Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/78221?usp=email )
Change subject: soc/amd/genoa: Add SMI support ......................................................................
Add SMI definitions as per Genoa PPR Doc #55901
Change-Id: I491f4075cef8976e4b0762752c9e2e3c2ef886d5 Signed-off-by: Varshit Pandya pandyavarshit@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/78221 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Felix Held felix-coreboot@felixheld.de --- M src/soc/amd/genoa/Kconfig A src/soc/amd/genoa/include/soc/smi.h 2 files changed, 183 insertions(+), 0 deletions(-)
diff --git a/src/soc/amd/genoa/Kconfig b/src/soc/amd/genoa/Kconfig index 3044d71..2d57906 100644 --- a/src/soc/amd/genoa/Kconfig +++ b/src/soc/amd/genoa/Kconfig @@ -16,6 +16,7 @@ select SOC_AMD_COMMON_BLOCK_LPC select SOC_AMD_COMMON_BLOCK_NONCAR select SOC_AMD_COMMON_BLOCK_PCI_MMCONF + select SOC_AMD_COMMON_BLOCK_SMI select SOC_AMD_COMMON_BLOCK_TSC select SOC_AMD_COMMON_BLOCK_USE_ESPI select X86_CUSTOM_BOOTMEDIA diff --git a/src/soc/amd/genoa/include/soc/smi.h b/src/soc/amd/genoa/include/soc/smi.h new file mode 100644 index 0000000..c9054c5 --- /dev/null +++ b/src/soc/amd/genoa/include/soc/smi.h @@ -0,0 +1,182 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#ifndef AMD_GENOA_SMI_H +#define AMD_GENOA_SMI_H + +#include <types.h> + +#define SMI_GEVENTS 24 +#define SCIMAPS 64 /* 0..63 */ +#define SCI_GPES 32 +#define NUMBER_SMITYPES 157 + +#define SMI_EVENT_STATUS 0x0 +#define SMI_EVENT_ENABLE 0x04 +#define SMI_SCI_TRIG 0x08 +#define SMI_SCI_LEVEL 0x0c +#define SMI_SCI_STATUS 0x10 +#define SMI_SCI_EN 0x14 +#define SMI_SCI_MAP0 0x40 +# define SMI_SCI_MAP(X) (SMI_SCI_MAP0 + (X)) + +/* SMI source and status */ +#define SMITYPE_G_GENINT1_L 0 +#define SMITYPE_G_AGPIO115 1 +#define SMITYPE_G_AGPIO3 2 +#define SMITYPE_G_AGPIO22 3 +#define SMITYPE_G_AGPIO4 4 +#define SMITYPE_G_AGPIO21 5 +#define SMITYPE_G_AGPIO116 6 +#define SMITYPE_G_AGPIO5 7 +#define SMITYPE_G_WAKE_L 8 +#define SMITYPE_G_NMI_SYNC_FLOOD 9 +#define SMITYPE_G_AGPIO6 10 +#define SMITYPE_G_AGPIO76 11 +#define SMITYPE_G_USBOC0_L 12 +#define SMITYPE_G_USBOC1_L 13 +#define SMITYPE_G_SMERR_L 14 +#define SMITYPE_G_PCIE_RST1_L 15 +#define SMITYPE_G_ESPI_RSTOUT_L 16 +#define SMITYPE_G_ESPI_RSTIN_L 17 +#define SMITYPE_G_X48M_OUT 18 +#define SMITYPE_G_SYSRESET_L 19 +#define SMITYPE_G_AGPIO104 20 +#define SMITYPE_G_PWR_BTN_L 21 +#define SMITYPE_G_AGPI105 22 +#define SMITYPE_G_AGPI106 23 +#define GEVENT_MASK ((1 << SMITYPE_G_GENINT1_L) \ + | (1 << SMITYPE_G_AGPIO115) \ + | (1 << SMITYPE_G_AGPIO3) \ + | (1 << SMITYPE_G_AGPIO22) \ + | (1 << SMITYPE_G_AGPIO4) \ + | (1 << SMITYPE_G_AGPIO21) \ + | (1 << SMITYPE_G_AGPIO116) \ + | (1 << SMITYPE_G_AGPIO5) \ + | (1 << SMITYPE_G_WAKE_L) \ + | (1 << SMITYPE_G_NMI_SYNC_FLOOD) \ + | (1 << SMITYPE_G_AGPIO6) \ + | (1 << SMITYPE_G_AGPIO76) \ + | (1 << SMITYPE_G_USBOC0_L) \ + | (1 << SMITYPE_G_USBOC1_L) \ + | (1 << SMITYPE_G_SMERR_L) \ + | (1 << SMITYPE_G_PCIE_RST1_L) \ + | (1 << SMITYPE_G_ESPI_RSTOUT_L) \ + | (1 << SMITYPE_G_ESPI_RSTIN_L) \ + | (1 << SMITYPE_G_X48M_OUT) \ + | (1 << SMITYPE_G_SYSRESET_L) \ + | (1 << SMITYPE_G_AGPIO104) \ + | (1 << SMITYPE_G_PWR_BTN_L) \ + | (1 << SMITYPE_G_AGPI105) \ + | (1 << SMITYPE_G_AGPI106)) +#define SMITYPE_MP2_WAKE 24 +#define SMITYPE_MP2_GPIO0 25 +#define SMITYPE_ESPI_SYS 26 +#define SMITYPE_ESPI_WAKE_PME 27 +#define SMITYPE_MP2_GPIO1 28 +#define SMITYPE_GPP_PME 29 +#define SMITYPE_NB_GPP_HOT_PLUG 30 +/* 31 Reserved */ +#define SMITYPE_WAKE_L2 32 +#define SMITYPE_PSP 33 +/* 34-35 Reserved */ +#define SMITYPE_ESPI_SCI_B 36 +#define SMITYPE_ESPI1_SYS_EVT_B 37 +#define SMITYPE_ESPI1_WAKE_PME 38 +#define SMITYPE_AZPME 39 +#define SMITYPE_USB_PD_I2C4 40 +#define SMITYPE_GPIO_CTL 41 +#define SMITYPE_ESPI1_SCI_B 42 +#define SMITYPE_ALT_HPET_ALARM 43 +#define SMITYPE_FAN_THERMAL 44 +#define SMITYPE_ASF_MASTER_SLAVE 45 +#define SMITYPE_I2S_WAKE 46 +#define SMITYPE_SMBUS0_MASTER 47 +#define SMITYPE_TWARN 48 +#define SMITYPE_TRAFFIC_MON 49 +#define SMITYPE_ILLB 50 +#define SMITYPE_PWRBUTTON_UP 51 +#define SMITYPE_PROCHOT 52 +#define SMITYPE_APU_HW 53 +#define SMITYPE_NB_SCI 54 +#define SMITYPE_RAS_SERR 55 +#define SMITYPE_XHC0_PME 56 +#define SMITYPE_XHC1_PME 57 +#define SMITYPE_ACDC_TIMER 58 +/* 59-63 Reserved */ +#define SMITYPE_KB_RESET 64 +#define SMITYPE_SLP_TYP 65 +#define SMITYPE_AL2H_ACPI 66 +/* 67-71 Reserved */ +#define SMITYPE_GBL_RLS 72 +#define SMITYPE_BIOS_RLS 73 +#define SMITYPE_PWRBUTTON_DOWN 74 +#define SMITYPE_SMI_CMD_PORT 75 +#define SMITYPE_USB_SMI 76 +#define SMITYPE_SERIRQ 77 +#define SMITYPE_SMBUS0_INTR 78 +/* 79-80 Reserved */ +#define SMITYPE_INTRUDER 81 +#define SMITYPE_VBAT_LOW 82 +#define SMITYPE_PROTHOT 83 +#define SMITYPE_PCI_SERR 84 +/* 85-89 Reserved */ +#define SMITYPE_EMUL60_64 90 +/* 91-132 Reserved */ +#define SMITYPE_FANIN0 133 +/* 134-140 Reserved */ +#define SMITYPE_CF9_WRITE 141 +#define SMITYPE_SHORT_TIMER 142 +#define SMITYPE_LONG_TIMER 143 +#define SMITYPE_AB_SMI 144 +/* 145 Reserved */ +#define SMITYPE_ESPI_SMI 146 +#define SMITYPE_ESPI1_SMI 147 +#define SMITYPE_IOTRAP0 148 +#define SMITYPE_IOTRAP1 149 +#define SMITYPE_IOTRAP2 150 +#define SMITYPE_IOTRAP3 151 +#define SMITYPE_MEMTRAP0 152 +/* 153-155 Reserved */ +#define SMITYPE_CFGTRAP0 156 +/* 157-159 Reserved */ + +#define TYPE_TO_MASK(X) (1 << (X) % 32) + +#define SMI_REG_SMISTS0 0x80 +#define SMI_REG_SMISTS1 0x84 +#define SMI_REG_SMISTS2 0x88 +#define SMI_REG_SMISTS3 0x8c +#define SMI_REG_SMISTS4 0x90 + +#define SMI_REG_POINTER 0x94 +# define SMI_STATUS_SRC_SCI (1 << 0) +# define SMI_STATUS_SRC_0 (1 << 1) /* SMIx80 */ +# define SMI_STATUS_SRC_1 (1 << 2) /* SMIx84... */ +# define SMI_STATUS_SRC_2 (1 << 3) +# define SMI_STATUS_SRC_3 (1 << 4) +# define SMI_STATUS_SRC_4 (1 << 5) + +#define SMI_TIMER 0x96 +#define SMI_TIMER_MASK 0x7fff +#define SMI_TIMER_EN (1 << 15) + +#define SMI_REG_SMITRIG0 0x98 +# define SMITRIG0_PSP (1 << 25) +# define SMITRG0_EOS (1 << 28) +# define SMI_TIMER_SEL (1 << 29) +# define SMITRG0_SMIENB (1 << 31) + +#define SMI_REG_CONTROL0 0xa0 +#define SMI_REG_CONTROL1 0xa4 +#define SMI_REG_CONTROL2 0xa8 +#define SMI_REG_CONTROL3 0xac +#define SMI_REG_CONTROL4 0xb0 +#define SMI_REG_CONTROL5 0xb4 +#define SMI_REG_CONTROL6 0xb8 +#define SMI_REG_CONTROL7 0xbc +#define SMI_REG_CONTROL8 0xc0 +#define SMI_REG_CONTROL9 0xc4 + +#define SMI_MODE_MASK 0x03 + +#endif /* AMD_GENOA_SMI_H */
