Attention is currently required from: Dinesh Gehlot, Eric Lai, Jayvik Desai, Kapil Porwal, Nick Vaccaro, Rui Zhou.
Hello Dinesh Gehlot, Eric Lai, Jayvik Desai, Kapil Porwal, Nick Vaccaro, Subrata Banik, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/84997?usp=email
to look at the new patch set (#14).
Change subject: mb/google/nissa/var/rull: add ssd timeing and modify ssd GPIO pins of rtd3 ......................................................................
The previous GPIO config will cause the SSD device to not be recognized. We adjust the position of the enable and reset pins.
BUG=b:374629673 BRANCH=None TEST=1. emerge-nissa coreboot chromeos-bootimage 2. power on proto board successfully
Change-Id: Idb36f67206450612655cb3efd3cce240475ef3ab Signed-off-by: Rui Zhou zhourui@huaqin.corp-partner.google.com --- M src/mainboard/google/brya/variants/rull/gpio.c M src/mainboard/google/brya/variants/rull/overridetree.cb 2 files changed, 20 insertions(+), 15 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/97/84997/14
