Attention is currently required from: Benjamin Doron, Martin L Roth, Sean Rhodes.
Matt DeVillier has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/87407?usp=email )
Change subject: payload/external/edk2: Add Kconfig to support use of PCIe OpROMs ......................................................................
Add a Kconfig to support passing `LOAD_OPTION_ROMS=TRUE` as a build parameter in order to enable edk2 support for dGPUs.
Change-Id: I05444425d1cb98b023681639389949bf3f3b8e9c Signed-off-by: Matt DeVillier matt.devillier@gmail.com --- M payloads/external/Makefile.mk M payloads/external/edk2/Kconfig M payloads/external/edk2/Makefile 3 files changed, 13 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/07/87407/1
diff --git a/payloads/external/Makefile.mk b/payloads/external/Makefile.mk index c279121..5e8c91f 100644 --- a/payloads/external/Makefile.mk +++ b/payloads/external/Makefile.mk @@ -182,6 +182,7 @@ CONFIG_EDK2_FULL_SCREEN_SETUP=$(CONFIG_EDK2_FULL_SCREEN_SETUP) \ CONFIG_EDK2_HAVE_EFI_SHELL=$(CONFIG_EDK2_HAVE_EFI_SHELL) \ CONFIG_EDK2_PRIORITIZE_INTERNAL=$(CONFIG_EDK2_PRIORITIZE_INTERNAL) \ + CONFIG_EDK2_LOAD_OPTION_ROMS=$(CONFIG_EDK2_LOAD_OPTION_ROMS) \ CONFIG_EDK2_PS2_SUPPORT=$(CONFIG_EDK2_PS2_SUPPORT) \ CONFIG_EDK2_SERIAL_SUPPORT=$(CONFIG_EDK2_SERIAL_SUPPORT) \ CONFIG_EDK2_SD_MMC_TIMEOUT=$(CONFIG_EDK2_SD_MMC_TIMEOUT) \ diff --git a/payloads/external/edk2/Kconfig b/payloads/external/edk2/Kconfig index ea24cee..08e48e5 100644 --- a/payloads/external/edk2/Kconfig +++ b/payloads/external/edk2/Kconfig @@ -240,6 +240,14 @@ help Prioritize internal boot devices over external devices
+config EDK2_LOAD_OPTION_ROMS + bool "Load and Execute OpROMs on PCIe devices" + depends on EDK2_REPO_MRCHROMEBOX + default n + help + Load and execute OpROMs on PCIe devices. + Select this option to support use of an external dGPU. + config EDK2_PS2_SUPPORT bool "Support PS/2 Keyboards" default y diff --git a/payloads/external/edk2/Makefile b/payloads/external/edk2/Makefile index 6464e9f..0908f4d 100644 --- a/payloads/external/edk2/Makefile +++ b/payloads/external/edk2/Makefile @@ -149,6 +149,10 @@ ifeq ($(CONFIG_EDK2_USE_LAPIC_TIMER),y) BUILD_STR += -D TIMER_SUPPORT=LAPIC endif +# LOAD_OPTION_ROMS = FALSE +ifeq ($(CONFIG_EDK2_LOAD_OPTION_ROMS),y) +BUILD_STR += -D LOAD_OPTION_ROMS=TRUE +endif
endif
