Martin Roth (gaumless@gmail.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/10615
commit 46504a07363c9e05bcfa658cc7bac22bcff86650 Author: Martin Roth gaumless@gmail.com Date: Sat Jun 20 16:45:30 2015 -0600
Remove obsolete EARLY_CONSOLE usage
The EARLY_CONSOLE Kconfig symbol was removed in commit 48713a1b - console: Drop EARLY_CONSOLE option
Because the symbol was missing from Kconfig, these platforms had the early console always disabled instead of the intended always enabled.
Change-Id: Idc60ffb2bac2b180f4fdd0adf5c411e1f692a846 Signed-off-by: Martin Roth gaumless@gmail.com --- src/arch/arm64/Makefile.inc | 2 +- src/arch/mips/Makefile.inc | 2 +- src/mainboard/emulation/qemu-armv7/Kconfig | 1 - src/soc/broadcom/cygnus/Kconfig | 1 - src/soc/marvell/bg4cd/Kconfig | 1 - src/soc/nvidia/tegra132/Kconfig | 1 - 6 files changed, 2 insertions(+), 6 deletions(-)
diff --git a/src/arch/arm64/Makefile.inc b/src/arch/arm64/Makefile.inc index 13e8415..c63cb4b 100644 --- a/src/arch/arm64/Makefile.inc +++ b/src/arch/arm64/Makefile.inc @@ -88,7 +88,7 @@ $(objcbfs)/verstage.debug: $(objgenerated)/libverstage.a $$(verstage-objs) @printf " LINK $(subst $(obj)/,,$(@))\n" $(LD_verstage) --gc-sections -static -o $@ -L$(obj) --whole-archive --start-group $(objgenerated)/libverstage.a $$(verstage-objs) --end-group -T $(obj)/mainboard/$(MAINBOARDDIR)/memlayout.verstage.ld
-verstage-$(CONFIG_EARLY_CONSOLE) += early_console.c +verstage-y += early_console.c verstage-y += boot.c verstage-y += div0.c verstage-y += eabi_compat.c diff --git a/src/arch/mips/Makefile.inc b/src/arch/mips/Makefile.inc index cff0151..ccbe740 100644 --- a/src/arch/mips/Makefile.inc +++ b/src/arch/mips/Makefile.inc @@ -61,7 +61,7 @@ endif # CONFIG_ARCH_BOOTBLOCK_MIPS ifeq ($(CONFIG_ARCH_ROMSTAGE_MIPS),y)
romstage-y += boot.c -romstage-$(CONFIG_EARLY_CONSOLE) += early_console.c +romstage-y += early_console.c romstage-y += cache.c romstage-y += mmu.c romstage-y += stages.c diff --git a/src/mainboard/emulation/qemu-armv7/Kconfig b/src/mainboard/emulation/qemu-armv7/Kconfig index 58ddd4e..c6199ea 100644 --- a/src/mainboard/emulation/qemu-armv7/Kconfig +++ b/src/mainboard/emulation/qemu-armv7/Kconfig @@ -26,7 +26,6 @@ config BOARD_SPECIFIC_OPTIONS # dummy select CPU_ARMLTD_CORTEX_A9 select DRIVERS_UART_PL011 select BOOTBLOCK_CONSOLE - select EARLY_CONSOLE select CONSOLE_SERIAL select ARM_BOOTBLOCK_ARMV7 select ARM_ROMSTAGE_ARMV7 diff --git a/src/soc/broadcom/cygnus/Kconfig b/src/soc/broadcom/cygnus/Kconfig index 7c17bd4..e6da57c 100644 --- a/src/soc/broadcom/cygnus/Kconfig +++ b/src/soc/broadcom/cygnus/Kconfig @@ -25,7 +25,6 @@ config SOC_BROADCOM_CYGNUS select ARCH_ROMSTAGE_ARMV7 select ARCH_VERSTAGE_ARMV7 select BOOTBLOCK_CONSOLE - select EARLY_CONSOLE select GENERIC_UDELAY select HAVE_MONOTONIC_TIMER select HAVE_UART_SPECIAL diff --git a/src/soc/marvell/bg4cd/Kconfig b/src/soc/marvell/bg4cd/Kconfig index f2cb16f..930645e 100644 --- a/src/soc/marvell/bg4cd/Kconfig +++ b/src/soc/marvell/bg4cd/Kconfig @@ -26,7 +26,6 @@ config SOC_MARVELL_BG4CD select ARCH_VERSTAGE_ARMV7_M select ARM_BOOTBLOCK_CUSTOM if VBOOT_VERIFY_FIRMWARE select BOOTBLOCK_CONSOLE - select EARLY_CONSOLE select GENERIC_UDELAY select HAVE_MONOTONIC_TIMER select GENERIC_GPIO_LIB diff --git a/src/soc/nvidia/tegra132/Kconfig b/src/soc/nvidia/tegra132/Kconfig index be8ae9b..a5df92a 100644 --- a/src/soc/nvidia/tegra132/Kconfig +++ b/src/soc/nvidia/tegra132/Kconfig @@ -11,7 +11,6 @@ config SOC_NVIDIA_TEGRA132 select GENERIC_UDELAY select HAVE_HARD_RESET select HAVE_UART_SPECIAL - select EARLY_CONSOLE select ARM_BOOTBLOCK_CUSTOM select SMP select ARM64_USE_SECURE_MONITOR
