + 0x00000000, /* DENALI_PHY_678_DATA */ + 0x00000000, /* DENALI_PHY_679_DATA */ + 0x00000000, /* DENALI_PHY_680_DATA */ + 0x00000000, /* DENALI_PHY_681_DATA */ + 0x00000000, /* DENALI_PHY_682_DATA */ + 0x00000000, /* DENALI_PHY_683_DATA */ + 0x00000000, /* DENALI_PHY_684_DATA */ + 0x00000000, /* DENALI_PHY_685_DATA */ + 0x00000000, /* DENALI_PHY_686_DATA */ + 0x00000000, /* DENALI_PHY_687_DATA */ + 0x00000000, /* DENALI_PHY_688_DATA */ + 0x00000000, /* DENALI_PHY_689_DATA */ + 0x00000000, /* DENALI_PHY_690_DATA */ + 0x00000000, /* DENALI_PHY_691_DATA */ + 0x00000000, /* DENALI_PHY_692_DATA */ + 0x00000000, /* DENALI_PHY_693_DATA */ + 0x00000000, /* DENALI_PHY_694_DATA */ + 0x00000000, /* DENALI_PHY_695_DATA */ + 0x00000000, /* DENALI_PHY_696_DATA */ + 0x00000000, /* DENALI_PHY_697_DATA */ + 0x00000000, /* DENALI_PHY_698_DATA */ + 0x00000000, /* DENALI_PHY_699_DATA */ + 0x00000000, /* DENALI_PHY_700_DATA */ + 0x00000000, /* DENALI_PHY_701_DATA */ + 0x00000000, /* DENALI_PHY_702_DATA */ + 0x00000000, /* DENALI_PHY_703_DATA */ + 0x00000000, /* DENALI_PHY_704_DATA */ + 0x00000000, /* DENALI_PHY_705_DATA */ + 0x00000000, /* DENALI_PHY_706_DATA */ + 0x00000000, /* DENALI_PHY_707_DATA */ + 0x00000000, /* DENALI_PHY_708_DATA */ + 0x00000000, /* DENALI_PHY_709_DATA */ + 0x00000000, /* DENALI_PHY_710_DATA */ + 0x00000000, /* DENALI_PHY_711_DATA */ + 0x00000000, /* DENALI_PHY_712_DATA */ + 0x00000000, /* DENALI_PHY_713_DATA */ + 0x00000000, /* DENALI_PHY_714_DATA */ + 0x00000000, /* DENALI_PHY_715_DATA */ + 0x00000000, /* DENALI_PHY_716_DATA */ + 0x00000000, /* DENALI_PHY_717_DATA */ + 0x00000000, /* DENALI_PHY_718_DATA */ + 0x00000000, /* DENALI_PHY_719_DATA */ + 0x00000000, /* DENALI_PHY_720_DATA */ + 0x00000000, /* DENALI_PHY_721_DATA */ + 0x00000000, /* DENALI_PHY_722_DATA */ + 0x00000000, /* DENALI_PHY_723_DATA */ + 0x00000000, /* DENALI_PHY_724_DATA */ + 0x00000000, /* DENALI_PHY_725_DATA */ + 0x00000000, /* DENALI_PHY_726_DATA */ + 0x00000000, /* DENALI_PHY_727_DATA */ + 0x00000000, /* DENALI_PHY_728_DATA */ + 0x00000000, /* DENALI_PHY_729_DATA */ + 0x00000000, /* DENALI_PHY_730_DATA */ + 0x00000000, /* DENALI_PHY_731_DATA */ + 0x00000000, /* DENALI_PHY_732_DATA */ + 0x00000000, /* DENALI_PHY_733_DATA */ + 0x00000000, /* DENALI_PHY_734_DATA */ + 0x00000000, /* DENALI_PHY_735_DATA */ + 0x00000000, /* DENALI_PHY_736_DATA */ + 0x00000000, /* DENALI_PHY_737_DATA */ + 0x00000000, /* DENALI_PHY_738_DATA */ + 0x00000000, /* DENALI_PHY_739_DATA */ + 0x00000000, /* DENALI_PHY_740_DATA */ + 0x00000000, /* DENALI_PHY_741_DATA */ + 0x00000000, /* DENALI_PHY_742_DATA */ + 0x00000000, /* DENALI_PHY_743_DATA */ + 0x00000000, /* DENALI_PHY_744_DATA */ + 0x00000000, /* DENALI_PHY_745_DATA */ + 0x00000000, /* DENALI_PHY_746_DATA */ + 0x00000000, /* DENALI_PHY_747_DATA */ + 0x00000000, /* DENALI_PHY_748_DATA */ + 0x00000000, /* DENALI_PHY_749_DATA */ + 0x00000000, /* DENALI_PHY_750_DATA */ + 0x00000000, /* DENALI_PHY_751_DATA */ + 0x00000000, /* DENALI_PHY_752_DATA */ + 0x00000000, /* DENALI_PHY_753_DATA */ + 0x00000000, /* DENALI_PHY_754_DATA */ + 0x00000000, /* DENALI_PHY_755_DATA */ + 0x00000000, /* DENALI_PHY_756_DATA */ + 0x00000000, /* DENALI_PHY_757_DATA */ + 0x00000000, /* DENALI_PHY_758_DATA */ + 0x00000000, /* DENALI_PHY_759_DATA */ + 0x00000000, /* DENALI_PHY_760_DATA */ + 0x00000000, /* DENALI_PHY_761_DATA */ + 0x00000000, /* DENALI_PHY_762_DATA */ + 0x00000000, /* DENALI_PHY_763_DATA */ + 0x00000000, /* DENALI_PHY_764_DATA */ + 0x00000000, /* DENALI_PHY_765_DATA */ + 0x00000000, /* DENALI_PHY_766_DATA */ + 0x00000000, /* DENALI_PHY_767_DATA */ + 0x00000000, /* DENALI_PHY_768_DATA */ + 0x00800000, /* DENALI_PHY_769_DATA */ + 0x00000000, /* DENALI_PHY_770_DATA */ + 0x00000000, /* DENALI_PHY_771_DATA */ + 0x00000000, /* DENALI_PHY_772_DATA */ + 0x00000000, /* DENALI_PHY_773_DATA */ + 0x00000000, /* DENALI_PHY_774_DATA */ + 0x00000001, /* DENALI_PHY_775_DATA */ + 0x00000000, /* DENALI_PHY_776_DATA */ + 0x00000000, /* DENALI_PHY_777_DATA */ + 0x00000000, /* DENALI_PHY_778_DATA */ + 0x00400320, /* DENALI_PHY_779_DATA */ + 0x00000040, /* DENALI_PHY_780_DATA */ + 0x00008eca, /* DENALI_PHY_781_DATA */ + 0x00009fdb, /* DENALI_PHY_782_DATA */ + 0x00008eca, /* DENALI_PHY_783_DATA */ + 0x01009fdb, /* DENALI_PHY_784_DATA */ + 0x00020003, /* DENALI_PHY_785_DATA */ + 0x00000000, /* DENALI_PHY_786_DATA */ + 0x00000000, /* DENALI_PHY_787_DATA */ + 0x00000000, /* DENALI_PHY_788_DATA */ + 0x000556aa, /* DENALI_PHY_789_DATA */ + 0x000aaaaa, /* DENALI_PHY_790_DATA */ + 0x000aa955, /* DENALI_PHY_791_DATA */ + 0x00055555, /* DENALI_PHY_792_DATA */ + 0x000b3133, /* DENALI_PHY_793_DATA */ + 0x0004cd33, /* DENALI_PHY_794_DATA */ + 0x0004cecc, /* DENALI_PHY_795_DATA */ + 0x000b32cc, /* DENALI_PHY_796_DATA */ + 0x1ee6b16a, /* DENALI_PHY_797_DATA */ + 0x10000000, /* DENALI_PHY_798_DATA */ + 0x00000000, /* DENALI_PHY_799_DATA */ + 0x00038055, /* DENALI_PHY_800_DATA */ + 0x03800380, /* DENALI_PHY_801_DATA */ + 0x03800380, /* DENALI_PHY_802_DATA */ + 0x00000380, /* DENALI_PHY_803_DATA */ + 0x42080010, /* DENALI_PHY_804_DATA */ + 0x00000003, /* DENALI_PHY_805_DATA */ + 0x00000000, /* DENALI_PHY_806_DATA */ + 0x00000000, /* DENALI_PHY_807_DATA */ + 0x00000000, /* DENALI_PHY_808_DATA */ + 0x00000000, /* DENALI_PHY_809_DATA */ + 0x00000000, /* DENALI_PHY_810_DATA */ + 0x00000000, /* DENALI_PHY_811_DATA */ + 0x00000000, /* DENALI_PHY_812_DATA */ + 0x00000000, /* DENALI_PHY_813_DATA */ + 0x00000000, /* DENALI_PHY_814_DATA */ + 0x00000000, /* DENALI_PHY_815_DATA */ + 0x00000000, /* DENALI_PHY_816_DATA */ + 0x00000000, /* DENALI_PHY_817_DATA */ + 0x00000000, /* DENALI_PHY_818_DATA */ + 0x00000000, /* DENALI_PHY_819_DATA */ + 0x00000000, /* DENALI_PHY_820_DATA */ + 0x00000000, /* DENALI_PHY_821_DATA */ + 0x00000000, /* DENALI_PHY_822_DATA */ + 0x00000000, /* DENALI_PHY_823_DATA */ + 0x00000000, /* DENALI_PHY_824_DATA */ + 0x00000000, /* DENALI_PHY_825_DATA */ + 0x00000000, /* DENALI_PHY_826_DATA */ + 0x00000000, /* DENALI_PHY_827_DATA */ + 0x00000000, /* DENALI_PHY_828_DATA */ + 0x00000000, /* DENALI_PHY_829_DATA */ + 0x00000000, /* DENALI_PHY_830_DATA */ + 0x00000000, /* DENALI_PHY_831_DATA */ + 0x00000000, /* DENALI_PHY_832_DATA */ + 0x00000000, /* DENALI_PHY_833_DATA */ + 0x00000000, /* DENALI_PHY_834_DATA */ + 0x00000000, /* DENALI_PHY_835_DATA */ + 0x00000000, /* DENALI_PHY_836_DATA */ + 0x00000000, /* DENALI_PHY_837_DATA */ + 0x00000000, /* DENALI_PHY_838_DATA */ + 0x00000000, /* DENALI_PHY_839_DATA */ + 0x00000000, /* DENALI_PHY_840_DATA */ + 0x00000000, /* DENALI_PHY_841_DATA */ + 0x00000000, /* DENALI_PHY_842_DATA */ + 0x00000000, /* DENALI_PHY_843_DATA */ + 0x00000000, /* DENALI_PHY_844_DATA */ + 0x00000000, /* DENALI_PHY_845_DATA */ + 0x00000000, /* DENALI_PHY_846_DATA */ + 0x00000000, /* DENALI_PHY_847_DATA */ + 0x00000000, /* DENALI_PHY_848_DATA */ + 0x00000000, /* DENALI_PHY_849_DATA */ + 0x00000000, /* DENALI_PHY_850_DATA */ + 0x00000000, /* DENALI_PHY_851_DATA */ + 0x00000000, /* DENALI_PHY_852_DATA */ + 0x00000000, /* DENALI_PHY_853_DATA */ + 0x00000000, /* DENALI_PHY_854_DATA */ + 0x00000000, /* DENALI_PHY_855_DATA */ + 0x00000000, /* DENALI_PHY_856_DATA */ + 0x00000000, /* DENALI_PHY_857_DATA */ + 0x00000000, /* DENALI_PHY_858_DATA */ + 0x00000000, /* DENALI_PHY_859_DATA */ + 0x00000000, /* DENALI_PHY_860_DATA */ + 0x00000000, /* DENALI_PHY_861_DATA */ + 0x00000000, /* DENALI_PHY_862_DATA */ + 0x00000000, /* DENALI_PHY_863_DATA */ + 0x00000000, /* DENALI_PHY_864_DATA */ + 0x00000000, /* DENALI_PHY_865_DATA */ + 0x00000000, /* DENALI_PHY_866_DATA */ + 0x00000000, /* DENALI_PHY_867_DATA */ + 0x00000000, /* DENALI_PHY_868_DATA */ + 0x00000000, /* DENALI_PHY_869_DATA */ + 0x00000000, /* DENALI_PHY_870_DATA */ + 0x00000000, /* DENALI_PHY_871_DATA */ + 0x00000000, /* DENALI_PHY_872_DATA */ + 0x00000000, /* DENALI_PHY_873_DATA */ + 0x00000000, /* DENALI_PHY_874_DATA */ + 0x00000000, /* DENALI_PHY_875_DATA */ + 0x00000000, /* DENALI_PHY_876_DATA */ + 0x00000000, /* DENALI_PHY_877_DATA */ + 0x00000000, /* DENALI_PHY_878_DATA */ + 0x00000000, /* DENALI_PHY_879_DATA */ + 0x00000000, /* DENALI_PHY_880_DATA */ + 0x00000000, /* DENALI_PHY_881_DATA */ + 0x00000000, /* DENALI_PHY_882_DATA */ + 0x00000000, /* DENALI_PHY_883_DATA */ + 0x00000000, /* DENALI_PHY_884_DATA */ + 0x00000000, /* DENALI_PHY_885_DATA */ + 0x00000000, /* DENALI_PHY_886_DATA */ + 0x00000000, /* DENALI_PHY_887_DATA */ + 0x00000000, /* DENALI_PHY_888_DATA */ + 0x00000000, /* DENALI_PHY_889_DATA */ + 0x00000000, /* DENALI_PHY_890_DATA */ + 0x00000000, /* DENALI_PHY_891_DATA */ + 0x00000000, /* DENALI_PHY_892_DATA */ + 0x00000000, /* DENALI_PHY_893_DATA */ + 0x00000000, /* DENALI_PHY_894_DATA */ + 0x00000000, /* DENALI_PHY_895_DATA */ + 0x00000001, /* DENALI_PHY_896_DATA */ + 0x00000000, /* DENALI_PHY_897_DATA */ + 0x01000005, /* DENALI_PHY_898_DATA */ + 0x04000f00, /* DENALI_PHY_899_DATA */ + 0x00020040, /* DENALI_PHY_900_DATA */ + 0x00020055, /* DENALI_PHY_901_DATA */ + 0x00000000, /* DENALI_PHY_902_DATA */ + 0x00000000, /* DENALI_PHY_903_DATA */ + 0x00000000, /* DENALI_PHY_904_DATA */ + 0x00000050, /* DENALI_PHY_905_DATA */ + 0x00000000, /* DENALI_PHY_906_DATA */ + 0x00010100, /* DENALI_PHY_907_DATA */ + 0x00000601, /* DENALI_PHY_908_DATA */ + 0x00000000, /* DENALI_PHY_909_DATA */ + 0x00006400, /* DENALI_PHY_910_DATA */ + 0x01221102, /* DENALI_PHY_911_DATA */ + 0x00000000, /* DENALI_PHY_912_DATA */ + 0x00051f00, /* DENALI_PHY_913_DATA */ + 0x051f051f, /* DENALI_PHY_914_DATA */ + 0x051f051f, /* DENALI_PHY_915_DATA */ + 0x00030003, /* DENALI_PHY_916_DATA */ + 0x03000300, /* DENALI_PHY_917_DATA */ + 0x00000300, /* DENALI_PHY_918_DATA */ + 0x01221102, /* DENALI_PHY_919_DATA */ + 0x00000000, /* DENALI_PHY_920_DATA */ + 0x00000000, /* DENALI_PHY_921_DATA */ + 0x03020000, /* DENALI_PHY_922_DATA */ + 0x00000001, /* DENALI_PHY_923_DATA */ + 0x00000011, /* DENALI_PHY_924_DATA */ + 0x00000011, /* DENALI_PHY_925_DATA */ + 0x00000400, /* DENALI_PHY_926_DATA */ + 0x00000000, /* DENALI_PHY_927_DATA */ + 0x00000011, /* DENALI_PHY_928_DATA */ + 0x00000011, /* DENALI_PHY_929_DATA */ + 0x00004410, /* DENALI_PHY_930_DATA */ + 0x00004410, /* DENALI_PHY_931_DATA */ + 0x00004410, /* DENALI_PHY_932_DATA */ + 0x00004410, /* DENALI_PHY_933_DATA */ + 0x00004410, /* DENALI_PHY_934_DATA */ + 0x00000011, /* DENALI_PHY_935_DATA */ + 0x00004410, /* DENALI_PHY_936_DATA */ + 0x00000011, /* DENALI_PHY_937_DATA */ + 0x00004410, /* DENALI_PHY_938_DATA */ + 0x00000011, /* DENALI_PHY_939_DATA */ + 0x00004410, /* DENALI_PHY_940_DATA */ + 0x00000000, /* DENALI_PHY_941_DATA */ + 0x00000000, /* DENALI_PHY_942_DATA */ + 0x00000000, /* DENALI_PHY_943_DATA */ + 0x04000000, /* DENALI_PHY_944_DATA */ + 0x00000000, /* DENALI_PHY_945_DATA */ + 0x00000000, /* DENALI_PHY_946_DATA */ + 0x00000508, /* DENALI_PHY_947_DATA */ + 0x00000000, /* DENALI_PHY_948_DATA */ + 0x00000000, /* DENALI_PHY_949_DATA */ + 0x00000000, /* DENALI_PHY_950_DATA */ + 0x00000000, /* DENALI_PHY_951_DATA */ + 0x00000000, /* DENALI_PHY_952_DATA */ + 0x00000000, /* DENALI_PHY_953_DATA */ + 0xe4000000, /* DENALI_PHY_954_DATA */ + 0x00000000, /* DENALI_PHY_955_DATA */ + 0x00000000, /* DENALI_PHY_956_DATA */ + 0x01010000, /* DENALI_PHY_957_DATA */ + 0x00000000 /* DENALI_PHY_958_DATA */ + } + }, +}; diff --git a/src/mainboard/google/gru/sdram_inf/sdram-lpddr3-hynix-4GB-666-no-odt.inc b/src/mainboard/google/gru/sdram_inf/sdram-lpddr3-hynix-4GB-666-no-odt.inc deleted file mode 100644 index dc5a78f..0000000 --- a/src/mainboard/google/gru/sdram_inf/sdram-lpddr3-hynix-4GB-666-no-odt.inc +++ /dev/null @@ -1,1563 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -{ - { - { - .rank = 0x2, - .col = 0xA, - .bk = 0x3, - .bw = 0x2, - .dbw = 0x2, - .row_3_4 = 0x0, - .cs0_row = 0xF, - .cs1_row = 0xF, - .ddrconfig = 1, - { - {0x19151115}, - {0x10030806}, - {0x00000002}, - {0x00006206}, - {0x00000054}, - 0x00000000 - } - }, - { - .rank = 0x2, - .col = 0xA, - .bk = 0x3, - .bw = 0x2, - .dbw = 0x2, - .row_3_4 = 0x0, - .cs0_row = 0xF, - .cs1_row = 0xF, - .ddrconfig = 1, - { - {0x19151115}, - {0x10030806}, - {0x00000002}, - {0x00006206}, - {0x00000054}, - 0x00000000 - } - } - }, - .ddr_freq = 666*MHz, - .dramtype = LPDDR3, - .num_channels = 2, - .stride = 13, - .odt = 1, - { - { - 0x00000700, /* DENALI_CTL_00_DATA */ - 0x00000000, /* DENALI_CTL_01_DATA */ - 0x00000000, /* DENALI_CTL_02_DATA */ - 0x00000000, /* DENALI_CTL_03_DATA */ - 0x00000000, /* DENALI_CTL_04_DATA */ - 0x00000043, /* DENALI_CTL_05_DATA */ - 0x000208d6, /* DENALI_CTL_06_DATA */ - 0x0000029b, /* DENALI_CTL_07_DATA */ - 0x00001a0b, /* DENALI_CTL_08_DATA */ - 0x00000028, /* DENALI_CTL_09_DATA */ - 0x00013880, /* DENALI_CTL_10_DATA */ - 0x00000190, /* DENALI_CTL_11_DATA */ - 0x00000fa0, /* DENALI_CTL_12_DATA */ - 0x00000043, /* DENALI_CTL_13_DATA */ - 0x000208d6, /* DENALI_CTL_14_DATA */ - 0x0000029b, /* DENALI_CTL_15_DATA */ - 0x01001a0b, /* DENALI_CTL_16_DATA */ - 0x00000000, /* DENALI_CTL_17_DATA */ - 0x00000101, /* DENALI_CTL_18_DATA */ - 0x00020100, /* DENALI_CTL_19_DATA */ - 0x00000086, /* DENALI_CTL_20_DATA */ - 0x0000014e, /* DENALI_CTL_21_DATA */ - 0x00000000, /* DENALI_CTL_22_DATA */ - 0x06140000, /* DENALI_CTL_23_DATA */ - 0x00061400, /* DENALI_CTL_24_DATA */ - 0x04000614, /* DENALI_CTL_25_DATA */ - 0x2a070004, /* DENALI_CTL_26_DATA */ - 0x220c051c, /* DENALI_CTL_27_DATA */ - 0x111a0400, /* DENALI_CTL_28_DATA */ - 0x00140804, /* DENALI_CTL_29_DATA */ - 0x051c2a07, /* DENALI_CTL_30_DATA */ - 0x0500220c, /* DENALI_CTL_31_DATA */ - 0x00000a0a, /* DENALI_CTL_32_DATA */ - 0x0500b64a, /* DENALI_CTL_33_DATA */ - 0x0a0a040a, /* DENALI_CTL_34_DATA */ - 0x03006d60, /* DENALI_CTL_35_DATA */ - 0x0a0a0506, /* DENALI_CTL_36_DATA */ - 0x0500b64a, /* DENALI_CTL_37_DATA */ - 0x0203000a, /* DENALI_CTL_38_DATA */ - 0x080a0c00, /* DENALI_CTL_39_DATA */ - 0x040a0c06, /* DENALI_CTL_40_DATA */ - 0x14000a0a, /* DENALI_CTL_41_DATA */ - 0x02020a0a, /* DENALI_CTL_42_DATA */ - 0x00010002, /* DENALI_CTL_43_DATA */ - 0x03160e16, /* DENALI_CTL_44_DATA */ - 0x000e090e, /* DENALI_CTL_45_DATA */ - 0x00000000, /* DENALI_CTL_46_DATA */ - 0x03010000, /* DENALI_CTL_47_DATA */ - 0x0a20008c, /* DENALI_CTL_48_DATA */ - 0x06100054, /* DENALI_CTL_49_DATA */ - 0x0a20008c, /* DENALI_CTL_50_DATA */ - 0x00000000, /* DENALI_CTL_51_DATA */ - 0x00030005, /* DENALI_CTL_52_DATA */ - 0x00100005, /* DENALI_CTL_53_DATA */ - 0x0010000a, /* DENALI_CTL_54_DATA */ - 0x000c080c, /* DENALI_CTL_55_DATA */ - 0x00000000, /* DENALI_CTL_56_DATA */ - 0x00000000, /* DENALI_CTL_57_DATA */ - 0x00000000, /* DENALI_CTL_58_DATA */ - 0x00930000, /* DENALI_CTL_59_DATA */ - 0x00580093, /* DENALI_CTL_60_DATA */ - 0x00930058, /* DENALI_CTL_61_DATA */ - 0x00000093, /* DENALI_CTL_62_DATA */ - 0x00000000, /* DENALI_CTL_63_DATA */ - 0x00000000, /* DENALI_CTL_64_DATA */ - 0x00000000, /* DENALI_CTL_65_DATA */ - 0x00000000, /* DENALI_CTL_66_DATA */ - 0x00000000, /* DENALI_CTL_67_DATA */ - 0x00000000, /* DENALI_CTL_68_DATA */ - 0x00000301, /* DENALI_CTL_69_DATA */ - 0x00000001, /* DENALI_CTL_70_DATA */ - 0x00000000, /* DENALI_CTL_71_DATA */ - 0x00000000, /* DENALI_CTL_72_DATA */ - 0x01000000, /* DENALI_CTL_73_DATA */ - 0x80104002, /* DENALI_CTL_74_DATA */ - 0x00040003, /* DENALI_CTL_75_DATA */ - 0x00040005, /* DENALI_CTL_76_DATA */ - 0x00030000, /* DENALI_CTL_77_DATA */ - 0x00050004, /* DENALI_CTL_78_DATA */ - 0x00000004, /* DENALI_CTL_79_DATA */ - 0x00040003, /* DENALI_CTL_80_DATA */ - 0x00040005, /* DENALI_CTL_81_DATA */ - 0x28800000, /* DENALI_CTL_82_DATA */ - 0x00001440, /* DENALI_CTL_83_DATA */ - 0x0c201840, /* DENALI_CTL_84_DATA */ - 0x28800000, /* DENALI_CTL_85_DATA */ - 0x00001440, /* DENALI_CTL_86_DATA */ - 0x00000000, /* DENALI_CTL_87_DATA */ - 0x00000000, /* DENALI_CTL_88_DATA */ - 0x00000000, /* DENALI_CTL_89_DATA */ - 0x00000000, /* DENALI_CTL_90_DATA */ - 0x00000000, /* DENALI_CTL_91_DATA */ - 0x02020200, /* DENALI_CTL_92_DATA */ - 0x00020202, /* DENALI_CTL_93_DATA */ - 0x00030200, /* DENALI_CTL_94_DATA */ - 0x00040700, /* DENALI_CTL_95_DATA */ - 0x00000302, /* DENALI_CTL_96_DATA */ - 0x02000407, /* DENALI_CTL_97_DATA */ - 0x00000003, /* DENALI_CTL_98_DATA */ - 0x00030f04, /* DENALI_CTL_99_DATA */ - 0x00070004, /* DENALI_CTL_100_DATA */ - 0x00000000, /* DENALI_CTL_101_DATA */ - 0x00000000, /* DENALI_CTL_102_DATA */ - 0x00000000, /* DENALI_CTL_103_DATA */ - 0x00000000, /* DENALI_CTL_104_DATA */ - 0x00000000, /* DENALI_CTL_105_DATA */ - 0x00000000, /* DENALI_CTL_106_DATA */ - 0x00000000, /* DENALI_CTL_107_DATA */ - 0x00010000, /* DENALI_CTL_108_DATA */ - 0x20040020, /* DENALI_CTL_109_DATA */ - 0x00200400, /* DENALI_CTL_110_DATA */ - 0x01000400, /* DENALI_CTL_111_DATA */ - 0x00000b80, /* DENALI_CTL_112_DATA */ - 0x00000000, /* DENALI_CTL_113_DATA */ - 0x00000001, /* DENALI_CTL_114_DATA */ - 0x00000002, /* DENALI_CTL_115_DATA */ - 0x0000000e, /* DENALI_CTL_116_DATA */ - 0x00000000, /* DENALI_CTL_117_DATA */ - 0x00000000, /* DENALI_CTL_118_DATA */ - 0x00000000, /* DENALI_CTL_119_DATA */ - 0x00000000, /* DENALI_CTL_120_DATA */ - 0x00000000, /* DENALI_CTL_121_DATA */ - 0x00860000, /* DENALI_CTL_122_DATA */ - 0x00a70043, /* DENALI_CTL_123_DATA */ - 0x00a70000, /* DENALI_CTL_124_DATA */ - 0x00280050, /* DENALI_CTL_125_DATA */ - 0x00000064, /* DENALI_CTL_126_DATA */ - 0x00860064, /* DENALI_CTL_127_DATA */ - 0x00a70043, /* DENALI_CTL_128_DATA */ - 0x00a70000, /* DENALI_CTL_129_DATA */ - 0x00000000, /* DENALI_CTL_130_DATA */ - 0x00000000, /* DENALI_CTL_131_DATA */ - 0x00000000, /* DENALI_CTL_132_DATA */ - 0x00030000, /* DENALI_CTL_133_DATA */ - 0x00000018, /* DENALI_CTL_134_DATA */ - 0x00080083, /* DENALI_CTL_135_DATA */ - 0x00030000, /* DENALI_CTL_136_DATA */ - 0x00000018, /* DENALI_CTL_137_DATA */ - 0x00010001, /* DENALI_CTL_138_DATA */ - 0x07000001, /* DENALI_CTL_139_DATA */ - 0x00000707, /* DENALI_CTL_140_DATA */ - 0x00000000, /* DENALI_CTL_141_DATA */ - 0x00000000, /* DENALI_CTL_142_DATA */ - 0x00000000, /* DENALI_CTL_143_DATA */ - 0x00000000, /* DENALI_CTL_144_DATA */ - 0x00000000, /* DENALI_CTL_145_DATA */ - 0x00000000, /* DENALI_CTL_146_DATA */ - 0x00030000, /* DENALI_CTL_147_DATA */ - 0x00000018, /* DENALI_CTL_148_DATA */ - 0x00080083, /* DENALI_CTL_149_DATA */ - 0x00030000, /* DENALI_CTL_150_DATA */ - 0x00000018, /* DENALI_CTL_151_DATA */ - 0x00010001, /* DENALI_CTL_152_DATA */ - 0x07000001, /* DENALI_CTL_153_DATA */ - 0x00000707, /* DENALI_CTL_154_DATA */ - 0x00000000, /* DENALI_CTL_155_DATA */ - 0x00000000, /* DENALI_CTL_156_DATA */ - 0x00000000, /* DENALI_CTL_157_DATA */ - 0x00000000, /* DENALI_CTL_158_DATA */ - 0x00000000, /* DENALI_CTL_159_DATA */ - 0x00000000, /* DENALI_CTL_160_DATA */ - 0x01000000, /* DENALI_CTL_161_DATA */ - 0x00000000, /* DENALI_CTL_162_DATA */ - 0x00000000, /* DENALI_CTL_163_DATA */ - 0x18151100, /* DENALI_CTL_164_DATA */ - 0x0000000c, /* DENALI_CTL_165_DATA */ - 0x00000000, /* DENALI_CTL_166_DATA */ - 0x00000000, /* DENALI_CTL_167_DATA */ - 0x00000000, /* DENALI_CTL_168_DATA */ - 0x00000000, /* DENALI_CTL_169_DATA */ - 0x00000000, /* DENALI_CTL_170_DATA */ - 0x00000000, /* DENALI_CTL_171_DATA */ - 0x00000000, /* DENALI_CTL_172_DATA */ - 0x00000000, /* DENALI_CTL_173_DATA */ - 0x00000000, /* DENALI_CTL_174_DATA */ - 0x00000000, /* DENALI_CTL_175_DATA */ - 0x00000000, /* DENALI_CTL_176_DATA */ - 0x00000000, /* DENALI_CTL_177_DATA */ - 0x00000000, /* DENALI_CTL_178_DATA */ - 0x00029b03, /* DENALI_CTL_179_DATA */ - 0x003c00f0, /* DENALI_CTL_180_DATA */ - 0x00000000, /* DENALI_CTL_181_DATA */ - 0x00900190, /* DENALI_CTL_182_DATA */ - 0x00000024, /* DENALI_CTL_183_DATA */ - 0x00029b00, /* DENALI_CTL_184_DATA */ - 0x003c00f0, /* DENALI_CTL_185_DATA */ - 0x00000000, /* DENALI_CTL_186_DATA */ - 0x00220000, /* DENALI_CTL_187_DATA */ - 0x00220014, /* DENALI_CTL_188_DATA */ - 0x01010100, /* DENALI_CTL_189_DATA */ - 0x01000202, /* DENALI_CTL_190_DATA */ - 0x0a000002, /* DENALI_CTL_191_DATA */ - 0x01000f0f, /* DENALI_CTL_192_DATA */ - 0x00000000, /* DENALI_CTL_193_DATA */ - 0x00000000, /* DENALI_CTL_194_DATA */ - 0x00010003, /* DENALI_CTL_195_DATA */ - 0x00000c03, /* DENALI_CTL_196_DATA */ - 0x00000100, /* DENALI_CTL_197_DATA */ - 0x00010000, /* DENALI_CTL_198_DATA */ - 0x01000000, /* DENALI_CTL_199_DATA */ - 0x00010000, /* DENALI_CTL_200_DATA */ - 0x00000001, /* DENALI_CTL_201_DATA */ - 0x00000000, /* DENALI_CTL_202_DATA */ - 0x00000000, /* DENALI_CTL_203_DATA */ - 0x00000000, /* DENALI_CTL_204_DATA */ - 0x00000000, /* DENALI_CTL_205_DATA */ - 0x00000000, /* DENALI_CTL_206_DATA */ - 0x00000000, /* DENALI_CTL_207_DATA */ - 0x00000000, /* DENALI_CTL_208_DATA */ - 0x00000000, /* DENALI_CTL_209_DATA */ - 0x00000000, /* DENALI_CTL_210_DATA */ - 0x00010000, /* DENALI_CTL_211_DATA */ - 0x03020301, /* DENALI_CTL_212_DATA */ - 0x01000808, /* DENALI_CTL_213_DATA */ - 0x04030001, /* DENALI_CTL_214_DATA */ - 0x08080803, /* DENALI_CTL_215_DATA */ - 0x02080808, /* DENALI_CTL_216_DATA */ - 0x02050203, /* DENALI_CTL_217_DATA */ - 0x02010303, /* DENALI_CTL_218_DATA */ - 0x00010203, /* DENALI_CTL_219_DATA */ - 0x00020202, /* DENALI_CTL_220_DATA */ - 0x03020400, /* DENALI_CTL_221_DATA */ - 0x00020401, /* DENALI_CTL_222_DATA */ - 0x00000000, /* DENALI_CTL_223_DATA */ - 0x00000000, /* DENALI_CTL_224_DATA */ - 0x0d000001, /* DENALI_CTL_225_DATA */ - 0x00010028, /* DENALI_CTL_226_DATA */ - 0x00010000, /* DENALI_CTL_227_DATA */ - 0x00000003, /* DENALI_CTL_228_DATA */ - 0x00000000, /* DENALI_CTL_229_DATA */ - 0x00000000, /* DENALI_CTL_230_DATA */ - 0x00000000, /* DENALI_CTL_231_DATA */ - 0x00000000, /* DENALI_CTL_232_DATA */ - 0x00000000, /* DENALI_CTL_233_DATA */ - 0x00000000, /* DENALI_CTL_234_DATA */ - 0x00000000, /* DENALI_CTL_235_DATA */ - 0x00000000, /* DENALI_CTL_236_DATA */ - 0x00010100, /* DENALI_CTL_237_DATA */ - 0x01000000, /* DENALI_CTL_238_DATA */ - 0x00000001, /* DENALI_CTL_239_DATA */ - 0x00000303, /* DENALI_CTL_240_DATA */ - 0x00000000, /* DENALI_CTL_241_DATA */ - 0x00000000, /* DENALI_CTL_242_DATA */ - 0x00000000, /* DENALI_CTL_243_DATA */ - 0x00000000, /* DENALI_CTL_244_DATA */ - 0x00000000, /* DENALI_CTL_245_DATA */ - 0x00000000, /* DENALI_CTL_246_DATA */ - 0x00000000, /* DENALI_CTL_247_DATA */ - 0x00000000, /* DENALI_CTL_248_DATA */ - 0x00000000, /* DENALI_CTL_249_DATA */ - 0x00000000, /* DENALI_CTL_250_DATA */ - 0x00000000, /* DENALI_CTL_251_DATA */ - 0x00000000, /* DENALI_CTL_252_DATA */ - 0x00000000, /* DENALI_CTL_253_DATA */ - 0x00000000, /* DENALI_CTL_254_DATA */ - 0x00000000, /* DENALI_CTL_255_DATA */ - 0x000556aa, /* DENALI_CTL_256_DATA */ - 0x000aaaaa, /* DENALI_CTL_257_DATA */ - 0x000aa955, /* DENALI_CTL_258_DATA */ - 0x00055555, /* DENALI_CTL_259_DATA */ - 0x000b3133, /* DENALI_CTL_260_DATA */ - 0x0004cd33, /* DENALI_CTL_261_DATA */ - 0x0004cecc, /* DENALI_CTL_262_DATA */ - 0x000b32cc, /* DENALI_CTL_263_DATA */ - 0x00010300, /* DENALI_CTL_264_DATA */ - 0x03000100, /* DENALI_CTL_265_DATA */ - 0x00000000, /* DENALI_CTL_266_DATA */ - 0x00000000, /* DENALI_CTL_267_DATA */ - 0x00000000, /* DENALI_CTL_268_DATA */ - 0x00000000, /* DENALI_CTL_269_DATA */ - 0x00000000, /* DENALI_CTL_270_DATA */ - 0x00000000, /* DENALI_CTL_271_DATA */ - 0x00000000, /* DENALI_CTL_272_DATA */ - 0x00000000, /* DENALI_CTL_273_DATA */ - 0x00ffff00, /* DENALI_CTL_274_DATA */ - 0x181b0000, /* DENALI_CTL_275_DATA */ - 0x0800001b, /* DENALI_CTL_276_DATA */ - 0x00001440, /* DENALI_CTL_277_DATA */ - 0x00000200, /* DENALI_CTL_278_DATA */ - 0x00000200, /* DENALI_CTL_279_DATA */ - 0x00000200, /* DENALI_CTL_280_DATA */ - 0x00000200, /* DENALI_CTL_281_DATA */ - 0x00001440, /* DENALI_CTL_282_DATA */ - 0x0000ca80, /* DENALI_CTL_283_DATA */ - 0x0c200509, /* DENALI_CTL_284_DATA */ - 0x00000200, /* DENALI_CTL_285_DATA */ - 0x00000200, /* DENALI_CTL_286_DATA */ - 0x00000200, /* DENALI_CTL_287_DATA */ - 0x00000200, /* DENALI_CTL_288_DATA */ - 0x00000c20, /* DENALI_CTL_289_DATA */ - 0x00007940, /* DENALI_CTL_290_DATA */ - 0x14400509, /* DENALI_CTL_291_DATA */ - 0x00000200, /* DENALI_CTL_292_DATA */ - 0x00000200, /* DENALI_CTL_293_DATA */ - 0x00000200, /* DENALI_CTL_294_DATA */ - 0x00000200, /* DENALI_CTL_295_DATA */ - 0x00001440, /* DENALI_CTL_296_DATA */ - 0x0000ca80, /* DENALI_CTL_297_DATA */ - 0x02020509, /* DENALI_CTL_298_DATA */ - 0x03030202, /* DENALI_CTL_299_DATA */ - 0x00000018, /* DENALI_CTL_300_DATA */ - 0x00000000, /* DENALI_CTL_301_DATA */ - 0x00000000, /* DENALI_CTL_302_DATA */ - 0x00001403, /* DENALI_CTL_303_DATA */ - 0x00000000, /* DENALI_CTL_304_DATA */ - 0x00000000, /* DENALI_CTL_305_DATA */ - 0x00000000, /* DENALI_CTL_306_DATA */ - 0x00030000, /* DENALI_CTL_307_DATA */ - 0x000d001f, /* DENALI_CTL_308_DATA */ - 0x000a001c, /* DENALI_CTL_309_DATA */ - 0x000d001f, /* DENALI_CTL_310_DATA */ - 0x00000000, /* DENALI_CTL_311_DATA */ - 0x00000000, /* DENALI_CTL_312_DATA */ - 0x01000000, /* DENALI_CTL_313_DATA */ - 0x00050005, /* DENALI_CTL_314_DATA */ - 0x00050005, /* DENALI_CTL_315_DATA */ - 0x00000000, /* DENALI_CTL_316_DATA */ - 0x00000000, /* DENALI_CTL_317_DATA */ - 0x00000000, /* DENALI_CTL_318_DATA */ - 0x00000000, /* DENALI_CTL_319_DATA */ - 0x00000000, /* DENALI_CTL_320_DATA */ - 0x00000000, /* DENALI_CTL_321_DATA */ - 0x00000000, /* DENALI_CTL_322_DATA */ - 0x00000000, /* DENALI_CTL_323_DATA */ - 0x01000101, /* DENALI_CTL_324_DATA */ - 0x01010101, /* DENALI_CTL_325_DATA */ - 0x01000101, /* DENALI_CTL_326_DATA */ - 0x01000100, /* DENALI_CTL_327_DATA */ - 0x00010001, /* DENALI_CTL_328_DATA */ - 0x00010002, /* DENALI_CTL_329_DATA */ - 0x00020100, /* DENALI_CTL_330_DATA */ - 0x00000002 /* DENALI_CTL_331_DATA */ - } - }, - { - { - 0x00000700, /* DENALI_PI_00_DATA */ - 0x00000000, /* DENALI_PI_01_DATA */ - 0x00002880, /* DENALI_PI_02_DATA */ - 0x00001440, /* DENALI_PI_03_DATA */ - 0x00002880, /* DENALI_PI_04_DATA */ - 0x00001440, /* DENALI_PI_05_DATA */ - 0x00002880, /* DENALI_PI_06_DATA */ - 0x14401440, /* DENALI_PI_07_DATA */ - 0x00000200, /* DENALI_PI_08_DATA */ - 0x00000200, /* DENALI_PI_09_DATA */ - 0x00000200, /* DENALI_PI_10_DATA */ - 0x00000200, /* DENALI_PI_11_DATA */ - 0x00001440, /* DENALI_PI_12_DATA */ - 0x00000200, /* DENALI_PI_13_DATA */ - 0x00000200, /* DENALI_PI_14_DATA */ - 0x00000200, /* DENALI_PI_15_DATA */ - 0x00000200, /* DENALI_PI_16_DATA */ - 0x00001440, /* DENALI_PI_17_DATA */ - 0x00000200, /* DENALI_PI_18_DATA */ - 0x00000200, /* DENALI_PI_19_DATA */ - 0x00000200, /* DENALI_PI_20_DATA */ - 0x00000200, /* DENALI_PI_21_DATA */ - 0x00010000, /* DENALI_PI_22_DATA */ - 0x00000007, /* DENALI_PI_23_DATA */ - 0x81000001, /* DENALI_PI_24_DATA */ - 0x0f0003f0, /* DENALI_PI_25_DATA */ - 0x3fffffff, /* DENALI_PI_26_DATA */ - 0x0f0000a0, /* DENALI_PI_27_DATA */ - 0x377ff000, /* DENALI_PI_28_DATA */ - 0x0f000020, /* DENALI_PI_29_DATA */ - 0x377ff000, /* DENALI_PI_30_DATA */ - 0x0f000030, /* DENALI_PI_31_DATA */ - 0x377ff000, /* DENALI_PI_32_DATA */ - 0x0f0000b0, /* DENALI_PI_33_DATA */ - 0x377ff000, /* DENALI_PI_34_DATA */ - 0x0f000100, /* DENALI_PI_35_DATA */ - 0x377ff000, /* DENALI_PI_36_DATA */ - 0x0f000110, /* DENALI_PI_37_DATA */ - 0x377ff000, /* DENALI_PI_38_DATA */ - 0x0f000010, /* DENALI_PI_39_DATA */ - 0x377ff000, /* DENALI_PI_40_DATA */ - 0x03000101, /* DENALI_PI_41_DATA */ - 0x042a2a2a, /* DENALI_PI_42_DATA */ - 0x06140006, /* DENALI_PI_43_DATA */ - 0x00061400, /* DENALI_PI_44_DATA */ - 0x00000014, /* DENALI_PI_45_DATA */ - 0x0a20008c, /* DENALI_PI_46_DATA */ - 0x0a20008c, /* DENALI_PI_47_DATA */ - 0x0a20008c, /* DENALI_PI_48_DATA */ - 0x00000500, /* DENALI_PI_49_DATA */ - 0x00000000, /* DENALI_PI_50_DATA */ - 0x00000000, /* DENALI_PI_51_DATA */ - 0x00000000, /* DENALI_PI_52_DATA */ - 0x00000000, /* DENALI_PI_53_DATA */ - 0x00000000, /* DENALI_PI_54_DATA */ - 0x00000000, /* DENALI_PI_55_DATA */ - 0x00000000, /* DENALI_PI_56_DATA */ - 0x00000000, /* DENALI_PI_57_DATA */ - 0x04040000, /* DENALI_PI_58_DATA */ - 0x0d000004, /* DENALI_PI_59_DATA */ - 0x00000128, /* DENALI_PI_60_DATA */ - 0x00000000, /* DENALI_PI_61_DATA */ - 0x00030003, /* DENALI_PI_62_DATA */ - 0x00000018, /* DENALI_PI_63_DATA */ - 0x00000000, /* DENALI_PI_64_DATA */ - 0x00000000, /* DENALI_PI_65_DATA */ - 0x03060002, /* DENALI_PI_66_DATA */ - 0x03010301, /* DENALI_PI_67_DATA */ - 0x01080801, /* DENALI_PI_68_DATA */ - 0x04020201, /* DENALI_PI_69_DATA */ - 0x01080804, /* DENALI_PI_70_DATA */ - 0x00000000, /* DENALI_PI_71_DATA */ - 0x03030000, /* DENALI_PI_72_DATA */ - 0x08080803, /* DENALI_PI_73_DATA */ - 0x00000000, /* DENALI_PI_74_DATA */ - 0x00000000, /* DENALI_PI_75_DATA */ - 0x00000000, /* DENALI_PI_76_DATA */ - 0x00030300, /* DENALI_PI_77_DATA */ - 0x00000014, /* DENALI_PI_78_DATA */ - 0x00000000, /* DENALI_PI_79_DATA */ - 0x01010300, /* DENALI_PI_80_DATA */ - 0x00000000, /* DENALI_PI_81_DATA */ - 0x00000000, /* DENALI_PI_82_DATA */ - 0x01000000, /* DENALI_PI_83_DATA */ - 0x00000101, /* DENALI_PI_84_DATA */ - 0x55555a5a, /* DENALI_PI_85_DATA */ - 0x55555a5a, /* DENALI_PI_86_DATA */ - 0x55555a5a, /* DENALI_PI_87_DATA */ - 0x55555a5a, /* DENALI_PI_88_DATA */ - 0x09090001, /* DENALI_PI_89_DATA */ - 0x05050009, /* DENALI_PI_90_DATA */ - 0x00000005, /* DENALI_PI_91_DATA */ - 0x00000100, /* DENALI_PI_92_DATA */ - 0x00030000, /* DENALI_PI_93_DATA */ - 0x17030000, /* DENALI_PI_94_DATA */ - 0x000d001f, /* DENALI_PI_95_DATA */ - 0x000d001f, /* DENALI_PI_96_DATA */ - 0x000d001f, /* DENALI_PI_97_DATA */ - 0x00000000, /* DENALI_PI_98_DATA */ - 0x00000000, /* DENALI_PI_99_DATA */ - 0x00000100, /* DENALI_PI_100_DATA */ - 0x140a0000, /* DENALI_PI_101_DATA */ - 0x000a020a, /* DENALI_PI_102_DATA */ - 0x02000a02, /* DENALI_PI_103_DATA */ - 0x010a000a, /* DENALI_PI_104_DATA */ - 0x00000100, /* DENALI_PI_105_DATA */ - 0x01000000, /* DENALI_PI_106_DATA */ - 0x00000000, /* DENALI_PI_107_DATA */ - 0x00000100, /* DENALI_PI_108_DATA */ - 0x1e1a0000, /* DENALI_PI_109_DATA */ - 0x10010204, /* DENALI_PI_110_DATA */ - 0x07070705, /* DENALI_PI_111_DATA */ - 0x20000202, /* DENALI_PI_112_DATA */ - 0x00201000, /* DENALI_PI_113_DATA */ - 0x00201000, /* DENALI_PI_114_DATA */ - 0x04041000, /* DENALI_PI_115_DATA */ - 0x0f0f0100, /* DENALI_PI_116_DATA */ - 0x0001010f, /* DENALI_PI_117_DATA */ - 0x004b004a, /* DENALI_PI_118_DATA */ - 0x1a030000, /* DENALI_PI_119_DATA */ - 0x0102041e, /* DENALI_PI_120_DATA */ - 0x34000000, /* DENALI_PI_121_DATA */ - 0x00000000, /* DENALI_PI_122_DATA */ - 0x00000000, /* DENALI_PI_123_DATA */ - 0x00000000, /* DENALI_PI_124_DATA */ - 0x00000300, /* DENALI_PI_125_DATA */ - 0x00010018, /* DENALI_PI_126_DATA */ - 0x004d4d07, /* DENALI_PI_127_DATA */ - 0x00180003, /* DENALI_PI_128_DATA */ - 0x4d070001, /* DENALI_PI_129_DATA */ - 0x0000034d, /* DENALI_PI_130_DATA */ - 0x00010018, /* DENALI_PI_131_DATA */ - 0x004d4d07, /* DENALI_PI_132_DATA */ - 0x00180003, /* DENALI_PI_133_DATA */ - 0x4d070001, /* DENALI_PI_134_DATA */ - 0x0000034d, /* DENALI_PI_135_DATA */ - 0x00010018, /* DENALI_PI_136_DATA */ - 0x004d4d07, /* DENALI_PI_137_DATA */ - 0x00180003, /* DENALI_PI_138_DATA */ - 0x4d070001, /* DENALI_PI_139_DATA */ - 0x0003004d, /* DENALI_PI_140_DATA */ - 0x00010018, /* DENALI_PI_141_DATA */ - 0x004d4d07, /* DENALI_PI_142_DATA */ - 0x00180003, /* DENALI_PI_143_DATA */ - 0x4d070001, /* DENALI_PI_144_DATA */ - 0x0000034d, /* DENALI_PI_145_DATA */ - 0x00010018, /* DENALI_PI_146_DATA */ - 0x004d4d07, /* DENALI_PI_147_DATA */ - 0x00180003, /* DENALI_PI_148_DATA */ - 0x4d070001, /* DENALI_PI_149_DATA */ - 0x0000034d, /* DENALI_PI_150_DATA */ - 0x00010018, /* DENALI_PI_151_DATA */ - 0x004d4d07, /* DENALI_PI_152_DATA */ - 0x00180003, /* DENALI_PI_153_DATA */ - 0x4d070001, /* DENALI_PI_154_DATA */ - 0x0100004d, /* DENALI_PI_155_DATA */ - 0x00a700a7, /* DENALI_PI_156_DATA */ - 0x050400a7, /* DENALI_PI_157_DATA */ - 0x0a050c0e, /* DENALI_PI_158_DATA */ - 0x1c00b477, /* DENALI_PI_159_DATA */ - 0x0a0a2004, /* DENALI_PI_160_DATA */ - 0x0c0e050a, /* DENALI_PI_161_DATA */ - 0x00000a05, /* DENALI_PI_162_DATA */ - 0x1c00b477, /* DENALI_PI_163_DATA */ - 0x0a0a2004, /* DENALI_PI_164_DATA */ - 0x0c0e050a, /* DENALI_PI_165_DATA */ - 0x00000a05, /* DENALI_PI_166_DATA */ - 0x1c00b477, /* DENALI_PI_167_DATA */ - 0x0a0a2004, /* DENALI_PI_168_DATA */ - 0x0200020a, /* DENALI_PI_169_DATA */ - 0x02000200, /* DENALI_PI_170_DATA */ - 0x02000200, /* DENALI_PI_171_DATA */ - 0x02000200, /* DENALI_PI_172_DATA */ - 0x02000200, /* DENALI_PI_173_DATA */ - 0x00000000, /* DENALI_PI_174_DATA */ - 0x00000000, /* DENALI_PI_175_DATA */ - 0x00000000, /* DENALI_PI_176_DATA */ - 0x00000000, /* DENALI_PI_177_DATA */ - 0x00000000, /* DENALI_PI_178_DATA */ - 0x00000000, /* DENALI_PI_179_DATA */ - 0x00000000, /* DENALI_PI_180_DATA */ - 0x00000000, /* DENALI_PI_181_DATA */ - 0x00000000, /* DENALI_PI_182_DATA */ - 0x00000000, /* DENALI_PI_183_DATA */ - 0x00000000, /* DENALI_PI_184_DATA */ - 0x00000000, /* DENALI_PI_185_DATA */ - 0x01000300, /* DENALI_PI_186_DATA */ - 0x00144000, /* DENALI_PI_187_DATA */ - 0x0000ca80, /* DENALI_PI_188_DATA */ - 0x00001440, /* DENALI_PI_189_DATA */ - 0x0000ca80, /* DENALI_PI_190_DATA */ - 0x00001440, /* DENALI_PI_191_DATA */ - 0x0000ca80, /* DENALI_PI_192_DATA */ - 0x08000000, /* DENALI_PI_193_DATA */ - 0x00000100, /* DENALI_PI_194_DATA */ - 0x00000000, /* DENALI_PI_195_DATA */ - 0x00000000, /* DENALI_PI_196_DATA */ - 0x00000000, /* DENALI_PI_197_DATA */ - 0x00000000, /* DENALI_PI_198_DATA */ - 0x00000002 /* DENALI_PI_199_DATA */ - } - }, - { - { - 0x76543210, /* DENALI_PHY_00_DATA */ - 0x0004c008, /* DENALI_PHY_01_DATA */ - 0x000001c4, /* DENALI_PHY_02_DATA */ - 0x00000000, /* DENALI_PHY_03_DATA */ - 0x00000000, /* DENALI_PHY_04_DATA */ - 0x00010000, /* DENALI_PHY_05_DATA */ - 0x01665555, /* DENALI_PHY_06_DATA */ - 0x00665555, /* DENALI_PHY_07_DATA */ - 0x00010f00, /* DENALI_PHY_08_DATA */ - 0x05000100, /* DENALI_PHY_09_DATA */ - 0x00000002, /* DENALI_PHY_10_DATA */ - 0x001700c0, /* DENALI_PHY_11_DATA */ - 0x00cc0101, /* DENALI_PHY_12_DATA */ - 0x00030066, /* DENALI_PHY_13_DATA */ - 0x00000000, /* DENALI_PHY_14_DATA */ - 0x00000000, /* DENALI_PHY_15_DATA */ - 0x00000000, /* DENALI_PHY_16_DATA */ - 0x00000000, /* DENALI_PHY_17_DATA */ - 0x00000000, /* DENALI_PHY_18_DATA */ - 0x00000000, /* DENALI_PHY_19_DATA */ - 0x00000000, /* DENALI_PHY_20_DATA */ - 0x00000000, /* DENALI_PHY_21_DATA */ - 0x04080000, /* DENALI_PHY_22_DATA */ - 0x04080400, /* DENALI_PHY_23_DATA */ - 0x08000000, /* DENALI_PHY_24_DATA */ - 0x0c00c007, /* DENALI_PHY_25_DATA */ - 0x00000100, /* DENALI_PHY_26_DATA */ - 0x00000100, /* DENALI_PHY_27_DATA */ - 0x55555555, /* DENALI_PHY_28_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_29_DATA */ - 0x55555555, /* DENALI_PHY_30_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_31_DATA */ - 0x00005555, /* DENALI_PHY_32_DATA */ - 0x00000000, /* DENALI_PHY_33_DATA */ - 0x00000000, /* DENALI_PHY_34_DATA */ - 0x00000000, /* DENALI_PHY_35_DATA */ - 0x00000000, /* DENALI_PHY_36_DATA */ - 0x00000000, /* DENALI_PHY_37_DATA */ - 0x00000000, /* DENALI_PHY_38_DATA */ - 0x00000000, /* DENALI_PHY_39_DATA */ - 0x00000000, /* DENALI_PHY_40_DATA */ - 0x00000000, /* DENALI_PHY_41_DATA */ - 0x00000000, /* DENALI_PHY_42_DATA */ - 0x00000000, /* DENALI_PHY_43_DATA */ - 0x00000000, /* DENALI_PHY_44_DATA */ - 0x00000000, /* DENALI_PHY_45_DATA */ - 0x00000000, /* DENALI_PHY_46_DATA */ - 0x00000000, /* DENALI_PHY_47_DATA */ - 0x00000000, /* DENALI_PHY_48_DATA */ - 0x00000000, /* DENALI_PHY_49_DATA */ - 0x00000000, /* DENALI_PHY_50_DATA */ - 0x00000000, /* DENALI_PHY_51_DATA */ - 0x00200000, /* DENALI_PHY_52_DATA */ - 0x00000000, /* DENALI_PHY_53_DATA */ - 0x00000000, /* DENALI_PHY_54_DATA */ - 0x00000000, /* DENALI_PHY_55_DATA */ - 0x00000000, /* DENALI_PHY_56_DATA */ - 0x00000000, /* DENALI_PHY_57_DATA */ - 0x00000000, /* DENALI_PHY_58_DATA */ - 0x02800280, /* DENALI_PHY_59_DATA */ - 0x02800280, /* DENALI_PHY_60_DATA */ - 0x02800280, /* DENALI_PHY_61_DATA */ - 0x02800280, /* DENALI_PHY_62_DATA */ - 0x00000280, /* DENALI_PHY_63_DATA */ - 0x00000000, /* DENALI_PHY_64_DATA */ - 0x00000000, /* DENALI_PHY_65_DATA */ - 0x00000000, /* DENALI_PHY_66_DATA */ - 0x00000000, /* DENALI_PHY_67_DATA */ - 0x00800000, /* DENALI_PHY_68_DATA */ - 0x00800080, /* DENALI_PHY_69_DATA */ - 0x00800080, /* DENALI_PHY_70_DATA */ - 0x00800080, /* DENALI_PHY_71_DATA */ - 0x00800080, /* DENALI_PHY_72_DATA */ - 0x00800080, /* DENALI_PHY_73_DATA */ - 0x00800080, /* DENALI_PHY_74_DATA */ - 0x00800080, /* DENALI_PHY_75_DATA */ - 0x00800080, /* DENALI_PHY_76_DATA */ - 0x01c40080, /* DENALI_PHY_77_DATA */ - 0x01900002, /* DENALI_PHY_78_DATA */ - 0x00000000, /* DENALI_PHY_79_DATA */ - 0x00020000, /* DENALI_PHY_80_DATA */ - 0x00000200, /* DENALI_PHY_81_DATA */ - 0x00000000, /* DENALI_PHY_82_DATA */ - 0x51315152, /* DENALI_PHY_83_DATA */ - 0xc0013150, /* DENALI_PHY_84_DATA */ - 0x010000c0, /* DENALI_PHY_85_DATA */ - 0x00100000, /* DENALI_PHY_86_DATA */ - 0x0c054208, /* DENALI_PHY_87_DATA */ - 0x000f0c18, /* DENALI_PHY_88_DATA */ - 0x01000140, /* DENALI_PHY_89_DATA */ - 0x00000c20, /* DENALI_PHY_90_DATA */ - 0x00000000, /* DENALI_PHY_91_DATA */ - 0x00000000, /* DENALI_PHY_92_DATA */ - 0x00000000, /* DENALI_PHY_93_DATA */ - 0x00000000, /* DENALI_PHY_94_DATA */ - 0x00000000, /* DENALI_PHY_95_DATA */ - 0x00000000, /* DENALI_PHY_96_DATA */ - 0x00000000, /* DENALI_PHY_97_DATA */ - 0x00000000, /* DENALI_PHY_98_DATA */ - 0x00000000, /* DENALI_PHY_99_DATA */ - 0x00000000, /* DENALI_PHY_100_DATA */ - 0x00000000, /* DENALI_PHY_101_DATA */ - 0x00000000, /* DENALI_PHY_102_DATA */ - 0x00000000, /* DENALI_PHY_103_DATA */ - 0x00000000, /* DENALI_PHY_104_DATA */ - 0x00000000, /* DENALI_PHY_105_DATA */ - 0x00000000, /* DENALI_PHY_106_DATA */ - 0x00000000, /* DENALI_PHY_107_DATA */ - 0x00000000, /* DENALI_PHY_108_DATA */ - 0x00000000, /* DENALI_PHY_109_DATA */ - 0x00000000, /* DENALI_PHY_110_DATA */ - 0x00000000, /* DENALI_PHY_111_DATA */ - 0x00000000, /* DENALI_PHY_112_DATA */ - 0x00000000, /* DENALI_PHY_113_DATA */ - 0x00000000, /* DENALI_PHY_114_DATA */ - 0x00000000, /* DENALI_PHY_115_DATA */ - 0x00000000, /* DENALI_PHY_116_DATA */ - 0x00000000, /* DENALI_PHY_117_DATA */ - 0x00000000, /* DENALI_PHY_118_DATA */ - 0x00000000, /* DENALI_PHY_119_DATA */ - 0x00000000, /* DENALI_PHY_120_DATA */ - 0x00000000, /* DENALI_PHY_121_DATA */ - 0x00000000, /* DENALI_PHY_122_DATA */ - 0x00000000, /* DENALI_PHY_123_DATA */ - 0x00000000, /* DENALI_PHY_124_DATA */ - 0x00000000, /* DENALI_PHY_125_DATA */ - 0x00000000, /* DENALI_PHY_126_DATA */ - 0x00000000, /* DENALI_PHY_127_DATA */ - 0x76543210, /* DENALI_PHY_128_DATA */ - 0x0004c008, /* DENALI_PHY_129_DATA */ - 0x000001c4, /* DENALI_PHY_130_DATA */ - 0x00000000, /* DENALI_PHY_131_DATA */ - 0x00000000, /* DENALI_PHY_132_DATA */ - 0x00010000, /* DENALI_PHY_133_DATA */ - 0x01665555, /* DENALI_PHY_134_DATA */ - 0x00665555, /* DENALI_PHY_135_DATA */ - 0x00010f00, /* DENALI_PHY_136_DATA */ - 0x05000100, /* DENALI_PHY_137_DATA */ - 0x00000002, /* DENALI_PHY_138_DATA */ - 0x001700c0, /* DENALI_PHY_139_DATA */ - 0x00cc0101, /* DENALI_PHY_140_DATA */ - 0x00030066, /* DENALI_PHY_141_DATA */ - 0x00000000, /* DENALI_PHY_142_DATA */ - 0x00000000, /* DENALI_PHY_143_DATA */ - 0x00000000, /* DENALI_PHY_144_DATA */ - 0x00000000, /* DENALI_PHY_145_DATA */ - 0x00000000, /* DENALI_PHY_146_DATA */ - 0x00000000, /* DENALI_PHY_147_DATA */ - 0x00000000, /* DENALI_PHY_148_DATA */ - 0x00000000, /* DENALI_PHY_149_DATA */ - 0x04080000, /* DENALI_PHY_150_DATA */ - 0x04080400, /* DENALI_PHY_151_DATA */ - 0x08000000, /* DENALI_PHY_152_DATA */ - 0x0c00c007, /* DENALI_PHY_153_DATA */ - 0x00000100, /* DENALI_PHY_154_DATA */ - 0x00000100, /* DENALI_PHY_155_DATA */ - 0x55555555, /* DENALI_PHY_156_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_157_DATA */ - 0x55555555, /* DENALI_PHY_158_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_159_DATA */ - 0x00005555, /* DENALI_PHY_160_DATA */ - 0x00000000, /* DENALI_PHY_161_DATA */ - 0x00000000, /* DENALI_PHY_162_DATA */ - 0x00000000, /* DENALI_PHY_163_DATA */ - 0x00000000, /* DENALI_PHY_164_DATA */ - 0x00000000, /* DENALI_PHY_165_DATA */ - 0x00000000, /* DENALI_PHY_166_DATA */ - 0x00000000, /* DENALI_PHY_167_DATA */ - 0x00000000, /* DENALI_PHY_168_DATA */ - 0x00000000, /* DENALI_PHY_169_DATA */ - 0x00000000, /* DENALI_PHY_170_DATA */ - 0x00000000, /* DENALI_PHY_171_DATA */ - 0x00000000, /* DENALI_PHY_172_DATA */ - 0x00000000, /* DENALI_PHY_173_DATA */ - 0x00000000, /* DENALI_PHY_174_DATA */ - 0x00000000, /* DENALI_PHY_175_DATA */ - 0x00000000, /* DENALI_PHY_176_DATA */ - 0x00000000, /* DENALI_PHY_177_DATA */ - 0x00000000, /* DENALI_PHY_178_DATA */ - 0x00000000, /* DENALI_PHY_179_DATA */ - 0x00200000, /* DENALI_PHY_180_DATA */ - 0x00000000, /* DENALI_PHY_181_DATA */ - 0x00000000, /* DENALI_PHY_182_DATA */ - 0x00000000, /* DENALI_PHY_183_DATA */ - 0x00000000, /* DENALI_PHY_184_DATA */ - 0x00000000, /* DENALI_PHY_185_DATA */ - 0x00000000, /* DENALI_PHY_186_DATA */ - 0x02800280, /* DENALI_PHY_187_DATA */ - 0x02800280, /* DENALI_PHY_188_DATA */ - 0x02800280, /* DENALI_PHY_189_DATA */ - 0x02800280, /* DENALI_PHY_190_DATA */ - 0x00000280, /* DENALI_PHY_191_DATA */ - 0x00000000, /* DENALI_PHY_192_DATA */ - 0x00000000, /* DENALI_PHY_193_DATA */ - 0x00000000, /* DENALI_PHY_194_DATA */ - 0x00000000, /* DENALI_PHY_195_DATA */ - 0x00800000, /* DENALI_PHY_196_DATA */ - 0x00800080, /* DENALI_PHY_197_DATA */ - 0x00800080, /* DENALI_PHY_198_DATA */ - 0x00800080, /* DENALI_PHY_199_DATA */ - 0x00800080, /* DENALI_PHY_200_DATA */ - 0x00800080, /* DENALI_PHY_201_DATA */ - 0x00800080, /* DENALI_PHY_202_DATA */ - 0x00800080, /* DENALI_PHY_203_DATA */ - 0x00800080, /* DENALI_PHY_204_DATA */ - 0x01c40080, /* DENALI_PHY_205_DATA */ - 0x01900002, /* DENALI_PHY_206_DATA */ - 0x00000000, /* DENALI_PHY_207_DATA */ - 0x00020000, /* DENALI_PHY_208_DATA */ - 0x00000200, /* DENALI_PHY_209_DATA */ - 0x00000000, /* DENALI_PHY_210_DATA */ - 0x51315152, /* DENALI_PHY_211_DATA */ - 0xc0013150, /* DENALI_PHY_212_DATA */ - 0x010000c0, /* DENALI_PHY_213_DATA */ - 0x00100000, /* DENALI_PHY_214_DATA */ - 0x0c054208, /* DENALI_PHY_215_DATA */ - 0x000f0c18, /* DENALI_PHY_216_DATA */ - 0x01000140, /* DENALI_PHY_217_DATA */ - 0x00000c20, /* DENALI_PHY_218_DATA */ - 0x00000000, /* DENALI_PHY_219_DATA */ - 0x00000000, /* DENALI_PHY_220_DATA */ - 0x00000000, /* DENALI_PHY_221_DATA */ - 0x00000000, /* DENALI_PHY_222_DATA */ - 0x00000000, /* DENALI_PHY_223_DATA */ - 0x00000000, /* DENALI_PHY_224_DATA */ - 0x00000000, /* DENALI_PHY_225_DATA */ - 0x00000000, /* DENALI_PHY_226_DATA */ - 0x00000000, /* DENALI_PHY_227_DATA */ - 0x00000000, /* DENALI_PHY_228_DATA */ - 0x00000000, /* DENALI_PHY_229_DATA */ - 0x00000000, /* DENALI_PHY_230_DATA */ - 0x00000000, /* DENALI_PHY_231_DATA */ - 0x00000000, /* DENALI_PHY_232_DATA */ - 0x00000000, /* DENALI_PHY_233_DATA */ - 0x00000000, /* DENALI_PHY_234_DATA */ - 0x00000000, /* DENALI_PHY_235_DATA */ - 0x00000000, /* DENALI_PHY_236_DATA */ - 0x00000000, /* DENALI_PHY_237_DATA */ - 0x00000000, /* DENALI_PHY_238_DATA */ - 0x00000000, /* DENALI_PHY_239_DATA */ - 0x00000000, /* DENALI_PHY_240_DATA */ - 0x00000000, /* DENALI_PHY_241_DATA */ - 0x00000000, /* DENALI_PHY_242_DATA */ - 0x00000000, /* DENALI_PHY_243_DATA */ - 0x00000000, /* DENALI_PHY_244_DATA */ - 0x00000000, /* DENALI_PHY_245_DATA */ - 0x00000000, /* DENALI_PHY_246_DATA */ - 0x00000000, /* DENALI_PHY_247_DATA */ - 0x00000000, /* DENALI_PHY_248_DATA */ - 0x00000000, /* DENALI_PHY_249_DATA */ - 0x00000000, /* DENALI_PHY_250_DATA */ - 0x00000000, /* DENALI_PHY_251_DATA */ - 0x00000000, /* DENALI_PHY_252_DATA */ - 0x00000000, /* DENALI_PHY_253_DATA */ - 0x00000000, /* DENALI_PHY_254_DATA */ - 0x00000000, /* DENALI_PHY_255_DATA */ - 0x76543210, /* DENALI_PHY_256_DATA */ - 0x0004c008, /* DENALI_PHY_257_DATA */ - 0x000001c4, /* DENALI_PHY_258_DATA */ - 0x00000000, /* DENALI_PHY_259_DATA */ - 0x00000000, /* DENALI_PHY_260_DATA */ - 0x00010000, /* DENALI_PHY_261_DATA */ - 0x01665555, /* DENALI_PHY_262_DATA */ - 0x00665555, /* DENALI_PHY_263_DATA */ - 0x00010f00, /* DENALI_PHY_264_DATA */ - 0x05000100, /* DENALI_PHY_265_DATA */ - 0x00000002, /* DENALI_PHY_266_DATA */ - 0x001700c0, /* DENALI_PHY_267_DATA */ - 0x00cc0101, /* DENALI_PHY_268_DATA */ - 0x00030066, /* DENALI_PHY_269_DATA */ - 0x00000000, /* DENALI_PHY_270_DATA */ - 0x00000000, /* DENALI_PHY_271_DATA */ - 0x00000000, /* DENALI_PHY_272_DATA */ - 0x00000000, /* DENALI_PHY_273_DATA */ - 0x00000000, /* DENALI_PHY_274_DATA */ - 0x00000000, /* DENALI_PHY_275_DATA */ - 0x00000000, /* DENALI_PHY_276_DATA */ - 0x00000000, /* DENALI_PHY_277_DATA */ - 0x04080000, /* DENALI_PHY_278_DATA */ - 0x04080400, /* DENALI_PHY_279_DATA */ - 0x08000000, /* DENALI_PHY_280_DATA */ - 0x0c00c007, /* DENALI_PHY_281_DATA */ - 0x00000100, /* DENALI_PHY_282_DATA */ - 0x00000100, /* DENALI_PHY_283_DATA */ - 0x55555555, /* DENALI_PHY_284_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_285_DATA */ - 0x55555555, /* DENALI_PHY_286_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_287_DATA */ - 0x00005555, /* DENALI_PHY_288_DATA */ - 0x00000000, /* DENALI_PHY_289_DATA */ - 0x00000000, /* DENALI_PHY_290_DATA */ - 0x00000000, /* DENALI_PHY_291_DATA */ - 0x00000000, /* DENALI_PHY_292_DATA */ - 0x00000000, /* DENALI_PHY_293_DATA */ - 0x00000000, /* DENALI_PHY_294_DATA */ - 0x00000000, /* DENALI_PHY_295_DATA */ - 0x00000000, /* DENALI_PHY_296_DATA */ - 0x00000000, /* DENALI_PHY_297_DATA */ - 0x00000000, /* DENALI_PHY_298_DATA */ - 0x00000000, /* DENALI_PHY_299_DATA */ - 0x00000000, /* DENALI_PHY_300_DATA */ - 0x00000000, /* DENALI_PHY_301_DATA */ - 0x00000000, /* DENALI_PHY_302_DATA */ - 0x00000000, /* DENALI_PHY_303_DATA */ - 0x00000000, /* DENALI_PHY_304_DATA */ - 0x00000000, /* DENALI_PHY_305_DATA */ - 0x00000000, /* DENALI_PHY_306_DATA */ - 0x00000000, /* DENALI_PHY_307_DATA */ - 0x00200000, /* DENALI_PHY_308_DATA */ - 0x00000000, /* DENALI_PHY_309_DATA */ - 0x00000000, /* DENALI_PHY_310_DATA */ - 0x00000000, /* DENALI_PHY_311_DATA */ - 0x00000000, /* DENALI_PHY_312_DATA */ - 0x00000000, /* DENALI_PHY_313_DATA */ - 0x00000000, /* DENALI_PHY_314_DATA */ - 0x02800280, /* DENALI_PHY_315_DATA */ - 0x02800280, /* DENALI_PHY_316_DATA */ - 0x02800280, /* DENALI_PHY_317_DATA */ - 0x02800280, /* DENALI_PHY_318_DATA */ - 0x00000280, /* DENALI_PHY_319_DATA */ - 0x00000000, /* DENALI_PHY_320_DATA */ - 0x00000000, /* DENALI_PHY_321_DATA */ - 0x00000000, /* DENALI_PHY_322_DATA */ - 0x00000000, /* DENALI_PHY_323_DATA */ - 0x00800000, /* DENALI_PHY_324_DATA */ - 0x00800080, /* DENALI_PHY_325_DATA */ - 0x00800080, /* DENALI_PHY_326_DATA */ - 0x00800080, /* DENALI_PHY_327_DATA */ - 0x00800080, /* DENALI_PHY_328_DATA */ - 0x00800080, /* DENALI_PHY_329_DATA */ - 0x00800080, /* DENALI_PHY_330_DATA */ - 0x00800080, /* DENALI_PHY_331_DATA */ - 0x00800080, /* DENALI_PHY_332_DATA */ - 0x01c40080, /* DENALI_PHY_333_DATA */ - 0x01900002, /* DENALI_PHY_334_DATA */ - 0x00000000, /* DENALI_PHY_335_DATA */ - 0x00020000, /* DENALI_PHY_336_DATA */ - 0x00000200, /* DENALI_PHY_337_DATA */ - 0x00000000, /* DENALI_PHY_338_DATA */ - 0x51315152, /* DENALI_PHY_339_DATA */ - 0xc0013150, /* DENALI_PHY_340_DATA */ - 0x010000c0, /* DENALI_PHY_341_DATA */ - 0x00100000, /* DENALI_PHY_342_DATA */ - 0x0c054208, /* DENALI_PHY_343_DATA */ - 0x000f0c18, /* DENALI_PHY_344_DATA */ - 0x01000140, /* DENALI_PHY_345_DATA */ - 0x00000c20, /* DENALI_PHY_346_DATA */ - 0x00000000, /* DENALI_PHY_347_DATA */ - 0x00000000, /* DENALI_PHY_348_DATA */ - 0x00000000, /* DENALI_PHY_349_DATA */ - 0x00000000, /* DENALI_PHY_350_DATA */ - 0x00000000, /* DENALI_PHY_351_DATA */ - 0x00000000, /* DENALI_PHY_352_DATA */ - 0x00000000, /* DENALI_PHY_353_DATA */ - 0x00000000, /* DENALI_PHY_354_DATA */ - 0x00000000, /* DENALI_PHY_355_DATA */ - 0x00000000, /* DENALI_PHY_356_DATA */ - 0x00000000, /* DENALI_PHY_357_DATA */ - 0x00000000, /* DENALI_PHY_358_DATA */ - 0x00000000, /* DENALI_PHY_359_DATA */ - 0x00000000, /* DENALI_PHY_360_DATA */ - 0x00000000, /* DENALI_PHY_361_DATA */ - 0x00000000, /* DENALI_PHY_362_DATA */ - 0x00000000, /* DENALI_PHY_363_DATA */ - 0x00000000, /* DENALI_PHY_364_DATA */ - 0x00000000, /* DENALI_PHY_365_DATA */ - 0x00000000, /* DENALI_PHY_366_DATA */ - 0x00000000, /* DENALI_PHY_367_DATA */ - 0x00000000, /* DENALI_PHY_368_DATA */ - 0x00000000, /* DENALI_PHY_369_DATA */ - 0x00000000, /* DENALI_PHY_370_DATA */ - 0x00000000, /* DENALI_PHY_371_DATA */ - 0x00000000, /* DENALI_PHY_372_DATA */ - 0x00000000, /* DENALI_PHY_373_DATA */ - 0x00000000, /* DENALI_PHY_374_DATA */ - 0x00000000, /* DENALI_PHY_375_DATA */ - 0x00000000, /* DENALI_PHY_376_DATA */ - 0x00000000, /* DENALI_PHY_377_DATA */ - 0x00000000, /* DENALI_PHY_378_DATA */ - 0x00000000, /* DENALI_PHY_379_DATA */ - 0x00000000, /* DENALI_PHY_380_DATA */ - 0x00000000, /* DENALI_PHY_381_DATA */ - 0x00000000, /* DENALI_PHY_382_DATA */ - 0x00000000, /* DENALI_PHY_383_DATA */ - 0x76543210, /* DENALI_PHY_384_DATA */ - 0x0004c008, /* DENALI_PHY_385_DATA */ - 0x000001c4, /* DENALI_PHY_386_DATA */ - 0x00000000, /* DENALI_PHY_387_DATA */ - 0x00000000, /* DENALI_PHY_388_DATA */ - 0x00010000, /* DENALI_PHY_389_DATA */ - 0x01665555, /* DENALI_PHY_390_DATA */ - 0x00665555, /* DENALI_PHY_391_DATA */ - 0x00010f00, /* DENALI_PHY_392_DATA */ - 0x05000100, /* DENALI_PHY_393_DATA */ - 0x00000002, /* DENALI_PHY_394_DATA */ - 0x001700c0, /* DENALI_PHY_395_DATA */ - 0x00cc0101, /* DENALI_PHY_396_DATA */ - 0x00030066, /* DENALI_PHY_397_DATA */ - 0x00000000, /* DENALI_PHY_398_DATA */ - 0x00000000, /* DENALI_PHY_399_DATA */ - 0x00000000, /* DENALI_PHY_400_DATA */ - 0x00000000, /* DENALI_PHY_401_DATA */ - 0x00000000, /* DENALI_PHY_402_DATA */ - 0x00000000, /* DENALI_PHY_403_DATA */ - 0x00000000, /* DENALI_PHY_404_DATA */ - 0x00000000, /* DENALI_PHY_405_DATA */ - 0x04080000, /* DENALI_PHY_406_DATA */ - 0x04080400, /* DENALI_PHY_407_DATA */ - 0x08000000, /* DENALI_PHY_408_DATA */ - 0x0c00c007, /* DENALI_PHY_409_DATA */ - 0x00000100, /* DENALI_PHY_410_DATA */ - 0x00000100, /* DENALI_PHY_411_DATA */ - 0x55555555, /* DENALI_PHY_412_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_413_DATA */ - 0x55555555, /* DENALI_PHY_414_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_415_DATA */ - 0x00005555, /* DENALI_PHY_416_DATA */ - 0x00000000, /* DENALI_PHY_417_DATA */ - 0x00000000, /* DENALI_PHY_418_DATA */ - 0x00000000, /* DENALI_PHY_419_DATA */ - 0x00000000, /* DENALI_PHY_420_DATA */ - 0x00000000, /* DENALI_PHY_421_DATA */ - 0x00000000, /* DENALI_PHY_422_DATA */ - 0x00000000, /* DENALI_PHY_423_DATA */ - 0x00000000, /* DENALI_PHY_424_DATA */ - 0x00000000, /* DENALI_PHY_425_DATA */ - 0x00000000, /* DENALI_PHY_426_DATA */ - 0x00000000, /* DENALI_PHY_427_DATA */ - 0x00000000, /* DENALI_PHY_428_DATA */ - 0x00000000, /* DENALI_PHY_429_DATA */ - 0x00000000, /* DENALI_PHY_430_DATA */ - 0x00000000, /* DENALI_PHY_431_DATA */ - 0x00000000, /* DENALI_PHY_432_DATA */ - 0x00000000, /* DENALI_PHY_433_DATA */ - 0x00000000, /* DENALI_PHY_434_DATA */ - 0x00000000, /* DENALI_PHY_435_DATA */ - 0x00200000, /* DENALI_PHY_436_DATA */ - 0x00000000, /* DENALI_PHY_437_DATA */ - 0x00000000, /* DENALI_PHY_438_DATA */ - 0x00000000, /* DENALI_PHY_439_DATA */ - 0x00000000, /* DENALI_PHY_440_DATA */ - 0x00000000, /* DENALI_PHY_441_DATA */ - 0x00000000, /* DENALI_PHY_442_DATA */ - 0x02800280, /* DENALI_PHY_443_DATA */ - 0x02800280, /* DENALI_PHY_444_DATA */ - 0x02800280, /* DENALI_PHY_445_DATA */ - 0x02800280, /* DENALI_PHY_446_DATA */ - 0x00000280, /* DENALI_PHY_447_DATA */ - 0x00000000, /* DENALI_PHY_448_DATA */ - 0x00000000, /* DENALI_PHY_449_DATA */ - 0x00000000, /* DENALI_PHY_450_DATA */ - 0x00000000, /* DENALI_PHY_451_DATA */ - 0x00800000, /* DENALI_PHY_452_DATA */ - 0x00800080, /* DENALI_PHY_453_DATA */ - 0x00800080, /* DENALI_PHY_454_DATA */ - 0x00800080, /* DENALI_PHY_455_DATA */ - 0x00800080, /* DENALI_PHY_456_DATA */ - 0x00800080, /* DENALI_PHY_457_DATA */ - 0x00800080, /* DENALI_PHY_458_DATA */ - 0x00800080, /* DENALI_PHY_459_DATA */ - 0x00800080, /* DENALI_PHY_460_DATA */ - 0x01c40080, /* DENALI_PHY_461_DATA */ - 0x01900002, /* DENALI_PHY_462_DATA */ - 0x00000000, /* DENALI_PHY_463_DATA */ - 0x00020000, /* DENALI_PHY_464_DATA */ - 0x00000200, /* DENALI_PHY_465_DATA */ - 0x00000000, /* DENALI_PHY_466_DATA */ - 0x51315152, /* DENALI_PHY_467_DATA */ - 0xc0013150, /* DENALI_PHY_468_DATA */ - 0x010000c0, /* DENALI_PHY_469_DATA */ - 0x00100000, /* DENALI_PHY_470_DATA */ - 0x0c054208, /* DENALI_PHY_471_DATA */ - 0x000f0c18, /* DENALI_PHY_472_DATA */ - 0x01000140, /* DENALI_PHY_473_DATA */ - 0x00000c20, /* DENALI_PHY_474_DATA */ - 0x00000000, /* DENALI_PHY_475_DATA */ - 0x00000000, /* DENALI_PHY_476_DATA */ - 0x00000000, /* DENALI_PHY_477_DATA */ - 0x00000000, /* DENALI_PHY_478_DATA */ - 0x00000000, /* DENALI_PHY_479_DATA */ - 0x00000000, /* DENALI_PHY_480_DATA */ - 0x00000000, /* DENALI_PHY_481_DATA */ - 0x00000000, /* DENALI_PHY_482_DATA */ - 0x00000000, /* DENALI_PHY_483_DATA */ - 0x00000000, /* DENALI_PHY_484_DATA */ - 0x00000000, /* DENALI_PHY_485_DATA */ - 0x00000000, /* DENALI_PHY_486_DATA */ - 0x00000000, /* DENALI_PHY_487_DATA */ - 0x00000000, /* DENALI_PHY_488_DATA */ - 0x00000000, /* DENALI_PHY_489_DATA */ - 0x00000000, /* DENALI_PHY_490_DATA */ - 0x00000000, /* DENALI_PHY_491_DATA */ - 0x00000000, /* DENALI_PHY_492_DATA */ - 0x00000000, /* DENALI_PHY_493_DATA */ - 0x00000000, /* DENALI_PHY_494_DATA */ - 0x00000000, /* DENALI_PHY_495_DATA */ - 0x00000000, /* DENALI_PHY_496_DATA */ - 0x00000000, /* DENALI_PHY_497_DATA */ - 0x00000000, /* DENALI_PHY_498_DATA */ - 0x00000000, /* DENALI_PHY_499_DATA */ - 0x00000000, /* DENALI_PHY_500_DATA */ - 0x00000000, /* DENALI_PHY_501_DATA */ - 0x00000000, /* DENALI_PHY_502_DATA */ - 0x00000000, /* DENALI_PHY_503_DATA */ - 0x00000000, /* DENALI_PHY_504_DATA */ - 0x00000000, /* DENALI_PHY_505_DATA */ - 0x00000000, /* DENALI_PHY_506_DATA */ - 0x00000000, /* DENALI_PHY_507_DATA */ - 0x00000000, /* DENALI_PHY_508_DATA */ - 0x00000000, /* DENALI_PHY_509_DATA */ - 0x00000000, /* DENALI_PHY_510_DATA */ - 0x00000000, /* DENALI_PHY_511_DATA */ - 0x00000000, /* DENALI_PHY_512_DATA */ - 0x00800000, /* DENALI_PHY_513_DATA */ - 0x00000000, /* DENALI_PHY_514_DATA */ - 0x00000000, /* DENALI_PHY_515_DATA */ - 0x00000000, /* DENALI_PHY_516_DATA */ - 0x00000000, /* DENALI_PHY_517_DATA */ - 0x00000000, /* DENALI_PHY_518_DATA */ - 0x00000001, /* DENALI_PHY_519_DATA */ - 0x00000000, /* DENALI_PHY_520_DATA */ - 0x00000000, /* DENALI_PHY_521_DATA */ - 0x00000000, /* DENALI_PHY_522_DATA */ - 0x00400320, /* DENALI_PHY_523_DATA */ - 0x00000040, /* DENALI_PHY_524_DATA */ - 0x00806420, /* DENALI_PHY_525_DATA */ - 0x00917531, /* DENALI_PHY_526_DATA */ - 0x00806420, /* DENALI_PHY_527_DATA */ - 0x01917531, /* DENALI_PHY_528_DATA */ - 0x00020003, /* DENALI_PHY_529_DATA */ - 0x00000000, /* DENALI_PHY_530_DATA */ - 0x00000000, /* DENALI_PHY_531_DATA */ - 0x00000000, /* DENALI_PHY_532_DATA */ - 0x000556aa, /* DENALI_PHY_533_DATA */ - 0x000aaaaa, /* DENALI_PHY_534_DATA */ - 0x000aa955, /* DENALI_PHY_535_DATA */ - 0x00055555, /* DENALI_PHY_536_DATA */ - 0x000b3133, /* DENALI_PHY_537_DATA */ - 0x0004cd33, /* DENALI_PHY_538_DATA */ - 0x0004cecc, /* DENALI_PHY_539_DATA */ - 0x000b32cc, /* DENALI_PHY_540_DATA */ - 0x0a418820, /* DENALI_PHY_541_DATA */ - 0x103f0000, /* DENALI_PHY_542_DATA */ - 0x0000003f, /* DENALI_PHY_543_DATA */ - 0x00038055, /* DENALI_PHY_544_DATA */ - 0x03800380, /* DENALI_PHY_545_DATA */ - 0x03800380, /* DENALI_PHY_546_DATA */ - 0x00000380, /* DENALI_PHY_547_DATA */ - 0x42080010, /* DENALI_PHY_548_DATA */ - 0x00000003, /* DENALI_PHY_549_DATA */ - 0x00000000, /* DENALI_PHY_550_DATA */ - 0x00000000, /* DENALI_PHY_551_DATA */ - 0x00000000, /* DENALI_PHY_552_DATA */ - 0x00000000, /* DENALI_PHY_553_DATA */ - 0x00000000, /* DENALI_PHY_554_DATA */ - 0x00000000, /* DENALI_PHY_555_DATA */ - 0x00000000, /* DENALI_PHY_556_DATA */ - 0x00000000, /* DENALI_PHY_557_DATA */ - 0x00000000, /* DENALI_PHY_558_DATA */ - 0x00000000, /* DENALI_PHY_559_DATA */ - 0x00000000, /* DENALI_PHY_560_DATA */ - 0x00000000, /* DENALI_PHY_561_DATA */ - 0x00000000, /* DENALI_PHY_562_DATA */ - 0x00000000, /* DENALI_PHY_563_DATA */ - 0x00000000, /* DENALI_PHY_564_DATA */ - 0x00000000, /* DENALI_PHY_565_DATA */ - 0x00000000, /* DENALI_PHY_566_DATA */ - 0x00000000, /* DENALI_PHY_567_DATA */ - 0x00000000, /* DENALI_PHY_568_DATA */ - 0x00000000, /* DENALI_PHY_569_DATA */ - 0x00000000, /* DENALI_PHY_570_DATA */ - 0x00000000, /* DENALI_PHY_571_DATA */ - 0x00000000, /* DENALI_PHY_572_DATA */ - 0x00000000, /* DENALI_PHY_573_DATA */ - 0x00000000, /* DENALI_PHY_574_DATA */ - 0x00000000, /* DENALI_PHY_575_DATA */ - 0x00000000, /* DENALI_PHY_576_DATA */ - 0x00000000, /* DENALI_PHY_577_DATA */ - 0x00000000, /* DENALI_PHY_578_DATA */ - 0x00000000, /* DENALI_PHY_579_DATA */ - 0x00000000, /* DENALI_PHY_580_DATA */ - 0x00000000, /* DENALI_PHY_581_DATA */ - 0x00000000, /* DENALI_PHY_582_DATA */ - 0x00000000, /* DENALI_PHY_583_DATA */ - 0x00000000, /* DENALI_PHY_584_DATA */ - 0x00000000, /* DENALI_PHY_585_DATA */ - 0x00000000, /* DENALI_PHY_586_DATA */ - 0x00000000, /* DENALI_PHY_587_DATA */ - 0x00000000, /* DENALI_PHY_588_DATA */ - 0x00000000, /* DENALI_PHY_589_DATA */ - 0x00000000, /* DENALI_PHY_590_DATA */ - 0x00000000, /* DENALI_PHY_591_DATA */ - 0x00000000, /* DENALI_PHY_592_DATA */ - 0x00000000, /* DENALI_PHY_593_DATA */ - 0x00000000, /* DENALI_PHY_594_DATA */ - 0x00000000, /* DENALI_PHY_595_DATA */ - 0x00000000, /* DENALI_PHY_596_DATA */ - 0x00000000, /* DENALI_PHY_597_DATA */ - 0x00000000, /* DENALI_PHY_598_DATA */ - 0x00000000, /* DENALI_PHY_599_DATA */ - 0x00000000, /* DENALI_PHY_600_DATA */ - 0x00000000, /* DENALI_PHY_601_DATA */ - 0x00000000, /* DENALI_PHY_602_DATA */ - 0x00000000, /* DENALI_PHY_603_DATA */ - 0x00000000, /* DENALI_PHY_604_DATA */ - 0x00000000, /* DENALI_PHY_605_DATA */ - 0x00000000, /* DENALI_PHY_606_DATA */ - 0x00000000, /* DENALI_PHY_607_DATA */ - 0x00000000, /* DENALI_PHY_608_DATA */ - 0x00000000, /* DENALI_PHY_609_DATA */ - 0x00000000, /* DENALI_PHY_610_DATA */ - 0x00000000, /* DENALI_PHY_611_DATA */ - 0x00000000, /* DENALI_PHY_612_DATA */ - 0x00000000, /* DENALI_PHY_613_DATA */ - 0x00000000, /* DENALI_PHY_614_DATA */ - 0x00000000, /* DENALI_PHY_615_DATA */ - 0x00000000, /* DENALI_PHY_616_DATA */ - 0x00000000, /* DENALI_PHY_617_DATA */ - 0x00000000, /* DENALI_PHY_618_DATA */ - 0x00000000, /* DENALI_PHY_619_DATA */ - 0x00000000, /* DENALI_PHY_620_DATA */ - 0x00000000, /* DENALI_PHY_621_DATA */ - 0x00000000, /* DENALI_PHY_622_DATA */ - 0x00000000, /* DENALI_PHY_623_DATA */ - 0x00000000, /* DENALI_PHY_624_DATA */ - 0x00000000, /* DENALI_PHY_625_DATA */ - 0x00000000, /* DENALI_PHY_626_DATA */ - 0x00000000, /* DENALI_PHY_627_DATA */ - 0x00000000, /* DENALI_PHY_628_DATA */ - 0x00000000, /* DENALI_PHY_629_DATA */ - 0x00000000, /* DENALI_PHY_630_DATA */ - 0x00000000, /* DENALI_PHY_631_DATA */ - 0x00000000, /* DENALI_PHY_632_DATA */ - 0x00000000, /* DENALI_PHY_633_DATA */ - 0x00000000, /* DENALI_PHY_634_DATA */ - 0x00000000, /* DENALI_PHY_635_DATA */ - 0x00000000, /* DENALI_PHY_636_DATA */ - 0x00000000, /* DENALI_PHY_637_DATA */ - 0x00000000, /* DENALI_PHY_638_DATA */ - 0x00000000, /* DENALI_PHY_639_DATA */ - 0x00000000, /* DENALI_PHY_640_DATA */ - 0x00800000, /* DENALI_PHY_641_DATA */ - 0x00000000, /* DENALI_PHY_642_DATA */ - 0x00000000, /* DENALI_PHY_643_DATA */ - 0x00000000, /* DENALI_PHY_644_DATA */ - 0x00000000, /* DENALI_PHY_645_DATA */ - 0x00000000, /* DENALI_PHY_646_DATA */ - 0x00000001, /* DENALI_PHY_647_DATA */ - 0x00000000, /* DENALI_PHY_648_DATA */ - 0x00000000, /* DENALI_PHY_649_DATA */ - 0x00000000, /* DENALI_PHY_650_DATA */ - 0x00400320, /* DENALI_PHY_651_DATA */ - 0x00000040, /* DENALI_PHY_652_DATA */ - 0x00008eca, /* DENALI_PHY_653_DATA */ - 0x00009fdb, /* DENALI_PHY_654_DATA */ - 0x00008eca, /* DENALI_PHY_655_DATA */ - 0x01009fdb, /* DENALI_PHY_656_DATA */ - 0x00020003, /* DENALI_PHY_657_DATA */ - 0x00000000, /* DENALI_PHY_658_DATA */ - 0x00000000, /* DENALI_PHY_659_DATA */ - 0x00000000, /* DENALI_PHY_660_DATA */ - 0x000556aa, /* DENALI_PHY_661_DATA */ - 0x000aaaaa, /* DENALI_PHY_662_DATA */ - 0x000aa955, /* DENALI_PHY_663_DATA */ - 0x00055555, /* DENALI_PHY_664_DATA */ - 0x000b3133, /* DENALI_PHY_665_DATA */ - 0x0004cd33, /* DENALI_PHY_666_DATA */ - 0x0004cecc, /* DENALI_PHY_667_DATA */ - 0x000b32cc, /* DENALI_PHY_668_DATA */ - 0x0004a0e6, /* DENALI_PHY_669_DATA */ - 0x080f0000, /* DENALI_PHY_670_DATA */ - 0x0000000f, /* DENALI_PHY_671_DATA */ - 0x00038055, /* DENALI_PHY_672_DATA */ - 0x03800380, /* DENALI_PHY_673_DATA */ - 0x03800380, /* DENALI_PHY_674_DATA */ - 0x00000380, /* DENALI_PHY_675_DATA */ - 0x42080010, /* DENALI_PHY_676_DATA */ - 0x00000003, /* DENALI_PHY_677_DATA */ - 0x00000000, /* DENALI_PHY_678_DATA */ - 0x00000000, /* DENALI_PHY_679_DATA */ - 0x00000000, /* DENALI_PHY_680_DATA */ - 0x00000000, /* DENALI_PHY_681_DATA */ - 0x00000000, /* DENALI_PHY_682_DATA */ - 0x00000000, /* DENALI_PHY_683_DATA */ - 0x00000000, /* DENALI_PHY_684_DATA */ - 0x00000000, /* DENALI_PHY_685_DATA */ - 0x00000000, /* DENALI_PHY_686_DATA */ - 0x00000000, /* DENALI_PHY_687_DATA */ - 0x00000000, /* DENALI_PHY_688_DATA */ - 0x00000000, /* DENALI_PHY_689_DATA */ - 0x00000000, /* DENALI_PHY_690_DATA */ - 0x00000000, /* DENALI_PHY_691_DATA */ - 0x00000000, /* DENALI_PHY_692_DATA */ - 0x00000000, /* DENALI_PHY_693_DATA */ - 0x00000000, /* DENALI_PHY_694_DATA */ - 0x00000000, /* DENALI_PHY_695_DATA */ - 0x00000000, /* DENALI_PHY_696_DATA */ - 0x00000000, /* DENALI_PHY_697_DATA */ - 0x00000000, /* DENALI_PHY_698_DATA */ - 0x00000000, /* DENALI_PHY_699_DATA */ - 0x00000000, /* DENALI_PHY_700_DATA */ - 0x00000000, /* DENALI_PHY_701_DATA */ - 0x00000000, /* DENALI_PHY_702_DATA */ - 0x00000000, /* DENALI_PHY_703_DATA */ - 0x00000000, /* DENALI_PHY_704_DATA */ - 0x00000000, /* DENALI_PHY_705_DATA */ - 0x00000000, /* DENALI_PHY_706_DATA */ - 0x00000000, /* DENALI_PHY_707_DATA */ - 0x00000000, /* DENALI_PHY_708_DATA */ - 0x00000000, /* DENALI_PHY_709_DATA */ - 0x00000000, /* DENALI_PHY_710_DATA */ - 0x00000000, /* DENALI_PHY_711_DATA */ - 0x00000000, /* DENALI_PHY_712_DATA */ - 0x00000000, /* DENALI_PHY_713_DATA */ - 0x00000000, /* DENALI_PHY_714_DATA */ - 0x00000000, /* DENALI_PHY_715_DATA */ - 0x00000000, /* DENALI_PHY_716_DATA */ - 0x00000000, /* DENALI_PHY_717_DATA */ - 0x00000000, /* DENALI_PHY_718_DATA */ - 0x00000000, /* DENALI_PHY_719_DATA */ - 0x00000000, /* DENALI_PHY_720_DATA */ - 0x00000000, /* DENALI_PHY_721_DATA */ - 0x00000000, /* DENALI_PHY_722_DATA */ - 0x00000000, /* DENALI_PHY_723_DATA */ - 0x00000000, /* DENALI_PHY_724_DATA */ - 0x00000000, /* DENALI_PHY_725_DATA */ - 0x00000000, /* DENALI_PHY_726_DATA */ - 0x00000000, /* DENALI_PHY_727_DATA */ - 0x00000000, /* DENALI_PHY_728_DATA */ - 0x00000000, /* DENALI_PHY_729_DATA */ - 0x00000000, /* DENALI_PHY_730_DATA */ - 0x00000000, /* DENALI_PHY_731_DATA */ - 0x00000000, /* DENALI_PHY_732_DATA */ - 0x00000000, /* DENALI_PHY_733_DATA */ - 0x00000000, /* DENALI_PHY_734_DATA */ - 0x00000000, /* DENALI_PHY_735_DATA */ - 0x00000000, /* DENALI_PHY_736_DATA */ - 0x00000000, /* DENALI_PHY_737_DATA */ - 0x00000000, /* DENALI_PHY_738_DATA */ - 0x00000000, /* DENALI_PHY_739_DATA */ - 0x00000000, /* DENALI_PHY_740_DATA */ - 0x00000000, /* DENALI_PHY_741_DATA */ - 0x00000000, /* DENALI_PHY_742_DATA */ - 0x00000000, /* DENALI_PHY_743_DATA */ - 0x00000000, /* DENALI_PHY_744_DATA */ - 0x00000000, /* DENALI_PHY_745_DATA */ - 0x00000000, /* DENALI_PHY_746_DATA */ - 0x00000000, /* DENALI_PHY_747_DATA */ - 0x00000000, /* DENALI_PHY_748_DATA */ - 0x00000000, /* DENALI_PHY_749_DATA */ - 0x00000000, /* DENALI_PHY_750_DATA */ - 0x00000000, /* DENALI_PHY_751_DATA */ - 0x00000000, /* DENALI_PHY_752_DATA */ - 0x00000000, /* DENALI_PHY_753_DATA */ - 0x00000000, /* DENALI_PHY_754_DATA */ - 0x00000000, /* DENALI_PHY_755_DATA */ - 0x00000000, /* DENALI_PHY_756_DATA */ - 0x00000000, /* DENALI_PHY_757_DATA */ - 0x00000000, /* DENALI_PHY_758_DATA */ - 0x00000000, /* DENALI_PHY_759_DATA */ - 0x00000000, /* DENALI_PHY_760_DATA */ - 0x00000000, /* DENALI_PHY_761_DATA */ - 0x00000000, /* DENALI_PHY_762_DATA */ - 0x00000000, /* DENALI_PHY_763_DATA */ - 0x00000000, /* DENALI_PHY_764_DATA */ - 0x00000000, /* DENALI_PHY_765_DATA */ - 0x00000000, /* DENALI_PHY_766_DATA */ - 0x00000000, /* DENALI_PHY_767_DATA */ - 0x00000000, /* DENALI_PHY_768_DATA */ - 0x00800000, /* DENALI_PHY_769_DATA */ - 0x00000000, /* DENALI_PHY_770_DATA */ - 0x00000000, /* DENALI_PHY_771_DATA */ - 0x00000000, /* DENALI_PHY_772_DATA */ - 0x00000000, /* DENALI_PHY_773_DATA */ - 0x00000000, /* DENALI_PHY_774_DATA */ - 0x00000001, /* DENALI_PHY_775_DATA */ - 0x00000000, /* DENALI_PHY_776_DATA */ - 0x00000000, /* DENALI_PHY_777_DATA */ - 0x00000000, /* DENALI_PHY_778_DATA */ - 0x00400320, /* DENALI_PHY_779_DATA */ - 0x00000040, /* DENALI_PHY_780_DATA */ - 0x00008eca, /* DENALI_PHY_781_DATA */ - 0x00009fdb, /* DENALI_PHY_782_DATA */ - 0x00008eca, /* DENALI_PHY_783_DATA */ - 0x01009fdb, /* DENALI_PHY_784_DATA */ - 0x00020003, /* DENALI_PHY_785_DATA */ - 0x00000000, /* DENALI_PHY_786_DATA */ - 0x00000000, /* DENALI_PHY_787_DATA */ - 0x00000000, /* DENALI_PHY_788_DATA */ - 0x000556aa, /* DENALI_PHY_789_DATA */ - 0x000aaaaa, /* DENALI_PHY_790_DATA */ - 0x000aa955, /* DENALI_PHY_791_DATA */ - 0x00055555, /* DENALI_PHY_792_DATA */ - 0x000b3133, /* DENALI_PHY_793_DATA */ - 0x0004cd33, /* DENALI_PHY_794_DATA */ - 0x0004cecc, /* DENALI_PHY_795_DATA */ - 0x000b32cc, /* DENALI_PHY_796_DATA */ - 0x1ee6b16a, /* DENALI_PHY_797_DATA */ - 0x10000000, /* DENALI_PHY_798_DATA */ - 0x00000000, /* DENALI_PHY_799_DATA */ - 0x00038055, /* DENALI_PHY_800_DATA */ - 0x03800380, /* DENALI_PHY_801_DATA */ - 0x03800380, /* DENALI_PHY_802_DATA */ - 0x00000380, /* DENALI_PHY_803_DATA */ - 0x42080010, /* DENALI_PHY_804_DATA */ - 0x00000003, /* DENALI_PHY_805_DATA */ - 0x00000000, /* DENALI_PHY_806_DATA */ - 0x00000000, /* DENALI_PHY_807_DATA */ - 0x00000000, /* DENALI_PHY_808_DATA */ - 0x00000000, /* DENALI_PHY_809_DATA */ - 0x00000000, /* DENALI_PHY_810_DATA */ - 0x00000000, /* DENALI_PHY_811_DATA */ - 0x00000000, /* DENALI_PHY_812_DATA */ - 0x00000000, /* DENALI_PHY_813_DATA */ - 0x00000000, /* DENALI_PHY_814_DATA */ - 0x00000000, /* DENALI_PHY_815_DATA */ - 0x00000000, /* DENALI_PHY_816_DATA */ - 0x00000000, /* DENALI_PHY_817_DATA */ - 0x00000000, /* DENALI_PHY_818_DATA */ - 0x00000000, /* DENALI_PHY_819_DATA */ - 0x00000000, /* DENALI_PHY_820_DATA */ - 0x00000000, /* DENALI_PHY_821_DATA */ - 0x00000000, /* DENALI_PHY_822_DATA */ - 0x00000000, /* DENALI_PHY_823_DATA */ - 0x00000000, /* DENALI_PHY_824_DATA */ - 0x00000000, /* DENALI_PHY_825_DATA */ - 0x00000000, /* DENALI_PHY_826_DATA */ - 0x00000000, /* DENALI_PHY_827_DATA */ - 0x00000000, /* DENALI_PHY_828_DATA */ - 0x00000000, /* DENALI_PHY_829_DATA */ - 0x00000000, /* DENALI_PHY_830_DATA */ - 0x00000000, /* DENALI_PHY_831_DATA */ - 0x00000000, /* DENALI_PHY_832_DATA */ - 0x00000000, /* DENALI_PHY_833_DATA */ - 0x00000000, /* DENALI_PHY_834_DATA */ - 0x00000000, /* DENALI_PHY_835_DATA */ - 0x00000000, /* DENALI_PHY_836_DATA */ - 0x00000000, /* DENALI_PHY_837_DATA */ - 0x00000000, /* DENALI_PHY_838_DATA */ - 0x00000000, /* DENALI_PHY_839_DATA */ - 0x00000000, /* DENALI_PHY_840_DATA */ - 0x00000000, /* DENALI_PHY_841_DATA */ - 0x00000000, /* DENALI_PHY_842_DATA */ - 0x00000000, /* DENALI_PHY_843_DATA */ - 0x00000000, /* DENALI_PHY_844_DATA */ - 0x00000000, /* DENALI_PHY_845_DATA */ - 0x00000000, /* DENALI_PHY_846_DATA */ - 0x00000000, /* DENALI_PHY_847_DATA */ - 0x00000000, /* DENALI_PHY_848_DATA */ - 0x00000000, /* DENALI_PHY_849_DATA */ - 0x00000000, /* DENALI_PHY_850_DATA */ - 0x00000000, /* DENALI_PHY_851_DATA */ - 0x00000000, /* DENALI_PHY_852_DATA */ - 0x00000000, /* DENALI_PHY_853_DATA */ - 0x00000000, /* DENALI_PHY_854_DATA */ - 0x00000000, /* DENALI_PHY_855_DATA */ - 0x00000000, /* DENALI_PHY_856_DATA */ - 0x00000000, /* DENALI_PHY_857_DATA */ - 0x00000000, /* DENALI_PHY_858_DATA */ - 0x00000000, /* DENALI_PHY_859_DATA */ - 0x00000000, /* DENALI_PHY_860_DATA */ - 0x00000000, /* DENALI_PHY_861_DATA */ - 0x00000000, /* DENALI_PHY_862_DATA */ - 0x00000000, /* DENALI_PHY_863_DATA */ - 0x00000000, /* DENALI_PHY_864_DATA */ - 0x00000000, /* DENALI_PHY_865_DATA */ - 0x00000000, /* DENALI_PHY_866_DATA */ - 0x00000000, /* DENALI_PHY_867_DATA */ - 0x00000000, /* DENALI_PHY_868_DATA */ - 0x00000000, /* DENALI_PHY_869_DATA */ - 0x00000000, /* DENALI_PHY_870_DATA */ - 0x00000000, /* DENALI_PHY_871_DATA */ - 0x00000000, /* DENALI_PHY_872_DATA */ - 0x00000000, /* DENALI_PHY_873_DATA */ - 0x00000000, /* DENALI_PHY_874_DATA */ - 0x00000000, /* DENALI_PHY_875_DATA */ - 0x00000000, /* DENALI_PHY_876_DATA */ - 0x00000000, /* DENALI_PHY_877_DATA */ - 0x00000000, /* DENALI_PHY_878_DATA */ - 0x00000000, /* DENALI_PHY_879_DATA */ - 0x00000000, /* DENALI_PHY_880_DATA */ - 0x00000000, /* DENALI_PHY_881_DATA */ - 0x00000000, /* DENALI_PHY_882_DATA */ - 0x00000000, /* DENALI_PHY_883_DATA */ - 0x00000000, /* DENALI_PHY_884_DATA */ - 0x00000000, /* DENALI_PHY_885_DATA */ - 0x00000000, /* DENALI_PHY_886_DATA */ - 0x00000000, /* DENALI_PHY_887_DATA */ - 0x00000000, /* DENALI_PHY_888_DATA */ - 0x00000000, /* DENALI_PHY_889_DATA */ - 0x00000000, /* DENALI_PHY_890_DATA */ - 0x00000000, /* DENALI_PHY_891_DATA */ - 0x00000000, /* DENALI_PHY_892_DATA */ - 0x00000000, /* DENALI_PHY_893_DATA */ - 0x00000000, /* DENALI_PHY_894_DATA */ - 0x00000000, /* DENALI_PHY_895_DATA */ - 0x00000001, /* DENALI_PHY_896_DATA */ - 0x00000000, /* DENALI_PHY_897_DATA */ - 0x01000005, /* DENALI_PHY_898_DATA */ - 0x04000f00, /* DENALI_PHY_899_DATA */ - 0x00020040, /* DENALI_PHY_900_DATA */ - 0x00020055, /* DENALI_PHY_901_DATA */ - 0x00000000, /* DENALI_PHY_902_DATA */ - 0x00000000, /* DENALI_PHY_903_DATA */ - 0x00000000, /* DENALI_PHY_904_DATA */ - 0x00000050, /* DENALI_PHY_905_DATA */ - 0x00000000, /* DENALI_PHY_906_DATA */ - 0x00010100, /* DENALI_PHY_907_DATA */ - 0x00000601, /* DENALI_PHY_908_DATA */ - 0x00000000, /* DENALI_PHY_909_DATA */ - 0x00006400, /* DENALI_PHY_910_DATA */ - 0x01221102, /* DENALI_PHY_911_DATA */ - 0x00000000, /* DENALI_PHY_912_DATA */ - 0x00051f00, /* DENALI_PHY_913_DATA */ - 0x051f051f, /* DENALI_PHY_914_DATA */ - 0x051f051f, /* DENALI_PHY_915_DATA */ - 0x00030003, /* DENALI_PHY_916_DATA */ - 0x03000300, /* DENALI_PHY_917_DATA */ - 0x00000300, /* DENALI_PHY_918_DATA */ - 0x01221102, /* DENALI_PHY_919_DATA */ - 0x00000000, /* DENALI_PHY_920_DATA */ - 0x00000000, /* DENALI_PHY_921_DATA */ - 0x03020000, /* DENALI_PHY_922_DATA */ - 0x00000001, /* DENALI_PHY_923_DATA */ - 0x00000011, /* DENALI_PHY_924_DATA */ - 0x00000011, /* DENALI_PHY_925_DATA */ - 0x00000400, /* DENALI_PHY_926_DATA */ - 0x00000000, /* DENALI_PHY_927_DATA */ - 0x00000011, /* DENALI_PHY_928_DATA */ - 0x00000011, /* DENALI_PHY_929_DATA */ - 0x00004410, /* DENALI_PHY_930_DATA */ - 0x00004410, /* DENALI_PHY_931_DATA */ - 0x00004410, /* DENALI_PHY_932_DATA */ - 0x00004410, /* DENALI_PHY_933_DATA */ - 0x00004410, /* DENALI_PHY_934_DATA */ - 0x00000011, /* DENALI_PHY_935_DATA */ - 0x00004410, /* DENALI_PHY_936_DATA */ - 0x00000011, /* DENALI_PHY_937_DATA */ - 0x00004410, /* DENALI_PHY_938_DATA */ - 0x00000011, /* DENALI_PHY_939_DATA */ - 0x00004410, /* DENALI_PHY_940_DATA */ - 0x00000000, /* DENALI_PHY_941_DATA */ - 0x00000000, /* DENALI_PHY_942_DATA */ - 0x00000000, /* DENALI_PHY_943_DATA */ - 0x04000000, /* DENALI_PHY_944_DATA */ - 0x00000000, /* DENALI_PHY_945_DATA */ - 0x00000000, /* DENALI_PHY_946_DATA */ - 0x00000508, /* DENALI_PHY_947_DATA */ - 0x00000000, /* DENALI_PHY_948_DATA */ - 0x00000000, /* DENALI_PHY_949_DATA */ - 0x00000000, /* DENALI_PHY_950_DATA */ - 0x00000000, /* DENALI_PHY_951_DATA */ - 0x00000000, /* DENALI_PHY_952_DATA */ - 0x00000000, /* DENALI_PHY_953_DATA */ - 0xe4000000, /* DENALI_PHY_954_DATA */ - 0x00000000, /* DENALI_PHY_955_DATA */ - 0x00000000, /* DENALI_PHY_956_DATA */ - 0x01010000, /* DENALI_PHY_957_DATA */ - 0x00000000 /* DENALI_PHY_958_DATA */ - } - }, -}, diff --git a/src/mainboard/google/gru/sdram_inf/sdram-lpddr3-hynix-4GB-666.c b/src/mainboard/google/gru/sdram_inf/sdram-lpddr3-hynix-4GB-666.c new file mode 100644 index 0000000..d5d6761 --- /dev/null +++ b/src/mainboard/google/gru/sdram_inf/sdram-lpddr3-hynix-4GB-666.c @@ -0,0 +1,1565 @@ +/* + * This file is part of the coreboot project. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <soc/sdram.h> + +struct rk3399_sdram_params params = { + { + { + .rank = 0x2, + .col = 0xA, + .bk = 0x3, + .bw = 0x2, + .dbw = 0x2, + .row_3_4 = 0x0, + .cs0_row = 0xF, + .cs1_row = 0xF, + .ddrconfig = 1, + { + {0x19151115}, + {0x10030806}, + {0x00000002}, + {0x00006206}, + {0x00000054}, + 0x00000000 + } + }, + { + .rank = 0x2, + .col = 0xA, + .bk = 0x3, + .bw = 0x2, + .dbw = 0x2, + .row_3_4 = 0x0, + .cs0_row = 0xF, + .cs1_row = 0xF, + .ddrconfig = 1, + { + {0x19151115}, + {0x10030806}, + {0x00000002}, + {0x00006206}, + {0x00000054}, + 0x00000000 + } + } + }, + .ddr_freq = 666*MHz, + .dramtype = LPDDR3, + .num_channels = 2, + .stride = 13, + .odt = 1, + { + { + 0x00000700, /* DENALI_CTL_00_DATA */ + 0x00000000, /* DENALI_CTL_01_DATA */ + 0x00000000, /* DENALI_CTL_02_DATA */ + 0x00000000, /* DENALI_CTL_03_DATA */ + 0x00000000, /* DENALI_CTL_04_DATA */ + 0x00000043, /* DENALI_CTL_05_DATA */ + 0x000208d6, /* DENALI_CTL_06_DATA */ + 0x0000029b, /* DENALI_CTL_07_DATA */ + 0x00001a0b, /* DENALI_CTL_08_DATA */ + 0x00000028, /* DENALI_CTL_09_DATA */ + 0x00013880, /* DENALI_CTL_10_DATA */ + 0x00000190, /* DENALI_CTL_11_DATA */ + 0x00000fa0, /* DENALI_CTL_12_DATA */ + 0x00000043, /* DENALI_CTL_13_DATA */ + 0x000208d6, /* DENALI_CTL_14_DATA */ + 0x0000029b, /* DENALI_CTL_15_DATA */ + 0x01001a0b, /* DENALI_CTL_16_DATA */ + 0x00000000, /* DENALI_CTL_17_DATA */ + 0x00000101, /* DENALI_CTL_18_DATA */ + 0x00020100, /* DENALI_CTL_19_DATA */ + 0x00000086, /* DENALI_CTL_20_DATA */ + 0x0000014e, /* DENALI_CTL_21_DATA */ + 0x00000000, /* DENALI_CTL_22_DATA */ + 0x06140000, /* DENALI_CTL_23_DATA */ + 0x00061400, /* DENALI_CTL_24_DATA */ + 0x04000614, /* DENALI_CTL_25_DATA */ + 0x2a070004, /* DENALI_CTL_26_DATA */ + 0x220c051c, /* DENALI_CTL_27_DATA */ + 0x111a0400, /* DENALI_CTL_28_DATA */ + 0x00140804, /* DENALI_CTL_29_DATA */ + 0x051c2a07, /* DENALI_CTL_30_DATA */ + 0x0500220c, /* DENALI_CTL_31_DATA */ + 0x00000a0a, /* DENALI_CTL_32_DATA */ + 0x0500b64a, /* DENALI_CTL_33_DATA */ + 0x0a0a040a, /* DENALI_CTL_34_DATA */ + 0x03006d60, /* DENALI_CTL_35_DATA */ + 0x0a0a0506, /* DENALI_CTL_36_DATA */ + 0x0500b64a, /* DENALI_CTL_37_DATA */ + 0x0203000a, /* DENALI_CTL_38_DATA */ + 0x080a0c00, /* DENALI_CTL_39_DATA */ + 0x040a0c06, /* DENALI_CTL_40_DATA */ + 0x14000a0a, /* DENALI_CTL_41_DATA */ + 0x02020a0a, /* DENALI_CTL_42_DATA */ + 0x00010002, /* DENALI_CTL_43_DATA */ + 0x03160e16, /* DENALI_CTL_44_DATA */ + 0x000e090e, /* DENALI_CTL_45_DATA */ + 0x00000000, /* DENALI_CTL_46_DATA */ + 0x03010000, /* DENALI_CTL_47_DATA */ + 0x0a20008c, /* DENALI_CTL_48_DATA */ + 0x06100054, /* DENALI_CTL_49_DATA */ + 0x0a20008c, /* DENALI_CTL_50_DATA */ + 0x00000000, /* DENALI_CTL_51_DATA */ + 0x00030005, /* DENALI_CTL_52_DATA */ + 0x00100005, /* DENALI_CTL_53_DATA */ + 0x0010000a, /* DENALI_CTL_54_DATA */ + 0x000c080c, /* DENALI_CTL_55_DATA */ + 0x00000000, /* DENALI_CTL_56_DATA */ + 0x00000000, /* DENALI_CTL_57_DATA */ + 0x00000000, /* DENALI_CTL_58_DATA */ + 0x00930000, /* DENALI_CTL_59_DATA */ + 0x00580093, /* DENALI_CTL_60_DATA */ + 0x00930058, /* DENALI_CTL_61_DATA */ + 0x00000093, /* DENALI_CTL_62_DATA */ + 0x00000000, /* DENALI_CTL_63_DATA */ + 0x00000000, /* DENALI_CTL_64_DATA */ + 0x00000000, /* DENALI_CTL_65_DATA */ + 0x00000000, /* DENALI_CTL_66_DATA */ + 0x00000000, /* DENALI_CTL_67_DATA */ + 0x00000000, /* DENALI_CTL_68_DATA */ + 0x00000301, /* DENALI_CTL_69_DATA */ + 0x00000001, /* DENALI_CTL_70_DATA */ + 0x00000000, /* DENALI_CTL_71_DATA */ + 0x00000000, /* DENALI_CTL_72_DATA */ + 0x01000000, /* DENALI_CTL_73_DATA */ + 0x80104002, /* DENALI_CTL_74_DATA */ + 0x00040003, /* DENALI_CTL_75_DATA */ + 0x00040005, /* DENALI_CTL_76_DATA */ + 0x00030000, /* DENALI_CTL_77_DATA */ + 0x00050004, /* DENALI_CTL_78_DATA */ + 0x00000004, /* DENALI_CTL_79_DATA */ + 0x00040003, /* DENALI_CTL_80_DATA */ + 0x00040005, /* DENALI_CTL_81_DATA */ + 0x28800000, /* DENALI_CTL_82_DATA */ + 0x00001440, /* DENALI_CTL_83_DATA */ + 0x0c201840, /* DENALI_CTL_84_DATA */ + 0x28800000, /* DENALI_CTL_85_DATA */ + 0x00001440, /* DENALI_CTL_86_DATA */ + 0x00000000, /* DENALI_CTL_87_DATA */ + 0x00000000, /* DENALI_CTL_88_DATA */ + 0x00000000, /* DENALI_CTL_89_DATA */ + 0x00000000, /* DENALI_CTL_90_DATA */ + 0x00000000, /* DENALI_CTL_91_DATA */ + 0x02020200, /* DENALI_CTL_92_DATA */ + 0x00020202, /* DENALI_CTL_93_DATA */ + 0x00030200, /* DENALI_CTL_94_DATA */ + 0x00040700, /* DENALI_CTL_95_DATA */ + 0x00000302, /* DENALI_CTL_96_DATA */ + 0x02000407, /* DENALI_CTL_97_DATA */ + 0x00000003, /* DENALI_CTL_98_DATA */ + 0x00030f04, /* DENALI_CTL_99_DATA */ + 0x00070004, /* DENALI_CTL_100_DATA */ + 0x00000000, /* DENALI_CTL_101_DATA */ + 0x00000000, /* DENALI_CTL_102_DATA */ + 0x00000000, /* DENALI_CTL_103_DATA */ + 0x00000000, /* DENALI_CTL_104_DATA */ + 0x00000000, /* DENALI_CTL_105_DATA */ + 0x00000000, /* DENALI_CTL_106_DATA */ + 0x00000000, /* DENALI_CTL_107_DATA */ + 0x00010000, /* DENALI_CTL_108_DATA */ + 0x20040020, /* DENALI_CTL_109_DATA */ + 0x00200400, /* DENALI_CTL_110_DATA */ + 0x01000400, /* DENALI_CTL_111_DATA */ + 0x00000b80, /* DENALI_CTL_112_DATA */ + 0x00000000, /* DENALI_CTL_113_DATA */ + 0x00000001, /* DENALI_CTL_114_DATA */ + 0x00000002, /* DENALI_CTL_115_DATA */ + 0x0000000e, /* DENALI_CTL_116_DATA */ + 0x00000000, /* DENALI_CTL_117_DATA */ + 0x00000000, /* DENALI_CTL_118_DATA */ + 0x00000000, /* DENALI_CTL_119_DATA */ + 0x00000000, /* DENALI_CTL_120_DATA */ + 0x00000000, /* DENALI_CTL_121_DATA */ + 0x00860000, /* DENALI_CTL_122_DATA */ + 0x00a70043, /* DENALI_CTL_123_DATA */ + 0x00a70000, /* DENALI_CTL_124_DATA */ + 0x00280050, /* DENALI_CTL_125_DATA */ + 0x00000064, /* DENALI_CTL_126_DATA */ + 0x00860064, /* DENALI_CTL_127_DATA */ + 0x00a70043, /* DENALI_CTL_128_DATA */ + 0x00a70000, /* DENALI_CTL_129_DATA */ + 0x00000000, /* DENALI_CTL_130_DATA */ + 0x00000000, /* DENALI_CTL_131_DATA */ + 0x00000000, /* DENALI_CTL_132_DATA */ + 0x00030000, /* DENALI_CTL_133_DATA */ + 0x00000018, /* DENALI_CTL_134_DATA */ + 0x00080083, /* DENALI_CTL_135_DATA */ + 0x00030000, /* DENALI_CTL_136_DATA */ + 0x00000018, /* DENALI_CTL_137_DATA */ + 0x00010001, /* DENALI_CTL_138_DATA */ + 0x06000001, /* DENALI_CTL_139_DATA */ + 0x00000707, /* DENALI_CTL_140_DATA */ + 0x00000000, /* DENALI_CTL_141_DATA */ + 0x00000000, /* DENALI_CTL_142_DATA */ + 0x00000000, /* DENALI_CTL_143_DATA */ + 0x00000000, /* DENALI_CTL_144_DATA */ + 0x00000000, /* DENALI_CTL_145_DATA */ + 0x00000000, /* DENALI_CTL_146_DATA */ + 0x00030000, /* DENALI_CTL_147_DATA */ + 0x00000018, /* DENALI_CTL_148_DATA */ + 0x00080083, /* DENALI_CTL_149_DATA */ + 0x00030000, /* DENALI_CTL_150_DATA */ + 0x00000018, /* DENALI_CTL_151_DATA */ + 0x00010001, /* DENALI_CTL_152_DATA */ + 0x06000001, /* DENALI_CTL_153_DATA */ + 0x00000707, /* DENALI_CTL_154_DATA */ + 0x00000000, /* DENALI_CTL_155_DATA */ + 0x00000000, /* DENALI_CTL_156_DATA */ + 0x00000000, /* DENALI_CTL_157_DATA */ + 0x00000000, /* DENALI_CTL_158_DATA */ + 0x00000000, /* DENALI_CTL_159_DATA */ + 0x00000000, /* DENALI_CTL_160_DATA */ + 0x01000000, /* DENALI_CTL_161_DATA */ + 0x00000000, /* DENALI_CTL_162_DATA */ + 0x00000000, /* DENALI_CTL_163_DATA */ + 0x18151100, /* DENALI_CTL_164_DATA */ + 0x0000000c, /* DENALI_CTL_165_DATA */ + 0x00000000, /* DENALI_CTL_166_DATA */ + 0x00000000, /* DENALI_CTL_167_DATA */ + 0x00000000, /* DENALI_CTL_168_DATA */ + 0x00000000, /* DENALI_CTL_169_DATA */ + 0x00000000, /* DENALI_CTL_170_DATA */ + 0x00000000, /* DENALI_CTL_171_DATA */ + 0x00000000, /* DENALI_CTL_172_DATA */ + 0x00000000, /* DENALI_CTL_173_DATA */ + 0x00000000, /* DENALI_CTL_174_DATA */ + 0x00000000, /* DENALI_CTL_175_DATA */ + 0x00000000, /* DENALI_CTL_176_DATA */ + 0x00000000, /* DENALI_CTL_177_DATA */ + 0x00000000, /* DENALI_CTL_178_DATA */ + 0x00029b03, /* DENALI_CTL_179_DATA */ + 0x003c00f0, /* DENALI_CTL_180_DATA */ + 0x00000000, /* DENALI_CTL_181_DATA */ + 0x00900190, /* DENALI_CTL_182_DATA */ + 0x00000024, /* DENALI_CTL_183_DATA */ + 0x00029b00, /* DENALI_CTL_184_DATA */ + 0x003c00f0, /* DENALI_CTL_185_DATA */ + 0x00000000, /* DENALI_CTL_186_DATA */ + 0x00220000, /* DENALI_CTL_187_DATA */ + 0x00220014, /* DENALI_CTL_188_DATA */ + 0x01010100, /* DENALI_CTL_189_DATA */ + 0x01000202, /* DENALI_CTL_190_DATA */ + 0x0a000002, /* DENALI_CTL_191_DATA */ + 0x01000f0f, /* DENALI_CTL_192_DATA */ + 0x00000000, /* DENALI_CTL_193_DATA */ + 0x00000000, /* DENALI_CTL_194_DATA */ + 0x00010003, /* DENALI_CTL_195_DATA */ + 0x00000c03, /* DENALI_CTL_196_DATA */ + 0x00000100, /* DENALI_CTL_197_DATA */ + 0x00010000, /* DENALI_CTL_198_DATA */ + 0x01000000, /* DENALI_CTL_199_DATA */ + 0x00010000, /* DENALI_CTL_200_DATA */ + 0x00000001, /* DENALI_CTL_201_DATA */ + 0x00000000, /* DENALI_CTL_202_DATA */ + 0x00000000, /* DENALI_CTL_203_DATA */ + 0x00000000, /* DENALI_CTL_204_DATA */ + 0x00000000, /* DENALI_CTL_205_DATA */ + 0x00000000, /* DENALI_CTL_206_DATA */ + 0x00000000, /* DENALI_CTL_207_DATA */ + 0x00000000, /* DENALI_CTL_208_DATA */ + 0x00000000, /* DENALI_CTL_209_DATA */ + 0x00000000, /* DENALI_CTL_210_DATA */ + 0x00010000, /* DENALI_CTL_211_DATA */ + 0x03020301, /* DENALI_CTL_212_DATA */ + 0x01010808, /* DENALI_CTL_213_DATA */ + 0x04030001, /* DENALI_CTL_214_DATA */ + 0x08080803, /* DENALI_CTL_215_DATA */ + 0x08080808, /* DENALI_CTL_216_DATA */ + 0x02050203, /* DENALI_CTL_217_DATA */ + 0x02010303, /* DENALI_CTL_218_DATA */ + 0x00010203, /* DENALI_CTL_219_DATA */ + 0x00020202, /* DENALI_CTL_220_DATA */ + 0x03020400, /* DENALI_CTL_221_DATA */ + 0x00020401, /* DENALI_CTL_222_DATA */ + 0x00000000, /* DENALI_CTL_223_DATA */ + 0x00000000, /* DENALI_CTL_224_DATA */ + 0x0d000001, /* DENALI_CTL_225_DATA */ + 0x00010028, /* DENALI_CTL_226_DATA */ + 0x00010000, /* DENALI_CTL_227_DATA */ + 0x00000003, /* DENALI_CTL_228_DATA */ + 0x00000000, /* DENALI_CTL_229_DATA */ + 0x00000000, /* DENALI_CTL_230_DATA */ + 0x00000000, /* DENALI_CTL_231_DATA */ + 0x00000000, /* DENALI_CTL_232_DATA */ + 0x00000000, /* DENALI_CTL_233_DATA */ + 0x00000000, /* DENALI_CTL_234_DATA */ + 0x00000000, /* DENALI_CTL_235_DATA */ + 0x00000000, /* DENALI_CTL_236_DATA */ + 0x00010100, /* DENALI_CTL_237_DATA */ + 0x01000000, /* DENALI_CTL_238_DATA */ + 0x00000001, /* DENALI_CTL_239_DATA */ + 0x00000303, /* DENALI_CTL_240_DATA */ + 0x00000000, /* DENALI_CTL_241_DATA */ + 0x00000000, /* DENALI_CTL_242_DATA */ + 0x00000000, /* DENALI_CTL_243_DATA */ + 0x00000000, /* DENALI_CTL_244_DATA */ + 0x00000000, /* DENALI_CTL_245_DATA */ + 0x00000000, /* DENALI_CTL_246_DATA */ + 0x00000000, /* DENALI_CTL_247_DATA */ + 0x00000000, /* DENALI_CTL_248_DATA */ + 0x00000000, /* DENALI_CTL_249_DATA */ + 0x00000000, /* DENALI_CTL_250_DATA */ + 0x00000000, /* DENALI_CTL_251_DATA */ + 0x00000000, /* DENALI_CTL_252_DATA */ + 0x00000000, /* DENALI_CTL_253_DATA */ + 0x00000000, /* DENALI_CTL_254_DATA */ + 0x00000000, /* DENALI_CTL_255_DATA */ + 0x000556aa, /* DENALI_CTL_256_DATA */ + 0x000aaaaa, /* DENALI_CTL_257_DATA */ + 0x000aa955, /* DENALI_CTL_258_DATA */ + 0x00055555, /* DENALI_CTL_259_DATA */ + 0x000b3133, /* DENALI_CTL_260_DATA */ + 0x0004cd33, /* DENALI_CTL_261_DATA */ + 0x0004cecc, /* DENALI_CTL_262_DATA */ + 0x000b32cc, /* DENALI_CTL_263_DATA */ + 0x00010300, /* DENALI_CTL_264_DATA */ + 0x03000100, /* DENALI_CTL_265_DATA */ + 0x00000000, /* DENALI_CTL_266_DATA */ + 0x00000000, /* DENALI_CTL_267_DATA */ + 0x00000000, /* DENALI_CTL_268_DATA */ + 0x00000000, /* DENALI_CTL_269_DATA */ + 0x00000000, /* DENALI_CTL_270_DATA */ + 0x00000000, /* DENALI_CTL_271_DATA */ + 0x00000000, /* DENALI_CTL_272_DATA */ + 0x00000000, /* DENALI_CTL_273_DATA */ + 0x00ffff00, /* DENALI_CTL_274_DATA */ + 0x181b0000, /* DENALI_CTL_275_DATA */ + 0x0800001b, /* DENALI_CTL_276_DATA */ + 0x00001440, /* DENALI_CTL_277_DATA */ + 0x00000200, /* DENALI_CTL_278_DATA */ + 0x00000200, /* DENALI_CTL_279_DATA */ + 0x00000200, /* DENALI_CTL_280_DATA */ + 0x00000200, /* DENALI_CTL_281_DATA */ + 0x00001440, /* DENALI_CTL_282_DATA */ + 0x0000ca80, /* DENALI_CTL_283_DATA */ + 0x0c200509, /* DENALI_CTL_284_DATA */ + 0x00000200, /* DENALI_CTL_285_DATA */ + 0x00000200, /* DENALI_CTL_286_DATA */ + 0x00000200, /* DENALI_CTL_287_DATA */ + 0x00000200, /* DENALI_CTL_288_DATA */ + 0x00000c20, /* DENALI_CTL_289_DATA */ + 0x00007940, /* DENALI_CTL_290_DATA */ + 0x14400509, /* DENALI_CTL_291_DATA */ + 0x00000200, /* DENALI_CTL_292_DATA */ + 0x00000200, /* DENALI_CTL_293_DATA */ + 0x00000200, /* DENALI_CTL_294_DATA */ + 0x00000200, /* DENALI_CTL_295_DATA */ + 0x00001440, /* DENALI_CTL_296_DATA */ + 0x0000ca80, /* DENALI_CTL_297_DATA */ + 0x02020509, /* DENALI_CTL_298_DATA */ + 0x03030202, /* DENALI_CTL_299_DATA */ + 0x00000018, /* DENALI_CTL_300_DATA */ + 0x00000000, /* DENALI_CTL_301_DATA */ + 0x00000000, /* DENALI_CTL_302_DATA */ + 0x00001403, /* DENALI_CTL_303_DATA */ + 0x00000000, /* DENALI_CTL_304_DATA */ + 0x00000000, /* DENALI_CTL_305_DATA */ + 0x00000000, /* DENALI_CTL_306_DATA */ + 0x00030000, /* DENALI_CTL_307_DATA */ + 0x000d001f, /* DENALI_CTL_308_DATA */ + 0x000a001c, /* DENALI_CTL_309_DATA */ + 0x000d001f, /* DENALI_CTL_310_DATA */ + 0x00000000, /* DENALI_CTL_311_DATA */ + 0x00000000, /* DENALI_CTL_312_DATA */ + 0x01000000, /* DENALI_CTL_313_DATA */ + 0x00050005, /* DENALI_CTL_314_DATA */ + 0x00050005, /* DENALI_CTL_315_DATA */ + 0x00000000, /* DENALI_CTL_316_DATA */ + 0x00000000, /* DENALI_CTL_317_DATA */ + 0x00000000, /* DENALI_CTL_318_DATA */ + 0x00000000, /* DENALI_CTL_319_DATA */ + 0x00000000, /* DENALI_CTL_320_DATA */ + 0x00000000, /* DENALI_CTL_321_DATA */ + 0x00000000, /* DENALI_CTL_322_DATA */ + 0x00000000, /* DENALI_CTL_323_DATA */ + 0x01000101, /* DENALI_CTL_324_DATA */ + 0x01010101, /* DENALI_CTL_325_DATA */ + 0x01000101, /* DENALI_CTL_326_DATA */ + 0x01000100, /* DENALI_CTL_327_DATA */ + 0x00010001, /* DENALI_CTL_328_DATA */ + 0x00010002, /* DENALI_CTL_329_DATA */ + 0x00020100, /* DENALI_CTL_330_DATA */ + 0x00000002 /* DENALI_CTL_331_DATA */ + } + }, + { + { + 0x00000700, /* DENALI_PI_00_DATA */ + 0x00000000, /* DENALI_PI_01_DATA */ + 0x00002880, /* DENALI_PI_02_DATA */ + 0x00001440, /* DENALI_PI_03_DATA */ + 0x00002880, /* DENALI_PI_04_DATA */ + 0x00001440, /* DENALI_PI_05_DATA */ + 0x00002880, /* DENALI_PI_06_DATA */ + 0x14401440, /* DENALI_PI_07_DATA */ + 0x00000200, /* DENALI_PI_08_DATA */ + 0x00000200, /* DENALI_PI_09_DATA */ + 0x00000200, /* DENALI_PI_10_DATA */ + 0x00000200, /* DENALI_PI_11_DATA */ + 0x00001440, /* DENALI_PI_12_DATA */ + 0x00000200, /* DENALI_PI_13_DATA */ + 0x00000200, /* DENALI_PI_14_DATA */ + 0x00000200, /* DENALI_PI_15_DATA */ + 0x00000200, /* DENALI_PI_16_DATA */ + 0x00001440, /* DENALI_PI_17_DATA */ + 0x00000200, /* DENALI_PI_18_DATA */ + 0x00000200, /* DENALI_PI_19_DATA */ + 0x00000200, /* DENALI_PI_20_DATA */ + 0x00000200, /* DENALI_PI_21_DATA */ + 0x00010000, /* DENALI_PI_22_DATA */ + 0x00000007, /* DENALI_PI_23_DATA */ + 0x81000001, /* DENALI_PI_24_DATA */ + 0x0f0003f0, /* DENALI_PI_25_DATA */ + 0x3fffffff, /* DENALI_PI_26_DATA */ + 0x0f0000a0, /* DENALI_PI_27_DATA */ + 0x377ff000, /* DENALI_PI_28_DATA */ + 0x0f000020, /* DENALI_PI_29_DATA */ + 0x377ff000, /* DENALI_PI_30_DATA */ + 0x0f000030, /* DENALI_PI_31_DATA */ + 0x377ff000, /* DENALI_PI_32_DATA */ + 0x0f0000b0, /* DENALI_PI_33_DATA */ + 0x377ff000, /* DENALI_PI_34_DATA */ + 0x0f000100, /* DENALI_PI_35_DATA */ + 0x377ff000, /* DENALI_PI_36_DATA */ + 0x0f000110, /* DENALI_PI_37_DATA */ + 0x377ff000, /* DENALI_PI_38_DATA */ + 0x0f000010, /* DENALI_PI_39_DATA */ + 0x377ff000, /* DENALI_PI_40_DATA */ + 0x03000101, /* DENALI_PI_41_DATA */ + 0x042a2a2a, /* DENALI_PI_42_DATA */ + 0x06140006, /* DENALI_PI_43_DATA */ + 0x00061400, /* DENALI_PI_44_DATA */ + 0x00000014, /* DENALI_PI_45_DATA */ + 0x0a20008c, /* DENALI_PI_46_DATA */ + 0x0a20008c, /* DENALI_PI_47_DATA */ + 0x0a20008c, /* DENALI_PI_48_DATA */ + 0x00000500, /* DENALI_PI_49_DATA */ + 0x00000000, /* DENALI_PI_50_DATA */ + 0x00000000, /* DENALI_PI_51_DATA */ + 0x00000000, /* DENALI_PI_52_DATA */ + 0x00000000, /* DENALI_PI_53_DATA */ + 0x00000000, /* DENALI_PI_54_DATA */ + 0x00000000, /* DENALI_PI_55_DATA */ + 0x00000000, /* DENALI_PI_56_DATA */ + 0x00000000, /* DENALI_PI_57_DATA */ + 0x04040000, /* DENALI_PI_58_DATA */ + 0x0d000004, /* DENALI_PI_59_DATA */ + 0x00000128, /* DENALI_PI_60_DATA */ + 0x00000000, /* DENALI_PI_61_DATA */ + 0x00030003, /* DENALI_PI_62_DATA */ + 0x00000018, /* DENALI_PI_63_DATA */ + 0x00000000, /* DENALI_PI_64_DATA */ + 0x00000000, /* DENALI_PI_65_DATA */ + 0x03060002, /* DENALI_PI_66_DATA */ + 0x03010301, /* DENALI_PI_67_DATA */ + 0x01080801, /* DENALI_PI_68_DATA */ + 0x04020201, /* DENALI_PI_69_DATA */ + 0x01080804, /* DENALI_PI_70_DATA */ + 0x00000000, /* DENALI_PI_71_DATA */ + 0x03030000, /* DENALI_PI_72_DATA */ + 0x08080803, /* DENALI_PI_73_DATA */ + 0x00000000, /* DENALI_PI_74_DATA */ + 0x00000000, /* DENALI_PI_75_DATA */ + 0x00000000, /* DENALI_PI_76_DATA */ + 0x00030300, /* DENALI_PI_77_DATA */ + 0x00000014, /* DENALI_PI_78_DATA */ + 0x00000000, /* DENALI_PI_79_DATA */ + 0x01010300, /* DENALI_PI_80_DATA */ + 0x00000000, /* DENALI_PI_81_DATA */ + 0x00000000, /* DENALI_PI_82_DATA */ + 0x01000000, /* DENALI_PI_83_DATA */ + 0x00000101, /* DENALI_PI_84_DATA */ + 0x55555a5a, /* DENALI_PI_85_DATA */ + 0x55555a5a, /* DENALI_PI_86_DATA */ + 0x55555a5a, /* DENALI_PI_87_DATA */ + 0x55555a5a, /* DENALI_PI_88_DATA */ + 0x09090001, /* DENALI_PI_89_DATA */ + 0x05050009, /* DENALI_PI_90_DATA */ + 0x00000005, /* DENALI_PI_91_DATA */ + 0x00000100, /* DENALI_PI_92_DATA */ + 0x00030000, /* DENALI_PI_93_DATA */ + 0x17030000, /* DENALI_PI_94_DATA */ + 0x000d001f, /* DENALI_PI_95_DATA */ + 0x000d001f, /* DENALI_PI_96_DATA */ + 0x000d001f, /* DENALI_PI_97_DATA */ + 0x00000000, /* DENALI_PI_98_DATA */ + 0x00000000, /* DENALI_PI_99_DATA */ + 0x00000100, /* DENALI_PI_100_DATA */ + 0x140a0000, /* DENALI_PI_101_DATA */ + 0x000a020a, /* DENALI_PI_102_DATA */ + 0x02000a02, /* DENALI_PI_103_DATA */ + 0x010a000a, /* DENALI_PI_104_DATA */ + 0x00000100, /* DENALI_PI_105_DATA */ + 0x01000000, /* DENALI_PI_106_DATA */ + 0x00000000, /* DENALI_PI_107_DATA */ + 0x00000100, /* DENALI_PI_108_DATA */ + 0x1e1a0000, /* DENALI_PI_109_DATA */ + 0x10010204, /* DENALI_PI_110_DATA */ + 0x07070705, /* DENALI_PI_111_DATA */ + 0x20000202, /* DENALI_PI_112_DATA */ + 0x00201000, /* DENALI_PI_113_DATA */ + 0x00201000, /* DENALI_PI_114_DATA */ + 0x04041000, /* DENALI_PI_115_DATA */ + 0x0f0f0100, /* DENALI_PI_116_DATA */ + 0x0001010f, /* DENALI_PI_117_DATA */ + 0x004b004a, /* DENALI_PI_118_DATA */ + 0x1a030000, /* DENALI_PI_119_DATA */ + 0x0102041e, /* DENALI_PI_120_DATA */ + 0x34000000, /* DENALI_PI_121_DATA */ + 0x00000000, /* DENALI_PI_122_DATA */ + 0x00000000, /* DENALI_PI_123_DATA */ + 0x00000000, /* DENALI_PI_124_DATA */ + 0x00000300, /* DENALI_PI_125_DATA */ + 0x00010018, /* DENALI_PI_126_DATA */ + 0x004d4d07, /* DENALI_PI_127_DATA */ + 0x00180003, /* DENALI_PI_128_DATA */ + 0x4d070001, /* DENALI_PI_129_DATA */ + 0x0000034d, /* DENALI_PI_130_DATA */ + 0x00010018, /* DENALI_PI_131_DATA */ + 0x004d4d07, /* DENALI_PI_132_DATA */ + 0x00180003, /* DENALI_PI_133_DATA */ + 0x4d070001, /* DENALI_PI_134_DATA */ + 0x0000034d, /* DENALI_PI_135_DATA */ + 0x00010018, /* DENALI_PI_136_DATA */ + 0x004d4d07, /* DENALI_PI_137_DATA */ + 0x00180003, /* DENALI_PI_138_DATA */ + 0x4d070001, /* DENALI_PI_139_DATA */ + 0x0003004d, /* DENALI_PI_140_DATA */ + 0x00010018, /* DENALI_PI_141_DATA */ + 0x004d4d07, /* DENALI_PI_142_DATA */ + 0x00180003, /* DENALI_PI_143_DATA */ + 0x4d070001, /* DENALI_PI_144_DATA */ + 0x0000034d, /* DENALI_PI_145_DATA */ + 0x00010018, /* DENALI_PI_146_DATA */ + 0x004d4d07, /* DENALI_PI_147_DATA */ + 0x00180003, /* DENALI_PI_148_DATA */ + 0x4d070001, /* DENALI_PI_149_DATA */ + 0x0000034d, /* DENALI_PI_150_DATA */ + 0x00010018, /* DENALI_PI_151_DATA */ + 0x004d4d07, /* DENALI_PI_152_DATA */ + 0x00180003, /* DENALI_PI_153_DATA */ + 0x4d070001, /* DENALI_PI_154_DATA */ + 0x0100004d, /* DENALI_PI_155_DATA */ + 0x00a700a7, /* DENALI_PI_156_DATA */ + 0x050400a7, /* DENALI_PI_157_DATA */ + 0x0a050c0e, /* DENALI_PI_158_DATA */ + 0x1c00b477, /* DENALI_PI_159_DATA */ + 0x0a0a2004, /* DENALI_PI_160_DATA */ + 0x0c0e050a, /* DENALI_PI_161_DATA */ + 0x00000a05, /* DENALI_PI_162_DATA */ + 0x1c00b477, /* DENALI_PI_163_DATA */ + 0x0a0a2004, /* DENALI_PI_164_DATA */ + 0x0c0e050a, /* DENALI_PI_165_DATA */ + 0x00000a05, /* DENALI_PI_166_DATA */ + 0x1c00b477, /* DENALI_PI_167_DATA */ + 0x0a0a2004, /* DENALI_PI_168_DATA */ + 0x0200020a, /* DENALI_PI_169_DATA */ + 0x02000200, /* DENALI_PI_170_DATA */ + 0x02000200, /* DENALI_PI_171_DATA */ + 0x02000200, /* DENALI_PI_172_DATA */ + 0x02000200, /* DENALI_PI_173_DATA */ + 0x00000000, /* DENALI_PI_174_DATA */ + 0x00000000, /* DENALI_PI_175_DATA */ + 0x00000000, /* DENALI_PI_176_DATA */ + 0x00000000, /* DENALI_PI_177_DATA */ + 0x00000000, /* DENALI_PI_178_DATA */ + 0x00000000, /* DENALI_PI_179_DATA */ + 0x00000000, /* DENALI_PI_180_DATA */ + 0x00000000, /* DENALI_PI_181_DATA */ + 0x00000000, /* DENALI_PI_182_DATA */ + 0x00000000, /* DENALI_PI_183_DATA */ + 0x00000000, /* DENALI_PI_184_DATA */ + 0x00000000, /* DENALI_PI_185_DATA */ + 0x01000300, /* DENALI_PI_186_DATA */ + 0x00144000, /* DENALI_PI_187_DATA */ + 0x0000ca80, /* DENALI_PI_188_DATA */ + 0x00001440, /* DENALI_PI_189_DATA */ + 0x0000ca80, /* DENALI_PI_190_DATA */ + 0x00001440, /* DENALI_PI_191_DATA */ + 0x0000ca80, /* DENALI_PI_192_DATA */ + 0x08000000, /* DENALI_PI_193_DATA */ + 0x00000100, /* DENALI_PI_194_DATA */ + 0x00000000, /* DENALI_PI_195_DATA */ + 0x00000000, /* DENALI_PI_196_DATA */ + 0x00000000, /* DENALI_PI_197_DATA */ + 0x00000000, /* DENALI_PI_198_DATA */ + 0x00000002 /* DENALI_PI_199_DATA */ + } + }, + { + { + 0x76543210, /* DENALI_PHY_00_DATA */ + 0x0004c008, /* DENALI_PHY_01_DATA */ + 0x000001c4, /* DENALI_PHY_02_DATA */ + 0x00000000, /* DENALI_PHY_03_DATA */ + 0x00000000, /* DENALI_PHY_04_DATA */ + 0x00010000, /* DENALI_PHY_05_DATA */ + 0x01665555, /* DENALI_PHY_06_DATA */ + 0x00665555, /* DENALI_PHY_07_DATA */ + 0x00010f00, /* DENALI_PHY_08_DATA */ + 0x05000100, /* DENALI_PHY_09_DATA */ + 0x00000002, /* DENALI_PHY_10_DATA */ + 0x001700c0, /* DENALI_PHY_11_DATA */ + 0x00cc0101, /* DENALI_PHY_12_DATA */ + 0x00030066, /* DENALI_PHY_13_DATA */ + 0x00000000, /* DENALI_PHY_14_DATA */ + 0x00000000, /* DENALI_PHY_15_DATA */ + 0x00000000, /* DENALI_PHY_16_DATA */ + 0x00000000, /* DENALI_PHY_17_DATA */ + 0x00000000, /* DENALI_PHY_18_DATA */ + 0x00000000, /* DENALI_PHY_19_DATA */ + 0x00000000, /* DENALI_PHY_20_DATA */ + 0x00000000, /* DENALI_PHY_21_DATA */ + 0x04080000, /* DENALI_PHY_22_DATA */ + 0x04080400, /* DENALI_PHY_23_DATA */ + 0x08000000, /* DENALI_PHY_24_DATA */ + 0x0c00c007, /* DENALI_PHY_25_DATA */ + 0x00000100, /* DENALI_PHY_26_DATA */ + 0x00000100, /* DENALI_PHY_27_DATA */ + 0x55555555, /* DENALI_PHY_28_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_29_DATA */ + 0x55555555, /* DENALI_PHY_30_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_31_DATA */ + 0x00005555, /* DENALI_PHY_32_DATA */ + 0x00000000, /* DENALI_PHY_33_DATA */ + 0x00000000, /* DENALI_PHY_34_DATA */ + 0x00000000, /* DENALI_PHY_35_DATA */ + 0x00000000, /* DENALI_PHY_36_DATA */ + 0x00000000, /* DENALI_PHY_37_DATA */ + 0x00000000, /* DENALI_PHY_38_DATA */ + 0x00000000, /* DENALI_PHY_39_DATA */ + 0x00000000, /* DENALI_PHY_40_DATA */ + 0x00000000, /* DENALI_PHY_41_DATA */ + 0x00000000, /* DENALI_PHY_42_DATA */ + 0x00000000, /* DENALI_PHY_43_DATA */ + 0x00000000, /* DENALI_PHY_44_DATA */ + 0x00000000, /* DENALI_PHY_45_DATA */ + 0x00000000, /* DENALI_PHY_46_DATA */ + 0x00000000, /* DENALI_PHY_47_DATA */ + 0x00000000, /* DENALI_PHY_48_DATA */ + 0x00000000, /* DENALI_PHY_49_DATA */ + 0x00000000, /* DENALI_PHY_50_DATA */ + 0x00000000, /* DENALI_PHY_51_DATA */ + 0x00200000, /* DENALI_PHY_52_DATA */ + 0x00000000, /* DENALI_PHY_53_DATA */ + 0x00000000, /* DENALI_PHY_54_DATA */ + 0x00000000, /* DENALI_PHY_55_DATA */ + 0x00000000, /* DENALI_PHY_56_DATA */ + 0x00000000, /* DENALI_PHY_57_DATA */ + 0x00000000, /* DENALI_PHY_58_DATA */ + 0x02800280, /* DENALI_PHY_59_DATA */ + 0x02800280, /* DENALI_PHY_60_DATA */ + 0x02800280, /* DENALI_PHY_61_DATA */ + 0x02800280, /* DENALI_PHY_62_DATA */ + 0x00000280, /* DENALI_PHY_63_DATA */ + 0x00000000, /* DENALI_PHY_64_DATA */ + 0x00000000, /* DENALI_PHY_65_DATA */ + 0x00000000, /* DENALI_PHY_66_DATA */ + 0x00000000, /* DENALI_PHY_67_DATA */ + 0x00800000, /* DENALI_PHY_68_DATA */ + 0x00800080, /* DENALI_PHY_69_DATA */ + 0x00800080, /* DENALI_PHY_70_DATA */ + 0x00800080, /* DENALI_PHY_71_DATA */ + 0x00800080, /* DENALI_PHY_72_DATA */ + 0x00800080, /* DENALI_PHY_73_DATA */ + 0x00800080, /* DENALI_PHY_74_DATA */ + 0x00800080, /* DENALI_PHY_75_DATA */ + 0x00800080, /* DENALI_PHY_76_DATA */ + 0x01c40080, /* DENALI_PHY_77_DATA */ + 0x01900002, /* DENALI_PHY_78_DATA */ + 0x00000000, /* DENALI_PHY_79_DATA */ + 0x00020000, /* DENALI_PHY_80_DATA */ + 0x00000200, /* DENALI_PHY_81_DATA */ + 0x00000000, /* DENALI_PHY_82_DATA */ + 0x51315152, /* DENALI_PHY_83_DATA */ + 0xc0013150, /* DENALI_PHY_84_DATA */ + 0x010000c0, /* DENALI_PHY_85_DATA */ + 0x00100000, /* DENALI_PHY_86_DATA */ + 0x0c054208, /* DENALI_PHY_87_DATA */ + 0x000f0c18, /* DENALI_PHY_88_DATA */ + 0x01000140, /* DENALI_PHY_89_DATA */ + 0x00000c20, /* DENALI_PHY_90_DATA */ + 0x00000000, /* DENALI_PHY_91_DATA */ + 0x00000000, /* DENALI_PHY_92_DATA */ + 0x00000000, /* DENALI_PHY_93_DATA */ + 0x00000000, /* DENALI_PHY_94_DATA */ + 0x00000000, /* DENALI_PHY_95_DATA */ + 0x00000000, /* DENALI_PHY_96_DATA */ + 0x00000000, /* DENALI_PHY_97_DATA */ + 0x00000000, /* DENALI_PHY_98_DATA */ + 0x00000000, /* DENALI_PHY_99_DATA */ + 0x00000000, /* DENALI_PHY_100_DATA */ + 0x00000000, /* DENALI_PHY_101_DATA */ + 0x00000000, /* DENALI_PHY_102_DATA */ + 0x00000000, /* DENALI_PHY_103_DATA */ + 0x00000000, /* DENALI_PHY_104_DATA */ + 0x00000000, /* DENALI_PHY_105_DATA */ + 0x00000000, /* DENALI_PHY_106_DATA */ + 0x00000000, /* DENALI_PHY_107_DATA */ + 0x00000000, /* DENALI_PHY_108_DATA */ + 0x00000000, /* DENALI_PHY_109_DATA */ + 0x00000000, /* DENALI_PHY_110_DATA */ + 0x00000000, /* DENALI_PHY_111_DATA */ + 0x00000000, /* DENALI_PHY_112_DATA */ + 0x00000000, /* DENALI_PHY_113_DATA */ + 0x00000000, /* DENALI_PHY_114_DATA */ + 0x00000000, /* DENALI_PHY_115_DATA */ + 0x00000000, /* DENALI_PHY_116_DATA */ + 0x00000000, /* DENALI_PHY_117_DATA */ + 0x00000000, /* DENALI_PHY_118_DATA */ + 0x00000000, /* DENALI_PHY_119_DATA */ + 0x00000000, /* DENALI_PHY_120_DATA */ + 0x00000000, /* DENALI_PHY_121_DATA */ + 0x00000000, /* DENALI_PHY_122_DATA */ + 0x00000000, /* DENALI_PHY_123_DATA */ + 0x00000000, /* DENALI_PHY_124_DATA */ + 0x00000000, /* DENALI_PHY_125_DATA */ + 0x00000000, /* DENALI_PHY_126_DATA */ + 0x00000000, /* DENALI_PHY_127_DATA */ + 0x76543210, /* DENALI_PHY_128_DATA */ + 0x0004c008, /* DENALI_PHY_129_DATA */ + 0x000001c4, /* DENALI_PHY_130_DATA */ + 0x00000000, /* DENALI_PHY_131_DATA */ + 0x00000000, /* DENALI_PHY_132_DATA */ + 0x00010000, /* DENALI_PHY_133_DATA */ + 0x01665555, /* DENALI_PHY_134_DATA */ + 0x00665555, /* DENALI_PHY_135_DATA */ + 0x00010f00, /* DENALI_PHY_136_DATA */ + 0x05000100, /* DENALI_PHY_137_DATA */ + 0x00000002, /* DENALI_PHY_138_DATA */ + 0x001700c0, /* DENALI_PHY_139_DATA */ + 0x00cc0101, /* DENALI_PHY_140_DATA */ + 0x00030066, /* DENALI_PHY_141_DATA */ + 0x00000000, /* DENALI_PHY_142_DATA */ + 0x00000000, /* DENALI_PHY_143_DATA */ + 0x00000000, /* DENALI_PHY_144_DATA */ + 0x00000000, /* DENALI_PHY_145_DATA */ + 0x00000000, /* DENALI_PHY_146_DATA */ + 0x00000000, /* DENALI_PHY_147_DATA */ + 0x00000000, /* DENALI_PHY_148_DATA */ + 0x00000000, /* DENALI_PHY_149_DATA */ + 0x04080000, /* DENALI_PHY_150_DATA */ + 0x04080400, /* DENALI_PHY_151_DATA */ + 0x08000000, /* DENALI_PHY_152_DATA */ + 0x0c00c007, /* DENALI_PHY_153_DATA */ + 0x00000100, /* DENALI_PHY_154_DATA */ + 0x00000100, /* DENALI_PHY_155_DATA */ + 0x55555555, /* DENALI_PHY_156_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_157_DATA */ + 0x55555555, /* DENALI_PHY_158_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_159_DATA */ + 0x00005555, /* DENALI_PHY_160_DATA */ + 0x00000000, /* DENALI_PHY_161_DATA */ + 0x00000000, /* DENALI_PHY_162_DATA */ + 0x00000000, /* DENALI_PHY_163_DATA */ + 0x00000000, /* DENALI_PHY_164_DATA */ + 0x00000000, /* DENALI_PHY_165_DATA */ + 0x00000000, /* DENALI_PHY_166_DATA */ + 0x00000000, /* DENALI_PHY_167_DATA */ + 0x00000000, /* DENALI_PHY_168_DATA */ + 0x00000000, /* DENALI_PHY_169_DATA */ + 0x00000000, /* DENALI_PHY_170_DATA */ + 0x00000000, /* DENALI_PHY_171_DATA */ + 0x00000000, /* DENALI_PHY_172_DATA */ + 0x00000000, /* DENALI_PHY_173_DATA */ + 0x00000000, /* DENALI_PHY_174_DATA */ + 0x00000000, /* DENALI_PHY_175_DATA */ + 0x00000000, /* DENALI_PHY_176_DATA */ + 0x00000000, /* DENALI_PHY_177_DATA */ + 0x00000000, /* DENALI_PHY_178_DATA */ + 0x00000000, /* DENALI_PHY_179_DATA */ + 0x00200000, /* DENALI_PHY_180_DATA */ + 0x00000000, /* DENALI_PHY_181_DATA */ + 0x00000000, /* DENALI_PHY_182_DATA */ + 0x00000000, /* DENALI_PHY_183_DATA */ + 0x00000000, /* DENALI_PHY_184_DATA */ + 0x00000000, /* DENALI_PHY_185_DATA */ + 0x00000000, /* DENALI_PHY_186_DATA */ + 0x02800280, /* DENALI_PHY_187_DATA */ + 0x02800280, /* DENALI_PHY_188_DATA */ + 0x02800280, /* DENALI_PHY_189_DATA */ + 0x02800280, /* DENALI_PHY_190_DATA */ + 0x00000280, /* DENALI_PHY_191_DATA */ + 0x00000000, /* DENALI_PHY_192_DATA */ + 0x00000000, /* DENALI_PHY_193_DATA */ + 0x00000000, /* DENALI_PHY_194_DATA */ + 0x00000000, /* DENALI_PHY_195_DATA */ + 0x00800000, /* DENALI_PHY_196_DATA */ + 0x00800080, /* DENALI_PHY_197_DATA */ + 0x00800080, /* DENALI_PHY_198_DATA */ + 0x00800080, /* DENALI_PHY_199_DATA */ + 0x00800080, /* DENALI_PHY_200_DATA */ + 0x00800080, /* DENALI_PHY_201_DATA */ + 0x00800080, /* DENALI_PHY_202_DATA */ + 0x00800080, /* DENALI_PHY_203_DATA */ + 0x00800080, /* DENALI_PHY_204_DATA */ + 0x01c40080, /* DENALI_PHY_205_DATA */ + 0x01900002, /* DENALI_PHY_206_DATA */ + 0x00000000, /* DENALI_PHY_207_DATA */ + 0x00020000, /* DENALI_PHY_208_DATA */ + 0x00000200, /* DENALI_PHY_209_DATA */ + 0x00000000, /* DENALI_PHY_210_DATA */ + 0x51315152, /* DENALI_PHY_211_DATA */ + 0xc0013150, /* DENALI_PHY_212_DATA */ + 0x010000c0, /* DENALI_PHY_213_DATA */ + 0x00100000, /* DENALI_PHY_214_DATA */ + 0x0c054208, /* DENALI_PHY_215_DATA */ + 0x000f0c18, /* DENALI_PHY_216_DATA */ + 0x01000140, /* DENALI_PHY_217_DATA */ + 0x00000c20, /* DENALI_PHY_218_DATA */ + 0x00000000, /* DENALI_PHY_219_DATA */ + 0x00000000, /* DENALI_PHY_220_DATA */ + 0x00000000, /* DENALI_PHY_221_DATA */ + 0x00000000, /* DENALI_PHY_222_DATA */ + 0x00000000, /* DENALI_PHY_223_DATA */ + 0x00000000, /* DENALI_PHY_224_DATA */ + 0x00000000, /* DENALI_PHY_225_DATA */ + 0x00000000, /* DENALI_PHY_226_DATA */ + 0x00000000, /* DENALI_PHY_227_DATA */ + 0x00000000, /* DENALI_PHY_228_DATA */ + 0x00000000, /* DENALI_PHY_229_DATA */ + 0x00000000, /* DENALI_PHY_230_DATA */ + 0x00000000, /* DENALI_PHY_231_DATA */ + 0x00000000, /* DENALI_PHY_232_DATA */ + 0x00000000, /* DENALI_PHY_233_DATA */ + 0x00000000, /* DENALI_PHY_234_DATA */ + 0x00000000, /* DENALI_PHY_235_DATA */ + 0x00000000, /* DENALI_PHY_236_DATA */ + 0x00000000, /* DENALI_PHY_237_DATA */ + 0x00000000, /* DENALI_PHY_238_DATA */ + 0x00000000, /* DENALI_PHY_239_DATA */ + 0x00000000, /* DENALI_PHY_240_DATA */ + 0x00000000, /* DENALI_PHY_241_DATA */ + 0x00000000, /* DENALI_PHY_242_DATA */ + 0x00000000, /* DENALI_PHY_243_DATA */ + 0x00000000, /* DENALI_PHY_244_DATA */ + 0x00000000, /* DENALI_PHY_245_DATA */ + 0x00000000, /* DENALI_PHY_246_DATA */ + 0x00000000, /* DENALI_PHY_247_DATA */ + 0x00000000, /* DENALI_PHY_248_DATA */ + 0x00000000, /* DENALI_PHY_249_DATA */ + 0x00000000, /* DENALI_PHY_250_DATA */ + 0x00000000, /* DENALI_PHY_251_DATA */ + 0x00000000, /* DENALI_PHY_252_DATA */ + 0x00000000, /* DENALI_PHY_253_DATA */ + 0x00000000, /* DENALI_PHY_254_DATA */ + 0x00000000, /* DENALI_PHY_255_DATA */ + 0x76543210, /* DENALI_PHY_256_DATA */ + 0x0004c008, /* DENALI_PHY_257_DATA */ + 0x000001c4, /* DENALI_PHY_258_DATA */ + 0x00000000, /* DENALI_PHY_259_DATA */ + 0x00000000, /* DENALI_PHY_260_DATA */ + 0x00010000, /* DENALI_PHY_261_DATA */ + 0x01665555, /* DENALI_PHY_262_DATA */ + 0x00665555, /* DENALI_PHY_263_DATA */ + 0x00010f00, /* DENALI_PHY_264_DATA */ + 0x05000100, /* DENALI_PHY_265_DATA */ + 0x00000002, /* DENALI_PHY_266_DATA */ + 0x001700c0, /* DENALI_PHY_267_DATA */ + 0x00cc0101, /* DENALI_PHY_268_DATA */ + 0x00030066, /* DENALI_PHY_269_DATA */ + 0x00000000, /* DENALI_PHY_270_DATA */ + 0x00000000, /* DENALI_PHY_271_DATA */ + 0x00000000, /* DENALI_PHY_272_DATA */ + 0x00000000, /* DENALI_PHY_273_DATA */ + 0x00000000, /* DENALI_PHY_274_DATA */ + 0x00000000, /* DENALI_PHY_275_DATA */ + 0x00000000, /* DENALI_PHY_276_DATA */ + 0x00000000, /* DENALI_PHY_277_DATA */ + 0x04080000, /* DENALI_PHY_278_DATA */ + 0x04080400, /* DENALI_PHY_279_DATA */ + 0x08000000, /* DENALI_PHY_280_DATA */ + 0x0c00c007, /* DENALI_PHY_281_DATA */ + 0x00000100, /* DENALI_PHY_282_DATA */ + 0x00000100, /* DENALI_PHY_283_DATA */ + 0x55555555, /* DENALI_PHY_284_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_285_DATA */ + 0x55555555, /* DENALI_PHY_286_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_287_DATA */ + 0x00005555, /* DENALI_PHY_288_DATA */ + 0x00000000, /* DENALI_PHY_289_DATA */ + 0x00000000, /* DENALI_PHY_290_DATA */ + 0x00000000, /* DENALI_PHY_291_DATA */ + 0x00000000, /* DENALI_PHY_292_DATA */ + 0x00000000, /* DENALI_PHY_293_DATA */ + 0x00000000, /* DENALI_PHY_294_DATA */ + 0x00000000, /* DENALI_PHY_295_DATA */ + 0x00000000, /* DENALI_PHY_296_DATA */ + 0x00000000, /* DENALI_PHY_297_DATA */ + 0x00000000, /* DENALI_PHY_298_DATA */ + 0x00000000, /* DENALI_PHY_299_DATA */ + 0x00000000, /* DENALI_PHY_300_DATA */ + 0x00000000, /* DENALI_PHY_301_DATA */ + 0x00000000, /* DENALI_PHY_302_DATA */ + 0x00000000, /* DENALI_PHY_303_DATA */ + 0x00000000, /* DENALI_PHY_304_DATA */ + 0x00000000, /* DENALI_PHY_305_DATA */ + 0x00000000, /* DENALI_PHY_306_DATA */ + 0x00000000, /* DENALI_PHY_307_DATA */ + 0x00200000, /* DENALI_PHY_308_DATA */ + 0x00000000, /* DENALI_PHY_309_DATA */ + 0x00000000, /* DENALI_PHY_310_DATA */ + 0x00000000, /* DENALI_PHY_311_DATA */ + 0x00000000, /* DENALI_PHY_312_DATA */ + 0x00000000, /* DENALI_PHY_313_DATA */ + 0x00000000, /* DENALI_PHY_314_DATA */ + 0x02800280, /* DENALI_PHY_315_DATA */ + 0x02800280, /* DENALI_PHY_316_DATA */ + 0x02800280, /* DENALI_PHY_317_DATA */ + 0x02800280, /* DENALI_PHY_318_DATA */ + 0x00000280, /* DENALI_PHY_319_DATA */ + 0x00000000, /* DENALI_PHY_320_DATA */ + 0x00000000, /* DENALI_PHY_321_DATA */ + 0x00000000, /* DENALI_PHY_322_DATA */ + 0x00000000, /* DENALI_PHY_323_DATA */ + 0x00800000, /* DENALI_PHY_324_DATA */ + 0x00800080, /* DENALI_PHY_325_DATA */ + 0x00800080, /* DENALI_PHY_326_DATA */ + 0x00800080, /* DENALI_PHY_327_DATA */ + 0x00800080, /* DENALI_PHY_328_DATA */ + 0x00800080, /* DENALI_PHY_329_DATA */ + 0x00800080, /* DENALI_PHY_330_DATA */ + 0x00800080, /* DENALI_PHY_331_DATA */ + 0x00800080, /* DENALI_PHY_332_DATA */ + 0x01c40080, /* DENALI_PHY_333_DATA */ + 0x01900002, /* DENALI_PHY_334_DATA */ + 0x00000000, /* DENALI_PHY_335_DATA */ + 0x00020000, /* DENALI_PHY_336_DATA */ + 0x00000200, /* DENALI_PHY_337_DATA */ + 0x00000000, /* DENALI_PHY_338_DATA */ + 0x51315152, /* DENALI_PHY_339_DATA */ + 0xc0013150, /* DENALI_PHY_340_DATA */ + 0x010000c0, /* DENALI_PHY_341_DATA */ + 0x00100000, /* DENALI_PHY_342_DATA */ + 0x0c054208, /* DENALI_PHY_343_DATA */ + 0x000f0c18, /* DENALI_PHY_344_DATA */ + 0x01000140, /* DENALI_PHY_345_DATA */ + 0x00000c20, /* DENALI_PHY_346_DATA */ + 0x00000000, /* DENALI_PHY_347_DATA */ + 0x00000000, /* DENALI_PHY_348_DATA */ + 0x00000000, /* DENALI_PHY_349_DATA */ + 0x00000000, /* DENALI_PHY_350_DATA */ + 0x00000000, /* DENALI_PHY_351_DATA */ + 0x00000000, /* DENALI_PHY_352_DATA */ + 0x00000000, /* DENALI_PHY_353_DATA */ + 0x00000000, /* DENALI_PHY_354_DATA */ + 0x00000000, /* DENALI_PHY_355_DATA */ + 0x00000000, /* DENALI_PHY_356_DATA */ + 0x00000000, /* DENALI_PHY_357_DATA */ + 0x00000000, /* DENALI_PHY_358_DATA */ + 0x00000000, /* DENALI_PHY_359_DATA */ + 0x00000000, /* DENALI_PHY_360_DATA */ + 0x00000000, /* DENALI_PHY_361_DATA */ + 0x00000000, /* DENALI_PHY_362_DATA */ + 0x00000000, /* DENALI_PHY_363_DATA */ + 0x00000000, /* DENALI_PHY_364_DATA */ + 0x00000000, /* DENALI_PHY_365_DATA */ + 0x00000000, /* DENALI_PHY_366_DATA */ + 0x00000000, /* DENALI_PHY_367_DATA */ + 0x00000000, /* DENALI_PHY_368_DATA */ + 0x00000000, /* DENALI_PHY_369_DATA */ + 0x00000000, /* DENALI_PHY_370_DATA */ + 0x00000000, /* DENALI_PHY_371_DATA */ + 0x00000000, /* DENALI_PHY_372_DATA */ + 0x00000000, /* DENALI_PHY_373_DATA */ + 0x00000000, /* DENALI_PHY_374_DATA */ + 0x00000000, /* DENALI_PHY_375_DATA */ + 0x00000000, /* DENALI_PHY_376_DATA */ + 0x00000000, /* DENALI_PHY_377_DATA */ + 0x00000000, /* DENALI_PHY_378_DATA */ + 0x00000000, /* DENALI_PHY_379_DATA */ + 0x00000000, /* DENALI_PHY_380_DATA */ + 0x00000000, /* DENALI_PHY_381_DATA */ + 0x00000000, /* DENALI_PHY_382_DATA */ + 0x00000000, /* DENALI_PHY_383_DATA */ + 0x76543210, /* DENALI_PHY_384_DATA */ + 0x0004c008, /* DENALI_PHY_385_DATA */ + 0x000001c4, /* DENALI_PHY_386_DATA */ + 0x00000000, /* DENALI_PHY_387_DATA */ + 0x00000000, /* DENALI_PHY_388_DATA */ + 0x00010000, /* DENALI_PHY_389_DATA */ + 0x01665555, /* DENALI_PHY_390_DATA */ + 0x00665555, /* DENALI_PHY_391_DATA */ + 0x00010f00, /* DENALI_PHY_392_DATA */ + 0x05000100, /* DENALI_PHY_393_DATA */ + 0x00000002, /* DENALI_PHY_394_DATA */ + 0x001700c0, /* DENALI_PHY_395_DATA */ + 0x00cc0101, /* DENALI_PHY_396_DATA */ + 0x00030066, /* DENALI_PHY_397_DATA */ + 0x00000000, /* DENALI_PHY_398_DATA */ + 0x00000000, /* DENALI_PHY_399_DATA */ + 0x00000000, /* DENALI_PHY_400_DATA */ + 0x00000000, /* DENALI_PHY_401_DATA */ + 0x00000000, /* DENALI_PHY_402_DATA */ + 0x00000000, /* DENALI_PHY_403_DATA */ + 0x00000000, /* DENALI_PHY_404_DATA */ + 0x00000000, /* DENALI_PHY_405_DATA */ + 0x04080000, /* DENALI_PHY_406_DATA */ + 0x04080400, /* DENALI_PHY_407_DATA */ + 0x08000000, /* DENALI_PHY_408_DATA */ + 0x0c00c007, /* DENALI_PHY_409_DATA */ + 0x00000100, /* DENALI_PHY_410_DATA */ + 0x00000100, /* DENALI_PHY_411_DATA */ + 0x55555555, /* DENALI_PHY_412_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_413_DATA */ + 0x55555555, /* DENALI_PHY_414_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_415_DATA */ + 0x00005555, /* DENALI_PHY_416_DATA */ + 0x00000000, /* DENALI_PHY_417_DATA */ + 0x00000000, /* DENALI_PHY_418_DATA */ + 0x00000000, /* DENALI_PHY_419_DATA */ + 0x00000000, /* DENALI_PHY_420_DATA */ + 0x00000000, /* DENALI_PHY_421_DATA */ + 0x00000000, /* DENALI_PHY_422_DATA */ + 0x00000000, /* DENALI_PHY_423_DATA */ + 0x00000000, /* DENALI_PHY_424_DATA */ + 0x00000000, /* DENALI_PHY_425_DATA */ + 0x00000000, /* DENALI_PHY_426_DATA */ + 0x00000000, /* DENALI_PHY_427_DATA */ + 0x00000000, /* DENALI_PHY_428_DATA */ + 0x00000000, /* DENALI_PHY_429_DATA */ + 0x00000000, /* DENALI_PHY_430_DATA */ + 0x00000000, /* DENALI_PHY_431_DATA */ + 0x00000000, /* DENALI_PHY_432_DATA */ + 0x00000000, /* DENALI_PHY_433_DATA */ + 0x00000000, /* DENALI_PHY_434_DATA */ + 0x00000000, /* DENALI_PHY_435_DATA */ + 0x00200000, /* DENALI_PHY_436_DATA */ + 0x00000000, /* DENALI_PHY_437_DATA */ + 0x00000000, /* DENALI_PHY_438_DATA */ + 0x00000000, /* DENALI_PHY_439_DATA */ + 0x00000000, /* DENALI_PHY_440_DATA */ + 0x00000000, /* DENALI_PHY_441_DATA */ + 0x00000000, /* DENALI_PHY_442_DATA */ + 0x02800280, /* DENALI_PHY_443_DATA */ + 0x02800280, /* DENALI_PHY_444_DATA */ + 0x02800280, /* DENALI_PHY_445_DATA */ + 0x02800280, /* DENALI_PHY_446_DATA */ + 0x00000280, /* DENALI_PHY_447_DATA */ + 0x00000000, /* DENALI_PHY_448_DATA */ + 0x00000000, /* DENALI_PHY_449_DATA */ + 0x00000000, /* DENALI_PHY_450_DATA */ + 0x00000000, /* DENALI_PHY_451_DATA */ + 0x00800000, /* DENALI_PHY_452_DATA */ + 0x00800080, /* DENALI_PHY_453_DATA */ + 0x00800080, /* DENALI_PHY_454_DATA */ + 0x00800080, /* DENALI_PHY_455_DATA */ + 0x00800080, /* DENALI_PHY_456_DATA */ + 0x00800080, /* DENALI_PHY_457_DATA */ + 0x00800080, /* DENALI_PHY_458_DATA */ + 0x00800080, /* DENALI_PHY_459_DATA */ + 0x00800080, /* DENALI_PHY_460_DATA */ + 0x01c40080, /* DENALI_PHY_461_DATA */ + 0x01900002, /* DENALI_PHY_462_DATA */ + 0x00000000, /* DENALI_PHY_463_DATA */ + 0x00020000, /* DENALI_PHY_464_DATA */ + 0x00000200, /* DENALI_PHY_465_DATA */ + 0x00000000, /* DENALI_PHY_466_DATA */ + 0x51315152, /* DENALI_PHY_467_DATA */ + 0xc0013150, /* DENALI_PHY_468_DATA */ + 0x010000c0, /* DENALI_PHY_469_DATA */ + 0x00100000, /* DENALI_PHY_470_DATA */ + 0x0c054208, /* DENALI_PHY_471_DATA */ + 0x000f0c18, /* DENALI_PHY_472_DATA */ + 0x01000140, /* DENALI_PHY_473_DATA */ + 0x00000c20, /* DENALI_PHY_474_DATA */ + 0x00000000, /* DENALI_PHY_475_DATA */ + 0x00000000, /* DENALI_PHY_476_DATA */ + 0x00000000, /* DENALI_PHY_477_DATA */ + 0x00000000, /* DENALI_PHY_478_DATA */ + 0x00000000, /* DENALI_PHY_479_DATA */ + 0x00000000, /* DENALI_PHY_480_DATA */ + 0x00000000, /* DENALI_PHY_481_DATA */ + 0x00000000, /* DENALI_PHY_482_DATA */ + 0x00000000, /* DENALI_PHY_483_DATA */ + 0x00000000, /* DENALI_PHY_484_DATA */ + 0x00000000, /* DENALI_PHY_485_DATA */ + 0x00000000, /* DENALI_PHY_486_DATA */ + 0x00000000, /* DENALI_PHY_487_DATA */ + 0x00000000, /* DENALI_PHY_488_DATA */ + 0x00000000, /* DENALI_PHY_489_DATA */ + 0x00000000, /* DENALI_PHY_490_DATA */ + 0x00000000, /* DENALI_PHY_491_DATA */ + 0x00000000, /* DENALI_PHY_492_DATA */ + 0x00000000, /* DENALI_PHY_493_DATA */ + 0x00000000, /* DENALI_PHY_494_DATA */ + 0x00000000, /* DENALI_PHY_495_DATA */ + 0x00000000, /* DENALI_PHY_496_DATA */ + 0x00000000, /* DENALI_PHY_497_DATA */ + 0x00000000, /* DENALI_PHY_498_DATA */ + 0x00000000, /* DENALI_PHY_499_DATA */ + 0x00000000, /* DENALI_PHY_500_DATA */ + 0x00000000, /* DENALI_PHY_501_DATA */ + 0x00000000, /* DENALI_PHY_502_DATA */ + 0x00000000, /* DENALI_PHY_503_DATA */ + 0x00000000, /* DENALI_PHY_504_DATA */ + 0x00000000, /* DENALI_PHY_505_DATA */ + 0x00000000, /* DENALI_PHY_506_DATA */ + 0x00000000, /* DENALI_PHY_507_DATA */ + 0x00000000, /* DENALI_PHY_508_DATA */ + 0x00000000, /* DENALI_PHY_509_DATA */ + 0x00000000, /* DENALI_PHY_510_DATA */ + 0x00000000, /* DENALI_PHY_511_DATA */ + 0x00000000, /* DENALI_PHY_512_DATA */ + 0x00800000, /* DENALI_PHY_513_DATA */ + 0x00000000, /* DENALI_PHY_514_DATA */ + 0x00000000, /* DENALI_PHY_515_DATA */ + 0x00000000, /* DENALI_PHY_516_DATA */ + 0x00000000, /* DENALI_PHY_517_DATA */ + 0x00000000, /* DENALI_PHY_518_DATA */ + 0x00000001, /* DENALI_PHY_519_DATA */ + 0x00000000, /* DENALI_PHY_520_DATA */ + 0x00000000, /* DENALI_PHY_521_DATA */ + 0x00000000, /* DENALI_PHY_522_DATA */ + 0x00400320, /* DENALI_PHY_523_DATA */ + 0x00000040, /* DENALI_PHY_524_DATA */ + 0x00806420, /* DENALI_PHY_525_DATA */ + 0x00917531, /* DENALI_PHY_526_DATA */ + 0x00806420, /* DENALI_PHY_527_DATA */ + 0x01917531, /* DENALI_PHY_528_DATA */ + 0x00020003, /* DENALI_PHY_529_DATA */ + 0x00000000, /* DENALI_PHY_530_DATA */ + 0x00000000, /* DENALI_PHY_531_DATA */ + 0x00000000, /* DENALI_PHY_532_DATA */ + 0x000556aa, /* DENALI_PHY_533_DATA */ + 0x000aaaaa, /* DENALI_PHY_534_DATA */ + 0x000aa955, /* DENALI_PHY_535_DATA */ + 0x00055555, /* DENALI_PHY_536_DATA */ + 0x000b3133, /* DENALI_PHY_537_DATA */ + 0x0004cd33, /* DENALI_PHY_538_DATA */ + 0x0004cecc, /* DENALI_PHY_539_DATA */ + 0x000b32cc, /* DENALI_PHY_540_DATA */ + 0x0a418820, /* DENALI_PHY_541_DATA */ + 0x103f0000, /* DENALI_PHY_542_DATA */ + 0x0000003f, /* DENALI_PHY_543_DATA */ + 0x00038055, /* DENALI_PHY_544_DATA */ + 0x03800380, /* DENALI_PHY_545_DATA */ + 0x03800380, /* DENALI_PHY_546_DATA */ + 0x00000380, /* DENALI_PHY_547_DATA */ + 0x42080010, /* DENALI_PHY_548_DATA */ + 0x00000003, /* DENALI_PHY_549_DATA */ + 0x00000000, /* DENALI_PHY_550_DATA */ + 0x00000000, /* DENALI_PHY_551_DATA */ + 0x00000000, /* DENALI_PHY_552_DATA */ + 0x00000000, /* DENALI_PHY_553_DATA */ + 0x00000000, /* DENALI_PHY_554_DATA */ + 0x00000000, /* DENALI_PHY_555_DATA */ + 0x00000000, /* DENALI_PHY_556_DATA */ + 0x00000000, /* DENALI_PHY_557_DATA */ + 0x00000000, /* DENALI_PHY_558_DATA */ + 0x00000000, /* DENALI_PHY_559_DATA */ + 0x00000000, /* DENALI_PHY_560_DATA */ + 0x00000000, /* DENALI_PHY_561_DATA */ + 0x00000000, /* DENALI_PHY_562_DATA */ + 0x00000000, /* DENALI_PHY_563_DATA */ + 0x00000000, /* DENALI_PHY_564_DATA */ + 0x00000000, /* DENALI_PHY_565_DATA */ + 0x00000000, /* DENALI_PHY_566_DATA */ + 0x00000000, /* DENALI_PHY_567_DATA */ + 0x00000000, /* DENALI_PHY_568_DATA */ + 0x00000000, /* DENALI_PHY_569_DATA */ + 0x00000000, /* DENALI_PHY_570_DATA */ + 0x00000000, /* DENALI_PHY_571_DATA */ + 0x00000000, /* DENALI_PHY_572_DATA */ + 0x00000000, /* DENALI_PHY_573_DATA */ + 0x00000000, /* DENALI_PHY_574_DATA */ + 0x00000000, /* DENALI_PHY_575_DATA */ + 0x00000000, /* DENALI_PHY_576_DATA */ + 0x00000000, /* DENALI_PHY_577_DATA */ + 0x00000000, /* DENALI_PHY_578_DATA */ + 0x00000000, /* DENALI_PHY_579_DATA */ + 0x00000000, /* DENALI_PHY_580_DATA */ + 0x00000000, /* DENALI_PHY_581_DATA */ + 0x00000000, /* DENALI_PHY_582_DATA */ + 0x00000000, /* DENALI_PHY_583_DATA */ + 0x00000000, /* DENALI_PHY_584_DATA */ + 0x00000000, /* DENALI_PHY_585_DATA */ + 0x00000000, /* DENALI_PHY_586_DATA */ + 0x00000000, /* DENALI_PHY_587_DATA */ + 0x00000000, /* DENALI_PHY_588_DATA */ + 0x00000000, /* DENALI_PHY_589_DATA */ + 0x00000000, /* DENALI_PHY_590_DATA */ + 0x00000000, /* DENALI_PHY_591_DATA */ + 0x00000000, /* DENALI_PHY_592_DATA */ + 0x00000000, /* DENALI_PHY_593_DATA */ + 0x00000000, /* DENALI_PHY_594_DATA */ + 0x00000000, /* DENALI_PHY_595_DATA */ + 0x00000000, /* DENALI_PHY_596_DATA */ + 0x00000000, /* DENALI_PHY_597_DATA */ + 0x00000000, /* DENALI_PHY_598_DATA */ + 0x00000000, /* DENALI_PHY_599_DATA */ + 0x00000000, /* DENALI_PHY_600_DATA */ + 0x00000000, /* DENALI_PHY_601_DATA */ + 0x00000000, /* DENALI_PHY_602_DATA */ + 0x00000000, /* DENALI_PHY_603_DATA */ + 0x00000000, /* DENALI_PHY_604_DATA */ + 0x00000000, /* DENALI_PHY_605_DATA */ + 0x00000000, /* DENALI_PHY_606_DATA */ + 0x00000000, /* DENALI_PHY_607_DATA */ + 0x00000000, /* DENALI_PHY_608_DATA */ + 0x00000000, /* DENALI_PHY_609_DATA */ + 0x00000000, /* DENALI_PHY_610_DATA */ + 0x00000000, /* DENALI_PHY_611_DATA */ + 0x00000000, /* DENALI_PHY_612_DATA */ + 0x00000000, /* DENALI_PHY_613_DATA */ + 0x00000000, /* DENALI_PHY_614_DATA */ + 0x00000000, /* DENALI_PHY_615_DATA */ + 0x00000000, /* DENALI_PHY_616_DATA */ + 0x00000000, /* DENALI_PHY_617_DATA */ + 0x00000000, /* DENALI_PHY_618_DATA */ + 0x00000000, /* DENALI_PHY_619_DATA */ + 0x00000000, /* DENALI_PHY_620_DATA */ + 0x00000000, /* DENALI_PHY_621_DATA */ + 0x00000000, /* DENALI_PHY_622_DATA */ + 0x00000000, /* DENALI_PHY_623_DATA */ + 0x00000000, /* DENALI_PHY_624_DATA */ + 0x00000000, /* DENALI_PHY_625_DATA */ + 0x00000000, /* DENALI_PHY_626_DATA */ + 0x00000000, /* DENALI_PHY_627_DATA */ + 0x00000000, /* DENALI_PHY_628_DATA */ + 0x00000000, /* DENALI_PHY_629_DATA */ + 0x00000000, /* DENALI_PHY_630_DATA */ + 0x00000000, /* DENALI_PHY_631_DATA */ + 0x00000000, /* DENALI_PHY_632_DATA */ + 0x00000000, /* DENALI_PHY_633_DATA */ + 0x00000000, /* DENALI_PHY_634_DATA */ + 0x00000000, /* DENALI_PHY_635_DATA */ + 0x00000000, /* DENALI_PHY_636_DATA */ + 0x00000000, /* DENALI_PHY_637_DATA */ + 0x00000000, /* DENALI_PHY_638_DATA */ + 0x00000000, /* DENALI_PHY_639_DATA */ + 0x00000000, /* DENALI_PHY_640_DATA */ + 0x00800000, /* DENALI_PHY_641_DATA */ + 0x00000000, /* DENALI_PHY_642_DATA */ + 0x00000000, /* DENALI_PHY_643_DATA */ + 0x00000000, /* DENALI_PHY_644_DATA */ + 0x00000000, /* DENALI_PHY_645_DATA */ + 0x00000000, /* DENALI_PHY_646_DATA */ + 0x00000001, /* DENALI_PHY_647_DATA */ + 0x00000000, /* DENALI_PHY_648_DATA */ + 0x00000000, /* DENALI_PHY_649_DATA */ + 0x00000000, /* DENALI_PHY_650_DATA */ + 0x00400320, /* DENALI_PHY_651_DATA */ + 0x00000040, /* DENALI_PHY_652_DATA */ + 0x00008eca, /* DENALI_PHY_653_DATA */ + 0x00009fdb, /* DENALI_PHY_654_DATA */ + 0x00008eca, /* DENALI_PHY_655_DATA */ + 0x01009fdb, /* DENALI_PHY_656_DATA */ + 0x00020003, /* DENALI_PHY_657_DATA */ + 0x00000000, /* DENALI_PHY_658_DATA */ + 0x00000000, /* DENALI_PHY_659_DATA */ + 0x00000000, /* DENALI_PHY_660_DATA */ + 0x000556aa, /* DENALI_PHY_661_DATA */ + 0x000aaaaa, /* DENALI_PHY_662_DATA */ + 0x000aa955, /* DENALI_PHY_663_DATA */ + 0x00055555, /* DENALI_PHY_664_DATA */ + 0x000b3133, /* DENALI_PHY_665_DATA */ + 0x0004cd33, /* DENALI_PHY_666_DATA */ + 0x0004cecc, /* DENALI_PHY_667_DATA */ + 0x000b32cc, /* DENALI_PHY_668_DATA */ + 0x0004a0e6, /* DENALI_PHY_669_DATA */ + 0x080f0000, /* DENALI_PHY_670_DATA */ + 0x0000000f, /* DENALI_PHY_671_DATA */ + 0x00038055, /* DENALI_PHY_672_DATA */ + 0x03800380, /* DENALI_PHY_673_DATA */ + 0x03800380, /* DENALI_PHY_674_DATA */ + 0x00000380, /* DENALI_PHY_675_DATA */ + 0x42080010, /* DENALI_PHY_676_DATA */ + 0x00000003, /* DENALI_PHY_677_DATA */ + 0x00000000, /* DENALI_PHY_678_DATA */ + 0x00000000, /* DENALI_PHY_679_DATA */ + 0x00000000, /* DENALI_PHY_680_DATA */ + 0x00000000, /* DENALI_PHY_681_DATA */ + 0x00000000, /* DENALI_PHY_682_DATA */ + 0x00000000, /* DENALI_PHY_683_DATA */ + 0x00000000, /* DENALI_PHY_684_DATA */ + 0x00000000, /* DENALI_PHY_685_DATA */ + 0x00000000, /* DENALI_PHY_686_DATA */ + 0x00000000, /* DENALI_PHY_687_DATA */ + 0x00000000, /* DENALI_PHY_688_DATA */ + 0x00000000, /* DENALI_PHY_689_DATA */ + 0x00000000, /* DENALI_PHY_690_DATA */ + 0x00000000, /* DENALI_PHY_691_DATA */ + 0x00000000, /* DENALI_PHY_692_DATA */ + 0x00000000, /* DENALI_PHY_693_DATA */ + 0x00000000, /* DENALI_PHY_694_DATA */ + 0x00000000, /* DENALI_PHY_695_DATA */ + 0x00000000, /* DENALI_PHY_696_DATA */ + 0x00000000, /* DENALI_PHY_697_DATA */ + 0x00000000, /* DENALI_PHY_698_DATA */ + 0x00000000, /* DENALI_PHY_699_DATA */ + 0x00000000, /* DENALI_PHY_700_DATA */ + 0x00000000, /* DENALI_PHY_701_DATA */ + 0x00000000, /* DENALI_PHY_702_DATA */ + 0x00000000, /* DENALI_PHY_703_DATA */ + 0x00000000, /* DENALI_PHY_704_DATA */ + 0x00000000, /* DENALI_PHY_705_DATA */ + 0x00000000, /* DENALI_PHY_706_DATA */ + 0x00000000, /* DENALI_PHY_707_DATA */ + 0x00000000, /* DENALI_PHY_708_DATA */ + 0x00000000, /* DENALI_PHY_709_DATA */ + 0x00000000, /* DENALI_PHY_710_DATA */ + 0x00000000, /* DENALI_PHY_711_DATA */ + 0x00000000, /* DENALI_PHY_712_DATA */ + 0x00000000, /* DENALI_PHY_713_DATA */ + 0x00000000, /* DENALI_PHY_714_DATA */ + 0x00000000, /* DENALI_PHY_715_DATA */ + 0x00000000, /* DENALI_PHY_716_DATA */ + 0x00000000, /* DENALI_PHY_717_DATA */ + 0x00000000, /* DENALI_PHY_718_DATA */ + 0x00000000, /* DENALI_PHY_719_DATA */ + 0x00000000, /* DENALI_PHY_720_DATA */ + 0x00000000, /* DENALI_PHY_721_DATA */ + 0x00000000, /* DENALI_PHY_722_DATA */ + 0x00000000, /* DENALI_PHY_723_DATA */ + 0x00000000, /* DENALI_PHY_724_DATA */ + 0x00000000, /* DENALI_PHY_725_DATA */ + 0x00000000, /* DENALI_PHY_726_DATA */ + 0x00000000, /* DENALI_PHY_727_DATA */ + 0x00000000, /* DENALI_PHY_728_DATA */ + 0x00000000, /* DENALI_PHY_729_DATA */ + 0x00000000, /* DENALI_PHY_730_DATA */ + 0x00000000, /* DENALI_PHY_731_DATA */ + 0x00000000, /* DENALI_PHY_732_DATA */ + 0x00000000, /* DENALI_PHY_733_DATA */ + 0x00000000, /* DENALI_PHY_734_DATA */ + 0x00000000, /* DENALI_PHY_735_DATA */ + 0x00000000, /* DENALI_PHY_736_DATA */ + 0x00000000, /* DENALI_PHY_737_DATA */ + 0x00000000, /* DENALI_PHY_738_DATA */ + 0x00000000, /* DENALI_PHY_739_DATA */ + 0x00000000, /* DENALI_PHY_740_DATA */ + 0x00000000, /* DENALI_PHY_741_DATA */ + 0x00000000, /* DENALI_PHY_742_DATA */ + 0x00000000, /* DENALI_PHY_743_DATA */ + 0x00000000, /* DENALI_PHY_744_DATA */ + 0x00000000, /* DENALI_PHY_745_DATA */ + 0x00000000, /* DENALI_PHY_746_DATA */ + 0x00000000, /* DENALI_PHY_747_DATA */ + 0x00000000, /* DENALI_PHY_748_DATA */ + 0x00000000, /* DENALI_PHY_749_DATA */ + 0x00000000, /* DENALI_PHY_750_DATA */ + 0x00000000, /* DENALI_PHY_751_DATA */ + 0x00000000, /* DENALI_PHY_752_DATA */ + 0x00000000, /* DENALI_PHY_753_DATA */ + 0x00000000, /* DENALI_PHY_754_DATA */ + 0x00000000, /* DENALI_PHY_755_DATA */ + 0x00000000, /* DENALI_PHY_756_DATA */ + 0x00000000, /* DENALI_PHY_757_DATA */ + 0x00000000, /* DENALI_PHY_758_DATA */ + 0x00000000, /* DENALI_PHY_759_DATA */ + 0x00000000, /* DENALI_PHY_760_DATA */ + 0x00000000, /* DENALI_PHY_761_DATA */ + 0x00000000, /* DENALI_PHY_762_DATA */ + 0x00000000, /* DENALI_PHY_763_DATA */ + 0x00000000, /* DENALI_PHY_764_DATA */ + 0x00000000, /* DENALI_PHY_765_DATA */ + 0x00000000, /* DENALI_PHY_766_DATA */ + 0x00000000, /* DENALI_PHY_767_DATA */ + 0x00000000, /* DENALI_PHY_768_DATA */ + 0x00800000, /* DENALI_PHY_769_DATA */ + 0x00000000, /* DENALI_PHY_770_DATA */ + 0x00000000, /* DENALI_PHY_771_DATA */ + 0x00000000, /* DENALI_PHY_772_DATA */ + 0x00000000, /* DENALI_PHY_773_DATA */ + 0x00000000, /* DENALI_PHY_774_DATA */ + 0x00000001, /* DENALI_PHY_775_DATA */ + 0x00000000, /* DENALI_PHY_776_DATA */ + 0x00000000, /* DENALI_PHY_777_DATA */ + 0x00000000, /* DENALI_PHY_778_DATA */ + 0x00400320, /* DENALI_PHY_779_DATA */ + 0x00000040, /* DENALI_PHY_780_DATA */ + 0x00008eca, /* DENALI_PHY_781_DATA */ + 0x00009fdb, /* DENALI_PHY_782_DATA */ + 0x00008eca, /* DENALI_PHY_783_DATA */ + 0x01009fdb, /* DENALI_PHY_784_DATA */ + 0x00020003, /* DENALI_PHY_785_DATA */ + 0x00000000, /* DENALI_PHY_786_DATA */ + 0x00000000, /* DENALI_PHY_787_DATA */ + 0x00000000, /* DENALI_PHY_788_DATA */ + 0x000556aa, /* DENALI_PHY_789_DATA */ + 0x000aaaaa, /* DENALI_PHY_790_DATA */ + 0x000aa955, /* DENALI_PHY_791_DATA */ + 0x00055555, /* DENALI_PHY_792_DATA */ + 0x000b3133, /* DENALI_PHY_793_DATA */ + 0x0004cd33, /* DENALI_PHY_794_DATA */ + 0x0004cecc, /* DENALI_PHY_795_DATA */ + 0x000b32cc, /* DENALI_PHY_796_DATA */ + 0x1ee6b16a, /* DENALI_PHY_797_DATA */ + 0x10000000, /* DENALI_PHY_798_DATA */ + 0x00000000, /* DENALI_PHY_799_DATA */ + 0x00038055, /* DENALI_PHY_800_DATA */ + 0x03800380, /* DENALI_PHY_801_DATA */ + 0x03800380, /* DENALI_PHY_802_DATA */ + 0x00000380, /* DENALI_PHY_803_DATA */ + 0x42080010, /* DENALI_PHY_804_DATA */ + 0x00000003, /* DENALI_PHY_805_DATA */ + 0x00000000, /* DENALI_PHY_806_DATA */ + 0x00000000, /* DENALI_PHY_807_DATA */ + 0x00000000, /* DENALI_PHY_808_DATA */ + 0x00000000, /* DENALI_PHY_809_DATA */ + 0x00000000, /* DENALI_PHY_810_DATA */ + 0x00000000, /* DENALI_PHY_811_DATA */ + 0x00000000, /* DENALI_PHY_812_DATA */ + 0x00000000, /* DENALI_PHY_813_DATA */ + 0x00000000, /* DENALI_PHY_814_DATA */ + 0x00000000, /* DENALI_PHY_815_DATA */ + 0x00000000, /* DENALI_PHY_816_DATA */ + 0x00000000, /* DENALI_PHY_817_DATA */ + 0x00000000, /* DENALI_PHY_818_DATA */ + 0x00000000, /* DENALI_PHY_819_DATA */ + 0x00000000, /* DENALI_PHY_820_DATA */ + 0x00000000, /* DENALI_PHY_821_DATA */ + 0x00000000, /* DENALI_PHY_822_DATA */ + 0x00000000, /* DENALI_PHY_823_DATA */ + 0x00000000, /* DENALI_PHY_824_DATA */ + 0x00000000, /* DENALI_PHY_825_DATA */ + 0x00000000, /* DENALI_PHY_826_DATA */ + 0x00000000, /* DENALI_PHY_827_DATA */ + 0x00000000, /* DENALI_PHY_828_DATA */ + 0x00000000, /* DENALI_PHY_829_DATA */ + 0x00000000, /* DENALI_PHY_830_DATA */ + 0x00000000, /* DENALI_PHY_831_DATA */ + 0x00000000, /* DENALI_PHY_832_DATA */ + 0x00000000, /* DENALI_PHY_833_DATA */ + 0x00000000, /* DENALI_PHY_834_DATA */ + 0x00000000, /* DENALI_PHY_835_DATA */ + 0x00000000, /* DENALI_PHY_836_DATA */ + 0x00000000, /* DENALI_PHY_837_DATA */ + 0x00000000, /* DENALI_PHY_838_DATA */ + 0x00000000, /* DENALI_PHY_839_DATA */ + 0x00000000, /* DENALI_PHY_840_DATA */ + 0x00000000, /* DENALI_PHY_841_DATA */ + 0x00000000, /* DENALI_PHY_842_DATA */ + 0x00000000, /* DENALI_PHY_843_DATA */ + 0x00000000, /* DENALI_PHY_844_DATA */ + 0x00000000, /* DENALI_PHY_845_DATA */ + 0x00000000, /* DENALI_PHY_846_DATA */ + 0x00000000, /* DENALI_PHY_847_DATA */ + 0x00000000, /* DENALI_PHY_848_DATA */ + 0x00000000, /* DENALI_PHY_849_DATA */ + 0x00000000, /* DENALI_PHY_850_DATA */ + 0x00000000, /* DENALI_PHY_851_DATA */ + 0x00000000, /* DENALI_PHY_852_DATA */ + 0x00000000, /* DENALI_PHY_853_DATA */ + 0x00000000, /* DENALI_PHY_854_DATA */ + 0x00000000, /* DENALI_PHY_855_DATA */ + 0x00000000, /* DENALI_PHY_856_DATA */ + 0x00000000, /* DENALI_PHY_857_DATA */ + 0x00000000, /* DENALI_PHY_858_DATA */ + 0x00000000, /* DENALI_PHY_859_DATA */ + 0x00000000, /* DENALI_PHY_860_DATA */ + 0x00000000, /* DENALI_PHY_861_DATA */ + 0x00000000, /* DENALI_PHY_862_DATA */ + 0x00000000, /* DENALI_PHY_863_DATA */ + 0x00000000, /* DENALI_PHY_864_DATA */ + 0x00000000, /* DENALI_PHY_865_DATA */ + 0x00000000, /* DENALI_PHY_866_DATA */ + 0x00000000, /* DENALI_PHY_867_DATA */ + 0x00000000, /* DENALI_PHY_868_DATA */ + 0x00000000, /* DENALI_PHY_869_DATA */ + 0x00000000, /* DENALI_PHY_870_DATA */ + 0x00000000, /* DENALI_PHY_871_DATA */ + 0x00000000, /* DENALI_PHY_872_DATA */ + 0x00000000, /* DENALI_PHY_873_DATA */ + 0x00000000, /* DENALI_PHY_874_DATA */ + 0x00000000, /* DENALI_PHY_875_DATA */ + 0x00000000, /* DENALI_PHY_876_DATA */ + 0x00000000, /* DENALI_PHY_877_DATA */ + 0x00000000, /* DENALI_PHY_878_DATA */ + 0x00000000, /* DENALI_PHY_879_DATA */ + 0x00000000, /* DENALI_PHY_880_DATA */ + 0x00000000, /* DENALI_PHY_881_DATA */ + 0x00000000, /* DENALI_PHY_882_DATA */ + 0x00000000, /* DENALI_PHY_883_DATA */ + 0x00000000, /* DENALI_PHY_884_DATA */ + 0x00000000, /* DENALI_PHY_885_DATA */ + 0x00000000, /* DENALI_PHY_886_DATA */ + 0x00000000, /* DENALI_PHY_887_DATA */ + 0x00000000, /* DENALI_PHY_888_DATA */ + 0x00000000, /* DENALI_PHY_889_DATA */ + 0x00000000, /* DENALI_PHY_890_DATA */ + 0x00000000, /* DENALI_PHY_891_DATA */ + 0x00000000, /* DENALI_PHY_892_DATA */ + 0x00000000, /* DENALI_PHY_893_DATA */ + 0x00000000, /* DENALI_PHY_894_DATA */ + 0x00000000, /* DENALI_PHY_895_DATA */ + 0x00000001, /* DENALI_PHY_896_DATA */ + 0x00000000, /* DENALI_PHY_897_DATA */ + 0x01000005, /* DENALI_PHY_898_DATA */ + 0x04000f00, /* DENALI_PHY_899_DATA */ + 0x00020040, /* DENALI_PHY_900_DATA */ + 0x00020055, /* DENALI_PHY_901_DATA */ + 0x00000000, /* DENALI_PHY_902_DATA */ + 0x00000000, /* DENALI_PHY_903_DATA */ + 0x00000000, /* DENALI_PHY_904_DATA */ + 0x00000050, /* DENALI_PHY_905_DATA */ + 0x00000000, /* DENALI_PHY_906_DATA */ + 0x00010100, /* DENALI_PHY_907_DATA */ + 0x00000601, /* DENALI_PHY_908_DATA */ + 0x00000000, /* DENALI_PHY_909_DATA */ + 0x00006400, /* DENALI_PHY_910_DATA */ + 0x01221102, /* DENALI_PHY_911_DATA */ + 0x00000000, /* DENALI_PHY_912_DATA */ + 0x00051f00, /* DENALI_PHY_913_DATA */ + 0x051f051f, /* DENALI_PHY_914_DATA */ + 0x051f051f, /* DENALI_PHY_915_DATA */ + 0x00030003, /* DENALI_PHY_916_DATA */ + 0x03000300, /* DENALI_PHY_917_DATA */ + 0x00000300, /* DENALI_PHY_918_DATA */ + 0x01221102, /* DENALI_PHY_919_DATA */ + 0x00000000, /* DENALI_PHY_920_DATA */ + 0x00000000, /* DENALI_PHY_921_DATA */ + 0x03020000, /* DENALI_PHY_922_DATA */ + 0x00000001, /* DENALI_PHY_923_DATA */ + 0x00000011, /* DENALI_PHY_924_DATA */ + 0x00000011, /* DENALI_PHY_925_DATA */ + 0x00000400, /* DENALI_PHY_926_DATA */ + 0x00000000, /* DENALI_PHY_927_DATA */ + 0x00000011, /* DENALI_PHY_928_DATA */ + 0x00000011, /* DENALI_PHY_929_DATA */ + 0x00004410, /* DENALI_PHY_930_DATA */ + 0x00004410, /* DENALI_PHY_931_DATA */ + 0x00004410, /* DENALI_PHY_932_DATA */ + 0x00004410, /* DENALI_PHY_933_DATA */ + 0x00004410, /* DENALI_PHY_934_DATA */ + 0x00000011, /* DENALI_PHY_935_DATA */ + 0x00004410, /* DENALI_PHY_936_DATA */ + 0x00000011, /* DENALI_PHY_937_DATA */ + 0x00004410, /* DENALI_PHY_938_DATA */ + 0x00000011, /* DENALI_PHY_939_DATA */ + 0x00004410, /* DENALI_PHY_940_DATA */ + 0x00000000, /* DENALI_PHY_941_DATA */ + 0x00000000, /* DENALI_PHY_942_DATA */ + 0x00000000, /* DENALI_PHY_943_DATA */ + 0x04000000, /* DENALI_PHY_944_DATA */ + 0x00000000, /* DENALI_PHY_945_DATA */ + 0x00000000, /* DENALI_PHY_946_DATA */ + 0x00000508, /* DENALI_PHY_947_DATA */ + 0x00000000, /* DENALI_PHY_948_DATA */ + 0x00000000, /* DENALI_PHY_949_DATA */ + 0x00000000, /* DENALI_PHY_950_DATA */ + 0x00000000, /* DENALI_PHY_951_DATA */ + 0x00000000, /* DENALI_PHY_952_DATA */ + 0x00000000, /* DENALI_PHY_953_DATA */ + 0xe4000000, /* DENALI_PHY_954_DATA */ + 0x00000000, /* DENALI_PHY_955_DATA */ + 0x00000000, /* DENALI_PHY_956_DATA */ + 0x01010000, /* DENALI_PHY_957_DATA */ + 0x00000000 /* DENALI_PHY_958_DATA */ + } + }, +}; diff --git a/src/mainboard/google/gru/sdram_inf/sdram-lpddr3-hynix-4GB-666.inc b/src/mainboard/google/gru/sdram_inf/sdram-lpddr3-hynix-4GB-666.inc deleted file mode 100644 index 96c1cb8..0000000 --- a/src/mainboard/google/gru/sdram_inf/sdram-lpddr3-hynix-4GB-666.inc +++ /dev/null @@ -1,1563 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -{ - { - { - .rank = 0x2, - .col = 0xA, - .bk = 0x3, - .bw = 0x2, - .dbw = 0x2, - .row_3_4 = 0x0, - .cs0_row = 0xF, - .cs1_row = 0xF, - .ddrconfig = 1, - { - {0x19151115}, - {0x10030806}, - {0x00000002}, - {0x00006206}, - {0x00000054}, - 0x00000000 - } - }, - { - .rank = 0x2, - .col = 0xA, - .bk = 0x3, - .bw = 0x2, - .dbw = 0x2, - .row_3_4 = 0x0, - .cs0_row = 0xF, - .cs1_row = 0xF, - .ddrconfig = 1, - { - {0x19151115}, - {0x10030806}, - {0x00000002}, - {0x00006206}, - {0x00000054}, - 0x00000000 - } - } - }, - .ddr_freq = 666*MHz, - .dramtype = LPDDR3, - .num_channels = 2, - .stride = 13, - .odt = 1, - { - { - 0x00000700, /* DENALI_CTL_00_DATA */ - 0x00000000, /* DENALI_CTL_01_DATA */ - 0x00000000, /* DENALI_CTL_02_DATA */ - 0x00000000, /* DENALI_CTL_03_DATA */ - 0x00000000, /* DENALI_CTL_04_DATA */ - 0x00000043, /* DENALI_CTL_05_DATA */ - 0x000208d6, /* DENALI_CTL_06_DATA */ - 0x0000029b, /* DENALI_CTL_07_DATA */ - 0x00001a0b, /* DENALI_CTL_08_DATA */ - 0x00000028, /* DENALI_CTL_09_DATA */ - 0x00013880, /* DENALI_CTL_10_DATA */ - 0x00000190, /* DENALI_CTL_11_DATA */ - 0x00000fa0, /* DENALI_CTL_12_DATA */ - 0x00000043, /* DENALI_CTL_13_DATA */ - 0x000208d6, /* DENALI_CTL_14_DATA */ - 0x0000029b, /* DENALI_CTL_15_DATA */ - 0x01001a0b, /* DENALI_CTL_16_DATA */ - 0x00000000, /* DENALI_CTL_17_DATA */ - 0x00000101, /* DENALI_CTL_18_DATA */ - 0x00020100, /* DENALI_CTL_19_DATA */ - 0x00000086, /* DENALI_CTL_20_DATA */ - 0x0000014e, /* DENALI_CTL_21_DATA */ - 0x00000000, /* DENALI_CTL_22_DATA */ - 0x06140000, /* DENALI_CTL_23_DATA */ - 0x00061400, /* DENALI_CTL_24_DATA */ - 0x04000614, /* DENALI_CTL_25_DATA */ - 0x2a070004, /* DENALI_CTL_26_DATA */ - 0x220c051c, /* DENALI_CTL_27_DATA */ - 0x111a0400, /* DENALI_CTL_28_DATA */ - 0x00140804, /* DENALI_CTL_29_DATA */ - 0x051c2a07, /* DENALI_CTL_30_DATA */ - 0x0500220c, /* DENALI_CTL_31_DATA */ - 0x00000a0a, /* DENALI_CTL_32_DATA */ - 0x0500b64a, /* DENALI_CTL_33_DATA */ - 0x0a0a040a, /* DENALI_CTL_34_DATA */ - 0x03006d60, /* DENALI_CTL_35_DATA */ - 0x0a0a0506, /* DENALI_CTL_36_DATA */ - 0x0500b64a, /* DENALI_CTL_37_DATA */ - 0x0203000a, /* DENALI_CTL_38_DATA */ - 0x080a0c00, /* DENALI_CTL_39_DATA */ - 0x040a0c06, /* DENALI_CTL_40_DATA */ - 0x14000a0a, /* DENALI_CTL_41_DATA */ - 0x02020a0a, /* DENALI_CTL_42_DATA */ - 0x00010002, /* DENALI_CTL_43_DATA */ - 0x03160e16, /* DENALI_CTL_44_DATA */ - 0x000e090e, /* DENALI_CTL_45_DATA */ - 0x00000000, /* DENALI_CTL_46_DATA */ - 0x03010000, /* DENALI_CTL_47_DATA */ - 0x0a20008c, /* DENALI_CTL_48_DATA */ - 0x06100054, /* DENALI_CTL_49_DATA */ - 0x0a20008c, /* DENALI_CTL_50_DATA */ - 0x00000000, /* DENALI_CTL_51_DATA */ - 0x00030005, /* DENALI_CTL_52_DATA */ - 0x00100005, /* DENALI_CTL_53_DATA */ - 0x0010000a, /* DENALI_CTL_54_DATA */ - 0x000c080c, /* DENALI_CTL_55_DATA */ - 0x00000000, /* DENALI_CTL_56_DATA */ - 0x00000000, /* DENALI_CTL_57_DATA */ - 0x00000000, /* DENALI_CTL_58_DATA */ - 0x00930000, /* DENALI_CTL_59_DATA */ - 0x00580093, /* DENALI_CTL_60_DATA */ - 0x00930058, /* DENALI_CTL_61_DATA */ - 0x00000093, /* DENALI_CTL_62_DATA */ - 0x00000000, /* DENALI_CTL_63_DATA */ - 0x00000000, /* DENALI_CTL_64_DATA */ - 0x00000000, /* DENALI_CTL_65_DATA */ - 0x00000000, /* DENALI_CTL_66_DATA */ - 0x00000000, /* DENALI_CTL_67_DATA */ - 0x00000000, /* DENALI_CTL_68_DATA */ - 0x00000301, /* DENALI_CTL_69_DATA */ - 0x00000001, /* DENALI_CTL_70_DATA */ - 0x00000000, /* DENALI_CTL_71_DATA */ - 0x00000000, /* DENALI_CTL_72_DATA */ - 0x01000000, /* DENALI_CTL_73_DATA */ - 0x80104002, /* DENALI_CTL_74_DATA */ - 0x00040003, /* DENALI_CTL_75_DATA */ - 0x00040005, /* DENALI_CTL_76_DATA */ - 0x00030000, /* DENALI_CTL_77_DATA */ - 0x00050004, /* DENALI_CTL_78_DATA */ - 0x00000004, /* DENALI_CTL_79_DATA */ - 0x00040003, /* DENALI_CTL_80_DATA */ - 0x00040005, /* DENALI_CTL_81_DATA */ - 0x28800000, /* DENALI_CTL_82_DATA */ - 0x00001440, /* DENALI_CTL_83_DATA */ - 0x0c201840, /* DENALI_CTL_84_DATA */ - 0x28800000, /* DENALI_CTL_85_DATA */ - 0x00001440, /* DENALI_CTL_86_DATA */ - 0x00000000, /* DENALI_CTL_87_DATA */ - 0x00000000, /* DENALI_CTL_88_DATA */ - 0x00000000, /* DENALI_CTL_89_DATA */ - 0x00000000, /* DENALI_CTL_90_DATA */ - 0x00000000, /* DENALI_CTL_91_DATA */ - 0x02020200, /* DENALI_CTL_92_DATA */ - 0x00020202, /* DENALI_CTL_93_DATA */ - 0x00030200, /* DENALI_CTL_94_DATA */ - 0x00040700, /* DENALI_CTL_95_DATA */ - 0x00000302, /* DENALI_CTL_96_DATA */ - 0x02000407, /* DENALI_CTL_97_DATA */ - 0x00000003, /* DENALI_CTL_98_DATA */ - 0x00030f04, /* DENALI_CTL_99_DATA */ - 0x00070004, /* DENALI_CTL_100_DATA */ - 0x00000000, /* DENALI_CTL_101_DATA */ - 0x00000000, /* DENALI_CTL_102_DATA */ - 0x00000000, /* DENALI_CTL_103_DATA */ - 0x00000000, /* DENALI_CTL_104_DATA */ - 0x00000000, /* DENALI_CTL_105_DATA */ - 0x00000000, /* DENALI_CTL_106_DATA */ - 0x00000000, /* DENALI_CTL_107_DATA */ - 0x00010000, /* DENALI_CTL_108_DATA */ - 0x20040020, /* DENALI_CTL_109_DATA */ - 0x00200400, /* DENALI_CTL_110_DATA */ - 0x01000400, /* DENALI_CTL_111_DATA */ - 0x00000b80, /* DENALI_CTL_112_DATA */ - 0x00000000, /* DENALI_CTL_113_DATA */ - 0x00000001, /* DENALI_CTL_114_DATA */ - 0x00000002, /* DENALI_CTL_115_DATA */ - 0x0000000e, /* DENALI_CTL_116_DATA */ - 0x00000000, /* DENALI_CTL_117_DATA */ - 0x00000000, /* DENALI_CTL_118_DATA */ - 0x00000000, /* DENALI_CTL_119_DATA */ - 0x00000000, /* DENALI_CTL_120_DATA */ - 0x00000000, /* DENALI_CTL_121_DATA */ - 0x00860000, /* DENALI_CTL_122_DATA */ - 0x00a70043, /* DENALI_CTL_123_DATA */ - 0x00a70000, /* DENALI_CTL_124_DATA */ - 0x00280050, /* DENALI_CTL_125_DATA */ - 0x00000064, /* DENALI_CTL_126_DATA */ - 0x00860064, /* DENALI_CTL_127_DATA */ - 0x00a70043, /* DENALI_CTL_128_DATA */ - 0x00a70000, /* DENALI_CTL_129_DATA */ - 0x00000000, /* DENALI_CTL_130_DATA */ - 0x00000000, /* DENALI_CTL_131_DATA */ - 0x00000000, /* DENALI_CTL_132_DATA */ - 0x00030000, /* DENALI_CTL_133_DATA */ - 0x00000018, /* DENALI_CTL_134_DATA */ - 0x00080083, /* DENALI_CTL_135_DATA */ - 0x00030000, /* DENALI_CTL_136_DATA */ - 0x00000018, /* DENALI_CTL_137_DATA */ - 0x00010001, /* DENALI_CTL_138_DATA */ - 0x06000001, /* DENALI_CTL_139_DATA */ - 0x00000707, /* DENALI_CTL_140_DATA */ - 0x00000000, /* DENALI_CTL_141_DATA */ - 0x00000000, /* DENALI_CTL_142_DATA */ - 0x00000000, /* DENALI_CTL_143_DATA */ - 0x00000000, /* DENALI_CTL_144_DATA */ - 0x00000000, /* DENALI_CTL_145_DATA */ - 0x00000000, /* DENALI_CTL_146_DATA */ - 0x00030000, /* DENALI_CTL_147_DATA */ - 0x00000018, /* DENALI_CTL_148_DATA */ - 0x00080083, /* DENALI_CTL_149_DATA */ - 0x00030000, /* DENALI_CTL_150_DATA */ - 0x00000018, /* DENALI_CTL_151_DATA */ - 0x00010001, /* DENALI_CTL_152_DATA */ - 0x06000001, /* DENALI_CTL_153_DATA */ - 0x00000707, /* DENALI_CTL_154_DATA */ - 0x00000000, /* DENALI_CTL_155_DATA */ - 0x00000000, /* DENALI_CTL_156_DATA */ - 0x00000000, /* DENALI_CTL_157_DATA */ - 0x00000000, /* DENALI_CTL_158_DATA */ - 0x00000000, /* DENALI_CTL_159_DATA */ - 0x00000000, /* DENALI_CTL_160_DATA */ - 0x01000000, /* DENALI_CTL_161_DATA */ - 0x00000000, /* DENALI_CTL_162_DATA */ - 0x00000000, /* DENALI_CTL_163_DATA */ - 0x18151100, /* DENALI_CTL_164_DATA */ - 0x0000000c, /* DENALI_CTL_165_DATA */ - 0x00000000, /* DENALI_CTL_166_DATA */ - 0x00000000, /* DENALI_CTL_167_DATA */ - 0x00000000, /* DENALI_CTL_168_DATA */ - 0x00000000, /* DENALI_CTL_169_DATA */ - 0x00000000, /* DENALI_CTL_170_DATA */ - 0x00000000, /* DENALI_CTL_171_DATA */ - 0x00000000, /* DENALI_CTL_172_DATA */ - 0x00000000, /* DENALI_CTL_173_DATA */ - 0x00000000, /* DENALI_CTL_174_DATA */ - 0x00000000, /* DENALI_CTL_175_DATA */ - 0x00000000, /* DENALI_CTL_176_DATA */ - 0x00000000, /* DENALI_CTL_177_DATA */ - 0x00000000, /* DENALI_CTL_178_DATA */ - 0x00029b03, /* DENALI_CTL_179_DATA */ - 0x003c00f0, /* DENALI_CTL_180_DATA */ - 0x00000000, /* DENALI_CTL_181_DATA */ - 0x00900190, /* DENALI_CTL_182_DATA */ - 0x00000024, /* DENALI_CTL_183_DATA */ - 0x00029b00, /* DENALI_CTL_184_DATA */ - 0x003c00f0, /* DENALI_CTL_185_DATA */ - 0x00000000, /* DENALI_CTL_186_DATA */ - 0x00220000, /* DENALI_CTL_187_DATA */ - 0x00220014, /* DENALI_CTL_188_DATA */ - 0x01010100, /* DENALI_CTL_189_DATA */ - 0x01000202, /* DENALI_CTL_190_DATA */ - 0x0a000002, /* DENALI_CTL_191_DATA */ - 0x01000f0f, /* DENALI_CTL_192_DATA */ - 0x00000000, /* DENALI_CTL_193_DATA */ - 0x00000000, /* DENALI_CTL_194_DATA */ - 0x00010003, /* DENALI_CTL_195_DATA */ - 0x00000c03, /* DENALI_CTL_196_DATA */ - 0x00000100, /* DENALI_CTL_197_DATA */ - 0x00010000, /* DENALI_CTL_198_DATA */ - 0x01000000, /* DENALI_CTL_199_DATA */ - 0x00010000, /* DENALI_CTL_200_DATA */ - 0x00000001, /* DENALI_CTL_201_DATA */ - 0x00000000, /* DENALI_CTL_202_DATA */ - 0x00000000, /* DENALI_CTL_203_DATA */ - 0x00000000, /* DENALI_CTL_204_DATA */ - 0x00000000, /* DENALI_CTL_205_DATA */ - 0x00000000, /* DENALI_CTL_206_DATA */ - 0x00000000, /* DENALI_CTL_207_DATA */ - 0x00000000, /* DENALI_CTL_208_DATA */ - 0x00000000, /* DENALI_CTL_209_DATA */ - 0x00000000, /* DENALI_CTL_210_DATA */ - 0x00010000, /* DENALI_CTL_211_DATA */ - 0x03020301, /* DENALI_CTL_212_DATA */ - 0x01010808, /* DENALI_CTL_213_DATA */ - 0x04030001, /* DENALI_CTL_214_DATA */ - 0x08080803, /* DENALI_CTL_215_DATA */ - 0x08080808, /* DENALI_CTL_216_DATA */ - 0x02050203, /* DENALI_CTL_217_DATA */ - 0x02010303, /* DENALI_CTL_218_DATA */ - 0x00010203, /* DENALI_CTL_219_DATA */ - 0x00020202, /* DENALI_CTL_220_DATA */ - 0x03020400, /* DENALI_CTL_221_DATA */ - 0x00020401, /* DENALI_CTL_222_DATA */ - 0x00000000, /* DENALI_CTL_223_DATA */ - 0x00000000, /* DENALI_CTL_224_DATA */ - 0x0d000001, /* DENALI_CTL_225_DATA */ - 0x00010028, /* DENALI_CTL_226_DATA */ - 0x00010000, /* DENALI_CTL_227_DATA */ - 0x00000003, /* DENALI_CTL_228_DATA */ - 0x00000000, /* DENALI_CTL_229_DATA */ - 0x00000000, /* DENALI_CTL_230_DATA */ - 0x00000000, /* DENALI_CTL_231_DATA */ - 0x00000000, /* DENALI_CTL_232_DATA */ - 0x00000000, /* DENALI_CTL_233_DATA */ - 0x00000000, /* DENALI_CTL_234_DATA */ - 0x00000000, /* DENALI_CTL_235_DATA */ - 0x00000000, /* DENALI_CTL_236_DATA */ - 0x00010100, /* DENALI_CTL_237_DATA */ - 0x01000000, /* DENALI_CTL_238_DATA */ - 0x00000001, /* DENALI_CTL_239_DATA */ - 0x00000303, /* DENALI_CTL_240_DATA */ - 0x00000000, /* DENALI_CTL_241_DATA */ - 0x00000000, /* DENALI_CTL_242_DATA */ - 0x00000000, /* DENALI_CTL_243_DATA */ - 0x00000000, /* DENALI_CTL_244_DATA */ - 0x00000000, /* DENALI_CTL_245_DATA */ - 0x00000000, /* DENALI_CTL_246_DATA */ - 0x00000000, /* DENALI_CTL_247_DATA */ - 0x00000000, /* DENALI_CTL_248_DATA */ - 0x00000000, /* DENALI_CTL_249_DATA */ - 0x00000000, /* DENALI_CTL_250_DATA */ - 0x00000000, /* DENALI_CTL_251_DATA */ - 0x00000000, /* DENALI_CTL_252_DATA */ - 0x00000000, /* DENALI_CTL_253_DATA */ - 0x00000000, /* DENALI_CTL_254_DATA */ - 0x00000000, /* DENALI_CTL_255_DATA */ - 0x000556aa, /* DENALI_CTL_256_DATA */ - 0x000aaaaa, /* DENALI_CTL_257_DATA */ - 0x000aa955, /* DENALI_CTL_258_DATA */ - 0x00055555, /* DENALI_CTL_259_DATA */ - 0x000b3133, /* DENALI_CTL_260_DATA */ - 0x0004cd33, /* DENALI_CTL_261_DATA */ - 0x0004cecc, /* DENALI_CTL_262_DATA */ - 0x000b32cc, /* DENALI_CTL_263_DATA */ - 0x00010300, /* DENALI_CTL_264_DATA */ - 0x03000100, /* DENALI_CTL_265_DATA */ - 0x00000000, /* DENALI_CTL_266_DATA */ - 0x00000000, /* DENALI_CTL_267_DATA */ - 0x00000000, /* DENALI_CTL_268_DATA */ - 0x00000000, /* DENALI_CTL_269_DATA */ - 0x00000000, /* DENALI_CTL_270_DATA */ - 0x00000000, /* DENALI_CTL_271_DATA */ - 0x00000000, /* DENALI_CTL_272_DATA */ - 0x00000000, /* DENALI_CTL_273_DATA */ - 0x00ffff00, /* DENALI_CTL_274_DATA */ - 0x181b0000, /* DENALI_CTL_275_DATA */ - 0x0800001b, /* DENALI_CTL_276_DATA */ - 0x00001440, /* DENALI_CTL_277_DATA */ - 0x00000200, /* DENALI_CTL_278_DATA */ - 0x00000200, /* DENALI_CTL_279_DATA */ - 0x00000200, /* DENALI_CTL_280_DATA */ - 0x00000200, /* DENALI_CTL_281_DATA */ - 0x00001440, /* DENALI_CTL_282_DATA */ - 0x0000ca80, /* DENALI_CTL_283_DATA */ - 0x0c200509, /* DENALI_CTL_284_DATA */ - 0x00000200, /* DENALI_CTL_285_DATA */ - 0x00000200, /* DENALI_CTL_286_DATA */ - 0x00000200, /* DENALI_CTL_287_DATA */ - 0x00000200, /* DENALI_CTL_288_DATA */ - 0x00000c20, /* DENALI_CTL_289_DATA */ - 0x00007940, /* DENALI_CTL_290_DATA */ - 0x14400509, /* DENALI_CTL_291_DATA */ - 0x00000200, /* DENALI_CTL_292_DATA */ - 0x00000200, /* DENALI_CTL_293_DATA */ - 0x00000200, /* DENALI_CTL_294_DATA */ - 0x00000200, /* DENALI_CTL_295_DATA */ - 0x00001440, /* DENALI_CTL_296_DATA */ - 0x0000ca80, /* DENALI_CTL_297_DATA */ - 0x02020509, /* DENALI_CTL_298_DATA */ - 0x03030202, /* DENALI_CTL_299_DATA */ - 0x00000018, /* DENALI_CTL_300_DATA */ - 0x00000000, /* DENALI_CTL_301_DATA */ - 0x00000000, /* DENALI_CTL_302_DATA */ - 0x00001403, /* DENALI_CTL_303_DATA */ - 0x00000000, /* DENALI_CTL_304_DATA */ - 0x00000000, /* DENALI_CTL_305_DATA */ - 0x00000000, /* DENALI_CTL_306_DATA */ - 0x00030000, /* DENALI_CTL_307_DATA */ - 0x000d001f, /* DENALI_CTL_308_DATA */ - 0x000a001c, /* DENALI_CTL_309_DATA */ - 0x000d001f, /* DENALI_CTL_310_DATA */ - 0x00000000, /* DENALI_CTL_311_DATA */ - 0x00000000, /* DENALI_CTL_312_DATA */ - 0x01000000, /* DENALI_CTL_313_DATA */ - 0x00050005, /* DENALI_CTL_314_DATA */ - 0x00050005, /* DENALI_CTL_315_DATA */ - 0x00000000, /* DENALI_CTL_316_DATA */ - 0x00000000, /* DENALI_CTL_317_DATA */ - 0x00000000, /* DENALI_CTL_318_DATA */ - 0x00000000, /* DENALI_CTL_319_DATA */ - 0x00000000, /* DENALI_CTL_320_DATA */ - 0x00000000, /* DENALI_CTL_321_DATA */ - 0x00000000, /* DENALI_CTL_322_DATA */ - 0x00000000, /* DENALI_CTL_323_DATA */ - 0x01000101, /* DENALI_CTL_324_DATA */ - 0x01010101, /* DENALI_CTL_325_DATA */ - 0x01000101, /* DENALI_CTL_326_DATA */ - 0x01000100, /* DENALI_CTL_327_DATA */ - 0x00010001, /* DENALI_CTL_328_DATA */ - 0x00010002, /* DENALI_CTL_329_DATA */ - 0x00020100, /* DENALI_CTL_330_DATA */ - 0x00000002 /* DENALI_CTL_331_DATA */ - } - }, - { - { - 0x00000700, /* DENALI_PI_00_DATA */ - 0x00000000, /* DENALI_PI_01_DATA */ - 0x00002880, /* DENALI_PI_02_DATA */ - 0x00001440, /* DENALI_PI_03_DATA */ - 0x00002880, /* DENALI_PI_04_DATA */ - 0x00001440, /* DENALI_PI_05_DATA */ - 0x00002880, /* DENALI_PI_06_DATA */ - 0x14401440, /* DENALI_PI_07_DATA */ - 0x00000200, /* DENALI_PI_08_DATA */ - 0x00000200, /* DENALI_PI_09_DATA */ - 0x00000200, /* DENALI_PI_10_DATA */ - 0x00000200, /* DENALI_PI_11_DATA */ - 0x00001440, /* DENALI_PI_12_DATA */ - 0x00000200, /* DENALI_PI_13_DATA */ - 0x00000200, /* DENALI_PI_14_DATA */ - 0x00000200, /* DENALI_PI_15_DATA */ - 0x00000200, /* DENALI_PI_16_DATA */ - 0x00001440, /* DENALI_PI_17_DATA */ - 0x00000200, /* DENALI_PI_18_DATA */ - 0x00000200, /* DENALI_PI_19_DATA */ - 0x00000200, /* DENALI_PI_20_DATA */ - 0x00000200, /* DENALI_PI_21_DATA */ - 0x00010000, /* DENALI_PI_22_DATA */ - 0x00000007, /* DENALI_PI_23_DATA */ - 0x81000001, /* DENALI_PI_24_DATA */ - 0x0f0003f0, /* DENALI_PI_25_DATA */ - 0x3fffffff, /* DENALI_PI_26_DATA */ - 0x0f0000a0, /* DENALI_PI_27_DATA */ - 0x377ff000, /* DENALI_PI_28_DATA */ - 0x0f000020, /* DENALI_PI_29_DATA */ - 0x377ff000, /* DENALI_PI_30_DATA */ - 0x0f000030, /* DENALI_PI_31_DATA */ - 0x377ff000, /* DENALI_PI_32_DATA */ - 0x0f0000b0, /* DENALI_PI_33_DATA */ - 0x377ff000, /* DENALI_PI_34_DATA */ - 0x0f000100, /* DENALI_PI_35_DATA */ - 0x377ff000, /* DENALI_PI_36_DATA */ - 0x0f000110, /* DENALI_PI_37_DATA */ - 0x377ff000, /* DENALI_PI_38_DATA */ - 0x0f000010, /* DENALI_PI_39_DATA */ - 0x377ff000, /* DENALI_PI_40_DATA */ - 0x03000101, /* DENALI_PI_41_DATA */ - 0x042a2a2a, /* DENALI_PI_42_DATA */ - 0x06140006, /* DENALI_PI_43_DATA */ - 0x00061400, /* DENALI_PI_44_DATA */ - 0x00000014, /* DENALI_PI_45_DATA */ - 0x0a20008c, /* DENALI_PI_46_DATA */ - 0x0a20008c, /* DENALI_PI_47_DATA */ - 0x0a20008c, /* DENALI_PI_48_DATA */ - 0x00000500, /* DENALI_PI_49_DATA */ - 0x00000000, /* DENALI_PI_50_DATA */ - 0x00000000, /* DENALI_PI_51_DATA */ - 0x00000000, /* DENALI_PI_52_DATA */ - 0x00000000, /* DENALI_PI_53_DATA */ - 0x00000000, /* DENALI_PI_54_DATA */ - 0x00000000, /* DENALI_PI_55_DATA */ - 0x00000000, /* DENALI_PI_56_DATA */ - 0x00000000, /* DENALI_PI_57_DATA */ - 0x04040000, /* DENALI_PI_58_DATA */ - 0x0d000004, /* DENALI_PI_59_DATA */ - 0x00000128, /* DENALI_PI_60_DATA */ - 0x00000000, /* DENALI_PI_61_DATA */ - 0x00030003, /* DENALI_PI_62_DATA */ - 0x00000018, /* DENALI_PI_63_DATA */ - 0x00000000, /* DENALI_PI_64_DATA */ - 0x00000000, /* DENALI_PI_65_DATA */ - 0x03060002, /* DENALI_PI_66_DATA */ - 0x03010301, /* DENALI_PI_67_DATA */ - 0x01080801, /* DENALI_PI_68_DATA */ - 0x04020201, /* DENALI_PI_69_DATA */ - 0x01080804, /* DENALI_PI_70_DATA */ - 0x00000000, /* DENALI_PI_71_DATA */ - 0x03030000, /* DENALI_PI_72_DATA */ - 0x08080803, /* DENALI_PI_73_DATA */ - 0x00000000, /* DENALI_PI_74_DATA */ - 0x00000000, /* DENALI_PI_75_DATA */ - 0x00000000, /* DENALI_PI_76_DATA */ - 0x00030300, /* DENALI_PI_77_DATA */ - 0x00000014, /* DENALI_PI_78_DATA */ - 0x00000000, /* DENALI_PI_79_DATA */ - 0x01010300, /* DENALI_PI_80_DATA */ - 0x00000000, /* DENALI_PI_81_DATA */ - 0x00000000, /* DENALI_PI_82_DATA */ - 0x01000000, /* DENALI_PI_83_DATA */ - 0x00000101, /* DENALI_PI_84_DATA */ - 0x55555a5a, /* DENALI_PI_85_DATA */ - 0x55555a5a, /* DENALI_PI_86_DATA */ - 0x55555a5a, /* DENALI_PI_87_DATA */ - 0x55555a5a, /* DENALI_PI_88_DATA */ - 0x09090001, /* DENALI_PI_89_DATA */ - 0x05050009, /* DENALI_PI_90_DATA */ - 0x00000005, /* DENALI_PI_91_DATA */ - 0x00000100, /* DENALI_PI_92_DATA */ - 0x00030000, /* DENALI_PI_93_DATA */ - 0x17030000, /* DENALI_PI_94_DATA */ - 0x000d001f, /* DENALI_PI_95_DATA */ - 0x000d001f, /* DENALI_PI_96_DATA */ - 0x000d001f, /* DENALI_PI_97_DATA */ - 0x00000000, /* DENALI_PI_98_DATA */ - 0x00000000, /* DENALI_PI_99_DATA */ - 0x00000100, /* DENALI_PI_100_DATA */ - 0x140a0000, /* DENALI_PI_101_DATA */ - 0x000a020a, /* DENALI_PI_102_DATA */ - 0x02000a02, /* DENALI_PI_103_DATA */ - 0x010a000a, /* DENALI_PI_104_DATA */ - 0x00000100, /* DENALI_PI_105_DATA */ - 0x01000000, /* DENALI_PI_106_DATA */ - 0x00000000, /* DENALI_PI_107_DATA */ - 0x00000100, /* DENALI_PI_108_DATA */ - 0x1e1a0000, /* DENALI_PI_109_DATA */ - 0x10010204, /* DENALI_PI_110_DATA */ - 0x07070705, /* DENALI_PI_111_DATA */ - 0x20000202, /* DENALI_PI_112_DATA */ - 0x00201000, /* DENALI_PI_113_DATA */ - 0x00201000, /* DENALI_PI_114_DATA */ - 0x04041000, /* DENALI_PI_115_DATA */ - 0x0f0f0100, /* DENALI_PI_116_DATA */ - 0x0001010f, /* DENALI_PI_117_DATA */ - 0x004b004a, /* DENALI_PI_118_DATA */ - 0x1a030000, /* DENALI_PI_119_DATA */ - 0x0102041e, /* DENALI_PI_120_DATA */ - 0x34000000, /* DENALI_PI_121_DATA */ - 0x00000000, /* DENALI_PI_122_DATA */ - 0x00000000, /* DENALI_PI_123_DATA */ - 0x00000000, /* DENALI_PI_124_DATA */ - 0x00000300, /* DENALI_PI_125_DATA */ - 0x00010018, /* DENALI_PI_126_DATA */ - 0x004d4d07, /* DENALI_PI_127_DATA */ - 0x00180003, /* DENALI_PI_128_DATA */ - 0x4d070001, /* DENALI_PI_129_DATA */ - 0x0000034d, /* DENALI_PI_130_DATA */ - 0x00010018, /* DENALI_PI_131_DATA */ - 0x004d4d07, /* DENALI_PI_132_DATA */ - 0x00180003, /* DENALI_PI_133_DATA */ - 0x4d070001, /* DENALI_PI_134_DATA */ - 0x0000034d, /* DENALI_PI_135_DATA */ - 0x00010018, /* DENALI_PI_136_DATA */ - 0x004d4d07, /* DENALI_PI_137_DATA */ - 0x00180003, /* DENALI_PI_138_DATA */ - 0x4d070001, /* DENALI_PI_139_DATA */ - 0x0003004d, /* DENALI_PI_140_DATA */ - 0x00010018, /* DENALI_PI_141_DATA */ - 0x004d4d07, /* DENALI_PI_142_DATA */ - 0x00180003, /* DENALI_PI_143_DATA */ - 0x4d070001, /* DENALI_PI_144_DATA */ - 0x0000034d, /* DENALI_PI_145_DATA */ - 0x00010018, /* DENALI_PI_146_DATA */ - 0x004d4d07, /* DENALI_PI_147_DATA */ - 0x00180003, /* DENALI_PI_148_DATA */ - 0x4d070001, /* DENALI_PI_149_DATA */ - 0x0000034d, /* DENALI_PI_150_DATA */ - 0x00010018, /* DENALI_PI_151_DATA */ - 0x004d4d07, /* DENALI_PI_152_DATA */ - 0x00180003, /* DENALI_PI_153_DATA */ - 0x4d070001, /* DENALI_PI_154_DATA */ - 0x0100004d, /* DENALI_PI_155_DATA */ - 0x00a700a7, /* DENALI_PI_156_DATA */ - 0x050400a7, /* DENALI_PI_157_DATA */ - 0x0a050c0e, /* DENALI_PI_158_DATA */ - 0x1c00b477, /* DENALI_PI_159_DATA */ - 0x0a0a2004, /* DENALI_PI_160_DATA */ - 0x0c0e050a, /* DENALI_PI_161_DATA */ - 0x00000a05, /* DENALI_PI_162_DATA */ - 0x1c00b477, /* DENALI_PI_163_DATA */ - 0x0a0a2004, /* DENALI_PI_164_DATA */ - 0x0c0e050a, /* DENALI_PI_165_DATA */ - 0x00000a05, /* DENALI_PI_166_DATA */ - 0x1c00b477, /* DENALI_PI_167_DATA */ - 0x0a0a2004, /* DENALI_PI_168_DATA */ - 0x0200020a, /* DENALI_PI_169_DATA */ - 0x02000200, /* DENALI_PI_170_DATA */ - 0x02000200, /* DENALI_PI_171_DATA */ - 0x02000200, /* DENALI_PI_172_DATA */ - 0x02000200, /* DENALI_PI_173_DATA */ - 0x00000000, /* DENALI_PI_174_DATA */ - 0x00000000, /* DENALI_PI_175_DATA */ - 0x00000000, /* DENALI_PI_176_DATA */ - 0x00000000, /* DENALI_PI_177_DATA */ - 0x00000000, /* DENALI_PI_178_DATA */ - 0x00000000, /* DENALI_PI_179_DATA */ - 0x00000000, /* DENALI_PI_180_DATA */ - 0x00000000, /* DENALI_PI_181_DATA */ - 0x00000000, /* DENALI_PI_182_DATA */ - 0x00000000, /* DENALI_PI_183_DATA */ - 0x00000000, /* DENALI_PI_184_DATA */ - 0x00000000, /* DENALI_PI_185_DATA */ - 0x01000300, /* DENALI_PI_186_DATA */ - 0x00144000, /* DENALI_PI_187_DATA */ - 0x0000ca80, /* DENALI_PI_188_DATA */ - 0x00001440, /* DENALI_PI_189_DATA */ - 0x0000ca80, /* DENALI_PI_190_DATA */ - 0x00001440, /* DENALI_PI_191_DATA */ - 0x0000ca80, /* DENALI_PI_192_DATA */ - 0x08000000, /* DENALI_PI_193_DATA */ - 0x00000100, /* DENALI_PI_194_DATA */ - 0x00000000, /* DENALI_PI_195_DATA */ - 0x00000000, /* DENALI_PI_196_DATA */ - 0x00000000, /* DENALI_PI_197_DATA */ - 0x00000000, /* DENALI_PI_198_DATA */ - 0x00000002 /* DENALI_PI_199_DATA */ - } - }, - { - { - 0x76543210, /* DENALI_PHY_00_DATA */ - 0x0004c008, /* DENALI_PHY_01_DATA */ - 0x000001c4, /* DENALI_PHY_02_DATA */ - 0x00000000, /* DENALI_PHY_03_DATA */ - 0x00000000, /* DENALI_PHY_04_DATA */ - 0x00010000, /* DENALI_PHY_05_DATA */ - 0x01665555, /* DENALI_PHY_06_DATA */ - 0x00665555, /* DENALI_PHY_07_DATA */ - 0x00010f00, /* DENALI_PHY_08_DATA */ - 0x05000100, /* DENALI_PHY_09_DATA */ - 0x00000002, /* DENALI_PHY_10_DATA */ - 0x001700c0, /* DENALI_PHY_11_DATA */ - 0x00cc0101, /* DENALI_PHY_12_DATA */ - 0x00030066, /* DENALI_PHY_13_DATA */ - 0x00000000, /* DENALI_PHY_14_DATA */ - 0x00000000, /* DENALI_PHY_15_DATA */ - 0x00000000, /* DENALI_PHY_16_DATA */ - 0x00000000, /* DENALI_PHY_17_DATA */ - 0x00000000, /* DENALI_PHY_18_DATA */ - 0x00000000, /* DENALI_PHY_19_DATA */ - 0x00000000, /* DENALI_PHY_20_DATA */ - 0x00000000, /* DENALI_PHY_21_DATA */ - 0x04080000, /* DENALI_PHY_22_DATA */ - 0x04080400, /* DENALI_PHY_23_DATA */ - 0x08000000, /* DENALI_PHY_24_DATA */ - 0x0c00c007, /* DENALI_PHY_25_DATA */ - 0x00000100, /* DENALI_PHY_26_DATA */ - 0x00000100, /* DENALI_PHY_27_DATA */ - 0x55555555, /* DENALI_PHY_28_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_29_DATA */ - 0x55555555, /* DENALI_PHY_30_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_31_DATA */ - 0x00005555, /* DENALI_PHY_32_DATA */ - 0x00000000, /* DENALI_PHY_33_DATA */ - 0x00000000, /* DENALI_PHY_34_DATA */ - 0x00000000, /* DENALI_PHY_35_DATA */ - 0x00000000, /* DENALI_PHY_36_DATA */ - 0x00000000, /* DENALI_PHY_37_DATA */ - 0x00000000, /* DENALI_PHY_38_DATA */ - 0x00000000, /* DENALI_PHY_39_DATA */ - 0x00000000, /* DENALI_PHY_40_DATA */ - 0x00000000, /* DENALI_PHY_41_DATA */ - 0x00000000, /* DENALI_PHY_42_DATA */ - 0x00000000, /* DENALI_PHY_43_DATA */ - 0x00000000, /* DENALI_PHY_44_DATA */ - 0x00000000, /* DENALI_PHY_45_DATA */ - 0x00000000, /* DENALI_PHY_46_DATA */ - 0x00000000, /* DENALI_PHY_47_DATA */ - 0x00000000, /* DENALI_PHY_48_DATA */ - 0x00000000, /* DENALI_PHY_49_DATA */ - 0x00000000, /* DENALI_PHY_50_DATA */ - 0x00000000, /* DENALI_PHY_51_DATA */ - 0x00200000, /* DENALI_PHY_52_DATA */ - 0x00000000, /* DENALI_PHY_53_DATA */ - 0x00000000, /* DENALI_PHY_54_DATA */ - 0x00000000, /* DENALI_PHY_55_DATA */ - 0x00000000, /* DENALI_PHY_56_DATA */ - 0x00000000, /* DENALI_PHY_57_DATA */ - 0x00000000, /* DENALI_PHY_58_DATA */ - 0x02800280, /* DENALI_PHY_59_DATA */ - 0x02800280, /* DENALI_PHY_60_DATA */ - 0x02800280, /* DENALI_PHY_61_DATA */ - 0x02800280, /* DENALI_PHY_62_DATA */ - 0x00000280, /* DENALI_PHY_63_DATA */ - 0x00000000, /* DENALI_PHY_64_DATA */ - 0x00000000, /* DENALI_PHY_65_DATA */ - 0x00000000, /* DENALI_PHY_66_DATA */ - 0x00000000, /* DENALI_PHY_67_DATA */ - 0x00800000, /* DENALI_PHY_68_DATA */ - 0x00800080, /* DENALI_PHY_69_DATA */ - 0x00800080, /* DENALI_PHY_70_DATA */ - 0x00800080, /* DENALI_PHY_71_DATA */ - 0x00800080, /* DENALI_PHY_72_DATA */ - 0x00800080, /* DENALI_PHY_73_DATA */ - 0x00800080, /* DENALI_PHY_74_DATA */ - 0x00800080, /* DENALI_PHY_75_DATA */ - 0x00800080, /* DENALI_PHY_76_DATA */ - 0x01c40080, /* DENALI_PHY_77_DATA */ - 0x01900002, /* DENALI_PHY_78_DATA */ - 0x00000000, /* DENALI_PHY_79_DATA */ - 0x00020000, /* DENALI_PHY_80_DATA */ - 0x00000200, /* DENALI_PHY_81_DATA */ - 0x00000000, /* DENALI_PHY_82_DATA */ - 0x51315152, /* DENALI_PHY_83_DATA */ - 0xc0013150, /* DENALI_PHY_84_DATA */ - 0x010000c0, /* DENALI_PHY_85_DATA */ - 0x00100000, /* DENALI_PHY_86_DATA */ - 0x0c054208, /* DENALI_PHY_87_DATA */ - 0x000f0c18, /* DENALI_PHY_88_DATA */ - 0x01000140, /* DENALI_PHY_89_DATA */ - 0x00000c20, /* DENALI_PHY_90_DATA */ - 0x00000000, /* DENALI_PHY_91_DATA */ - 0x00000000, /* DENALI_PHY_92_DATA */ - 0x00000000, /* DENALI_PHY_93_DATA */ - 0x00000000, /* DENALI_PHY_94_DATA */ - 0x00000000, /* DENALI_PHY_95_DATA */ - 0x00000000, /* DENALI_PHY_96_DATA */ - 0x00000000, /* DENALI_PHY_97_DATA */ - 0x00000000, /* DENALI_PHY_98_DATA */ - 0x00000000, /* DENALI_PHY_99_DATA */ - 0x00000000, /* DENALI_PHY_100_DATA */ - 0x00000000, /* DENALI_PHY_101_DATA */ - 0x00000000, /* DENALI_PHY_102_DATA */ - 0x00000000, /* DENALI_PHY_103_DATA */ - 0x00000000, /* DENALI_PHY_104_DATA */ - 0x00000000, /* DENALI_PHY_105_DATA */ - 0x00000000, /* DENALI_PHY_106_DATA */ - 0x00000000, /* DENALI_PHY_107_DATA */ - 0x00000000, /* DENALI_PHY_108_DATA */ - 0x00000000, /* DENALI_PHY_109_DATA */ - 0x00000000, /* DENALI_PHY_110_DATA */ - 0x00000000, /* DENALI_PHY_111_DATA */ - 0x00000000, /* DENALI_PHY_112_DATA */ - 0x00000000, /* DENALI_PHY_113_DATA */ - 0x00000000, /* DENALI_PHY_114_DATA */ - 0x00000000, /* DENALI_PHY_115_DATA */ - 0x00000000, /* DENALI_PHY_116_DATA */ - 0x00000000, /* DENALI_PHY_117_DATA */ - 0x00000000, /* DENALI_PHY_118_DATA */ - 0x00000000, /* DENALI_PHY_119_DATA */ - 0x00000000, /* DENALI_PHY_120_DATA */ - 0x00000000, /* DENALI_PHY_121_DATA */ - 0x00000000, /* DENALI_PHY_122_DATA */ - 0x00000000, /* DENALI_PHY_123_DATA */ - 0x00000000, /* DENALI_PHY_124_DATA */ - 0x00000000, /* DENALI_PHY_125_DATA */ - 0x00000000, /* DENALI_PHY_126_DATA */ - 0x00000000, /* DENALI_PHY_127_DATA */ - 0x76543210, /* DENALI_PHY_128_DATA */ - 0x0004c008, /* DENALI_PHY_129_DATA */ - 0x000001c4, /* DENALI_PHY_130_DATA */ - 0x00000000, /* DENALI_PHY_131_DATA */ - 0x00000000, /* DENALI_PHY_132_DATA */ - 0x00010000, /* DENALI_PHY_133_DATA */ - 0x01665555, /* DENALI_PHY_134_DATA */ - 0x00665555, /* DENALI_PHY_135_DATA */ - 0x00010f00, /* DENALI_PHY_136_DATA */ - 0x05000100, /* DENALI_PHY_137_DATA */ - 0x00000002, /* DENALI_PHY_138_DATA */ - 0x001700c0, /* DENALI_PHY_139_DATA */ - 0x00cc0101, /* DENALI_PHY_140_DATA */ - 0x00030066, /* DENALI_PHY_141_DATA */ - 0x00000000, /* DENALI_PHY_142_DATA */ - 0x00000000, /* DENALI_PHY_143_DATA */ - 0x00000000, /* DENALI_PHY_144_DATA */ - 0x00000000, /* DENALI_PHY_145_DATA */ - 0x00000000, /* DENALI_PHY_146_DATA */ - 0x00000000, /* DENALI_PHY_147_DATA */ - 0x00000000, /* DENALI_PHY_148_DATA */ - 0x00000000, /* DENALI_PHY_149_DATA */ - 0x04080000, /* DENALI_PHY_150_DATA */ - 0x04080400, /* DENALI_PHY_151_DATA */ - 0x08000000, /* DENALI_PHY_152_DATA */ - 0x0c00c007, /* DENALI_PHY_153_DATA */ - 0x00000100, /* DENALI_PHY_154_DATA */ - 0x00000100, /* DENALI_PHY_155_DATA */ - 0x55555555, /* DENALI_PHY_156_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_157_DATA */ - 0x55555555, /* DENALI_PHY_158_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_159_DATA */ - 0x00005555, /* DENALI_PHY_160_DATA */ - 0x00000000, /* DENALI_PHY_161_DATA */ - 0x00000000, /* DENALI_PHY_162_DATA */ - 0x00000000, /* DENALI_PHY_163_DATA */ - 0x00000000, /* DENALI_PHY_164_DATA */ - 0x00000000, /* DENALI_PHY_165_DATA */ - 0x00000000, /* DENALI_PHY_166_DATA */ - 0x00000000, /* DENALI_PHY_167_DATA */ - 0x00000000, /* DENALI_PHY_168_DATA */ - 0x00000000, /* DENALI_PHY_169_DATA */ - 0x00000000, /* DENALI_PHY_170_DATA */ - 0x00000000, /* DENALI_PHY_171_DATA */ - 0x00000000, /* DENALI_PHY_172_DATA */ - 0x00000000, /* DENALI_PHY_173_DATA */ - 0x00000000, /* DENALI_PHY_174_DATA */ - 0x00000000, /* DENALI_PHY_175_DATA */ - 0x00000000, /* DENALI_PHY_176_DATA */ - 0x00000000, /* DENALI_PHY_177_DATA */ - 0x00000000, /* DENALI_PHY_178_DATA */ - 0x00000000, /* DENALI_PHY_179_DATA */ - 0x00200000, /* DENALI_PHY_180_DATA */ - 0x00000000, /* DENALI_PHY_181_DATA */ - 0x00000000, /* DENALI_PHY_182_DATA */ - 0x00000000, /* DENALI_PHY_183_DATA */ - 0x00000000, /* DENALI_PHY_184_DATA */ - 0x00000000, /* DENALI_PHY_185_DATA */ - 0x00000000, /* DENALI_PHY_186_DATA */ - 0x02800280, /* DENALI_PHY_187_DATA */ - 0x02800280, /* DENALI_PHY_188_DATA */ - 0x02800280, /* DENALI_PHY_189_DATA */ - 0x02800280, /* DENALI_PHY_190_DATA */ - 0x00000280, /* DENALI_PHY_191_DATA */ - 0x00000000, /* DENALI_PHY_192_DATA */ - 0x00000000, /* DENALI_PHY_193_DATA */ - 0x00000000, /* DENALI_PHY_194_DATA */ - 0x00000000, /* DENALI_PHY_195_DATA */ - 0x00800000, /* DENALI_PHY_196_DATA */ - 0x00800080, /* DENALI_PHY_197_DATA */ - 0x00800080, /* DENALI_PHY_198_DATA */ - 0x00800080, /* DENALI_PHY_199_DATA */ - 0x00800080, /* DENALI_PHY_200_DATA */ - 0x00800080, /* DENALI_PHY_201_DATA */ - 0x00800080, /* DENALI_PHY_202_DATA */ - 0x00800080, /* DENALI_PHY_203_DATA */ - 0x00800080, /* DENALI_PHY_204_DATA */ - 0x01c40080, /* DENALI_PHY_205_DATA */ - 0x01900002, /* DENALI_PHY_206_DATA */ - 0x00000000, /* DENALI_PHY_207_DATA */ - 0x00020000, /* DENALI_PHY_208_DATA */ - 0x00000200, /* DENALI_PHY_209_DATA */ - 0x00000000, /* DENALI_PHY_210_DATA */ - 0x51315152, /* DENALI_PHY_211_DATA */ - 0xc0013150, /* DENALI_PHY_212_DATA */ - 0x010000c0, /* DENALI_PHY_213_DATA */ - 0x00100000, /* DENALI_PHY_214_DATA */ - 0x0c054208, /* DENALI_PHY_215_DATA */ - 0x000f0c18, /* DENALI_PHY_216_DATA */ - 0x01000140, /* DENALI_PHY_217_DATA */ - 0x00000c20, /* DENALI_PHY_218_DATA */ - 0x00000000, /* DENALI_PHY_219_DATA */ - 0x00000000, /* DENALI_PHY_220_DATA */ - 0x00000000, /* DENALI_PHY_221_DATA */ - 0x00000000, /* DENALI_PHY_222_DATA */ - 0x00000000, /* DENALI_PHY_223_DATA */ - 0x00000000, /* DENALI_PHY_224_DATA */ - 0x00000000, /* DENALI_PHY_225_DATA */ - 0x00000000, /* DENALI_PHY_226_DATA */ - 0x00000000, /* DENALI_PHY_227_DATA */ - 0x00000000, /* DENALI_PHY_228_DATA */ - 0x00000000, /* DENALI_PHY_229_DATA */ - 0x00000000, /* DENALI_PHY_230_DATA */ - 0x00000000, /* DENALI_PHY_231_DATA */ - 0x00000000, /* DENALI_PHY_232_DATA */ - 0x00000000, /* DENALI_PHY_233_DATA */ - 0x00000000, /* DENALI_PHY_234_DATA */ - 0x00000000, /* DENALI_PHY_235_DATA */ - 0x00000000, /* DENALI_PHY_236_DATA */ - 0x00000000, /* DENALI_PHY_237_DATA */ - 0x00000000, /* DENALI_PHY_238_DATA */ - 0x00000000, /* DENALI_PHY_239_DATA */ - 0x00000000, /* DENALI_PHY_240_DATA */ - 0x00000000, /* DENALI_PHY_241_DATA */ - 0x00000000, /* DENALI_PHY_242_DATA */ - 0x00000000, /* DENALI_PHY_243_DATA */ - 0x00000000, /* DENALI_PHY_244_DATA */ - 0x00000000, /* DENALI_PHY_245_DATA */ - 0x00000000, /* DENALI_PHY_246_DATA */ - 0x00000000, /* DENALI_PHY_247_DATA */ - 0x00000000, /* DENALI_PHY_248_DATA */ - 0x00000000, /* DENALI_PHY_249_DATA */ - 0x00000000, /* DENALI_PHY_250_DATA */ - 0x00000000, /* DENALI_PHY_251_DATA */ - 0x00000000, /* DENALI_PHY_252_DATA */ - 0x00000000, /* DENALI_PHY_253_DATA */ - 0x00000000, /* DENALI_PHY_254_DATA */ - 0x00000000, /* DENALI_PHY_255_DATA */ - 0x76543210, /* DENALI_PHY_256_DATA */ - 0x0004c008, /* DENALI_PHY_257_DATA */ - 0x000001c4, /* DENALI_PHY_258_DATA */ - 0x00000000, /* DENALI_PHY_259_DATA */ - 0x00000000, /* DENALI_PHY_260_DATA */ - 0x00010000, /* DENALI_PHY_261_DATA */ - 0x01665555, /* DENALI_PHY_262_DATA */ - 0x00665555, /* DENALI_PHY_263_DATA */ - 0x00010f00, /* DENALI_PHY_264_DATA */ - 0x05000100, /* DENALI_PHY_265_DATA */ - 0x00000002, /* DENALI_PHY_266_DATA */ - 0x001700c0, /* DENALI_PHY_267_DATA */ - 0x00cc0101, /* DENALI_PHY_268_DATA */ - 0x00030066, /* DENALI_PHY_269_DATA */ - 0x00000000, /* DENALI_PHY_270_DATA */ - 0x00000000, /* DENALI_PHY_271_DATA */ - 0x00000000, /* DENALI_PHY_272_DATA */ - 0x00000000, /* DENALI_PHY_273_DATA */ - 0x00000000, /* DENALI_PHY_274_DATA */ - 0x00000000, /* DENALI_PHY_275_DATA */ - 0x00000000, /* DENALI_PHY_276_DATA */ - 0x00000000, /* DENALI_PHY_277_DATA */ - 0x04080000, /* DENALI_PHY_278_DATA */ - 0x04080400, /* DENALI_PHY_279_DATA */ - 0x08000000, /* DENALI_PHY_280_DATA */ - 0x0c00c007, /* DENALI_PHY_281_DATA */ - 0x00000100, /* DENALI_PHY_282_DATA */ - 0x00000100, /* DENALI_PHY_283_DATA */ - 0x55555555, /* DENALI_PHY_284_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_285_DATA */ - 0x55555555, /* DENALI_PHY_286_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_287_DATA */ - 0x00005555, /* DENALI_PHY_288_DATA */ - 0x00000000, /* DENALI_PHY_289_DATA */ - 0x00000000, /* DENALI_PHY_290_DATA */ - 0x00000000, /* DENALI_PHY_291_DATA */ - 0x00000000, /* DENALI_PHY_292_DATA */ - 0x00000000, /* DENALI_PHY_293_DATA */ - 0x00000000, /* DENALI_PHY_294_DATA */ - 0x00000000, /* DENALI_PHY_295_DATA */ - 0x00000000, /* DENALI_PHY_296_DATA */ - 0x00000000, /* DENALI_PHY_297_DATA */ - 0x00000000, /* DENALI_PHY_298_DATA */ - 0x00000000, /* DENALI_PHY_299_DATA */ - 0x00000000, /* DENALI_PHY_300_DATA */ - 0x00000000, /* DENALI_PHY_301_DATA */ - 0x00000000, /* DENALI_PHY_302_DATA */ - 0x00000000, /* DENALI_PHY_303_DATA */ - 0x00000000, /* DENALI_PHY_304_DATA */ - 0x00000000, /* DENALI_PHY_305_DATA */ - 0x00000000, /* DENALI_PHY_306_DATA */ - 0x00000000, /* DENALI_PHY_307_DATA */ - 0x00200000, /* DENALI_PHY_308_DATA */ - 0x00000000, /* DENALI_PHY_309_DATA */ - 0x00000000, /* DENALI_PHY_310_DATA */ - 0x00000000, /* DENALI_PHY_311_DATA */ - 0x00000000, /* DENALI_PHY_312_DATA */ - 0x00000000, /* DENALI_PHY_313_DATA */ - 0x00000000, /* DENALI_PHY_314_DATA */ - 0x02800280, /* DENALI_PHY_315_DATA */ - 0x02800280, /* DENALI_PHY_316_DATA */ - 0x02800280, /* DENALI_PHY_317_DATA */ - 0x02800280, /* DENALI_PHY_318_DATA */ - 0x00000280, /* DENALI_PHY_319_DATA */ - 0x00000000, /* DENALI_PHY_320_DATA */ - 0x00000000, /* DENALI_PHY_321_DATA */ - 0x00000000, /* DENALI_PHY_322_DATA */ - 0x00000000, /* DENALI_PHY_323_DATA */ - 0x00800000, /* DENALI_PHY_324_DATA */ - 0x00800080, /* DENALI_PHY_325_DATA */ - 0x00800080, /* DENALI_PHY_326_DATA */ - 0x00800080, /* DENALI_PHY_327_DATA */ - 0x00800080, /* DENALI_PHY_328_DATA */ - 0x00800080, /* DENALI_PHY_329_DATA */ - 0x00800080, /* DENALI_PHY_330_DATA */ - 0x00800080, /* DENALI_PHY_331_DATA */ - 0x00800080, /* DENALI_PHY_332_DATA */ - 0x01c40080, /* DENALI_PHY_333_DATA */ - 0x01900002, /* DENALI_PHY_334_DATA */ - 0x00000000, /* DENALI_PHY_335_DATA */ - 0x00020000, /* DENALI_PHY_336_DATA */ - 0x00000200, /* DENALI_PHY_337_DATA */ - 0x00000000, /* DENALI_PHY_338_DATA */ - 0x51315152, /* DENALI_PHY_339_DATA */ - 0xc0013150, /* DENALI_PHY_340_DATA */ - 0x010000c0, /* DENALI_PHY_341_DATA */ - 0x00100000, /* DENALI_PHY_342_DATA */ - 0x0c054208, /* DENALI_PHY_343_DATA */ - 0x000f0c18, /* DENALI_PHY_344_DATA */ - 0x01000140, /* DENALI_PHY_345_DATA */ - 0x00000c20, /* DENALI_PHY_346_DATA */ - 0x00000000, /* DENALI_PHY_347_DATA */ - 0x00000000, /* DENALI_PHY_348_DATA */ - 0x00000000, /* DENALI_PHY_349_DATA */ - 0x00000000, /* DENALI_PHY_350_DATA */ - 0x00000000, /* DENALI_PHY_351_DATA */ - 0x00000000, /* DENALI_PHY_352_DATA */ - 0x00000000, /* DENALI_PHY_353_DATA */ - 0x00000000, /* DENALI_PHY_354_DATA */ - 0x00000000, /* DENALI_PHY_355_DATA */ - 0x00000000, /* DENALI_PHY_356_DATA */ - 0x00000000, /* DENALI_PHY_357_DATA */ - 0x00000000, /* DENALI_PHY_358_DATA */ - 0x00000000, /* DENALI_PHY_359_DATA */ - 0x00000000, /* DENALI_PHY_360_DATA */ - 0x00000000, /* DENALI_PHY_361_DATA */ - 0x00000000, /* DENALI_PHY_362_DATA */ - 0x00000000, /* DENALI_PHY_363_DATA */ - 0x00000000, /* DENALI_PHY_364_DATA */ - 0x00000000, /* DENALI_PHY_365_DATA */ - 0x00000000, /* DENALI_PHY_366_DATA */ - 0x00000000, /* DENALI_PHY_367_DATA */ - 0x00000000, /* DENALI_PHY_368_DATA */ - 0x00000000, /* DENALI_PHY_369_DATA */ - 0x00000000, /* DENALI_PHY_370_DATA */ - 0x00000000, /* DENALI_PHY_371_DATA */ - 0x00000000, /* DENALI_PHY_372_DATA */ - 0x00000000, /* DENALI_PHY_373_DATA */ - 0x00000000, /* DENALI_PHY_374_DATA */ - 0x00000000, /* DENALI_PHY_375_DATA */ - 0x00000000, /* DENALI_PHY_376_DATA */ - 0x00000000, /* DENALI_PHY_377_DATA */ - 0x00000000, /* DENALI_PHY_378_DATA */ - 0x00000000, /* DENALI_PHY_379_DATA */ - 0x00000000, /* DENALI_PHY_380_DATA */ - 0x00000000, /* DENALI_PHY_381_DATA */ - 0x00000000, /* DENALI_PHY_382_DATA */ - 0x00000000, /* DENALI_PHY_383_DATA */ - 0x76543210, /* DENALI_PHY_384_DATA */ - 0x0004c008, /* DENALI_PHY_385_DATA */ - 0x000001c4, /* DENALI_PHY_386_DATA */ - 0x00000000, /* DENALI_PHY_387_DATA */ - 0x00000000, /* DENALI_PHY_388_DATA */ - 0x00010000, /* DENALI_PHY_389_DATA */ - 0x01665555, /* DENALI_PHY_390_DATA */ - 0x00665555, /* DENALI_PHY_391_DATA */ - 0x00010f00, /* DENALI_PHY_392_DATA */ - 0x05000100, /* DENALI_PHY_393_DATA */ - 0x00000002, /* DENALI_PHY_394_DATA */ - 0x001700c0, /* DENALI_PHY_395_DATA */ - 0x00cc0101, /* DENALI_PHY_396_DATA */ - 0x00030066, /* DENALI_PHY_397_DATA */ - 0x00000000, /* DENALI_PHY_398_DATA */ - 0x00000000, /* DENALI_PHY_399_DATA */ - 0x00000000, /* DENALI_PHY_400_DATA */ - 0x00000000, /* DENALI_PHY_401_DATA */ - 0x00000000, /* DENALI_PHY_402_DATA */ - 0x00000000, /* DENALI_PHY_403_DATA */ - 0x00000000, /* DENALI_PHY_404_DATA */ - 0x00000000, /* DENALI_PHY_405_DATA */ - 0x04080000, /* DENALI_PHY_406_DATA */ - 0x04080400, /* DENALI_PHY_407_DATA */ - 0x08000000, /* DENALI_PHY_408_DATA */ - 0x0c00c007, /* DENALI_PHY_409_DATA */ - 0x00000100, /* DENALI_PHY_410_DATA */ - 0x00000100, /* DENALI_PHY_411_DATA */ - 0x55555555, /* DENALI_PHY_412_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_413_DATA */ - 0x55555555, /* DENALI_PHY_414_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_415_DATA */ - 0x00005555, /* DENALI_PHY_416_DATA */ - 0x00000000, /* DENALI_PHY_417_DATA */ - 0x00000000, /* DENALI_PHY_418_DATA */ - 0x00000000, /* DENALI_PHY_419_DATA */ - 0x00000000, /* DENALI_PHY_420_DATA */ - 0x00000000, /* DENALI_PHY_421_DATA */ - 0x00000000, /* DENALI_PHY_422_DATA */ - 0x00000000, /* DENALI_PHY_423_DATA */ - 0x00000000, /* DENALI_PHY_424_DATA */ - 0x00000000, /* DENALI_PHY_425_DATA */ - 0x00000000, /* DENALI_PHY_426_DATA */ - 0x00000000, /* DENALI_PHY_427_DATA */ - 0x00000000, /* DENALI_PHY_428_DATA */ - 0x00000000, /* DENALI_PHY_429_DATA */ - 0x00000000, /* DENALI_PHY_430_DATA */ - 0x00000000, /* DENALI_PHY_431_DATA */ - 0x00000000, /* DENALI_PHY_432_DATA */ - 0x00000000, /* DENALI_PHY_433_DATA */ - 0x00000000, /* DENALI_PHY_434_DATA */ - 0x00000000, /* DENALI_PHY_435_DATA */ - 0x00200000, /* DENALI_PHY_436_DATA */ - 0x00000000, /* DENALI_PHY_437_DATA */ - 0x00000000, /* DENALI_PHY_438_DATA */ - 0x00000000, /* DENALI_PHY_439_DATA */ - 0x00000000, /* DENALI_PHY_440_DATA */ - 0x00000000, /* DENALI_PHY_441_DATA */ - 0x00000000, /* DENALI_PHY_442_DATA */ - 0x02800280, /* DENALI_PHY_443_DATA */ - 0x02800280, /* DENALI_PHY_444_DATA */ - 0x02800280, /* DENALI_PHY_445_DATA */ - 0x02800280, /* DENALI_PHY_446_DATA */ - 0x00000280, /* DENALI_PHY_447_DATA */ - 0x00000000, /* DENALI_PHY_448_DATA */ - 0x00000000, /* DENALI_PHY_449_DATA */ - 0x00000000, /* DENALI_PHY_450_DATA */ - 0x00000000, /* DENALI_PHY_451_DATA */ - 0x00800000, /* DENALI_PHY_452_DATA */ - 0x00800080, /* DENALI_PHY_453_DATA */ - 0x00800080, /* DENALI_PHY_454_DATA */ - 0x00800080, /* DENALI_PHY_455_DATA */ - 0x00800080, /* DENALI_PHY_456_DATA */ - 0x00800080, /* DENALI_PHY_457_DATA */ - 0x00800080, /* DENALI_PHY_458_DATA */ - 0x00800080, /* DENALI_PHY_459_DATA */ - 0x00800080, /* DENALI_PHY_460_DATA */ - 0x01c40080, /* DENALI_PHY_461_DATA */ - 0x01900002, /* DENALI_PHY_462_DATA */ - 0x00000000, /* DENALI_PHY_463_DATA */ - 0x00020000, /* DENALI_PHY_464_DATA */ - 0x00000200, /* DENALI_PHY_465_DATA */ - 0x00000000, /* DENALI_PHY_466_DATA */ - 0x51315152, /* DENALI_PHY_467_DATA */ - 0xc0013150, /* DENALI_PHY_468_DATA */ - 0x010000c0, /* DENALI_PHY_469_DATA */ - 0x00100000, /* DENALI_PHY_470_DATA */ - 0x0c054208, /* DENALI_PHY_471_DATA */ - 0x000f0c18, /* DENALI_PHY_472_DATA */ - 0x01000140, /* DENALI_PHY_473_DATA */ - 0x00000c20, /* DENALI_PHY_474_DATA */ - 0x00000000, /* DENALI_PHY_475_DATA */ - 0x00000000, /* DENALI_PHY_476_DATA */ - 0x00000000, /* DENALI_PHY_477_DATA */ - 0x00000000, /* DENALI_PHY_478_DATA */ - 0x00000000, /* DENALI_PHY_479_DATA */ - 0x00000000, /* DENALI_PHY_480_DATA */ - 0x00000000, /* DENALI_PHY_481_DATA */ - 0x00000000, /* DENALI_PHY_482_DATA */ - 0x00000000, /* DENALI_PHY_483_DATA */ - 0x00000000, /* DENALI_PHY_484_DATA */ - 0x00000000, /* DENALI_PHY_485_DATA */ - 0x00000000, /* DENALI_PHY_486_DATA */ - 0x00000000, /* DENALI_PHY_487_DATA */ - 0x00000000, /* DENALI_PHY_488_DATA */ - 0x00000000, /* DENALI_PHY_489_DATA */ - 0x00000000, /* DENALI_PHY_490_DATA */ - 0x00000000, /* DENALI_PHY_491_DATA */ - 0x00000000, /* DENALI_PHY_492_DATA */ - 0x00000000, /* DENALI_PHY_493_DATA */ - 0x00000000, /* DENALI_PHY_494_DATA */ - 0x00000000, /* DENALI_PHY_495_DATA */ - 0x00000000, /* DENALI_PHY_496_DATA */ - 0x00000000, /* DENALI_PHY_497_DATA */ - 0x00000000, /* DENALI_PHY_498_DATA */ - 0x00000000, /* DENALI_PHY_499_DATA */ - 0x00000000, /* DENALI_PHY_500_DATA */ - 0x00000000, /* DENALI_PHY_501_DATA */ - 0x00000000, /* DENALI_PHY_502_DATA */ - 0x00000000, /* DENALI_PHY_503_DATA */ - 0x00000000, /* DENALI_PHY_504_DATA */ - 0x00000000, /* DENALI_PHY_505_DATA */ - 0x00000000, /* DENALI_PHY_506_DATA */ - 0x00000000, /* DENALI_PHY_507_DATA */ - 0x00000000, /* DENALI_PHY_508_DATA */ - 0x00000000, /* DENALI_PHY_509_DATA */ - 0x00000000, /* DENALI_PHY_510_DATA */ - 0x00000000, /* DENALI_PHY_511_DATA */ - 0x00000000, /* DENALI_PHY_512_DATA */ - 0x00800000, /* DENALI_PHY_513_DATA */ - 0x00000000, /* DENALI_PHY_514_DATA */ - 0x00000000, /* DENALI_PHY_515_DATA */ - 0x00000000, /* DENALI_PHY_516_DATA */ - 0x00000000, /* DENALI_PHY_517_DATA */ - 0x00000000, /* DENALI_PHY_518_DATA */ - 0x00000001, /* DENALI_PHY_519_DATA */ - 0x00000000, /* DENALI_PHY_520_DATA */ - 0x00000000, /* DENALI_PHY_521_DATA */ - 0x00000000, /* DENALI_PHY_522_DATA */ - 0x00400320, /* DENALI_PHY_523_DATA */ - 0x00000040, /* DENALI_PHY_524_DATA */ - 0x00806420, /* DENALI_PHY_525_DATA */ - 0x00917531, /* DENALI_PHY_526_DATA */ - 0x00806420, /* DENALI_PHY_527_DATA */ - 0x01917531, /* DENALI_PHY_528_DATA */ - 0x00020003, /* DENALI_PHY_529_DATA */ - 0x00000000, /* DENALI_PHY_530_DATA */ - 0x00000000, /* DENALI_PHY_531_DATA */ - 0x00000000, /* DENALI_PHY_532_DATA */ - 0x000556aa, /* DENALI_PHY_533_DATA */ - 0x000aaaaa, /* DENALI_PHY_534_DATA */ - 0x000aa955, /* DENALI_PHY_535_DATA */ - 0x00055555, /* DENALI_PHY_536_DATA */ - 0x000b3133, /* DENALI_PHY_537_DATA */ - 0x0004cd33, /* DENALI_PHY_538_DATA */ - 0x0004cecc, /* DENALI_PHY_539_DATA */ - 0x000b32cc, /* DENALI_PHY_540_DATA */ - 0x0a418820, /* DENALI_PHY_541_DATA */ - 0x103f0000, /* DENALI_PHY_542_DATA */ - 0x0000003f, /* DENALI_PHY_543_DATA */ - 0x00038055, /* DENALI_PHY_544_DATA */ - 0x03800380, /* DENALI_PHY_545_DATA */ - 0x03800380, /* DENALI_PHY_546_DATA */ - 0x00000380, /* DENALI_PHY_547_DATA */ - 0x42080010, /* DENALI_PHY_548_DATA */ - 0x00000003, /* DENALI_PHY_549_DATA */ - 0x00000000, /* DENALI_PHY_550_DATA */ - 0x00000000, /* DENALI_PHY_551_DATA */ - 0x00000000, /* DENALI_PHY_552_DATA */ - 0x00000000, /* DENALI_PHY_553_DATA */ - 0x00000000, /* DENALI_PHY_554_DATA */ - 0x00000000, /* DENALI_PHY_555_DATA */ - 0x00000000, /* DENALI_PHY_556_DATA */ - 0x00000000, /* DENALI_PHY_557_DATA */ - 0x00000000, /* DENALI_PHY_558_DATA */ - 0x00000000, /* DENALI_PHY_559_DATA */ - 0x00000000, /* DENALI_PHY_560_DATA */ - 0x00000000, /* DENALI_PHY_561_DATA */ - 0x00000000, /* DENALI_PHY_562_DATA */ - 0x00000000, /* DENALI_PHY_563_DATA */ - 0x00000000, /* DENALI_PHY_564_DATA */ - 0x00000000, /* DENALI_PHY_565_DATA */ - 0x00000000, /* DENALI_PHY_566_DATA */ - 0x00000000, /* DENALI_PHY_567_DATA */ - 0x00000000, /* DENALI_PHY_568_DATA */ - 0x00000000, /* DENALI_PHY_569_DATA */ - 0x00000000, /* DENALI_PHY_570_DATA */ - 0x00000000, /* DENALI_PHY_571_DATA */ - 0x00000000, /* DENALI_PHY_572_DATA */ - 0x00000000, /* DENALI_PHY_573_DATA */ - 0x00000000, /* DENALI_PHY_574_DATA */ - 0x00000000, /* DENALI_PHY_575_DATA */ - 0x00000000, /* DENALI_PHY_576_DATA */ - 0x00000000, /* DENALI_PHY_577_DATA */ - 0x00000000, /* DENALI_PHY_578_DATA */ - 0x00000000, /* DENALI_PHY_579_DATA */ - 0x00000000, /* DENALI_PHY_580_DATA */ - 0x00000000, /* DENALI_PHY_581_DATA */ - 0x00000000, /* DENALI_PHY_582_DATA */ - 0x00000000, /* DENALI_PHY_583_DATA */ - 0x00000000, /* DENALI_PHY_584_DATA */ - 0x00000000, /* DENALI_PHY_585_DATA */ - 0x00000000, /* DENALI_PHY_586_DATA */ - 0x00000000, /* DENALI_PHY_587_DATA */ - 0x00000000, /* DENALI_PHY_588_DATA */ - 0x00000000, /* DENALI_PHY_589_DATA */ - 0x00000000, /* DENALI_PHY_590_DATA */ - 0x00000000, /* DENALI_PHY_591_DATA */ - 0x00000000, /* DENALI_PHY_592_DATA */ - 0x00000000, /* DENALI_PHY_593_DATA */ - 0x00000000, /* DENALI_PHY_594_DATA */ - 0x00000000, /* DENALI_PHY_595_DATA */ - 0x00000000, /* DENALI_PHY_596_DATA */ - 0x00000000, /* DENALI_PHY_597_DATA */ - 0x00000000, /* DENALI_PHY_598_DATA */ - 0x00000000, /* DENALI_PHY_599_DATA */ - 0x00000000, /* DENALI_PHY_600_DATA */ - 0x00000000, /* DENALI_PHY_601_DATA */ - 0x00000000, /* DENALI_PHY_602_DATA */ - 0x00000000, /* DENALI_PHY_603_DATA */ - 0x00000000, /* DENALI_PHY_604_DATA */ - 0x00000000, /* DENALI_PHY_605_DATA */ - 0x00000000, /* DENALI_PHY_606_DATA */ - 0x00000000, /* DENALI_PHY_607_DATA */ - 0x00000000, /* DENALI_PHY_608_DATA */ - 0x00000000, /* DENALI_PHY_609_DATA */ - 0x00000000, /* DENALI_PHY_610_DATA */ - 0x00000000, /* DENALI_PHY_611_DATA */ - 0x00000000, /* DENALI_PHY_612_DATA */ - 0x00000000, /* DENALI_PHY_613_DATA */ - 0x00000000, /* DENALI_PHY_614_DATA */ - 0x00000000, /* DENALI_PHY_615_DATA */ - 0x00000000, /* DENALI_PHY_616_DATA */ - 0x00000000, /* DENALI_PHY_617_DATA */ - 0x00000000, /* DENALI_PHY_618_DATA */ - 0x00000000, /* DENALI_PHY_619_DATA */ - 0x00000000, /* DENALI_PHY_620_DATA */ - 0x00000000, /* DENALI_PHY_621_DATA */ - 0x00000000, /* DENALI_PHY_622_DATA */ - 0x00000000, /* DENALI_PHY_623_DATA */ - 0x00000000, /* DENALI_PHY_624_DATA */ - 0x00000000, /* DENALI_PHY_625_DATA */ - 0x00000000, /* DENALI_PHY_626_DATA */ - 0x00000000, /* DENALI_PHY_627_DATA */ - 0x00000000, /* DENALI_PHY_628_DATA */ - 0x00000000, /* DENALI_PHY_629_DATA */ - 0x00000000, /* DENALI_PHY_630_DATA */ - 0x00000000, /* DENALI_PHY_631_DATA */ - 0x00000000, /* DENALI_PHY_632_DATA */ - 0x00000000, /* DENALI_PHY_633_DATA */ - 0x00000000, /* DENALI_PHY_634_DATA */ - 0x00000000, /* DENALI_PHY_635_DATA */ - 0x00000000, /* DENALI_PHY_636_DATA */ - 0x00000000, /* DENALI_PHY_637_DATA */ - 0x00000000, /* DENALI_PHY_638_DATA */ - 0x00000000, /* DENALI_PHY_639_DATA */ - 0x00000000, /* DENALI_PHY_640_DATA */ - 0x00800000, /* DENALI_PHY_641_DATA */ - 0x00000000, /* DENALI_PHY_642_DATA */ - 0x00000000, /* DENALI_PHY_643_DATA */ - 0x00000000, /* DENALI_PHY_644_DATA */ - 0x00000000, /* DENALI_PHY_645_DATA */ - 0x00000000, /* DENALI_PHY_646_DATA */ - 0x00000001, /* DENALI_PHY_647_DATA */ - 0x00000000, /* DENALI_PHY_648_DATA */ - 0x00000000, /* DENALI_PHY_649_DATA */ - 0x00000000, /* DENALI_PHY_650_DATA */ - 0x00400320, /* DENALI_PHY_651_DATA */ - 0x00000040, /* DENALI_PHY_652_DATA */ - 0x00008eca, /* DENALI_PHY_653_DATA */ - 0x00009fdb, /* DENALI_PHY_654_DATA */ - 0x00008eca, /* DENALI_PHY_655_DATA */ - 0x01009fdb, /* DENALI_PHY_656_DATA */ - 0x00020003, /* DENALI_PHY_657_DATA */ - 0x00000000, /* DENALI_PHY_658_DATA */ - 0x00000000, /* DENALI_PHY_659_DATA */ - 0x00000000, /* DENALI_PHY_660_DATA */ - 0x000556aa, /* DENALI_PHY_661_DATA */ - 0x000aaaaa, /* DENALI_PHY_662_DATA */ - 0x000aa955, /* DENALI_PHY_663_DATA */ - 0x00055555, /* DENALI_PHY_664_DATA */ - 0x000b3133, /* DENALI_PHY_665_DATA */ - 0x0004cd33, /* DENALI_PHY_666_DATA */ - 0x0004cecc, /* DENALI_PHY_667_DATA */ - 0x000b32cc, /* DENALI_PHY_668_DATA */ - 0x0004a0e6, /* DENALI_PHY_669_DATA */ - 0x080f0000, /* DENALI_PHY_670_DATA */ - 0x0000000f, /* DENALI_PHY_671_DATA */ - 0x00038055, /* DENALI_PHY_672_DATA */ - 0x03800380, /* DENALI_PHY_673_DATA */ - 0x03800380, /* DENALI_PHY_674_DATA */ - 0x00000380, /* DENALI_PHY_675_DATA */ - 0x42080010, /* DENALI_PHY_676_DATA */ - 0x00000003, /* DENALI_PHY_677_DATA */ - 0x00000000, /* DENALI_PHY_678_DATA */ - 0x00000000, /* DENALI_PHY_679_DATA */ - 0x00000000, /* DENALI_PHY_680_DATA */ - 0x00000000, /* DENALI_PHY_681_DATA */ - 0x00000000, /* DENALI_PHY_682_DATA */ - 0x00000000, /* DENALI_PHY_683_DATA */ - 0x00000000, /* DENALI_PHY_684_DATA */ - 0x00000000, /* DENALI_PHY_685_DATA */ - 0x00000000, /* DENALI_PHY_686_DATA */ - 0x00000000, /* DENALI_PHY_687_DATA */ - 0x00000000, /* DENALI_PHY_688_DATA */ - 0x00000000, /* DENALI_PHY_689_DATA */ - 0x00000000, /* DENALI_PHY_690_DATA */ - 0x00000000, /* DENALI_PHY_691_DATA */ - 0x00000000, /* DENALI_PHY_692_DATA */ - 0x00000000, /* DENALI_PHY_693_DATA */ - 0x00000000, /* DENALI_PHY_694_DATA */ - 0x00000000, /* DENALI_PHY_695_DATA */ - 0x00000000, /* DENALI_PHY_696_DATA */ - 0x00000000, /* DENALI_PHY_697_DATA */ - 0x00000000, /* DENALI_PHY_698_DATA */ - 0x00000000, /* DENALI_PHY_699_DATA */ - 0x00000000, /* DENALI_PHY_700_DATA */ - 0x00000000, /* DENALI_PHY_701_DATA */ - 0x00000000, /* DENALI_PHY_702_DATA */ - 0x00000000, /* DENALI_PHY_703_DATA */ - 0x00000000, /* DENALI_PHY_704_DATA */ - 0x00000000, /* DENALI_PHY_705_DATA */ - 0x00000000, /* DENALI_PHY_706_DATA */ - 0x00000000, /* DENALI_PHY_707_DATA */ - 0x00000000, /* DENALI_PHY_708_DATA */ - 0x00000000, /* DENALI_PHY_709_DATA */ - 0x00000000, /* DENALI_PHY_710_DATA */ - 0x00000000, /* DENALI_PHY_711_DATA */ - 0x00000000, /* DENALI_PHY_712_DATA */ - 0x00000000, /* DENALI_PHY_713_DATA */ - 0x00000000, /* DENALI_PHY_714_DATA */ - 0x00000000, /* DENALI_PHY_715_DATA */ - 0x00000000, /* DENALI_PHY_716_DATA */ - 0x00000000, /* DENALI_PHY_717_DATA */ - 0x00000000, /* DENALI_PHY_718_DATA */ - 0x00000000, /* DENALI_PHY_719_DATA */ - 0x00000000, /* DENALI_PHY_720_DATA */ - 0x00000000, /* DENALI_PHY_721_DATA */ - 0x00000000, /* DENALI_PHY_722_DATA */ - 0x00000000, /* DENALI_PHY_723_DATA */ - 0x00000000, /* DENALI_PHY_724_DATA */ - 0x00000000, /* DENALI_PHY_725_DATA */ - 0x00000000, /* DENALI_PHY_726_DATA */ - 0x00000000, /* DENALI_PHY_727_DATA */ - 0x00000000, /* DENALI_PHY_728_DATA */ - 0x00000000, /* DENALI_PHY_729_DATA */ - 0x00000000, /* DENALI_PHY_730_DATA */ - 0x00000000, /* DENALI_PHY_731_DATA */ - 0x00000000, /* DENALI_PHY_732_DATA */ - 0x00000000, /* DENALI_PHY_733_DATA */ - 0x00000000, /* DENALI_PHY_734_DATA */ - 0x00000000, /* DENALI_PHY_735_DATA */ - 0x00000000, /* DENALI_PHY_736_DATA */ - 0x00000000, /* DENALI_PHY_737_DATA */ - 0x00000000, /* DENALI_PHY_738_DATA */ - 0x00000000, /* DENALI_PHY_739_DATA */ - 0x00000000, /* DENALI_PHY_740_DATA */ - 0x00000000, /* DENALI_PHY_741_DATA */ - 0x00000000, /* DENALI_PHY_742_DATA */ - 0x00000000, /* DENALI_PHY_743_DATA */ - 0x00000000, /* DENALI_PHY_744_DATA */ - 0x00000000, /* DENALI_PHY_745_DATA */ - 0x00000000, /* DENALI_PHY_746_DATA */ - 0x00000000, /* DENALI_PHY_747_DATA */ - 0x00000000, /* DENALI_PHY_748_DATA */ - 0x00000000, /* DENALI_PHY_749_DATA */ - 0x00000000, /* DENALI_PHY_750_DATA */ - 0x00000000, /* DENALI_PHY_751_DATA */ - 0x00000000, /* DENALI_PHY_752_DATA */ - 0x00000000, /* DENALI_PHY_753_DATA */ - 0x00000000, /* DENALI_PHY_754_DATA */ - 0x00000000, /* DENALI_PHY_755_DATA */ - 0x00000000, /* DENALI_PHY_756_DATA */ - 0x00000000, /* DENALI_PHY_757_DATA */ - 0x00000000, /* DENALI_PHY_758_DATA */ - 0x00000000, /* DENALI_PHY_759_DATA */ - 0x00000000, /* DENALI_PHY_760_DATA */ - 0x00000000, /* DENALI_PHY_761_DATA */ - 0x00000000, /* DENALI_PHY_762_DATA */ - 0x00000000, /* DENALI_PHY_763_DATA */ - 0x00000000, /* DENALI_PHY_764_DATA */ - 0x00000000, /* DENALI_PHY_765_DATA */ - 0x00000000, /* DENALI_PHY_766_DATA */ - 0x00000000, /* DENALI_PHY_767_DATA */ - 0x00000000, /* DENALI_PHY_768_DATA */ - 0x00800000, /* DENALI_PHY_769_DATA */ - 0x00000000, /* DENALI_PHY_770_DATA */ - 0x00000000, /* DENALI_PHY_771_DATA */ - 0x00000000, /* DENALI_PHY_772_DATA */ - 0x00000000, /* DENALI_PHY_773_DATA */ - 0x00000000, /* DENALI_PHY_774_DATA */ - 0x00000001, /* DENALI_PHY_775_DATA */ - 0x00000000, /* DENALI_PHY_776_DATA */ - 0x00000000, /* DENALI_PHY_777_DATA */ - 0x00000000, /* DENALI_PHY_778_DATA */ - 0x00400320, /* DENALI_PHY_779_DATA */ - 0x00000040, /* DENALI_PHY_780_DATA */ - 0x00008eca, /* DENALI_PHY_781_DATA */ - 0x00009fdb, /* DENALI_PHY_782_DATA */ - 0x00008eca, /* DENALI_PHY_783_DATA */ - 0x01009fdb, /* DENALI_PHY_784_DATA */ - 0x00020003, /* DENALI_PHY_785_DATA */ - 0x00000000, /* DENALI_PHY_786_DATA */ - 0x00000000, /* DENALI_PHY_787_DATA */ - 0x00000000, /* DENALI_PHY_788_DATA */ - 0x000556aa, /* DENALI_PHY_789_DATA */ - 0x000aaaaa, /* DENALI_PHY_790_DATA */ - 0x000aa955, /* DENALI_PHY_791_DATA */ - 0x00055555, /* DENALI_PHY_792_DATA */ - 0x000b3133, /* DENALI_PHY_793_DATA */ - 0x0004cd33, /* DENALI_PHY_794_DATA */ - 0x0004cecc, /* DENALI_PHY_795_DATA */ - 0x000b32cc, /* DENALI_PHY_796_DATA */ - 0x1ee6b16a, /* DENALI_PHY_797_DATA */ - 0x10000000, /* DENALI_PHY_798_DATA */ - 0x00000000, /* DENALI_PHY_799_DATA */ - 0x00038055, /* DENALI_PHY_800_DATA */ - 0x03800380, /* DENALI_PHY_801_DATA */ - 0x03800380, /* DENALI_PHY_802_DATA */ - 0x00000380, /* DENALI_PHY_803_DATA */ - 0x42080010, /* DENALI_PHY_804_DATA */ - 0x00000003, /* DENALI_PHY_805_DATA */ - 0x00000000, /* DENALI_PHY_806_DATA */ - 0x00000000, /* DENALI_PHY_807_DATA */ - 0x00000000, /* DENALI_PHY_808_DATA */ - 0x00000000, /* DENALI_PHY_809_DATA */ - 0x00000000, /* DENALI_PHY_810_DATA */ - 0x00000000, /* DENALI_PHY_811_DATA */ - 0x00000000, /* DENALI_PHY_812_DATA */ - 0x00000000, /* DENALI_PHY_813_DATA */ - 0x00000000, /* DENALI_PHY_814_DATA */ - 0x00000000, /* DENALI_PHY_815_DATA */ - 0x00000000, /* DENALI_PHY_816_DATA */ - 0x00000000, /* DENALI_PHY_817_DATA */ - 0x00000000, /* DENALI_PHY_818_DATA */ - 0x00000000, /* DENALI_PHY_819_DATA */ - 0x00000000, /* DENALI_PHY_820_DATA */ - 0x00000000, /* DENALI_PHY_821_DATA */ - 0x00000000, /* DENALI_PHY_822_DATA */ - 0x00000000, /* DENALI_PHY_823_DATA */ - 0x00000000, /* DENALI_PHY_824_DATA */ - 0x00000000, /* DENALI_PHY_825_DATA */ - 0x00000000, /* DENALI_PHY_826_DATA */ - 0x00000000, /* DENALI_PHY_827_DATA */ - 0x00000000, /* DENALI_PHY_828_DATA */ - 0x00000000, /* DENALI_PHY_829_DATA */ - 0x00000000, /* DENALI_PHY_830_DATA */ - 0x00000000, /* DENALI_PHY_831_DATA */ - 0x00000000, /* DENALI_PHY_832_DATA */ - 0x00000000, /* DENALI_PHY_833_DATA */ - 0x00000000, /* DENALI_PHY_834_DATA */ - 0x00000000, /* DENALI_PHY_835_DATA */ - 0x00000000, /* DENALI_PHY_836_DATA */ - 0x00000000, /* DENALI_PHY_837_DATA */ - 0x00000000, /* DENALI_PHY_838_DATA */ - 0x00000000, /* DENALI_PHY_839_DATA */ - 0x00000000, /* DENALI_PHY_840_DATA */ - 0x00000000, /* DENALI_PHY_841_DATA */ - 0x00000000, /* DENALI_PHY_842_DATA */ - 0x00000000, /* DENALI_PHY_843_DATA */ - 0x00000000, /* DENALI_PHY_844_DATA */ - 0x00000000, /* DENALI_PHY_845_DATA */ - 0x00000000, /* DENALI_PHY_846_DATA */ - 0x00000000, /* DENALI_PHY_847_DATA */ - 0x00000000, /* DENALI_PHY_848_DATA */ - 0x00000000, /* DENALI_PHY_849_DATA */ - 0x00000000, /* DENALI_PHY_850_DATA */ - 0x00000000, /* DENALI_PHY_851_DATA */ - 0x00000000, /* DENALI_PHY_852_DATA */ - 0x00000000, /* DENALI_PHY_853_DATA */ - 0x00000000, /* DENALI_PHY_854_DATA */ - 0x00000000, /* DENALI_PHY_855_DATA */ - 0x00000000, /* DENALI_PHY_856_DATA */ - 0x00000000, /* DENALI_PHY_857_DATA */ - 0x00000000, /* DENALI_PHY_858_DATA */ - 0x00000000, /* DENALI_PHY_859_DATA */ - 0x00000000, /* DENALI_PHY_860_DATA */ - 0x00000000, /* DENALI_PHY_861_DATA */ - 0x00000000, /* DENALI_PHY_862_DATA */ - 0x00000000, /* DENALI_PHY_863_DATA */ - 0x00000000, /* DENALI_PHY_864_DATA */ - 0x00000000, /* DENALI_PHY_865_DATA */ - 0x00000000, /* DENALI_PHY_866_DATA */ - 0x00000000, /* DENALI_PHY_867_DATA */ - 0x00000000, /* DENALI_PHY_868_DATA */ - 0x00000000, /* DENALI_PHY_869_DATA */ - 0x00000000, /* DENALI_PHY_870_DATA */ - 0x00000000, /* DENALI_PHY_871_DATA */ - 0x00000000, /* DENALI_PHY_872_DATA */ - 0x00000000, /* DENALI_PHY_873_DATA */ - 0x00000000, /* DENALI_PHY_874_DATA */ - 0x00000000, /* DENALI_PHY_875_DATA */ - 0x00000000, /* DENALI_PHY_876_DATA */ - 0x00000000, /* DENALI_PHY_877_DATA */ - 0x00000000, /* DENALI_PHY_878_DATA */ - 0x00000000, /* DENALI_PHY_879_DATA */ - 0x00000000, /* DENALI_PHY_880_DATA */ - 0x00000000, /* DENALI_PHY_881_DATA */ - 0x00000000, /* DENALI_PHY_882_DATA */ - 0x00000000, /* DENALI_PHY_883_DATA */ - 0x00000000, /* DENALI_PHY_884_DATA */ - 0x00000000, /* DENALI_PHY_885_DATA */ - 0x00000000, /* DENALI_PHY_886_DATA */ - 0x00000000, /* DENALI_PHY_887_DATA */ - 0x00000000, /* DENALI_PHY_888_DATA */ - 0x00000000, /* DENALI_PHY_889_DATA */ - 0x00000000, /* DENALI_PHY_890_DATA */ - 0x00000000, /* DENALI_PHY_891_DATA */ - 0x00000000, /* DENALI_PHY_892_DATA */ - 0x00000000, /* DENALI_PHY_893_DATA */ - 0x00000000, /* DENALI_PHY_894_DATA */ - 0x00000000, /* DENALI_PHY_895_DATA */ - 0x00000001, /* DENALI_PHY_896_DATA */ - 0x00000000, /* DENALI_PHY_897_DATA */ - 0x01000005, /* DENALI_PHY_898_DATA */ - 0x04000f00, /* DENALI_PHY_899_DATA */ - 0x00020040, /* DENALI_PHY_900_DATA */ - 0x00020055, /* DENALI_PHY_901_DATA */ - 0x00000000, /* DENALI_PHY_902_DATA */ - 0x00000000, /* DENALI_PHY_903_DATA */ - 0x00000000, /* DENALI_PHY_904_DATA */ - 0x00000050, /* DENALI_PHY_905_DATA */ - 0x00000000, /* DENALI_PHY_906_DATA */ - 0x00010100, /* DENALI_PHY_907_DATA */ - 0x00000601, /* DENALI_PHY_908_DATA */ - 0x00000000, /* DENALI_PHY_909_DATA */ - 0x00006400, /* DENALI_PHY_910_DATA */ - 0x01221102, /* DENALI_PHY_911_DATA */ - 0x00000000, /* DENALI_PHY_912_DATA */ - 0x00051f00, /* DENALI_PHY_913_DATA */ - 0x051f051f, /* DENALI_PHY_914_DATA */ - 0x051f051f, /* DENALI_PHY_915_DATA */ - 0x00030003, /* DENALI_PHY_916_DATA */ - 0x03000300, /* DENALI_PHY_917_DATA */ - 0x00000300, /* DENALI_PHY_918_DATA */ - 0x01221102, /* DENALI_PHY_919_DATA */ - 0x00000000, /* DENALI_PHY_920_DATA */ - 0x00000000, /* DENALI_PHY_921_DATA */ - 0x03020000, /* DENALI_PHY_922_DATA */ - 0x00000001, /* DENALI_PHY_923_DATA */ - 0x00000011, /* DENALI_PHY_924_DATA */ - 0x00000011, /* DENALI_PHY_925_DATA */ - 0x00000400, /* DENALI_PHY_926_DATA */ - 0x00000000, /* DENALI_PHY_927_DATA */ - 0x00000011, /* DENALI_PHY_928_DATA */ - 0x00000011, /* DENALI_PHY_929_DATA */ - 0x00004410, /* DENALI_PHY_930_DATA */ - 0x00004410, /* DENALI_PHY_931_DATA */ - 0x00004410, /* DENALI_PHY_932_DATA */ - 0x00004410, /* DENALI_PHY_933_DATA */ - 0x00004410, /* DENALI_PHY_934_DATA */ - 0x00000011, /* DENALI_PHY_935_DATA */ - 0x00004410, /* DENALI_PHY_936_DATA */ - 0x00000011, /* DENALI_PHY_937_DATA */ - 0x00004410, /* DENALI_PHY_938_DATA */ - 0x00000011, /* DENALI_PHY_939_DATA */ - 0x00004410, /* DENALI_PHY_940_DATA */ - 0x00000000, /* DENALI_PHY_941_DATA */ - 0x00000000, /* DENALI_PHY_942_DATA */ - 0x00000000, /* DENALI_PHY_943_DATA */ - 0x04000000, /* DENALI_PHY_944_DATA */ - 0x00000000, /* DENALI_PHY_945_DATA */ - 0x00000000, /* DENALI_PHY_946_DATA */ - 0x00000508, /* DENALI_PHY_947_DATA */ - 0x00000000, /* DENALI_PHY_948_DATA */ - 0x00000000, /* DENALI_PHY_949_DATA */ - 0x00000000, /* DENALI_PHY_950_DATA */ - 0x00000000, /* DENALI_PHY_951_DATA */ - 0x00000000, /* DENALI_PHY_952_DATA */ - 0x00000000, /* DENALI_PHY_953_DATA */ - 0xe4000000, /* DENALI_PHY_954_DATA */ - 0x00000000, /* DENALI_PHY_955_DATA */ - 0x00000000, /* DENALI_PHY_956_DATA */ - 0x01010000, /* DENALI_PHY_957_DATA */ - 0x00000000 /* DENALI_PHY_958_DATA */ - } - }, -}, diff --git a/src/mainboard/google/gru/sdram_inf/sdram-lpddr3-hynix-4GB-800-no-odt.c b/src/mainboard/google/gru/sdram_inf/sdram-lpddr3-hynix-4GB-800-no-odt.c new file mode 100644 index 0000000..866759b --- /dev/null +++ b/src/mainboard/google/gru/sdram_inf/sdram-lpddr3-hynix-4GB-800-no-odt.c @@ -0,0 +1,1565 @@ +/* + * This file is part of the coreboot project. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <soc/sdram.h> + +struct rk3399_sdram_params params = { + { + { + .rank = 0x2, + .col = 0xA, + .bk = 0x3, + .bw = 0x2, + .dbw = 0x2, + .row_3_4 = 0x0, + .cs0_row = 0xF, + .cs1_row = 0xF, + .ddrconfig = 1, + { + {0x1d191519}, + {0x14040808}, + {0x00000002}, + {0x00006226}, + {0x00000054}, + 0x00000000 + } + }, + { + .rank = 0x2, + .col = 0xA, + .bk = 0x3, + .bw = 0x2, + .dbw = 0x2, + .row_3_4 = 0x0, + .cs0_row = 0xF, + .cs1_row = 0xF, + .ddrconfig = 1, + { + {0x1d191519}, + {0x14040808}, + {0x00000002}, + {0x00006226}, + {0x00000054}, + 0x00000000 + } + } + }, + .ddr_freq = 800*MHz, + .dramtype = LPDDR3, + .num_channels = 2, + .stride = 13, + .odt = 1, + { + { + 0x00000700, /* DENALI_CTL_00_DATA */ + 0x00000000, /* DENALI_CTL_01_DATA */ + 0x00000000, /* DENALI_CTL_02_DATA */ + 0x00000000, /* DENALI_CTL_03_DATA */ + 0x00000000, /* DENALI_CTL_04_DATA */ + 0x00000050, /* DENALI_CTL_05_DATA */ + 0x00027100, /* DENALI_CTL_06_DATA */ + 0x00000320, /* DENALI_CTL_07_DATA */ + 0x00001f40, /* DENALI_CTL_08_DATA */ + 0x00000028, /* DENALI_CTL_09_DATA */ + 0x00013880, /* DENALI_CTL_10_DATA */ + 0x00000190, /* DENALI_CTL_11_DATA */ + 0x00000fa0, /* DENALI_CTL_12_DATA */ + 0x00000050, /* DENALI_CTL_13_DATA */ + 0x00027100, /* DENALI_CTL_14_DATA */ + 0x00000320, /* DENALI_CTL_15_DATA */ + 0x01001f40, /* DENALI_CTL_16_DATA */ + 0x00000000, /* DENALI_CTL_17_DATA */ + 0x00000101, /* DENALI_CTL_18_DATA */ + 0x00020100, /* DENALI_CTL_19_DATA */ + 0x000000a0, /* DENALI_CTL_20_DATA */ + 0x00000190, /* DENALI_CTL_21_DATA */ + 0x00000000, /* DENALI_CTL_22_DATA */ + 0x06180000, /* DENALI_CTL_23_DATA */ + 0x00061800, /* DENALI_CTL_24_DATA */ + 0x04000618, /* DENALI_CTL_25_DATA */ + 0x33080004, /* DENALI_CTL_26_DATA */ + 0x280f0622, /* DENALI_CTL_27_DATA */ + 0x111a0400, /* DENALI_CTL_28_DATA */ + 0x00140804, /* DENALI_CTL_29_DATA */ + 0x06223308, /* DENALI_CTL_30_DATA */ + 0x0600280f, /* DENALI_CTL_31_DATA */ + 0x00000a0a, /* DENALI_CTL_32_DATA */ + 0x0600dac0, /* DENALI_CTL_33_DATA */ + 0x0a0a040c, /* DENALI_CTL_34_DATA */ + 0x03006d60, /* DENALI_CTL_35_DATA */ + 0x0a0a0606, /* DENALI_CTL_36_DATA */ + 0x0600dac0, /* DENALI_CTL_37_DATA */ + 0x0203000c, /* DENALI_CTL_38_DATA */ + 0x080c0f00, /* DENALI_CTL_39_DATA */ + 0x040c0f06, /* DENALI_CTL_40_DATA */ + 0x14000a0a, /* DENALI_CTL_41_DATA */ + 0x02030a0a, /* DENALI_CTL_42_DATA */ + 0x00010003, /* DENALI_CTL_43_DATA */ + 0x031b0e1b, /* DENALI_CTL_44_DATA */ + 0x00110911, /* DENALI_CTL_45_DATA */ + 0x00000000, /* DENALI_CTL_46_DATA */ + 0x03010000, /* DENALI_CTL_47_DATA */ + 0x0c2800a8, /* DENALI_CTL_48_DATA */ + 0x06100054, /* DENALI_CTL_49_DATA */ + 0x0c2800a8, /* DENALI_CTL_50_DATA */ + 0x00000000, /* DENALI_CTL_51_DATA */ + 0x00030006, /* DENALI_CTL_52_DATA */ + 0x00140006, /* DENALI_CTL_53_DATA */ + 0x0014000a, /* DENALI_CTL_54_DATA */ + 0x000f080f, /* DENALI_CTL_55_DATA */ + 0x00000000, /* DENALI_CTL_56_DATA */ + 0x00000000, /* DENALI_CTL_57_DATA */ + 0x00000000, /* DENALI_CTL_58_DATA */ + 0x00b00000, /* DENALI_CTL_59_DATA */ + 0x005800b0, /* DENALI_CTL_60_DATA */ + 0x00b00058, /* DENALI_CTL_61_DATA */ + 0x000000b0, /* DENALI_CTL_62_DATA */ + 0x00000000, /* DENALI_CTL_63_DATA */ + 0x00000000, /* DENALI_CTL_64_DATA */ + 0x00000000, /* DENALI_CTL_65_DATA */ + 0x00000000, /* DENALI_CTL_66_DATA */ + 0x00000000, /* DENALI_CTL_67_DATA */ + 0x00000000, /* DENALI_CTL_68_DATA */ + 0x00000301, /* DENALI_CTL_69_DATA */ + 0x00000001, /* DENALI_CTL_70_DATA */ + 0x00000000, /* DENALI_CTL_71_DATA */ + 0x00000000, /* DENALI_CTL_72_DATA */ + 0x01000000, /* DENALI_CTL_73_DATA */ + 0x80104002, /* DENALI_CTL_74_DATA */ + 0x00040003, /* DENALI_CTL_75_DATA */ + 0x00040005, /* DENALI_CTL_76_DATA */ + 0x00030000, /* DENALI_CTL_77_DATA */ + 0x00050004, /* DENALI_CTL_78_DATA */ + 0x00000004, /* DENALI_CTL_79_DATA */ + 0x00040003, /* DENALI_CTL_80_DATA */ + 0x00040005, /* DENALI_CTL_81_DATA */ + 0x30a00000, /* DENALI_CTL_82_DATA */ + 0x00001850, /* DENALI_CTL_83_DATA */ + 0x0c201840, /* DENALI_CTL_84_DATA */ + 0x30a00000, /* DENALI_CTL_85_DATA */ + 0x00001850, /* DENALI_CTL_86_DATA */ + 0x00000000, /* DENALI_CTL_87_DATA */ + 0x00000000, /* DENALI_CTL_88_DATA */ + 0x00000000, /* DENALI_CTL_89_DATA */ + 0x00000000, /* DENALI_CTL_90_DATA */ + 0x00000000, /* DENALI_CTL_91_DATA */ + 0x02020200, /* DENALI_CTL_92_DATA */ + 0x00020202, /* DENALI_CTL_93_DATA */ + 0x00030200, /* DENALI_CTL_94_DATA */ + 0x00040700, /* DENALI_CTL_95_DATA */ + 0x00000302, /* DENALI_CTL_96_DATA */ + 0x02000407, /* DENALI_CTL_97_DATA */ + 0x00000003, /* DENALI_CTL_98_DATA */ + 0x00030f04, /* DENALI_CTL_99_DATA */ + 0x00070004, /* DENALI_CTL_100_DATA */ + 0x00000000, /* DENALI_CTL_101_DATA */ + 0x00000000, /* DENALI_CTL_102_DATA */ + 0x00000000, /* DENALI_CTL_103_DATA */ + 0x00000000, /* DENALI_CTL_104_DATA */ + 0x00000000, /* DENALI_CTL_105_DATA */ + 0x00000000, /* DENALI_CTL_106_DATA */ + 0x00000000, /* DENALI_CTL_107_DATA */ + 0x00010000, /* DENALI_CTL_108_DATA */ + 0x20040020, /* DENALI_CTL_109_DATA */ + 0x00200400, /* DENALI_CTL_110_DATA */ + 0x01000400, /* DENALI_CTL_111_DATA */ + 0x00000b80, /* DENALI_CTL_112_DATA */ + 0x00000000, /* DENALI_CTL_113_DATA */ + 0x00000001, /* DENALI_CTL_114_DATA */ + 0x00000002, /* DENALI_CTL_115_DATA */ + 0x0000000e, /* DENALI_CTL_116_DATA */ + 0x00000000, /* DENALI_CTL_117_DATA */ + 0x00000000, /* DENALI_CTL_118_DATA */ + 0x00000000, /* DENALI_CTL_119_DATA */ + 0x00000000, /* DENALI_CTL_120_DATA */ + 0x00000000, /* DENALI_CTL_121_DATA */ + 0x00a00000, /* DENALI_CTL_122_DATA */ + 0x00c80050, /* DENALI_CTL_123_DATA */ + 0x00c80000, /* DENALI_CTL_124_DATA */ + 0x00280050, /* DENALI_CTL_125_DATA */ + 0x00000064, /* DENALI_CTL_126_DATA */ + 0x00a00064, /* DENALI_CTL_127_DATA */ + 0x00c80050, /* DENALI_CTL_128_DATA */ + 0x00c80000, /* DENALI_CTL_129_DATA */ + 0x00000000, /* DENALI_CTL_130_DATA */ + 0x00000000, /* DENALI_CTL_131_DATA */ + 0x00000000, /* DENALI_CTL_132_DATA */ + 0x00430000, /* DENALI_CTL_133_DATA */ + 0x0000001a, /* DENALI_CTL_134_DATA */ + 0x000a0083, /* DENALI_CTL_135_DATA */ + 0x00430000, /* DENALI_CTL_136_DATA */ + 0x0000001a, /* DENALI_CTL_137_DATA */ + 0x00010001, /* DENALI_CTL_138_DATA */ + 0x07000001, /* DENALI_CTL_139_DATA */ + 0x00000707, /* DENALI_CTL_140_DATA */ + 0x00000000, /* DENALI_CTL_141_DATA */ + 0x00000000, /* DENALI_CTL_142_DATA */ + 0x00000000, /* DENALI_CTL_143_DATA */ + 0x00000000, /* DENALI_CTL_144_DATA */ + 0x00000000, /* DENALI_CTL_145_DATA */ + 0x00000000, /* DENALI_CTL_146_DATA */ + 0x00430000, /* DENALI_CTL_147_DATA */ + 0x0000001a, /* DENALI_CTL_148_DATA */ + 0x000a0083, /* DENALI_CTL_149_DATA */ + 0x00430000, /* DENALI_CTL_150_DATA */ + 0x0000001a, /* DENALI_CTL_151_DATA */ + 0x00010001, /* DENALI_CTL_152_DATA */ + 0x07000001, /* DENALI_CTL_153_DATA */ + 0x00000707, /* DENALI_CTL_154_DATA */ + 0x00000000, /* DENALI_CTL_155_DATA */ + 0x00000000, /* DENALI_CTL_156_DATA */ + 0x00000000, /* DENALI_CTL_157_DATA */ + 0x00000000, /* DENALI_CTL_158_DATA */ + 0x00000000, /* DENALI_CTL_159_DATA */ + 0x00000000, /* DENALI_CTL_160_DATA */ + 0x01000000, /* DENALI_CTL_161_DATA */ + 0x00000000, /* DENALI_CTL_162_DATA */ + 0x00000000, /* DENALI_CTL_163_DATA */ + 0x18151100, /* DENALI_CTL_164_DATA */ + 0x0000000c, /* DENALI_CTL_165_DATA */ + 0x00000000, /* DENALI_CTL_166_DATA */ + 0x00000000, /* DENALI_CTL_167_DATA */ + 0x00000000, /* DENALI_CTL_168_DATA */ + 0x00000000, /* DENALI_CTL_169_DATA */ + 0x00000000, /* DENALI_CTL_170_DATA */ + 0x00000000, /* DENALI_CTL_171_DATA */ + 0x00000000, /* DENALI_CTL_172_DATA */ + 0x00000000, /* DENALI_CTL_173_DATA */ + 0x00000000, /* DENALI_CTL_174_DATA */ + 0x00000000, /* DENALI_CTL_175_DATA */ + 0x00000000, /* DENALI_CTL_176_DATA */ + 0x00000000, /* DENALI_CTL_177_DATA */ + 0x00000000, /* DENALI_CTL_178_DATA */ + 0x00032003, /* DENALI_CTL_179_DATA */ + 0x00480120, /* DENALI_CTL_180_DATA */ + 0x00000000, /* DENALI_CTL_181_DATA */ + 0x00900190, /* DENALI_CTL_182_DATA */ + 0x00000024, /* DENALI_CTL_183_DATA */ + 0x00032000, /* DENALI_CTL_184_DATA */ + 0x00480120, /* DENALI_CTL_185_DATA */ + 0x00000000, /* DENALI_CTL_186_DATA */ + 0x00280000, /* DENALI_CTL_187_DATA */ + 0x00280014, /* DENALI_CTL_188_DATA */ + 0x01010100, /* DENALI_CTL_189_DATA */ + 0x01000202, /* DENALI_CTL_190_DATA */ + 0x0a000002, /* DENALI_CTL_191_DATA */ + 0x01000f0f, /* DENALI_CTL_192_DATA */ + 0x00000000, /* DENALI_CTL_193_DATA */ + 0x00000000, /* DENALI_CTL_194_DATA */ + 0x00010003, /* DENALI_CTL_195_DATA */ + 0x00000c03, /* DENALI_CTL_196_DATA */ + 0x00000100, /* DENALI_CTL_197_DATA */ + 0x00010000, /* DENALI_CTL_198_DATA */ + 0x01000000, /* DENALI_CTL_199_DATA */ + 0x00010000, /* DENALI_CTL_200_DATA */ + 0x00000001, /* DENALI_CTL_201_DATA */ + 0x00000000, /* DENALI_CTL_202_DATA */ + 0x00000000, /* DENALI_CTL_203_DATA */ + 0x00000000, /* DENALI_CTL_204_DATA */ + 0x00000000, /* DENALI_CTL_205_DATA */ + 0x00000000, /* DENALI_CTL_206_DATA */ + 0x00000000, /* DENALI_CTL_207_DATA */ + 0x00000000, /* DENALI_CTL_208_DATA */ + 0x00000000, /* DENALI_CTL_209_DATA */ + 0x00000000, /* DENALI_CTL_210_DATA */ + 0x00010000, /* DENALI_CTL_211_DATA */ + 0x03020301, /* DENALI_CTL_212_DATA */ + 0x01000808, /* DENALI_CTL_213_DATA */ + 0x04030001, /* DENALI_CTL_214_DATA */ + 0x0a0a0a03, /* DENALI_CTL_215_DATA */ + 0x02080808, /* DENALI_CTL_216_DATA */ + 0x02050103, /* DENALI_CTL_217_DATA */ + 0x02010103, /* DENALI_CTL_218_DATA */ + 0x00010103, /* DENALI_CTL_219_DATA */ + 0x00020202, /* DENALI_CTL_220_DATA */ + 0x03020500, /* DENALI_CTL_221_DATA */ + 0x00020501, /* DENALI_CTL_222_DATA */ + 0x00000000, /* DENALI_CTL_223_DATA */ + 0x00000000, /* DENALI_CTL_224_DATA */ + 0x0d000001, /* DENALI_CTL_225_DATA */ + 0x00010028, /* DENALI_CTL_226_DATA */ + 0x00010000, /* DENALI_CTL_227_DATA */ + 0x00000003, /* DENALI_CTL_228_DATA */ + 0x00000000, /* DENALI_CTL_229_DATA */ + 0x00000000, /* DENALI_CTL_230_DATA */ + 0x00000000, /* DENALI_CTL_231_DATA */ + 0x00000000, /* DENALI_CTL_232_DATA */ + 0x00000000, /* DENALI_CTL_233_DATA */ + 0x00000000, /* DENALI_CTL_234_DATA */ + 0x00000000, /* DENALI_CTL_235_DATA */ + 0x00000000, /* DENALI_CTL_236_DATA */ + 0x00010100, /* DENALI_CTL_237_DATA */ + 0x01000000, /* DENALI_CTL_238_DATA */ + 0x00000001, /* DENALI_CTL_239_DATA */ + 0x00000303, /* DENALI_CTL_240_DATA */ + 0x00000000, /* DENALI_CTL_241_DATA */ + 0x00000000, /* DENALI_CTL_242_DATA */ + 0x00000000, /* DENALI_CTL_243_DATA */ + 0x00000000, /* DENALI_CTL_244_DATA */ + 0x00000000, /* DENALI_CTL_245_DATA */ + 0x00000000, /* DENALI_CTL_246_DATA */ + 0x00000000, /* DENALI_CTL_247_DATA */ + 0x00000000, /* DENALI_CTL_248_DATA */ + 0x00000000, /* DENALI_CTL_249_DATA */ + 0x00000000, /* DENALI_CTL_250_DATA */ + 0x00000000, /* DENALI_CTL_251_DATA */ + 0x00000000, /* DENALI_CTL_252_DATA */ + 0x00000000, /* DENALI_CTL_253_DATA */ + 0x00000000, /* DENALI_CTL_254_DATA */ + 0x00000000, /* DENALI_CTL_255_DATA */ + 0x000556aa, /* DENALI_CTL_256_DATA */ + 0x000aaaaa, /* DENALI_CTL_257_DATA */ + 0x000aa955, /* DENALI_CTL_258_DATA */ + 0x00055555, /* DENALI_CTL_259_DATA */ + 0x000b3133, /* DENALI_CTL_260_DATA */ + 0x0004cd33, /* DENALI_CTL_261_DATA */ + 0x0004cecc, /* DENALI_CTL_262_DATA */ + 0x000b32cc, /* DENALI_CTL_263_DATA */ + 0x00010300, /* DENALI_CTL_264_DATA */ + 0x03000100, /* DENALI_CTL_265_DATA */ + 0x00000000, /* DENALI_CTL_266_DATA */ + 0x00000000, /* DENALI_CTL_267_DATA */ + 0x00000000, /* DENALI_CTL_268_DATA */ + 0x00000000, /* DENALI_CTL_269_DATA */ + 0x00000000, /* DENALI_CTL_270_DATA */ + 0x00000000, /* DENALI_CTL_271_DATA */ + 0x00000000, /* DENALI_CTL_272_DATA */ + 0x00000000, /* DENALI_CTL_273_DATA */ + 0x00ffff00, /* DENALI_CTL_274_DATA */ + 0x181e0000, /* DENALI_CTL_275_DATA */ + 0x0800001e, /* DENALI_CTL_276_DATA */ + 0x00001850, /* DENALI_CTL_277_DATA */ + 0x00000200, /* DENALI_CTL_278_DATA */ + 0x00000200, /* DENALI_CTL_279_DATA */ + 0x00000200, /* DENALI_CTL_280_DATA */ + 0x00000200, /* DENALI_CTL_281_DATA */ + 0x00001850, /* DENALI_CTL_282_DATA */ + 0x0000f320, /* DENALI_CTL_283_DATA */ + 0x0c20050a, /* DENALI_CTL_284_DATA */ + 0x00000200, /* DENALI_CTL_285_DATA */ + 0x00000200, /* DENALI_CTL_286_DATA */ + 0x00000200, /* DENALI_CTL_287_DATA */ + 0x00000200, /* DENALI_CTL_288_DATA */ + 0x00000c20, /* DENALI_CTL_289_DATA */ + 0x00007940, /* DENALI_CTL_290_DATA */ + 0x1850050b, /* DENALI_CTL_291_DATA */ + 0x00000200, /* DENALI_CTL_292_DATA */ + 0x00000200, /* DENALI_CTL_293_DATA */ + 0x00000200, /* DENALI_CTL_294_DATA */ + 0x00000200, /* DENALI_CTL_295_DATA */ + 0x00001850, /* DENALI_CTL_296_DATA */ + 0x0000f320, /* DENALI_CTL_297_DATA */ + 0x0202050a, /* DENALI_CTL_298_DATA */ + 0x03030202, /* DENALI_CTL_299_DATA */ + 0x00000018, /* DENALI_CTL_300_DATA */ + 0x00000000, /* DENALI_CTL_301_DATA */ + 0x00000000, /* DENALI_CTL_302_DATA */ + 0x00001403, /* DENALI_CTL_303_DATA */ + 0x00000000, /* DENALI_CTL_304_DATA */ + 0x00000000, /* DENALI_CTL_305_DATA */ + 0x00000000, /* DENALI_CTL_306_DATA */ + 0x00030000, /* DENALI_CTL_307_DATA */ + 0x000e0020, /* DENALI_CTL_308_DATA */ + 0x000a001c, /* DENALI_CTL_309_DATA */ + 0x000e0020, /* DENALI_CTL_310_DATA */ + 0x00000000, /* DENALI_CTL_311_DATA */ + 0x00000000, /* DENALI_CTL_312_DATA */ + 0x01000000, /* DENALI_CTL_313_DATA */ + 0x00070007, /* DENALI_CTL_314_DATA */ + 0x00050007, /* DENALI_CTL_315_DATA */ + 0x00000000, /* DENALI_CTL_316_DATA */ + 0x00000000, /* DENALI_CTL_317_DATA */ + 0x00000000, /* DENALI_CTL_318_DATA */ + 0x00000000, /* DENALI_CTL_319_DATA */ + 0x00000000, /* DENALI_CTL_320_DATA */ + 0x00000000, /* DENALI_CTL_321_DATA */ + 0x00000000, /* DENALI_CTL_322_DATA */ + 0x00000000, /* DENALI_CTL_323_DATA */ + 0x01000101, /* DENALI_CTL_324_DATA */ + 0x01010101, /* DENALI_CTL_325_DATA */ + 0x01000101, /* DENALI_CTL_326_DATA */ + 0x01000100, /* DENALI_CTL_327_DATA */ + 0x00010001, /* DENALI_CTL_328_DATA */ + 0x00010002, /* DENALI_CTL_329_DATA */ + 0x00020100, /* DENALI_CTL_330_DATA */ + 0x00000002 /* DENALI_CTL_331_DATA */ + } + }, + { + { + 0x00000700, /* DENALI_PI_00_DATA */ + 0x00000000, /* DENALI_PI_01_DATA */ + 0x000030a0, /* DENALI_PI_02_DATA */ + 0x00001850, /* DENALI_PI_03_DATA */ + 0x00001840, /* DENALI_PI_04_DATA */ + 0x00000c20, /* DENALI_PI_05_DATA */ + 0x000030a0, /* DENALI_PI_06_DATA */ + 0x18501850, /* DENALI_PI_07_DATA */ + 0x00000200, /* DENALI_PI_08_DATA */ + 0x00000200, /* DENALI_PI_09_DATA */ + 0x00000200, /* DENALI_PI_10_DATA */ + 0x00000200, /* DENALI_PI_11_DATA */ + 0x00000c20, /* DENALI_PI_12_DATA */ + 0x00000200, /* DENALI_PI_13_DATA */ + 0x00000200, /* DENALI_PI_14_DATA */ + 0x00000200, /* DENALI_PI_15_DATA */ + 0x00000200, /* DENALI_PI_16_DATA */ + 0x00001850, /* DENALI_PI_17_DATA */ + 0x00000200, /* DENALI_PI_18_DATA */ + 0x00000200, /* DENALI_PI_19_DATA */ + 0x00000200, /* DENALI_PI_20_DATA */ + 0x00000200, /* DENALI_PI_21_DATA */ + 0x00010000, /* DENALI_PI_22_DATA */ + 0x00000007, /* DENALI_PI_23_DATA */ + 0x81000001, /* DENALI_PI_24_DATA */ + 0x0f0003f0, /* DENALI_PI_25_DATA */ + 0x3fffffff, /* DENALI_PI_26_DATA */ + 0x0f0000a0, /* DENALI_PI_27_DATA */ + 0x377ff000, /* DENALI_PI_28_DATA */ + 0x0f000020, /* DENALI_PI_29_DATA */ + 0x377ff000, /* DENALI_PI_30_DATA */ + 0x0f000030, /* DENALI_PI_31_DATA */ + 0x377ff000, /* DENALI_PI_32_DATA */ + 0x0f0000b0, /* DENALI_PI_33_DATA */ + 0x377ff000, /* DENALI_PI_34_DATA */ + 0x0f000100, /* DENALI_PI_35_DATA */ + 0x377ff000, /* DENALI_PI_36_DATA */ + 0x0f000110, /* DENALI_PI_37_DATA */ + 0x377ff000, /* DENALI_PI_38_DATA */ + 0x0f000010, /* DENALI_PI_39_DATA */ + 0x377ff000, /* DENALI_PI_40_DATA */ + 0x03000101, /* DENALI_PI_41_DATA */ + 0x042e292e, /* DENALI_PI_42_DATA */ + 0x06180006, /* DENALI_PI_43_DATA */ + 0x00061800, /* DENALI_PI_44_DATA */ + 0x00000018, /* DENALI_PI_45_DATA */ + 0x0c2800a8, /* DENALI_PI_46_DATA */ + 0x06100054, /* DENALI_PI_47_DATA */ + 0x0c2800a8, /* DENALI_PI_48_DATA */ + 0x00000500, /* DENALI_PI_49_DATA */ + 0x00000000, /* DENALI_PI_50_DATA */ + 0x00000000, /* DENALI_PI_51_DATA */ + 0x00000000, /* DENALI_PI_52_DATA */ + 0x00000000, /* DENALI_PI_53_DATA */ + 0x00000000, /* DENALI_PI_54_DATA */ + 0x00000000, /* DENALI_PI_55_DATA */ + 0x00000000, /* DENALI_PI_56_DATA */ + 0x00000000, /* DENALI_PI_57_DATA */ + 0x04040000, /* DENALI_PI_58_DATA */ + 0x0d000004, /* DENALI_PI_59_DATA */ + 0x00000128, /* DENALI_PI_60_DATA */ + 0x00000000, /* DENALI_PI_61_DATA */ + 0x00030003, /* DENALI_PI_62_DATA */ + 0x00000018, /* DENALI_PI_63_DATA */ + 0x00000000, /* DENALI_PI_64_DATA */ + 0x00000000, /* DENALI_PI_65_DATA */ + 0x03060002, /* DENALI_PI_66_DATA */ + 0x03010201, /* DENALI_PI_67_DATA */ + 0x01080801, /* DENALI_PI_68_DATA */ + 0x04020201, /* DENALI_PI_69_DATA */ + 0x01080804, /* DENALI_PI_70_DATA */ + 0x00000000, /* DENALI_PI_71_DATA */ + 0x04030000, /* DENALI_PI_72_DATA */ + 0x0a0a0a03, /* DENALI_PI_73_DATA */ + 0x00000000, /* DENALI_PI_74_DATA */ + 0x00000000, /* DENALI_PI_75_DATA */ + 0x00000000, /* DENALI_PI_76_DATA */ + 0x00030300, /* DENALI_PI_77_DATA */ + 0x00000014, /* DENALI_PI_78_DATA */ + 0x00000000, /* DENALI_PI_79_DATA */ + 0x01010300, /* DENALI_PI_80_DATA */ + 0x00000000, /* DENALI_PI_81_DATA */ + 0x00000000, /* DENALI_PI_82_DATA */ + 0x01000000, /* DENALI_PI_83_DATA */ + 0x00000101, /* DENALI_PI_84_DATA */ + 0x55555a5a, /* DENALI_PI_85_DATA */ + 0x55555a5a, /* DENALI_PI_86_DATA */ + 0x55555a5a, /* DENALI_PI_87_DATA */ + 0x55555a5a, /* DENALI_PI_88_DATA */ + 0x0b0a0001, /* DENALI_PI_89_DATA */ + 0x0505000a, /* DENALI_PI_90_DATA */ + 0x00000005, /* DENALI_PI_91_DATA */ + 0x00000100, /* DENALI_PI_92_DATA */ + 0x00030000, /* DENALI_PI_93_DATA */ + 0x17030000, /* DENALI_PI_94_DATA */ + 0x000e0020, /* DENALI_PI_95_DATA */ + 0x000a001c, /* DENALI_PI_96_DATA */ + 0x000e0020, /* DENALI_PI_97_DATA */ + 0x00000000, /* DENALI_PI_98_DATA */ + 0x00000000, /* DENALI_PI_99_DATA */ + 0x00000100, /* DENALI_PI_100_DATA */ + 0x140a0000, /* DENALI_PI_101_DATA */ + 0x000a030a, /* DENALI_PI_102_DATA */ + 0x03000a02, /* DENALI_PI_103_DATA */ + 0x010a000a, /* DENALI_PI_104_DATA */ + 0x00000100, /* DENALI_PI_105_DATA */ + 0x01000000, /* DENALI_PI_106_DATA */ + 0x00000000, /* DENALI_PI_107_DATA */ + 0x00000100, /* DENALI_PI_108_DATA */ + 0x1e1a0000, /* DENALI_PI_109_DATA */ + 0x10010204, /* DENALI_PI_110_DATA */ + 0x07060705, /* DENALI_PI_111_DATA */ + 0x20000202, /* DENALI_PI_112_DATA */ + 0x00201000, /* DENALI_PI_113_DATA */ + 0x00201000, /* DENALI_PI_114_DATA */ + 0x04041000, /* DENALI_PI_115_DATA */ + 0x0c100100, /* DENALI_PI_116_DATA */ + 0x00010110, /* DENALI_PI_117_DATA */ + 0x004b004a, /* DENALI_PI_118_DATA */ + 0x1a030000, /* DENALI_PI_119_DATA */ + 0x0102041e, /* DENALI_PI_120_DATA */ + 0x34000000, /* DENALI_PI_121_DATA */ + 0x00000000, /* DENALI_PI_122_DATA */ + 0x00000000, /* DENALI_PI_123_DATA */ + 0x00000000, /* DENALI_PI_124_DATA */ + 0x00004300, /* DENALI_PI_125_DATA */ + 0x0001001a, /* DENALI_PI_126_DATA */ + 0x004d4d07, /* DENALI_PI_127_DATA */ + 0x000a0083, /* DENALI_PI_128_DATA */ + 0x4d070001, /* DENALI_PI_129_DATA */ + 0x0000434d, /* DENALI_PI_130_DATA */ + 0x0001001a, /* DENALI_PI_131_DATA */ + 0x004d4d07, /* DENALI_PI_132_DATA */ + 0x001a0043, /* DENALI_PI_133_DATA */ + 0x4d070001, /* DENALI_PI_134_DATA */ + 0x0000834d, /* DENALI_PI_135_DATA */ + 0x0001000a, /* DENALI_PI_136_DATA */ + 0x004d4d07, /* DENALI_PI_137_DATA */ + 0x001a0043, /* DENALI_PI_138_DATA */ + 0x4d070001, /* DENALI_PI_139_DATA */ + 0x0043004d, /* DENALI_PI_140_DATA */ + 0x0001001a, /* DENALI_PI_141_DATA */ + 0x004d4d07, /* DENALI_PI_142_DATA */ + 0x000a0083, /* DENALI_PI_143_DATA */ + 0x4d070001, /* DENALI_PI_144_DATA */ + 0x0000434d, /* DENALI_PI_145_DATA */ + 0x0001001a, /* DENALI_PI_146_DATA */ + 0x004d4d07, /* DENALI_PI_147_DATA */ + 0x001a0043, /* DENALI_PI_148_DATA */ + 0x4d070001, /* DENALI_PI_149_DATA */ + 0x0000834d, /* DENALI_PI_150_DATA */ + 0x0001000a, /* DENALI_PI_151_DATA */ + 0x004d4d07, /* DENALI_PI_152_DATA */ + 0x001a0043, /* DENALI_PI_153_DATA */ + 0x4d070001, /* DENALI_PI_154_DATA */ + 0x0100004d, /* DENALI_PI_155_DATA */ + 0x006400c8, /* DENALI_PI_156_DATA */ + 0x060400c8, /* DENALI_PI_157_DATA */ + 0x0c060f11, /* DENALI_PI_158_DATA */ + 0x2200d890, /* DENALI_PI_159_DATA */ + 0x0a0c2005, /* DENALI_PI_160_DATA */ + 0x0809040a, /* DENALI_PI_161_DATA */ + 0x00000604, /* DENALI_PI_162_DATA */ + 0x11006c48, /* DENALI_PI_163_DATA */ + 0x0a062003, /* DENALI_PI_164_DATA */ + 0x0f11060a, /* DENALI_PI_165_DATA */ + 0x00000c06, /* DENALI_PI_166_DATA */ + 0x2200d890, /* DENALI_PI_167_DATA */ + 0x0a0c2005, /* DENALI_PI_168_DATA */ + 0x0200020a, /* DENALI_PI_169_DATA */ + 0x02000200, /* DENALI_PI_170_DATA */ + 0x02000200, /* DENALI_PI_171_DATA */ + 0x02000200, /* DENALI_PI_172_DATA */ + 0x02000200, /* DENALI_PI_173_DATA */ + 0x00000000, /* DENALI_PI_174_DATA */ + 0x00000000, /* DENALI_PI_175_DATA */ + 0x00000000, /* DENALI_PI_176_DATA */ + 0x00000000, /* DENALI_PI_177_DATA */ + 0x00000000, /* DENALI_PI_178_DATA */ + 0x00000000, /* DENALI_PI_179_DATA */ + 0x00000000, /* DENALI_PI_180_DATA */ + 0x00000000, /* DENALI_PI_181_DATA */ + 0x00000000, /* DENALI_PI_182_DATA */ + 0x00000000, /* DENALI_PI_183_DATA */ + 0x00000000, /* DENALI_PI_184_DATA */ + 0x00000000, /* DENALI_PI_185_DATA */ + 0x01000300, /* DENALI_PI_186_DATA */ + 0x00185000, /* DENALI_PI_187_DATA */ + 0x0000f320, /* DENALI_PI_188_DATA */ + 0x00000c20, /* DENALI_PI_189_DATA */ + 0x00007940, /* DENALI_PI_190_DATA */ + 0x00001850, /* DENALI_PI_191_DATA */ + 0x0000f320, /* DENALI_PI_192_DATA */ + 0x08000000, /* DENALI_PI_193_DATA */ + 0x00000100, /* DENALI_PI_194_DATA */ + 0x00000000, /* DENALI_PI_195_DATA */ + 0x00000000, /* DENALI_PI_196_DATA */ + 0x00000000, /* DENALI_PI_197_DATA */ + 0x00000000, /* DENALI_PI_198_DATA */ + 0x00000002 /* DENALI_PI_199_DATA */ + } + }, + { + { + 0x76543210, /* DENALI_PHY_00_DATA */ + 0x0004c008, /* DENALI_PHY_01_DATA */ + 0x000000b3, /* DENALI_PHY_02_DATA */ + 0x00000000, /* DENALI_PHY_03_DATA */ + 0x00000000, /* DENALI_PHY_04_DATA */ + 0x00010000, /* DENALI_PHY_05_DATA */ + 0x01665555, /* DENALI_PHY_06_DATA */ + 0x00665555, /* DENALI_PHY_07_DATA */ + 0x00010f00, /* DENALI_PHY_08_DATA */ + 0x05010200, /* DENALI_PHY_09_DATA */ + 0x00000003, /* DENALI_PHY_10_DATA */ + 0x001700c0, /* DENALI_PHY_11_DATA */ + 0x00cc0101, /* DENALI_PHY_12_DATA */ + 0x00030066, /* DENALI_PHY_13_DATA */ + 0x00000000, /* DENALI_PHY_14_DATA */ + 0x00000000, /* DENALI_PHY_15_DATA */ + 0x00000000, /* DENALI_PHY_16_DATA */ + 0x00000000, /* DENALI_PHY_17_DATA */ + 0x00000000, /* DENALI_PHY_18_DATA */ + 0x00000000, /* DENALI_PHY_19_DATA */ + 0x00000000, /* DENALI_PHY_20_DATA */ + 0x00000000, /* DENALI_PHY_21_DATA */ + 0x04080000, /* DENALI_PHY_22_DATA */ + 0x04080400, /* DENALI_PHY_23_DATA */ + 0x08000000, /* DENALI_PHY_24_DATA */ + 0x0c00c007, /* DENALI_PHY_25_DATA */ + 0x00000100, /* DENALI_PHY_26_DATA */ + 0x00000100, /* DENALI_PHY_27_DATA */ + 0x55555555, /* DENALI_PHY_28_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_29_DATA */ + 0x55555555, /* DENALI_PHY_30_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_31_DATA */ + 0x00005555, /* DENALI_PHY_32_DATA */ + 0x00000000, /* DENALI_PHY_33_DATA */ + 0x00000000, /* DENALI_PHY_34_DATA */ + 0x00000000, /* DENALI_PHY_35_DATA */ + 0x00000000, /* DENALI_PHY_36_DATA */ + 0x00000000, /* DENALI_PHY_37_DATA */ + 0x00000000, /* DENALI_PHY_38_DATA */ + 0x00000000, /* DENALI_PHY_39_DATA */ + 0x00000000, /* DENALI_PHY_40_DATA */ + 0x00000000, /* DENALI_PHY_41_DATA */ + 0x00000000, /* DENALI_PHY_42_DATA */ + 0x00000000, /* DENALI_PHY_43_DATA */ + 0x00000000, /* DENALI_PHY_44_DATA */ + 0x00000000, /* DENALI_PHY_45_DATA */ + 0x00000000, /* DENALI_PHY_46_DATA */ + 0x00000000, /* DENALI_PHY_47_DATA */ + 0x00000000, /* DENALI_PHY_48_DATA */ + 0x00000000, /* DENALI_PHY_49_DATA */ + 0x00000000, /* DENALI_PHY_50_DATA */ + 0x00000000, /* DENALI_PHY_51_DATA */ + 0x00200000, /* DENALI_PHY_52_DATA */ + 0x00000000, /* DENALI_PHY_53_DATA */ + 0x00000000, /* DENALI_PHY_54_DATA */ + 0x00000000, /* DENALI_PHY_55_DATA */ + 0x00000000, /* DENALI_PHY_56_DATA */ + 0x00000000, /* DENALI_PHY_57_DATA */ + 0x00000000, /* DENALI_PHY_58_DATA */ + 0x02800280, /* DENALI_PHY_59_DATA */ + 0x02800280, /* DENALI_PHY_60_DATA */ + 0x02800280, /* DENALI_PHY_61_DATA */ + 0x02800280, /* DENALI_PHY_62_DATA */ + 0x00000280, /* DENALI_PHY_63_DATA */ + 0x00000000, /* DENALI_PHY_64_DATA */ + 0x00000000, /* DENALI_PHY_65_DATA */ + 0x00000000, /* DENALI_PHY_66_DATA */ + 0x00000000, /* DENALI_PHY_67_DATA */ + 0x00800000, /* DENALI_PHY_68_DATA */ + 0x00800080, /* DENALI_PHY_69_DATA */ + 0x00800080, /* DENALI_PHY_70_DATA */ + 0x00800080, /* DENALI_PHY_71_DATA */ + 0x00800080, /* DENALI_PHY_72_DATA */ + 0x00800080, /* DENALI_PHY_73_DATA */ + 0x00800080, /* DENALI_PHY_74_DATA */ + 0x00800080, /* DENALI_PHY_75_DATA */ + 0x00800080, /* DENALI_PHY_76_DATA */ + 0x00b30080, /* DENALI_PHY_77_DATA */ + 0x01900003, /* DENALI_PHY_78_DATA */ + 0x00000000, /* DENALI_PHY_79_DATA */ + 0x00020000, /* DENALI_PHY_80_DATA */ + 0x00000200, /* DENALI_PHY_81_DATA */ + 0x00000000, /* DENALI_PHY_82_DATA */ + 0x51315152, /* DENALI_PHY_83_DATA */ + 0xc0013150, /* DENALI_PHY_84_DATA */ + 0x020000c0, /* DENALI_PHY_85_DATA */ + 0x00100001, /* DENALI_PHY_86_DATA */ + 0x0c054208, /* DENALI_PHY_87_DATA */ + 0x000f0c18, /* DENALI_PHY_88_DATA */ + 0x01000140, /* DENALI_PHY_89_DATA */ + 0x00000c20, /* DENALI_PHY_90_DATA */ + 0x00000000, /* DENALI_PHY_91_DATA */ + 0x00000000, /* DENALI_PHY_92_DATA */ + 0x00000000, /* DENALI_PHY_93_DATA */ + 0x00000000, /* DENALI_PHY_94_DATA */ + 0x00000000, /* DENALI_PHY_95_DATA */ + 0x00000000, /* DENALI_PHY_96_DATA */ + 0x00000000, /* DENALI_PHY_97_DATA */ + 0x00000000, /* DENALI_PHY_98_DATA */ + 0x00000000, /* DENALI_PHY_99_DATA */ + 0x00000000, /* DENALI_PHY_100_DATA */ + 0x00000000, /* DENALI_PHY_101_DATA */ + 0x00000000, /* DENALI_PHY_102_DATA */ + 0x00000000, /* DENALI_PHY_103_DATA */ + 0x00000000, /* DENALI_PHY_104_DATA */ + 0x00000000, /* DENALI_PHY_105_DATA */ + 0x00000000, /* DENALI_PHY_106_DATA */ + 0x00000000, /* DENALI_PHY_107_DATA */ + 0x00000000, /* DENALI_PHY_108_DATA */ + 0x00000000, /* DENALI_PHY_109_DATA */ + 0x00000000, /* DENALI_PHY_110_DATA */ + 0x00000000, /* DENALI_PHY_111_DATA */ + 0x00000000, /* DENALI_PHY_112_DATA */ + 0x00000000, /* DENALI_PHY_113_DATA */ + 0x00000000, /* DENALI_PHY_114_DATA */ + 0x00000000, /* DENALI_PHY_115_DATA */ + 0x00000000, /* DENALI_PHY_116_DATA */ + 0x00000000, /* DENALI_PHY_117_DATA */ + 0x00000000, /* DENALI_PHY_118_DATA */ + 0x00000000, /* DENALI_PHY_119_DATA */ + 0x00000000, /* DENALI_PHY_120_DATA */ + 0x00000000, /* DENALI_PHY_121_DATA */ + 0x00000000, /* DENALI_PHY_122_DATA */ + 0x00000000, /* DENALI_PHY_123_DATA */ + 0x00000000, /* DENALI_PHY_124_DATA */ + 0x00000000, /* DENALI_PHY_125_DATA */ + 0x00000000, /* DENALI_PHY_126_DATA */ + 0x00000000, /* DENALI_PHY_127_DATA */ + 0x76543210, /* DENALI_PHY_128_DATA */ + 0x0004c008, /* DENALI_PHY_129_DATA */ + 0x000000b3, /* DENALI_PHY_130_DATA */ + 0x00000000, /* DENALI_PHY_131_DATA */ + 0x00000000, /* DENALI_PHY_132_DATA */ + 0x00010000, /* DENALI_PHY_133_DATA */ + 0x01665555, /* DENALI_PHY_134_DATA */ + 0x00665555, /* DENALI_PHY_135_DATA */ + 0x00010f00, /* DENALI_PHY_136_DATA */ + 0x05010200, /* DENALI_PHY_137_DATA */ + 0x00000003, /* DENALI_PHY_138_DATA */ + 0x001700c0, /* DENALI_PHY_139_DATA */ + 0x00cc0101, /* DENALI_PHY_140_DATA */ + 0x00030066, /* DENALI_PHY_141_DATA */ + 0x00000000, /* DENALI_PHY_142_DATA */ + 0x00000000, /* DENALI_PHY_143_DATA */ + 0x00000000, /* DENALI_PHY_144_DATA */ + 0x00000000, /* DENALI_PHY_145_DATA */ + 0x00000000, /* DENALI_PHY_146_DATA */ + 0x00000000, /* DENALI_PHY_147_DATA */ + 0x00000000, /* DENALI_PHY_148_DATA */ + 0x00000000, /* DENALI_PHY_149_DATA */ + 0x04080000, /* DENALI_PHY_150_DATA */ + 0x04080400, /* DENALI_PHY_151_DATA */ + 0x08000000, /* DENALI_PHY_152_DATA */ + 0x0c00c007, /* DENALI_PHY_153_DATA */ + 0x00000100, /* DENALI_PHY_154_DATA */ + 0x00000100, /* DENALI_PHY_155_DATA */ + 0x55555555, /* DENALI_PHY_156_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_157_DATA */ + 0x55555555, /* DENALI_PHY_158_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_159_DATA */ + 0x00005555, /* DENALI_PHY_160_DATA */ + 0x00000000, /* DENALI_PHY_161_DATA */ + 0x00000000, /* DENALI_PHY_162_DATA */ + 0x00000000, /* DENALI_PHY_163_DATA */ + 0x00000000, /* DENALI_PHY_164_DATA */ + 0x00000000, /* DENALI_PHY_165_DATA */ + 0x00000000, /* DENALI_PHY_166_DATA */ + 0x00000000, /* DENALI_PHY_167_DATA */ + 0x00000000, /* DENALI_PHY_168_DATA */ + 0x00000000, /* DENALI_PHY_169_DATA */ + 0x00000000, /* DENALI_PHY_170_DATA */ + 0x00000000, /* DENALI_PHY_171_DATA */ + 0x00000000, /* DENALI_PHY_172_DATA */ + 0x00000000, /* DENALI_PHY_173_DATA */ + 0x00000000, /* DENALI_PHY_174_DATA */ + 0x00000000, /* DENALI_PHY_175_DATA */ + 0x00000000, /* DENALI_PHY_176_DATA */ + 0x00000000, /* DENALI_PHY_177_DATA */ + 0x00000000, /* DENALI_PHY_178_DATA */ + 0x00000000, /* DENALI_PHY_179_DATA */ + 0x00200000, /* DENALI_PHY_180_DATA */ + 0x00000000, /* DENALI_PHY_181_DATA */ + 0x00000000, /* DENALI_PHY_182_DATA */ + 0x00000000, /* DENALI_PHY_183_DATA */ + 0x00000000, /* DENALI_PHY_184_DATA */ + 0x00000000, /* DENALI_PHY_185_DATA */ + 0x00000000, /* DENALI_PHY_186_DATA */ + 0x02800280, /* DENALI_PHY_187_DATA */ + 0x02800280, /* DENALI_PHY_188_DATA */ + 0x02800280, /* DENALI_PHY_189_DATA */ + 0x02800280, /* DENALI_PHY_190_DATA */ + 0x00000280, /* DENALI_PHY_191_DATA */ + 0x00000000, /* DENALI_PHY_192_DATA */ + 0x00000000, /* DENALI_PHY_193_DATA */ + 0x00000000, /* DENALI_PHY_194_DATA */ + 0x00000000, /* DENALI_PHY_195_DATA */ + 0x00800000, /* DENALI_PHY_196_DATA */ + 0x00800080, /* DENALI_PHY_197_DATA */ + 0x00800080, /* DENALI_PHY_198_DATA */ + 0x00800080, /* DENALI_PHY_199_DATA */ + 0x00800080, /* DENALI_PHY_200_DATA */ + 0x00800080, /* DENALI_PHY_201_DATA */ + 0x00800080, /* DENALI_PHY_202_DATA */ + 0x00800080, /* DENALI_PHY_203_DATA */ + 0x00800080, /* DENALI_PHY_204_DATA */ + 0x00b30080, /* DENALI_PHY_205_DATA */ + 0x01900003, /* DENALI_PHY_206_DATA */ + 0x00000000, /* DENALI_PHY_207_DATA */ + 0x00020000, /* DENALI_PHY_208_DATA */ + 0x00000200, /* DENALI_PHY_209_DATA */ + 0x00000000, /* DENALI_PHY_210_DATA */ + 0x51315152, /* DENALI_PHY_211_DATA */ + 0xc0013150, /* DENALI_PHY_212_DATA */ + 0x020000c0, /* DENALI_PHY_213_DATA */ + 0x00100001, /* DENALI_PHY_214_DATA */ + 0x0c054208, /* DENALI_PHY_215_DATA */ + 0x000f0c18, /* DENALI_PHY_216_DATA */ + 0x01000140, /* DENALI_PHY_217_DATA */ + 0x00000c20, /* DENALI_PHY_218_DATA */ + 0x00000000, /* DENALI_PHY_219_DATA */ + 0x00000000, /* DENALI_PHY_220_DATA */ + 0x00000000, /* DENALI_PHY_221_DATA */ + 0x00000000, /* DENALI_PHY_222_DATA */ + 0x00000000, /* DENALI_PHY_223_DATA */ + 0x00000000, /* DENALI_PHY_224_DATA */ + 0x00000000, /* DENALI_PHY_225_DATA */ + 0x00000000, /* DENALI_PHY_226_DATA */ + 0x00000000, /* DENALI_PHY_227_DATA */ + 0x00000000, /* DENALI_PHY_228_DATA */ + 0x00000000, /* DENALI_PHY_229_DATA */ + 0x00000000, /* DENALI_PHY_230_DATA */ + 0x00000000, /* DENALI_PHY_231_DATA */ + 0x00000000, /* DENALI_PHY_232_DATA */ + 0x00000000, /* DENALI_PHY_233_DATA */ + 0x00000000, /* DENALI_PHY_234_DATA */ + 0x00000000, /* DENALI_PHY_235_DATA */ + 0x00000000, /* DENALI_PHY_236_DATA */ + 0x00000000, /* DENALI_PHY_237_DATA */ + 0x00000000, /* DENALI_PHY_238_DATA */ + 0x00000000, /* DENALI_PHY_239_DATA */ + 0x00000000, /* DENALI_PHY_240_DATA */ + 0x00000000, /* DENALI_PHY_241_DATA */ + 0x00000000, /* DENALI_PHY_242_DATA */ + 0x00000000, /* DENALI_PHY_243_DATA */ + 0x00000000, /* DENALI_PHY_244_DATA */ + 0x00000000, /* DENALI_PHY_245_DATA */ + 0x00000000, /* DENALI_PHY_246_DATA */ + 0x00000000, /* DENALI_PHY_247_DATA */ + 0x00000000, /* DENALI_PHY_248_DATA */ + 0x00000000, /* DENALI_PHY_249_DATA */ + 0x00000000, /* DENALI_PHY_250_DATA */ + 0x00000000, /* DENALI_PHY_251_DATA */ + 0x00000000, /* DENALI_PHY_252_DATA */ + 0x00000000, /* DENALI_PHY_253_DATA */ + 0x00000000, /* DENALI_PHY_254_DATA */ + 0x00000000, /* DENALI_PHY_255_DATA */ + 0x76543210, /* DENALI_PHY_256_DATA */ + 0x0004c008, /* DENALI_PHY_257_DATA */ + 0x000000b3, /* DENALI_PHY_258_DATA */ + 0x00000000, /* DENALI_PHY_259_DATA */ + 0x00000000, /* DENALI_PHY_260_DATA */ + 0x00010000, /* DENALI_PHY_261_DATA */ + 0x01665555, /* DENALI_PHY_262_DATA */ + 0x00665555, /* DENALI_PHY_263_DATA */ + 0x00010f00, /* DENALI_PHY_264_DATA */ + 0x05010200, /* DENALI_PHY_265_DATA */ + 0x00000003, /* DENALI_PHY_266_DATA */ + 0x001700c0, /* DENALI_PHY_267_DATA */ + 0x00cc0101, /* DENALI_PHY_268_DATA */ + 0x00030066, /* DENALI_PHY_269_DATA */ + 0x00000000, /* DENALI_PHY_270_DATA */ + 0x00000000, /* DENALI_PHY_271_DATA */ + 0x00000000, /* DENALI_PHY_272_DATA */ + 0x00000000, /* DENALI_PHY_273_DATA */ + 0x00000000, /* DENALI_PHY_274_DATA */ + 0x00000000, /* DENALI_PHY_275_DATA */ + 0x00000000, /* DENALI_PHY_276_DATA */ + 0x00000000, /* DENALI_PHY_277_DATA */ + 0x04080000, /* DENALI_PHY_278_DATA */ + 0x04080400, /* DENALI_PHY_279_DATA */ + 0x08000000, /* DENALI_PHY_280_DATA */ + 0x0c00c007, /* DENALI_PHY_281_DATA */ + 0x00000100, /* DENALI_PHY_282_DATA */ + 0x00000100, /* DENALI_PHY_283_DATA */ + 0x55555555, /* DENALI_PHY_284_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_285_DATA */ + 0x55555555, /* DENALI_PHY_286_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_287_DATA */ + 0x00005555, /* DENALI_PHY_288_DATA */ + 0x00000000, /* DENALI_PHY_289_DATA */ + 0x00000000, /* DENALI_PHY_290_DATA */ + 0x00000000, /* DENALI_PHY_291_DATA */ + 0x00000000, /* DENALI_PHY_292_DATA */ + 0x00000000, /* DENALI_PHY_293_DATA */ + 0x00000000, /* DENALI_PHY_294_DATA */ + 0x00000000, /* DENALI_PHY_295_DATA */ + 0x00000000, /* DENALI_PHY_296_DATA */ + 0x00000000, /* DENALI_PHY_297_DATA */ + 0x00000000, /* DENALI_PHY_298_DATA */ + 0x00000000, /* DENALI_PHY_299_DATA */ + 0x00000000, /* DENALI_PHY_300_DATA */ + 0x00000000, /* DENALI_PHY_301_DATA */ + 0x00000000, /* DENALI_PHY_302_DATA */ + 0x00000000, /* DENALI_PHY_303_DATA */ + 0x00000000, /* DENALI_PHY_304_DATA */ + 0x00000000, /* DENALI_PHY_305_DATA */ + 0x00000000, /* DENALI_PHY_306_DATA */ + 0x00000000, /* DENALI_PHY_307_DATA */ + 0x00200000, /* DENALI_PHY_308_DATA */ + 0x00000000, /* DENALI_PHY_309_DATA */ + 0x00000000, /* DENALI_PHY_310_DATA */ + 0x00000000, /* DENALI_PHY_311_DATA */ + 0x00000000, /* DENALI_PHY_312_DATA */ + 0x00000000, /* DENALI_PHY_313_DATA */ + 0x00000000, /* DENALI_PHY_314_DATA */ + 0x02800280, /* DENALI_PHY_315_DATA */ + 0x02800280, /* DENALI_PHY_316_DATA */ + 0x02800280, /* DENALI_PHY_317_DATA */ + 0x02800280, /* DENALI_PHY_318_DATA */ + 0x00000280, /* DENALI_PHY_319_DATA */ + 0x00000000, /* DENALI_PHY_320_DATA */ + 0x00000000, /* DENALI_PHY_321_DATA */ + 0x00000000, /* DENALI_PHY_322_DATA */ + 0x00000000, /* DENALI_PHY_323_DATA */ + 0x00800000, /* DENALI_PHY_324_DATA */ + 0x00800080, /* DENALI_PHY_325_DATA */ + 0x00800080, /* DENALI_PHY_326_DATA */ + 0x00800080, /* DENALI_PHY_327_DATA */ + 0x00800080, /* DENALI_PHY_328_DATA */ + 0x00800080, /* DENALI_PHY_329_DATA */ + 0x00800080, /* DENALI_PHY_330_DATA */ + 0x00800080, /* DENALI_PHY_331_DATA */ + 0x00800080, /* DENALI_PHY_332_DATA */ + 0x00b30080, /* DENALI_PHY_333_DATA */ + 0x01900003, /* DENALI_PHY_334_DATA */ + 0x00000000, /* DENALI_PHY_335_DATA */ + 0x00020000, /* DENALI_PHY_336_DATA */ + 0x00000200, /* DENALI_PHY_337_DATA */ + 0x00000000, /* DENALI_PHY_338_DATA */ + 0x51315152, /* DENALI_PHY_339_DATA */ + 0xc0013150, /* DENALI_PHY_340_DATA */ + 0x020000c0, /* DENALI_PHY_341_DATA */ + 0x00100001, /* DENALI_PHY_342_DATA */ + 0x0c054208, /* DENALI_PHY_343_DATA */ + 0x000f0c18, /* DENALI_PHY_344_DATA */ + 0x01000140, /* DENALI_PHY_345_DATA */ + 0x00000c20, /* DENALI_PHY_346_DATA */ + 0x00000000, /* DENALI_PHY_347_DATA */ + 0x00000000, /* DENALI_PHY_348_DATA */ + 0x00000000, /* DENALI_PHY_349_DATA */ + 0x00000000, /* DENALI_PHY_350_DATA */ + 0x00000000, /* DENALI_PHY_351_DATA */ + 0x00000000, /* DENALI_PHY_352_DATA */ + 0x00000000, /* DENALI_PHY_353_DATA */ + 0x00000000, /* DENALI_PHY_354_DATA */ + 0x00000000, /* DENALI_PHY_355_DATA */ + 0x00000000, /* DENALI_PHY_356_DATA */ + 0x00000000, /* DENALI_PHY_357_DATA */ + 0x00000000, /* DENALI_PHY_358_DATA */ + 0x00000000, /* DENALI_PHY_359_DATA */ + 0x00000000, /* DENALI_PHY_360_DATA */ + 0x00000000, /* DENALI_PHY_361_DATA */ + 0x00000000, /* DENALI_PHY_362_DATA */ + 0x00000000, /* DENALI_PHY_363_DATA */ + 0x00000000, /* DENALI_PHY_364_DATA */ + 0x00000000, /* DENALI_PHY_365_DATA */ + 0x00000000, /* DENALI_PHY_366_DATA */ + 0x00000000, /* DENALI_PHY_367_DATA */ + 0x00000000, /* DENALI_PHY_368_DATA */ + 0x00000000, /* DENALI_PHY_369_DATA */ + 0x00000000, /* DENALI_PHY_370_DATA */ + 0x00000000, /* DENALI_PHY_371_DATA */ + 0x00000000, /* DENALI_PHY_372_DATA */ + 0x00000000, /* DENALI_PHY_373_DATA */ + 0x00000000, /* DENALI_PHY_374_DATA */ + 0x00000000, /* DENALI_PHY_375_DATA */ + 0x00000000, /* DENALI_PHY_376_DATA */ + 0x00000000, /* DENALI_PHY_377_DATA */ + 0x00000000, /* DENALI_PHY_378_DATA */ + 0x00000000, /* DENALI_PHY_379_DATA */ + 0x00000000, /* DENALI_PHY_380_DATA */ + 0x00000000, /* DENALI_PHY_381_DATA */ + 0x00000000, /* DENALI_PHY_382_DATA */ + 0x00000000, /* DENALI_PHY_383_DATA */ + 0x76543210, /* DENALI_PHY_384_DATA */ + 0x0004c008, /* DENALI_PHY_385_DATA */ + 0x000000b3, /* DENALI_PHY_386_DATA */ + 0x00000000, /* DENALI_PHY_387_DATA */ + 0x00000000, /* DENALI_PHY_388_DATA */ + 0x00010000, /* DENALI_PHY_389_DATA */ + 0x01665555, /* DENALI_PHY_390_DATA */ + 0x00665555, /* DENALI_PHY_391_DATA */ + 0x00010f00, /* DENALI_PHY_392_DATA */ + 0x05010200, /* DENALI_PHY_393_DATA */ + 0x00000003, /* DENALI_PHY_394_DATA */ + 0x001700c0, /* DENALI_PHY_395_DATA */ + 0x00cc0101, /* DENALI_PHY_396_DATA */ + 0x00030066, /* DENALI_PHY_397_DATA */ + 0x00000000, /* DENALI_PHY_398_DATA */ + 0x00000000, /* DENALI_PHY_399_DATA */ + 0x00000000, /* DENALI_PHY_400_DATA */ + 0x00000000, /* DENALI_PHY_401_DATA */ + 0x00000000, /* DENALI_PHY_402_DATA */ + 0x00000000, /* DENALI_PHY_403_DATA */ + 0x00000000, /* DENALI_PHY_404_DATA */ + 0x00000000, /* DENALI_PHY_405_DATA */ + 0x04080000, /* DENALI_PHY_406_DATA */ + 0x04080400, /* DENALI_PHY_407_DATA */ + 0x08000000, /* DENALI_PHY_408_DATA */ + 0x0c00c007, /* DENALI_PHY_409_DATA */ + 0x00000100, /* DENALI_PHY_410_DATA */ + 0x00000100, /* DENALI_PHY_411_DATA */ + 0x55555555, /* DENALI_PHY_412_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_413_DATA */ + 0x55555555, /* DENALI_PHY_414_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_415_DATA */ + 0x00005555, /* DENALI_PHY_416_DATA */ + 0x00000000, /* DENALI_PHY_417_DATA */ + 0x00000000, /* DENALI_PHY_418_DATA */ + 0x00000000, /* DENALI_PHY_419_DATA */ + 0x00000000, /* DENALI_PHY_420_DATA */ + 0x00000000, /* DENALI_PHY_421_DATA */ + 0x00000000, /* DENALI_PHY_422_DATA */ + 0x00000000, /* DENALI_PHY_423_DATA */ + 0x00000000, /* DENALI_PHY_424_DATA */ + 0x00000000, /* DENALI_PHY_425_DATA */ + 0x00000000, /* DENALI_PHY_426_DATA */ + 0x00000000, /* DENALI_PHY_427_DATA */ + 0x00000000, /* DENALI_PHY_428_DATA */ + 0x00000000, /* DENALI_PHY_429_DATA */ + 0x00000000, /* DENALI_PHY_430_DATA */ + 0x00000000, /* DENALI_PHY_431_DATA */ + 0x00000000, /* DENALI_PHY_432_DATA */ + 0x00000000, /* DENALI_PHY_433_DATA */ + 0x00000000, /* DENALI_PHY_434_DATA */ + 0x00000000, /* DENALI_PHY_435_DATA */ + 0x00200000, /* DENALI_PHY_436_DATA */ + 0x00000000, /* DENALI_PHY_437_DATA */ + 0x00000000, /* DENALI_PHY_438_DATA */ + 0x00000000, /* DENALI_PHY_439_DATA */ + 0x00000000, /* DENALI_PHY_440_DATA */ + 0x00000000, /* DENALI_PHY_441_DATA */ + 0x00000000, /* DENALI_PHY_442_DATA */ + 0x02800280, /* DENALI_PHY_443_DATA */ + 0x02800280, /* DENALI_PHY_444_DATA */ + 0x02800280, /* DENALI_PHY_445_DATA */ + 0x02800280, /* DENALI_PHY_446_DATA */ + 0x00000280, /* DENALI_PHY_447_DATA */ + 0x00000000, /* DENALI_PHY_448_DATA */ + 0x00000000, /* DENALI_PHY_449_DATA */ + 0x00000000, /* DENALI_PHY_450_DATA */ + 0x00000000, /* DENALI_PHY_451_DATA */ + 0x00800000, /* DENALI_PHY_452_DATA */ + 0x00800080, /* DENALI_PHY_453_DATA */ + 0x00800080, /* DENALI_PHY_454_DATA */ + 0x00800080, /* DENALI_PHY_455_DATA */ + 0x00800080, /* DENALI_PHY_456_DATA */ + 0x00800080, /* DENALI_PHY_457_DATA */ + 0x00800080, /* DENALI_PHY_458_DATA */ + 0x00800080, /* DENALI_PHY_459_DATA */ + 0x00800080, /* DENALI_PHY_460_DATA */ + 0x00b30080, /* DENALI_PHY_461_DATA */ + 0x01900003, /* DENALI_PHY_462_DATA */ + 0x00000000, /* DENALI_PHY_463_DATA */ + 0x00020000, /* DENALI_PHY_464_DATA */ + 0x00000200, /* DENALI_PHY_465_DATA */ + 0x00000000, /* DENALI_PHY_466_DATA */ + 0x51315152, /* DENALI_PHY_467_DATA */ + 0xc0013150, /* DENALI_PHY_468_DATA */ + 0x020000c0, /* DENALI_PHY_469_DATA */ + 0x00100001, /* DENALI_PHY_470_DATA */ + 0x0c054208, /* DENALI_PHY_471_DATA */ + 0x000f0c18, /* DENALI_PHY_472_DATA */ + 0x01000140, /* DENALI_PHY_473_DATA */ + 0x00000c20, /* DENALI_PHY_474_DATA */ + 0x00000000, /* DENALI_PHY_475_DATA */ + 0x00000000, /* DENALI_PHY_476_DATA */ + 0x00000000, /* DENALI_PHY_477_DATA */ + 0x00000000, /* DENALI_PHY_478_DATA */ + 0x00000000, /* DENALI_PHY_479_DATA */ + 0x00000000, /* DENALI_PHY_480_DATA */ + 0x00000000, /* DENALI_PHY_481_DATA */ + 0x00000000, /* DENALI_PHY_482_DATA */ + 0x00000000, /* DENALI_PHY_483_DATA */ + 0x00000000, /* DENALI_PHY_484_DATA */ + 0x00000000, /* DENALI_PHY_485_DATA */ + 0x00000000, /* DENALI_PHY_486_DATA */ + 0x00000000, /* DENALI_PHY_487_DATA */ + 0x00000000, /* DENALI_PHY_488_DATA */ + 0x00000000, /* DENALI_PHY_489_DATA */ + 0x00000000, /* DENALI_PHY_490_DATA */ + 0x00000000, /* DENALI_PHY_491_DATA */ + 0x00000000, /* DENALI_PHY_492_DATA */ + 0x00000000, /* DENALI_PHY_493_DATA */ + 0x00000000, /* DENALI_PHY_494_DATA */ + 0x00000000, /* DENALI_PHY_495_DATA */ + 0x00000000, /* DENALI_PHY_496_DATA */ + 0x00000000, /* DENALI_PHY_497_DATA */ + 0x00000000, /* DENALI_PHY_498_DATA */ + 0x00000000, /* DENALI_PHY_499_DATA */ + 0x00000000, /* DENALI_PHY_500_DATA */ + 0x00000000, /* DENALI_PHY_501_DATA */ + 0x00000000, /* DENALI_PHY_502_DATA */ + 0x00000000, /* DENALI_PHY_503_DATA */ + 0x00000000, /* DENALI_PHY_504_DATA */ + 0x00000000, /* DENALI_PHY_505_DATA */ + 0x00000000, /* DENALI_PHY_506_DATA */ + 0x00000000, /* DENALI_PHY_507_DATA */ + 0x00000000, /* DENALI_PHY_508_DATA */ + 0x00000000, /* DENALI_PHY_509_DATA */ + 0x00000000, /* DENALI_PHY_510_DATA */ + 0x00000000, /* DENALI_PHY_511_DATA */ + 0x00000000, /* DENALI_PHY_512_DATA */ + 0x00800000, /* DENALI_PHY_513_DATA */ + 0x00000000, /* DENALI_PHY_514_DATA */ + 0x00000000, /* DENALI_PHY_515_DATA */ + 0x00000000, /* DENALI_PHY_516_DATA */ + 0x00000000, /* DENALI_PHY_517_DATA */ + 0x00000000, /* DENALI_PHY_518_DATA */ + 0x00000001, /* DENALI_PHY_519_DATA */ + 0x00000000, /* DENALI_PHY_520_DATA */ + 0x00000000, /* DENALI_PHY_521_DATA */ + 0x00000000, /* DENALI_PHY_522_DATA */ + 0x00400320, /* DENALI_PHY_523_DATA */ + 0x00000040, /* DENALI_PHY_524_DATA */ + 0x00806420, /* DENALI_PHY_525_DATA */ + 0x00917531, /* DENALI_PHY_526_DATA */ + 0x00806420, /* DENALI_PHY_527_DATA */ + 0x01917531, /* DENALI_PHY_528_DATA */ + 0x00020003, /* DENALI_PHY_529_DATA */ + 0x00000000, /* DENALI_PHY_530_DATA */ + 0x00000000, /* DENALI_PHY_531_DATA */ + 0x00000000, /* DENALI_PHY_532_DATA */ + 0x000556aa, /* DENALI_PHY_533_DATA */ + 0x000aaaaa, /* DENALI_PHY_534_DATA */ + 0x000aa955, /* DENALI_PHY_535_DATA */ + 0x00055555, /* DENALI_PHY_536_DATA */ + 0x000b3133, /* DENALI_PHY_537_DATA */ + 0x0004cd33, /* DENALI_PHY_538_DATA */ + 0x0004cecc, /* DENALI_PHY_539_DATA */ + 0x000b32cc, /* DENALI_PHY_540_DATA */ + 0x0a418820, /* DENALI_PHY_541_DATA */ + 0x103f0000, /* DENALI_PHY_542_DATA */ + 0x0000003f, /* DENALI_PHY_543_DATA */ + 0x00038055, /* DENALI_PHY_544_DATA */ + 0x03800380, /* DENALI_PHY_545_DATA */ + 0x03800380, /* DENALI_PHY_546_DATA */ + 0x00000380, /* DENALI_PHY_547_DATA */ + 0x42080010, /* DENALI_PHY_548_DATA */ + 0x00000003, /* DENALI_PHY_549_DATA */ + 0x00000000, /* DENALI_PHY_550_DATA */ + 0x00000000, /* DENALI_PHY_551_DATA */ + 0x00000000, /* DENALI_PHY_552_DATA */ + 0x00000000, /* DENALI_PHY_553_DATA */ + 0x00000000, /* DENALI_PHY_554_DATA */ + 0x00000000, /* DENALI_PHY_555_DATA */ + 0x00000000, /* DENALI_PHY_556_DATA */ + 0x00000000, /* DENALI_PHY_557_DATA */ + 0x00000000, /* DENALI_PHY_558_DATA */ + 0x00000000, /* DENALI_PHY_559_DATA */ + 0x00000000, /* DENALI_PHY_560_DATA */ + 0x00000000, /* DENALI_PHY_561_DATA */ + 0x00000000, /* DENALI_PHY_562_DATA */ + 0x00000000, /* DENALI_PHY_563_DATA */ + 0x00000000, /* DENALI_PHY_564_DATA */ + 0x00000000, /* DENALI_PHY_565_DATA */ + 0x00000000, /* DENALI_PHY_566_DATA */ + 0x00000000, /* DENALI_PHY_567_DATA */ + 0x00000000, /* DENALI_PHY_568_DATA */ + 0x00000000, /* DENALI_PHY_569_DATA */ + 0x00000000, /* DENALI_PHY_570_DATA */ + 0x00000000, /* DENALI_PHY_571_DATA */ + 0x00000000, /* DENALI_PHY_572_DATA */ + 0x00000000, /* DENALI_PHY_573_DATA */ + 0x00000000, /* DENALI_PHY_574_DATA */ + 0x00000000, /* DENALI_PHY_575_DATA */ + 0x00000000, /* DENALI_PHY_576_DATA */ + 0x00000000, /* DENALI_PHY_577_DATA */ + 0x00000000, /* DENALI_PHY_578_DATA */ + 0x00000000, /* DENALI_PHY_579_DATA */ + 0x00000000, /* DENALI_PHY_580_DATA */ + 0x00000000, /* DENALI_PHY_581_DATA */ + 0x00000000, /* DENALI_PHY_582_DATA */ + 0x00000000, /* DENALI_PHY_583_DATA */ + 0x00000000, /* DENALI_PHY_584_DATA */ + 0x00000000, /* DENALI_PHY_585_DATA */ + 0x00000000, /* DENALI_PHY_586_DATA */ + 0x00000000, /* DENALI_PHY_587_DATA */ + 0x00000000, /* DENALI_PHY_588_DATA */ + 0x00000000, /* DENALI_PHY_589_DATA */ + 0x00000000, /* DENALI_PHY_590_DATA */ + 0x00000000, /* DENALI_PHY_591_DATA */ + 0x00000000, /* DENALI_PHY_592_DATA */ + 0x00000000, /* DENALI_PHY_593_DATA */ + 0x00000000, /* DENALI_PHY_594_DATA */ + 0x00000000, /* DENALI_PHY_595_DATA */ + 0x00000000, /* DENALI_PHY_596_DATA */ + 0x00000000, /* DENALI_PHY_597_DATA */ + 0x00000000, /* DENALI_PHY_598_DATA */ + 0x00000000, /* DENALI_PHY_599_DATA */ + 0x00000000, /* DENALI_PHY_600_DATA */ + 0x00000000, /* DENALI_PHY_601_DATA */ + 0x00000000, /* DENALI_PHY_602_DATA */ + 0x00000000, /* DENALI_PHY_603_DATA */ + 0x00000000, /* DENALI_PHY_604_DATA */ + 0x00000000, /* DENALI_PHY_605_DATA */ + 0x00000000, /* DENALI_PHY_606_DATA */ + 0x00000000, /* DENALI_PHY_607_DATA */ + 0x00000000, /* DENALI_PHY_608_DATA */ + 0x00000000, /* DENALI_PHY_609_DATA */ + 0x00000000, /* DENALI_PHY_610_DATA */ + 0x00000000, /* DENALI_PHY_611_DATA */ + 0x00000000, /* DENALI_PHY_612_DATA */ + 0x00000000, /* DENALI_PHY_613_DATA */ + 0x00000000, /* DENALI_PHY_614_DATA */ + 0x00000000, /* DENALI_PHY_615_DATA */ + 0x00000000, /* DENALI_PHY_616_DATA */ + 0x00000000, /* DENALI_PHY_617_DATA */ + 0x00000000, /* DENALI_PHY_618_DATA */ + 0x00000000, /* DENALI_PHY_619_DATA */ + 0x00000000, /* DENALI_PHY_620_DATA */ + 0x00000000, /* DENALI_PHY_621_DATA */ + 0x00000000, /* DENALI_PHY_622_DATA */ + 0x00000000, /* DENALI_PHY_623_DATA */ + 0x00000000, /* DENALI_PHY_624_DATA */ + 0x00000000, /* DENALI_PHY_625_DATA */ + 0x00000000, /* DENALI_PHY_626_DATA */ + 0x00000000, /* DENALI_PHY_627_DATA */ + 0x00000000, /* DENALI_PHY_628_DATA */ + 0x00000000, /* DENALI_PHY_629_DATA */ + 0x00000000, /* DENALI_PHY_630_DATA */ + 0x00000000, /* DENALI_PHY_631_DATA */ + 0x00000000, /* DENALI_PHY_632_DATA */ + 0x00000000, /* DENALI_PHY_633_DATA */ + 0x00000000, /* DENALI_PHY_634_DATA */ + 0x00000000, /* DENALI_PHY_635_DATA */ + 0x00000000, /* DENALI_PHY_636_DATA */ + 0x00000000, /* DENALI_PHY_637_DATA */ + 0x00000000, /* DENALI_PHY_638_DATA */ + 0x00000000, /* DENALI_PHY_639_DATA */ + 0x00000000, /* DENALI_PHY_640_DATA */ + 0x00800000, /* DENALI_PHY_641_DATA */ + 0x00000000, /* DENALI_PHY_642_DATA */ + 0x00000000, /* DENALI_PHY_643_DATA */ + 0x00000000, /* DENALI_PHY_644_DATA */ + 0x00000000, /* DENALI_PHY_645_DATA */ + 0x00000000, /* DENALI_PHY_646_DATA */ + 0x00000001, /* DENALI_PHY_647_DATA */ + 0x00000000, /* DENALI_PHY_648_DATA */ + 0x00000000, /* DENALI_PHY_649_DATA */ + 0x00000000, /* DENALI_PHY_650_DATA */ + 0x00400320, /* DENALI_PHY_651_DATA */ + 0x00000040, /* DENALI_PHY_652_DATA */ + 0x00008eca, /* DENALI_PHY_653_DATA */ + 0x00009fdb, /* DENALI_PHY_654_DATA */ + 0x00008eca, /* DENALI_PHY_655_DATA */ + 0x01009fdb, /* DENALI_PHY_656_DATA */ + 0x00020003, /* DENALI_PHY_657_DATA */ + 0x00000000, /* DENALI_PHY_658_DATA */ + 0x00000000, /* DENALI_PHY_659_DATA */ + 0x00000000, /* DENALI_PHY_660_DATA */ + 0x000556aa, /* DENALI_PHY_661_DATA */ + 0x000aaaaa, /* DENALI_PHY_662_DATA */ + 0x000aa955, /* DENALI_PHY_663_DATA */ + 0x00055555, /* DENALI_PHY_664_DATA */ + 0x000b3133, /* DENALI_PHY_665_DATA */ + 0x0004cd33, /* DENALI_PHY_666_DATA */ + 0x0004cecc, /* DENALI_PHY_667_DATA */ + 0x000b32cc, /* DENALI_PHY_668_DATA */ + 0x0004a0e6, /* DENALI_PHY_669_DATA */ + 0x080f0000, /* DENALI_PHY_670_DATA */ + 0x0000000f, /* DENALI_PHY_671_DATA */ + 0x00038055, /* DENALI_PHY_672_DATA */ + 0x03800380, /* DENALI_PHY_673_DATA */ + 0x03800380, /* DENALI_PHY_674_DATA */ + 0x00000380, /* DENALI_PHY_675_DATA */ + 0x42080010, /* DENALI_PHY_676_DATA */ + 0x00000003, /* DENALI_PHY_677_DATA */ + 0x00000000, /* DENALI_PHY_678_DATA */ + 0x00000000, /* DENALI_PHY_679_DATA */ + 0x00000000, /* DENALI_PHY_680_DATA */ + 0x00000000, /* DENALI_PHY_681_DATA */ + 0x00000000, /* DENALI_PHY_682_DATA */ + 0x00000000, /* DENALI_PHY_683_DATA */ + 0x00000000, /* DENALI_PHY_684_DATA */ + 0x00000000, /* DENALI_PHY_685_DATA */ + 0x00000000, /* DENALI_PHY_686_DATA */ + 0x00000000, /* DENALI_PHY_687_DATA */ + 0x00000000, /* DENALI_PHY_688_DATA */ + 0x00000000, /* DENALI_PHY_689_DATA */ + 0x00000000, /* DENALI_PHY_690_DATA */ + 0x00000000, /* DENALI_PHY_691_DATA */ + 0x00000000, /* DENALI_PHY_692_DATA */ + 0x00000000, /* DENALI_PHY_693_DATA */ + 0x00000000, /* DENALI_PHY_694_DATA */ + 0x00000000, /* DENALI_PHY_695_DATA */ + 0x00000000, /* DENALI_PHY_696_DATA */ + 0x00000000, /* DENALI_PHY_697_DATA */ + 0x00000000, /* DENALI_PHY_698_DATA */ + 0x00000000, /* DENALI_PHY_699_DATA */ + 0x00000000, /* DENALI_PHY_700_DATA */ + 0x00000000, /* DENALI_PHY_701_DATA */ + 0x00000000, /* DENALI_PHY_702_DATA */ + 0x00000000, /* DENALI_PHY_703_DATA */ + 0x00000000, /* DENALI_PHY_704_DATA */ + 0x00000000, /* DENALI_PHY_705_DATA */ + 0x00000000, /* DENALI_PHY_706_DATA */ + 0x00000000, /* DENALI_PHY_707_DATA */ + 0x00000000, /* DENALI_PHY_708_DATA */ + 0x00000000, /* DENALI_PHY_709_DATA */ + 0x00000000, /* DENALI_PHY_710_DATA */ + 0x00000000, /* DENALI_PHY_711_DATA */ + 0x00000000, /* DENALI_PHY_712_DATA */ + 0x00000000, /* DENALI_PHY_713_DATA */ + 0x00000000, /* DENALI_PHY_714_DATA */ + 0x00000000, /* DENALI_PHY_715_DATA */ + 0x00000000, /* DENALI_PHY_716_DATA */ + 0x00000000, /* DENALI_PHY_717_DATA */ + 0x00000000, /* DENALI_PHY_718_DATA */ + 0x00000000, /* DENALI_PHY_719_DATA */ + 0x00000000, /* DENALI_PHY_720_DATA */ + 0x00000000, /* DENALI_PHY_721_DATA */ + 0x00000000, /* DENALI_PHY_722_DATA */ + 0x00000000, /* DENALI_PHY_723_DATA */ + 0x00000000, /* DENALI_PHY_724_DATA */ + 0x00000000, /* DENALI_PHY_725_DATA */ + 0x00000000, /* DENALI_PHY_726_DATA */ + 0x00000000, /* DENALI_PHY_727_DATA */ + 0x00000000, /* DENALI_PHY_728_DATA */ + 0x00000000, /* DENALI_PHY_729_DATA */ + 0x00000000, /* DENALI_PHY_730_DATA */ + 0x00000000, /* DENALI_PHY_731_DATA */ + 0x00000000, /* DENALI_PHY_732_DATA */ + 0x00000000, /* DENALI_PHY_733_DATA */ + 0x00000000, /* DENALI_PHY_734_DATA */ + 0x00000000, /* DENALI_PHY_735_DATA */ + 0x00000000, /* DENALI_PHY_736_DATA */ + 0x00000000, /* DENALI_PHY_737_DATA */ + 0x00000000, /* DENALI_PHY_738_DATA */ + 0x00000000, /* DENALI_PHY_739_DATA */ + 0x00000000, /* DENALI_PHY_740_DATA */ + 0x00000000, /* DENALI_PHY_741_DATA */ + 0x00000000, /* DENALI_PHY_742_DATA */ + 0x00000000, /* DENALI_PHY_743_DATA */ + 0x00000000, /* DENALI_PHY_744_DATA */ + 0x00000000, /* DENALI_PHY_745_DATA */ + 0x00000000, /* DENALI_PHY_746_DATA */ + 0x00000000, /* DENALI_PHY_747_DATA */ + 0x00000000, /* DENALI_PHY_748_DATA */ + 0x00000000, /* DENALI_PHY_749_DATA */ + 0x00000000, /* DENALI_PHY_750_DATA */ + 0x00000000, /* DENALI_PHY_751_DATA */ + 0x00000000, /* DENALI_PHY_752_DATA */ + 0x00000000, /* DENALI_PHY_753_DATA */ + 0x00000000, /* DENALI_PHY_754_DATA */ + 0x00000000, /* DENALI_PHY_755_DATA */ + 0x00000000, /* DENALI_PHY_756_DATA */ + 0x00000000, /* DENALI_PHY_757_DATA */ + 0x00000000, /* DENALI_PHY_758_DATA */ + 0x00000000, /* DENALI_PHY_759_DATA */ + 0x00000000, /* DENALI_PHY_760_DATA */ + 0x00000000, /* DENALI_PHY_761_DATA */ + 0x00000000, /* DENALI_PHY_762_DATA */ + 0x00000000, /* DENALI_PHY_763_DATA */ + 0x00000000, /* DENALI_PHY_764_DATA */ + 0x00000000, /* DENALI_PHY_765_DATA */ + 0x00000000, /* DENALI_PHY_766_DATA */ + 0x00000000, /* DENALI_PHY_767_DATA */ + 0x00000000, /* DENALI_PHY_768_DATA */ + 0x00800000, /* DENALI_PHY_769_DATA */ + 0x00000000, /* DENALI_PHY_770_DATA */ + 0x00000000, /* DENALI_PHY_771_DATA */ + 0x00000000, /* DENALI_PHY_772_DATA */ + 0x00000000, /* DENALI_PHY_773_DATA */ + 0x00000000, /* DENALI_PHY_774_DATA */ + 0x00000001, /* DENALI_PHY_775_DATA */ + 0x00000000, /* DENALI_PHY_776_DATA */ + 0x00000000, /* DENALI_PHY_777_DATA */ + 0x00000000, /* DENALI_PHY_778_DATA */ + 0x00400320, /* DENALI_PHY_779_DATA */ + 0x00000040, /* DENALI_PHY_780_DATA */ + 0x00008eca, /* DENALI_PHY_781_DATA */ + 0x00009fdb, /* DENALI_PHY_782_DATA */ + 0x00008eca, /* DENALI_PHY_783_DATA */ + 0x01009fdb, /* DENALI_PHY_784_DATA */ + 0x00020003, /* DENALI_PHY_785_DATA */ + 0x00000000, /* DENALI_PHY_786_DATA */ + 0x00000000, /* DENALI_PHY_787_DATA */ + 0x00000000, /* DENALI_PHY_788_DATA */ + 0x000556aa, /* DENALI_PHY_789_DATA */ + 0x000aaaaa, /* DENALI_PHY_790_DATA */ + 0x000aa955, /* DENALI_PHY_791_DATA */ + 0x00055555, /* DENALI_PHY_792_DATA */ + 0x000b3133, /* DENALI_PHY_793_DATA */ + 0x0004cd33, /* DENALI_PHY_794_DATA */ + 0x0004cecc, /* DENALI_PHY_795_DATA */ + 0x000b32cc, /* DENALI_PHY_796_DATA */ + 0x1ee6b16a, /* DENALI_PHY_797_DATA */ + 0x10000000, /* DENALI_PHY_798_DATA */ + 0x00000000, /* DENALI_PHY_799_DATA */ + 0x00038055, /* DENALI_PHY_800_DATA */ + 0x03800380, /* DENALI_PHY_801_DATA */ + 0x03800380, /* DENALI_PHY_802_DATA */ + 0x00000380, /* DENALI_PHY_803_DATA */ + 0x42080010, /* DENALI_PHY_804_DATA */ + 0x00000003, /* DENALI_PHY_805_DATA */ + 0x00000000, /* DENALI_PHY_806_DATA */ + 0x00000000, /* DENALI_PHY_807_DATA */ + 0x00000000, /* DENALI_PHY_808_DATA */ + 0x00000000, /* DENALI_PHY_809_DATA */ + 0x00000000, /* DENALI_PHY_810_DATA */ + 0x00000000, /* DENALI_PHY_811_DATA */ + 0x00000000, /* DENALI_PHY_812_DATA */ + 0x00000000, /* DENALI_PHY_813_DATA */ + 0x00000000, /* DENALI_PHY_814_DATA */ + 0x00000000, /* DENALI_PHY_815_DATA */ + 0x00000000, /* DENALI_PHY_816_DATA */ + 0x00000000, /* DENALI_PHY_817_DATA */ + 0x00000000, /* DENALI_PHY_818_DATA */ + 0x00000000, /* DENALI_PHY_819_DATA */ + 0x00000000, /* DENALI_PHY_820_DATA */ + 0x00000000, /* DENALI_PHY_821_DATA */ + 0x00000000, /* DENALI_PHY_822_DATA */ + 0x00000000, /* DENALI_PHY_823_DATA */ + 0x00000000, /* DENALI_PHY_824_DATA */ + 0x00000000, /* DENALI_PHY_825_DATA */ + 0x00000000, /* DENALI_PHY_826_DATA */ + 0x00000000, /* DENALI_PHY_827_DATA */ + 0x00000000, /* DENALI_PHY_828_DATA */ + 0x00000000, /* DENALI_PHY_829_DATA */ + 0x00000000, /* DENALI_PHY_830_DATA */ + 0x00000000, /* DENALI_PHY_831_DATA */ + 0x00000000, /* DENALI_PHY_832_DATA */ + 0x00000000, /* DENALI_PHY_833_DATA */ + 0x00000000, /* DENALI_PHY_834_DATA */ + 0x00000000, /* DENALI_PHY_835_DATA */ + 0x00000000, /* DENALI_PHY_836_DATA */ + 0x00000000, /* DENALI_PHY_837_DATA */ + 0x00000000, /* DENALI_PHY_838_DATA */ + 0x00000000, /* DENALI_PHY_839_DATA */ + 0x00000000, /* DENALI_PHY_840_DATA */ + 0x00000000, /* DENALI_PHY_841_DATA */ + 0x00000000, /* DENALI_PHY_842_DATA */ + 0x00000000, /* DENALI_PHY_843_DATA */ + 0x00000000, /* DENALI_PHY_844_DATA */ + 0x00000000, /* DENALI_PHY_845_DATA */ + 0x00000000, /* DENALI_PHY_846_DATA */ + 0x00000000, /* DENALI_PHY_847_DATA */ + 0x00000000, /* DENALI_PHY_848_DATA */ + 0x00000000, /* DENALI_PHY_849_DATA */ + 0x00000000, /* DENALI_PHY_850_DATA */ + 0x00000000, /* DENALI_PHY_851_DATA */ + 0x00000000, /* DENALI_PHY_852_DATA */ + 0x00000000, /* DENALI_PHY_853_DATA */ + 0x00000000, /* DENALI_PHY_854_DATA */ + 0x00000000, /* DENALI_PHY_855_DATA */ + 0x00000000, /* DENALI_PHY_856_DATA */ + 0x00000000, /* DENALI_PHY_857_DATA */ + 0x00000000, /* DENALI_PHY_858_DATA */ + 0x00000000, /* DENALI_PHY_859_DATA */ + 0x00000000, /* DENALI_PHY_860_DATA */ + 0x00000000, /* DENALI_PHY_861_DATA */ + 0x00000000, /* DENALI_PHY_862_DATA */ + 0x00000000, /* DENALI_PHY_863_DATA */ + 0x00000000, /* DENALI_PHY_864_DATA */ + 0x00000000, /* DENALI_PHY_865_DATA */ + 0x00000000, /* DENALI_PHY_866_DATA */ + 0x00000000, /* DENALI_PHY_867_DATA */ + 0x00000000, /* DENALI_PHY_868_DATA */ + 0x00000000, /* DENALI_PHY_869_DATA */ + 0x00000000, /* DENALI_PHY_870_DATA */ + 0x00000000, /* DENALI_PHY_871_DATA */ + 0x00000000, /* DENALI_PHY_872_DATA */ + 0x00000000, /* DENALI_PHY_873_DATA */ + 0x00000000, /* DENALI_PHY_874_DATA */ + 0x00000000, /* DENALI_PHY_875_DATA */ + 0x00000000, /* DENALI_PHY_876_DATA */ + 0x00000000, /* DENALI_PHY_877_DATA */ + 0x00000000, /* DENALI_PHY_878_DATA */ + 0x00000000, /* DENALI_PHY_879_DATA */ + 0x00000000, /* DENALI_PHY_880_DATA */ + 0x00000000, /* DENALI_PHY_881_DATA */ + 0x00000000, /* DENALI_PHY_882_DATA */ + 0x00000000, /* DENALI_PHY_883_DATA */ + 0x00000000, /* DENALI_PHY_884_DATA */ + 0x00000000, /* DENALI_PHY_885_DATA */ + 0x00000000, /* DENALI_PHY_886_DATA */ + 0x00000000, /* DENALI_PHY_887_DATA */ + 0x00000000, /* DENALI_PHY_888_DATA */ + 0x00000000, /* DENALI_PHY_889_DATA */ + 0x00000000, /* DENALI_PHY_890_DATA */ + 0x00000000, /* DENALI_PHY_891_DATA */ + 0x00000000, /* DENALI_PHY_892_DATA */ + 0x00000000, /* DENALI_PHY_893_DATA */ + 0x00000000, /* DENALI_PHY_894_DATA */ + 0x00000000, /* DENALI_PHY_895_DATA */ + 0x00000001, /* DENALI_PHY_896_DATA */ + 0x00000000, /* DENALI_PHY_897_DATA */ + 0x01000005, /* DENALI_PHY_898_DATA */ + 0x04000f00, /* DENALI_PHY_899_DATA */ + 0x00020040, /* DENALI_PHY_900_DATA */ + 0x00020055, /* DENALI_PHY_901_DATA */ + 0x00000000, /* DENALI_PHY_902_DATA */ + 0x00000000, /* DENALI_PHY_903_DATA */ + 0x00000000, /* DENALI_PHY_904_DATA */ + 0x00000050, /* DENALI_PHY_905_DATA */ + 0x00000000, /* DENALI_PHY_906_DATA */ + 0x00010100, /* DENALI_PHY_907_DATA */ + 0x00000601, /* DENALI_PHY_908_DATA */ + 0x00000000, /* DENALI_PHY_909_DATA */ + 0x00006400, /* DENALI_PHY_910_DATA */ + 0x01221102, /* DENALI_PHY_911_DATA */ + 0x00000000, /* DENALI_PHY_912_DATA */ + 0x00051f00, /* DENALI_PHY_913_DATA */ + 0x051f051f, /* DENALI_PHY_914_DATA */ + 0x051f051f, /* DENALI_PHY_915_DATA */ + 0x00030003, /* DENALI_PHY_916_DATA */ + 0x03000300, /* DENALI_PHY_917_DATA */ + 0x00000300, /* DENALI_PHY_918_DATA */ + 0x01221102, /* DENALI_PHY_919_DATA */ + 0x00000000, /* DENALI_PHY_920_DATA */ + 0x00000000, /* DENALI_PHY_921_DATA */ + 0x03020000, /* DENALI_PHY_922_DATA */ + 0x00000001, /* DENALI_PHY_923_DATA */ + 0x00000011, /* DENALI_PHY_924_DATA */ + 0x00000011, /* DENALI_PHY_925_DATA */ + 0x00000400, /* DENALI_PHY_926_DATA */ + 0x00000000, /* DENALI_PHY_927_DATA */ + 0x00000011, /* DENALI_PHY_928_DATA */ + 0x00000011, /* DENALI_PHY_929_DATA */ + 0x00004410, /* DENALI_PHY_930_DATA */ + 0x00004410, /* DENALI_PHY_931_DATA */ + 0x00004410, /* DENALI_PHY_932_DATA */ + 0x00004410, /* DENALI_PHY_933_DATA */ + 0x00004410, /* DENALI_PHY_934_DATA */ + 0x00000011, /* DENALI_PHY_935_DATA */ + 0x00004410, /* DENALI_PHY_936_DATA */ + 0x00000011, /* DENALI_PHY_937_DATA */ + 0x00004410, /* DENALI_PHY_938_DATA */ + 0x00000011, /* DENALI_PHY_939_DATA */ + 0x00004410, /* DENALI_PHY_940_DATA */ + 0x00000000, /* DENALI_PHY_941_DATA */ + 0x00000000, /* DENALI_PHY_942_DATA */ + 0x00000000, /* DENALI_PHY_943_DATA */ + 0x04000000, /* DENALI_PHY_944_DATA */ + 0x00000000, /* DENALI_PHY_945_DATA */ + 0x00000000, /* DENALI_PHY_946_DATA */ + 0x00000508, /* DENALI_PHY_947_DATA */ + 0x00000000, /* DENALI_PHY_948_DATA */ + 0x00000000, /* DENALI_PHY_949_DATA */ + 0x00000000, /* DENALI_PHY_950_DATA */ + 0x00000000, /* DENALI_PHY_951_DATA */ + 0x00000000, /* DENALI_PHY_952_DATA */ + 0x00000000, /* DENALI_PHY_953_DATA */ + 0xe4000000, /* DENALI_PHY_954_DATA */ + 0x00000000, /* DENALI_PHY_955_DATA */ + 0x00000000, /* DENALI_PHY_956_DATA */ + 0x01010000, /* DENALI_PHY_957_DATA */ + 0x00000000 /* DENALI_PHY_958_DATA */ + } + }, +}; diff --git a/src/mainboard/google/gru/sdram_inf/sdram-lpddr3-hynix-4GB-800-no-odt.inc b/src/mainboard/google/gru/sdram_inf/sdram-lpddr3-hynix-4GB-800-no-odt.inc deleted file mode 100644 index 4b02679..0000000 --- a/src/mainboard/google/gru/sdram_inf/sdram-lpddr3-hynix-4GB-800-no-odt.inc +++ /dev/null @@ -1,1563 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -{ - { - { - .rank = 0x2, - .col = 0xA, - .bk = 0x3, - .bw = 0x2, - .dbw = 0x2, - .row_3_4 = 0x0, - .cs0_row = 0xF, - .cs1_row = 0xF, - .ddrconfig = 1, - { - {0x1d191519}, - {0x14040808}, - {0x00000002}, - {0x00006226}, - {0x00000054}, - 0x00000000 - } - }, - { - .rank = 0x2, - .col = 0xA, - .bk = 0x3, - .bw = 0x2, - .dbw = 0x2, - .row_3_4 = 0x0, - .cs0_row = 0xF, - .cs1_row = 0xF, - .ddrconfig = 1, - { - {0x1d191519}, - {0x14040808}, - {0x00000002}, - {0x00006226}, - {0x00000054}, - 0x00000000 - } - } - }, - .ddr_freq = 800*MHz, - .dramtype = LPDDR3, - .num_channels = 2, - .stride = 13, - .odt = 1, - { - { - 0x00000700, /* DENALI_CTL_00_DATA */ - 0x00000000, /* DENALI_CTL_01_DATA */ - 0x00000000, /* DENALI_CTL_02_DATA */ - 0x00000000, /* DENALI_CTL_03_DATA */ - 0x00000000, /* DENALI_CTL_04_DATA */ - 0x00000050, /* DENALI_CTL_05_DATA */ - 0x00027100, /* DENALI_CTL_06_DATA */ - 0x00000320, /* DENALI_CTL_07_DATA */ - 0x00001f40, /* DENALI_CTL_08_DATA */ - 0x00000028, /* DENALI_CTL_09_DATA */ - 0x00013880, /* DENALI_CTL_10_DATA */ - 0x00000190, /* DENALI_CTL_11_DATA */ - 0x00000fa0, /* DENALI_CTL_12_DATA */ - 0x00000050, /* DENALI_CTL_13_DATA */ - 0x00027100, /* DENALI_CTL_14_DATA */ - 0x00000320, /* DENALI_CTL_15_DATA */ - 0x01001f40, /* DENALI_CTL_16_DATA */ - 0x00000000, /* DENALI_CTL_17_DATA */ - 0x00000101, /* DENALI_CTL_18_DATA */ - 0x00020100, /* DENALI_CTL_19_DATA */ - 0x000000a0, /* DENALI_CTL_20_DATA */ - 0x00000190, /* DENALI_CTL_21_DATA */ - 0x00000000, /* DENALI_CTL_22_DATA */ - 0x06180000, /* DENALI_CTL_23_DATA */ - 0x00061800, /* DENALI_CTL_24_DATA */ - 0x04000618, /* DENALI_CTL_25_DATA */ - 0x33080004, /* DENALI_CTL_26_DATA */ - 0x280f0622, /* DENALI_CTL_27_DATA */ - 0x111a0400, /* DENALI_CTL_28_DATA */ - 0x00140804, /* DENALI_CTL_29_DATA */ - 0x06223308, /* DENALI_CTL_30_DATA */ - 0x0600280f, /* DENALI_CTL_31_DATA */ - 0x00000a0a, /* DENALI_CTL_32_DATA */ - 0x0600dac0, /* DENALI_CTL_33_DATA */ - 0x0a0a040c, /* DENALI_CTL_34_DATA */ - 0x03006d60, /* DENALI_CTL_35_DATA */ - 0x0a0a0606, /* DENALI_CTL_36_DATA */ - 0x0600dac0, /* DENALI_CTL_37_DATA */ - 0x0203000c, /* DENALI_CTL_38_DATA */ - 0x080c0f00, /* DENALI_CTL_39_DATA */ - 0x040c0f06, /* DENALI_CTL_40_DATA */ - 0x14000a0a, /* DENALI_CTL_41_DATA */ - 0x02030a0a, /* DENALI_CTL_42_DATA */ - 0x00010003, /* DENALI_CTL_43_DATA */ - 0x031b0e1b, /* DENALI_CTL_44_DATA */ - 0x00110911, /* DENALI_CTL_45_DATA */ - 0x00000000, /* DENALI_CTL_46_DATA */ - 0x03010000, /* DENALI_CTL_47_DATA */ - 0x0c2800a8, /* DENALI_CTL_48_DATA */ - 0x06100054, /* DENALI_CTL_49_DATA */ - 0x0c2800a8, /* DENALI_CTL_50_DATA */ - 0x00000000, /* DENALI_CTL_51_DATA */ - 0x00030006, /* DENALI_CTL_52_DATA */ - 0x00140006, /* DENALI_CTL_53_DATA */ - 0x0014000a, /* DENALI_CTL_54_DATA */ - 0x000f080f, /* DENALI_CTL_55_DATA */ - 0x00000000, /* DENALI_CTL_56_DATA */ - 0x00000000, /* DENALI_CTL_57_DATA */ - 0x00000000, /* DENALI_CTL_58_DATA */ - 0x00b00000, /* DENALI_CTL_59_DATA */ - 0x005800b0, /* DENALI_CTL_60_DATA */ - 0x00b00058, /* DENALI_CTL_61_DATA */ - 0x000000b0, /* DENALI_CTL_62_DATA */ - 0x00000000, /* DENALI_CTL_63_DATA */ - 0x00000000, /* DENALI_CTL_64_DATA */ - 0x00000000, /* DENALI_CTL_65_DATA */ - 0x00000000, /* DENALI_CTL_66_DATA */ - 0x00000000, /* DENALI_CTL_67_DATA */ - 0x00000000, /* DENALI_CTL_68_DATA */ - 0x00000301, /* DENALI_CTL_69_DATA */ - 0x00000001, /* DENALI_CTL_70_DATA */ - 0x00000000, /* DENALI_CTL_71_DATA */ - 0x00000000, /* DENALI_CTL_72_DATA */ - 0x01000000, /* DENALI_CTL_73_DATA */ - 0x80104002, /* DENALI_CTL_74_DATA */ - 0x00040003, /* DENALI_CTL_75_DATA */ - 0x00040005, /* DENALI_CTL_76_DATA */ - 0x00030000, /* DENALI_CTL_77_DATA */ - 0x00050004, /* DENALI_CTL_78_DATA */ - 0x00000004, /* DENALI_CTL_79_DATA */ - 0x00040003, /* DENALI_CTL_80_DATA */ - 0x00040005, /* DENALI_CTL_81_DATA */ - 0x30a00000, /* DENALI_CTL_82_DATA */ - 0x00001850, /* DENALI_CTL_83_DATA */ - 0x0c201840, /* DENALI_CTL_84_DATA */ - 0x30a00000, /* DENALI_CTL_85_DATA */ - 0x00001850, /* DENALI_CTL_86_DATA */ - 0x00000000, /* DENALI_CTL_87_DATA */ - 0x00000000, /* DENALI_CTL_88_DATA */ - 0x00000000, /* DENALI_CTL_89_DATA */ - 0x00000000, /* DENALI_CTL_90_DATA */ - 0x00000000, /* DENALI_CTL_91_DATA */ - 0x02020200, /* DENALI_CTL_92_DATA */ - 0x00020202, /* DENALI_CTL_93_DATA */ - 0x00030200, /* DENALI_CTL_94_DATA */ - 0x00040700, /* DENALI_CTL_95_DATA */ - 0x00000302, /* DENALI_CTL_96_DATA */ - 0x02000407, /* DENALI_CTL_97_DATA */ - 0x00000003, /* DENALI_CTL_98_DATA */ - 0x00030f04, /* DENALI_CTL_99_DATA */ - 0x00070004, /* DENALI_CTL_100_DATA */ - 0x00000000, /* DENALI_CTL_101_DATA */ - 0x00000000, /* DENALI_CTL_102_DATA */ - 0x00000000, /* DENALI_CTL_103_DATA */ - 0x00000000, /* DENALI_CTL_104_DATA */ - 0x00000000, /* DENALI_CTL_105_DATA */ - 0x00000000, /* DENALI_CTL_106_DATA */ - 0x00000000, /* DENALI_CTL_107_DATA */ - 0x00010000, /* DENALI_CTL_108_DATA */ - 0x20040020, /* DENALI_CTL_109_DATA */ - 0x00200400, /* DENALI_CTL_110_DATA */ - 0x01000400, /* DENALI_CTL_111_DATA */ - 0x00000b80, /* DENALI_CTL_112_DATA */ - 0x00000000, /* DENALI_CTL_113_DATA */ - 0x00000001, /* DENALI_CTL_114_DATA */ - 0x00000002, /* DENALI_CTL_115_DATA */ - 0x0000000e, /* DENALI_CTL_116_DATA */ - 0x00000000, /* DENALI_CTL_117_DATA */ - 0x00000000, /* DENALI_CTL_118_DATA */ - 0x00000000, /* DENALI_CTL_119_DATA */ - 0x00000000, /* DENALI_CTL_120_DATA */ - 0x00000000, /* DENALI_CTL_121_DATA */ - 0x00a00000, /* DENALI_CTL_122_DATA */ - 0x00c80050, /* DENALI_CTL_123_DATA */ - 0x00c80000, /* DENALI_CTL_124_DATA */ - 0x00280050, /* DENALI_CTL_125_DATA */ - 0x00000064, /* DENALI_CTL_126_DATA */ - 0x00a00064, /* DENALI_CTL_127_DATA */ - 0x00c80050, /* DENALI_CTL_128_DATA */ - 0x00c80000, /* DENALI_CTL_129_DATA */ - 0x00000000, /* DENALI_CTL_130_DATA */ - 0x00000000, /* DENALI_CTL_131_DATA */ - 0x00000000, /* DENALI_CTL_132_DATA */ - 0x00430000, /* DENALI_CTL_133_DATA */ - 0x0000001a, /* DENALI_CTL_134_DATA */ - 0x000a0083, /* DENALI_CTL_135_DATA */ - 0x00430000, /* DENALI_CTL_136_DATA */ - 0x0000001a, /* DENALI_CTL_137_DATA */ - 0x00010001, /* DENALI_CTL_138_DATA */ - 0x07000001, /* DENALI_CTL_139_DATA */ - 0x00000707, /* DENALI_CTL_140_DATA */ - 0x00000000, /* DENALI_CTL_141_DATA */ - 0x00000000, /* DENALI_CTL_142_DATA */ - 0x00000000, /* DENALI_CTL_143_DATA */ - 0x00000000, /* DENALI_CTL_144_DATA */ - 0x00000000, /* DENALI_CTL_145_DATA */ - 0x00000000, /* DENALI_CTL_146_DATA */ - 0x00430000, /* DENALI_CTL_147_DATA */ - 0x0000001a, /* DENALI_CTL_148_DATA */ - 0x000a0083, /* DENALI_CTL_149_DATA */ - 0x00430000, /* DENALI_CTL_150_DATA */ - 0x0000001a, /* DENALI_CTL_151_DATA */ - 0x00010001, /* DENALI_CTL_152_DATA */ - 0x07000001, /* DENALI_CTL_153_DATA */ - 0x00000707, /* DENALI_CTL_154_DATA */ - 0x00000000, /* DENALI_CTL_155_DATA */ - 0x00000000, /* DENALI_CTL_156_DATA */ - 0x00000000, /* DENALI_CTL_157_DATA */ - 0x00000000, /* DENALI_CTL_158_DATA */ - 0x00000000, /* DENALI_CTL_159_DATA */ - 0x00000000, /* DENALI_CTL_160_DATA */ - 0x01000000, /* DENALI_CTL_161_DATA */ - 0x00000000, /* DENALI_CTL_162_DATA */ - 0x00000000, /* DENALI_CTL_163_DATA */ - 0x18151100, /* DENALI_CTL_164_DATA */ - 0x0000000c, /* DENALI_CTL_165_DATA */ - 0x00000000, /* DENALI_CTL_166_DATA */ - 0x00000000, /* DENALI_CTL_167_DATA */ - 0x00000000, /* DENALI_CTL_168_DATA */ - 0x00000000, /* DENALI_CTL_169_DATA */ - 0x00000000, /* DENALI_CTL_170_DATA */ - 0x00000000, /* DENALI_CTL_171_DATA */ - 0x00000000, /* DENALI_CTL_172_DATA */ - 0x00000000, /* DENALI_CTL_173_DATA */ - 0x00000000, /* DENALI_CTL_174_DATA */ - 0x00000000, /* DENALI_CTL_175_DATA */ - 0x00000000, /* DENALI_CTL_176_DATA */ - 0x00000000, /* DENALI_CTL_177_DATA */ - 0x00000000, /* DENALI_CTL_178_DATA */ - 0x00032003, /* DENALI_CTL_179_DATA */ - 0x00480120, /* DENALI_CTL_180_DATA */ - 0x00000000, /* DENALI_CTL_181_DATA */ - 0x00900190, /* DENALI_CTL_182_DATA */ - 0x00000024, /* DENALI_CTL_183_DATA */ - 0x00032000, /* DENALI_CTL_184_DATA */ - 0x00480120, /* DENALI_CTL_185_DATA */ - 0x00000000, /* DENALI_CTL_186_DATA */ - 0x00280000, /* DENALI_CTL_187_DATA */ - 0x00280014, /* DENALI_CTL_188_DATA */ - 0x01010100, /* DENALI_CTL_189_DATA */ - 0x01000202, /* DENALI_CTL_190_DATA */ - 0x0a000002, /* DENALI_CTL_191_DATA */ - 0x01000f0f, /* DENALI_CTL_192_DATA */ - 0x00000000, /* DENALI_CTL_193_DATA */ - 0x00000000, /* DENALI_CTL_194_DATA */ - 0x00010003, /* DENALI_CTL_195_DATA */ - 0x00000c03, /* DENALI_CTL_196_DATA */ - 0x00000100, /* DENALI_CTL_197_DATA */ - 0x00010000, /* DENALI_CTL_198_DATA */ - 0x01000000, /* DENALI_CTL_199_DATA */ - 0x00010000, /* DENALI_CTL_200_DATA */ - 0x00000001, /* DENALI_CTL_201_DATA */ - 0x00000000, /* DENALI_CTL_202_DATA */ - 0x00000000, /* DENALI_CTL_203_DATA */ - 0x00000000, /* DENALI_CTL_204_DATA */ - 0x00000000, /* DENALI_CTL_205_DATA */ - 0x00000000, /* DENALI_CTL_206_DATA */ - 0x00000000, /* DENALI_CTL_207_DATA */ - 0x00000000, /* DENALI_CTL_208_DATA */ - 0x00000000, /* DENALI_CTL_209_DATA */ - 0x00000000, /* DENALI_CTL_210_DATA */ - 0x00010000, /* DENALI_CTL_211_DATA */ - 0x03020301, /* DENALI_CTL_212_DATA */ - 0x01000808, /* DENALI_CTL_213_DATA */ - 0x04030001, /* DENALI_CTL_214_DATA */ - 0x0a0a0a03, /* DENALI_CTL_215_DATA */ - 0x02080808, /* DENALI_CTL_216_DATA */ - 0x02050103, /* DENALI_CTL_217_DATA */ - 0x02010103, /* DENALI_CTL_218_DATA */ - 0x00010103, /* DENALI_CTL_219_DATA */ - 0x00020202, /* DENALI_CTL_220_DATA */ - 0x03020500, /* DENALI_CTL_221_DATA */ - 0x00020501, /* DENALI_CTL_222_DATA */ - 0x00000000, /* DENALI_CTL_223_DATA */ - 0x00000000, /* DENALI_CTL_224_DATA */ - 0x0d000001, /* DENALI_CTL_225_DATA */ - 0x00010028, /* DENALI_CTL_226_DATA */ - 0x00010000, /* DENALI_CTL_227_DATA */ - 0x00000003, /* DENALI_CTL_228_DATA */ - 0x00000000, /* DENALI_CTL_229_DATA */ - 0x00000000, /* DENALI_CTL_230_DATA */ - 0x00000000, /* DENALI_CTL_231_DATA */ - 0x00000000, /* DENALI_CTL_232_DATA */ - 0x00000000, /* DENALI_CTL_233_DATA */ - 0x00000000, /* DENALI_CTL_234_DATA */ - 0x00000000, /* DENALI_CTL_235_DATA */ - 0x00000000, /* DENALI_CTL_236_DATA */ - 0x00010100, /* DENALI_CTL_237_DATA */ - 0x01000000, /* DENALI_CTL_238_DATA */ - 0x00000001, /* DENALI_CTL_239_DATA */ - 0x00000303, /* DENALI_CTL_240_DATA */ - 0x00000000, /* DENALI_CTL_241_DATA */ - 0x00000000, /* DENALI_CTL_242_DATA */ - 0x00000000, /* DENALI_CTL_243_DATA */ - 0x00000000, /* DENALI_CTL_244_DATA */ - 0x00000000, /* DENALI_CTL_245_DATA */ - 0x00000000, /* DENALI_CTL_246_DATA */ - 0x00000000, /* DENALI_CTL_247_DATA */ - 0x00000000, /* DENALI_CTL_248_DATA */ - 0x00000000, /* DENALI_CTL_249_DATA */ - 0x00000000, /* DENALI_CTL_250_DATA */ - 0x00000000, /* DENALI_CTL_251_DATA */ - 0x00000000, /* DENALI_CTL_252_DATA */ - 0x00000000, /* DENALI_CTL_253_DATA */ - 0x00000000, /* DENALI_CTL_254_DATA */ - 0x00000000, /* DENALI_CTL_255_DATA */ - 0x000556aa, /* DENALI_CTL_256_DATA */ - 0x000aaaaa, /* DENALI_CTL_257_DATA */ - 0x000aa955, /* DENALI_CTL_258_DATA */ - 0x00055555, /* DENALI_CTL_259_DATA */ - 0x000b3133, /* DENALI_CTL_260_DATA */ - 0x0004cd33, /* DENALI_CTL_261_DATA */ - 0x0004cecc, /* DENALI_CTL_262_DATA */ - 0x000b32cc, /* DENALI_CTL_263_DATA */ - 0x00010300, /* DENALI_CTL_264_DATA */ - 0x03000100, /* DENALI_CTL_265_DATA */ - 0x00000000, /* DENALI_CTL_266_DATA */ - 0x00000000, /* DENALI_CTL_267_DATA */ - 0x00000000, /* DENALI_CTL_268_DATA */ - 0x00000000, /* DENALI_CTL_269_DATA */ - 0x00000000, /* DENALI_CTL_270_DATA */ - 0x00000000, /* DENALI_CTL_271_DATA */ - 0x00000000, /* DENALI_CTL_272_DATA */ - 0x00000000, /* DENALI_CTL_273_DATA */ - 0x00ffff00, /* DENALI_CTL_274_DATA */ - 0x181e0000, /* DENALI_CTL_275_DATA */ - 0x0800001e, /* DENALI_CTL_276_DATA */ - 0x00001850, /* DENALI_CTL_277_DATA */ - 0x00000200, /* DENALI_CTL_278_DATA */ - 0x00000200, /* DENALI_CTL_279_DATA */ - 0x00000200, /* DENALI_CTL_280_DATA */ - 0x00000200, /* DENALI_CTL_281_DATA */ - 0x00001850, /* DENALI_CTL_282_DATA */ - 0x0000f320, /* DENALI_CTL_283_DATA */ - 0x0c20050a, /* DENALI_CTL_284_DATA */ - 0x00000200, /* DENALI_CTL_285_DATA */ - 0x00000200, /* DENALI_CTL_286_DATA */ - 0x00000200, /* DENALI_CTL_287_DATA */ - 0x00000200, /* DENALI_CTL_288_DATA */ - 0x00000c20, /* DENALI_CTL_289_DATA */ - 0x00007940, /* DENALI_CTL_290_DATA */ - 0x1850050b, /* DENALI_CTL_291_DATA */ - 0x00000200, /* DENALI_CTL_292_DATA */ - 0x00000200, /* DENALI_CTL_293_DATA */ - 0x00000200, /* DENALI_CTL_294_DATA */ - 0x00000200, /* DENALI_CTL_295_DATA */ - 0x00001850, /* DENALI_CTL_296_DATA */ - 0x0000f320, /* DENALI_CTL_297_DATA */ - 0x0202050a, /* DENALI_CTL_298_DATA */ - 0x03030202, /* DENALI_CTL_299_DATA */ - 0x00000018, /* DENALI_CTL_300_DATA */ - 0x00000000, /* DENALI_CTL_301_DATA */ - 0x00000000, /* DENALI_CTL_302_DATA */ - 0x00001403, /* DENALI_CTL_303_DATA */ - 0x00000000, /* DENALI_CTL_304_DATA */ - 0x00000000, /* DENALI_CTL_305_DATA */ - 0x00000000, /* DENALI_CTL_306_DATA */ - 0x00030000, /* DENALI_CTL_307_DATA */ - 0x000e0020, /* DENALI_CTL_308_DATA */ - 0x000a001c, /* DENALI_CTL_309_DATA */ - 0x000e0020, /* DENALI_CTL_310_DATA */ - 0x00000000, /* DENALI_CTL_311_DATA */ - 0x00000000, /* DENALI_CTL_312_DATA */ - 0x01000000, /* DENALI_CTL_313_DATA */ - 0x00070007, /* DENALI_CTL_314_DATA */ - 0x00050007, /* DENALI_CTL_315_DATA */ - 0x00000000, /* DENALI_CTL_316_DATA */ - 0x00000000, /* DENALI_CTL_317_DATA */ - 0x00000000, /* DENALI_CTL_318_DATA */ - 0x00000000, /* DENALI_CTL_319_DATA */ - 0x00000000, /* DENALI_CTL_320_DATA */ - 0x00000000, /* DENALI_CTL_321_DATA */ - 0x00000000, /* DENALI_CTL_322_DATA */ - 0x00000000, /* DENALI_CTL_323_DATA */ - 0x01000101, /* DENALI_CTL_324_DATA */ - 0x01010101, /* DENALI_CTL_325_DATA */ - 0x01000101, /* DENALI_CTL_326_DATA */ - 0x01000100, /* DENALI_CTL_327_DATA */ - 0x00010001, /* DENALI_CTL_328_DATA */ - 0x00010002, /* DENALI_CTL_329_DATA */ - 0x00020100, /* DENALI_CTL_330_DATA */ - 0x00000002 /* DENALI_CTL_331_DATA */ - } - }, - { - { - 0x00000700, /* DENALI_PI_00_DATA */ - 0x00000000, /* DENALI_PI_01_DATA */ - 0x000030a0, /* DENALI_PI_02_DATA */ - 0x00001850, /* DENALI_PI_03_DATA */ - 0x00001840, /* DENALI_PI_04_DATA */ - 0x00000c20, /* DENALI_PI_05_DATA */ - 0x000030a0, /* DENALI_PI_06_DATA */ - 0x18501850, /* DENALI_PI_07_DATA */ - 0x00000200, /* DENALI_PI_08_DATA */ - 0x00000200, /* DENALI_PI_09_DATA */ - 0x00000200, /* DENALI_PI_10_DATA */ - 0x00000200, /* DENALI_PI_11_DATA */ - 0x00000c20, /* DENALI_PI_12_DATA */ - 0x00000200, /* DENALI_PI_13_DATA */ - 0x00000200, /* DENALI_PI_14_DATA */ - 0x00000200, /* DENALI_PI_15_DATA */ - 0x00000200, /* DENALI_PI_16_DATA */ - 0x00001850, /* DENALI_PI_17_DATA */ - 0x00000200, /* DENALI_PI_18_DATA */ - 0x00000200, /* DENALI_PI_19_DATA */ - 0x00000200, /* DENALI_PI_20_DATA */ - 0x00000200, /* DENALI_PI_21_DATA */ - 0x00010000, /* DENALI_PI_22_DATA */ - 0x00000007, /* DENALI_PI_23_DATA */ - 0x81000001, /* DENALI_PI_24_DATA */ - 0x0f0003f0, /* DENALI_PI_25_DATA */ - 0x3fffffff, /* DENALI_PI_26_DATA */ - 0x0f0000a0, /* DENALI_PI_27_DATA */ - 0x377ff000, /* DENALI_PI_28_DATA */ - 0x0f000020, /* DENALI_PI_29_DATA */ - 0x377ff000, /* DENALI_PI_30_DATA */ - 0x0f000030, /* DENALI_PI_31_DATA */ - 0x377ff000, /* DENALI_PI_32_DATA */ - 0x0f0000b0, /* DENALI_PI_33_DATA */ - 0x377ff000, /* DENALI_PI_34_DATA */ - 0x0f000100, /* DENALI_PI_35_DATA */ - 0x377ff000, /* DENALI_PI_36_DATA */ - 0x0f000110, /* DENALI_PI_37_DATA */ - 0x377ff000, /* DENALI_PI_38_DATA */ - 0x0f000010, /* DENALI_PI_39_DATA */ - 0x377ff000, /* DENALI_PI_40_DATA */ - 0x03000101, /* DENALI_PI_41_DATA */ - 0x042e292e, /* DENALI_PI_42_DATA */ - 0x06180006, /* DENALI_PI_43_DATA */ - 0x00061800, /* DENALI_PI_44_DATA */ - 0x00000018, /* DENALI_PI_45_DATA */ - 0x0c2800a8, /* DENALI_PI_46_DATA */ - 0x06100054, /* DENALI_PI_47_DATA */ - 0x0c2800a8, /* DENALI_PI_48_DATA */ - 0x00000500, /* DENALI_PI_49_DATA */ - 0x00000000, /* DENALI_PI_50_DATA */ - 0x00000000, /* DENALI_PI_51_DATA */ - 0x00000000, /* DENALI_PI_52_DATA */ - 0x00000000, /* DENALI_PI_53_DATA */ - 0x00000000, /* DENALI_PI_54_DATA */ - 0x00000000, /* DENALI_PI_55_DATA */ - 0x00000000, /* DENALI_PI_56_DATA */ - 0x00000000, /* DENALI_PI_57_DATA */ - 0x04040000, /* DENALI_PI_58_DATA */ - 0x0d000004, /* DENALI_PI_59_DATA */ - 0x00000128, /* DENALI_PI_60_DATA */ - 0x00000000, /* DENALI_PI_61_DATA */ - 0x00030003, /* DENALI_PI_62_DATA */ - 0x00000018, /* DENALI_PI_63_DATA */ - 0x00000000, /* DENALI_PI_64_DATA */ - 0x00000000, /* DENALI_PI_65_DATA */ - 0x03060002, /* DENALI_PI_66_DATA */ - 0x03010201, /* DENALI_PI_67_DATA */ - 0x01080801, /* DENALI_PI_68_DATA */ - 0x04020201, /* DENALI_PI_69_DATA */ - 0x01080804, /* DENALI_PI_70_DATA */ - 0x00000000, /* DENALI_PI_71_DATA */ - 0x04030000, /* DENALI_PI_72_DATA */ - 0x0a0a0a03, /* DENALI_PI_73_DATA */ - 0x00000000, /* DENALI_PI_74_DATA */ - 0x00000000, /* DENALI_PI_75_DATA */ - 0x00000000, /* DENALI_PI_76_DATA */ - 0x00030300, /* DENALI_PI_77_DATA */ - 0x00000014, /* DENALI_PI_78_DATA */ - 0x00000000, /* DENALI_PI_79_DATA */ - 0x01010300, /* DENALI_PI_80_DATA */ - 0x00000000, /* DENALI_PI_81_DATA */ - 0x00000000, /* DENALI_PI_82_DATA */ - 0x01000000, /* DENALI_PI_83_DATA */ - 0x00000101, /* DENALI_PI_84_DATA */ - 0x55555a5a, /* DENALI_PI_85_DATA */ - 0x55555a5a, /* DENALI_PI_86_DATA */ - 0x55555a5a, /* DENALI_PI_87_DATA */ - 0x55555a5a, /* DENALI_PI_88_DATA */ - 0x0b0a0001, /* DENALI_PI_89_DATA */ - 0x0505000a, /* DENALI_PI_90_DATA */ - 0x00000005, /* DENALI_PI_91_DATA */ - 0x00000100, /* DENALI_PI_92_DATA */ - 0x00030000, /* DENALI_PI_93_DATA */ - 0x17030000, /* DENALI_PI_94_DATA */ - 0x000e0020, /* DENALI_PI_95_DATA */ - 0x000a001c, /* DENALI_PI_96_DATA */ - 0x000e0020, /* DENALI_PI_97_DATA */ - 0x00000000, /* DENALI_PI_98_DATA */ - 0x00000000, /* DENALI_PI_99_DATA */ - 0x00000100, /* DENALI_PI_100_DATA */ - 0x140a0000, /* DENALI_PI_101_DATA */ - 0x000a030a, /* DENALI_PI_102_DATA */ - 0x03000a02, /* DENALI_PI_103_DATA */ - 0x010a000a, /* DENALI_PI_104_DATA */ - 0x00000100, /* DENALI_PI_105_DATA */ - 0x01000000, /* DENALI_PI_106_DATA */ - 0x00000000, /* DENALI_PI_107_DATA */ - 0x00000100, /* DENALI_PI_108_DATA */ - 0x1e1a0000, /* DENALI_PI_109_DATA */ - 0x10010204, /* DENALI_PI_110_DATA */ - 0x07060705, /* DENALI_PI_111_DATA */ - 0x20000202, /* DENALI_PI_112_DATA */ - 0x00201000, /* DENALI_PI_113_DATA */ - 0x00201000, /* DENALI_PI_114_DATA */ - 0x04041000, /* DENALI_PI_115_DATA */ - 0x0c100100, /* DENALI_PI_116_DATA */ - 0x00010110, /* DENALI_PI_117_DATA */ - 0x004b004a, /* DENALI_PI_118_DATA */ - 0x1a030000, /* DENALI_PI_119_DATA */ - 0x0102041e, /* DENALI_PI_120_DATA */ - 0x34000000, /* DENALI_PI_121_DATA */ - 0x00000000, /* DENALI_PI_122_DATA */ - 0x00000000, /* DENALI_PI_123_DATA */ - 0x00000000, /* DENALI_PI_124_DATA */ - 0x00004300, /* DENALI_PI_125_DATA */ - 0x0001001a, /* DENALI_PI_126_DATA */ - 0x004d4d07, /* DENALI_PI_127_DATA */ - 0x000a0083, /* DENALI_PI_128_DATA */ - 0x4d070001, /* DENALI_PI_129_DATA */ - 0x0000434d, /* DENALI_PI_130_DATA */ - 0x0001001a, /* DENALI_PI_131_DATA */ - 0x004d4d07, /* DENALI_PI_132_DATA */ - 0x001a0043, /* DENALI_PI_133_DATA */ - 0x4d070001, /* DENALI_PI_134_DATA */ - 0x0000834d, /* DENALI_PI_135_DATA */ - 0x0001000a, /* DENALI_PI_136_DATA */ - 0x004d4d07, /* DENALI_PI_137_DATA */ - 0x001a0043, /* DENALI_PI_138_DATA */ - 0x4d070001, /* DENALI_PI_139_DATA */ - 0x0043004d, /* DENALI_PI_140_DATA */ - 0x0001001a, /* DENALI_PI_141_DATA */ - 0x004d4d07, /* DENALI_PI_142_DATA */ - 0x000a0083, /* DENALI_PI_143_DATA */ - 0x4d070001, /* DENALI_PI_144_DATA */ - 0x0000434d, /* DENALI_PI_145_DATA */ - 0x0001001a, /* DENALI_PI_146_DATA */ - 0x004d4d07, /* DENALI_PI_147_DATA */ - 0x001a0043, /* DENALI_PI_148_DATA */ - 0x4d070001, /* DENALI_PI_149_DATA */ - 0x0000834d, /* DENALI_PI_150_DATA */ - 0x0001000a, /* DENALI_PI_151_DATA */ - 0x004d4d07, /* DENALI_PI_152_DATA */ - 0x001a0043, /* DENALI_PI_153_DATA */ - 0x4d070001, /* DENALI_PI_154_DATA */ - 0x0100004d, /* DENALI_PI_155_DATA */ - 0x006400c8, /* DENALI_PI_156_DATA */ - 0x060400c8, /* DENALI_PI_157_DATA */ - 0x0c060f11, /* DENALI_PI_158_DATA */ - 0x2200d890, /* DENALI_PI_159_DATA */ - 0x0a0c2005, /* DENALI_PI_160_DATA */ - 0x0809040a, /* DENALI_PI_161_DATA */ - 0x00000604, /* DENALI_PI_162_DATA */ - 0x11006c48, /* DENALI_PI_163_DATA */ - 0x0a062003, /* DENALI_PI_164_DATA */ - 0x0f11060a, /* DENALI_PI_165_DATA */ - 0x00000c06, /* DENALI_PI_166_DATA */ - 0x2200d890, /* DENALI_PI_167_DATA */ - 0x0a0c2005, /* DENALI_PI_168_DATA */ - 0x0200020a, /* DENALI_PI_169_DATA */ - 0x02000200, /* DENALI_PI_170_DATA */ - 0x02000200, /* DENALI_PI_171_DATA */ - 0x02000200, /* DENALI_PI_172_DATA */ - 0x02000200, /* DENALI_PI_173_DATA */ - 0x00000000, /* DENALI_PI_174_DATA */ - 0x00000000, /* DENALI_PI_175_DATA */ - 0x00000000, /* DENALI_PI_176_DATA */ - 0x00000000, /* DENALI_PI_177_DATA */ - 0x00000000, /* DENALI_PI_178_DATA */ - 0x00000000, /* DENALI_PI_179_DATA */ - 0x00000000, /* DENALI_PI_180_DATA */ - 0x00000000, /* DENALI_PI_181_DATA */ - 0x00000000, /* DENALI_PI_182_DATA */ - 0x00000000, /* DENALI_PI_183_DATA */ - 0x00000000, /* DENALI_PI_184_DATA */ - 0x00000000, /* DENALI_PI_185_DATA */ - 0x01000300, /* DENALI_PI_186_DATA */ - 0x00185000, /* DENALI_PI_187_DATA */ - 0x0000f320, /* DENALI_PI_188_DATA */ - 0x00000c20, /* DENALI_PI_189_DATA */ - 0x00007940, /* DENALI_PI_190_DATA */ - 0x00001850, /* DENALI_PI_191_DATA */ - 0x0000f320, /* DENALI_PI_192_DATA */ - 0x08000000, /* DENALI_PI_193_DATA */ - 0x00000100, /* DENALI_PI_194_DATA */ - 0x00000000, /* DENALI_PI_195_DATA */ - 0x00000000, /* DENALI_PI_196_DATA */ - 0x00000000, /* DENALI_PI_197_DATA */ - 0x00000000, /* DENALI_PI_198_DATA */ - 0x00000002 /* DENALI_PI_199_DATA */ - } - }, - { - { - 0x76543210, /* DENALI_PHY_00_DATA */ - 0x0004c008, /* DENALI_PHY_01_DATA */ - 0x000000b3, /* DENALI_PHY_02_DATA */ - 0x00000000, /* DENALI_PHY_03_DATA */ - 0x00000000, /* DENALI_PHY_04_DATA */ - 0x00010000, /* DENALI_PHY_05_DATA */ - 0x01665555, /* DENALI_PHY_06_DATA */ - 0x00665555, /* DENALI_PHY_07_DATA */ - 0x00010f00, /* DENALI_PHY_08_DATA */ - 0x05010200, /* DENALI_PHY_09_DATA */ - 0x00000003, /* DENALI_PHY_10_DATA */ - 0x001700c0, /* DENALI_PHY_11_DATA */ - 0x00cc0101, /* DENALI_PHY_12_DATA */ - 0x00030066, /* DENALI_PHY_13_DATA */ - 0x00000000, /* DENALI_PHY_14_DATA */ - 0x00000000, /* DENALI_PHY_15_DATA */ - 0x00000000, /* DENALI_PHY_16_DATA */ - 0x00000000, /* DENALI_PHY_17_DATA */ - 0x00000000, /* DENALI_PHY_18_DATA */ - 0x00000000, /* DENALI_PHY_19_DATA */ - 0x00000000, /* DENALI_PHY_20_DATA */ - 0x00000000, /* DENALI_PHY_21_DATA */ - 0x04080000, /* DENALI_PHY_22_DATA */ - 0x04080400, /* DENALI_PHY_23_DATA */ - 0x08000000, /* DENALI_PHY_24_DATA */ - 0x0c00c007, /* DENALI_PHY_25_DATA */ - 0x00000100, /* DENALI_PHY_26_DATA */ - 0x00000100, /* DENALI_PHY_27_DATA */ - 0x55555555, /* DENALI_PHY_28_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_29_DATA */ - 0x55555555, /* DENALI_PHY_30_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_31_DATA */ - 0x00005555, /* DENALI_PHY_32_DATA */ - 0x00000000, /* DENALI_PHY_33_DATA */ - 0x00000000, /* DENALI_PHY_34_DATA */ - 0x00000000, /* DENALI_PHY_35_DATA */ - 0x00000000, /* DENALI_PHY_36_DATA */ - 0x00000000, /* DENALI_PHY_37_DATA */ - 0x00000000, /* DENALI_PHY_38_DATA */ - 0x00000000, /* DENALI_PHY_39_DATA */ - 0x00000000, /* DENALI_PHY_40_DATA */ - 0x00000000, /* DENALI_PHY_41_DATA */ - 0x00000000, /* DENALI_PHY_42_DATA */ - 0x00000000, /* DENALI_PHY_43_DATA */ - 0x00000000, /* DENALI_PHY_44_DATA */ - 0x00000000, /* DENALI_PHY_45_DATA */ - 0x00000000, /* DENALI_PHY_46_DATA */ - 0x00000000, /* DENALI_PHY_47_DATA */ - 0x00000000, /* DENALI_PHY_48_DATA */ - 0x00000000, /* DENALI_PHY_49_DATA */ - 0x00000000, /* DENALI_PHY_50_DATA */ - 0x00000000, /* DENALI_PHY_51_DATA */ - 0x00200000, /* DENALI_PHY_52_DATA */ - 0x00000000, /* DENALI_PHY_53_DATA */ - 0x00000000, /* DENALI_PHY_54_DATA */ - 0x00000000, /* DENALI_PHY_55_DATA */ - 0x00000000, /* DENALI_PHY_56_DATA */ - 0x00000000, /* DENALI_PHY_57_DATA */ - 0x00000000, /* DENALI_PHY_58_DATA */ - 0x02800280, /* DENALI_PHY_59_DATA */ - 0x02800280, /* DENALI_PHY_60_DATA */ - 0x02800280, /* DENALI_PHY_61_DATA */ - 0x02800280, /* DENALI_PHY_62_DATA */ - 0x00000280, /* DENALI_PHY_63_DATA */ - 0x00000000, /* DENALI_PHY_64_DATA */ - 0x00000000, /* DENALI_PHY_65_DATA */ - 0x00000000, /* DENALI_PHY_66_DATA */ - 0x00000000, /* DENALI_PHY_67_DATA */ - 0x00800000, /* DENALI_PHY_68_DATA */ - 0x00800080, /* DENALI_PHY_69_DATA */ - 0x00800080, /* DENALI_PHY_70_DATA */ - 0x00800080, /* DENALI_PHY_71_DATA */ - 0x00800080, /* DENALI_PHY_72_DATA */ - 0x00800080, /* DENALI_PHY_73_DATA */ - 0x00800080, /* DENALI_PHY_74_DATA */ - 0x00800080, /* DENALI_PHY_75_DATA */ - 0x00800080, /* DENALI_PHY_76_DATA */ - 0x00b30080, /* DENALI_PHY_77_DATA */ - 0x01900003, /* DENALI_PHY_78_DATA */ - 0x00000000, /* DENALI_PHY_79_DATA */ - 0x00020000, /* DENALI_PHY_80_DATA */ - 0x00000200, /* DENALI_PHY_81_DATA */ - 0x00000000, /* DENALI_PHY_82_DATA */ - 0x51315152, /* DENALI_PHY_83_DATA */ - 0xc0013150, /* DENALI_PHY_84_DATA */ - 0x020000c0, /* DENALI_PHY_85_DATA */ - 0x00100001, /* DENALI_PHY_86_DATA */ - 0x0c054208, /* DENALI_PHY_87_DATA */ - 0x000f0c18, /* DENALI_PHY_88_DATA */ - 0x01000140, /* DENALI_PHY_89_DATA */ - 0x00000c20, /* DENALI_PHY_90_DATA */ - 0x00000000, /* DENALI_PHY_91_DATA */ - 0x00000000, /* DENALI_PHY_92_DATA */ - 0x00000000, /* DENALI_PHY_93_DATA */ - 0x00000000, /* DENALI_PHY_94_DATA */ - 0x00000000, /* DENALI_PHY_95_DATA */ - 0x00000000, /* DENALI_PHY_96_DATA */ - 0x00000000, /* DENALI_PHY_97_DATA */ - 0x00000000, /* DENALI_PHY_98_DATA */ - 0x00000000, /* DENALI_PHY_99_DATA */ - 0x00000000, /* DENALI_PHY_100_DATA */ - 0x00000000, /* DENALI_PHY_101_DATA */ - 0x00000000, /* DENALI_PHY_102_DATA */ - 0x00000000, /* DENALI_PHY_103_DATA */ - 0x00000000, /* DENALI_PHY_104_DATA */ - 0x00000000, /* DENALI_PHY_105_DATA */ - 0x00000000, /* DENALI_PHY_106_DATA */ - 0x00000000, /* DENALI_PHY_107_DATA */ - 0x00000000, /* DENALI_PHY_108_DATA */ - 0x00000000, /* DENALI_PHY_109_DATA */ - 0x00000000, /* DENALI_PHY_110_DATA */ - 0x00000000, /* DENALI_PHY_111_DATA */ - 0x00000000, /* DENALI_PHY_112_DATA */ - 0x00000000, /* DENALI_PHY_113_DATA */ - 0x00000000, /* DENALI_PHY_114_DATA */ - 0x00000000, /* DENALI_PHY_115_DATA */ - 0x00000000, /* DENALI_PHY_116_DATA */ - 0x00000000, /* DENALI_PHY_117_DATA */ - 0x00000000, /* DENALI_PHY_118_DATA */ - 0x00000000, /* DENALI_PHY_119_DATA */ - 0x00000000, /* DENALI_PHY_120_DATA */ - 0x00000000, /* DENALI_PHY_121_DATA */ - 0x00000000, /* DENALI_PHY_122_DATA */ - 0x00000000, /* DENALI_PHY_123_DATA */ - 0x00000000, /* DENALI_PHY_124_DATA */ - 0x00000000, /* DENALI_PHY_125_DATA */ - 0x00000000, /* DENALI_PHY_126_DATA */ - 0x00000000, /* DENALI_PHY_127_DATA */ - 0x76543210, /* DENALI_PHY_128_DATA */ - 0x0004c008, /* DENALI_PHY_129_DATA */ - 0x000000b3, /* DENALI_PHY_130_DATA */ - 0x00000000, /* DENALI_PHY_131_DATA */ - 0x00000000, /* DENALI_PHY_132_DATA */ - 0x00010000, /* DENALI_PHY_133_DATA */ - 0x01665555, /* DENALI_PHY_134_DATA */ - 0x00665555, /* DENALI_PHY_135_DATA */ - 0x00010f00, /* DENALI_PHY_136_DATA */ - 0x05010200, /* DENALI_PHY_137_DATA */ - 0x00000003, /* DENALI_PHY_138_DATA */ - 0x001700c0, /* DENALI_PHY_139_DATA */ - 0x00cc0101, /* DENALI_PHY_140_DATA */ - 0x00030066, /* DENALI_PHY_141_DATA */ - 0x00000000, /* DENALI_PHY_142_DATA */ - 0x00000000, /* DENALI_PHY_143_DATA */ - 0x00000000, /* DENALI_PHY_144_DATA */ - 0x00000000, /* DENALI_PHY_145_DATA */ - 0x00000000, /* DENALI_PHY_146_DATA */ - 0x00000000, /* DENALI_PHY_147_DATA */ - 0x00000000, /* DENALI_PHY_148_DATA */ - 0x00000000, /* DENALI_PHY_149_DATA */ - 0x04080000, /* DENALI_PHY_150_DATA */ - 0x04080400, /* DENALI_PHY_151_DATA */ - 0x08000000, /* DENALI_PHY_152_DATA */ - 0x0c00c007, /* DENALI_PHY_153_DATA */ - 0x00000100, /* DENALI_PHY_154_DATA */ - 0x00000100, /* DENALI_PHY_155_DATA */ - 0x55555555, /* DENALI_PHY_156_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_157_DATA */ - 0x55555555, /* DENALI_PHY_158_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_159_DATA */ - 0x00005555, /* DENALI_PHY_160_DATA */ - 0x00000000, /* DENALI_PHY_161_DATA */ - 0x00000000, /* DENALI_PHY_162_DATA */ - 0x00000000, /* DENALI_PHY_163_DATA */ - 0x00000000, /* DENALI_PHY_164_DATA */ - 0x00000000, /* DENALI_PHY_165_DATA */ - 0x00000000, /* DENALI_PHY_166_DATA */ - 0x00000000, /* DENALI_PHY_167_DATA */ - 0x00000000, /* DENALI_PHY_168_DATA */ - 0x00000000, /* DENALI_PHY_169_DATA */ - 0x00000000, /* DENALI_PHY_170_DATA */ - 0x00000000, /* DENALI_PHY_171_DATA */ - 0x00000000, /* DENALI_PHY_172_DATA */ - 0x00000000, /* DENALI_PHY_173_DATA */ - 0x00000000, /* DENALI_PHY_174_DATA */ - 0x00000000, /* DENALI_PHY_175_DATA */ - 0x00000000, /* DENALI_PHY_176_DATA */ - 0x00000000, /* DENALI_PHY_177_DATA */ - 0x00000000, /* DENALI_PHY_178_DATA */ - 0x00000000, /* DENALI_PHY_179_DATA */ - 0x00200000, /* DENALI_PHY_180_DATA */ - 0x00000000, /* DENALI_PHY_181_DATA */ - 0x00000000, /* DENALI_PHY_182_DATA */ - 0x00000000, /* DENALI_PHY_183_DATA */ - 0x00000000, /* DENALI_PHY_184_DATA */ - 0x00000000, /* DENALI_PHY_185_DATA */ - 0x00000000, /* DENALI_PHY_186_DATA */ - 0x02800280, /* DENALI_PHY_187_DATA */ - 0x02800280, /* DENALI_PHY_188_DATA */ - 0x02800280, /* DENALI_PHY_189_DATA */ - 0x02800280, /* DENALI_PHY_190_DATA */ - 0x00000280, /* DENALI_PHY_191_DATA */ - 0x00000000, /* DENALI_PHY_192_DATA */ - 0x00000000, /* DENALI_PHY_193_DATA */ - 0x00000000, /* DENALI_PHY_194_DATA */ - 0x00000000, /* DENALI_PHY_195_DATA */ - 0x00800000, /* DENALI_PHY_196_DATA */ - 0x00800080, /* DENALI_PHY_197_DATA */ - 0x00800080, /* DENALI_PHY_198_DATA */ - 0x00800080, /* DENALI_PHY_199_DATA */ - 0x00800080, /* DENALI_PHY_200_DATA */ - 0x00800080, /* DENALI_PHY_201_DATA */ - 0x00800080, /* DENALI_PHY_202_DATA */ - 0x00800080, /* DENALI_PHY_203_DATA */ - 0x00800080, /* DENALI_PHY_204_DATA */ - 0x00b30080, /* DENALI_PHY_205_DATA */ - 0x01900003, /* DENALI_PHY_206_DATA */ - 0x00000000, /* DENALI_PHY_207_DATA */ - 0x00020000, /* DENALI_PHY_208_DATA */ - 0x00000200, /* DENALI_PHY_209_DATA */ - 0x00000000, /* DENALI_PHY_210_DATA */ - 0x51315152, /* DENALI_PHY_211_DATA */ - 0xc0013150, /* DENALI_PHY_212_DATA */ - 0x020000c0, /* DENALI_PHY_213_DATA */ - 0x00100001, /* DENALI_PHY_214_DATA */ - 0x0c054208, /* DENALI_PHY_215_DATA */ - 0x000f0c18, /* DENALI_PHY_216_DATA */ - 0x01000140, /* DENALI_PHY_217_DATA */ - 0x00000c20, /* DENALI_PHY_218_DATA */ - 0x00000000, /* DENALI_PHY_219_DATA */ - 0x00000000, /* DENALI_PHY_220_DATA */ - 0x00000000, /* DENALI_PHY_221_DATA */ - 0x00000000, /* DENALI_PHY_222_DATA */ - 0x00000000, /* DENALI_PHY_223_DATA */ - 0x00000000, /* DENALI_PHY_224_DATA */ - 0x00000000, /* DENALI_PHY_225_DATA */ - 0x00000000, /* DENALI_PHY_226_DATA */ - 0x00000000, /* DENALI_PHY_227_DATA */ - 0x00000000, /* DENALI_PHY_228_DATA */ - 0x00000000, /* DENALI_PHY_229_DATA */ - 0x00000000, /* DENALI_PHY_230_DATA */ - 0x00000000, /* DENALI_PHY_231_DATA */ - 0x00000000, /* DENALI_PHY_232_DATA */ - 0x00000000, /* DENALI_PHY_233_DATA */ - 0x00000000, /* DENALI_PHY_234_DATA */ - 0x00000000, /* DENALI_PHY_235_DATA */ - 0x00000000, /* DENALI_PHY_236_DATA */ - 0x00000000, /* DENALI_PHY_237_DATA */ - 0x00000000, /* DENALI_PHY_238_DATA */ - 0x00000000, /* DENALI_PHY_239_DATA */ - 0x00000000, /* DENALI_PHY_240_DATA */ - 0x00000000, /* DENALI_PHY_241_DATA */ - 0x00000000, /* DENALI_PHY_242_DATA */ - 0x00000000, /* DENALI_PHY_243_DATA */ - 0x00000000, /* DENALI_PHY_244_DATA */ - 0x00000000, /* DENALI_PHY_245_DATA */ - 0x00000000, /* DENALI_PHY_246_DATA */ - 0x00000000, /* DENALI_PHY_247_DATA */ - 0x00000000, /* DENALI_PHY_248_DATA */ - 0x00000000, /* DENALI_PHY_249_DATA */ - 0x00000000, /* DENALI_PHY_250_DATA */ - 0x00000000, /* DENALI_PHY_251_DATA */ - 0x00000000, /* DENALI_PHY_252_DATA */ - 0x00000000, /* DENALI_PHY_253_DATA */ - 0x00000000, /* DENALI_PHY_254_DATA */ - 0x00000000, /* DENALI_PHY_255_DATA */ - 0x76543210, /* DENALI_PHY_256_DATA */ - 0x0004c008, /* DENALI_PHY_257_DATA */ - 0x000000b3, /* DENALI_PHY_258_DATA */ - 0x00000000, /* DENALI_PHY_259_DATA */ - 0x00000000, /* DENALI_PHY_260_DATA */ - 0x00010000, /* DENALI_PHY_261_DATA */ - 0x01665555, /* DENALI_PHY_262_DATA */ - 0x00665555, /* DENALI_PHY_263_DATA */ - 0x00010f00, /* DENALI_PHY_264_DATA */ - 0x05010200, /* DENALI_PHY_265_DATA */ - 0x00000003, /* DENALI_PHY_266_DATA */ - 0x001700c0, /* DENALI_PHY_267_DATA */ - 0x00cc0101, /* DENALI_PHY_268_DATA */ - 0x00030066, /* DENALI_PHY_269_DATA */ - 0x00000000, /* DENALI_PHY_270_DATA */ - 0x00000000, /* DENALI_PHY_271_DATA */ - 0x00000000, /* DENALI_PHY_272_DATA */ - 0x00000000, /* DENALI_PHY_273_DATA */ - 0x00000000, /* DENALI_PHY_274_DATA */ - 0x00000000, /* DENALI_PHY_275_DATA */ - 0x00000000, /* DENALI_PHY_276_DATA */ - 0x00000000, /* DENALI_PHY_277_DATA */ - 0x04080000, /* DENALI_PHY_278_DATA */ - 0x04080400, /* DENALI_PHY_279_DATA */ - 0x08000000, /* DENALI_PHY_280_DATA */ - 0x0c00c007, /* DENALI_PHY_281_DATA */ - 0x00000100, /* DENALI_PHY_282_DATA */ - 0x00000100, /* DENALI_PHY_283_DATA */ - 0x55555555, /* DENALI_PHY_284_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_285_DATA */ - 0x55555555, /* DENALI_PHY_286_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_287_DATA */ - 0x00005555, /* DENALI_PHY_288_DATA */ - 0x00000000, /* DENALI_PHY_289_DATA */ - 0x00000000, /* DENALI_PHY_290_DATA */ - 0x00000000, /* DENALI_PHY_291_DATA */ - 0x00000000, /* DENALI_PHY_292_DATA */ - 0x00000000, /* DENALI_PHY_293_DATA */ - 0x00000000, /* DENALI_PHY_294_DATA */ - 0x00000000, /* DENALI_PHY_295_DATA */ - 0x00000000, /* DENALI_PHY_296_DATA */ - 0x00000000, /* DENALI_PHY_297_DATA */ - 0x00000000, /* DENALI_PHY_298_DATA */ - 0x00000000, /* DENALI_PHY_299_DATA */ - 0x00000000, /* DENALI_PHY_300_DATA */ - 0x00000000, /* DENALI_PHY_301_DATA */ - 0x00000000, /* DENALI_PHY_302_DATA */ - 0x00000000, /* DENALI_PHY_303_DATA */ - 0x00000000, /* DENALI_PHY_304_DATA */ - 0x00000000, /* DENALI_PHY_305_DATA */ - 0x00000000, /* DENALI_PHY_306_DATA */ - 0x00000000, /* DENALI_PHY_307_DATA */ - 0x00200000, /* DENALI_PHY_308_DATA */ - 0x00000000, /* DENALI_PHY_309_DATA */ - 0x00000000, /* DENALI_PHY_310_DATA */ - 0x00000000, /* DENALI_PHY_311_DATA */ - 0x00000000, /* DENALI_PHY_312_DATA */ - 0x00000000, /* DENALI_PHY_313_DATA */ - 0x00000000, /* DENALI_PHY_314_DATA */ - 0x02800280, /* DENALI_PHY_315_DATA */ - 0x02800280, /* DENALI_PHY_316_DATA */ - 0x02800280, /* DENALI_PHY_317_DATA */ - 0x02800280, /* DENALI_PHY_318_DATA */ - 0x00000280, /* DENALI_PHY_319_DATA */ - 0x00000000, /* DENALI_PHY_320_DATA */ - 0x00000000, /* DENALI_PHY_321_DATA */ - 0x00000000, /* DENALI_PHY_322_DATA */ - 0x00000000, /* DENALI_PHY_323_DATA */ - 0x00800000, /* DENALI_PHY_324_DATA */ - 0x00800080, /* DENALI_PHY_325_DATA */ - 0x00800080, /* DENALI_PHY_326_DATA */ - 0x00800080, /* DENALI_PHY_327_DATA */ - 0x00800080, /* DENALI_PHY_328_DATA */ - 0x00800080, /* DENALI_PHY_329_DATA */ - 0x00800080, /* DENALI_PHY_330_DATA */ - 0x00800080, /* DENALI_PHY_331_DATA */ - 0x00800080, /* DENALI_PHY_332_DATA */ - 0x00b30080, /* DENALI_PHY_333_DATA */ - 0x01900003, /* DENALI_PHY_334_DATA */ - 0x00000000, /* DENALI_PHY_335_DATA */ - 0x00020000, /* DENALI_PHY_336_DATA */ - 0x00000200, /* DENALI_PHY_337_DATA */ - 0x00000000, /* DENALI_PHY_338_DATA */ - 0x51315152, /* DENALI_PHY_339_DATA */ - 0xc0013150, /* DENALI_PHY_340_DATA */ - 0x020000c0, /* DENALI_PHY_341_DATA */ - 0x00100001, /* DENALI_PHY_342_DATA */ - 0x0c054208, /* DENALI_PHY_343_DATA */ - 0x000f0c18, /* DENALI_PHY_344_DATA */ - 0x01000140, /* DENALI_PHY_345_DATA */ - 0x00000c20, /* DENALI_PHY_346_DATA */ - 0x00000000, /* DENALI_PHY_347_DATA */ - 0x00000000, /* DENALI_PHY_348_DATA */ - 0x00000000, /* DENALI_PHY_349_DATA */ - 0x00000000, /* DENALI_PHY_350_DATA */ - 0x00000000, /* DENALI_PHY_351_DATA */ - 0x00000000, /* DENALI_PHY_352_DATA */ - 0x00000000, /* DENALI_PHY_353_DATA */ - 0x00000000, /* DENALI_PHY_354_DATA */ - 0x00000000, /* DENALI_PHY_355_DATA */ - 0x00000000, /* DENALI_PHY_356_DATA */ - 0x00000000, /* DENALI_PHY_357_DATA */ - 0x00000000, /* DENALI_PHY_358_DATA */ - 0x00000000, /* DENALI_PHY_359_DATA */ - 0x00000000, /* DENALI_PHY_360_DATA */ - 0x00000000, /* DENALI_PHY_361_DATA */ - 0x00000000, /* DENALI_PHY_362_DATA */ - 0x00000000, /* DENALI_PHY_363_DATA */ - 0x00000000, /* DENALI_PHY_364_DATA */ - 0x00000000, /* DENALI_PHY_365_DATA */ - 0x00000000, /* DENALI_PHY_366_DATA */ - 0x00000000, /* DENALI_PHY_367_DATA */ - 0x00000000, /* DENALI_PHY_368_DATA */ - 0x00000000, /* DENALI_PHY_369_DATA */ - 0x00000000, /* DENALI_PHY_370_DATA */ - 0x00000000, /* DENALI_PHY_371_DATA */ - 0x00000000, /* DENALI_PHY_372_DATA */ - 0x00000000, /* DENALI_PHY_373_DATA */ - 0x00000000, /* DENALI_PHY_374_DATA */ - 0x00000000, /* DENALI_PHY_375_DATA */ - 0x00000000, /* DENALI_PHY_376_DATA */ - 0x00000000, /* DENALI_PHY_377_DATA */ - 0x00000000, /* DENALI_PHY_378_DATA */ - 0x00000000, /* DENALI_PHY_379_DATA */ - 0x00000000, /* DENALI_PHY_380_DATA */ - 0x00000000, /* DENALI_PHY_381_DATA */ - 0x00000000, /* DENALI_PHY_382_DATA */ - 0x00000000, /* DENALI_PHY_383_DATA */ - 0x76543210, /* DENALI_PHY_384_DATA */ - 0x0004c008, /* DENALI_PHY_385_DATA */ - 0x000000b3, /* DENALI_PHY_386_DATA */ - 0x00000000, /* DENALI_PHY_387_DATA */ - 0x00000000, /* DENALI_PHY_388_DATA */ - 0x00010000, /* DENALI_PHY_389_DATA */ - 0x01665555, /* DENALI_PHY_390_DATA */ - 0x00665555, /* DENALI_PHY_391_DATA */ - 0x00010f00, /* DENALI_PHY_392_DATA */ - 0x05010200, /* DENALI_PHY_393_DATA */ - 0x00000003, /* DENALI_PHY_394_DATA */ - 0x001700c0, /* DENALI_PHY_395_DATA */ - 0x00cc0101, /* DENALI_PHY_396_DATA */ - 0x00030066, /* DENALI_PHY_397_DATA */ - 0x00000000, /* DENALI_PHY_398_DATA */ - 0x00000000, /* DENALI_PHY_399_DATA */ - 0x00000000, /* DENALI_PHY_400_DATA */ - 0x00000000, /* DENALI_PHY_401_DATA */ - 0x00000000, /* DENALI_PHY_402_DATA */ - 0x00000000, /* DENALI_PHY_403_DATA */ - 0x00000000, /* DENALI_PHY_404_DATA */ - 0x00000000, /* DENALI_PHY_405_DATA */ - 0x04080000, /* DENALI_PHY_406_DATA */ - 0x04080400, /* DENALI_PHY_407_DATA */ - 0x08000000, /* DENALI_PHY_408_DATA */ - 0x0c00c007, /* DENALI_PHY_409_DATA */ - 0x00000100, /* DENALI_PHY_410_DATA */ - 0x00000100, /* DENALI_PHY_411_DATA */ - 0x55555555, /* DENALI_PHY_412_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_413_DATA */ - 0x55555555, /* DENALI_PHY_414_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_415_DATA */ - 0x00005555, /* DENALI_PHY_416_DATA */ - 0x00000000, /* DENALI_PHY_417_DATA */ - 0x00000000, /* DENALI_PHY_418_DATA */ - 0x00000000, /* DENALI_PHY_419_DATA */ - 0x00000000, /* DENALI_PHY_420_DATA */ - 0x00000000, /* DENALI_PHY_421_DATA */ - 0x00000000, /* DENALI_PHY_422_DATA */ - 0x00000000, /* DENALI_PHY_423_DATA */ - 0x00000000, /* DENALI_PHY_424_DATA */ - 0x00000000, /* DENALI_PHY_425_DATA */ - 0x00000000, /* DENALI_PHY_426_DATA */ - 0x00000000, /* DENALI_PHY_427_DATA */ - 0x00000000, /* DENALI_PHY_428_DATA */ - 0x00000000, /* DENALI_PHY_429_DATA */ - 0x00000000, /* DENALI_PHY_430_DATA */ - 0x00000000, /* DENALI_PHY_431_DATA */ - 0x00000000, /* DENALI_PHY_432_DATA */ - 0x00000000, /* DENALI_PHY_433_DATA */ - 0x00000000, /* DENALI_PHY_434_DATA */ - 0x00000000, /* DENALI_PHY_435_DATA */ - 0x00200000, /* DENALI_PHY_436_DATA */ - 0x00000000, /* DENALI_PHY_437_DATA */ - 0x00000000, /* DENALI_PHY_438_DATA */ - 0x00000000, /* DENALI_PHY_439_DATA */ - 0x00000000, /* DENALI_PHY_440_DATA */ - 0x00000000, /* DENALI_PHY_441_DATA */ - 0x00000000, /* DENALI_PHY_442_DATA */ - 0x02800280, /* DENALI_PHY_443_DATA */ - 0x02800280, /* DENALI_PHY_444_DATA */ - 0x02800280, /* DENALI_PHY_445_DATA */ - 0x02800280, /* DENALI_PHY_446_DATA */ - 0x00000280, /* DENALI_PHY_447_DATA */ - 0x00000000, /* DENALI_PHY_448_DATA */ - 0x00000000, /* DENALI_PHY_449_DATA */ - 0x00000000, /* DENALI_PHY_450_DATA */ - 0x00000000, /* DENALI_PHY_451_DATA */ - 0x00800000, /* DENALI_PHY_452_DATA */ - 0x00800080, /* DENALI_PHY_453_DATA */ - 0x00800080, /* DENALI_PHY_454_DATA */ - 0x00800080, /* DENALI_PHY_455_DATA */ - 0x00800080, /* DENALI_PHY_456_DATA */ - 0x00800080, /* DENALI_PHY_457_DATA */ - 0x00800080, /* DENALI_PHY_458_DATA */ - 0x00800080, /* DENALI_PHY_459_DATA */ - 0x00800080, /* DENALI_PHY_460_DATA */ - 0x00b30080, /* DENALI_PHY_461_DATA */ - 0x01900003, /* DENALI_PHY_462_DATA */ - 0x00000000, /* DENALI_PHY_463_DATA */ - 0x00020000, /* DENALI_PHY_464_DATA */ - 0x00000200, /* DENALI_PHY_465_DATA */ - 0x00000000, /* DENALI_PHY_466_DATA */ - 0x51315152, /* DENALI_PHY_467_DATA */ - 0xc0013150, /* DENALI_PHY_468_DATA */ - 0x020000c0, /* DENALI_PHY_469_DATA */ - 0x00100001, /* DENALI_PHY_470_DATA */ - 0x0c054208, /* DENALI_PHY_471_DATA */ - 0x000f0c18, /* DENALI_PHY_472_DATA */ - 0x01000140, /* DENALI_PHY_473_DATA */ - 0x00000c20, /* DENALI_PHY_474_DATA */ - 0x00000000, /* DENALI_PHY_475_DATA */ - 0x00000000, /* DENALI_PHY_476_DATA */ - 0x00000000, /* DENALI_PHY_477_DATA */ - 0x00000000, /* DENALI_PHY_478_DATA */ - 0x00000000, /* DENALI_PHY_479_DATA */ - 0x00000000, /* DENALI_PHY_480_DATA */ - 0x00000000, /* DENALI_PHY_481_DATA */ - 0x00000000, /* DENALI_PHY_482_DATA */ - 0x00000000, /* DENALI_PHY_483_DATA */ - 0x00000000, /* DENALI_PHY_484_DATA */ - 0x00000000, /* DENALI_PHY_485_DATA */ - 0x00000000, /* DENALI_PHY_486_DATA */ - 0x00000000, /* DENALI_PHY_487_DATA */ - 0x00000000, /* DENALI_PHY_488_DATA */ - 0x00000000, /* DENALI_PHY_489_DATA */ - 0x00000000, /* DENALI_PHY_490_DATA */ - 0x00000000, /* DENALI_PHY_491_DATA */ - 0x00000000, /* DENALI_PHY_492_DATA */ - 0x00000000, /* DENALI_PHY_493_DATA */ - 0x00000000, /* DENALI_PHY_494_DATA */ - 0x00000000, /* DENALI_PHY_495_DATA */ - 0x00000000, /* DENALI_PHY_496_DATA */ - 0x00000000, /* DENALI_PHY_497_DATA */ - 0x00000000, /* DENALI_PHY_498_DATA */ - 0x00000000, /* DENALI_PHY_499_DATA */ - 0x00000000, /* DENALI_PHY_500_DATA */ - 0x00000000, /* DENALI_PHY_501_DATA */ - 0x00000000, /* DENALI_PHY_502_DATA */ - 0x00000000, /* DENALI_PHY_503_DATA */ - 0x00000000, /* DENALI_PHY_504_DATA */ - 0x00000000, /* DENALI_PHY_505_DATA */ - 0x00000000, /* DENALI_PHY_506_DATA */ - 0x00000000, /* DENALI_PHY_507_DATA */ - 0x00000000, /* DENALI_PHY_508_DATA */ - 0x00000000, /* DENALI_PHY_509_DATA */ - 0x00000000, /* DENALI_PHY_510_DATA */ - 0x00000000, /* DENALI_PHY_511_DATA */ - 0x00000000, /* DENALI_PHY_512_DATA */ - 0x00800000, /* DENALI_PHY_513_DATA */ - 0x00000000, /* DENALI_PHY_514_DATA */ - 0x00000000, /* DENALI_PHY_515_DATA */ - 0x00000000, /* DENALI_PHY_516_DATA */ - 0x00000000, /* DENALI_PHY_517_DATA */ - 0x00000000, /* DENALI_PHY_518_DATA */ - 0x00000001, /* DENALI_PHY_519_DATA */ - 0x00000000, /* DENALI_PHY_520_DATA */ - 0x00000000, /* DENALI_PHY_521_DATA */ - 0x00000000, /* DENALI_PHY_522_DATA */ - 0x00400320, /* DENALI_PHY_523_DATA */ - 0x00000040, /* DENALI_PHY_524_DATA */ - 0x00806420, /* DENALI_PHY_525_DATA */ - 0x00917531, /* DENALI_PHY_526_DATA */ - 0x00806420, /* DENALI_PHY_527_DATA */ - 0x01917531, /* DENALI_PHY_528_DATA */ - 0x00020003, /* DENALI_PHY_529_DATA */ - 0x00000000, /* DENALI_PHY_530_DATA */ - 0x00000000, /* DENALI_PHY_531_DATA */ - 0x00000000, /* DENALI_PHY_532_DATA */ - 0x000556aa, /* DENALI_PHY_533_DATA */ - 0x000aaaaa, /* DENALI_PHY_534_DATA */ - 0x000aa955, /* DENALI_PHY_535_DATA */ - 0x00055555, /* DENALI_PHY_536_DATA */ - 0x000b3133, /* DENALI_PHY_537_DATA */ - 0x0004cd33, /* DENALI_PHY_538_DATA */ - 0x0004cecc, /* DENALI_PHY_539_DATA */ - 0x000b32cc, /* DENALI_PHY_540_DATA */ - 0x0a418820, /* DENALI_PHY_541_DATA */ - 0x103f0000, /* DENALI_PHY_542_DATA */ - 0x0000003f, /* DENALI_PHY_543_DATA */ - 0x00038055, /* DENALI_PHY_544_DATA */ - 0x03800380, /* DENALI_PHY_545_DATA */ - 0x03800380, /* DENALI_PHY_546_DATA */ - 0x00000380, /* DENALI_PHY_547_DATA */ - 0x42080010, /* DENALI_PHY_548_DATA */ - 0x00000003, /* DENALI_PHY_549_DATA */ - 0x00000000, /* DENALI_PHY_550_DATA */ - 0x00000000, /* DENALI_PHY_551_DATA */ - 0x00000000, /* DENALI_PHY_552_DATA */ - 0x00000000, /* DENALI_PHY_553_DATA */ - 0x00000000, /* DENALI_PHY_554_DATA */ - 0x00000000, /* DENALI_PHY_555_DATA */ - 0x00000000, /* DENALI_PHY_556_DATA */ - 0x00000000, /* DENALI_PHY_557_DATA */ - 0x00000000, /* DENALI_PHY_558_DATA */ - 0x00000000, /* DENALI_PHY_559_DATA */ - 0x00000000, /* DENALI_PHY_560_DATA */ - 0x00000000, /* DENALI_PHY_561_DATA */ - 0x00000000, /* DENALI_PHY_562_DATA */ - 0x00000000, /* DENALI_PHY_563_DATA */ - 0x00000000, /* DENALI_PHY_564_DATA */ - 0x00000000, /* DENALI_PHY_565_DATA */ - 0x00000000, /* DENALI_PHY_566_DATA */ - 0x00000000, /* DENALI_PHY_567_DATA */ - 0x00000000, /* DENALI_PHY_568_DATA */ - 0x00000000, /* DENALI_PHY_569_DATA */ - 0x00000000, /* DENALI_PHY_570_DATA */ - 0x00000000, /* DENALI_PHY_571_DATA */ - 0x00000000, /* DENALI_PHY_572_DATA */ - 0x00000000, /* DENALI_PHY_573_DATA */ - 0x00000000, /* DENALI_PHY_574_DATA */ - 0x00000000, /* DENALI_PHY_575_DATA */ - 0x00000000, /* DENALI_PHY_576_DATA */ - 0x00000000, /* DENALI_PHY_577_DATA */ - 0x00000000, /* DENALI_PHY_578_DATA */ - 0x00000000, /* DENALI_PHY_579_DATA */ - 0x00000000, /* DENALI_PHY_580_DATA */ - 0x00000000, /* DENALI_PHY_581_DATA */ - 0x00000000, /* DENALI_PHY_582_DATA */ - 0x00000000, /* DENALI_PHY_583_DATA */ - 0x00000000, /* DENALI_PHY_584_DATA */ - 0x00000000, /* DENALI_PHY_585_DATA */ - 0x00000000, /* DENALI_PHY_586_DATA */ - 0x00000000, /* DENALI_PHY_587_DATA */ - 0x00000000, /* DENALI_PHY_588_DATA */ - 0x00000000, /* DENALI_PHY_589_DATA */ - 0x00000000, /* DENALI_PHY_590_DATA */ - 0x00000000, /* DENALI_PHY_591_DATA */ - 0x00000000, /* DENALI_PHY_592_DATA */ - 0x00000000, /* DENALI_PHY_593_DATA */ - 0x00000000, /* DENALI_PHY_594_DATA */ - 0x00000000, /* DENALI_PHY_595_DATA */ - 0x00000000, /* DENALI_PHY_596_DATA */ - 0x00000000, /* DENALI_PHY_597_DATA */ - 0x00000000, /* DENALI_PHY_598_DATA */ - 0x00000000, /* DENALI_PHY_599_DATA */ - 0x00000000, /* DENALI_PHY_600_DATA */ - 0x00000000, /* DENALI_PHY_601_DATA */ - 0x00000000, /* DENALI_PHY_602_DATA */ - 0x00000000, /* DENALI_PHY_603_DATA */ - 0x00000000, /* DENALI_PHY_604_DATA */ - 0x00000000, /* DENALI_PHY_605_DATA */ - 0x00000000, /* DENALI_PHY_606_DATA */ - 0x00000000, /* DENALI_PHY_607_DATA */ - 0x00000000, /* DENALI_PHY_608_DATA */ - 0x00000000, /* DENALI_PHY_609_DATA */ - 0x00000000, /* DENALI_PHY_610_DATA */ - 0x00000000, /* DENALI_PHY_611_DATA */ - 0x00000000, /* DENALI_PHY_612_DATA */ - 0x00000000, /* DENALI_PHY_613_DATA */ - 0x00000000, /* DENALI_PHY_614_DATA */ - 0x00000000, /* DENALI_PHY_615_DATA */ - 0x00000000, /* DENALI_PHY_616_DATA */ - 0x00000000, /* DENALI_PHY_617_DATA */ - 0x00000000, /* DENALI_PHY_618_DATA */ - 0x00000000, /* DENALI_PHY_619_DATA */ - 0x00000000, /* DENALI_PHY_620_DATA */ - 0x00000000, /* DENALI_PHY_621_DATA */ - 0x00000000, /* DENALI_PHY_622_DATA */ - 0x00000000, /* DENALI_PHY_623_DATA */ - 0x00000000, /* DENALI_PHY_624_DATA */ - 0x00000000, /* DENALI_PHY_625_DATA */ - 0x00000000, /* DENALI_PHY_626_DATA */ - 0x00000000, /* DENALI_PHY_627_DATA */ - 0x00000000, /* DENALI_PHY_628_DATA */ - 0x00000000, /* DENALI_PHY_629_DATA */ - 0x00000000, /* DENALI_PHY_630_DATA */ - 0x00000000, /* DENALI_PHY_631_DATA */ - 0x00000000, /* DENALI_PHY_632_DATA */ - 0x00000000, /* DENALI_PHY_633_DATA */ - 0x00000000, /* DENALI_PHY_634_DATA */ - 0x00000000, /* DENALI_PHY_635_DATA */ - 0x00000000, /* DENALI_PHY_636_DATA */ - 0x00000000, /* DENALI_PHY_637_DATA */ - 0x00000000, /* DENALI_PHY_638_DATA */ - 0x00000000, /* DENALI_PHY_639_DATA */ - 0x00000000, /* DENALI_PHY_640_DATA */ - 0x00800000, /* DENALI_PHY_641_DATA */ - 0x00000000, /* DENALI_PHY_642_DATA */ - 0x00000000, /* DENALI_PHY_643_DATA */ - 0x00000000, /* DENALI_PHY_644_DATA */ - 0x00000000, /* DENALI_PHY_645_DATA */ - 0x00000000, /* DENALI_PHY_646_DATA */ - 0x00000001, /* DENALI_PHY_647_DATA */ - 0x00000000, /* DENALI_PHY_648_DATA */ - 0x00000000, /* DENALI_PHY_649_DATA */ - 0x00000000, /* DENALI_PHY_650_DATA */ - 0x00400320, /* DENALI_PHY_651_DATA */ - 0x00000040, /* DENALI_PHY_652_DATA */ - 0x00008eca, /* DENALI_PHY_653_DATA */ - 0x00009fdb, /* DENALI_PHY_654_DATA */ - 0x00008eca, /* DENALI_PHY_655_DATA */ - 0x01009fdb, /* DENALI_PHY_656_DATA */ - 0x00020003, /* DENALI_PHY_657_DATA */ - 0x00000000, /* DENALI_PHY_658_DATA */ - 0x00000000, /* DENALI_PHY_659_DATA */ - 0x00000000, /* DENALI_PHY_660_DATA */ - 0x000556aa, /* DENALI_PHY_661_DATA */ - 0x000aaaaa, /* DENALI_PHY_662_DATA */ - 0x000aa955, /* DENALI_PHY_663_DATA */ - 0x00055555, /* DENALI_PHY_664_DATA */ - 0x000b3133, /* DENALI_PHY_665_DATA */ - 0x0004cd33, /* DENALI_PHY_666_DATA */ - 0x0004cecc, /* DENALI_PHY_667_DATA */ - 0x000b32cc, /* DENALI_PHY_668_DATA */ - 0x0004a0e6, /* DENALI_PHY_669_DATA */ - 0x080f0000, /* DENALI_PHY_670_DATA */ - 0x0000000f, /* DENALI_PHY_671_DATA */ - 0x00038055, /* DENALI_PHY_672_DATA */ - 0x03800380, /* DENALI_PHY_673_DATA */ - 0x03800380, /* DENALI_PHY_674_DATA */ - 0x00000380, /* DENALI_PHY_675_DATA */ - 0x42080010, /* DENALI_PHY_676_DATA */ - 0x00000003, /* DENALI_PHY_677_DATA */ - 0x00000000, /* DENALI_PHY_678_DATA */ - 0x00000000, /* DENALI_PHY_679_DATA */ - 0x00000000, /* DENALI_PHY_680_DATA */ - 0x00000000, /* DENALI_PHY_681_DATA */ - 0x00000000, /* DENALI_PHY_682_DATA */ - 0x00000000, /* DENALI_PHY_683_DATA */ - 0x00000000, /* DENALI_PHY_684_DATA */ - 0x00000000, /* DENALI_PHY_685_DATA */ - 0x00000000, /* DENALI_PHY_686_DATA */ - 0x00000000, /* DENALI_PHY_687_DATA */ - 0x00000000, /* DENALI_PHY_688_DATA */ - 0x00000000, /* DENALI_PHY_689_DATA */ - 0x00000000, /* DENALI_PHY_690_DATA */ - 0x00000000, /* DENALI_PHY_691_DATA */ - 0x00000000, /* DENALI_PHY_692_DATA */ - 0x00000000, /* DENALI_PHY_693_DATA */ - 0x00000000, /* DENALI_PHY_694_DATA */ - 0x00000000, /* DENALI_PHY_695_DATA */ - 0x00000000, /* DENALI_PHY_696_DATA */ - 0x00000000, /* DENALI_PHY_697_DATA */ - 0x00000000, /* DENALI_PHY_698_DATA */ - 0x00000000, /* DENALI_PHY_699_DATA */ - 0x00000000, /* DENALI_PHY_700_DATA */ - 0x00000000, /* DENALI_PHY_701_DATA */ - 0x00000000, /* DENALI_PHY_702_DATA */ - 0x00000000, /* DENALI_PHY_703_DATA */ - 0x00000000, /* DENALI_PHY_704_DATA */ - 0x00000000, /* DENALI_PHY_705_DATA */ - 0x00000000, /* DENALI_PHY_706_DATA */ - 0x00000000, /* DENALI_PHY_707_DATA */ - 0x00000000, /* DENALI_PHY_708_DATA */ - 0x00000000, /* DENALI_PHY_709_DATA */ - 0x00000000, /* DENALI_PHY_710_DATA */ - 0x00000000, /* DENALI_PHY_711_DATA */ - 0x00000000, /* DENALI_PHY_712_DATA */ - 0x00000000, /* DENALI_PHY_713_DATA */ - 0x00000000, /* DENALI_PHY_714_DATA */ - 0x00000000, /* DENALI_PHY_715_DATA */ - 0x00000000, /* DENALI_PHY_716_DATA */ - 0x00000000, /* DENALI_PHY_717_DATA */ - 0x00000000, /* DENALI_PHY_718_DATA */ - 0x00000000, /* DENALI_PHY_719_DATA */ - 0x00000000, /* DENALI_PHY_720_DATA */ - 0x00000000, /* DENALI_PHY_721_DATA */ - 0x00000000, /* DENALI_PHY_722_DATA */ - 0x00000000, /* DENALI_PHY_723_DATA */ - 0x00000000, /* DENALI_PHY_724_DATA */ - 0x00000000, /* DENALI_PHY_725_DATA */ - 0x00000000, /* DENALI_PHY_726_DATA */ - 0x00000000, /* DENALI_PHY_727_DATA */ - 0x00000000, /* DENALI_PHY_728_DATA */ - 0x00000000, /* DENALI_PHY_729_DATA */ - 0x00000000, /* DENALI_PHY_730_DATA */ - 0x00000000, /* DENALI_PHY_731_DATA */ - 0x00000000, /* DENALI_PHY_732_DATA */ - 0x00000000, /* DENALI_PHY_733_DATA */ - 0x00000000, /* DENALI_PHY_734_DATA */ - 0x00000000, /* DENALI_PHY_735_DATA */ - 0x00000000, /* DENALI_PHY_736_DATA */ - 0x00000000, /* DENALI_PHY_737_DATA */ - 0x00000000, /* DENALI_PHY_738_DATA */ - 0x00000000, /* DENALI_PHY_739_DATA */ - 0x00000000, /* DENALI_PHY_740_DATA */ - 0x00000000, /* DENALI_PHY_741_DATA */ - 0x00000000, /* DENALI_PHY_742_DATA */ - 0x00000000, /* DENALI_PHY_743_DATA */ - 0x00000000, /* DENALI_PHY_744_DATA */ - 0x00000000, /* DENALI_PHY_745_DATA */ - 0x00000000, /* DENALI_PHY_746_DATA */ - 0x00000000, /* DENALI_PHY_747_DATA */ - 0x00000000, /* DENALI_PHY_748_DATA */ - 0x00000000, /* DENALI_PHY_749_DATA */ - 0x00000000, /* DENALI_PHY_750_DATA */ - 0x00000000, /* DENALI_PHY_751_DATA */ - 0x00000000, /* DENALI_PHY_752_DATA */ - 0x00000000, /* DENALI_PHY_753_DATA */ - 0x00000000, /* DENALI_PHY_754_DATA */ - 0x00000000, /* DENALI_PHY_755_DATA */ - 0x00000000, /* DENALI_PHY_756_DATA */ - 0x00000000, /* DENALI_PHY_757_DATA */ - 0x00000000, /* DENALI_PHY_758_DATA */ - 0x00000000, /* DENALI_PHY_759_DATA */ - 0x00000000, /* DENALI_PHY_760_DATA */ - 0x00000000, /* DENALI_PHY_761_DATA */ - 0x00000000, /* DENALI_PHY_762_DATA */ - 0x00000000, /* DENALI_PHY_763_DATA */ - 0x00000000, /* DENALI_PHY_764_DATA */ - 0x00000000, /* DENALI_PHY_765_DATA */ - 0x00000000, /* DENALI_PHY_766_DATA */ - 0x00000000, /* DENALI_PHY_767_DATA */ - 0x00000000, /* DENALI_PHY_768_DATA */ - 0x00800000, /* DENALI_PHY_769_DATA */ - 0x00000000, /* DENALI_PHY_770_DATA */ - 0x00000000, /* DENALI_PHY_771_DATA */ - 0x00000000, /* DENALI_PHY_772_DATA */ - 0x00000000, /* DENALI_PHY_773_DATA */ - 0x00000000, /* DENALI_PHY_774_DATA */ - 0x00000001, /* DENALI_PHY_775_DATA */ - 0x00000000, /* DENALI_PHY_776_DATA */ - 0x00000000, /* DENALI_PHY_777_DATA */ - 0x00000000, /* DENALI_PHY_778_DATA */ - 0x00400320, /* DENALI_PHY_779_DATA */ - 0x00000040, /* DENALI_PHY_780_DATA */ - 0x00008eca, /* DENALI_PHY_781_DATA */ - 0x00009fdb, /* DENALI_PHY_782_DATA */ - 0x00008eca, /* DENALI_PHY_783_DATA */ - 0x01009fdb, /* DENALI_PHY_784_DATA */ - 0x00020003, /* DENALI_PHY_785_DATA */ - 0x00000000, /* DENALI_PHY_786_DATA */ - 0x00000000, /* DENALI_PHY_787_DATA */ - 0x00000000, /* DENALI_PHY_788_DATA */ - 0x000556aa, /* DENALI_PHY_789_DATA */ - 0x000aaaaa, /* DENALI_PHY_790_DATA */ - 0x000aa955, /* DENALI_PHY_791_DATA */ - 0x00055555, /* DENALI_PHY_792_DATA */ - 0x000b3133, /* DENALI_PHY_793_DATA */ - 0x0004cd33, /* DENALI_PHY_794_DATA */ - 0x0004cecc, /* DENALI_PHY_795_DATA */ - 0x000b32cc, /* DENALI_PHY_796_DATA */ - 0x1ee6b16a, /* DENALI_PHY_797_DATA */ - 0x10000000, /* DENALI_PHY_798_DATA */ - 0x00000000, /* DENALI_PHY_799_DATA */ - 0x00038055, /* DENALI_PHY_800_DATA */ - 0x03800380, /* DENALI_PHY_801_DATA */ - 0x03800380, /* DENALI_PHY_802_DATA */ - 0x00000380, /* DENALI_PHY_803_DATA */ - 0x42080010, /* DENALI_PHY_804_DATA */ - 0x00000003, /* DENALI_PHY_805_DATA */ - 0x00000000, /* DENALI_PHY_806_DATA */ - 0x00000000, /* DENALI_PHY_807_DATA */ - 0x00000000, /* DENALI_PHY_808_DATA */ - 0x00000000, /* DENALI_PHY_809_DATA */ - 0x00000000, /* DENALI_PHY_810_DATA */ - 0x00000000, /* DENALI_PHY_811_DATA */ - 0x00000000, /* DENALI_PHY_812_DATA */ - 0x00000000, /* DENALI_PHY_813_DATA */ - 0x00000000, /* DENALI_PHY_814_DATA */ - 0x00000000, /* DENALI_PHY_815_DATA */ - 0x00000000, /* DENALI_PHY_816_DATA */ - 0x00000000, /* DENALI_PHY_817_DATA */ - 0x00000000, /* DENALI_PHY_818_DATA */ - 0x00000000, /* DENALI_PHY_819_DATA */ - 0x00000000, /* DENALI_PHY_820_DATA */ - 0x00000000, /* DENALI_PHY_821_DATA */ - 0x00000000, /* DENALI_PHY_822_DATA */ - 0x00000000, /* DENALI_PHY_823_DATA */ - 0x00000000, /* DENALI_PHY_824_DATA */ - 0x00000000, /* DENALI_PHY_825_DATA */ - 0x00000000, /* DENALI_PHY_826_DATA */ - 0x00000000, /* DENALI_PHY_827_DATA */ - 0x00000000, /* DENALI_PHY_828_DATA */ - 0x00000000, /* DENALI_PHY_829_DATA */ - 0x00000000, /* DENALI_PHY_830_DATA */ - 0x00000000, /* DENALI_PHY_831_DATA */ - 0x00000000, /* DENALI_PHY_832_DATA */ - 0x00000000, /* DENALI_PHY_833_DATA */ - 0x00000000, /* DENALI_PHY_834_DATA */ - 0x00000000, /* DENALI_PHY_835_DATA */ - 0x00000000, /* DENALI_PHY_836_DATA */ - 0x00000000, /* DENALI_PHY_837_DATA */ - 0x00000000, /* DENALI_PHY_838_DATA */ - 0x00000000, /* DENALI_PHY_839_DATA */ - 0x00000000, /* DENALI_PHY_840_DATA */ - 0x00000000, /* DENALI_PHY_841_DATA */ - 0x00000000, /* DENALI_PHY_842_DATA */ - 0x00000000, /* DENALI_PHY_843_DATA */ - 0x00000000, /* DENALI_PHY_844_DATA */ - 0x00000000, /* DENALI_PHY_845_DATA */ - 0x00000000, /* DENALI_PHY_846_DATA */ - 0x00000000, /* DENALI_PHY_847_DATA */ - 0x00000000, /* DENALI_PHY_848_DATA */ - 0x00000000, /* DENALI_PHY_849_DATA */ - 0x00000000, /* DENALI_PHY_850_DATA */ - 0x00000000, /* DENALI_PHY_851_DATA */ - 0x00000000, /* DENALI_PHY_852_DATA */ - 0x00000000, /* DENALI_PHY_853_DATA */ - 0x00000000, /* DENALI_PHY_854_DATA */ - 0x00000000, /* DENALI_PHY_855_DATA */ - 0x00000000, /* DENALI_PHY_856_DATA */ - 0x00000000, /* DENALI_PHY_857_DATA */ - 0x00000000, /* DENALI_PHY_858_DATA */ - 0x00000000, /* DENALI_PHY_859_DATA */ - 0x00000000, /* DENALI_PHY_860_DATA */ - 0x00000000, /* DENALI_PHY_861_DATA */ - 0x00000000, /* DENALI_PHY_862_DATA */ - 0x00000000, /* DENALI_PHY_863_DATA */ - 0x00000000, /* DENALI_PHY_864_DATA */ - 0x00000000, /* DENALI_PHY_865_DATA */ - 0x00000000, /* DENALI_PHY_866_DATA */ - 0x00000000, /* DENALI_PHY_867_DATA */ - 0x00000000, /* DENALI_PHY_868_DATA */ - 0x00000000, /* DENALI_PHY_869_DATA */ - 0x00000000, /* DENALI_PHY_870_DATA */ - 0x00000000, /* DENALI_PHY_871_DATA */ - 0x00000000, /* DENALI_PHY_872_DATA */ - 0x00000000, /* DENALI_PHY_873_DATA */ - 0x00000000, /* DENALI_PHY_874_DATA */ - 0x00000000, /* DENALI_PHY_875_DATA */ - 0x00000000, /* DENALI_PHY_876_DATA */ - 0x00000000, /* DENALI_PHY_877_DATA */ - 0x00000000, /* DENALI_PHY_878_DATA */ - 0x00000000, /* DENALI_PHY_879_DATA */ - 0x00000000, /* DENALI_PHY_880_DATA */ - 0x00000000, /* DENALI_PHY_881_DATA */ - 0x00000000, /* DENALI_PHY_882_DATA */ - 0x00000000, /* DENALI_PHY_883_DATA */ - 0x00000000, /* DENALI_PHY_884_DATA */ - 0x00000000, /* DENALI_PHY_885_DATA */ - 0x00000000, /* DENALI_PHY_886_DATA */ - 0x00000000, /* DENALI_PHY_887_DATA */ - 0x00000000, /* DENALI_PHY_888_DATA */ - 0x00000000, /* DENALI_PHY_889_DATA */ - 0x00000000, /* DENALI_PHY_890_DATA */ - 0x00000000, /* DENALI_PHY_891_DATA */ - 0x00000000, /* DENALI_PHY_892_DATA */ - 0x00000000, /* DENALI_PHY_893_DATA */ - 0x00000000, /* DENALI_PHY_894_DATA */ - 0x00000000, /* DENALI_PHY_895_DATA */ - 0x00000001, /* DENALI_PHY_896_DATA */ - 0x00000000, /* DENALI_PHY_897_DATA */ - 0x01000005, /* DENALI_PHY_898_DATA */ - 0x04000f00, /* DENALI_PHY_899_DATA */ - 0x00020040, /* DENALI_PHY_900_DATA */ - 0x00020055, /* DENALI_PHY_901_DATA */ - 0x00000000, /* DENALI_PHY_902_DATA */ - 0x00000000, /* DENALI_PHY_903_DATA */ - 0x00000000, /* DENALI_PHY_904_DATA */ - 0x00000050, /* DENALI_PHY_905_DATA */ - 0x00000000, /* DENALI_PHY_906_DATA */ - 0x00010100, /* DENALI_PHY_907_DATA */ - 0x00000601, /* DENALI_PHY_908_DATA */ - 0x00000000, /* DENALI_PHY_909_DATA */ - 0x00006400, /* DENALI_PHY_910_DATA */ - 0x01221102, /* DENALI_PHY_911_DATA */ - 0x00000000, /* DENALI_PHY_912_DATA */ - 0x00051f00, /* DENALI_PHY_913_DATA */ - 0x051f051f, /* DENALI_PHY_914_DATA */ - 0x051f051f, /* DENALI_PHY_915_DATA */ - 0x00030003, /* DENALI_PHY_916_DATA */ - 0x03000300, /* DENALI_PHY_917_DATA */ - 0x00000300, /* DENALI_PHY_918_DATA */ - 0x01221102, /* DENALI_PHY_919_DATA */ - 0x00000000, /* DENALI_PHY_920_DATA */ - 0x00000000, /* DENALI_PHY_921_DATA */ - 0x03020000, /* DENALI_PHY_922_DATA */ - 0x00000001, /* DENALI_PHY_923_DATA */ - 0x00000011, /* DENALI_PHY_924_DATA */ - 0x00000011, /* DENALI_PHY_925_DATA */ - 0x00000400, /* DENALI_PHY_926_DATA */ - 0x00000000, /* DENALI_PHY_927_DATA */ - 0x00000011, /* DENALI_PHY_928_DATA */ - 0x00000011, /* DENALI_PHY_929_DATA */ - 0x00004410, /* DENALI_PHY_930_DATA */ - 0x00004410, /* DENALI_PHY_931_DATA */ - 0x00004410, /* DENALI_PHY_932_DATA */ - 0x00004410, /* DENALI_PHY_933_DATA */ - 0x00004410, /* DENALI_PHY_934_DATA */ - 0x00000011, /* DENALI_PHY_935_DATA */ - 0x00004410, /* DENALI_PHY_936_DATA */ - 0x00000011, /* DENALI_PHY_937_DATA */ - 0x00004410, /* DENALI_PHY_938_DATA */ - 0x00000011, /* DENALI_PHY_939_DATA */ - 0x00004410, /* DENALI_PHY_940_DATA */ - 0x00000000, /* DENALI_PHY_941_DATA */ - 0x00000000, /* DENALI_PHY_942_DATA */ - 0x00000000, /* DENALI_PHY_943_DATA */ - 0x04000000, /* DENALI_PHY_944_DATA */ - 0x00000000, /* DENALI_PHY_945_DATA */ - 0x00000000, /* DENALI_PHY_946_DATA */ - 0x00000508, /* DENALI_PHY_947_DATA */ - 0x00000000, /* DENALI_PHY_948_DATA */ - 0x00000000, /* DENALI_PHY_949_DATA */ - 0x00000000, /* DENALI_PHY_950_DATA */ - 0x00000000, /* DENALI_PHY_951_DATA */ - 0x00000000, /* DENALI_PHY_952_DATA */ - 0x00000000, /* DENALI_PHY_953_DATA */ - 0xe4000000, /* DENALI_PHY_954_DATA */ - 0x00000000, /* DENALI_PHY_955_DATA */ - 0x00000000, /* DENALI_PHY_956_DATA */ - 0x01010000, /* DENALI_PHY_957_DATA */ - 0x00000000 /* DENALI_PHY_958_DATA */ - } - }, -}, diff --git a/src/mainboard/google/gru/sdram_inf/sdram-lpddr3-hynix-4GB-800.c b/src/mainboard/google/gru/sdram_inf/sdram-lpddr3-hynix-4GB-800.c new file mode 100644 index 0000000..3a937bf --- /dev/null +++ b/src/mainboard/google/gru/sdram_inf/sdram-lpddr3-hynix-4GB-800.c @@ -0,0 +1,1565 @@ +/* + * This file is part of the coreboot project. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <soc/sdram.h> + +struct rk3399_sdram_params params = { + { + { + .rank = 0x2, + .col = 0xA, + .bk = 0x3, + .bw = 0x2, + .dbw = 0x2, + .row_3_4 = 0x0, + .cs0_row = 0xF, + .cs1_row = 0xF, + .ddrconfig = 1, + { + {0x1d191519}, + {0x14040808}, + {0x00000002}, + {0x00006226}, + {0x00000054}, + 0x00000000 + } + }, + { + .rank = 0x2, + .col = 0xA, + .bk = 0x3, + .bw = 0x2, + .dbw = 0x2, + .row_3_4 = 0x0, + .cs0_row = 0xF, + .cs1_row = 0xF, + .ddrconfig = 1, + { + {0x1d191519}, + {0x14040808}, + {0x00000002}, + {0x00006226}, + {0x00000054}, + 0x00000000 + } + } + }, + .ddr_freq = 800*MHz, + .dramtype = LPDDR3, + .num_channels = 2, + .stride = 13, + .odt = 1, + { + { + 0x00000700, /* DENALI_CTL_00_DATA */ + 0x00000000, /* DENALI_CTL_01_DATA */ + 0x00000000, /* DENALI_CTL_02_DATA */ + 0x00000000, /* DENALI_CTL_03_DATA */ + 0x00000000, /* DENALI_CTL_04_DATA */ + 0x00000050, /* DENALI_CTL_05_DATA */ + 0x00027100, /* DENALI_CTL_06_DATA */ + 0x00000320, /* DENALI_CTL_07_DATA */ + 0x00001f40, /* DENALI_CTL_08_DATA */ + 0x00000028, /* DENALI_CTL_09_DATA */ + 0x00013880, /* DENALI_CTL_10_DATA */ + 0x00000190, /* DENALI_CTL_11_DATA */ + 0x00000fa0, /* DENALI_CTL_12_DATA */ + 0x00000050, /* DENALI_CTL_13_DATA */ + 0x00027100, /* DENALI_CTL_14_DATA */ + 0x00000320, /* DENALI_CTL_15_DATA */ + 0x01001f40, /* DENALI_CTL_16_DATA */ + 0x00000000, /* DENALI_CTL_17_DATA */ + 0x00000101, /* DENALI_CTL_18_DATA */ + 0x00020100, /* DENALI_CTL_19_DATA */ + 0x000000a0, /* DENALI_CTL_20_DATA */ + 0x00000190, /* DENALI_CTL_21_DATA */ + 0x00000000, /* DENALI_CTL_22_DATA */ + 0x06180000, /* DENALI_CTL_23_DATA */ + 0x00061800, /* DENALI_CTL_24_DATA */ + 0x04000618, /* DENALI_CTL_25_DATA */ + 0x33080004, /* DENALI_CTL_26_DATA */ + 0x280f0622, /* DENALI_CTL_27_DATA */ + 0x111a0400, /* DENALI_CTL_28_DATA */ + 0x00140804, /* DENALI_CTL_29_DATA */ + 0x06223308, /* DENALI_CTL_30_DATA */ + 0x0600280f, /* DENALI_CTL_31_DATA */ + 0x00000a0a, /* DENALI_CTL_32_DATA */ + 0x0600dac0, /* DENALI_CTL_33_DATA */ + 0x0a0a040c, /* DENALI_CTL_34_DATA */ + 0x03006d60, /* DENALI_CTL_35_DATA */ + 0x0a0a0606, /* DENALI_CTL_36_DATA */ + 0x0600dac0, /* DENALI_CTL_37_DATA */ + 0x0203000c, /* DENALI_CTL_38_DATA */ + 0x080c0f00, /* DENALI_CTL_39_DATA */ + 0x040c0f06, /* DENALI_CTL_40_DATA */ + 0x14000a0a, /* DENALI_CTL_41_DATA */ + 0x02030a0a, /* DENALI_CTL_42_DATA */ + 0x00010003, /* DENALI_CTL_43_DATA */ + 0x031b0e1b, /* DENALI_CTL_44_DATA */ + 0x00110911, /* DENALI_CTL_45_DATA */ + 0x00000000, /* DENALI_CTL_46_DATA */ + 0x03010000, /* DENALI_CTL_47_DATA */ + 0x0c2800a8, /* DENALI_CTL_48_DATA */ + 0x06100054, /* DENALI_CTL_49_DATA */ + 0x0c2800a8, /* DENALI_CTL_50_DATA */ + 0x00000000, /* DENALI_CTL_51_DATA */ + 0x00030006, /* DENALI_CTL_52_DATA */ + 0x00140006, /* DENALI_CTL_53_DATA */ + 0x0014000a, /* DENALI_CTL_54_DATA */ + 0x000f080f, /* DENALI_CTL_55_DATA */ + 0x00000000, /* DENALI_CTL_56_DATA */ + 0x00000000, /* DENALI_CTL_57_DATA */ + 0x00000000, /* DENALI_CTL_58_DATA */ + 0x00b00000, /* DENALI_CTL_59_DATA */ + 0x005800b0, /* DENALI_CTL_60_DATA */ + 0x00b00058, /* DENALI_CTL_61_DATA */ + 0x000000b0, /* DENALI_CTL_62_DATA */ + 0x00000000, /* DENALI_CTL_63_DATA */ + 0x00000000, /* DENALI_CTL_64_DATA */ + 0x00000000, /* DENALI_CTL_65_DATA */ + 0x00000000, /* DENALI_CTL_66_DATA */ + 0x00000000, /* DENALI_CTL_67_DATA */ + 0x00000000, /* DENALI_CTL_68_DATA */ + 0x00000301, /* DENALI_CTL_69_DATA */ + 0x00000001, /* DENALI_CTL_70_DATA */ + 0x00000000, /* DENALI_CTL_71_DATA */ + 0x00000000, /* DENALI_CTL_72_DATA */ + 0x01000000, /* DENALI_CTL_73_DATA */ + 0x80104002, /* DENALI_CTL_74_DATA */ + 0x00040003, /* DENALI_CTL_75_DATA */ + 0x00040005, /* DENALI_CTL_76_DATA */ + 0x00030000, /* DENALI_CTL_77_DATA */ + 0x00050004, /* DENALI_CTL_78_DATA */ + 0x00000004, /* DENALI_CTL_79_DATA */ + 0x00040003, /* DENALI_CTL_80_DATA */ + 0x00040005, /* DENALI_CTL_81_DATA */ + 0x30a00000, /* DENALI_CTL_82_DATA */ + 0x00001850, /* DENALI_CTL_83_DATA */ + 0x0c201840, /* DENALI_CTL_84_DATA */ + 0x30a00000, /* DENALI_CTL_85_DATA */ + 0x00001850, /* DENALI_CTL_86_DATA */ + 0x00000000, /* DENALI_CTL_87_DATA */ + 0x00000000, /* DENALI_CTL_88_DATA */ + 0x00000000, /* DENALI_CTL_89_DATA */ + 0x00000000, /* DENALI_CTL_90_DATA */ + 0x00000000, /* DENALI_CTL_91_DATA */ + 0x02020200, /* DENALI_CTL_92_DATA */ + 0x00020202, /* DENALI_CTL_93_DATA */ + 0x00030200, /* DENALI_CTL_94_DATA */ + 0x00040700, /* DENALI_CTL_95_DATA */ + 0x00000302, /* DENALI_CTL_96_DATA */ + 0x02000407, /* DENALI_CTL_97_DATA */ + 0x00000003, /* DENALI_CTL_98_DATA */ + 0x00030f04, /* DENALI_CTL_99_DATA */ + 0x00070004, /* DENALI_CTL_100_DATA */ + 0x00000000, /* DENALI_CTL_101_DATA */ + 0x00000000, /* DENALI_CTL_102_DATA */ + 0x00000000, /* DENALI_CTL_103_DATA */ + 0x00000000, /* DENALI_CTL_104_DATA */ + 0x00000000, /* DENALI_CTL_105_DATA */ + 0x00000000, /* DENALI_CTL_106_DATA */ + 0x00000000, /* DENALI_CTL_107_DATA */ + 0x00010000, /* DENALI_CTL_108_DATA */ + 0x20040020, /* DENALI_CTL_109_DATA */ + 0x00200400, /* DENALI_CTL_110_DATA */ + 0x01000400, /* DENALI_CTL_111_DATA */ + 0x00000b80, /* DENALI_CTL_112_DATA */ + 0x00000000, /* DENALI_CTL_113_DATA */ + 0x00000001, /* DENALI_CTL_114_DATA */ + 0x00000002, /* DENALI_CTL_115_DATA */ + 0x0000000e, /* DENALI_CTL_116_DATA */ + 0x00000000, /* DENALI_CTL_117_DATA */ + 0x00000000, /* DENALI_CTL_118_DATA */ + 0x00000000, /* DENALI_CTL_119_DATA */ + 0x00000000, /* DENALI_CTL_120_DATA */ + 0x00000000, /* DENALI_CTL_121_DATA */ + 0x00a00000, /* DENALI_CTL_122_DATA */ + 0x00c80050, /* DENALI_CTL_123_DATA */ + 0x00c80000, /* DENALI_CTL_124_DATA */ + 0x00280050, /* DENALI_CTL_125_DATA */ + 0x00000064, /* DENALI_CTL_126_DATA */ + 0x00a00064, /* DENALI_CTL_127_DATA */ + 0x00c80050, /* DENALI_CTL_128_DATA */ + 0x00c80000, /* DENALI_CTL_129_DATA */ + 0x00000000, /* DENALI_CTL_130_DATA */ + 0x00000000, /* DENALI_CTL_131_DATA */ + 0x00000000, /* DENALI_CTL_132_DATA */ + 0x00430000, /* DENALI_CTL_133_DATA */ + 0x0000001a, /* DENALI_CTL_134_DATA */ + 0x000a0083, /* DENALI_CTL_135_DATA */ + 0x00430000, /* DENALI_CTL_136_DATA */ + 0x0000001a, /* DENALI_CTL_137_DATA */ + 0x00010001, /* DENALI_CTL_138_DATA */ + 0x06000001, /* DENALI_CTL_139_DATA */ + 0x00000707, /* DENALI_CTL_140_DATA */ + 0x00000000, /* DENALI_CTL_141_DATA */ + 0x00000000, /* DENALI_CTL_142_DATA */ + 0x00000000, /* DENALI_CTL_143_DATA */ + 0x00000000, /* DENALI_CTL_144_DATA */ + 0x00000000, /* DENALI_CTL_145_DATA */ + 0x00000000, /* DENALI_CTL_146_DATA */ + 0x00430000, /* DENALI_CTL_147_DATA */ + 0x0000001a, /* DENALI_CTL_148_DATA */ + 0x000a0083, /* DENALI_CTL_149_DATA */ + 0x00430000, /* DENALI_CTL_150_DATA */ + 0x0000001a, /* DENALI_CTL_151_DATA */ + 0x00010001, /* DENALI_CTL_152_DATA */ + 0x06000001, /* DENALI_CTL_153_DATA */ + 0x00000707, /* DENALI_CTL_154_DATA */ + 0x00000000, /* DENALI_CTL_155_DATA */ + 0x00000000, /* DENALI_CTL_156_DATA */ + 0x00000000, /* DENALI_CTL_157_DATA */ + 0x00000000, /* DENALI_CTL_158_DATA */ + 0x00000000, /* DENALI_CTL_159_DATA */ + 0x00000000, /* DENALI_CTL_160_DATA */ + 0x01000000, /* DENALI_CTL_161_DATA */ + 0x00000000, /* DENALI_CTL_162_DATA */ + 0x00000000, /* DENALI_CTL_163_DATA */ + 0x18151100, /* DENALI_CTL_164_DATA */ + 0x0000000c, /* DENALI_CTL_165_DATA */ + 0x00000000, /* DENALI_CTL_166_DATA */ + 0x00000000, /* DENALI_CTL_167_DATA */ + 0x00000000, /* DENALI_CTL_168_DATA */ + 0x00000000, /* DENALI_CTL_169_DATA */ + 0x00000000, /* DENALI_CTL_170_DATA */ + 0x00000000, /* DENALI_CTL_171_DATA */ + 0x00000000, /* DENALI_CTL_172_DATA */ + 0x00000000, /* DENALI_CTL_173_DATA */ + 0x00000000, /* DENALI_CTL_174_DATA */ + 0x00000000, /* DENALI_CTL_175_DATA */ + 0x00000000, /* DENALI_CTL_176_DATA */ + 0x00000000, /* DENALI_CTL_177_DATA */ + 0x00000000, /* DENALI_CTL_178_DATA */ + 0x00032003, /* DENALI_CTL_179_DATA */ + 0x00480120, /* DENALI_CTL_180_DATA */ + 0x00000000, /* DENALI_CTL_181_DATA */ + 0x00900190, /* DENALI_CTL_182_DATA */ + 0x00000024, /* DENALI_CTL_183_DATA */ + 0x00032000, /* DENALI_CTL_184_DATA */ + 0x00480120, /* DENALI_CTL_185_DATA */ + 0x00000000, /* DENALI_CTL_186_DATA */ + 0x00280000, /* DENALI_CTL_187_DATA */ + 0x00280014, /* DENALI_CTL_188_DATA */ + 0x01010100, /* DENALI_CTL_189_DATA */ + 0x01000202, /* DENALI_CTL_190_DATA */ + 0x0a000002, /* DENALI_CTL_191_DATA */ + 0x01000f0f, /* DENALI_CTL_192_DATA */ + 0x00000000, /* DENALI_CTL_193_DATA */ + 0x00000000, /* DENALI_CTL_194_DATA */ + 0x00010003, /* DENALI_CTL_195_DATA */ + 0x00000c03, /* DENALI_CTL_196_DATA */ + 0x00000100, /* DENALI_CTL_197_DATA */ + 0x00010000, /* DENALI_CTL_198_DATA */ + 0x01000000, /* DENALI_CTL_199_DATA */ + 0x00010000, /* DENALI_CTL_200_DATA */ + 0x00000001, /* DENALI_CTL_201_DATA */ + 0x00000000, /* DENALI_CTL_202_DATA */ + 0x00000000, /* DENALI_CTL_203_DATA */ + 0x00000000, /* DENALI_CTL_204_DATA */ + 0x00000000, /* DENALI_CTL_205_DATA */ + 0x00000000, /* DENALI_CTL_206_DATA */ + 0x00000000, /* DENALI_CTL_207_DATA */ + 0x00000000, /* DENALI_CTL_208_DATA */ + 0x00000000, /* DENALI_CTL_209_DATA */ + 0x00000000, /* DENALI_CTL_210_DATA */ + 0x00010000, /* DENALI_CTL_211_DATA */ + 0x03020301, /* DENALI_CTL_212_DATA */ + 0x01010808, /* DENALI_CTL_213_DATA */ + 0x04030001, /* DENALI_CTL_214_DATA */ + 0x0a0a0a03, /* DENALI_CTL_215_DATA */ + 0x08080808, /* DENALI_CTL_216_DATA */ + 0x02050103, /* DENALI_CTL_217_DATA */ + 0x02010103, /* DENALI_CTL_218_DATA */ + 0x00010103, /* DENALI_CTL_219_DATA */ + 0x00020202, /* DENALI_CTL_220_DATA */ + 0x03020500, /* DENALI_CTL_221_DATA */ + 0x00020501, /* DENALI_CTL_222_DATA */ + 0x00000000, /* DENALI_CTL_223_DATA */ + 0x00000000, /* DENALI_CTL_224_DATA */ + 0x0d000001, /* DENALI_CTL_225_DATA */ + 0x00010028, /* DENALI_CTL_226_DATA */ + 0x00010000, /* DENALI_CTL_227_DATA */ + 0x00000003, /* DENALI_CTL_228_DATA */ + 0x00000000, /* DENALI_CTL_229_DATA */ + 0x00000000, /* DENALI_CTL_230_DATA */ + 0x00000000, /* DENALI_CTL_231_DATA */ + 0x00000000, /* DENALI_CTL_232_DATA */ + 0x00000000, /* DENALI_CTL_233_DATA */ + 0x00000000, /* DENALI_CTL_234_DATA */ + 0x00000000, /* DENALI_CTL_235_DATA */ + 0x00000000, /* DENALI_CTL_236_DATA */ + 0x00010100, /* DENALI_CTL_237_DATA */ + 0x01000000, /* DENALI_CTL_238_DATA */ + 0x00000001, /* DENALI_CTL_239_DATA */ + 0x00000303, /* DENALI_CTL_240_DATA */ + 0x00000000, /* DENALI_CTL_241_DATA */ + 0x00000000, /* DENALI_CTL_242_DATA */ + 0x00000000, /* DENALI_CTL_243_DATA */ + 0x00000000, /* DENALI_CTL_244_DATA */ + 0x00000000, /* DENALI_CTL_245_DATA */ + 0x00000000, /* DENALI_CTL_246_DATA */ + 0x00000000, /* DENALI_CTL_247_DATA */ + 0x00000000, /* DENALI_CTL_248_DATA */ + 0x00000000, /* DENALI_CTL_249_DATA */ + 0x00000000, /* DENALI_CTL_250_DATA */ + 0x00000000, /* DENALI_CTL_251_DATA */ + 0x00000000, /* DENALI_CTL_252_DATA */ + 0x00000000, /* DENALI_CTL_253_DATA */ + 0x00000000, /* DENALI_CTL_254_DATA */ + 0x00000000, /* DENALI_CTL_255_DATA */ + 0x000556aa, /* DENALI_CTL_256_DATA */ + 0x000aaaaa, /* DENALI_CTL_257_DATA */ + 0x000aa955, /* DENALI_CTL_258_DATA */ + 0x00055555, /* DENALI_CTL_259_DATA */ + 0x000b3133, /* DENALI_CTL_260_DATA */ + 0x0004cd33, /* DENALI_CTL_261_DATA */ + 0x0004cecc, /* DENALI_CTL_262_DATA */ + 0x000b32cc, /* DENALI_CTL_263_DATA */ + 0x00010300, /* DENALI_CTL_264_DATA */ + 0x03000100, /* DENALI_CTL_265_DATA */ + 0x00000000, /* DENALI_CTL_266_DATA */ + 0x00000000, /* DENALI_CTL_267_DATA */ + 0x00000000, /* DENALI_CTL_268_DATA */ + 0x00000000, /* DENALI_CTL_269_DATA */ + 0x00000000, /* DENALI_CTL_270_DATA */ + 0x00000000, /* DENALI_CTL_271_DATA */ + 0x00000000, /* DENALI_CTL_272_DATA */ + 0x00000000, /* DENALI_CTL_273_DATA */ + 0x00ffff00, /* DENALI_CTL_274_DATA */ + 0x181e0000, /* DENALI_CTL_275_DATA */ + 0x0800001e, /* DENALI_CTL_276_DATA */ + 0x00001850, /* DENALI_CTL_277_DATA */ + 0x00000200, /* DENALI_CTL_278_DATA */ + 0x00000200, /* DENALI_CTL_279_DATA */ + 0x00000200, /* DENALI_CTL_280_DATA */ + 0x00000200, /* DENALI_CTL_281_DATA */ + 0x00001850, /* DENALI_CTL_282_DATA */ + 0x0000f320, /* DENALI_CTL_283_DATA */ + 0x0c20050a, /* DENALI_CTL_284_DATA */ + 0x00000200, /* DENALI_CTL_285_DATA */ + 0x00000200, /* DENALI_CTL_286_DATA */ + 0x00000200, /* DENALI_CTL_287_DATA */ + 0x00000200, /* DENALI_CTL_288_DATA */ + 0x00000c20, /* DENALI_CTL_289_DATA */ + 0x00007940, /* DENALI_CTL_290_DATA */ + 0x1850050b, /* DENALI_CTL_291_DATA */ + 0x00000200, /* DENALI_CTL_292_DATA */ + 0x00000200, /* DENALI_CTL_293_DATA */ + 0x00000200, /* DENALI_CTL_294_DATA */ + 0x00000200, /* DENALI_CTL_295_DATA */ + 0x00001850, /* DENALI_CTL_296_DATA */ + 0x0000f320, /* DENALI_CTL_297_DATA */ + 0x0202050a, /* DENALI_CTL_298_DATA */ + 0x03030202, /* DENALI_CTL_299_DATA */ + 0x00000018, /* DENALI_CTL_300_DATA */ + 0x00000000, /* DENALI_CTL_301_DATA */ + 0x00000000, /* DENALI_CTL_302_DATA */ + 0x00001403, /* DENALI_CTL_303_DATA */ + 0x00000000, /* DENALI_CTL_304_DATA */ + 0x00000000, /* DENALI_CTL_305_DATA */ + 0x00000000, /* DENALI_CTL_306_DATA */ + 0x00030000, /* DENALI_CTL_307_DATA */ + 0x000e0020, /* DENALI_CTL_308_DATA */ + 0x000a001c, /* DENALI_CTL_309_DATA */ + 0x000e0020, /* DENALI_CTL_310_DATA */ + 0x00000000, /* DENALI_CTL_311_DATA */ + 0x00000000, /* DENALI_CTL_312_DATA */ + 0x01000000, /* DENALI_CTL_313_DATA */ + 0x00070007, /* DENALI_CTL_314_DATA */ + 0x00050007, /* DENALI_CTL_315_DATA */ + 0x00000000, /* DENALI_CTL_316_DATA */ + 0x00000000, /* DENALI_CTL_317_DATA */ + 0x00000000, /* DENALI_CTL_318_DATA */ + 0x00000000, /* DENALI_CTL_319_DATA */ + 0x00000000, /* DENALI_CTL_320_DATA */ + 0x00000000, /* DENALI_CTL_321_DATA */ + 0x00000000, /* DENALI_CTL_322_DATA */ + 0x00000000, /* DENALI_CTL_323_DATA */ + 0x01000101, /* DENALI_CTL_324_DATA */ + 0x01010101, /* DENALI_CTL_325_DATA */ + 0x01000101, /* DENALI_CTL_326_DATA */ + 0x01000100, /* DENALI_CTL_327_DATA */ + 0x00010001, /* DENALI_CTL_328_DATA */ + 0x00010002, /* DENALI_CTL_329_DATA */ + 0x00020100, /* DENALI_CTL_330_DATA */ + 0x00000002 /* DENALI_CTL_331_DATA */ + } + }, + { + { + 0x00000700, /* DENALI_PI_00_DATA */ + 0x00000000, /* DENALI_PI_01_DATA */ + 0x000030a0, /* DENALI_PI_02_DATA */ + 0x00001850, /* DENALI_PI_03_DATA */ + 0x00001840, /* DENALI_PI_04_DATA */ + 0x00000c20, /* DENALI_PI_05_DATA */ + 0x000030a0, /* DENALI_PI_06_DATA */ + 0x18501850, /* DENALI_PI_07_DATA */ + 0x00000200, /* DENALI_PI_08_DATA */ + 0x00000200, /* DENALI_PI_09_DATA */ + 0x00000200, /* DENALI_PI_10_DATA */ + 0x00000200, /* DENALI_PI_11_DATA */ + 0x00000c20, /* DENALI_PI_12_DATA */ + 0x00000200, /* DENALI_PI_13_DATA */ + 0x00000200, /* DENALI_PI_14_DATA */ + 0x00000200, /* DENALI_PI_15_DATA */ + 0x00000200, /* DENALI_PI_16_DATA */ + 0x00001850, /* DENALI_PI_17_DATA */ + 0x00000200, /* DENALI_PI_18_DATA */ + 0x00000200, /* DENALI_PI_19_DATA */ + 0x00000200, /* DENALI_PI_20_DATA */ + 0x00000200, /* DENALI_PI_21_DATA */ + 0x00010000, /* DENALI_PI_22_DATA */ + 0x00000007, /* DENALI_PI_23_DATA */ + 0x81000001, /* DENALI_PI_24_DATA */ + 0x0f0003f0, /* DENALI_PI_25_DATA */ + 0x3fffffff, /* DENALI_PI_26_DATA */ + 0x0f0000a0, /* DENALI_PI_27_DATA */ + 0x377ff000, /* DENALI_PI_28_DATA */ + 0x0f000020, /* DENALI_PI_29_DATA */ + 0x377ff000, /* DENALI_PI_30_DATA */ + 0x0f000030, /* DENALI_PI_31_DATA */ + 0x377ff000, /* DENALI_PI_32_DATA */ + 0x0f0000b0, /* DENALI_PI_33_DATA */ + 0x377ff000, /* DENALI_PI_34_DATA */ + 0x0f000100, /* DENALI_PI_35_DATA */ + 0x377ff000, /* DENALI_PI_36_DATA */ + 0x0f000110, /* DENALI_PI_37_DATA */ + 0x377ff000, /* DENALI_PI_38_DATA */ + 0x0f000010, /* DENALI_PI_39_DATA */ + 0x377ff000, /* DENALI_PI_40_DATA */ + 0x03000101, /* DENALI_PI_41_DATA */ + 0x042e292e, /* DENALI_PI_42_DATA */ + 0x06180006, /* DENALI_PI_43_DATA */ + 0x00061800, /* DENALI_PI_44_DATA */ + 0x00000018, /* DENALI_PI_45_DATA */ + 0x0c2800a8, /* DENALI_PI_46_DATA */ + 0x06100054, /* DENALI_PI_47_DATA */ + 0x0c2800a8, /* DENALI_PI_48_DATA */ + 0x00000500, /* DENALI_PI_49_DATA */ + 0x00000000, /* DENALI_PI_50_DATA */ + 0x00000000, /* DENALI_PI_51_DATA */ + 0x00000000, /* DENALI_PI_52_DATA */ + 0x00000000, /* DENALI_PI_53_DATA */ + 0x00000000, /* DENALI_PI_54_DATA */ + 0x00000000, /* DENALI_PI_55_DATA */ + 0x00000000, /* DENALI_PI_56_DATA */ + 0x00000000, /* DENALI_PI_57_DATA */ + 0x04040000, /* DENALI_PI_58_DATA */ + 0x0d000004, /* DENALI_PI_59_DATA */ + 0x00000128, /* DENALI_PI_60_DATA */ + 0x00000000, /* DENALI_PI_61_DATA */ + 0x00030003, /* DENALI_PI_62_DATA */ + 0x00000018, /* DENALI_PI_63_DATA */ + 0x00000000, /* DENALI_PI_64_DATA */ + 0x00000000, /* DENALI_PI_65_DATA */ + 0x03060002, /* DENALI_PI_66_DATA */ + 0x03010201, /* DENALI_PI_67_DATA */ + 0x01080801, /* DENALI_PI_68_DATA */ + 0x04020201, /* DENALI_PI_69_DATA */ + 0x01080804, /* DENALI_PI_70_DATA */ + 0x00000000, /* DENALI_PI_71_DATA */ + 0x04030000, /* DENALI_PI_72_DATA */ + 0x0a0a0a03, /* DENALI_PI_73_DATA */ + 0x00000000, /* DENALI_PI_74_DATA */ + 0x00000000, /* DENALI_PI_75_DATA */ + 0x00000000, /* DENALI_PI_76_DATA */ + 0x00030300, /* DENALI_PI_77_DATA */ + 0x00000014, /* DENALI_PI_78_DATA */ + 0x00000000, /* DENALI_PI_79_DATA */ + 0x01010300, /* DENALI_PI_80_DATA */ + 0x00000000, /* DENALI_PI_81_DATA */ + 0x00000000, /* DENALI_PI_82_DATA */ + 0x01000000, /* DENALI_PI_83_DATA */ + 0x00000101, /* DENALI_PI_84_DATA */ + 0x55555a5a, /* DENALI_PI_85_DATA */ + 0x55555a5a, /* DENALI_PI_86_DATA */ + 0x55555a5a, /* DENALI_PI_87_DATA */ + 0x55555a5a, /* DENALI_PI_88_DATA */ + 0x0b0a0001, /* DENALI_PI_89_DATA */ + 0x0505000a, /* DENALI_PI_90_DATA */ + 0x00000005, /* DENALI_PI_91_DATA */ + 0x00000100, /* DENALI_PI_92_DATA */ + 0x00030000, /* DENALI_PI_93_DATA */ + 0x17030000, /* DENALI_PI_94_DATA */ + 0x000e0020, /* DENALI_PI_95_DATA */ + 0x000a001c, /* DENALI_PI_96_DATA */ + 0x000e0020, /* DENALI_PI_97_DATA */ + 0x00000000, /* DENALI_PI_98_DATA */ + 0x00000000, /* DENALI_PI_99_DATA */ + 0x00000100, /* DENALI_PI_100_DATA */ + 0x140a0000, /* DENALI_PI_101_DATA */ + 0x000a030a, /* DENALI_PI_102_DATA */ + 0x03000a02, /* DENALI_PI_103_DATA */ + 0x010a000a, /* DENALI_PI_104_DATA */ + 0x00000100, /* DENALI_PI_105_DATA */ + 0x01000000, /* DENALI_PI_106_DATA */ + 0x00000000, /* DENALI_PI_107_DATA */ + 0x00000100, /* DENALI_PI_108_DATA */ + 0x1e1a0000, /* DENALI_PI_109_DATA */ + 0x10010204, /* DENALI_PI_110_DATA */ + 0x07060705, /* DENALI_PI_111_DATA */ + 0x20000202, /* DENALI_PI_112_DATA */ + 0x00201000, /* DENALI_PI_113_DATA */ + 0x00201000, /* DENALI_PI_114_DATA */ + 0x04041000, /* DENALI_PI_115_DATA */ + 0x0c100100, /* DENALI_PI_116_DATA */ + 0x00010110, /* DENALI_PI_117_DATA */ + 0x004b004a, /* DENALI_PI_118_DATA */ + 0x1a030000, /* DENALI_PI_119_DATA */ + 0x0102041e, /* DENALI_PI_120_DATA */ + 0x34000000, /* DENALI_PI_121_DATA */ + 0x00000000, /* DENALI_PI_122_DATA */ + 0x00000000, /* DENALI_PI_123_DATA */ + 0x00000000, /* DENALI_PI_124_DATA */ + 0x00004300, /* DENALI_PI_125_DATA */ + 0x0001001a, /* DENALI_PI_126_DATA */ + 0x004d4d07, /* DENALI_PI_127_DATA */ + 0x000a0083, /* DENALI_PI_128_DATA */ + 0x4d070001, /* DENALI_PI_129_DATA */ + 0x0000434d, /* DENALI_PI_130_DATA */ + 0x0001001a, /* DENALI_PI_131_DATA */ + 0x004d4d07, /* DENALI_PI_132_DATA */ + 0x001a0043, /* DENALI_PI_133_DATA */ + 0x4d070001, /* DENALI_PI_134_DATA */ + 0x0000834d, /* DENALI_PI_135_DATA */ + 0x0001000a, /* DENALI_PI_136_DATA */ + 0x004d4d07, /* DENALI_PI_137_DATA */ + 0x001a0043, /* DENALI_PI_138_DATA */ + 0x4d070001, /* DENALI_PI_139_DATA */ + 0x0043004d, /* DENALI_PI_140_DATA */ + 0x0001001a, /* DENALI_PI_141_DATA */ + 0x004d4d07, /* DENALI_PI_142_DATA */ + 0x000a0083, /* DENALI_PI_143_DATA */ + 0x4d070001, /* DENALI_PI_144_DATA */ + 0x0000434d, /* DENALI_PI_145_DATA */ + 0x0001001a, /* DENALI_PI_146_DATA */ + 0x004d4d07, /* DENALI_PI_147_DATA */ + 0x001a0043, /* DENALI_PI_148_DATA */ + 0x4d070001, /* DENALI_PI_149_DATA */ + 0x0000834d, /* DENALI_PI_150_DATA */ + 0x0001000a, /* DENALI_PI_151_DATA */ + 0x004d4d07, /* DENALI_PI_152_DATA */ + 0x001a0043, /* DENALI_PI_153_DATA */ + 0x4d070001, /* DENALI_PI_154_DATA */ + 0x0100004d, /* DENALI_PI_155_DATA */ + 0x006400c8, /* DENALI_PI_156_DATA */ + 0x060400c8, /* DENALI_PI_157_DATA */ + 0x0c060f11, /* DENALI_PI_158_DATA */ + 0x2200d890, /* DENALI_PI_159_DATA */ + 0x0a0c2005, /* DENALI_PI_160_DATA */ + 0x0809040a, /* DENALI_PI_161_DATA */ + 0x00000604, /* DENALI_PI_162_DATA */ + 0x11006c48, /* DENALI_PI_163_DATA */ + 0x0a062003, /* DENALI_PI_164_DATA */ + 0x0f11060a, /* DENALI_PI_165_DATA */ + 0x00000c06, /* DENALI_PI_166_DATA */ + 0x2200d890, /* DENALI_PI_167_DATA */ + 0x0a0c2005, /* DENALI_PI_168_DATA */ + 0x0200020a, /* DENALI_PI_169_DATA */ + 0x02000200, /* DENALI_PI_170_DATA */ + 0x02000200, /* DENALI_PI_171_DATA */ + 0x02000200, /* DENALI_PI_172_DATA */ + 0x02000200, /* DENALI_PI_173_DATA */ + 0x00000000, /* DENALI_PI_174_DATA */ + 0x00000000, /* DENALI_PI_175_DATA */ + 0x00000000, /* DENALI_PI_176_DATA */ + 0x00000000, /* DENALI_PI_177_DATA */ + 0x00000000, /* DENALI_PI_178_DATA */ + 0x00000000, /* DENALI_PI_179_DATA */ + 0x00000000, /* DENALI_PI_180_DATA */ + 0x00000000, /* DENALI_PI_181_DATA */ + 0x00000000, /* DENALI_PI_182_DATA */ + 0x00000000, /* DENALI_PI_183_DATA */ + 0x00000000, /* DENALI_PI_184_DATA */ + 0x00000000, /* DENALI_PI_185_DATA */ + 0x01000300, /* DENALI_PI_186_DATA */ + 0x00185000, /* DENALI_PI_187_DATA */ + 0x0000f320, /* DENALI_PI_188_DATA */ + 0x00000c20, /* DENALI_PI_189_DATA */ + 0x00007940, /* DENALI_PI_190_DATA */ + 0x00001850, /* DENALI_PI_191_DATA */ + 0x0000f320, /* DENALI_PI_192_DATA */ + 0x08000000, /* DENALI_PI_193_DATA */ + 0x00000100, /* DENALI_PI_194_DATA */ + 0x00000000, /* DENALI_PI_195_DATA */ + 0x00000000, /* DENALI_PI_196_DATA */ + 0x00000000, /* DENALI_PI_197_DATA */ + 0x00000000, /* DENALI_PI_198_DATA */ + 0x00000002 /* DENALI_PI_199_DATA */ + } + }, + { + { + 0x76543210, /* DENALI_PHY_00_DATA */ + 0x0004c008, /* DENALI_PHY_01_DATA */ + 0x000000b3, /* DENALI_PHY_02_DATA */ + 0x00000000, /* DENALI_PHY_03_DATA */ + 0x00000000, /* DENALI_PHY_04_DATA */ + 0x00010000, /* DENALI_PHY_05_DATA */ + 0x01665555, /* DENALI_PHY_06_DATA */ + 0x00665555, /* DENALI_PHY_07_DATA */ + 0x00010f00, /* DENALI_PHY_08_DATA */ + 0x05010200, /* DENALI_PHY_09_DATA */ + 0x00000003, /* DENALI_PHY_10_DATA */ + 0x001700c0, /* DENALI_PHY_11_DATA */ + 0x00cc0101, /* DENALI_PHY_12_DATA */ + 0x00030066, /* DENALI_PHY_13_DATA */ + 0x00000000, /* DENALI_PHY_14_DATA */ + 0x00000000, /* DENALI_PHY_15_DATA */ + 0x00000000, /* DENALI_PHY_16_DATA */ + 0x00000000, /* DENALI_PHY_17_DATA */ + 0x00000000, /* DENALI_PHY_18_DATA */ + 0x00000000, /* DENALI_PHY_19_DATA */ + 0x00000000, /* DENALI_PHY_20_DATA */ + 0x00000000, /* DENALI_PHY_21_DATA */ + 0x04080000, /* DENALI_PHY_22_DATA */ + 0x04080400, /* DENALI_PHY_23_DATA */ + 0x08000000, /* DENALI_PHY_24_DATA */ + 0x0c00c007, /* DENALI_PHY_25_DATA */ + 0x00000100, /* DENALI_PHY_26_DATA */ + 0x00000100, /* DENALI_PHY_27_DATA */ + 0x55555555, /* DENALI_PHY_28_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_29_DATA */ + 0x55555555, /* DENALI_PHY_30_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_31_DATA */ + 0x00005555, /* DENALI_PHY_32_DATA */ + 0x00000000, /* DENALI_PHY_33_DATA */ + 0x00000000, /* DENALI_PHY_34_DATA */ + 0x00000000, /* DENALI_PHY_35_DATA */ + 0x00000000, /* DENALI_PHY_36_DATA */ + 0x00000000, /* DENALI_PHY_37_DATA */ + 0x00000000, /* DENALI_PHY_38_DATA */ + 0x00000000, /* DENALI_PHY_39_DATA */ + 0x00000000, /* DENALI_PHY_40_DATA */ + 0x00000000, /* DENALI_PHY_41_DATA */ + 0x00000000, /* DENALI_PHY_42_DATA */ + 0x00000000, /* DENALI_PHY_43_DATA */ + 0x00000000, /* DENALI_PHY_44_DATA */ + 0x00000000, /* DENALI_PHY_45_DATA */ + 0x00000000, /* DENALI_PHY_46_DATA */ + 0x00000000, /* DENALI_PHY_47_DATA */ + 0x00000000, /* DENALI_PHY_48_DATA */ + 0x00000000, /* DENALI_PHY_49_DATA */ + 0x00000000, /* DENALI_PHY_50_DATA */ + 0x00000000, /* DENALI_PHY_51_DATA */ + 0x00200000, /* DENALI_PHY_52_DATA */ + 0x00000000, /* DENALI_PHY_53_DATA */ + 0x00000000, /* DENALI_PHY_54_DATA */ + 0x00000000, /* DENALI_PHY_55_DATA */ + 0x00000000, /* DENALI_PHY_56_DATA */ + 0x00000000, /* DENALI_PHY_57_DATA */ + 0x00000000, /* DENALI_PHY_58_DATA */ + 0x02800280, /* DENALI_PHY_59_DATA */ + 0x02800280, /* DENALI_PHY_60_DATA */ + 0x02800280, /* DENALI_PHY_61_DATA */ + 0x02800280, /* DENALI_PHY_62_DATA */ + 0x00000280, /* DENALI_PHY_63_DATA */ + 0x00000000, /* DENALI_PHY_64_DATA */ + 0x00000000, /* DENALI_PHY_65_DATA */ + 0x00000000, /* DENALI_PHY_66_DATA */ + 0x00000000, /* DENALI_PHY_67_DATA */ + 0x00800000, /* DENALI_PHY_68_DATA */ + 0x00800080, /* DENALI_PHY_69_DATA */ + 0x00800080, /* DENALI_PHY_70_DATA */ + 0x00800080, /* DENALI_PHY_71_DATA */ + 0x00800080, /* DENALI_PHY_72_DATA */ + 0x00800080, /* DENALI_PHY_73_DATA */ + 0x00800080, /* DENALI_PHY_74_DATA */ + 0x00800080, /* DENALI_PHY_75_DATA */ + 0x00800080, /* DENALI_PHY_76_DATA */ + 0x00b30080, /* DENALI_PHY_77_DATA */ + 0x01900003, /* DENALI_PHY_78_DATA */ + 0x00000000, /* DENALI_PHY_79_DATA */ + 0x00020000, /* DENALI_PHY_80_DATA */ + 0x00000200, /* DENALI_PHY_81_DATA */ + 0x00000000, /* DENALI_PHY_82_DATA */ + 0x51315152, /* DENALI_PHY_83_DATA */ + 0xc0013150, /* DENALI_PHY_84_DATA */ + 0x020000c0, /* DENALI_PHY_85_DATA */ + 0x00100001, /* DENALI_PHY_86_DATA */ + 0x0c054208, /* DENALI_PHY_87_DATA */ + 0x000f0c18, /* DENALI_PHY_88_DATA */ + 0x01000140, /* DENALI_PHY_89_DATA */ + 0x00000c20, /* DENALI_PHY_90_DATA */ + 0x00000000, /* DENALI_PHY_91_DATA */ + 0x00000000, /* DENALI_PHY_92_DATA */ + 0x00000000, /* DENALI_PHY_93_DATA */ + 0x00000000, /* DENALI_PHY_94_DATA */ + 0x00000000, /* DENALI_PHY_95_DATA */ + 0x00000000, /* DENALI_PHY_96_DATA */ + 0x00000000, /* DENALI_PHY_97_DATA */ + 0x00000000, /* DENALI_PHY_98_DATA */ + 0x00000000, /* DENALI_PHY_99_DATA */ + 0x00000000, /* DENALI_PHY_100_DATA */ + 0x00000000, /* DENALI_PHY_101_DATA */ + 0x00000000, /* DENALI_PHY_102_DATA */ + 0x00000000, /* DENALI_PHY_103_DATA */ + 0x00000000, /* DENALI_PHY_104_DATA */ + 0x00000000, /* DENALI_PHY_105_DATA */ + 0x00000000, /* DENALI_PHY_106_DATA */ + 0x00000000, /* DENALI_PHY_107_DATA */ + 0x00000000, /* DENALI_PHY_108_DATA */ + 0x00000000, /* DENALI_PHY_109_DATA */ + 0x00000000, /* DENALI_PHY_110_DATA */ + 0x00000000, /* DENALI_PHY_111_DATA */ + 0x00000000, /* DENALI_PHY_112_DATA */ + 0x00000000, /* DENALI_PHY_113_DATA */ + 0x00000000, /* DENALI_PHY_114_DATA */ + 0x00000000, /* DENALI_PHY_115_DATA */ + 0x00000000, /* DENALI_PHY_116_DATA */ + 0x00000000, /* DENALI_PHY_117_DATA */ + 0x00000000, /* DENALI_PHY_118_DATA */ + 0x00000000, /* DENALI_PHY_119_DATA */ + 0x00000000, /* DENALI_PHY_120_DATA */ + 0x00000000, /* DENALI_PHY_121_DATA */ + 0x00000000, /* DENALI_PHY_122_DATA */ + 0x00000000, /* DENALI_PHY_123_DATA */ + 0x00000000, /* DENALI_PHY_124_DATA */ + 0x00000000, /* DENALI_PHY_125_DATA */ + 0x00000000, /* DENALI_PHY_126_DATA */ + 0x00000000, /* DENALI_PHY_127_DATA */ + 0x76543210, /* DENALI_PHY_128_DATA */ + 0x0004c008, /* DENALI_PHY_129_DATA */ + 0x000000b3, /* DENALI_PHY_130_DATA */ + 0x00000000, /* DENALI_PHY_131_DATA */ + 0x00000000, /* DENALI_PHY_132_DATA */ + 0x00010000, /* DENALI_PHY_133_DATA */ + 0x01665555, /* DENALI_PHY_134_DATA */ + 0x00665555, /* DENALI_PHY_135_DATA */ + 0x00010f00, /* DENALI_PHY_136_DATA */ + 0x05010200, /* DENALI_PHY_137_DATA */ + 0x00000003, /* DENALI_PHY_138_DATA */ + 0x001700c0, /* DENALI_PHY_139_DATA */ + 0x00cc0101, /* DENALI_PHY_140_DATA */ + 0x00030066, /* DENALI_PHY_141_DATA */ + 0x00000000, /* DENALI_PHY_142_DATA */ + 0x00000000, /* DENALI_PHY_143_DATA */ + 0x00000000, /* DENALI_PHY_144_DATA */ + 0x00000000, /* DENALI_PHY_145_DATA */ + 0x00000000, /* DENALI_PHY_146_DATA */ + 0x00000000, /* DENALI_PHY_147_DATA */ + 0x00000000, /* DENALI_PHY_148_DATA */ + 0x00000000, /* DENALI_PHY_149_DATA */ + 0x04080000, /* DENALI_PHY_150_DATA */ + 0x04080400, /* DENALI_PHY_151_DATA */ + 0x08000000, /* DENALI_PHY_152_DATA */ + 0x0c00c007, /* DENALI_PHY_153_DATA */ + 0x00000100, /* DENALI_PHY_154_DATA */ + 0x00000100, /* DENALI_PHY_155_DATA */ + 0x55555555, /* DENALI_PHY_156_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_157_DATA */ + 0x55555555, /* DENALI_PHY_158_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_159_DATA */ + 0x00005555, /* DENALI_PHY_160_DATA */ + 0x00000000, /* DENALI_PHY_161_DATA */ + 0x00000000, /* DENALI_PHY_162_DATA */ + 0x00000000, /* DENALI_PHY_163_DATA */ + 0x00000000, /* DENALI_PHY_164_DATA */ + 0x00000000, /* DENALI_PHY_165_DATA */ + 0x00000000, /* DENALI_PHY_166_DATA */ + 0x00000000, /* DENALI_PHY_167_DATA */ + 0x00000000, /* DENALI_PHY_168_DATA */ + 0x00000000, /* DENALI_PHY_169_DATA */ + 0x00000000, /* DENALI_PHY_170_DATA */ + 0x00000000, /* DENALI_PHY_171_DATA */ + 0x00000000, /* DENALI_PHY_172_DATA */ + 0x00000000, /* DENALI_PHY_173_DATA */ + 0x00000000, /* DENALI_PHY_174_DATA */ + 0x00000000, /* DENALI_PHY_175_DATA */ + 0x00000000, /* DENALI_PHY_176_DATA */ + 0x00000000, /* DENALI_PHY_177_DATA */ + 0x00000000, /* DENALI_PHY_178_DATA */ + 0x00000000, /* DENALI_PHY_179_DATA */ + 0x00200000, /* DENALI_PHY_180_DATA */ + 0x00000000, /* DENALI_PHY_181_DATA */ + 0x00000000, /* DENALI_PHY_182_DATA */ + 0x00000000, /* DENALI_PHY_183_DATA */ + 0x00000000, /* DENALI_PHY_184_DATA */ + 0x00000000, /* DENALI_PHY_185_DATA */ + 0x00000000, /* DENALI_PHY_186_DATA */ + 0x02800280, /* DENALI_PHY_187_DATA */ + 0x02800280, /* DENALI_PHY_188_DATA */ + 0x02800280, /* DENALI_PHY_189_DATA */ + 0x02800280, /* DENALI_PHY_190_DATA */ + 0x00000280, /* DENALI_PHY_191_DATA */ + 0x00000000, /* DENALI_PHY_192_DATA */ + 0x00000000, /* DENALI_PHY_193_DATA */ + 0x00000000, /* DENALI_PHY_194_DATA */ + 0x00000000, /* DENALI_PHY_195_DATA */ + 0x00800000, /* DENALI_PHY_196_DATA */ + 0x00800080, /* DENALI_PHY_197_DATA */ + 0x00800080, /* DENALI_PHY_198_DATA */ + 0x00800080, /* DENALI_PHY_199_DATA */ + 0x00800080, /* DENALI_PHY_200_DATA */ + 0x00800080, /* DENALI_PHY_201_DATA */ + 0x00800080, /* DENALI_PHY_202_DATA */ + 0x00800080, /* DENALI_PHY_203_DATA */ + 0x00800080, /* DENALI_PHY_204_DATA */ + 0x00b30080, /* DENALI_PHY_205_DATA */ + 0x01900003, /* DENALI_PHY_206_DATA */ + 0x00000000, /* DENALI_PHY_207_DATA */ + 0x00020000, /* DENALI_PHY_208_DATA */ + 0x00000200, /* DENALI_PHY_209_DATA */ + 0x00000000, /* DENALI_PHY_210_DATA */ + 0x51315152, /* DENALI_PHY_211_DATA */ + 0xc0013150, /* DENALI_PHY_212_DATA */ + 0x020000c0, /* DENALI_PHY_213_DATA */ + 0x00100001, /* DENALI_PHY_214_DATA */ + 0x0c054208, /* DENALI_PHY_215_DATA */ + 0x000f0c18, /* DENALI_PHY_216_DATA */ + 0x01000140, /* DENALI_PHY_217_DATA */ + 0x00000c20, /* DENALI_PHY_218_DATA */ + 0x00000000, /* DENALI_PHY_219_DATA */ + 0x00000000, /* DENALI_PHY_220_DATA */ + 0x00000000, /* DENALI_PHY_221_DATA */ + 0x00000000, /* DENALI_PHY_222_DATA */ + 0x00000000, /* DENALI_PHY_223_DATA */ + 0x00000000, /* DENALI_PHY_224_DATA */ + 0x00000000, /* DENALI_PHY_225_DATA */ + 0x00000000, /* DENALI_PHY_226_DATA */ + 0x00000000, /* DENALI_PHY_227_DATA */ + 0x00000000, /* DENALI_PHY_228_DATA */ + 0x00000000, /* DENALI_PHY_229_DATA */ + 0x00000000, /* DENALI_PHY_230_DATA */ + 0x00000000, /* DENALI_PHY_231_DATA */ + 0x00000000, /* DENALI_PHY_232_DATA */ + 0x00000000, /* DENALI_PHY_233_DATA */ + 0x00000000, /* DENALI_PHY_234_DATA */ + 0x00000000, /* DENALI_PHY_235_DATA */ + 0x00000000, /* DENALI_PHY_236_DATA */ + 0x00000000, /* DENALI_PHY_237_DATA */ + 0x00000000, /* DENALI_PHY_238_DATA */ + 0x00000000, /* DENALI_PHY_239_DATA */ + 0x00000000, /* DENALI_PHY_240_DATA */ + 0x00000000, /* DENALI_PHY_241_DATA */ + 0x00000000, /* DENALI_PHY_242_DATA */ + 0x00000000, /* DENALI_PHY_243_DATA */ + 0x00000000, /* DENALI_PHY_244_DATA */ + 0x00000000, /* DENALI_PHY_245_DATA */ + 0x00000000, /* DENALI_PHY_246_DATA */ + 0x00000000, /* DENALI_PHY_247_DATA */ + 0x00000000, /* DENALI_PHY_248_DATA */ + 0x00000000, /* DENALI_PHY_249_DATA */ + 0x00000000, /* DENALI_PHY_250_DATA */ + 0x00000000, /* DENALI_PHY_251_DATA */ + 0x00000000, /* DENALI_PHY_252_DATA */ + 0x00000000, /* DENALI_PHY_253_DATA */ + 0x00000000, /* DENALI_PHY_254_DATA */ + 0x00000000, /* DENALI_PHY_255_DATA */ + 0x76543210, /* DENALI_PHY_256_DATA */ + 0x0004c008, /* DENALI_PHY_257_DATA */ + 0x000000b3, /* DENALI_PHY_258_DATA */ + 0x00000000, /* DENALI_PHY_259_DATA */ + 0x00000000, /* DENALI_PHY_260_DATA */ + 0x00010000, /* DENALI_PHY_261_DATA */ + 0x01665555, /* DENALI_PHY_262_DATA */ + 0x00665555, /* DENALI_PHY_263_DATA */ + 0x00010f00, /* DENALI_PHY_264_DATA */ + 0x05010200, /* DENALI_PHY_265_DATA */ + 0x00000003, /* DENALI_PHY_266_DATA */ + 0x001700c0, /* DENALI_PHY_267_DATA */ + 0x00cc0101, /* DENALI_PHY_268_DATA */ + 0x00030066, /* DENALI_PHY_269_DATA */ + 0x00000000, /* DENALI_PHY_270_DATA */ + 0x00000000, /* DENALI_PHY_271_DATA */ + 0x00000000, /* DENALI_PHY_272_DATA */ + 0x00000000, /* DENALI_PHY_273_DATA */ + 0x00000000, /* DENALI_PHY_274_DATA */ + 0x00000000, /* DENALI_PHY_275_DATA */ + 0x00000000, /* DENALI_PHY_276_DATA */ + 0x00000000, /* DENALI_PHY_277_DATA */ + 0x04080000, /* DENALI_PHY_278_DATA */ + 0x04080400, /* DENALI_PHY_279_DATA */ + 0x08000000, /* DENALI_PHY_280_DATA */ + 0x0c00c007, /* DENALI_PHY_281_DATA */ + 0x00000100, /* DENALI_PHY_282_DATA */ + 0x00000100, /* DENALI_PHY_283_DATA */ + 0x55555555, /* DENALI_PHY_284_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_285_DATA */ + 0x55555555, /* DENALI_PHY_286_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_287_DATA */ + 0x00005555, /* DENALI_PHY_288_DATA */ + 0x00000000, /* DENALI_PHY_289_DATA */ + 0x00000000, /* DENALI_PHY_290_DATA */ + 0x00000000, /* DENALI_PHY_291_DATA */ + 0x00000000, /* DENALI_PHY_292_DATA */ + 0x00000000, /* DENALI_PHY_293_DATA */ + 0x00000000, /* DENALI_PHY_294_DATA */ + 0x00000000, /* DENALI_PHY_295_DATA */ + 0x00000000, /* DENALI_PHY_296_DATA */ + 0x00000000, /* DENALI_PHY_297_DATA */ + 0x00000000, /* DENALI_PHY_298_DATA */ + 0x00000000, /* DENALI_PHY_299_DATA */ + 0x00000000, /* DENALI_PHY_300_DATA */ + 0x00000000, /* DENALI_PHY_301_DATA */ + 0x00000000, /* DENALI_PHY_302_DATA */ + 0x00000000, /* DENALI_PHY_303_DATA */ + 0x00000000, /* DENALI_PHY_304_DATA */ + 0x00000000, /* DENALI_PHY_305_DATA */ + 0x00000000, /* DENALI_PHY_306_DATA */ + 0x00000000, /* DENALI_PHY_307_DATA */ + 0x00200000, /* DENALI_PHY_308_DATA */ + 0x00000000, /* DENALI_PHY_309_DATA */ + 0x00000000, /* DENALI_PHY_310_DATA */ + 0x00000000, /* DENALI_PHY_311_DATA */ + 0x00000000, /* DENALI_PHY_312_DATA */ + 0x00000000, /* DENALI_PHY_313_DATA */ + 0x00000000, /* DENALI_PHY_314_DATA */ + 0x02800280, /* DENALI_PHY_315_DATA */ + 0x02800280, /* DENALI_PHY_316_DATA */ + 0x02800280, /* DENALI_PHY_317_DATA */ + 0x02800280, /* DENALI_PHY_318_DATA */ + 0x00000280, /* DENALI_PHY_319_DATA */ + 0x00000000, /* DENALI_PHY_320_DATA */ + 0x00000000, /* DENALI_PHY_321_DATA */ + 0x00000000, /* DENALI_PHY_322_DATA */ + 0x00000000, /* DENALI_PHY_323_DATA */ + 0x00800000, /* DENALI_PHY_324_DATA */ + 0x00800080, /* DENALI_PHY_325_DATA */ + 0x00800080, /* DENALI_PHY_326_DATA */ + 0x00800080, /* DENALI_PHY_327_DATA */ + 0x00800080, /* DENALI_PHY_328_DATA */ + 0x00800080, /* DENALI_PHY_329_DATA */ + 0x00800080, /* DENALI_PHY_330_DATA */ + 0x00800080, /* DENALI_PHY_331_DATA */ + 0x00800080, /* DENALI_PHY_332_DATA */ + 0x00b30080, /* DENALI_PHY_333_DATA */ + 0x01900003, /* DENALI_PHY_334_DATA */ + 0x00000000, /* DENALI_PHY_335_DATA */ + 0x00020000, /* DENALI_PHY_336_DATA */ + 0x00000200, /* DENALI_PHY_337_DATA */ + 0x00000000, /* DENALI_PHY_338_DATA */ + 0x51315152, /* DENALI_PHY_339_DATA */ + 0xc0013150, /* DENALI_PHY_340_DATA */ + 0x020000c0, /* DENALI_PHY_341_DATA */ + 0x00100001, /* DENALI_PHY_342_DATA */ + 0x0c054208, /* DENALI_PHY_343_DATA */ + 0x000f0c18, /* DENALI_PHY_344_DATA */ + 0x01000140, /* DENALI_PHY_345_DATA */ + 0x00000c20, /* DENALI_PHY_346_DATA */ + 0x00000000, /* DENALI_PHY_347_DATA */ + 0x00000000, /* DENALI_PHY_348_DATA */ + 0x00000000, /* DENALI_PHY_349_DATA */ + 0x00000000, /* DENALI_PHY_350_DATA */ + 0x00000000, /* DENALI_PHY_351_DATA */ + 0x00000000, /* DENALI_PHY_352_DATA */ + 0x00000000, /* DENALI_PHY_353_DATA */ + 0x00000000, /* DENALI_PHY_354_DATA */ + 0x00000000, /* DENALI_PHY_355_DATA */ + 0x00000000, /* DENALI_PHY_356_DATA */ + 0x00000000, /* DENALI_PHY_357_DATA */ + 0x00000000, /* DENALI_PHY_358_DATA */ + 0x00000000, /* DENALI_PHY_359_DATA */ + 0x00000000, /* DENALI_PHY_360_DATA */ + 0x00000000, /* DENALI_PHY_361_DATA */ + 0x00000000, /* DENALI_PHY_362_DATA */ + 0x00000000, /* DENALI_PHY_363_DATA */ + 0x00000000, /* DENALI_PHY_364_DATA */ + 0x00000000, /* DENALI_PHY_365_DATA */ + 0x00000000, /* DENALI_PHY_366_DATA */ + 0x00000000, /* DENALI_PHY_367_DATA */ + 0x00000000, /* DENALI_PHY_368_DATA */ + 0x00000000, /* DENALI_PHY_369_DATA */ + 0x00000000, /* DENALI_PHY_370_DATA */ + 0x00000000, /* DENALI_PHY_371_DATA */ + 0x00000000, /* DENALI_PHY_372_DATA */ + 0x00000000, /* DENALI_PHY_373_DATA */ + 0x00000000, /* DENALI_PHY_374_DATA */ + 0x00000000, /* DENALI_PHY_375_DATA */ + 0x00000000, /* DENALI_PHY_376_DATA */ + 0x00000000, /* DENALI_PHY_377_DATA */ + 0x00000000, /* DENALI_PHY_378_DATA */ + 0x00000000, /* DENALI_PHY_379_DATA */ + 0x00000000, /* DENALI_PHY_380_DATA */ + 0x00000000, /* DENALI_PHY_381_DATA */ + 0x00000000, /* DENALI_PHY_382_DATA */ + 0x00000000, /* DENALI_PHY_383_DATA */ + 0x76543210, /* DENALI_PHY_384_DATA */ + 0x0004c008, /* DENALI_PHY_385_DATA */ + 0x000000b3, /* DENALI_PHY_386_DATA */ + 0x00000000, /* DENALI_PHY_387_DATA */ + 0x00000000, /* DENALI_PHY_388_DATA */ + 0x00010000, /* DENALI_PHY_389_DATA */ + 0x01665555, /* DENALI_PHY_390_DATA */ + 0x00665555, /* DENALI_PHY_391_DATA */ + 0x00010f00, /* DENALI_PHY_392_DATA */ + 0x05010200, /* DENALI_PHY_393_DATA */ + 0x00000003, /* DENALI_PHY_394_DATA */ + 0x001700c0, /* DENALI_PHY_395_DATA */ + 0x00cc0101, /* DENALI_PHY_396_DATA */ + 0x00030066, /* DENALI_PHY_397_DATA */ + 0x00000000, /* DENALI_PHY_398_DATA */ + 0x00000000, /* DENALI_PHY_399_DATA */ + 0x00000000, /* DENALI_PHY_400_DATA */ + 0x00000000, /* DENALI_PHY_401_DATA */ + 0x00000000, /* DENALI_PHY_402_DATA */ + 0x00000000, /* DENALI_PHY_403_DATA */ + 0x00000000, /* DENALI_PHY_404_DATA */ + 0x00000000, /* DENALI_PHY_405_DATA */ + 0x04080000, /* DENALI_PHY_406_DATA */ + 0x04080400, /* DENALI_PHY_407_DATA */ + 0x08000000, /* DENALI_PHY_408_DATA */ + 0x0c00c007, /* DENALI_PHY_409_DATA */ + 0x00000100, /* DENALI_PHY_410_DATA */ + 0x00000100, /* DENALI_PHY_411_DATA */ + 0x55555555, /* DENALI_PHY_412_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_413_DATA */ + 0x55555555, /* DENALI_PHY_414_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_415_DATA */ + 0x00005555, /* DENALI_PHY_416_DATA */ + 0x00000000, /* DENALI_PHY_417_DATA */ + 0x00000000, /* DENALI_PHY_418_DATA */ + 0x00000000, /* DENALI_PHY_419_DATA */ + 0x00000000, /* DENALI_PHY_420_DATA */ + 0x00000000, /* DENALI_PHY_421_DATA */ + 0x00000000, /* DENALI_PHY_422_DATA */ + 0x00000000, /* DENALI_PHY_423_DATA */ + 0x00000000, /* DENALI_PHY_424_DATA */ + 0x00000000, /* DENALI_PHY_425_DATA */ + 0x00000000, /* DENALI_PHY_426_DATA */ + 0x00000000, /* DENALI_PHY_427_DATA */ + 0x00000000, /* DENALI_PHY_428_DATA */ + 0x00000000, /* DENALI_PHY_429_DATA */ + 0x00000000, /* DENALI_PHY_430_DATA */ + 0x00000000, /* DENALI_PHY_431_DATA */ + 0x00000000, /* DENALI_PHY_432_DATA */ + 0x00000000, /* DENALI_PHY_433_DATA */ + 0x00000000, /* DENALI_PHY_434_DATA */ + 0x00000000, /* DENALI_PHY_435_DATA */ + 0x00200000, /* DENALI_PHY_436_DATA */ + 0x00000000, /* DENALI_PHY_437_DATA */ + 0x00000000, /* DENALI_PHY_438_DATA */ + 0x00000000, /* DENALI_PHY_439_DATA */ + 0x00000000, /* DENALI_PHY_440_DATA */ + 0x00000000, /* DENALI_PHY_441_DATA */ + 0x00000000, /* DENALI_PHY_442_DATA */ + 0x02800280, /* DENALI_PHY_443_DATA */ + 0x02800280, /* DENALI_PHY_444_DATA */ + 0x02800280, /* DENALI_PHY_445_DATA */ + 0x02800280, /* DENALI_PHY_446_DATA */ + 0x00000280, /* DENALI_PHY_447_DATA */ + 0x00000000, /* DENALI_PHY_448_DATA */ + 0x00000000, /* DENALI_PHY_449_DATA */ + 0x00000000, /* DENALI_PHY_450_DATA */ + 0x00000000, /* DENALI_PHY_451_DATA */ + 0x00800000, /* DENALI_PHY_452_DATA */ + 0x00800080, /* DENALI_PHY_453_DATA */ + 0x00800080, /* DENALI_PHY_454_DATA */ + 0x00800080, /* DENALI_PHY_455_DATA */ + 0x00800080, /* DENALI_PHY_456_DATA */ + 0x00800080, /* DENALI_PHY_457_DATA */ + 0x00800080, /* DENALI_PHY_458_DATA */ + 0x00800080, /* DENALI_PHY_459_DATA */ + 0x00800080, /* DENALI_PHY_460_DATA */ + 0x00b30080, /* DENALI_PHY_461_DATA */ + 0x01900003, /* DENALI_PHY_462_DATA */ + 0x00000000, /* DENALI_PHY_463_DATA */ + 0x00020000, /* DENALI_PHY_464_DATA */ + 0x00000200, /* DENALI_PHY_465_DATA */ + 0x00000000, /* DENALI_PHY_466_DATA */ + 0x51315152, /* DENALI_PHY_467_DATA */ + 0xc0013150, /* DENALI_PHY_468_DATA */ + 0x020000c0, /* DENALI_PHY_469_DATA */ + 0x00100001, /* DENALI_PHY_470_DATA */ + 0x0c054208, /* DENALI_PHY_471_DATA */ + 0x000f0c18, /* DENALI_PHY_472_DATA */ + 0x01000140, /* DENALI_PHY_473_DATA */ + 0x00000c20, /* DENALI_PHY_474_DATA */ + 0x00000000, /* DENALI_PHY_475_DATA */ + 0x00000000, /* DENALI_PHY_476_DATA */ + 0x00000000, /* DENALI_PHY_477_DATA */ + 0x00000000, /* DENALI_PHY_478_DATA */ + 0x00000000, /* DENALI_PHY_479_DATA */ + 0x00000000, /* DENALI_PHY_480_DATA */ + 0x00000000, /* DENALI_PHY_481_DATA */ + 0x00000000, /* DENALI_PHY_482_DATA */ + 0x00000000, /* DENALI_PHY_483_DATA */ + 0x00000000, /* DENALI_PHY_484_DATA */ + 0x00000000, /* DENALI_PHY_485_DATA */ + 0x00000000, /* DENALI_PHY_486_DATA */ + 0x00000000, /* DENALI_PHY_487_DATA */ + 0x00000000, /* DENALI_PHY_488_DATA */ + 0x00000000, /* DENALI_PHY_489_DATA */ + 0x00000000, /* DENALI_PHY_490_DATA */ + 0x00000000, /* DENALI_PHY_491_DATA */ + 0x00000000, /* DENALI_PHY_492_DATA */ + 0x00000000, /* DENALI_PHY_493_DATA */ + 0x00000000, /* DENALI_PHY_494_DATA */ + 0x00000000, /* DENALI_PHY_495_DATA */ + 0x00000000, /* DENALI_PHY_496_DATA */ + 0x00000000, /* DENALI_PHY_497_DATA */ + 0x00000000, /* DENALI_PHY_498_DATA */ + 0x00000000, /* DENALI_PHY_499_DATA */ + 0x00000000, /* DENALI_PHY_500_DATA */ + 0x00000000, /* DENALI_PHY_501_DATA */ + 0x00000000, /* DENALI_PHY_502_DATA */ + 0x00000000, /* DENALI_PHY_503_DATA */ + 0x00000000, /* DENALI_PHY_504_DATA */ + 0x00000000, /* DENALI_PHY_505_DATA */ + 0x00000000, /* DENALI_PHY_506_DATA */ + 0x00000000, /* DENALI_PHY_507_DATA */ + 0x00000000, /* DENALI_PHY_508_DATA */ + 0x00000000, /* DENALI_PHY_509_DATA */ + 0x00000000, /* DENALI_PHY_510_DATA */ + 0x00000000, /* DENALI_PHY_511_DATA */ + 0x00000000, /* DENALI_PHY_512_DATA */ + 0x00800000, /* DENALI_PHY_513_DATA */ + 0x00000000, /* DENALI_PHY_514_DATA */ + 0x00000000, /* DENALI_PHY_515_DATA */ + 0x00000000, /* DENALI_PHY_516_DATA */ + 0x00000000, /* DENALI_PHY_517_DATA */ + 0x00000000, /* DENALI_PHY_518_DATA */ + 0x00000001, /* DENALI_PHY_519_DATA */ + 0x00000000, /* DENALI_PHY_520_DATA */ + 0x00000000, /* DENALI_PHY_521_DATA */ + 0x00000000, /* DENALI_PHY_522_DATA */ + 0x00400320, /* DENALI_PHY_523_DATA */ + 0x00000040, /* DENALI_PHY_524_DATA */ + 0x00806420, /* DENALI_PHY_525_DATA */ + 0x00917531, /* DENALI_PHY_526_DATA */ + 0x00806420, /* DENALI_PHY_527_DATA */ + 0x01917531, /* DENALI_PHY_528_DATA */ + 0x00020003, /* DENALI_PHY_529_DATA */ + 0x00000000, /* DENALI_PHY_530_DATA */ + 0x00000000, /* DENALI_PHY_531_DATA */ + 0x00000000, /* DENALI_PHY_532_DATA */ + 0x000556aa, /* DENALI_PHY_533_DATA */ + 0x000aaaaa, /* DENALI_PHY_534_DATA */ + 0x000aa955, /* DENALI_PHY_535_DATA */ + 0x00055555, /* DENALI_PHY_536_DATA */ + 0x000b3133, /* DENALI_PHY_537_DATA */ + 0x0004cd33, /* DENALI_PHY_538_DATA */ + 0x0004cecc, /* DENALI_PHY_539_DATA */ + 0x000b32cc, /* DENALI_PHY_540_DATA */ + 0x0a418820, /* DENALI_PHY_541_DATA */ + 0x103f0000, /* DENALI_PHY_542_DATA */ + 0x0000003f, /* DENALI_PHY_543_DATA */ + 0x00038055, /* DENALI_PHY_544_DATA */ + 0x03800380, /* DENALI_PHY_545_DATA */ + 0x03800380, /* DENALI_PHY_546_DATA */ + 0x00000380, /* DENALI_PHY_547_DATA */ + 0x42080010, /* DENALI_PHY_548_DATA */ + 0x00000003, /* DENALI_PHY_549_DATA */ + 0x00000000, /* DENALI_PHY_550_DATA */ + 0x00000000, /* DENALI_PHY_551_DATA */ + 0x00000000, /* DENALI_PHY_552_DATA */ + 0x00000000, /* DENALI_PHY_553_DATA */ + 0x00000000, /* DENALI_PHY_554_DATA */ + 0x00000000, /* DENALI_PHY_555_DATA */ + 0x00000000, /* DENALI_PHY_556_DATA */ + 0x00000000, /* DENALI_PHY_557_DATA */ + 0x00000000, /* DENALI_PHY_558_DATA */ + 0x00000000, /* DENALI_PHY_559_DATA */ + 0x00000000, /* DENALI_PHY_560_DATA */ + 0x00000000, /* DENALI_PHY_561_DATA */ + 0x00000000, /* DENALI_PHY_562_DATA */ + 0x00000000, /* DENALI_PHY_563_DATA */ + 0x00000000, /* DENALI_PHY_564_DATA */ + 0x00000000, /* DENALI_PHY_565_DATA */ + 0x00000000, /* DENALI_PHY_566_DATA */ + 0x00000000, /* DENALI_PHY_567_DATA */ + 0x00000000, /* DENALI_PHY_568_DATA */ + 0x00000000, /* DENALI_PHY_569_DATA */ + 0x00000000, /* DENALI_PHY_570_DATA */ + 0x00000000, /* DENALI_PHY_571_DATA */ + 0x00000000, /* DENALI_PHY_572_DATA */ + 0x00000000, /* DENALI_PHY_573_DATA */ + 0x00000000, /* DENALI_PHY_574_DATA */ + 0x00000000, /* DENALI_PHY_575_DATA */ + 0x00000000, /* DENALI_PHY_576_DATA */ + 0x00000000, /* DENALI_PHY_577_DATA */ + 0x00000000, /* DENALI_PHY_578_DATA */ + 0x00000000, /* DENALI_PHY_579_DATA */ + 0x00000000, /* DENALI_PHY_580_DATA */ + 0x00000000, /* DENALI_PHY_581_DATA */ + 0x00000000, /* DENALI_PHY_582_DATA */ + 0x00000000, /* DENALI_PHY_583_DATA */ + 0x00000000, /* DENALI_PHY_584_DATA */ + 0x00000000, /* DENALI_PHY_585_DATA */ + 0x00000000, /* DENALI_PHY_586_DATA */ + 0x00000000, /* DENALI_PHY_587_DATA */ + 0x00000000, /* DENALI_PHY_588_DATA */ + 0x00000000, /* DENALI_PHY_589_DATA */ + 0x00000000, /* DENALI_PHY_590_DATA */ + 0x00000000, /* DENALI_PHY_591_DATA */ + 0x00000000, /* DENALI_PHY_592_DATA */ + 0x00000000, /* DENALI_PHY_593_DATA */ + 0x00000000, /* DENALI_PHY_594_DATA */ + 0x00000000, /* DENALI_PHY_595_DATA */ + 0x00000000, /* DENALI_PHY_596_DATA */ + 0x00000000, /* DENALI_PHY_597_DATA */ + 0x00000000, /* DENALI_PHY_598_DATA */ + 0x00000000, /* DENALI_PHY_599_DATA */ + 0x00000000, /* DENALI_PHY_600_DATA */ + 0x00000000, /* DENALI_PHY_601_DATA */ + 0x00000000, /* DENALI_PHY_602_DATA */ + 0x00000000, /* DENALI_PHY_603_DATA */ + 0x00000000, /* DENALI_PHY_604_DATA */ + 0x00000000, /* DENALI_PHY_605_DATA */ + 0x00000000, /* DENALI_PHY_606_DATA */ + 0x00000000, /* DENALI_PHY_607_DATA */ + 0x00000000, /* DENALI_PHY_608_DATA */ + 0x00000000, /* DENALI_PHY_609_DATA */ + 0x00000000, /* DENALI_PHY_610_DATA */ + 0x00000000, /* DENALI_PHY_611_DATA */ + 0x00000000, /* DENALI_PHY_612_DATA */ + 0x00000000, /* DENALI_PHY_613_DATA */ + 0x00000000, /* DENALI_PHY_614_DATA */ + 0x00000000, /* DENALI_PHY_615_DATA */ + 0x00000000, /* DENALI_PHY_616_DATA */ + 0x00000000, /* DENALI_PHY_617_DATA */ + 0x00000000, /* DENALI_PHY_618_DATA */ + 0x00000000, /* DENALI_PHY_619_DATA */ + 0x00000000, /* DENALI_PHY_620_DATA */ + 0x00000000, /* DENALI_PHY_621_DATA */ + 0x00000000, /* DENALI_PHY_622_DATA */ + 0x00000000, /* DENALI_PHY_623_DATA */ + 0x00000000, /* DENALI_PHY_624_DATA */ + 0x00000000, /* DENALI_PHY_625_DATA */ + 0x00000000, /* DENALI_PHY_626_DATA */ + 0x00000000, /* DENALI_PHY_627_DATA */ + 0x00000000, /* DENALI_PHY_628_DATA */ + 0x00000000, /* DENALI_PHY_629_DATA */ + 0x00000000, /* DENALI_PHY_630_DATA */ + 0x00000000, /* DENALI_PHY_631_DATA */ + 0x00000000, /* DENALI_PHY_632_DATA */ + 0x00000000, /* DENALI_PHY_633_DATA */ + 0x00000000, /* DENALI_PHY_634_DATA */ + 0x00000000, /* DENALI_PHY_635_DATA */ + 0x00000000, /* DENALI_PHY_636_DATA */ + 0x00000000, /* DENALI_PHY_637_DATA */ + 0x00000000, /* DENALI_PHY_638_DATA */ + 0x00000000, /* DENALI_PHY_639_DATA */ + 0x00000000, /* DENALI_PHY_640_DATA */ + 0x00800000, /* DENALI_PHY_641_DATA */ + 0x00000000, /* DENALI_PHY_642_DATA */ + 0x00000000, /* DENALI_PHY_643_DATA */ + 0x00000000, /* DENALI_PHY_644_DATA */ + 0x00000000, /* DENALI_PHY_645_DATA */ + 0x00000000, /* DENALI_PHY_646_DATA */ + 0x00000001, /* DENALI_PHY_647_DATA */ + 0x00000000, /* DENALI_PHY_648_DATA */ + 0x00000000, /* DENALI_PHY_649_DATA */ + 0x00000000, /* DENALI_PHY_650_DATA */ + 0x00400320, /* DENALI_PHY_651_DATA */ + 0x00000040, /* DENALI_PHY_652_DATA */ + 0x00008eca, /* DENALI_PHY_653_DATA */ + 0x00009fdb, /* DENALI_PHY_654_DATA */ + 0x00008eca, /* DENALI_PHY_655_DATA */ + 0x01009fdb, /* DENALI_PHY_656_DATA */ + 0x00020003, /* DENALI_PHY_657_DATA */ + 0x00000000, /* DENALI_PHY_658_DATA */ + 0x00000000, /* DENALI_PHY_659_DATA */ + 0x00000000, /* DENALI_PHY_660_DATA */ + 0x000556aa, /* DENALI_PHY_661_DATA */ + 0x000aaaaa, /* DENALI_PHY_662_DATA */ + 0x000aa955, /* DENALI_PHY_663_DATA */ + 0x00055555, /* DENALI_PHY_664_DATA */ + 0x000b3133, /* DENALI_PHY_665_DATA */ + 0x0004cd33, /* DENALI_PHY_666_DATA */ + 0x0004cecc, /* DENALI_PHY_667_DATA */ + 0x000b32cc, /* DENALI_PHY_668_DATA */ + 0x0004a0e6, /* DENALI_PHY_669_DATA */ + 0x080f0000, /* DENALI_PHY_670_DATA */ + 0x0000000f, /* DENALI_PHY_671_DATA */ + 0x00038055, /* DENALI_PHY_672_DATA */ + 0x03800380, /* DENALI_PHY_673_DATA */ + 0x03800380, /* DENALI_PHY_674_DATA */ + 0x00000380, /* DENALI_PHY_675_DATA */ + 0x42080010, /* DENALI_PHY_676_DATA */ + 0x00000003, /* DENALI_PHY_677_DATA */ + 0x00000000, /* DENALI_PHY_678_DATA */ + 0x00000000, /* DENALI_PHY_679_DATA */ + 0x00000000, /* DENALI_PHY_680_DATA */ + 0x00000000, /* DENALI_PHY_681_DATA */ + 0x00000000, /* DENALI_PHY_682_DATA */ + 0x00000000, /* DENALI_PHY_683_DATA */ + 0x00000000, /* DENALI_PHY_684_DATA */ + 0x00000000, /* DENALI_PHY_685_DATA */ + 0x00000000, /* DENALI_PHY_686_DATA */ + 0x00000000, /* DENALI_PHY_687_DATA */ + 0x00000000, /* DENALI_PHY_688_DATA */ + 0x00000000, /* DENALI_PHY_689_DATA */ + 0x00000000, /* DENALI_PHY_690_DATA */ + 0x00000000, /* DENALI_PHY_691_DATA */ + 0x00000000, /* DENALI_PHY_692_DATA */ + 0x00000000, /* DENALI_PHY_693_DATA */ + 0x00000000, /* DENALI_PHY_694_DATA */ + 0x00000000, /* DENALI_PHY_695_DATA */ + 0x00000000, /* DENALI_PHY_696_DATA */ + 0x00000000, /* DENALI_PHY_697_DATA */ + 0x00000000, /* DENALI_PHY_698_DATA */ + 0x00000000, /* DENALI_PHY_699_DATA */ + 0x00000000, /* DENALI_PHY_700_DATA */ + 0x00000000, /* DENALI_PHY_701_DATA */ + 0x00000000, /* DENALI_PHY_702_DATA */ + 0x00000000, /* DENALI_PHY_703_DATA */ + 0x00000000, /* DENALI_PHY_704_DATA */ + 0x00000000, /* DENALI_PHY_705_DATA */ + 0x00000000, /* DENALI_PHY_706_DATA */ + 0x00000000, /* DENALI_PHY_707_DATA */ + 0x00000000, /* DENALI_PHY_708_DATA */ + 0x00000000, /* DENALI_PHY_709_DATA */ + 0x00000000, /* DENALI_PHY_710_DATA */ + 0x00000000, /* DENALI_PHY_711_DATA */ + 0x00000000, /* DENALI_PHY_712_DATA */ + 0x00000000, /* DENALI_PHY_713_DATA */ + 0x00000000, /* DENALI_PHY_714_DATA */ + 0x00000000, /* DENALI_PHY_715_DATA */ + 0x00000000, /* DENALI_PHY_716_DATA */ + 0x00000000, /* DENALI_PHY_717_DATA */ + 0x00000000, /* DENALI_PHY_718_DATA */ + 0x00000000, /* DENALI_PHY_719_DATA */ + 0x00000000, /* DENALI_PHY_720_DATA */ + 0x00000000, /* DENALI_PHY_721_DATA */ + 0x00000000, /* DENALI_PHY_722_DATA */ + 0x00000000, /* DENALI_PHY_723_DATA */ + 0x00000000, /* DENALI_PHY_724_DATA */ + 0x00000000, /* DENALI_PHY_725_DATA */ + 0x00000000, /* DENALI_PHY_726_DATA */ + 0x00000000, /* DENALI_PHY_727_DATA */ + 0x00000000, /* DENALI_PHY_728_DATA */ + 0x00000000, /* DENALI_PHY_729_DATA */ + 0x00000000, /* DENALI_PHY_730_DATA */ + 0x00000000, /* DENALI_PHY_731_DATA */ + 0x00000000, /* DENALI_PHY_732_DATA */ + 0x00000000, /* DENALI_PHY_733_DATA */ + 0x00000000, /* DENALI_PHY_734_DATA */ + 0x00000000, /* DENALI_PHY_735_DATA */ + 0x00000000, /* DENALI_PHY_736_DATA */ + 0x00000000, /* DENALI_PHY_737_DATA */ + 0x00000000, /* DENALI_PHY_738_DATA */ + 0x00000000, /* DENALI_PHY_739_DATA */ + 0x00000000, /* DENALI_PHY_740_DATA */ + 0x00000000, /* DENALI_PHY_741_DATA */ + 0x00000000, /* DENALI_PHY_742_DATA */ + 0x00000000, /* DENALI_PHY_743_DATA */ + 0x00000000, /* DENALI_PHY_744_DATA */ + 0x00000000, /* DENALI_PHY_745_DATA */ + 0x00000000, /* DENALI_PHY_746_DATA */ + 0x00000000, /* DENALI_PHY_747_DATA */ + 0x00000000, /* DENALI_PHY_748_DATA */ + 0x00000000, /* DENALI_PHY_749_DATA */ + 0x00000000, /* DENALI_PHY_750_DATA */ + 0x00000000, /* DENALI_PHY_751_DATA */ + 0x00000000, /* DENALI_PHY_752_DATA */ + 0x00000000, /* DENALI_PHY_753_DATA */ + 0x00000000, /* DENALI_PHY_754_DATA */ + 0x00000000, /* DENALI_PHY_755_DATA */ + 0x00000000, /* DENALI_PHY_756_DATA */ + 0x00000000, /* DENALI_PHY_757_DATA */ + 0x00000000, /* DENALI_PHY_758_DATA */ + 0x00000000, /* DENALI_PHY_759_DATA */ + 0x00000000, /* DENALI_PHY_760_DATA */ + 0x00000000, /* DENALI_PHY_761_DATA */ + 0x00000000, /* DENALI_PHY_762_DATA */ + 0x00000000, /* DENALI_PHY_763_DATA */ + 0x00000000, /* DENALI_PHY_764_DATA */ + 0x00000000, /* DENALI_PHY_765_DATA */ + 0x00000000, /* DENALI_PHY_766_DATA */ + 0x00000000, /* DENALI_PHY_767_DATA */ + 0x00000000, /* DENALI_PHY_768_DATA */ + 0x00800000, /* DENALI_PHY_769_DATA */ + 0x00000000, /* DENALI_PHY_770_DATA */ + 0x00000000, /* DENALI_PHY_771_DATA */ + 0x00000000, /* DENALI_PHY_772_DATA */ + 0x00000000, /* DENALI_PHY_773_DATA */ + 0x00000000, /* DENALI_PHY_774_DATA */ + 0x00000001, /* DENALI_PHY_775_DATA */ + 0x00000000, /* DENALI_PHY_776_DATA */ + 0x00000000, /* DENALI_PHY_777_DATA */ + 0x00000000, /* DENALI_PHY_778_DATA */ + 0x00400320, /* DENALI_PHY_779_DATA */ + 0x00000040, /* DENALI_PHY_780_DATA */ + 0x00008eca, /* DENALI_PHY_781_DATA */ + 0x00009fdb, /* DENALI_PHY_782_DATA */ + 0x00008eca, /* DENALI_PHY_783_DATA */ + 0x01009fdb, /* DENALI_PHY_784_DATA */ + 0x00020003, /* DENALI_PHY_785_DATA */ + 0x00000000, /* DENALI_PHY_786_DATA */ + 0x00000000, /* DENALI_PHY_787_DATA */ + 0x00000000, /* DENALI_PHY_788_DATA */ + 0x000556aa, /* DENALI_PHY_789_DATA */ + 0x000aaaaa, /* DENALI_PHY_790_DATA */ + 0x000aa955, /* DENALI_PHY_791_DATA */ + 0x00055555, /* DENALI_PHY_792_DATA */ + 0x000b3133, /* DENALI_PHY_793_DATA */ + 0x0004cd33, /* DENALI_PHY_794_DATA */ + 0x0004cecc, /* DENALI_PHY_795_DATA */ + 0x000b32cc, /* DENALI_PHY_796_DATA */ + 0x1ee6b16a, /* DENALI_PHY_797_DATA */ + 0x10000000, /* DENALI_PHY_798_DATA */ + 0x00000000, /* DENALI_PHY_799_DATA */ + 0x00038055, /* DENALI_PHY_800_DATA */ + 0x03800380, /* DENALI_PHY_801_DATA */ + 0x03800380, /* DENALI_PHY_802_DATA */ + 0x00000380, /* DENALI_PHY_803_DATA */ + 0x42080010, /* DENALI_PHY_804_DATA */ + 0x00000003, /* DENALI_PHY_805_DATA */ + 0x00000000, /* DENALI_PHY_806_DATA */ + 0x00000000, /* DENALI_PHY_807_DATA */ + 0x00000000, /* DENALI_PHY_808_DATA */ + 0x00000000, /* DENALI_PHY_809_DATA */ + 0x00000000, /* DENALI_PHY_810_DATA */ + 0x00000000, /* DENALI_PHY_811_DATA */ + 0x00000000, /* DENALI_PHY_812_DATA */ + 0x00000000, /* DENALI_PHY_813_DATA */ + 0x00000000, /* DENALI_PHY_814_DATA */ + 0x00000000, /* DENALI_PHY_815_DATA */ + 0x00000000, /* DENALI_PHY_816_DATA */ + 0x00000000, /* DENALI_PHY_817_DATA */ + 0x00000000, /* DENALI_PHY_818_DATA */ + 0x00000000, /* DENALI_PHY_819_DATA */ + 0x00000000, /* DENALI_PHY_820_DATA */ + 0x00000000, /* DENALI_PHY_821_DATA */ + 0x00000000, /* DENALI_PHY_822_DATA */ + 0x00000000, /* DENALI_PHY_823_DATA */ + 0x00000000, /* DENALI_PHY_824_DATA */ + 0x00000000, /* DENALI_PHY_825_DATA */ + 0x00000000, /* DENALI_PHY_826_DATA */ + 0x00000000, /* DENALI_PHY_827_DATA */ + 0x00000000, /* DENALI_PHY_828_DATA */ + 0x00000000, /* DENALI_PHY_829_DATA */ + 0x00000000, /* DENALI_PHY_830_DATA */ + 0x00000000, /* DENALI_PHY_831_DATA */ + 0x00000000, /* DENALI_PHY_832_DATA */ + 0x00000000, /* DENALI_PHY_833_DATA */ + 0x00000000, /* DENALI_PHY_834_DATA */ + 0x00000000, /* DENALI_PHY_835_DATA */ + 0x00000000, /* DENALI_PHY_836_DATA */ + 0x00000000, /* DENALI_PHY_837_DATA */ + 0x00000000, /* DENALI_PHY_838_DATA */ + 0x00000000, /* DENALI_PHY_839_DATA */ + 0x00000000, /* DENALI_PHY_840_DATA */ + 0x00000000, /* DENALI_PHY_841_DATA */ + 0x00000000, /* DENALI_PHY_842_DATA */ + 0x00000000, /* DENALI_PHY_843_DATA */ + 0x00000000, /* DENALI_PHY_844_DATA */ + 0x00000000, /* DENALI_PHY_845_DATA */ + 0x00000000, /* DENALI_PHY_846_DATA */ + 0x00000000, /* DENALI_PHY_847_DATA */ + 0x00000000, /* DENALI_PHY_848_DATA */ + 0x00000000, /* DENALI_PHY_849_DATA */ + 0x00000000, /* DENALI_PHY_850_DATA */ + 0x00000000, /* DENALI_PHY_851_DATA */ + 0x00000000, /* DENALI_PHY_852_DATA */ + 0x00000000, /* DENALI_PHY_853_DATA */ + 0x00000000, /* DENALI_PHY_854_DATA */ + 0x00000000, /* DENALI_PHY_855_DATA */ + 0x00000000, /* DENALI_PHY_856_DATA */ + 0x00000000, /* DENALI_PHY_857_DATA */ + 0x00000000, /* DENALI_PHY_858_DATA */ + 0x00000000, /* DENALI_PHY_859_DATA */ + 0x00000000, /* DENALI_PHY_860_DATA */ + 0x00000000, /* DENALI_PHY_861_DATA */ + 0x00000000, /* DENALI_PHY_862_DATA */ + 0x00000000, /* DENALI_PHY_863_DATA */ + 0x00000000, /* DENALI_PHY_864_DATA */ + 0x00000000, /* DENALI_PHY_865_DATA */ + 0x00000000, /* DENALI_PHY_866_DATA */ + 0x00000000, /* DENALI_PHY_867_DATA */ + 0x00000000, /* DENALI_PHY_868_DATA */ + 0x00000000, /* DENALI_PHY_869_DATA */ + 0x00000000, /* DENALI_PHY_870_DATA */ + 0x00000000, /* DENALI_PHY_871_DATA */ + 0x00000000, /* DENALI_PHY_872_DATA */ + 0x00000000, /* DENALI_PHY_873_DATA */ + 0x00000000, /* DENALI_PHY_874_DATA */ + 0x00000000, /* DENALI_PHY_875_DATA */ + 0x00000000, /* DENALI_PHY_876_DATA */ + 0x00000000, /* DENALI_PHY_877_DATA */ + 0x00000000, /* DENALI_PHY_878_DATA */ + 0x00000000, /* DENALI_PHY_879_DATA */ + 0x00000000, /* DENALI_PHY_880_DATA */ + 0x00000000, /* DENALI_PHY_881_DATA */ + 0x00000000, /* DENALI_PHY_882_DATA */ + 0x00000000, /* DENALI_PHY_883_DATA */ + 0x00000000, /* DENALI_PHY_884_DATA */ + 0x00000000, /* DENALI_PHY_885_DATA */ + 0x00000000, /* DENALI_PHY_886_DATA */ + 0x00000000, /* DENALI_PHY_887_DATA */ + 0x00000000, /* DENALI_PHY_888_DATA */ + 0x00000000, /* DENALI_PHY_889_DATA */ + 0x00000000, /* DENALI_PHY_890_DATA */ + 0x00000000, /* DENALI_PHY_891_DATA */ + 0x00000000, /* DENALI_PHY_892_DATA */ + 0x00000000, /* DENALI_PHY_893_DATA */ + 0x00000000, /* DENALI_PHY_894_DATA */ + 0x00000000, /* DENALI_PHY_895_DATA */ + 0x00000001, /* DENALI_PHY_896_DATA */ + 0x00000000, /* DENALI_PHY_897_DATA */ + 0x01000005, /* DENALI_PHY_898_DATA */ + 0x04000f00, /* DENALI_PHY_899_DATA */ + 0x00020040, /* DENALI_PHY_900_DATA */ + 0x00020055, /* DENALI_PHY_901_DATA */ + 0x00000000, /* DENALI_PHY_902_DATA */ + 0x00000000, /* DENALI_PHY_903_DATA */ + 0x00000000, /* DENALI_PHY_904_DATA */ + 0x00000050, /* DENALI_PHY_905_DATA */ + 0x00000000, /* DENALI_PHY_906_DATA */ + 0x00010100, /* DENALI_PHY_907_DATA */ + 0x00000601, /* DENALI_PHY_908_DATA */ + 0x00000000, /* DENALI_PHY_909_DATA */ + 0x00006400, /* DENALI_PHY_910_DATA */ + 0x01221102, /* DENALI_PHY_911_DATA */ + 0x00000000, /* DENALI_PHY_912_DATA */ + 0x00051f00, /* DENALI_PHY_913_DATA */ + 0x051f051f, /* DENALI_PHY_914_DATA */ + 0x051f051f, /* DENALI_PHY_915_DATA */ + 0x00030003, /* DENALI_PHY_916_DATA */ + 0x03000300, /* DENALI_PHY_917_DATA */ + 0x00000300, /* DENALI_PHY_918_DATA */ + 0x01221102, /* DENALI_PHY_919_DATA */ + 0x00000000, /* DENALI_PHY_920_DATA */ + 0x00000000, /* DENALI_PHY_921_DATA */ + 0x03020000, /* DENALI_PHY_922_DATA */ + 0x00000001, /* DENALI_PHY_923_DATA */ + 0x00000011, /* DENALI_PHY_924_DATA */ + 0x00000011, /* DENALI_PHY_925_DATA */ + 0x00000400, /* DENALI_PHY_926_DATA */ + 0x00000000, /* DENALI_PHY_927_DATA */ + 0x00000011, /* DENALI_PHY_928_DATA */ + 0x00000011, /* DENALI_PHY_929_DATA */ + 0x00004410, /* DENALI_PHY_930_DATA */ + 0x00004410, /* DENALI_PHY_931_DATA */ + 0x00004410, /* DENALI_PHY_932_DATA */ + 0x00004410, /* DENALI_PHY_933_DATA */ + 0x00004410, /* DENALI_PHY_934_DATA */ + 0x00000011, /* DENALI_PHY_935_DATA */ + 0x00004410, /* DENALI_PHY_936_DATA */ + 0x00000011, /* DENALI_PHY_937_DATA */ + 0x00004410, /* DENALI_PHY_938_DATA */ + 0x00000011, /* DENALI_PHY_939_DATA */ + 0x00004410, /* DENALI_PHY_940_DATA */ + 0x00000000, /* DENALI_PHY_941_DATA */ + 0x00000000, /* DENALI_PHY_942_DATA */ + 0x00000000, /* DENALI_PHY_943_DATA */ + 0x04000000, /* DENALI_PHY_944_DATA */ + 0x00000000, /* DENALI_PHY_945_DATA */ + 0x00000000, /* DENALI_PHY_946_DATA */ + 0x00000508, /* DENALI_PHY_947_DATA */ + 0x00000000, /* DENALI_PHY_948_DATA */ + 0x00000000, /* DENALI_PHY_949_DATA */ + 0x00000000, /* DENALI_PHY_950_DATA */ + 0x00000000, /* DENALI_PHY_951_DATA */ + 0x00000000, /* DENALI_PHY_952_DATA */ + 0x00000000, /* DENALI_PHY_953_DATA */ + 0xe4000000, /* DENALI_PHY_954_DATA */ + 0x00000000, /* DENALI_PHY_955_DATA */ + 0x00000000, /* DENALI_PHY_956_DATA */ + 0x01010000, /* DENALI_PHY_957_DATA */ + 0x00000000 /* DENALI_PHY_958_DATA */ + } + }, +}; diff --git a/src/mainboard/google/gru/sdram_inf/sdram-lpddr3-hynix-4GB-800.inc b/src/mainboard/google/gru/sdram_inf/sdram-lpddr3-hynix-4GB-800.inc deleted file mode 100644 index f4a9b3d..0000000 --- a/src/mainboard/google/gru/sdram_inf/sdram-lpddr3-hynix-4GB-800.inc +++ /dev/null @@ -1,1563 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -{ - { - { - .rank = 0x2, - .col = 0xA, - .bk = 0x3, - .bw = 0x2, - .dbw = 0x2, - .row_3_4 = 0x0, - .cs0_row = 0xF, - .cs1_row = 0xF, - .ddrconfig = 1, - { - {0x1d191519}, - {0x14040808}, - {0x00000002}, - {0x00006226}, - {0x00000054}, - 0x00000000 - } - }, - { - .rank = 0x2, - .col = 0xA, - .bk = 0x3, - .bw = 0x2, - .dbw = 0x2, - .row_3_4 = 0x0, - .cs0_row = 0xF, - .cs1_row = 0xF, - .ddrconfig = 1, - { - {0x1d191519}, - {0x14040808}, - {0x00000002}, - {0x00006226}, - {0x00000054}, - 0x00000000 - } - } - }, - .ddr_freq = 800*MHz, - .dramtype = LPDDR3, - .num_channels = 2, - .stride = 13, - .odt = 1, - { - { - 0x00000700, /* DENALI_CTL_00_DATA */ - 0x00000000, /* DENALI_CTL_01_DATA */ - 0x00000000, /* DENALI_CTL_02_DATA */ - 0x00000000, /* DENALI_CTL_03_DATA */ - 0x00000000, /* DENALI_CTL_04_DATA */ - 0x00000050, /* DENALI_CTL_05_DATA */ - 0x00027100, /* DENALI_CTL_06_DATA */ - 0x00000320, /* DENALI_CTL_07_DATA */ - 0x00001f40, /* DENALI_CTL_08_DATA */ - 0x00000028, /* DENALI_CTL_09_DATA */ - 0x00013880, /* DENALI_CTL_10_DATA */ - 0x00000190, /* DENALI_CTL_11_DATA */ - 0x00000fa0, /* DENALI_CTL_12_DATA */ - 0x00000050, /* DENALI_CTL_13_DATA */ - 0x00027100, /* DENALI_CTL_14_DATA */ - 0x00000320, /* DENALI_CTL_15_DATA */ - 0x01001f40, /* DENALI_CTL_16_DATA */ - 0x00000000, /* DENALI_CTL_17_DATA */ - 0x00000101, /* DENALI_CTL_18_DATA */ - 0x00020100, /* DENALI_CTL_19_DATA */ - 0x000000a0, /* DENALI_CTL_20_DATA */ - 0x00000190, /* DENALI_CTL_21_DATA */ - 0x00000000, /* DENALI_CTL_22_DATA */ - 0x06180000, /* DENALI_CTL_23_DATA */ - 0x00061800, /* DENALI_CTL_24_DATA */ - 0x04000618, /* DENALI_CTL_25_DATA */ - 0x33080004, /* DENALI_CTL_26_DATA */ - 0x280f0622, /* DENALI_CTL_27_DATA */ - 0x111a0400, /* DENALI_CTL_28_DATA */ - 0x00140804, /* DENALI_CTL_29_DATA */ - 0x06223308, /* DENALI_CTL_30_DATA */ - 0x0600280f, /* DENALI_CTL_31_DATA */ - 0x00000a0a, /* DENALI_CTL_32_DATA */ - 0x0600dac0, /* DENALI_CTL_33_DATA */ - 0x0a0a040c, /* DENALI_CTL_34_DATA */ - 0x03006d60, /* DENALI_CTL_35_DATA */ - 0x0a0a0606, /* DENALI_CTL_36_DATA */ - 0x0600dac0, /* DENALI_CTL_37_DATA */ - 0x0203000c, /* DENALI_CTL_38_DATA */ - 0x080c0f00, /* DENALI_CTL_39_DATA */ - 0x040c0f06, /* DENALI_CTL_40_DATA */ - 0x14000a0a, /* DENALI_CTL_41_DATA */ - 0x02030a0a, /* DENALI_CTL_42_DATA */ - 0x00010003, /* DENALI_CTL_43_DATA */ - 0x031b0e1b, /* DENALI_CTL_44_DATA */ - 0x00110911, /* DENALI_CTL_45_DATA */ - 0x00000000, /* DENALI_CTL_46_DATA */ - 0x03010000, /* DENALI_CTL_47_DATA */ - 0x0c2800a8, /* DENALI_CTL_48_DATA */ - 0x06100054, /* DENALI_CTL_49_DATA */ - 0x0c2800a8, /* DENALI_CTL_50_DATA */ - 0x00000000, /* DENALI_CTL_51_DATA */ - 0x00030006, /* DENALI_CTL_52_DATA */ - 0x00140006, /* DENALI_CTL_53_DATA */ - 0x0014000a, /* DENALI_CTL_54_DATA */ - 0x000f080f, /* DENALI_CTL_55_DATA */ - 0x00000000, /* DENALI_CTL_56_DATA */ - 0x00000000, /* DENALI_CTL_57_DATA */ - 0x00000000, /* DENALI_CTL_58_DATA */ - 0x00b00000, /* DENALI_CTL_59_DATA */ - 0x005800b0, /* DENALI_CTL_60_DATA */ - 0x00b00058, /* DENALI_CTL_61_DATA */ - 0x000000b0, /* DENALI_CTL_62_DATA */ - 0x00000000, /* DENALI_CTL_63_DATA */ - 0x00000000, /* DENALI_CTL_64_DATA */ - 0x00000000, /* DENALI_CTL_65_DATA */ - 0x00000000, /* DENALI_CTL_66_DATA */ - 0x00000000, /* DENALI_CTL_67_DATA */ - 0x00000000, /* DENALI_CTL_68_DATA */ - 0x00000301, /* DENALI_CTL_69_DATA */ - 0x00000001, /* DENALI_CTL_70_DATA */ - 0x00000000, /* DENALI_CTL_71_DATA */ - 0x00000000, /* DENALI_CTL_72_DATA */ - 0x01000000, /* DENALI_CTL_73_DATA */ - 0x80104002, /* DENALI_CTL_74_DATA */ - 0x00040003, /* DENALI_CTL_75_DATA */ - 0x00040005, /* DENALI_CTL_76_DATA */ - 0x00030000, /* DENALI_CTL_77_DATA */ - 0x00050004, /* DENALI_CTL_78_DATA */ - 0x00000004, /* DENALI_CTL_79_DATA */ - 0x00040003, /* DENALI_CTL_80_DATA */ - 0x00040005, /* DENALI_CTL_81_DATA */ - 0x30a00000, /* DENALI_CTL_82_DATA */ - 0x00001850, /* DENALI_CTL_83_DATA */ - 0x0c201840, /* DENALI_CTL_84_DATA */ - 0x30a00000, /* DENALI_CTL_85_DATA */ - 0x00001850, /* DENALI_CTL_86_DATA */ - 0x00000000, /* DENALI_CTL_87_DATA */ - 0x00000000, /* DENALI_CTL_88_DATA */ - 0x00000000, /* DENALI_CTL_89_DATA */ - 0x00000000, /* DENALI_CTL_90_DATA */ - 0x00000000, /* DENALI_CTL_91_DATA */ - 0x02020200, /* DENALI_CTL_92_DATA */ - 0x00020202, /* DENALI_CTL_93_DATA */ - 0x00030200, /* DENALI_CTL_94_DATA */ - 0x00040700, /* DENALI_CTL_95_DATA */ - 0x00000302, /* DENALI_CTL_96_DATA */ - 0x02000407, /* DENALI_CTL_97_DATA */ - 0x00000003, /* DENALI_CTL_98_DATA */ - 0x00030f04, /* DENALI_CTL_99_DATA */ - 0x00070004, /* DENALI_CTL_100_DATA */ - 0x00000000, /* DENALI_CTL_101_DATA */ - 0x00000000, /* DENALI_CTL_102_DATA */ - 0x00000000, /* DENALI_CTL_103_DATA */ - 0x00000000, /* DENALI_CTL_104_DATA */ - 0x00000000, /* DENALI_CTL_105_DATA */ - 0x00000000, /* DENALI_CTL_106_DATA */ - 0x00000000, /* DENALI_CTL_107_DATA */ - 0x00010000, /* DENALI_CTL_108_DATA */ - 0x20040020, /* DENALI_CTL_109_DATA */ - 0x00200400, /* DENALI_CTL_110_DATA */ - 0x01000400, /* DENALI_CTL_111_DATA */ - 0x00000b80, /* DENALI_CTL_112_DATA */ - 0x00000000, /* DENALI_CTL_113_DATA */ - 0x00000001, /* DENALI_CTL_114_DATA */ - 0x00000002, /* DENALI_CTL_115_DATA */ - 0x0000000e, /* DENALI_CTL_116_DATA */ - 0x00000000, /* DENALI_CTL_117_DATA */ - 0x00000000, /* DENALI_CTL_118_DATA */ - 0x00000000, /* DENALI_CTL_119_DATA */ - 0x00000000, /* DENALI_CTL_120_DATA */ - 0x00000000, /* DENALI_CTL_121_DATA */ - 0x00a00000, /* DENALI_CTL_122_DATA */ - 0x00c80050, /* DENALI_CTL_123_DATA */ - 0x00c80000, /* DENALI_CTL_124_DATA */ - 0x00280050, /* DENALI_CTL_125_DATA */ - 0x00000064, /* DENALI_CTL_126_DATA */ - 0x00a00064, /* DENALI_CTL_127_DATA */ - 0x00c80050, /* DENALI_CTL_128_DATA */ - 0x00c80000, /* DENALI_CTL_129_DATA */ - 0x00000000, /* DENALI_CTL_130_DATA */ - 0x00000000, /* DENALI_CTL_131_DATA */ - 0x00000000, /* DENALI_CTL_132_DATA */ - 0x00430000, /* DENALI_CTL_133_DATA */ - 0x0000001a, /* DENALI_CTL_134_DATA */ - 0x000a0083, /* DENALI_CTL_135_DATA */ - 0x00430000, /* DENALI_CTL_136_DATA */ - 0x0000001a, /* DENALI_CTL_137_DATA */ - 0x00010001, /* DENALI_CTL_138_DATA */ - 0x06000001, /* DENALI_CTL_139_DATA */ - 0x00000707, /* DENALI_CTL_140_DATA */ - 0x00000000, /* DENALI_CTL_141_DATA */ - 0x00000000, /* DENALI_CTL_142_DATA */ - 0x00000000, /* DENALI_CTL_143_DATA */ - 0x00000000, /* DENALI_CTL_144_DATA */ - 0x00000000, /* DENALI_CTL_145_DATA */ - 0x00000000, /* DENALI_CTL_146_DATA */ - 0x00430000, /* DENALI_CTL_147_DATA */ - 0x0000001a, /* DENALI_CTL_148_DATA */ - 0x000a0083, /* DENALI_CTL_149_DATA */ - 0x00430000, /* DENALI_CTL_150_DATA */ - 0x0000001a, /* DENALI_CTL_151_DATA */ - 0x00010001, /* DENALI_CTL_152_DATA */ - 0x06000001, /* DENALI_CTL_153_DATA */ - 0x00000707, /* DENALI_CTL_154_DATA */ - 0x00000000, /* DENALI_CTL_155_DATA */ - 0x00000000, /* DENALI_CTL_156_DATA */ - 0x00000000, /* DENALI_CTL_157_DATA */ - 0x00000000, /* DENALI_CTL_158_DATA */ - 0x00000000, /* DENALI_CTL_159_DATA */ - 0x00000000, /* DENALI_CTL_160_DATA */ - 0x01000000, /* DENALI_CTL_161_DATA */ - 0x00000000, /* DENALI_CTL_162_DATA */ - 0x00000000, /* DENALI_CTL_163_DATA */ - 0x18151100, /* DENALI_CTL_164_DATA */ - 0x0000000c, /* DENALI_CTL_165_DATA */ - 0x00000000, /* DENALI_CTL_166_DATA */ - 0x00000000, /* DENALI_CTL_167_DATA */ - 0x00000000, /* DENALI_CTL_168_DATA */ - 0x00000000, /* DENALI_CTL_169_DATA */ - 0x00000000, /* DENALI_CTL_170_DATA */ - 0x00000000, /* DENALI_CTL_171_DATA */ - 0x00000000, /* DENALI_CTL_172_DATA */ - 0x00000000, /* DENALI_CTL_173_DATA */ - 0x00000000, /* DENALI_CTL_174_DATA */ - 0x00000000, /* DENALI_CTL_175_DATA */ - 0x00000000, /* DENALI_CTL_176_DATA */ - 0x00000000, /* DENALI_CTL_177_DATA */ - 0x00000000, /* DENALI_CTL_178_DATA */ - 0x00032003, /* DENALI_CTL_179_DATA */ - 0x00480120, /* DENALI_CTL_180_DATA */ - 0x00000000, /* DENALI_CTL_181_DATA */ - 0x00900190, /* DENALI_CTL_182_DATA */ - 0x00000024, /* DENALI_CTL_183_DATA */ - 0x00032000, /* DENALI_CTL_184_DATA */ - 0x00480120, /* DENALI_CTL_185_DATA */ - 0x00000000, /* DENALI_CTL_186_DATA */ - 0x00280000, /* DENALI_CTL_187_DATA */ - 0x00280014, /* DENALI_CTL_188_DATA */ - 0x01010100, /* DENALI_CTL_189_DATA */ - 0x01000202, /* DENALI_CTL_190_DATA */ - 0x0a000002, /* DENALI_CTL_191_DATA */ - 0x01000f0f, /* DENALI_CTL_192_DATA */ - 0x00000000, /* DENALI_CTL_193_DATA */ - 0x00000000, /* DENALI_CTL_194_DATA */ - 0x00010003, /* DENALI_CTL_195_DATA */ - 0x00000c03, /* DENALI_CTL_196_DATA */ - 0x00000100, /* DENALI_CTL_197_DATA */ - 0x00010000, /* DENALI_CTL_198_DATA */ - 0x01000000, /* DENALI_CTL_199_DATA */ - 0x00010000, /* DENALI_CTL_200_DATA */ - 0x00000001, /* DENALI_CTL_201_DATA */ - 0x00000000, /* DENALI_CTL_202_DATA */ - 0x00000000, /* DENALI_CTL_203_DATA */ - 0x00000000, /* DENALI_CTL_204_DATA */ - 0x00000000, /* DENALI_CTL_205_DATA */ - 0x00000000, /* DENALI_CTL_206_DATA */ - 0x00000000, /* DENALI_CTL_207_DATA */ - 0x00000000, /* DENALI_CTL_208_DATA */ - 0x00000000, /* DENALI_CTL_209_DATA */ - 0x00000000, /* DENALI_CTL_210_DATA */ - 0x00010000, /* DENALI_CTL_211_DATA */ - 0x03020301, /* DENALI_CTL_212_DATA */ - 0x01010808, /* DENALI_CTL_213_DATA */ - 0x04030001, /* DENALI_CTL_214_DATA */ - 0x0a0a0a03, /* DENALI_CTL_215_DATA */ - 0x08080808, /* DENALI_CTL_216_DATA */ - 0x02050103, /* DENALI_CTL_217_DATA */ - 0x02010103, /* DENALI_CTL_218_DATA */ - 0x00010103, /* DENALI_CTL_219_DATA */ - 0x00020202, /* DENALI_CTL_220_DATA */ - 0x03020500, /* DENALI_CTL_221_DATA */ - 0x00020501, /* DENALI_CTL_222_DATA */ - 0x00000000, /* DENALI_CTL_223_DATA */ - 0x00000000, /* DENALI_CTL_224_DATA */ - 0x0d000001, /* DENALI_CTL_225_DATA */ - 0x00010028, /* DENALI_CTL_226_DATA */ - 0x00010000, /* DENALI_CTL_227_DATA */ - 0x00000003, /* DENALI_CTL_228_DATA */ - 0x00000000, /* DENALI_CTL_229_DATA */ - 0x00000000, /* DENALI_CTL_230_DATA */ - 0x00000000, /* DENALI_CTL_231_DATA */ - 0x00000000, /* DENALI_CTL_232_DATA */ - 0x00000000, /* DENALI_CTL_233_DATA */ - 0x00000000, /* DENALI_CTL_234_DATA */ - 0x00000000, /* DENALI_CTL_235_DATA */ - 0x00000000, /* DENALI_CTL_236_DATA */ - 0x00010100, /* DENALI_CTL_237_DATA */ - 0x01000000, /* DENALI_CTL_238_DATA */ - 0x00000001, /* DENALI_CTL_239_DATA */ - 0x00000303, /* DENALI_CTL_240_DATA */ - 0x00000000, /* DENALI_CTL_241_DATA */ - 0x00000000, /* DENALI_CTL_242_DATA */ - 0x00000000, /* DENALI_CTL_243_DATA */ - 0x00000000, /* DENALI_CTL_244_DATA */ - 0x00000000, /* DENALI_CTL_245_DATA */ - 0x00000000, /* DENALI_CTL_246_DATA */ - 0x00000000, /* DENALI_CTL_247_DATA */ - 0x00000000, /* DENALI_CTL_248_DATA */ - 0x00000000, /* DENALI_CTL_249_DATA */ - 0x00000000, /* DENALI_CTL_250_DATA */ - 0x00000000, /* DENALI_CTL_251_DATA */ - 0x00000000, /* DENALI_CTL_252_DATA */ - 0x00000000, /* DENALI_CTL_253_DATA */ - 0x00000000, /* DENALI_CTL_254_DATA */ - 0x00000000, /* DENALI_CTL_255_DATA */ - 0x000556aa, /* DENALI_CTL_256_DATA */ - 0x000aaaaa, /* DENALI_CTL_257_DATA */ - 0x000aa955, /* DENALI_CTL_258_DATA */ - 0x00055555, /* DENALI_CTL_259_DATA */ - 0x000b3133, /* DENALI_CTL_260_DATA */ - 0x0004cd33, /* DENALI_CTL_261_DATA */ - 0x0004cecc, /* DENALI_CTL_262_DATA */ - 0x000b32cc, /* DENALI_CTL_263_DATA */ - 0x00010300, /* DENALI_CTL_264_DATA */ - 0x03000100, /* DENALI_CTL_265_DATA */ - 0x00000000, /* DENALI_CTL_266_DATA */ - 0x00000000, /* DENALI_CTL_267_DATA */ - 0x00000000, /* DENALI_CTL_268_DATA */ - 0x00000000, /* DENALI_CTL_269_DATA */ - 0x00000000, /* DENALI_CTL_270_DATA */ - 0x00000000, /* DENALI_CTL_271_DATA */ - 0x00000000, /* DENALI_CTL_272_DATA */ - 0x00000000, /* DENALI_CTL_273_DATA */ - 0x00ffff00, /* DENALI_CTL_274_DATA */ - 0x181e0000, /* DENALI_CTL_275_DATA */ - 0x0800001e, /* DENALI_CTL_276_DATA */ - 0x00001850, /* DENALI_CTL_277_DATA */ - 0x00000200, /* DENALI_CTL_278_DATA */ - 0x00000200, /* DENALI_CTL_279_DATA */ - 0x00000200, /* DENALI_CTL_280_DATA */ - 0x00000200, /* DENALI_CTL_281_DATA */ - 0x00001850, /* DENALI_CTL_282_DATA */ - 0x0000f320, /* DENALI_CTL_283_DATA */ - 0x0c20050a, /* DENALI_CTL_284_DATA */ - 0x00000200, /* DENALI_CTL_285_DATA */ - 0x00000200, /* DENALI_CTL_286_DATA */ - 0x00000200, /* DENALI_CTL_287_DATA */ - 0x00000200, /* DENALI_CTL_288_DATA */ - 0x00000c20, /* DENALI_CTL_289_DATA */ - 0x00007940, /* DENALI_CTL_290_DATA */ - 0x1850050b, /* DENALI_CTL_291_DATA */ - 0x00000200, /* DENALI_CTL_292_DATA */ - 0x00000200, /* DENALI_CTL_293_DATA */ - 0x00000200, /* DENALI_CTL_294_DATA */ - 0x00000200, /* DENALI_CTL_295_DATA */ - 0x00001850, /* DENALI_CTL_296_DATA */ - 0x0000f320, /* DENALI_CTL_297_DATA */ - 0x0202050a, /* DENALI_CTL_298_DATA */ - 0x03030202, /* DENALI_CTL_299_DATA */ - 0x00000018, /* DENALI_CTL_300_DATA */ - 0x00000000, /* DENALI_CTL_301_DATA */ - 0x00000000, /* DENALI_CTL_302_DATA */ - 0x00001403, /* DENALI_CTL_303_DATA */ - 0x00000000, /* DENALI_CTL_304_DATA */ - 0x00000000, /* DENALI_CTL_305_DATA */ - 0x00000000, /* DENALI_CTL_306_DATA */ - 0x00030000, /* DENALI_CTL_307_DATA */ - 0x000e0020, /* DENALI_CTL_308_DATA */ - 0x000a001c, /* DENALI_CTL_309_DATA */ - 0x000e0020, /* DENALI_CTL_310_DATA */ - 0x00000000, /* DENALI_CTL_311_DATA */ - 0x00000000, /* DENALI_CTL_312_DATA */ - 0x01000000, /* DENALI_CTL_313_DATA */ - 0x00070007, /* DENALI_CTL_314_DATA */ - 0x00050007, /* DENALI_CTL_315_DATA */ - 0x00000000, /* DENALI_CTL_316_DATA */ - 0x00000000, /* DENALI_CTL_317_DATA */ - 0x00000000, /* DENALI_CTL_318_DATA */ - 0x00000000, /* DENALI_CTL_319_DATA */ - 0x00000000, /* DENALI_CTL_320_DATA */ - 0x00000000, /* DENALI_CTL_321_DATA */ - 0x00000000, /* DENALI_CTL_322_DATA */ - 0x00000000, /* DENALI_CTL_323_DATA */ - 0x01000101, /* DENALI_CTL_324_DATA */ - 0x01010101, /* DENALI_CTL_325_DATA */ - 0x01000101, /* DENALI_CTL_326_DATA */ - 0x01000100, /* DENALI_CTL_327_DATA */ - 0x00010001, /* DENALI_CTL_328_DATA */ - 0x00010002, /* DENALI_CTL_329_DATA */ - 0x00020100, /* DENALI_CTL_330_DATA */ - 0x00000002 /* DENALI_CTL_331_DATA */ - } - }, - { - { - 0x00000700, /* DENALI_PI_00_DATA */ - 0x00000000, /* DENALI_PI_01_DATA */ - 0x000030a0, /* DENALI_PI_02_DATA */ - 0x00001850, /* DENALI_PI_03_DATA */ - 0x00001840, /* DENALI_PI_04_DATA */ - 0x00000c20, /* DENALI_PI_05_DATA */ - 0x000030a0, /* DENALI_PI_06_DATA */ - 0x18501850, /* DENALI_PI_07_DATA */ - 0x00000200, /* DENALI_PI_08_DATA */ - 0x00000200, /* DENALI_PI_09_DATA */ - 0x00000200, /* DENALI_PI_10_DATA */ - 0x00000200, /* DENALI_PI_11_DATA */ - 0x00000c20, /* DENALI_PI_12_DATA */ - 0x00000200, /* DENALI_PI_13_DATA */ - 0x00000200, /* DENALI_PI_14_DATA */ - 0x00000200, /* DENALI_PI_15_DATA */ - 0x00000200, /* DENALI_PI_16_DATA */ - 0x00001850, /* DENALI_PI_17_DATA */ - 0x00000200, /* DENALI_PI_18_DATA */ - 0x00000200, /* DENALI_PI_19_DATA */ - 0x00000200, /* DENALI_PI_20_DATA */ - 0x00000200, /* DENALI_PI_21_DATA */ - 0x00010000, /* DENALI_PI_22_DATA */ - 0x00000007, /* DENALI_PI_23_DATA */ - 0x81000001, /* DENALI_PI_24_DATA */ - 0x0f0003f0, /* DENALI_PI_25_DATA */ - 0x3fffffff, /* DENALI_PI_26_DATA */ - 0x0f0000a0, /* DENALI_PI_27_DATA */ - 0x377ff000, /* DENALI_PI_28_DATA */ - 0x0f000020, /* DENALI_PI_29_DATA */ - 0x377ff000, /* DENALI_PI_30_DATA */ - 0x0f000030, /* DENALI_PI_31_DATA */ - 0x377ff000, /* DENALI_PI_32_DATA */ - 0x0f0000b0, /* DENALI_PI_33_DATA */ - 0x377ff000, /* DENALI_PI_34_DATA */ - 0x0f000100, /* DENALI_PI_35_DATA */ - 0x377ff000, /* DENALI_PI_36_DATA */ - 0x0f000110, /* DENALI_PI_37_DATA */ - 0x377ff000, /* DENALI_PI_38_DATA */ - 0x0f000010, /* DENALI_PI_39_DATA */ - 0x377ff000, /* DENALI_PI_40_DATA */ - 0x03000101, /* DENALI_PI_41_DATA */ - 0x042e292e, /* DENALI_PI_42_DATA */ - 0x06180006, /* DENALI_PI_43_DATA */ - 0x00061800, /* DENALI_PI_44_DATA */ - 0x00000018, /* DENALI_PI_45_DATA */ - 0x0c2800a8, /* DENALI_PI_46_DATA */ - 0x06100054, /* DENALI_PI_47_DATA */ - 0x0c2800a8, /* DENALI_PI_48_DATA */ - 0x00000500, /* DENALI_PI_49_DATA */ - 0x00000000, /* DENALI_PI_50_DATA */ - 0x00000000, /* DENALI_PI_51_DATA */ - 0x00000000, /* DENALI_PI_52_DATA */ - 0x00000000, /* DENALI_PI_53_DATA */ - 0x00000000, /* DENALI_PI_54_DATA */ - 0x00000000, /* DENALI_PI_55_DATA */ - 0x00000000, /* DENALI_PI_56_DATA */ - 0x00000000, /* DENALI_PI_57_DATA */ - 0x04040000, /* DENALI_PI_58_DATA */ - 0x0d000004, /* DENALI_PI_59_DATA */ - 0x00000128, /* DENALI_PI_60_DATA */ - 0x00000000, /* DENALI_PI_61_DATA */ - 0x00030003, /* DENALI_PI_62_DATA */ - 0x00000018, /* DENALI_PI_63_DATA */ - 0x00000000, /* DENALI_PI_64_DATA */ - 0x00000000, /* DENALI_PI_65_DATA */ - 0x03060002, /* DENALI_PI_66_DATA */ - 0x03010201, /* DENALI_PI_67_DATA */ - 0x01080801, /* DENALI_PI_68_DATA */ - 0x04020201, /* DENALI_PI_69_DATA */ - 0x01080804, /* DENALI_PI_70_DATA */ - 0x00000000, /* DENALI_PI_71_DATA */ - 0x04030000, /* DENALI_PI_72_DATA */ - 0x0a0a0a03, /* DENALI_PI_73_DATA */ - 0x00000000, /* DENALI_PI_74_DATA */ - 0x00000000, /* DENALI_PI_75_DATA */ - 0x00000000, /* DENALI_PI_76_DATA */ - 0x00030300, /* DENALI_PI_77_DATA */ - 0x00000014, /* DENALI_PI_78_DATA */ - 0x00000000, /* DENALI_PI_79_DATA */ - 0x01010300, /* DENALI_PI_80_DATA */ - 0x00000000, /* DENALI_PI_81_DATA */ - 0x00000000, /* DENALI_PI_82_DATA */ - 0x01000000, /* DENALI_PI_83_DATA */ - 0x00000101, /* DENALI_PI_84_DATA */ - 0x55555a5a, /* DENALI_PI_85_DATA */ - 0x55555a5a, /* DENALI_PI_86_DATA */ - 0x55555a5a, /* DENALI_PI_87_DATA */ - 0x55555a5a, /* DENALI_PI_88_DATA */ - 0x0b0a0001, /* DENALI_PI_89_DATA */ - 0x0505000a, /* DENALI_PI_90_DATA */ - 0x00000005, /* DENALI_PI_91_DATA */ - 0x00000100, /* DENALI_PI_92_DATA */ - 0x00030000, /* DENALI_PI_93_DATA */ - 0x17030000, /* DENALI_PI_94_DATA */ - 0x000e0020, /* DENALI_PI_95_DATA */ - 0x000a001c, /* DENALI_PI_96_DATA */ - 0x000e0020, /* DENALI_PI_97_DATA */ - 0x00000000, /* DENALI_PI_98_DATA */ - 0x00000000, /* DENALI_PI_99_DATA */ - 0x00000100, /* DENALI_PI_100_DATA */ - 0x140a0000, /* DENALI_PI_101_DATA */ - 0x000a030a, /* DENALI_PI_102_DATA */ - 0x03000a02, /* DENALI_PI_103_DATA */ - 0x010a000a, /* DENALI_PI_104_DATA */ - 0x00000100, /* DENALI_PI_105_DATA */ - 0x01000000, /* DENALI_PI_106_DATA */ - 0x00000000, /* DENALI_PI_107_DATA */ - 0x00000100, /* DENALI_PI_108_DATA */ - 0x1e1a0000, /* DENALI_PI_109_DATA */ - 0x10010204, /* DENALI_PI_110_DATA */ - 0x07060705, /* DENALI_PI_111_DATA */ - 0x20000202, /* DENALI_PI_112_DATA */ - 0x00201000, /* DENALI_PI_113_DATA */ - 0x00201000, /* DENALI_PI_114_DATA */ - 0x04041000, /* DENALI_PI_115_DATA */ - 0x0c100100, /* DENALI_PI_116_DATA */ - 0x00010110, /* DENALI_PI_117_DATA */ - 0x004b004a, /* DENALI_PI_118_DATA */ - 0x1a030000, /* DENALI_PI_119_DATA */ - 0x0102041e, /* DENALI_PI_120_DATA */ - 0x34000000, /* DENALI_PI_121_DATA */ - 0x00000000, /* DENALI_PI_122_DATA */ - 0x00000000, /* DENALI_PI_123_DATA */ - 0x00000000, /* DENALI_PI_124_DATA */ - 0x00004300, /* DENALI_PI_125_DATA */ - 0x0001001a, /* DENALI_PI_126_DATA */ - 0x004d4d07, /* DENALI_PI_127_DATA */ - 0x000a0083, /* DENALI_PI_128_DATA */ - 0x4d070001, /* DENALI_PI_129_DATA */ - 0x0000434d, /* DENALI_PI_130_DATA */ - 0x0001001a, /* DENALI_PI_131_DATA */ - 0x004d4d07, /* DENALI_PI_132_DATA */ - 0x001a0043, /* DENALI_PI_133_DATA */ - 0x4d070001, /* DENALI_PI_134_DATA */ - 0x0000834d, /* DENALI_PI_135_DATA */ - 0x0001000a, /* DENALI_PI_136_DATA */ - 0x004d4d07, /* DENALI_PI_137_DATA */ - 0x001a0043, /* DENALI_PI_138_DATA */ - 0x4d070001, /* DENALI_PI_139_DATA */ - 0x0043004d, /* DENALI_PI_140_DATA */ - 0x0001001a, /* DENALI_PI_141_DATA */ - 0x004d4d07, /* DENALI_PI_142_DATA */ - 0x000a0083, /* DENALI_PI_143_DATA */ - 0x4d070001, /* DENALI_PI_144_DATA */ - 0x0000434d, /* DENALI_PI_145_DATA */ - 0x0001001a, /* DENALI_PI_146_DATA */ - 0x004d4d07, /* DENALI_PI_147_DATA */ - 0x001a0043, /* DENALI_PI_148_DATA */ - 0x4d070001, /* DENALI_PI_149_DATA */ - 0x0000834d, /* DENALI_PI_150_DATA */ - 0x0001000a, /* DENALI_PI_151_DATA */ - 0x004d4d07, /* DENALI_PI_152_DATA */ - 0x001a0043, /* DENALI_PI_153_DATA */ - 0x4d070001, /* DENALI_PI_154_DATA */ - 0x0100004d, /* DENALI_PI_155_DATA */ - 0x006400c8, /* DENALI_PI_156_DATA */ - 0x060400c8, /* DENALI_PI_157_DATA */ - 0x0c060f11, /* DENALI_PI_158_DATA */ - 0x2200d890, /* DENALI_PI_159_DATA */ - 0x0a0c2005, /* DENALI_PI_160_DATA */ - 0x0809040a, /* DENALI_PI_161_DATA */ - 0x00000604, /* DENALI_PI_162_DATA */ - 0x11006c48, /* DENALI_PI_163_DATA */ - 0x0a062003, /* DENALI_PI_164_DATA */ - 0x0f11060a, /* DENALI_PI_165_DATA */ - 0x00000c06, /* DENALI_PI_166_DATA */ - 0x2200d890, /* DENALI_PI_167_DATA */ - 0x0a0c2005, /* DENALI_PI_168_DATA */ - 0x0200020a, /* DENALI_PI_169_DATA */ - 0x02000200, /* DENALI_PI_170_DATA */ - 0x02000200, /* DENALI_PI_171_DATA */ - 0x02000200, /* DENALI_PI_172_DATA */ - 0x02000200, /* DENALI_PI_173_DATA */ - 0x00000000, /* DENALI_PI_174_DATA */ - 0x00000000, /* DENALI_PI_175_DATA */ - 0x00000000, /* DENALI_PI_176_DATA */ - 0x00000000, /* DENALI_PI_177_DATA */ - 0x00000000, /* DENALI_PI_178_DATA */ - 0x00000000, /* DENALI_PI_179_DATA */ - 0x00000000, /* DENALI_PI_180_DATA */ - 0x00000000, /* DENALI_PI_181_DATA */ - 0x00000000, /* DENALI_PI_182_DATA */ - 0x00000000, /* DENALI_PI_183_DATA */ - 0x00000000, /* DENALI_PI_184_DATA */ - 0x00000000, /* DENALI_PI_185_DATA */ - 0x01000300, /* DENALI_PI_186_DATA */ - 0x00185000, /* DENALI_PI_187_DATA */ - 0x0000f320, /* DENALI_PI_188_DATA */ - 0x00000c20, /* DENALI_PI_189_DATA */ - 0x00007940, /* DENALI_PI_190_DATA */ - 0x00001850, /* DENALI_PI_191_DATA */ - 0x0000f320, /* DENALI_PI_192_DATA */ - 0x08000000, /* DENALI_PI_193_DATA */ - 0x00000100, /* DENALI_PI_194_DATA */ - 0x00000000, /* DENALI_PI_195_DATA */ - 0x00000000, /* DENALI_PI_196_DATA */ - 0x00000000, /* DENALI_PI_197_DATA */ - 0x00000000, /* DENALI_PI_198_DATA */ - 0x00000002 /* DENALI_PI_199_DATA */ - } - }, - { - { - 0x76543210, /* DENALI_PHY_00_DATA */ - 0x0004c008, /* DENALI_PHY_01_DATA */ - 0x000000b3, /* DENALI_PHY_02_DATA */ - 0x00000000, /* DENALI_PHY_03_DATA */ - 0x00000000, /* DENALI_PHY_04_DATA */ - 0x00010000, /* DENALI_PHY_05_DATA */ - 0x01665555, /* DENALI_PHY_06_DATA */ - 0x00665555, /* DENALI_PHY_07_DATA */ - 0x00010f00, /* DENALI_PHY_08_DATA */ - 0x05010200, /* DENALI_PHY_09_DATA */ - 0x00000003, /* DENALI_PHY_10_DATA */ - 0x001700c0, /* DENALI_PHY_11_DATA */ - 0x00cc0101, /* DENALI_PHY_12_DATA */ - 0x00030066, /* DENALI_PHY_13_DATA */ - 0x00000000, /* DENALI_PHY_14_DATA */ - 0x00000000, /* DENALI_PHY_15_DATA */ - 0x00000000, /* DENALI_PHY_16_DATA */ - 0x00000000, /* DENALI_PHY_17_DATA */ - 0x00000000, /* DENALI_PHY_18_DATA */ - 0x00000000, /* DENALI_PHY_19_DATA */ - 0x00000000, /* DENALI_PHY_20_DATA */ - 0x00000000, /* DENALI_PHY_21_DATA */ - 0x04080000, /* DENALI_PHY_22_DATA */ - 0x04080400, /* DENALI_PHY_23_DATA */ - 0x08000000, /* DENALI_PHY_24_DATA */ - 0x0c00c007, /* DENALI_PHY_25_DATA */ - 0x00000100, /* DENALI_PHY_26_DATA */ - 0x00000100, /* DENALI_PHY_27_DATA */ - 0x55555555, /* DENALI_PHY_28_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_29_DATA */ - 0x55555555, /* DENALI_PHY_30_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_31_DATA */ - 0x00005555, /* DENALI_PHY_32_DATA */ - 0x00000000, /* DENALI_PHY_33_DATA */ - 0x00000000, /* DENALI_PHY_34_DATA */ - 0x00000000, /* DENALI_PHY_35_DATA */ - 0x00000000, /* DENALI_PHY_36_DATA */ - 0x00000000, /* DENALI_PHY_37_DATA */ - 0x00000000, /* DENALI_PHY_38_DATA */ - 0x00000000, /* DENALI_PHY_39_DATA */ - 0x00000000, /* DENALI_PHY_40_DATA */ - 0x00000000, /* DENALI_PHY_41_DATA */ - 0x00000000, /* DENALI_PHY_42_DATA */ - 0x00000000, /* DENALI_PHY_43_DATA */ - 0x00000000, /* DENALI_PHY_44_DATA */ - 0x00000000, /* DENALI_PHY_45_DATA */ - 0x00000000, /* DENALI_PHY_46_DATA */ - 0x00000000, /* DENALI_PHY_47_DATA */ - 0x00000000, /* DENALI_PHY_48_DATA */ - 0x00000000, /* DENALI_PHY_49_DATA */ - 0x00000000, /* DENALI_PHY_50_DATA */ - 0x00000000, /* DENALI_PHY_51_DATA */ - 0x00200000, /* DENALI_PHY_52_DATA */ - 0x00000000, /* DENALI_PHY_53_DATA */ - 0x00000000, /* DENALI_PHY_54_DATA */ - 0x00000000, /* DENALI_PHY_55_DATA */ - 0x00000000, /* DENALI_PHY_56_DATA */ - 0x00000000, /* DENALI_PHY_57_DATA */ - 0x00000000, /* DENALI_PHY_58_DATA */ - 0x02800280, /* DENALI_PHY_59_DATA */ - 0x02800280, /* DENALI_PHY_60_DATA */ - 0x02800280, /* DENALI_PHY_61_DATA */ - 0x02800280, /* DENALI_PHY_62_DATA */ - 0x00000280, /* DENALI_PHY_63_DATA */ - 0x00000000, /* DENALI_PHY_64_DATA */ - 0x00000000, /* DENALI_PHY_65_DATA */ - 0x00000000, /* DENALI_PHY_66_DATA */ - 0x00000000, /* DENALI_PHY_67_DATA */ - 0x00800000, /* DENALI_PHY_68_DATA */ - 0x00800080, /* DENALI_PHY_69_DATA */ - 0x00800080, /* DENALI_PHY_70_DATA */ - 0x00800080, /* DENALI_PHY_71_DATA */ - 0x00800080, /* DENALI_PHY_72_DATA */ - 0x00800080, /* DENALI_PHY_73_DATA */ - 0x00800080, /* DENALI_PHY_74_DATA */ - 0x00800080, /* DENALI_PHY_75_DATA */ - 0x00800080, /* DENALI_PHY_76_DATA */ - 0x00b30080, /* DENALI_PHY_77_DATA */ - 0x01900003, /* DENALI_PHY_78_DATA */ - 0x00000000, /* DENALI_PHY_79_DATA */ - 0x00020000, /* DENALI_PHY_80_DATA */ - 0x00000200, /* DENALI_PHY_81_DATA */ - 0x00000000, /* DENALI_PHY_82_DATA */ - 0x51315152, /* DENALI_PHY_83_DATA */ - 0xc0013150, /* DENALI_PHY_84_DATA */ - 0x020000c0, /* DENALI_PHY_85_DATA */ - 0x00100001, /* DENALI_PHY_86_DATA */ - 0x0c054208, /* DENALI_PHY_87_DATA */ - 0x000f0c18, /* DENALI_PHY_88_DATA */ - 0x01000140, /* DENALI_PHY_89_DATA */ - 0x00000c20, /* DENALI_PHY_90_DATA */ - 0x00000000, /* DENALI_PHY_91_DATA */ - 0x00000000, /* DENALI_PHY_92_DATA */ - 0x00000000, /* DENALI_PHY_93_DATA */ - 0x00000000, /* DENALI_PHY_94_DATA */ - 0x00000000, /* DENALI_PHY_95_DATA */ - 0x00000000, /* DENALI_PHY_96_DATA */ - 0x00000000, /* DENALI_PHY_97_DATA */ - 0x00000000, /* DENALI_PHY_98_DATA */ - 0x00000000, /* DENALI_PHY_99_DATA */ - 0x00000000, /* DENALI_PHY_100_DATA */ - 0x00000000, /* DENALI_PHY_101_DATA */ - 0x00000000, /* DENALI_PHY_102_DATA */ - 0x00000000, /* DENALI_PHY_103_DATA */ - 0x00000000, /* DENALI_PHY_104_DATA */ - 0x00000000, /* DENALI_PHY_105_DATA */ - 0x00000000, /* DENALI_PHY_106_DATA */ - 0x00000000, /* DENALI_PHY_107_DATA */ - 0x00000000, /* DENALI_PHY_108_DATA */ - 0x00000000, /* DENALI_PHY_109_DATA */ - 0x00000000, /* DENALI_PHY_110_DATA */ - 0x00000000, /* DENALI_PHY_111_DATA */ - 0x00000000, /* DENALI_PHY_112_DATA */ - 0x00000000, /* DENALI_PHY_113_DATA */ - 0x00000000, /* DENALI_PHY_114_DATA */ - 0x00000000, /* DENALI_PHY_115_DATA */ - 0x00000000, /* DENALI_PHY_116_DATA */ - 0x00000000, /* DENALI_PHY_117_DATA */ - 0x00000000, /* DENALI_PHY_118_DATA */ - 0x00000000, /* DENALI_PHY_119_DATA */ - 0x00000000, /* DENALI_PHY_120_DATA */ - 0x00000000, /* DENALI_PHY_121_DATA */ - 0x00000000, /* DENALI_PHY_122_DATA */ - 0x00000000, /* DENALI_PHY_123_DATA */ - 0x00000000, /* DENALI_PHY_124_DATA */ - 0x00000000, /* DENALI_PHY_125_DATA */ - 0x00000000, /* DENALI_PHY_126_DATA */ - 0x00000000, /* DENALI_PHY_127_DATA */ - 0x76543210, /* DENALI_PHY_128_DATA */ - 0x0004c008, /* DENALI_PHY_129_DATA */ - 0x000000b3, /* DENALI_PHY_130_DATA */ - 0x00000000, /* DENALI_PHY_131_DATA */ - 0x00000000, /* DENALI_PHY_132_DATA */ - 0x00010000, /* DENALI_PHY_133_DATA */ - 0x01665555, /* DENALI_PHY_134_DATA */ - 0x00665555, /* DENALI_PHY_135_DATA */ - 0x00010f00, /* DENALI_PHY_136_DATA */ - 0x05010200, /* DENALI_PHY_137_DATA */ - 0x00000003, /* DENALI_PHY_138_DATA */ - 0x001700c0, /* DENALI_PHY_139_DATA */ - 0x00cc0101, /* DENALI_PHY_140_DATA */ - 0x00030066, /* DENALI_PHY_141_DATA */ - 0x00000000, /* DENALI_PHY_142_DATA */ - 0x00000000, /* DENALI_PHY_143_DATA */ - 0x00000000, /* DENALI_PHY_144_DATA */ - 0x00000000, /* DENALI_PHY_145_DATA */ - 0x00000000, /* DENALI_PHY_146_DATA */ - 0x00000000, /* DENALI_PHY_147_DATA */ - 0x00000000, /* DENALI_PHY_148_DATA */ - 0x00000000, /* DENALI_PHY_149_DATA */ - 0x04080000, /* DENALI_PHY_150_DATA */ - 0x04080400, /* DENALI_PHY_151_DATA */ - 0x08000000, /* DENALI_PHY_152_DATA */ - 0x0c00c007, /* DENALI_PHY_153_DATA */ - 0x00000100, /* DENALI_PHY_154_DATA */ - 0x00000100, /* DENALI_PHY_155_DATA */ - 0x55555555, /* DENALI_PHY_156_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_157_DATA */ - 0x55555555, /* DENALI_PHY_158_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_159_DATA */ - 0x00005555, /* DENALI_PHY_160_DATA */ - 0x00000000, /* DENALI_PHY_161_DATA */ - 0x00000000, /* DENALI_PHY_162_DATA */ - 0x00000000, /* DENALI_PHY_163_DATA */ - 0x00000000, /* DENALI_PHY_164_DATA */ - 0x00000000, /* DENALI_PHY_165_DATA */ - 0x00000000, /* DENALI_PHY_166_DATA */ - 0x00000000, /* DENALI_PHY_167_DATA */ - 0x00000000, /* DENALI_PHY_168_DATA */ - 0x00000000, /* DENALI_PHY_169_DATA */ - 0x00000000, /* DENALI_PHY_170_DATA */ - 0x00000000, /* DENALI_PHY_171_DATA */ - 0x00000000, /* DENALI_PHY_172_DATA */ - 0x00000000, /* DENALI_PHY_173_DATA */ - 0x00000000, /* DENALI_PHY_174_DATA */ - 0x00000000, /* DENALI_PHY_175_DATA */ - 0x00000000, /* DENALI_PHY_176_DATA */ - 0x00000000, /* DENALI_PHY_177_DATA */ - 0x00000000, /* DENALI_PHY_178_DATA */ - 0x00000000, /* DENALI_PHY_179_DATA */ - 0x00200000, /* DENALI_PHY_180_DATA */ - 0x00000000, /* DENALI_PHY_181_DATA */ - 0x00000000, /* DENALI_PHY_182_DATA */ - 0x00000000, /* DENALI_PHY_183_DATA */ - 0x00000000, /* DENALI_PHY_184_DATA */ - 0x00000000, /* DENALI_PHY_185_DATA */ - 0x00000000, /* DENALI_PHY_186_DATA */ - 0x02800280, /* DENALI_PHY_187_DATA */ - 0x02800280, /* DENALI_PHY_188_DATA */ - 0x02800280, /* DENALI_PHY_189_DATA */ - 0x02800280, /* DENALI_PHY_190_DATA */ - 0x00000280, /* DENALI_PHY_191_DATA */ - 0x00000000, /* DENALI_PHY_192_DATA */ - 0x00000000, /* DENALI_PHY_193_DATA */ - 0x00000000, /* DENALI_PHY_194_DATA */ - 0x00000000, /* DENALI_PHY_195_DATA */ - 0x00800000, /* DENALI_PHY_196_DATA */ - 0x00800080, /* DENALI_PHY_197_DATA */ - 0x00800080, /* DENALI_PHY_198_DATA */ - 0x00800080, /* DENALI_PHY_199_DATA */ - 0x00800080, /* DENALI_PHY_200_DATA */ - 0x00800080, /* DENALI_PHY_201_DATA */ - 0x00800080, /* DENALI_PHY_202_DATA */ - 0x00800080, /* DENALI_PHY_203_DATA */ - 0x00800080, /* DENALI_PHY_204_DATA */ - 0x00b30080, /* DENALI_PHY_205_DATA */ - 0x01900003, /* DENALI_PHY_206_DATA */ - 0x00000000, /* DENALI_PHY_207_DATA */ - 0x00020000, /* DENALI_PHY_208_DATA */ - 0x00000200, /* DENALI_PHY_209_DATA */ - 0x00000000, /* DENALI_PHY_210_DATA */ - 0x51315152, /* DENALI_PHY_211_DATA */ - 0xc0013150, /* DENALI_PHY_212_DATA */ - 0x020000c0, /* DENALI_PHY_213_DATA */ - 0x00100001, /* DENALI_PHY_214_DATA */ - 0x0c054208, /* DENALI_PHY_215_DATA */ - 0x000f0c18, /* DENALI_PHY_216_DATA */ - 0x01000140, /* DENALI_PHY_217_DATA */ - 0x00000c20, /* DENALI_PHY_218_DATA */ - 0x00000000, /* DENALI_PHY_219_DATA */ - 0x00000000, /* DENALI_PHY_220_DATA */ - 0x00000000, /* DENALI_PHY_221_DATA */ - 0x00000000, /* DENALI_PHY_222_DATA */ - 0x00000000, /* DENALI_PHY_223_DATA */ - 0x00000000, /* DENALI_PHY_224_DATA */ - 0x00000000, /* DENALI_PHY_225_DATA */ - 0x00000000, /* DENALI_PHY_226_DATA */ - 0x00000000, /* DENALI_PHY_227_DATA */ - 0x00000000, /* DENALI_PHY_228_DATA */ - 0x00000000, /* DENALI_PHY_229_DATA */ - 0x00000000, /* DENALI_PHY_230_DATA */ - 0x00000000, /* DENALI_PHY_231_DATA */ - 0x00000000, /* DENALI_PHY_232_DATA */ - 0x00000000, /* DENALI_PHY_233_DATA */ - 0x00000000, /* DENALI_PHY_234_DATA */ - 0x00000000, /* DENALI_PHY_235_DATA */ - 0x00000000, /* DENALI_PHY_236_DATA */ - 0x00000000, /* DENALI_PHY_237_DATA */ - 0x00000000, /* DENALI_PHY_238_DATA */ - 0x00000000, /* DENALI_PHY_239_DATA */ - 0x00000000, /* DENALI_PHY_240_DATA */ - 0x00000000, /* DENALI_PHY_241_DATA */ - 0x00000000, /* DENALI_PHY_242_DATA */ - 0x00000000, /* DENALI_PHY_243_DATA */ - 0x00000000, /* DENALI_PHY_244_DATA */ - 0x00000000, /* DENALI_PHY_245_DATA */ - 0x00000000, /* DENALI_PHY_246_DATA */ - 0x00000000, /* DENALI_PHY_247_DATA */ - 0x00000000, /* DENALI_PHY_248_DATA */ - 0x00000000, /* DENALI_PHY_249_DATA */ - 0x00000000, /* DENALI_PHY_250_DATA */ - 0x00000000, /* DENALI_PHY_251_DATA */ - 0x00000000, /* DENALI_PHY_252_DATA */ - 0x00000000, /* DENALI_PHY_253_DATA */ - 0x00000000, /* DENALI_PHY_254_DATA */ - 0x00000000, /* DENALI_PHY_255_DATA */ - 0x76543210, /* DENALI_PHY_256_DATA */ - 0x0004c008, /* DENALI_PHY_257_DATA */ - 0x000000b3, /* DENALI_PHY_258_DATA */ - 0x00000000, /* DENALI_PHY_259_DATA */ - 0x00000000, /* DENALI_PHY_260_DATA */ - 0x00010000, /* DENALI_PHY_261_DATA */ - 0x01665555, /* DENALI_PHY_262_DATA */ - 0x00665555, /* DENALI_PHY_263_DATA */ - 0x00010f00, /* DENALI_PHY_264_DATA */ - 0x05010200, /* DENALI_PHY_265_DATA */ - 0x00000003, /* DENALI_PHY_266_DATA */ - 0x001700c0, /* DENALI_PHY_267_DATA */ - 0x00cc0101, /* DENALI_PHY_268_DATA */ - 0x00030066, /* DENALI_PHY_269_DATA */ - 0x00000000, /* DENALI_PHY_270_DATA */ - 0x00000000, /* DENALI_PHY_271_DATA */ - 0x00000000, /* DENALI_PHY_272_DATA */ - 0x00000000, /* DENALI_PHY_273_DATA */ - 0x00000000, /* DENALI_PHY_274_DATA */ - 0x00000000, /* DENALI_PHY_275_DATA */ - 0x00000000, /* DENALI_PHY_276_DATA */ - 0x00000000, /* DENALI_PHY_277_DATA */ - 0x04080000, /* DENALI_PHY_278_DATA */ - 0x04080400, /* DENALI_PHY_279_DATA */ - 0x08000000, /* DENALI_PHY_280_DATA */ - 0x0c00c007, /* DENALI_PHY_281_DATA */ - 0x00000100, /* DENALI_PHY_282_DATA */ - 0x00000100, /* DENALI_PHY_283_DATA */ - 0x55555555, /* DENALI_PHY_284_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_285_DATA */ - 0x55555555, /* DENALI_PHY_286_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_287_DATA */ - 0x00005555, /* DENALI_PHY_288_DATA */ - 0x00000000, /* DENALI_PHY_289_DATA */ - 0x00000000, /* DENALI_PHY_290_DATA */ - 0x00000000, /* DENALI_PHY_291_DATA */ - 0x00000000, /* DENALI_PHY_292_DATA */ - 0x00000000, /* DENALI_PHY_293_DATA */ - 0x00000000, /* DENALI_PHY_294_DATA */ - 0x00000000, /* DENALI_PHY_295_DATA */ - 0x00000000, /* DENALI_PHY_296_DATA */ - 0x00000000, /* DENALI_PHY_297_DATA */ - 0x00000000, /* DENALI_PHY_298_DATA */ - 0x00000000, /* DENALI_PHY_299_DATA */ - 0x00000000, /* DENALI_PHY_300_DATA */ - 0x00000000, /* DENALI_PHY_301_DATA */ - 0x00000000, /* DENALI_PHY_302_DATA */ - 0x00000000, /* DENALI_PHY_303_DATA */ - 0x00000000, /* DENALI_PHY_304_DATA */ - 0x00000000, /* DENALI_PHY_305_DATA */ - 0x00000000, /* DENALI_PHY_306_DATA */ - 0x00000000, /* DENALI_PHY_307_DATA */ - 0x00200000, /* DENALI_PHY_308_DATA */ - 0x00000000, /* DENALI_PHY_309_DATA */ - 0x00000000, /* DENALI_PHY_310_DATA */ - 0x00000000, /* DENALI_PHY_311_DATA */ - 0x00000000, /* DENALI_PHY_312_DATA */ - 0x00000000, /* DENALI_PHY_313_DATA */ - 0x00000000, /* DENALI_PHY_314_DATA */ - 0x02800280, /* DENALI_PHY_315_DATA */ - 0x02800280, /* DENALI_PHY_316_DATA */ - 0x02800280, /* DENALI_PHY_317_DATA */ - 0x02800280, /* DENALI_PHY_318_DATA */ - 0x00000280, /* DENALI_PHY_319_DATA */ - 0x00000000, /* DENALI_PHY_320_DATA */ - 0x00000000, /* DENALI_PHY_321_DATA */ - 0x00000000, /* DENALI_PHY_322_DATA */ - 0x00000000, /* DENALI_PHY_323_DATA */ - 0x00800000, /* DENALI_PHY_324_DATA */ - 0x00800080, /* DENALI_PHY_325_DATA */ - 0x00800080, /* DENALI_PHY_326_DATA */ - 0x00800080, /* DENALI_PHY_327_DATA */ - 0x00800080, /* DENALI_PHY_328_DATA */ - 0x00800080, /* DENALI_PHY_329_DATA */ - 0x00800080, /* DENALI_PHY_330_DATA */ - 0x00800080, /* DENALI_PHY_331_DATA */ - 0x00800080, /* DENALI_PHY_332_DATA */ - 0x00b30080, /* DENALI_PHY_333_DATA */ - 0x01900003, /* DENALI_PHY_334_DATA */ - 0x00000000, /* DENALI_PHY_335_DATA */ - 0x00020000, /* DENALI_PHY_336_DATA */ - 0x00000200, /* DENALI_PHY_337_DATA */ - 0x00000000, /* DENALI_PHY_338_DATA */ - 0x51315152, /* DENALI_PHY_339_DATA */ - 0xc0013150, /* DENALI_PHY_340_DATA */ - 0x020000c0, /* DENALI_PHY_341_DATA */ - 0x00100001, /* DENALI_PHY_342_DATA */ - 0x0c054208, /* DENALI_PHY_343_DATA */ - 0x000f0c18, /* DENALI_PHY_344_DATA */ - 0x01000140, /* DENALI_PHY_345_DATA */ - 0x00000c20, /* DENALI_PHY_346_DATA */ - 0x00000000, /* DENALI_PHY_347_DATA */ - 0x00000000, /* DENALI_PHY_348_DATA */ - 0x00000000, /* DENALI_PHY_349_DATA */ - 0x00000000, /* DENALI_PHY_350_DATA */ - 0x00000000, /* DENALI_PHY_351_DATA */ - 0x00000000, /* DENALI_PHY_352_DATA */ - 0x00000000, /* DENALI_PHY_353_DATA */ - 0x00000000, /* DENALI_PHY_354_DATA */ - 0x00000000, /* DENALI_PHY_355_DATA */ - 0x00000000, /* DENALI_PHY_356_DATA */ - 0x00000000, /* DENALI_PHY_357_DATA */ - 0x00000000, /* DENALI_PHY_358_DATA */ - 0x00000000, /* DENALI_PHY_359_DATA */ - 0x00000000, /* DENALI_PHY_360_DATA */ - 0x00000000, /* DENALI_PHY_361_DATA */ - 0x00000000, /* DENALI_PHY_362_DATA */ - 0x00000000, /* DENALI_PHY_363_DATA */ - 0x00000000, /* DENALI_PHY_364_DATA */ - 0x00000000, /* DENALI_PHY_365_DATA */ - 0x00000000, /* DENALI_PHY_366_DATA */ - 0x00000000, /* DENALI_PHY_367_DATA */ - 0x00000000, /* DENALI_PHY_368_DATA */ - 0x00000000, /* DENALI_PHY_369_DATA */ - 0x00000000, /* DENALI_PHY_370_DATA */ - 0x00000000, /* DENALI_PHY_371_DATA */ - 0x00000000, /* DENALI_PHY_372_DATA */ - 0x00000000, /* DENALI_PHY_373_DATA */ - 0x00000000, /* DENALI_PHY_374_DATA */ - 0x00000000, /* DENALI_PHY_375_DATA */ - 0x00000000, /* DENALI_PHY_376_DATA */ - 0x00000000, /* DENALI_PHY_377_DATA */ - 0x00000000, /* DENALI_PHY_378_DATA */ - 0x00000000, /* DENALI_PHY_379_DATA */ - 0x00000000, /* DENALI_PHY_380_DATA */ - 0x00000000, /* DENALI_PHY_381_DATA */ - 0x00000000, /* DENALI_PHY_382_DATA */ - 0x00000000, /* DENALI_PHY_383_DATA */ - 0x76543210, /* DENALI_PHY_384_DATA */ - 0x0004c008, /* DENALI_PHY_385_DATA */ - 0x000000b3, /* DENALI_PHY_386_DATA */ - 0x00000000, /* DENALI_PHY_387_DATA */ - 0x00000000, /* DENALI_PHY_388_DATA */ - 0x00010000, /* DENALI_PHY_389_DATA */ - 0x01665555, /* DENALI_PHY_390_DATA */ - 0x00665555, /* DENALI_PHY_391_DATA */ - 0x00010f00, /* DENALI_PHY_392_DATA */ - 0x05010200, /* DENALI_PHY_393_DATA */ - 0x00000003, /* DENALI_PHY_394_DATA */ - 0x001700c0, /* DENALI_PHY_395_DATA */ - 0x00cc0101, /* DENALI_PHY_396_DATA */ - 0x00030066, /* DENALI_PHY_397_DATA */ - 0x00000000, /* DENALI_PHY_398_DATA */ - 0x00000000, /* DENALI_PHY_399_DATA */ - 0x00000000, /* DENALI_PHY_400_DATA */ - 0x00000000, /* DENALI_PHY_401_DATA */ - 0x00000000, /* DENALI_PHY_402_DATA */ - 0x00000000, /* DENALI_PHY_403_DATA */ - 0x00000000, /* DENALI_PHY_404_DATA */ - 0x00000000, /* DENALI_PHY_405_DATA */ - 0x04080000, /* DENALI_PHY_406_DATA */ - 0x04080400, /* DENALI_PHY_407_DATA */ - 0x08000000, /* DENALI_PHY_408_DATA */ - 0x0c00c007, /* DENALI_PHY_409_DATA */ - 0x00000100, /* DENALI_PHY_410_DATA */ - 0x00000100, /* DENALI_PHY_411_DATA */ - 0x55555555, /* DENALI_PHY_412_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_413_DATA */ - 0x55555555, /* DENALI_PHY_414_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_415_DATA */ - 0x00005555, /* DENALI_PHY_416_DATA */ - 0x00000000, /* DENALI_PHY_417_DATA */ - 0x00000000, /* DENALI_PHY_418_DATA */ - 0x00000000, /* DENALI_PHY_419_DATA */ - 0x00000000, /* DENALI_PHY_420_DATA */ - 0x00000000, /* DENALI_PHY_421_DATA */ - 0x00000000, /* DENALI_PHY_422_DATA */ - 0x00000000, /* DENALI_PHY_423_DATA */ - 0x00000000, /* DENALI_PHY_424_DATA */ - 0x00000000, /* DENALI_PHY_425_DATA */ - 0x00000000, /* DENALI_PHY_426_DATA */ - 0x00000000, /* DENALI_PHY_427_DATA */ - 0x00000000, /* DENALI_PHY_428_DATA */ - 0x00000000, /* DENALI_PHY_429_DATA */ - 0x00000000, /* DENALI_PHY_430_DATA */ - 0x00000000, /* DENALI_PHY_431_DATA */ - 0x00000000, /* DENALI_PHY_432_DATA */ - 0x00000000, /* DENALI_PHY_433_DATA */ - 0x00000000, /* DENALI_PHY_434_DATA */ - 0x00000000, /* DENALI_PHY_435_DATA */ - 0x00200000, /* DENALI_PHY_436_DATA */ - 0x00000000, /* DENALI_PHY_437_DATA */ - 0x00000000, /* DENALI_PHY_438_DATA */ - 0x00000000, /* DENALI_PHY_439_DATA */ - 0x00000000, /* DENALI_PHY_440_DATA */ - 0x00000000, /* DENALI_PHY_441_DATA */ - 0x00000000, /* DENALI_PHY_442_DATA */ - 0x02800280, /* DENALI_PHY_443_DATA */ - 0x02800280, /* DENALI_PHY_444_DATA */ - 0x02800280, /* DENALI_PHY_445_DATA */ - 0x02800280, /* DENALI_PHY_446_DATA */ - 0x00000280, /* DENALI_PHY_447_DATA */ - 0x00000000, /* DENALI_PHY_448_DATA */ - 0x00000000, /* DENALI_PHY_449_DATA */ - 0x00000000, /* DENALI_PHY_450_DATA */ - 0x00000000, /* DENALI_PHY_451_DATA */ - 0x00800000, /* DENALI_PHY_452_DATA */ - 0x00800080, /* DENALI_PHY_453_DATA */ - 0x00800080, /* DENALI_PHY_454_DATA */ - 0x00800080, /* DENALI_PHY_455_DATA */ - 0x00800080, /* DENALI_PHY_456_DATA */ - 0x00800080, /* DENALI_PHY_457_DATA */ - 0x00800080, /* DENALI_PHY_458_DATA */ - 0x00800080, /* DENALI_PHY_459_DATA */ - 0x00800080, /* DENALI_PHY_460_DATA */ - 0x00b30080, /* DENALI_PHY_461_DATA */ - 0x01900003, /* DENALI_PHY_462_DATA */ - 0x00000000, /* DENALI_PHY_463_DATA */ - 0x00020000, /* DENALI_PHY_464_DATA */ - 0x00000200, /* DENALI_PHY_465_DATA */ - 0x00000000, /* DENALI_PHY_466_DATA */ - 0x51315152, /* DENALI_PHY_467_DATA */ - 0xc0013150, /* DENALI_PHY_468_DATA */ - 0x020000c0, /* DENALI_PHY_469_DATA */ - 0x00100001, /* DENALI_PHY_470_DATA */ - 0x0c054208, /* DENALI_PHY_471_DATA */ - 0x000f0c18, /* DENALI_PHY_472_DATA */ - 0x01000140, /* DENALI_PHY_473_DATA */ - 0x00000c20, /* DENALI_PHY_474_DATA */ - 0x00000000, /* DENALI_PHY_475_DATA */ - 0x00000000, /* DENALI_PHY_476_DATA */ - 0x00000000, /* DENALI_PHY_477_DATA */ - 0x00000000, /* DENALI_PHY_478_DATA */ - 0x00000000, /* DENALI_PHY_479_DATA */ - 0x00000000, /* DENALI_PHY_480_DATA */ - 0x00000000, /* DENALI_PHY_481_DATA */ - 0x00000000, /* DENALI_PHY_482_DATA */ - 0x00000000, /* DENALI_PHY_483_DATA */ - 0x00000000, /* DENALI_PHY_484_DATA */ - 0x00000000, /* DENALI_PHY_485_DATA */ - 0x00000000, /* DENALI_PHY_486_DATA */ - 0x00000000, /* DENALI_PHY_487_DATA */ - 0x00000000, /* DENALI_PHY_488_DATA */ - 0x00000000, /* DENALI_PHY_489_DATA */ - 0x00000000, /* DENALI_PHY_490_DATA */ - 0x00000000, /* DENALI_PHY_491_DATA */ - 0x00000000, /* DENALI_PHY_492_DATA */ - 0x00000000, /* DENALI_PHY_493_DATA */ - 0x00000000, /* DENALI_PHY_494_DATA */ - 0x00000000, /* DENALI_PHY_495_DATA */ - 0x00000000, /* DENALI_PHY_496_DATA */ - 0x00000000, /* DENALI_PHY_497_DATA */ - 0x00000000, /* DENALI_PHY_498_DATA */ - 0x00000000, /* DENALI_PHY_499_DATA */ - 0x00000000, /* DENALI_PHY_500_DATA */ - 0x00000000, /* DENALI_PHY_501_DATA */ - 0x00000000, /* DENALI_PHY_502_DATA */ - 0x00000000, /* DENALI_PHY_503_DATA */ - 0x00000000, /* DENALI_PHY_504_DATA */ - 0x00000000, /* DENALI_PHY_505_DATA */ - 0x00000000, /* DENALI_PHY_506_DATA */ - 0x00000000, /* DENALI_PHY_507_DATA */ - 0x00000000, /* DENALI_PHY_508_DATA */ - 0x00000000, /* DENALI_PHY_509_DATA */ - 0x00000000, /* DENALI_PHY_510_DATA */ - 0x00000000, /* DENALI_PHY_511_DATA */ - 0x00000000, /* DENALI_PHY_512_DATA */ - 0x00800000, /* DENALI_PHY_513_DATA */ - 0x00000000, /* DENALI_PHY_514_DATA */ - 0x00000000, /* DENALI_PHY_515_DATA */ - 0x00000000, /* DENALI_PHY_516_DATA */ - 0x00000000, /* DENALI_PHY_517_DATA */ - 0x00000000, /* DENALI_PHY_518_DATA */ - 0x00000001, /* DENALI_PHY_519_DATA */ - 0x00000000, /* DENALI_PHY_520_DATA */ - 0x00000000, /* DENALI_PHY_521_DATA */ - 0x00000000, /* DENALI_PHY_522_DATA */ - 0x00400320, /* DENALI_PHY_523_DATA */ - 0x00000040, /* DENALI_PHY_524_DATA */ - 0x00806420, /* DENALI_PHY_525_DATA */ - 0x00917531, /* DENALI_PHY_526_DATA */ - 0x00806420, /* DENALI_PHY_527_DATA */ - 0x01917531, /* DENALI_PHY_528_DATA */ - 0x00020003, /* DENALI_PHY_529_DATA */ - 0x00000000, /* DENALI_PHY_530_DATA */ - 0x00000000, /* DENALI_PHY_531_DATA */ - 0x00000000, /* DENALI_PHY_532_DATA */ - 0x000556aa, /* DENALI_PHY_533_DATA */ - 0x000aaaaa, /* DENALI_PHY_534_DATA */ - 0x000aa955, /* DENALI_PHY_535_DATA */ - 0x00055555, /* DENALI_PHY_536_DATA */ - 0x000b3133, /* DENALI_PHY_537_DATA */ - 0x0004cd33, /* DENALI_PHY_538_DATA */ - 0x0004cecc, /* DENALI_PHY_539_DATA */ - 0x000b32cc, /* DENALI_PHY_540_DATA */ - 0x0a418820, /* DENALI_PHY_541_DATA */ - 0x103f0000, /* DENALI_PHY_542_DATA */ - 0x0000003f, /* DENALI_PHY_543_DATA */ - 0x00038055, /* DENALI_PHY_544_DATA */ - 0x03800380, /* DENALI_PHY_545_DATA */ - 0x03800380, /* DENALI_PHY_546_DATA */ - 0x00000380, /* DENALI_PHY_547_DATA */ - 0x42080010, /* DENALI_PHY_548_DATA */ - 0x00000003, /* DENALI_PHY_549_DATA */ - 0x00000000, /* DENALI_PHY_550_DATA */ - 0x00000000, /* DENALI_PHY_551_DATA */ - 0x00000000, /* DENALI_PHY_552_DATA */ - 0x00000000, /* DENALI_PHY_553_DATA */ - 0x00000000, /* DENALI_PHY_554_DATA */ - 0x00000000, /* DENALI_PHY_555_DATA */ - 0x00000000, /* DENALI_PHY_556_DATA */ - 0x00000000, /* DENALI_PHY_557_DATA */ - 0x00000000, /* DENALI_PHY_558_DATA */ - 0x00000000, /* DENALI_PHY_559_DATA */ - 0x00000000, /* DENALI_PHY_560_DATA */ - 0x00000000, /* DENALI_PHY_561_DATA */ - 0x00000000, /* DENALI_PHY_562_DATA */ - 0x00000000, /* DENALI_PHY_563_DATA */ - 0x00000000, /* DENALI_PHY_564_DATA */ - 0x00000000, /* DENALI_PHY_565_DATA */ - 0x00000000, /* DENALI_PHY_566_DATA */ - 0x00000000, /* DENALI_PHY_567_DATA */ - 0x00000000, /* DENALI_PHY_568_DATA */ - 0x00000000, /* DENALI_PHY_569_DATA */ - 0x00000000, /* DENALI_PHY_570_DATA */ - 0x00000000, /* DENALI_PHY_571_DATA */ - 0x00000000, /* DENALI_PHY_572_DATA */ - 0x00000000, /* DENALI_PHY_573_DATA */ - 0x00000000, /* DENALI_PHY_574_DATA */ - 0x00000000, /* DENALI_PHY_575_DATA */ - 0x00000000, /* DENALI_PHY_576_DATA */ - 0x00000000, /* DENALI_PHY_577_DATA */ - 0x00000000, /* DENALI_PHY_578_DATA */ - 0x00000000, /* DENALI_PHY_579_DATA */ - 0x00000000, /* DENALI_PHY_580_DATA */ - 0x00000000, /* DENALI_PHY_581_DATA */ - 0x00000000, /* DENALI_PHY_582_DATA */ - 0x00000000, /* DENALI_PHY_583_DATA */ - 0x00000000, /* DENALI_PHY_584_DATA */ - 0x00000000, /* DENALI_PHY_585_DATA */ - 0x00000000, /* DENALI_PHY_586_DATA */ - 0x00000000, /* DENALI_PHY_587_DATA */ - 0x00000000, /* DENALI_PHY_588_DATA */ - 0x00000000, /* DENALI_PHY_589_DATA */ - 0x00000000, /* DENALI_PHY_590_DATA */ - 0x00000000, /* DENALI_PHY_591_DATA */ - 0x00000000, /* DENALI_PHY_592_DATA */ - 0x00000000, /* DENALI_PHY_593_DATA */ - 0x00000000, /* DENALI_PHY_594_DATA */ - 0x00000000, /* DENALI_PHY_595_DATA */ - 0x00000000, /* DENALI_PHY_596_DATA */ - 0x00000000, /* DENALI_PHY_597_DATA */ - 0x00000000, /* DENALI_PHY_598_DATA */ - 0x00000000, /* DENALI_PHY_599_DATA */ - 0x00000000, /* DENALI_PHY_600_DATA */ - 0x00000000, /* DENALI_PHY_601_DATA */ - 0x00000000, /* DENALI_PHY_602_DATA */ - 0x00000000, /* DENALI_PHY_603_DATA */ - 0x00000000, /* DENALI_PHY_604_DATA */ - 0x00000000, /* DENALI_PHY_605_DATA */ - 0x00000000, /* DENALI_PHY_606_DATA */ - 0x00000000, /* DENALI_PHY_607_DATA */ - 0x00000000, /* DENALI_PHY_608_DATA */ - 0x00000000, /* DENALI_PHY_609_DATA */ - 0x00000000, /* DENALI_PHY_610_DATA */ - 0x00000000, /* DENALI_PHY_611_DATA */ - 0x00000000, /* DENALI_PHY_612_DATA */ - 0x00000000, /* DENALI_PHY_613_DATA */ - 0x00000000, /* DENALI_PHY_614_DATA */ - 0x00000000, /* DENALI_PHY_615_DATA */ - 0x00000000, /* DENALI_PHY_616_DATA */ - 0x00000000, /* DENALI_PHY_617_DATA */ - 0x00000000, /* DENALI_PHY_618_DATA */ - 0x00000000, /* DENALI_PHY_619_DATA */ - 0x00000000, /* DENALI_PHY_620_DATA */ - 0x00000000, /* DENALI_PHY_621_DATA */ - 0x00000000, /* DENALI_PHY_622_DATA */ - 0x00000000, /* DENALI_PHY_623_DATA */ - 0x00000000, /* DENALI_PHY_624_DATA */ - 0x00000000, /* DENALI_PHY_625_DATA */ - 0x00000000, /* DENALI_PHY_626_DATA */ - 0x00000000, /* DENALI_PHY_627_DATA */ - 0x00000000, /* DENALI_PHY_628_DATA */ - 0x00000000, /* DENALI_PHY_629_DATA */ - 0x00000000, /* DENALI_PHY_630_DATA */ - 0x00000000, /* DENALI_PHY_631_DATA */ - 0x00000000, /* DENALI_PHY_632_DATA */ - 0x00000000, /* DENALI_PHY_633_DATA */ - 0x00000000, /* DENALI_PHY_634_DATA */ - 0x00000000, /* DENALI_PHY_635_DATA */ - 0x00000000, /* DENALI_PHY_636_DATA */ - 0x00000000, /* DENALI_PHY_637_DATA */ - 0x00000000, /* DENALI_PHY_638_DATA */ - 0x00000000, /* DENALI_PHY_639_DATA */ - 0x00000000, /* DENALI_PHY_640_DATA */ - 0x00800000, /* DENALI_PHY_641_DATA */ - 0x00000000, /* DENALI_PHY_642_DATA */ - 0x00000000, /* DENALI_PHY_643_DATA */ - 0x00000000, /* DENALI_PHY_644_DATA */ - 0x00000000, /* DENALI_PHY_645_DATA */ - 0x00000000, /* DENALI_PHY_646_DATA */ - 0x00000001, /* DENALI_PHY_647_DATA */ - 0x00000000, /* DENALI_PHY_648_DATA */ - 0x00000000, /* DENALI_PHY_649_DATA */ - 0x00000000, /* DENALI_PHY_650_DATA */ - 0x00400320, /* DENALI_PHY_651_DATA */ - 0x00000040, /* DENALI_PHY_652_DATA */ - 0x00008eca, /* DENALI_PHY_653_DATA */ - 0x00009fdb, /* DENALI_PHY_654_DATA */ - 0x00008eca, /* DENALI_PHY_655_DATA */ - 0x01009fdb, /* DENALI_PHY_656_DATA */ - 0x00020003, /* DENALI_PHY_657_DATA */ - 0x00000000, /* DENALI_PHY_658_DATA */ - 0x00000000, /* DENALI_PHY_659_DATA */ - 0x00000000, /* DENALI_PHY_660_DATA */ - 0x000556aa, /* DENALI_PHY_661_DATA */ - 0x000aaaaa, /* DENALI_PHY_662_DATA */ - 0x000aa955, /* DENALI_PHY_663_DATA */ - 0x00055555, /* DENALI_PHY_664_DATA */ - 0x000b3133, /* DENALI_PHY_665_DATA */ - 0x0004cd33, /* DENALI_PHY_666_DATA */ - 0x0004cecc, /* DENALI_PHY_667_DATA */ - 0x000b32cc, /* DENALI_PHY_668_DATA */ - 0x0004a0e6, /* DENALI_PHY_669_DATA */ - 0x080f0000, /* DENALI_PHY_670_DATA */ - 0x0000000f, /* DENALI_PHY_671_DATA */ - 0x00038055, /* DENALI_PHY_672_DATA */ - 0x03800380, /* DENALI_PHY_673_DATA */ - 0x03800380, /* DENALI_PHY_674_DATA */ - 0x00000380, /* DENALI_PHY_675_DATA */ - 0x42080010, /* DENALI_PHY_676_DATA */ - 0x00000003, /* DENALI_PHY_677_DATA */ - 0x00000000, /* DENALI_PHY_678_DATA */ - 0x00000000, /* DENALI_PHY_679_DATA */ - 0x00000000, /* DENALI_PHY_680_DATA */ - 0x00000000, /* DENALI_PHY_681_DATA */ - 0x00000000, /* DENALI_PHY_682_DATA */ - 0x00000000, /* DENALI_PHY_683_DATA */ - 0x00000000, /* DENALI_PHY_684_DATA */ - 0x00000000, /* DENALI_PHY_685_DATA */ - 0x00000000, /* DENALI_PHY_686_DATA */ - 0x00000000, /* DENALI_PHY_687_DATA */ - 0x00000000, /* DENALI_PHY_688_DATA */ - 0x00000000, /* DENALI_PHY_689_DATA */ - 0x00000000, /* DENALI_PHY_690_DATA */ - 0x00000000, /* DENALI_PHY_691_DATA */ - 0x00000000, /* DENALI_PHY_692_DATA */ - 0x00000000, /* DENALI_PHY_693_DATA */ - 0x00000000, /* DENALI_PHY_694_DATA */ - 0x00000000, /* DENALI_PHY_695_DATA */ - 0x00000000, /* DENALI_PHY_696_DATA */ - 0x00000000, /* DENALI_PHY_697_DATA */ - 0x00000000, /* DENALI_PHY_698_DATA */ - 0x00000000, /* DENALI_PHY_699_DATA */ - 0x00000000, /* DENALI_PHY_700_DATA */ - 0x00000000, /* DENALI_PHY_701_DATA */ - 0x00000000, /* DENALI_PHY_702_DATA */ - 0x00000000, /* DENALI_PHY_703_DATA */ - 0x00000000, /* DENALI_PHY_704_DATA */ - 0x00000000, /* DENALI_PHY_705_DATA */ - 0x00000000, /* DENALI_PHY_706_DATA */ - 0x00000000, /* DENALI_PHY_707_DATA */ - 0x00000000, /* DENALI_PHY_708_DATA */ - 0x00000000, /* DENALI_PHY_709_DATA */ - 0x00000000, /* DENALI_PHY_710_DATA */ - 0x00000000, /* DENALI_PHY_711_DATA */ - 0x00000000, /* DENALI_PHY_712_DATA */ - 0x00000000, /* DENALI_PHY_713_DATA */ - 0x00000000, /* DENALI_PHY_714_DATA */ - 0x00000000, /* DENALI_PHY_715_DATA */ - 0x00000000, /* DENALI_PHY_716_DATA */ - 0x00000000, /* DENALI_PHY_717_DATA */ - 0x00000000, /* DENALI_PHY_718_DATA */ - 0x00000000, /* DENALI_PHY_719_DATA */ - 0x00000000, /* DENALI_PHY_720_DATA */ - 0x00000000, /* DENALI_PHY_721_DATA */ - 0x00000000, /* DENALI_PHY_722_DATA */ - 0x00000000, /* DENALI_PHY_723_DATA */ - 0x00000000, /* DENALI_PHY_724_DATA */ - 0x00000000, /* DENALI_PHY_725_DATA */ - 0x00000000, /* DENALI_PHY_726_DATA */ - 0x00000000, /* DENALI_PHY_727_DATA */ - 0x00000000, /* DENALI_PHY_728_DATA */ - 0x00000000, /* DENALI_PHY_729_DATA */ - 0x00000000, /* DENALI_PHY_730_DATA */ - 0x00000000, /* DENALI_PHY_731_DATA */ - 0x00000000, /* DENALI_PHY_732_DATA */ - 0x00000000, /* DENALI_PHY_733_DATA */ - 0x00000000, /* DENALI_PHY_734_DATA */ - 0x00000000, /* DENALI_PHY_735_DATA */ - 0x00000000, /* DENALI_PHY_736_DATA */ - 0x00000000, /* DENALI_PHY_737_DATA */ - 0x00000000, /* DENALI_PHY_738_DATA */ - 0x00000000, /* DENALI_PHY_739_DATA */ - 0x00000000, /* DENALI_PHY_740_DATA */ - 0x00000000, /* DENALI_PHY_741_DATA */ - 0x00000000, /* DENALI_PHY_742_DATA */ - 0x00000000, /* DENALI_PHY_743_DATA */ - 0x00000000, /* DENALI_PHY_744_DATA */ - 0x00000000, /* DENALI_PHY_745_DATA */ - 0x00000000, /* DENALI_PHY_746_DATA */ - 0x00000000, /* DENALI_PHY_747_DATA */ - 0x00000000, /* DENALI_PHY_748_DATA */ - 0x00000000, /* DENALI_PHY_749_DATA */ - 0x00000000, /* DENALI_PHY_750_DATA */ - 0x00000000, /* DENALI_PHY_751_DATA */ - 0x00000000, /* DENALI_PHY_752_DATA */ - 0x00000000, /* DENALI_PHY_753_DATA */ - 0x00000000, /* DENALI_PHY_754_DATA */ - 0x00000000, /* DENALI_PHY_755_DATA */ - 0x00000000, /* DENALI_PHY_756_DATA */ - 0x00000000, /* DENALI_PHY_757_DATA */ - 0x00000000, /* DENALI_PHY_758_DATA */ - 0x00000000, /* DENALI_PHY_759_DATA */ - 0x00000000, /* DENALI_PHY_760_DATA */ - 0x00000000, /* DENALI_PHY_761_DATA */ - 0x00000000, /* DENALI_PHY_762_DATA */ - 0x00000000, /* DENALI_PHY_763_DATA */ - 0x00000000, /* DENALI_PHY_764_DATA */ - 0x00000000, /* DENALI_PHY_765_DATA */ - 0x00000000, /* DENALI_PHY_766_DATA */ - 0x00000000, /* DENALI_PHY_767_DATA */ - 0x00000000, /* DENALI_PHY_768_DATA */ - 0x00800000, /* DENALI_PHY_769_DATA */ - 0x00000000, /* DENALI_PHY_770_DATA */ - 0x00000000, /* DENALI_PHY_771_DATA */ - 0x00000000, /* DENALI_PHY_772_DATA */ - 0x00000000, /* DENALI_PHY_773_DATA */ - 0x00000000, /* DENALI_PHY_774_DATA */ - 0x00000001, /* DENALI_PHY_775_DATA */ - 0x00000000, /* DENALI_PHY_776_DATA */ - 0x00000000, /* DENALI_PHY_777_DATA */ - 0x00000000, /* DENALI_PHY_778_DATA */ - 0x00400320, /* DENALI_PHY_779_DATA */ - 0x00000040, /* DENALI_PHY_780_DATA */ - 0x00008eca, /* DENALI_PHY_781_DATA */ - 0x00009fdb, /* DENALI_PHY_782_DATA */ - 0x00008eca, /* DENALI_PHY_783_DATA */ - 0x01009fdb, /* DENALI_PHY_784_DATA */ - 0x00020003, /* DENALI_PHY_785_DATA */ - 0x00000000, /* DENALI_PHY_786_DATA */ - 0x00000000, /* DENALI_PHY_787_DATA */ - 0x00000000, /* DENALI_PHY_788_DATA */ - 0x000556aa, /* DENALI_PHY_789_DATA */ - 0x000aaaaa, /* DENALI_PHY_790_DATA */ - 0x000aa955, /* DENALI_PHY_791_DATA */ - 0x00055555, /* DENALI_PHY_792_DATA */ - 0x000b3133, /* DENALI_PHY_793_DATA */ - 0x0004cd33, /* DENALI_PHY_794_DATA */ - 0x0004cecc, /* DENALI_PHY_795_DATA */ - 0x000b32cc, /* DENALI_PHY_796_DATA */ - 0x1ee6b16a, /* DENALI_PHY_797_DATA */ - 0x10000000, /* DENALI_PHY_798_DATA */ - 0x00000000, /* DENALI_PHY_799_DATA */ - 0x00038055, /* DENALI_PHY_800_DATA */ - 0x03800380, /* DENALI_PHY_801_DATA */ - 0x03800380, /* DENALI_PHY_802_DATA */ - 0x00000380, /* DENALI_PHY_803_DATA */ - 0x42080010, /* DENALI_PHY_804_DATA */ - 0x00000003, /* DENALI_PHY_805_DATA */ - 0x00000000, /* DENALI_PHY_806_DATA */ - 0x00000000, /* DENALI_PHY_807_DATA */ - 0x00000000, /* DENALI_PHY_808_DATA */ - 0x00000000, /* DENALI_PHY_809_DATA */ - 0x00000000, /* DENALI_PHY_810_DATA */ - 0x00000000, /* DENALI_PHY_811_DATA */ - 0x00000000, /* DENALI_PHY_812_DATA */ - 0x00000000, /* DENALI_PHY_813_DATA */ - 0x00000000, /* DENALI_PHY_814_DATA */ - 0x00000000, /* DENALI_PHY_815_DATA */ - 0x00000000, /* DENALI_PHY_816_DATA */ - 0x00000000, /* DENALI_PHY_817_DATA */ - 0x00000000, /* DENALI_PHY_818_DATA */ - 0x00000000, /* DENALI_PHY_819_DATA */ - 0x00000000, /* DENALI_PHY_820_DATA */ - 0x00000000, /* DENALI_PHY_821_DATA */ - 0x00000000, /* DENALI_PHY_822_DATA */ - 0x00000000, /* DENALI_PHY_823_DATA */ - 0x00000000, /* DENALI_PHY_824_DATA */ - 0x00000000, /* DENALI_PHY_825_DATA */ - 0x00000000, /* DENALI_PHY_826_DATA */ - 0x00000000, /* DENALI_PHY_827_DATA */ - 0x00000000, /* DENALI_PHY_828_DATA */ - 0x00000000, /* DENALI_PHY_829_DATA */ - 0x00000000, /* DENALI_PHY_830_DATA */ - 0x00000000, /* DENALI_PHY_831_DATA */ - 0x00000000, /* DENALI_PHY_832_DATA */ - 0x00000000, /* DENALI_PHY_833_DATA */ - 0x00000000, /* DENALI_PHY_834_DATA */ - 0x00000000, /* DENALI_PHY_835_DATA */ - 0x00000000, /* DENALI_PHY_836_DATA */ - 0x00000000, /* DENALI_PHY_837_DATA */ - 0x00000000, /* DENALI_PHY_838_DATA */ - 0x00000000, /* DENALI_PHY_839_DATA */ - 0x00000000, /* DENALI_PHY_840_DATA */ - 0x00000000, /* DENALI_PHY_841_DATA */ - 0x00000000, /* DENALI_PHY_842_DATA */ - 0x00000000, /* DENALI_PHY_843_DATA */ - 0x00000000, /* DENALI_PHY_844_DATA */ - 0x00000000, /* DENALI_PHY_845_DATA */ - 0x00000000, /* DENALI_PHY_846_DATA */ - 0x00000000, /* DENALI_PHY_847_DATA */ - 0x00000000, /* DENALI_PHY_848_DATA */ - 0x00000000, /* DENALI_PHY_849_DATA */ - 0x00000000, /* DENALI_PHY_850_DATA */ - 0x00000000, /* DENALI_PHY_851_DATA */ - 0x00000000, /* DENALI_PHY_852_DATA */ - 0x00000000, /* DENALI_PHY_853_DATA */ - 0x00000000, /* DENALI_PHY_854_DATA */ - 0x00000000, /* DENALI_PHY_855_DATA */ - 0x00000000, /* DENALI_PHY_856_DATA */ - 0x00000000, /* DENALI_PHY_857_DATA */ - 0x00000000, /* DENALI_PHY_858_DATA */ - 0x00000000, /* DENALI_PHY_859_DATA */ - 0x00000000, /* DENALI_PHY_860_DATA */ - 0x00000000, /* DENALI_PHY_861_DATA */ - 0x00000000, /* DENALI_PHY_862_DATA */ - 0x00000000, /* DENALI_PHY_863_DATA */ - 0x00000000, /* DENALI_PHY_864_DATA */ - 0x00000000, /* DENALI_PHY_865_DATA */ - 0x00000000, /* DENALI_PHY_866_DATA */ - 0x00000000, /* DENALI_PHY_867_DATA */ - 0x00000000, /* DENALI_PHY_868_DATA */ - 0x00000000, /* DENALI_PHY_869_DATA */ - 0x00000000, /* DENALI_PHY_870_DATA */ - 0x00000000, /* DENALI_PHY_871_DATA */ - 0x00000000, /* DENALI_PHY_872_DATA */ - 0x00000000, /* DENALI_PHY_873_DATA */ - 0x00000000, /* DENALI_PHY_874_DATA */ - 0x00000000, /* DENALI_PHY_875_DATA */ - 0x00000000, /* DENALI_PHY_876_DATA */ - 0x00000000, /* DENALI_PHY_877_DATA */ - 0x00000000, /* DENALI_PHY_878_DATA */ - 0x00000000, /* DENALI_PHY_879_DATA */ - 0x00000000, /* DENALI_PHY_880_DATA */ - 0x00000000, /* DENALI_PHY_881_DATA */ - 0x00000000, /* DENALI_PHY_882_DATA */ - 0x00000000, /* DENALI_PHY_883_DATA */ - 0x00000000, /* DENALI_PHY_884_DATA */ - 0x00000000, /* DENALI_PHY_885_DATA */ - 0x00000000, /* DENALI_PHY_886_DATA */ - 0x00000000, /* DENALI_PHY_887_DATA */ - 0x00000000, /* DENALI_PHY_888_DATA */ - 0x00000000, /* DENALI_PHY_889_DATA */ - 0x00000000, /* DENALI_PHY_890_DATA */ - 0x00000000, /* DENALI_PHY_891_DATA */ - 0x00000000, /* DENALI_PHY_892_DATA */ - 0x00000000, /* DENALI_PHY_893_DATA */ - 0x00000000, /* DENALI_PHY_894_DATA */ - 0x00000000, /* DENALI_PHY_895_DATA */ - 0x00000001, /* DENALI_PHY_896_DATA */ - 0x00000000, /* DENALI_PHY_897_DATA */ - 0x01000005, /* DENALI_PHY_898_DATA */ - 0x04000f00, /* DENALI_PHY_899_DATA */ - 0x00020040, /* DENALI_PHY_900_DATA */ - 0x00020055, /* DENALI_PHY_901_DATA */ - 0x00000000, /* DENALI_PHY_902_DATA */ - 0x00000000, /* DENALI_PHY_903_DATA */ - 0x00000000, /* DENALI_PHY_904_DATA */ - 0x00000050, /* DENALI_PHY_905_DATA */ - 0x00000000, /* DENALI_PHY_906_DATA */ - 0x00010100, /* DENALI_PHY_907_DATA */ - 0x00000601, /* DENALI_PHY_908_DATA */ - 0x00000000, /* DENALI_PHY_909_DATA */ - 0x00006400, /* DENALI_PHY_910_DATA */ - 0x01221102, /* DENALI_PHY_911_DATA */ - 0x00000000, /* DENALI_PHY_912_DATA */ - 0x00051f00, /* DENALI_PHY_913_DATA */ - 0x051f051f, /* DENALI_PHY_914_DATA */ - 0x051f051f, /* DENALI_PHY_915_DATA */ - 0x00030003, /* DENALI_PHY_916_DATA */ - 0x03000300, /* DENALI_PHY_917_DATA */ - 0x00000300, /* DENALI_PHY_918_DATA */ - 0x01221102, /* DENALI_PHY_919_DATA */ - 0x00000000, /* DENALI_PHY_920_DATA */ - 0x00000000, /* DENALI_PHY_921_DATA */ - 0x03020000, /* DENALI_PHY_922_DATA */ - 0x00000001, /* DENALI_PHY_923_DATA */ - 0x00000011, /* DENALI_PHY_924_DATA */ - 0x00000011, /* DENALI_PHY_925_DATA */ - 0x00000400, /* DENALI_PHY_926_DATA */ - 0x00000000, /* DENALI_PHY_927_DATA */ - 0x00000011, /* DENALI_PHY_928_DATA */ - 0x00000011, /* DENALI_PHY_929_DATA */ - 0x00004410, /* DENALI_PHY_930_DATA */ - 0x00004410, /* DENALI_PHY_931_DATA */ - 0x00004410, /* DENALI_PHY_932_DATA */ - 0x00004410, /* DENALI_PHY_933_DATA */ - 0x00004410, /* DENALI_PHY_934_DATA */ - 0x00000011, /* DENALI_PHY_935_DATA */ - 0x00004410, /* DENALI_PHY_936_DATA */ - 0x00000011, /* DENALI_PHY_937_DATA */ - 0x00004410, /* DENALI_PHY_938_DATA */ - 0x00000011, /* DENALI_PHY_939_DATA */ - 0x00004410, /* DENALI_PHY_940_DATA */ - 0x00000000, /* DENALI_PHY_941_DATA */ - 0x00000000, /* DENALI_PHY_942_DATA */ - 0x00000000, /* DENALI_PHY_943_DATA */ - 0x04000000, /* DENALI_PHY_944_DATA */ - 0x00000000, /* DENALI_PHY_945_DATA */ - 0x00000000, /* DENALI_PHY_946_DATA */ - 0x00000508, /* DENALI_PHY_947_DATA */ - 0x00000000, /* DENALI_PHY_948_DATA */ - 0x00000000, /* DENALI_PHY_949_DATA */ - 0x00000000, /* DENALI_PHY_950_DATA */ - 0x00000000, /* DENALI_PHY_951_DATA */ - 0x00000000, /* DENALI_PHY_952_DATA */ - 0x00000000, /* DENALI_PHY_953_DATA */ - 0xe4000000, /* DENALI_PHY_954_DATA */ - 0x00000000, /* DENALI_PHY_955_DATA */ - 0x00000000, /* DENALI_PHY_956_DATA */ - 0x01010000, /* DENALI_PHY_957_DATA */ - 0x00000000 /* DENALI_PHY_958_DATA */ - } - }, -}, diff --git a/src/mainboard/google/gru/sdram_inf/sdram-lpddr3-hynix-4GB-933.c b/src/mainboard/google/gru/sdram_inf/sdram-lpddr3-hynix-4GB-933.c new file mode 100644 index 0000000..2ef9d0c --- /dev/null +++ b/src/mainboard/google/gru/sdram_inf/sdram-lpddr3-hynix-4GB-933.c @@ -0,0 +1,1565 @@ +/* + * This file is part of the coreboot project. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <soc/sdram.h> + +struct rk3399_sdram_params params = { + { + { + .rank = 0x2, + .col = 0xA, + .bk = 0x3, + .bw = 0x2, + .dbw = 0x2, + .row_3_4 = 0x0, + .cs0_row = 0xF, + .cs1_row = 0xF, + .ddrconfig = 1, + { + {0x1d191519}, + {0x14040808}, + {0x00000002}, + {0x00006226}, + {0x00000054}, + 0x00000000 + } + }, + { + .rank = 0x2, + .col = 0xA, + .bk = 0x3, + .bw = 0x2, + .dbw = 0x2, + .row_3_4 = 0x0, + .cs0_row = 0xF, + .cs1_row = 0xF, + .ddrconfig = 1, + { + {0x1d191519}, + {0x14040808}, + {0x00000002}, + {0x00006226}, + {0x00000054}, + 0x00000000 + } + } + }, + .ddr_freq = 933*MHz, + .dramtype = LPDDR3, + .num_channels = 2, + .stride = 13, + .odt = 1, + { + { + 0x00000700, /* DENALI_CTL_00_DATA */ + 0x00000000, /* DENALI_CTL_01_DATA */ + 0x00000000, /* DENALI_CTL_02_DATA */ + 0x00000000, /* DENALI_CTL_03_DATA */ + 0x00000000, /* DENALI_CTL_04_DATA */ + 0x0000005e, /* DENALI_CTL_05_DATA */ + 0x0002d976, /* DENALI_CTL_06_DATA */ + 0x000003a6, /* DENALI_CTL_07_DATA */ + 0x0000247a, /* DENALI_CTL_08_DATA */ + 0x0000005e, /* DENALI_CTL_09_DATA */ + 0x0002d976, /* DENALI_CTL_10_DATA */ + 0x000003a6, /* DENALI_CTL_11_DATA */ + 0x0000247a, /* DENALI_CTL_12_DATA */ + 0x0000005e, /* DENALI_CTL_13_DATA */ + 0x0002d976, /* DENALI_CTL_14_DATA */ + 0x000003a6, /* DENALI_CTL_15_DATA */ + 0x0100247a, /* DENALI_CTL_16_DATA */ + 0x00000000, /* DENALI_CTL_17_DATA */ + 0x00000101, /* DENALI_CTL_18_DATA */ + 0x00020100, /* DENALI_CTL_19_DATA */ + 0x000000bb, /* DENALI_CTL_20_DATA */ + 0x000001d3, /* DENALI_CTL_21_DATA */ + 0x00000000, /* DENALI_CTL_22_DATA */ + 0x081c0000, /* DENALI_CTL_23_DATA */ + 0x00081c00, /* DENALI_CTL_24_DATA */ + 0x0400081c, /* DENALI_CTL_25_DATA */ + 0x3b0a0004, /* DENALI_CTL_26_DATA */ + 0x2f110828, /* DENALI_CTL_27_DATA */ + 0x283b0a00, /* DENALI_CTL_28_DATA */ + 0x002f1108, /* DENALI_CTL_29_DATA */ + 0x08283b0a, /* DENALI_CTL_30_DATA */ + 0x08002f11, /* DENALI_CTL_31_DATA */ + 0x00000a0a, /* DENALI_CTL_32_DATA */ + 0x0800ff4f, /* DENALI_CTL_33_DATA */ + 0x0a0a080f, /* DENALI_CTL_34_DATA */ + 0x0800ff4f, /* DENALI_CTL_35_DATA */ + 0x0a0a080f, /* DENALI_CTL_36_DATA */ + 0x0800ff4f, /* DENALI_CTL_37_DATA */ + 0x0203000f, /* DENALI_CTL_38_DATA */ + 0x110f1100, /* DENALI_CTL_39_DATA */ + 0x040f110f, /* DENALI_CTL_40_DATA */ + 0x14000a0a, /* DENALI_CTL_41_DATA */ + 0x03030a0a, /* DENALI_CTL_42_DATA */ + 0x00010003, /* DENALI_CTL_43_DATA */ + 0x03212121, /* DENALI_CTL_44_DATA */ + 0x00141414, /* DENALI_CTL_45_DATA */ + 0x00000000, /* DENALI_CTL_46_DATA */ + 0x03010000, /* DENALI_CTL_47_DATA */ + 0x0e3100c5, /* DENALI_CTL_48_DATA */ + 0x0e3100c5, /* DENALI_CTL_49_DATA */ + 0x0e3100c5, /* DENALI_CTL_50_DATA */ + 0x00000000, /* DENALI_CTL_51_DATA */ + 0x00080008, /* DENALI_CTL_52_DATA */ + 0x00170008, /* DENALI_CTL_53_DATA */ + 0x00170017, /* DENALI_CTL_54_DATA */ + 0x00111111, /* DENALI_CTL_55_DATA */ + 0x00000000, /* DENALI_CTL_56_DATA */ + 0x00000000, /* DENALI_CTL_57_DATA */ + 0x00000000, /* DENALI_CTL_58_DATA */ + 0x00ce0000, /* DENALI_CTL_59_DATA */ + 0x00ce00ce, /* DENALI_CTL_60_DATA */ + 0x00ce00ce, /* DENALI_CTL_61_DATA */ + 0x000000ce, /* DENALI_CTL_62_DATA */ + 0x00000000, /* DENALI_CTL_63_DATA */ + 0x00000000, /* DENALI_CTL_64_DATA */ + 0x00000000, /* DENALI_CTL_65_DATA */ + 0x00000000, /* DENALI_CTL_66_DATA */ + 0x00000000, /* DENALI_CTL_67_DATA */ + 0x00000000, /* DENALI_CTL_68_DATA */ + 0x00000301, /* DENALI_CTL_69_DATA */ + 0x00000001, /* DENALI_CTL_70_DATA */ + 0x00000000, /* DENALI_CTL_71_DATA */ + 0x00000000, /* DENALI_CTL_72_DATA */ + 0x01000000, /* DENALI_CTL_73_DATA */ + 0x80104002, /* DENALI_CTL_74_DATA */ + 0x00040003, /* DENALI_CTL_75_DATA */ + 0x00040005, /* DENALI_CTL_76_DATA */ + 0x00030000, /* DENALI_CTL_77_DATA */ + 0x00050004, /* DENALI_CTL_78_DATA */ + 0x00000004, /* DENALI_CTL_79_DATA */ + 0x00040003, /* DENALI_CTL_80_DATA */ + 0x00040005, /* DENALI_CTL_81_DATA */ + 0x38c40000, /* DENALI_CTL_82_DATA */ + 0x00001c62, /* DENALI_CTL_83_DATA */ + 0x1c6238c4, /* DENALI_CTL_84_DATA */ + 0x38c40000, /* DENALI_CTL_85_DATA */ + 0x00001c62, /* DENALI_CTL_86_DATA */ + 0x00000000, /* DENALI_CTL_87_DATA */ + 0x00000000, /* DENALI_CTL_88_DATA */ + 0x00000000, /* DENALI_CTL_89_DATA */ + 0x00000000, /* DENALI_CTL_90_DATA */ + 0x00000000, /* DENALI_CTL_91_DATA */ + 0x02020200, /* DENALI_CTL_92_DATA */ + 0x00020202, /* DENALI_CTL_93_DATA */ + 0x00030200, /* DENALI_CTL_94_DATA */ + 0x00040700, /* DENALI_CTL_95_DATA */ + 0x00000302, /* DENALI_CTL_96_DATA */ + 0x02000407, /* DENALI_CTL_97_DATA */ + 0x00000003, /* DENALI_CTL_98_DATA */ + 0x00030f04, /* DENALI_CTL_99_DATA */ + 0x00070004, /* DENALI_CTL_100_DATA */ + 0x00000000, /* DENALI_CTL_101_DATA */ + 0x00000000, /* DENALI_CTL_102_DATA */ + 0x00000000, /* DENALI_CTL_103_DATA */ + 0x00000000, /* DENALI_CTL_104_DATA */ + 0x00000000, /* DENALI_CTL_105_DATA */ + 0x00000000, /* DENALI_CTL_106_DATA */ + 0x00000000, /* DENALI_CTL_107_DATA */ + 0x00010000, /* DENALI_CTL_108_DATA */ + 0x20040020, /* DENALI_CTL_109_DATA */ + 0x00200400, /* DENALI_CTL_110_DATA */ + 0x01000400, /* DENALI_CTL_111_DATA */ + 0x00000b80, /* DENALI_CTL_112_DATA */ + 0x00000000, /* DENALI_CTL_113_DATA */ + 0x00000001, /* DENALI_CTL_114_DATA */ + 0x00000002, /* DENALI_CTL_115_DATA */ + 0x0000000e, /* DENALI_CTL_116_DATA */ + 0x00000000, /* DENALI_CTL_117_DATA */ + 0x00000000, /* DENALI_CTL_118_DATA */ + 0x00000000, /* DENALI_CTL_119_DATA */ + 0x00000000, /* DENALI_CTL_120_DATA */ + 0x00000000, /* DENALI_CTL_121_DATA */ + 0x00bb0000, /* DENALI_CTL_122_DATA */ + 0x00ea005e, /* DENALI_CTL_123_DATA */ + 0x00ea0000, /* DENALI_CTL_124_DATA */ + 0x005e00bb, /* DENALI_CTL_125_DATA */ + 0x000000ea, /* DENALI_CTL_126_DATA */ + 0x00bb00ea, /* DENALI_CTL_127_DATA */ + 0x00ea005e, /* DENALI_CTL_128_DATA */ + 0x00ea0000, /* DENALI_CTL_129_DATA */ + 0x00000000, /* DENALI_CTL_130_DATA */ + 0x00000000, /* DENALI_CTL_131_DATA */ + 0x00000000, /* DENALI_CTL_132_DATA */ + 0x00c30000, /* DENALI_CTL_133_DATA */ + 0x0000001c, /* DENALI_CTL_134_DATA */ + 0x001c00c3, /* DENALI_CTL_135_DATA */ + 0x00c30000, /* DENALI_CTL_136_DATA */ + 0x0000001c, /* DENALI_CTL_137_DATA */ + 0x00010001, /* DENALI_CTL_138_DATA */ + 0x06000001, /* DENALI_CTL_139_DATA */ + 0x00000707, /* DENALI_CTL_140_DATA */ + 0x00000000, /* DENALI_CTL_141_DATA */ + 0x00000000, /* DENALI_CTL_142_DATA */ + 0x00000000, /* DENALI_CTL_143_DATA */ + 0x00000000, /* DENALI_CTL_144_DATA */ + 0x00000000, /* DENALI_CTL_145_DATA */ + 0x00000000, /* DENALI_CTL_146_DATA */ + 0x00c30000, /* DENALI_CTL_147_DATA */ + 0x0000001c, /* DENALI_CTL_148_DATA */ + 0x001c00c3, /* DENALI_CTL_149_DATA */ + 0x00c30000, /* DENALI_CTL_150_DATA */ + 0x0000001c, /* DENALI_CTL_151_DATA */ + 0x00010001, /* DENALI_CTL_152_DATA */ + 0x06000001, /* DENALI_CTL_153_DATA */ + 0x00000707, /* DENALI_CTL_154_DATA */ + 0x00000000, /* DENALI_CTL_155_DATA */ + 0x00000000, /* DENALI_CTL_156_DATA */ + 0x00000000, /* DENALI_CTL_157_DATA */ + 0x00000000, /* DENALI_CTL_158_DATA */ + 0x00000000, /* DENALI_CTL_159_DATA */ + 0x00000000, /* DENALI_CTL_160_DATA */ + 0x01000000, /* DENALI_CTL_161_DATA */ + 0x00000000, /* DENALI_CTL_162_DATA */ + 0x00000000, /* DENALI_CTL_163_DATA */ + 0x18151100, /* DENALI_CTL_164_DATA */ + 0x0000000c, /* DENALI_CTL_165_DATA */ + 0x00000000, /* DENALI_CTL_166_DATA */ + 0x00000000, /* DENALI_CTL_167_DATA */ + 0x00000000, /* DENALI_CTL_168_DATA */ + 0x00000000, /* DENALI_CTL_169_DATA */ + 0x00000000, /* DENALI_CTL_170_DATA */ + 0x00000000, /* DENALI_CTL_171_DATA */ + 0x00000000, /* DENALI_CTL_172_DATA */ + 0x00000000, /* DENALI_CTL_173_DATA */ + 0x00000000, /* DENALI_CTL_174_DATA */ + 0x00000000, /* DENALI_CTL_175_DATA */ + 0x00000000, /* DENALI_CTL_176_DATA */ + 0x00000000, /* DENALI_CTL_177_DATA */ + 0x00000000, /* DENALI_CTL_178_DATA */ + 0x0003a603, /* DENALI_CTL_179_DATA */ + 0x00550151, /* DENALI_CTL_180_DATA */ + 0x00000000, /* DENALI_CTL_181_DATA */ + 0x015103a6, /* DENALI_CTL_182_DATA */ + 0x00000055, /* DENALI_CTL_183_DATA */ + 0x0003a600, /* DENALI_CTL_184_DATA */ + 0x00550151, /* DENALI_CTL_185_DATA */ + 0x00000000, /* DENALI_CTL_186_DATA */ + 0x002f0000, /* DENALI_CTL_187_DATA */ + 0x002f002f, /* DENALI_CTL_188_DATA */ + 0x01010100, /* DENALI_CTL_189_DATA */ + 0x01000202, /* DENALI_CTL_190_DATA */ + 0x0a000002, /* DENALI_CTL_191_DATA */ + 0x01000f0f, /* DENALI_CTL_192_DATA */ + 0x00000000, /* DENALI_CTL_193_DATA */ + 0x00000000, /* DENALI_CTL_194_DATA */ + 0x00010003, /* DENALI_CTL_195_DATA */ + 0x00000c03, /* DENALI_CTL_196_DATA */ + 0x00000100, /* DENALI_CTL_197_DATA */ + 0x00010000, /* DENALI_CTL_198_DATA */ + 0x01000000, /* DENALI_CTL_199_DATA */ + 0x00010000, /* DENALI_CTL_200_DATA */ + 0x00000001, /* DENALI_CTL_201_DATA */ + 0x00000000, /* DENALI_CTL_202_DATA */ + 0x00000000, /* DENALI_CTL_203_DATA */ + 0x00000000, /* DENALI_CTL_204_DATA */ + 0x00000000, /* DENALI_CTL_205_DATA */ + 0x00000000, /* DENALI_CTL_206_DATA */ + 0x00000000, /* DENALI_CTL_207_DATA */ + 0x00000000, /* DENALI_CTL_208_DATA */ + 0x00000000, /* DENALI_CTL_209_DATA */ + 0x00000000, /* DENALI_CTL_210_DATA */ + 0x00010000, /* DENALI_CTL_211_DATA */ + 0x04040401, /* DENALI_CTL_212_DATA */ + 0x01010808, /* DENALI_CTL_213_DATA */ + 0x04040001, /* DENALI_CTL_214_DATA */ + 0x0c0c0c04, /* DENALI_CTL_215_DATA */ + 0x08080808, /* DENALI_CTL_216_DATA */ + 0x02010103, /* DENALI_CTL_217_DATA */ + 0x02010103, /* DENALI_CTL_218_DATA */ + 0x00010103, /* DENALI_CTL_219_DATA */ + 0x00020202, /* DENALI_CTL_220_DATA */ + 0x06030600, /* DENALI_CTL_221_DATA */ + 0x00030603, /* DENALI_CTL_222_DATA */ + 0x00000000, /* DENALI_CTL_223_DATA */ + 0x00000000, /* DENALI_CTL_224_DATA */ + 0x0d000001, /* DENALI_CTL_225_DATA */ + 0x00010028, /* DENALI_CTL_226_DATA */ + 0x00010000, /* DENALI_CTL_227_DATA */ + 0x00000003, /* DENALI_CTL_228_DATA */ + 0x00000000, /* DENALI_CTL_229_DATA */ + 0x00000000, /* DENALI_CTL_230_DATA */ + 0x00000000, /* DENALI_CTL_231_DATA */ + 0x00000000, /* DENALI_CTL_232_DATA */ + 0x00000000, /* DENALI_CTL_233_DATA */ + 0x00000000, /* DENALI_CTL_234_DATA */ + 0x00000000, /* DENALI_CTL_235_DATA */ + 0x00000000, /* DENALI_CTL_236_DATA */ + 0x00010100, /* DENALI_CTL_237_DATA */ + 0x01000000, /* DENALI_CTL_238_DATA */ + 0x00000001, /* DENALI_CTL_239_DATA */ + 0x00000303, /* DENALI_CTL_240_DATA */ + 0x00000000, /* DENALI_CTL_241_DATA */ + 0x00000000, /* DENALI_CTL_242_DATA */ + 0x00000000, /* DENALI_CTL_243_DATA */ + 0x00000000, /* DENALI_CTL_244_DATA */ + 0x00000000, /* DENALI_CTL_245_DATA */ + 0x00000000, /* DENALI_CTL_246_DATA */ + 0x00000000, /* DENALI_CTL_247_DATA */ + 0x00000000, /* DENALI_CTL_248_DATA */ + 0x00000000, /* DENALI_CTL_249_DATA */ + 0x00000000, /* DENALI_CTL_250_DATA */ + 0x00000000, /* DENALI_CTL_251_DATA */ + 0x00000000, /* DENALI_CTL_252_DATA */ + 0x00000000, /* DENALI_CTL_253_DATA */ + 0x00000000, /* DENALI_CTL_254_DATA */ + 0x00000000, /* DENALI_CTL_255_DATA */ + 0x000556aa, /* DENALI_CTL_256_DATA */ + 0x000aaaaa, /* DENALI_CTL_257_DATA */ + 0x000aa955, /* DENALI_CTL_258_DATA */ + 0x00055555, /* DENALI_CTL_259_DATA */ + 0x000b3133, /* DENALI_CTL_260_DATA */ + 0x0004cd33, /* DENALI_CTL_261_DATA */ + 0x0004cecc, /* DENALI_CTL_262_DATA */ + 0x000b32cc, /* DENALI_CTL_263_DATA */ + 0x00010300, /* DENALI_CTL_264_DATA */ + 0x03000100, /* DENALI_CTL_265_DATA */ + 0x00000000, /* DENALI_CTL_266_DATA */ + 0x00000000, /* DENALI_CTL_267_DATA */ + 0x00000000, /* DENALI_CTL_268_DATA */ + 0x00000000, /* DENALI_CTL_269_DATA */ + 0x00000000, /* DENALI_CTL_270_DATA */ + 0x00000000, /* DENALI_CTL_271_DATA */ + 0x00000000, /* DENALI_CTL_272_DATA */ + 0x00000000, /* DENALI_CTL_273_DATA */ + 0x00ffff00, /* DENALI_CTL_274_DATA */ + 0x20200000, /* DENALI_CTL_275_DATA */ + 0x08000020, /* DENALI_CTL_276_DATA */ + 0x00001c62, /* DENALI_CTL_277_DATA */ + 0x00000200, /* DENALI_CTL_278_DATA */ + 0x00000200, /* DENALI_CTL_279_DATA */ + 0x00000200, /* DENALI_CTL_280_DATA */ + 0x00000200, /* DENALI_CTL_281_DATA */ + 0x00001c62, /* DENALI_CTL_282_DATA */ + 0x00011bd4, /* DENALI_CTL_283_DATA */ + 0x1c62070c, /* DENALI_CTL_284_DATA */ + 0x00000200, /* DENALI_CTL_285_DATA */ + 0x00000200, /* DENALI_CTL_286_DATA */ + 0x00000200, /* DENALI_CTL_287_DATA */ + 0x00000200, /* DENALI_CTL_288_DATA */ + 0x00001c62, /* DENALI_CTL_289_DATA */ + 0x00011bd4, /* DENALI_CTL_290_DATA */ + 0x1c62070c, /* DENALI_CTL_291_DATA */ + 0x00000200, /* DENALI_CTL_292_DATA */ + 0x00000200, /* DENALI_CTL_293_DATA */ + 0x00000200, /* DENALI_CTL_294_DATA */ + 0x00000200, /* DENALI_CTL_295_DATA */ + 0x00001c62, /* DENALI_CTL_296_DATA */ + 0x00011bd4, /* DENALI_CTL_297_DATA */ + 0x0202070c, /* DENALI_CTL_298_DATA */ + 0x03030202, /* DENALI_CTL_299_DATA */ + 0x00000018, /* DENALI_CTL_300_DATA */ + 0x00000000, /* DENALI_CTL_301_DATA */ + 0x00000000, /* DENALI_CTL_302_DATA */ + 0x00001403, /* DENALI_CTL_303_DATA */ + 0x00000000, /* DENALI_CTL_304_DATA */ + 0x00000000, /* DENALI_CTL_305_DATA */ + 0x00000000, /* DENALI_CTL_306_DATA */ + 0x00030000, /* DENALI_CTL_307_DATA */ + 0x000f0021, /* DENALI_CTL_308_DATA */ + 0x000f0021, /* DENALI_CTL_309_DATA */ + 0x000f0021, /* DENALI_CTL_310_DATA */ + 0x00000000, /* DENALI_CTL_311_DATA */ + 0x00000000, /* DENALI_CTL_312_DATA */ + 0x01000000, /* DENALI_CTL_313_DATA */ + 0x02090209, /* DENALI_CTL_314_DATA */ + 0x00050209, /* DENALI_CTL_315_DATA */ + 0x00000000, /* DENALI_CTL_316_DATA */ + 0x00000000, /* DENALI_CTL_317_DATA */ + 0x00000000, /* DENALI_CTL_318_DATA */ + 0x00000000, /* DENALI_CTL_319_DATA */ + 0x00000000, /* DENALI_CTL_320_DATA */ + 0x00000000, /* DENALI_CTL_321_DATA */ + 0x00000000, /* DENALI_CTL_322_DATA */ + 0x00000000, /* DENALI_CTL_323_DATA */ + 0x01000101, /* DENALI_CTL_324_DATA */ + 0x01010101, /* DENALI_CTL_325_DATA */ + 0x01000101, /* DENALI_CTL_326_DATA */ + 0x01000100, /* DENALI_CTL_327_DATA */ + 0x00010001, /* DENALI_CTL_328_DATA */ + 0x00010002, /* DENALI_CTL_329_DATA */ + 0x00020100, /* DENALI_CTL_330_DATA */ + 0x00000002 /* DENALI_CTL_331_DATA */ + } + }, + { + { + 0x00000700, /* DENALI_PI_00_DATA */ + 0x00000000, /* DENALI_PI_01_DATA */ + 0x000038c4, /* DENALI_PI_02_DATA */ + 0x00001c62, /* DENALI_PI_03_DATA */ + 0x000038c4, /* DENALI_PI_04_DATA */ + 0x00001c62, /* DENALI_PI_05_DATA */ + 0x000038c4, /* DENALI_PI_06_DATA */ + 0x1c621c62, /* DENALI_PI_07_DATA */ + 0x00000200, /* DENALI_PI_08_DATA */ + 0x00000200, /* DENALI_PI_09_DATA */ + 0x00000200, /* DENALI_PI_10_DATA */ + 0x00000200, /* DENALI_PI_11_DATA */ + 0x00001c62, /* DENALI_PI_12_DATA */ + 0x00000200, /* DENALI_PI_13_DATA */ + 0x00000200, /* DENALI_PI_14_DATA */ + 0x00000200, /* DENALI_PI_15_DATA */ + 0x00000200, /* DENALI_PI_16_DATA */ + 0x00001c62, /* DENALI_PI_17_DATA */ + 0x00000200, /* DENALI_PI_18_DATA */ + 0x00000200, /* DENALI_PI_19_DATA */ + 0x00000200, /* DENALI_PI_20_DATA */ + 0x00000200, /* DENALI_PI_21_DATA */ + 0x00010000, /* DENALI_PI_22_DATA */ + 0x00000007, /* DENALI_PI_23_DATA */ + 0x81000001, /* DENALI_PI_24_DATA */ + 0x0f0003f0, /* DENALI_PI_25_DATA */ + 0x3fffffff, /* DENALI_PI_26_DATA */ + 0x0f0000a0, /* DENALI_PI_27_DATA */ + 0x377ff000, /* DENALI_PI_28_DATA */ + 0x0f000020, /* DENALI_PI_29_DATA */ + 0x377ff000, /* DENALI_PI_30_DATA */ + 0x0f000030, /* DENALI_PI_31_DATA */ + 0x377ff000, /* DENALI_PI_32_DATA */ + 0x0f0000b0, /* DENALI_PI_33_DATA */ + 0x377ff000, /* DENALI_PI_34_DATA */ + 0x0f000100, /* DENALI_PI_35_DATA */ + 0x377ff000, /* DENALI_PI_36_DATA */ + 0x0f000110, /* DENALI_PI_37_DATA */ + 0x377ff000, /* DENALI_PI_38_DATA */ + 0x0f000010, /* DENALI_PI_39_DATA */ + 0x377ff000, /* DENALI_PI_40_DATA */ + 0x03000101, /* DENALI_PI_41_DATA */ + 0x04323232, /* DENALI_PI_42_DATA */ + 0x081c0008, /* DENALI_PI_43_DATA */ + 0x00081c00, /* DENALI_PI_44_DATA */ + 0x0000001c, /* DENALI_PI_45_DATA */ + 0x0e3100c5, /* DENALI_PI_46_DATA */ + 0x0e3100c5, /* DENALI_PI_47_DATA */ + 0x0e3100c5, /* DENALI_PI_48_DATA */ + 0x00000500, /* DENALI_PI_49_DATA */ + 0x00000000, /* DENALI_PI_50_DATA */ + 0x00000000, /* DENALI_PI_51_DATA */ + 0x00000000, /* DENALI_PI_52_DATA */ + 0x00000000, /* DENALI_PI_53_DATA */ + 0x00000000, /* DENALI_PI_54_DATA */ + 0x00000000, /* DENALI_PI_55_DATA */ + 0x00000000, /* DENALI_PI_56_DATA */ + 0x00000000, /* DENALI_PI_57_DATA */ + 0x04040000, /* DENALI_PI_58_DATA */ + 0x0d000004, /* DENALI_PI_59_DATA */ + 0x00000128, /* DENALI_PI_60_DATA */ + 0x00000000, /* DENALI_PI_61_DATA */ + 0x00030003, /* DENALI_PI_62_DATA */ + 0x00000018, /* DENALI_PI_63_DATA */ + 0x00000000, /* DENALI_PI_64_DATA */ + 0x00000000, /* DENALI_PI_65_DATA */ + 0x04060002, /* DENALI_PI_66_DATA */ + 0x04010401, /* DENALI_PI_67_DATA */ + 0x01080801, /* DENALI_PI_68_DATA */ + 0x04020201, /* DENALI_PI_69_DATA */ + 0x01080804, /* DENALI_PI_70_DATA */ + 0x00000000, /* DENALI_PI_71_DATA */ + 0x04040000, /* DENALI_PI_72_DATA */ + 0x0c0c0c04, /* DENALI_PI_73_DATA */ + 0x00000000, /* DENALI_PI_74_DATA */ + 0x00000000, /* DENALI_PI_75_DATA */ + 0x00000000, /* DENALI_PI_76_DATA */ + 0x00030300, /* DENALI_PI_77_DATA */ + 0x00000014, /* DENALI_PI_78_DATA */ + 0x00000000, /* DENALI_PI_79_DATA */ + 0x01010300, /* DENALI_PI_80_DATA */ + 0x00000000, /* DENALI_PI_81_DATA */ + 0x00000000, /* DENALI_PI_82_DATA */ + 0x01000000, /* DENALI_PI_83_DATA */ + 0x00000101, /* DENALI_PI_84_DATA */ + 0x55555a5a, /* DENALI_PI_85_DATA */ + 0x55555a5a, /* DENALI_PI_86_DATA */ + 0x55555a5a, /* DENALI_PI_87_DATA */ + 0x55555a5a, /* DENALI_PI_88_DATA */ + 0x0c0c0001, /* DENALI_PI_89_DATA */ + 0x0707000c, /* DENALI_PI_90_DATA */ + 0x02020007, /* DENALI_PI_91_DATA */ + 0x00000102, /* DENALI_PI_92_DATA */ + 0x00030000, /* DENALI_PI_93_DATA */ + 0x17030000, /* DENALI_PI_94_DATA */ + 0x000f0021, /* DENALI_PI_95_DATA */ + 0x000f0021, /* DENALI_PI_96_DATA */ + 0x000f0021, /* DENALI_PI_97_DATA */ + 0x00000000, /* DENALI_PI_98_DATA */ + 0x00000000, /* DENALI_PI_99_DATA */ + 0x00000100, /* DENALI_PI_100_DATA */ + 0x140a0000, /* DENALI_PI_101_DATA */ + 0x000a030a, /* DENALI_PI_102_DATA */ + 0x03000a03, /* DENALI_PI_103_DATA */ + 0x010a000a, /* DENALI_PI_104_DATA */ + 0x00000100, /* DENALI_PI_105_DATA */ + 0x01000000, /* DENALI_PI_106_DATA */ + 0x00000000, /* DENALI_PI_107_DATA */ + 0x00000100, /* DENALI_PI_108_DATA */ + 0x1e1a0000, /* DENALI_PI_109_DATA */ + 0x10010204, /* DENALI_PI_110_DATA */ + 0x07070705, /* DENALI_PI_111_DATA */ + 0x20000202, /* DENALI_PI_112_DATA */ + 0x00201000, /* DENALI_PI_113_DATA */ + 0x00201000, /* DENALI_PI_114_DATA */ + 0x04041000, /* DENALI_PI_115_DATA */ + 0x12120100, /* DENALI_PI_116_DATA */ + 0x00010112, /* DENALI_PI_117_DATA */ + 0x004b004a, /* DENALI_PI_118_DATA */ + 0x1a030000, /* DENALI_PI_119_DATA */ + 0x0102041e, /* DENALI_PI_120_DATA */ + 0x34000000, /* DENALI_PI_121_DATA */ + 0x00000000, /* DENALI_PI_122_DATA */ + 0x00000000, /* DENALI_PI_123_DATA */ + 0x00000000, /* DENALI_PI_124_DATA */ + 0x0000c300, /* DENALI_PI_125_DATA */ + 0x0001001c, /* DENALI_PI_126_DATA */ + 0x004d4d07, /* DENALI_PI_127_DATA */ + 0x001c00c3, /* DENALI_PI_128_DATA */ + 0x4d070001, /* DENALI_PI_129_DATA */ + 0x0000c34d, /* DENALI_PI_130_DATA */ + 0x0001001c, /* DENALI_PI_131_DATA */ + 0x004d4d07, /* DENALI_PI_132_DATA */ + 0x001c00c3, /* DENALI_PI_133_DATA */ + 0x4d070001, /* DENALI_PI_134_DATA */ + 0x0000c34d, /* DENALI_PI_135_DATA */ + 0x0001001c, /* DENALI_PI_136_DATA */ + 0x004d4d07, /* DENALI_PI_137_DATA */ + 0x001c00c3, /* DENALI_PI_138_DATA */ + 0x4d070001, /* DENALI_PI_139_DATA */ + 0x00c3004d, /* DENALI_PI_140_DATA */ + 0x0001001c, /* DENALI_PI_141_DATA */ + 0x004d4d07, /* DENALI_PI_142_DATA */ + 0x001c00c3, /* DENALI_PI_143_DATA */ + 0x4d070001, /* DENALI_PI_144_DATA */ + 0x0000c34d, /* DENALI_PI_145_DATA */ + 0x0001001c, /* DENALI_PI_146_DATA */ + 0x004d4d07, /* DENALI_PI_147_DATA */ + 0x001c00c3, /* DENALI_PI_148_DATA */ + 0x4d070001, /* DENALI_PI_149_DATA */ + 0x0000c34d, /* DENALI_PI_150_DATA */ + 0x0001001c, /* DENALI_PI_151_DATA */ + 0x004d4d07, /* DENALI_PI_152_DATA */ + 0x001c00c3, /* DENALI_PI_153_DATA */ + 0x4d070001, /* DENALI_PI_154_DATA */ + 0x0100004d, /* DENALI_PI_155_DATA */ + 0x00ea00ea, /* DENALI_PI_156_DATA */ + 0x080400ea, /* DENALI_PI_157_DATA */ + 0x0f081114, /* DENALI_PI_158_DATA */ + 0x2800fcc1, /* DENALI_PI_159_DATA */ + 0x0a0e2006, /* DENALI_PI_160_DATA */ + 0x1114080a, /* DENALI_PI_161_DATA */ + 0x00000f08, /* DENALI_PI_162_DATA */ + 0x2800fcc1, /* DENALI_PI_163_DATA */ + 0x0a0e2006, /* DENALI_PI_164_DATA */ + 0x1114080a, /* DENALI_PI_165_DATA */ + 0x00000f08, /* DENALI_PI_166_DATA */ + 0x2800fcc1, /* DENALI_PI_167_DATA */ + 0x0a0e2006, /* DENALI_PI_168_DATA */ + 0x0200020a, /* DENALI_PI_169_DATA */ + 0x02000200, /* DENALI_PI_170_DATA */ + 0x02000200, /* DENALI_PI_171_DATA */ + 0x02000200, /* DENALI_PI_172_DATA */ + 0x02000200, /* DENALI_PI_173_DATA */ + 0x00000000, /* DENALI_PI_174_DATA */ + 0x00000000, /* DENALI_PI_175_DATA */ + 0x00000000, /* DENALI_PI_176_DATA */ + 0x00000000, /* DENALI_PI_177_DATA */ + 0x00000000, /* DENALI_PI_178_DATA */ + 0x00000000, /* DENALI_PI_179_DATA */ + 0x00000000, /* DENALI_PI_180_DATA */ + 0x00000000, /* DENALI_PI_181_DATA */ + 0x00000000, /* DENALI_PI_182_DATA */ + 0x00000000, /* DENALI_PI_183_DATA */ + 0x00000000, /* DENALI_PI_184_DATA */ + 0x00000000, /* DENALI_PI_185_DATA */ + 0x01000300, /* DENALI_PI_186_DATA */ + 0x001c6200, /* DENALI_PI_187_DATA */ + 0x00011bd4, /* DENALI_PI_188_DATA */ + 0x00001c62, /* DENALI_PI_189_DATA */ + 0x00011bd4, /* DENALI_PI_190_DATA */ + 0x00001c62, /* DENALI_PI_191_DATA */ + 0x00011bd4, /* DENALI_PI_192_DATA */ + 0x08000000, /* DENALI_PI_193_DATA */ + 0x00000100, /* DENALI_PI_194_DATA */ + 0x00000000, /* DENALI_PI_195_DATA */ + 0x00000000, /* DENALI_PI_196_DATA */ + 0x00000000, /* DENALI_PI_197_DATA */ + 0x00000000, /* DENALI_PI_198_DATA */ + 0x00000002 /* DENALI_PI_199_DATA */ + } + }, + { + { + 0x76543210, /* DENALI_PHY_00_DATA */ + 0x0004c008, /* DENALI_PHY_01_DATA */ + 0x000001a2, /* DENALI_PHY_02_DATA */ + 0x00000000, /* DENALI_PHY_03_DATA */ + 0x00000000, /* DENALI_PHY_04_DATA */ + 0x00010000, /* DENALI_PHY_05_DATA */ + 0x01665555, /* DENALI_PHY_06_DATA */ + 0x00665555, /* DENALI_PHY_07_DATA */ + 0x00010f00, /* DENALI_PHY_08_DATA */ + 0x06010200, /* DENALI_PHY_09_DATA */ + 0x00000003, /* DENALI_PHY_10_DATA */ + 0x001700c0, /* DENALI_PHY_11_DATA */ + 0x00cc0101, /* DENALI_PHY_12_DATA */ + 0x00030066, /* DENALI_PHY_13_DATA */ + 0x00000000, /* DENALI_PHY_14_DATA */ + 0x00000000, /* DENALI_PHY_15_DATA */ + 0x00000000, /* DENALI_PHY_16_DATA */ + 0x00000000, /* DENALI_PHY_17_DATA */ + 0x00000000, /* DENALI_PHY_18_DATA */ + 0x00000000, /* DENALI_PHY_19_DATA */ + 0x00000000, /* DENALI_PHY_20_DATA */ + 0x00000000, /* DENALI_PHY_21_DATA */ + 0x04080000, /* DENALI_PHY_22_DATA */ + 0x04080400, /* DENALI_PHY_23_DATA */ + 0x08000000, /* DENALI_PHY_24_DATA */ + 0x0c00c007, /* DENALI_PHY_25_DATA */ + 0x00000100, /* DENALI_PHY_26_DATA */ + 0x00000100, /* DENALI_PHY_27_DATA */ + 0x55555555, /* DENALI_PHY_28_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_29_DATA */ + 0x55555555, /* DENALI_PHY_30_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_31_DATA */ + 0x00005555, /* DENALI_PHY_32_DATA */ + 0x00000000, /* DENALI_PHY_33_DATA */ + 0x00000000, /* DENALI_PHY_34_DATA */ + 0x00000000, /* DENALI_PHY_35_DATA */ + 0x00000000, /* DENALI_PHY_36_DATA */ + 0x00000000, /* DENALI_PHY_37_DATA */ + 0x00000000, /* DENALI_PHY_38_DATA */ + 0x00000000, /* DENALI_PHY_39_DATA */ + 0x00000000, /* DENALI_PHY_40_DATA */ + 0x00000000, /* DENALI_PHY_41_DATA */ + 0x00000000, /* DENALI_PHY_42_DATA */ + 0x00000000, /* DENALI_PHY_43_DATA */ + 0x00000000, /* DENALI_PHY_44_DATA */ + 0x00000000, /* DENALI_PHY_45_DATA */ + 0x00000000, /* DENALI_PHY_46_DATA */ + 0x00000000, /* DENALI_PHY_47_DATA */ + 0x00000000, /* DENALI_PHY_48_DATA */ + 0x00000000, /* DENALI_PHY_49_DATA */ + 0x00000000, /* DENALI_PHY_50_DATA */ + 0x00000000, /* DENALI_PHY_51_DATA */ + 0x00200000, /* DENALI_PHY_52_DATA */ + 0x00000000, /* DENALI_PHY_53_DATA */ + 0x00000000, /* DENALI_PHY_54_DATA */ + 0x00000000, /* DENALI_PHY_55_DATA */ + 0x00000000, /* DENALI_PHY_56_DATA */ + 0x00000000, /* DENALI_PHY_57_DATA */ + 0x00000000, /* DENALI_PHY_58_DATA */ + 0x02600260, /* DENALI_PHY_59_DATA */ + 0x02600260, /* DENALI_PHY_60_DATA */ + 0x02600260, /* DENALI_PHY_61_DATA */ + 0x02600260, /* DENALI_PHY_62_DATA */ + 0x00000260, /* DENALI_PHY_63_DATA */ + 0x00000000, /* DENALI_PHY_64_DATA */ + 0x00000000, /* DENALI_PHY_65_DATA */ + 0x00000000, /* DENALI_PHY_66_DATA */ + 0x00000000, /* DENALI_PHY_67_DATA */ + 0x00800000, /* DENALI_PHY_68_DATA */ + 0x00800080, /* DENALI_PHY_69_DATA */ + 0x00800080, /* DENALI_PHY_70_DATA */ + 0x00800080, /* DENALI_PHY_71_DATA */ + 0x00800080, /* DENALI_PHY_72_DATA */ + 0x00800080, /* DENALI_PHY_73_DATA */ + 0x00800080, /* DENALI_PHY_74_DATA */ + 0x00800080, /* DENALI_PHY_75_DATA */ + 0x00800080, /* DENALI_PHY_76_DATA */ + 0x01a20080, /* DENALI_PHY_77_DATA */ + 0x01900003, /* DENALI_PHY_78_DATA */ + 0x00000000, /* DENALI_PHY_79_DATA */ + 0x00030000, /* DENALI_PHY_80_DATA */ + 0x00000200, /* DENALI_PHY_81_DATA */ + 0x00000000, /* DENALI_PHY_82_DATA */ + 0x51315152, /* DENALI_PHY_83_DATA */ + 0xc0013150, /* DENALI_PHY_84_DATA */ + 0x020000c0, /* DENALI_PHY_85_DATA */ + 0x00100001, /* DENALI_PHY_86_DATA */ + 0x0c064208, /* DENALI_PHY_87_DATA */ + 0x000f0c18, /* DENALI_PHY_88_DATA */ + 0x01000140, /* DENALI_PHY_89_DATA */ + 0x00000c20, /* DENALI_PHY_90_DATA */ + 0x00000000, /* DENALI_PHY_91_DATA */ + 0x00000000, /* DENALI_PHY_92_DATA */ + 0x00000000, /* DENALI_PHY_93_DATA */ + 0x00000000, /* DENALI_PHY_94_DATA */ + 0x00000000, /* DENALI_PHY_95_DATA */ + 0x00000000, /* DENALI_PHY_96_DATA */ + 0x00000000, /* DENALI_PHY_97_DATA */ + 0x00000000, /* DENALI_PHY_98_DATA */ + 0x00000000, /* DENALI_PHY_99_DATA */ + 0x00000000, /* DENALI_PHY_100_DATA */ + 0x00000000, /* DENALI_PHY_101_DATA */ + 0x00000000, /* DENALI_PHY_102_DATA */ + 0x00000000, /* DENALI_PHY_103_DATA */ + 0x00000000, /* DENALI_PHY_104_DATA */ + 0x00000000, /* DENALI_PHY_105_DATA */ + 0x00000000, /* DENALI_PHY_106_DATA */ + 0x00000000, /* DENALI_PHY_107_DATA */ + 0x00000000, /* DENALI_PHY_108_DATA */ + 0x00000000, /* DENALI_PHY_109_DATA */ + 0x00000000, /* DENALI_PHY_110_DATA */ + 0x00000000, /* DENALI_PHY_111_DATA */ + 0x00000000, /* DENALI_PHY_112_DATA */ + 0x00000000, /* DENALI_PHY_113_DATA */ + 0x00000000, /* DENALI_PHY_114_DATA */ + 0x00000000, /* DENALI_PHY_115_DATA */ + 0x00000000, /* DENALI_PHY_116_DATA */ + 0x00000000, /* DENALI_PHY_117_DATA */ + 0x00000000, /* DENALI_PHY_118_DATA */ + 0x00000000, /* DENALI_PHY_119_DATA */ + 0x00000000, /* DENALI_PHY_120_DATA */ + 0x00000000, /* DENALI_PHY_121_DATA */ + 0x00000000, /* DENALI_PHY_122_DATA */ + 0x00000000, /* DENALI_PHY_123_DATA */ + 0x00000000, /* DENALI_PHY_124_DATA */ + 0x00000000, /* DENALI_PHY_125_DATA */ + 0x00000000, /* DENALI_PHY_126_DATA */ + 0x00000000, /* DENALI_PHY_127_DATA */ + 0x76543210, /* DENALI_PHY_128_DATA */ + 0x0004c008, /* DENALI_PHY_129_DATA */ + 0x000001a2, /* DENALI_PHY_130_DATA */ + 0x00000000, /* DENALI_PHY_131_DATA */ + 0x00000000, /* DENALI_PHY_132_DATA */ + 0x00010000, /* DENALI_PHY_133_DATA */ + 0x01665555, /* DENALI_PHY_134_DATA */ + 0x00665555, /* DENALI_PHY_135_DATA */ + 0x00010f00, /* DENALI_PHY_136_DATA */ + 0x06010200, /* DENALI_PHY_137_DATA */ + 0x00000003, /* DENALI_PHY_138_DATA */ + 0x001700c0, /* DENALI_PHY_139_DATA */ + 0x00cc0101, /* DENALI_PHY_140_DATA */ + 0x00030066, /* DENALI_PHY_141_DATA */ + 0x00000000, /* DENALI_PHY_142_DATA */ + 0x00000000, /* DENALI_PHY_143_DATA */ + 0x00000000, /* DENALI_PHY_144_DATA */ + 0x00000000, /* DENALI_PHY_145_DATA */ + 0x00000000, /* DENALI_PHY_146_DATA */ + 0x00000000, /* DENALI_PHY_147_DATA */ + 0x00000000, /* DENALI_PHY_148_DATA */ + 0x00000000, /* DENALI_PHY_149_DATA */ + 0x04080000, /* DENALI_PHY_150_DATA */ + 0x04080400, /* DENALI_PHY_151_DATA */ + 0x08000000, /* DENALI_PHY_152_DATA */ + 0x0c00c007, /* DENALI_PHY_153_DATA */ + 0x00000100, /* DENALI_PHY_154_DATA */ + 0x00000100, /* DENALI_PHY_155_DATA */ + 0x55555555, /* DENALI_PHY_156_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_157_DATA */ + 0x55555555, /* DENALI_PHY_158_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_159_DATA */ + 0x00005555, /* DENALI_PHY_160_DATA */ + 0x00000000, /* DENALI_PHY_161_DATA */ + 0x00000000, /* DENALI_PHY_162_DATA */ + 0x00000000, /* DENALI_PHY_163_DATA */ + 0x00000000, /* DENALI_PHY_164_DATA */ + 0x00000000, /* DENALI_PHY_165_DATA */ + 0x00000000, /* DENALI_PHY_166_DATA */ + 0x00000000, /* DENALI_PHY_167_DATA */ + 0x00000000, /* DENALI_PHY_168_DATA */ + 0x00000000, /* DENALI_PHY_169_DATA */ + 0x00000000, /* DENALI_PHY_170_DATA */ + 0x00000000, /* DENALI_PHY_171_DATA */ + 0x00000000, /* DENALI_PHY_172_DATA */ + 0x00000000, /* DENALI_PHY_173_DATA */ + 0x00000000, /* DENALI_PHY_174_DATA */ + 0x00000000, /* DENALI_PHY_175_DATA */ + 0x00000000, /* DENALI_PHY_176_DATA */ + 0x00000000, /* DENALI_PHY_177_DATA */ + 0x00000000, /* DENALI_PHY_178_DATA */ + 0x00000000, /* DENALI_PHY_179_DATA */ + 0x00200000, /* DENALI_PHY_180_DATA */ + 0x00000000, /* DENALI_PHY_181_DATA */ + 0x00000000, /* DENALI_PHY_182_DATA */ + 0x00000000, /* DENALI_PHY_183_DATA */ + 0x00000000, /* DENALI_PHY_184_DATA */ + 0x00000000, /* DENALI_PHY_185_DATA */ + 0x00000000, /* DENALI_PHY_186_DATA */ + 0x02600260, /* DENALI_PHY_187_DATA */ + 0x02600260, /* DENALI_PHY_188_DATA */ + 0x02600260, /* DENALI_PHY_189_DATA */ + 0x02600260, /* DENALI_PHY_190_DATA */ + 0x00000260, /* DENALI_PHY_191_DATA */ + 0x00000000, /* DENALI_PHY_192_DATA */ + 0x00000000, /* DENALI_PHY_193_DATA */ + 0x00000000, /* DENALI_PHY_194_DATA */ + 0x00000000, /* DENALI_PHY_195_DATA */ + 0x00800000, /* DENALI_PHY_196_DATA */ + 0x00800080, /* DENALI_PHY_197_DATA */ + 0x00800080, /* DENALI_PHY_198_DATA */ + 0x00800080, /* DENALI_PHY_199_DATA */ + 0x00800080, /* DENALI_PHY_200_DATA */ + 0x00800080, /* DENALI_PHY_201_DATA */ + 0x00800080, /* DENALI_PHY_202_DATA */ + 0x00800080, /* DENALI_PHY_203_DATA */ + 0x00800080, /* DENALI_PHY_204_DATA */ + 0x01a20080, /* DENALI_PHY_205_DATA */ + 0x01900003, /* DENALI_PHY_206_DATA */ + 0x00000000, /* DENALI_PHY_207_DATA */ + 0x00030000, /* DENALI_PHY_208_DATA */ + 0x00000200, /* DENALI_PHY_209_DATA */ + 0x00000000, /* DENALI_PHY_210_DATA */ + 0x51315152, /* DENALI_PHY_211_DATA */ + 0xc0013150, /* DENALI_PHY_212_DATA */ + 0x020000c0, /* DENALI_PHY_213_DATA */ + 0x00100001, /* DENALI_PHY_214_DATA */ + 0x0c064208, /* DENALI_PHY_215_DATA */ + 0x000f0c18, /* DENALI_PHY_216_DATA */ + 0x01000140, /* DENALI_PHY_217_DATA */ + 0x00000c20, /* DENALI_PHY_218_DATA */ + 0x00000000, /* DENALI_PHY_219_DATA */ + 0x00000000, /* DENALI_PHY_220_DATA */ + 0x00000000, /* DENALI_PHY_221_DATA */ + 0x00000000, /* DENALI_PHY_222_DATA */ + 0x00000000, /* DENALI_PHY_223_DATA */ + 0x00000000, /* DENALI_PHY_224_DATA */ + 0x00000000, /* DENALI_PHY_225_DATA */ + 0x00000000, /* DENALI_PHY_226_DATA */ + 0x00000000, /* DENALI_PHY_227_DATA */ + 0x00000000, /* DENALI_PHY_228_DATA */ + 0x00000000, /* DENALI_PHY_229_DATA */ + 0x00000000, /* DENALI_PHY_230_DATA */ + 0x00000000, /* DENALI_PHY_231_DATA */ + 0x00000000, /* DENALI_PHY_232_DATA */ + 0x00000000, /* DENALI_PHY_233_DATA */ + 0x00000000, /* DENALI_PHY_234_DATA */ + 0x00000000, /* DENALI_PHY_235_DATA */ + 0x00000000, /* DENALI_PHY_236_DATA */ + 0x00000000, /* DENALI_PHY_237_DATA */ + 0x00000000, /* DENALI_PHY_238_DATA */ + 0x00000000, /* DENALI_PHY_239_DATA */ + 0x00000000, /* DENALI_PHY_240_DATA */ + 0x00000000, /* DENALI_PHY_241_DATA */ + 0x00000000, /* DENALI_PHY_242_DATA */ + 0x00000000, /* DENALI_PHY_243_DATA */ + 0x00000000, /* DENALI_PHY_244_DATA */ + 0x00000000, /* DENALI_PHY_245_DATA */ + 0x00000000, /* DENALI_PHY_246_DATA */ + 0x00000000, /* DENALI_PHY_247_DATA */ + 0x00000000, /* DENALI_PHY_248_DATA */ + 0x00000000, /* DENALI_PHY_249_DATA */ + 0x00000000, /* DENALI_PHY_250_DATA */ + 0x00000000, /* DENALI_PHY_251_DATA */ + 0x00000000, /* DENALI_PHY_252_DATA */ + 0x00000000, /* DENALI_PHY_253_DATA */ + 0x00000000, /* DENALI_PHY_254_DATA */ + 0x00000000, /* DENALI_PHY_255_DATA */ + 0x76543210, /* DENALI_PHY_256_DATA */ + 0x0004c008, /* DENALI_PHY_257_DATA */ + 0x000001a2, /* DENALI_PHY_258_DATA */ + 0x00000000, /* DENALI_PHY_259_DATA */ + 0x00000000, /* DENALI_PHY_260_DATA */ + 0x00010000, /* DENALI_PHY_261_DATA */ + 0x01665555, /* DENALI_PHY_262_DATA */ + 0x00665555, /* DENALI_PHY_263_DATA */ + 0x00010f00, /* DENALI_PHY_264_DATA */ + 0x06010200, /* DENALI_PHY_265_DATA */ + 0x00000003, /* DENALI_PHY_266_DATA */ + 0x001700c0, /* DENALI_PHY_267_DATA */ + 0x00cc0101, /* DENALI_PHY_268_DATA */ + 0x00030066, /* DENALI_PHY_269_DATA */ + 0x00000000, /* DENALI_PHY_270_DATA */ + 0x00000000, /* DENALI_PHY_271_DATA */ + 0x00000000, /* DENALI_PHY_272_DATA */ + 0x00000000, /* DENALI_PHY_273_DATA */ + 0x00000000, /* DENALI_PHY_274_DATA */ + 0x00000000, /* DENALI_PHY_275_DATA */ + 0x00000000, /* DENALI_PHY_276_DATA */ + 0x00000000, /* DENALI_PHY_277_DATA */ + 0x04080000, /* DENALI_PHY_278_DATA */ + 0x04080400, /* DENALI_PHY_279_DATA */ + 0x08000000, /* DENALI_PHY_280_DATA */ + 0x0c00c007, /* DENALI_PHY_281_DATA */ + 0x00000100, /* DENALI_PHY_282_DATA */ + 0x00000100, /* DENALI_PHY_283_DATA */ + 0x55555555, /* DENALI_PHY_284_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_285_DATA */ + 0x55555555, /* DENALI_PHY_286_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_287_DATA */ + 0x00005555, /* DENALI_PHY_288_DATA */ + 0x00000000, /* DENALI_PHY_289_DATA */ + 0x00000000, /* DENALI_PHY_290_DATA */ + 0x00000000, /* DENALI_PHY_291_DATA */ + 0x00000000, /* DENALI_PHY_292_DATA */ + 0x00000000, /* DENALI_PHY_293_DATA */ + 0x00000000, /* DENALI_PHY_294_DATA */ + 0x00000000, /* DENALI_PHY_295_DATA */ + 0x00000000, /* DENALI_PHY_296_DATA */ + 0x00000000, /* DENALI_PHY_297_DATA */ + 0x00000000, /* DENALI_PHY_298_DATA */ + 0x00000000, /* DENALI_PHY_299_DATA */ + 0x00000000, /* DENALI_PHY_300_DATA */ + 0x00000000, /* DENALI_PHY_301_DATA */ + 0x00000000, /* DENALI_PHY_302_DATA */ + 0x00000000, /* DENALI_PHY_303_DATA */ + 0x00000000, /* DENALI_PHY_304_DATA */ + 0x00000000, /* DENALI_PHY_305_DATA */ + 0x00000000, /* DENALI_PHY_306_DATA */ + 0x00000000, /* DENALI_PHY_307_DATA */ + 0x00200000, /* DENALI_PHY_308_DATA */ + 0x00000000, /* DENALI_PHY_309_DATA */ + 0x00000000, /* DENALI_PHY_310_DATA */ + 0x00000000, /* DENALI_PHY_311_DATA */ + 0x00000000, /* DENALI_PHY_312_DATA */ + 0x00000000, /* DENALI_PHY_313_DATA */ + 0x00000000, /* DENALI_PHY_314_DATA */ + 0x02600260, /* DENALI_PHY_315_DATA */ + 0x02600260, /* DENALI_PHY_316_DATA */ + 0x02600260, /* DENALI_PHY_317_DATA */ + 0x02600260, /* DENALI_PHY_318_DATA */ + 0x00000260, /* DENALI_PHY_319_DATA */ + 0x00000000, /* DENALI_PHY_320_DATA */ + 0x00000000, /* DENALI_PHY_321_DATA */ + 0x00000000, /* DENALI_PHY_322_DATA */ + 0x00000000, /* DENALI_PHY_323_DATA */ + 0x00800000, /* DENALI_PHY_324_DATA */ + 0x00800080, /* DENALI_PHY_325_DATA */ + 0x00800080, /* DENALI_PHY_326_DATA */ + 0x00800080, /* DENALI_PHY_327_DATA */ + 0x00800080, /* DENALI_PHY_328_DATA */ + 0x00800080, /* DENALI_PHY_329_DATA */ + 0x00800080, /* DENALI_PHY_330_DATA */ + 0x00800080, /* DENALI_PHY_331_DATA */ + 0x00800080, /* DENALI_PHY_332_DATA */ + 0x01a20080, /* DENALI_PHY_333_DATA */ + 0x01900003, /* DENALI_PHY_334_DATA */ + 0x00000000, /* DENALI_PHY_335_DATA */ + 0x00030000, /* DENALI_PHY_336_DATA */ + 0x00000200, /* DENALI_PHY_337_DATA */ + 0x00000000, /* DENALI_PHY_338_DATA */ + 0x51315152, /* DENALI_PHY_339_DATA */ + 0xc0013150, /* DENALI_PHY_340_DATA */ + 0x020000c0, /* DENALI_PHY_341_DATA */ + 0x00100001, /* DENALI_PHY_342_DATA */ + 0x0c064208, /* DENALI_PHY_343_DATA */ + 0x000f0c18, /* DENALI_PHY_344_DATA */ + 0x01000140, /* DENALI_PHY_345_DATA */ + 0x00000c20, /* DENALI_PHY_346_DATA */ + 0x00000000, /* DENALI_PHY_347_DATA */ + 0x00000000, /* DENALI_PHY_348_DATA */ + 0x00000000, /* DENALI_PHY_349_DATA */ + 0x00000000, /* DENALI_PHY_350_DATA */ + 0x00000000, /* DENALI_PHY_351_DATA */ + 0x00000000, /* DENALI_PHY_352_DATA */ + 0x00000000, /* DENALI_PHY_353_DATA */ + 0x00000000, /* DENALI_PHY_354_DATA */ + 0x00000000, /* DENALI_PHY_355_DATA */ + 0x00000000, /* DENALI_PHY_356_DATA */ + 0x00000000, /* DENALI_PHY_357_DATA */ + 0x00000000, /* DENALI_PHY_358_DATA */ + 0x00000000, /* DENALI_PHY_359_DATA */ + 0x00000000, /* DENALI_PHY_360_DATA */ + 0x00000000, /* DENALI_PHY_361_DATA */ + 0x00000000, /* DENALI_PHY_362_DATA */ + 0x00000000, /* DENALI_PHY_363_DATA */ + 0x00000000, /* DENALI_PHY_364_DATA */ + 0x00000000, /* DENALI_PHY_365_DATA */ + 0x00000000, /* DENALI_PHY_366_DATA */ + 0x00000000, /* DENALI_PHY_367_DATA */ + 0x00000000, /* DENALI_PHY_368_DATA */ + 0x00000000, /* DENALI_PHY_369_DATA */ + 0x00000000, /* DENALI_PHY_370_DATA */ + 0x00000000, /* DENALI_PHY_371_DATA */ + 0x00000000, /* DENALI_PHY_372_DATA */ + 0x00000000, /* DENALI_PHY_373_DATA */ + 0x00000000, /* DENALI_PHY_374_DATA */ + 0x00000000, /* DENALI_PHY_375_DATA */ + 0x00000000, /* DENALI_PHY_376_DATA */ + 0x00000000, /* DENALI_PHY_377_DATA */ + 0x00000000, /* DENALI_PHY_378_DATA */ + 0x00000000, /* DENALI_PHY_379_DATA */ + 0x00000000, /* DENALI_PHY_380_DATA */ + 0x00000000, /* DENALI_PHY_381_DATA */ + 0x00000000, /* DENALI_PHY_382_DATA */ + 0x00000000, /* DENALI_PHY_383_DATA */ + 0x76543210, /* DENALI_PHY_384_DATA */ + 0x0004c008, /* DENALI_PHY_385_DATA */ + 0x000001a2, /* DENALI_PHY_386_DATA */ + 0x00000000, /* DENALI_PHY_387_DATA */ + 0x00000000, /* DENALI_PHY_388_DATA */ + 0x00010000, /* DENALI_PHY_389_DATA */ + 0x01665555, /* DENALI_PHY_390_DATA */ + 0x00665555, /* DENALI_PHY_391_DATA */ + 0x00010f00, /* DENALI_PHY_392_DATA */ + 0x06010200, /* DENALI_PHY_393_DATA */ + 0x00000003, /* DENALI_PHY_394_DATA */ + 0x001700c0, /* DENALI_PHY_395_DATA */ + 0x00cc0101, /* DENALI_PHY_396_DATA */ + 0x00030066, /* DENALI_PHY_397_DATA */ + 0x00000000, /* DENALI_PHY_398_DATA */ + 0x00000000, /* DENALI_PHY_399_DATA */ + 0x00000000, /* DENALI_PHY_400_DATA */ + 0x00000000, /* DENALI_PHY_401_DATA */ + 0x00000000, /* DENALI_PHY_402_DATA */ + 0x00000000, /* DENALI_PHY_403_DATA */ + 0x00000000, /* DENALI_PHY_404_DATA */ + 0x00000000, /* DENALI_PHY_405_DATA */ + 0x04080000, /* DENALI_PHY_406_DATA */ + 0x04080400, /* DENALI_PHY_407_DATA */ + 0x08000000, /* DENALI_PHY_408_DATA */ + 0x0c00c007, /* DENALI_PHY_409_DATA */ + 0x00000100, /* DENALI_PHY_410_DATA */ + 0x00000100, /* DENALI_PHY_411_DATA */ + 0x55555555, /* DENALI_PHY_412_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_413_DATA */ + 0x55555555, /* DENALI_PHY_414_DATA */ + 0xaaaaaaaa, /* DENALI_PHY_415_DATA */ + 0x00005555, /* DENALI_PHY_416_DATA */ + 0x00000000, /* DENALI_PHY_417_DATA */ + 0x00000000, /* DENALI_PHY_418_DATA */ + 0x00000000, /* DENALI_PHY_419_DATA */ + 0x00000000, /* DENALI_PHY_420_DATA */ + 0x00000000, /* DENALI_PHY_421_DATA */ + 0x00000000, /* DENALI_PHY_422_DATA */ + 0x00000000, /* DENALI_PHY_423_DATA */ + 0x00000000, /* DENALI_PHY_424_DATA */ + 0x00000000, /* DENALI_PHY_425_DATA */ + 0x00000000, /* DENALI_PHY_426_DATA */ + 0x00000000, /* DENALI_PHY_427_DATA */ + 0x00000000, /* DENALI_PHY_428_DATA */ + 0x00000000, /* DENALI_PHY_429_DATA */ + 0x00000000, /* DENALI_PHY_430_DATA */ + 0x00000000, /* DENALI_PHY_431_DATA */ + 0x00000000, /* DENALI_PHY_432_DATA */ + 0x00000000, /* DENALI_PHY_433_DATA */ + 0x00000000, /* DENALI_PHY_434_DATA */ + 0x00000000, /* DENALI_PHY_435_DATA */ + 0x00200000, /* DENALI_PHY_436_DATA */ + 0x00000000, /* DENALI_PHY_437_DATA */ + 0x00000000, /* DENALI_PHY_438_DATA */ + 0x00000000, /* DENALI_PHY_439_DATA */ + 0x00000000, /* DENALI_PHY_440_DATA */ + 0x00000000, /* DENALI_PHY_441_DATA */ + 0x00000000, /* DENALI_PHY_442_DATA */ + 0x02600260, /* DENALI_PHY_443_DATA */ + 0x02600260, /* DENALI_PHY_444_DATA */ + 0x02600260, /* DENALI_PHY_445_DATA */ + 0x02600260, /* DENALI_PHY_446_DATA */ + 0x00000260, /* DENALI_PHY_447_DATA */ + 0x00000000, /* DENALI_PHY_448_DATA */ + 0x00000000, /* DENALI_PHY_449_DATA */ + 0x00000000, /* DENALI_PHY_450_DATA */ + 0x00000000, /* DENALI_PHY_451_DATA */ + 0x00800000, /* DENALI_PHY_452_DATA */ + 0x00800080, /* DENALI_PHY_453_DATA */ + 0x00800080, /* DENALI_PHY_454_DATA */ + 0x00800080, /* DENALI_PHY_455_DATA */ + 0x00800080, /* DENALI_PHY_456_DATA */ + 0x00800080, /* DENALI_PHY_457_DATA */ + 0x00800080, /* DENALI_PHY_458_DATA */ + 0x00800080, /* DENALI_PHY_459_DATA */ + 0x00800080, /* DENALI_PHY_460_DATA */ + 0x01a20080, /* DENALI_PHY_461_DATA */ + 0x01900003, /* DENALI_PHY_462_DATA */ + 0x00000000, /* DENALI_PHY_463_DATA */ + 0x00030000, /* DENALI_PHY_464_DATA */ + 0x00000200, /* DENALI_PHY_465_DATA */ + 0x00000000, /* DENALI_PHY_466_DATA */ + 0x51315152, /* DENALI_PHY_467_DATA */ + 0xc0013150, /* DENALI_PHY_468_DATA */ + 0x020000c0, /* DENALI_PHY_469_DATA */ + 0x00100001, /* DENALI_PHY_470_DATA */ + 0x0c064208, /* DENALI_PHY_471_DATA */ + 0x000f0c18, /* DENALI_PHY_472_DATA */ + 0x01000140, /* DENALI_PHY_473_DATA */ + 0x00000c20, /* DENALI_PHY_474_DATA */ + 0x00000000, /* DENALI_PHY_475_DATA */ + 0x00000000, /* DENALI_PHY_476_DATA */ + 0x00000000, /* DENALI_PHY_477_DATA */ + 0x00000000, /* DENALI_PHY_478_DATA */ + 0x00000000, /* DENALI_PHY_479_DATA */ + 0x00000000, /* DENALI_PHY_480_DATA */ + 0x00000000, /* DENALI_PHY_481_DATA */ + 0x00000000, /* DENALI_PHY_482_DATA */ + 0x00000000, /* DENALI_PHY_483_DATA */ + 0x00000000, /* DENALI_PHY_484_DATA */ + 0x00000000, /* DENALI_PHY_485_DATA */ + 0x00000000, /* DENALI_PHY_486_DATA */ + 0x00000000, /* DENALI_PHY_487_DATA */ + 0x00000000, /* DENALI_PHY_488_DATA */ + 0x00000000, /* DENALI_PHY_489_DATA */ + 0x00000000, /* DENALI_PHY_490_DATA */ + 0x00000000, /* DENALI_PHY_491_DATA */ + 0x00000000, /* DENALI_PHY_492_DATA */ + 0x00000000, /* DENALI_PHY_493_DATA */ + 0x00000000, /* DENALI_PHY_494_DATA */ + 0x00000000, /* DENALI_PHY_495_DATA */ + 0x00000000, /* DENALI_PHY_496_DATA */ + 0x00000000, /* DENALI_PHY_497_DATA */ + 0x00000000, /* DENALI_PHY_498_DATA */ + 0x00000000, /* DENALI_PHY_499_DATA */ + 0x00000000, /* DENALI_PHY_500_DATA */ + 0x00000000, /* DENALI_PHY_501_DATA */ + 0x00000000, /* DENALI_PHY_502_DATA */ + 0x00000000, /* DENALI_PHY_503_DATA */ + 0x00000000, /* DENALI_PHY_504_DATA */ + 0x00000000, /* DENALI_PHY_505_DATA */ + 0x00000000, /* DENALI_PHY_506_DATA */ + 0x00000000, /* DENALI_PHY_507_DATA */ + 0x00000000, /* DENALI_PHY_508_DATA */ + 0x00000000, /* DENALI_PHY_509_DATA */ + 0x00000000, /* DENALI_PHY_510_DATA */ + 0x00000000, /* DENALI_PHY_511_DATA */ + 0x00000000, /* DENALI_PHY_512_DATA */ + 0x00800000, /* DENALI_PHY_513_DATA */ + 0x00000000, /* DENALI_PHY_514_DATA */ + 0x00000000, /* DENALI_PHY_515_DATA */ + 0x00000000, /* DENALI_PHY_516_DATA */ + 0x00000000, /* DENALI_PHY_517_DATA */ + 0x00000000, /* DENALI_PHY_518_DATA */ + 0x00000001, /* DENALI_PHY_519_DATA */ + 0x00000000, /* DENALI_PHY_520_DATA */ + 0x00000000, /* DENALI_PHY_521_DATA */ + 0x00000000, /* DENALI_PHY_522_DATA */ + 0x00400320, /* DENALI_PHY_523_DATA */ + 0x00000040, /* DENALI_PHY_524_DATA */ + 0x00806420, /* DENALI_PHY_525_DATA */ + 0x00917531, /* DENALI_PHY_526_DATA */ + 0x00806420, /* DENALI_PHY_527_DATA */ + 0x01917531, /* DENALI_PHY_528_DATA */ + 0x00020003, /* DENALI_PHY_529_DATA */ + 0x00000000, /* DENALI_PHY_530_DATA */ + 0x00000000, /* DENALI_PHY_531_DATA */ + 0x00000000, /* DENALI_PHY_532_DATA */ + 0x000556aa, /* DENALI_PHY_533_DATA */ + 0x000aaaaa, /* DENALI_PHY_534_DATA */ + 0x000aa955, /* DENALI_PHY_535_DATA */ + 0x00055555, /* DENALI_PHY_536_DATA */ + 0x000b3133, /* DENALI_PHY_537_DATA */ + 0x0004cd33, /* DENALI_PHY_538_DATA */ + 0x0004cecc, /* DENALI_PHY_539_DATA */ + 0x000b32cc, /* DENALI_PHY_540_DATA */ + 0x0a418820, /* DENALI_PHY_541_DATA */ + 0x103f0000, /* DENALI_PHY_542_DATA */ + 0x0000003f, /* DENALI_PHY_543_DATA */ + 0x00038055, /* DENALI_PHY_544_DATA */ + 0x03800380, /* DENALI_PHY_545_DATA */ + 0x03800380, /* DENALI_PHY_546_DATA */ + 0x00000380, /* DENALI_PHY_547_DATA */ + 0x42080010, /* DENALI_PHY_548_DATA */ + 0x00000003, /* DENALI_PHY_549_DATA */ + 0x00000000, /* DENALI_PHY_550_DATA */ + 0x00000000, /* DENALI_PHY_551_DATA */ + 0x00000000, /* DENALI_PHY_552_DATA */ + 0x00000000, /* DENALI_PHY_553_DATA */ + 0x00000000, /* DENALI_PHY_554_DATA */ + 0x00000000, /* DENALI_PHY_555_DATA */ + 0x00000000, /* DENALI_PHY_556_DATA */ + 0x00000000, /* DENALI_PHY_557_DATA */ + 0x00000000, /* DENALI_PHY_558_DATA */ + 0x00000000, /* DENALI_PHY_559_DATA */ + 0x00000000, /* DENALI_PHY_560_DATA */ + 0x00000000, /* DENALI_PHY_561_DATA */ + 0x00000000, /* DENALI_PHY_562_DATA */ + 0x00000000, /* DENALI_PHY_563_DATA */ + 0x00000000, /* DENALI_PHY_564_DATA */ + 0x00000000, /* DENALI_PHY_565_DATA */ + 0x00000000, /* DENALI_PHY_566_DATA */ + 0x00000000, /* DENALI_PHY_567_DATA */ + 0x00000000, /* DENALI_PHY_568_DATA */ + 0x00000000, /* DENALI_PHY_569_DATA */ + 0x00000000, /* DENALI_PHY_570_DATA */ + 0x00000000, /* DENALI_PHY_571_DATA */ + 0x00000000, /* DENALI_PHY_572_DATA */ + 0x00000000, /* DENALI_PHY_573_DATA */ + 0x00000000, /* DENALI_PHY_574_DATA */ + 0x00000000, /* DENALI_PHY_575_DATA */ + 0x00000000, /* DENALI_PHY_576_DATA */ + 0x00000000, /* DENALI_PHY_577_DATA */ + 0x00000000, /* DENALI_PHY_578_DATA */ + 0x00000000, /* DENALI_PHY_579_DATA */ + 0x00000000, /* DENALI_PHY_580_DATA */ + 0x00000000, /* DENALI_PHY_581_DATA */ + 0x00000000, /* DENALI_PHY_582_DATA */ + 0x00000000, /* DENALI_PHY_583_DATA */ + 0x00000000, /* DENALI_PHY_584_DATA */ + 0x00000000, /* DENALI_PHY_585_DATA */ + 0x00000000, /* DENALI_PHY_586_DATA */ + 0x00000000, /* DENALI_PHY_587_DATA */ + 0x00000000, /* DENALI_PHY_588_DATA */ + 0x00000000, /* DENALI_PHY_589_DATA */ + 0x00000000, /* DENALI_PHY_590_DATA */ + 0x00000000, /* DENALI_PHY_591_DATA */ + 0x00000000, /* DENALI_PHY_592_DATA */ + 0x00000000, /* DENALI_PHY_593_DATA */ + 0x00000000, /* DENALI_PHY_594_DATA */ + 0x00000000, /* DENALI_PHY_595_DATA */ + 0x00000000, /* DENALI_PHY_596_DATA */ + 0x00000000, /* DENALI_PHY_597_DATA */ + 0x00000000, /* DENALI_PHY_598_DATA */ + 0x00000000, /* DENALI_PHY_599_DATA */ + 0x00000000, /* DENALI_PHY_600_DATA */ + 0x00000000, /* DENALI_PHY_601_DATA */ + 0x00000000, /* DENALI_PHY_602_DATA */ + 0x00000000, /* DENALI_PHY_603_DATA */ + 0x00000000, /* DENALI_PHY_604_DATA */ + 0x00000000, /* DENALI_PHY_605_DATA */ + 0x00000000, /* DENALI_PHY_606_DATA */ + 0x00000000, /* DENALI_PHY_607_DATA */ + 0x00000000, /* DENALI_PHY_608_DATA */ + 0x00000000, /* DENALI_PHY_609_DATA */ + 0x00000000, /* DENALI_PHY_610_DATA */ + 0x00000000, /* DENALI_PHY_611_DATA */ + 0x00000000, /* DENALI_PHY_612_DATA */ + 0x00000000, /* DENALI_PHY_613_DATA */ + 0x00000000, /* DENALI_PHY_614_DATA */ + 0x00000000, /* DENALI_PHY_615_DATA */ + 0x00000000, /* DENALI_PHY_616_DATA */ + 0x00000000, /* DENALI_PHY_617_DATA */ + 0x00000000, /* DENALI_PHY_618_DATA */ + 0x00000000, /* DENALI_PHY_619_DATA */ + 0x00000000, /* DENALI_PHY_620_DATA */ + 0x00000000, /* DENALI_PHY_621_DATA */ + 0x00000000, /* DENALI_PHY_622_DATA */ + 0x00000000, /* DENALI_PHY_623_DATA */ + 0x00000000, /* DENALI_PHY_624_DATA */ + 0x00000000, /* DENALI_PHY_625_DATA */ + 0x00000000, /* DENALI_PHY_626_DATA */ + 0x00000000, /* DENALI_PHY_627_DATA */ + 0x00000000, /* DENALI_PHY_628_DATA */ + 0x00000000, /* DENALI_PHY_629_DATA */ + 0x00000000, /* DENALI_PHY_630_DATA */ + 0x00000000, /* DENALI_PHY_631_DATA */ + 0x00000000, /* DENALI_PHY_632_DATA */ + 0x00000000, /* DENALI_PHY_633_DATA */ + 0x00000000, /* DENALI_PHY_634_DATA */ + 0x00000000, /* DENALI_PHY_635_DATA */ + 0x00000000, /* DENALI_PHY_636_DATA */ + 0x00000000, /* DENALI_PHY_637_DATA */ + 0x00000000, /* DENALI_PHY_638_DATA */ + 0x00000000, /* DENALI_PHY_639_DATA */ + 0x00000000, /* DENALI_PHY_640_DATA */ + 0x00800000, /* DENALI_PHY_641_DATA */ + 0x00000000, /* DENALI_PHY_642_DATA */ + 0x00000000, /* DENALI_PHY_643_DATA */ + 0x00000000, /* DENALI_PHY_644_DATA */ + 0x00000000, /* DENALI_PHY_645_DATA */ + 0x00000000, /* DENALI_PHY_646_DATA */ + 0x00000001, /* DENALI_PHY_647_DATA */ + 0x00000000, /* DENALI_PHY_648_DATA */ + 0x00000000, /* DENALI_PHY_649_DATA */ + 0x00000000, /* DENALI_PHY_650_DATA */ + 0x00400320, /* DENALI_PHY_651_DATA */ + 0x00000040, /* DENALI_PHY_652_DATA */ + 0x00008eca, /* DENALI_PHY_653_DATA */ + 0x00009fdb, /* DENALI_PHY_654_DATA */ + 0x00008eca, /* DENALI_PHY_655_DATA */ + 0x01009fdb, /* DENALI_PHY_656_DATA */ + 0x00020003, /* DENALI_PHY_657_DATA */ + 0x00000000, /* DENALI_PHY_658_DATA */ + 0x00000000, /* DENALI_PHY_659_DATA */ + 0x00000000, /* DENALI_PHY_660_DATA */ + 0x000556aa, /* DENALI_PHY_661_DATA */ + 0x000aaaaa, /* DENALI_PHY_662_DATA */ + 0x000aa955, /* DENALI_PHY_663_DATA */ + 0x00055555, /* DENALI_PHY_664_DATA */ + 0x000b3133, /* DENALI_PHY_665_DATA */ + 0x0004cd33, /* DENALI_PHY_666_DATA */ + 0x0004cecc, /* DENALI_PHY_667_DATA */ + 0x000b32cc, /* DENALI_PHY_668_DATA */ + 0x0004a0e6, /* DENALI_PHY_669_DATA */ + 0x080f0000, /* DENALI_PHY_670_DATA */ + 0x0000000f, /* DENALI_PHY_671_DATA */ + 0x00038055, /* DENALI_PHY_672_DATA */ + 0x03800380, /* DENALI_PHY_673_DATA */ + 0x03800380, /* DENALI_PHY_674_DATA */ + 0x00000380, /* DENALI_PHY_675_DATA */ + 0x42080010, /* DENALI_PHY_676_DATA */ + 0x00000003, /* DENALI_PHY_677_DATA */ + 0x00000000, /* DENALI_PHY_678_DATA */ + 0x00000000, /* DENALI_PHY_679_DATA */ + 0x00000000, /* DENALI_PHY_680_DATA */ + 0x00000000, /* DENALI_PHY_681_DATA */ + 0x00000000, /* DENALI_PHY_682_DATA */ + 0x00000000, /* DENALI_PHY_683_DATA */ + 0x00000000, /* DENALI_PHY_684_DATA */ + 0x00000000, /* DENALI_PHY_685_DATA */ + 0x00000000, /* DENALI_PHY_686_DATA */ + 0x00000000, /* DENALI_PHY_687_DATA */ + 0x00000000, /* DENALI_PHY_688_DATA */ + 0x00000000, /* DENALI_PHY_689_DATA */ + 0x00000000, /* DENALI_PHY_690_DATA */ + 0x00000000, /* DENALI_PHY_691_DATA */ + 0x00000000, /* DENALI_PHY_692_DATA */ + 0x00000000, /* DENALI_PHY_693_DATA */ + 0x00000000, /* DENALI_PHY_694_DATA */ + 0x00000000, /* DENALI_PHY_695_DATA */ + 0x00000000, /* DENALI_PHY_696_DATA */ + 0x00000000, /* DENALI_PHY_697_DATA */ + 0x00000000, /* DENALI_PHY_698_DATA */ + 0x00000000, /* DENALI_PHY_699_DATA */ + 0x00000000, /* DENALI_PHY_700_DATA */ + 0x00000000, /* DENALI_PHY_701_DATA */ + 0x00000000, /* DENALI_PHY_702_DATA */ + 0x00000000, /* DENALI_PHY_703_DATA */ + 0x00000000, /* DENALI_PHY_704_DATA */ + 0x00000000, /* DENALI_PHY_705_DATA */ + 0x00000000, /* DENALI_PHY_706_DATA */ + 0x00000000, /* DENALI_PHY_707_DATA */ + 0x00000000, /* DENALI_PHY_708_DATA */ + 0x00000000, /* DENALI_PHY_709_DATA */ + 0x00000000, /* DENALI_PHY_710_DATA */ + 0x00000000, /* DENALI_PHY_711_DATA */ + 0x00000000, /* DENALI_PHY_712_DATA */ + 0x00000000, /* DENALI_PHY_713_DATA */ + 0x00000000, /* DENALI_PHY_714_DATA */ + 0x00000000, /* DENALI_PHY_715_DATA */ + 0x00000000, /* DENALI_PHY_716_DATA */ + 0x00000000, /* DENALI_PHY_717_DATA */ + 0x00000000, /* DENALI_PHY_718_DATA */ + 0x00000000, /* DENALI_PHY_719_DATA */ + 0x00000000, /* DENALI_PHY_720_DATA */ + 0x00000000, /* DENALI_PHY_721_DATA */ + 0x00000000, /* DENALI_PHY_722_DATA */ + 0x00000000, /* DENALI_PHY_723_DATA */ + 0x00000000, /* DENALI_PHY_724_DATA */ + 0x00000000, /* DENALI_PHY_725_DATA */ + 0x00000000, /* DENALI_PHY_726_DATA */ + 0x00000000, /* DENALI_PHY_727_DATA */ + 0x00000000, /* DENALI_PHY_728_DATA */ + 0x00000000, /* DENALI_PHY_729_DATA */ + 0x00000000, /* DENALI_PHY_730_DATA */ + 0x00000000, /* DENALI_PHY_731_DATA */ + 0x00000000, /* DENALI_PHY_732_DATA */ + 0x00000000, /* DENALI_PHY_733_DATA */ + 0x00000000, /* DENALI_PHY_734_DATA */ + 0x00000000, /* DENALI_PHY_735_DATA */ + 0x00000000, /* DENALI_PHY_736_DATA */ + 0x00000000, /* DENALI_PHY_737_DATA */ + 0x00000000, /* DENALI_PHY_738_DATA */ + 0x00000000, /* DENALI_PHY_739_DATA */ + 0x00000000, /* DENALI_PHY_740_DATA */ + 0x00000000, /* DENALI_PHY_741_DATA */ + 0x00000000, /* DENALI_PHY_742_DATA */ + 0x00000000, /* DENALI_PHY_743_DATA */ + 0x00000000, /* DENALI_PHY_744_DATA */ + 0x00000000, /* DENALI_PHY_745_DATA */ + 0x00000000, /* DENALI_PHY_746_DATA */ + 0x00000000, /* DENALI_PHY_747_DATA */ + 0x00000000, /* DENALI_PHY_748_DATA */ + 0x00000000, /* DENALI_PHY_749_DATA */ + 0x00000000, /* DENALI_PHY_750_DATA */ + 0x00000000, /* DENALI_PHY_751_DATA */ + 0x00000000, /* DENALI_PHY_752_DATA */ + 0x00000000, /* DENALI_PHY_753_DATA */ + 0x00000000, /* DENALI_PHY_754_DATA */ + 0x00000000, /* DENALI_PHY_755_DATA */ + 0x00000000, /* DENALI_PHY_756_DATA */ + 0x00000000, /* DENALI_PHY_757_DATA */ + 0x00000000, /* DENALI_PHY_758_DATA */ + 0x00000000, /* DENALI_PHY_759_DATA */ + 0x00000000, /* DENALI_PHY_760_DATA */ + 0x00000000, /* DENALI_PHY_761_DATA */ + 0x00000000, /* DENALI_PHY_762_DATA */ + 0x00000000, /* DENALI_PHY_763_DATA */ + 0x00000000, /* DENALI_PHY_764_DATA */ + 0x00000000, /* DENALI_PHY_765_DATA */ + 0x00000000, /* DENALI_PHY_766_DATA */ + 0x00000000, /* DENALI_PHY_767_DATA */ + 0x00000000, /* DENALI_PHY_768_DATA */ + 0x00800000, /* DENALI_PHY_769_DATA */ + 0x00000000, /* DENALI_PHY_770_DATA */ + 0x00000000, /* DENALI_PHY_771_DATA */ + 0x00000000, /* DENALI_PHY_772_DATA */ + 0x00000000, /* DENALI_PHY_773_DATA */ + 0x00000000, /* DENALI_PHY_774_DATA */ + 0x00000001, /* DENALI_PHY_775_DATA */ + 0x00000000, /* DENALI_PHY_776_DATA */ + 0x00000000, /* DENALI_PHY_777_DATA */ + 0x00000000, /* DENALI_PHY_778_DATA */ + 0x00400320, /* DENALI_PHY_779_DATA */ + 0x00000040, /* DENALI_PHY_780_DATA */ + 0x00008eca, /* DENALI_PHY_781_DATA */ + 0x00009fdb, /* DENALI_PHY_782_DATA */ + 0x00008eca, /* DENALI_PHY_783_DATA */ + 0x01009fdb, /* DENALI_PHY_784_DATA */ + 0x00020003, /* DENALI_PHY_785_DATA */ + 0x00000000, /* DENALI_PHY_786_DATA */ + 0x00000000, /* DENALI_PHY_787_DATA */ + 0x00000000, /* DENALI_PHY_788_DATA */ + 0x000556aa, /* DENALI_PHY_789_DATA */ + 0x000aaaaa, /* DENALI_PHY_790_DATA */ + 0x000aa955, /* DENALI_PHY_791_DATA */ + 0x00055555, /* DENALI_PHY_792_DATA */ + 0x000b3133, /* DENALI_PHY_793_DATA */ + 0x0004cd33, /* DENALI_PHY_794_DATA */ + 0x0004cecc, /* DENALI_PHY_795_DATA */ + 0x000b32cc, /* DENALI_PHY_796_DATA */ + 0x1ee6b16a, /* DENALI_PHY_797_DATA */ + 0x10000000, /* DENALI_PHY_798_DATA */ + 0x00000000, /* DENALI_PHY_799_DATA */ + 0x00038055, /* DENALI_PHY_800_DATA */ + 0x03800380, /* DENALI_PHY_801_DATA */ + 0x03800380, /* DENALI_PHY_802_DATA */ + 0x00000380, /* DENALI_PHY_803_DATA */ + 0x42080010, /* DENALI_PHY_804_DATA */ + 0x00000003, /* DENALI_PHY_805_DATA */ + 0x00000000, /* DENALI_PHY_806_DATA */ + 0x00000000, /* DENALI_PHY_807_DATA */ + 0x00000000, /* DENALI_PHY_808_DATA */ + 0x00000000, /* DENALI_PHY_809_DATA */ + 0x00000000, /* DENALI_PHY_810_DATA */ + 0x00000000, /* DENALI_PHY_811_DATA */ + 0x00000000, /* DENALI_PHY_812_DATA */ + 0x00000000, /* DENALI_PHY_813_DATA */ + 0x00000000, /* DENALI_PHY_814_DATA */ + 0x00000000, /* DENALI_PHY_815_DATA */ + 0x00000000, /* DENALI_PHY_816_DATA */ + 0x00000000, /* DENALI_PHY_817_DATA */ + 0x00000000, /* DENALI_PHY_818_DATA */ + 0x00000000, /* DENALI_PHY_819_DATA */ + 0x00000000, /* DENALI_PHY_820_DATA */ + 0x00000000, /* DENALI_PHY_821_DATA */ + 0x00000000, /* DENALI_PHY_822_DATA */ + 0x00000000, /* DENALI_PHY_823_DATA */ + 0x00000000, /* DENALI_PHY_824_DATA */ + 0x00000000, /* DENALI_PHY_825_DATA */ + 0x00000000, /* DENALI_PHY_826_DATA */ + 0x00000000, /* DENALI_PHY_827_DATA */ + 0x00000000, /* DENALI_PHY_828_DATA */ + 0x00000000, /* DENALI_PHY_829_DATA */ + 0x00000000, /* DENALI_PHY_830_DATA */ + 0x00000000, /* DENALI_PHY_831_DATA */ + 0x00000000, /* DENALI_PHY_832_DATA */ + 0x00000000, /* DENALI_PHY_833_DATA */ + 0x00000000, /* DENALI_PHY_834_DATA */ + 0x00000000, /* DENALI_PHY_835_DATA */ + 0x00000000, /* DENALI_PHY_836_DATA */ + 0x00000000, /* DENALI_PHY_837_DATA */ + 0x00000000, /* DENALI_PHY_838_DATA */ + 0x00000000, /* DENALI_PHY_839_DATA */ + 0x00000000, /* DENALI_PHY_840_DATA */ + 0x00000000, /* DENALI_PHY_841_DATA */ + 0x00000000, /* DENALI_PHY_842_DATA */ + 0x00000000, /* DENALI_PHY_843_DATA */ + 0x00000000, /* DENALI_PHY_844_DATA */ + 0x00000000, /* DENALI_PHY_845_DATA */ + 0x00000000, /* DENALI_PHY_846_DATA */ + 0x00000000, /* DENALI_PHY_847_DATA */ + 0x00000000, /* DENALI_PHY_848_DATA */ + 0x00000000, /* DENALI_PHY_849_DATA */ + 0x00000000, /* DENALI_PHY_850_DATA */ + 0x00000000, /* DENALI_PHY_851_DATA */ + 0x00000000, /* DENALI_PHY_852_DATA */ + 0x00000000, /* DENALI_PHY_853_DATA */ + 0x00000000, /* DENALI_PHY_854_DATA */ + 0x00000000, /* DENALI_PHY_855_DATA */ + 0x00000000, /* DENALI_PHY_856_DATA */ + 0x00000000, /* DENALI_PHY_857_DATA */ + 0x00000000, /* DENALI_PHY_858_DATA */ + 0x00000000, /* DENALI_PHY_859_DATA */ + 0x00000000, /* DENALI_PHY_860_DATA */ + 0x00000000, /* DENALI_PHY_861_DATA */ + 0x00000000, /* DENALI_PHY_862_DATA */ + 0x00000000, /* DENALI_PHY_863_DATA */ + 0x00000000, /* DENALI_PHY_864_DATA */ + 0x00000000, /* DENALI_PHY_865_DATA */ + 0x00000000, /* DENALI_PHY_866_DATA */ + 0x00000000, /* DENALI_PHY_867_DATA */ + 0x00000000, /* DENALI_PHY_868_DATA */ + 0x00000000, /* DENALI_PHY_869_DATA */ + 0x00000000, /* DENALI_PHY_870_DATA */ + 0x00000000, /* DENALI_PHY_871_DATA */ + 0x00000000, /* DENALI_PHY_872_DATA */ + 0x00000000, /* DENALI_PHY_873_DATA */ + 0x00000000, /* DENALI_PHY_874_DATA */ + 0x00000000, /* DENALI_PHY_875_DATA */ + 0x00000000, /* DENALI_PHY_876_DATA */ + 0x00000000, /* DENALI_PHY_877_DATA */ + 0x00000000, /* DENALI_PHY_878_DATA */ + 0x00000000, /* DENALI_PHY_879_DATA */ + 0x00000000, /* DENALI_PHY_880_DATA */ + 0x00000000, /* DENALI_PHY_881_DATA */ + 0x00000000, /* DENALI_PHY_882_DATA */ + 0x00000000, /* DENALI_PHY_883_DATA */ + 0x00000000, /* DENALI_PHY_884_DATA */ + 0x00000000, /* DENALI_PHY_885_DATA */ + 0x00000000, /* DENALI_PHY_886_DATA */ + 0x00000000, /* DENALI_PHY_887_DATA */ + 0x00000000, /* DENALI_PHY_888_DATA */ + 0x00000000, /* DENALI_PHY_889_DATA */ + 0x00000000, /* DENALI_PHY_890_DATA */ + 0x00000000, /* DENALI_PHY_891_DATA */ + 0x00000000, /* DENALI_PHY_892_DATA */ + 0x00000000, /* DENALI_PHY_893_DATA */ + 0x00000000, /* DENALI_PHY_894_DATA */ + 0x00000000, /* DENALI_PHY_895_DATA */ + 0x00000001, /* DENALI_PHY_896_DATA */ + 0x00000000, /* DENALI_PHY_897_DATA */ + 0x01000005, /* DENALI_PHY_898_DATA */ + 0x04000f00, /* DENALI_PHY_899_DATA */ + 0x00020040, /* DENALI_PHY_900_DATA */ + 0x00020055, /* DENALI_PHY_901_DATA */ + 0x00000000, /* DENALI_PHY_902_DATA */ + 0x00000000, /* DENALI_PHY_903_DATA */ + 0x00000000, /* DENALI_PHY_904_DATA */ + 0x00000050, /* DENALI_PHY_905_DATA */ + 0x00000000, /* DENALI_PHY_906_DATA */ + 0x00010100, /* DENALI_PHY_907_DATA */ + 0x00000601, /* DENALI_PHY_908_DATA */ + 0x00000000, /* DENALI_PHY_909_DATA */ + 0x00006400, /* DENALI_PHY_910_DATA */ + 0x01221102, /* DENALI_PHY_911_DATA */ + 0x00000000, /* DENALI_PHY_912_DATA */ + 0x00051f00, /* DENALI_PHY_913_DATA */ + 0x051f051f, /* DENALI_PHY_914_DATA */ + 0x051f051f, /* DENALI_PHY_915_DATA */ + 0x00030003, /* DENALI_PHY_916_DATA */ + 0x03000300, /* DENALI_PHY_917_DATA */ + 0x00000300, /* DENALI_PHY_918_DATA */ + 0x01221102, /* DENALI_PHY_919_DATA */ + 0x00000000, /* DENALI_PHY_920_DATA */ + 0x00000000, /* DENALI_PHY_921_DATA */ + 0x04020000, /* DENALI_PHY_922_DATA */ + 0x00000001, /* DENALI_PHY_923_DATA */ + 0x00000011, /* DENALI_PHY_924_DATA */ + 0x00000011, /* DENALI_PHY_925_DATA */ + 0x00000400, /* DENALI_PHY_926_DATA */ + 0x00000000, /* DENALI_PHY_927_DATA */ + 0x00000011, /* DENALI_PHY_928_DATA */ + 0x00000011, /* DENALI_PHY_929_DATA */ + 0x00004410, /* DENALI_PHY_930_DATA */ + 0x00004410, /* DENALI_PHY_931_DATA */ + 0x00004410, /* DENALI_PHY_932_DATA */ + 0x00004410, /* DENALI_PHY_933_DATA */ + 0x00004410, /* DENALI_PHY_934_DATA */ + 0x00000011, /* DENALI_PHY_935_DATA */ + 0x00004410, /* DENALI_PHY_936_DATA */ + 0x00000011, /* DENALI_PHY_937_DATA */ + 0x00004410, /* DENALI_PHY_938_DATA */ + 0x00000011, /* DENALI_PHY_939_DATA */ + 0x00004410, /* DENALI_PHY_940_DATA */ + 0x00000000, /* DENALI_PHY_941_DATA */ + 0x00000000, /* DENALI_PHY_942_DATA */ + 0x00000000, /* DENALI_PHY_943_DATA */ + 0x04000000, /* DENALI_PHY_944_DATA */ + 0x00000000, /* DENALI_PHY_945_DATA */ + 0x00000000, /* DENALI_PHY_946_DATA */ + 0x00000508, /* DENALI_PHY_947_DATA */ + 0x00000000, /* DENALI_PHY_948_DATA */ + 0x00000000, /* DENALI_PHY_949_DATA */ + 0x00000000, /* DENALI_PHY_950_DATA */ + 0x00000000, /* DENALI_PHY_951_DATA */ + 0x00000000, /* DENALI_PHY_952_DATA */ + 0x00000000, /* DENALI_PHY_953_DATA */ + 0xe4000000, /* DENALI_PHY_954_DATA */ + 0x00000000, /* DENALI_PHY_955_DATA */ + 0x00000000, /* DENALI_PHY_956_DATA */ + 0x01010000, /* DENALI_PHY_957_DATA */ + 0x00000000 /* DENALI_PHY_958_DATA */ + } + }, +}; diff --git a/src/mainboard/google/gru/sdram_inf/sdram-lpddr3-hynix-4GB-933.inc b/src/mainboard/google/gru/sdram_inf/sdram-lpddr3-hynix-4GB-933.inc deleted file mode 100644 index fe1949e..0000000 --- a/src/mainboard/google/gru/sdram_inf/sdram-lpddr3-hynix-4GB-933.inc +++ /dev/null @@ -1,1563 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -{ - { - { - .rank = 0x2, - .col = 0xA, - .bk = 0x3, - .bw = 0x2, - .dbw = 0x2, - .row_3_4 = 0x0, - .cs0_row = 0xF, - .cs1_row = 0xF, - .ddrconfig = 1, - { - {0x1d191519}, - {0x14040808}, - {0x00000002}, - {0x00006226}, - {0x00000054}, - 0x00000000 - } - }, - { - .rank = 0x2, - .col = 0xA, - .bk = 0x3, - .bw = 0x2, - .dbw = 0x2, - .row_3_4 = 0x0, - .cs0_row = 0xF, - .cs1_row = 0xF, - .ddrconfig = 1, - { - {0x1d191519}, - {0x14040808}, - {0x00000002}, - {0x00006226}, - {0x00000054}, - 0x00000000 - } - } - }, - .ddr_freq = 933*MHz, - .dramtype = LPDDR3, - .num_channels = 2, - .stride = 13, - .odt = 1, - { - { - 0x00000700, /* DENALI_CTL_00_DATA */ - 0x00000000, /* DENALI_CTL_01_DATA */ - 0x00000000, /* DENALI_CTL_02_DATA */ - 0x00000000, /* DENALI_CTL_03_DATA */ - 0x00000000, /* DENALI_CTL_04_DATA */ - 0x0000005e, /* DENALI_CTL_05_DATA */ - 0x0002d976, /* DENALI_CTL_06_DATA */ - 0x000003a6, /* DENALI_CTL_07_DATA */ - 0x0000247a, /* DENALI_CTL_08_DATA */ - 0x0000005e, /* DENALI_CTL_09_DATA */ - 0x0002d976, /* DENALI_CTL_10_DATA */ - 0x000003a6, /* DENALI_CTL_11_DATA */ - 0x0000247a, /* DENALI_CTL_12_DATA */ - 0x0000005e, /* DENALI_CTL_13_DATA */ - 0x0002d976, /* DENALI_CTL_14_DATA */ - 0x000003a6, /* DENALI_CTL_15_DATA */ - 0x0100247a, /* DENALI_CTL_16_DATA */ - 0x00000000, /* DENALI_CTL_17_DATA */ - 0x00000101, /* DENALI_CTL_18_DATA */ - 0x00020100, /* DENALI_CTL_19_DATA */ - 0x000000bb, /* DENALI_CTL_20_DATA */ - 0x000001d3, /* DENALI_CTL_21_DATA */ - 0x00000000, /* DENALI_CTL_22_DATA */ - 0x081c0000, /* DENALI_CTL_23_DATA */ - 0x00081c00, /* DENALI_CTL_24_DATA */ - 0x0400081c, /* DENALI_CTL_25_DATA */ - 0x3b0a0004, /* DENALI_CTL_26_DATA */ - 0x2f110828, /* DENALI_CTL_27_DATA */ - 0x283b0a00, /* DENALI_CTL_28_DATA */ - 0x002f1108, /* DENALI_CTL_29_DATA */ - 0x08283b0a, /* DENALI_CTL_30_DATA */ - 0x08002f11, /* DENALI_CTL_31_DATA */ - 0x00000a0a, /* DENALI_CTL_32_DATA */ - 0x0800ff4f, /* DENALI_CTL_33_DATA */ - 0x0a0a080f, /* DENALI_CTL_34_DATA */ - 0x0800ff4f, /* DENALI_CTL_35_DATA */ - 0x0a0a080f, /* DENALI_CTL_36_DATA */ - 0x0800ff4f, /* DENALI_CTL_37_DATA */ - 0x0203000f, /* DENALI_CTL_38_DATA */ - 0x110f1100, /* DENALI_CTL_39_DATA */ - 0x040f110f, /* DENALI_CTL_40_DATA */ - 0x14000a0a, /* DENALI_CTL_41_DATA */ - 0x03030a0a, /* DENALI_CTL_42_DATA */ - 0x00010003, /* DENALI_CTL_43_DATA */ - 0x03212121, /* DENALI_CTL_44_DATA */ - 0x00141414, /* DENALI_CTL_45_DATA */ - 0x00000000, /* DENALI_CTL_46_DATA */ - 0x03010000, /* DENALI_CTL_47_DATA */ - 0x0e3100c5, /* DENALI_CTL_48_DATA */ - 0x0e3100c5, /* DENALI_CTL_49_DATA */ - 0x0e3100c5, /* DENALI_CTL_50_DATA */ - 0x00000000, /* DENALI_CTL_51_DATA */ - 0x00080008, /* DENALI_CTL_52_DATA */ - 0x00170008, /* DENALI_CTL_53_DATA */ - 0x00170017, /* DENALI_CTL_54_DATA */ - 0x00111111, /* DENALI_CTL_55_DATA */ - 0x00000000, /* DENALI_CTL_56_DATA */ - 0x00000000, /* DENALI_CTL_57_DATA */ - 0x00000000, /* DENALI_CTL_58_DATA */ - 0x00ce0000, /* DENALI_CTL_59_DATA */ - 0x00ce00ce, /* DENALI_CTL_60_DATA */ - 0x00ce00ce, /* DENALI_CTL_61_DATA */ - 0x000000ce, /* DENALI_CTL_62_DATA */ - 0x00000000, /* DENALI_CTL_63_DATA */ - 0x00000000, /* DENALI_CTL_64_DATA */ - 0x00000000, /* DENALI_CTL_65_DATA */ - 0x00000000, /* DENALI_CTL_66_DATA */ - 0x00000000, /* DENALI_CTL_67_DATA */ - 0x00000000, /* DENALI_CTL_68_DATA */ - 0x00000301, /* DENALI_CTL_69_DATA */ - 0x00000001, /* DENALI_CTL_70_DATA */ - 0x00000000, /* DENALI_CTL_71_DATA */ - 0x00000000, /* DENALI_CTL_72_DATA */ - 0x01000000, /* DENALI_CTL_73_DATA */ - 0x80104002, /* DENALI_CTL_74_DATA */ - 0x00040003, /* DENALI_CTL_75_DATA */ - 0x00040005, /* DENALI_CTL_76_DATA */ - 0x00030000, /* DENALI_CTL_77_DATA */ - 0x00050004, /* DENALI_CTL_78_DATA */ - 0x00000004, /* DENALI_CTL_79_DATA */ - 0x00040003, /* DENALI_CTL_80_DATA */ - 0x00040005, /* DENALI_CTL_81_DATA */ - 0x38c40000, /* DENALI_CTL_82_DATA */ - 0x00001c62, /* DENALI_CTL_83_DATA */ - 0x1c6238c4, /* DENALI_CTL_84_DATA */ - 0x38c40000, /* DENALI_CTL_85_DATA */ - 0x00001c62, /* DENALI_CTL_86_DATA */ - 0x00000000, /* DENALI_CTL_87_DATA */ - 0x00000000, /* DENALI_CTL_88_DATA */ - 0x00000000, /* DENALI_CTL_89_DATA */ - 0x00000000, /* DENALI_CTL_90_DATA */ - 0x00000000, /* DENALI_CTL_91_DATA */ - 0x02020200, /* DENALI_CTL_92_DATA */ - 0x00020202, /* DENALI_CTL_93_DATA */ - 0x00030200, /* DENALI_CTL_94_DATA */ - 0x00040700, /* DENALI_CTL_95_DATA */ - 0x00000302, /* DENALI_CTL_96_DATA */ - 0x02000407, /* DENALI_CTL_97_DATA */ - 0x00000003, /* DENALI_CTL_98_DATA */ - 0x00030f04, /* DENALI_CTL_99_DATA */ - 0x00070004, /* DENALI_CTL_100_DATA */ - 0x00000000, /* DENALI_CTL_101_DATA */ - 0x00000000, /* DENALI_CTL_102_DATA */ - 0x00000000, /* DENALI_CTL_103_DATA */ - 0x00000000, /* DENALI_CTL_104_DATA */ - 0x00000000, /* DENALI_CTL_105_DATA */ - 0x00000000, /* DENALI_CTL_106_DATA */ - 0x00000000, /* DENALI_CTL_107_DATA */ - 0x00010000, /* DENALI_CTL_108_DATA */ - 0x20040020, /* DENALI_CTL_109_DATA */ - 0x00200400, /* DENALI_CTL_110_DATA */ - 0x01000400, /* DENALI_CTL_111_DATA */ - 0x00000b80, /* DENALI_CTL_112_DATA */ - 0x00000000, /* DENALI_CTL_113_DATA */ - 0x00000001, /* DENALI_CTL_114_DATA */ - 0x00000002, /* DENALI_CTL_115_DATA */ - 0x0000000e, /* DENALI_CTL_116_DATA */ - 0x00000000, /* DENALI_CTL_117_DATA */ - 0x00000000, /* DENALI_CTL_118_DATA */ - 0x00000000, /* DENALI_CTL_119_DATA */ - 0x00000000, /* DENALI_CTL_120_DATA */ - 0x00000000, /* DENALI_CTL_121_DATA */ - 0x00bb0000, /* DENALI_CTL_122_DATA */ - 0x00ea005e, /* DENALI_CTL_123_DATA */ - 0x00ea0000, /* DENALI_CTL_124_DATA */ - 0x005e00bb, /* DENALI_CTL_125_DATA */ - 0x000000ea, /* DENALI_CTL_126_DATA */ - 0x00bb00ea, /* DENALI_CTL_127_DATA */ - 0x00ea005e, /* DENALI_CTL_128_DATA */ - 0x00ea0000, /* DENALI_CTL_129_DATA */ - 0x00000000, /* DENALI_CTL_130_DATA */ - 0x00000000, /* DENALI_CTL_131_DATA */ - 0x00000000, /* DENALI_CTL_132_DATA */ - 0x00c30000, /* DENALI_CTL_133_DATA */ - 0x0000001c, /* DENALI_CTL_134_DATA */ - 0x001c00c3, /* DENALI_CTL_135_DATA */ - 0x00c30000, /* DENALI_CTL_136_DATA */ - 0x0000001c, /* DENALI_CTL_137_DATA */ - 0x00010001, /* DENALI_CTL_138_DATA */ - 0x06000001, /* DENALI_CTL_139_DATA */ - 0x00000707, /* DENALI_CTL_140_DATA */ - 0x00000000, /* DENALI_CTL_141_DATA */ - 0x00000000, /* DENALI_CTL_142_DATA */ - 0x00000000, /* DENALI_CTL_143_DATA */ - 0x00000000, /* DENALI_CTL_144_DATA */ - 0x00000000, /* DENALI_CTL_145_DATA */ - 0x00000000, /* DENALI_CTL_146_DATA */ - 0x00c30000, /* DENALI_CTL_147_DATA */ - 0x0000001c, /* DENALI_CTL_148_DATA */ - 0x001c00c3, /* DENALI_CTL_149_DATA */ - 0x00c30000, /* DENALI_CTL_150_DATA */ - 0x0000001c, /* DENALI_CTL_151_DATA */ - 0x00010001, /* DENALI_CTL_152_DATA */ - 0x06000001, /* DENALI_CTL_153_DATA */ - 0x00000707, /* DENALI_CTL_154_DATA */ - 0x00000000, /* DENALI_CTL_155_DATA */ - 0x00000000, /* DENALI_CTL_156_DATA */ - 0x00000000, /* DENALI_CTL_157_DATA */ - 0x00000000, /* DENALI_CTL_158_DATA */ - 0x00000000, /* DENALI_CTL_159_DATA */ - 0x00000000, /* DENALI_CTL_160_DATA */ - 0x01000000, /* DENALI_CTL_161_DATA */ - 0x00000000, /* DENALI_CTL_162_DATA */ - 0x00000000, /* DENALI_CTL_163_DATA */ - 0x18151100, /* DENALI_CTL_164_DATA */ - 0x0000000c, /* DENALI_CTL_165_DATA */ - 0x00000000, /* DENALI_CTL_166_DATA */ - 0x00000000, /* DENALI_CTL_167_DATA */ - 0x00000000, /* DENALI_CTL_168_DATA */ - 0x00000000, /* DENALI_CTL_169_DATA */ - 0x00000000, /* DENALI_CTL_170_DATA */ - 0x00000000, /* DENALI_CTL_171_DATA */ - 0x00000000, /* DENALI_CTL_172_DATA */ - 0x00000000, /* DENALI_CTL_173_DATA */ - 0x00000000, /* DENALI_CTL_174_DATA */ - 0x00000000, /* DENALI_CTL_175_DATA */ - 0x00000000, /* DENALI_CTL_176_DATA */ - 0x00000000, /* DENALI_CTL_177_DATA */ - 0x00000000, /* DENALI_CTL_178_DATA */ - 0x0003a603, /* DENALI_CTL_179_DATA */ - 0x00550151, /* DENALI_CTL_180_DATA */ - 0x00000000, /* DENALI_CTL_181_DATA */ - 0x015103a6, /* DENALI_CTL_182_DATA */ - 0x00000055, /* DENALI_CTL_183_DATA */ - 0x0003a600, /* DENALI_CTL_184_DATA */ - 0x00550151, /* DENALI_CTL_185_DATA */ - 0x00000000, /* DENALI_CTL_186_DATA */ - 0x002f0000, /* DENALI_CTL_187_DATA */ - 0x002f002f, /* DENALI_CTL_188_DATA */ - 0x01010100, /* DENALI_CTL_189_DATA */ - 0x01000202, /* DENALI_CTL_190_DATA */ - 0x0a000002, /* DENALI_CTL_191_DATA */ - 0x01000f0f, /* DENALI_CTL_192_DATA */ - 0x00000000, /* DENALI_CTL_193_DATA */ - 0x00000000, /* DENALI_CTL_194_DATA */ - 0x00010003, /* DENALI_CTL_195_DATA */ - 0x00000c03, /* DENALI_CTL_196_DATA */ - 0x00000100, /* DENALI_CTL_197_DATA */ - 0x00010000, /* DENALI_CTL_198_DATA */ - 0x01000000, /* DENALI_CTL_199_DATA */ - 0x00010000, /* DENALI_CTL_200_DATA */ - 0x00000001, /* DENALI_CTL_201_DATA */ - 0x00000000, /* DENALI_CTL_202_DATA */ - 0x00000000, /* DENALI_CTL_203_DATA */ - 0x00000000, /* DENALI_CTL_204_DATA */ - 0x00000000, /* DENALI_CTL_205_DATA */ - 0x00000000, /* DENALI_CTL_206_DATA */ - 0x00000000, /* DENALI_CTL_207_DATA */ - 0x00000000, /* DENALI_CTL_208_DATA */ - 0x00000000, /* DENALI_CTL_209_DATA */ - 0x00000000, /* DENALI_CTL_210_DATA */ - 0x00010000, /* DENALI_CTL_211_DATA */ - 0x04040401, /* DENALI_CTL_212_DATA */ - 0x01010808, /* DENALI_CTL_213_DATA */ - 0x04040001, /* DENALI_CTL_214_DATA */ - 0x0c0c0c04, /* DENALI_CTL_215_DATA */ - 0x08080808, /* DENALI_CTL_216_DATA */ - 0x02010103, /* DENALI_CTL_217_DATA */ - 0x02010103, /* DENALI_CTL_218_DATA */ - 0x00010103, /* DENALI_CTL_219_DATA */ - 0x00020202, /* DENALI_CTL_220_DATA */ - 0x06030600, /* DENALI_CTL_221_DATA */ - 0x00030603, /* DENALI_CTL_222_DATA */ - 0x00000000, /* DENALI_CTL_223_DATA */ - 0x00000000, /* DENALI_CTL_224_DATA */ - 0x0d000001, /* DENALI_CTL_225_DATA */ - 0x00010028, /* DENALI_CTL_226_DATA */ - 0x00010000, /* DENALI_CTL_227_DATA */ - 0x00000003, /* DENALI_CTL_228_DATA */ - 0x00000000, /* DENALI_CTL_229_DATA */ - 0x00000000, /* DENALI_CTL_230_DATA */ - 0x00000000, /* DENALI_CTL_231_DATA */ - 0x00000000, /* DENALI_CTL_232_DATA */ - 0x00000000, /* DENALI_CTL_233_DATA */ - 0x00000000, /* DENALI_CTL_234_DATA */ - 0x00000000, /* DENALI_CTL_235_DATA */ - 0x00000000, /* DENALI_CTL_236_DATA */ - 0x00010100, /* DENALI_CTL_237_DATA */ - 0x01000000, /* DENALI_CTL_238_DATA */ - 0x00000001, /* DENALI_CTL_239_DATA */ - 0x00000303, /* DENALI_CTL_240_DATA */ - 0x00000000, /* DENALI_CTL_241_DATA */ - 0x00000000, /* DENALI_CTL_242_DATA */ - 0x00000000, /* DENALI_CTL_243_DATA */ - 0x00000000, /* DENALI_CTL_244_DATA */ - 0x00000000, /* DENALI_CTL_245_DATA */ - 0x00000000, /* DENALI_CTL_246_DATA */ - 0x00000000, /* DENALI_CTL_247_DATA */ - 0x00000000, /* DENALI_CTL_248_DATA */ - 0x00000000, /* DENALI_CTL_249_DATA */ - 0x00000000, /* DENALI_CTL_250_DATA */ - 0x00000000, /* DENALI_CTL_251_DATA */ - 0x00000000, /* DENALI_CTL_252_DATA */ - 0x00000000, /* DENALI_CTL_253_DATA */ - 0x00000000, /* DENALI_CTL_254_DATA */ - 0x00000000, /* DENALI_CTL_255_DATA */ - 0x000556aa, /* DENALI_CTL_256_DATA */ - 0x000aaaaa, /* DENALI_CTL_257_DATA */ - 0x000aa955, /* DENALI_CTL_258_DATA */ - 0x00055555, /* DENALI_CTL_259_DATA */ - 0x000b3133, /* DENALI_CTL_260_DATA */ - 0x0004cd33, /* DENALI_CTL_261_DATA */ - 0x0004cecc, /* DENALI_CTL_262_DATA */ - 0x000b32cc, /* DENALI_CTL_263_DATA */ - 0x00010300, /* DENALI_CTL_264_DATA */ - 0x03000100, /* DENALI_CTL_265_DATA */ - 0x00000000, /* DENALI_CTL_266_DATA */ - 0x00000000, /* DENALI_CTL_267_DATA */ - 0x00000000, /* DENALI_CTL_268_DATA */ - 0x00000000, /* DENALI_CTL_269_DATA */ - 0x00000000, /* DENALI_CTL_270_DATA */ - 0x00000000, /* DENALI_CTL_271_DATA */ - 0x00000000, /* DENALI_CTL_272_DATA */ - 0x00000000, /* DENALI_CTL_273_DATA */ - 0x00ffff00, /* DENALI_CTL_274_DATA */ - 0x20200000, /* DENALI_CTL_275_DATA */ - 0x08000020, /* DENALI_CTL_276_DATA */ - 0x00001c62, /* DENALI_CTL_277_DATA */ - 0x00000200, /* DENALI_CTL_278_DATA */ - 0x00000200, /* DENALI_CTL_279_DATA */ - 0x00000200, /* DENALI_CTL_280_DATA */ - 0x00000200, /* DENALI_CTL_281_DATA */ - 0x00001c62, /* DENALI_CTL_282_DATA */ - 0x00011bd4, /* DENALI_CTL_283_DATA */ - 0x1c62070c, /* DENALI_CTL_284_DATA */ - 0x00000200, /* DENALI_CTL_285_DATA */ - 0x00000200, /* DENALI_CTL_286_DATA */ - 0x00000200, /* DENALI_CTL_287_DATA */ - 0x00000200, /* DENALI_CTL_288_DATA */ - 0x00001c62, /* DENALI_CTL_289_DATA */ - 0x00011bd4, /* DENALI_CTL_290_DATA */ - 0x1c62070c, /* DENALI_CTL_291_DATA */ - 0x00000200, /* DENALI_CTL_292_DATA */ - 0x00000200, /* DENALI_CTL_293_DATA */ - 0x00000200, /* DENALI_CTL_294_DATA */ - 0x00000200, /* DENALI_CTL_295_DATA */ - 0x00001c62, /* DENALI_CTL_296_DATA */ - 0x00011bd4, /* DENALI_CTL_297_DATA */ - 0x0202070c, /* DENALI_CTL_298_DATA */ - 0x03030202, /* DENALI_CTL_299_DATA */ - 0x00000018, /* DENALI_CTL_300_DATA */ - 0x00000000, /* DENALI_CTL_301_DATA */ - 0x00000000, /* DENALI_CTL_302_DATA */ - 0x00001403, /* DENALI_CTL_303_DATA */ - 0x00000000, /* DENALI_CTL_304_DATA */ - 0x00000000, /* DENALI_CTL_305_DATA */ - 0x00000000, /* DENALI_CTL_306_DATA */ - 0x00030000, /* DENALI_CTL_307_DATA */ - 0x000f0021, /* DENALI_CTL_308_DATA */ - 0x000f0021, /* DENALI_CTL_309_DATA */ - 0x000f0021, /* DENALI_CTL_310_DATA */ - 0x00000000, /* DENALI_CTL_311_DATA */ - 0x00000000, /* DENALI_CTL_312_DATA */ - 0x01000000, /* DENALI_CTL_313_DATA */ - 0x02090209, /* DENALI_CTL_314_DATA */ - 0x00050209, /* DENALI_CTL_315_DATA */ - 0x00000000, /* DENALI_CTL_316_DATA */ - 0x00000000, /* DENALI_CTL_317_DATA */ - 0x00000000, /* DENALI_CTL_318_DATA */ - 0x00000000, /* DENALI_CTL_319_DATA */ - 0x00000000, /* DENALI_CTL_320_DATA */ - 0x00000000, /* DENALI_CTL_321_DATA */ - 0x00000000, /* DENALI_CTL_322_DATA */ - 0x00000000, /* DENALI_CTL_323_DATA */ - 0x01000101, /* DENALI_CTL_324_DATA */ - 0x01010101, /* DENALI_CTL_325_DATA */ - 0x01000101, /* DENALI_CTL_326_DATA */ - 0x01000100, /* DENALI_CTL_327_DATA */ - 0x00010001, /* DENALI_CTL_328_DATA */ - 0x00010002, /* DENALI_CTL_329_DATA */ - 0x00020100, /* DENALI_CTL_330_DATA */ - 0x00000002 /* DENALI_CTL_331_DATA */ - } - }, - { - { - 0x00000700, /* DENALI_PI_00_DATA */ - 0x00000000, /* DENALI_PI_01_DATA */ - 0x000038c4, /* DENALI_PI_02_DATA */ - 0x00001c62, /* DENALI_PI_03_DATA */ - 0x000038c4, /* DENALI_PI_04_DATA */ - 0x00001c62, /* DENALI_PI_05_DATA */ - 0x000038c4, /* DENALI_PI_06_DATA */ - 0x1c621c62, /* DENALI_PI_07_DATA */ - 0x00000200, /* DENALI_PI_08_DATA */ - 0x00000200, /* DENALI_PI_09_DATA */ - 0x00000200, /* DENALI_PI_10_DATA */ - 0x00000200, /* DENALI_PI_11_DATA */ - 0x00001c62, /* DENALI_PI_12_DATA */ - 0x00000200, /* DENALI_PI_13_DATA */ - 0x00000200, /* DENALI_PI_14_DATA */ - 0x00000200, /* DENALI_PI_15_DATA */ - 0x00000200, /* DENALI_PI_16_DATA */ - 0x00001c62, /* DENALI_PI_17_DATA */ - 0x00000200, /* DENALI_PI_18_DATA */ - 0x00000200, /* DENALI_PI_19_DATA */ - 0x00000200, /* DENALI_PI_20_DATA */ - 0x00000200, /* DENALI_PI_21_DATA */ - 0x00010000, /* DENALI_PI_22_DATA */ - 0x00000007, /* DENALI_PI_23_DATA */ - 0x81000001, /* DENALI_PI_24_DATA */ - 0x0f0003f0, /* DENALI_PI_25_DATA */ - 0x3fffffff, /* DENALI_PI_26_DATA */ - 0x0f0000a0, /* DENALI_PI_27_DATA */ - 0x377ff000, /* DENALI_PI_28_DATA */ - 0x0f000020, /* DENALI_PI_29_DATA */ - 0x377ff000, /* DENALI_PI_30_DATA */ - 0x0f000030, /* DENALI_PI_31_DATA */ - 0x377ff000, /* DENALI_PI_32_DATA */ - 0x0f0000b0, /* DENALI_PI_33_DATA */ - 0x377ff000, /* DENALI_PI_34_DATA */ - 0x0f000100, /* DENALI_PI_35_DATA */ - 0x377ff000, /* DENALI_PI_36_DATA */ - 0x0f000110, /* DENALI_PI_37_DATA */ - 0x377ff000, /* DENALI_PI_38_DATA */ - 0x0f000010, /* DENALI_PI_39_DATA */ - 0x377ff000, /* DENALI_PI_40_DATA */ - 0x03000101, /* DENALI_PI_41_DATA */ - 0x04323232, /* DENALI_PI_42_DATA */ - 0x081c0008, /* DENALI_PI_43_DATA */ - 0x00081c00, /* DENALI_PI_44_DATA */ - 0x0000001c, /* DENALI_PI_45_DATA */ - 0x0e3100c5, /* DENALI_PI_46_DATA */ - 0x0e3100c5, /* DENALI_PI_47_DATA */ - 0x0e3100c5, /* DENALI_PI_48_DATA */ - 0x00000500, /* DENALI_PI_49_DATA */ - 0x00000000, /* DENALI_PI_50_DATA */ - 0x00000000, /* DENALI_PI_51_DATA */ - 0x00000000, /* DENALI_PI_52_DATA */ - 0x00000000, /* DENALI_PI_53_DATA */ - 0x00000000, /* DENALI_PI_54_DATA */ - 0x00000000, /* DENALI_PI_55_DATA */ - 0x00000000, /* DENALI_PI_56_DATA */ - 0x00000000, /* DENALI_PI_57_DATA */ - 0x04040000, /* DENALI_PI_58_DATA */ - 0x0d000004, /* DENALI_PI_59_DATA */ - 0x00000128, /* DENALI_PI_60_DATA */ - 0x00000000, /* DENALI_PI_61_DATA */ - 0x00030003, /* DENALI_PI_62_DATA */ - 0x00000018, /* DENALI_PI_63_DATA */ - 0x00000000, /* DENALI_PI_64_DATA */ - 0x00000000, /* DENALI_PI_65_DATA */ - 0x04060002, /* DENALI_PI_66_DATA */ - 0x04010401, /* DENALI_PI_67_DATA */ - 0x01080801, /* DENALI_PI_68_DATA */ - 0x04020201, /* DENALI_PI_69_DATA */ - 0x01080804, /* DENALI_PI_70_DATA */ - 0x00000000, /* DENALI_PI_71_DATA */ - 0x04040000, /* DENALI_PI_72_DATA */ - 0x0c0c0c04, /* DENALI_PI_73_DATA */ - 0x00000000, /* DENALI_PI_74_DATA */ - 0x00000000, /* DENALI_PI_75_DATA */ - 0x00000000, /* DENALI_PI_76_DATA */ - 0x00030300, /* DENALI_PI_77_DATA */ - 0x00000014, /* DENALI_PI_78_DATA */ - 0x00000000, /* DENALI_PI_79_DATA */ - 0x01010300, /* DENALI_PI_80_DATA */ - 0x00000000, /* DENALI_PI_81_DATA */ - 0x00000000, /* DENALI_PI_82_DATA */ - 0x01000000, /* DENALI_PI_83_DATA */ - 0x00000101, /* DENALI_PI_84_DATA */ - 0x55555a5a, /* DENALI_PI_85_DATA */ - 0x55555a5a, /* DENALI_PI_86_DATA */ - 0x55555a5a, /* DENALI_PI_87_DATA */ - 0x55555a5a, /* DENALI_PI_88_DATA */ - 0x0c0c0001, /* DENALI_PI_89_DATA */ - 0x0707000c, /* DENALI_PI_90_DATA */ - 0x02020007, /* DENALI_PI_91_DATA */ - 0x00000102, /* DENALI_PI_92_DATA */ - 0x00030000, /* DENALI_PI_93_DATA */ - 0x17030000, /* DENALI_PI_94_DATA */ - 0x000f0021, /* DENALI_PI_95_DATA */ - 0x000f0021, /* DENALI_PI_96_DATA */ - 0x000f0021, /* DENALI_PI_97_DATA */ - 0x00000000, /* DENALI_PI_98_DATA */ - 0x00000000, /* DENALI_PI_99_DATA */ - 0x00000100, /* DENALI_PI_100_DATA */ - 0x140a0000, /* DENALI_PI_101_DATA */ - 0x000a030a, /* DENALI_PI_102_DATA */ - 0x03000a03, /* DENALI_PI_103_DATA */ - 0x010a000a, /* DENALI_PI_104_DATA */ - 0x00000100, /* DENALI_PI_105_DATA */ - 0x01000000, /* DENALI_PI_106_DATA */ - 0x00000000, /* DENALI_PI_107_DATA */ - 0x00000100, /* DENALI_PI_108_DATA */ - 0x1e1a0000, /* DENALI_PI_109_DATA */ - 0x10010204, /* DENALI_PI_110_DATA */ - 0x07070705, /* DENALI_PI_111_DATA */ - 0x20000202, /* DENALI_PI_112_DATA */ - 0x00201000, /* DENALI_PI_113_DATA */ - 0x00201000, /* DENALI_PI_114_DATA */ - 0x04041000, /* DENALI_PI_115_DATA */ - 0x12120100, /* DENALI_PI_116_DATA */ - 0x00010112, /* DENALI_PI_117_DATA */ - 0x004b004a, /* DENALI_PI_118_DATA */ - 0x1a030000, /* DENALI_PI_119_DATA */ - 0x0102041e, /* DENALI_PI_120_DATA */ - 0x34000000, /* DENALI_PI_121_DATA */ - 0x00000000, /* DENALI_PI_122_DATA */ - 0x00000000, /* DENALI_PI_123_DATA */ - 0x00000000, /* DENALI_PI_124_DATA */ - 0x0000c300, /* DENALI_PI_125_DATA */ - 0x0001001c, /* DENALI_PI_126_DATA */ - 0x004d4d07, /* DENALI_PI_127_DATA */ - 0x001c00c3, /* DENALI_PI_128_DATA */ - 0x4d070001, /* DENALI_PI_129_DATA */ - 0x0000c34d, /* DENALI_PI_130_DATA */ - 0x0001001c, /* DENALI_PI_131_DATA */ - 0x004d4d07, /* DENALI_PI_132_DATA */ - 0x001c00c3, /* DENALI_PI_133_DATA */ - 0x4d070001, /* DENALI_PI_134_DATA */ - 0x0000c34d, /* DENALI_PI_135_DATA */ - 0x0001001c, /* DENALI_PI_136_DATA */ - 0x004d4d07, /* DENALI_PI_137_DATA */ - 0x001c00c3, /* DENALI_PI_138_DATA */ - 0x4d070001, /* DENALI_PI_139_DATA */ - 0x00c3004d, /* DENALI_PI_140_DATA */ - 0x0001001c, /* DENALI_PI_141_DATA */ - 0x004d4d07, /* DENALI_PI_142_DATA */ - 0x001c00c3, /* DENALI_PI_143_DATA */ - 0x4d070001, /* DENALI_PI_144_DATA */ - 0x0000c34d, /* DENALI_PI_145_DATA */ - 0x0001001c, /* DENALI_PI_146_DATA */ - 0x004d4d07, /* DENALI_PI_147_DATA */ - 0x001c00c3, /* DENALI_PI_148_DATA */ - 0x4d070001, /* DENALI_PI_149_DATA */ - 0x0000c34d, /* DENALI_PI_150_DATA */ - 0x0001001c, /* DENALI_PI_151_DATA */ - 0x004d4d07, /* DENALI_PI_152_DATA */ - 0x001c00c3, /* DENALI_PI_153_DATA */ - 0x4d070001, /* DENALI_PI_154_DATA */ - 0x0100004d, /* DENALI_PI_155_DATA */ - 0x00ea00ea, /* DENALI_PI_156_DATA */ - 0x080400ea, /* DENALI_PI_157_DATA */ - 0x0f081114, /* DENALI_PI_158_DATA */ - 0x2800fcc1, /* DENALI_PI_159_DATA */ - 0x0a0e2006, /* DENALI_PI_160_DATA */ - 0x1114080a, /* DENALI_PI_161_DATA */ - 0x00000f08, /* DENALI_PI_162_DATA */ - 0x2800fcc1, /* DENALI_PI_163_DATA */ - 0x0a0e2006, /* DENALI_PI_164_DATA */ - 0x1114080a, /* DENALI_PI_165_DATA */ - 0x00000f08, /* DENALI_PI_166_DATA */ - 0x2800fcc1, /* DENALI_PI_167_DATA */ - 0x0a0e2006, /* DENALI_PI_168_DATA */ - 0x0200020a, /* DENALI_PI_169_DATA */ - 0x02000200, /* DENALI_PI_170_DATA */ - 0x02000200, /* DENALI_PI_171_DATA */ - 0x02000200, /* DENALI_PI_172_DATA */ - 0x02000200, /* DENALI_PI_173_DATA */ - 0x00000000, /* DENALI_PI_174_DATA */ - 0x00000000, /* DENALI_PI_175_DATA */ - 0x00000000, /* DENALI_PI_176_DATA */ - 0x00000000, /* DENALI_PI_177_DATA */ - 0x00000000, /* DENALI_PI_178_DATA */ - 0x00000000, /* DENALI_PI_179_DATA */ - 0x00000000, /* DENALI_PI_180_DATA */ - 0x00000000, /* DENALI_PI_181_DATA */ - 0x00000000, /* DENALI_PI_182_DATA */ - 0x00000000, /* DENALI_PI_183_DATA */ - 0x00000000, /* DENALI_PI_184_DATA */ - 0x00000000, /* DENALI_PI_185_DATA */ - 0x01000300, /* DENALI_PI_186_DATA */ - 0x001c6200, /* DENALI_PI_187_DATA */ - 0x00011bd4, /* DENALI_PI_188_DATA */ - 0x00001c62, /* DENALI_PI_189_DATA */ - 0x00011bd4, /* DENALI_PI_190_DATA */ - 0x00001c62, /* DENALI_PI_191_DATA */ - 0x00011bd4, /* DENALI_PI_192_DATA */ - 0x08000000, /* DENALI_PI_193_DATA */ - 0x00000100, /* DENALI_PI_194_DATA */ - 0x00000000, /* DENALI_PI_195_DATA */ - 0x00000000, /* DENALI_PI_196_DATA */ - 0x00000000, /* DENALI_PI_197_DATA */ - 0x00000000, /* DENALI_PI_198_DATA */ - 0x00000002 /* DENALI_PI_199_DATA */ - } - }, - { - { - 0x76543210, /* DENALI_PHY_00_DATA */ - 0x0004c008, /* DENALI_PHY_01_DATA */ - 0x000001a2, /* DENALI_PHY_02_DATA */ - 0x00000000, /* DENALI_PHY_03_DATA */ - 0x00000000, /* DENALI_PHY_04_DATA */ - 0x00010000, /* DENALI_PHY_05_DATA */ - 0x01665555, /* DENALI_PHY_06_DATA */ - 0x00665555, /* DENALI_PHY_07_DATA */ - 0x00010f00, /* DENALI_PHY_08_DATA */ - 0x06010200, /* DENALI_PHY_09_DATA */ - 0x00000003, /* DENALI_PHY_10_DATA */ - 0x001700c0, /* DENALI_PHY_11_DATA */ - 0x00cc0101, /* DENALI_PHY_12_DATA */ - 0x00030066, /* DENALI_PHY_13_DATA */ - 0x00000000, /* DENALI_PHY_14_DATA */ - 0x00000000, /* DENALI_PHY_15_DATA */ - 0x00000000, /* DENALI_PHY_16_DATA */ - 0x00000000, /* DENALI_PHY_17_DATA */ - 0x00000000, /* DENALI_PHY_18_DATA */ - 0x00000000, /* DENALI_PHY_19_DATA */ - 0x00000000, /* DENALI_PHY_20_DATA */ - 0x00000000, /* DENALI_PHY_21_DATA */ - 0x04080000, /* DENALI_PHY_22_DATA */ - 0x04080400, /* DENALI_PHY_23_DATA */ - 0x08000000, /* DENALI_PHY_24_DATA */ - 0x0c00c007, /* DENALI_PHY_25_DATA */ - 0x00000100, /* DENALI_PHY_26_DATA */ - 0x00000100, /* DENALI_PHY_27_DATA */ - 0x55555555, /* DENALI_PHY_28_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_29_DATA */ - 0x55555555, /* DENALI_PHY_30_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_31_DATA */ - 0x00005555, /* DENALI_PHY_32_DATA */ - 0x00000000, /* DENALI_PHY_33_DATA */ - 0x00000000, /* DENALI_PHY_34_DATA */ - 0x00000000, /* DENALI_PHY_35_DATA */ - 0x00000000, /* DENALI_PHY_36_DATA */ - 0x00000000, /* DENALI_PHY_37_DATA */ - 0x00000000, /* DENALI_PHY_38_DATA */ - 0x00000000, /* DENALI_PHY_39_DATA */ - 0x00000000, /* DENALI_PHY_40_DATA */ - 0x00000000, /* DENALI_PHY_41_DATA */ - 0x00000000, /* DENALI_PHY_42_DATA */ - 0x00000000, /* DENALI_PHY_43_DATA */ - 0x00000000, /* DENALI_PHY_44_DATA */ - 0x00000000, /* DENALI_PHY_45_DATA */ - 0x00000000, /* DENALI_PHY_46_DATA */ - 0x00000000, /* DENALI_PHY_47_DATA */ - 0x00000000, /* DENALI_PHY_48_DATA */ - 0x00000000, /* DENALI_PHY_49_DATA */ - 0x00000000, /* DENALI_PHY_50_DATA */ - 0x00000000, /* DENALI_PHY_51_DATA */ - 0x00200000, /* DENALI_PHY_52_DATA */ - 0x00000000, /* DENALI_PHY_53_DATA */ - 0x00000000, /* DENALI_PHY_54_DATA */ - 0x00000000, /* DENALI_PHY_55_DATA */ - 0x00000000, /* DENALI_PHY_56_DATA */ - 0x00000000, /* DENALI_PHY_57_DATA */ - 0x00000000, /* DENALI_PHY_58_DATA */ - 0x02600260, /* DENALI_PHY_59_DATA */ - 0x02600260, /* DENALI_PHY_60_DATA */ - 0x02600260, /* DENALI_PHY_61_DATA */ - 0x02600260, /* DENALI_PHY_62_DATA */ - 0x00000260, /* DENALI_PHY_63_DATA */ - 0x00000000, /* DENALI_PHY_64_DATA */ - 0x00000000, /* DENALI_PHY_65_DATA */ - 0x00000000, /* DENALI_PHY_66_DATA */ - 0x00000000, /* DENALI_PHY_67_DATA */ - 0x00800000, /* DENALI_PHY_68_DATA */ - 0x00800080, /* DENALI_PHY_69_DATA */ - 0x00800080, /* DENALI_PHY_70_DATA */ - 0x00800080, /* DENALI_PHY_71_DATA */ - 0x00800080, /* DENALI_PHY_72_DATA */ - 0x00800080, /* DENALI_PHY_73_DATA */ - 0x00800080, /* DENALI_PHY_74_DATA */ - 0x00800080, /* DENALI_PHY_75_DATA */ - 0x00800080, /* DENALI_PHY_76_DATA */ - 0x01a20080, /* DENALI_PHY_77_DATA */ - 0x01900003, /* DENALI_PHY_78_DATA */ - 0x00000000, /* DENALI_PHY_79_DATA */ - 0x00030000, /* DENALI_PHY_80_DATA */ - 0x00000200, /* DENALI_PHY_81_DATA */ - 0x00000000, /* DENALI_PHY_82_DATA */ - 0x51315152, /* DENALI_PHY_83_DATA */ - 0xc0013150, /* DENALI_PHY_84_DATA */ - 0x020000c0, /* DENALI_PHY_85_DATA */ - 0x00100001, /* DENALI_PHY_86_DATA */ - 0x0c064208, /* DENALI_PHY_87_DATA */ - 0x000f0c18, /* DENALI_PHY_88_DATA */ - 0x01000140, /* DENALI_PHY_89_DATA */ - 0x00000c20, /* DENALI_PHY_90_DATA */ - 0x00000000, /* DENALI_PHY_91_DATA */ - 0x00000000, /* DENALI_PHY_92_DATA */ - 0x00000000, /* DENALI_PHY_93_DATA */ - 0x00000000, /* DENALI_PHY_94_DATA */ - 0x00000000, /* DENALI_PHY_95_DATA */ - 0x00000000, /* DENALI_PHY_96_DATA */ - 0x00000000, /* DENALI_PHY_97_DATA */ - 0x00000000, /* DENALI_PHY_98_DATA */ - 0x00000000, /* DENALI_PHY_99_DATA */ - 0x00000000, /* DENALI_PHY_100_DATA */ - 0x00000000, /* DENALI_PHY_101_DATA */ - 0x00000000, /* DENALI_PHY_102_DATA */ - 0x00000000, /* DENALI_PHY_103_DATA */ - 0x00000000, /* DENALI_PHY_104_DATA */ - 0x00000000, /* DENALI_PHY_105_DATA */ - 0x00000000, /* DENALI_PHY_106_DATA */ - 0x00000000, /* DENALI_PHY_107_DATA */ - 0x00000000, /* DENALI_PHY_108_DATA */ - 0x00000000, /* DENALI_PHY_109_DATA */ - 0x00000000, /* DENALI_PHY_110_DATA */ - 0x00000000, /* DENALI_PHY_111_DATA */ - 0x00000000, /* DENALI_PHY_112_DATA */ - 0x00000000, /* DENALI_PHY_113_DATA */ - 0x00000000, /* DENALI_PHY_114_DATA */ - 0x00000000, /* DENALI_PHY_115_DATA */ - 0x00000000, /* DENALI_PHY_116_DATA */ - 0x00000000, /* DENALI_PHY_117_DATA */ - 0x00000000, /* DENALI_PHY_118_DATA */ - 0x00000000, /* DENALI_PHY_119_DATA */ - 0x00000000, /* DENALI_PHY_120_DATA */ - 0x00000000, /* DENALI_PHY_121_DATA */ - 0x00000000, /* DENALI_PHY_122_DATA */ - 0x00000000, /* DENALI_PHY_123_DATA */ - 0x00000000, /* DENALI_PHY_124_DATA */ - 0x00000000, /* DENALI_PHY_125_DATA */ - 0x00000000, /* DENALI_PHY_126_DATA */ - 0x00000000, /* DENALI_PHY_127_DATA */ - 0x76543210, /* DENALI_PHY_128_DATA */ - 0x0004c008, /* DENALI_PHY_129_DATA */ - 0x000001a2, /* DENALI_PHY_130_DATA */ - 0x00000000, /* DENALI_PHY_131_DATA */ - 0x00000000, /* DENALI_PHY_132_DATA */ - 0x00010000, /* DENALI_PHY_133_DATA */ - 0x01665555, /* DENALI_PHY_134_DATA */ - 0x00665555, /* DENALI_PHY_135_DATA */ - 0x00010f00, /* DENALI_PHY_136_DATA */ - 0x06010200, /* DENALI_PHY_137_DATA */ - 0x00000003, /* DENALI_PHY_138_DATA */ - 0x001700c0, /* DENALI_PHY_139_DATA */ - 0x00cc0101, /* DENALI_PHY_140_DATA */ - 0x00030066, /* DENALI_PHY_141_DATA */ - 0x00000000, /* DENALI_PHY_142_DATA */ - 0x00000000, /* DENALI_PHY_143_DATA */ - 0x00000000, /* DENALI_PHY_144_DATA */ - 0x00000000, /* DENALI_PHY_145_DATA */ - 0x00000000, /* DENALI_PHY_146_DATA */ - 0x00000000, /* DENALI_PHY_147_DATA */ - 0x00000000, /* DENALI_PHY_148_DATA */ - 0x00000000, /* DENALI_PHY_149_DATA */ - 0x04080000, /* DENALI_PHY_150_DATA */ - 0x04080400, /* DENALI_PHY_151_DATA */ - 0x08000000, /* DENALI_PHY_152_DATA */ - 0x0c00c007, /* DENALI_PHY_153_DATA */ - 0x00000100, /* DENALI_PHY_154_DATA */ - 0x00000100, /* DENALI_PHY_155_DATA */ - 0x55555555, /* DENALI_PHY_156_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_157_DATA */ - 0x55555555, /* DENALI_PHY_158_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_159_DATA */ - 0x00005555, /* DENALI_PHY_160_DATA */ - 0x00000000, /* DENALI_PHY_161_DATA */ - 0x00000000, /* DENALI_PHY_162_DATA */ - 0x00000000, /* DENALI_PHY_163_DATA */ - 0x00000000, /* DENALI_PHY_164_DATA */ - 0x00000000, /* DENALI_PHY_165_DATA */ - 0x00000000, /* DENALI_PHY_166_DATA */ - 0x00000000, /* DENALI_PHY_167_DATA */ - 0x00000000, /* DENALI_PHY_168_DATA */ - 0x00000000, /* DENALI_PHY_169_DATA */ - 0x00000000, /* DENALI_PHY_170_DATA */ - 0x00000000, /* DENALI_PHY_171_DATA */ - 0x00000000, /* DENALI_PHY_172_DATA */ - 0x00000000, /* DENALI_PHY_173_DATA */ - 0x00000000, /* DENALI_PHY_174_DATA */ - 0x00000000, /* DENALI_PHY_175_DATA */ - 0x00000000, /* DENALI_PHY_176_DATA */ - 0x00000000, /* DENALI_PHY_177_DATA */ - 0x00000000, /* DENALI_PHY_178_DATA */ - 0x00000000, /* DENALI_PHY_179_DATA */ - 0x00200000, /* DENALI_PHY_180_DATA */ - 0x00000000, /* DENALI_PHY_181_DATA */ - 0x00000000, /* DENALI_PHY_182_DATA */ - 0x00000000, /* DENALI_PHY_183_DATA */ - 0x00000000, /* DENALI_PHY_184_DATA */ - 0x00000000, /* DENALI_PHY_185_DATA */ - 0x00000000, /* DENALI_PHY_186_DATA */ - 0x02600260, /* DENALI_PHY_187_DATA */ - 0x02600260, /* DENALI_PHY_188_DATA */ - 0x02600260, /* DENALI_PHY_189_DATA */ - 0x02600260, /* DENALI_PHY_190_DATA */ - 0x00000260, /* DENALI_PHY_191_DATA */ - 0x00000000, /* DENALI_PHY_192_DATA */ - 0x00000000, /* DENALI_PHY_193_DATA */ - 0x00000000, /* DENALI_PHY_194_DATA */ - 0x00000000, /* DENALI_PHY_195_DATA */ - 0x00800000, /* DENALI_PHY_196_DATA */ - 0x00800080, /* DENALI_PHY_197_DATA */ - 0x00800080, /* DENALI_PHY_198_DATA */ - 0x00800080, /* DENALI_PHY_199_DATA */ - 0x00800080, /* DENALI_PHY_200_DATA */ - 0x00800080, /* DENALI_PHY_201_DATA */ - 0x00800080, /* DENALI_PHY_202_DATA */ - 0x00800080, /* DENALI_PHY_203_DATA */ - 0x00800080, /* DENALI_PHY_204_DATA */ - 0x01a20080, /* DENALI_PHY_205_DATA */ - 0x01900003, /* DENALI_PHY_206_DATA */ - 0x00000000, /* DENALI_PHY_207_DATA */ - 0x00030000, /* DENALI_PHY_208_DATA */ - 0x00000200, /* DENALI_PHY_209_DATA */ - 0x00000000, /* DENALI_PHY_210_DATA */ - 0x51315152, /* DENALI_PHY_211_DATA */ - 0xc0013150, /* DENALI_PHY_212_DATA */ - 0x020000c0, /* DENALI_PHY_213_DATA */ - 0x00100001, /* DENALI_PHY_214_DATA */ - 0x0c064208, /* DENALI_PHY_215_DATA */ - 0x000f0c18, /* DENALI_PHY_216_DATA */ - 0x01000140, /* DENALI_PHY_217_DATA */ - 0x00000c20, /* DENALI_PHY_218_DATA */ - 0x00000000, /* DENALI_PHY_219_DATA */ - 0x00000000, /* DENALI_PHY_220_DATA */ - 0x00000000, /* DENALI_PHY_221_DATA */ - 0x00000000, /* DENALI_PHY_222_DATA */ - 0x00000000, /* DENALI_PHY_223_DATA */ - 0x00000000, /* DENALI_PHY_224_DATA */ - 0x00000000, /* DENALI_PHY_225_DATA */ - 0x00000000, /* DENALI_PHY_226_DATA */ - 0x00000000, /* DENALI_PHY_227_DATA */ - 0x00000000, /* DENALI_PHY_228_DATA */ - 0x00000000, /* DENALI_PHY_229_DATA */ - 0x00000000, /* DENALI_PHY_230_DATA */ - 0x00000000, /* DENALI_PHY_231_DATA */ - 0x00000000, /* DENALI_PHY_232_DATA */ - 0x00000000, /* DENALI_PHY_233_DATA */ - 0x00000000, /* DENALI_PHY_234_DATA */ - 0x00000000, /* DENALI_PHY_235_DATA */ - 0x00000000, /* DENALI_PHY_236_DATA */ - 0x00000000, /* DENALI_PHY_237_DATA */ - 0x00000000, /* DENALI_PHY_238_DATA */ - 0x00000000, /* DENALI_PHY_239_DATA */ - 0x00000000, /* DENALI_PHY_240_DATA */ - 0x00000000, /* DENALI_PHY_241_DATA */ - 0x00000000, /* DENALI_PHY_242_DATA */ - 0x00000000, /* DENALI_PHY_243_DATA */ - 0x00000000, /* DENALI_PHY_244_DATA */ - 0x00000000, /* DENALI_PHY_245_DATA */ - 0x00000000, /* DENALI_PHY_246_DATA */ - 0x00000000, /* DENALI_PHY_247_DATA */ - 0x00000000, /* DENALI_PHY_248_DATA */ - 0x00000000, /* DENALI_PHY_249_DATA */ - 0x00000000, /* DENALI_PHY_250_DATA */ - 0x00000000, /* DENALI_PHY_251_DATA */ - 0x00000000, /* DENALI_PHY_252_DATA */ - 0x00000000, /* DENALI_PHY_253_DATA */ - 0x00000000, /* DENALI_PHY_254_DATA */ - 0x00000000, /* DENALI_PHY_255_DATA */ - 0x76543210, /* DENALI_PHY_256_DATA */ - 0x0004c008, /* DENALI_PHY_257_DATA */ - 0x000001a2, /* DENALI_PHY_258_DATA */ - 0x00000000, /* DENALI_PHY_259_DATA */ - 0x00000000, /* DENALI_PHY_260_DATA */ - 0x00010000, /* DENALI_PHY_261_DATA */ - 0x01665555, /* DENALI_PHY_262_DATA */ - 0x00665555, /* DENALI_PHY_263_DATA */ - 0x00010f00, /* DENALI_PHY_264_DATA */ - 0x06010200, /* DENALI_PHY_265_DATA */ - 0x00000003, /* DENALI_PHY_266_DATA */ - 0x001700c0, /* DENALI_PHY_267_DATA */ - 0x00cc0101, /* DENALI_PHY_268_DATA */ - 0x00030066, /* DENALI_PHY_269_DATA */ - 0x00000000, /* DENALI_PHY_270_DATA */ - 0x00000000, /* DENALI_PHY_271_DATA */ - 0x00000000, /* DENALI_PHY_272_DATA */ - 0x00000000, /* DENALI_PHY_273_DATA */ - 0x00000000, /* DENALI_PHY_274_DATA */ - 0x00000000, /* DENALI_PHY_275_DATA */ - 0x00000000, /* DENALI_PHY_276_DATA */ - 0x00000000, /* DENALI_PHY_277_DATA */ - 0x04080000, /* DENALI_PHY_278_DATA */ - 0x04080400, /* DENALI_PHY_279_DATA */ - 0x08000000, /* DENALI_PHY_280_DATA */ - 0x0c00c007, /* DENALI_PHY_281_DATA */ - 0x00000100, /* DENALI_PHY_282_DATA */ - 0x00000100, /* DENALI_PHY_283_DATA */ - 0x55555555, /* DENALI_PHY_284_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_285_DATA */ - 0x55555555, /* DENALI_PHY_286_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_287_DATA */ - 0x00005555, /* DENALI_PHY_288_DATA */ - 0x00000000, /* DENALI_PHY_289_DATA */ - 0x00000000, /* DENALI_PHY_290_DATA */ - 0x00000000, /* DENALI_PHY_291_DATA */ - 0x00000000, /* DENALI_PHY_292_DATA */ - 0x00000000, /* DENALI_PHY_293_DATA */ - 0x00000000, /* DENALI_PHY_294_DATA */ - 0x00000000, /* DENALI_PHY_295_DATA */ - 0x00000000, /* DENALI_PHY_296_DATA */ - 0x00000000, /* DENALI_PHY_297_DATA */ - 0x00000000, /* DENALI_PHY_298_DATA */ - 0x00000000, /* DENALI_PHY_299_DATA */ - 0x00000000, /* DENALI_PHY_300_DATA */ - 0x00000000, /* DENALI_PHY_301_DATA */ - 0x00000000, /* DENALI_PHY_302_DATA */ - 0x00000000, /* DENALI_PHY_303_DATA */ - 0x00000000, /* DENALI_PHY_304_DATA */ - 0x00000000, /* DENALI_PHY_305_DATA */ - 0x00000000, /* DENALI_PHY_306_DATA */ - 0x00000000, /* DENALI_PHY_307_DATA */ - 0x00200000, /* DENALI_PHY_308_DATA */ - 0x00000000, /* DENALI_PHY_309_DATA */ - 0x00000000, /* DENALI_PHY_310_DATA */ - 0x00000000, /* DENALI_PHY_311_DATA */ - 0x00000000, /* DENALI_PHY_312_DATA */ - 0x00000000, /* DENALI_PHY_313_DATA */ - 0x00000000, /* DENALI_PHY_314_DATA */ - 0x02600260, /* DENALI_PHY_315_DATA */ - 0x02600260, /* DENALI_PHY_316_DATA */ - 0x02600260, /* DENALI_PHY_317_DATA */ - 0x02600260, /* DENALI_PHY_318_DATA */ - 0x00000260, /* DENALI_PHY_319_DATA */ - 0x00000000, /* DENALI_PHY_320_DATA */ - 0x00000000, /* DENALI_PHY_321_DATA */ - 0x00000000, /* DENALI_PHY_322_DATA */ - 0x00000000, /* DENALI_PHY_323_DATA */ - 0x00800000, /* DENALI_PHY_324_DATA */ - 0x00800080, /* DENALI_PHY_325_DATA */ - 0x00800080, /* DENALI_PHY_326_DATA */ - 0x00800080, /* DENALI_PHY_327_DATA */ - 0x00800080, /* DENALI_PHY_328_DATA */ - 0x00800080, /* DENALI_PHY_329_DATA */ - 0x00800080, /* DENALI_PHY_330_DATA */ - 0x00800080, /* DENALI_PHY_331_DATA */ - 0x00800080, /* DENALI_PHY_332_DATA */ - 0x01a20080, /* DENALI_PHY_333_DATA */ - 0x01900003, /* DENALI_PHY_334_DATA */ - 0x00000000, /* DENALI_PHY_335_DATA */ - 0x00030000, /* DENALI_PHY_336_DATA */ - 0x00000200, /* DENALI_PHY_337_DATA */ - 0x00000000, /* DENALI_PHY_338_DATA */ - 0x51315152, /* DENALI_PHY_339_DATA */ - 0xc0013150, /* DENALI_PHY_340_DATA */ - 0x020000c0, /* DENALI_PHY_341_DATA */ - 0x00100001, /* DENALI_PHY_342_DATA */ - 0x0c064208, /* DENALI_PHY_343_DATA */ - 0x000f0c18, /* DENALI_PHY_344_DATA */ - 0x01000140, /* DENALI_PHY_345_DATA */ - 0x00000c20, /* DENALI_PHY_346_DATA */ - 0x00000000, /* DENALI_PHY_347_DATA */ - 0x00000000, /* DENALI_PHY_348_DATA */ - 0x00000000, /* DENALI_PHY_349_DATA */ - 0x00000000, /* DENALI_PHY_350_DATA */ - 0x00000000, /* DENALI_PHY_351_DATA */ - 0x00000000, /* DENALI_PHY_352_DATA */ - 0x00000000, /* DENALI_PHY_353_DATA */ - 0x00000000, /* DENALI_PHY_354_DATA */ - 0x00000000, /* DENALI_PHY_355_DATA */ - 0x00000000, /* DENALI_PHY_356_DATA */ - 0x00000000, /* DENALI_PHY_357_DATA */ - 0x00000000, /* DENALI_PHY_358_DATA */ - 0x00000000, /* DENALI_PHY_359_DATA */ - 0x00000000, /* DENALI_PHY_360_DATA */ - 0x00000000, /* DENALI_PHY_361_DATA */ - 0x00000000, /* DENALI_PHY_362_DATA */ - 0x00000000, /* DENALI_PHY_363_DATA */ - 0x00000000, /* DENALI_PHY_364_DATA */ - 0x00000000, /* DENALI_PHY_365_DATA */ - 0x00000000, /* DENALI_PHY_366_DATA */ - 0x00000000, /* DENALI_PHY_367_DATA */ - 0x00000000, /* DENALI_PHY_368_DATA */ - 0x00000000, /* DENALI_PHY_369_DATA */ - 0x00000000, /* DENALI_PHY_370_DATA */ - 0x00000000, /* DENALI_PHY_371_DATA */ - 0x00000000, /* DENALI_PHY_372_DATA */ - 0x00000000, /* DENALI_PHY_373_DATA */ - 0x00000000, /* DENALI_PHY_374_DATA */ - 0x00000000, /* DENALI_PHY_375_DATA */ - 0x00000000, /* DENALI_PHY_376_DATA */ - 0x00000000, /* DENALI_PHY_377_DATA */ - 0x00000000, /* DENALI_PHY_378_DATA */ - 0x00000000, /* DENALI_PHY_379_DATA */ - 0x00000000, /* DENALI_PHY_380_DATA */ - 0x00000000, /* DENALI_PHY_381_DATA */ - 0x00000000, /* DENALI_PHY_382_DATA */ - 0x00000000, /* DENALI_PHY_383_DATA */ - 0x76543210, /* DENALI_PHY_384_DATA */ - 0x0004c008, /* DENALI_PHY_385_DATA */ - 0x000001a2, /* DENALI_PHY_386_DATA */ - 0x00000000, /* DENALI_PHY_387_DATA */ - 0x00000000, /* DENALI_PHY_388_DATA */ - 0x00010000, /* DENALI_PHY_389_DATA */ - 0x01665555, /* DENALI_PHY_390_DATA */ - 0x00665555, /* DENALI_PHY_391_DATA */ - 0x00010f00, /* DENALI_PHY_392_DATA */ - 0x06010200, /* DENALI_PHY_393_DATA */ - 0x00000003, /* DENALI_PHY_394_DATA */ - 0x001700c0, /* DENALI_PHY_395_DATA */ - 0x00cc0101, /* DENALI_PHY_396_DATA */ - 0x00030066, /* DENALI_PHY_397_DATA */ - 0x00000000, /* DENALI_PHY_398_DATA */ - 0x00000000, /* DENALI_PHY_399_DATA */ - 0x00000000, /* DENALI_PHY_400_DATA */ - 0x00000000, /* DENALI_PHY_401_DATA */ - 0x00000000, /* DENALI_PHY_402_DATA */ - 0x00000000, /* DENALI_PHY_403_DATA */ - 0x00000000, /* DENALI_PHY_404_DATA */ - 0x00000000, /* DENALI_PHY_405_DATA */ - 0x04080000, /* DENALI_PHY_406_DATA */ - 0x04080400, /* DENALI_PHY_407_DATA */ - 0x08000000, /* DENALI_PHY_408_DATA */ - 0x0c00c007, /* DENALI_PHY_409_DATA */ - 0x00000100, /* DENALI_PHY_410_DATA */ - 0x00000100, /* DENALI_PHY_411_DATA */ - 0x55555555, /* DENALI_PHY_412_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_413_DATA */ - 0x55555555, /* DENALI_PHY_414_DATA */ - 0xaaaaaaaa, /* DENALI_PHY_415_DATA */ - 0x00005555, /* DENALI_PHY_416_DATA */ - 0x00000000, /* DENALI_PHY_417_DATA */ - 0x00000000, /* DENALI_PHY_418_DATA */ - 0x00000000, /* DENALI_PHY_419_DATA */ - 0x00000000, /* DENALI_PHY_420_DATA */ - 0x00000000, /* DENALI_PHY_421_DATA */ - 0x00000000, /* DENALI_PHY_422_DATA */ - 0x00000000, /* DENALI_PHY_423_DATA */ - 0x00000000, /* DENALI_PHY_424_DATA */ - 0x00000000, /* DENALI_PHY_425_DATA */ - 0x00000000, /* DENALI_PHY_426_DATA */ - 0x00000000, /* DENALI_PHY_427_DATA */ - 0x00000000, /* DENALI_PHY_428_DATA */ - 0x00000000, /* DENALI_PHY_429_DATA */ - 0x00000000, /* DENALI_PHY_430_DATA */ - 0x00000000, /* DENALI_PHY_431_DATA */ - 0x00000000, /* DENALI_PHY_432_DATA */ - 0x00000000, /* DENALI_PHY_433_DATA */ - 0x00000000, /* DENALI_PHY_434_DATA */ - 0x00000000, /* DENALI_PHY_435_DATA */ - 0x00200000, /* DENALI_PHY_436_DATA */ - 0x00000000, /* DENALI_PHY_437_DATA */ - 0x00000000, /* DENALI_PHY_438_DATA */ - 0x00000000, /* DENALI_PHY_439_DATA */ - 0x00000000, /* DENALI_PHY_440_DATA */ - 0x00000000, /* DENALI_PHY_441_DATA */ - 0x00000000, /* DENALI_PHY_442_DATA */ - 0x02600260, /* DENALI_PHY_443_DATA */ - 0x02600260, /* DENALI_PHY_444_DATA */ - 0x02600260, /* DENALI_PHY_445_DATA */ - 0x02600260, /* DENALI_PHY_446_DATA */ - 0x00000260, /* DENALI_PHY_447_DATA */ - 0x00000000, /* DENALI_PHY_448_DATA */ - 0x00000000, /* DENALI_PHY_449_DATA */ - 0x00000000, /* DENALI_PHY_450_DATA */ - 0x00000000, /* DENALI_PHY_451_DATA */ - 0x00800000, /* DENALI_PHY_452_DATA */ - 0x00800080, /* DENALI_PHY_453_DATA */ - 0x00800080, /* DENALI_PHY_454_DATA */ - 0x00800080, /* DENALI_PHY_455_DATA */ - 0x00800080, /* DENALI_PHY_456_DATA */ - 0x00800080, /* DENALI_PHY_457_DATA */ - 0x00800080, /* DENALI_PHY_458_DATA */ - 0x00800080, /* DENALI_PHY_459_DATA */ - 0x00800080, /* DENALI_PHY_460_DATA */ - 0x01a20080, /* DENALI_PHY_461_DATA */ - 0x01900003, /* DENALI_PHY_462_DATA */ - 0x00000000, /* DENALI_PHY_463_DATA */ - 0x00030000, /* DENALI_PHY_464_DATA */ - 0x00000200, /* DENALI_PHY_465_DATA */ - 0x00000000, /* DENALI_PHY_466_DATA */ - 0x51315152, /* DENALI_PHY_467_DATA */ - 0xc0013150, /* DENALI_PHY_468_DATA */ - 0x020000c0, /* DENALI_PHY_469_DATA */ - 0x00100001, /* DENALI_PHY_470_DATA */ - 0x0c064208, /* DENALI_PHY_471_DATA */ - 0x000f0c18, /* DENALI_PHY_472_DATA */ - 0x01000140, /* DENALI_PHY_473_DATA */ - 0x00000c20, /* DENALI_PHY_474_DATA */ - 0x00000000, /* DENALI_PHY_475_DATA */ - 0x00000000, /* DENALI_PHY_476_DATA */ - 0x00000000, /* DENALI_PHY_477_DATA */ - 0x00000000, /* DENALI_PHY_478_DATA */ - 0x00000000, /* DENALI_PHY_479_DATA */ - 0x00000000, /* DENALI_PHY_480_DATA */ - 0x00000000, /* DENALI_PHY_481_DATA */ - 0x00000000, /* DENALI_PHY_482_DATA */ - 0x00000000, /* DENALI_PHY_483_DATA */ - 0x00000000, /* DENALI_PHY_484_DATA */ - 0x00000000, /* DENALI_PHY_485_DATA */ - 0x00000000, /* DENALI_PHY_486_DATA */ - 0x00000000, /* DENALI_PHY_487_DATA */ - 0x00000000, /* DENALI_PHY_488_DATA */ - 0x00000000, /* DENALI_PHY_489_DATA */ - 0x00000000, /* DENALI_PHY_490_DATA */ - 0x00000000, /* DENALI_PHY_491_DATA */ - 0x00000000, /* DENALI_PHY_492_DATA */ - 0x00000000, /* DENALI_PHY_493_DATA */ - 0x00000000, /* DENALI_PHY_494_DATA */ - 0x00000000, /* DENALI_PHY_495_DATA */ - 0x00000000, /* DENALI_PHY_496_DATA */ - 0x00000000, /* DENALI_PHY_497_DATA */ - 0x00000000, /* DENALI_PHY_498_DATA */ - 0x00000000, /* DENALI_PHY_499_DATA */ - 0x00000000, /* DENALI_PHY_500_DATA */ - 0x00000000, /* DENALI_PHY_501_DATA */ - 0x00000000, /* DENALI_PHY_502_DATA */ - 0x00000000, /* DENALI_PHY_503_DATA */ - 0x00000000, /* DENALI_PHY_504_DATA */ - 0x00000000, /* DENALI_PHY_505_DATA */ - 0x00000000, /* DENALI_PHY_506_DATA */ - 0x00000000, /* DENALI_PHY_507_DATA */ - 0x00000000, /* DENALI_PHY_508_DATA */ - 0x00000000, /* DENALI_PHY_509_DATA */ - 0x00000000, /* DENALI_PHY_510_DATA */ - 0x00000000, /* DENALI_PHY_511_DATA */ - 0x00000000, /* DENALI_PHY_512_DATA */ - 0x00800000, /* DENALI_PHY_513_DATA */ - 0x00000000, /* DENALI_PHY_514_DATA */ - 0x00000000, /* DENALI_PHY_515_DATA */ - 0x00000000, /* DENALI_PHY_516_DATA */ - 0x00000000, /* DENALI_PHY_517_DATA */ - 0x00000000, /* DENALI_PHY_518_DATA */ - 0x00000001, /* DENALI_PHY_519_DATA */ - 0x00000000, /* DENALI_PHY_520_DATA */ - 0x00000000, /* DENALI_PHY_521_DATA */ - 0x00000000, /* DENALI_PHY_522_DATA */ - 0x00400320, /* DENALI_PHY_523_DATA */ - 0x00000040, /* DENALI_PHY_524_DATA */ - 0x00806420, /* DENALI_PHY_525_DATA */ - 0x00917531, /* DENALI_PHY_526_DATA */ - 0x00806420, /* DENALI_PHY_527_DATA */ - 0x01917531, /* DENALI_PHY_528_DATA */ - 0x00020003, /* DENALI_PHY_529_DATA */ - 0x00000000, /* DENALI_PHY_530_DATA */ - 0x00000000, /* DENALI_PHY_531_DATA */ - 0x00000000, /* DENALI_PHY_532_DATA */ - 0x000556aa, /* DENALI_PHY_533_DATA */ - 0x000aaaaa, /* DENALI_PHY_534_DATA */ - 0x000aa955, /* DENALI_PHY_535_DATA */ - 0x00055555, /* DENALI_PHY_536_DATA */ - 0x000b3133, /* DENALI_PHY_537_DATA */ - 0x0004cd33, /* DENALI_PHY_538_DATA */ - 0x0004cecc, /* DENALI_PHY_539_DATA */ - 0x000b32cc, /* DENALI_PHY_540_DATA */ - 0x0a418820, /* DENALI_PHY_541_DATA */ - 0x103f0000, /* DENALI_PHY_542_DATA */ - 0x0000003f, /* DENALI_PHY_543_DATA */ - 0x00038055, /* DENALI_PHY_544_DATA */ - 0x03800380, /* DENALI_PHY_545_DATA */ - 0x03800380, /* DENALI_PHY_546_DATA */ - 0x00000380, /* DENALI_PHY_547_DATA */ - 0x42080010, /* DENALI_PHY_548_DATA */ - 0x00000003, /* DENALI_PHY_549_DATA */ - 0x00000000, /* DENALI_PHY_550_DATA */ - 0x00000000, /* DENALI_PHY_551_DATA */ - 0x00000000, /* DENALI_PHY_552_DATA */ - 0x00000000, /* DENALI_PHY_553_DATA */ - 0x00000000, /* DENALI_PHY_554_DATA */ - 0x00000000, /* DENALI_PHY_555_DATA */ - 0x00000000, /* DENALI_PHY_556_DATA */ - 0x00000000, /* DENALI_PHY_557_DATA */ - 0x00000000, /* DENALI_PHY_558_DATA */ - 0x00000000, /* DENALI_PHY_559_DATA */ - 0x00000000, /* DENALI_PHY_560_DATA */ - 0x00000000, /* DENALI_PHY_561_DATA */ - 0x00000000, /* DENALI_PHY_562_DATA */ - 0x00000000, /* DENALI_PHY_563_DATA */ - 0x00000000, /* DENALI_PHY_564_DATA */ - 0x00000000, /* DENALI_PHY_565_DATA */ - 0x00000000, /* DENALI_PHY_566_DATA */ - 0x00000000, /* DENALI_PHY_567_DATA */ - 0x00000000, /* DENALI_PHY_568_DATA */ - 0x00000000, /* DENALI_PHY_569_DATA */ - 0x00000000, /* DENALI_PHY_570_DATA */ - 0x00000000, /* DENALI_PHY_571_DATA */ - 0x00000000, /* DENALI_PHY_572_DATA */ - 0x00000000, /* DENALI_PHY_573_DATA */ - 0x00000000, /* DENALI_PHY_574_DATA */ - 0x00000000, /* DENALI_PHY_575_DATA */ - 0x00000000, /* DENALI_PHY_576_DATA */ - 0x00000000, /* DENALI_PHY_577_DATA */ - 0x00000000, /* DENALI_PHY_578_DATA */ - 0x00000000, /* DENALI_PHY_579_DATA */ - 0x00000000, /* DENALI_PHY_580_DATA */ - 0x00000000, /* DENALI_PHY_581_DATA */ - 0x00000000, /* DENALI_PHY_582_DATA */ - 0x00000000, /* DENALI_PHY_583_DATA */ - 0x00000000, /* DENALI_PHY_584_DATA */ - 0x00000000, /* DENALI_PHY_585_DATA */ - 0x00000000, /* DENALI_PHY_586_DATA */ - 0x00000000, /* DENALI_PHY_587_DATA */ - 0x00000000, /* DENALI_PHY_588_DATA */ - 0x00000000, /* DENALI_PHY_589_DATA */ - 0x00000000, /* DENALI_PHY_590_DATA */ - 0x00000000, /* DENALI_PHY_591_DATA */ - 0x00000000, /* DENALI_PHY_592_DATA */ - 0x00000000, /* DENALI_PHY_593_DATA */ - 0x00000000, /* DENALI_PHY_594_DATA */ - 0x00000000, /* DENALI_PHY_595_DATA */ - 0x00000000, /* DENALI_PHY_596_DATA */ - 0x00000000, /* DENALI_PHY_597_DATA */ - 0x00000000, /* DENALI_PHY_598_DATA */ - 0x00000000, /* DENALI_PHY_599_DATA */ - 0x00000000, /* DENALI_PHY_600_DATA */ - 0x00000000, /* DENALI_PHY_601_DATA */ - 0x00000000, /* DENALI_PHY_602_DATA */ - 0x00000000, /* DENALI_PHY_603_DATA */ - 0x00000000, /* DENALI_PHY_604_DATA */ - 0x00000000, /* DENALI_PHY_605_DATA */ - 0x00000000, /* DENALI_PHY_606_DATA */ - 0x00000000, /* DENALI_PHY_607_DATA */ - 0x00000000, /* DENALI_PHY_608_DATA */ - 0x00000000, /* DENALI_PHY_609_DATA */ - 0x00000000, /* DENALI_PHY_610_DATA */ - 0x00000000, /* DENALI_PHY_611_DATA */ - 0x00000000, /* DENALI_PHY_612_DATA */ - 0x00000000, /* DENALI_PHY_613_DATA */ - 0x00000000, /* DENALI_PHY_614_DATA */ - 0x00000000, /* DENALI_PHY_615_DATA */ - 0x00000000, /* DENALI_PHY_616_DATA */ - 0x00000000, /* DENALI_PHY_617_DATA */ - 0x00000000, /* DENALI_PHY_618_DATA */ - 0x00000000, /* DENALI_PHY_619_DATA */ - 0x00000000, /* DENALI_PHY_620_DATA */ - 0x00000000, /* DENALI_PHY_621_DATA */ - 0x00000000, /* DENALI_PHY_622_DATA */ - 0x00000000, /* DENALI_PHY_623_DATA */ - 0x00000000, /* DENALI_PHY_624_DATA */ - 0x00000000, /* DENALI_PHY_625_DATA */ - 0x00000000, /* DENALI_PHY_626_DATA */ - 0x00000000, /* DENALI_PHY_627_DATA */ - 0x00000000, /* DENALI_PHY_628_DATA */ - 0x00000000, /* DENALI_PHY_629_DATA */ - 0x00000000, /* DENALI_PHY_630_DATA */ - 0x00000000, /* DENALI_PHY_631_DATA */ - 0x00000000, /* DENALI_PHY_632_DATA */ - 0x00000000, /* DENALI_PHY_633_DATA */ - 0x00000000, /* DENALI_PHY_634_DATA */ - 0x00000000, /* DENALI_PHY_635_DATA */ - 0x00000000, /* DENALI_PHY_636_DATA */ - 0x00000000, /* DENALI_PHY_637_DATA */ - 0x00000000, /* DENALI_PHY_638_DATA */ - 0x00000000, /* DENALI_PHY_639_DATA */ - 0x00000000, /* DENALI_PHY_640_DATA */ - 0x00800000, /* DENALI_PHY_641_DATA */ - 0x00000000, /* DENALI_PHY_642_DATA */ - 0x00000000, /* DENALI_PHY_643_DATA */ - 0x00000000, /* DENALI_PHY_644_DATA */ - 0x00000000, /* DENALI_PHY_645_DATA */ - 0x00000000, /* DENALI_PHY_646_DATA */ - 0x00000001, /* DENALI_PHY_647_DATA */ - 0x00000000, /* DENALI_PHY_648_DATA */ - 0x00000000, /* DENALI_PHY_649_DATA */ - 0x00000000, /* DENALI_PHY_650_DATA */ - 0x00400320, /* DENALI_PHY_651_DATA */ - 0x00000040, /* DENALI_PHY_652_DATA */ - 0x00008eca, /* DENALI_PHY_653_DATA */ - 0x00009fdb, /* DENALI_PHY_654_DATA */ - 0x00008eca, /* DENALI_PHY_655_DATA */ - 0x01009fdb, /* DENALI_PHY_656_DATA */ - 0x00020003, /* DENALI_PHY_657_DATA */ - 0x00000000, /* DENALI_PHY_658_DATA */ - 0x00000000, /* DENALI_PHY_659_DATA */ - 0x00000000, /* DENALI_PHY_660_DATA */ - 0x000556aa, /* DENALI_PHY_661_DATA */ - 0x000aaaaa, /* DENALI_PHY_662_DATA */ - 0x000aa955, /* DENALI_PHY_663_DATA */ - 0x00055555, /* DENALI_PHY_664_DATA */ - 0x000b3133, /* DENALI_PHY_665_DATA */ - 0x0004cd33, /* DENALI_PHY_666_DATA */ - 0x0004cecc, /* DENALI_PHY_667_DATA */ - 0x000b32cc, /* DENALI_PHY_668_DATA */ - 0x0004a0e6, /* DENALI_PHY_669_DATA */ - 0x080f0000, /* DENALI_PHY_670_DATA */ - 0x0000000f, /* DENALI_PHY_671_DATA */ - 0x00038055, /* DENALI_PHY_672_DATA */ - 0x03800380, /* DENALI_PHY_673_DATA */ - 0x03800380, /* DENALI_PHY_674_DATA */ - 0x00000380, /* DENALI_PHY_675_DATA */ - 0x42080010, /* DENALI_PHY_676_DATA */ - 0x00000003, /* DENALI_PHY_677_DATA */ - 0x00000000, /* DENALI_PHY_678_DATA */ - 0x00000000, /* DENALI_PHY_679_DATA */ - 0x00000000, /* DENALI_PHY_680_DATA */ - 0x00000000, /* DENALI_PHY_681_DATA */ - 0x00000000, /* DENALI_PHY_682_DATA */ - 0x00000000, /* DENALI_PHY_683_DATA */ - 0x00000000, /* DENALI_PHY_684_DATA */ - 0x00000000, /* DENALI_PHY_685_DATA */ - 0x00000000, /* DENALI_PHY_686_DATA */ - 0x00000000, /* DENALI_PHY_687_DATA */ - 0x00000000, /* DENALI_PHY_688_DATA */ - 0x00000000, /* DENALI_PHY_689_DATA */ - 0x00000000, /* DENALI_PHY_690_DATA */ - 0x00000000, /* DENALI_PHY_691_DATA */ - 0x00000000, /* DENALI_PHY_692_DATA */ - 0x00000000, /* DENALI_PHY_693_DATA */ - 0x00000000, /* DENALI_PHY_694_DATA */ - 0x00000000, /* DENALI_PHY_695_DATA */ - 0x00000000, /* DENALI_PHY_696_DATA */ - 0x00000000, /* DENALI_PHY_697_DATA */ - 0x00000000, /* DENALI_PHY_698_DATA */ - 0x00000000, /* DENALI_PHY_699_DATA */ - 0x00000000, /* DENALI_PHY_700_DATA */ - 0x00000000, /* DENALI_PHY_701_DATA */ - 0x00000000, /* DENALI_PHY_702_DATA */ - 0x00000000, /* DENALI_PHY_703_DATA */ - 0x00000000, /* DENALI_PHY_704_DATA */ - 0x00000000, /* DENALI_PHY_705_DATA */ - 0x00000000, /* DENALI_PHY_706_DATA */ - 0x00000000, /* DENALI_PHY_707_DATA */ - 0x00000000, /* DENALI_PHY_708_DATA */ - 0x00000000, /* DENALI_PHY_709_DATA */ - 0x00000000, /* DENALI_PHY_710_DATA */ - 0x00000000, /* DENALI_PHY_711_DATA */ - 0x00000000, /* DENALI_PHY_712_DATA */ - 0x00000000, /* DENALI_PHY_713_DATA */ - 0x00000000, /* DENALI_PHY_714_DATA */ - 0x00000000, /* DENALI_PHY_715_DATA */ - 0x00000000, /* DENALI_PHY_716_DATA */ - 0x00000000, /* DENALI_PHY_717_DATA */ - 0x00000000, /* DENALI_PHY_718_DATA */ - 0x00000000, /* DENALI_PHY_719_DATA */ - 0x00000000, /* DENALI_PHY_720_DATA */ - 0x00000000, /* DENALI_PHY_721_DATA */ - 0x00000000, /* DENALI_PHY_722_DATA */ - 0x00000000, /* DENALI_PHY_723_DATA */ - 0x00000000, /* DENALI_PHY_724_DATA */ - 0x00000000, /* DENALI_PHY_725_DATA */ - 0x00000000, /* DENALI_PHY_726_DATA */ - 0x00000000, /* DENALI_PHY_727_DATA */ - 0x00000000, /* DENALI_PHY_728_DATA */ - 0x00000000, /* DENALI_PHY_729_DATA */ - 0x00000000, /* DENALI_PHY_730_DATA */ - 0x00000000, /* DENALI_PHY_731_DATA */ - 0x00000000, /* DENALI_PHY_732_DATA */ - 0x00000000, /* DENALI_PHY_733_DATA */ - 0x00000000, /* DENALI_PHY_734_DATA */ - 0x00000000, /* DENALI_PHY_735_DATA */ - 0x00000000, /* DENALI_PHY_736_DATA */ - 0x00000000, /* DENALI_PHY_737_DATA */ - 0x00000000, /* DENALI_PHY_738_DATA */ - 0x00000000, /* DENALI_PHY_739_DATA */ - 0x00000000, /* DENALI_PHY_740_DATA */ - 0x00000000, /* DENALI_PHY_741_DATA */ - 0x00000000, /* DENALI_PHY_742_DATA */ - 0x00000000, /* DENALI_PHY_743_DATA */ - 0x00000000, /* DENALI_PHY_744_DATA */ - 0x00000000, /* DENALI_PHY_745_DATA */ - 0x00000000, /* DENALI_PHY_746_DATA */ - 0x00000000, /* DENALI_PHY_747_DATA */ - 0x00000000, /* DENALI_PHY_748_DATA */ - 0x00000000, /* DENALI_PHY_749_DATA */ - 0x00000000, /* DENALI_PHY_750_DATA */ - 0x00000000, /* DENALI_PHY_751_DATA */ - 0x00000000, /* DENALI_PHY_752_DATA */ - 0x00000000, /* DENALI_PHY_753_DATA */ - 0x00000000, /* DENALI_PHY_754_DATA */ - 0x00000000, /* DENALI_PHY_755_DATA */ - 0x00000000, /* DENALI_PHY_756_DATA */ - 0x00000000, /* DENALI_PHY_757_DATA */ - 0x00000000, /* DENALI_PHY_758_DATA */ - 0x00000000, /* DENALI_PHY_759_DATA */ - 0x00000000, /* DENALI_PHY_760_DATA */ - 0x00000000, /* DENALI_PHY_761_DATA */ - 0x00000000, /* DENALI_PHY_762_DATA */ - 0x00000000, /* DENALI_PHY_763_DATA */ - 0x00000000, /* DENALI_PHY_764_DATA */ - 0x00000000, /* DENALI_PHY_765_DATA */ - 0x00000000, /* DENALI_PHY_766_DATA */ - 0x00000000, /* DENALI_PHY_767_DATA */ - 0x00000000, /* DENALI_PHY_768_DATA */ - 0x00800000, /* DENALI_PHY_769_DATA */ - 0x00000000, /* DENALI_PHY_770_DATA */ - 0x00000000, /* DENALI_PHY_771_DATA */ - 0x00000000, /* DENALI_PHY_772_DATA */ - 0x00000000, /* DENALI_PHY_773_DATA */ - 0x00000000, /* DENALI_PHY_774_DATA */ - 0x00000001, /* DENALI_PHY_775_DATA */ - 0x00000000, /* DENALI_PHY_776_DATA */ - 0x00000000, /* DENALI_PHY_777_DATA */ - 0x00000000, /* DENALI_PHY_778_DATA */ - 0x00400320, /* DENALI_PHY_779_DATA */ - 0x00000040, /* DENALI_PHY_780_DATA */ - 0x00008eca, /* DENALI_PHY_781_DATA */ - 0x00009fdb, /* DENALI_PHY_782_DATA */ - 0x00008eca, /* DENALI_PHY_783_DATA */ - 0x01009fdb, /* DENALI_PHY_784_DATA */ - 0x00020003, /* DENALI_PHY_785_DATA */ - 0x00000000, /* DENALI_PHY_786_DATA */ - 0x00000000, /* DENALI_PHY_787_DATA */ - 0x00000000, /* DENALI_PHY_788_DATA */ - 0x000556aa, /* DENALI_PHY_789_DATA */ - 0x000aaaaa, /* DENALI_PHY_790_DATA */ - 0x000aa955, /* DENALI_PHY_791_DATA */ - 0x00055555, /* DENALI_PHY_792_DATA */ - 0x000b3133, /* DENALI_PHY_793_DATA */ - 0x0004cd33, /* DENALI_PHY_794_DATA */ - 0x0004cecc, /* DENALI_PHY_795_DATA */ - 0x000b32cc, /* DENALI_PHY_796_DATA */ - 0x1ee6b16a, /* DENALI_PHY_797_DATA */ - 0x10000000, /* DENALI_PHY_798_DATA */ - 0x00000000, /* DENALI_PHY_799_DATA */ - 0x00038055, /* DENALI_PHY_800_DATA */ - 0x03800380, /* DENALI_PHY_801_DATA */ - 0x03800380, /* DENALI_PHY_802_DATA */ - 0x00000380, /* DENALI_PHY_803_DATA */ - 0x42080010, /* DENALI_PHY_804_DATA */ - 0x00000003, /* DENALI_PHY_805_DATA */ - 0x00000000, /* DENALI_PHY_806_DATA */ - 0x00000000, /* DENALI_PHY_807_DATA */ - 0x00000000, /* DENALI_PHY_808_DATA */ - 0x00000000, /* DENALI_PHY_809_DATA */ - 0x00000000, /* DENALI_PHY_810_DATA */ - 0x00000000, /* DENALI_PHY_811_DATA */ - 0x00000000, /* DENALI_PHY_812_DATA */ - 0x00000000, /* DENALI_PHY_813_DATA */ - 0x00000000, /* DENALI_PHY_814_DATA */ - 0x00000000, /* DENALI_PHY_815_DATA */ - 0x00000000, /* DENALI_PHY_816_DATA */ - 0x00000000, /* DENALI_PHY_817_DATA */ - 0x00000000, /* DENALI_PHY_818_DATA */ - 0x00000000, /* DENALI_PHY_819_DATA */ - 0x00000000, /* DENALI_PHY_820_DATA */ - 0x00000000, /* DENALI_PHY_821_DATA */ - 0x00000000, /* DENALI_PHY_822_DATA */ - 0x00000000, /* DENALI_PHY_823_DATA */ - 0x00000000, /* DENALI_PHY_824_DATA */ - 0x00000000, /* DENALI_PHY_825_DATA */ - 0x00000000, /* DENALI_PHY_826_DATA */ - 0x00000000, /* DENALI_PHY_827_DATA */ - 0x00000000, /* DENALI_PHY_828_DATA */ - 0x00000000, /* DENALI_PHY_829_DATA */ - 0x00000000, /* DENALI_PHY_830_DATA */ - 0x00000000, /* DENALI_PHY_831_DATA */ - 0x00000000, /* DENALI_PHY_832_DATA */ - 0x00000000, /* DENALI_PHY_833_DATA */ - 0x00000000, /* DENALI_PHY_834_DATA */ - 0x00000000, /* DENALI_PHY_835_DATA */ - 0x00000000, /* DENALI_PHY_836_DATA */ - 0x00000000, /* DENALI_PHY_837_DATA */ - 0x00000000, /* DENALI_PHY_838_DATA */ - 0x00000000, /* DENALI_PHY_839_DATA */ - 0x00000000, /* DENALI_PHY_840_DATA */ - 0x00000000, /* DENALI_PHY_841_DATA */ - 0x00000000, /* DENALI_PHY_842_DATA */ - 0x00000000, /* DENALI_PHY_843_DATA */ - 0x00000000, /* DENALI_PHY_844_DATA */ - 0x00000000, /* DENALI_PHY_845_DATA */ - 0x00000000, /* DENALI_PHY_846_DATA */ - 0x00000000, /* DENALI_PHY_847_DATA */ - 0x00000000, /* DENALI_PHY_848_DATA */ - 0x00000000, /* DENALI_PHY_849_DATA */ - 0x00000000, /* DENALI_PHY_850_DATA */ - 0x00000000, /* DENALI_PHY_851_DATA */ - 0x00000000, /* DENALI_PHY_852_DATA */ - 0x00000000, /* DENALI_PHY_853_DATA */ - 0x00000000, /* DENALI_PHY_854_DATA */ - 0x00000000, /* DENALI_PHY_855_DATA */ - 0x00000000, /* DENALI_PHY_856_DATA */ - 0x00000000, /* DENALI_PHY_857_DATA */ - 0x00000000, /* DENALI_PHY_858_DATA */ - 0x00000000, /* DENALI_PHY_859_DATA */ - 0x00000000, /* DENALI_PHY_860_DATA */ - 0x00000000, /* DENALI_PHY_861_DATA */ - 0x00000000, /* DENALI_PHY_862_DATA */ - 0x00000000, /* DENALI_PHY_863_DATA */ - 0x00000000, /* DENALI_PHY_864_DATA */ - 0x00000000, /* DENALI_PHY_865_DATA */ - 0x00000000, /* DENALI_PHY_866_DATA */ - 0x00000000, /* DENALI_PHY_867_DATA */ - 0x00000000, /* DENALI_PHY_868_DATA */ - 0x00000000, /* DENALI_PHY_869_DATA */ - 0x00000000, /* DENALI_PHY_870_DATA */ - 0x00000000, /* DENALI_PHY_871_DATA */ - 0x00000000, /* DENALI_PHY_872_DATA */ - 0x00000000, /* DENALI_PHY_873_DATA */ - 0x00000000, /* DENALI_PHY_874_DATA */ - 0x00000000, /* DENALI_PHY_875_DATA */ - 0x00000000, /* DENALI_PHY_876_DATA */ - 0x00000000, /* DENALI_PHY_877_DATA */ - 0x00000000, /* DENALI_PHY_878_DATA */ - 0x00000000, /* DENALI_PHY_879_DATA */ - 0x00000000, /* DENALI_PHY_880_DATA */ - 0x00000000, /* DENALI_PHY_881_DATA */ - 0x00000000, /* DENALI_PHY_882_DATA */ - 0x00000000, /* DENALI_PHY_883_DATA */ - 0x00000000, /* DENALI_PHY_884_DATA */ - 0x00000000, /* DENALI_PHY_885_DATA */ - 0x00000000, /* DENALI_PHY_886_DATA */ - 0x00000000, /* DENALI_PHY_887_DATA */ - 0x00000000, /* DENALI_PHY_888_DATA */ - 0x00000000, /* DENALI_PHY_889_DATA */ - 0x00000000, /* DENALI_PHY_890_DATA */ - 0x00000000, /* DENALI_PHY_891_DATA */ - 0x00000000, /* DENALI_PHY_892_DATA */ - 0x00000000, /* DENALI_PHY_893_DATA */ - 0x00000000, /* DENALI_PHY_894_DATA */ - 0x00000000, /* DENALI_PHY_895_DATA */ - 0x00000001, /* DENALI_PHY_896_DATA */ - 0x00000000, /* DENALI_PHY_897_DATA */ - 0x01000005, /* DENALI_PHY_898_DATA */ - 0x04000f00, /* DENALI_PHY_899_DATA */ - 0x00020040, /* DENALI_PHY_900_DATA */ - 0x00020055, /* DENALI_PHY_901_DATA */ - 0x00000000, /* DENALI_PHY_902_DATA */ - 0x00000000, /* DENALI_PHY_903_DATA */ - 0x00000000, /* DENALI_PHY_904_DATA */ - 0x00000050, /* DENALI_PHY_905_DATA */ - 0x00000000, /* DENALI_PHY_906_DATA */ - 0x00010100, /* DENALI_PHY_907_DATA */ - 0x00000601, /* DENALI_PHY_908_DATA */ - 0x00000000, /* DENALI_PHY_909_DATA */ - 0x00006400, /* DENALI_PHY_910_DATA */ - 0x01221102, /* DENALI_PHY_911_DATA */ - 0x00000000, /* DENALI_PHY_912_DATA */ - 0x00051f00, /* DENALI_PHY_913_DATA */ - 0x051f051f, /* DENALI_PHY_914_DATA */ - 0x051f051f, /* DENALI_PHY_915_DATA */ - 0x00030003, /* DENALI_PHY_916_DATA */ - 0x03000300, /* DENALI_PHY_917_DATA */ - 0x00000300, /* DENALI_PHY_918_DATA */ - 0x01221102, /* DENALI_PHY_919_DATA */ - 0x00000000, /* DENALI_PHY_920_DATA */ - 0x00000000, /* DENALI_PHY_921_DATA */ - 0x04020000, /* DENALI_PHY_922_DATA */ - 0x00000001, /* DENALI_PHY_923_DATA */ - 0x00000011, /* DENALI_PHY_924_DATA */ - 0x00000011, /* DENALI_PHY_925_DATA */ - 0x00000400, /* DENALI_PHY_926_DATA */ - 0x00000000, /* DENALI_PHY_927_DATA */ - 0x00000011, /* DENALI_PHY_928_DATA */ - 0x00000011, /* DENALI_PHY_929_DATA */ - 0x00004410, /* DENALI_PHY_930_DATA */ - 0x00004410, /* DENALI_PHY_931_DATA */ - 0x00004410, /* DENALI_PHY_932_DATA */ - 0x00004410, /* DENALI_PHY_933_DATA */ - 0x00004410, /* DENALI_PHY_934_DATA */ - 0x00000011, /* DENALI_PHY_935_DATA */ - 0x00004410, /* DENALI_PHY_936_DATA */ - 0x00000011, /* DENALI_PHY_937_DATA */ - 0x00004410, /* DENALI_PHY_938_DATA */ - 0x00000011, /* DENALI_PHY_939_DATA */ - 0x00004410, /* DENALI_PHY_940_DATA */ - 0x00000000, /* DENALI_PHY_941_DATA */ - 0x00000000, /* DENALI_PHY_942_DATA */ - 0x00000000, /* DENALI_PHY_943_DATA */ - 0x04000000, /* DENALI_PHY_944_DATA */ - 0x00000000, /* DENALI_PHY_945_DATA */ - 0x00000000, /* DENALI_PHY_946_DATA */ - 0x00000508, /* DENALI_PHY_947_DATA */ - 0x00000000, /* DENALI_PHY_948_DATA */ - 0x00000000, /* DENALI_PHY_949_DATA */ - 0x00000000, /* DENALI_PHY_950_DATA */ - 0x00000000, /* DENALI_PHY_951_DATA */ - 0x00000000, /* DENALI_PHY_952_DATA */ - 0x00000000, /* DENALI_PHY_953_DATA */ - 0xe4000000, /* DENALI_PHY_954_DATA */ - 0x00000000, /* DENALI_PHY_955_DATA */ - 0x00000000, /* DENALI_PHY_956_DATA */ - 0x01010000, /* DENALI_PHY_957_DATA */ - 0x00000000 /* DENALI_PHY_958_DATA */ - } - }, -}, diff --git a/src/soc/rockchip/rk3399/include/soc/sdram.h b/src/soc/rockchip/rk3399/include/soc/sdram.h index 5c7273b..1ec6d39 100644 --- a/src/soc/rockchip/rk3399/include/soc/sdram.h +++ b/src/soc/rockchip/rk3399/include/soc/sdram.h @@ -16,7 +16,7 @@ #ifndef __SOC_ROCKCHIP_RK3399_SDRAM_H__ #define __SOC_ROCKCHIP_RK3399_SDRAM_H__
-#include <stddef.h> +#include <types.h>
enum { DDR3 = 3, @@ -183,8 +183,6 @@ struct rk3399_sdram_params { void sdram_init(const struct rk3399_sdram_params *sdram_params); u32 sdram_get_ram_code(void); const struct rk3399_sdram_params *get_sdram_config(void); -const struct rk3399_sdram_params - *get_default_sdram_config(unsigned char dramtype); size_t sdram_size_mb(void);
#endif
