Tim Wawrzynczak has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/50567 )
Change subject: mb/google/brya: Enable cr50 support ......................................................................
Add Kconfig options and devicetree entries for cr50 TPM.
BUG=b:180017621 TEST=verify (via console) successful cr50 communications in verstage and payload (depthcharge).
Signed-off-by: Tim Wawrzynczak twawrzynczak@chromium.org Change-Id: I80e27d0377960fb81f9149efb6f062d06432d40d --- M src/mainboard/google/brya/Kconfig M src/mainboard/google/brya/variants/baseboard/devicetree.cb 2 files changed, 29 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/67/50567/1
diff --git a/src/mainboard/google/brya/Kconfig b/src/mainboard/google/brya/Kconfig index ca76078..fbda4f7 100644 --- a/src/mainboard/google/brya/Kconfig +++ b/src/mainboard/google/brya/Kconfig @@ -13,6 +13,8 @@ select HAVE_SPD_IN_CBFS select INTEL_LPSS_UART_FOR_CONSOLE select MAINBOARD_HAS_CHROMEOS + select MAINBOARD_HAS_I2C_TPM_CR50 + select MAINBOARD_HAS_TPM2 select SOC_INTEL_ALDERLAKE
if BOARD_GOOGLE_BASEBOARD_BRYA @@ -30,6 +32,18 @@ string default "variants/baseboard/devicetree.cb"
+config DRIVER_TPM_I2C_BUS + hex + default 0x3 + +config DRIVER_TPM_I2C_ADDR + hex + default 0x50 + +config TPM_TIS_ACPI_INTERRUPT + int + default 13 # GPE0_DW0_13 (GPP_A13_IRQ) + config OVERRIDE_DEVICETREE string default "variants/$(CONFIG_VARIANT_DIR)/overridetree.cb" diff --git a/src/mainboard/google/brya/variants/baseboard/devicetree.cb b/src/mainboard/google/brya/variants/baseboard/devicetree.cb index 647ea42..9ced455 100644 --- a/src/mainboard/google/brya/variants/baseboard/devicetree.cb +++ b/src/mainboard/google/brya/variants/baseboard/devicetree.cb @@ -3,6 +3,13 @@ device lapic 0 on end end
+ register "gpio_override_pm" = "1" + register "gpio_pm[COMM_0]" = "0" + register "gpio_pm[COMM_1]" = "0" + register "gpio_pm[COMM_2]" = "0" + register "gpio_pm[COMM_4]" = "0" + register "gpio_pm[COMM_5]" = "0" + register "usb2_ports[0]" = "USB2_PORT_TYPE_C(OC0)" # USB2_C0 register "usb2_ports[1]" = "USB2_PORT_TYPE_C(OC1)" # USB2_C1 register "usb2_ports[2]" = "USB2_PORT_TYPE_C(OC2)" # USB2_C2 @@ -90,6 +97,14 @@ device generic 0 on end end end + device ref i2c3 on + chip drivers/i2c/generic + register "hid" = "ACPI_DT_NAMESPACE_HID" + register "compat_string" = ""google,cr50"" + register "irq" = "ACPI_IRQ_EDGE_LOW(GPP_A13_IRQ)" + device i2c 50 on end + end + end device ref heci1 on end device ref sata on end device ref pcie_rp5 on
