Arthur Heymans (arthur@aheymans.xyz) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/18022
commit bed6d99355b376d3993153a297378b4f5e76d2a4 Author: Arthur Heymans arthur@aheymans.xyz Date: Tue Jan 3 00:49:45 2017 +0100
nb/x4x/raminit: Fix programming dram timings
Results obtained by comparing vendor bios with coreboot at same timings.
This fixes 2 issues: * 1333MHz fsb CPUs were limited to 667MHz ddr2 speeds; * 1067MHz fsb CPUs can now boot with dimm in second slot.
TESTED on ga-g41m-es2l on 800, 1067 and 1333MHz CPUs on DDR2 667 and 800MHz.
Change-Id: I70f554f97b44947c2c78713b4d73a47c06d7ba60 Signed-off-by: Arthur Heymans arthur@aheymans.xyz --- src/northbridge/intel/x4x/raminit.c | 4 +--- src/northbridge/intel/x4x/raminit_ddr2.c | 16 ++++++++++------ 2 files changed, 11 insertions(+), 9 deletions(-)
diff --git a/src/northbridge/intel/x4x/raminit.c b/src/northbridge/intel/x4x/raminit.c index 122cab5..86f63f1 100644 --- a/src/northbridge/intel/x4x/raminit.c +++ b/src/northbridge/intel/x4x/raminit.c @@ -228,9 +228,7 @@ static void sdram_detect_ram_speed(struct sysinfo *s) // Max RAM speed if (s->spd_type == DDR2) {
- // FIXME: Limit memory speed to 667MHz if FSB is 1333MHz - maxfreq = (s->max_fsb == FSB_CLOCK_1333MHz) - ? MEM_CLOCK_667MHz : MEM_CLOCK_800MHz; + maxfreq = MEM_CLOCK_800MHz;
// Choose common CAS latency from {6,5}, 4 does not work commoncas = 0x60; diff --git a/src/northbridge/intel/x4x/raminit_ddr2.c b/src/northbridge/intel/x4x/raminit_ddr2.c index a763bf0..4d36be5 100644 --- a/src/northbridge/intel/x4x/raminit_ddr2.c +++ b/src/northbridge/intel/x4x/raminit_ddr2.c @@ -544,6 +544,9 @@ static void timings_ddr2(struct sysinfo *s) u8 trpmod = 0; u8 bankmod = 1; u8 pagemod = 0; + u8 adjusted_cas; + + adjusted_cas = s->selected_timings.CAS - 3;
u16 fsb2ps[3] = { 5000, // 800 @@ -587,13 +590,14 @@ static void timings_ddr2(struct sysinfo *s) }
FOR_EACH_POPULATED_CHANNEL(s->dimms, i) { - MCHBAR8(0x400*i + 0x2f6) = MCHBAR8(0x400*i + 0x2f6) | 0x3; + MCHBAR8(0x400*i + 0x26f) = MCHBAR8(0x400*i + 0x26f) | 0x3; MCHBAR8(0x400*i + 0x228) = (MCHBAR8(0x400*i + 0x228) & ~0x7) | 0x2; - MCHBAR8(0x400*i + 0x240) = (MCHBAR8(0x400*i + 0x240) & ~0xf0) | (twl << 4); + MCHBAR8(0x400*i + 0x240) = (MCHBAR8(0x400*i + 0x240) & ~0xf0) + | (0 << 4); MCHBAR8(0x400*i + 0x240) = (MCHBAR8(0x400*i + 0x240) & ~0xf) | - s->selected_timings.CAS; + adjusted_cas; MCHBAR16(0x400*i + 0x265) = (MCHBAR16(0x400*i + 0x265) & ~0x3f00) | - ((s->selected_timings.CAS + 9) << 8); + ((adjusted_cas + 9) << 8);
reg16 = (s->selected_timings.tRAS << 11) | ((twl + 4 + s->selected_timings.tWR) << 6) | @@ -673,7 +677,7 @@ static void timings_ddr2(struct sysinfo *s)
fsb = fsb2ps[s->selected_timings.fsb_clk]; ddr = ddr2ps[s->selected_timings.mem_clk]; - reg32 = (u32)((s->selected_timings.CAS + 7 + reg8) * ddr); + reg32 = (u32)((adjusted_cas + 7 + reg8) * ddr); reg32 = (u32)((reg32 / fsb) << 8); reg32 |= 0x0e000000; if ((fsb2mhz(s->selected_timings.fsb_clk) / @@ -751,7 +755,7 @@ static void timings_ddr2(struct sysinfo *s) MCHBAR32(0x120) = (2 << 29) | (1 << 28) | (1 << 23) | 0xd7f5f; reg8 = (u8)((MCHBAR32(0x252) & 0x1e000) >> 13); MCHBAR8(0x12d) = (MCHBAR8(0x12d) & ~0xf0) | (reg8 << 4); - reg8 = (u8)((MCHBAR32(0x258) & ~0x1e0000) >> 17); + reg8 = (u8)((MCHBAR32(0x258) & 0x1e0000) >> 17); MCHBAR8(0x12d) = (MCHBAR8(0x12d) & ~0xf) | reg8; MCHBAR8(0x12f) = 0x4c; reg32 = (1 << 31) | (0x80 << 14) | (1 << 13) | (0xa << 9);
