Michael Niewöhner has submitted this change. ( https://review.coreboot.org/c/coreboot/+/44137 )
Change subject: soc/intel/skylake: acpi: drop HWP's dependency on EIST ......................................................................
Enhanced Intel SpeedStep Technology (EIST) and Intel Speed Shift Technology (ISST) - also know as HWP - are two independent mechanisms for controlling voltage and frequency based on performance hints.
When HWP is enabled, it overrides the software-based EIST. It does not depend on EIST, though, but can be enabled on its own.
Break up that currently existing dependency in ACPI generation code.
It was tested that HWP can be enabled and gets used by the Linux pstate cpufreq driver. With HWP disabled, the frequency does not decrease, even not in powersave mode. After enabling HWP the frequency changed in relation to the current workload. (Test device: Acer ES1-572)
Change-Id: I93d888ddce7b54e91b54e5b4fdd4d9cf16630eda Signed-off-by: Michael Niewöhner foss@mniewoehner.de Reviewed-on: https://review.coreboot.org/c/coreboot/+/44137 Reviewed-by: Arthur Heymans arthur@aheymans.xyz Reviewed-by: Subrata Banik subrata.banik@intel.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/soc/intel/skylake/acpi.c 1 file changed, 5 insertions(+), 3 deletions(-)
Approvals: build bot (Jenkins): Verified Arthur Heymans: Looks good to me, but someone else must approve Subrata Banik: Looks good to me, approved
diff --git a/src/soc/intel/skylake/acpi.c b/src/soc/intel/skylake/acpi.c index 0ec6e47..eb5b5b0 100644 --- a/src/soc/intel/skylake/acpi.c +++ b/src/soc/intel/skylake/acpi.c @@ -379,7 +379,7 @@ printk(BIOS_DEBUG, "Found %d CPU(s) with %d core(s) each.\n", numcpus, cores_per_package);
- if (config->eist_enable && config->speed_shift_enable) { + if (config->speed_shift_enable) { struct cppc_config cppc_config; cpu_init_cppc_config(&cppc_config, 2 /* version 2 */); acpigen_write_CPPC_package(&cppc_config); @@ -403,9 +403,11 @@ /* Generate P-state tables */ generate_p_state_entries(core_id, cores_per_package); - if (config->speed_shift_enable) - acpigen_write_CPPC_method(); } + + if (config->speed_shift_enable) + acpigen_write_CPPC_method(); + acpigen_pop_len(); } }
