Attention is currently required from: Subrata Banik, Tim Wawrzynczak, Patrick Rudolph. Hello Subrata Banik, Tim Wawrzynczak, Patrick Rudolph,
https://review.coreboot.org/c/coreboot/+/62645
Change subject: soc/intel/adl/chip.h: Convert all camel case variables to snake case ......................................................................
coreboot chip.h files mainly contains variable which allows board to fill platform configuration through devicetree. Since many of this configuration involves FSP UPDs, variable names were in camel case which aligned with UPD naming convention.
By default coreboot follow snake case variable naming, so cleaning up file to align all variable names as per coreboot convention.
During renaming process, this patch also removes unused variables listed below: -> SataEnable // Checked in SoC code based on PCI dev enabled status -> ITbtConnectTopologyTimeoutInMs // SoC always passes 0, so not used
Note: Since separating out changes into smaller CL might break the compilation for the patch set, this is being pushed as a single big CL.
BUG=None BRANCH=firmware-brya-14505.B TEST=All boards using ADL SoC compiles with the CL.
Change-Id: Ieda567a89ec9287e3d988d489f3b3769dffcf9e0 Signed-off-by: MAULIK V VAGHELA maulik.v.vaghela@intel.com --- M src/mainboard/google/brya/variants/agah/overridetree.cb M src/mainboard/google/brya/variants/anahera/overridetree.cb M src/mainboard/google/brya/variants/anahera4es/overridetree.cb M src/mainboard/google/brya/variants/banshee/overridetree.cb M src/mainboard/google/brya/variants/baseboard/brask/devicetree.cb M src/mainboard/google/brya/variants/baseboard/brask/ramstage.c M src/mainboard/google/brya/variants/baseboard/brya/devicetree.cb M src/mainboard/google/brya/variants/baseboard/nissa/devicetree.cb M src/mainboard/google/brya/variants/brask/variant.c M src/mainboard/google/brya/variants/brya0/overridetree.cb M src/mainboard/google/brya/variants/brya0/variant.c M src/mainboard/google/brya/variants/brya4es/overridetree.cb M src/mainboard/google/brya/variants/brya4es/variant.c M src/mainboard/google/brya/variants/felwinter/overridetree.cb M src/mainboard/google/brya/variants/felwinter/variant.c M src/mainboard/google/brya/variants/gimble/overridetree.cb M src/mainboard/google/brya/variants/gimble/variant.c M src/mainboard/google/brya/variants/gimble4es/overridetree.cb M src/mainboard/google/brya/variants/gimble4es/variant.c M src/mainboard/google/brya/variants/kano/overridetree.cb M src/mainboard/google/brya/variants/kano/variant.c M src/mainboard/google/brya/variants/nereid/overridetree.cb M src/mainboard/google/brya/variants/nivviks/overridetree.cb M src/mainboard/google/brya/variants/primus/overridetree.cb M src/mainboard/google/brya/variants/primus4es/overridetree.cb M src/mainboard/google/brya/variants/redrix/overridetree.cb M src/mainboard/google/brya/variants/redrix4es/overridetree.cb M src/mainboard/google/brya/variants/taeko/overridetree.cb M src/mainboard/google/brya/variants/taeko4es/overridetree.cb M src/mainboard/google/brya/variants/taniks/overridetree.cb M src/mainboard/google/brya/variants/vell/overridetree.cb M src/mainboard/google/brya/variants/volmar/overridetree.cb M src/mainboard/google/brya/variants/volmar/variant.c M src/mainboard/intel/adlrvp/devicetree.cb M src/mainboard/intel/adlrvp/devicetree_m.cb M src/mainboard/intel/adlrvp/devicetree_n.cb M src/mainboard/intel/shadowmountain/variants/baseboard/devicetree.cb M src/mainboard/prodrive/atlas/devicetree.cb M src/soc/intel/alderlake/chip.h M src/soc/intel/alderlake/fsp_params.c M src/soc/intel/alderlake/romstage/fsp_params.c 41 files changed, 284 insertions(+), 279 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/45/62645/6
