Attention is currently required from: Kyle Lin, Nick Vaccaro, Subrata Banik.
Hello Kyle Lin, Nick Vaccaro, Subrata Banik, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/78289?usp=email
Change subject: mb/google/nissa/var/gothrax: Supplement register settings for SX9324 P-sensor ......................................................................
Set the following register value to make SX9324 work normally "ph0_pin" = "{1, 3, 3}" "ph1_pin" = "{3, 2, 1}" "ph2_pin" = "{3, 3, 1}" "ph3_pin" = "{1, 3, 3}" "ph01_resolution" = "512" "ph23_resolution" = "1024" "startup_sensor" = "1" "ph01_proxraw_strength" = "2" "ph23_proxraw_strength" = "2" "avg_pos_strength" = "256" "cs_idle_sleep" = ""gnd"" "int_comp_resistor" = ""lowest"" "input_precharge_resistor_ohms" = "4000" "input_analog_gain" = "3"
BUG=b:295109511 BRANCH=None TEST=emerge-nissa coreboot chromeos-bootimage & Check sar sensor data
Change-Id: Ib15f12d754fec8b379afd702b27d0701fac78072 --- M src/mainboard/google/brya/variants/gothrax/overridetree.cb 1 file changed, 15 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/89/78289/3
