Attention is currently required from: Shreesh Chhabbi, Ravishankar Sarawadi, Duncan Laurie, Alex Levin, Raj Astekar, Patrick Rudolph. Shreesh Chhabbi has uploaded a new patch set (#37) to the change originally created by Shreesh Chhabbi. ( https://review.coreboot.org/c/coreboot/+/49766 )
Change subject: soc/intel/tgl: Update S0ix enable mask based on SoC and mainboard design ......................................................................
This change uses the following information to determine the appropriate S0ix states to enable as per PDG document: 607872 for TGL UP3 Rev2p2 (section 10.13):
1. SoC - UP3 v/s UP4 2. H/W design - external phy gating, external clk gating, external bypass 3. Devices enabled at runtime - CNVi, ISH
In some cases, it is recommended to use a shallower state for S0ix even if the higher state can be achieved (e.g. with external gating not enabled). This recommendation is because the shallower state is determined to provide better power savings as per the above document. Deepest state expected on tigerlake up3 based platforms is S0i3.1.
BUG=b:177821896 TEST= 1. Build coreboot for volteer. 2. Verify "cat /sys/kernel/debug/pmc_core/substate_residencies" on delbin. S0i2.0, S0i2.1, S0i3.0 and S0i3.1 states show as enabled.
Signed-off-by: Shreesh Chhabbi shreesh.chhabbi@intel.corp-partner.google.com Change-Id: I5f2ac8b72d0c9b05bc02c092188d0c742cc83af9 --- M src/soc/intel/tigerlake/chip.h M src/soc/intel/tigerlake/fsp_params.c 2 files changed, 77 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/66/49766/37
