hakim giydan (hgiydan@marvell.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/15335
commit c8d3b4bf51b1db7a0b5d5b64b3c765a52959df7e Author: Hakim Giydan hgiydan@marvell.com Date: Wed Aug 17 13:44:27 2016 -0700
arch/arm: Add armv7-r configuration
This change adds armv7-r support for all stages.
armv7-r is an ARM processor based on the Cortex-R series.
Currently, there is support for armv7-a and armv7-m and armv7-a files has been modfied to accommodate armv7-r by adding ENV_ARMV7_A, ENV_ARMV7_R and ENV_ARMV7_M constants to src/include/rules.h.
armv7-r exceptions support will added in a later time.
Change-Id: If94415d07fd6bd96c43d087374f609a2211f1885 Signed-off-by: Hakim Giydan hgiydan@marvell.com --- src/arch/arm/armv7/Kconfig | 16 +++++++++++ src/arch/arm/armv7/Makefile.inc | 59 +++++++++++++++++++++++++++++++++++++-- src/arch/arm/armv7/cpu.S | 12 ++++++++ src/arch/arm/armv7/exception_m.c | 36 ------------------------ src/arch/arm/armv7/exception_mr.c | 36 ++++++++++++++++++++++++ src/include/rules.h | 13 +++++++++ util/xcompile/xcompile | 2 +- 7 files changed, 134 insertions(+), 40 deletions(-)
diff --git a/src/arch/arm/armv7/Kconfig b/src/arch/arm/armv7/Kconfig index 0ab3542..3734426 100644 --- a/src/arch/arm/armv7/Kconfig +++ b/src/arch/arm/armv7/Kconfig @@ -19,3 +19,19 @@ config ARCH_BOOTBLOCK_ARMV7_M config ARCH_VERSTAGE_ARMV7_M def_bool n select ARCH_VERSTAGE_ARM + +config ARCH_BOOTBLOCK_ARMV7_R + def_bool n + select ARCH_BOOTBLOCK_ARM + +config ARCH_VERSTAGE_ARMV7_R + def_bool n + select ARCH_VERSTAGE_ARM + +config ARCH_ROMSTAGE_ARMV7_R + def_bool n + select ARCH_ROMSTAGE_ARM + +config ARCH_RAMSTAGE_ARMV7_R + def_bool n + select ARCH_RAMSTAGE_ARM diff --git a/src/arch/arm/armv7/Makefile.inc b/src/arch/arm/armv7/Makefile.inc index 2e9c49c..d978f00 100644 --- a/src/arch/arm/armv7/Makefile.inc +++ b/src/arch/arm/armv7/Makefile.inc @@ -16,10 +16,12 @@ ###############################################################################
armv7_flags = -mthumb -I$(src)/arch/arm/include/armv7/ -D__COREBOOT_ARM_ARCH__=7 -armv7-a_flags = -march=armv7-a $(armv7_flags) -armv7-m_flags = -march=armv7-m $(armv7_flags) +armv7-a_flags = -march=armv7-a $(armv7_flags) -D__COREBOOT_ARM_V7_A__ +armv7-m_flags = -march=armv7-m $(armv7_flags) -D__COREBOOT_ARM_V7_M__ +armv7-r_flags = -march=armv7-r $(armv7_flags) -D__COREBOOT_ARM_V7_R__
armv7_asm_flags = -Wa,-mthumb -Wa,-mimplicit-it=always -Wa,-mno-warn-deprecated +armv7-r_asm_flags = $(armv7-r_flags) $(armv7_asm_flags)
############################################################################### # bootblock @@ -46,9 +48,22 @@ bootblock-S-ccopts += $(armv7_asm_flags) ifneq ($(CONFIG_BOOTBLOCK_CUSTOM),y) bootblock-y += bootblock_m.S endif -bootblock-y += exception_m.c +bootblock-y += exception_mr.c bootblock-y += cache_m.c
+else ifeq ($(CONFIG_ARCH_BOOTBLOCK_ARMV7_R),y) +bootblock-generic-ccopts += $(armv7-r_flags) +bootblock-S-ccopts += $(armv7-r_asm_flags) + +ifneq ($(CONFIG_BOOTBLOCK_CUSTOM),y) +bootblock-y += bootblock.S +endif + +bootblock-y += cache.c +bootblock-y += cpu.S +bootblock-y += exception_mr.c +bootblock-y += mmu.c + endif # CONFIG_ARCH_BOOTBLOCK_ARMV7
################################################################################ @@ -73,6 +88,17 @@ libverstage-S-ccopts += $(armv7_asm_flags) verstage-generic-ccopts += $(armv7-m_flags) verstage-S-ccopts += $(armv7_asm_flags)
+else ifeq ($(CONFIG_ARCH_VERSTAGE_ARMV7_R),y) +libverstage-generic-ccopts += $(armv7-r_flags) +libverstage-S-ccopts += $(armv7-r_asm_flags) +verstage-generic-ccopts += $(armv7-r_flags) +verstage-S-ccopts += $(armv7-r_asm_flags) + +verstage-y += cache.c +verstage-y += cpu.S +verstage-y += exception_mr.c +verstage-y += mmu.c + endif # CONFIG_ARCH_VERSTAGE_ARMV7_M
################################################################################ @@ -91,6 +117,18 @@ romstage-S-ccopts += $(armv7_asm_flags) rmodules_arm-generic-ccopts += $(armv7-a_flags) rmodules_arm-S-ccopts += $(armv7_asm_flags)
+else ifeq ($(CONFIG_ARCH_ROMSTAGE_ARMV7_R),y) +romstage-y += cache.c +romstage-y += cpu.S +romstage-y += exception_mr.c +romstage-y += mmu.c + +romstage-generic-ccopts += $(armv7-r_flags) +romstage-S-ccopts += $(armv7-r_asm_flags) + +rmodules_arm-generic-ccopts += $(armv7-r_flags) +rmodules_arm-S-ccopts += $(armv7-r_asm_flags) + endif # CONFIG_ARCH_ROMSTAGE_ARMV7
############################################################################### @@ -111,4 +149,19 @@ ramstage-S-ccopts += $(armv7_asm_flags) # All rmodule code is armv7 if ramstage is armv7. rmodules_arm-generic-ccopts += $(armv7-a_flags) rmodules_arm-S-ccopts += $(armv7_asm_flags) + +else ifeq ($(CONFIG_ARCH_RAMSTAGE_ARMV7_R),y) + +ramstage-y += cache.c +ramstage-y += cpu.S +ramstage-y += exception_mr.c +ramstage-y += mmu.c + +ramstage-generic-ccopts += $(armv7-r_flags) +ramstage-S-ccopts += $(armv7-r_asm_flags) + +# All rmodule code is armv7 if ramstage is armv7. +rmodules_arm-generic-ccopts += $(armv7-r_flags) +rmodules_arm-S-ccopts += $(armv7-r_asm_flags) + endif # CONFIG_ARCH_RAMSTAGE_ARMV7 diff --git a/src/arch/arm/armv7/cpu.S b/src/arch/arm/armv7/cpu.S index 6c00f62..21a16d2 100644 --- a/src/arch/arm/armv7/cpu.S +++ b/src/arch/arm/armv7/cpu.S @@ -31,6 +31,7 @@ */
#include <arch/asm.h> +#include <rules.h>
/* * Dcache invalidations by set/way work by passing a [way:sbz:set:sbz:level:0] @@ -126,6 +127,7 @@ ENTRY(arm_init_caches) /* Flush and invalidate dcache in ascending order */ bl dcache_invalidate_all
+#if ENV_ARMV7_A /* Deactivate MMU (0), Alignment Check (1) and DCache (2) */ and r4, # ~(1 << 0) & ~(1 << 1) & ~(1 << 2) mcr p15, 0, r4, c1, c0, 0 @@ -133,6 +135,16 @@ ENTRY(arm_init_caches) /* Invalidate icache and TLB for good measure */ mcr p15, 0, r0, c7, c5, 0 mcr p15, 0, r0, c8, c7, 0 +#endif + +#if ENV_ARMV7_R + /* Deactivate Alignment Check (1) and DCache (2) */ + and r4, # ~(1 << 1) & ~(1 << 2) + mcr p15, 0, r4, c1, c0, 0 + + /* Invalidate icache for good measure */ + mcr p15, 0, r0, c7, c5, 0 +#endif dsb isb
diff --git a/src/arch/arm/armv7/exception_m.c b/src/arch/arm/armv7/exception_m.c deleted file mode 100644 index d76cc6a..0000000 --- a/src/arch/arm/armv7/exception_m.c +++ /dev/null @@ -1,36 +0,0 @@ -/* - * This file is part of the libpayload project. - * - * Copyright 2013 Google Inc. - * - * Redistribution and use in source and binary forms, with or without - * modification, are permitted provided that the following conditions - * are met: - * 1. Redistributions of source code must retain the above copyright - * notice, this list of conditions and the following disclaimer. - * 2. Redistributions in binary form must reproduce the above copyright - * notice, this list of conditions and the following disclaimer in the - * documentation and/or other materials provided with the distribution. - * 3. The name of the author may not be used to endorse or promote products - * derived from this software without specific prior written permission. - * - * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND - * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE - * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE - * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE - * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL - * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS - * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) - * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT - * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY - * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF - * SUCH DAMAGE. - */ - -#include <arch/exception.h> -#include <console/console.h> - -void exception_init(void) -{ - printk(BIOS_DEBUG, "Exception handlers not installed.\n"); -} diff --git a/src/arch/arm/armv7/exception_mr.c b/src/arch/arm/armv7/exception_mr.c new file mode 100644 index 0000000..d76cc6a --- /dev/null +++ b/src/arch/arm/armv7/exception_mr.c @@ -0,0 +1,36 @@ +/* + * This file is part of the libpayload project. + * + * Copyright 2013 Google Inc. + * + * Redistribution and use in source and binary forms, with or without + * modification, are permitted provided that the following conditions + * are met: + * 1. Redistributions of source code must retain the above copyright + * notice, this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright + * notice, this list of conditions and the following disclaimer in the + * documentation and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE + * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF + * SUCH DAMAGE. + */ + +#include <arch/exception.h> +#include <console/console.h> + +void exception_init(void) +{ + printk(BIOS_DEBUG, "Exception handlers not installed.\n"); +} diff --git a/src/include/rules.h b/src/include/rules.h index 89fdd21..a632804 100644 --- a/src/include/rules.h +++ b/src/include/rules.h @@ -131,6 +131,19 @@ #elif __COREBOOT_ARM_ARCH__ == 7 #define ENV_ARMV4 0 #define ENV_ARMV7 1 +#if defined(__COREBOOT_ARM_V7_A__) +#define ENV_ARMV7_A 1 +#define ENV_ARMV7_M 0 +#define ENV_ARMV7_R 0 +#elif defined(__COREBOOT_ARM_V7_M__) +#define ENV_ARMV7_A 0 +#define ENV_ARMV7_M 1 +#define ENV_ARMV7_R 0 +#elif defined(__COREBOOT_ARM_V7_R__) +#define ENV_ARMV7_A 0 +#define ENV_ARMV7_M 0 +#define ENV_ARMV7_R 1 +#endif #else #define ENV_ARMV4 0 #define ENV_ARMV7 0 diff --git a/util/xcompile/xcompile b/util/xcompile/xcompile index 6c75da6..37e6404 100755 --- a/util/xcompile/xcompile +++ b/util/xcompile/xcompile @@ -316,7 +316,7 @@ arch_config_arm() { TBFDARCHS="littlearm" TCLIST="armv7-a armv7a arm" TWIDTH="32" - TSUPP="arm armv4 armv7 armv7_m" + TSUPP="arm armv4 armv7 armv7_m armv7_r" TABI="eabi" }
