Stefan Reinauer (stefan.reinauer@coreboot.org) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/14232
commit 68c3b6ff97a3139b8faeb4362d309860b3f0cca3 Author: Stefan Reinauer stefan.reinauer@coreboot.org Date: Sun Apr 3 20:52:01 2016 -0700
crossgcc: Fix compilation on Clang systems
Most cross compilers fail to compile on systems with Clang being the default compiler (OS X and some BSDs). Clang dislikes some of GCC's autogenerated code. We also missed switching CFLAGS to CXXFLAGS when GCC switched to C++ compilation per default.
Change-Id: I87caa1a15982c431048aa79748ea7ef655a9a3a1 Signed-off-by: Stefan Reinauer stefan.reinauer@coreboot.org --- util/crossgcc/buildgcc | 13 ++++++++++--- 1 file changed, 10 insertions(+), 3 deletions(-)
diff --git a/util/crossgcc/buildgcc b/util/crossgcc/buildgcc index 525b574..96e4c19 100755 --- a/util/crossgcc/buildgcc +++ b/util/crossgcc/buildgcc @@ -18,8 +18,8 @@
cd $(dirname $0)
-CROSSGCC_DATE="March 21st, 2016" -CROSSGCC_VERSION="1.37" +CROSSGCC_DATE="April 3rd, 2016" +CROSSGCC_VERSION="1.38"
# default settings PACKAGE=GCC @@ -453,13 +453,20 @@ build_BINUTILS() {
build_GCC() { + # Work around crazy code generator in GCC that confuses CLANG. + $CC --version | grep clang &>/dev/null && + HOSTCFLAGS="$HOSTCFLAGS -fbracket-depth=1024" + # GCC does not honor HOSTCFLAGS at all. CFLAGS are used for # both target and host object files. # There's a work-around called CFLAGS_FOR_BUILD and CFLAGS_FOR_TARGET # but it does not seem to work properly. At least the host library # libiberty is not compiled with CFLAGS_FOR_BUILD. + # Also set the CXX version of the flags because GCC is now compiled + # using C++. CC="$CC" CFLAGS_FOR_TARGET="-O2 -Dinhibit_libc" CFLAGS="$HOSTCFLAGS" \ - CFLAGS_FOR_BUILD="$HOSTCFLAGS" ../gcc-${GCC_VERSION}/configure \ + CFLAGS_FOR_BUILD="$HOSTCFLAGS" CXXFLAGS="$HOSTCFLAGS" \ + CXXFLAGS_FOR_BUILD="$HOSTCFLAGS" ../gcc-${GCC_VERSION}/configure \ --prefix=$TARGETDIR --libexecdir=$TARGETDIR/lib \ --target=${TARGETARCH} --disable-werror --disable-shared \ --enable-lto --enable-plugins --enable-gold --enable-ld=default \
