Attention is currently required from: Arthur Heymans, ron minnich. Hello build bot (Jenkins), Nico Huber, Angel Pons, Arthur Heymans, ron minnich,
https://review.coreboot.org/c/coreboot/+/62574
Change subject: cbfstool/linux_trampoline: Fill the ACPI RSDP entry ......................................................................
With LinuxBoot Linux relied on the legacy method of fetching the RSDP pointer to get ACPI. This uses a more modern approach available since 2018 on the Linux kernel, which involves filling in the zero page.
This method takes precedence over any other method of fetching the RSDP in Linux (UEFI, Kexec, Legacy/BIOS). Some UEFI zealots are threatening that legacy code will be removed from Linux so it's best to already adapt to that possibility.
Tested on Qemu: - With qemu the RSDP is always in the EBDA, so checking if Linux uses the provided pointer is better done with a forced bad entry - With a fake bad pointer Linux correctly does not find RDSP
Change-Id: I688b94608b03b0177c42d2834c7e3beb802ae686 Signed-off-by: Arthur Heymans arthur@aheymans.xyz --- M util/cbfstool/linux_trampoline.S M util/cbfstool/linux_trampoline.c 2 files changed, 22 insertions(+), 9 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/74/62574/7
