Timothy Pearson (tpearson@raptorengineeringinc.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/13521
commit 36335a9344822f23eb033e29fd8a9c5d16ea508c Author: Timothy Pearson tpearson@raptorengineeringinc.com Date: Tue Nov 24 14:12:08 2015 -0600
mainboard/asus/kcma-d8: Add copy of ASUS KGPE-D16 board for initial support work
Change-Id: I943e81c8c2987a8333fc2a1cdb3675abf2d90cf1 Signed-off-by: Timothy Pearson tpearson@raptorengineeringinc.com --- src/mainboard/asus/kcma-d8/Kconfig | 103 ++++ src/mainboard/asus/kcma-d8/Kconfig.name | 2 + src/mainboard/asus/kcma-d8/abuild.disabled | 2 + src/mainboard/asus/kcma-d8/acpi/pm_ctrl.asl | 368 +++++++++++++ src/mainboard/asus/kcma-d8/acpi_tables.c | 109 ++++ src/mainboard/asus/kcma-d8/board_info.txt | 5 + src/mainboard/asus/kcma-d8/bootblock.c | 52 ++ src/mainboard/asus/kcma-d8/cmos.default | 30 ++ src/mainboard/asus/kcma-d8/cmos.layout | 155 ++++++ src/mainboard/asus/kcma-d8/devicetree.cb | 253 +++++++++ src/mainboard/asus/kcma-d8/dsdt.asl | 789 ++++++++++++++++++++++++++++ src/mainboard/asus/kcma-d8/get_bus_conf.c | 121 +++++ src/mainboard/asus/kcma-d8/irq_tables.c | 128 +++++ src/mainboard/asus/kcma-d8/mainboard.c | 116 ++++ src/mainboard/asus/kcma-d8/mb_sysconf.h | 40 ++ src/mainboard/asus/kcma-d8/mptable.c | 231 ++++++++ src/mainboard/asus/kcma-d8/resourcemap.c | 550 +++++++++++++++++++ src/mainboard/asus/kcma-d8/romstage.c | 608 +++++++++++++++++++++ src/mainboard/asus/kcma-d8/spd_notes.txt | 46 ++ 19 files changed, 3708 insertions(+)
diff --git a/src/mainboard/asus/kcma-d8/Kconfig b/src/mainboard/asus/kcma-d8/Kconfig new file mode 100644 index 0000000..23c91f0 --- /dev/null +++ b/src/mainboard/asus/kcma-d8/Kconfig @@ -0,0 +1,103 @@ +if BOARD_ASUS_KGPE_D16 + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + select CPU_AMD_SOCKET_G34_NON_AGESA + select DIMM_DDR3 + select DIMM_REGISTERED + # select QRANK_DIMM_SUPPORT + select DIMM_VOLTAGE_SET_SUPPORT + select NORTHBRIDGE_AMD_AMDFAM10 + select SOUTHBRIDGE_AMD_SR5650 + select SOUTHBRIDGE_AMD_SB700 + select SOUTHBRIDGE_AMD_SB700_DISABLE_ISA_DMA + select SOUTHBRIDGE_AMD_SUBTYPE_SP5100 + select SUPERIO_WINBOND_W83667HG_A + select PARALLEL_CPU_INIT + select HAVE_ROMSTAGE_CONSOLE_SPINLOCK + select HAVE_ROMSTAGE_NVRAM_CBFS_SPINLOCK + select HAVE_ROMSTAGE_MICROCODE_CBFS_SPINLOCK + select HAVE_HARD_RESET + select HAVE_OPTION_TABLE + select HAVE_CMOS_DEFAULT + select HAVE_PIRQ_TABLE + select HAVE_MP_TABLE + select HAVE_ACPI_TABLES + select SB_HT_CHAIN_UNITID_OFFSET_ONLY + select LIFT_BSP_APIC_ID + select BOARD_ROMSIZE_KB_2048 + select ENABLE_APIC_EXT_ID + select MMCONF_SUPPORT_DEFAULT + select SPI_FLASH + select SPI_FLASH_WINBOND + select HAVE_ACPI_RESUME + select DRIVERS_I2C_W83795 + select DRIVERS_ASPEED_AST2050 + select MAINBOARD_HAS_NATIVE_VGA_INIT_TEXTMODECFG + +config MAINBOARD_DIR + string + default "asus/kgpe-d16" + +config BOOTBLOCK_MAINBOARD_INIT + string + default "mainboard/asus/kgpe-d16/bootblock.c" + +config DCACHE_RAM_BASE + hex + default 0xc2000 + +config DCACHE_RAM_SIZE + hex + default 0x1e000 + +config APIC_ID_OFFSET + hex + default 0 + +config MAINBOARD_PART_NUMBER + string + default "KGPE-D16" + +config HW_MEM_HOLE_SIZEK + hex + default 0x100000 + +config MAX_CPUS + int + default 32 + +# 2 (internal) processors per G34 socket +config MAX_PHYSICAL_CPUS + int + default 4 + +config HT_CHAIN_UNITID_BASE + hex + default 0x0 + +config HT_CHAIN_END_UNITID_BASE + hex + default 0x20 + +config IRQ_SLOT_COUNT + int + default 13 + +config SOUTHBRIDGE_AMD_SB700_SATA_PORT_COUNT_BITFIELD + hex + default 0x3f + +config ONBOARD_VGA_IS_PRIMARY + bool + default y + +config MAINBOARD_POWER_ON_AFTER_POWER_FAIL + bool + default y + +config MAX_REBOOT_CNT + int + default 10 + +endif # BOARD_ASUS_KGPE_D16 diff --git a/src/mainboard/asus/kcma-d8/Kconfig.name b/src/mainboard/asus/kcma-d8/Kconfig.name new file mode 100644 index 0000000..bdfa31a --- /dev/null +++ b/src/mainboard/asus/kcma-d8/Kconfig.name @@ -0,0 +1,2 @@ +config BOARD_ASUS_KGPE_D16 + bool "KGPE-D16" diff --git a/src/mainboard/asus/kcma-d8/abuild.disabled b/src/mainboard/asus/kcma-d8/abuild.disabled new file mode 100644 index 0000000..5003c92 --- /dev/null +++ b/src/mainboard/asus/kcma-d8/abuild.disabled @@ -0,0 +1,2 @@ +Build disabled until name string update in subsequent patch +Required as Jenkins will prevent merge if the direct copy is built diff --git a/src/mainboard/asus/kcma-d8/acpi/pm_ctrl.asl b/src/mainboard/asus/kcma-d8/acpi/pm_ctrl.asl new file mode 100644 index 0000000..658d877 --- /dev/null +++ b/src/mainboard/asus/kcma-d8/acpi/pm_ctrl.asl @@ -0,0 +1,368 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2015 Raptor Engineering + * Copyright (C) 2009 Advanced Micro Devices, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +/* Port 80 POST card debug */ +OperationRegion (DBG0, SystemIO, 0x80, One) + Field (DBG0, ByteAcc, NoLock, Preserve) { + DBG8, 8 +} + +/* SuperIO control port */ +Name (SPIO, 0x2E) + +/* SuperIO control map */ +OperationRegion (SPIM, SystemIO, SPIO, 0x02) + Field (SPIM, ByteAcc, NoLock, Preserve) { + INDX, 8, + DATA, 8 +} + +/* SuperIO control registers */ +IndexField (INDX, DATA, ByteAcc, NoLock, Preserve) { + Offset (0x07), + CR07, 8, /* Logical device number */ + Offset (0x2C), + CR2C, 8, /* GPIO3 multiplexed pin selection */ + Offset (0x30), + CR30, 8, /* Logical device activation control register */ + Offset (0xE0), + CRE0, 8, /* Wake control register */ + Offset (0xE4), + CRE4, 8, /* Standby power control register */ + Offset (0xE6), + CRE6, 8, /* Mouse wake event configuration register */ + Offset (0xF1), + CRF1, 8, /* GPIO3 data register */ + Offset (0xF3), + CRF3, 8, /* SUSLED mode register */ + Offset (0xF6), + CRF6, 8, /* SMI/PME event generation control register */ + Offset (0xF9), + CRF9, 8, /* ACPI PME configuration register */ +} + +/* Power Management I/O registers */ +OperationRegion(PIOR, SystemIO, 0x00000CD6, 0x00000002) + Field(PIOR, ByteAcc, NoLock, Preserve) { + PIOI, 0x00000008, + PIOD, 0x00000008, +} +IndexField (PIOI, PIOD, ByteAcc, NoLock, Preserve) { + Offset(0x00), /* MiscControl */ + , 1, + T1EE, 1, + T2EE, 1, + Offset(0x01), /* MiscStatus */ + , 1, + T1E, 1, + T2E, 1, + Offset(0x04), /* SmiWakeUpEventEnable3 */ + , 7, + SSEN, 1, + Offset(0x07), /* SmiWakeUpEventStatus3 */ + , 7, + CSSM, 1, + Offset(0x10), /* AcpiEnable */ + , 6, + PWDE, 1, + Offset(0x1C), /* ProgramIoEnable */ + , 3, + MKME, 1, + IO3E, 1, + IO2E, 1, + IO1E, 1, + IO0E, 1, + Offset(0x1D), /* IOMonitorStatus */ + , 3, + MKMS, 1, + IO3S, 1, + IO2S, 1, + IO1S, 1, + IO0S,1, + Offset(0x20), /* AcpiPmEvtBlk */ + APEB, 16, + Offset(0x36), /* GEvtLevelConfig */ + , 6, + ELC6, 1, + ELC7, 1, + Offset(0x37), /* GPMLevelConfig0 */ + , 3, + PLC0, 1, + PLC1, 1, + PLC2, 1, + PLC3, 1, + PLC8, 1, + Offset(0x38), /* GPMLevelConfig1 */ + , 1, + PLC4, 1, + PLC5, 1, + , 1, + PLC6, 1, + PLC7, 1, + Offset(0x3B), /* PMEStatus1 */ + GP0S, 1, + GM4S, 1, + GM5S, 1, + APS, 1, + GM6S, 1, + GM7S, 1, + GP2S, 1, + STSS, 1, + Offset(0x55), /* SoftPciRst */ + SPRE, 1, + , 1, + , 1, + PNAT, 1, + PWMK, 1, + PWNS, 1, + + /* Offset(0x61), */ /* Options_1 */ + /* ,7, */ + /* R617,1, */ + + Offset(0x65), /* UsbPMControl */ + , 4, + URRE, 1, + , 2, + BCDL, 1, + Offset(0x68), /* MiscEnable68 */ + , 2, + MAPC, 1, + TMTE, 1, + , 1, + Offset(0x7C), /* MiscEnable7C */ + , 2, + BLNK, 2, + Offset(0x92), /* GEVENTIN */ + , 7, + E7IS, 1, + Offset(0x96), /* GPM98IN */ + G8IS, 1, + G9IS, 1, + Offset(0x9A), /* EnhanceControl */ + ,7, + HPDE, 1, + Offset(0xA8), /* PIO7654Enable */ + IO4E, 1, + IO5E, 1, + IO6E, 1, + IO7E, 1, + Offset(0xA9), /* PIO7654Status */ + IO4S, 1, + IO5S, 1, + IO6S, 1, + IO7S, 1, +} + +/* PM1 Event Block + * First word is PM1_Status, Second word is PM1_Enable + */ +OperationRegion(P1EB, SystemIO, APEB, 0x04) + Field(P1EB, ByteAcc, NoLock, Preserve) { + TMST, 1, + , 3, + BMST, 1, + GBST, 1, + Offset(0x01), + PBST, 1, + , 1, + RTST, 1, + , 3, + PWST, 1, + SPWS, 1, + Offset(0x02), + TMEN, 1, + , 4, + GBEN, 1, + Offset(0x03), + PBEN, 1, + , 1, + RTEN, 1, + , 3, + PWDA, 1, +} + +/* Wake status package */ +Name(WKST,Package() {Zero, Zero}) + +/* + * _WAK System Wake method + * + * Entry: + * Arg0=The value of the sleeping state S1=1, S2=2 + * + * Exit: + * Return package of 2 DWords + * Dword 1 - Status + * 0x00000000 wake succeeded + * 0x00000001 Wake was signaled but failed due to lack of power + * 0x00000002 Wake was signaled but failed due to thermal condition + * Dword 2 - Power Supply state + * if non-zero the effective S-state the power supply entered + */ +Method(_WAK, 1) { + Store (0x20, DBG8) + + /* Set up LEDs */ + /* Set power LED to steady on */ + Store(0x0, BLNK) + + /* Configure SuperIO for wake */ + /* Access SuperIO ACPI device */ + Store(0x87, INDX) + Store(0x87, INDX) + Store(0x0A, CR07) + + if (LEqual(Arg0, One)) /* Resuming from power state S1 */ + { + /* Deactivate the ACPI device */ + Store(Zero, CR30) + + /* Disable PS/2 SMI/PME events */ + And(CRF6, 0xCF, CRF6) + } + if (Lor(LEqual(Arg0, 0x03), LEqual(Arg0, 0x04))) /* Resuming from power state S3 or S4 */ + { + /* Disable PS/2 wake */ + And(CRE0, 0x1D, CRE0) + And(CRE6, 0x7F, CRE6) + } + + /* Restore default SuperIO access */ + Store(0xAA, INDX) + + Store (0x21, DBG8) + + /* Re-enable HPET */ + Store(1, HPDE) + + /* Restore PCIRST# so it resets USB */ + if (LEqual(Arg0, 3)){ + Store(1, URRE) + } + + /* Configure southbridge for wake */ + /* Arbitrarily clear PciExpWakeStatus */ + Store(PWST, Local1) + Store(Local1, PWST) + + Store (0x22, DBG8) + + Notify(_SB.PWRB, 0x02) /* NOTIFY_DEVICE_WAKE */ + + Return(WKST) +} + +/* + * _PTS - Prepare to Sleep method + * + * Entry: + * Arg0=The value of the sleeping state S1=1, S2=2, etc + * + * Exit: + * -none- + * + * The _PTS control method is executed at the beginning of the sleep process + * for S1-S5. The sleeping value is passed to the _PTS control method. This + * control method may be executed a relatively long time before entering the + * sleep state and the OS may abort the operation without notification to + * the ACPI driver. This method cannot modify the configuration or power + * state of any device in the system. + */ +Method(_PTS, 1) { + Store (Arg0, DBG8) + + /* Set up LEDs */ + if (LEqual(Arg0, One)) /* Power state S1 requested */ + { + /* Set suspend LED to 0.25Hz toggle pulse with 50% duty cycle */ + Store(0x2, BLNK) + } + + /* Configure SuperIO for sleep */ + /* Access SuperIO ACPI device */ + Store(0x87, INDX) + Store(0x87, INDX) + Store(0x0A, CR07) + + /* Disable PS/2 wakeup and connect PANSW_IN to PANSW_OUT */ + And(CRE0, 0x1F, CRE0) + + if (LEqual(Arg0, One)) /* Power state S1 requested */ + { + /* Activate the ACPI device */ + Store(One, CR30) + + /* Disable SMI/PME events for: + * LPT + * FDC + * UART + */ + Store(0x00, CRF6) + + /* Enable PS/2 keyboard SMI/PME events */ + Or(CRF6, 0x10, CRF6) + + /* Enable PS/2 keyboard wake */ + Or(CRE0, 0x40, CRE0) + + /* Enable PS/2 mouse SMI/PME events */ + Or(CRF6, 0x20, CRF6) + + /* Enable PS/2 mouse wake */ + Or(CRE0, 0x20, CRE0) + } else { + /* Enable PS/2 keyboard wake on any keypress */ + Or(CRE0, 0x41, CRE0) + + /* Enable PS/2 mouse wake on any click */ + Or(CRE0, 0x22, CRE0) + Or(CRE6, 0x80, CRE6) + + if (LEqual(Arg0, 0x03)) /* Power state S3 requested */ + { + /* Set VSBGATE# to provide standby power during S3 */ + Or(CRE4, 0x10, CRE4) + } + } + + /* Restore default SuperIO access */ + Store(0xAA, INDX) + + Store (0x10, DBG8) + + /* Don't allow PCIRST# to reset USB */ + if (LEqual(Arg0, 3)){ + Store(0, URRE) + } + + /* Configure southbridge for sleep */ + /* Use bus clock for delay timebase */ + Store(0, BCDL) + /* Defer APIC interrupts until first ACPI access */ + Store(One, MAPC) + + /* On older chips, clear PciExpWakeDisEn */ + // if (LLessEqual(SBRI, 0x13)) { + // Store(0, PWDE) + // } + + Store (0x11, DBG8) + + /* Clear wake status structure. */ + Store(0, Index(WKST,0)) + Store(0, Index(WKST,1)) +} diff --git a/src/mainboard/asus/kcma-d8/acpi_tables.c b/src/mainboard/asus/kcma-d8/acpi_tables.c new file mode 100644 index 0000000..f20e837 --- /dev/null +++ b/src/mainboard/asus/kcma-d8/acpi_tables.c @@ -0,0 +1,109 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2010 Advanced Micro Devices, Inc. + * Copyright (C) 2015 Timothy Pearson tpearson@raptorengineeringinc.com, Raptor Engineering + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <console/console.h> +#include <string.h> +#include <arch/acpi.h> +#include <arch/ioapic.h> +#include <device/pci.h> +#include <device/pci_ids.h> +#include <cpu/x86/msr.h> +#include <cpu/amd/mtrr.h> +#include <cpu/amd/amdfam10_sysconf.h> + +#include "mb_sysconf.h" + +unsigned long acpi_fill_madt(unsigned long current) +{ + device_t dev; + u32 dword; + u32 gsi_base=0; + uint32_t apicid_sp5100; + uint32_t apicid_sr5650; + /* create all subtables for processors */ + current = acpi_create_madt_lapics(current); + + if (IS_ENABLED(CONFIG_ENABLE_APIC_EXT_ID) && (CONFIG_APIC_ID_OFFSET > 0)) + apicid_sp5100 = 0x0; + else + apicid_sp5100 = 0x20; + apicid_sr5650 = apicid_sp5100 + 1; + + /* Write SB700 IOAPIC, only one */ + current += acpi_create_madt_ioapic((acpi_madt_ioapic_t *) current, apicid_sp5100, + IO_APIC_ADDR, gsi_base); + /* IOAPIC on rs5690 */ + gsi_base += 24; /* SB700 has 24 IOAPIC entries. */ + dev = dev_find_slot(0, PCI_DEVFN(0, 0)); + if (dev) { + pci_write_config32(dev, 0xF8, 0x1); + dword = pci_read_config32(dev, 0xFC) & 0xfffffff0; + current += acpi_create_madt_ioapic((acpi_madt_ioapic_t *) current, apicid_sr5650, + dword, gsi_base); + } + + /* bus, source, gsirq, flags */ + current += acpi_create_madt_irqoverride((acpi_madt_irqoverride_t *) + current, 0, 0, 2, 0); + current += acpi_create_madt_irqoverride((acpi_madt_irqoverride_t *) + current, 0, 9, 9, 0xf); + + /* create all subtables for processors */ + current += acpi_create_madt_lapic_nmi((acpi_madt_lapic_nmi_t *)current, 0xff, 0, 1); + /* 1: LINT1 connect to NMI */ + + return current; +} + +unsigned long acpi_fill_ivrs_ioapic(acpi_ivrs_t* ivrs, unsigned long current) +{ + uint8_t *p; + + uint32_t apicid_sp5100; + uint32_t apicid_sr5650; + + if (IS_ENABLED(CONFIG_ENABLE_APIC_EXT_ID) && (CONFIG_APIC_ID_OFFSET > 0)) + apicid_sp5100 = 0x0; + else + apicid_sp5100 = 0x20; + apicid_sr5650 = apicid_sp5100 + 1; + + /* Describe NB IOAPIC */ + p = (uint8_t *)current; + p[0] = 0x48; /* Entry type */ + p[1] = 0; /* Device */ + p[2] = 0; /* Bus */ + p[3] = 0x0; /* Data */ + p[4] = apicid_sr5650; /* IOAPIC ID */ + p[5] = 0x1; /* Device 0 Function 1 */ + p[6] = 0x0; /* Northbridge bus */ + p[7] = 0x1; /* Variety */ + current += 8; + + /* Describe SB IOAPIC */ + p = (uint8_t *)current; + p[0] = 0x48; /* Entry type */ + p[1] = 0; /* Device */ + p[2] = 0; /* Bus */ + p[3] = 0xd7; /* Data */ + p[4] = apicid_sp5100; /* IOAPIC ID */ + p[5] = 0x14 << 3; /* Device 0x14 Function 0 */ + p[6] = 0x0; /* Southbridge bus */ + p[7] = 0x1; /* Variety */ + current += 8; + + return current; +} \ No newline at end of file diff --git a/src/mainboard/asus/kcma-d8/board_info.txt b/src/mainboard/asus/kcma-d8/board_info.txt new file mode 100644 index 0000000..788888e --- /dev/null +++ b/src/mainboard/asus/kcma-d8/board_info.txt @@ -0,0 +1,5 @@ +Category: server +ROM package: PLCC-32 +ROM protocol: LPC +ROM socketed: y +Flashrom support: y \ No newline at end of file diff --git a/src/mainboard/asus/kcma-d8/bootblock.c b/src/mainboard/asus/kcma-d8/bootblock.c new file mode 100644 index 0000000..6f2c0a1 --- /dev/null +++ b/src/mainboard/asus/kcma-d8/bootblock.c @@ -0,0 +1,52 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2015 Timothy Pearson tpearson@raptorengineeringinc.com, Raptor Engineering + * Copyright (C) 2014 Edward O'Callaghan eocallaghan@alterapraxis.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <arch/io.h> +#include <pc80/mc146818rtc.h> + +void bootblock_mainboard_init(void) +{ + uint8_t recovery_enabled; + unsigned char addr; + unsigned char byte; + + bootblock_northbridge_init(); + bootblock_southbridge_init(); + + /* Recovery jumper is connected to SP5100 GPIO61, and clears the GPIO when placed in the Recovery position */ + byte = pci_io_read_config8(PCI_DEV(0, 0x14, 0), 0x56); + byte |= 0x1 << 4; /* Set GPIO61 to input mode */ + pci_io_write_config8(PCI_DEV(0, 0x14, 0), 0x56, byte); + recovery_enabled = (!(pci_io_read_config8(PCI_DEV(0, 0x14, 0), 0x57) & 0x1)); + if (recovery_enabled) { +#if CONFIG_USE_OPTION_TABLE + /* Clear NVRAM checksum */ + for (addr = LB_CKS_RANGE_START; addr <= LB_CKS_RANGE_END; addr++) { + cmos_write(0x0, addr); + } + + /* Set fallback boot */ + byte = cmos_read(RTC_BOOT_BYTE); + byte &= 0xfc; + cmos_write(byte, RTC_BOOT_BYTE); +#else + /* FIXME + * Figure out how to recover if the option table is not available + */ +#endif + } +} diff --git a/src/mainboard/asus/kcma-d8/cmos.default b/src/mainboard/asus/kcma-d8/cmos.default new file mode 100644 index 0000000..0e7afb3 --- /dev/null +++ b/src/mainboard/asus/kcma-d8/cmos.default @@ -0,0 +1,30 @@ +baud_rate = 115200 +debug_level = Spew +multi_core = Enable +slow_cpu = off +compute_unit_siblings = Enable +iommu = Enable +nmi = Disable +hypertransport_speed_limit = Auto +max_mem_clock = DDR3-1600 +minimum_memory_voltage = 1.5V +dimm_spd_checksum = Enforce +ECC_memory = Enable +ECC_redirection = Enable +ecc_scrub_rate = 1.28us +interleave_chip_selects = Enable +interleave_nodes = Disable +interleave_memory_channels = Enable +cpu_c_states = Enable +cpu_cc6_state = Enable +cpu_core_boost = Enable +sata_ahci_mode = Enable +sata_alpm = Disable +maximum_p_state_limit = 0xf +probe_filter = Auto +l3_cache_partitioning = Disable +ieee1394_controller = Enable +gart = Enable +experimental_memory_speed_boost = Disable +power_on_after_fail = On +boot_option = Fallback diff --git a/src/mainboard/asus/kcma-d8/cmos.layout b/src/mainboard/asus/kcma-d8/cmos.layout new file mode 100644 index 0000000..075388e --- /dev/null +++ b/src/mainboard/asus/kcma-d8/cmos.layout @@ -0,0 +1,155 @@ +## +## This file is part of the coreboot project. +## +## Copyright (C) 2015 Timothy Pearson tpearson@raptorengineeringinc.com, Raptor Engineering +## Copyright (C) 2007 AMD +## Written by Yinghai Lu yinghailu@amd.com for AMD. +## +## This program is free software; you can redistribute it and/or modify +## it under the terms of the GNU General Public License as published by +## the Free Software Foundation; either version 2 of the License, or +## (at your option) any later version. +## +## This program is distributed in the hope that it will be useful, +## but WITHOUT ANY WARRANTY; without even the implied warranty of +## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +## GNU General Public License for more details. +## + +entries + +0 384 r 0 reserved_memory +384 1 e 4 boot_option +388 4 r 0 reboot_bits +393 3 e 5 baud_rate +396 5 e 10 ecc_scrub_rate +401 1 e 1 interleave_chip_selects +402 1 e 1 interleave_nodes +403 1 e 1 interleave_memory_channels +404 4 e 8 max_mem_clock +408 1 e 2 multi_core +412 4 e 6 debug_level +440 4 e 9 slow_cpu +444 1 e 1 nmi +445 1 e 1 gart +446 2 e 3 power_on_after_fail +456 1 e 1 ECC_memory +457 1 e 1 ECC_redirection +458 4 e 11 hypertransport_speed_limit +462 2 e 12 minimum_memory_voltage +464 1 e 2 compute_unit_siblings +465 1 e 1 cpu_c_states +466 1 e 1 cpu_cc6_state +467 1 e 1 sata_ahci_mode +468 1 e 1 sata_alpm +469 4 h 0 maximum_p_state_limit +473 2 e 13 dimm_spd_checksum +475 1 e 14 probe_filter +476 1 e 1 l3_cache_partitioning +477 1 e 1 ieee1394_controller +478 1 e 1 iommu +479 1 e 1 cpu_core_boost +480 1 e 1 experimental_memory_speed_boost +481 1 r 0 allow_spd_nvram_cache_restore +728 256 h 0 user_data +984 16 h 0 check_sum +# Reserve the extended AMD configuration registers +1000 24 r 0 amd_reserved + + + +enumerations + +#ID value text +1 0 Disable +1 1 Enable +2 0 Enable +2 1 Disable +3 0 Off +3 1 On +3 2 Last +4 0 Fallback +4 1 Normal +5 0 115200 +5 1 57600 +5 2 38400 +5 3 19200 +5 4 9600 +5 5 4800 +5 6 2400 +5 7 1200 +6 0 Emergency +6 1 Alert +6 2 Critical +6 3 Error +6 4 Warning +6 5 Notice +6 6 Information +6 7 Debug +6 8 Spew +8 0 DDR3-1866 +8 1 DDR3-1600 +8 2 DDR3-1333 +8 3 DDR3-1066 +8 4 DDR3-800 +8 5 DDR3-667 +9 0 off +9 1 87.5% +9 2 75.0% +9 3 62.5% +9 4 50.0% +9 5 37.5% +9 6 25.0% +9 7 12.5% +10 0 Disabled +10 1 40ns +10 2 80ns +10 3 160ns +10 4 320ns +10 5 640ns +10 6 1.28us +10 7 2.56us +10 8 5.12us +10 9 10.2us +10 10 20.5us +10 11 41us +10 12 81.9us +10 13 163.8us +10 14 327.7us +10 15 655.4us +10 16 1.31ms +10 17 2.62ms +10 18 5.24ms +10 19 10.49ms +10 20 20.97ms +10 21 42ms +10 22 84ms +11 0 Auto +11 1 3.2GHz +11 2 3.0GHz +11 3 2.8GHz +11 4 2.6GHz +11 5 2.4GHz +11 6 2.2GHz +11 7 2.0GHz +11 8 1.8GHz +11 9 1.6GHz +11 10 1.4GHz +11 11 1.2GHz +11 12 1.0GHz +11 13 800MHz +11 14 600MHz +11 15 500MHz +12 0 1.5V +12 1 1.35V +12 2 1.25V +12 3 1.15V +13 0 Enforce +13 1 Ignore +13 2 Override +14 0 Disable +14 1 Auto + +checksums + +checksum 392 983 984 diff --git a/src/mainboard/asus/kcma-d8/devicetree.cb b/src/mainboard/asus/kcma-d8/devicetree.cb new file mode 100644 index 0000000..4bf1603 --- /dev/null +++ b/src/mainboard/asus/kcma-d8/devicetree.cb @@ -0,0 +1,253 @@ +chip northbridge/amd/amdfam10/root_complex # Root complex + device cpu_cluster 0 on # (L)APIC cluster + chip cpu/amd/socket_F_1207 # CPU socket + device lapic 0 on end # Local APIC of the CPU + end + end + device domain 0 on # PCI domain + subsystemid 0x1043 0x8163 inherit + chip northbridge/amd/amdfam10 # Northbridge / RAM controller + register "maximum_memory_capacity" = "0x4000000000" # 256GB + device pci 18.0 on end # Link 0 == LDT 0 + device pci 18.0 on end # Link 1 == LDT 1 + device pci 18.0 on end # Link 2 == LDT 2 + device pci 18.0 on # Link 3 == LDT 3 [SB on link 3] + chip southbridge/amd/sr5650 # Primary southbridge + device pci 0.0 on end # HT Root Complex 0x9600 + device pci 0.1 on end # CLKCONFIG + device pci 0.2 on end # IOMMU + device pci 2.0 on # PCIE P2P bridge 0x9603 (GPP1 Port0) + # Slot # PCI E 1 / PCI E 2 + end + device pci 3.0 off end # PCIE P2P bridge 0x960b (GPP1 Port1) + device pci 4.0 on # PCIE P2P bridge 0x9604 (GPP3a Port0) + # PIKE SAS + end + device pci 5.0 off end # PCIE P2P bridge 0x9605 (GPP3a Port1) + device pci 6.0 off end # PCIE P2P bridge 0x9606 (GPP3a Port2) + device pci 7.0 off end # PCIE P2P bridge 0x9607 (GPP3a Port3) + device pci 8.0 off end # NB/SB Link P2P bridge + device pci 9.0 on # Bridge (GPP3a Port4) + # Onboard # NIC A + end + device pci a.0 on # Bridge (GPP3a Port5) + # Onboard # NIC B + end + device pci b.0 on # Bridge (GPP2 Port0) + # Slot # PCI E 4 + end + device pci c.0 on # Bridge (GPP2 Port1) + # Slot # PCI E 5 + end + device pci d.0 on # Bridge (GPP3b Port0) + # Slot # PCI E 3 + end + register "gpp1_configuration" = "0" # Configuration 16:0 default + register "gpp2_configuration" = "1" # Configuration 8:8 + register "gpp3a_configuration" = "2" # Configuration 4:1:1:0:0:0 + register "port_enable" = "0x3f1c" # Enable all ports except 0, 1, 5, 6, and 7 + register "pcie_settling_time" = "1000000" # Allow PIKE to be detected / configured + end + chip southbridge/amd/sb700 # Secondary southbridge + device pci 11.0 on end # SATA + device pci 12.0 on end # USB + device pci 12.1 on end # USB + device pci 12.2 on end # USB + device pci 13.0 on end # USB + device pci 13.1 on end # USB + device pci 13.2 on end # USB + device pci 14.0 on # SM + chip drivers/generic/generic # DIMM n-0-0-0 + device i2c 50 on end + end + chip drivers/generic/generic # DIMM n-0-0-1 + device i2c 51 on end + end + chip drivers/generic/generic # DIMM n-0-1-0 + device i2c 52 on end + end + chip drivers/generic/generic # DIMM n-0-1-1 + device i2c 53 on end + end + chip drivers/generic/generic # DIMM n-1-0-0 + device i2c 54 on end + end + chip drivers/generic/generic # DIMM n-1-0-1 + device i2c 55 on end + end + chip drivers/generic/generic # DIMM n-1-1-0 + device i2c 56 on end + end + chip drivers/generic/generic # DIMM n-1-1-1 + device i2c 57 on end + end + chip drivers/i2c/w83795 + register "fanin_ctl1" = "0xff" # Enable monitoring of FANIN1 - FANIN8 + register "fanin_ctl2" = "0x00" # Connect FANIN11 - FANIN14 to alternate functions + register "temp_ctl1" = "0x2a" # Enable monitoring of DTS, VSEN12, and VSEN13 + register "temp_ctl2" = "0x01" # Enable monitoring of TD1/TR1 + register "temp_dtse" = "0x03" # Enable DTS1 and DTS2 + register "volt_ctl1" = "0xff" # Enable monitoring of VSEN1 - VSEN8 + register "volt_ctl2" = "0xf7" # Enable monitoring of VSEN9 - VSEN11, 3VDD, 3VSB, and VBAT + register "temp1_fan_select" = "0x00" # All fans to manual mode (no dependence on Temp1) + register "temp2_fan_select" = "0x00" # All fans to manual mode (no dependence on Temp2) + register "temp3_fan_select" = "0x00" # All fans to manual mode (no dependence on Temp3) + register "temp4_fan_select" = "0x00" # All fans to manual mode (no dependence on Temp4) + register "temp5_fan_select" = "0x00" # All fans to manual mode (no dependence on Temp5) + register "temp6_fan_select" = "0x00" # All fans to manual mode (no dependence on Temp6) + register "temp1_source_select" = "0x00" # Use TD1/TR1 as data source for Temp1 + register "temp2_source_select" = "0x00" # Use TD2/TR2 as data source for Temp2 + register "temp3_source_select" = "0x00" # Use TD3/TR3 as data source for Temp3 + register "temp4_source_select" = "0x00" # Use TD4/TR4 as data source for Temp4 + register "temp5_source_select" = "0x00" # Use TR5 as data source for Temp5 + register "temp6_source_select" = "0x00" # Use TR6 as data source for Temp6 + register "tr1_critical_temperature" = "85" # Set TD1/TR1 critical temperature to 85°C + register "tr1_critical_hysteresis" = "80" # Set TD1/TR1 critical hysteresis temperature to 80°C + register "tr1_warning_temperature" = "70" # Set TD1/TR1 warning temperature to 70°C + register "tr1_warning_hysteresis" = "65" # Set TD1/TR1 warning hysteresis temperature to 65°C + register "dts_critical_temperature" = "85" # Set DTS (CPU) critical temperature to 85°C + register "dts_critical_hysteresis" = "80" # Set DTS (CPU) critical hysteresis temperature to 80°C + register "dts_warning_temperature" = "70" # Set DTS (CPU) warning temperature to 70°C + register "dts_warning_hysteresis" = "65" # Set DTS (CPU) warning hysteresis temperature to 65°C + register "temp1_critical_temperature" = "80" # Set Temp1 critical temperature to 80°C + register "temp2_critical_temperature" = "80" # Set Temp1 critical temperature to 80°C + register "temp3_critical_temperature" = "80" # Set Temp1 critical temperature to 80°C + register "temp4_critical_temperature" = "80" # Set Temp1 critical temperature to 80°C + register "temp5_critical_temperature" = "80" # Set Temp1 critical temperature to 80°C + register "temp6_critical_temperature" = "80" # Set Temp1 critical temperature to 80°C + register "temp1_target_temperature" = "80" # Set Temp1 target temperature to 80°C + register "temp2_target_temperature" = "80" # Set Temp1 target temperature to 80°C + register "temp3_target_temperature" = "80" # Set Temp1 target temperature to 80°C + register "temp4_target_temperature" = "80" # Set Temp1 target temperature to 80°C + register "temp5_target_temperature" = "80" # Set Temp1 target temperature to 80°C + register "temp6_target_temperature" = "80" # Set Temp1 target temperature to 80°C + register "fan1_nonstop" = "7" # Set Fan 1 minimum speed + register "fan2_nonstop" = "7" # Set Fan 2 minimum speed + register "fan3_nonstop" = "7" # Set Fan 3 minimum speed + register "fan4_nonstop" = "7" # Set Fan 4 minimum speed + register "fan5_nonstop" = "7" # Set Fan 5 minimum speed + register "fan6_nonstop" = "7" # Set Fan 6 minimum speed + register "fan7_nonstop" = "7" # Set Fan 7 minimum speed + register "fan8_nonstop" = "7" # Set Fan 8 minimum speed + register "default_speed" = "100" # All fans to full speed on power up + register "fan1_duty" = "100" # Fan 1 to full speed + register "fan2_duty" = "100" # Fan 2 to full speed + register "fan3_duty" = "100" # Fan 3 to full speed + register "fan4_duty" = "100" # Fan 4 to full speed + register "fan5_duty" = "100" # Fan 5 to full speed + register "fan6_duty" = "100" # Fan 6 to full speed + register "fan7_duty" = "100" # Fan 7 to full speed + register "fan8_duty" = "100" # Fan 8 to full speed + register "vcore1_high_limit_mv" = "1500" # VCORE1 (Node 0) high limit to 1.5V + register "vcore1_low_limit_mv" = "900" # VCORE1 (Node 0) low limit to 0.9V + register "vcore2_high_limit_mv" = "1500" # VCORE2 (Node 1) high limit to 1.5V + register "vcore2_low_limit_mv" = "900" # VCORE2 (Node 1) low limit to 0.9V + register "vsen3_high_limit_mv" = "1600" # VSEN1 (Node 0 RAM voltage) high limit to 1.6V + register "vsen3_low_limit_mv" = "1100" # VSEN1 (Node 0 RAM voltage) low limit to 1.1V + register "vsen4_high_limit_mv" = "1600" # VSEN2 (Node 1 RAM voltage) high limit to 1.6V + register "vsen4_low_limit_mv" = "1100" # VSEN2 (Node 1 RAM voltage) low limit to 1.1V + register "vsen5_high_limit_mv" = "1250" # VSEN5 (Node 0 HT link voltage) high limit to 1.25V + register "vsen5_low_limit_mv" = "1150" # VSEN5 (Node 0 HT link voltage) low limit to 1.15V + register "vsen6_high_limit_mv" = "1250" # VSEN6 (Node 1 HT link voltage) high limit to 1.25V + register "vsen6_low_limit_mv" = "1150" # VSEN6 (Node 1 HT link voltage) low limit to 1.15V + register "vsen7_high_limit_mv" = "1250" # VSEN7 (Northbridge core voltage) high limit to 1.25V + register "vsen7_low_limit_mv" = "1050" # VSEN7 (Northbridge core voltage) low limit to 1.05V + register "vsen8_high_limit_mv" = "1900" # VSEN8 (+1.8V) high limit to 1.9V + register "vsen8_low_limit_mv" = "1700" # VSEN8 (+1.8V) low limit to 1.7V + register "vsen9_high_limit_mv" = "1250" # VSEN9 (+1.2V) high limit to 1.25V + register "vsen9_low_limit_mv" = "1150" # VSEN9 (+1.2V) low limit to 1.15V + register "vsen10_high_limit_mv" = "1150" # VSEN10 (+1.1V) high limit to 1.15V + register "vsen10_low_limit_mv" = "1050" # VSEN10 (+1.1V) low limit to 1.05V + register "vsen11_high_limit_mv" = "1625" # VSEN11 (5VSB, scaling factor ~3.2) high limit to 5.2V + register "vsen11_low_limit_mv" = "1500" # VSEN11 (5VSB, scaling factor ~3.2) low limit to 4.8V + register "vsen12_high_limit_mv" = "1083" # VSEN12 (+12V, scaling factor ~12) high limit to 13V + register "vsen12_low_limit_mv" = "917" # VSEN12 (+12V, scaling factor ~12) low limit to 11V + register "vsen13_high_limit_mv" = "1625" # VSEN13 (+5V, scaling factor ~3.2) high limit to 5.2V + register "vsen13_low_limit_mv" = "1500" # VSEN13 (+5V, scaling factor ~3.2) low limit to 4.8V + register "vdd_high_limit_mv" = "3500" # 3VDD high limit to 3.5V + register "vdd_low_limit_mv" = "3100" # 3VDD low limit to 3.1V + register "vsb_high_limit_mv" = "3500" # 3VSB high limit to 3.5V + register "vsb_low_limit_mv" = "3100" # 3VSB low limit to 3.1V + register "vbat_high_limit_mv" = "3500" # VBAT (+3V) high limit to 3.5V + register "vbat_low_limit_mv" = "2500" # VBAT (+3V) low limit to 2.5V + register "smbus_aux" = "1" # Device located on auxiliary SMBUS controller + device i2c 0x2f on end + end + end + device pci 14.1 on end # IDE 0x439c + device pci 14.2 on end # HDA 0x4383 (ASUS MIO add-on card) + device pci 14.3 on # LPC 0x439d (SMBUS primary controller) + chip superio/winbond/w83667hg-a # Super I/O + device pnp 2e.0 off end # FDC; Not available on the KCMA-D8 + device pnp 2e.1 off end # LPT1; Not available on the KCMA-D8 + device pnp 2e.2 on # COM1 + io 0x60 = 0x3f8 + irq 0x70 = 4 + end + device pnp 2e.3 on # COM2 + io 0x60 = 0x2f8 + irq 0x70 = 3 + end + device pnp 2e.5 on # PS/2 keyboard & mouse + io 0x60 = 0x60 + io 0x62 = 0x64 + irq 0x70 = 1 + irq 0x72 = 12 + end + device pnp 2e.106 off end # SPI: Not available on the KCMA-D8 + device pnp 2e.107 off end # GIPO6 + device pnp 2e.207 off end # GIPO7 + device pnp 2e.307 off end # GIPO8 + device pnp 2e.407 off end # GIPO9 + device pnp 2e.8 off end # WDT + device pnp 2e.108 off end # GPIO 1 + device pnp 2e.9 off end # GPIO2 + device pnp 2e.109 off end # GPIO3 + device pnp 2e.209 off end # GPIO4 + device pnp 2e.309 off end # GPIO5 + device pnp 2e.a on end # ACPI + device pnp 2e.b on # HW Monitor + io 0x60 = 0x290 + irq 0x70 = 5 + end + device pnp 2e.c off end # PECI + device pnp 2e.d off end # VID_BUSSEL + device pnp 2e.f off end # GPIO_PP_OD + end + end + device pci 14.4 on # Bridge + device pci 1.0 on end # VGA + device pci 2.0 on end # FireWire + device pci 3.0 on # Slot + # Slot # PCI 0 + end + end + device pci 14.5 on end # USB OHCI2 0x4399 + end + end + device pci 18.1 on end + device pci 18.2 on end + device pci 18.3 on end + device pci 18.4 on end + device pci 18.5 on end + device pci 19.0 on end # Socket 0 node 1 + device pci 19.1 on end + device pci 19.2 on end + device pci 19.3 on end + device pci 19.4 on end + device pci 19.5 on end + device pci 1a.0 on end # Socket 1 node 0 + device pci 1a.1 on end + device pci 1a.2 on end + device pci 1a.3 on end + device pci 1a.4 on end + device pci 1a.5 on end + device pci 1b.0 on end # Socket 1 node 1 + device pci 1b.1 on end + device pci 1b.2 on end + device pci 1b.3 on end + device pci 1b.4 on end + device pci 1b.5 on end + end + end +end diff --git a/src/mainboard/asus/kcma-d8/dsdt.asl b/src/mainboard/asus/kcma-d8/dsdt.asl new file mode 100644 index 0000000..5f9195a --- /dev/null +++ b/src/mainboard/asus/kcma-d8/dsdt.asl @@ -0,0 +1,789 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2015 Timothy Pearson tpearson@raptorengineeringinc.com, Raptor Engineering + * Copyright (C) 2005 - 2012 Advanced Micro Devices, Inc. + * Copyright (C) 2007-2009 coresystems GmbH + * Copyright (C) 2004 Nick Barker Nick.Barker9@btinternet.com + * Copyright (C) 2007, 2008 Rudolf Marek r.marek@assembler.cz + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +/* + * WARNING: Sleep/Wake is a work in progress and is still somewhat flaky! + * Everything else does to the best of my knowledge... (T.P. 01/26/2015) + */ + +/* + * ISA portions taken from QEMU acpi-dsdt.dsl. + */ + +/* + * PCI link routing templates taken from ck804.asl and modified for this board + */ + +DefinitionBlock ( + "DSDT.AML", /* Output filename */ + "DSDT", /* Signature */ + 0x03, /* DSDT Revision, needs to be 2 or higher for 64bit */ + "ASUS ", /* OEMID */ + "COREBOOT", /* TABLE ID */ + 0x00000001 /* OEM Revision */ + ) +{ + #include "northbridge/amd/amdfam10/amdfam10_util.asl" + #include "southbridge/amd/sr5650/acpi/sr5650.asl" + + /* Some global data */ + Name(OSVR, 3) /* Assume nothing. WinXp = 1, Vista = 2, Linux = 3, WinCE = 4 */ + Name(OSV, Ones) /* Assume nothing */ + Name(PICM, One) /* Assume APIC */ + + /* HPET enable */ + Name (HPTE, 0x1) + + /* Define power states */ + Name (_S0, Package () { 0x00, 0x00, 0x00, 0x00 }) /* Normal operation */ + Name (_S1, Package () { 0x01, 0x01, 0x00, 0x00 }) /* Standby */ + Name (_S3, Package () { 0x03, 0x03, 0x00, 0x00 }) /* Suspend to RAM */ + Name (_S4, Package () { 0x04, 0x04, 0x00, 0x00 }) /* Suspend to disk */ + Name (_S5, Package () { 0x05, 0x05, 0x00, 0x00 }) /* Hard power off */ + + /* The _PIC method is called by the OS to choose between interrupt + * routing via the i8259 interrupt controller or the APIC. + * + * _PIC is called with a parameter of 0 for i8259 configuration and + * with a parameter of 1 for Local Apic/IOAPIC configuration. + */ + Method (_PIC, 1, Serialized) { + If (Arg0) + { + _SB.CIRQ() + } + Store (Arg0, PICM) + } + + /* _PR CPU0 is dynamically supplied by SSDT */ + /* CPU objects and _PSS entries are dynamically supplied by SSDT */ + + Scope(_GPE) { /* Start Scope GPE */ + /* General event 3 */ + Method(_L03) { + /* Level-Triggered GPE */ + Notify(_SB.PWRB, 0x02) /* NOTIFY_DEVICE_WAKE */ + } + + /* General event 4 */ + Method(_L04) { + /* Level-Triggered GPE */ + Notify (_SB.PCI0.PBR0, 0x02) /* NOTIFY_DEVICE_WAKE */ + Notify (_SB.PWRB, 0x02) /* NOTIFY_DEVICE_WAKE */ + } + + /* Keyboard controller PME# */ + Method(_L08) { + /* Level-Triggered GPE */ + Notify(_SB.PCI0.LPC.PS2K, 0x02) /* NOTIFY_DEVICE_WAKE */ + Notify(_SB.PCI0.LPC.PS2M, 0x02) /* NOTIFY_DEVICE_WAKE */ + Notify(_SB.PWRB, 0x02) /* NOTIFY_DEVICE_WAKE */ + } + + /* USB controller PME# */ + Method(_L0B) { + /* Level-Triggered GPE */ + Notify (_SB.PCI0.USB0, 0x02) /* NOTIFY_DEVICE_WAKE */ + Notify (_SB.PCI0.USB1, 0x02) /* NOTIFY_DEVICE_WAKE */ + Notify (_SB.PCI0.USB2, 0x02) /* NOTIFY_DEVICE_WAKE */ + Notify (_SB.PCI0.USB3, 0x02) /* NOTIFY_DEVICE_WAKE */ + Notify (_SB.PCI0.USB4, 0x02) /* NOTIFY_DEVICE_WAKE */ + Notify (_SB.PCI0.USB5, 0x02) /* NOTIFY_DEVICE_WAKE */ + Notify (_SB.PCI0.USB6, 0x02) /* NOTIFY_DEVICE_WAKE */ + Notify (_SB.PWRB, 0x02) /* NOTIFY_DEVICE_WAKE */ + } + + /* GPIO0 or GEvent8 event */ + Method(_L18) { + /* Level-Triggered GPE */ + Notify (_SB.PCI0.PCE1, 0x02) /* NOTIFY_DEVICE_WAKE */ + Notify (_SB.PCI0.NICA, 0x02) /* NOTIFY_DEVICE_WAKE */ + Notify (_SB.PCI0.NICB, 0x02) /* NOTIFY_DEVICE_WAKE */ + Notify (_SB.PCI0.PCE4, 0x02) /* NOTIFY_DEVICE_WAKE */ + Notify (_SB.PCI0.PCE5, 0x02) /* NOTIFY_DEVICE_WAKE */ + Notify (_SB.PCI0.PCE3, 0x02) /* NOTIFY_DEVICE_WAKE */ + } + + } /* End Scope GPE */ + + /* Root of the bus hierarchy */ + Scope (_SB) + { + /* Top southbridge PCI device (SR5690 + SP5100) */ + Device (PCI0) + { + /* BUS0 root bus */ + + Name (_HID, EisaId ("PNP0A08")) /* PCI-e root bus (SR5690) */ + Name (_CID, EisaId ("PNP0A03")) /* PCI root bus (SP5100) */ + Name (_ADR, 0x00180001) + Name (_UID, 0x00) + + Name (HCIN, 0x00) // HC1 + + Method (_BBN, 0, NotSerialized) + { + Return (GBUS (GHCN(HCIN), GHCL(HCIN))) + } + + /* Operating System Capabilities Method */ + Method(_OSC,4) + { + /* Let OS control everything */ + Return (Arg3) + } + + External (BUSN) + External (MMIO) + External (PCIO) + External (SBLK) + External (TOM1) + External (HCLK) + External (SBDN) + External (HCDN) + External (CBST) + + /* PCI Routing Tables */ + Name (PR00, Package () { + /* PIC */ + /* Top southbridge device (SR5690) */ + /* HT Link */ + Package (0x04) { 0x0000FFFF, 0x00, LNKA, 0x00 }, + + /* PCI-E Slot 1 (Bridge) */ + Package (0x04) { 0x0002FFFF, 0x00, LNKE, 0x00 }, + + /* NIC A (Bridge) */ + Package (0x04) { 0x0009FFFF, 0x00, LNKF, 0x00 }, + + /* NIC B (Bridge) */ + Package (0x04) { 0x000AFFFF, 0x00, LNKG, 0x00 }, + + /* PCI-E Slot 4 (Bridge) */ + Package (0x04) { 0x000BFFFF, 0x00, LNKG, 0x00 }, + + /* PCI-E Slot 5 (Bridge) */ + Package (0x04) { 0x000CFFFF, 0x00, LNKG, 0x00 }, + + /* PCI-E Slot 3 (Bridge) */ + Package (0x04) { 0x000DFFFF, 0x00, LNKG, 0x00 }, + + /* Bottom southbridge device (SP5100) */ + /* SATA 0 */ + Package (0x04) { 0x0011FFFF, 0x00, LNKG, 0x00 }, + + /* USB 0 */ + Package (0x04) { 0x0012FFFF, 0x00, LNKA, 0x00 }, + Package (0x04) { 0x0012FFFF, 0x01, LNKB, 0x00 }, + Package (0x04) { 0x0012FFFF, 0x02, LNKC, 0x00 }, + Package (0x04) { 0x0012FFFF, 0x03, LNKD, 0x00 }, + + /* USB 1 */ + Package (0x04) { 0x0013FFFF, 0x00, LNKC, 0x00 }, + Package (0x04) { 0x0013FFFF, 0x01, LNKD, 0x00 }, + Package (0x04) { 0x0013FFFF, 0x02, LNKA, 0x00 }, + Package (0x04) { 0x0013FFFF, 0x03, LNKB, 0x00 }, + + /* SMBUS / IDE / LPC / VGA / FireWire / PCI Slot 0 */ + Package (0x04) { 0x0014FFFF, 0x00, LNKA, 0x00 }, + Package (0x04) { 0x0014FFFF, 0x01, LNKB, 0x00 }, + Package (0x04) { 0x0014FFFF, 0x02, LNKC, 0x00 }, + Package (0x04) { 0x0014FFFF, 0x03, LNKD, 0x00 }, + }) + + Name (AR00, Package () { + /* APIC */ + /* Top southbridge device (SR5690) */ + /* HT Link */ + Package (0x04) { 0x0000FFFF, 0x00, 0x00, 55 }, + + /* PCI-E Slot 1 (Bridge) */ + Package (0x04) { 0x0002FFFF, 0x00, 0x00, 52 }, + + /* NIC A (Bridge) */ + Package (0x04) { 0x0009FFFF, 0x00, 0x00, 53 }, + + /* NIC B (Bridge) */ + Package (0x04) { 0x000AFFFF, 0x00, 0x00, 54 }, + + /* PCI-E Slot 4 (Bridge) */ + Package (0x04) { 0x000BFFFF, 0x00, 0x00, 54 }, + + /* PCI-E Slot 5 (Bridge) */ + Package (0x04) { 0x000CFFFF, 0x00, 0x00, 54 }, + + /* PCI-E Slot 3 (Bridge) */ + Package (0x04) { 0x000DFFFF, 0x00, 0x00, 54 }, + + /* Bottom southbridge device (SP5100) */ + /* SATA 0 */ + Package (0x04) { 0x0011FFFF, 0x00, 0x00, 22 }, + + /* USB 0 */ + Package (0x04) { 0x0012FFFF, 0x00, 0x00, 16 }, + Package (0x04) { 0x0012FFFF, 0x01, 0x00, 17 }, + Package (0x04) { 0x0012FFFF, 0x02, 0x00, 18 }, + Package (0x04) { 0x0012FFFF, 0x03, 0x00, 19 }, + + /* USB 1 */ + Package (0x04) { 0x0013FFFF, 0x00, 0x00, 18 }, + Package (0x04) { 0x0013FFFF, 0x01, 0x00, 19 }, + Package (0x04) { 0x0013FFFF, 0x02, 0x00, 16 }, + Package (0x04) { 0x0013FFFF, 0x03, 0x00, 17 }, + + /* SMBUS / IDE / LPC / VGA / FireWire / PCI Slot 0 */ + Package (0x04) { 0x0014FFFF, 0x00, 0x00, 16 }, + Package (0x04) { 0x0014FFFF, 0x01, 0x00, 17 }, + Package (0x04) { 0x0014FFFF, 0x02, 0x00, 18 }, + Package (0x04) { 0x0014FFFF, 0x03, 0x00, 19 }, + }) + + Name (PR01, Package () { + /* PIC */ + Package (0x04) { 0x1FFFF, 0x00, LNKF, 0x00 }, + Package (0x04) { 0x2FFFF, 0x00, LNKE, 0x00 }, + Package (0x04) { 0x3FFFF, 0x00, LNKG, 0x00 }, + Package (0x04) { 0x3FFFF, 0x01, LNKH, 0x00 }, + Package (0x04) { 0x3FFFF, 0x02, LNKE, 0x00 }, + Package (0x04) { 0x3FFFF, 0x03, LNKF, 0x00 }, + }) + + Name (AR01, Package () { + /* APIC */ + Package (0x04) { 0x1FFFF, 0x00, 0x00, 21 }, + Package (0x04) { 0x2FFFF, 0x00, 0x00, 20 }, + Package (0x04) { 0x3FFFF, 0x00, 0x00, 22 }, + Package (0x04) { 0x3FFFF, 0x01, 0x00, 23 }, + Package (0x04) { 0x3FFFF, 0x02, 0x00, 20 }, + Package (0x04) { 0x3FFFF, 0x03, 0x00, 21 }, + }) + + Name (PR02, Package () { + /* PIC */ + Package (0x04) { 0xFFFF, 0x00, LNKA, 0x00 }, + Package (0x04) { 0xFFFF, 0x01, LNKB, 0x00 }, + Package (0x04) { 0xFFFF, 0x02, LNKC, 0x00 }, + Package (0x04) { 0xFFFF, 0x03, LNKD, 0x00 }, + }) + + Name (AR02, Package () { + /* APIC */ + Package (0x04) { 0xFFFF, 0x00, 0x00, 24 }, + Package (0x04) { 0xFFFF, 0x01, 0x00, 25 }, + Package (0x04) { 0xFFFF, 0x02, 0x00, 26 }, + Package (0x04) { 0xFFFF, 0x03, 0x00, 27 }, + }) + + Name (PR03, Package () { + /* PIC */ + Package (0x04) { 0xFFFF, 0x00, LNKE, 0x00 }, + Package (0x04) { 0xFFFF, 0x01, LNKF, 0x00 }, + Package (0x04) { 0xFFFF, 0x02, LNKG, 0x00 }, + Package (0x04) { 0xFFFF, 0x03, LNKH, 0x00 }, + }) + + Name (AR03, Package () { + /* APIC */ + Package (0x04) { 0xFFFF, 0x00, 0x00, 44 }, + Package (0x04) { 0xFFFF, 0x01, 0x00, 45 }, + Package (0x04) { 0xFFFF, 0x02, 0x00, 46 }, + Package (0x04) { 0xFFFF, 0x03, 0x00, 47 }, + }) + + Name (PR04, Package () { + /* PIC */ + Package (0x04) { 0xFFFF, 0x00, LNKA, 0x00 }, + Package (0x04) { 0xFFFF, 0x01, LNKB, 0x00 }, + Package (0x04) { 0xFFFF, 0x02, LNKC, 0x00 }, + Package (0x04) { 0xFFFF, 0x03, LNKD, 0x00 }, + }) + + Name (AR04, Package () { + /* APIC */ + Package (0x04) { 0xFFFF, 0x00, 0x00, 48 }, + Package (0x04) { 0xFFFF, 0x01, 0x00, 49 }, + Package (0x04) { 0xFFFF, 0x02, 0x00, 50 }, + Package (0x04) { 0xFFFF, 0x03, 0x00, 51 }, + }) + + Name (PR05, Package () { + /* PIC */ + Package (0x04) { 0xFFFF, 0x00, LNKH, 0x00 }, + Package (0x04) { 0xFFFF, 0x01, LNKE, 0x00 }, + Package (0x04) { 0xFFFF, 0x02, LNKF, 0x00 }, + Package (0x04) { 0xFFFF, 0x03, LNKG, 0x00 }, + }) + + Name (AR05, Package () { + /* APIC */ + Package (0x04) { 0xFFFF, 0x00, 0x00, 47 }, + Package (0x04) { 0xFFFF, 0x01, 0x00, 44 }, + Package (0x04) { 0xFFFF, 0x02, 0x00, 45 }, + Package (0x04) { 0xFFFF, 0x03, 0x00, 46 }, + }) + + Name (PR06, Package () { + /* PIC */ + Package (0x04) { 0xFFFF, 0x00, LNKA, 0x00 }, + Package (0x04) { 0xFFFF, 0x01, LNKB, 0x00 }, + Package (0x04) { 0xFFFF, 0x02, LNKC, 0x00 }, + Package (0x04) { 0xFFFF, 0x03, LNKD, 0x00 }, + }) + + Name (AR06, Package () { + /* APIC */ + Package (0x04) { 0xFFFF, 0x00, 0x00, 32 }, + Package (0x04) { 0xFFFF, 0x01, 0x00, 33 }, + Package (0x04) { 0xFFFF, 0x02, 0x00, 34 }, + Package (0x04) { 0xFFFF, 0x03, 0x00, 35 }, + }) + + Name (PR07, Package () { + /* PIC */ + Package (0x04) { 0xFFFF, 0x00, LNKE, 0x00 }, + Package (0x04) { 0xFFFF, 0x01, LNKF, 0x00 }, + Package (0x04) { 0xFFFF, 0x02, LNKG, 0x00 }, + Package (0x04) { 0xFFFF, 0x03, LNKH, 0x00 }, + }) + + Name (AR07, Package () { + /* APIC */ + Package (0x04) { 0xFFFF, 0x00, 0x00, 36 }, + Package (0x04) { 0xFFFF, 0x01, 0x00, 37 }, + Package (0x04) { 0xFFFF, 0x02, 0x00, 38 }, + Package (0x04) { 0xFFFF, 0x03, 0x00, 39 }, + }) + + Name (PR08, Package () { + /* PIC */ + Package (0x04) { 0xFFFF, 0x00, LNKA, 0x00 }, + Package (0x04) { 0xFFFF, 0x01, LNKB, 0x00 }, + Package (0x04) { 0xFFFF, 0x02, LNKC, 0x00 }, + Package (0x04) { 0xFFFF, 0x03, LNKD, 0x00 }, + }) + + Name (AR08, Package () { + /* APIC */ + Package (0x04) { 0xFFFF, 0x00, 0x00, 40 }, + Package (0x04) { 0xFFFF, 0x01, 0x00, 41 }, + Package (0x04) { 0xFFFF, 0x02, 0x00, 42 }, + Package (0x04) { 0xFFFF, 0x03, 0x00, 43 }, + }) + + /* PCI Resource Tables */ + + /* PCI Resource Settings Access */ + Method (_CRS, 0, Serialized) + { + Name (BUF0, ResourceTemplate () + { + IO (Decode16, + 0x0CF8, // Address Range Minimum + 0x0CF8, // Address Range Maximum + 0x01, // Address Alignment + 0x08, // Address Length + ) + WordIO (ResourceProducer, MinFixed, MaxFixed, PosDecode, EntireRange, + 0x0000, // Address Space Granularity + 0x0000, // Address Range Minimum + 0x0CF7, // Address Range Maximum + 0x0000, // Address Translation Offset + 0x0CF8, // Address Length + ,, , TypeStatic) + }) + /* Methods below use SSDT to get actual MMIO regs + The IO ports are from 0xd00, optionally an VGA, + otherwise the info from MMIO is used. + _SB.GXXX(node, link) + */ + Concatenate (_SB.GMEM (0x00, _SB.PCI0.SBLK), BUF0, Local1) + Concatenate (_SB.GIOR (0x00, _SB.PCI0.SBLK), Local1, Local2) + Concatenate (_SB.GWBN (0x00, _SB.PCI0.SBLK), Local2, Local3) + Return (Local3) + } + + /* PCI Routing Table Access */ + Method (_PRT, 0, NotSerialized) { + If (PICM) { + Return (AR00) + } Else { + Return (PR00) + } + } + + /* 0:11.0 SP5100 SATA 0 */ + Device(SAT0) + { + Name (_ADR, 0x00110000) // _ADR: Address + Name(_PRW, Package () {0x05, 0x04}) // Wake from S1-S4 + #include "southbridge/amd/sb700/acpi/sata.asl" + } + + /* 0:12.0 SP5100 USB 0 */ + Device (USB0) + { + Name (_ADR, 0x00120000) // _ADR: Address + Name(_PRW, Package () {0x05, 0x04}) // Wake from S1-S4 + } + + /* 0:12.1 SP5100 USB 1 */ + Device (USB1) + { + Name (_ADR, 0x00120001) // _ADR: Address + Name(_PRW, Package () {0x05, 0x04}) // Wake from S1-S4 + } + + /* 0:12.2 SP5100 USB 2 */ + Device (USB2) + { + Name (_ADR, 0x00120002) // _ADR: Address + Name(_PRW, Package () {0x05, 0x04}) // Wake from S1-S4 + } + + /* 0:13.0 SP5100 USB 3 */ + Device (USB3) + { + Name (_ADR, 0x00130000) // _ADR: Address + Name(_PRW, Package () {0x05, 0x04}) // Wake from S1-S4 + } + + /* 0:13.1 SP5100 USB 4 */ + Device (USB4) + { + Name (_ADR, 0x00130001) // _ADR: Address + Name(_PRW, Package () {0x05, 0x04}) // Wake from S1-S4 + } + + /* 0:13.2 SP5100 USB 5 */ + Device (USB5) + { + Name (_ADR, 0x00130002) // _ADR: Address + Name(_PRW, Package () {0x05, 0x04}) // Wake from S1-S4 + } + + /* 0:14.1 SP5100 IDE Controller */ + Device (IDEC) + { + Name (_ADR, 0x00140001) // _ADR: Address + Name(_PRW, Package () {0x05, 0x04}) // Wake from S1-S4 + #include "southbridge/amd/sb700/acpi/ide.asl" + } + + /* 0:14.3 SP5100 LPC */ + Device (LPC) { + Name (_HID, EisaId ("PNP0A05")) + Name (_ADR, 0x00140003) + + /* Real Time Clock Device */ + Device(RTC0) { + Name(_HID, EISAID("PNP0B00")) /* AT Real Time Clock (not PIIX4 compatible) */ + Name(BUF0, ResourceTemplate() { + IO(Decode16, 0x0070, 0x0070, 0x01, 0x02) + }) + Name(BUF1, ResourceTemplate() { + IRQNoFlags() { 8 } + IO(Decode16, 0x0070, 0x0070, 0x01, 0x02) + }) + Method(_CRS, 0) { + If(HPTE) { + Return(BUF0) + } + Return(BUF1) + } + } + + Device(TMR) { /* Timer */ + Name(_HID,EISAID("PNP0100")) /* System Timer */ + Name(BUF0, ResourceTemplate() { + IO(Decode16, 0x0040, 0x0040, 0x01, 0x04) + }) + Name(BUF1, ResourceTemplate() { + IRQNoFlags() { 0 } + IO(Decode16, 0x0040, 0x0040, 0x01, 0x04) + }) + Method(_CRS, 0) { + If(HPTE) { + Return(BUF0) + } + Return(BUF1) + } + } + + Device(SPKR) { /* Speaker */ + Name(_HID,EISAID("PNP0800")) /* AT style speaker */ + Name(_CRS, ResourceTemplate() { + IO(Decode16, 0x0061, 0x0061, 0, 1) + }) + } + + Device(PIC) { + Name(_HID,EISAID("PNP0000")) /* AT Interrupt Controller */ + Name(_CRS, ResourceTemplate() { + IRQNoFlags() { 2 } + IO(Decode16,0x0020, 0x0020, 0, 2) + IO(Decode16,0x00A0, 0x00A0, 0, 2) + }) + } + + Device(MAD) { /* 8257 DMA */ + Name(_HID,EISAID("PNP0200")) /* Hardware Device ID */ + Name(_CRS, ResourceTemplate() { + DMA(Compatibility,BusMaster,Transfer8){4} + IO(Decode16, 0x0000, 0x0000, 0x10, 0x10) + IO(Decode16, 0x0081, 0x0081, 0x01, 0x03) + IO(Decode16, 0x0087, 0x0087, 0x01, 0x01) + IO(Decode16, 0x0089, 0x0089, 0x01, 0x03) + IO(Decode16, 0x008F, 0x008F, 0x01, 0x01) + IO(Decode16, 0x00C0, 0x00C0, 0x10, 0x20) + }) /* End Name(_SB.PCI0.LpcIsaBr.MAD._CRS) */ + } + + Device(COPR) { + Name(_HID,EISAID("PNP0C04")) /* Math Coprocessor */ + Name(_CRS, ResourceTemplate() { + IO(Decode16, 0x00F0, 0x00F0, 0, 0x10) + IRQNoFlags(){13} + }) + } + + #include "../../../superio/winbond/w83667hg-a/ps2_controller.asl" + + /* UART 1 */ + Device (URT1) + { + Name (_HID, EisaId ("PNP0501")) // "PNP0501" for UART + Name(_PRW, Package () {0x03, 0x04}) // Wake from S1-S4 + Method (_STA, 0, NotSerialized) + { + Return (0x0f) // Always enable + } + Name (_PRS, ResourceTemplate() { + StartDependentFn(0, 1) { + IO(Decode16, 0x3f8, 0x3f8, 0x8, 0x8) + IRQNoFlags() { 4 } + } EndDependentFn() + }) + Method (_CRS, 0) + { + Return(ResourceTemplate() { + IO(Decode16, 0x3f8, 0x3f8, 0x8, 0x8) + IRQNoFlags() { 4 } + }) + } + } + } + + /* High Precision Event Timer */ + Device (HPET) + { + Name (_HID, EisaId ("PNP0103")) + Name (CRS, ResourceTemplate () + { + Memory32Fixed(ReadOnly, 0xFED00000, 0x00000400) + }) + Method (_STA, 0) + { + If(HPTE) { + Return (0x0F) + } + Return (0x0) + } + Method(_CRS, 0) + { + Return(CRS) + } + } + + /* 0:14.4 PCI Bridge */ + Device (PBR0) + { + Name (_ADR, 0x00140004) // _ADR: Address + Name(_PRW, Package () {0x11, 0x04}) // Wake from S1-S4 + Method (_PRT, 0, NotSerialized) // _PRT: PCI Routing Table + { + If (PICM) { + Return (AR01) + } Else { + Return (PR01) + } + } + Device (SLT1) + { + Name (_ADR, 0xFFFF) // _ADR: Address + Name(_PRW, Package () {0x0B, 0x04}) // Wake from S1-S4 + } + } + + /* 0:14.5 SP5100 USB 6 */ + Device (USB6) + { + Name (_ADR, 0x00140005) // _ADR: Address + Name(_PRW, Package () {0x05, 0x04}) // Wake from S1-S4 + } + + /* 2:00.0 PCIe x16 */ + Device (PCE1) + { + Name (_ADR, 0x00020000) // _ADR: Address + Name(_PRW, Package () {0x11, 0x04}) // Wake from S1-S4 + Method (_PRT, 0, NotSerialized) // _PRT: PCI Routing Table + { + If (PICM) { + Return (AR02) + } Else { + Return (PR02) + } + } + Device (SLT1) + { + Name (_ADR, 0xFFFF) // _ADR: Address + Name(_PRW, Package () {0x0B, 0x04}) // Wake from S1-S4 + } + } + + /* 1:00.0 PIKE */ + Device (PIKE) + { + Name (_ADR, 0x00040000) // _ADR: Address + Name(_PRW, Package () {0x11, 0x04}) // Wake from S1-S4 + Method (_PRT, 0, NotSerialized) // _PRT: PCI Routing Table + { + If (PICM) { + Return (AR03) + } Else { + Return (PR03) + } + } + Device (SLT1) + { + Name (_ADR, 0xFFFF) // _ADR: Address + Name(_PRW, Package () {0x0B, 0x04}) // Wake from S1-S4 + } + } + + /* 3:00.0 PCIe NIC A */ + Device (NICA) + { + Name (_ADR, 0x00090000) // _ADR: Address + Name(_PRW, Package () {0x11, 0x04}) // Wake from S1-S4 + Method (_PRT, 0, NotSerialized) // _PRT: PCI Routing Table + { + If (PICM) { + Return (AR04) + } Else { + Return (PR04) + } + } + Device (BDC1) + { + Name (_ADR, Zero) // _ADR: Address + } + } + + /* 4:00.0 PCIe NIC B */ + Device (NICB) + { + Name (_ADR, 0x000A0000) // _ADR: Address + Name(_PRW, Package () {0x11, 0x04}) // Wake from S1-S4 + Method (_PRT, 0, NotSerialized) // _PRT: PCI Routing Table + { + If (PICM) { + Return (AR05) + } Else { + Return (PR05) + } + } + Device (BDC2) + { + Name (_ADR, Zero) // _ADR: Address + } + } + + /* 5:00.0 PCIe x16 */ + Device (PCE4) + { + Name (_ADR, 0x000B0000) // _ADR: Address + Name(_PRW, Package () {0x11, 0x04}) // Wake from S1-S4 + Method (_PRT, 0, NotSerialized) // _PRT: PCI Routing Table + { + If (PICM) { + Return (AR06) + } Else { + Return (PR06) + } + } + Device (SLT1) + { + Name (_ADR, 0xFFFF) // _ADR: Address + Name(_PRW, Package () {0x0B, 0x04}) // Wake from S1-S4 + } + } + + /* 6:00.0 PCIe x16 */ + Device (PCE5) + { + Name (_ADR, 0x000C0000) // _ADR: Address + Name(_PRW, Package () {0x11, 0x04}) // Wake from S1-S4 + Method (_PRT, 0, NotSerialized) // _PRT: PCI Routing Table + { + If (PICM) { + Return (AR07) + } Else { + Return (PR07) + } + } + Device (SLT1) + { + Name (_ADR, 0xFFFF) // _ADR: Address + Name(_PRW, Package () {0x0B, 0x04}) // Wake from S1-S4 + } + } + + /* 7:00.0 PCIe x16 */ + Device (PCE3) + { + Name (_ADR, 0x000D0000) // _ADR: Address + Name(_PRW, Package () {0x11, 0x04}) // Wake from S1-S4 + Method (_PRT, 0, NotSerialized) // _PRT: PCI Routing Table + { + If (PICM) { + Return (AR08) + } Else { + Return (PR08) + } + } + Device (SLT1) + { + Name (_ADR, 0xFFFF) // _ADR: Address + Name(_PRW, Package () {0x0B, 0x04}) // Wake from S1-S4 + } + } + } + + Device (PWRB) { /* Start Power button device */ + Name(_HID, EISAID("PNP0C0C")) + Name(_UID, 0xAA) + Name(_PRW, Package () {3, 0x04}) /* wake from S1-S4 */ + Name(_STA, 0x0B) /* sata is invisible */ + } + } + +#include "acpi/pm_ctrl.asl" + +} diff --git a/src/mainboard/asus/kcma-d8/get_bus_conf.c b/src/mainboard/asus/kcma-d8/get_bus_conf.c new file mode 100644 index 0000000..5ebc714 --- /dev/null +++ b/src/mainboard/asus/kcma-d8/get_bus_conf.c @@ -0,0 +1,121 @@ + /* + * This file is part of the coreboot project. + * + * Copyright (C) 2010 Advanced Micro Devices, Inc. + * Copyright (C) 2015 Timothy Pearson tpearson@raptorengineeringinc.com, Raptor Engineering + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <console/console.h> +#include <device/pci.h> +#include <device/pci_ids.h> +#include <string.h> +#include <stdint.h> +#include <stdlib.h> +#include <cpu/amd/multicore.h> + +#include <cpu/amd/amdfam10_sysconf.h> + +/* Global variables for MB layouts and these will be shared by irqtable mptable +* and acpi_tables busnum is default. +*/ +u8 bus_isa; +u8 bus_sr5650[14]; +u8 bus_sp5100[2]; +u32 apicid_sp5100; + +/* +* Here you only need to set value in pci1234 for HT-IO that could be installed or not +* You may need to preset pci1234 for HTIO board, +* please refer to src/northbridge/amd/amdk8/get_sblk_pci1234.c for detail +*/ +u32 pci1234x[] = { + 0x0000ff0, +}; + +/* +* HT Chain device num, actually it is unit id base of every ht device in chain, +* assume every chain only have 4 ht device at most +*/ +u32 hcdnx[] = { + 0x20202020, +}; + + +u32 sbdn_sr5650; +u32 sbdn_sp5100; + +extern void get_pci1234(void); + +static u32 get_bus_conf_done = 0; + +void get_bus_conf(void) +{ + u32 apicid_base; + device_t dev; + int i; + + if (get_bus_conf_done == 1) + return; /* do it only once */ + get_bus_conf_done = 1; + + sysconf.hc_possible_num = ARRAY_SIZE(pci1234x); + for (i = 0; i < sysconf.hc_possible_num; i++) { + sysconf.pci1234[i] = pci1234x[i]; + sysconf.hcdn[i] = hcdnx[i]; + } + + get_pci1234(); + + sysconf.sbdn = (sysconf.hcdn[0] & 0xff); + sbdn_sr5650 = sysconf.sbdn; + sbdn_sp5100 = 0; + + for (i = 0; i < 2; i++) { + bus_sp5100[i] = 0; + } + for (i = 0; i < ARRAY_SIZE(bus_sr5650); i++) { + bus_sr5650[i] = 0; + } + + + bus_sr5650[0] = (sysconf.pci1234[0] >> 16) & 0xff; + bus_sp5100[0] = bus_sr5650[0]; + + + /* sp5100 */ + dev = dev_find_slot(bus_sp5100[0], PCI_DEVFN(sbdn_sp5100 + 0x14, 4)); + if (dev) { + bus_sp5100[1] = pci_read_config8(dev, PCI_SECONDARY_BUS); + bus_isa = pci_read_config8(dev, PCI_SUBORDINATE_BUS); + bus_isa++; + } + + /* sr5650 */ + for (i = 1; i < ARRAY_SIZE(bus_sr5650); i++) { + dev = dev_find_slot(bus_sr5650[0], PCI_DEVFN(sbdn_sr5650 + i, 0)); + if (dev) { + bus_sr5650[i] = pci_read_config8(dev, PCI_SECONDARY_BUS); + if(255 != bus_sr5650[i]) { + bus_isa = pci_read_config8(dev, PCI_SUBORDINATE_BUS); + bus_isa++; + } + } + } + + /* I/O APICs: APIC ID Version State Address */ + bus_isa = 10; + if (IS_ENABLED(CONFIG_LOGICAL_CPUS)) + apicid_base = get_apicid_base(1); + else + apicid_base = CONFIG_MAX_PHYSICAL_CPUS; + apicid_sp5100 = apicid_base + 0; +} diff --git a/src/mainboard/asus/kcma-d8/irq_tables.c b/src/mainboard/asus/kcma-d8/irq_tables.c new file mode 100644 index 0000000..ef39db2 --- /dev/null +++ b/src/mainboard/asus/kcma-d8/irq_tables.c @@ -0,0 +1,128 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2010 Advanced Micro Devices, Inc. + * Copyright (C) 2015 Raptor Engineering + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <console/console.h> +#include <device/pci_ids.h> +#include <device/pci.h> +#include <string.h> +#include <stdint.h> +#include <arch/pirq_routing.h> + +#include <cpu/amd/amdfam10_sysconf.h> + +/* Free irqs are 3, 4, 5, 6, 7, 9, 10, 11, 12, 14, and 15 */ +#define IRQBM ((1<<3)|(1<<4)|(1<<5)|(1<<6)|(1<<7)|(1<<9)|(1<<10)|(1<<11)|(1<<12)|(1<<14)|(1<<15)) + +#define LNKA 1 +#define LNKB 2 +#define LNKC 3 +#define LNKD 4 + +/* + * For simplicity map LNK[E-H] to LNK[A-D]. + * This also means we are 82C596 compatible. + * Needs 0:11.0 0x46[4] set to 0. + */ +#define LNKE 1 +#define LNKF 2 +#define LNKG 3 +#define LNKH 4 + +static void write_pirq_info(struct irq_info *pirq_info, u8 bus, u8 devfn, + u8 link0, u16 bitmap0, u8 link1, u16 bitmap1, + u8 link2, u16 bitmap2, u8 link3, u16 bitmap3, + u8 slot, u8 rfu) +{ + pirq_info->bus = bus; + pirq_info->devfn = devfn; + pirq_info->irq[0].link = link0; + pirq_info->irq[0].bitmap = bitmap0; + pirq_info->irq[1].link = link1; + pirq_info->irq[1].bitmap = bitmap1; + pirq_info->irq[2].link = link2; + pirq_info->irq[2].bitmap = bitmap2; + pirq_info->irq[3].link = link3; + pirq_info->irq[3].bitmap = bitmap3; + pirq_info->slot = slot; + pirq_info->rfu = rfu; +} +extern u8 bus_isa; +extern u8 bus_sr5650[14]; +extern u8 bus_sp5100[2]; +extern u32 sbdn_sp5100; +extern u32 sbdn_sr5650; + +unsigned long write_pirq_routing_table(unsigned long addr) +{ + struct irq_routing_table *pirq; + struct irq_info *pirq_info; + u32 slot_num; + u8 *v; + + u8 sum = 0; + int i; + + get_bus_conf(); /* it will find out all bus num and apic that share with mptable.c and mptable.c and acpi_tables.c */ + + /* Align the table to be 16 byte aligned. */ + addr += 15; + addr &= ~15; + + /* This table must be between 0xf0000 & 0x100000 */ + printk(BIOS_INFO, "Writing IRQ routing tables to 0x%lx...", addr); + + pirq = (void *)(addr); + v = (u8 *) (addr); + + pirq->signature = PIRQ_SIGNATURE; + pirq->version = PIRQ_VERSION; + + /* Where the interrupt router resides */ + pirq->rtr_bus = bus_sp5100[0]; + pirq->rtr_devfn = PCI_DEVFN(0x14, 4); + + pirq->exclusive_irqs = 0; + + pirq->rtr_vendor = PCI_VENDOR_ID_ATI; + pirq->rtr_device = PCI_DEVICE_ID_ATI_SB700_PCI; + + pirq->miniport_data = 0; + + memset(pirq->rfu, 0, sizeof(pirq->rfu)); + + pirq_info = (void *)(&pirq->checksum + 1); + slot_num = 0; + + /* pci bridge */ + write_pirq_info(pirq_info, bus_sp5100[0], ((sbdn_sp5100 + 0x14) << 3) | 4, + LNKA, IRQBM, LNKB, IRQBM, LNKC, IRQBM, LNKD, IRQBM, 0, 0); + pirq_info++; + slot_num++; + + pirq->size = 32 + 16 * slot_num; + + for (i = 0; i < pirq->size; i++) + sum += v[i]; + + sum = pirq->checksum - sum; + if (sum != pirq->checksum) { + pirq->checksum = sum; + } + + printk(BIOS_INFO, "done.\n"); + + return (unsigned long)pirq_info; +} diff --git a/src/mainboard/asus/kcma-d8/mainboard.c b/src/mainboard/asus/kcma-d8/mainboard.c new file mode 100644 index 0000000..65029d4 --- /dev/null +++ b/src/mainboard/asus/kcma-d8/mainboard.c @@ -0,0 +1,116 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2015 Timothy Pearson tpearson@raptorengineeringinc.com, Raptor Engineering + * Copyright (C) 2010 Advanced Micro Devices, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <console/console.h> +#include <device/device.h> +#include <device/pci.h> +#include <arch/io.h> +#include <cpu/x86/msr.h> +#include <cpu/amd/mtrr.h> +#include <device/pci_def.h> +#include <southbridge/amd/sb700/sb700.h> +#include <southbridge/amd/sr5650/cmn.h> + + +void set_pcie_reset(void); +void set_pcie_dereset(void); + +void set_pcie_reset(void) +{ + device_t pcie_core_dev; + + pcie_core_dev = dev_find_slot(0, PCI_DEVFN(0, 0)); + set_htiu_enable_bits(pcie_core_dev, 0xA8, 0xFFFFFFFF, 0x28282828); + set_htiu_enable_bits(pcie_core_dev, 0xA9, 0x000000FF, 0x00000028); +} + +void set_pcie_dereset(void) +{ + device_t pcie_core_dev; + + pcie_core_dev = dev_find_slot(0, PCI_DEVFN(0, 0)); + set_htiu_enable_bits(pcie_core_dev, 0xA8, 0xFFFFFFFF, 0x6F6F6F6F); + set_htiu_enable_bits(pcie_core_dev, 0xA9, 0x000000FF, 0x0000006F); +} + +/************************************************* +* enable the dedicated function in kgpe-d16 board. +* This function is called earlier than sr5650_enable. +*************************************************/ +static void mainboard_enable(device_t dev) +{ + printk(BIOS_INFO, "Mainboard KGPE-D16 Enable. dev=0x%p\n", dev); + + msr_t msr, msr2; + + /* TOP_MEM: the top of DRAM below 4G */ + msr = rdmsr(TOP_MEM); + printk + (BIOS_INFO, "%s, TOP MEM: msr.lo = 0x%08x, msr.hi = 0x%08x\n", + __func__, msr.lo, msr.hi); + + /* TOP_MEM2: the top of DRAM above 4G */ + msr2 = rdmsr(TOP_MEM2); + printk + (BIOS_INFO, "%s, TOP MEM2: msr2.lo = 0x%08x, msr2.hi = 0x%08x\n", + __func__, msr2.lo, msr2.hi); + + set_pcie_dereset(); + /* get_ide_dma66(); */ +} + +/* override the default SATA PHY setup */ +void sb7xx_51xx_setup_sata_phys(struct device *dev) +{ + /* RPR7.6.1 Program the PHY Global Control to 0x2C00 */ + pci_write_config16(dev, 0x86, 0x2c00); + + /* RPR7.6.2 SATA GENI PHY ports setting */ + pci_write_config32(dev, 0x88, 0x01b48016); + pci_write_config32(dev, 0x8c, 0x01b48016); + pci_write_config32(dev, 0x90, 0x01b48016); + pci_write_config32(dev, 0x94, 0x01b48016); + pci_write_config32(dev, 0x98, 0x01b48016); + pci_write_config32(dev, 0x9c, 0x01b48016); + + /* RPR7.6.3 SATA GEN II PHY port setting for port [0~5]. */ + pci_write_config16(dev, 0xa0, 0xa07a); + pci_write_config16(dev, 0xa2, 0xa07a); + pci_write_config16(dev, 0xa4, 0xa07a); + pci_write_config16(dev, 0xa6, 0xa07a); + pci_write_config16(dev, 0xa8, 0xa07a); + pci_write_config16(dev, 0xaa, 0xa07a); +} + +/* override the default SATA port setup */ +void sb7xx_51xx_setup_sata_port_indication(void *sata_bar5) +{ + uint32_t dword; + + /* RPR7.9 Program Port Indication Registers */ + dword = read32(sata_bar5 + 0xf8); + dword &= ~(0x3f << 12); /* All ports are iSATA */ + dword &= ~0x3f; + write32(sata_bar5 + 0xf8, dword); + + dword = read32(sata_bar5 + 0xfc); + dword &= ~(0x1 << 20); /* No eSATA ports are present */ + write32(sata_bar5 + 0xfc, dword); +} + +struct chip_operations mainboard_ops = { + .enable_dev = mainboard_enable, +}; diff --git a/src/mainboard/asus/kcma-d8/mb_sysconf.h b/src/mainboard/asus/kcma-d8/mb_sysconf.h new file mode 100644 index 0000000..7db0d9f --- /dev/null +++ b/src/mainboard/asus/kcma-d8/mb_sysconf.h @@ -0,0 +1,40 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2010 Advanced Micro Devices, Inc. + * Copyright (C) 2015 Timothy Pearson tpearson@raptorengineeringinc.com, Raptor Engineering + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef MB_SYSCONF_H + +#define MB_SYSCONF_H + +struct mb_sysconf_t { + u8 bus_isa; + u8 bus_8132_0; + u8 bus_8132_1; + u8 bus_8132_2; + u8 bus_8111_0; + u8 bus_8111_1; + u8 bus_8132a[31][3]; + u8 bus_8151[31][2]; + + u32 apicid_8111; + u32 apicid_8132_1; + u32 apicid_8132_2; + u32 apicid_8132a[31][2]; + u32 sbdn3; + u32 sbdn3a[31]; + u32 sbdn5[31]; +}; + +#endif diff --git a/src/mainboard/asus/kcma-d8/mptable.c b/src/mainboard/asus/kcma-d8/mptable.c new file mode 100644 index 0000000..c869d31 --- /dev/null +++ b/src/mainboard/asus/kcma-d8/mptable.c @@ -0,0 +1,231 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2010 Advanced Micro Devices, Inc. + * Copyright (C) 2015 Raptor Engineering + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <console/console.h> +#include <arch/smp/mpspec.h> +#include <device/pci.h> +#include <arch/io.h> +#include <string.h> +#include <stdint.h> +#include <cpu/amd/amdfam10_sysconf.h> + +extern u8 bus_sr5650[14]; +extern u8 bus_sp5100[2]; + +extern u32 apicid_sp5100; + +extern u32 sbdn_sr5650; +extern u32 sbdn_sp5100; + + +static void *smp_write_config_table(void *v) +{ + struct mp_config_table *mc; + int bus_isa; + u32 apicid_sr5650; + device_t dev; + uint8_t sp5100_bus_number; + + mc = (void *)(((char *)v) + SMP_FLOATING_TABLE_LEN); + + mptable_init(mc, LOCAL_APIC_ADDR); + + smp_write_processors(mc); + + get_bus_conf(); + + if (IS_ENABLED(CONFIG_ENABLE_APIC_EXT_ID) && (CONFIG_APIC_ID_OFFSET > 0)) + apicid_sp5100 = 0x0; + else + apicid_sp5100 = 0x20; + apicid_sr5650 = apicid_sp5100 + 1; + + mptable_write_buses(mc, NULL, &bus_isa); + /* I/O APICs: APIC ID Version State Address */ + { + uint32_t *dword_ptr; + uint32_t dword; + uint16_t word; + uint8_t byte; + + sp5100_bus_number = 0; //bus_sp5100[0]; TODO: why bus_sp5100[0] use same value of bus_sr5650[0] assigned by get_pci1234(), instead of 0. + + dev = dev_find_slot(sp5100_bus_number, PCI_DEVFN(sbdn_sp5100 + 0x14, 0)); + if (dev) { + dword_ptr = (u32 *)(pci_read_config32(dev, 0x74) & 0xfffffff0); + smp_write_ioapic(mc, apicid_sp5100, 0x11, dword_ptr); + + /* Initialize interrupt mapping */ + /* USB 1 & 2 */ + word = pci_read_config16(dev, 0xbe); + word &= ~0x3f3f; + word |= 0x0; /* 0: INTA, ...., 7: INTH */ + word |= (0x1 << 3); /* 0: INTA, ...., 7: INTH */ + word |= (0x2 << 8); /* 0: INTA, ...., 7: INTH */ + word |= (0x3 << 11); /* 0: INTA, ...., 7: INTH */ + pci_write_config16(dev, 0xbe, word); + + /* USB 3 */ + byte = pci_read_config8(dev, 0x63); + byte &= 0xf8; + byte |= (0x2 << 4); /* 0: INTA, ...., 7: INTH */ + pci_write_config8(dev, 0x63, byte); + + dword = pci_read_config32(dev, 0xac); + + /* SATA */ + dword &= ~(7 << 26); + dword |= (0x6 << 26); /* 0: INTA, ...., 7: INTH */ + + /* Hide IDE */ + dword &= ~(0x00080000); + + /* dword_ptr |= 1<<22; PIC and APIC co exists */ + pci_write_config32(dev, 0xac, dword); + + /* + * 00:12.0: PROG SATA : INT F + * 00:13.0: INTA USB_0 + * 00:13.1: INTB USB_1 + * 00:13.2: INTC USB_2 + * 00:13.3: INTD USB_3 + * 00:13.4: INTC USB_4 + * 00:13.5: INTD USB2 + * 00:14.1: INTA IDE + * 00:14.2: Prog HDA : INT E + * 00:14.5: INTB ACI + * 00:14.6: INTB MCI + */ + } + dev = dev_find_slot(0, PCI_DEVFN(0, 0)); + if (dev) { + pci_write_config32(dev, 0xF8, 0x1); + dword_ptr = (u32 *)(pci_read_config32(dev, 0xFC) & 0xfffffff0); + smp_write_ioapic(mc, apicid_sr5650, 0x11, dword_ptr); + } + } + + /* I/O Ints: Type Polarity Trigger Bus ID IRQ APIC ID PIN# */ +#define IO_LOCAL_INT(type, intr, apicid, pin) \ + smp_write_lintsrc(mc, (type), MP_IRQ_TRIGGER_EDGE | MP_IRQ_POLARITY_HIGH, bus_isa, (intr), (apicid), (pin)); + + mptable_add_isa_interrupts(mc, bus_isa, apicid_sp5100, 0); + + /* SR5650 devices */ + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, 0, (((0)<<2)|(2)), apicid_sr5650, 31); /* Device 0 Function 2 (LNKA, APIC pin 31) */ + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, 0, (((2)<<2)|(0)), apicid_sr5650, 28); /* Device 2 (LNKE, APIC pin 28) */ + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, 0, (((4)<<2)|(0)), apicid_sr5650, 28); /* Device 4 (LNKF, APIC pin 28) */ + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, 0, (((9)<<2)|(0)), apicid_sr5650, 29); /* Device 9 (LNKG, APIC pin 29) */ + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, 0, (((10)<<2)|(0)), apicid_sr5650, 30); /* Device 10 (LNKG, APIC pin 30) */ + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, 0, (((11)<<2)|(0)), apicid_sr5650, 30); /* Device 11 (LNKG, APIC pin 30) */ + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, 0, (((12)<<2)|(0)), apicid_sr5650, 30); /* Device 12 (LNKG, APIC pin 30) */ + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, 0, (((13)<<2)|(0)), apicid_sr5650, 30); /* Device 13 (LNKG, APIC pin 30)) */ + + dev = dev_find_slot(0, PCI_DEVFN(0x2, 0)); + if (dev && dev->enabled) { + uint8_t bus_pci = dev->link_list->secondary; + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_pci, (((0)<<0x2)|(0)), apicid_sr5650, 0); /* card behind dev2 */ + } + dev = dev_find_slot(0, PCI_DEVFN(0x4, 0)); + if (dev && dev->enabled) { + uint8_t bus_pci = dev->link_list->secondary; + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_pci, (((0)<<0x4)|(0)), apicid_sr5650, 0); /* PIKE */ + } + dev = dev_find_slot(0, PCI_DEVFN(0x9, 0)); + if (dev && dev->enabled) { + uint8_t bus_pci = dev->link_list->secondary; + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_pci, (((0)<<0x9)|(0)), apicid_sr5650, 23); /* NIC A */ + } + dev = dev_find_slot(0, PCI_DEVFN(0xa, 0)); + if (dev && dev->enabled) { + uint8_t bus_pci = dev->link_list->secondary; + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_pci, (((0)<<0xa)|(0)), apicid_sr5650, 24); /* NIC B */ + } + dev = dev_find_slot(0, PCI_DEVFN(0xb, 0)); + if (dev && dev->enabled) { + uint8_t bus_pci = dev->link_list->secondary; + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_pci, (((0)<<0xb)|(0)), apicid_sr5650, 0); /* card behind dev11 */ + } + dev = dev_find_slot(0, PCI_DEVFN(0xc, 0)); + if (dev && dev->enabled) { + uint8_t bus_pci = dev->link_list->secondary; + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_pci, (((0)<<0xc)|(0)), apicid_sr5650, 0); /* card behind dev12 */ + } + dev = dev_find_slot(0, PCI_DEVFN(0xd, 0)); + if (dev && dev->enabled) { + uint8_t bus_pci = dev->link_list->secondary; + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_pci, (((0)<<0xd)|(0)), apicid_sr5650, 0); /* card behind dev13 */ + } + + /* PCI interrupts are level triggered, and are + * associated with a specific bus/device/function tuple. + */ +#define PCI_INT(bus, dev, interrupt_signal, pin) \ + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, (bus), (((dev)<<2)|(interrupt_signal)), apicid_sp5100, (pin)) + + /* USB1 */ + PCI_INT(sp5100_bus_number, 0x12, 0x0, 0x10); /* OHCI0 Port 0~2 */ + PCI_INT(sp5100_bus_number, 0x12, 0x1, 0x11); /* OHCI1 Port 3~5 */ + + /* USB2 */ + PCI_INT(sp5100_bus_number, 0x13, 0x0, 0x12); /* OHCI0 Port 6~8 */ + PCI_INT(sp5100_bus_number, 0x13, 0x1, 0x13); /* EHCI Port 6~11 */ + + /* USB3 */ + PCI_INT(sp5100_bus_number, 0x14, 0x3, 0x12); /* OHCI0 Port 12~13 */ + + /* SATA */ + PCI_INT(sp5100_bus_number, 0x11, 0x0, 0x16); /* 6, INTG */ + + /* PCI slots */ + dev = dev_find_slot(0, PCI_DEVFN(0x14, 4)); + if (dev && dev->enabled) { + u8 bus_pci = dev->link_list->secondary; + + /* PCI_SLOT 0. */ + PCI_INT(bus_pci, 0x1, 0x0, 0x15); + PCI_INT(bus_pci, 0x1, 0x1, 0x16); + PCI_INT(bus_pci, 0x1, 0x2, 0x17); + PCI_INT(bus_pci, 0x1, 0x3, 0x14); + + /* PCI_SLOT 1. */ + PCI_INT(bus_pci, 0x2, 0x0, 0x14); + PCI_INT(bus_pci, 0x2, 0x1, 0x15); + PCI_INT(bus_pci, 0x2, 0x2, 0x16); + PCI_INT(bus_pci, 0x2, 0x3, 0x17); + + /* PCI_SLOT 2. */ + PCI_INT(bus_pci, 0x3, 0x0, 0x16); + PCI_INT(bus_pci, 0x3, 0x1, 0x17); + PCI_INT(bus_pci, 0x3, 0x2, 0x14); + PCI_INT(bus_pci, 0x3, 0x3, 0x15); + } + + /*Local Ints: Type Polarity Trigger Bus ID IRQ APIC ID PIN# */ + IO_LOCAL_INT(mp_ExtINT, 0x0, MP_APIC_ALL, 0x0); + IO_LOCAL_INT(mp_NMI, 0x0, MP_APIC_ALL, 0x1); + /* There is no extension information... */ + + /* Compute the checksums */ + return mptable_finalize(mc); +} + +unsigned long write_smp_table(unsigned long addr) +{ + void *v; + v = smp_write_floating_table(addr, 0); + return (unsigned long)smp_write_config_table(v); +} diff --git a/src/mainboard/asus/kcma-d8/resourcemap.c b/src/mainboard/asus/kcma-d8/resourcemap.c new file mode 100644 index 0000000..8bcb28b --- /dev/null +++ b/src/mainboard/asus/kcma-d8/resourcemap.c @@ -0,0 +1,550 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2015 Timothy Pearson tpearson@raptorengineeringinc.com, Raptor Engineering + * + * Copyright (C) 2007 AMD + * Written by Yinghai Lu yinghailu@amd.com for AMD. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +static void setup_mb_resource_map(void) +{ + static const unsigned int fam15h_register_values[] = { + /* Careful set limit registers before base registers which contain the enables */ + /* DRAM Limit i Registers + * F1:0x44 i = 0 + * F1:0x4C i = 1 + * F1:0x54 i = 2 + * F1:0x5C i = 3 + * F1:0x64 i = 4 + * F1:0x6C i = 5 + * F1:0x74 i = 6 + * F1:0x7C i = 7 + * [ 2: 0] Destination Node ID + * 000 = Node 0 + * 001 = Node 1 + * 010 = Node 2 + * 011 = Node 3 + * 100 = Node 4 + * 101 = Node 5 + * 110 = Node 6 + * 111 = Node 7 + * [ 7: 3] Reserved + * [10: 8] Interleave select + * specifies the values of A[14:12] to use with interleave enable. + * [15:11] Reserved + * [31:16] DRAM Limit Address i Bits 39-24 + * This field defines the upper address bits of a 40 bit address + * that define the end of the DRAM region. + */ + // PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x44), 0x0000f8f8, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x4C), 0x0000f8f8, 0x00000001, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x54), 0x0000f8f8, 0x00000002, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x5C), 0x0000f8f8, 0x00000003, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x64), 0x0000f8f8, 0x00000004, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x6C), 0x0000f8f8, 0x00000005, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x74), 0x0000f8f8, 0x00000006, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x7C), 0x0000f8f8, 0x00000007, + + /* DRAM Base i Registers + * F1:0x40 i = 0 + * F1:0x48 i = 1 + * F1:0x50 i = 2 + * F1:0x58 i = 3 + * F1:0x60 i = 4 + * F1:0x68 i = 5 + * F1:0x70 i = 6 + * F1:0x78 i = 7 + * [ 0: 0] Read Enable + * 0 = Reads Disabled + * 1 = Reads Enabled + * [ 1: 1] Write Enable + * 0 = Writes Disabled + * 1 = Writes Enabled + * [ 7: 2] Reserved + * [10: 8] Interleave Enable + * 000 = No interleave + * 001 = Interleave on A[12] (2 nodes) + * 010 = reserved + * 011 = Interleave on A[12] and A[14] (4 nodes) + * 100 = reserved + * 101 = reserved + * 110 = reserved + * 111 = Interleve on A[12] and A[13] and A[14] (8 nodes) + * [15:11] Reserved + * [31:16] DRAM Base Address i Bits 39-24 + * This field defines the upper address bits of a 40-bit address + * that define the start of the DRAM region. + */ + // PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x40), 0x0000f8fc, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x48), 0x0000f8fc, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x50), 0x0000f8fc, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x58), 0x0000f8fc, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x60), 0x0000f8fc, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x68), 0x0000f8fc, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x70), 0x0000f8fc, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x78), 0x0000f8fc, 0x00000000, + + /* Memory-Mapped I/O Limit i Registers + * F1:0x84 i = 0 + * F1:0x8C i = 1 + * F1:0x94 i = 2 + * F1:0x9C i = 3 + * F1:0xA4 i = 4 + * F1:0xAC i = 5 + * F1:0xB4 i = 6 + * F1:0xBC i = 7 + * [ 2: 0] Destination Node ID + * 000 = Node 0 + * 001 = Node 1 + * 010 = Node 2 + * 011 = Node 3 + * 100 = Node 4 + * 101 = Node 5 + * 110 = Node 6 + * 111 = Node 7 + * [ 3: 3] Reserved + * [ 5: 4] Destination Link ID + * 00 = Link 0 + * 01 = Link 1 + * 10 = Link 2 + * 11 = Link 3 + * [ 6: 6] Reserved + * [ 7: 7] Non-Posted + * 0 = CPU writes may be posted + * 1 = CPU writes must be non-posted + * [31: 8] Memory-Mapped I/O Limit Address i (39-16) + * This field defines the upp adddress bits of a 40-bit address that + * defines the end of a memory-mapped I/O region n + */ + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x84), 0x00000048, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x8C), 0x00000048, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x94), 0x00000048, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x9C), 0x00000048, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xA4), 0x00000048, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xAC), 0x00000048, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xB4), 0x00000048, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xBC), 0x00000048, 0x00000000, + + /* Memory-Mapped I/O Base i Registers + * F1:0x80 i = 0 + * F1:0x88 i = 1 + * F1:0x90 i = 2 + * F1:0x98 i = 3 + * F1:0xA0 i = 4 + * F1:0xA8 i = 5 + * F1:0xB0 i = 6 + * F1:0xB8 i = 7 + * [ 0: 0] Read Enable + * 0 = Reads disabled + * 1 = Reads Enabled + * [ 1: 1] Write Enable + * 0 = Writes disabled + * 1 = Writes Enabled + * [ 2: 2] Cpu Disable + * 0 = Cpu can use this I/O range + * 1 = Cpu requests do not use this I/O range + * [ 3: 3] Lock + * 0 = base/limit registers i are read/write + * 1 = base/limit registers i are read-only + * [ 7: 4] Reserved + * [31: 8] Memory-Mapped I/O Base Address i (39-16) + * This field defines the upper address bits of a 40bit address + * that defines the start of memory-mapped I/O region i + */ + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x80), 0x000000f0, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x88), 0x000000f0, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x90), 0x000000f0, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x98), 0x000000f0, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xA0), 0x000000f0, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xA8), 0x000000f0, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xB0), 0x000000f0, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xB8), 0x000000f0, 0x00000000, + + /* PCI I/O Limit i Registers + * F1:0xC4 i = 0 + * F1:0xCC i = 1 + * F1:0xD4 i = 2 + * F1:0xDC i = 3 + * [ 2: 0] Destination Node ID + * 000 = Node 0 + * 001 = Node 1 + * 010 = Node 2 + * 011 = Node 3 + * 100 = Node 4 + * 101 = Node 5 + * 110 = Node 6 + * 111 = Node 7 + * [ 3: 3] Reserved + * [ 5: 4] Destination Link ID + * 00 = Link 0 + * 01 = Link 1 + * 10 = Link 2 + * 11 = Link 3 + * [11: 6] Reserved + * [24:12] PCI I/O Limit Address i + * This field defines the end of PCI I/O region n + * [31:25] Reserved + */ + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xC4), 0xFE000FC8, 0x00fff010, /* link 1 of cpu 0 --> AMD SR5690 */ + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xCC), 0xFE000FC8, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xD4), 0xFE000FC8, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xDC), 0xFE000FC8, 0x00000000, + + /* PCI I/O Base i Registers + * F1:0xC0 i = 0 + * F1:0xC8 i = 1 + * F1:0xD0 i = 2 + * F1:0xD8 i = 3 + * [ 0: 0] Read Enable + * 0 = Reads Disabled + * 1 = Reads Enabled + * [ 1: 1] Write Enable + * 0 = Writes Disabled + * 1 = Writes Enabled + * [ 3: 2] Reserved + * [ 4: 4] VGA Enable + * 0 = VGA matches Disabled + * 1 = matches all address < 64K and where A[9:0] is in the + * range 3B0-3BB or 3C0-3DF independent of the base & limit registers + * [ 5: 5] ISA Enable + * 0 = ISA matches Disabled + * 1 = Blocks address < 64K and in the last 768 bytes of eack 1K block + * from matching agains this base/limit pair + * [11: 6] Reserved + * [24:12] PCI I/O Base i + * This field defines the start of PCI I/O region n + * [31:25] Reserved + */ +// PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xC0), 0xFE000FCC, 0x00001013, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xC8), 0xFE000FCC, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xD0), 0xFE000FCC, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xD8), 0xFE000FCC, 0x00000000, + + /* Config Base and Limit i Registers + * F1:0xE0 i = 0 + * F1:0xE4 i = 1 + * F1:0xE8 i = 2 + * F1:0xEC i = 3 + * [ 0: 0] Read Enable + * 0 = Reads Disabled + * 1 = Reads Enabled + * [ 1: 1] Write Enable + * 0 = Writes Disabled + * 1 = Writes Enabled + * [ 2: 2] Device Number Compare Enable + * 0 = The ranges are based on bus number + * 1 = The ranges are ranges of devices on bus 0 + * [ 3: 3] Reserved + * [ 6: 4] Destination Node + * 000 = Node 0 + * 001 = Node 1 + * 010 = Node 2 + * 011 = Node 3 + * 100 = Node 4 + * 101 = Node 5 + * 110 = Node 6 + * 111 = Node 7 + * [ 7: 7] Reserved + * [ 9: 8] Destination Link + * 00 = Link 0 + * 01 = Link 1 + * 10 = Link 2 + * 11 - Link 3 + * [15:10] Reserved + * [23:16] Bus Number Base i + * This field defines the lowest bus number in configuration region i + * [31:24] Bus Number Limit i + * This field defines the highest bus number in configuration region i + */ + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xE0), 0x0000FC88, 0x05000103, /* link 1 of cpu 0 --> AMD SR5690 */ + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xE4), 0x0000FC88, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xE8), 0x0000FC88, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xEC), 0x0000FC88, 0x00000000, + + }; + + static const unsigned int fam10h_register_values[] = { + /* Careful set limit registers before base registers which contain the enables */ + /* DRAM Limit i Registers + * F1:0x44 i = 0 + * F1:0x4C i = 1 + * F1:0x54 i = 2 + * F1:0x5C i = 3 + * F1:0x64 i = 4 + * F1:0x6C i = 5 + * F1:0x74 i = 6 + * F1:0x7C i = 7 + * [ 2: 0] Destination Node ID + * 000 = Node 0 + * 001 = Node 1 + * 010 = Node 2 + * 011 = Node 3 + * 100 = Node 4 + * 101 = Node 5 + * 110 = Node 6 + * 111 = Node 7 + * [ 7: 3] Reserved + * [10: 8] Interleave select + * specifies the values of A[14:12] to use with interleave enable. + * [15:11] Reserved + * [31:16] DRAM Limit Address i Bits 39-24 + * This field defines the upper address bits of a 40 bit address + * that define the end of the DRAM region. + */ + // PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x44), 0x0000f8f8, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x4C), 0x0000f8f8, 0x00000001, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x54), 0x0000f8f8, 0x00000002, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x5C), 0x0000f8f8, 0x00000003, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x64), 0x0000f8f8, 0x00000004, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x6C), 0x0000f8f8, 0x00000005, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x74), 0x0000f8f8, 0x00000006, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x7C), 0x0000f8f8, 0x00000007, + + /* DRAM Base i Registers + * F1:0x40 i = 0 + * F1:0x48 i = 1 + * F1:0x50 i = 2 + * F1:0x58 i = 3 + * F1:0x60 i = 4 + * F1:0x68 i = 5 + * F1:0x70 i = 6 + * F1:0x78 i = 7 + * [ 0: 0] Read Enable + * 0 = Reads Disabled + * 1 = Reads Enabled + * [ 1: 1] Write Enable + * 0 = Writes Disabled + * 1 = Writes Enabled + * [ 7: 2] Reserved + * [10: 8] Interleave Enable + * 000 = No interleave + * 001 = Interleave on A[12] (2 nodes) + * 010 = reserved + * 011 = Interleave on A[12] and A[14] (4 nodes) + * 100 = reserved + * 101 = reserved + * 110 = reserved + * 111 = Interleve on A[12] and A[13] and A[14] (8 nodes) + * [15:11] Reserved + * [31:16] DRAM Base Address i Bits 39-24 + * This field defines the upper address bits of a 40-bit address + * that define the start of the DRAM region. + */ + // PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x40), 0x0000f8fc, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x48), 0x0000f8fc, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x50), 0x0000f8fc, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x58), 0x0000f8fc, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x60), 0x0000f8fc, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x68), 0x0000f8fc, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x70), 0x0000f8fc, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x78), 0x0000f8fc, 0x00000000, + + /* Memory-Mapped I/O Limit i Registers + * F1:0x84 i = 0 + * F1:0x8C i = 1 + * F1:0x94 i = 2 + * F1:0x9C i = 3 + * F1:0xA4 i = 4 + * F1:0xAC i = 5 + * F1:0xB4 i = 6 + * F1:0xBC i = 7 + * [ 2: 0] Destination Node ID + * 000 = Node 0 + * 001 = Node 1 + * 010 = Node 2 + * 011 = Node 3 + * 100 = Node 4 + * 101 = Node 5 + * 110 = Node 6 + * 111 = Node 7 + * [ 3: 3] Reserved + * [ 5: 4] Destination Link ID + * 00 = Link 0 + * 01 = Link 1 + * 10 = Link 2 + * 11 = Link 3 + * [ 6: 6] Reserved + * [ 7: 7] Non-Posted + * 0 = CPU writes may be posted + * 1 = CPU writes must be non-posted + * [31: 8] Memory-Mapped I/O Limit Address i (39-16) + * This field defines the upp adddress bits of a 40-bit address that + * defines the end of a memory-mapped I/O region n + */ + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x84), 0x00000048, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x8C), 0x00000048, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x94), 0x00000048, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x9C), 0x00000048, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xA4), 0x00000048, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xAC), 0x00000048, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xB4), 0x00000048, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xBC), 0x00000048, 0x00000000, + + /* Memory-Mapped I/O Base i Registers + * F1:0x80 i = 0 + * F1:0x88 i = 1 + * F1:0x90 i = 2 + * F1:0x98 i = 3 + * F1:0xA0 i = 4 + * F1:0xA8 i = 5 + * F1:0xB0 i = 6 + * F1:0xB8 i = 7 + * [ 0: 0] Read Enable + * 0 = Reads disabled + * 1 = Reads Enabled + * [ 1: 1] Write Enable + * 0 = Writes disabled + * 1 = Writes Enabled + * [ 2: 2] Cpu Disable + * 0 = Cpu can use this I/O range + * 1 = Cpu requests do not use this I/O range + * [ 3: 3] Lock + * 0 = base/limit registers i are read/write + * 1 = base/limit registers i are read-only + * [ 7: 4] Reserved + * [31: 8] Memory-Mapped I/O Base Address i (39-16) + * This field defines the upper address bits of a 40bit address + * that defines the start of memory-mapped I/O region i + */ + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x80), 0x000000f0, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x88), 0x000000f0, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x90), 0x000000f0, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0x98), 0x000000f0, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xA0), 0x000000f0, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xA8), 0x000000f0, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xB0), 0x000000f0, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xB8), 0x000000f0, 0x00000000, + + /* PCI I/O Limit i Registers + * F1:0xC4 i = 0 + * F1:0xCC i = 1 + * F1:0xD4 i = 2 + * F1:0xDC i = 3 + * [ 2: 0] Destination Node ID + * 000 = Node 0 + * 001 = Node 1 + * 010 = Node 2 + * 011 = Node 3 + * 100 = Node 4 + * 101 = Node 5 + * 110 = Node 6 + * 111 = Node 7 + * [ 3: 3] Reserved + * [ 5: 4] Destination Link ID + * 00 = Link 0 + * 01 = Link 1 + * 10 = Link 2 + * 11 = Link 3 + * [11: 6] Reserved + * [24:12] PCI I/O Limit Address i + * This field defines the end of PCI I/O region n + * [31:25] Reserved + */ + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xC4), 0xFE000FC8, 0x00fff110, /* link 3 of cpu 0 --> AMD SR5690 */ + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xCC), 0xFE000FC8, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xD4), 0xFE000FC8, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xDC), 0xFE000FC8, 0x00000000, + + /* PCI I/O Base i Registers + * F1:0xC0 i = 0 + * F1:0xC8 i = 1 + * F1:0xD0 i = 2 + * F1:0xD8 i = 3 + * [ 0: 0] Read Enable + * 0 = Reads Disabled + * 1 = Reads Enabled + * [ 1: 1] Write Enable + * 0 = Writes Disabled + * 1 = Writes Enabled + * [ 3: 2] Reserved + * [ 4: 4] VGA Enable + * 0 = VGA matches Disabled + * 1 = matches all address < 64K and where A[9:0] is in the + * range 3B0-3BB or 3C0-3DF independent of the base & limit registers + * [ 5: 5] ISA Enable + * 0 = ISA matches Disabled + * 1 = Blocks address < 64K and in the last 768 bytes of eack 1K block + * from matching agains this base/limit pair + * [11: 6] Reserved + * [24:12] PCI I/O Base i + * This field defines the start of PCI I/O region n + * [31:25] Reserved + */ +// PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xC0), 0xFE000FCC, 0x00001013, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xC8), 0xFE000FCC, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xD0), 0xFE000FCC, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xD8), 0xFE000FCC, 0x00000000, + + /* Config Base and Limit i Registers + * F1:0xE0 i = 0 + * F1:0xE4 i = 1 + * F1:0xE8 i = 2 + * F1:0xEC i = 3 + * [ 0: 0] Read Enable + * 0 = Reads Disabled + * 1 = Reads Enabled + * [ 1: 1] Write Enable + * 0 = Writes Disabled + * 1 = Writes Enabled + * [ 2: 2] Device Number Compare Enable + * 0 = The ranges are based on bus number + * 1 = The ranges are ranges of devices on bus 0 + * [ 3: 3] Reserved + * [ 6: 4] Destination Node + * 000 = Node 0 + * 001 = Node 1 + * 010 = Node 2 + * 011 = Node 3 + * 100 = Node 4 + * 101 = Node 5 + * 110 = Node 6 + * 111 = Node 7 + * [ 7: 7] Reserved + * [ 9: 8] Destination Link + * 00 = Link 0 + * 01 = Link 1 + * 10 = Link 2 + * 11 - Link 3 + * [15:10] Reserved + * [23:16] Bus Number Base i + * This field defines the lowest bus number in configuration region i + * [31:24] Bus Number Limit i + * This field defines the highest bus number in configuration region i + */ + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xE0), 0x0000FC88, 0x05000303, /* link 3 of cpu 0 --> AMD SR5690 */ + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xE4), 0x0000FC88, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xE8), 0x0000FC88, 0x00000000, + PCI_ADDR(CONFIG_CBB, CONFIG_CDB, 1, 0xEC), 0x0000FC88, 0x00000000, + + }; + + int max; + uint8_t fam15h = 0; + uint32_t family; + + family = cpuid_eax(0x80000001); + family = ((family & 0xf00000) >> 16) | ((family & 0xf00) >> 8); + + if (family >= 0x6f) + /* Family 15h or later */ + fam15h = 1; + + if (fam15h) { + max = ARRAY_SIZE(fam15h_register_values); + setup_resource_map(fam15h_register_values, max); + } else { + max = ARRAY_SIZE(fam10h_register_values); + setup_resource_map(fam10h_register_values, max); + } +} diff --git a/src/mainboard/asus/kcma-d8/romstage.c b/src/mainboard/asus/kcma-d8/romstage.c new file mode 100644 index 0000000..1904bc2 --- /dev/null +++ b/src/mainboard/asus/kcma-d8/romstage.c @@ -0,0 +1,608 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2015 Timothy Pearson tpearson@raptorengineeringinc.com, Raptor Engineering + * + * Copyright (C) 2007 AMD + * Written by Yinghai Lu yinghailu@amd.com for AMD. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <stdint.h> +#include <string.h> +#include <reset.h> +#include <device/pci_def.h> +#include <device/pci_ids.h> +#include <arch/io.h> +#include <device/pnp_def.h> +#include <cpu/x86/lapic.h> +#include <console/console.h> +#include <timestamp.h> +#include <lib.h> +#include <spd.h> +#include <cpu/amd/model_10xxx_rev.h> +#include <northbridge/amd/amdfam10/raminit.h> +#include <northbridge/amd/amdfam10/amdfam10.h> +#include <delay.h> +#include <cpu/x86/lapic.h> +#include "northbridge/amd/amdfam10/reset_test.c" +#include <superio/winbond/common/winbond.h> +#include <superio/winbond/w83667hg-a/w83667hg-a.h> +#include <cpu/x86/bist.h> +#include <smp/spinlock.h> +// #include "northbridge/amd/amdk8/incoherent_ht.c" +#include <southbridge/amd/sb700/sb700.h> +#include <southbridge/amd/sb700/smbus.h> +#include <southbridge/amd/sr5650/sr5650.h> +#include "northbridge/amd/amdfam10/debug.c" +#include "northbridge/amd/amdfam10/setup_resource_map.c" + +#define SERIAL_DEV PNP_DEV(0x2e, W83667HG_A_SP1) + +static void activate_spd_rom(const struct mem_controller *ctrl); + +static inline int spd_read_byte(unsigned device, unsigned address) +{ + return do_smbus_read_byte(SMBUS_AUX_IO_BASE, device, address); +} + +#include <northbridge/amd/amdfam10/amdfam10.h> +#include "northbridge/amd/amdfam10/raminit_sysinfo_in_ram.c" +#include "northbridge/amd/amdfam10/pci.c" +#include "resourcemap.c" +#include "cpu/amd/quadcore/quadcore.c" + +#include <cpu/amd/microcode.h> + +#include "cpu/amd/family_10h-family_15h/init_cpus.c" +#include "northbridge/amd/amdfam10/early_ht.c" + +/* + * ASUS KGPE-D16 specific SPD enable/disable magic. + * + * Setting SP5100 GPIOs 59 and 60 controls an SPI mux with four settings: + * 0: Disabled + * 1: Normal SPI access + * 2: CPU0 SPD + * 3: CPU1 SPD + * + * Disable SPD access after RAM init to allow access to standard SMBus/I2C offsets + * which is required e.g. by lm-sensors. + */ + +/* Relevant GPIO register information is available in the + * AMD SP5100 Register Reference Guide rev. 3.03, page 130 + */ +static void switch_spd_mux(uint8_t channel) +{ + uint8_t byte; + + byte = pci_read_config8(PCI_DEV(0, 0x14, 0), 0x54); + byte &= ~0xc; /* Clear SPD mux GPIOs */ + byte &= ~0xc0; /* Enable SPD mux GPIO output drivers */ + byte |= (channel << 2) & 0xc; /* Set SPD mux GPIOs */ + pci_write_config8(PCI_DEV(0, 0x14, 0), 0x54, byte); +} + +static const uint8_t spd_addr_fam15[] = { + // Socket 0 Node 0 ("Node 0") + RC00, DIMM0, DIMM1, 0, 0, DIMM2, DIMM3, 0, 0, + // Socket 0 Node 1 ("Node 1") + RC00, DIMM4, DIMM5, 0, 0, DIMM6, DIMM7, 0, 0, + // Socket 1 Node 0 ("Node 2") + RC01, DIMM0, DIMM1, 0, 0, DIMM2, DIMM3, 0, 0, + // Socket 1 Node 1 ("Node 3") + RC01, DIMM4, DIMM5, 0, 0, DIMM6, DIMM7, 0, 0, +}; + +static const uint8_t spd_addr_fam10[] = { + // Socket 0 Node 0 ("Node 0") + RC00, DIMM0, DIMM1, 0, 0, DIMM2, DIMM3, 0, 0, + // Socket 0 Node 1 ("Node 1") + RC00, DIMM4, DIMM5, 0, 0, DIMM6, DIMM7, 0, 0, + // Socket 1 Node 1 ("Node 2") + RC01, DIMM4, DIMM5, 0, 0, DIMM6, DIMM7, 0, 0, + // Socket 1 Node 0 ("Node 3") + RC01, DIMM0, DIMM1, 0, 0, DIMM2, DIMM3, 0, 0, +}; + +static void activate_spd_rom(const struct mem_controller *ctrl) { + struct sys_info *sysinfo = &sysinfo_car; + + printk(BIOS_DEBUG, "activate_spd_rom() for node %02x\n", ctrl->node_id); + if (ctrl->node_id == 0) { + printk(BIOS_DEBUG, "enable_spd_node0()\n"); + switch_spd_mux(0x2); + } else if (ctrl->node_id == 1) { + printk(BIOS_DEBUG, "enable_spd_node1()\n"); + switch_spd_mux((is_fam15h() || (sysinfo->nodes <= 2))?0x2:0x3); + } else if (ctrl->node_id == 2) { + printk(BIOS_DEBUG, "enable_spd_node2()\n"); + switch_spd_mux((is_fam15h() || (sysinfo->nodes <= 2))?0x3:0x2); + } else if (ctrl->node_id == 3) { + printk(BIOS_DEBUG, "enable_spd_node3()\n"); + switch_spd_mux(0x3); + } +} + +/* Voltages are specified by index + * Valid indicies for this platform are: + * 0: 1.5V + * 1: 1.35V + * 2: 1.25V + * 3: 1.15V + */ +static void set_ddr3_voltage(uint8_t node, uint8_t index) { + uint8_t byte; + uint8_t value = 0; + + if (index == 0) + value = 0x0; + else if (index == 1) + value = 0x1; + else if (index == 2) + value = 0x4; + else if (index == 3) + value = 0x5; + if (node == 1) + value <<= 1; + + /* Set GPIOs */ + byte = pci_read_config8(PCI_DEV(0, 0x14, 3), 0xd1); + if (node == 0) + byte &= ~0x5; + if (node == 1) + byte &= ~0xa; + byte |= value; + pci_write_config8(PCI_DEV(0, 0x14, 3), 0xd1, byte); + + /* Enable GPIO output drivers */ + byte = pci_read_config8(PCI_DEV(0, 0x14, 3), 0xd0); + byte &= 0x0f; + pci_write_config8(PCI_DEV(0, 0x14, 3), 0xd0, byte); + + printk(BIOS_DEBUG, "Node %02d DIMM voltage set to index %02x\n", node, index); +} + +void DIMMSetVoltages(struct MCTStatStruc *pMCTstat, + struct DCTStatStruc *pDCTstatA) { + /* This mainboard allows the DIMM voltage to be set per-socket. + * Therefore, for each socket, iterate over all DIMMs to find the + * lowest supported voltage common to all DIMMs on that socket. + */ + uint8_t nvram; + uint8_t dimm; + uint8_t node; + uint8_t socket; + uint8_t allowed_voltages = 0xf; /* The mainboard VRMs allow 1.15V, 1.25V, 1.35V, and 1.5V */ + uint8_t socket_allowed_voltages = allowed_voltages; + uint32_t set_voltage = 0; + + if (get_option(&nvram, "minimum_memory_voltage") == CB_SUCCESS) { + switch (nvram) { + case 2: + allowed_voltages = 0x7; /* Allow 1.25V, 1.35V, and 1.5V */ + break; + case 1: + allowed_voltages = 0x3; /* Allow 1.35V and 1.5V */ + break; + case 0: + default: + allowed_voltages = 0x1; /* Allow 1.5V only */ + break; + } + } + + for (node = 0; node < MAX_NODES_SUPPORTED; node++) { + socket = node / 2; + struct DCTStatStruc *pDCTstat; + pDCTstat = pDCTstatA + node; + + /* reset socket_allowed_voltages before processing each socket */ + if (!(node % 2)) + socket_allowed_voltages = allowed_voltages; + + if (pDCTstat->NodePresent) { + for (dimm = 0; dimm < MAX_DIMMS_SUPPORTED; dimm++) { + if (pDCTstat->DIMMValid & (1 << dimm)) { + socket_allowed_voltages &= pDCTstat->DimmSupportedVoltages[dimm]; + } + } + } + + /* set voltage per socket after processing last contained node */ + if (pDCTstat->NodePresent && (node % 2)) { + /* Set voltages */ + if (socket_allowed_voltages & 0x8) { + set_voltage = 0x8; + set_ddr3_voltage(socket, 3); + } else if (socket_allowed_voltages & 0x4) { + set_voltage = 0x4; + set_ddr3_voltage(socket, 2); + } else if (socket_allowed_voltages & 0x2) { + set_voltage = 0x2; + set_ddr3_voltage(socket, 1); + } else { + set_voltage = 0x1; + set_ddr3_voltage(socket, 0); + } + + /* Save final DIMM voltages for MCT and SMBIOS use */ + if (pDCTstat->NodePresent) { + for (dimm = 0; dimm < MAX_DIMMS_SUPPORTED; dimm++) { + pDCTstat->DimmConfiguredVoltage[dimm] = set_voltage; + } + } + pDCTstat = pDCTstatA + (node - 1); + if (pDCTstat->NodePresent) { + for (dimm = 0; dimm < MAX_DIMMS_SUPPORTED; dimm++) { + pDCTstat->DimmConfiguredVoltage[dimm] = set_voltage; + } + } + } + } + + /* Allow the DDR supply voltages to settle */ + udelay(100000); +} + +static void set_peripheral_control_lines(void) { + uint8_t byte; + uint8_t nvram; + uint8_t enable_ieee1394; + + enable_ieee1394 = 1; + + if (get_option(&nvram, "ieee1394_controller") == CB_SUCCESS) + enable_ieee1394 = nvram & 0x1; + + if (enable_ieee1394) { + /* Enable PCICLK5 (onboard FireWire device) */ + outb(0x41, 0xcd6); + outb(0x02, 0xcd7); + } else { + /* Disable PCICLK5 (onboard FireWire device) */ + outb(0x41, 0xcd6); + outb(0x00, 0xcd7); + } + + /* Enable the RTC AltCentury register */ + outb(0x41, 0xcd6); + byte = inb(0xcd7); + byte |= 0x10; + outb(byte, 0xcd7); +} + +#ifdef TEST_MEMORY +static void execute_memory_test(void) +{ + /* Test DRAM functionality */ + uint32_t i; + uint32_t* dataptr; + printk(BIOS_DEBUG, "Writing test patterns to memory...\n"); + for (i=0; i < 0x1000000; i = i + 8) { + dataptr = (void *)(0x300000 + i); + *dataptr = 0x55555555; + dataptr = (void *)(0x300000 + i + 4); + *dataptr = 0xaaaaaaaa; + } + printk(BIOS_DEBUG, "Done!\n"); + printk(BIOS_DEBUG, "Testing memory...\n"); + uint32_t readback; + for (i=0; i < 0x1000000; i = i + 8) { + dataptr = (void *)(0x300000 + i); + readback = *dataptr; + if (readback != 0x55555555) + printk(BIOS_DEBUG, "%p: INCORRECT VALUE %08x (should have been %08x)\n", dataptr, readback, 0x55555555); + dataptr = (void *)(0x300000 + i + 4); + readback = *dataptr; + if (readback != 0xaaaaaaaa) + printk(BIOS_DEBUG, "%p: INCORRECT VALUE %08x (should have been %08x)\n", dataptr, readback, 0xaaaaaaaa); + } + printk(BIOS_DEBUG, "Done!\n"); +} +#endif + +static spinlock_t printk_spinlock CAR_GLOBAL; + +spinlock_t* romstage_console_lock(void) +{ + return car_get_var_ptr(&printk_spinlock); +} + +void initialize_romstage_console_lock(void) +{ + car_get_var(printk_spinlock) = SPIN_LOCK_UNLOCKED; +} + +static spinlock_t nvram_cbfs_spinlock CAR_GLOBAL; + +spinlock_t* romstage_nvram_cbfs_lock(void) +{ + return car_get_var_ptr(&nvram_cbfs_spinlock); +} + +void initialize_romstage_nvram_cbfs_lock(void) +{ + car_get_var(nvram_cbfs_spinlock) = SPIN_LOCK_UNLOCKED; +} + +static spinlock_t microcode_cbfs_spinlock CAR_GLOBAL; + +spinlock_t* romstage_microcode_cbfs_lock(void) +{ + return car_get_var_ptr(µcode_cbfs_spinlock); +} + +void initialize_romstage_microcode_cbfs_lock(void) +{ + car_get_var(microcode_cbfs_spinlock) = SPIN_LOCK_UNLOCKED; +} + +void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) +{ + uint32_t esp; + __asm__ volatile ( + "movl %%esp, %0" + : "=r" (esp) + ); + + struct sys_info *sysinfo = &sysinfo_car; + + /* Limit the maximum HT speed to 2.6GHz to prevent lockups + * due to HT CPU <--> CPU wiring not being validated to 3.2GHz + */ + sysinfo->ht_link_cfg.ht_speed_limit = 2600; + + uint32_t bsp_apicid = 0, val; + uint8_t byte; + msr_t msr; + + int s3resume = acpi_is_wakeup_s3(); + + if (!cpu_init_detectedx && boot_cpu()) { + /* Initial timestamp */ + timestamp_init(timestamp_get()); + timestamp_add_now(TS_START_ROMSTAGE); + + /* Initialize the printk, nvram CBFS, and microcode CBFS spinlocks */ + initialize_romstage_console_lock(); + initialize_romstage_nvram_cbfs_lock(); + initialize_romstage_microcode_cbfs_lock(); + + /* Nothing special needs to be done to find bus 0 */ + /* Allow the HT devices to be found */ + set_bsp_node_CHtExtNodeCfgEn(); + enumerate_ht_chain(); + + /* SR56x0 pcie bridges block pci_locate_device() before pcie training. + * disable all pcie bridges on SR56x0 to work around it + */ + sr5650_disable_pcie_bridge(); + + /* Initialize southbridge */ + sb7xx_51xx_pci_port80(); + + /* Initialize early serial */ + winbond_enable_serial(SERIAL_DEV, CONFIG_TTYS0_BASE); + console_init(); + + /* Disable LPC legacy DMA support to prevent lockup */ + byte = pci_read_config8(PCI_DEV(0, 0x14, 3), 0x78); + byte &= ~(1 << 0); + pci_write_config8(PCI_DEV(0, 0x14, 3), 0x78, byte); + } + + printk(BIOS_SPEW, "Initial stack pointer: %08x\n", esp); + + post_code(0x30); + + if (bist == 0) + bsp_apicid = init_cpus(cpu_init_detectedx, sysinfo); + + post_code(0x32); + + enable_sr5650_dev8(); + sb7xx_51xx_lpc_init(); + + if (CONFIG_MAX_PHYSICAL_CPUS != 4) + printk(BIOS_WARNING, "CONFIG_MAX_PHYSICAL_CPUS is %d, but this is a dual socket AMD G34 board!\n", CONFIG_MAX_PHYSICAL_CPUS); + + /* Halt if there was a built in self test failure */ + report_bist_failure(bist); + + val = cpuid_eax(1); + printk(BIOS_DEBUG, "BSP Family_Model: %08x\n", val); + printk(BIOS_DEBUG, "*sysinfo range: [%p,%p]\n",sysinfo,sysinfo+1); + printk(BIOS_DEBUG, "bsp_apicid = %02x\n", bsp_apicid); + printk(BIOS_DEBUG, "cpu_init_detectedx = %08lx\n", cpu_init_detectedx); + + /* Setup sysinfo defaults */ + set_sysinfo_in_ram(0); + + update_microcode(val); + + post_code(0x33); + + cpuSetAMDMSR(0); + post_code(0x34); + + amd_ht_init(sysinfo); + amd_ht_fixup(sysinfo); + post_code(0x35); + + /* Setup nodes PCI space and start core 0 AP init. */ + finalize_node_setup(sysinfo); + + /* Setup any mainboard PCI settings etc. */ + setup_mb_resource_map(); + post_code(0x36); + + /* Wait for all the APs core0 started by finalize_node_setup. */ + wait_all_core0_started(); + + /* run _early_setup before soft-reset. */ + sr5650_early_setup(); + sb7xx_51xx_early_setup(); + + if (IS_ENABLED(CONFIG_LOGICAL_CPUS)) { + /* Core0 on each node is configured. Now setup any additional cores. */ + printk(BIOS_DEBUG, "start_other_cores()\n"); + start_other_cores(bsp_apicid); + post_code(0x37); + wait_all_other_cores_started(bsp_apicid); + } + + if (IS_ENABLED(CONFIG_SET_FIDVID)) { + msr = rdmsr(0xc0010071); + printk(BIOS_DEBUG, "\nBegin FIDVID MSR 0xc0010071 0x%08x 0x%08x\n", msr.hi, msr.lo); + + /* FIXME: The sb fid change may survive the warm reset and only need to be done once */ + enable_fid_change_on_sb(sysinfo->sbbusn, sysinfo->sbdn); + + post_code(0x39); + + #if IS_ENABLED(CONFIG_SET_FIDVID) + if (!warm_reset_detect(0)) { // BSP is node 0 + init_fidvid_bsp(bsp_apicid, sysinfo->nodes); + } else { + init_fidvid_stage2(bsp_apicid, 0); // BSP is node 0 + } + #endif + + post_code(0x3A); + + /* show final fid and vid */ + msr=rdmsr(0xc0010071); + printk(BIOS_DEBUG, "End FIDVIDMSR 0xc0010071 0x%08x 0x%08x\n", msr.hi, msr.lo); + } + + post_code(0x38); + + init_timer(); // Need to use TMICT to synconize FID/VID + + sr5650_htinit(); + + /* Reset for HT, FIDVID, PLL and errata changes to take effect. */ + if (!warm_reset_detect(0)) { + printk(BIOS_INFO, "...WARM RESET...\n\n\n"); + soft_reset(); + die("After soft_reset_x - shouldn't see this message!!!\n"); + } + + sr5650_htinit_dect_and_enable_isochronous_link(); + + /* Set default DDR memory voltage + * This will be overridden later during RAM initialization + */ + set_lpc_sticky_ctl(1); /* Retain LPC/IMC GPIO configuration during S3 sleep */ + if (!s3resume) { /* Avoid supply voltage glitches while the DIMMs are retaining data */ + set_ddr3_voltage(0, 0); /* Node 0 */ + set_ddr3_voltage(1, 0); /* Node 1 */ + } + + /* Set up peripheral control lines */ + set_peripheral_control_lines(); + + post_code(0x3B); + + /* Wait for all APs to be stopped, otherwise ram initialization may hang */ + if (IS_ENABLED(CONFIG_LOGICAL_CPUS)) + wait_all_other_cores_stopped(bsp_apicid); + + /* It's the time to set ctrl in sysinfo now; */ + printk(BIOS_DEBUG, "fill_mem_ctrl() detected %d nodes\n", sysinfo->nodes); + if (is_fam15h()) + fill_mem_ctrl(sysinfo->nodes, sysinfo->ctrl, spd_addr_fam15); + else + fill_mem_ctrl(sysinfo->nodes, sysinfo->ctrl, spd_addr_fam10); + post_code(0x3D); + +#if 0 + /* FIXME + * After the AMD K10 code has been converted to use + * IS_ENABLED(CONFIG_DEBUG_SMBUS) uncomment this block + */ + if (IS_ENABLED(CONFIG_DEBUG_SMBUS)) { + dump_spd_registers(&cpu[0]); + dump_smbus_registers(); + } +#endif + + post_code(0x40); + + timestamp_add_now(TS_BEFORE_INITRAM); + printk(BIOS_DEBUG, "raminit_amdmct()\n"); + raminit_amdmct(sysinfo); + timestamp_add_now(TS_AFTER_INITRAM); + +#ifdef TEST_MEMORY + execute_memory_test(); +#endif + +#if !IS_ENABLED(CONFIG_LATE_CBMEM_INIT) + if (s3resume) + cbmem_initialize(); + else + cbmem_initialize_empty(); + post_code(0x41); + + amdmct_cbmem_store_info(sysinfo); +#endif + + printk(BIOS_DEBUG, "disable_spd()\n"); + switch_spd_mux(0x1); + + sr5650_before_pci_init(); + sb7xx_51xx_before_pci_init(); + + /* Configure SP5100 GPIOs to match vendor settings */ + pci_write_config16(PCI_DEV(0, 0x14, 0), 0x50, 0x0170); + pci_write_config16(PCI_DEV(0, 0x14, 0), 0x54, 0x0707); + pci_write_config16(PCI_DEV(0, 0x14, 0), 0x56, 0x0bb0); + pci_write_config16(PCI_DEV(0, 0x14, 0), 0x5a, 0x0ff0); + + timestamp_add_now(TS_END_ROMSTAGE); + + post_cache_as_ram(); // BSP switch stack to ram, copy then execute LB. + post_code(0x43); // Should never see this post code. +} + +/** + * BOOL AMD_CB_ManualBUIDSwapList(u8 Node, u8 Link, u8 **List) + * Description: + * This routine is called every time a non-coherent chain is processed. + * BUID assignment may be controlled explicitly on a non-coherent chain. Provide a + * swap list. The first part of the list controls the BUID assignment and the + * second part of the list provides the device to device linking. Device orientation + * can be detected automatically, or explicitly. See documentation for more details. + * + * Automatic non-coherent init assigns BUIDs starting at 1 and incrementing sequentially + * based on each device's unit count. + * + * Parameters: + * @param[in] node = The node on which this chain is located + * @param[in] link = The link on the host for this chain + * @param[out] List = supply a pointer to a list + */ +BOOL AMD_CB_ManualBUIDSwapList (u8 node, u8 link, const u8 **List) +{ + /* Force BUID to 0 */ + static const u8 swaplist[] = {0, 0, 0xFF, 0, 0xFF}; + if ((is_fam15h() && (node == 0) && (link == 1)) /* Family 15h BSP SB link */ + || (!is_fam15h() && (node == 0) && (link == 3))) { /* Family 10h BSP SB link */ + *List = swaplist; + return 1; + } + + return 0; +} diff --git a/src/mainboard/asus/kcma-d8/spd_notes.txt b/src/mainboard/asus/kcma-d8/spd_notes.txt new file mode 100644 index 0000000..ddd5cc8 --- /dev/null +++ b/src/mainboard/asus/kcma-d8/spd_notes.txt @@ -0,0 +1,46 @@ +==================================================================================================== +SPD mux +==================================================================================================== + SP5100 + GPIO 60 GPIO 59 +Disabled 0 0 +Normal operation 0 1 +CPU 0 SPD 1 0 +CPU 1 SPD 1 1 + +==================================================================================================== +W83795 +==================================================================================================== + +Sensor mappings: +CPU_FAN1: FAN1 +CPU_FAN2: FAN2 +FRNT_FAN1: FAN3 +FRNT_FAN2: FAN4 +FRNT_FAN3: FAN5 +FRNT_FAN4: FAN6 +FRNT_FAN5: FAN7 +REAR_FAN1: FAN8 + +==================================================================================================== +Other hardware +==================================================================================================== + +RECOVERY1 middle pin is connected to southbridge (AMD SP5100) GPIO 61 +Normal is HIGH, recovery is LOW. + ++12VSB is generated using a charge pump attached to pin 7 of PU24 (APW7145). + +The +12VSB standby voltage to each bank of DIMMs is switched by a bank of small FETs located close to each RAM power regulator control chip. +The +12V primary voltage (lower left pin of the FET placed on the upper left of the control chip of the second node) is also connected to the 232GE located near the PCI slot. + +The control line running to the gates of the +12VSB control FETs is connected to the +5VSB power for the USB ports. +That line in turn is connected to +5VSB via the lone P06P03G PMOS transistor on the reverse side of the board, near the center on the lower half. +The gate of that transistor is connected via a resistor to the source of the P06P03G PMOS transistor located adjacent to the unpopulated SMA clock header. +The gate of that transistor is connected directly to the drain of the small FET directly below it. +After that, there's a cascade of small FETs and resistors in that region, eventually leading to SuperIO pin 81. + +SuperIO pin 81 (VSBGATE#) enables the standby voltage rails when set LOW. +VSBGATE# is reset on every assertion of PWRGOOD. + +Setting SuperIO LDN 9 CRF4 bits 1 or 0 (or both) to 0 disables NICB. \ No newline at end of file
