HAOUAS Elyes (ehaouas@noos.fr) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/6320
commit 04e57b657f250366515a28acf5c540c3b205fa3a Author: Elyes HAOUAS ehaouas@noos.fr Date: Tue Jul 22 18:56:48 2014 +0200
google/link & stout: Remove a trailing whitespace
Change-Id: Id538d6bf7df3867a629f93ab3c3db67c66d94b15 Signed-off-by: Elyes HAOUAS ehaouas@noos.fr --- src/mainboard/google/link/fadt.c | 10 +- src/mainboard/google/link/i915_reg.h | 2820 ++++++++++++++++----------------- src/mainboard/google/stout/fadt.c | 10 +- src/mainboard/google/stout/i915_reg.h | 2820 ++++++++++++++++----------------- 4 files changed, 2830 insertions(+), 2830 deletions(-)
diff --git a/src/mainboard/google/link/fadt.c b/src/mainboard/google/link/fadt.c index 5ce9ab1..49acb88 100644 --- a/src/mainboard/google/link/fadt.c +++ b/src/mainboard/google/link/fadt.c @@ -26,11 +26,11 @@ * code and the mainboard fadt. */ #define APM_CNT 0xb2 -#define CST_CONTROL 0x85 -#define PST_CONTROL 0x80 -#define ACPI_DISABLE 0x1e -#define ACPI_ENABLE 0xe1 -#define GNVS_UPDATE 0xea +#define CST_CONTROL 0x85 +#define PST_CONTROL 0x80 +#define ACPI_DISABLE 0x1e +#define ACPI_ENABLE 0xe1 +#define GNVS_UPDATE 0xea
void acpi_create_fadt(acpi_fadt_t * fadt, acpi_facs_t * facs, void *dsdt) { diff --git a/src/mainboard/google/link/i915_reg.h b/src/mainboard/google/link/i915_reg.h index 8bdf2cb..83164fb 100644 --- a/src/mainboard/google/link/i915_reg.h +++ b/src/mainboard/google/link/i915_reg.h @@ -39,65 +39,65 @@ /* PCI config space */
#define HPLLCC 0xc0 /* 855 only */ -#define GC_CLOCK_CONTROL_MASK (0xf << 0) -#define GC_CLOCK_133_200 (0 << 0) -#define GC_CLOCK_100_200 (1 << 0) -#define GC_CLOCK_100_133 (2 << 0) -#define GC_CLOCK_166_250 (3 << 0) +#define GC_CLOCK_CONTROL_MASK (0xf << 0) +#define GC_CLOCK_133_200 (0 << 0) +#define GC_CLOCK_100_200 (1 << 0) +#define GC_CLOCK_100_133 (2 << 0) +#define GC_CLOCK_166_250 (3 << 0) #define GCFGC2 0xda #define GCFGC 0xf0 /* 915+ only */ -#define GC_LOW_FREQUENCY_ENABLE (1 << 7) -#define GC_DISPLAY_CLOCK_190_200_MHZ (0 << 4) -#define GC_DISPLAY_CLOCK_333_MHZ (4 << 4) -#define GC_DISPLAY_CLOCK_MASK (7 << 4) -#define GM45_GC_RENDER_CLOCK_MASK (0xf << 0) -#define GM45_GC_RENDER_CLOCK_266_MHZ (8 << 0) -#define GM45_GC_RENDER_CLOCK_320_MHZ (9 << 0) -#define GM45_GC_RENDER_CLOCK_400_MHZ (0xb << 0) -#define GM45_GC_RENDER_CLOCK_533_MHZ (0xc << 0) -#define I965_GC_RENDER_CLOCK_MASK (0xf << 0) -#define I965_GC_RENDER_CLOCK_267_MHZ (2 << 0) -#define I965_GC_RENDER_CLOCK_333_MHZ (3 << 0) -#define I965_GC_RENDER_CLOCK_444_MHZ (4 << 0) -#define I965_GC_RENDER_CLOCK_533_MHZ (5 << 0) -#define I945_GC_RENDER_CLOCK_MASK (7 << 0) -#define I945_GC_RENDER_CLOCK_166_MHZ (0 << 0) -#define I945_GC_RENDER_CLOCK_200_MHZ (1 << 0) -#define I945_GC_RENDER_CLOCK_250_MHZ (3 << 0) -#define I945_GC_RENDER_CLOCK_400_MHZ (5 << 0) -#define I915_GC_RENDER_CLOCK_MASK (7 << 0) -#define I915_GC_RENDER_CLOCK_166_MHZ (0 << 0) -#define I915_GC_RENDER_CLOCK_200_MHZ (1 << 0) -#define I915_GC_RENDER_CLOCK_333_MHZ (4 << 0) +#define GC_LOW_FREQUENCY_ENABLE (1 << 7) +#define GC_DISPLAY_CLOCK_190_200_MHZ (0 << 4) +#define GC_DISPLAY_CLOCK_333_MHZ (4 << 4) +#define GC_DISPLAY_CLOCK_MASK (7 << 4) +#define GM45_GC_RENDER_CLOCK_MASK (0xf << 0) +#define GM45_GC_RENDER_CLOCK_266_MHZ (8 << 0) +#define GM45_GC_RENDER_CLOCK_320_MHZ (9 << 0) +#define GM45_GC_RENDER_CLOCK_400_MHZ (0xb << 0) +#define GM45_GC_RENDER_CLOCK_533_MHZ (0xc << 0) +#define I965_GC_RENDER_CLOCK_MASK (0xf << 0) +#define I965_GC_RENDER_CLOCK_267_MHZ (2 << 0) +#define I965_GC_RENDER_CLOCK_333_MHZ (3 << 0) +#define I965_GC_RENDER_CLOCK_444_MHZ (4 << 0) +#define I965_GC_RENDER_CLOCK_533_MHZ (5 << 0) +#define I945_GC_RENDER_CLOCK_MASK (7 << 0) +#define I945_GC_RENDER_CLOCK_166_MHZ (0 << 0) +#define I945_GC_RENDER_CLOCK_200_MHZ (1 << 0) +#define I945_GC_RENDER_CLOCK_250_MHZ (3 << 0) +#define I945_GC_RENDER_CLOCK_400_MHZ (5 << 0) +#define I915_GC_RENDER_CLOCK_MASK (7 << 0) +#define I915_GC_RENDER_CLOCK_166_MHZ (0 << 0) +#define I915_GC_RENDER_CLOCK_200_MHZ (1 << 0) +#define I915_GC_RENDER_CLOCK_333_MHZ (4 << 0) #define LBB 0xf4
/* Graphics reset regs */ #define I965_GDRST 0xc0 /* PCI config register */ #define ILK_GDSR 0x2ca4 /* MCHBAR offset */ -#define GRDOM_FULL (0<<2) -#define GRDOM_RENDER (1<<2) -#define GRDOM_MEDIA (3<<2) +#define GRDOM_FULL (0<<2) +#define GRDOM_RENDER (1<<2) +#define GRDOM_MEDIA (3<<2)
#define GEN6_MBCUNIT_SNPCR 0x900c /* for LLC config */ -#define GEN6_MBC_SNPCR_SHIFT 21 -#define GEN6_MBC_SNPCR_MASK (3<<21) -#define GEN6_MBC_SNPCR_MAX (0<<21) -#define GEN6_MBC_SNPCR_MED (1<<21) -#define GEN6_MBC_SNPCR_LOW (2<<21) -#define GEN6_MBC_SNPCR_MIN (3<<21) /* only 1/16th of the cache is shared */ +#define GEN6_MBC_SNPCR_SHIFT 21 +#define GEN6_MBC_SNPCR_MASK (3<<21) +#define GEN6_MBC_SNPCR_MAX (0<<21) +#define GEN6_MBC_SNPCR_MED (1<<21) +#define GEN6_MBC_SNPCR_LOW (2<<21) +#define GEN6_MBC_SNPCR_MIN (3<<21) /* only 1/16th of the cache is shared */
#define GEN6_MBCTL 0x0907c -#define GEN6_MBCTL_ENABLE_BOOT_FETCH (1 << 4) -#define GEN6_MBCTL_CTX_FETCH_NEEDED (1 << 3) -#define GEN6_MBCTL_BME_UPDATE_ENABLE (1 << 2) -#define GEN6_MBCTL_MAE_UPDATE_ENABLE (1 << 1) -#define GEN6_MBCTL_BOOT_FETCH_MECH (1 << 0) +#define GEN6_MBCTL_ENABLE_BOOT_FETCH (1 << 4) +#define GEN6_MBCTL_CTX_FETCH_NEEDED (1 << 3) +#define GEN6_MBCTL_BME_UPDATE_ENABLE (1 << 2) +#define GEN6_MBCTL_MAE_UPDATE_ENABLE (1 << 1) +#define GEN6_MBCTL_BOOT_FETCH_MECH (1 << 0)
#define GEN6_GDRST 0x941c -#define GEN6_GRDOM_FULL (1 << 0) -#define GEN6_GRDOM_RENDER (1 << 1) -#define GEN6_GRDOM_MEDIA (1 << 2) -#define GEN6_GRDOM_BLT (1 << 3) +#define GEN6_GRDOM_FULL (1 << 0) +#define GEN6_GRDOM_RENDER (1 << 1) +#define GEN6_GRDOM_MEDIA (1 << 2) +#define GEN6_GRDOM_BLT (1 << 3)
/* PPGTT stuff */ #define GEN6_GTT_ADDR_ENCODE(addr) ((addr) | (((addr) >> 28) & 0xff0)) @@ -118,12 +118,12 @@ #define RING_PP_DIR_BASE(ring) ((ring)->mmio_base+0x228) #define RING_PP_DIR_BASE_READ(ring) ((ring)->mmio_base+0x518) #define RING_PP_DIR_DCLV(ring) ((ring)->mmio_base+0x220) -#define PP_DIR_DCLV_2G 0xffffffff +#define PP_DIR_DCLV_2G 0xffffffff
#define GAM_ECOCHK 0x4090 -#define ECOCHK_SNB_BIT (1<<10) -#define ECOCHK_PPGTT_CACHE64B (0x3<<3) -#define ECOCHK_PPGTT_CACHE4B (0x0<<3) +#define ECOCHK_SNB_BIT (1<<10) +#define ECOCHK_PPGTT_CACHE64B (0x3<<3) +#define ECOCHK_PPGTT_CACHE4B (0x0<<3)
/* VGA stuff */
@@ -132,29 +132,29 @@
#define VGA_MSR_WRITE 0x3c2 #define VGA_MSR_READ 0x3cc -#define VGA_MSR_MEM_EN (1<<1) -#define VGA_MSR_CGA_MODE (1<<0) +#define VGA_MSR_MEM_EN (1<<1) +#define VGA_MSR_CGA_MODE (1<<0)
#define VGA_SR_INDEX 0x3c4 #define VGA_SR_DATA 0x3c5
#define VGA_AR_INDEX 0x3c0 -#define VGA_AR_VID_EN (1<<5) +#define VGA_AR_VID_EN (1<<5) #define VGA_AR_DATA_WRITE 0x3c0 #define VGA_AR_DATA_READ 0x3c1
#define VGA_GR_INDEX 0x3ce #define VGA_GR_DATA 0x3cf /* GR05 */ -#define VGA_GR_MEM_READ_MODE_SHIFT 3 -#define VGA_GR_MEM_READ_MODE_PLANE 1 +#define VGA_GR_MEM_READ_MODE_SHIFT 3 +#define VGA_GR_MEM_READ_MODE_PLANE 1 /* GR06 */ -#define VGA_GR_MEM_MODE_MASK 0xc -#define VGA_GR_MEM_MODE_SHIFT 2 -#define VGA_GR_MEM_A0000_AFFFF 0 -#define VGA_GR_MEM_A0000_BFFFF 1 -#define VGA_GR_MEM_B0000_B7FFF 2 -#define VGA_GR_MEM_B0000_BFFFF 3 +#define VGA_GR_MEM_MODE_MASK 0xc +#define VGA_GR_MEM_MODE_SHIFT 2 +#define VGA_GR_MEM_A0000_AFFFF 0 +#define VGA_GR_MEM_A0000_BFFFF 1 +#define VGA_GR_MEM_B0000_B7FFF 2 +#define VGA_GR_MEM_B0000_BFFFF 3
#define VGA_DACMASK 0x3c6 #define VGA_DACRX 0x3c7 @@ -174,40 +174,40 @@ #define MI_NOOP MI_INSTR(0, 0) #define MI_USER_INTERRUPT MI_INSTR(0x02, 0) #define MI_WAIT_FOR_EVENT MI_INSTR(0x03, 0) -#define MI_WAIT_FOR_OVERLAY_FLIP (1<<16) -#define MI_WAIT_FOR_PLANE_B_FLIP (1<<6) -#define MI_WAIT_FOR_PLANE_A_FLIP (1<<2) -#define MI_WAIT_FOR_PLANE_A_SCANLINES (1<<1) +#define MI_WAIT_FOR_OVERLAY_FLIP (1<<16) +#define MI_WAIT_FOR_PLANE_B_FLIP (1<<6) +#define MI_WAIT_FOR_PLANE_A_FLIP (1<<2) +#define MI_WAIT_FOR_PLANE_A_SCANLINES (1<<1) #define MI_FLUSH MI_INSTR(0x04, 0) -#define MI_READ_FLUSH (1 << 0) -#define MI_EXE_FLUSH (1 << 1) -#define MI_NO_WRITE_FLUSH (1 << 2) -#define MI_SCENE_COUNT (1 << 3) /* just increment scene count */ -#define MI_END_SCENE (1 << 4) /* flush binner and incr scene count */ -#define MI_INVALIDATE_ISP (1 << 5) /* invalidate indirect state pointers */ +#define MI_READ_FLUSH (1 << 0) +#define MI_EXE_FLUSH (1 << 1) +#define MI_NO_WRITE_FLUSH (1 << 2) +#define MI_SCENE_COUNT (1 << 3) /* just increment scene count */ +#define MI_END_SCENE (1 << 4) /* flush binner and incr scene count */ +#define MI_INVALIDATE_ISP (1 << 5) /* invalidate indirect state pointers */ #define MI_BATCH_BUFFER_END MI_INSTR(0x0a, 0) #define MI_SUSPEND_FLUSH MI_INSTR(0x0b, 0) -#define MI_SUSPEND_FLUSH_EN (1<<0) +#define MI_SUSPEND_FLUSH_EN (1<<0) #define MI_REPORT_HEAD MI_INSTR(0x07, 0) #define MI_OVERLAY_FLIP MI_INSTR(0x11, 0) -#define MI_OVERLAY_CONTINUE (0x0<<21) -#define MI_OVERLAY_ON (0x1<<21) -#define MI_OVERLAY_OFF (0x2<<21) +#define MI_OVERLAY_CONTINUE (0x0<<21) +#define MI_OVERLAY_ON (0x1<<21) +#define MI_OVERLAY_OFF (0x2<<21) #define MI_LOAD_SCAN_LINES_INCL MI_INSTR(0x12, 0) #define MI_DISPLAY_FLIP MI_INSTR(0x14, 2) #define MI_DISPLAY_FLIP_I915 MI_INSTR(0x14, 1) -#define MI_DISPLAY_FLIP_PLANE(n) ((n) << 20) +#define MI_DISPLAY_FLIP_PLANE(n) ((n) << 20) #define MI_SET_CONTEXT MI_INSTR(0x18, 0) -#define MI_MM_SPACE_GTT (1<<8) -#define MI_MM_SPACE_PHYSICAL (0<<8) -#define MI_SAVE_EXT_STATE_EN (1<<3) -#define MI_RESTORE_EXT_STATE_EN (1<<2) -#define MI_FORCE_RESTORE (1<<1) -#define MI_RESTORE_INHIBIT (1<<0) +#define MI_MM_SPACE_GTT (1<<8) +#define MI_MM_SPACE_PHYSICAL (0<<8) +#define MI_SAVE_EXT_STATE_EN (1<<3) +#define MI_RESTORE_EXT_STATE_EN (1<<2) +#define MI_FORCE_RESTORE (1<<1) +#define MI_RESTORE_INHIBIT (1<<0) #define MI_STORE_DWORD_IMM MI_INSTR(0x20, 1) -#define MI_MEM_VIRTUAL (1 << 22) /* 965+ only */ +#define MI_MEM_VIRTUAL (1 << 22) /* 965+ only */ #define MI_STORE_DWORD_INDEX MI_INSTR(0x21, 1) -#define MI_STORE_DWORD_INDEX_SHIFT 2 +#define MI_STORE_DWORD_INDEX_SHIFT 2 /* Official intel docs are somewhat sloppy concerning MI_LOAD_REGISTER_IMM: * - Always issue a MI_NOOP _before_ the MI_LOAD_REGISTER_IMM - otherwise hw * simply ignores the register load under certain conditions. @@ -216,24 +216,24 @@ */ #define MI_LOAD_REGISTER_IMM(x) MI_INSTR(0x22, 2*x-1) #define MI_FLUSH_DW MI_INSTR(0x26, 1) /* for GEN6 */ -#define MI_INVALIDATE_TLB (1<<18) -#define MI_INVALIDATE_BSD (1<<7) +#define MI_INVALIDATE_TLB (1<<18) +#define MI_INVALIDATE_BSD (1<<7) #define MI_BATCH_BUFFER MI_INSTR(0x30, 1) -#define MI_BATCH_NON_SECURE (1) -#define MI_BATCH_NON_SECURE_I965 (1<<8) +#define MI_BATCH_NON_SECURE (1) +#define MI_BATCH_NON_SECURE_I965 (1<<8) #define MI_BATCH_BUFFER_START MI_INSTR(0x31, 0) #define MI_SEMAPHORE_MBOX MI_INSTR(0x16, 1) /* gen6+ */ -#define MI_SEMAPHORE_GLOBAL_GTT (1<<22) -#define MI_SEMAPHORE_UPDATE (1<<21) -#define MI_SEMAPHORE_COMPARE (1<<20) -#define MI_SEMAPHORE_REGISTER (1<<18) -#define MI_SEMAPHORE_SYNC_RV (2<<16) -#define MI_SEMAPHORE_SYNC_RB (0<<16) -#define MI_SEMAPHORE_SYNC_VR (0<<16) -#define MI_SEMAPHORE_SYNC_VB (2<<16) -#define MI_SEMAPHORE_SYNC_BR (2<<16) -#define MI_SEMAPHORE_SYNC_BV (0<<16) -#define MI_SEMAPHORE_SYNC_INVALID (1<<0) +#define MI_SEMAPHORE_GLOBAL_GTT (1<<22) +#define MI_SEMAPHORE_UPDATE (1<<21) +#define MI_SEMAPHORE_COMPARE (1<<20) +#define MI_SEMAPHORE_REGISTER (1<<18) +#define MI_SEMAPHORE_SYNC_RV (2<<16) +#define MI_SEMAPHORE_SYNC_RB (0<<16) +#define MI_SEMAPHORE_SYNC_VR (0<<16) +#define MI_SEMAPHORE_SYNC_VB (2<<16) +#define MI_SEMAPHORE_SYNC_BR (2<<16) +#define MI_SEMAPHORE_SYNC_BV (0<<16) +#define MI_SEMAPHORE_SYNC_INVALID (1<<0) /* * 3D instructions used by the kernel */ @@ -241,15 +241,15 @@
#define GFX_OP_RASTER_RULES ((0x3<<29)|(0x7<<24)) #define GFX_OP_SCISSOR ((0x3<<29)|(0x1c<<24)|(0x10<<19)) -#define SC_UPDATE_SCISSOR (0x1<<1) -#define SC_ENABLE_MASK (0x1<<0) -#define SC_ENABLE (0x1<<0) +#define SC_UPDATE_SCISSOR (0x1<<1) +#define SC_ENABLE_MASK (0x1<<0) +#define SC_ENABLE (0x1<<0) #define GFX_OP_LOAD_INDIRECT ((0x3<<29)|(0x1d<<24)|(0x7<<16)) #define GFX_OP_SCISSOR_INFO ((0x3<<29)|(0x1d<<24)|(0x81<<16)|(0x1)) -#define SCI_YMIN_MASK (0xffff<<16) -#define SCI_XMIN_MASK (0xffff<<0) -#define SCI_YMAX_MASK (0xffff<<16) -#define SCI_XMAX_MASK (0xffff<<0) +#define SCI_YMIN_MASK (0xffff<<16) +#define SCI_XMIN_MASK (0xffff<<0) +#define SCI_YMAX_MASK (0xffff<<16) +#define SCI_XMAX_MASK (0xffff<<0) #define GFX_OP_SCISSOR_ENABLE ((0x3<<29)|(0x1c<<24)|(0x10<<19)) #define GFX_OP_SCISSOR_RECT ((0x3<<29)|(0x1d<<24)|(0x81<<16)|1) #define GFX_OP_COLOR_FACTOR ((0x3<<29)|(0x1d<<24)|(0x1<<16)|0x0) @@ -264,42 +264,42 @@ #define XY_MONO_SRC_COPY_IMM_BLT ((2<<29)|(0x71<<22)|5) #define XY_SRC_COPY_BLT_WRITE_ALPHA (1<<21) #define XY_SRC_COPY_BLT_WRITE_RGB (1<<20) -#define BLT_DEPTH_8 (0<<24) -#define BLT_DEPTH_16_565 (1<<24) -#define BLT_DEPTH_16_1555 (2<<24) -#define BLT_DEPTH_32 (3<<24) -#define BLT_ROP_GXCOPY (0xcc<<16) +#define BLT_DEPTH_8 (0<<24) +#define BLT_DEPTH_16_565 (1<<24) +#define BLT_DEPTH_16_1555 (2<<24) +#define BLT_DEPTH_32 (3<<24) +#define BLT_ROP_GXCOPY (0xcc<<16) #define XY_SRC_COPY_BLT_SRC_TILED (1<<15) /* 965+ only */ #define XY_SRC_COPY_BLT_DST_TILED (1<<11) /* 965+ only */ #define CMD_OP_DISPLAYBUFFER_INFO ((0x0<<29)|(0x14<<23)|2) -#define ASYNC_FLIP (1<<22) -#define DISPLAY_PLANE_A (0<<20) -#define DISPLAY_PLANE_B (1<<20) +#define ASYNC_FLIP (1<<22) +#define DISPLAY_PLANE_A (0<<20) +#define DISPLAY_PLANE_B (1<<20) #define GFX_OP_PIPE_CONTROL(len) ((0x3<<29)|(0x3<<27)|(0x2<<24)|(len-2)) -#define PIPE_CONTROL_CS_STALL (1<<20) -#define PIPE_CONTROL_QW_WRITE (1<<14) -#define PIPE_CONTROL_DEPTH_STALL (1<<13) -#define PIPE_CONTROL_WRITE_FLUSH (1<<12) -#define PIPE_CONTROL_RENDER_TARGET_CACHE_FLUSH (1<<12) /* gen6+ */ -#define PIPE_CONTROL_INSTRUCTION_CACHE_INVALIDATE (1<<11) /* MBZ on Ironlake */ -#define PIPE_CONTROL_TEXTURE_CACHE_INVALIDATE (1<<10) /* GM45+ only */ -#define PIPE_CONTROL_INDIRECT_STATE_DISABLE (1<<9) -#define PIPE_CONTROL_NOTIFY (1<<8) -#define PIPE_CONTROL_VF_CACHE_INVALIDATE (1<<4) -#define PIPE_CONTROL_CONST_CACHE_INVALIDATE (1<<3) -#define PIPE_CONTROL_STATE_CACHE_INVALIDATE (1<<2) -#define PIPE_CONTROL_STALL_AT_SCOREBOARD (1<<1) -#define PIPE_CONTROL_DEPTH_CACHE_FLUSH (1<<0) -#define PIPE_CONTROL_GLOBAL_GTT (1<<2) /* in addr dword */ +#define PIPE_CONTROL_CS_STALL (1<<20) +#define PIPE_CONTROL_QW_WRITE (1<<14) +#define PIPE_CONTROL_DEPTH_STALL (1<<13) +#define PIPE_CONTROL_WRITE_FLUSH (1<<12) +#define PIPE_CONTROL_RENDER_TARGET_CACHE_FLUSH (1<<12) /* gen6+ */ +#define PIPE_CONTROL_INSTRUCTION_CACHE_INVALIDATE (1<<11) /* MBZ on Ironlake */ +#define PIPE_CONTROL_TEXTURE_CACHE_INVALIDATE (1<<10) /* GM45+ only */ +#define PIPE_CONTROL_INDIRECT_STATE_DISABLE (1<<9) +#define PIPE_CONTROL_NOTIFY (1<<8) +#define PIPE_CONTROL_VF_CACHE_INVALIDATE (1<<4) +#define PIPE_CONTROL_CONST_CACHE_INVALIDATE (1<<3) +#define PIPE_CONTROL_STATE_CACHE_INVALIDATE (1<<2) +#define PIPE_CONTROL_STALL_AT_SCOREBOARD (1<<1) +#define PIPE_CONTROL_DEPTH_CACHE_FLUSH (1<<0) +#define PIPE_CONTROL_GLOBAL_GTT (1<<2) /* in addr dword */
/* * Reset registers */ #define DEBUG_RESET_I830 0x6070 -#define DEBUG_RESET_FULL (1<<7) -#define DEBUG_RESET_RENDER (1<<8) -#define DEBUG_RESET_DISPLAY (1<<9) +#define DEBUG_RESET_FULL (1<<7) +#define DEBUG_RESET_RENDER (1<<8) +#define DEBUG_RESET_DISPLAY (1<<9)
/* @@ -307,32 +307,32 @@ */ #define FENCE_REG_830_0 0x2000 #define FENCE_REG_945_8 0x3000 -#define I830_FENCE_START_MASK 0x07f80000 -#define I830_FENCE_TILING_Y_SHIFT 12 -#define I830_FENCE_SIZE_BITS(size) ((ffs((size) >> 19) - 1) << 8) -#define I830_FENCE_PITCH_SHIFT 4 -#define I830_FENCE_REG_VALID (1<<0) -#define I915_FENCE_MAX_PITCH_VAL 4 -#define I830_FENCE_MAX_PITCH_VAL 6 -#define I830_FENCE_MAX_SIZE_VAL (1<<8) - -#define I915_FENCE_START_MASK 0x0ff00000 -#define I915_FENCE_SIZE_BITS(size) ((ffs((size) >> 20) - 1) << 8) +#define I830_FENCE_START_MASK 0x07f80000 +#define I830_FENCE_TILING_Y_SHIFT 12 +#define I830_FENCE_SIZE_BITS(size) ((ffs((size) >> 19) - 1) << 8) +#define I830_FENCE_PITCH_SHIFT 4 +#define I830_FENCE_REG_VALID (1<<0) +#define I915_FENCE_MAX_PITCH_VAL 4 +#define I830_FENCE_MAX_PITCH_VAL 6 +#define I830_FENCE_MAX_SIZE_VAL (1<<8) + +#define I915_FENCE_START_MASK 0x0ff00000 +#define I915_FENCE_SIZE_BITS(size) ((ffs((size) >> 20) - 1) << 8)
#define FENCE_REG_965_0 0x03000 -#define I965_FENCE_PITCH_SHIFT 2 -#define I965_FENCE_TILING_Y_SHIFT 1 -#define I965_FENCE_REG_VALID (1<<0) -#define I965_FENCE_MAX_PITCH_VAL 0x0400 +#define I965_FENCE_PITCH_SHIFT 2 +#define I965_FENCE_TILING_Y_SHIFT 1 +#define I965_FENCE_REG_VALID (1<<0) +#define I965_FENCE_MAX_PITCH_VAL 0x0400
#define FENCE_REG_SANDYBRIDGE_0 0x100000 -#define SANDYBRIDGE_FENCE_PITCH_SHIFT 32 +#define SANDYBRIDGE_FENCE_PITCH_SHIFT 32
/* control register for cpu gtt access */ #define TILECTL 0x101000 -#define TILECTL_SWZCTL (1 << 0) -#define TILECTL_TLB_PREFETCH_DIS (1 << 2) -#define TILECTL_BACKSNOOP_DIS (1 << 3) +#define TILECTL_SWZCTL (1 << 0) +#define TILECTL_TLB_PREFETCH_DIS (1 << 2) +#define TILECTL_BACKSNOOP_DIS (1 << 3)
/* * Instruction and interrupt control regs @@ -358,10 +358,10 @@ #define RING_HWS_PGA(base) ((base)+0x80) #define RING_HWS_PGA_GEN6(base) ((base)+0x2080) #define ARB_MODE 0x04030 -#define ARB_MODE_SWIZZLE_SNB (1<<4) -#define ARB_MODE_SWIZZLE_IVB (1<<5) -#define ARB_MODE_ENABLE(x) GFX_MODE_ENABLE(x) -#define ARB_MODE_DISABLE(x) GFX_MODE_DISABLE(x) +#define ARB_MODE_SWIZZLE_SNB (1<<4) +#define ARB_MODE_SWIZZLE_IVB (1<<5) +#define ARB_MODE_ENABLE(x) GFX_MODE_ENABLE(x) +#define ARB_MODE_DISABLE(x) GFX_MODE_DISABLE(x) #define RENDER_HWS_PGA_GEN7 (0x04080) #define RING_FAULT_REG(ring) (0x4094 + 0x100*(ring)->id) #define DONE_REG 0x40b0 @@ -370,21 +370,21 @@ #define RING_ACTHD(base) ((base)+0x74) #define RING_NOPID(base) ((base)+0x94) #define RING_IMR(base) ((base)+0xa8) -#define TAIL_ADDR 0x001FFFF8 -#define HEAD_WRAP_COUNT 0xFFE00000 -#define HEAD_WRAP_ONE 0x00200000 -#define HEAD_ADDR 0x001FFFFC -#define RING_NR_PAGES 0x001FF000 -#define RING_REPORT_MASK 0x00000006 -#define RING_REPORT_64K 0x00000002 -#define RING_REPORT_128K 0x00000004 -#define RING_NO_REPORT 0x00000000 -#define RING_VALID_MASK 0x00000001 -#define RING_VALID 0x00000001 -#define RING_INVALID 0x00000000 -#define RING_WAIT_I8XX (1<<0) /* gen2, PRBx_HEAD */ -#define RING_WAIT (1<<11) /* gen3+, PRBx_CTL */ -#define RING_WAIT_SEMAPHORE (1<<10) /* gen6+ */ +#define TAIL_ADDR 0x001FFFF8 +#define HEAD_WRAP_COUNT 0xFFE00000 +#define HEAD_WRAP_ONE 0x00200000 +#define HEAD_ADDR 0x001FFFFC +#define RING_NR_PAGES 0x001FF000 +#define RING_REPORT_MASK 0x00000006 +#define RING_REPORT_64K 0x00000002 +#define RING_REPORT_128K 0x00000004 +#define RING_NO_REPORT 0x00000000 +#define RING_VALID_MASK 0x00000001 +#define RING_VALID 0x00000001 +#define RING_INVALID 0x00000000 +#define RING_WAIT_I8XX (1<<0) /* gen2, PRBx_HEAD */ +#define RING_WAIT (1<<11) /* gen3+, PRBx_CTL */ +#define RING_WAIT_SEMAPHORE (1<<10) /* gen6+ */ #if 0 #define PRB0_TAIL 0x02030 #define PRB0_HEAD 0x02034 @@ -411,7 +411,7 @@ #define HWS_ADDRESS_MASK 0xfffff000 #define HWS_START_ADDRESS_SHIFT 4 #define PWRCTXA 0x2088 /* 965GM+ only */ -#define PWRCTX_EN (1<<0) +#define PWRCTX_EN (1<<0) #define IPEIR 0x02088 #define IPEHR 0x0208c #define INSTDONE 0x02090 @@ -440,12 +440,12 @@ #define GFX_MODE 0x02520 #define GFX_MODE_GEN7 0x0229c #define RING_MODE_GEN7(ring) ((ring)->mmio_base+0x29c) -#define GFX_RUN_LIST_ENABLE (1<<15) -#define GFX_TLB_INVALIDATE_ALWAYS (1<<13) -#define GFX_SURFACE_FAULT_ENABLE (1<<12) -#define GFX_REPLAY_MODE (1<<11) -#define GFX_PSMI_GRANULARITY (1<<10) -#define GFX_PPGTT_ENABLE (1<<9) +#define GFX_RUN_LIST_ENABLE (1<<15) +#define GFX_TLB_INVALIDATE_ALWAYS (1<<13) +#define GFX_SURFACE_FAULT_ENABLE (1<<12) +#define GFX_REPLAY_MODE (1<<11) +#define GFX_PSMI_GRANULARITY (1<<10) +#define GFX_PPGTT_ENABLE (1<<9)
#define GFX_MODE_ENABLE(bit) (((bit) << 16) | (bit)) #define GFX_MODE_DISABLE(bit) (((bit) << 16) | (0)) @@ -455,163 +455,163 @@ #define IIR 0x020a4 #define IMR 0x020a8 #define ISR 0x020ac -#define I915_PIPE_CONTROL_NOTIFY_INTERRUPT (1<<18) -#define I915_DISPLAY_PORT_INTERRUPT (1<<17) -#define I915_RENDER_COMMAND_PARSER_ERROR_INTERRUPT (1<<15) -#define I915_GMCH_THERMAL_SENSOR_EVENT_INTERRUPT (1<<14) /* p-state */ -#define I915_HWB_OOM_INTERRUPT (1<<13) -#define I915_SYNC_STATUS_INTERRUPT (1<<12) -#define I915_DISPLAY_PLANE_A_FLIP_PENDING_INTERRUPT (1<<11) -#define I915_DISPLAY_PLANE_B_FLIP_PENDING_INTERRUPT (1<<10) -#define I915_OVERLAY_PLANE_FLIP_PENDING_INTERRUPT (1<<9) -#define I915_DISPLAY_PLANE_C_FLIP_PENDING_INTERRUPT (1<<8) -#define I915_DISPLAY_PIPE_A_VBLANK_INTERRUPT (1<<7) -#define I915_DISPLAY_PIPE_A_EVENT_INTERRUPT (1<<6) -#define I915_DISPLAY_PIPE_B_VBLANK_INTERRUPT (1<<5) -#define I915_DISPLAY_PIPE_B_EVENT_INTERRUPT (1<<4) -#define I915_DEBUG_INTERRUPT (1<<2) -#define I915_USER_INTERRUPT (1<<1) -#define I915_ASLE_INTERRUPT (1<<0) -#define I915_BSD_USER_INTERRUPT (1<<25) +#define I915_PIPE_CONTROL_NOTIFY_INTERRUPT (1<<18) +#define I915_DISPLAY_PORT_INTERRUPT (1<<17) +#define I915_RENDER_COMMAND_PARSER_ERROR_INTERRUPT (1<<15) +#define I915_GMCH_THERMAL_SENSOR_EVENT_INTERRUPT (1<<14) /* p-state */ +#define I915_HWB_OOM_INTERRUPT (1<<13) +#define I915_SYNC_STATUS_INTERRUPT (1<<12) +#define I915_DISPLAY_PLANE_A_FLIP_PENDING_INTERRUPT (1<<11) +#define I915_DISPLAY_PLANE_B_FLIP_PENDING_INTERRUPT (1<<10) +#define I915_OVERLAY_PLANE_FLIP_PENDING_INTERRUPT (1<<9) +#define I915_DISPLAY_PLANE_C_FLIP_PENDING_INTERRUPT (1<<8) +#define I915_DISPLAY_PIPE_A_VBLANK_INTERRUPT (1<<7) +#define I915_DISPLAY_PIPE_A_EVENT_INTERRUPT (1<<6) +#define I915_DISPLAY_PIPE_B_VBLANK_INTERRUPT (1<<5) +#define I915_DISPLAY_PIPE_B_EVENT_INTERRUPT (1<<4) +#define I915_DEBUG_INTERRUPT (1<<2) +#define I915_USER_INTERRUPT (1<<1) +#define I915_ASLE_INTERRUPT (1<<0) +#define I915_BSD_USER_INTERRUPT (1<<25) #define EIR 0x020b0 #define EMR 0x020b4 #define ESR 0x020b8 -#define GM45_ERROR_PAGE_TABLE (1<<5) -#define GM45_ERROR_MEM_PRIV (1<<4) -#define I915_ERROR_PAGE_TABLE (1<<4) -#define GM45_ERROR_CP_PRIV (1<<3) -#define I915_ERROR_MEMORY_REFRESH (1<<1) -#define I915_ERROR_INSTRUCTION (1<<0) +#define GM45_ERROR_PAGE_TABLE (1<<5) +#define GM45_ERROR_MEM_PRIV (1<<4) +#define I915_ERROR_PAGE_TABLE (1<<4) +#define GM45_ERROR_CP_PRIV (1<<3) +#define I915_ERROR_MEMORY_REFRESH (1<<1) +#define I915_ERROR_INSTRUCTION (1<<0) #define INSTPM 0x020c0 -#define INSTPM_SELF_EN (1<<12) /* 915GM only */ -#define INSTPM_AGPBUSY_DIS (1<<11) /* gen3: when disabled, pending interrupts +#define INSTPM_SELF_EN (1<<12) /* 915GM only */ +#define INSTPM_AGPBUSY_DIS (1<<11) /* gen3: when disabled, pending interrupts will not assert AGPBUSY# and will only be delivered when out of C3. */ -#define INSTPM_FORCE_ORDERING (1<<7) /* GEN6+ */ +#define INSTPM_FORCE_ORDERING (1<<7) /* GEN6+ */ #define ACTHD 0x020c8 #define FW_BLC 0x020d8 #define FW_BLC2 0x020dc #define FW_BLC_SELF 0x020e0 /* 915+ only */ -#define FW_BLC_SELF_EN_MASK (1<<31) -#define FW_BLC_SELF_FIFO_MASK (1<<16) /* 945 only */ -#define FW_BLC_SELF_EN (1<<15) /* 945 only */ +#define FW_BLC_SELF_EN_MASK (1<<31) +#define FW_BLC_SELF_FIFO_MASK (1<<16) /* 945 only */ +#define FW_BLC_SELF_EN (1<<15) /* 945 only */ #define MM_BURST_LENGTH 0x00700000 #define MM_FIFO_WATERMARK 0x0001F000 #define LM_BURST_LENGTH 0x00000700 #define LM_FIFO_WATERMARK 0x0000001F #define MI_ARB_STATE 0x020e4 /* 915+ only */ -#define MI_ARB_MASK_SHIFT 16 /* shift for enable bits */ +#define MI_ARB_MASK_SHIFT 16 /* shift for enable bits */
/* Make render/texture TLB fetches lower priorty than associated data * fetches. This is not turned on by default */ -#define MI_ARB_RENDER_TLB_LOW_PRIORITY (1 << 15) +#define MI_ARB_RENDER_TLB_LOW_PRIORITY (1 << 15)
/* Isoch request wait on GTT enable (Display A/B/C streams). * Make isoch requests stall on the TLB update. May cause * display underruns (test mode only) */ -#define MI_ARB_ISOCH_WAIT_GTT (1 << 14) +#define MI_ARB_ISOCH_WAIT_GTT (1 << 14)
/* Block grant count for isoch requests when block count is * set to a finite value. */ -#define MI_ARB_BLOCK_GRANT_MASK (3 << 12) -#define MI_ARB_BLOCK_GRANT_8 (0 << 12) /* for 3 display planes */ -#define MI_ARB_BLOCK_GRANT_4 (1 << 12) /* for 2 display planes */ -#define MI_ARB_BLOCK_GRANT_2 (2 << 12) /* for 1 display plane */ -#define MI_ARB_BLOCK_GRANT_0 (3 << 12) /* don't use */ +#define MI_ARB_BLOCK_GRANT_MASK (3 << 12) +#define MI_ARB_BLOCK_GRANT_8 (0 << 12) /* for 3 display planes */ +#define MI_ARB_BLOCK_GRANT_4 (1 << 12) /* for 2 display planes */ +#define MI_ARB_BLOCK_GRANT_2 (2 << 12) /* for 1 display plane */ +#define MI_ARB_BLOCK_GRANT_0 (3 << 12) /* don't use */
/* Enable render writes to complete in C2/C3/C4 power states. * If this isn't enabled, render writes are prevented in low * power states. That seems bad to me. */ -#define MI_ARB_C3_LP_WRITE_ENABLE (1 << 11) +#define MI_ARB_C3_LP_WRITE_ENABLE (1 << 11)
/* This acknowledges an async flip immediately instead * of waiting for 2TLB fetches. */ -#define MI_ARB_ASYNC_FLIP_ACK_IMMEDIATE (1 << 10) +#define MI_ARB_ASYNC_FLIP_ACK_IMMEDIATE (1 << 10)
/* Enables non-sequential data reads through arbiter */ -#define MI_ARB_DUAL_DATA_PHASE_DISABLE (1 << 9) +#define MI_ARB_DUAL_DATA_PHASE_DISABLE (1 << 9)
/* Disable FSB snooping of cacheable write cycles from binner/render * command stream */ -#define MI_ARB_CACHE_SNOOP_DISABLE (1 << 8) +#define MI_ARB_CACHE_SNOOP_DISABLE (1 << 8)
/* Arbiter time slice for non-isoch streams */ -#define MI_ARB_TIME_SLICE_MASK (7 << 5) -#define MI_ARB_TIME_SLICE_1 (0 << 5) -#define MI_ARB_TIME_SLICE_2 (1 << 5) -#define MI_ARB_TIME_SLICE_4 (2 << 5) -#define MI_ARB_TIME_SLICE_6 (3 << 5) -#define MI_ARB_TIME_SLICE_8 (4 << 5) -#define MI_ARB_TIME_SLICE_10 (5 << 5) -#define MI_ARB_TIME_SLICE_14 (6 << 5) -#define MI_ARB_TIME_SLICE_16 (7 << 5) +#define MI_ARB_TIME_SLICE_MASK (7 << 5) +#define MI_ARB_TIME_SLICE_1 (0 << 5) +#define MI_ARB_TIME_SLICE_2 (1 << 5) +#define MI_ARB_TIME_SLICE_4 (2 << 5) +#define MI_ARB_TIME_SLICE_6 (3 << 5) +#define MI_ARB_TIME_SLICE_8 (4 << 5) +#define MI_ARB_TIME_SLICE_10 (5 << 5) +#define MI_ARB_TIME_SLICE_14 (6 << 5) +#define MI_ARB_TIME_SLICE_16 (7 << 5)
/* Low priority grace period page size */ -#define MI_ARB_LOW_PRIORITY_GRACE_4KB (0 << 4) /* default */ -#define MI_ARB_LOW_PRIORITY_GRACE_8KB (1 << 4) +#define MI_ARB_LOW_PRIORITY_GRACE_4KB (0 << 4) /* default */ +#define MI_ARB_LOW_PRIORITY_GRACE_8KB (1 << 4)
/* Disable display A/B trickle feed */ -#define MI_ARB_DISPLAY_TRICKLE_FEED_DISABLE (1 << 2) +#define MI_ARB_DISPLAY_TRICKLE_FEED_DISABLE (1 << 2)
/* Set display plane priority */ -#define MI_ARB_DISPLAY_PRIORITY_A_B (0 << 0) /* display A > display B */ -#define MI_ARB_DISPLAY_PRIORITY_B_A (1 << 0) /* display B > display A */ +#define MI_ARB_DISPLAY_PRIORITY_A_B (0 << 0) /* display A > display B */ +#define MI_ARB_DISPLAY_PRIORITY_B_A (1 << 0) /* display B > display A */
#define CACHE_MODE_0 0x02120 /* 915+ only */ -#define CM0_MASK_SHIFT 16 -#define CM0_IZ_OPT_DISABLE (1<<6) -#define CM0_ZR_OPT_DISABLE (1<<5) +#define CM0_MASK_SHIFT 16 +#define CM0_IZ_OPT_DISABLE (1<<6) +#define CM0_ZR_OPT_DISABLE (1<<5) #define CM0_STC_EVICT_DISABLE_LRA_SNB (1<<5) -#define CM0_DEPTH_EVICT_DISABLE (1<<4) -#define CM0_COLOR_EVICT_DISABLE (1<<3) -#define CM0_DEPTH_WRITE_DISABLE (1<<1) -#define CM0_RC_OP_FLUSH_DISABLE (1<<0) +#define CM0_DEPTH_EVICT_DISABLE (1<<4) +#define CM0_COLOR_EVICT_DISABLE (1<<3) +#define CM0_DEPTH_WRITE_DISABLE (1<<1) +#define CM0_RC_OP_FLUSH_DISABLE (1<<0) #define BB_ADDR 0x02140 /* 8 bytes */ #define GFX_FLSH_CNTL 0x02170 /* 915+ only */ #define ECOSKPD 0x021d0 -#define ECO_GATING_CX_ONLY (1<<3) -#define ECO_FLIP_DONE (1<<0) +#define ECO_GATING_CX_ONLY (1<<3) +#define ECO_FLIP_DONE (1<<0)
/* GEN6 interrupt control */ #define GEN6_RENDER_HWSTAM 0x2098 #define GEN6_RENDER_IMR 0x20a8 -#define GEN6_RENDER_CONTEXT_SWITCH_INTERRUPT (1 << 8) -#define GEN6_RENDER_PPGTT_PAGE_FAULT (1 << 7) -#define GEN6_RENDER_TIMEOUT_COUNTER_EXPIRED (1 << 6) -#define GEN6_RENDER_L3_PARITY_ERROR (1 << 5) -#define GEN6_RENDER_PIPE_CONTROL_NOTIFY_INTERRUPT (1 << 4) -#define GEN6_RENDER_COMMAND_PARSER_MASTER_ERROR (1 << 3) -#define GEN6_RENDER_SYNC_STATUS (1 << 2) -#define GEN6_RENDER_DEBUG_INTERRUPT (1 << 1) -#define GEN6_RENDER_USER_INTERRUPT (1 << 0) +#define GEN6_RENDER_CONTEXT_SWITCH_INTERRUPT (1 << 8) +#define GEN6_RENDER_PPGTT_PAGE_FAULT (1 << 7) +#define GEN6_RENDER_TIMEOUT_COUNTER_EXPIRED (1 << 6) +#define GEN6_RENDER_L3_PARITY_ERROR (1 << 5) +#define GEN6_RENDER_PIPE_CONTROL_NOTIFY_INTERRUPT (1 << 4) +#define GEN6_RENDER_COMMAND_PARSER_MASTER_ERROR (1 << 3) +#define GEN6_RENDER_SYNC_STATUS (1 << 2) +#define GEN6_RENDER_DEBUG_INTERRUPT (1 << 1) +#define GEN6_RENDER_USER_INTERRUPT (1 << 0)
#define GEN6_BLITTER_HWSTAM 0x22098 #define GEN6_BLITTER_IMR 0x220a8 -#define GEN6_BLITTER_MI_FLUSH_DW_NOTIFY_INTERRUPT (1 << 26) -#define GEN6_BLITTER_COMMAND_PARSER_MASTER_ERROR (1 << 25) -#define GEN6_BLITTER_SYNC_STATUS (1 << 24) -#define GEN6_BLITTER_USER_INTERRUPT (1 << 22) +#define GEN6_BLITTER_MI_FLUSH_DW_NOTIFY_INTERRUPT (1 << 26) +#define GEN6_BLITTER_COMMAND_PARSER_MASTER_ERROR (1 << 25) +#define GEN6_BLITTER_SYNC_STATUS (1 << 24) +#define GEN6_BLITTER_USER_INTERRUPT (1 << 22)
#define GEN6_BLITTER_ECOSKPD 0x221d0 -#define GEN6_BLITTER_LOCK_SHIFT 16 -#define GEN6_BLITTER_FBC_NOTIFY (1<<3) +#define GEN6_BLITTER_LOCK_SHIFT 16 +#define GEN6_BLITTER_FBC_NOTIFY (1<<3)
#define GEN6_BSD_SLEEP_PSMI_CONTROL 0x12050 -#define GEN6_BSD_SLEEP_PSMI_CONTROL_RC_ILDL_MESSAGE_MODIFY_MASK (1 << 16) -#define GEN6_BSD_SLEEP_PSMI_CONTROL_RC_ILDL_MESSAGE_DISABLE (1 << 0) -#define GEN6_BSD_SLEEP_PSMI_CONTROL_RC_ILDL_MESSAGE_ENABLE 0 -#define GEN6_BSD_SLEEP_PSMI_CONTROL_IDLE_INDICATOR (1 << 3) +#define GEN6_BSD_SLEEP_PSMI_CONTROL_RC_ILDL_MESSAGE_MODIFY_MASK (1 << 16) +#define GEN6_BSD_SLEEP_PSMI_CONTROL_RC_ILDL_MESSAGE_DISABLE (1 << 0) +#define GEN6_BSD_SLEEP_PSMI_CONTROL_RC_ILDL_MESSAGE_ENABLE 0 +#define GEN6_BSD_SLEEP_PSMI_CONTROL_IDLE_INDICATOR (1 << 3)
#define GEN6_BSD_HWSTAM 0x12098 #define GEN6_BSD_IMR 0x120a8 -#define GEN6_BSD_USER_INTERRUPT (1 << 12) +#define GEN6_BSD_USER_INTERRUPT (1 << 12)
#define GEN6_BSD_RNCID 0x12198
@@ -622,29 +622,29 @@ #define FBC_CFB_BASE 0x03200 /* 4k page aligned */ #define FBC_LL_BASE 0x03204 /* 4k page aligned */ #define FBC_CONTROL 0x03208 -#define FBC_CTL_EN (1<<31) -#define FBC_CTL_PERIODIC (1<<30) -#define FBC_CTL_INTERVAL_SHIFT (16) -#define FBC_CTL_UNCOMPRESSIBLE (1<<14) -#define FBC_CTL_C3_IDLE (1<<13) -#define FBC_CTL_STRIDE_SHIFT (5) -#define FBC_CTL_FENCENO (1<<0) +#define FBC_CTL_EN (1<<31) +#define FBC_CTL_PERIODIC (1<<30) +#define FBC_CTL_INTERVAL_SHIFT (16) +#define FBC_CTL_UNCOMPRESSIBLE (1<<14) +#define FBC_CTL_C3_IDLE (1<<13) +#define FBC_CTL_STRIDE_SHIFT (5) +#define FBC_CTL_FENCENO (1<<0) #define FBC_COMMAND 0x0320c -#define FBC_CMD_COMPRESS (1<<0) +#define FBC_CMD_COMPRESS (1<<0) #define FBC_STATUS 0x03210 -#define FBC_STAT_COMPRESSING (1<<31) -#define FBC_STAT_COMPRESSED (1<<30) -#define FBC_STAT_MODIFIED (1<<29) -#define FBC_STAT_CURRENT_LINE (1<<0) +#define FBC_STAT_COMPRESSING (1<<31) +#define FBC_STAT_COMPRESSED (1<<30) +#define FBC_STAT_MODIFIED (1<<29) +#define FBC_STAT_CURRENT_LINE (1<<0) #define FBC_CONTROL2 0x03214 -#define FBC_CTL_FENCE_DBL (0<<4) -#define FBC_CTL_IDLE_IMM (0<<2) -#define FBC_CTL_IDLE_FULL (1<<2) -#define FBC_CTL_IDLE_LINE (2<<2) -#define FBC_CTL_IDLE_DEBUG (3<<2) -#define FBC_CTL_CPU_FENCE (1<<1) -#define FBC_CTL_PLANEA (0<<0) -#define FBC_CTL_PLANEB (1<<0) +#define FBC_CTL_FENCE_DBL (0<<4) +#define FBC_CTL_IDLE_IMM (0<<2) +#define FBC_CTL_IDLE_FULL (1<<2) +#define FBC_CTL_IDLE_LINE (2<<2) +#define FBC_CTL_IDLE_DEBUG (3<<2) +#define FBC_CTL_CPU_FENCE (1<<1) +#define FBC_CTL_PLANEA (0<<0) +#define FBC_CTL_PLANEB (1<<0) #define FBC_FENCE_OFF 0x0321b #define FBC_TAG 0x03300
@@ -653,45 +653,45 @@ /* Framebuffer compression for GM45+ */ #define DPFC_CB_BASE 0x3200 #define DPFC_CONTROL 0x3208 -#define DPFC_CTL_EN (1<<31) -#define DPFC_CTL_PLANEA (0<<30) -#define DPFC_CTL_PLANEB (1<<30) -#define DPFC_CTL_FENCE_EN (1<<29) -#define DPFC_CTL_PERSISTENT_MODE (1<<25) -#define DPFC_SR_EN (1<<10) -#define DPFC_CTL_LIMIT_1X (0<<6) -#define DPFC_CTL_LIMIT_2X (1<<6) -#define DPFC_CTL_LIMIT_4X (2<<6) +#define DPFC_CTL_EN (1<<31) +#define DPFC_CTL_PLANEA (0<<30) +#define DPFC_CTL_PLANEB (1<<30) +#define DPFC_CTL_FENCE_EN (1<<29) +#define DPFC_CTL_PERSISTENT_MODE (1<<25) +#define DPFC_SR_EN (1<<10) +#define DPFC_CTL_LIMIT_1X (0<<6) +#define DPFC_CTL_LIMIT_2X (1<<6) +#define DPFC_CTL_LIMIT_4X (2<<6) #define DPFC_RECOMP_CTL 0x320c -#define DPFC_RECOMP_STALL_EN (1<<27) -#define DPFC_RECOMP_STALL_WM_SHIFT (16) -#define DPFC_RECOMP_STALL_WM_MASK (0x07ff0000) -#define DPFC_RECOMP_TIMER_COUNT_SHIFT (0) -#define DPFC_RECOMP_TIMER_COUNT_MASK (0x0000003f) +#define DPFC_RECOMP_STALL_EN (1<<27) +#define DPFC_RECOMP_STALL_WM_SHIFT (16) +#define DPFC_RECOMP_STALL_WM_MASK (0x07ff0000) +#define DPFC_RECOMP_TIMER_COUNT_SHIFT (0) +#define DPFC_RECOMP_TIMER_COUNT_MASK (0x0000003f) #define DPFC_STATUS 0x3210 -#define DPFC_INVAL_SEG_SHIFT (16) -#define DPFC_INVAL_SEG_MASK (0x07ff0000) -#define DPFC_COMP_SEG_SHIFT (0) -#define DPFC_COMP_SEG_MASK (0x000003ff) +#define DPFC_INVAL_SEG_SHIFT (16) +#define DPFC_INVAL_SEG_MASK (0x07ff0000) +#define DPFC_COMP_SEG_SHIFT (0) +#define DPFC_COMP_SEG_MASK (0x000003ff) #define DPFC_STATUS2 0x3214 #define DPFC_FENCE_YOFF 0x3218 #define DPFC_CHICKEN 0x3224 -#define DPFC_HT_MODIFY (1<<31) +#define DPFC_HT_MODIFY (1<<31)
/* Framebuffer compression for Ironlake */ #define ILK_DPFC_CB_BASE 0x43200 #define ILK_DPFC_CONTROL 0x43208 /* The bit 28-8 is reserved */ -#define DPFC_RESERVED (0x1FFFFF00) +#define DPFC_RESERVED (0x1FFFFF00) #define ILK_DPFC_RECOMP_CTL 0x4320c #define ILK_DPFC_STATUS 0x43210 #define ILK_DPFC_FENCE_YOFF 0x43218 #define ILK_DPFC_CHICKEN 0x43224 #define ILK_FBC_RT_BASE 0x2128 -#define ILK_FBC_RT_VALID (1<<0) +#define ILK_FBC_RT_VALID (1<<0)
#define ILK_DISPLAY_CHICKEN1 0x42000 -#define ILK_FBCQ_DIS (1<<22) +#define ILK_FBCQ_DIS (1<<22) #define ILK_PABSTRETCH_DIS (1<<21)
@@ -701,7 +701,7 @@ * The following two registers are of type GTTMMADR */ #define SNB_DPFC_CTL_SA 0x100100 -#define SNB_CPU_FENCE_ENABLE (1<<29) +#define SNB_CPU_FENCE_ENABLE (1<<29) #define DPFC_CPU_FENCE_OFFSET 0x100104
@@ -732,52 +732,52 @@ # define GPIO_DATA_PULLUP_DISABLE (1 << 13)
#define GMBUS0 0x5100 /* clock/port select */ -#define GMBUS_RATE_100KHZ (0<<8) -#define GMBUS_RATE_50KHZ (1<<8) -#define GMBUS_RATE_400KHZ (2<<8) /* reserved on Pineview */ -#define GMBUS_RATE_1MHZ (3<<8) /* reserved on Pineview */ -#define GMBUS_RATE_MASK (3<<8) -#define GMBUS_HOLD_EXT (1<<7) /* 300ns hold time, rsvd on Pineview */ -#define GMBUS_PORT_DISABLED 0 -#define GMBUS_PORT_SSC 1 -#define GMBUS_PORT_VGADDC 2 -#define GMBUS_PORT_PANEL 3 -#define GMBUS_PORT_DPC 4 /* HDMIC */ -#define GMBUS_PORT_DPB 5 /* SDVO, HDMIB */ -#define GMBUS_PORT_DPD 6 /* HDMID */ -#define GMBUS_PORT_RESERVED 7 /* 7 reserved */ -#define GMBUS_NUM_PORTS (GMBUS_PORT_DPD - GMBUS_PORT_SSC + 1) -#define GMBUS_PORT_MASK 7 +#define GMBUS_RATE_100KHZ (0<<8) +#define GMBUS_RATE_50KHZ (1<<8) +#define GMBUS_RATE_400KHZ (2<<8) /* reserved on Pineview */ +#define GMBUS_RATE_1MHZ (3<<8) /* reserved on Pineview */ +#define GMBUS_RATE_MASK (3<<8) +#define GMBUS_HOLD_EXT (1<<7) /* 300ns hold time, rsvd on Pineview */ +#define GMBUS_PORT_DISABLED 0 +#define GMBUS_PORT_SSC 1 +#define GMBUS_PORT_VGADDC 2 +#define GMBUS_PORT_PANEL 3 +#define GMBUS_PORT_DPC 4 /* HDMIC */ +#define GMBUS_PORT_DPB 5 /* SDVO, HDMIB */ +#define GMBUS_PORT_DPD 6 /* HDMID */ +#define GMBUS_PORT_RESERVED 7 /* 7 reserved */ +#define GMBUS_NUM_PORTS (GMBUS_PORT_DPD - GMBUS_PORT_SSC + 1) +#define GMBUS_PORT_MASK 7 #define GMBUS1 0x5104 /* command/status */ -#define GMBUS_SW_CLR_INT (1<<31) -#define GMBUS_SW_RDY (1<<30) -#define GMBUS_ENT (1<<29) /* enable timeout */ -#define GMBUS_CYCLE_NONE (0<<25) -#define GMBUS_CYCLE_WAIT (1<<25) -#define GMBUS_CYCLE_INDEX (2<<25) -#define GMBUS_CYCLE_STOP (4<<25) -#define GMBUS_BYTE_COUNT_SHIFT 16 -#define GMBUS_SLAVE_INDEX_SHIFT 8 -#define GMBUS_SLAVE_ADDR_SHIFT 1 -#define GMBUS_SLAVE_READ (1<<0) -#define GMBUS_SLAVE_WRITE (0<<0) +#define GMBUS_SW_CLR_INT (1<<31) +#define GMBUS_SW_RDY (1<<30) +#define GMBUS_ENT (1<<29) /* enable timeout */ +#define GMBUS_CYCLE_NONE (0<<25) +#define GMBUS_CYCLE_WAIT (1<<25) +#define GMBUS_CYCLE_INDEX (2<<25) +#define GMBUS_CYCLE_STOP (4<<25) +#define GMBUS_BYTE_COUNT_SHIFT 16 +#define GMBUS_SLAVE_INDEX_SHIFT 8 +#define GMBUS_SLAVE_ADDR_SHIFT 1 +#define GMBUS_SLAVE_READ (1<<0) +#define GMBUS_SLAVE_WRITE (0<<0) #define GMBUS2 0x5108 /* status */ -#define GMBUS_INUSE (1<<15) -#define GMBUS_HW_WAIT_PHASE (1<<14) -#define GMBUS_STALL_TIMEOUT (1<<13) -#define GMBUS_INT (1<<12) -#define GMBUS_HW_RDY (1<<11) -#define GMBUS_SATOER (1<<10) -#define GMBUS_ACTIVE (1<<9) +#define GMBUS_INUSE (1<<15) +#define GMBUS_HW_WAIT_PHASE (1<<14) +#define GMBUS_STALL_TIMEOUT (1<<13) +#define GMBUS_INT (1<<12) +#define GMBUS_HW_RDY (1<<11) +#define GMBUS_SATOER (1<<10) +#define GMBUS_ACTIVE (1<<9) #define GMBUS3 0x510c /* data buffer bytes 3-0 */ #define GMBUS4 0x5110 /* interrupt mask (Pineview+) */ -#define GMBUS_SLAVE_TIMEOUT_EN (1<<4) -#define GMBUS_NAK_EN (1<<3) -#define GMBUS_IDLE_EN (1<<2) -#define GMBUS_HW_WAIT_EN (1<<1) -#define GMBUS_HW_RDY_EN (1<<0) +#define GMBUS_SLAVE_TIMEOUT_EN (1<<4) +#define GMBUS_NAK_EN (1<<3) +#define GMBUS_IDLE_EN (1<<2) +#define GMBUS_HW_WAIT_EN (1<<1) +#define GMBUS_HW_RDY_EN (1<<0) #define GMBUS5 0x5120 /* byte index */ -#define GMBUS_2BYTE_INDEX_EN (1<<31) +#define GMBUS_2BYTE_INDEX_EN (1<<31)
/* * Clock control & power management @@ -786,31 +786,31 @@ #define VGA0 0x6000 #define VGA1 0x6004 #define VGA_PD 0x6010 -#define VGA0_PD_P2_DIV_4 (1 << 7) -#define VGA0_PD_P1_DIV_2 (1 << 5) -#define VGA0_PD_P1_SHIFT 0 -#define VGA0_PD_P1_MASK (0x1f << 0) -#define VGA1_PD_P2_DIV_4 (1 << 15) -#define VGA1_PD_P1_DIV_2 (1 << 13) -#define VGA1_PD_P1_SHIFT 8 -#define VGA1_PD_P1_MASK (0x1f << 8) +#define VGA0_PD_P2_DIV_4 (1 << 7) +#define VGA0_PD_P1_DIV_2 (1 << 5) +#define VGA0_PD_P1_SHIFT 0 +#define VGA0_PD_P1_MASK (0x1f << 0) +#define VGA1_PD_P2_DIV_4 (1 << 15) +#define VGA1_PD_P1_DIV_2 (1 << 13) +#define VGA1_PD_P1_SHIFT 8 +#define VGA1_PD_P1_MASK (0x1f << 8) #define _DPLL_A 0x06014 #define _DPLL_B 0x06018 #define DPLL(pipe) _PIPE(pipe, _DPLL_A, _DPLL_B) -#define DPLL_VCO_ENABLE (1 << 31) -#define DPLL_DVO_HIGH_SPEED (1 << 30) -#define DPLL_SYNCLOCK_ENABLE (1 << 29) -#define DPLL_VGA_MODE_DIS (1 << 28) -#define DPLLB_MODE_DAC_SERIAL (1 << 26) /* i915 */ -#define DPLLB_MODE_LVDS (2 << 26) /* i915 */ -#define DPLL_MODE_MASK (3 << 26) -#define DPLL_DAC_SERIAL_P2_CLOCK_DIV_10 (0 << 24) /* i915 */ -#define DPLL_DAC_SERIAL_P2_CLOCK_DIV_5 (1 << 24) /* i915 */ -#define DPLLB_LVDS_P2_CLOCK_DIV_14 (0 << 24) /* i915 */ -#define DPLLB_LVDS_P2_CLOCK_DIV_7 (1 << 24) /* i915 */ -#define DPLL_P2_CLOCK_DIV_MASK 0x03000000 /* i915 */ -#define DPLL_FPA01_P1_POST_DIV_MASK 0x00ff0000 /* i915 */ -#define DPLL_FPA01_P1_POST_DIV_MASK_PINEVIEW 0x00ff8000 /* Pineview */ +#define DPLL_VCO_ENABLE (1 << 31) +#define DPLL_DVO_HIGH_SPEED (1 << 30) +#define DPLL_SYNCLOCK_ENABLE (1 << 29) +#define DPLL_VGA_MODE_DIS (1 << 28) +#define DPLLB_MODE_DAC_SERIAL (1 << 26) /* i915 */ +#define DPLLB_MODE_LVDS (2 << 26) /* i915 */ +#define DPLL_MODE_MASK (3 << 26) +#define DPLL_DAC_SERIAL_P2_CLOCK_DIV_10 (0 << 24) /* i915 */ +#define DPLL_DAC_SERIAL_P2_CLOCK_DIV_5 (1 << 24) /* i915 */ +#define DPLLB_LVDS_P2_CLOCK_DIV_14 (0 << 24) /* i915 */ +#define DPLLB_LVDS_P2_CLOCK_DIV_7 (1 << 24) /* i915 */ +#define DPLL_P2_CLOCK_DIV_MASK 0x03000000 /* i915 */ +#define DPLL_FPA01_P1_POST_DIV_MASK 0x00ff0000 /* i915 */ +#define DPLL_FPA01_P1_POST_DIV_MASK_PINEVIEW 0x00ff8000 /* Pineview */
#define SRX_INDEX 0x3c4 #define SRX_DATA 0x3c5 @@ -829,23 +829,23 @@
/* Scratch pad debug 0 reg: */ -#define DPLL_FPA01_P1_POST_DIV_MASK_I830 0x001f0000 +#define DPLL_FPA01_P1_POST_DIV_MASK_I830 0x001f0000 /* * The i830 generation, in LVDS mode, defines P1 as the bit number set within * this field (only one bit may be set). */ -#define DPLL_FPA01_P1_POST_DIV_MASK_I830_LVDS 0x003f0000 -#define DPLL_FPA01_P1_POST_DIV_SHIFT 16 -#define DPLL_FPA01_P1_POST_DIV_SHIFT_PINEVIEW 15 +#define DPLL_FPA01_P1_POST_DIV_MASK_I830_LVDS 0x003f0000 +#define DPLL_FPA01_P1_POST_DIV_SHIFT 16 +#define DPLL_FPA01_P1_POST_DIV_SHIFT_PINEVIEW 15 /* i830, required in DVO non-gang */ -#define PLL_P2_DIVIDE_BY_4 (1 << 23) -#define PLL_P1_DIVIDE_BY_TWO (1 << 21) /* i830 */ -#define PLL_REF_INPUT_DREFCLK (0 << 13) -#define PLL_REF_INPUT_TVCLKINA (1 << 13) /* i830 */ -#define PLL_REF_INPUT_TVCLKINBC (2 << 13) /* SDVO TVCLKIN */ -#define PLLB_REF_INPUT_SPREADSPECTRUMIN (3 << 13) -#define PLL_REF_INPUT_MASK (3 << 13) -#define PLL_LOAD_PULSE_PHASE_SHIFT 9 +#define PLL_P2_DIVIDE_BY_4 (1 << 23) +#define PLL_P1_DIVIDE_BY_TWO (1 << 21) /* i830 */ +#define PLL_REF_INPUT_DREFCLK (0 << 13) +#define PLL_REF_INPUT_TVCLKINA (1 << 13) /* i830 */ +#define PLL_REF_INPUT_TVCLKINBC (2 << 13) /* SDVO TVCLKIN */ +#define PLLB_REF_INPUT_SPREADSPECTRUMIN (3 << 13) +#define PLL_REF_INPUT_MASK (3 << 13) +#define PLL_LOAD_PULSE_PHASE_SHIFT 9 /* Ironlake */ # define PLL_REF_SDVO_HDMI_MULTIPLIER_SHIFT 9 # define PLL_REF_SDVO_HDMI_MULTIPLIER_MASK (7 << 9) @@ -859,25 +859,25 @@ * digital display port. The range is 4 to 13; 10 or more * is just a flip delay. The default is 6 */ -#define PLL_LOAD_PULSE_PHASE_MASK (0xf << PLL_LOAD_PULSE_PHASE_SHIFT) -#define DISPLAY_RATE_SELECT_FPA1 (1 << 8) +#define PLL_LOAD_PULSE_PHASE_MASK (0xf << PLL_LOAD_PULSE_PHASE_SHIFT) +#define DISPLAY_RATE_SELECT_FPA1 (1 << 8) /* * SDVO multiplier for 945G/GM. Not used on 965. */ -#define SDVO_MULTIPLIER_MASK 0x000000ff -#define SDVO_MULTIPLIER_SHIFT_HIRES 4 -#define SDVO_MULTIPLIER_SHIFT_VGA 0 +#define SDVO_MULTIPLIER_MASK 0x000000ff +#define SDVO_MULTIPLIER_SHIFT_HIRES 4 +#define SDVO_MULTIPLIER_SHIFT_VGA 0 #define _DPLL_A_MD 0x0601c /* 965+ only */ /* * UDI pixel divider, controlling how many pixels are stuffed into a packet. * * Value is pixels minus 1. Must be set to 1 pixel for SDVO. */ -#define DPLL_MD_UDI_DIVIDER_MASK 0x3f000000 -#define DPLL_MD_UDI_DIVIDER_SHIFT 24 +#define DPLL_MD_UDI_DIVIDER_MASK 0x3f000000 +#define DPLL_MD_UDI_DIVIDER_SHIFT 24 /* UDI pixel divider for VGA, same as DPLL_MD_UDI_DIVIDER_MASK. */ -#define DPLL_MD_VGA_UDI_DIVIDER_MASK 0x003f0000 -#define DPLL_MD_VGA_UDI_DIVIDER_SHIFT 16 +#define DPLL_MD_VGA_UDI_DIVIDER_MASK 0x003f0000 +#define DPLL_MD_VGA_UDI_DIVIDER_SHIFT 16 /* * SDVO/UDI pixel multiplier. * @@ -895,15 +895,15 @@ * This register field has values of multiplication factor minus 1, with * a maximum multiplier of 5 for SDVO. */ -#define DPLL_MD_UDI_MULTIPLIER_MASK 0x00003f00 -#define DPLL_MD_UDI_MULTIPLIER_SHIFT 8 +#define DPLL_MD_UDI_MULTIPLIER_MASK 0x00003f00 +#define DPLL_MD_UDI_MULTIPLIER_SHIFT 8 /* * SDVO/UDI pixel multiplier for VGA, same as DPLL_MD_UDI_MULTIPLIER_MASK. * This best be set to the default value (3) or the CRT won't work. No, * I don't entirely understand what this does... */ -#define DPLL_MD_VGA_UDI_MULTIPLIER_MASK 0x0000003f -#define DPLL_MD_VGA_UDI_MULTIPLIER_SHIFT 0 +#define DPLL_MD_VGA_UDI_MULTIPLIER_MASK 0x0000003f +#define DPLL_MD_VGA_UDI_MULTIPLIER_SHIFT 0 #define _DPLL_B_MD 0x06020 /* 965+ only */ #define DPLL_MD(pipe) _PIPE(pipe, _DPLL_A_MD, _DPLL_B_MD) #define _FPA0 0x06040 @@ -912,30 +912,30 @@ #define _FPB1 0x0604c #define FP0(pipe) _PIPE(pipe, _FPA0, _FPB0) #define FP1(pipe) _PIPE(pipe, _FPA1, _FPB1) -#define FP_N_DIV_MASK 0x003f0000 -#define FP_N_PINEVIEW_DIV_MASK 0x00ff0000 -#define FP_N_DIV_SHIFT 16 -#define FP_M1_DIV_MASK 0x00003f00 -#define FP_M1_DIV_SHIFT 8 -#define FP_M2_DIV_MASK 0x0000003f -#define FP_M2_PINEVIEW_DIV_MASK 0x000000ff -#define FP_M2_DIV_SHIFT 0 +#define FP_N_DIV_MASK 0x003f0000 +#define FP_N_PINEVIEW_DIV_MASK 0x00ff0000 +#define FP_N_DIV_SHIFT 16 +#define FP_M1_DIV_MASK 0x00003f00 +#define FP_M1_DIV_SHIFT 8 +#define FP_M2_DIV_MASK 0x0000003f +#define FP_M2_PINEVIEW_DIV_MASK 0x000000ff +#define FP_M2_DIV_SHIFT 0 #define DPLL_TEST 0x606c -#define DPLLB_TEST_SDVO_DIV_1 (0 << 22) -#define DPLLB_TEST_SDVO_DIV_2 (1 << 22) -#define DPLLB_TEST_SDVO_DIV_4 (2 << 22) -#define DPLLB_TEST_SDVO_DIV_MASK (3 << 22) -#define DPLLB_TEST_N_BYPASS (1 << 19) -#define DPLLB_TEST_M_BYPASS (1 << 18) -#define DPLLB_INPUT_BUFFER_ENABLE (1 << 16) -#define DPLLA_TEST_N_BYPASS (1 << 3) -#define DPLLA_TEST_M_BYPASS (1 << 2) -#define DPLLA_INPUT_BUFFER_ENABLE (1 << 0) +#define DPLLB_TEST_SDVO_DIV_1 (0 << 22) +#define DPLLB_TEST_SDVO_DIV_2 (1 << 22) +#define DPLLB_TEST_SDVO_DIV_4 (2 << 22) +#define DPLLB_TEST_SDVO_DIV_MASK (3 << 22) +#define DPLLB_TEST_N_BYPASS (1 << 19) +#define DPLLB_TEST_M_BYPASS (1 << 18) +#define DPLLB_INPUT_BUFFER_ENABLE (1 << 16) +#define DPLLA_TEST_N_BYPASS (1 << 3) +#define DPLLA_TEST_M_BYPASS (1 << 2) +#define DPLLA_INPUT_BUFFER_ENABLE (1 << 0) #define D_STATE 0x6104 -#define DSTATE_GFX_RESET_I830 (1<<6) -#define DSTATE_PLL_D3_OFF (1<<3) -#define DSTATE_GFX_CLOCK_GATING (1<<1) -#define DSTATE_DOT_CLOCK_GATING (1<<0) +#define DSTATE_GFX_RESET_I830 (1<<6) +#define DSTATE_PLL_D3_OFF (1<<3) +#define DSTATE_GFX_CLOCK_GATING (1<<1) +#define DSTATE_DOT_CLOCK_GATING (1<<0) #define DSPCLK_GATE_D 0x6200 # define DPUNIT_B_CLOCK_GATE_DISABLE (1 << 30) /* 965 */ # define VSUNIT_CLOCK_GATE_DISABLE (1 << 29) /* 965 */ @@ -1089,23 +1089,23 @@ #define MAD_DIMM_C0 (MCHBAR_MIRROR_BASE_SNB + 0x5004) #define MAD_DIMM_C1 (MCHBAR_MIRROR_BASE_SNB + 0x5008) #define MAD_DIMM_C2 (MCHBAR_MIRROR_BASE_SNB + 0x500C) -#define MAD_DIMM_ECC_MASK (0x3 << 24) -#define MAD_DIMM_ECC_OFF (0x0 << 24) -#define MAD_DIMM_ECC_IO_ON_LOGIC_OFF (0x1 << 24) -#define MAD_DIMM_ECC_IO_OFF_LOGIC_ON (0x2 << 24) -#define MAD_DIMM_ECC_ON (0x3 << 24) -#define MAD_DIMM_ENH_INTERLEAVE (0x1 << 22) -#define MAD_DIMM_RANK_INTERLEAVE (0x1 << 21) -#define MAD_DIMM_B_WIDTH_X16 (0x1 << 20) /* X8 chips if unset */ -#define MAD_DIMM_A_WIDTH_X16 (0x1 << 19) /* X8 chips if unset */ -#define MAD_DIMM_B_DUAL_RANK (0x1 << 18) -#define MAD_DIMM_A_DUAL_RANK (0x1 << 17) -#define MAD_DIMM_A_SELECT (0x1 << 16) +#define MAD_DIMM_ECC_MASK (0x3 << 24) +#define MAD_DIMM_ECC_OFF (0x0 << 24) +#define MAD_DIMM_ECC_IO_ON_LOGIC_OFF (0x1 << 24) +#define MAD_DIMM_ECC_IO_OFF_LOGIC_ON (0x2 << 24) +#define MAD_DIMM_ECC_ON (0x3 << 24) +#define MAD_DIMM_ENH_INTERLEAVE (0x1 << 22) +#define MAD_DIMM_RANK_INTERLEAVE (0x1 << 21) +#define MAD_DIMM_B_WIDTH_X16 (0x1 << 20) /* X8 chips if unset */ +#define MAD_DIMM_A_WIDTH_X16 (0x1 << 19) /* X8 chips if unset */ +#define MAD_DIMM_B_DUAL_RANK (0x1 << 18) +#define MAD_DIMM_A_DUAL_RANK (0x1 << 17) +#define MAD_DIMM_A_SELECT (0x1 << 16) /* DIMM sizes are in multiples of 256mb. */ -#define MAD_DIMM_B_SIZE_SHIFT 8 -#define MAD_DIMM_B_SIZE_MASK (0xff << MAD_DIMM_B_SIZE_SHIFT) -#define MAD_DIMM_A_SIZE_SHIFT 0 -#define MAD_DIMM_A_SIZE_MASK (0xff << MAD_DIMM_A_SIZE_SHIFT) +#define MAD_DIMM_B_SIZE_SHIFT 8 +#define MAD_DIMM_B_SIZE_MASK (0xff << MAD_DIMM_B_SIZE_SHIFT) +#define MAD_DIMM_A_SIZE_SHIFT 0 +#define MAD_DIMM_A_SIZE_MASK (0xff << MAD_DIMM_A_SIZE_SHIFT)
/* Clocking configuration register */ @@ -1126,194 +1126,194 @@ #define CLKCFG_MEM_MASK (7 << 4)
#define TSC1 0x11001 -#define TSE (1<<0) +#define TSE (1<<0) #define TR1 0x11006 #define TSFS 0x11020 -#define TSFS_SLOPE_MASK 0x0000ff00 -#define TSFS_SLOPE_SHIFT 8 -#define TSFS_INTR_MASK 0x000000ff +#define TSFS_SLOPE_MASK 0x0000ff00 +#define TSFS_SLOPE_SHIFT 8 +#define TSFS_INTR_MASK 0x000000ff
#define CRSTANDVID 0x11100 #define PXVFREQ_BASE 0x11110 /* P[0-15]VIDFREQ (0x1114c) (Ironlake) */ -#define PXVFREQ_PX_MASK 0x7f000000 -#define PXVFREQ_PX_SHIFT 24 +#define PXVFREQ_PX_MASK 0x7f000000 +#define PXVFREQ_PX_SHIFT 24 #define VIDFREQ_BASE 0x11110 #define VIDFREQ1 0x11110 /* VIDFREQ1-4 (0x1111c) (Cantiga) */ #define VIDFREQ2 0x11114 #define VIDFREQ3 0x11118 #define VIDFREQ4 0x1111c -#define VIDFREQ_P0_MASK 0x1f000000 -#define VIDFREQ_P0_SHIFT 24 -#define VIDFREQ_P0_CSCLK_MASK 0x00f00000 -#define VIDFREQ_P0_CSCLK_SHIFT 20 -#define VIDFREQ_P0_CRCLK_MASK 0x000f0000 -#define VIDFREQ_P0_CRCLK_SHIFT 16 -#define VIDFREQ_P1_MASK 0x00001f00 -#define VIDFREQ_P1_SHIFT 8 -#define VIDFREQ_P1_CSCLK_MASK 0x000000f0 -#define VIDFREQ_P1_CSCLK_SHIFT 4 -#define VIDFREQ_P1_CRCLK_MASK 0x0000000f +#define VIDFREQ_P0_MASK 0x1f000000 +#define VIDFREQ_P0_SHIFT 24 +#define VIDFREQ_P0_CSCLK_MASK 0x00f00000 +#define VIDFREQ_P0_CSCLK_SHIFT 20 +#define VIDFREQ_P0_CRCLK_MASK 0x000f0000 +#define VIDFREQ_P0_CRCLK_SHIFT 16 +#define VIDFREQ_P1_MASK 0x00001f00 +#define VIDFREQ_P1_SHIFT 8 +#define VIDFREQ_P1_CSCLK_MASK 0x000000f0 +#define VIDFREQ_P1_CSCLK_SHIFT 4 +#define VIDFREQ_P1_CRCLK_MASK 0x0000000f #define INTTOEXT_BASE_ILK 0x11300 #define INTTOEXT_BASE 0x11120 /* INTTOEXT1-8 (0x1113c) */ -#define INTTOEXT_MAP3_SHIFT 24 -#define INTTOEXT_MAP3_MASK (0x1f << INTTOEXT_MAP3_SHIFT) -#define INTTOEXT_MAP2_SHIFT 16 -#define INTTOEXT_MAP2_MASK (0x1f << INTTOEXT_MAP2_SHIFT) -#define INTTOEXT_MAP1_SHIFT 8 -#define INTTOEXT_MAP1_MASK (0x1f << INTTOEXT_MAP1_SHIFT) -#define INTTOEXT_MAP0_SHIFT 0 -#define INTTOEXT_MAP0_MASK (0x1f << INTTOEXT_MAP0_SHIFT) +#define INTTOEXT_MAP3_SHIFT 24 +#define INTTOEXT_MAP3_MASK (0x1f << INTTOEXT_MAP3_SHIFT) +#define INTTOEXT_MAP2_SHIFT 16 +#define INTTOEXT_MAP2_MASK (0x1f << INTTOEXT_MAP2_SHIFT) +#define INTTOEXT_MAP1_SHIFT 8 +#define INTTOEXT_MAP1_MASK (0x1f << INTTOEXT_MAP1_SHIFT) +#define INTTOEXT_MAP0_SHIFT 0 +#define INTTOEXT_MAP0_MASK (0x1f << INTTOEXT_MAP0_SHIFT) #define MEMSWCTL 0x11170 /* Ironlake only */ -#define MEMCTL_CMD_MASK 0xe000 -#define MEMCTL_CMD_SHIFT 13 -#define MEMCTL_CMD_RCLK_OFF 0 -#define MEMCTL_CMD_RCLK_ON 1 -#define MEMCTL_CMD_CHFREQ 2 -#define MEMCTL_CMD_CHVID 3 -#define MEMCTL_CMD_VMMOFF 4 -#define MEMCTL_CMD_VMMON 5 -#define MEMCTL_CMD_STS (1<<12) /* write 1 triggers command, clears +#define MEMCTL_CMD_MASK 0xe000 +#define MEMCTL_CMD_SHIFT 13 +#define MEMCTL_CMD_RCLK_OFF 0 +#define MEMCTL_CMD_RCLK_ON 1 +#define MEMCTL_CMD_CHFREQ 2 +#define MEMCTL_CMD_CHVID 3 +#define MEMCTL_CMD_VMMOFF 4 +#define MEMCTL_CMD_VMMON 5 +#define MEMCTL_CMD_STS (1<<12) /* write 1 triggers command, clears when command complete */ -#define MEMCTL_FREQ_MASK 0x0f00 /* jitter, from 0-15 */ -#define MEMCTL_FREQ_SHIFT 8 -#define MEMCTL_SFCAVM (1<<7) -#define MEMCTL_TGT_VID_MASK 0x007f +#define MEMCTL_FREQ_MASK 0x0f00 /* jitter, from 0-15 */ +#define MEMCTL_FREQ_SHIFT 8 +#define MEMCTL_SFCAVM (1<<7) +#define MEMCTL_TGT_VID_MASK 0x007f #define MEMIHYST 0x1117c #define MEMINTREN 0x11180 /* 16 bits */ -#define MEMINT_RSEXIT_EN (1<<8) -#define MEMINT_CX_SUPR_EN (1<<7) -#define MEMINT_CONT_BUSY_EN (1<<6) -#define MEMINT_AVG_BUSY_EN (1<<5) -#define MEMINT_EVAL_CHG_EN (1<<4) -#define MEMINT_MON_IDLE_EN (1<<3) -#define MEMINT_UP_EVAL_EN (1<<2) -#define MEMINT_DOWN_EVAL_EN (1<<1) -#define MEMINT_SW_CMD_EN (1<<0) +#define MEMINT_RSEXIT_EN (1<<8) +#define MEMINT_CX_SUPR_EN (1<<7) +#define MEMINT_CONT_BUSY_EN (1<<6) +#define MEMINT_AVG_BUSY_EN (1<<5) +#define MEMINT_EVAL_CHG_EN (1<<4) +#define MEMINT_MON_IDLE_EN (1<<3) +#define MEMINT_UP_EVAL_EN (1<<2) +#define MEMINT_DOWN_EVAL_EN (1<<1) +#define MEMINT_SW_CMD_EN (1<<0) #define MEMINTRSTR 0x11182 /* 16 bits */ -#define MEM_RSEXIT_MASK 0xc000 -#define MEM_RSEXIT_SHIFT 14 -#define MEM_CONT_BUSY_MASK 0x3000 -#define MEM_CONT_BUSY_SHIFT 12 -#define MEM_AVG_BUSY_MASK 0x0c00 -#define MEM_AVG_BUSY_SHIFT 10 -#define MEM_EVAL_CHG_MASK 0x0300 -#define MEM_EVAL_BUSY_SHIFT 8 -#define MEM_MON_IDLE_MASK 0x00c0 -#define MEM_MON_IDLE_SHIFT 6 -#define MEM_UP_EVAL_MASK 0x0030 -#define MEM_UP_EVAL_SHIFT 4 -#define MEM_DOWN_EVAL_MASK 0x000c -#define MEM_DOWN_EVAL_SHIFT 2 -#define MEM_SW_CMD_MASK 0x0003 -#define MEM_INT_STEER_GFX 0 -#define MEM_INT_STEER_CMR 1 -#define MEM_INT_STEER_SMI 2 -#define MEM_INT_STEER_SCI 3 +#define MEM_RSEXIT_MASK 0xc000 +#define MEM_RSEXIT_SHIFT 14 +#define MEM_CONT_BUSY_MASK 0x3000 +#define MEM_CONT_BUSY_SHIFT 12 +#define MEM_AVG_BUSY_MASK 0x0c00 +#define MEM_AVG_BUSY_SHIFT 10 +#define MEM_EVAL_CHG_MASK 0x0300 +#define MEM_EVAL_BUSY_SHIFT 8 +#define MEM_MON_IDLE_MASK 0x00c0 +#define MEM_MON_IDLE_SHIFT 6 +#define MEM_UP_EVAL_MASK 0x0030 +#define MEM_UP_EVAL_SHIFT 4 +#define MEM_DOWN_EVAL_MASK 0x000c +#define MEM_DOWN_EVAL_SHIFT 2 +#define MEM_SW_CMD_MASK 0x0003 +#define MEM_INT_STEER_GFX 0 +#define MEM_INT_STEER_CMR 1 +#define MEM_INT_STEER_SMI 2 +#define MEM_INT_STEER_SCI 3 #define MEMINTRSTS 0x11184 -#define MEMINT_RSEXIT (1<<7) -#define MEMINT_CONT_BUSY (1<<6) -#define MEMINT_AVG_BUSY (1<<5) -#define MEMINT_EVAL_CHG (1<<4) -#define MEMINT_MON_IDLE (1<<3) -#define MEMINT_UP_EVAL (1<<2) -#define MEMINT_DOWN_EVAL (1<<1) -#define MEMINT_SW_CMD (1<<0) +#define MEMINT_RSEXIT (1<<7) +#define MEMINT_CONT_BUSY (1<<6) +#define MEMINT_AVG_BUSY (1<<5) +#define MEMINT_EVAL_CHG (1<<4) +#define MEMINT_MON_IDLE (1<<3) +#define MEMINT_UP_EVAL (1<<2) +#define MEMINT_DOWN_EVAL (1<<1) +#define MEMINT_SW_CMD (1<<0) #define MEMMODECTL 0x11190 -#define MEMMODE_BOOST_EN (1<<31) -#define MEMMODE_BOOST_FREQ_MASK 0x0f000000 /* jitter for boost, 0-15 */ -#define MEMMODE_BOOST_FREQ_SHIFT 24 -#define MEMMODE_IDLE_MODE_MASK 0x00030000 -#define MEMMODE_IDLE_MODE_SHIFT 16 -#define MEMMODE_IDLE_MODE_EVAL 0 -#define MEMMODE_IDLE_MODE_CONT 1 -#define MEMMODE_HWIDLE_EN (1<<15) -#define MEMMODE_SWMODE_EN (1<<14) -#define MEMMODE_RCLK_GATE (1<<13) -#define MEMMODE_HW_UPDATE (1<<12) -#define MEMMODE_FSTART_MASK 0x00000f00 /* starting jitter, 0-15 */ -#define MEMMODE_FSTART_SHIFT 8 -#define MEMMODE_FMAX_MASK 0x000000f0 /* max jitter, 0-15 */ -#define MEMMODE_FMAX_SHIFT 4 -#define MEMMODE_FMIN_MASK 0x0000000f /* min jitter, 0-15 */ +#define MEMMODE_BOOST_EN (1<<31) +#define MEMMODE_BOOST_FREQ_MASK 0x0f000000 /* jitter for boost, 0-15 */ +#define MEMMODE_BOOST_FREQ_SHIFT 24 +#define MEMMODE_IDLE_MODE_MASK 0x00030000 +#define MEMMODE_IDLE_MODE_SHIFT 16 +#define MEMMODE_IDLE_MODE_EVAL 0 +#define MEMMODE_IDLE_MODE_CONT 1 +#define MEMMODE_HWIDLE_EN (1<<15) +#define MEMMODE_SWMODE_EN (1<<14) +#define MEMMODE_RCLK_GATE (1<<13) +#define MEMMODE_HW_UPDATE (1<<12) +#define MEMMODE_FSTART_MASK 0x00000f00 /* starting jitter, 0-15 */ +#define MEMMODE_FSTART_SHIFT 8 +#define MEMMODE_FMAX_MASK 0x000000f0 /* max jitter, 0-15 */ +#define MEMMODE_FMAX_SHIFT 4 +#define MEMMODE_FMIN_MASK 0x0000000f /* min jitter, 0-15 */ #define RCBMAXAVG 0x1119c #define MEMSWCTL2 0x1119e /* Cantiga only */ -#define SWMEMCMD_RENDER_OFF (0 << 13) -#define SWMEMCMD_RENDER_ON (1 << 13) -#define SWMEMCMD_SWFREQ (2 << 13) -#define SWMEMCMD_TARVID (3 << 13) -#define SWMEMCMD_VRM_OFF (4 << 13) -#define SWMEMCMD_VRM_ON (5 << 13) -#define CMDSTS (1<<12) -#define SFCAVM (1<<11) -#define SWFREQ_MASK 0x0380 /* P0-7 */ -#define SWFREQ_SHIFT 7 -#define TARVID_MASK 0x001f +#define SWMEMCMD_RENDER_OFF (0 << 13) +#define SWMEMCMD_RENDER_ON (1 << 13) +#define SWMEMCMD_SWFREQ (2 << 13) +#define SWMEMCMD_TARVID (3 << 13) +#define SWMEMCMD_VRM_OFF (4 << 13) +#define SWMEMCMD_VRM_ON (5 << 13) +#define CMDSTS (1<<12) +#define SFCAVM (1<<11) +#define SWFREQ_MASK 0x0380 /* P0-7 */ +#define SWFREQ_SHIFT 7 +#define TARVID_MASK 0x001f #define MEMSTAT_CTG 0x111a0 #define RCBMINAVG 0x111a0 #define RCUPEI 0x111b0 #define RCDNEI 0x111b4 #define RSTDBYCTL 0x111b8 -#define RS1EN (1<<31) -#define RS2EN (1<<30) -#define RS3EN (1<<29) -#define D3RS3EN (1<<28) /* Display D3 imlies RS3 */ -#define SWPROMORSX (1<<27) /* RSx promotion timers ignored */ -#define RCWAKERW (1<<26) /* Resetwarn from PCH causes wakeup */ -#define DPRSLPVREN (1<<25) /* Fast voltage ramp enable */ -#define GFXTGHYST (1<<24) /* Hysteresis to allow trunk gating */ -#define RCX_SW_EXIT (1<<23) /* Leave RSx and prevent re-entry */ -#define RSX_STATUS_MASK (7<<20) -#define RSX_STATUS_ON (0<<20) -#define RSX_STATUS_RC1 (1<<20) -#define RSX_STATUS_RC1E (2<<20) -#define RSX_STATUS_RS1 (3<<20) -#define RSX_STATUS_RS2 (4<<20) /* aka rc6 */ -#define RSX_STATUS_RSVD (5<<20) /* deep rc6 unsupported on ilk */ -#define RSX_STATUS_RS3 (6<<20) /* rs3 unsupported on ilk */ -#define RSX_STATUS_RSVD2 (7<<20) -#define UWRCRSXE (1<<19) /* wake counter limit prevents rsx */ -#define RSCRP (1<<18) /* rs requests control on rs1/2 reqs */ -#define JRSC (1<<17) /* rsx coupled to cpu c-state */ -#define RS2INC0 (1<<16) /* allow rs2 in cpu c0 */ -#define RS1CONTSAV_MASK (3<<14) -#define RS1CONTSAV_NO_RS1 (0<<14) /* rs1 doesn't save/restore context */ -#define RS1CONTSAV_RSVD (1<<14) -#define RS1CONTSAV_SAVE_RS1 (2<<14) /* rs1 saves context */ -#define RS1CONTSAV_FULL_RS1 (3<<14) /* rs1 saves and restores context */ -#define NORMSLEXLAT_MASK (3<<12) -#define SLOW_RS123 (0<<12) -#define SLOW_RS23 (1<<12) -#define SLOW_RS3 (2<<12) -#define NORMAL_RS123 (3<<12) -#define RCMODE_TIMEOUT (1<<11) /* 0 is eval interval method */ -#define IMPROMOEN (1<<10) /* promo is immediate or delayed until next idle interval (only for timeout method above) */ -#define RCENTSYNC (1<<9) /* rs coupled to cpu c-state (3/6/7) */ -#define STATELOCK (1<<7) /* locked to rs_cstate if 0 */ -#define RS_CSTATE_MASK (3<<4) -#define RS_CSTATE_C367_RS1 (0<<4) -#define RS_CSTATE_C36_RS1_C7_RS2 (1<<4) -#define RS_CSTATE_RSVD (2<<4) -#define RS_CSTATE_C367_RS2 (3<<4) -#define REDSAVES (1<<3) /* no context save if was idle during rs0 */ -#define REDRESTORES (1<<2) /* no restore if was idle during rs0 */ +#define RS1EN (1<<31) +#define RS2EN (1<<30) +#define RS3EN (1<<29) +#define D3RS3EN (1<<28) /* Display D3 imlies RS3 */ +#define SWPROMORSX (1<<27) /* RSx promotion timers ignored */ +#define RCWAKERW (1<<26) /* Resetwarn from PCH causes wakeup */ +#define DPRSLPVREN (1<<25) /* Fast voltage ramp enable */ +#define GFXTGHYST (1<<24) /* Hysteresis to allow trunk gating */ +#define RCX_SW_EXIT (1<<23) /* Leave RSx and prevent re-entry */ +#define RSX_STATUS_MASK (7<<20) +#define RSX_STATUS_ON (0<<20) +#define RSX_STATUS_RC1 (1<<20) +#define RSX_STATUS_RC1E (2<<20) +#define RSX_STATUS_RS1 (3<<20) +#define RSX_STATUS_RS2 (4<<20) /* aka rc6 */ +#define RSX_STATUS_RSVD (5<<20) /* deep rc6 unsupported on ilk */ +#define RSX_STATUS_RS3 (6<<20) /* rs3 unsupported on ilk */ +#define RSX_STATUS_RSVD2 (7<<20) +#define UWRCRSXE (1<<19) /* wake counter limit prevents rsx */ +#define RSCRP (1<<18) /* rs requests control on rs1/2 reqs */ +#define JRSC (1<<17) /* rsx coupled to cpu c-state */ +#define RS2INC0 (1<<16) /* allow rs2 in cpu c0 */ +#define RS1CONTSAV_MASK (3<<14) +#define RS1CONTSAV_NO_RS1 (0<<14) /* rs1 doesn't save/restore context */ +#define RS1CONTSAV_RSVD (1<<14) +#define RS1CONTSAV_SAVE_RS1 (2<<14) /* rs1 saves context */ +#define RS1CONTSAV_FULL_RS1 (3<<14) /* rs1 saves and restores context */ +#define NORMSLEXLAT_MASK (3<<12) +#define SLOW_RS123 (0<<12) +#define SLOW_RS23 (1<<12) +#define SLOW_RS3 (2<<12) +#define NORMAL_RS123 (3<<12) +#define RCMODE_TIMEOUT (1<<11) /* 0 is eval interval method */ +#define IMPROMOEN (1<<10) /* promo is immediate or delayed until next idle interval (only for timeout method above) */ +#define RCENTSYNC (1<<9) /* rs coupled to cpu c-state (3/6/7) */ +#define STATELOCK (1<<7) /* locked to rs_cstate if 0 */ +#define RS_CSTATE_MASK (3<<4) +#define RS_CSTATE_C367_RS1 (0<<4) +#define RS_CSTATE_C36_RS1_C7_RS2 (1<<4) +#define RS_CSTATE_RSVD (2<<4) +#define RS_CSTATE_C367_RS2 (3<<4) +#define REDSAVES (1<<3) /* no context save if was idle during rs0 */ +#define REDRESTORES (1<<2) /* no restore if was idle during rs0 */ #define VIDCTL 0x111c0 #define VIDSTS 0x111c8 #define VIDSTART 0x111cc /* 8 bits */ #define MEMSTAT_ILK 0x111f8 -#define MEMSTAT_VID_MASK 0x7f00 -#define MEMSTAT_VID_SHIFT 8 -#define MEMSTAT_PSTATE_MASK 0x00f8 -#define MEMSTAT_PSTATE_SHIFT 3 -#define MEMSTAT_MON_ACTV (1<<2) -#define MEMSTAT_SRC_CTL_MASK 0x0003 -#define MEMSTAT_SRC_CTL_CORE 0 -#define MEMSTAT_SRC_CTL_TRB 1 -#define MEMSTAT_SRC_CTL_THM 2 -#define MEMSTAT_SRC_CTL_STDBY 3 +#define MEMSTAT_VID_MASK 0x7f00 +#define MEMSTAT_VID_SHIFT 8 +#define MEMSTAT_PSTATE_MASK 0x00f8 +#define MEMSTAT_PSTATE_SHIFT 3 +#define MEMSTAT_MON_ACTV (1<<2) +#define MEMSTAT_SRC_CTL_MASK 0x0003 +#define MEMSTAT_SRC_CTL_CORE 0 +#define MEMSTAT_SRC_CTL_TRB 1 +#define MEMSTAT_SRC_CTL_THM 2 +#define MEMSTAT_SRC_CTL_STDBY 3 #define RCPREVBSYTUPAVG 0x113b8 #define RCPREVBSYTDNAVG 0x113bc #define PMMISC 0x11214 -#define MCPPCE_EN (1<<0) /* enable PM_MSG from PCH->MPC */ +#define MCPPCE_EN (1<<0) /* enable PM_MSG from PCH->MPC */ #define SDEW 0x1124c #define CSIEW0 0x11250 #define CSIEW1 0x11254 @@ -1330,9 +1330,9 @@ #define RPPREVBSYTUPAVG 0x113b8 #define RPPREVBSYTDNAVG 0x113bc #define ECR 0x11600 -#define ECR_GPFE (1<<31) -#define ECR_IMONE (1<<30) -#define ECR_CAP_MASK 0x0000001f /* Event range, 0-31 */ +#define ECR_GPFE (1<<31) +#define ECR_IMONE (1<<30) +#define ECR_CAP_MASK 0x0000001f /* Event range, 0-31 */ #define OGW0 0x11608 #define OGW1 0x1160c #define EG0 0x11610 @@ -1346,7 +1346,7 @@ #define PXW 0x11664 #define PXWL 0x11680 #define LCFUSE02 0x116c0 -#define LCFUSE_HIV_MASK 0x000000ff +#define LCFUSE_HIV_MASK 0x000000ff #define CSIPLL0 0x12c10 #define DDRMPLL1 0X12c20 #define PEG_BAND_GAP_DATA 0x14d68 @@ -1362,7 +1362,7 @@ * Logical Context regs */ #define CCID 0x2180 -#define CCID_EN (1<<0) +#define CCID_EN (1<<0) /* * Overlay regs */ @@ -1415,42 +1415,42 @@
/* VGA port control */ #define ADPA 0x61100 -#define ADPA_DAC_ENABLE (1<<31) -#define ADPA_DAC_DISABLE 0 -#define ADPA_PIPE_SELECT_MASK (1<<30) -#define ADPA_PIPE_A_SELECT 0 -#define ADPA_PIPE_B_SELECT (1<<30) -#define ADPA_PIPE_SELECT(pipe) ((pipe) << 30) -#define ADPA_USE_VGA_HVPOLARITY (1<<15) -#define ADPA_SETS_HVPOLARITY 0 -#define ADPA_VSYNC_CNTL_DISABLE (1<<11) -#define ADPA_VSYNC_CNTL_ENABLE 0 -#define ADPA_HSYNC_CNTL_DISABLE (1<<10) -#define ADPA_HSYNC_CNTL_ENABLE 0 -#define ADPA_VSYNC_ACTIVE_HIGH (1<<4) -#define ADPA_VSYNC_ACTIVE_LOW 0 -#define ADPA_HSYNC_ACTIVE_HIGH (1<<3) -#define ADPA_HSYNC_ACTIVE_LOW 0 -#define ADPA_DPMS_MASK (~(3<<10)) -#define ADPA_DPMS_ON (0<<10) -#define ADPA_DPMS_SUSPEND (1<<10) -#define ADPA_DPMS_STANDBY (2<<10) -#define ADPA_DPMS_OFF (3<<10) +#define ADPA_DAC_ENABLE (1<<31) +#define ADPA_DAC_DISABLE 0 +#define ADPA_PIPE_SELECT_MASK (1<<30) +#define ADPA_PIPE_A_SELECT 0 +#define ADPA_PIPE_B_SELECT (1<<30) +#define ADPA_PIPE_SELECT(pipe) ((pipe) << 30) +#define ADPA_USE_VGA_HVPOLARITY (1<<15) +#define ADPA_SETS_HVPOLARITY 0 +#define ADPA_VSYNC_CNTL_DISABLE (1<<11) +#define ADPA_VSYNC_CNTL_ENABLE 0 +#define ADPA_HSYNC_CNTL_DISABLE (1<<10) +#define ADPA_HSYNC_CNTL_ENABLE 0 +#define ADPA_VSYNC_ACTIVE_HIGH (1<<4) +#define ADPA_VSYNC_ACTIVE_LOW 0 +#define ADPA_HSYNC_ACTIVE_HIGH (1<<3) +#define ADPA_HSYNC_ACTIVE_LOW 0 +#define ADPA_DPMS_MASK (~(3<<10)) +#define ADPA_DPMS_ON (0<<10) +#define ADPA_DPMS_SUSPEND (1<<10) +#define ADPA_DPMS_STANDBY (2<<10) +#define ADPA_DPMS_OFF (3<<10)
/* Hotplug control (945+ only) */ #define PORT_HOTPLUG_EN 0x61110 -#define HDMIB_HOTPLUG_INT_EN (1 << 29) -#define DPB_HOTPLUG_INT_EN (1 << 29) -#define HDMIC_HOTPLUG_INT_EN (1 << 28) -#define DPC_HOTPLUG_INT_EN (1 << 28) -#define HDMID_HOTPLUG_INT_EN (1 << 27) -#define DPD_HOTPLUG_INT_EN (1 << 27) -#define SDVOB_HOTPLUG_INT_EN (1 << 26) -#define SDVOC_HOTPLUG_INT_EN (1 << 25) -#define TV_HOTPLUG_INT_EN (1 << 18) -#define CRT_HOTPLUG_INT_EN (1 << 9) -#define CRT_HOTPLUG_FORCE_DETECT (1 << 3) +#define HDMIB_HOTPLUG_INT_EN (1 << 29) +#define DPB_HOTPLUG_INT_EN (1 << 29) +#define HDMIC_HOTPLUG_INT_EN (1 << 28) +#define DPC_HOTPLUG_INT_EN (1 << 28) +#define HDMID_HOTPLUG_INT_EN (1 << 27) +#define DPD_HOTPLUG_INT_EN (1 << 27) +#define SDVOB_HOTPLUG_INT_EN (1 << 26) +#define SDVOC_HOTPLUG_INT_EN (1 << 25) +#define TV_HOTPLUG_INT_EN (1 << 18) +#define CRT_HOTPLUG_INT_EN (1 << 9) +#define CRT_HOTPLUG_FORCE_DETECT (1 << 3) #define CRT_HOTPLUG_ACTIVATION_PERIOD_32 (0 << 8) /* must use period 64 on GM45 according to docs */ #define CRT_HOTPLUG_ACTIVATION_PERIOD_64 (1 << 8) @@ -1467,28 +1467,28 @@ #define CRT_HOTPLUG_DETECT_VOLTAGE_475MV (1 << 2)
#define PORT_HOTPLUG_STAT 0x61114 -#define HDMIB_HOTPLUG_INT_STATUS (1 << 29) -#define DPB_HOTPLUG_INT_STATUS (1 << 29) -#define HDMIC_HOTPLUG_INT_STATUS (1 << 28) -#define DPC_HOTPLUG_INT_STATUS (1 << 28) -#define HDMID_HOTPLUG_INT_STATUS (1 << 27) -#define DPD_HOTPLUG_INT_STATUS (1 << 27) -#define CRT_HOTPLUG_INT_STATUS (1 << 11) -#define TV_HOTPLUG_INT_STATUS (1 << 10) -#define CRT_HOTPLUG_MONITOR_MASK (3 << 8) -#define CRT_HOTPLUG_MONITOR_COLOR (3 << 8) -#define CRT_HOTPLUG_MONITOR_MONO (2 << 8) -#define CRT_HOTPLUG_MONITOR_NONE (0 << 8) -#define SDVOC_HOTPLUG_INT_STATUS (1 << 7) -#define SDVOB_HOTPLUG_INT_STATUS (1 << 6) +#define HDMIB_HOTPLUG_INT_STATUS (1 << 29) +#define DPB_HOTPLUG_INT_STATUS (1 << 29) +#define HDMIC_HOTPLUG_INT_STATUS (1 << 28) +#define DPC_HOTPLUG_INT_STATUS (1 << 28) +#define HDMID_HOTPLUG_INT_STATUS (1 << 27) +#define DPD_HOTPLUG_INT_STATUS (1 << 27) +#define CRT_HOTPLUG_INT_STATUS (1 << 11) +#define TV_HOTPLUG_INT_STATUS (1 << 10) +#define CRT_HOTPLUG_MONITOR_MASK (3 << 8) +#define CRT_HOTPLUG_MONITOR_COLOR (3 << 8) +#define CRT_HOTPLUG_MONITOR_MONO (2 << 8) +#define CRT_HOTPLUG_MONITOR_NONE (0 << 8) +#define SDVOC_HOTPLUG_INT_STATUS (1 << 7) +#define SDVOB_HOTPLUG_INT_STATUS (1 << 6)
/* SDVO port control */ #define SDVOB 0x61140 #define SDVOC 0x61160 -#define SDVO_ENABLE (1 << 31) -#define SDVO_PIPE_B_SELECT (1 << 30) -#define SDVO_STALL_SELECT (1 << 29) -#define SDVO_INTERRUPT_ENABLE (1 << 26) +#define SDVO_ENABLE (1 << 31) +#define SDVO_PIPE_B_SELECT (1 << 30) +#define SDVO_STALL_SELECT (1 << 29) +#define SDVO_INTERRUPT_ENABLE (1 << 26) /** * 915G/GM SDVO pixel multiplier. * @@ -1496,62 +1496,62 @@ * * \sa DPLL_MD_UDI_MULTIPLIER_MASK */ -#define SDVO_PORT_MULTIPLY_MASK (7 << 23) -#define SDVO_PORT_MULTIPLY_SHIFT 23 -#define SDVO_PHASE_SELECT_MASK (15 << 19) -#define SDVO_PHASE_SELECT_DEFAULT (6 << 19) -#define SDVO_CLOCK_OUTPUT_INVERT (1 << 18) -#define SDVOC_GANG_MODE (1 << 16) -#define SDVO_ENCODING_SDVO (0x0 << 10) -#define SDVO_ENCODING_HDMI (0x2 << 10) +#define SDVO_PORT_MULTIPLY_MASK (7 << 23) +#define SDVO_PORT_MULTIPLY_SHIFT 23 +#define SDVO_PHASE_SELECT_MASK (15 << 19) +#define SDVO_PHASE_SELECT_DEFAULT (6 << 19) +#define SDVO_CLOCK_OUTPUT_INVERT (1 << 18) +#define SDVOC_GANG_MODE (1 << 16) +#define SDVO_ENCODING_SDVO (0x0 << 10) +#define SDVO_ENCODING_HDMI (0x2 << 10) /** Requird for HDMI operation */ -#define SDVO_NULL_PACKETS_DURING_VSYNC (1 << 9) -#define SDVO_COLOR_RANGE_16_235 (1 << 8) -#define SDVO_BORDER_ENABLE (1 << 7) -#define SDVO_AUDIO_ENABLE (1 << 6) +#define SDVO_NULL_PACKETS_DURING_VSYNC (1 << 9) +#define SDVO_COLOR_RANGE_16_235 (1 << 8) +#define SDVO_BORDER_ENABLE (1 << 7) +#define SDVO_AUDIO_ENABLE (1 << 6) /** New with 965, default is to be set */ -#define SDVO_VSYNC_ACTIVE_HIGH (1 << 4) +#define SDVO_VSYNC_ACTIVE_HIGH (1 << 4) /** New with 965, default is to be set */ -#define SDVO_HSYNC_ACTIVE_HIGH (1 << 3) -#define SDVOB_PCIE_CONCURRENCY (1 << 3) -#define SDVO_DETECTED (1 << 2) +#define SDVO_HSYNC_ACTIVE_HIGH (1 << 3) +#define SDVOB_PCIE_CONCURRENCY (1 << 3) +#define SDVO_DETECTED (1 << 2) /* Bits to be preserved when writing */ -#define SDVOB_PRESERVE_MASK ((1 << 17) | (1 << 16) | (1 << 14) | (1 << 26)) -#define SDVOC_PRESERVE_MASK ((1 << 17) | (1 << 26)) +#define SDVOB_PRESERVE_MASK ((1 << 17) | (1 << 16) | (1 << 14) | (1 << 26)) +#define SDVOC_PRESERVE_MASK ((1 << 17) | (1 << 26))
/* DVO port control */ #define DVOA 0x61120 #define DVOB 0x61140 #define DVOC 0x61160 -#define DVO_ENABLE (1 << 31) -#define DVO_PIPE_B_SELECT (1 << 30) -#define DVO_PIPE_STALL_UNUSED (0 << 28) -#define DVO_PIPE_STALL (1 << 28) -#define DVO_PIPE_STALL_TV (2 << 28) -#define DVO_PIPE_STALL_MASK (3 << 28) -#define DVO_USE_VGA_SYNC (1 << 15) -#define DVO_DATA_ORDER_I740 (0 << 14) -#define DVO_DATA_ORDER_FP (1 << 14) -#define DVO_VSYNC_DISABLE (1 << 11) -#define DVO_HSYNC_DISABLE (1 << 10) -#define DVO_VSYNC_TRISTATE (1 << 9) -#define DVO_HSYNC_TRISTATE (1 << 8) -#define DVO_BORDER_ENABLE (1 << 7) -#define DVO_DATA_ORDER_GBRG (1 << 6) -#define DVO_DATA_ORDER_RGGB (0 << 6) -#define DVO_DATA_ORDER_GBRG_ERRATA (0 << 6) -#define DVO_DATA_ORDER_RGGB_ERRATA (1 << 6) -#define DVO_VSYNC_ACTIVE_HIGH (1 << 4) -#define DVO_HSYNC_ACTIVE_HIGH (1 << 3) -#define DVO_BLANK_ACTIVE_HIGH (1 << 2) -#define DVO_OUTPUT_CSTATE_PIXELS (1 << 1) /* SDG only */ -#define DVO_OUTPUT_SOURCE_SIZE_PIXELS (1 << 0) /* SDG only */ -#define DVO_PRESERVE_MASK (0x7<<24) +#define DVO_ENABLE (1 << 31) +#define DVO_PIPE_B_SELECT (1 << 30) +#define DVO_PIPE_STALL_UNUSED (0 << 28) +#define DVO_PIPE_STALL (1 << 28) +#define DVO_PIPE_STALL_TV (2 << 28) +#define DVO_PIPE_STALL_MASK (3 << 28) +#define DVO_USE_VGA_SYNC (1 << 15) +#define DVO_DATA_ORDER_I740 (0 << 14) +#define DVO_DATA_ORDER_FP (1 << 14) +#define DVO_VSYNC_DISABLE (1 << 11) +#define DVO_HSYNC_DISABLE (1 << 10) +#define DVO_VSYNC_TRISTATE (1 << 9) +#define DVO_HSYNC_TRISTATE (1 << 8) +#define DVO_BORDER_ENABLE (1 << 7) +#define DVO_DATA_ORDER_GBRG (1 << 6) +#define DVO_DATA_ORDER_RGGB (0 << 6) +#define DVO_DATA_ORDER_GBRG_ERRATA (0 << 6) +#define DVO_DATA_ORDER_RGGB_ERRATA (1 << 6) +#define DVO_VSYNC_ACTIVE_HIGH (1 << 4) +#define DVO_HSYNC_ACTIVE_HIGH (1 << 3) +#define DVO_BLANK_ACTIVE_HIGH (1 << 2) +#define DVO_OUTPUT_CSTATE_PIXELS (1 << 1) /* SDG only */ +#define DVO_OUTPUT_SOURCE_SIZE_PIXELS (1 << 0) /* SDG only */ +#define DVO_PRESERVE_MASK (0x7<<24) #define DVOA_SRCDIM 0x61124 #define DVOB_SRCDIM 0x61144 #define DVOC_SRCDIM 0x61164 -#define DVO_SRCDIM_HORIZONTAL_SHIFT 12 -#define DVO_SRCDIM_VERTICAL_SHIFT 0 +#define DVO_SRCDIM_HORIZONTAL_SHIFT 12 +#define DVO_SRCDIM_VERTICAL_SHIFT 0
/* LVDS port control */ #define LVDS 0x61180 @@ -1559,70 +1559,70 @@ * Enables the LVDS port. This bit must be set before DPLLs are enabled, as * the DPLL semantics change when the LVDS is assigned to that pipe. */ -#define LVDS_PORT_EN (1 << 31) +#define LVDS_PORT_EN (1 << 31) /* Selects pipe B for LVDS data. Must be set on pre-965. */ -#define LVDS_PIPEB_SELECT (1 << 30) -#define LVDS_PIPE_MASK (1 << 30) -#define LVDS_PIPE(pipe) ((pipe) << 30) +#define LVDS_PIPEB_SELECT (1 << 30) +#define LVDS_PIPE_MASK (1 << 30) +#define LVDS_PIPE(pipe) ((pipe) << 30) /* LVDS dithering flag on 965/g4x platform */ -#define LVDS_ENABLE_DITHER (1 << 25) +#define LVDS_ENABLE_DITHER (1 << 25) /* LVDS sync polarity flags. Set to invert (i.e. negative) */ -#define LVDS_VSYNC_POLARITY (1 << 21) -#define LVDS_HSYNC_POLARITY (1 << 20) +#define LVDS_VSYNC_POLARITY (1 << 21) +#define LVDS_HSYNC_POLARITY (1 << 20)
/* Enable border for unscaled (or aspect-scaled) display */ -#define LVDS_BORDER_ENABLE (1 << 15) +#define LVDS_BORDER_ENABLE (1 << 15) /* * Enables the A0-A2 data pairs and CLKA, containing 18 bits of color data per * pixel. */ -#define LVDS_A0A2_CLKA_POWER_MASK (3 << 8) -#define LVDS_A0A2_CLKA_POWER_DOWN (0 << 8) -#define LVDS_A0A2_CLKA_POWER_UP (3 << 8) +#define LVDS_A0A2_CLKA_POWER_MASK (3 << 8) +#define LVDS_A0A2_CLKA_POWER_DOWN (0 << 8) +#define LVDS_A0A2_CLKA_POWER_UP (3 << 8) /* * Controls the A3 data pair, which contains the additional LSBs for 24 bit * mode. Only enabled if LVDS_A0A2_CLKA_POWER_UP also indicates it should be * on. */ -#define LVDS_A3_POWER_MASK (3 << 6) -#define LVDS_A3_POWER_DOWN (0 << 6) -#define LVDS_A3_POWER_UP (3 << 6) +#define LVDS_A3_POWER_MASK (3 << 6) +#define LVDS_A3_POWER_DOWN (0 << 6) +#define LVDS_A3_POWER_UP (3 << 6) /* * Controls the CLKB pair. This should only be set when LVDS_B0B3_POWER_UP * is set. */ -#define LVDS_CLKB_POWER_MASK (3 << 4) -#define LVDS_CLKB_POWER_DOWN (0 << 4) -#define LVDS_CLKB_POWER_UP (3 << 4) +#define LVDS_CLKB_POWER_MASK (3 << 4) +#define LVDS_CLKB_POWER_DOWN (0 << 4) +#define LVDS_CLKB_POWER_UP (3 << 4) /* * Controls the B0-B3 data pairs. This must be set to match the DPLL p2 * setting for whether we are in dual-channel mode. The B3 pair will * additionally only be powered up when LVDS_A3_POWER_UP is set. */ -#define LVDS_B0B3_POWER_MASK (3 << 2) -#define LVDS_B0B3_POWER_DOWN (0 << 2) -#define LVDS_B0B3_POWER_UP (3 << 2) +#define LVDS_B0B3_POWER_MASK (3 << 2) +#define LVDS_B0B3_POWER_DOWN (0 << 2) +#define LVDS_B0B3_POWER_UP (3 << 2)
/* Video Data Island Packet control */ #define VIDEO_DIP_DATA 0x61178 #define VIDEO_DIP_CTL 0x61170 -#define VIDEO_DIP_ENABLE (1 << 31) -#define VIDEO_DIP_PORT_B (1 << 29) -#define VIDEO_DIP_PORT_C (2 << 29) -#define VIDEO_DIP_ENABLE_AVI (1 << 21) -#define VIDEO_DIP_ENABLE_VENDOR (2 << 21) -#define VIDEO_DIP_ENABLE_SPD (8 << 21) -#define VIDEO_DIP_SELECT_AVI (0 << 19) -#define VIDEO_DIP_SELECT_VENDOR (1 << 19) -#define VIDEO_DIP_SELECT_SPD (3 << 19) -#define VIDEO_DIP_SELECT_MASK (3 << 19) -#define VIDEO_DIP_FREQ_ONCE (0 << 16) -#define VIDEO_DIP_FREQ_VSYNC (1 << 16) -#define VIDEO_DIP_FREQ_2VSYNC (2 << 16) +#define VIDEO_DIP_ENABLE (1 << 31) +#define VIDEO_DIP_PORT_B (1 << 29) +#define VIDEO_DIP_PORT_C (2 << 29) +#define VIDEO_DIP_ENABLE_AVI (1 << 21) +#define VIDEO_DIP_ENABLE_VENDOR (2 << 21) +#define VIDEO_DIP_ENABLE_SPD (8 << 21) +#define VIDEO_DIP_SELECT_AVI (0 << 19) +#define VIDEO_DIP_SELECT_VENDOR (1 << 19) +#define VIDEO_DIP_SELECT_SPD (3 << 19) +#define VIDEO_DIP_SELECT_MASK (3 << 19) +#define VIDEO_DIP_FREQ_ONCE (0 << 16) +#define VIDEO_DIP_FREQ_VSYNC (1 << 16) +#define VIDEO_DIP_FREQ_2VSYNC (2 << 16)
/* Panel power sequencing */ #define PP_STATUS 0x61200 -#define PP_ON (1 << 31) +#define PP_ON (1 << 31) /* * Indicates that all dependencies of the panel are on: * @@ -1630,51 +1630,51 @@ * - pipe enabled * - LVDS/DVOB/DVOC on */ -#define PP_READY (1 << 30) -#define PP_SEQUENCE_NONE (0 << 28) -#define PP_SEQUENCE_POWER_UP (1 << 28) -#define PP_SEQUENCE_POWER_DOWN (2 << 28) -#define PP_SEQUENCE_MASK (3 << 28) -#define PP_SEQUENCE_SHIFT 28 -#define PP_CYCLE_DELAY_ACTIVE (1 << 27) -#define PP_SEQUENCE_STATE_MASK 0x0000000f -#define PP_SEQUENCE_STATE_OFF_IDLE (0x0 << 0) -#define PP_SEQUENCE_STATE_OFF_S0_1 (0x1 << 0) -#define PP_SEQUENCE_STATE_OFF_S0_2 (0x2 << 0) -#define PP_SEQUENCE_STATE_OFF_S0_3 (0x3 << 0) -#define PP_SEQUENCE_STATE_ON_IDLE (0x8 << 0) -#define PP_SEQUENCE_STATE_ON_S1_0 (0x9 << 0) -#define PP_SEQUENCE_STATE_ON_S1_2 (0xa << 0) -#define PP_SEQUENCE_STATE_ON_S1_3 (0xb << 0) -#define PP_SEQUENCE_STATE_RESET (0xf << 0) +#define PP_READY (1 << 30) +#define PP_SEQUENCE_NONE (0 << 28) +#define PP_SEQUENCE_POWER_UP (1 << 28) +#define PP_SEQUENCE_POWER_DOWN (2 << 28) +#define PP_SEQUENCE_MASK (3 << 28) +#define PP_SEQUENCE_SHIFT 28 +#define PP_CYCLE_DELAY_ACTIVE (1 << 27) +#define PP_SEQUENCE_STATE_MASK 0x0000000f +#define PP_SEQUENCE_STATE_OFF_IDLE (0x0 << 0) +#define PP_SEQUENCE_STATE_OFF_S0_1 (0x1 << 0) +#define PP_SEQUENCE_STATE_OFF_S0_2 (0x2 << 0) +#define PP_SEQUENCE_STATE_OFF_S0_3 (0x3 << 0) +#define PP_SEQUENCE_STATE_ON_IDLE (0x8 << 0) +#define PP_SEQUENCE_STATE_ON_S1_0 (0x9 << 0) +#define PP_SEQUENCE_STATE_ON_S1_2 (0xa << 0) +#define PP_SEQUENCE_STATE_ON_S1_3 (0xb << 0) +#define PP_SEQUENCE_STATE_RESET (0xf << 0) #define PP_CONTROL 0x61204 -#define POWER_TARGET_ON (1 << 0) +#define POWER_TARGET_ON (1 << 0) #define PP_ON_DELAYS 0x61208 #define PP_OFF_DELAYS 0x6120c #define PP_DIVISOR 0x61210
/* Panel fitting */ #define PFIT_CONTROL 0x61230 -#define PFIT_ENABLE (1 << 31) -#define PFIT_PIPE_MASK (3 << 29) -#define PFIT_PIPE_SHIFT 29 -#define VERT_INTERP_DISABLE (0 << 10) -#define VERT_INTERP_BILINEAR (1 << 10) -#define VERT_INTERP_MASK (3 << 10) -#define VERT_AUTO_SCALE (1 << 9) -#define HORIZ_INTERP_DISABLE (0 << 6) -#define HORIZ_INTERP_BILINEAR (1 << 6) -#define HORIZ_INTERP_MASK (3 << 6) -#define HORIZ_AUTO_SCALE (1 << 5) -#define PANEL_8TO6_DITHER_ENABLE (1 << 3) -#define PFIT_FILTER_FUZZY (0 << 24) -#define PFIT_SCALING_AUTO (0 << 26) -#define PFIT_SCALING_PROGRAMMED (1 << 26) -#define PFIT_SCALING_PILLAR (2 << 26) -#define PFIT_SCALING_LETTER (3 << 26) +#define PFIT_ENABLE (1 << 31) +#define PFIT_PIPE_MASK (3 << 29) +#define PFIT_PIPE_SHIFT 29 +#define VERT_INTERP_DISABLE (0 << 10) +#define VERT_INTERP_BILINEAR (1 << 10) +#define VERT_INTERP_MASK (3 << 10) +#define VERT_AUTO_SCALE (1 << 9) +#define HORIZ_INTERP_DISABLE (0 << 6) +#define HORIZ_INTERP_BILINEAR (1 << 6) +#define HORIZ_INTERP_MASK (3 << 6) +#define HORIZ_AUTO_SCALE (1 << 5) +#define PANEL_8TO6_DITHER_ENABLE (1 << 3) +#define PFIT_FILTER_FUZZY (0 << 24) +#define PFIT_SCALING_AUTO (0 << 26) +#define PFIT_SCALING_PROGRAMMED (1 << 26) +#define PFIT_SCALING_PILLAR (2 << 26) +#define PFIT_SCALING_LETTER (3 << 26) #define PFIT_PGM_RATIOS 0x61234 -#define PFIT_VERT_SCALE_MASK 0xfff00000 -#define PFIT_HORIZ_SCALE_MASK 0x0000fff0 +#define PFIT_VERT_SCALE_MASK 0xfff00000 +#define PFIT_HORIZ_SCALE_MASK 0x0000fff0 /* Pre-965 */ #define PFIT_VERT_SCALE_SHIFT 20 #define PFIT_VERT_SCALE_MASK 0xfff00000 @@ -1690,17 +1690,17 @@
/* Backlight control */ #define BLC_PWM_CTL 0x61254 -#define BACKLIGHT_MODULATION_FREQ_SHIFT (17) +#define BACKLIGHT_MODULATION_FREQ_SHIFT (17) #define BLC_PWM_CTL2 0x61250 /* 965+ only */ -#define BLM_COMBINATION_MODE (1 << 30) +#define BLM_COMBINATION_MODE (1 << 30) /* * This is the most significant 15 bits of the number of backlight cycles in a * complete cycle of the modulated backlight control. * * The actual value is this field multiplied by two. */ -#define BACKLIGHT_MODULATION_FREQ_MASK (0x7fff << 17) -#define BLM_LEGACY_MODE (1 << 16) +#define BACKLIGHT_MODULATION_FREQ_MASK (0x7fff << 17) +#define BLM_LEGACY_MODE (1 << 16) /* * This is the number of cycles out of the backlight modulation cycle for which * the backlight is on. @@ -1708,8 +1708,8 @@ * This field must be no greater than the number of cycles in the complete * backlight modulation cycle. */ -#define BACKLIGHT_DUTY_CYCLE_SHIFT (0) -#define BACKLIGHT_DUTY_CYCLE_MASK (0xffff) +#define BACKLIGHT_DUTY_CYCLE_SHIFT (0) +#define BACKLIGHT_DUTY_CYCLE_MASK (0xffff)
#define BLC_HIST_CTL 0x61260
@@ -2199,82 +2199,82 @@ #define DP_C 0x64200 #define DP_D 0x64300
-#define DP_PORT_EN (1 << 31) -#define DP_PIPEB_SELECT (1 << 30) -#define DP_PIPE_MASK (1 << 30) +#define DP_PORT_EN (1 << 31) +#define DP_PIPEB_SELECT (1 << 30) +#define DP_PIPE_MASK (1 << 30)
/* Link training mode - select a suitable mode for each stage */ -#define DP_LINK_TRAIN_PAT_1 (0 << 28) -#define DP_LINK_TRAIN_PAT_2 (1 << 28) -#define DP_LINK_TRAIN_PAT_IDLE (2 << 28) -#define DP_LINK_TRAIN_OFF (3 << 28) -#define DP_LINK_TRAIN_MASK (3 << 28) -#define DP_LINK_TRAIN_SHIFT 28 +#define DP_LINK_TRAIN_PAT_1 (0 << 28) +#define DP_LINK_TRAIN_PAT_2 (1 << 28) +#define DP_LINK_TRAIN_PAT_IDLE (2 << 28) +#define DP_LINK_TRAIN_OFF (3 << 28) +#define DP_LINK_TRAIN_MASK (3 << 28) +#define DP_LINK_TRAIN_SHIFT 28
/* CPT Link training mode */ -#define DP_LINK_TRAIN_PAT_1_CPT (0 << 8) -#define DP_LINK_TRAIN_PAT_2_CPT (1 << 8) -#define DP_LINK_TRAIN_PAT_IDLE_CPT (2 << 8) -#define DP_LINK_TRAIN_OFF_CPT (3 << 8) -#define DP_LINK_TRAIN_MASK_CPT (7 << 8) -#define DP_LINK_TRAIN_SHIFT_CPT 8 +#define DP_LINK_TRAIN_PAT_1_CPT (0 << 8) +#define DP_LINK_TRAIN_PAT_2_CPT (1 << 8) +#define DP_LINK_TRAIN_PAT_IDLE_CPT (2 << 8) +#define DP_LINK_TRAIN_OFF_CPT (3 << 8) +#define DP_LINK_TRAIN_MASK_CPT (7 << 8) +#define DP_LINK_TRAIN_SHIFT_CPT 8
/* Signal voltages. These are mostly controlled by the other end */ -#define DP_VOLTAGE_0_4 (0 << 25) -#define DP_VOLTAGE_0_6 (1 << 25) -#define DP_VOLTAGE_0_8 (2 << 25) -#define DP_VOLTAGE_1_2 (3 << 25) -#define DP_VOLTAGE_MASK (7 << 25) -#define DP_VOLTAGE_SHIFT 25 +#define DP_VOLTAGE_0_4 (0 << 25) +#define DP_VOLTAGE_0_6 (1 << 25) +#define DP_VOLTAGE_0_8 (2 << 25) +#define DP_VOLTAGE_1_2 (3 << 25) +#define DP_VOLTAGE_MASK (7 << 25) +#define DP_VOLTAGE_SHIFT 25
/* Signal pre-emphasis levels, like voltages, the other end tells us what * they want */ -#define DP_PRE_EMPHASIS_0 (0 << 22) -#define DP_PRE_EMPHASIS_3_5 (1 << 22) -#define DP_PRE_EMPHASIS_6 (2 << 22) -#define DP_PRE_EMPHASIS_9_5 (3 << 22) -#define DP_PRE_EMPHASIS_MASK (7 << 22) -#define DP_PRE_EMPHASIS_SHIFT 22 +#define DP_PRE_EMPHASIS_0 (0 << 22) +#define DP_PRE_EMPHASIS_3_5 (1 << 22) +#define DP_PRE_EMPHASIS_6 (2 << 22) +#define DP_PRE_EMPHASIS_9_5 (3 << 22) +#define DP_PRE_EMPHASIS_MASK (7 << 22) +#define DP_PRE_EMPHASIS_SHIFT 22
/* How many wires to use. I guess 3 was too hard */ -#define DP_PORT_WIDTH_1 (0 << 19) -#define DP_PORT_WIDTH_2 (1 << 19) -#define DP_PORT_WIDTH_4 (3 << 19) -#define DP_PORT_WIDTH_MASK (7 << 19) +#define DP_PORT_WIDTH_1 (0 << 19) +#define DP_PORT_WIDTH_2 (1 << 19) +#define DP_PORT_WIDTH_4 (3 << 19) +#define DP_PORT_WIDTH_MASK (7 << 19)
/* Mystic DPCD version 1.1 special mode */ -#define DP_ENHANCED_FRAMING (1 << 18) +#define DP_ENHANCED_FRAMING (1 << 18)
/* eDP */ -#define DP_PLL_FREQ_270MHZ (0 << 16) -#define DP_PLL_FREQ_160MHZ (1 << 16) -#define DP_PLL_FREQ_MASK (3 << 16) +#define DP_PLL_FREQ_270MHZ (0 << 16) +#define DP_PLL_FREQ_160MHZ (1 << 16) +#define DP_PLL_FREQ_MASK (3 << 16)
/** locked once port is enabled */ -#define DP_PORT_REVERSAL (1 << 15) +#define DP_PORT_REVERSAL (1 << 15)
/* eDP */ -#define DP_PLL_ENABLE (1 << 14) +#define DP_PLL_ENABLE (1 << 14)
/** sends the clock on lane 15 of the PEG for debug */ -#define DP_CLOCK_OUTPUT_ENABLE (1 << 13) +#define DP_CLOCK_OUTPUT_ENABLE (1 << 13)
-#define DP_SCRAMBLING_DISABLE (1 << 12) -#define DP_SCRAMBLING_DISABLE_IRONLAKE (1 << 7) +#define DP_SCRAMBLING_DISABLE (1 << 12) +#define DP_SCRAMBLING_DISABLE_IRONLAKE (1 << 7)
/** limit RGB values to avoid confusing TVs */ -#define DP_COLOR_RANGE_16_235 (1 << 8) +#define DP_COLOR_RANGE_16_235 (1 << 8)
/** Turn on the audio link */ -#define DP_AUDIO_OUTPUT_ENABLE (1 << 6) +#define DP_AUDIO_OUTPUT_ENABLE (1 << 6)
/** vs and hs sync polarity */ -#define DP_SYNC_VS_HIGH (1 << 4) -#define DP_SYNC_HS_HIGH (1 << 3) +#define DP_SYNC_VS_HIGH (1 << 4) +#define DP_SYNC_HS_HIGH (1 << 3)
/** A fantasy */ -#define DP_DETECTED (1 << 2) +#define DP_DETECTED (1 << 2)
/** The aux channel provides a way to talk to the * signal sink for DDC etc. Max packet size supported @@ -2309,27 +2309,27 @@ #define DPD_AUX_CH_DATA4 0x64320 #define DPD_AUX_CH_DATA5 0x64324
-#define DP_AUX_CH_CTL_SEND_BUSY (1 << 31) -#define DP_AUX_CH_CTL_DONE (1 << 30) -#define DP_AUX_CH_CTL_INTERRUPT (1 << 29) -#define DP_AUX_CH_CTL_TIME_OUT_ERROR (1 << 28) -#define DP_AUX_CH_CTL_TIME_OUT_400us (0 << 26) -#define DP_AUX_CH_CTL_TIME_OUT_600us (1 << 26) -#define DP_AUX_CH_CTL_TIME_OUT_800us (2 << 26) -#define DP_AUX_CH_CTL_TIME_OUT_1600us (3 << 26) -#define DP_AUX_CH_CTL_TIME_OUT_MASK (3 << 26) -#define DP_AUX_CH_CTL_RECEIVE_ERROR (1 << 25) -#define DP_AUX_CH_CTL_MESSAGE_SIZE_MASK (0x1f << 20) -#define DP_AUX_CH_CTL_MESSAGE_SIZE_SHIFT 20 -#define DP_AUX_CH_CTL_PRECHARGE_2US_MASK (0xf << 16) -#define DP_AUX_CH_CTL_PRECHARGE_2US_SHIFT 16 -#define DP_AUX_CH_CTL_AUX_AKSV_SELECT (1 << 15) -#define DP_AUX_CH_CTL_MANCHESTER_TEST (1 << 14) -#define DP_AUX_CH_CTL_SYNC_TEST (1 << 13) -#define DP_AUX_CH_CTL_DEGLITCH_TEST (1 << 12) -#define DP_AUX_CH_CTL_PRECHARGE_TEST (1 << 11) -#define DP_AUX_CH_CTL_BIT_CLOCK_2X_MASK (0x7ff) -#define DP_AUX_CH_CTL_BIT_CLOCK_2X_SHIFT 0 +#define DP_AUX_CH_CTL_SEND_BUSY (1 << 31) +#define DP_AUX_CH_CTL_DONE (1 << 30) +#define DP_AUX_CH_CTL_INTERRUPT (1 << 29) +#define DP_AUX_CH_CTL_TIME_OUT_ERROR (1 << 28) +#define DP_AUX_CH_CTL_TIME_OUT_400us (0 << 26) +#define DP_AUX_CH_CTL_TIME_OUT_600us (1 << 26) +#define DP_AUX_CH_CTL_TIME_OUT_800us (2 << 26) +#define DP_AUX_CH_CTL_TIME_OUT_1600us (3 << 26) +#define DP_AUX_CH_CTL_TIME_OUT_MASK (3 << 26) +#define DP_AUX_CH_CTL_RECEIVE_ERROR (1 << 25) +#define DP_AUX_CH_CTL_MESSAGE_SIZE_MASK (0x1f << 20) +#define DP_AUX_CH_CTL_MESSAGE_SIZE_SHIFT 20 +#define DP_AUX_CH_CTL_PRECHARGE_2US_MASK (0xf << 16) +#define DP_AUX_CH_CTL_PRECHARGE_2US_SHIFT 16 +#define DP_AUX_CH_CTL_AUX_AKSV_SELECT (1 << 15) +#define DP_AUX_CH_CTL_MANCHESTER_TEST (1 << 14) +#define DP_AUX_CH_CTL_SYNC_TEST (1 << 13) +#define DP_AUX_CH_CTL_DEGLITCH_TEST (1 << 12) +#define DP_AUX_CH_CTL_PRECHARGE_TEST (1 << 11) +#define DP_AUX_CH_CTL_BIT_CLOCK_2X_MASK (0x7ff) +#define DP_AUX_CH_CTL_BIT_CLOCK_2X_SHIFT 0
/* * Computing GMCH M and N values for the Display Port link @@ -2348,14 +2348,14 @@ #define _PIPEB_GMCH_DATA_M 0x71050
/* Transfer unit size for display port - 1, default is 0x3f (for TU size 64) */ -#define PIPE_GMCH_DATA_M_TU_SIZE_MASK (0x3f << 25) -#define PIPE_GMCH_DATA_M_TU_SIZE_SHIFT 25 +#define PIPE_GMCH_DATA_M_TU_SIZE_MASK (0x3f << 25) +#define PIPE_GMCH_DATA_M_TU_SIZE_SHIFT 25
-#define PIPE_GMCH_DATA_M_MASK (0xffffff) +#define PIPE_GMCH_DATA_M_MASK (0xffffff)
#define _PIPEA_GMCH_DATA_N 0x70054 #define _PIPEB_GMCH_DATA_N 0x71054 -#define PIPE_GMCH_DATA_N_MASK (0xffffff) +#define PIPE_GMCH_DATA_N_MASK (0xffffff)
/* * Computing Link M and N values for the Display Port link @@ -2370,11 +2370,11 @@
#define _PIPEA_DP_LINK_M 0x70060 #define _PIPEB_DP_LINK_M 0x71060 -#define PIPEA_DP_LINK_M_MASK (0xffffff) +#define PIPEA_DP_LINK_M_MASK (0xffffff)
#define _PIPEA_DP_LINK_N 0x70064 #define _PIPEB_DP_LINK_N 0x71064 -#define PIPEA_DP_LINK_N_MASK (0xffffff) +#define PIPEA_DP_LINK_N_MASK (0xffffff)
#define PIPE_GMCH_DATA_M(pipe) _PIPE(pipe, _PIPEA_GMCH_DATA_M, _PIPEB_GMCH_DATA_M) #define PIPE_GMCH_DATA_N(pipe) _PIPE(pipe, _PIPEA_GMCH_DATA_N, _PIPEB_GMCH_DATA_N) @@ -2385,81 +2385,81 @@
/* Pipe A */ #define _PIPEADSL 0x70000 -#define DSL_LINEMASK 0x00000fff +#define DSL_LINEMASK 0x00000fff #define _PIPEACONF 0x70008 -#define PIPECONF_ENABLE (1<<31) -#define PIPECONF_DISABLE 0 -#define PIPECONF_DOUBLE_WIDE (1<<30) -#define I965_PIPECONF_ACTIVE (1<<30) -#define PIPECONF_FRAME_START_DELAY_MASK (3<<27) -#define PIPECONF_SINGLE_WIDE 0 -#define PIPECONF_PIPE_UNLOCKED 0 -#define PIPECONF_PIPE_LOCKED (1<<25) -#define PIPECONF_PALETTE 0 -#define PIPECONF_GAMMA (1<<24) -#define PIPECONF_FORCE_BORDER (1<<25) -#define PIPECONF_INTERLACE_MASK (7 << 21) +#define PIPECONF_ENABLE (1<<31) +#define PIPECONF_DISABLE 0 +#define PIPECONF_DOUBLE_WIDE (1<<30) +#define I965_PIPECONF_ACTIVE (1<<30) +#define PIPECONF_FRAME_START_DELAY_MASK (3<<27) +#define PIPECONF_SINGLE_WIDE 0 +#define PIPECONF_PIPE_UNLOCKED 0 +#define PIPECONF_PIPE_LOCKED (1<<25) +#define PIPECONF_PALETTE 0 +#define PIPECONF_GAMMA (1<<24) +#define PIPECONF_FORCE_BORDER (1<<25) +#define PIPECONF_INTERLACE_MASK (7 << 21) /* Note that pre-gen3 does not support interlaced display directly. Panel * fitting must be disabled on pre-ilk for interlaced. */ -#define PIPECONF_PROGRESSIVE (0 << 21) -#define PIPECONF_INTERLACE_W_SYNC_SHIFT_PANEL (4 << 21) /* gen4 only */ -#define PIPECONF_INTERLACE_W_SYNC_SHIFT (5 << 21) /* gen4 only */ -#define PIPECONF_INTERLACE_W_FIELD_INDICATION (6 << 21) -#define PIPECONF_INTERLACE_FIELD_0_ONLY (7 << 21) /* gen3 only */ +#define PIPECONF_PROGRESSIVE (0 << 21) +#define PIPECONF_INTERLACE_W_SYNC_SHIFT_PANEL (4 << 21) /* gen4 only */ +#define PIPECONF_INTERLACE_W_SYNC_SHIFT (5 << 21) /* gen4 only */ +#define PIPECONF_INTERLACE_W_FIELD_INDICATION (6 << 21) +#define PIPECONF_INTERLACE_FIELD_0_ONLY (7 << 21) /* gen3 only */ /* Ironlake and later have a complete new set of values for interlaced. PFIT * means panel fitter required, PF means progressive fetch, DBL means power * saving pixel doubling. */ -#define PIPECONF_PFIT_PF_INTERLACED_ILK (1 << 21) -#define PIPECONF_INTERLACED_ILK (3 << 21) -#define PIPECONF_INTERLACED_DBL_ILK (4 << 21) /* ilk/snb only */ -#define PIPECONF_PFIT_PF_INTERLACED_DBL_ILK (5 << 21) /* ilk/snb only */ -#define PIPECONF_CXSR_DOWNCLOCK (1<<16) -#define PIPECONF_BPP_MASK (0x000000e0) -#define PIPECONF_BPP_8 (0<<5) -#define PIPECONF_BPP_10 (1<<5) -#define PIPECONF_BPP_6 (2<<5) -#define PIPECONF_BPP_12 (3<<5) -#define PIPECONF_DITHER_EN (1<<4) -#define PIPECONF_DITHER_TYPE_MASK (0x0000000c) -#define PIPECONF_DITHER_TYPE_SP (0<<2) -#define PIPECONF_DITHER_TYPE_ST1 (1<<2) -#define PIPECONF_DITHER_TYPE_ST2 (2<<2) -#define PIPECONF_DITHER_TYPE_TEMP (3<<2) +#define PIPECONF_PFIT_PF_INTERLACED_ILK (1 << 21) +#define PIPECONF_INTERLACED_ILK (3 << 21) +#define PIPECONF_INTERLACED_DBL_ILK (4 << 21) /* ilk/snb only */ +#define PIPECONF_PFIT_PF_INTERLACED_DBL_ILK (5 << 21) /* ilk/snb only */ +#define PIPECONF_CXSR_DOWNCLOCK (1<<16) +#define PIPECONF_BPP_MASK (0x000000e0) +#define PIPECONF_BPP_8 (0<<5) +#define PIPECONF_BPP_10 (1<<5) +#define PIPECONF_BPP_6 (2<<5) +#define PIPECONF_BPP_12 (3<<5) +#define PIPECONF_DITHER_EN (1<<4) +#define PIPECONF_DITHER_TYPE_MASK (0x0000000c) +#define PIPECONF_DITHER_TYPE_SP (0<<2) +#define PIPECONF_DITHER_TYPE_ST1 (1<<2) +#define PIPECONF_DITHER_TYPE_ST2 (2<<2) +#define PIPECONF_DITHER_TYPE_TEMP (3<<2) #define _PIPEASTAT 0x70024 -#define PIPE_FIFO_UNDERRUN_STATUS (1UL<<31) -#define PIPE_CRC_ERROR_ENABLE (1UL<<29) -#define PIPE_CRC_DONE_ENABLE (1UL<<28) -#define PIPE_GMBUS_EVENT_ENABLE (1UL<<27) -#define PIPE_HOTPLUG_INTERRUPT_ENABLE (1UL<<26) -#define PIPE_VSYNC_INTERRUPT_ENABLE (1UL<<25) -#define PIPE_DISPLAY_LINE_COMPARE_ENABLE (1UL<<24) -#define PIPE_DPST_EVENT_ENABLE (1UL<<23) -#define PIPE_LEGACY_BLC_EVENT_ENABLE (1UL<<22) -#define PIPE_ODD_FIELD_INTERRUPT_ENABLE (1UL<<21) -#define PIPE_EVEN_FIELD_INTERRUPT_ENABLE (1UL<<20) -#define PIPE_HOTPLUG_TV_INTERRUPT_ENABLE (1UL<<18) /* pre-965 */ -#define PIPE_START_VBLANK_INTERRUPT_ENABLE (1UL<<18) /* 965 or later */ -#define PIPE_VBLANK_INTERRUPT_ENABLE (1UL<<17) -#define PIPE_OVERLAY_UPDATED_ENABLE (1UL<<16) -#define PIPE_CRC_ERROR_INTERRUPT_STATUS (1UL<<13) -#define PIPE_CRC_DONE_INTERRUPT_STATUS (1UL<<12) -#define PIPE_GMBUS_INTERRUPT_STATUS (1UL<<11) -#define PIPE_HOTPLUG_INTERRUPT_STATUS (1UL<<10) -#define PIPE_VSYNC_INTERRUPT_STATUS (1UL<<9) -#define PIPE_DISPLAY_LINE_COMPARE_STATUS (1UL<<8) -#define PIPE_DPST_EVENT_STATUS (1UL<<7) -#define PIPE_LEGACY_BLC_EVENT_STATUS (1UL<<6) -#define PIPE_ODD_FIELD_INTERRUPT_STATUS (1UL<<5) -#define PIPE_EVEN_FIELD_INTERRUPT_STATUS (1UL<<4) -#define PIPE_HOTPLUG_TV_INTERRUPT_STATUS (1UL<<2) /* pre-965 */ -#define PIPE_START_VBLANK_INTERRUPT_STATUS (1UL<<2) /* 965 or later */ -#define PIPE_VBLANK_INTERRUPT_STATUS (1UL<<1) -#define PIPE_OVERLAY_UPDATED_STATUS (1UL<<0) -#define PIPE_BPC_MASK (7 << 5) /* Ironlake */ -#define PIPE_8BPC (0 << 5) -#define PIPE_10BPC (1 << 5) -#define PIPE_6BPC (2 << 5) -#define PIPE_12BPC (3 << 5) +#define PIPE_FIFO_UNDERRUN_STATUS (1UL<<31) +#define PIPE_CRC_ERROR_ENABLE (1UL<<29) +#define PIPE_CRC_DONE_ENABLE (1UL<<28) +#define PIPE_GMBUS_EVENT_ENABLE (1UL<<27) +#define PIPE_HOTPLUG_INTERRUPT_ENABLE (1UL<<26) +#define PIPE_VSYNC_INTERRUPT_ENABLE (1UL<<25) +#define PIPE_DISPLAY_LINE_COMPARE_ENABLE (1UL<<24) +#define PIPE_DPST_EVENT_ENABLE (1UL<<23) +#define PIPE_LEGACY_BLC_EVENT_ENABLE (1UL<<22) +#define PIPE_ODD_FIELD_INTERRUPT_ENABLE (1UL<<21) +#define PIPE_EVEN_FIELD_INTERRUPT_ENABLE (1UL<<20) +#define PIPE_HOTPLUG_TV_INTERRUPT_ENABLE (1UL<<18) /* pre-965 */ +#define PIPE_START_VBLANK_INTERRUPT_ENABLE (1UL<<18) /* 965 or later */ +#define PIPE_VBLANK_INTERRUPT_ENABLE (1UL<<17) +#define PIPE_OVERLAY_UPDATED_ENABLE (1UL<<16) +#define PIPE_CRC_ERROR_INTERRUPT_STATUS (1UL<<13) +#define PIPE_CRC_DONE_INTERRUPT_STATUS (1UL<<12) +#define PIPE_GMBUS_INTERRUPT_STATUS (1UL<<11) +#define PIPE_HOTPLUG_INTERRUPT_STATUS (1UL<<10) +#define PIPE_VSYNC_INTERRUPT_STATUS (1UL<<9) +#define PIPE_DISPLAY_LINE_COMPARE_STATUS (1UL<<8) +#define PIPE_DPST_EVENT_STATUS (1UL<<7) +#define PIPE_LEGACY_BLC_EVENT_STATUS (1UL<<6) +#define PIPE_ODD_FIELD_INTERRUPT_STATUS (1UL<<5) +#define PIPE_EVEN_FIELD_INTERRUPT_STATUS (1UL<<4) +#define PIPE_HOTPLUG_TV_INTERRUPT_STATUS (1UL<<2) /* pre-965 */ +#define PIPE_START_VBLANK_INTERRUPT_STATUS (1UL<<2) /* 965 or later */ +#define PIPE_VBLANK_INTERRUPT_STATUS (1UL<<1) +#define PIPE_OVERLAY_UPDATED_STATUS (1UL<<0) +#define PIPE_BPC_MASK (7 << 5) /* Ironlake */ +#define PIPE_8BPC (0 << 5) +#define PIPE_10BPC (1 << 5) +#define PIPE_6BPC (2 << 5) +#define PIPE_12BPC (3 << 5)
#define PIPESRC(pipe) _PIPE(pipe, _PIPEASRC, _PIPEBSRC) #define PIPECONF(pipe) _PIPE(pipe, _PIPEACONF, _PIPEBCONF) @@ -2469,33 +2469,33 @@ #define PIPESTAT(pipe) _PIPE(pipe, _PIPEASTAT, _PIPEBSTAT)
#define DSPARB 0x70030 -#define DSPARB_CSTART_MASK (0x7f << 7) -#define DSPARB_CSTART_SHIFT 7 -#define DSPARB_BSTART_MASK (0x7f) -#define DSPARB_BSTART_SHIFT 0 -#define DSPARB_BEND_SHIFT 9 /* on 855 */ -#define DSPARB_AEND_SHIFT 0 +#define DSPARB_CSTART_MASK (0x7f << 7) +#define DSPARB_CSTART_SHIFT 7 +#define DSPARB_BSTART_MASK (0x7f) +#define DSPARB_BSTART_SHIFT 0 +#define DSPARB_BEND_SHIFT 9 /* on 855 */ +#define DSPARB_AEND_SHIFT 0
#define DSPFW1 0x70034 -#define DSPFW_SR_SHIFT 23 -#define DSPFW_SR_MASK (0x1ff<<23) -#define DSPFW_CURSORB_SHIFT 16 -#define DSPFW_CURSORB_MASK (0x3f<<16) -#define DSPFW_PLANEB_SHIFT 8 -#define DSPFW_PLANEB_MASK (0x7f<<8) -#define DSPFW_PLANEA_MASK (0x7f) +#define DSPFW_SR_SHIFT 23 +#define DSPFW_SR_MASK (0x1ff<<23) +#define DSPFW_CURSORB_SHIFT 16 +#define DSPFW_CURSORB_MASK (0x3f<<16) +#define DSPFW_PLANEB_SHIFT 8 +#define DSPFW_PLANEB_MASK (0x7f<<8) +#define DSPFW_PLANEA_MASK (0x7f) #define DSPFW2 0x70038 -#define DSPFW_CURSORA_MASK 0x00003f00 -#define DSPFW_CURSORA_SHIFT 8 -#define DSPFW_PLANEC_MASK (0x7f) +#define DSPFW_CURSORA_MASK 0x00003f00 +#define DSPFW_CURSORA_SHIFT 8 +#define DSPFW_PLANEC_MASK (0x7f) #define DSPFW3 0x7003c -#define DSPFW_HPLL_SR_EN (1<<31) -#define DSPFW_CURSOR_SR_SHIFT 24 -#define PINEVIEW_SELF_REFRESH_EN (1<<30) -#define DSPFW_CURSOR_SR_MASK (0x3f<<24) -#define DSPFW_HPLL_CURSOR_SHIFT 16 -#define DSPFW_HPLL_CURSOR_MASK (0x3f<<16) -#define DSPFW_HPLL_SR_MASK (0x1ff) +#define DSPFW_HPLL_SR_EN (1<<31) +#define DSPFW_CURSOR_SR_SHIFT 24 +#define PINEVIEW_SELF_REFRESH_EN (1<<30) +#define DSPFW_CURSOR_SR_MASK (0x3f<<24) +#define DSPFW_HPLL_CURSOR_SHIFT 16 +#define DSPFW_HPLL_CURSOR_MASK (0x3f<<16) +#define DSPFW_HPLL_SR_MASK (0x1ff)
/* FIFO watermark sizes etc */ #define G4X_FIFO_LINE_SIZE 64 @@ -2529,38 +2529,38 @@
/* define the Watermark register on Ironlake */ #define WM0_PIPEA_ILK 0x45100 -#define WM0_PIPE_PLANE_MASK (0x7f<<16) -#define WM0_PIPE_PLANE_SHIFT 16 -#define WM0_PIPE_SPRITE_MASK (0x3f<<8) -#define WM0_PIPE_SPRITE_SHIFT 8 -#define WM0_PIPE_CURSOR_MASK (0x1f) +#define WM0_PIPE_PLANE_MASK (0x7f<<16) +#define WM0_PIPE_PLANE_SHIFT 16 +#define WM0_PIPE_SPRITE_MASK (0x3f<<8) +#define WM0_PIPE_SPRITE_SHIFT 8 +#define WM0_PIPE_CURSOR_MASK (0x1f)
#define WM0_PIPEB_ILK 0x45104 #define WM0_PIPEC_IVB 0x45200 #define WM1_LP_ILK 0x45108 -#define WM1_LP_SR_EN (1<<31) -#define WM1_LP_LATENCY_SHIFT 24 -#define WM1_LP_LATENCY_MASK (0x7f<<24) -#define WM1_LP_FBC_MASK (0xf<<20) -#define WM1_LP_FBC_SHIFT 20 -#define WM1_LP_SR_MASK (0x1ff<<8) -#define WM1_LP_SR_SHIFT 8 -#define WM1_LP_CURSOR_MASK (0x3f) +#define WM1_LP_SR_EN (1<<31) +#define WM1_LP_LATENCY_SHIFT 24 +#define WM1_LP_LATENCY_MASK (0x7f<<24) +#define WM1_LP_FBC_MASK (0xf<<20) +#define WM1_LP_FBC_SHIFT 20 +#define WM1_LP_SR_MASK (0x1ff<<8) +#define WM1_LP_SR_SHIFT 8 +#define WM1_LP_CURSOR_MASK (0x3f) #define WM2_LP_ILK 0x4510c -#define WM2_LP_EN (1<<31) +#define WM2_LP_EN (1<<31) #define WM3_LP_ILK 0x45110 -#define WM3_LP_EN (1<<31) +#define WM3_LP_EN (1<<31) #define WM1S_LP_ILK 0x45120 #define WM2S_LP_IVB 0x45124 #define WM3S_LP_IVB 0x45128 -#define WM1S_LP_EN (1<<31) +#define WM1S_LP_EN (1<<31)
/* Memory latency timer register */ #define MLTR_ILK 0x11222 -#define MLTR_WM1_SHIFT 0 -#define MLTR_WM2_SHIFT 8 +#define MLTR_WM1_SHIFT 0 +#define MLTR_WM2_SHIFT 8 /* the unit of memory self-refresh latency time is 0.5us */ -#define ILK_SRLT_MASK 0x3f +#define ILK_SRLT_MASK 0x3f #define ILK_LATENCY(shift) (I915_READ(MLTR_ILK) >> (shift) & ILK_SRLT_MASK) #define ILK_READ_WM1_LATENCY() ILK_LATENCY(MLTR_WM1_SHIFT) #define ILK_READ_WM2_LATENCY() ILK_LATENCY(MLTR_WM2_SHIFT) @@ -2632,13 +2632,13 @@ * frame = (high1 << 8) | low1; */ #define _PIPEAFRAMEHIGH 0x70040 -#define PIPE_FRAME_HIGH_MASK 0x0000ffff -#define PIPE_FRAME_HIGH_SHIFT 0 +#define PIPE_FRAME_HIGH_MASK 0x0000ffff +#define PIPE_FRAME_HIGH_SHIFT 0 #define _PIPEAFRAMEPIXEL 0x70044 -#define PIPE_FRAME_LOW_MASK 0xff000000 -#define PIPE_FRAME_LOW_SHIFT 24 -#define PIPE_PIXEL_MASK 0x00ffffff -#define PIPE_PIXEL_SHIFT 0 +#define PIPE_FRAME_LOW_MASK 0xff000000 +#define PIPE_FRAME_LOW_SHIFT 24 +#define PIPE_PIXEL_MASK 0x00ffffff +#define PIPE_PIXEL_SHIFT 0 /* GM45+ just has to be different */ #define _PIPEA_FRMCOUNT_GM45 0x70040 #define _PIPEA_FLIPCOUNT_GM45 0x70044 @@ -2647,31 +2647,31 @@ /* Cursor A & B regs */ #define _CURACNTR 0x70080 /* Old style CUR*CNTR flags (desktop 8xx) */ -#define CURSOR_ENABLE 0x80000000 -#define CURSOR_GAMMA_ENABLE 0x40000000 -#define CURSOR_STRIDE_MASK 0x30000000 -#define CURSOR_FORMAT_SHIFT 24 -#define CURSOR_FORMAT_MASK (0x07 << CURSOR_FORMAT_SHIFT) -#define CURSOR_FORMAT_2C (0x00 << CURSOR_FORMAT_SHIFT) -#define CURSOR_FORMAT_3C (0x01 << CURSOR_FORMAT_SHIFT) -#define CURSOR_FORMAT_4C (0x02 << CURSOR_FORMAT_SHIFT) -#define CURSOR_FORMAT_ARGB (0x04 << CURSOR_FORMAT_SHIFT) -#define CURSOR_FORMAT_XRGB (0x05 << CURSOR_FORMAT_SHIFT) +#define CURSOR_ENABLE 0x80000000 +#define CURSOR_GAMMA_ENABLE 0x40000000 +#define CURSOR_STRIDE_MASK 0x30000000 +#define CURSOR_FORMAT_SHIFT 24 +#define CURSOR_FORMAT_MASK (0x07 << CURSOR_FORMAT_SHIFT) +#define CURSOR_FORMAT_2C (0x00 << CURSOR_FORMAT_SHIFT) +#define CURSOR_FORMAT_3C (0x01 << CURSOR_FORMAT_SHIFT) +#define CURSOR_FORMAT_4C (0x02 << CURSOR_FORMAT_SHIFT) +#define CURSOR_FORMAT_ARGB (0x04 << CURSOR_FORMAT_SHIFT) +#define CURSOR_FORMAT_XRGB (0x05 << CURSOR_FORMAT_SHIFT) /* New style CUR*CNTR flags */ -#define CURSOR_MODE 0x27 -#define CURSOR_MODE_DISABLE 0x00 -#define CURSOR_MODE_64_32B_AX 0x07 -#define CURSOR_MODE_64_ARGB_AX ((1 << 5) | CURSOR_MODE_64_32B_AX) -#define MCURSOR_PIPE_SELECT (1 << 28) -#define MCURSOR_PIPE_A 0x00 -#define MCURSOR_PIPE_B (1 << 28) -#define MCURSOR_GAMMA_ENABLE (1 << 26) +#define CURSOR_MODE 0x27 +#define CURSOR_MODE_DISABLE 0x00 +#define CURSOR_MODE_64_32B_AX 0x07 +#define CURSOR_MODE_64_ARGB_AX ((1 << 5) | CURSOR_MODE_64_32B_AX) +#define MCURSOR_PIPE_SELECT (1 << 28) +#define MCURSOR_PIPE_A 0x00 +#define MCURSOR_PIPE_B (1 << 28) +#define MCURSOR_GAMMA_ENABLE (1 << 26) #define _CURABASE 0x70084 #define _CURAPOS 0x70088 -#define CURSOR_POS_MASK 0x007FF -#define CURSOR_POS_SIGN 0x8000 -#define CURSOR_X_SHIFT 0 -#define CURSOR_Y_SHIFT 16 +#define CURSOR_POS_MASK 0x007FF +#define CURSOR_POS_SIGN 0x8000 +#define CURSOR_X_SHIFT 0 +#define CURSOR_Y_SHIFT 16 #define CURSIZE 0x700a0 #define _CURBCNTR 0x700c0 #define _CURBBASE 0x700c4 @@ -2691,31 +2691,31 @@
/* Display A control */ #define _DSPACNTR 0x70180 -#define DISPLAY_PLANE_ENABLE (1<<31) -#define DISPLAY_PLANE_DISABLE 0 -#define DISPPLANE_GAMMA_ENABLE (1<<30) -#define DISPPLANE_GAMMA_DISABLE 0 -#define DISPPLANE_PIXFORMAT_MASK (0xf<<26) -#define DISPPLANE_8BPP (0x2<<26) -#define DISPPLANE_15_16BPP (0x4<<26) -#define DISPPLANE_16BPP (0x5<<26) -#define DISPPLANE_32BPP_NO_ALPHA (0x6<<26) -#define DISPPLANE_32BPP (0x7<<26) -#define DISPPLANE_32BPP_30BIT_NO_ALPHA (0xa<<26) -#define DISPPLANE_STEREO_ENABLE (1<<25) -#define DISPPLANE_STEREO_DISABLE 0 -#define DISPPLANE_SEL_PIPE_SHIFT 24 -#define DISPPLANE_SEL_PIPE_MASK (3<<DISPPLANE_SEL_PIPE_SHIFT) -#define DISPPLANE_SEL_PIPE_A 0 -#define DISPPLANE_SEL_PIPE_B (1<<DISPPLANE_SEL_PIPE_SHIFT) -#define DISPPLANE_SRC_KEY_ENABLE (1<<22) -#define DISPPLANE_SRC_KEY_DISABLE 0 -#define DISPPLANE_LINE_DOUBLE (1<<20) -#define DISPPLANE_NO_LINE_DOUBLE 0 -#define DISPPLANE_STEREO_POLARITY_FIRST 0 -#define DISPPLANE_STEREO_POLARITY_SECOND (1<<18) -#define DISPPLANE_TRICKLE_FEED_DISABLE (1<<14) /* Ironlake */ -#define DISPPLANE_TILED (1<<10) +#define DISPLAY_PLANE_ENABLE (1<<31) +#define DISPLAY_PLANE_DISABLE 0 +#define DISPPLANE_GAMMA_ENABLE (1<<30) +#define DISPPLANE_GAMMA_DISABLE 0 +#define DISPPLANE_PIXFORMAT_MASK (0xf<<26) +#define DISPPLANE_8BPP (0x2<<26) +#define DISPPLANE_15_16BPP (0x4<<26) +#define DISPPLANE_16BPP (0x5<<26) +#define DISPPLANE_32BPP_NO_ALPHA (0x6<<26) +#define DISPPLANE_32BPP (0x7<<26) +#define DISPPLANE_32BPP_30BIT_NO_ALPHA (0xa<<26) +#define DISPPLANE_STEREO_ENABLE (1<<25) +#define DISPPLANE_STEREO_DISABLE 0 +#define DISPPLANE_SEL_PIPE_SHIFT 24 +#define DISPPLANE_SEL_PIPE_MASK (3<<DISPPLANE_SEL_PIPE_SHIFT) +#define DISPPLANE_SEL_PIPE_A 0 +#define DISPPLANE_SEL_PIPE_B (1<<DISPPLANE_SEL_PIPE_SHIFT) +#define DISPPLANE_SRC_KEY_ENABLE (1<<22) +#define DISPPLANE_SRC_KEY_DISABLE 0 +#define DISPPLANE_LINE_DOUBLE (1<<20) +#define DISPPLANE_NO_LINE_DOUBLE 0 +#define DISPPLANE_STEREO_POLARITY_FIRST 0 +#define DISPPLANE_STEREO_POLARITY_SECOND (1<<18) +#define DISPPLANE_TRICKLE_FEED_DISABLE (1<<14) /* Ironlake */ +#define DISPPLANE_TILED (1<<10) #define _DSPAADDR 0x70184 #define _DSPASTRIDE 0x70188 #define _DSPAPOS 0x7018C /* reserved */ @@ -2758,10 +2758,10 @@
/* Display B control */ #define _DSPBCNTR 0x71180 -#define DISPPLANE_ALPHA_TRANS_ENABLE (1<<15) -#define DISPPLANE_ALPHA_TRANS_DISABLE 0 -#define DISPPLANE_SPRITE_ABOVE_DISPLAY 0 -#define DISPPLANE_SPRITE_ABOVE_OVERLAY (1) +#define DISPPLANE_ALPHA_TRANS_ENABLE (1<<15) +#define DISPPLANE_ALPHA_TRANS_DISABLE 0 +#define DISPPLANE_SPRITE_ABOVE_DISPLAY 0 +#define DISPPLANE_SPRITE_ABOVE_OVERLAY (1) #define _DSPBADDR 0x71184 #define _DSPBSTRIDE 0x71188 #define _DSPBPOS 0x7118C @@ -2771,23 +2771,23 @@
/* Sprite A control */ #define _DVSACNTR 0x72180 -#define DVS_ENABLE (1<<31) -#define DVS_GAMMA_ENABLE (1<<30) -#define DVS_PIXFORMAT_MASK (3<<25) -#define DVS_FORMAT_YUV422 (0<<25) -#define DVS_FORMAT_RGBX101010 (1<<25) -#define DVS_FORMAT_RGBX888 (2<<25) -#define DVS_FORMAT_RGBX161616 (3<<25) -#define DVS_SOURCE_KEY (1<<22) -#define DVS_RGB_ORDER_XBGR (1<<20) -#define DVS_YUV_BYTE_ORDER_MASK (3<<16) -#define DVS_YUV_ORDER_YUYV (0<<16) -#define DVS_YUV_ORDER_UYVY (1<<16) -#define DVS_YUV_ORDER_YVYU (2<<16) -#define DVS_YUV_ORDER_VYUY (3<<16) -#define DVS_DEST_KEY (1<<2) -#define DVS_TRICKLE_FEED_DISABLE (1<<14) -#define DVS_TILED (1<<10) +#define DVS_ENABLE (1<<31) +#define DVS_GAMMA_ENABLE (1<<30) +#define DVS_PIXFORMAT_MASK (3<<25) +#define DVS_FORMAT_YUV422 (0<<25) +#define DVS_FORMAT_RGBX101010 (1<<25) +#define DVS_FORMAT_RGBX888 (2<<25) +#define DVS_FORMAT_RGBX161616 (3<<25) +#define DVS_SOURCE_KEY (1<<22) +#define DVS_RGB_ORDER_XBGR (1<<20) +#define DVS_YUV_BYTE_ORDER_MASK (3<<16) +#define DVS_YUV_ORDER_YUYV (0<<16) +#define DVS_YUV_ORDER_UYVY (1<<16) +#define DVS_YUV_ORDER_YVYU (2<<16) +#define DVS_YUV_ORDER_VYUY (3<<16) +#define DVS_DEST_KEY (1<<2) +#define DVS_TRICKLE_FEED_DISABLE (1<<14) +#define DVS_TILED (1<<10) #define _DVSALINOFF 0x72184 #define _DVSASTRIDE 0x72188 #define _DVSAPOS 0x7218c @@ -2799,13 +2799,13 @@ #define _DVSATILEOFF 0x721a4 #define _DVSASURFLIVE 0x721ac #define _DVSASCALE 0x72204 -#define DVS_SCALE_ENABLE (1<<31) -#define DVS_FILTER_MASK (3<<29) -#define DVS_FILTER_MEDIUM (0<<29) -#define DVS_FILTER_ENHANCING (1<<29) -#define DVS_FILTER_SOFTENING (2<<29) -#define DVS_VERTICAL_OFFSET_HALF (1<<28) /* must be enabled below */ -#define DVS_VERTICAL_OFFSET_ENABLE (1<<27) +#define DVS_SCALE_ENABLE (1<<31) +#define DVS_FILTER_MASK (3<<29) +#define DVS_FILTER_MEDIUM (0<<29) +#define DVS_FILTER_ENHANCING (1<<29) +#define DVS_FILTER_SOFTENING (2<<29) +#define DVS_VERTICAL_OFFSET_HALF (1<<28) /* must be enabled below */ +#define DVS_VERTICAL_OFFSET_ENABLE (1<<27) #define _DVSAGAMC 0x72300
#define _DVSBCNTR 0x73180 @@ -2835,29 +2835,29 @@ #define DVSKEYMSK(pipe) _PIPE(pipe, _DVSAKEYMSK, _DVSBKEYMSK)
#define _SPRA_CTL 0x70280 -#define SPRITE_ENABLE (1<<31) -#define SPRITE_GAMMA_ENABLE (1<<30) -#define SPRITE_PIXFORMAT_MASK (7<<25) -#define SPRITE_FORMAT_YUV422 (0<<25) -#define SPRITE_FORMAT_RGBX101010 (1<<25) -#define SPRITE_FORMAT_RGBX888 (2<<25) -#define SPRITE_FORMAT_RGBX161616 (3<<25) -#define SPRITE_FORMAT_YUV444 (4<<25) -#define SPRITE_FORMAT_XR_BGR101010 (5<<25) /* Extended range */ -#define SPRITE_CSC_ENABLE (1<<24) -#define SPRITE_SOURCE_KEY (1<<22) -#define SPRITE_RGB_ORDER_RGBX (1<<20) /* only for 888 and 161616 */ -#define SPRITE_YUV_TO_RGB_CSC_DISABLE (1<<19) -#define SPRITE_YUV_CSC_FORMAT_BT709 (1<<18) /* 0 is BT601 */ -#define SPRITE_YUV_BYTE_ORDER_MASK (3<<16) -#define SPRITE_YUV_ORDER_YUYV (0<<16) -#define SPRITE_YUV_ORDER_UYVY (1<<16) -#define SPRITE_YUV_ORDER_YVYU (2<<16) -#define SPRITE_YUV_ORDER_VYUY (3<<16) -#define SPRITE_TRICKLE_FEED_DISABLE (1<<14) -#define SPRITE_INT_GAMMA_ENABLE (1<<13) -#define SPRITE_TILED (1<<10) -#define SPRITE_DEST_KEY (1<<2) +#define SPRITE_ENABLE (1<<31) +#define SPRITE_GAMMA_ENABLE (1<<30) +#define SPRITE_PIXFORMAT_MASK (7<<25) +#define SPRITE_FORMAT_YUV422 (0<<25) +#define SPRITE_FORMAT_RGBX101010 (1<<25) +#define SPRITE_FORMAT_RGBX888 (2<<25) +#define SPRITE_FORMAT_RGBX161616 (3<<25) +#define SPRITE_FORMAT_YUV444 (4<<25) +#define SPRITE_FORMAT_XR_BGR101010 (5<<25) /* Extended range */ +#define SPRITE_CSC_ENABLE (1<<24) +#define SPRITE_SOURCE_KEY (1<<22) +#define SPRITE_RGB_ORDER_RGBX (1<<20) /* only for 888 and 161616 */ +#define SPRITE_YUV_TO_RGB_CSC_DISABLE (1<<19) +#define SPRITE_YUV_CSC_FORMAT_BT709 (1<<18) /* 0 is BT601 */ +#define SPRITE_YUV_BYTE_ORDER_MASK (3<<16) +#define SPRITE_YUV_ORDER_YUYV (0<<16) +#define SPRITE_YUV_ORDER_UYVY (1<<16) +#define SPRITE_YUV_ORDER_YVYU (2<<16) +#define SPRITE_YUV_ORDER_VYUY (3<<16) +#define SPRITE_TRICKLE_FEED_DISABLE (1<<14) +#define SPRITE_INT_GAMMA_ENABLE (1<<13) +#define SPRITE_TILED (1<<10) +#define SPRITE_DEST_KEY (1<<2) #define _SPRA_LINOFF 0x70284 #define _SPRA_STRIDE 0x70288 #define _SPRA_POS 0x7028c @@ -2868,13 +2868,13 @@ #define _SPRA_KEYMAX 0x702a0 #define _SPRA_TILEOFF 0x702a4 #define _SPRA_SCALE 0x70304 -#define SPRITE_SCALE_ENABLE (1<<31) -#define SPRITE_FILTER_MASK (3<<29) -#define SPRITE_FILTER_MEDIUM (0<<29) -#define SPRITE_FILTER_ENHANCING (1<<29) -#define SPRITE_FILTER_SOFTENING (2<<29) -#define SPRITE_VERTICAL_OFFSET_HALF (1<<28) /* must be enabled below */ -#define SPRITE_VERTICAL_OFFSET_ENABLE (1<<27) +#define SPRITE_SCALE_ENABLE (1<<31) +#define SPRITE_FILTER_MASK (3<<29) +#define SPRITE_FILTER_MEDIUM (0<<29) +#define SPRITE_FILTER_ENHANCING (1<<29) +#define SPRITE_FILTER_SOFTENING (2<<29) +#define SPRITE_VERTICAL_OFFSET_HALF (1<<28) /* must be enabled below */ +#define SPRITE_VERTICAL_OFFSET_ENABLE (1<<27) #define _SPRA_GAMC 0x70400
#define _SPRB_CTL 0x71280 @@ -2914,22 +2914,22 @@ #define CPU_VGACNTRL 0x41000
#define DIGITAL_PORT_HOTPLUG_CNTRL 0x44030 -#define DIGITAL_PORTA_HOTPLUG_ENABLE (1 << 4) -#define DIGITAL_PORTA_SHORT_PULSE_2MS (0 << 2) -#define DIGITAL_PORTA_SHORT_PULSE_4_5MS (1 << 2) -#define DIGITAL_PORTA_SHORT_PULSE_6MS (2 << 2) -#define DIGITAL_PORTA_SHORT_PULSE_100MS (3 << 2) -#define DIGITAL_PORTA_NO_DETECT (0 << 0) -#define DIGITAL_PORTA_LONG_PULSE_DETECT_MASK (1 << 1) -#define DIGITAL_PORTA_SHORT_PULSE_DETECT_MASK (1 << 0) +#define DIGITAL_PORTA_HOTPLUG_ENABLE (1 << 4) +#define DIGITAL_PORTA_SHORT_PULSE_2MS (0 << 2) +#define DIGITAL_PORTA_SHORT_PULSE_4_5MS (1 << 2) +#define DIGITAL_PORTA_SHORT_PULSE_6MS (2 << 2) +#define DIGITAL_PORTA_SHORT_PULSE_100MS (3 << 2) +#define DIGITAL_PORTA_NO_DETECT (0 << 0) +#define DIGITAL_PORTA_LONG_PULSE_DETECT_MASK (1 << 1) +#define DIGITAL_PORTA_SHORT_PULSE_DETECT_MASK (1 << 0)
/* refresh rate hardware control */ #define RR_HW_CTL 0x45300 -#define RR_HW_LOW_POWER_FRAMES_MASK 0xff -#define RR_HW_HIGH_POWER_FRAMES_MASK 0xff00 +#define RR_HW_LOW_POWER_FRAMES_MASK 0xff +#define RR_HW_HIGH_POWER_FRAMES_MASK 0xff00
#define FDI_PLL_BIOS_0 0x46000 -#define FDI_PLL_FB_CLOCK_MASK 0xff +#define FDI_PLL_FB_CLOCK_MASK 0xff #define FDI_PLL_BIOS_1 0x46004 #define FDI_PLL_BIOS_2 0x46008 #define DISPLAY_PORT_PLL_BIOS_0 0x4600c @@ -2950,32 +2950,32 @@ # define VFMUNIT_CLOCK_GATE_DISABLE (1 << 11)
#define FDI_PLL_FREQ_CTL 0x46030 -#define FDI_PLL_FREQ_CHANGE_REQUEST (1<<24) -#define FDI_PLL_FREQ_LOCK_LIMIT_MASK 0xfff00 -#define FDI_PLL_FREQ_DISABLE_COUNT_LIMIT_MASK 0xff +#define FDI_PLL_FREQ_CHANGE_REQUEST (1<<24) +#define FDI_PLL_FREQ_LOCK_LIMIT_MASK 0xfff00 +#define FDI_PLL_FREQ_DISABLE_COUNT_LIMIT_MASK 0xff
#define _PIPEA_DATA_M1 0x60030 -#define TU_SIZE(x) (((x)-1) << 25) /* default size 64 */ -#define TU_SIZE_MASK 0x7e000000 -#define PIPE_DATA_M1_OFFSET 0 +#define TU_SIZE(x) (((x)-1) << 25) /* default size 64 */ +#define TU_SIZE_MASK 0x7e000000 +#define PIPE_DATA_M1_OFFSET 0 #define _PIPEA_DATA_N1 0x60034 -#define PIPE_DATA_N1_OFFSET 0 +#define PIPE_DATA_N1_OFFSET 0
#define _PIPEA_DATA_M2 0x60038 -#define PIPE_DATA_M2_OFFSET 0 +#define PIPE_DATA_M2_OFFSET 0 #define _PIPEA_DATA_N2 0x6003c -#define PIPE_DATA_N2_OFFSET 0 +#define PIPE_DATA_N2_OFFSET 0
#define _PIPEA_LINK_M1 0x60040 -#define PIPE_LINK_M1_OFFSET 0 +#define PIPE_LINK_M1_OFFSET 0 #define _PIPEA_LINK_N1 0x60044 -#define PIPE_LINK_N1_OFFSET 0 +#define PIPE_LINK_N1_OFFSET 0
#define _PIPEA_LINK_M2 0x60048 -#define PIPE_LINK_M2_OFFSET 0 +#define PIPE_LINK_M2_OFFSET 0 #define _PIPEA_LINK_N2 0x6004c -#define PIPE_LINK_N2_OFFSET 0 +#define PIPE_LINK_N2_OFFSET 0
/* PIPEB timing regs are same start from 0x61000 */
@@ -3004,12 +3004,12 @@ /* IVB+ has 3 fitters, 0 is 7x5 capable, the other two only 3x3 */ #define _PFA_CTL_1 0x68080 #define _PFB_CTL_1 0x68880 -#define PF_ENABLE (1<<31) -#define PF_FILTER_MASK (3<<23) -#define PF_FILTER_PROGRAMMED (0<<23) -#define PF_FILTER_MED_3x3 (1<<23) -#define PF_FILTER_EDGE_ENHANCE (2<<23) -#define PF_FILTER_EDGE_SOFTEN (3<<23) +#define PF_ENABLE (1<<31) +#define PF_FILTER_MASK (3<<23) +#define PF_FILTER_PROGRAMMED (0<<23) +#define PF_FILTER_MED_3x3 (1<<23) +#define PF_FILTER_EDGE_ENHANCE (2<<23) +#define PF_FILTER_EDGE_SOFTEN (3<<23) #define _PFA_WIN_SZ 0x68074 #define _PFB_WIN_SZ 0x68874 #define _PFA_WIN_POS 0x68070 @@ -3090,47 +3090,47 @@
#define ILK_DISPLAY_CHICKEN2 0x42004 /* Required on all Ironlake and Sandybridge according to the B-Spec. */ -#define ILK_ELPIN_409_SELECT (1 << 25) -#define ILK_DPARB_GATE (1<<22) -#define ILK_VSDPFD_FULL (1<<21) +#define ILK_ELPIN_409_SELECT (1 << 25) +#define ILK_DPARB_GATE (1<<22) +#define ILK_VSDPFD_FULL (1<<21) #define ILK_DISPLAY_CHICKEN_FUSES 0x42014 -#define ILK_INTERNAL_GRAPHICS_DISABLE (1<<31) -#define ILK_INTERNAL_DISPLAY_DISABLE (1<<30) -#define ILK_DISPLAY_DEBUG_DISABLE (1<<29) -#define ILK_HDCP_DISABLE (1<<25) -#define ILK_eDP_A_DISABLE (1<<24) -#define ILK_DESKTOP (1<<23) +#define ILK_INTERNAL_GRAPHICS_DISABLE (1<<31) +#define ILK_INTERNAL_DISPLAY_DISABLE (1<<30) +#define ILK_DISPLAY_DEBUG_DISABLE (1<<29) +#define ILK_HDCP_DISABLE (1<<25) +#define ILK_eDP_A_DISABLE (1<<24) +#define ILK_DESKTOP (1<<23) #define ILK_DSPCLK_GATE 0x42020 -#define IVB_VRHUNIT_CLK_GATE (1<<28) -#define ILK_DPARB_CLK_GATE (1<<5) -#define ILK_DPFD_CLK_GATE (1<<7) +#define IVB_VRHUNIT_CLK_GATE (1<<28) +#define ILK_DPARB_CLK_GATE (1<<5) +#define ILK_DPFD_CLK_GATE (1<<7)
/* According to spec this bit 7/8/9 of 0x42020 should be set to enable FBC */ -#define ILK_CLK_FBC (1<<7) -#define ILK_DPFC_DIS1 (1<<8) -#define ILK_DPFC_DIS2 (1<<9) +#define ILK_CLK_FBC (1<<7) +#define ILK_DPFC_DIS1 (1<<8) +#define ILK_DPFC_DIS2 (1<<9)
#define IVB_CHICKEN3 0x4200c # define CHICKEN3_DGMG_REQ_OUT_FIX_DISABLE (1 << 5) # define CHICKEN3_DGMG_DONE_FIX_DISABLE (1 << 2)
#define DISP_ARB_CTL 0x45000 -#define DISP_TILE_SURFACE_SWIZZLING (1<<13) -#define DISP_FBC_WM_DIS (1<<15) +#define DISP_TILE_SURFACE_SWIZZLING (1<<13) +#define DISP_FBC_WM_DIS (1<<15)
/* GEN7 chicken */ #define GEN7_COMMON_SLICE_CHICKEN1 0x7010 # define GEN7_CSC1_RHWO_OPT_DISABLE_IN_RCC ((1<<10) | (1<<26))
#define GEN7_L3CNTLREG1 0xB01C -#define GEN7_WA_FOR_GEN7_L3_CONTROL 0x3C4FFF8C +#define GEN7_WA_FOR_GEN7_L3_CONTROL 0x3C4FFF8C
#define GEN7_L3_CHICKEN_MODE_REGISTER 0xB030 -#define GEN7_WA_L3_CHICKEN_MODE 0x20000000 +#define GEN7_WA_L3_CHICKEN_MODE 0x20000000
/* WaCatErrorRejectionIssue */ #define GEN7_SQ_CHICKEN_MBCUNIT_CONFIG 0x9030 -#define GEN7_SQ_CHICKEN_MBCUNIT_SQINTMOB (1<<11) +#define GEN7_SQ_CHICKEN_MBCUNIT_SQINTMOB (1<<11)
/* PCH */
@@ -3234,7 +3234,7 @@ #define PCH_DPLL(pipe) (pipe == 0 ? _PCH_DPLL_A : _PCH_DPLL_B)
#define _PCH_FPA0 0xc6040 -#define FP_CB_TUNE (0x3<<22) +#define FP_CB_TUNE (0x3<<22) #define _PCH_FPA1 0xc6044 #define _PCH_FPB0 0xc6048 #define _PCH_FPB1 0xc604c @@ -3244,34 +3244,34 @@ #define PCH_DPLL_TEST 0xc606c
#define PCH_DREF_CONTROL 0xC6200 -#define DREF_CONTROL_MASK 0x7fc3 -#define DREF_CPU_SOURCE_OUTPUT_DISABLE (0<<13) -#define DREF_CPU_SOURCE_OUTPUT_DOWNSPREAD (2<<13) -#define DREF_CPU_SOURCE_OUTPUT_NONSPREAD (3<<13) -#define DREF_CPU_SOURCE_OUTPUT_MASK (3<<13) -#define DREF_SSC_SOURCE_DISABLE (0<<11) -#define DREF_SSC_SOURCE_ENABLE (2<<11) -#define DREF_SSC_SOURCE_MASK (3<<11) -#define DREF_NONSPREAD_SOURCE_DISABLE (0<<9) -#define DREF_NONSPREAD_CK505_ENABLE (1<<9) -#define DREF_NONSPREAD_SOURCE_ENABLE (2<<9) -#define DREF_NONSPREAD_SOURCE_MASK (3<<9) -#define DREF_SUPERSPREAD_SOURCE_DISABLE (0<<7) -#define DREF_SUPERSPREAD_SOURCE_ENABLE (2<<7) -#define DREF_SUPERSPREAD_SOURCE_MASK (3<<7) -#define DREF_SSC4_DOWNSPREAD (0<<6) -#define DREF_SSC4_CENTERSPREAD (1<<6) -#define DREF_SSC1_DISABLE (0<<1) -#define DREF_SSC1_ENABLE (1<<1) -#define DREF_SSC4_DISABLE (0) -#define DREF_SSC4_ENABLE (1) +#define DREF_CONTROL_MASK 0x7fc3 +#define DREF_CPU_SOURCE_OUTPUT_DISABLE (0<<13) +#define DREF_CPU_SOURCE_OUTPUT_DOWNSPREAD (2<<13) +#define DREF_CPU_SOURCE_OUTPUT_NONSPREAD (3<<13) +#define DREF_CPU_SOURCE_OUTPUT_MASK (3<<13) +#define DREF_SSC_SOURCE_DISABLE (0<<11) +#define DREF_SSC_SOURCE_ENABLE (2<<11) +#define DREF_SSC_SOURCE_MASK (3<<11) +#define DREF_NONSPREAD_SOURCE_DISABLE (0<<9) +#define DREF_NONSPREAD_CK505_ENABLE (1<<9) +#define DREF_NONSPREAD_SOURCE_ENABLE (2<<9) +#define DREF_NONSPREAD_SOURCE_MASK (3<<9) +#define DREF_SUPERSPREAD_SOURCE_DISABLE (0<<7) +#define DREF_SUPERSPREAD_SOURCE_ENABLE (2<<7) +#define DREF_SUPERSPREAD_SOURCE_MASK (3<<7) +#define DREF_SSC4_DOWNSPREAD (0<<6) +#define DREF_SSC4_CENTERSPREAD (1<<6) +#define DREF_SSC1_DISABLE (0<<1) +#define DREF_SSC1_ENABLE (1<<1) +#define DREF_SSC4_DISABLE (0) +#define DREF_SSC4_ENABLE (1)
#define PCH_RAWCLK_FREQ 0xc6204 -#define FDL_TP1_TIMER_SHIFT 12 -#define FDL_TP1_TIMER_MASK (3<<12) -#define FDL_TP2_TIMER_SHIFT 10 -#define FDL_TP2_TIMER_MASK (3<<10) -#define RAWCLK_FREQ_MASK 0x3ff +#define FDL_TP1_TIMER_SHIFT 12 +#define FDL_TP1_TIMER_MASK (3<<12) +#define FDL_TP2_TIMER_SHIFT 10 +#define FDL_TP2_TIMER_MASK (3<<10) +#define RAWCLK_FREQ_MASK 0x3ff
#define PCH_DPLL_TMR_CFG 0xc6208
@@ -3279,36 +3279,36 @@ #define PCH_SSC4_AUX_PARMS 0xc6214
#define PCH_DPLL_SEL 0xc7000 -#define TRANSA_DPLL_ENABLE (1<<3) +#define TRANSA_DPLL_ENABLE (1<<3) #define TRANSA_DPLLB_SEL (1<<0) #define TRANSA_DPLLA_SEL 0 -#define TRANSB_DPLL_ENABLE (1<<7) +#define TRANSB_DPLL_ENABLE (1<<7) #define TRANSB_DPLLB_SEL (1<<4) #define TRANSB_DPLLA_SEL (0) -#define TRANSC_DPLL_ENABLE (1<<11) +#define TRANSC_DPLL_ENABLE (1<<11) #define TRANSC_DPLLB_SEL (1<<8) #define TRANSC_DPLLA_SEL (0)
/* transcoder */
#define _TRANS_HTOTAL_A 0xe0000 -#define TRANS_HTOTAL_SHIFT 16 -#define TRANS_HACTIVE_SHIFT 0 +#define TRANS_HTOTAL_SHIFT 16 +#define TRANS_HACTIVE_SHIFT 0 #define _TRANS_HBLANK_A 0xe0004 -#define TRANS_HBLANK_END_SHIFT 16 -#define TRANS_HBLANK_START_SHIFT 0 +#define TRANS_HBLANK_END_SHIFT 16 +#define TRANS_HBLANK_START_SHIFT 0 #define _TRANS_HSYNC_A 0xe0008 -#define TRANS_HSYNC_END_SHIFT 16 -#define TRANS_HSYNC_START_SHIFT 0 +#define TRANS_HSYNC_END_SHIFT 16 +#define TRANS_HSYNC_START_SHIFT 0 #define _TRANS_VTOTAL_A 0xe000c -#define TRANS_VTOTAL_SHIFT 16 -#define TRANS_VACTIVE_SHIFT 0 +#define TRANS_VTOTAL_SHIFT 16 +#define TRANS_VACTIVE_SHIFT 0 #define _TRANS_VBLANK_A 0xe0010 -#define TRANS_VBLANK_END_SHIFT 16 -#define TRANS_VBLANK_START_SHIFT 0 +#define TRANS_VBLANK_END_SHIFT 16 +#define TRANS_VBLANK_START_SHIFT 0 #define _TRANS_VSYNC_A 0xe0014 -#define TRANS_VSYNC_END_SHIFT 16 -#define TRANS_VSYNC_START_SHIFT 0 +#define TRANS_VSYNC_END_SHIFT 16 +#define TRANS_VSYNC_START_SHIFT 0 #define _TRANS_VSYNCSHIFT_A 0xe0028
#define _TRANSA_DATA_M1 0xe0030 @@ -3372,128 +3372,128 @@ #define _TRANSACONF 0xf0008 #define _TRANSBCONF 0xf1008 #define TRANSCONF(plane) _PIPE(plane, _TRANSACONF, _TRANSBCONF) -#define TRANS_DISABLE (0<<31) -#define TRANS_ENABLE (1<<31) -#define TRANS_STATE_MASK (1<<30) -#define TRANS_STATE_DISABLE (0<<30) -#define TRANS_STATE_ENABLE (1<<30) -#define TRANS_FSYNC_DELAY_HB1 (0<<27) -#define TRANS_FSYNC_DELAY_HB2 (1<<27) -#define TRANS_FSYNC_DELAY_HB3 (2<<27) -#define TRANS_FSYNC_DELAY_HB4 (3<<27) -#define TRANS_DP_AUDIO_ONLY (1<<26) -#define TRANS_DP_VIDEO_AUDIO (0<<26) -#define TRANS_INTERLACE_MASK (7<<21) -#define TRANS_PROGRESSIVE (0<<21) -#define TRANS_INTERLACED (3<<21) -#define TRANS_LEGACY_INTERLACED_ILK (2<<21) -#define TRANS_8BPC (0<<5) -#define TRANS_10BPC (1<<5) -#define TRANS_6BPC (2<<5) -#define TRANS_12BPC (3<<5) +#define TRANS_DISABLE (0<<31) +#define TRANS_ENABLE (1<<31) +#define TRANS_STATE_MASK (1<<30) +#define TRANS_STATE_DISABLE (0<<30) +#define TRANS_STATE_ENABLE (1<<30) +#define TRANS_FSYNC_DELAY_HB1 (0<<27) +#define TRANS_FSYNC_DELAY_HB2 (1<<27) +#define TRANS_FSYNC_DELAY_HB3 (2<<27) +#define TRANS_FSYNC_DELAY_HB4 (3<<27) +#define TRANS_DP_AUDIO_ONLY (1<<26) +#define TRANS_DP_VIDEO_AUDIO (0<<26) +#define TRANS_INTERLACE_MASK (7<<21) +#define TRANS_PROGRESSIVE (0<<21) +#define TRANS_INTERLACED (3<<21) +#define TRANS_LEGACY_INTERLACED_ILK (2<<21) +#define TRANS_8BPC (0<<5) +#define TRANS_10BPC (1<<5) +#define TRANS_6BPC (2<<5) +#define TRANS_12BPC (3<<5)
#define _TRANSA_CHICKEN2 0xf0064 #define _TRANSB_CHICKEN2 0xf1064 #define TRANS_CHICKEN2(pipe) _PIPE(pipe, _TRANSA_CHICKEN2, _TRANSB_CHICKEN2) -#define TRANS_AUTOTRAIN_GEN_STALL_DIS (1<<31) +#define TRANS_AUTOTRAIN_GEN_STALL_DIS (1<<31)
#define SOUTH_CHICKEN1 0xc2000 -#define FDIA_PHASE_SYNC_SHIFT_OVR 19 -#define FDIA_PHASE_SYNC_SHIFT_EN 18 +#define FDIA_PHASE_SYNC_SHIFT_OVR 19 +#define FDIA_PHASE_SYNC_SHIFT_EN 18 #define FDI_PHASE_SYNC_OVR(pipe) (1<<(FDIA_PHASE_SYNC_SHIFT_OVR - ((pipe) * 2))) #define FDI_PHASE_SYNC_EN(pipe) (1<<(FDIA_PHASE_SYNC_SHIFT_EN - ((pipe) * 2))) #define SOUTH_CHICKEN2 0xc2004 -#define DPLS_EDP_PPS_FIX_DIS (1<<0) +#define DPLS_EDP_PPS_FIX_DIS (1<<0)
#define _FDI_RXA_CHICKEN 0xc200c #define _FDI_RXB_CHICKEN 0xc2010 -#define FDI_RX_PHASE_SYNC_POINTER_OVR (1<<1) -#define FDI_RX_PHASE_SYNC_POINTER_EN (1<<0) +#define FDI_RX_PHASE_SYNC_POINTER_OVR (1<<1) +#define FDI_RX_PHASE_SYNC_POINTER_EN (1<<0) #define FDI_RX_CHICKEN(pipe) _PIPE(pipe, _FDI_RXA_CHICKEN, _FDI_RXB_CHICKEN)
#define SOUTH_DSPCLK_GATE_D 0xc2020 -#define PCH_DPLSUNIT_CLOCK_GATE_DISABLE (1<<29) +#define PCH_DPLSUNIT_CLOCK_GATE_DISABLE (1<<29)
/* CPU: FDI_TX */ #define _FDI_TXA_CTL 0x60100 #define _FDI_TXB_CTL 0x61100 #define FDI_TX_CTL(pipe) _PIPE(pipe, _FDI_TXA_CTL, _FDI_TXB_CTL) -#define FDI_TX_DISABLE (0<<31) -#define FDI_TX_ENABLE (1<<31) -#define FDI_LINK_TRAIN_PATTERN_1 (0<<28) -#define FDI_LINK_TRAIN_PATTERN_2 (1<<28) -#define FDI_LINK_TRAIN_PATTERN_IDLE (2<<28) -#define FDI_LINK_TRAIN_NONE (3<<28) -#define FDI_LINK_TRAIN_VOLTAGE_0_4V (0<<25) -#define FDI_LINK_TRAIN_VOLTAGE_0_6V (1<<25) -#define FDI_LINK_TRAIN_VOLTAGE_0_8V (2<<25) -#define FDI_LINK_TRAIN_VOLTAGE_1_2V (3<<25) -#define FDI_LINK_TRAIN_PRE_EMPHASIS_NONE (0<<22) -#define FDI_LINK_TRAIN_PRE_EMPHASIS_1_5X (1<<22) -#define FDI_LINK_TRAIN_PRE_EMPHASIS_2X (2<<22) -#define FDI_LINK_TRAIN_PRE_EMPHASIS_3X (3<<22) +#define FDI_TX_DISABLE (0<<31) +#define FDI_TX_ENABLE (1<<31) +#define FDI_LINK_TRAIN_PATTERN_1 (0<<28) +#define FDI_LINK_TRAIN_PATTERN_2 (1<<28) +#define FDI_LINK_TRAIN_PATTERN_IDLE (2<<28) +#define FDI_LINK_TRAIN_NONE (3<<28) +#define FDI_LINK_TRAIN_VOLTAGE_0_4V (0<<25) +#define FDI_LINK_TRAIN_VOLTAGE_0_6V (1<<25) +#define FDI_LINK_TRAIN_VOLTAGE_0_8V (2<<25) +#define FDI_LINK_TRAIN_VOLTAGE_1_2V (3<<25) +#define FDI_LINK_TRAIN_PRE_EMPHASIS_NONE (0<<22) +#define FDI_LINK_TRAIN_PRE_EMPHASIS_1_5X (1<<22) +#define FDI_LINK_TRAIN_PRE_EMPHASIS_2X (2<<22) +#define FDI_LINK_TRAIN_PRE_EMPHASIS_3X (3<<22) /* ILK always use 400mV 0dB for voltage swing and pre-emphasis level. SNB has different settings. */ /* SNB A-stepping */ -#define FDI_LINK_TRAIN_400MV_0DB_SNB_A (0x38<<22) -#define FDI_LINK_TRAIN_400MV_6DB_SNB_A (0x02<<22) -#define FDI_LINK_TRAIN_600MV_3_5DB_SNB_A (0x01<<22) -#define FDI_LINK_TRAIN_800MV_0DB_SNB_A (0x0<<22) +#define FDI_LINK_TRAIN_400MV_0DB_SNB_A (0x38<<22) +#define FDI_LINK_TRAIN_400MV_6DB_SNB_A (0x02<<22) +#define FDI_LINK_TRAIN_600MV_3_5DB_SNB_A (0x01<<22) +#define FDI_LINK_TRAIN_800MV_0DB_SNB_A (0x0<<22) /* SNB B-stepping */ -#define FDI_LINK_TRAIN_400MV_0DB_SNB_B (0x0<<22) -#define FDI_LINK_TRAIN_400MV_6DB_SNB_B (0x3a<<22) -#define FDI_LINK_TRAIN_600MV_3_5DB_SNB_B (0x39<<22) -#define FDI_LINK_TRAIN_800MV_0DB_SNB_B (0x38<<22) -#define FDI_LINK_TRAIN_VOL_EMP_MASK (0x3f<<22) -#define FDI_DP_PORT_WIDTH_X1 (0<<19) -#define FDI_DP_PORT_WIDTH_X2 (1<<19) -#define FDI_DP_PORT_WIDTH_X3 (2<<19) -#define FDI_DP_PORT_WIDTH_X4 (3<<19) -#define FDI_TX_ENHANCE_FRAME_ENABLE (1<<18) +#define FDI_LINK_TRAIN_400MV_0DB_SNB_B (0x0<<22) +#define FDI_LINK_TRAIN_400MV_6DB_SNB_B (0x3a<<22) +#define FDI_LINK_TRAIN_600MV_3_5DB_SNB_B (0x39<<22) +#define FDI_LINK_TRAIN_800MV_0DB_SNB_B (0x38<<22) +#define FDI_LINK_TRAIN_VOL_EMP_MASK (0x3f<<22) +#define FDI_DP_PORT_WIDTH_X1 (0<<19) +#define FDI_DP_PORT_WIDTH_X2 (1<<19) +#define FDI_DP_PORT_WIDTH_X3 (2<<19) +#define FDI_DP_PORT_WIDTH_X4 (3<<19) +#define FDI_TX_ENHANCE_FRAME_ENABLE (1<<18) /* Ironlake: hardwired to 1 */ -#define FDI_TX_PLL_ENABLE (1<<14) +#define FDI_TX_PLL_ENABLE (1<<14)
/* Ivybridge has different bits for lolz */ -#define FDI_LINK_TRAIN_PATTERN_1_IVB (0<<8) -#define FDI_LINK_TRAIN_PATTERN_2_IVB (1<<8) -#define FDI_LINK_TRAIN_PATTERN_IDLE_IVB (2<<8) -#define FDI_LINK_TRAIN_NONE_IVB (3<<8) +#define FDI_LINK_TRAIN_PATTERN_1_IVB (0<<8) +#define FDI_LINK_TRAIN_PATTERN_2_IVB (1<<8) +#define FDI_LINK_TRAIN_PATTERN_IDLE_IVB (2<<8) +#define FDI_LINK_TRAIN_NONE_IVB (3<<8)
/* both Tx and Rx */ -#define FDI_COMPOSITE_SYNC (1<<11) -#define FDI_LINK_TRAIN_AUTO (1<<10) -#define FDI_SCRAMBLING_ENABLE (0<<7) -#define FDI_SCRAMBLING_DISABLE (1<<7) +#define FDI_COMPOSITE_SYNC (1<<11) +#define FDI_LINK_TRAIN_AUTO (1<<10) +#define FDI_SCRAMBLING_ENABLE (0<<7) +#define FDI_SCRAMBLING_DISABLE (1<<7)
/* FDI_RX, FDI_X is hard-wired to Transcoder_X */ #define _FDI_RXA_CTL 0xf000c #define _FDI_RXB_CTL 0xf100c #define FDI_RX_CTL(pipe) _PIPE(pipe, _FDI_RXA_CTL, _FDI_RXB_CTL) -#define FDI_RX_ENABLE (1<<31) +#define FDI_RX_ENABLE (1<<31) /* train, dp width same as FDI_TX */ -#define FDI_FS_ERRC_ENABLE (1<<27) -#define FDI_FE_ERRC_ENABLE (1<<26) -#define FDI_DP_PORT_WIDTH_X8 (7<<19) -#define FDI_8BPC (0<<16) -#define FDI_10BPC (1<<16) -#define FDI_6BPC (2<<16) -#define FDI_12BPC (3<<16) -#define FDI_LINK_REVERSE_OVERWRITE (1<<15) -#define FDI_DMI_LINK_REVERSE_MASK (1<<14) -#define FDI_RX_PLL_ENABLE (1<<13) -#define FDI_FS_ERR_CORRECT_ENABLE (1<<11) -#define FDI_FE_ERR_CORRECT_ENABLE (1<<10) -#define FDI_FS_ERR_REPORT_ENABLE (1<<9) -#define FDI_FE_ERR_REPORT_ENABLE (1<<8) -#define FDI_RX_ENHANCE_FRAME_ENABLE (1<<6) -#define FDI_PCDCLK (1<<4) +#define FDI_FS_ERRC_ENABLE (1<<27) +#define FDI_FE_ERRC_ENABLE (1<<26) +#define FDI_DP_PORT_WIDTH_X8 (7<<19) +#define FDI_8BPC (0<<16) +#define FDI_10BPC (1<<16) +#define FDI_6BPC (2<<16) +#define FDI_12BPC (3<<16) +#define FDI_LINK_REVERSE_OVERWRITE (1<<15) +#define FDI_DMI_LINK_REVERSE_MASK (1<<14) +#define FDI_RX_PLL_ENABLE (1<<13) +#define FDI_FS_ERR_CORRECT_ENABLE (1<<11) +#define FDI_FE_ERR_CORRECT_ENABLE (1<<10) +#define FDI_FS_ERR_REPORT_ENABLE (1<<9) +#define FDI_FE_ERR_REPORT_ENABLE (1<<8) +#define FDI_RX_ENHANCE_FRAME_ENABLE (1<<6) +#define FDI_PCDCLK (1<<4) /* CPT */ -#define FDI_AUTO_TRAINING (1<<10) -#define FDI_LINK_TRAIN_PATTERN_1_CPT (0<<8) -#define FDI_LINK_TRAIN_PATTERN_2_CPT (1<<8) -#define FDI_LINK_TRAIN_PATTERN_IDLE_CPT (2<<8) -#define FDI_LINK_TRAIN_NORMAL_CPT (3<<8) -#define FDI_LINK_TRAIN_PATTERN_MASK_CPT (3<<8) +#define FDI_AUTO_TRAINING (1<<10) +#define FDI_LINK_TRAIN_PATTERN_1_CPT (0<<8) +#define FDI_LINK_TRAIN_PATTERN_2_CPT (1<<8) +#define FDI_LINK_TRAIN_PATTERN_IDLE_CPT (2<<8) +#define FDI_LINK_TRAIN_NORMAL_CPT (3<<8) +#define FDI_LINK_TRAIN_PATTERN_MASK_CPT (3<<8)
#define _FDI_RXA_MISC 0xf0010 #define _FDI_RXB_MISC 0xf1010 @@ -3530,50 +3530,50 @@
/* CRT */ #define PCH_ADPA 0xe1100 -#define ADPA_TRANS_SELECT_MASK (1<<30) -#define ADPA_TRANS_A_SELECT 0 -#define ADPA_TRANS_B_SELECT (1<<30) -#define ADPA_CRT_HOTPLUG_MASK 0x03ff0000 /* bit 25-16 */ -#define ADPA_CRT_HOTPLUG_MONITOR_NONE (0<<24) -#define ADPA_CRT_HOTPLUG_MONITOR_MASK (3<<24) -#define ADPA_CRT_HOTPLUG_MONITOR_COLOR (3<<24) -#define ADPA_CRT_HOTPLUG_MONITOR_MONO (2<<24) -#define ADPA_CRT_HOTPLUG_ENABLE (1<<23) -#define ADPA_CRT_HOTPLUG_PERIOD_64 (0<<22) -#define ADPA_CRT_HOTPLUG_PERIOD_128 (1<<22) -#define ADPA_CRT_HOTPLUG_WARMUP_5MS (0<<21) -#define ADPA_CRT_HOTPLUG_WARMUP_10MS (1<<21) -#define ADPA_CRT_HOTPLUG_SAMPLE_2S (0<<20) -#define ADPA_CRT_HOTPLUG_SAMPLE_4S (1<<20) -#define ADPA_CRT_HOTPLUG_VOLTAGE_40 (0<<18) -#define ADPA_CRT_HOTPLUG_VOLTAGE_50 (1<<18) -#define ADPA_CRT_HOTPLUG_VOLTAGE_60 (2<<18) -#define ADPA_CRT_HOTPLUG_VOLTAGE_70 (3<<18) -#define ADPA_CRT_HOTPLUG_VOLREF_325MV (0<<17) -#define ADPA_CRT_HOTPLUG_VOLREF_475MV (1<<17) -#define ADPA_CRT_HOTPLUG_FORCE_TRIGGER (1<<16) +#define ADPA_TRANS_SELECT_MASK (1<<30) +#define ADPA_TRANS_A_SELECT 0 +#define ADPA_TRANS_B_SELECT (1<<30) +#define ADPA_CRT_HOTPLUG_MASK 0x03ff0000 /* bit 25-16 */ +#define ADPA_CRT_HOTPLUG_MONITOR_NONE (0<<24) +#define ADPA_CRT_HOTPLUG_MONITOR_MASK (3<<24) +#define ADPA_CRT_HOTPLUG_MONITOR_COLOR (3<<24) +#define ADPA_CRT_HOTPLUG_MONITOR_MONO (2<<24) +#define ADPA_CRT_HOTPLUG_ENABLE (1<<23) +#define ADPA_CRT_HOTPLUG_PERIOD_64 (0<<22) +#define ADPA_CRT_HOTPLUG_PERIOD_128 (1<<22) +#define ADPA_CRT_HOTPLUG_WARMUP_5MS (0<<21) +#define ADPA_CRT_HOTPLUG_WARMUP_10MS (1<<21) +#define ADPA_CRT_HOTPLUG_SAMPLE_2S (0<<20) +#define ADPA_CRT_HOTPLUG_SAMPLE_4S (1<<20) +#define ADPA_CRT_HOTPLUG_VOLTAGE_40 (0<<18) +#define ADPA_CRT_HOTPLUG_VOLTAGE_50 (1<<18) +#define ADPA_CRT_HOTPLUG_VOLTAGE_60 (2<<18) +#define ADPA_CRT_HOTPLUG_VOLTAGE_70 (3<<18) +#define ADPA_CRT_HOTPLUG_VOLREF_325MV (0<<17) +#define ADPA_CRT_HOTPLUG_VOLREF_475MV (1<<17) +#define ADPA_CRT_HOTPLUG_FORCE_TRIGGER (1<<16)
/* or SDVOB */ #define HDMIB 0xe1140 -#define PORT_ENABLE (1 << 31) -#define TRANSCODER(pipe) ((pipe) << 30) -#define TRANSCODER_CPT(pipe) ((pipe) << 29) -#define TRANSCODER_MASK (1 << 30) -#define TRANSCODER_MASK_CPT (3 << 29) -#define COLOR_FORMAT_8bpc (0) -#define COLOR_FORMAT_12bpc (3 << 26) -#define SDVOB_HOTPLUG_ENABLE (1 << 23) -#define SDVO_ENCODING (0) -#define TMDS_ENCODING (2 << 10) -#define NULL_PACKET_VSYNC_ENABLE (1 << 9) +#define PORT_ENABLE (1 << 31) +#define TRANSCODER(pipe) ((pipe) << 30) +#define TRANSCODER_CPT(pipe) ((pipe) << 29) +#define TRANSCODER_MASK (1 << 30) +#define TRANSCODER_MASK_CPT (3 << 29) +#define COLOR_FORMAT_8bpc (0) +#define COLOR_FORMAT_12bpc (3 << 26) +#define SDVOB_HOTPLUG_ENABLE (1 << 23) +#define SDVO_ENCODING (0) +#define TMDS_ENCODING (2 << 10) +#define NULL_PACKET_VSYNC_ENABLE (1 << 9) /* CPT */ -#define HDMI_MODE_SELECT (1 << 9) -#define DVI_MODE_SELECT (0) -#define SDVOB_BORDER_ENABLE (1 << 7) -#define AUDIO_ENABLE (1 << 6) -#define VSYNC_ACTIVE_HIGH (1 << 4) -#define HSYNC_ACTIVE_HIGH (1 << 3) -#define PORT_DETECTED (1 << 2) +#define HDMI_MODE_SELECT (1 << 9) +#define DVI_MODE_SELECT (0) +#define SDVOB_BORDER_ENABLE (1 << 7) +#define AUDIO_ENABLE (1 << 6) +#define VSYNC_ACTIVE_HIGH (1 << 4) +#define HSYNC_ACTIVE_HIGH (1 << 3) +#define PORT_DETECTED (1 << 2)
/* PCH SDVOB multiplex with HDMIB */ #define PCH_SDVOB HDMIB @@ -3582,55 +3582,55 @@ #define HDMID 0xe1160
#define PCH_LVDS 0xe1180 -#define LVDS_DETECTED (1 << 1) +#define LVDS_DETECTED (1 << 1)
#define BLC_PWM_CPU_CTL2 0x48250 -#define PWM_ENABLE (1 << 31) -#define PWM_PIPE_A (0 << 29) -#define PWM_PIPE_B (1 << 29) +#define PWM_ENABLE (1 << 31) +#define PWM_PIPE_A (0 << 29) +#define PWM_PIPE_B (1 << 29) #define BLC_PWM_CPU_CTL 0x48254
#define BLC_PWM_PCH_CTL1 0xc8250 -#define PWM_PCH_ENABLE (1 << 31) -#define PWM_POLARITY_ACTIVE_LOW (1 << 29) -#define PWM_POLARITY_ACTIVE_HIGH (0 << 29) -#define PWM_POLARITY_ACTIVE_LOW2 (1 << 28) -#define PWM_POLARITY_ACTIVE_HIGH2 (0 << 28) +#define PWM_PCH_ENABLE (1 << 31) +#define PWM_POLARITY_ACTIVE_LOW (1 << 29) +#define PWM_POLARITY_ACTIVE_HIGH (0 << 29) +#define PWM_POLARITY_ACTIVE_LOW2 (1 << 28) +#define PWM_POLARITY_ACTIVE_HIGH2 (0 << 28)
#define BLC_PWM_PCH_CTL2 0xc8254
#define PCH_PP_STATUS 0xc7200 #define PCH_PP_CONTROL 0xc7204 -#define PANEL_UNLOCK_REGS (0xabcd << 16) -#define PANEL_UNLOCK_MASK (0xffff << 16) -#define EDP_FORCE_VDD (1 << 3) -#define EDP_BLC_ENABLE (1 << 2) -#define PANEL_POWER_RESET (1 << 1) -#define PANEL_POWER_OFF (0 << 0) -#define PANEL_POWER_ON (1 << 0) +#define PANEL_UNLOCK_REGS (0xabcd << 16) +#define PANEL_UNLOCK_MASK (0xffff << 16) +#define EDP_FORCE_VDD (1 << 3) +#define EDP_BLC_ENABLE (1 << 2) +#define PANEL_POWER_RESET (1 << 1) +#define PANEL_POWER_OFF (0 << 0) +#define PANEL_POWER_ON (1 << 0) #define PCH_PP_ON_DELAYS 0xc7208 -#define PANEL_PORT_SELECT_MASK (3 << 30) -#define PANEL_PORT_SELECT_LVDS (0 << 30) -#define PANEL_PORT_SELECT_DPA (1 << 30) -#define EDP_PANEL (1 << 30) -#define PANEL_PORT_SELECT_DPC (2 << 30) -#define PANEL_PORT_SELECT_DPD (3 << 30) -#define PANEL_POWER_UP_DELAY_MASK (0x1fff0000) -#define PANEL_POWER_UP_DELAY_SHIFT 16 -#define PANEL_LIGHT_ON_DELAY_MASK (0x1fff) -#define PANEL_LIGHT_ON_DELAY_SHIFT 0 +#define PANEL_PORT_SELECT_MASK (3 << 30) +#define PANEL_PORT_SELECT_LVDS (0 << 30) +#define PANEL_PORT_SELECT_DPA (1 << 30) +#define EDP_PANEL (1 << 30) +#define PANEL_PORT_SELECT_DPC (2 << 30) +#define PANEL_PORT_SELECT_DPD (3 << 30) +#define PANEL_POWER_UP_DELAY_MASK (0x1fff0000) +#define PANEL_POWER_UP_DELAY_SHIFT 16 +#define PANEL_LIGHT_ON_DELAY_MASK (0x1fff) +#define PANEL_LIGHT_ON_DELAY_SHIFT 0
#define PCH_PP_OFF_DELAYS 0xc720c -#define PANEL_POWER_DOWN_DELAY_MASK (0x1fff0000) -#define PANEL_POWER_DOWN_DELAY_SHIFT 16 -#define PANEL_LIGHT_OFF_DELAY_MASK (0x1fff) -#define PANEL_LIGHT_OFF_DELAY_SHIFT 0 +#define PANEL_POWER_DOWN_DELAY_MASK (0x1fff0000) +#define PANEL_POWER_DOWN_DELAY_SHIFT 16 +#define PANEL_LIGHT_OFF_DELAY_MASK (0x1fff) +#define PANEL_LIGHT_OFF_DELAY_SHIFT 0
#define PCH_PP_DIVISOR 0xc7210 -#define PP_REFERENCE_DIVIDER_MASK (0xffffff00) -#define PP_REFERENCE_DIVIDER_SHIFT 8 -#define PANEL_POWER_CYCLE_DELAY_MASK (0x1f) -#define PANEL_POWER_CYCLE_DELAY_SHIFT 0 +#define PP_REFERENCE_DIVIDER_MASK (0xffffff00) +#define PP_REFERENCE_DIVIDER_SHIFT 8 +#define PANEL_POWER_CYCLE_DELAY_MASK (0x1f) +#define PANEL_POWER_CYCLE_DELAY_SHIFT 0
#define PCH_DP_B 0xe4100 #define PCH_DPB_AUX_CH_CTL 0xe4110 @@ -3657,48 +3657,48 @@ #define PCH_DPD_AUX_CH_DATA5 0xe4324
/* CPT */ -#define PORT_TRANS_A_SEL_CPT 0 -#define PORT_TRANS_B_SEL_CPT (1<<29) -#define PORT_TRANS_C_SEL_CPT (2<<29) -#define PORT_TRANS_SEL_MASK (3<<29) -#define PORT_TRANS_SEL_CPT(pipe) ((pipe) << 29) +#define PORT_TRANS_A_SEL_CPT 0 +#define PORT_TRANS_B_SEL_CPT (1<<29) +#define PORT_TRANS_C_SEL_CPT (2<<29) +#define PORT_TRANS_SEL_MASK (3<<29) +#define PORT_TRANS_SEL_CPT(pipe) ((pipe) << 29)
#define TRANS_DP_CTL_A 0xe0300 #define TRANS_DP_CTL_B 0xe1300 #define TRANS_DP_CTL_C 0xe2300 #define TRANS_DP_CTL(pipe) (TRANS_DP_CTL_A + (pipe) * 0x01000) -#define TRANS_DP_OUTPUT_ENABLE (1<<31) -#define TRANS_DP_PORT_SEL_B (0<<29) -#define TRANS_DP_PORT_SEL_C (1<<29) -#define TRANS_DP_PORT_SEL_D (2<<29) -#define TRANS_DP_PORT_SEL_NONE (3<<29) -#define TRANS_DP_PORT_SEL_MASK (3<<29) -#define TRANS_DP_AUDIO_ONLY (1<<26) -#define TRANS_DP_ENH_FRAMING (1<<18) -#define TRANS_DP_8BPC (0<<9) -#define TRANS_DP_10BPC (1<<9) -#define TRANS_DP_6BPC (2<<9) -#define TRANS_DP_12BPC (3<<9) -#define TRANS_DP_BPC_MASK (3<<9) -#define TRANS_DP_VSYNC_ACTIVE_HIGH (1<<4) -#define TRANS_DP_VSYNC_ACTIVE_LOW 0 -#define TRANS_DP_HSYNC_ACTIVE_HIGH (1<<3) -#define TRANS_DP_HSYNC_ACTIVE_LOW 0 -#define TRANS_DP_SYNC_MASK (3<<3) +#define TRANS_DP_OUTPUT_ENABLE (1<<31) +#define TRANS_DP_PORT_SEL_B (0<<29) +#define TRANS_DP_PORT_SEL_C (1<<29) +#define TRANS_DP_PORT_SEL_D (2<<29) +#define TRANS_DP_PORT_SEL_NONE (3<<29) +#define TRANS_DP_PORT_SEL_MASK (3<<29) +#define TRANS_DP_AUDIO_ONLY (1<<26) +#define TRANS_DP_ENH_FRAMING (1<<18) +#define TRANS_DP_8BPC (0<<9) +#define TRANS_DP_10BPC (1<<9) +#define TRANS_DP_6BPC (2<<9) +#define TRANS_DP_12BPC (3<<9) +#define TRANS_DP_BPC_MASK (3<<9) +#define TRANS_DP_VSYNC_ACTIVE_HIGH (1<<4) +#define TRANS_DP_VSYNC_ACTIVE_LOW 0 +#define TRANS_DP_HSYNC_ACTIVE_HIGH (1<<3) +#define TRANS_DP_HSYNC_ACTIVE_LOW 0 +#define TRANS_DP_SYNC_MASK (3<<3)
/* SNB eDP training params */ /* SNB A-stepping */ -#define EDP_LINK_TRAIN_400MV_0DB_SNB_A (0x38<<22) -#define EDP_LINK_TRAIN_400MV_6DB_SNB_A (0x02<<22) -#define EDP_LINK_TRAIN_600MV_3_5DB_SNB_A (0x01<<22) -#define EDP_LINK_TRAIN_800MV_0DB_SNB_A (0x0<<22) +#define EDP_LINK_TRAIN_400MV_0DB_SNB_A (0x38<<22) +#define EDP_LINK_TRAIN_400MV_6DB_SNB_A (0x02<<22) +#define EDP_LINK_TRAIN_600MV_3_5DB_SNB_A (0x01<<22) +#define EDP_LINK_TRAIN_800MV_0DB_SNB_A (0x0<<22) /* SNB B-stepping */ -#define EDP_LINK_TRAIN_400_600MV_0DB_SNB_B (0x0<<22) -#define EDP_LINK_TRAIN_400MV_3_5DB_SNB_B (0x1<<22) -#define EDP_LINK_TRAIN_400_600MV_6DB_SNB_B (0x3a<<22) -#define EDP_LINK_TRAIN_600_800MV_3_5DB_SNB_B (0x39<<22) -#define EDP_LINK_TRAIN_800_1200MV_0DB_SNB_B (0x38<<22) -#define EDP_LINK_TRAIN_VOL_EMP_MASK_SNB (0x3f<<22) +#define EDP_LINK_TRAIN_400_600MV_0DB_SNB_B (0x0<<22) +#define EDP_LINK_TRAIN_400MV_3_5DB_SNB_B (0x1<<22) +#define EDP_LINK_TRAIN_400_600MV_6DB_SNB_B (0x3a<<22) +#define EDP_LINK_TRAIN_600_800MV_3_5DB_SNB_B (0x39<<22) +#define EDP_LINK_TRAIN_800_1200MV_0DB_SNB_B (0x38<<22) +#define EDP_LINK_TRAIN_VOL_EMP_MASK_SNB (0x3f<<22)
/* IVB */ #define EDP_LINK_TRAIN_400MV_0DB_IVB (0x24 <<22) @@ -3716,23 +3716,23 @@ #define EDP_LINK_TRAIN_1000MV_3_5DB_IVB (0x22 <<22) #define EDP_LINK_TRAIN_1000MV_6DB_IVB (0x23 <<22)
-#define EDP_LINK_TRAIN_VOL_EMP_MASK_IVB (0x3f<<22) +#define EDP_LINK_TRAIN_VOL_EMP_MASK_IVB (0x3f<<22)
-#define FORCEWAKE 0xA18C -#define FORCEWAKE_ACK 0x130090 -#define FORCEWAKE_MT 0xa188 /* multi-threaded */ -#define FORCEWAKE_MT_ACK 0x130040 -#define ECOBUS 0xa180 -#define FORCEWAKE_MT_ENABLE (1<<5) +#define FORCEWAKE 0xA18C +#define FORCEWAKE_ACK 0x130090 +#define FORCEWAKE_MT 0xa188 /* multi-threaded */ +#define FORCEWAKE_MT_ACK 0x130040 +#define ECOBUS 0xa180 +#define FORCEWAKE_MT_ENABLE (1<<5)
-#define GTFIFODBG 0x120000 -#define GT_FIFO_CPU_ERROR_MASK 7 -#define GT_FIFO_OVFERR (1<<2) -#define GT_FIFO_IAWRERR (1<<1) -#define GT_FIFO_IARDERR (1<<0) +#define GTFIFODBG 0x120000 +#define GT_FIFO_CPU_ERROR_MASK 7 +#define GT_FIFO_OVFERR (1<<2) +#define GT_FIFO_IAWRERR (1<<1) +#define GT_FIFO_IARDERR (1<<0)
-#define GT_FIFO_FREE_ENTRIES 0x120008 -#define GT_FIFO_NUM_RESERVED_ENTRIES 20 +#define GT_FIFO_FREE_ENTRIES 0x120008 +#define GT_FIFO_NUM_RESERVED_ENTRIES 20
#define GEN6_UCGCTL1 0x9400 # define GEN6_BLBUNIT_CLOCK_GATE_DISABLE (1 << 5) @@ -3743,46 +3743,46 @@ # define GEN6_RCCUNIT_CLOCK_GATE_DISABLE (1 << 11)
#define GEN6_RPNSWREQ 0xA008 -#define GEN6_TURBO_DISABLE (1<<31) -#define GEN6_FREQUENCY(x) ((x)<<25) -#define GEN6_OFFSET(x) ((x)<<19) -#define GEN6_AGGRESSIVE_TURBO (0<<15) +#define GEN6_TURBO_DISABLE (1<<31) +#define GEN6_FREQUENCY(x) ((x)<<25) +#define GEN6_OFFSET(x) ((x)<<19) +#define GEN6_AGGRESSIVE_TURBO (0<<15) #define GEN6_RC_VIDEO_FREQ 0xA00C #define GEN6_RC_CONTROL 0xA090 -#define GEN6_RC_CTL_RC6pp_ENABLE (1<<16) -#define GEN6_RC_CTL_RC6p_ENABLE (1<<17) -#define GEN6_RC_CTL_RC6_ENABLE (1<<18) -#define GEN6_RC_CTL_RC1e_ENABLE (1<<20) -#define GEN6_RC_CTL_RC7_ENABLE (1<<22) -#define GEN6_RC_CTL_EI_MODE(x) ((x)<<27) -#define GEN6_RC_CTL_HW_ENABLE (1<<31) +#define GEN6_RC_CTL_RC6pp_ENABLE (1<<16) +#define GEN6_RC_CTL_RC6p_ENABLE (1<<17) +#define GEN6_RC_CTL_RC6_ENABLE (1<<18) +#define GEN6_RC_CTL_RC1e_ENABLE (1<<20) +#define GEN6_RC_CTL_RC7_ENABLE (1<<22) +#define GEN6_RC_CTL_EI_MODE(x) ((x)<<27) +#define GEN6_RC_CTL_HW_ENABLE (1<<31) #define GEN6_RP_DOWN_TIMEOUT 0xA010 #define GEN6_RP_INTERRUPT_LIMITS 0xA014 #define GEN6_RPSTAT1 0xA01C -#define GEN6_CAGF_SHIFT 8 -#define GEN6_CAGF_MASK (0x7f << GEN6_CAGF_SHIFT) +#define GEN6_CAGF_SHIFT 8 +#define GEN6_CAGF_MASK (0x7f << GEN6_CAGF_SHIFT) #define GEN6_RP_CONTROL 0xA024 -#define GEN6_RP_MEDIA_TURBO (1<<11) -#define GEN6_RP_MEDIA_MODE_MASK (3<<9) -#define GEN6_RP_MEDIA_HW_TURBO_MODE (3<<9) -#define GEN6_RP_MEDIA_HW_NORMAL_MODE (2<<9) -#define GEN6_RP_MEDIA_HW_MODE (1<<9) -#define GEN6_RP_MEDIA_SW_MODE (0<<9) -#define GEN6_RP_MEDIA_IS_GFX (1<<8) -#define GEN6_RP_ENABLE (1<<7) -#define GEN6_RP_UP_IDLE_MIN (0x1<<3) -#define GEN6_RP_UP_BUSY_AVG (0x2<<3) -#define GEN6_RP_UP_BUSY_CONT (0x4<<3) -#define GEN6_RP_DOWN_IDLE_CONT (0x1<<0) +#define GEN6_RP_MEDIA_TURBO (1<<11) +#define GEN6_RP_MEDIA_MODE_MASK (3<<9) +#define GEN6_RP_MEDIA_HW_TURBO_MODE (3<<9) +#define GEN6_RP_MEDIA_HW_NORMAL_MODE (2<<9) +#define GEN6_RP_MEDIA_HW_MODE (1<<9) +#define GEN6_RP_MEDIA_SW_MODE (0<<9) +#define GEN6_RP_MEDIA_IS_GFX (1<<8) +#define GEN6_RP_ENABLE (1<<7) +#define GEN6_RP_UP_IDLE_MIN (0x1<<3) +#define GEN6_RP_UP_BUSY_AVG (0x2<<3) +#define GEN6_RP_UP_BUSY_CONT (0x4<<3) +#define GEN6_RP_DOWN_IDLE_CONT (0x1<<0) #define GEN6_RP_UP_THRESHOLD 0xA02C #define GEN6_RP_DOWN_THRESHOLD 0xA030 #define GEN6_RP_CUR_UP_EI 0xA050 -#define GEN6_CURICONT_MASK 0xffffff +#define GEN6_CURICONT_MASK 0xffffff #define GEN6_RP_CUR_UP 0xA054 -#define GEN6_CURBSYTAVG_MASK 0xffffff +#define GEN6_CURBSYTAVG_MASK 0xffffff #define GEN6_RP_PREV_UP 0xA058 #define GEN6_RP_CUR_DOWN_EI 0xA05C -#define GEN6_CURIAVG_MASK 0xffffff +#define GEN6_CURIAVG_MASK 0xffffff #define GEN6_RP_CUR_DOWN 0xA060 #define GEN6_RP_PREV_DOWN 0xA064 #define GEN6_RP_UP_EI 0xA068 @@ -3805,32 +3805,32 @@ #define GEN6_PMIMR 0x44024 /* rps_lock */ #define GEN6_PMIIR 0x44028 #define GEN6_PMIER 0x4402C -#define GEN6_PM_MBOX_EVENT (1<<25) -#define GEN6_PM_THERMAL_EVENT (1<<24) -#define GEN6_PM_RP_DOWN_TIMEOUT (1<<6) -#define GEN6_PM_RP_UP_THRESHOLD (1<<5) -#define GEN6_PM_RP_DOWN_THRESHOLD (1<<4) -#define GEN6_PM_RP_UP_EI_EXPIRED (1<<2) -#define GEN6_PM_RP_DOWN_EI_EXPIRED (1<<1) -#define GEN6_PM_DEFERRED_EVENTS (GEN6_PM_RP_UP_THRESHOLD | \ +#define GEN6_PM_MBOX_EVENT (1<<25) +#define GEN6_PM_THERMAL_EVENT (1<<24) +#define GEN6_PM_RP_DOWN_TIMEOUT (1<<6) +#define GEN6_PM_RP_UP_THRESHOLD (1<<5) +#define GEN6_PM_RP_DOWN_THRESHOLD (1<<4) +#define GEN6_PM_RP_UP_EI_EXPIRED (1<<2) +#define GEN6_PM_RP_DOWN_EI_EXPIRED (1<<1) +#define GEN6_PM_DEFERRED_EVENTS (GEN6_PM_RP_UP_THRESHOLD | \ GEN6_PM_RP_DOWN_THRESHOLD | \ GEN6_PM_RP_DOWN_TIMEOUT)
#define GEN6_PCODE_MAILBOX 0x138124 -#define GEN6_PCODE_READY (1<<31) -#define GEN6_READ_OC_PARAMS 0xc -#define GEN6_PCODE_WRITE_MIN_FREQ_TABLE 0x8 -#define GEN6_PCODE_READ_MIN_FREQ_TABLE 0x9 +#define GEN6_PCODE_READY (1<<31) +#define GEN6_READ_OC_PARAMS 0xc +#define GEN6_PCODE_WRITE_MIN_FREQ_TABLE 0x8 +#define GEN6_PCODE_READ_MIN_FREQ_TABLE 0x9 #define GEN6_PCODE_DATA 0x138128 -#define GEN6_PCODE_FREQ_IA_RATIO_SHIFT 8 +#define GEN6_PCODE_FREQ_IA_RATIO_SHIFT 8
#define GEN6_GT_CORE_STATUS 0x138060 -#define GEN6_CORE_CPD_STATE_MASK (7<<4) -#define GEN6_RCn_MASK 7 -#define GEN6_RC0 0 -#define GEN6_RC3 2 -#define GEN6_RC6 3 -#define GEN6_RC7 4 +#define GEN6_CORE_CPD_STATE_MASK (7<<4) +#define GEN6_RCn_MASK 7 +#define GEN6_RC0 0 +#define GEN6_RC3 2 +#define GEN6_RC6 3 +#define GEN6_RC7 4
#define G4X_AUD_VID_DID 0x62020 #define INTEL_AUDIO_DEVCL 0x808629FB @@ -3865,14 +3865,14 @@
#define IBX_AUD_CONFIG_A 0xe2000 #define CPT_AUD_CONFIG_A 0xe5000 -#define AUD_CONFIG_N_VALUE_INDEX (1 << 29) -#define AUD_CONFIG_N_PROG_ENABLE (1 << 28) -#define AUD_CONFIG_UPPER_N_SHIFT 20 -#define AUD_CONFIG_UPPER_N_VALUE (0xff << 20) -#define AUD_CONFIG_LOWER_N_SHIFT 4 -#define AUD_CONFIG_LOWER_N_VALUE (0xfff << 4) -#define AUD_CONFIG_PIXEL_CLOCK_HDMI_SHIFT 16 -#define AUD_CONFIG_PIXEL_CLOCK_HDMI (0xf << 16) -#define AUD_CONFIG_DISABLE_NCTS (1 << 3) +#define AUD_CONFIG_N_VALUE_INDEX (1 << 29) +#define AUD_CONFIG_N_PROG_ENABLE (1 << 28) +#define AUD_CONFIG_UPPER_N_SHIFT 20 +#define AUD_CONFIG_UPPER_N_VALUE (0xff << 20) +#define AUD_CONFIG_LOWER_N_SHIFT 4 +#define AUD_CONFIG_LOWER_N_VALUE (0xfff << 4) +#define AUD_CONFIG_PIXEL_CLOCK_HDMI_SHIFT 16 +#define AUD_CONFIG_PIXEL_CLOCK_HDMI (0xf << 16) +#define AUD_CONFIG_DISABLE_NCTS (1 << 3)
#endif /* _I915_REG_H_ */ diff --git a/src/mainboard/google/stout/fadt.c b/src/mainboard/google/stout/fadt.c index 5ce9ab1..49acb88 100644 --- a/src/mainboard/google/stout/fadt.c +++ b/src/mainboard/google/stout/fadt.c @@ -26,11 +26,11 @@ * code and the mainboard fadt. */ #define APM_CNT 0xb2 -#define CST_CONTROL 0x85 -#define PST_CONTROL 0x80 -#define ACPI_DISABLE 0x1e -#define ACPI_ENABLE 0xe1 -#define GNVS_UPDATE 0xea +#define CST_CONTROL 0x85 +#define PST_CONTROL 0x80 +#define ACPI_DISABLE 0x1e +#define ACPI_ENABLE 0xe1 +#define GNVS_UPDATE 0xea
void acpi_create_fadt(acpi_fadt_t * fadt, acpi_facs_t * facs, void *dsdt) { diff --git a/src/mainboard/google/stout/i915_reg.h b/src/mainboard/google/stout/i915_reg.h index 11c198a..4509127 100644 --- a/src/mainboard/google/stout/i915_reg.h +++ b/src/mainboard/google/stout/i915_reg.h @@ -39,65 +39,65 @@ /* PCI config space */
#define HPLLCC 0xc0 /* 855 only */ -#define GC_CLOCK_CONTROL_MASK (0xf << 0) -#define GC_CLOCK_133_200 (0 << 0) -#define GC_CLOCK_100_200 (1 << 0) -#define GC_CLOCK_100_133 (2 << 0) -#define GC_CLOCK_166_250 (3 << 0) +#define GC_CLOCK_CONTROL_MASK (0xf << 0) +#define GC_CLOCK_133_200 (0 << 0) +#define GC_CLOCK_100_200 (1 << 0) +#define GC_CLOCK_100_133 (2 << 0) +#define GC_CLOCK_166_250 (3 << 0) #define GCFGC2 0xda #define GCFGC 0xf0 /* 915+ only */ -#define GC_LOW_FREQUENCY_ENABLE (1 << 7) -#define GC_DISPLAY_CLOCK_190_200_MHZ (0 << 4) -#define GC_DISPLAY_CLOCK_333_MHZ (4 << 4) -#define GC_DISPLAY_CLOCK_MASK (7 << 4) -#define GM45_GC_RENDER_CLOCK_MASK (0xf << 0) -#define GM45_GC_RENDER_CLOCK_266_MHZ (8 << 0) -#define GM45_GC_RENDER_CLOCK_320_MHZ (9 << 0) -#define GM45_GC_RENDER_CLOCK_400_MHZ (0xb << 0) -#define GM45_GC_RENDER_CLOCK_533_MHZ (0xc << 0) -#define I965_GC_RENDER_CLOCK_MASK (0xf << 0) -#define I965_GC_RENDER_CLOCK_267_MHZ (2 << 0) -#define I965_GC_RENDER_CLOCK_333_MHZ (3 << 0) -#define I965_GC_RENDER_CLOCK_444_MHZ (4 << 0) -#define I965_GC_RENDER_CLOCK_533_MHZ (5 << 0) -#define I945_GC_RENDER_CLOCK_MASK (7 << 0) -#define I945_GC_RENDER_CLOCK_166_MHZ (0 << 0) -#define I945_GC_RENDER_CLOCK_200_MHZ (1 << 0) -#define I945_GC_RENDER_CLOCK_250_MHZ (3 << 0) -#define I945_GC_RENDER_CLOCK_400_MHZ (5 << 0) -#define I915_GC_RENDER_CLOCK_MASK (7 << 0) -#define I915_GC_RENDER_CLOCK_166_MHZ (0 << 0) -#define I915_GC_RENDER_CLOCK_200_MHZ (1 << 0) -#define I915_GC_RENDER_CLOCK_333_MHZ (4 << 0) +#define GC_LOW_FREQUENCY_ENABLE (1 << 7) +#define GC_DISPLAY_CLOCK_190_200_MHZ (0 << 4) +#define GC_DISPLAY_CLOCK_333_MHZ (4 << 4) +#define GC_DISPLAY_CLOCK_MASK (7 << 4) +#define GM45_GC_RENDER_CLOCK_MASK (0xf << 0) +#define GM45_GC_RENDER_CLOCK_266_MHZ (8 << 0) +#define GM45_GC_RENDER_CLOCK_320_MHZ (9 << 0) +#define GM45_GC_RENDER_CLOCK_400_MHZ (0xb << 0) +#define GM45_GC_RENDER_CLOCK_533_MHZ (0xc << 0) +#define I965_GC_RENDER_CLOCK_MASK (0xf << 0) +#define I965_GC_RENDER_CLOCK_267_MHZ (2 << 0) +#define I965_GC_RENDER_CLOCK_333_MHZ (3 << 0) +#define I965_GC_RENDER_CLOCK_444_MHZ (4 << 0) +#define I965_GC_RENDER_CLOCK_533_MHZ (5 << 0) +#define I945_GC_RENDER_CLOCK_MASK (7 << 0) +#define I945_GC_RENDER_CLOCK_166_MHZ (0 << 0) +#define I945_GC_RENDER_CLOCK_200_MHZ (1 << 0) +#define I945_GC_RENDER_CLOCK_250_MHZ (3 << 0) +#define I945_GC_RENDER_CLOCK_400_MHZ (5 << 0) +#define I915_GC_RENDER_CLOCK_MASK (7 << 0) +#define I915_GC_RENDER_CLOCK_166_MHZ (0 << 0) +#define I915_GC_RENDER_CLOCK_200_MHZ (1 << 0) +#define I915_GC_RENDER_CLOCK_333_MHZ (4 << 0) #define LBB 0xf4
/* Graphics reset regs */ #define I965_GDRST 0xc0 /* PCI config register */ #define ILK_GDSR 0x2ca4 /* MCHBAR offset */ -#define GRDOM_FULL (0<<2) -#define GRDOM_RENDER (1<<2) -#define GRDOM_MEDIA (3<<2) +#define GRDOM_FULL (0<<2) +#define GRDOM_RENDER (1<<2) +#define GRDOM_MEDIA (3<<2)
#define GEN6_MBCUNIT_SNPCR 0x900c /* for LLC config */ -#define GEN6_MBC_SNPCR_SHIFT 21 -#define GEN6_MBC_SNPCR_MASK (3<<21) -#define GEN6_MBC_SNPCR_MAX (0<<21) -#define GEN6_MBC_SNPCR_MED (1<<21) -#define GEN6_MBC_SNPCR_LOW (2<<21) -#define GEN6_MBC_SNPCR_MIN (3<<21) /* only 1/16th of the cache is shared */ +#define GEN6_MBC_SNPCR_SHIFT 21 +#define GEN6_MBC_SNPCR_MASK (3<<21) +#define GEN6_MBC_SNPCR_MAX (0<<21) +#define GEN6_MBC_SNPCR_MED (1<<21) +#define GEN6_MBC_SNPCR_LOW (2<<21) +#define GEN6_MBC_SNPCR_MIN (3<<21) /* only 1/16th of the cache is shared */
#define GEN6_MBCTL 0x0907c -#define GEN6_MBCTL_ENABLE_BOOT_FETCH (1 << 4) -#define GEN6_MBCTL_CTX_FETCH_NEEDED (1 << 3) -#define GEN6_MBCTL_BME_UPDATE_ENABLE (1 << 2) -#define GEN6_MBCTL_MAE_UPDATE_ENABLE (1 << 1) -#define GEN6_MBCTL_BOOT_FETCH_MECH (1 << 0) +#define GEN6_MBCTL_ENABLE_BOOT_FETCH (1 << 4) +#define GEN6_MBCTL_CTX_FETCH_NEEDED (1 << 3) +#define GEN6_MBCTL_BME_UPDATE_ENABLE (1 << 2) +#define GEN6_MBCTL_MAE_UPDATE_ENABLE (1 << 1) +#define GEN6_MBCTL_BOOT_FETCH_MECH (1 << 0)
#define GEN6_GDRST 0x941c -#define GEN6_GRDOM_FULL (1 << 0) -#define GEN6_GRDOM_RENDER (1 << 1) -#define GEN6_GRDOM_MEDIA (1 << 2) -#define GEN6_GRDOM_BLT (1 << 3) +#define GEN6_GRDOM_FULL (1 << 0) +#define GEN6_GRDOM_RENDER (1 << 1) +#define GEN6_GRDOM_MEDIA (1 << 2) +#define GEN6_GRDOM_BLT (1 << 3)
/* PPGTT stuff */ #define GEN6_GTT_ADDR_ENCODE(addr) ((addr) | (((addr) >> 28) & 0xff0)) @@ -118,12 +118,12 @@ #define RING_PP_DIR_BASE(ring) ((ring)->mmio_base+0x228) #define RING_PP_DIR_BASE_READ(ring) ((ring)->mmio_base+0x518) #define RING_PP_DIR_DCLV(ring) ((ring)->mmio_base+0x220) -#define PP_DIR_DCLV_2G 0xffffffff +#define PP_DIR_DCLV_2G 0xffffffff
#define GAM_ECOCHK 0x4090 -#define ECOCHK_SNB_BIT (1<<10) -#define ECOCHK_PPGTT_CACHE64B (0x3<<3) -#define ECOCHK_PPGTT_CACHE4B (0x0<<3) +#define ECOCHK_SNB_BIT (1<<10) +#define ECOCHK_PPGTT_CACHE64B (0x3<<3) +#define ECOCHK_PPGTT_CACHE4B (0x0<<3)
/* VGA stuff */
@@ -132,29 +132,29 @@
#define VGA_MSR_WRITE 0x3c2 #define VGA_MSR_READ 0x3cc -#define VGA_MSR_MEM_EN (1<<1) -#define VGA_MSR_CGA_MODE (1<<0) +#define VGA_MSR_MEM_EN (1<<1) +#define VGA_MSR_CGA_MODE (1<<0)
#define VGA_SR_INDEX 0x3c4 #define VGA_SR_DATA 0x3c5
#define VGA_AR_INDEX 0x3c0 -#define VGA_AR_VID_EN (1<<5) +#define VGA_AR_VID_EN (1<<5) #define VGA_AR_DATA_WRITE 0x3c0 #define VGA_AR_DATA_READ 0x3c1
#define VGA_GR_INDEX 0x3ce #define VGA_GR_DATA 0x3cf /* GR05 */ -#define VGA_GR_MEM_READ_MODE_SHIFT 3 -#define VGA_GR_MEM_READ_MODE_PLANE 1 +#define VGA_GR_MEM_READ_MODE_SHIFT 3 +#define VGA_GR_MEM_READ_MODE_PLANE 1 /* GR06 */ -#define VGA_GR_MEM_MODE_MASK 0xc -#define VGA_GR_MEM_MODE_SHIFT 2 -#define VGA_GR_MEM_A0000_AFFFF 0 -#define VGA_GR_MEM_A0000_BFFFF 1 -#define VGA_GR_MEM_B0000_B7FFF 2 -#define VGA_GR_MEM_B0000_BFFFF 3 +#define VGA_GR_MEM_MODE_MASK 0xc +#define VGA_GR_MEM_MODE_SHIFT 2 +#define VGA_GR_MEM_A0000_AFFFF 0 +#define VGA_GR_MEM_A0000_BFFFF 1 +#define VGA_GR_MEM_B0000_B7FFF 2 +#define VGA_GR_MEM_B0000_BFFFF 3
#define VGA_DACMASK 0x3c6 #define VGA_DACRX 0x3c7 @@ -174,40 +174,40 @@ #define MI_NOOP MI_INSTR(0, 0) #define MI_USER_INTERRUPT MI_INSTR(0x02, 0) #define MI_WAIT_FOR_EVENT MI_INSTR(0x03, 0) -#define MI_WAIT_FOR_OVERLAY_FLIP (1<<16) -#define MI_WAIT_FOR_PLANE_B_FLIP (1<<6) -#define MI_WAIT_FOR_PLANE_A_FLIP (1<<2) -#define MI_WAIT_FOR_PLANE_A_SCANLINES (1<<1) +#define MI_WAIT_FOR_OVERLAY_FLIP (1<<16) +#define MI_WAIT_FOR_PLANE_B_FLIP (1<<6) +#define MI_WAIT_FOR_PLANE_A_FLIP (1<<2) +#define MI_WAIT_FOR_PLANE_A_SCANLINES (1<<1) #define MI_FLUSH MI_INSTR(0x04, 0) -#define MI_READ_FLUSH (1 << 0) -#define MI_EXE_FLUSH (1 << 1) -#define MI_NO_WRITE_FLUSH (1 << 2) -#define MI_SCENE_COUNT (1 << 3) /* just increment scene count */ -#define MI_END_SCENE (1 << 4) /* flush binner and incr scene count */ -#define MI_INVALIDATE_ISP (1 << 5) /* invalidate indirect state pointers */ +#define MI_READ_FLUSH (1 << 0) +#define MI_EXE_FLUSH (1 << 1) +#define MI_NO_WRITE_FLUSH (1 << 2) +#define MI_SCENE_COUNT (1 << 3) /* just increment scene count */ +#define MI_END_SCENE (1 << 4) /* flush binner and incr scene count */ +#define MI_INVALIDATE_ISP (1 << 5) /* invalidate indirect state pointers */ #define MI_BATCH_BUFFER_END MI_INSTR(0x0a, 0) #define MI_SUSPEND_FLUSH MI_INSTR(0x0b, 0) -#define MI_SUSPEND_FLUSH_EN (1<<0) +#define MI_SUSPEND_FLUSH_EN (1<<0) #define MI_REPORT_HEAD MI_INSTR(0x07, 0) #define MI_OVERLAY_FLIP MI_INSTR(0x11, 0) -#define MI_OVERLAY_CONTINUE (0x0<<21) -#define MI_OVERLAY_ON (0x1<<21) -#define MI_OVERLAY_OFF (0x2<<21) +#define MI_OVERLAY_CONTINUE (0x0<<21) +#define MI_OVERLAY_ON (0x1<<21) +#define MI_OVERLAY_OFF (0x2<<21) #define MI_LOAD_SCAN_LINES_INCL MI_INSTR(0x12, 0) #define MI_DISPLAY_FLIP MI_INSTR(0x14, 2) #define MI_DISPLAY_FLIP_I915 MI_INSTR(0x14, 1) -#define MI_DISPLAY_FLIP_PLANE(n) ((n) << 20) +#define MI_DISPLAY_FLIP_PLANE(n) ((n) << 20) #define MI_SET_CONTEXT MI_INSTR(0x18, 0) -#define MI_MM_SPACE_GTT (1<<8) -#define MI_MM_SPACE_PHYSICAL (0<<8) -#define MI_SAVE_EXT_STATE_EN (1<<3) -#define MI_RESTORE_EXT_STATE_EN (1<<2) -#define MI_FORCE_RESTORE (1<<1) -#define MI_RESTORE_INHIBIT (1<<0) +#define MI_MM_SPACE_GTT (1<<8) +#define MI_MM_SPACE_PHYSICAL (0<<8) +#define MI_SAVE_EXT_STATE_EN (1<<3) +#define MI_RESTORE_EXT_STATE_EN (1<<2) +#define MI_FORCE_RESTORE (1<<1) +#define MI_RESTORE_INHIBIT (1<<0) #define MI_STORE_DWORD_IMM MI_INSTR(0x20, 1) -#define MI_MEM_VIRTUAL (1 << 22) /* 965+ only */ +#define MI_MEM_VIRTUAL (1 << 22) /* 965+ only */ #define MI_STORE_DWORD_INDEX MI_INSTR(0x21, 1) -#define MI_STORE_DWORD_INDEX_SHIFT 2 +#define MI_STORE_DWORD_INDEX_SHIFT 2 /* Official intel docs are somewhat sloppy concerning MI_LOAD_REGISTER_IMM: * - Always issue a MI_NOOP _before_ the MI_LOAD_REGISTER_IMM - otherwise hw * simply ignores the register load under certain conditions. @@ -216,24 +216,24 @@ */ #define MI_LOAD_REGISTER_IMM(x) MI_INSTR(0x22, 2*x-1) #define MI_FLUSH_DW MI_INSTR(0x26, 1) /* for GEN6 */ -#define MI_INVALIDATE_TLB (1<<18) -#define MI_INVALIDATE_BSD (1<<7) +#define MI_INVALIDATE_TLB (1<<18) +#define MI_INVALIDATE_BSD (1<<7) #define MI_BATCH_BUFFER MI_INSTR(0x30, 1) -#define MI_BATCH_NON_SECURE (1) -#define MI_BATCH_NON_SECURE_I965 (1<<8) +#define MI_BATCH_NON_SECURE (1) +#define MI_BATCH_NON_SECURE_I965 (1<<8) #define MI_BATCH_BUFFER_START MI_INSTR(0x31, 0) #define MI_SEMAPHORE_MBOX MI_INSTR(0x16, 1) /* gen6+ */ -#define MI_SEMAPHORE_GLOBAL_GTT (1<<22) -#define MI_SEMAPHORE_UPDATE (1<<21) -#define MI_SEMAPHORE_COMPARE (1<<20) -#define MI_SEMAPHORE_REGISTER (1<<18) -#define MI_SEMAPHORE_SYNC_RV (2<<16) -#define MI_SEMAPHORE_SYNC_RB (0<<16) -#define MI_SEMAPHORE_SYNC_VR (0<<16) -#define MI_SEMAPHORE_SYNC_VB (2<<16) -#define MI_SEMAPHORE_SYNC_BR (2<<16) -#define MI_SEMAPHORE_SYNC_BV (0<<16) -#define MI_SEMAPHORE_SYNC_INVALID (1<<0) +#define MI_SEMAPHORE_GLOBAL_GTT (1<<22) +#define MI_SEMAPHORE_UPDATE (1<<21) +#define MI_SEMAPHORE_COMPARE (1<<20) +#define MI_SEMAPHORE_REGISTER (1<<18) +#define MI_SEMAPHORE_SYNC_RV (2<<16) +#define MI_SEMAPHORE_SYNC_RB (0<<16) +#define MI_SEMAPHORE_SYNC_VR (0<<16) +#define MI_SEMAPHORE_SYNC_VB (2<<16) +#define MI_SEMAPHORE_SYNC_BR (2<<16) +#define MI_SEMAPHORE_SYNC_BV (0<<16) +#define MI_SEMAPHORE_SYNC_INVALID (1<<0) /* * 3D instructions used by the kernel */ @@ -241,15 +241,15 @@
#define GFX_OP_RASTER_RULES ((0x3<<29)|(0x7<<24)) #define GFX_OP_SCISSOR ((0x3<<29)|(0x1c<<24)|(0x10<<19)) -#define SC_UPDATE_SCISSOR (0x1<<1) -#define SC_ENABLE_MASK (0x1<<0) -#define SC_ENABLE (0x1<<0) +#define SC_UPDATE_SCISSOR (0x1<<1) +#define SC_ENABLE_MASK (0x1<<0) +#define SC_ENABLE (0x1<<0) #define GFX_OP_LOAD_INDIRECT ((0x3<<29)|(0x1d<<24)|(0x7<<16)) #define GFX_OP_SCISSOR_INFO ((0x3<<29)|(0x1d<<24)|(0x81<<16)|(0x1)) -#define SCI_YMIN_MASK (0xffff<<16) -#define SCI_XMIN_MASK (0xffff<<0) -#define SCI_YMAX_MASK (0xffff<<16) -#define SCI_XMAX_MASK (0xffff<<0) +#define SCI_YMIN_MASK (0xffff<<16) +#define SCI_XMIN_MASK (0xffff<<0) +#define SCI_YMAX_MASK (0xffff<<16) +#define SCI_XMAX_MASK (0xffff<<0) #define GFX_OP_SCISSOR_ENABLE ((0x3<<29)|(0x1c<<24)|(0x10<<19)) #define GFX_OP_SCISSOR_RECT ((0x3<<29)|(0x1d<<24)|(0x81<<16)|1) #define GFX_OP_COLOR_FACTOR ((0x3<<29)|(0x1d<<24)|(0x1<<16)|0x0) @@ -264,42 +264,42 @@ #define XY_MONO_SRC_COPY_IMM_BLT ((2<<29)|(0x71<<22)|5) #define XY_SRC_COPY_BLT_WRITE_ALPHA (1<<21) #define XY_SRC_COPY_BLT_WRITE_RGB (1<<20) -#define BLT_DEPTH_8 (0<<24) -#define BLT_DEPTH_16_565 (1<<24) -#define BLT_DEPTH_16_1555 (2<<24) -#define BLT_DEPTH_32 (3<<24) -#define BLT_ROP_GXCOPY (0xcc<<16) +#define BLT_DEPTH_8 (0<<24) +#define BLT_DEPTH_16_565 (1<<24) +#define BLT_DEPTH_16_1555 (2<<24) +#define BLT_DEPTH_32 (3<<24) +#define BLT_ROP_GXCOPY (0xcc<<16) #define XY_SRC_COPY_BLT_SRC_TILED (1<<15) /* 965+ only */ #define XY_SRC_COPY_BLT_DST_TILED (1<<11) /* 965+ only */ #define CMD_OP_DISPLAYBUFFER_INFO ((0x0<<29)|(0x14<<23)|2) -#define ASYNC_FLIP (1<<22) -#define DISPLAY_PLANE_A (0<<20) -#define DISPLAY_PLANE_B (1<<20) +#define ASYNC_FLIP (1<<22) +#define DISPLAY_PLANE_A (0<<20) +#define DISPLAY_PLANE_B (1<<20) #define GFX_OP_PIPE_CONTROL(len) ((0x3<<29)|(0x3<<27)|(0x2<<24)|(len-2)) -#define PIPE_CONTROL_CS_STALL (1<<20) -#define PIPE_CONTROL_QW_WRITE (1<<14) -#define PIPE_CONTROL_DEPTH_STALL (1<<13) -#define PIPE_CONTROL_WRITE_FLUSH (1<<12) -#define PIPE_CONTROL_RENDER_TARGET_CACHE_FLUSH (1<<12) /* gen6+ */ -#define PIPE_CONTROL_INSTRUCTION_CACHE_INVALIDATE (1<<11) /* MBZ on Ironlake */ -#define PIPE_CONTROL_TEXTURE_CACHE_INVALIDATE (1<<10) /* GM45+ only */ -#define PIPE_CONTROL_INDIRECT_STATE_DISABLE (1<<9) -#define PIPE_CONTROL_NOTIFY (1<<8) -#define PIPE_CONTROL_VF_CACHE_INVALIDATE (1<<4) -#define PIPE_CONTROL_CONST_CACHE_INVALIDATE (1<<3) -#define PIPE_CONTROL_STATE_CACHE_INVALIDATE (1<<2) -#define PIPE_CONTROL_STALL_AT_SCOREBOARD (1<<1) -#define PIPE_CONTROL_DEPTH_CACHE_FLUSH (1<<0) -#define PIPE_CONTROL_GLOBAL_GTT (1<<2) /* in addr dword */ +#define PIPE_CONTROL_CS_STALL (1<<20) +#define PIPE_CONTROL_QW_WRITE (1<<14) +#define PIPE_CONTROL_DEPTH_STALL (1<<13) +#define PIPE_CONTROL_WRITE_FLUSH (1<<12) +#define PIPE_CONTROL_RENDER_TARGET_CACHE_FLUSH (1<<12) /* gen6+ */ +#define PIPE_CONTROL_INSTRUCTION_CACHE_INVALIDATE (1<<11) /* MBZ on Ironlake */ +#define PIPE_CONTROL_TEXTURE_CACHE_INVALIDATE (1<<10) /* GM45+ only */ +#define PIPE_CONTROL_INDIRECT_STATE_DISABLE (1<<9) +#define PIPE_CONTROL_NOTIFY (1<<8) +#define PIPE_CONTROL_VF_CACHE_INVALIDATE (1<<4) +#define PIPE_CONTROL_CONST_CACHE_INVALIDATE (1<<3) +#define PIPE_CONTROL_STATE_CACHE_INVALIDATE (1<<2) +#define PIPE_CONTROL_STALL_AT_SCOREBOARD (1<<1) +#define PIPE_CONTROL_DEPTH_CACHE_FLUSH (1<<0) +#define PIPE_CONTROL_GLOBAL_GTT (1<<2) /* in addr dword */
/* * Reset registers */ #define DEBUG_RESET_I830 0x6070 -#define DEBUG_RESET_FULL (1<<7) -#define DEBUG_RESET_RENDER (1<<8) -#define DEBUG_RESET_DISPLAY (1<<9) +#define DEBUG_RESET_FULL (1<<7) +#define DEBUG_RESET_RENDER (1<<8) +#define DEBUG_RESET_DISPLAY (1<<9)
/* @@ -307,32 +307,32 @@ */ #define FENCE_REG_830_0 0x2000 #define FENCE_REG_945_8 0x3000 -#define I830_FENCE_START_MASK 0x07f80000 -#define I830_FENCE_TILING_Y_SHIFT 12 -#define I830_FENCE_SIZE_BITS(size) ((ffs((size) >> 19) - 1) << 8) -#define I830_FENCE_PITCH_SHIFT 4 -#define I830_FENCE_REG_VALID (1<<0) -#define I915_FENCE_MAX_PITCH_VAL 4 -#define I830_FENCE_MAX_PITCH_VAL 6 -#define I830_FENCE_MAX_SIZE_VAL (1<<8) - -#define I915_FENCE_START_MASK 0x0ff00000 -#define I915_FENCE_SIZE_BITS(size) ((ffs((size) >> 20) - 1) << 8) +#define I830_FENCE_START_MASK 0x07f80000 +#define I830_FENCE_TILING_Y_SHIFT 12 +#define I830_FENCE_SIZE_BITS(size) ((ffs((size) >> 19) - 1) << 8) +#define I830_FENCE_PITCH_SHIFT 4 +#define I830_FENCE_REG_VALID (1<<0) +#define I915_FENCE_MAX_PITCH_VAL 4 +#define I830_FENCE_MAX_PITCH_VAL 6 +#define I830_FENCE_MAX_SIZE_VAL (1<<8) + +#define I915_FENCE_START_MASK 0x0ff00000 +#define I915_FENCE_SIZE_BITS(size) ((ffs((size) >> 20) - 1) << 8)
#define FENCE_REG_965_0 0x03000 -#define I965_FENCE_PITCH_SHIFT 2 -#define I965_FENCE_TILING_Y_SHIFT 1 -#define I965_FENCE_REG_VALID (1<<0) -#define I965_FENCE_MAX_PITCH_VAL 0x0400 +#define I965_FENCE_PITCH_SHIFT 2 +#define I965_FENCE_TILING_Y_SHIFT 1 +#define I965_FENCE_REG_VALID (1<<0) +#define I965_FENCE_MAX_PITCH_VAL 0x0400
#define FENCE_REG_SANDYBRIDGE_0 0x100000 -#define SANDYBRIDGE_FENCE_PITCH_SHIFT 32 +#define SANDYBRIDGE_FENCE_PITCH_SHIFT 32
/* control register for cpu gtt access */ #define TILECTL 0x101000 -#define TILECTL_SWZCTL (1 << 0) -#define TILECTL_TLB_PREFETCH_DIS (1 << 2) -#define TILECTL_BACKSNOOP_DIS (1 << 3) +#define TILECTL_SWZCTL (1 << 0) +#define TILECTL_TLB_PREFETCH_DIS (1 << 2) +#define TILECTL_BACKSNOOP_DIS (1 << 3)
/* * Instruction and interrupt control regs @@ -358,10 +358,10 @@ #define RING_HWS_PGA(base) ((base)+0x80) #define RING_HWS_PGA_GEN6(base) ((base)+0x2080) #define ARB_MODE 0x04030 -#define ARB_MODE_SWIZZLE_SNB (1<<4) -#define ARB_MODE_SWIZZLE_IVB (1<<5) -#define ARB_MODE_ENABLE(x) GFX_MODE_ENABLE(x) -#define ARB_MODE_DISABLE(x) GFX_MODE_DISABLE(x) +#define ARB_MODE_SWIZZLE_SNB (1<<4) +#define ARB_MODE_SWIZZLE_IVB (1<<5) +#define ARB_MODE_ENABLE(x) GFX_MODE_ENABLE(x) +#define ARB_MODE_DISABLE(x) GFX_MODE_DISABLE(x) #define RENDER_HWS_PGA_GEN7 (0x04080) #define RING_FAULT_REG(ring) (0x4094 + 0x100*(ring)->id) #define DONE_REG 0x40b0 @@ -370,21 +370,21 @@ #define RING_ACTHD(base) ((base)+0x74) #define RING_NOPID(base) ((base)+0x94) #define RING_IMR(base) ((base)+0xa8) -#define TAIL_ADDR 0x001FFFF8 -#define HEAD_WRAP_COUNT 0xFFE00000 -#define HEAD_WRAP_ONE 0x00200000 -#define HEAD_ADDR 0x001FFFFC -#define RING_NR_PAGES 0x001FF000 -#define RING_REPORT_MASK 0x00000006 -#define RING_REPORT_64K 0x00000002 -#define RING_REPORT_128K 0x00000004 -#define RING_NO_REPORT 0x00000000 -#define RING_VALID_MASK 0x00000001 -#define RING_VALID 0x00000001 -#define RING_INVALID 0x00000000 -#define RING_WAIT_I8XX (1<<0) /* gen2, PRBx_HEAD */ -#define RING_WAIT (1<<11) /* gen3+, PRBx_CTL */ -#define RING_WAIT_SEMAPHORE (1<<10) /* gen6+ */ +#define TAIL_ADDR 0x001FFFF8 +#define HEAD_WRAP_COUNT 0xFFE00000 +#define HEAD_WRAP_ONE 0x00200000 +#define HEAD_ADDR 0x001FFFFC +#define RING_NR_PAGES 0x001FF000 +#define RING_REPORT_MASK 0x00000006 +#define RING_REPORT_64K 0x00000002 +#define RING_REPORT_128K 0x00000004 +#define RING_NO_REPORT 0x00000000 +#define RING_VALID_MASK 0x00000001 +#define RING_VALID 0x00000001 +#define RING_INVALID 0x00000000 +#define RING_WAIT_I8XX (1<<0) /* gen2, PRBx_HEAD */ +#define RING_WAIT (1<<11) /* gen3+, PRBx_CTL */ +#define RING_WAIT_SEMAPHORE (1<<10) /* gen6+ */ #define PRB0_TAIL 0x02030 #define PRB0_HEAD 0x02034 #define PRB0_START 0x02038 @@ -411,7 +411,7 @@ #define HWS_ADDRESS_MASK 0xfffff000 #define HWS_START_ADDRESS_SHIFT 4 #define PWRCTXA 0x2088 /* 965GM+ only */ -#define PWRCTX_EN (1<<0) +#define PWRCTX_EN (1<<0) #define IPEIR 0x02088 #define IPEHR 0x0208c #define INSTDONE 0x02090 @@ -440,12 +440,12 @@ #define GFX_MODE 0x02520 #define GFX_MODE_GEN7 0x0229c #define RING_MODE_GEN7(ring) ((ring)->mmio_base+0x29c) -#define GFX_RUN_LIST_ENABLE (1<<15) -#define GFX_TLB_INVALIDATE_ALWAYS (1<<13) -#define GFX_SURFACE_FAULT_ENABLE (1<<12) -#define GFX_REPLAY_MODE (1<<11) -#define GFX_PSMI_GRANULARITY (1<<10) -#define GFX_PPGTT_ENABLE (1<<9) +#define GFX_RUN_LIST_ENABLE (1<<15) +#define GFX_TLB_INVALIDATE_ALWAYS (1<<13) +#define GFX_SURFACE_FAULT_ENABLE (1<<12) +#define GFX_REPLAY_MODE (1<<11) +#define GFX_PSMI_GRANULARITY (1<<10) +#define GFX_PPGTT_ENABLE (1<<9)
#define GFX_MODE_ENABLE(bit) (((bit) << 16) | (bit)) #define GFX_MODE_DISABLE(bit) (((bit) << 16) | (0)) @@ -455,163 +455,163 @@ #define IIR 0x020a4 #define IMR 0x020a8 #define ISR 0x020ac -#define I915_PIPE_CONTROL_NOTIFY_INTERRUPT (1<<18) -#define I915_DISPLAY_PORT_INTERRUPT (1<<17) -#define I915_RENDER_COMMAND_PARSER_ERROR_INTERRUPT (1<<15) -#define I915_GMCH_THERMAL_SENSOR_EVENT_INTERRUPT (1<<14) /* p-state */ -#define I915_HWB_OOM_INTERRUPT (1<<13) -#define I915_SYNC_STATUS_INTERRUPT (1<<12) -#define I915_DISPLAY_PLANE_A_FLIP_PENDING_INTERRUPT (1<<11) -#define I915_DISPLAY_PLANE_B_FLIP_PENDING_INTERRUPT (1<<10) -#define I915_OVERLAY_PLANE_FLIP_PENDING_INTERRUPT (1<<9) -#define I915_DISPLAY_PLANE_C_FLIP_PENDING_INTERRUPT (1<<8) -#define I915_DISPLAY_PIPE_A_VBLANK_INTERRUPT (1<<7) -#define I915_DISPLAY_PIPE_A_EVENT_INTERRUPT (1<<6) -#define I915_DISPLAY_PIPE_B_VBLANK_INTERRUPT (1<<5) -#define I915_DISPLAY_PIPE_B_EVENT_INTERRUPT (1<<4) -#define I915_DEBUG_INTERRUPT (1<<2) -#define I915_USER_INTERRUPT (1<<1) -#define I915_ASLE_INTERRUPT (1<<0) -#define I915_BSD_USER_INTERRUPT (1<<25) +#define I915_PIPE_CONTROL_NOTIFY_INTERRUPT (1<<18) +#define I915_DISPLAY_PORT_INTERRUPT (1<<17) +#define I915_RENDER_COMMAND_PARSER_ERROR_INTERRUPT (1<<15) +#define I915_GMCH_THERMAL_SENSOR_EVENT_INTERRUPT (1<<14) /* p-state */ +#define I915_HWB_OOM_INTERRUPT (1<<13) +#define I915_SYNC_STATUS_INTERRUPT (1<<12) +#define I915_DISPLAY_PLANE_A_FLIP_PENDING_INTERRUPT (1<<11) +#define I915_DISPLAY_PLANE_B_FLIP_PENDING_INTERRUPT (1<<10) +#define I915_OVERLAY_PLANE_FLIP_PENDING_INTERRUPT (1<<9) +#define I915_DISPLAY_PLANE_C_FLIP_PENDING_INTERRUPT (1<<8) +#define I915_DISPLAY_PIPE_A_VBLANK_INTERRUPT (1<<7) +#define I915_DISPLAY_PIPE_A_EVENT_INTERRUPT (1<<6) +#define I915_DISPLAY_PIPE_B_VBLANK_INTERRUPT (1<<5) +#define I915_DISPLAY_PIPE_B_EVENT_INTERRUPT (1<<4) +#define I915_DEBUG_INTERRUPT (1<<2) +#define I915_USER_INTERRUPT (1<<1) +#define I915_ASLE_INTERRUPT (1<<0) +#define I915_BSD_USER_INTERRUPT (1<<25) #define EIR 0x020b0 #define EMR 0x020b4 #define ESR 0x020b8 -#define GM45_ERROR_PAGE_TABLE (1<<5) -#define GM45_ERROR_MEM_PRIV (1<<4) -#define I915_ERROR_PAGE_TABLE (1<<4) -#define GM45_ERROR_CP_PRIV (1<<3) -#define I915_ERROR_MEMORY_REFRESH (1<<1) -#define I915_ERROR_INSTRUCTION (1<<0) +#define GM45_ERROR_PAGE_TABLE (1<<5) +#define GM45_ERROR_MEM_PRIV (1<<4) +#define I915_ERROR_PAGE_TABLE (1<<4) +#define GM45_ERROR_CP_PRIV (1<<3) +#define I915_ERROR_MEMORY_REFRESH (1<<1) +#define I915_ERROR_INSTRUCTION (1<<0) #define INSTPM 0x020c0 -#define INSTPM_SELF_EN (1<<12) /* 915GM only */ -#define INSTPM_AGPBUSY_DIS (1<<11) /* gen3: when disabled, pending interrupts +#define INSTPM_SELF_EN (1<<12) /* 915GM only */ +#define INSTPM_AGPBUSY_DIS (1<<11) /* gen3: when disabled, pending interrupts will not assert AGPBUSY# and will only be delivered when out of C3. */ -#define INSTPM_FORCE_ORDERING (1<<7) /* GEN6+ */ +#define INSTPM_FORCE_ORDERING (1<<7) /* GEN6+ */ #define ACTHD 0x020c8 #define FW_BLC 0x020d8 #define FW_BLC2 0x020dc #define FW_BLC_SELF 0x020e0 /* 915+ only */ -#define FW_BLC_SELF_EN_MASK (1<<31) -#define FW_BLC_SELF_FIFO_MASK (1<<16) /* 945 only */ -#define FW_BLC_SELF_EN (1<<15) /* 945 only */ +#define FW_BLC_SELF_EN_MASK (1<<31) +#define FW_BLC_SELF_FIFO_MASK (1<<16) /* 945 only */ +#define FW_BLC_SELF_EN (1<<15) /* 945 only */ #define MM_BURST_LENGTH 0x00700000 #define MM_FIFO_WATERMARK 0x0001F000 #define LM_BURST_LENGTH 0x00000700 #define LM_FIFO_WATERMARK 0x0000001F #define MI_ARB_STATE 0x020e4 /* 915+ only */ -#define MI_ARB_MASK_SHIFT 16 /* shift for enable bits */ +#define MI_ARB_MASK_SHIFT 16 /* shift for enable bits */
/* Make render/texture TLB fetches lower priorty than associated data * fetches. This is not turned on by default */ -#define MI_ARB_RENDER_TLB_LOW_PRIORITY (1 << 15) +#define MI_ARB_RENDER_TLB_LOW_PRIORITY (1 << 15)
/* Isoch request wait on GTT enable (Display A/B/C streams). * Make isoch requests stall on the TLB update. May cause * display underruns (test mode only) */ -#define MI_ARB_ISOCH_WAIT_GTT (1 << 14) +#define MI_ARB_ISOCH_WAIT_GTT (1 << 14)
/* Block grant count for isoch requests when block count is * set to a finite value. */ -#define MI_ARB_BLOCK_GRANT_MASK (3 << 12) -#define MI_ARB_BLOCK_GRANT_8 (0 << 12) /* for 3 display planes */ -#define MI_ARB_BLOCK_GRANT_4 (1 << 12) /* for 2 display planes */ -#define MI_ARB_BLOCK_GRANT_2 (2 << 12) /* for 1 display plane */ -#define MI_ARB_BLOCK_GRANT_0 (3 << 12) /* don't use */ +#define MI_ARB_BLOCK_GRANT_MASK (3 << 12) +#define MI_ARB_BLOCK_GRANT_8 (0 << 12) /* for 3 display planes */ +#define MI_ARB_BLOCK_GRANT_4 (1 << 12) /* for 2 display planes */ +#define MI_ARB_BLOCK_GRANT_2 (2 << 12) /* for 1 display plane */ +#define MI_ARB_BLOCK_GRANT_0 (3 << 12) /* don't use */
/* Enable render writes to complete in C2/C3/C4 power states. * If this isn't enabled, render writes are prevented in low * power states. That seems bad to me. */ -#define MI_ARB_C3_LP_WRITE_ENABLE (1 << 11) +#define MI_ARB_C3_LP_WRITE_ENABLE (1 << 11)
/* This acknowledges an async flip immediately instead * of waiting for 2TLB fetches. */ -#define MI_ARB_ASYNC_FLIP_ACK_IMMEDIATE (1 << 10) +#define MI_ARB_ASYNC_FLIP_ACK_IMMEDIATE (1 << 10)
/* Enables non-sequential data reads through arbiter */ -#define MI_ARB_DUAL_DATA_PHASE_DISABLE (1 << 9) +#define MI_ARB_DUAL_DATA_PHASE_DISABLE (1 << 9)
/* Disable FSB snooping of cacheable write cycles from binner/render * command stream */ -#define MI_ARB_CACHE_SNOOP_DISABLE (1 << 8) +#define MI_ARB_CACHE_SNOOP_DISABLE (1 << 8)
/* Arbiter time slice for non-isoch streams */ -#define MI_ARB_TIME_SLICE_MASK (7 << 5) -#define MI_ARB_TIME_SLICE_1 (0 << 5) -#define MI_ARB_TIME_SLICE_2 (1 << 5) -#define MI_ARB_TIME_SLICE_4 (2 << 5) -#define MI_ARB_TIME_SLICE_6 (3 << 5) -#define MI_ARB_TIME_SLICE_8 (4 << 5) -#define MI_ARB_TIME_SLICE_10 (5 << 5) -#define MI_ARB_TIME_SLICE_14 (6 << 5) -#define MI_ARB_TIME_SLICE_16 (7 << 5) +#define MI_ARB_TIME_SLICE_MASK (7 << 5) +#define MI_ARB_TIME_SLICE_1 (0 << 5) +#define MI_ARB_TIME_SLICE_2 (1 << 5) +#define MI_ARB_TIME_SLICE_4 (2 << 5) +#define MI_ARB_TIME_SLICE_6 (3 << 5) +#define MI_ARB_TIME_SLICE_8 (4 << 5) +#define MI_ARB_TIME_SLICE_10 (5 << 5) +#define MI_ARB_TIME_SLICE_14 (6 << 5) +#define MI_ARB_TIME_SLICE_16 (7 << 5)
/* Low priority grace period page size */ -#define MI_ARB_LOW_PRIORITY_GRACE_4KB (0 << 4) /* default */ -#define MI_ARB_LOW_PRIORITY_GRACE_8KB (1 << 4) +#define MI_ARB_LOW_PRIORITY_GRACE_4KB (0 << 4) /* default */ +#define MI_ARB_LOW_PRIORITY_GRACE_8KB (1 << 4)
/* Disable display A/B trickle feed */ -#define MI_ARB_DISPLAY_TRICKLE_FEED_DISABLE (1 << 2) +#define MI_ARB_DISPLAY_TRICKLE_FEED_DISABLE (1 << 2)
/* Set display plane priority */ -#define MI_ARB_DISPLAY_PRIORITY_A_B (0 << 0) /* display A > display B */ -#define MI_ARB_DISPLAY_PRIORITY_B_A (1 << 0) /* display B > display A */ +#define MI_ARB_DISPLAY_PRIORITY_A_B (0 << 0) /* display A > display B */ +#define MI_ARB_DISPLAY_PRIORITY_B_A (1 << 0) /* display B > display A */
#define CACHE_MODE_0 0x02120 /* 915+ only */ -#define CM0_MASK_SHIFT 16 -#define CM0_IZ_OPT_DISABLE (1<<6) -#define CM0_ZR_OPT_DISABLE (1<<5) +#define CM0_MASK_SHIFT 16 +#define CM0_IZ_OPT_DISABLE (1<<6) +#define CM0_ZR_OPT_DISABLE (1<<5) #define CM0_STC_EVICT_DISABLE_LRA_SNB (1<<5) -#define CM0_DEPTH_EVICT_DISABLE (1<<4) -#define CM0_COLOR_EVICT_DISABLE (1<<3) -#define CM0_DEPTH_WRITE_DISABLE (1<<1) -#define CM0_RC_OP_FLUSH_DISABLE (1<<0) +#define CM0_DEPTH_EVICT_DISABLE (1<<4) +#define CM0_COLOR_EVICT_DISABLE (1<<3) +#define CM0_DEPTH_WRITE_DISABLE (1<<1) +#define CM0_RC_OP_FLUSH_DISABLE (1<<0) #define BB_ADDR 0x02140 /* 8 bytes */ #define GFX_FLSH_CNTL 0x02170 /* 915+ only */ #define ECOSKPD 0x021d0 -#define ECO_GATING_CX_ONLY (1<<3) -#define ECO_FLIP_DONE (1<<0) +#define ECO_GATING_CX_ONLY (1<<3) +#define ECO_FLIP_DONE (1<<0)
/* GEN6 interrupt control */ #define GEN6_RENDER_HWSTAM 0x2098 #define GEN6_RENDER_IMR 0x20a8 -#define GEN6_RENDER_CONTEXT_SWITCH_INTERRUPT (1 << 8) -#define GEN6_RENDER_PPGTT_PAGE_FAULT (1 << 7) -#define GEN6_RENDER_TIMEOUT_COUNTER_EXPIRED (1 << 6) -#define GEN6_RENDER_L3_PARITY_ERROR (1 << 5) -#define GEN6_RENDER_PIPE_CONTROL_NOTIFY_INTERRUPT (1 << 4) -#define GEN6_RENDER_COMMAND_PARSER_MASTER_ERROR (1 << 3) -#define GEN6_RENDER_SYNC_STATUS (1 << 2) -#define GEN6_RENDER_DEBUG_INTERRUPT (1 << 1) -#define GEN6_RENDER_USER_INTERRUPT (1 << 0) +#define GEN6_RENDER_CONTEXT_SWITCH_INTERRUPT (1 << 8) +#define GEN6_RENDER_PPGTT_PAGE_FAULT (1 << 7) +#define GEN6_RENDER_TIMEOUT_COUNTER_EXPIRED (1 << 6) +#define GEN6_RENDER_L3_PARITY_ERROR (1 << 5) +#define GEN6_RENDER_PIPE_CONTROL_NOTIFY_INTERRUPT (1 << 4) +#define GEN6_RENDER_COMMAND_PARSER_MASTER_ERROR (1 << 3) +#define GEN6_RENDER_SYNC_STATUS (1 << 2) +#define GEN6_RENDER_DEBUG_INTERRUPT (1 << 1) +#define GEN6_RENDER_USER_INTERRUPT (1 << 0)
#define GEN6_BLITTER_HWSTAM 0x22098 #define GEN6_BLITTER_IMR 0x220a8 -#define GEN6_BLITTER_MI_FLUSH_DW_NOTIFY_INTERRUPT (1 << 26) -#define GEN6_BLITTER_COMMAND_PARSER_MASTER_ERROR (1 << 25) -#define GEN6_BLITTER_SYNC_STATUS (1 << 24) -#define GEN6_BLITTER_USER_INTERRUPT (1 << 22) +#define GEN6_BLITTER_MI_FLUSH_DW_NOTIFY_INTERRUPT (1 << 26) +#define GEN6_BLITTER_COMMAND_PARSER_MASTER_ERROR (1 << 25) +#define GEN6_BLITTER_SYNC_STATUS (1 << 24) +#define GEN6_BLITTER_USER_INTERRUPT (1 << 22)
#define GEN6_BLITTER_ECOSKPD 0x221d0 -#define GEN6_BLITTER_LOCK_SHIFT 16 -#define GEN6_BLITTER_FBC_NOTIFY (1<<3) +#define GEN6_BLITTER_LOCK_SHIFT 16 +#define GEN6_BLITTER_FBC_NOTIFY (1<<3)
#define GEN6_BSD_SLEEP_PSMI_CONTROL 0x12050 -#define GEN6_BSD_SLEEP_PSMI_CONTROL_RC_ILDL_MESSAGE_MODIFY_MASK (1 << 16) -#define GEN6_BSD_SLEEP_PSMI_CONTROL_RC_ILDL_MESSAGE_DISABLE (1 << 0) -#define GEN6_BSD_SLEEP_PSMI_CONTROL_RC_ILDL_MESSAGE_ENABLE 0 -#define GEN6_BSD_SLEEP_PSMI_CONTROL_IDLE_INDICATOR (1 << 3) +#define GEN6_BSD_SLEEP_PSMI_CONTROL_RC_ILDL_MESSAGE_MODIFY_MASK (1 << 16) +#define GEN6_BSD_SLEEP_PSMI_CONTROL_RC_ILDL_MESSAGE_DISABLE (1 << 0) +#define GEN6_BSD_SLEEP_PSMI_CONTROL_RC_ILDL_MESSAGE_ENABLE 0 +#define GEN6_BSD_SLEEP_PSMI_CONTROL_IDLE_INDICATOR (1 << 3)
#define GEN6_BSD_HWSTAM 0x12098 #define GEN6_BSD_IMR 0x120a8 -#define GEN6_BSD_USER_INTERRUPT (1 << 12) +#define GEN6_BSD_USER_INTERRUPT (1 << 12)
#define GEN6_BSD_RNCID 0x12198
@@ -622,29 +622,29 @@ #define FBC_CFB_BASE 0x03200 /* 4k page aligned */ #define FBC_LL_BASE 0x03204 /* 4k page aligned */ #define FBC_CONTROL 0x03208 -#define FBC_CTL_EN (1<<31) -#define FBC_CTL_PERIODIC (1<<30) -#define FBC_CTL_INTERVAL_SHIFT (16) -#define FBC_CTL_UNCOMPRESSIBLE (1<<14) -#define FBC_CTL_C3_IDLE (1<<13) -#define FBC_CTL_STRIDE_SHIFT (5) -#define FBC_CTL_FENCENO (1<<0) +#define FBC_CTL_EN (1<<31) +#define FBC_CTL_PERIODIC (1<<30) +#define FBC_CTL_INTERVAL_SHIFT (16) +#define FBC_CTL_UNCOMPRESSIBLE (1<<14) +#define FBC_CTL_C3_IDLE (1<<13) +#define FBC_CTL_STRIDE_SHIFT (5) +#define FBC_CTL_FENCENO (1<<0) #define FBC_COMMAND 0x0320c -#define FBC_CMD_COMPRESS (1<<0) +#define FBC_CMD_COMPRESS (1<<0) #define FBC_STATUS 0x03210 -#define FBC_STAT_COMPRESSING (1<<31) -#define FBC_STAT_COMPRESSED (1<<30) -#define FBC_STAT_MODIFIED (1<<29) -#define FBC_STAT_CURRENT_LINE (1<<0) +#define FBC_STAT_COMPRESSING (1<<31) +#define FBC_STAT_COMPRESSED (1<<30) +#define FBC_STAT_MODIFIED (1<<29) +#define FBC_STAT_CURRENT_LINE (1<<0) #define FBC_CONTROL2 0x03214 -#define FBC_CTL_FENCE_DBL (0<<4) -#define FBC_CTL_IDLE_IMM (0<<2) -#define FBC_CTL_IDLE_FULL (1<<2) -#define FBC_CTL_IDLE_LINE (2<<2) -#define FBC_CTL_IDLE_DEBUG (3<<2) -#define FBC_CTL_CPU_FENCE (1<<1) -#define FBC_CTL_PLANEA (0<<0) -#define FBC_CTL_PLANEB (1<<0) +#define FBC_CTL_FENCE_DBL (0<<4) +#define FBC_CTL_IDLE_IMM (0<<2) +#define FBC_CTL_IDLE_FULL (1<<2) +#define FBC_CTL_IDLE_LINE (2<<2) +#define FBC_CTL_IDLE_DEBUG (3<<2) +#define FBC_CTL_CPU_FENCE (1<<1) +#define FBC_CTL_PLANEA (0<<0) +#define FBC_CTL_PLANEB (1<<0) #define FBC_FENCE_OFF 0x0321b #define FBC_TAG 0x03300
@@ -653,45 +653,45 @@ /* Framebuffer compression for GM45+ */ #define DPFC_CB_BASE 0x3200 #define DPFC_CONTROL 0x3208 -#define DPFC_CTL_EN (1<<31) -#define DPFC_CTL_PLANEA (0<<30) -#define DPFC_CTL_PLANEB (1<<30) -#define DPFC_CTL_FENCE_EN (1<<29) -#define DPFC_CTL_PERSISTENT_MODE (1<<25) -#define DPFC_SR_EN (1<<10) -#define DPFC_CTL_LIMIT_1X (0<<6) -#define DPFC_CTL_LIMIT_2X (1<<6) -#define DPFC_CTL_LIMIT_4X (2<<6) +#define DPFC_CTL_EN (1<<31) +#define DPFC_CTL_PLANEA (0<<30) +#define DPFC_CTL_PLANEB (1<<30) +#define DPFC_CTL_FENCE_EN (1<<29) +#define DPFC_CTL_PERSISTENT_MODE (1<<25) +#define DPFC_SR_EN (1<<10) +#define DPFC_CTL_LIMIT_1X (0<<6) +#define DPFC_CTL_LIMIT_2X (1<<6) +#define DPFC_CTL_LIMIT_4X (2<<6) #define DPFC_RECOMP_CTL 0x320c -#define DPFC_RECOMP_STALL_EN (1<<27) -#define DPFC_RECOMP_STALL_WM_SHIFT (16) -#define DPFC_RECOMP_STALL_WM_MASK (0x07ff0000) -#define DPFC_RECOMP_TIMER_COUNT_SHIFT (0) -#define DPFC_RECOMP_TIMER_COUNT_MASK (0x0000003f) +#define DPFC_RECOMP_STALL_EN (1<<27) +#define DPFC_RECOMP_STALL_WM_SHIFT (16) +#define DPFC_RECOMP_STALL_WM_MASK (0x07ff0000) +#define DPFC_RECOMP_TIMER_COUNT_SHIFT (0) +#define DPFC_RECOMP_TIMER_COUNT_MASK (0x0000003f) #define DPFC_STATUS 0x3210 -#define DPFC_INVAL_SEG_SHIFT (16) -#define DPFC_INVAL_SEG_MASK (0x07ff0000) -#define DPFC_COMP_SEG_SHIFT (0) -#define DPFC_COMP_SEG_MASK (0x000003ff) +#define DPFC_INVAL_SEG_SHIFT (16) +#define DPFC_INVAL_SEG_MASK (0x07ff0000) +#define DPFC_COMP_SEG_SHIFT (0) +#define DPFC_COMP_SEG_MASK (0x000003ff) #define DPFC_STATUS2 0x3214 #define DPFC_FENCE_YOFF 0x3218 #define DPFC_CHICKEN 0x3224 -#define DPFC_HT_MODIFY (1<<31) +#define DPFC_HT_MODIFY (1<<31)
/* Framebuffer compression for Ironlake */ #define ILK_DPFC_CB_BASE 0x43200 #define ILK_DPFC_CONTROL 0x43208 /* The bit 28-8 is reserved */ -#define DPFC_RESERVED (0x1FFFFF00) +#define DPFC_RESERVED (0x1FFFFF00) #define ILK_DPFC_RECOMP_CTL 0x4320c #define ILK_DPFC_STATUS 0x43210 #define ILK_DPFC_FENCE_YOFF 0x43218 #define ILK_DPFC_CHICKEN 0x43224 #define ILK_FBC_RT_BASE 0x2128 -#define ILK_FBC_RT_VALID (1<<0) +#define ILK_FBC_RT_VALID (1<<0)
#define ILK_DISPLAY_CHICKEN1 0x42000 -#define ILK_FBCQ_DIS (1<<22) +#define ILK_FBCQ_DIS (1<<22) #define ILK_PABSTRETCH_DIS (1<<21)
@@ -701,7 +701,7 @@ * The following two registers are of type GTTMMADR */ #define SNB_DPFC_CTL_SA 0x100100 -#define SNB_CPU_FENCE_ENABLE (1<<29) +#define SNB_CPU_FENCE_ENABLE (1<<29) #define DPFC_CPU_FENCE_OFFSET 0x100104
@@ -732,52 +732,52 @@ # define GPIO_DATA_PULLUP_DISABLE (1 << 13)
#define GMBUS0 0x5100 /* clock/port select */ -#define GMBUS_RATE_100KHZ (0<<8) -#define GMBUS_RATE_50KHZ (1<<8) -#define GMBUS_RATE_400KHZ (2<<8) /* reserved on Pineview */ -#define GMBUS_RATE_1MHZ (3<<8) /* reserved on Pineview */ -#define GMBUS_RATE_MASK (3<<8) -#define GMBUS_HOLD_EXT (1<<7) /* 300ns hold time, rsvd on Pineview */ -#define GMBUS_PORT_DISABLED 0 -#define GMBUS_PORT_SSC 1 -#define GMBUS_PORT_VGADDC 2 -#define GMBUS_PORT_PANEL 3 -#define GMBUS_PORT_DPC 4 /* HDMIC */ -#define GMBUS_PORT_DPB 5 /* SDVO, HDMIB */ -#define GMBUS_PORT_DPD 6 /* HDMID */ -#define GMBUS_PORT_RESERVED 7 /* 7 reserved */ -#define GMBUS_NUM_PORTS (GMBUS_PORT_DPD - GMBUS_PORT_SSC + 1) -#define GMBUS_PORT_MASK 7 +#define GMBUS_RATE_100KHZ (0<<8) +#define GMBUS_RATE_50KHZ (1<<8) +#define GMBUS_RATE_400KHZ (2<<8) /* reserved on Pineview */ +#define GMBUS_RATE_1MHZ (3<<8) /* reserved on Pineview */ +#define GMBUS_RATE_MASK (3<<8) +#define GMBUS_HOLD_EXT (1<<7) /* 300ns hold time, rsvd on Pineview */ +#define GMBUS_PORT_DISABLED 0 +#define GMBUS_PORT_SSC 1 +#define GMBUS_PORT_VGADDC 2 +#define GMBUS_PORT_PANEL 3 +#define GMBUS_PORT_DPC 4 /* HDMIC */ +#define GMBUS_PORT_DPB 5 /* SDVO, HDMIB */ +#define GMBUS_PORT_DPD 6 /* HDMID */ +#define GMBUS_PORT_RESERVED 7 /* 7 reserved */ +#define GMBUS_NUM_PORTS (GMBUS_PORT_DPD - GMBUS_PORT_SSC + 1) +#define GMBUS_PORT_MASK 7 #define GMBUS1 0x5104 /* command/status */ -#define GMBUS_SW_CLR_INT (1<<31) -#define GMBUS_SW_RDY (1<<30) -#define GMBUS_ENT (1<<29) /* enable timeout */ -#define GMBUS_CYCLE_NONE (0<<25) -#define GMBUS_CYCLE_WAIT (1<<25) -#define GMBUS_CYCLE_INDEX (2<<25) -#define GMBUS_CYCLE_STOP (4<<25) -#define GMBUS_BYTE_COUNT_SHIFT 16 -#define GMBUS_SLAVE_INDEX_SHIFT 8 -#define GMBUS_SLAVE_ADDR_SHIFT 1 -#define GMBUS_SLAVE_READ (1<<0) -#define GMBUS_SLAVE_WRITE (0<<0) +#define GMBUS_SW_CLR_INT (1<<31) +#define GMBUS_SW_RDY (1<<30) +#define GMBUS_ENT (1<<29) /* enable timeout */ +#define GMBUS_CYCLE_NONE (0<<25) +#define GMBUS_CYCLE_WAIT (1<<25) +#define GMBUS_CYCLE_INDEX (2<<25) +#define GMBUS_CYCLE_STOP (4<<25) +#define GMBUS_BYTE_COUNT_SHIFT 16 +#define GMBUS_SLAVE_INDEX_SHIFT 8 +#define GMBUS_SLAVE_ADDR_SHIFT 1 +#define GMBUS_SLAVE_READ (1<<0) +#define GMBUS_SLAVE_WRITE (0<<0) #define GMBUS2 0x5108 /* status */ -#define GMBUS_INUSE (1<<15) -#define GMBUS_HW_WAIT_PHASE (1<<14) -#define GMBUS_STALL_TIMEOUT (1<<13) -#define GMBUS_INT (1<<12) -#define GMBUS_HW_RDY (1<<11) -#define GMBUS_SATOER (1<<10) -#define GMBUS_ACTIVE (1<<9) +#define GMBUS_INUSE (1<<15) +#define GMBUS_HW_WAIT_PHASE (1<<14) +#define GMBUS_STALL_TIMEOUT (1<<13) +#define GMBUS_INT (1<<12) +#define GMBUS_HW_RDY (1<<11) +#define GMBUS_SATOER (1<<10) +#define GMBUS_ACTIVE (1<<9) #define GMBUS3 0x510c /* data buffer bytes 3-0 */ #define GMBUS4 0x5110 /* interrupt mask (Pineview+) */ -#define GMBUS_SLAVE_TIMEOUT_EN (1<<4) -#define GMBUS_NAK_EN (1<<3) -#define GMBUS_IDLE_EN (1<<2) -#define GMBUS_HW_WAIT_EN (1<<1) -#define GMBUS_HW_RDY_EN (1<<0) +#define GMBUS_SLAVE_TIMEOUT_EN (1<<4) +#define GMBUS_NAK_EN (1<<3) +#define GMBUS_IDLE_EN (1<<2) +#define GMBUS_HW_WAIT_EN (1<<1) +#define GMBUS_HW_RDY_EN (1<<0) #define GMBUS5 0x5120 /* byte index */ -#define GMBUS_2BYTE_INDEX_EN (1<<31) +#define GMBUS_2BYTE_INDEX_EN (1<<31)
/* * Clock control & power management @@ -786,31 +786,31 @@ #define VGA0 0x6000 #define VGA1 0x6004 #define VGA_PD 0x6010 -#define VGA0_PD_P2_DIV_4 (1 << 7) -#define VGA0_PD_P1_DIV_2 (1 << 5) -#define VGA0_PD_P1_SHIFT 0 -#define VGA0_PD_P1_MASK (0x1f << 0) -#define VGA1_PD_P2_DIV_4 (1 << 15) -#define VGA1_PD_P1_DIV_2 (1 << 13) -#define VGA1_PD_P1_SHIFT 8 -#define VGA1_PD_P1_MASK (0x1f << 8) +#define VGA0_PD_P2_DIV_4 (1 << 7) +#define VGA0_PD_P1_DIV_2 (1 << 5) +#define VGA0_PD_P1_SHIFT 0 +#define VGA0_PD_P1_MASK (0x1f << 0) +#define VGA1_PD_P2_DIV_4 (1 << 15) +#define VGA1_PD_P1_DIV_2 (1 << 13) +#define VGA1_PD_P1_SHIFT 8 +#define VGA1_PD_P1_MASK (0x1f << 8) #define _DPLL_A 0x06014 #define _DPLL_B 0x06018 #define DPLL(pipe) _PIPE(pipe, _DPLL_A, _DPLL_B) -#define DPLL_VCO_ENABLE (1 << 31) -#define DPLL_DVO_HIGH_SPEED (1 << 30) -#define DPLL_SYNCLOCK_ENABLE (1 << 29) -#define DPLL_VGA_MODE_DIS (1 << 28) -#define DPLLB_MODE_DAC_SERIAL (1 << 26) /* i915 */ -#define DPLLB_MODE_LVDS (2 << 26) /* i915 */ -#define DPLL_MODE_MASK (3 << 26) -#define DPLL_DAC_SERIAL_P2_CLOCK_DIV_10 (0 << 24) /* i915 */ -#define DPLL_DAC_SERIAL_P2_CLOCK_DIV_5 (1 << 24) /* i915 */ -#define DPLLB_LVDS_P2_CLOCK_DIV_14 (0 << 24) /* i915 */ -#define DPLLB_LVDS_P2_CLOCK_DIV_7 (1 << 24) /* i915 */ -#define DPLL_P2_CLOCK_DIV_MASK 0x03000000 /* i915 */ -#define DPLL_FPA01_P1_POST_DIV_MASK 0x00ff0000 /* i915 */ -#define DPLL_FPA01_P1_POST_DIV_MASK_PINEVIEW 0x00ff8000 /* Pineview */ +#define DPLL_VCO_ENABLE (1 << 31) +#define DPLL_DVO_HIGH_SPEED (1 << 30) +#define DPLL_SYNCLOCK_ENABLE (1 << 29) +#define DPLL_VGA_MODE_DIS (1 << 28) +#define DPLLB_MODE_DAC_SERIAL (1 << 26) /* i915 */ +#define DPLLB_MODE_LVDS (2 << 26) /* i915 */ +#define DPLL_MODE_MASK (3 << 26) +#define DPLL_DAC_SERIAL_P2_CLOCK_DIV_10 (0 << 24) /* i915 */ +#define DPLL_DAC_SERIAL_P2_CLOCK_DIV_5 (1 << 24) /* i915 */ +#define DPLLB_LVDS_P2_CLOCK_DIV_14 (0 << 24) /* i915 */ +#define DPLLB_LVDS_P2_CLOCK_DIV_7 (1 << 24) /* i915 */ +#define DPLL_P2_CLOCK_DIV_MASK 0x03000000 /* i915 */ +#define DPLL_FPA01_P1_POST_DIV_MASK 0x00ff0000 /* i915 */ +#define DPLL_FPA01_P1_POST_DIV_MASK_PINEVIEW 0x00ff8000 /* Pineview */
#define SRX_INDEX 0x3c4 #define SRX_DATA 0x3c5 @@ -829,23 +829,23 @@
/* Scratch pad debug 0 reg: */ -#define DPLL_FPA01_P1_POST_DIV_MASK_I830 0x001f0000 +#define DPLL_FPA01_P1_POST_DIV_MASK_I830 0x001f0000 /* * The i830 generation, in LVDS mode, defines P1 as the bit number set within * this field (only one bit may be set). */ -#define DPLL_FPA01_P1_POST_DIV_MASK_I830_LVDS 0x003f0000 -#define DPLL_FPA01_P1_POST_DIV_SHIFT 16 -#define DPLL_FPA01_P1_POST_DIV_SHIFT_PINEVIEW 15 +#define DPLL_FPA01_P1_POST_DIV_MASK_I830_LVDS 0x003f0000 +#define DPLL_FPA01_P1_POST_DIV_SHIFT 16 +#define DPLL_FPA01_P1_POST_DIV_SHIFT_PINEVIEW 15 /* i830, required in DVO non-gang */ -#define PLL_P2_DIVIDE_BY_4 (1 << 23) -#define PLL_P1_DIVIDE_BY_TWO (1 << 21) /* i830 */ -#define PLL_REF_INPUT_DREFCLK (0 << 13) -#define PLL_REF_INPUT_TVCLKINA (1 << 13) /* i830 */ -#define PLL_REF_INPUT_TVCLKINBC (2 << 13) /* SDVO TVCLKIN */ -#define PLLB_REF_INPUT_SPREADSPECTRUMIN (3 << 13) -#define PLL_REF_INPUT_MASK (3 << 13) -#define PLL_LOAD_PULSE_PHASE_SHIFT 9 +#define PLL_P2_DIVIDE_BY_4 (1 << 23) +#define PLL_P1_DIVIDE_BY_TWO (1 << 21) /* i830 */ +#define PLL_REF_INPUT_DREFCLK (0 << 13) +#define PLL_REF_INPUT_TVCLKINA (1 << 13) /* i830 */ +#define PLL_REF_INPUT_TVCLKINBC (2 << 13) /* SDVO TVCLKIN */ +#define PLLB_REF_INPUT_SPREADSPECTRUMIN (3 << 13) +#define PLL_REF_INPUT_MASK (3 << 13) +#define PLL_LOAD_PULSE_PHASE_SHIFT 9 /* Ironlake */ # define PLL_REF_SDVO_HDMI_MULTIPLIER_SHIFT 9 # define PLL_REF_SDVO_HDMI_MULTIPLIER_MASK (7 << 9) @@ -859,25 +859,25 @@ * digital display port. The range is 4 to 13; 10 or more * is just a flip delay. The default is 6 */ -#define PLL_LOAD_PULSE_PHASE_MASK (0xf << PLL_LOAD_PULSE_PHASE_SHIFT) -#define DISPLAY_RATE_SELECT_FPA1 (1 << 8) +#define PLL_LOAD_PULSE_PHASE_MASK (0xf << PLL_LOAD_PULSE_PHASE_SHIFT) +#define DISPLAY_RATE_SELECT_FPA1 (1 << 8) /* * SDVO multiplier for 945G/GM. Not used on 965. */ -#define SDVO_MULTIPLIER_MASK 0x000000ff -#define SDVO_MULTIPLIER_SHIFT_HIRES 4 -#define SDVO_MULTIPLIER_SHIFT_VGA 0 +#define SDVO_MULTIPLIER_MASK 0x000000ff +#define SDVO_MULTIPLIER_SHIFT_HIRES 4 +#define SDVO_MULTIPLIER_SHIFT_VGA 0 #define _DPLL_A_MD 0x0601c /* 965+ only */ /* * UDI pixel divider, controlling how many pixels are stuffed into a packet. * * Value is pixels minus 1. Must be set to 1 pixel for SDVO. */ -#define DPLL_MD_UDI_DIVIDER_MASK 0x3f000000 -#define DPLL_MD_UDI_DIVIDER_SHIFT 24 +#define DPLL_MD_UDI_DIVIDER_MASK 0x3f000000 +#define DPLL_MD_UDI_DIVIDER_SHIFT 24 /* UDI pixel divider for VGA, same as DPLL_MD_UDI_DIVIDER_MASK. */ -#define DPLL_MD_VGA_UDI_DIVIDER_MASK 0x003f0000 -#define DPLL_MD_VGA_UDI_DIVIDER_SHIFT 16 +#define DPLL_MD_VGA_UDI_DIVIDER_MASK 0x003f0000 +#define DPLL_MD_VGA_UDI_DIVIDER_SHIFT 16 /* * SDVO/UDI pixel multiplier. * @@ -895,15 +895,15 @@ * This register field has values of multiplication factor minus 1, with * a maximum multiplier of 5 for SDVO. */ -#define DPLL_MD_UDI_MULTIPLIER_MASK 0x00003f00 -#define DPLL_MD_UDI_MULTIPLIER_SHIFT 8 +#define DPLL_MD_UDI_MULTIPLIER_MASK 0x00003f00 +#define DPLL_MD_UDI_MULTIPLIER_SHIFT 8 /* * SDVO/UDI pixel multiplier for VGA, same as DPLL_MD_UDI_MULTIPLIER_MASK. * This best be set to the default value (3) or the CRT won't work. No, * I don't entirely understand what this does... */ -#define DPLL_MD_VGA_UDI_MULTIPLIER_MASK 0x0000003f -#define DPLL_MD_VGA_UDI_MULTIPLIER_SHIFT 0 +#define DPLL_MD_VGA_UDI_MULTIPLIER_MASK 0x0000003f +#define DPLL_MD_VGA_UDI_MULTIPLIER_SHIFT 0 #define _DPLL_B_MD 0x06020 /* 965+ only */ #define DPLL_MD(pipe) _PIPE(pipe, _DPLL_A_MD, _DPLL_B_MD) #define _FPA0 0x06040 @@ -912,30 +912,30 @@ #define _FPB1 0x0604c #define FP0(pipe) _PIPE(pipe, _FPA0, _FPB0) #define FP1(pipe) _PIPE(pipe, _FPA1, _FPB1) -#define FP_N_DIV_MASK 0x003f0000 -#define FP_N_PINEVIEW_DIV_MASK 0x00ff0000 -#define FP_N_DIV_SHIFT 16 -#define FP_M1_DIV_MASK 0x00003f00 -#define FP_M1_DIV_SHIFT 8 -#define FP_M2_DIV_MASK 0x0000003f -#define FP_M2_PINEVIEW_DIV_MASK 0x000000ff -#define FP_M2_DIV_SHIFT 0 +#define FP_N_DIV_MASK 0x003f0000 +#define FP_N_PINEVIEW_DIV_MASK 0x00ff0000 +#define FP_N_DIV_SHIFT 16 +#define FP_M1_DIV_MASK 0x00003f00 +#define FP_M1_DIV_SHIFT 8 +#define FP_M2_DIV_MASK 0x0000003f +#define FP_M2_PINEVIEW_DIV_MASK 0x000000ff +#define FP_M2_DIV_SHIFT 0 #define DPLL_TEST 0x606c -#define DPLLB_TEST_SDVO_DIV_1 (0 << 22) -#define DPLLB_TEST_SDVO_DIV_2 (1 << 22) -#define DPLLB_TEST_SDVO_DIV_4 (2 << 22) -#define DPLLB_TEST_SDVO_DIV_MASK (3 << 22) -#define DPLLB_TEST_N_BYPASS (1 << 19) -#define DPLLB_TEST_M_BYPASS (1 << 18) -#define DPLLB_INPUT_BUFFER_ENABLE (1 << 16) -#define DPLLA_TEST_N_BYPASS (1 << 3) -#define DPLLA_TEST_M_BYPASS (1 << 2) -#define DPLLA_INPUT_BUFFER_ENABLE (1 << 0) +#define DPLLB_TEST_SDVO_DIV_1 (0 << 22) +#define DPLLB_TEST_SDVO_DIV_2 (1 << 22) +#define DPLLB_TEST_SDVO_DIV_4 (2 << 22) +#define DPLLB_TEST_SDVO_DIV_MASK (3 << 22) +#define DPLLB_TEST_N_BYPASS (1 << 19) +#define DPLLB_TEST_M_BYPASS (1 << 18) +#define DPLLB_INPUT_BUFFER_ENABLE (1 << 16) +#define DPLLA_TEST_N_BYPASS (1 << 3) +#define DPLLA_TEST_M_BYPASS (1 << 2) +#define DPLLA_INPUT_BUFFER_ENABLE (1 << 0) #define D_STATE 0x6104 -#define DSTATE_GFX_RESET_I830 (1<<6) -#define DSTATE_PLL_D3_OFF (1<<3) -#define DSTATE_GFX_CLOCK_GATING (1<<1) -#define DSTATE_DOT_CLOCK_GATING (1<<0) +#define DSTATE_GFX_RESET_I830 (1<<6) +#define DSTATE_PLL_D3_OFF (1<<3) +#define DSTATE_GFX_CLOCK_GATING (1<<1) +#define DSTATE_DOT_CLOCK_GATING (1<<0) #define DSPCLK_GATE_D 0x6200 # define DPUNIT_B_CLOCK_GATE_DISABLE (1 << 30) /* 965 */ # define VSUNIT_CLOCK_GATE_DISABLE (1 << 29) /* 965 */ @@ -1089,23 +1089,23 @@ #define MAD_DIMM_C0 (MCHBAR_MIRROR_BASE_SNB + 0x5004) #define MAD_DIMM_C1 (MCHBAR_MIRROR_BASE_SNB + 0x5008) #define MAD_DIMM_C2 (MCHBAR_MIRROR_BASE_SNB + 0x500C) -#define MAD_DIMM_ECC_MASK (0x3 << 24) -#define MAD_DIMM_ECC_OFF (0x0 << 24) -#define MAD_DIMM_ECC_IO_ON_LOGIC_OFF (0x1 << 24) -#define MAD_DIMM_ECC_IO_OFF_LOGIC_ON (0x2 << 24) -#define MAD_DIMM_ECC_ON (0x3 << 24) -#define MAD_DIMM_ENH_INTERLEAVE (0x1 << 22) -#define MAD_DIMM_RANK_INTERLEAVE (0x1 << 21) -#define MAD_DIMM_B_WIDTH_X16 (0x1 << 20) /* X8 chips if unset */ -#define MAD_DIMM_A_WIDTH_X16 (0x1 << 19) /* X8 chips if unset */ -#define MAD_DIMM_B_DUAL_RANK (0x1 << 18) -#define MAD_DIMM_A_DUAL_RANK (0x1 << 17) -#define MAD_DIMM_A_SELECT (0x1 << 16) +#define MAD_DIMM_ECC_MASK (0x3 << 24) +#define MAD_DIMM_ECC_OFF (0x0 << 24) +#define MAD_DIMM_ECC_IO_ON_LOGIC_OFF (0x1 << 24) +#define MAD_DIMM_ECC_IO_OFF_LOGIC_ON (0x2 << 24) +#define MAD_DIMM_ECC_ON (0x3 << 24) +#define MAD_DIMM_ENH_INTERLEAVE (0x1 << 22) +#define MAD_DIMM_RANK_INTERLEAVE (0x1 << 21) +#define MAD_DIMM_B_WIDTH_X16 (0x1 << 20) /* X8 chips if unset */ +#define MAD_DIMM_A_WIDTH_X16 (0x1 << 19) /* X8 chips if unset */ +#define MAD_DIMM_B_DUAL_RANK (0x1 << 18) +#define MAD_DIMM_A_DUAL_RANK (0x1 << 17) +#define MAD_DIMM_A_SELECT (0x1 << 16) /* DIMM sizes are in multiples of 256mb. */ -#define MAD_DIMM_B_SIZE_SHIFT 8 -#define MAD_DIMM_B_SIZE_MASK (0xff << MAD_DIMM_B_SIZE_SHIFT) -#define MAD_DIMM_A_SIZE_SHIFT 0 -#define MAD_DIMM_A_SIZE_MASK (0xff << MAD_DIMM_A_SIZE_SHIFT) +#define MAD_DIMM_B_SIZE_SHIFT 8 +#define MAD_DIMM_B_SIZE_MASK (0xff << MAD_DIMM_B_SIZE_SHIFT) +#define MAD_DIMM_A_SIZE_SHIFT 0 +#define MAD_DIMM_A_SIZE_MASK (0xff << MAD_DIMM_A_SIZE_SHIFT)
/* Clocking configuration register */ @@ -1126,194 +1126,194 @@ #define CLKCFG_MEM_MASK (7 << 4)
#define TSC1 0x11001 -#define TSE (1<<0) +#define TSE (1<<0) #define TR1 0x11006 #define TSFS 0x11020 -#define TSFS_SLOPE_MASK 0x0000ff00 -#define TSFS_SLOPE_SHIFT 8 -#define TSFS_INTR_MASK 0x000000ff +#define TSFS_SLOPE_MASK 0x0000ff00 +#define TSFS_SLOPE_SHIFT 8 +#define TSFS_INTR_MASK 0x000000ff
#define CRSTANDVID 0x11100 #define PXVFREQ_BASE 0x11110 /* P[0-15]VIDFREQ (0x1114c) (Ironlake) */ -#define PXVFREQ_PX_MASK 0x7f000000 -#define PXVFREQ_PX_SHIFT 24 +#define PXVFREQ_PX_MASK 0x7f000000 +#define PXVFREQ_PX_SHIFT 24 #define VIDFREQ_BASE 0x11110 #define VIDFREQ1 0x11110 /* VIDFREQ1-4 (0x1111c) (Cantiga) */ #define VIDFREQ2 0x11114 #define VIDFREQ3 0x11118 #define VIDFREQ4 0x1111c -#define VIDFREQ_P0_MASK 0x1f000000 -#define VIDFREQ_P0_SHIFT 24 -#define VIDFREQ_P0_CSCLK_MASK 0x00f00000 -#define VIDFREQ_P0_CSCLK_SHIFT 20 -#define VIDFREQ_P0_CRCLK_MASK 0x000f0000 -#define VIDFREQ_P0_CRCLK_SHIFT 16 -#define VIDFREQ_P1_MASK 0x00001f00 -#define VIDFREQ_P1_SHIFT 8 -#define VIDFREQ_P1_CSCLK_MASK 0x000000f0 -#define VIDFREQ_P1_CSCLK_SHIFT 4 -#define VIDFREQ_P1_CRCLK_MASK 0x0000000f +#define VIDFREQ_P0_MASK 0x1f000000 +#define VIDFREQ_P0_SHIFT 24 +#define VIDFREQ_P0_CSCLK_MASK 0x00f00000 +#define VIDFREQ_P0_CSCLK_SHIFT 20 +#define VIDFREQ_P0_CRCLK_MASK 0x000f0000 +#define VIDFREQ_P0_CRCLK_SHIFT 16 +#define VIDFREQ_P1_MASK 0x00001f00 +#define VIDFREQ_P1_SHIFT 8 +#define VIDFREQ_P1_CSCLK_MASK 0x000000f0 +#define VIDFREQ_P1_CSCLK_SHIFT 4 +#define VIDFREQ_P1_CRCLK_MASK 0x0000000f #define INTTOEXT_BASE_ILK 0x11300 #define INTTOEXT_BASE 0x11120 /* INTTOEXT1-8 (0x1113c) */ -#define INTTOEXT_MAP3_SHIFT 24 -#define INTTOEXT_MAP3_MASK (0x1f << INTTOEXT_MAP3_SHIFT) -#define INTTOEXT_MAP2_SHIFT 16 -#define INTTOEXT_MAP2_MASK (0x1f << INTTOEXT_MAP2_SHIFT) -#define INTTOEXT_MAP1_SHIFT 8 -#define INTTOEXT_MAP1_MASK (0x1f << INTTOEXT_MAP1_SHIFT) -#define INTTOEXT_MAP0_SHIFT 0 -#define INTTOEXT_MAP0_MASK (0x1f << INTTOEXT_MAP0_SHIFT) +#define INTTOEXT_MAP3_SHIFT 24 +#define INTTOEXT_MAP3_MASK (0x1f << INTTOEXT_MAP3_SHIFT) +#define INTTOEXT_MAP2_SHIFT 16 +#define INTTOEXT_MAP2_MASK (0x1f << INTTOEXT_MAP2_SHIFT) +#define INTTOEXT_MAP1_SHIFT 8 +#define INTTOEXT_MAP1_MASK (0x1f << INTTOEXT_MAP1_SHIFT) +#define INTTOEXT_MAP0_SHIFT 0 +#define INTTOEXT_MAP0_MASK (0x1f << INTTOEXT_MAP0_SHIFT) #define MEMSWCTL 0x11170 /* Ironlake only */ -#define MEMCTL_CMD_MASK 0xe000 -#define MEMCTL_CMD_SHIFT 13 -#define MEMCTL_CMD_RCLK_OFF 0 -#define MEMCTL_CMD_RCLK_ON 1 -#define MEMCTL_CMD_CHFREQ 2 -#define MEMCTL_CMD_CHVID 3 -#define MEMCTL_CMD_VMMOFF 4 -#define MEMCTL_CMD_VMMON 5 -#define MEMCTL_CMD_STS (1<<12) /* write 1 triggers command, clears +#define MEMCTL_CMD_MASK 0xe000 +#define MEMCTL_CMD_SHIFT 13 +#define MEMCTL_CMD_RCLK_OFF 0 +#define MEMCTL_CMD_RCLK_ON 1 +#define MEMCTL_CMD_CHFREQ 2 +#define MEMCTL_CMD_CHVID 3 +#define MEMCTL_CMD_VMMOFF 4 +#define MEMCTL_CMD_VMMON 5 +#define MEMCTL_CMD_STS (1<<12) /* write 1 triggers command, clears when command complete */ -#define MEMCTL_FREQ_MASK 0x0f00 /* jitter, from 0-15 */ -#define MEMCTL_FREQ_SHIFT 8 -#define MEMCTL_SFCAVM (1<<7) -#define MEMCTL_TGT_VID_MASK 0x007f +#define MEMCTL_FREQ_MASK 0x0f00 /* jitter, from 0-15 */ +#define MEMCTL_FREQ_SHIFT 8 +#define MEMCTL_SFCAVM (1<<7) +#define MEMCTL_TGT_VID_MASK 0x007f #define MEMIHYST 0x1117c #define MEMINTREN 0x11180 /* 16 bits */ -#define MEMINT_RSEXIT_EN (1<<8) -#define MEMINT_CX_SUPR_EN (1<<7) -#define MEMINT_CONT_BUSY_EN (1<<6) -#define MEMINT_AVG_BUSY_EN (1<<5) -#define MEMINT_EVAL_CHG_EN (1<<4) -#define MEMINT_MON_IDLE_EN (1<<3) -#define MEMINT_UP_EVAL_EN (1<<2) -#define MEMINT_DOWN_EVAL_EN (1<<1) -#define MEMINT_SW_CMD_EN (1<<0) +#define MEMINT_RSEXIT_EN (1<<8) +#define MEMINT_CX_SUPR_EN (1<<7) +#define MEMINT_CONT_BUSY_EN (1<<6) +#define MEMINT_AVG_BUSY_EN (1<<5) +#define MEMINT_EVAL_CHG_EN (1<<4) +#define MEMINT_MON_IDLE_EN (1<<3) +#define MEMINT_UP_EVAL_EN (1<<2) +#define MEMINT_DOWN_EVAL_EN (1<<1) +#define MEMINT_SW_CMD_EN (1<<0) #define MEMINTRSTR 0x11182 /* 16 bits */ -#define MEM_RSEXIT_MASK 0xc000 -#define MEM_RSEXIT_SHIFT 14 -#define MEM_CONT_BUSY_MASK 0x3000 -#define MEM_CONT_BUSY_SHIFT 12 -#define MEM_AVG_BUSY_MASK 0x0c00 -#define MEM_AVG_BUSY_SHIFT 10 -#define MEM_EVAL_CHG_MASK 0x0300 -#define MEM_EVAL_BUSY_SHIFT 8 -#define MEM_MON_IDLE_MASK 0x00c0 -#define MEM_MON_IDLE_SHIFT 6 -#define MEM_UP_EVAL_MASK 0x0030 -#define MEM_UP_EVAL_SHIFT 4 -#define MEM_DOWN_EVAL_MASK 0x000c -#define MEM_DOWN_EVAL_SHIFT 2 -#define MEM_SW_CMD_MASK 0x0003 -#define MEM_INT_STEER_GFX 0 -#define MEM_INT_STEER_CMR 1 -#define MEM_INT_STEER_SMI 2 -#define MEM_INT_STEER_SCI 3 +#define MEM_RSEXIT_MASK 0xc000 +#define MEM_RSEXIT_SHIFT 14 +#define MEM_CONT_BUSY_MASK 0x3000 +#define MEM_CONT_BUSY_SHIFT 12 +#define MEM_AVG_BUSY_MASK 0x0c00 +#define MEM_AVG_BUSY_SHIFT 10 +#define MEM_EVAL_CHG_MASK 0x0300 +#define MEM_EVAL_BUSY_SHIFT 8 +#define MEM_MON_IDLE_MASK 0x00c0 +#define MEM_MON_IDLE_SHIFT 6 +#define MEM_UP_EVAL_MASK 0x0030 +#define MEM_UP_EVAL_SHIFT 4 +#define MEM_DOWN_EVAL_MASK 0x000c +#define MEM_DOWN_EVAL_SHIFT 2 +#define MEM_SW_CMD_MASK 0x0003 +#define MEM_INT_STEER_GFX 0 +#define MEM_INT_STEER_CMR 1 +#define MEM_INT_STEER_SMI 2 +#define MEM_INT_STEER_SCI 3 #define MEMINTRSTS 0x11184 -#define MEMINT_RSEXIT (1<<7) -#define MEMINT_CONT_BUSY (1<<6) -#define MEMINT_AVG_BUSY (1<<5) -#define MEMINT_EVAL_CHG (1<<4) -#define MEMINT_MON_IDLE (1<<3) -#define MEMINT_UP_EVAL (1<<2) -#define MEMINT_DOWN_EVAL (1<<1) -#define MEMINT_SW_CMD (1<<0) +#define MEMINT_RSEXIT (1<<7) +#define MEMINT_CONT_BUSY (1<<6) +#define MEMINT_AVG_BUSY (1<<5) +#define MEMINT_EVAL_CHG (1<<4) +#define MEMINT_MON_IDLE (1<<3) +#define MEMINT_UP_EVAL (1<<2) +#define MEMINT_DOWN_EVAL (1<<1) +#define MEMINT_SW_CMD (1<<0) #define MEMMODECTL 0x11190 -#define MEMMODE_BOOST_EN (1<<31) -#define MEMMODE_BOOST_FREQ_MASK 0x0f000000 /* jitter for boost, 0-15 */ -#define MEMMODE_BOOST_FREQ_SHIFT 24 -#define MEMMODE_IDLE_MODE_MASK 0x00030000 -#define MEMMODE_IDLE_MODE_SHIFT 16 -#define MEMMODE_IDLE_MODE_EVAL 0 -#define MEMMODE_IDLE_MODE_CONT 1 -#define MEMMODE_HWIDLE_EN (1<<15) -#define MEMMODE_SWMODE_EN (1<<14) -#define MEMMODE_RCLK_GATE (1<<13) -#define MEMMODE_HW_UPDATE (1<<12) -#define MEMMODE_FSTART_MASK 0x00000f00 /* starting jitter, 0-15 */ -#define MEMMODE_FSTART_SHIFT 8 -#define MEMMODE_FMAX_MASK 0x000000f0 /* max jitter, 0-15 */ -#define MEMMODE_FMAX_SHIFT 4 -#define MEMMODE_FMIN_MASK 0x0000000f /* min jitter, 0-15 */ +#define MEMMODE_BOOST_EN (1<<31) +#define MEMMODE_BOOST_FREQ_MASK 0x0f000000 /* jitter for boost, 0-15 */ +#define MEMMODE_BOOST_FREQ_SHIFT 24 +#define MEMMODE_IDLE_MODE_MASK 0x00030000 +#define MEMMODE_IDLE_MODE_SHIFT 16 +#define MEMMODE_IDLE_MODE_EVAL 0 +#define MEMMODE_IDLE_MODE_CONT 1 +#define MEMMODE_HWIDLE_EN (1<<15) +#define MEMMODE_SWMODE_EN (1<<14) +#define MEMMODE_RCLK_GATE (1<<13) +#define MEMMODE_HW_UPDATE (1<<12) +#define MEMMODE_FSTART_MASK 0x00000f00 /* starting jitter, 0-15 */ +#define MEMMODE_FSTART_SHIFT 8 +#define MEMMODE_FMAX_MASK 0x000000f0 /* max jitter, 0-15 */ +#define MEMMODE_FMAX_SHIFT 4 +#define MEMMODE_FMIN_MASK 0x0000000f /* min jitter, 0-15 */ #define RCBMAXAVG 0x1119c #define MEMSWCTL2 0x1119e /* Cantiga only */ -#define SWMEMCMD_RENDER_OFF (0 << 13) -#define SWMEMCMD_RENDER_ON (1 << 13) -#define SWMEMCMD_SWFREQ (2 << 13) -#define SWMEMCMD_TARVID (3 << 13) -#define SWMEMCMD_VRM_OFF (4 << 13) -#define SWMEMCMD_VRM_ON (5 << 13) -#define CMDSTS (1<<12) -#define SFCAVM (1<<11) -#define SWFREQ_MASK 0x0380 /* P0-7 */ -#define SWFREQ_SHIFT 7 -#define TARVID_MASK 0x001f +#define SWMEMCMD_RENDER_OFF (0 << 13) +#define SWMEMCMD_RENDER_ON (1 << 13) +#define SWMEMCMD_SWFREQ (2 << 13) +#define SWMEMCMD_TARVID (3 << 13) +#define SWMEMCMD_VRM_OFF (4 << 13) +#define SWMEMCMD_VRM_ON (5 << 13) +#define CMDSTS (1<<12) +#define SFCAVM (1<<11) +#define SWFREQ_MASK 0x0380 /* P0-7 */ +#define SWFREQ_SHIFT 7 +#define TARVID_MASK 0x001f #define MEMSTAT_CTG 0x111a0 #define RCBMINAVG 0x111a0 #define RCUPEI 0x111b0 #define RCDNEI 0x111b4 #define RSTDBYCTL 0x111b8 -#define RS1EN (1<<31) -#define RS2EN (1<<30) -#define RS3EN (1<<29) -#define D3RS3EN (1<<28) /* Display D3 imlies RS3 */ -#define SWPROMORSX (1<<27) /* RSx promotion timers ignored */ -#define RCWAKERW (1<<26) /* Resetwarn from PCH causes wakeup */ -#define DPRSLPVREN (1<<25) /* Fast voltage ramp enable */ -#define GFXTGHYST (1<<24) /* Hysteresis to allow trunk gating */ -#define RCX_SW_EXIT (1<<23) /* Leave RSx and prevent re-entry */ -#define RSX_STATUS_MASK (7<<20) -#define RSX_STATUS_ON (0<<20) -#define RSX_STATUS_RC1 (1<<20) -#define RSX_STATUS_RC1E (2<<20) -#define RSX_STATUS_RS1 (3<<20) -#define RSX_STATUS_RS2 (4<<20) /* aka rc6 */ -#define RSX_STATUS_RSVD (5<<20) /* deep rc6 unsupported on ilk */ -#define RSX_STATUS_RS3 (6<<20) /* rs3 unsupported on ilk */ -#define RSX_STATUS_RSVD2 (7<<20) -#define UWRCRSXE (1<<19) /* wake counter limit prevents rsx */ -#define RSCRP (1<<18) /* rs requests control on rs1/2 reqs */ -#define JRSC (1<<17) /* rsx coupled to cpu c-state */ -#define RS2INC0 (1<<16) /* allow rs2 in cpu c0 */ -#define RS1CONTSAV_MASK (3<<14) -#define RS1CONTSAV_NO_RS1 (0<<14) /* rs1 doesn't save/restore context */ -#define RS1CONTSAV_RSVD (1<<14) -#define RS1CONTSAV_SAVE_RS1 (2<<14) /* rs1 saves context */ -#define RS1CONTSAV_FULL_RS1 (3<<14) /* rs1 saves and restores context */ -#define NORMSLEXLAT_MASK (3<<12) -#define SLOW_RS123 (0<<12) -#define SLOW_RS23 (1<<12) -#define SLOW_RS3 (2<<12) -#define NORMAL_RS123 (3<<12) -#define RCMODE_TIMEOUT (1<<11) /* 0 is eval interval method */ -#define IMPROMOEN (1<<10) /* promo is immediate or delayed until next idle interval (only for timeout method above) */ -#define RCENTSYNC (1<<9) /* rs coupled to cpu c-state (3/6/7) */ -#define STATELOCK (1<<7) /* locked to rs_cstate if 0 */ -#define RS_CSTATE_MASK (3<<4) -#define RS_CSTATE_C367_RS1 (0<<4) -#define RS_CSTATE_C36_RS1_C7_RS2 (1<<4) -#define RS_CSTATE_RSVD (2<<4) -#define RS_CSTATE_C367_RS2 (3<<4) -#define REDSAVES (1<<3) /* no context save if was idle during rs0 */ -#define REDRESTORES (1<<2) /* no restore if was idle during rs0 */ +#define RS1EN (1<<31) +#define RS2EN (1<<30) +#define RS3EN (1<<29) +#define D3RS3EN (1<<28) /* Display D3 imlies RS3 */ +#define SWPROMORSX (1<<27) /* RSx promotion timers ignored */ +#define RCWAKERW (1<<26) /* Resetwarn from PCH causes wakeup */ +#define DPRSLPVREN (1<<25) /* Fast voltage ramp enable */ +#define GFXTGHYST (1<<24) /* Hysteresis to allow trunk gating */ +#define RCX_SW_EXIT (1<<23) /* Leave RSx and prevent re-entry */ +#define RSX_STATUS_MASK (7<<20) +#define RSX_STATUS_ON (0<<20) +#define RSX_STATUS_RC1 (1<<20) +#define RSX_STATUS_RC1E (2<<20) +#define RSX_STATUS_RS1 (3<<20) +#define RSX_STATUS_RS2 (4<<20) /* aka rc6 */ +#define RSX_STATUS_RSVD (5<<20) /* deep rc6 unsupported on ilk */ +#define RSX_STATUS_RS3 (6<<20) /* rs3 unsupported on ilk */ +#define RSX_STATUS_RSVD2 (7<<20) +#define UWRCRSXE (1<<19) /* wake counter limit prevents rsx */ +#define RSCRP (1<<18) /* rs requests control on rs1/2 reqs */ +#define JRSC (1<<17) /* rsx coupled to cpu c-state */ +#define RS2INC0 (1<<16) /* allow rs2 in cpu c0 */ +#define RS1CONTSAV_MASK (3<<14) +#define RS1CONTSAV_NO_RS1 (0<<14) /* rs1 doesn't save/restore context */ +#define RS1CONTSAV_RSVD (1<<14) +#define RS1CONTSAV_SAVE_RS1 (2<<14) /* rs1 saves context */ +#define RS1CONTSAV_FULL_RS1 (3<<14) /* rs1 saves and restores context */ +#define NORMSLEXLAT_MASK (3<<12) +#define SLOW_RS123 (0<<12) +#define SLOW_RS23 (1<<12) +#define SLOW_RS3 (2<<12) +#define NORMAL_RS123 (3<<12) +#define RCMODE_TIMEOUT (1<<11) /* 0 is eval interval method */ +#define IMPROMOEN (1<<10) /* promo is immediate or delayed until next idle interval (only for timeout method above) */ +#define RCENTSYNC (1<<9) /* rs coupled to cpu c-state (3/6/7) */ +#define STATELOCK (1<<7) /* locked to rs_cstate if 0 */ +#define RS_CSTATE_MASK (3<<4) +#define RS_CSTATE_C367_RS1 (0<<4) +#define RS_CSTATE_C36_RS1_C7_RS2 (1<<4) +#define RS_CSTATE_RSVD (2<<4) +#define RS_CSTATE_C367_RS2 (3<<4) +#define REDSAVES (1<<3) /* no context save if was idle during rs0 */ +#define REDRESTORES (1<<2) /* no restore if was idle during rs0 */ #define VIDCTL 0x111c0 #define VIDSTS 0x111c8 #define VIDSTART 0x111cc /* 8 bits */ #define MEMSTAT_ILK 0x111f8 -#define MEMSTAT_VID_MASK 0x7f00 -#define MEMSTAT_VID_SHIFT 8 -#define MEMSTAT_PSTATE_MASK 0x00f8 -#define MEMSTAT_PSTATE_SHIFT 3 -#define MEMSTAT_MON_ACTV (1<<2) -#define MEMSTAT_SRC_CTL_MASK 0x0003 -#define MEMSTAT_SRC_CTL_CORE 0 -#define MEMSTAT_SRC_CTL_TRB 1 -#define MEMSTAT_SRC_CTL_THM 2 -#define MEMSTAT_SRC_CTL_STDBY 3 +#define MEMSTAT_VID_MASK 0x7f00 +#define MEMSTAT_VID_SHIFT 8 +#define MEMSTAT_PSTATE_MASK 0x00f8 +#define MEMSTAT_PSTATE_SHIFT 3 +#define MEMSTAT_MON_ACTV (1<<2) +#define MEMSTAT_SRC_CTL_MASK 0x0003 +#define MEMSTAT_SRC_CTL_CORE 0 +#define MEMSTAT_SRC_CTL_TRB 1 +#define MEMSTAT_SRC_CTL_THM 2 +#define MEMSTAT_SRC_CTL_STDBY 3 #define RCPREVBSYTUPAVG 0x113b8 #define RCPREVBSYTDNAVG 0x113bc #define PMMISC 0x11214 -#define MCPPCE_EN (1<<0) /* enable PM_MSG from PCH->MPC */ +#define MCPPCE_EN (1<<0) /* enable PM_MSG from PCH->MPC */ #define SDEW 0x1124c #define CSIEW0 0x11250 #define CSIEW1 0x11254 @@ -1330,9 +1330,9 @@ #define RPPREVBSYTUPAVG 0x113b8 #define RPPREVBSYTDNAVG 0x113bc #define ECR 0x11600 -#define ECR_GPFE (1<<31) -#define ECR_IMONE (1<<30) -#define ECR_CAP_MASK 0x0000001f /* Event range, 0-31 */ +#define ECR_GPFE (1<<31) +#define ECR_IMONE (1<<30) +#define ECR_CAP_MASK 0x0000001f /* Event range, 0-31 */ #define OGW0 0x11608 #define OGW1 0x1160c #define EG0 0x11610 @@ -1346,7 +1346,7 @@ #define PXW 0x11664 #define PXWL 0x11680 #define LCFUSE02 0x116c0 -#define LCFUSE_HIV_MASK 0x000000ff +#define LCFUSE_HIV_MASK 0x000000ff #define CSIPLL0 0x12c10 #define DDRMPLL1 0X12c20 #define PEG_BAND_GAP_DATA 0x14d68 @@ -1362,7 +1362,7 @@ * Logical Context regs */ #define CCID 0x2180 -#define CCID_EN (1<<0) +#define CCID_EN (1<<0) /* * Overlay regs */ @@ -1415,42 +1415,42 @@
/* VGA port control */ #define ADPA 0x61100 -#define ADPA_DAC_ENABLE (1<<31) -#define ADPA_DAC_DISABLE 0 -#define ADPA_PIPE_SELECT_MASK (1<<30) -#define ADPA_PIPE_A_SELECT 0 -#define ADPA_PIPE_B_SELECT (1<<30) -#define ADPA_PIPE_SELECT(pipe) ((pipe) << 30) -#define ADPA_USE_VGA_HVPOLARITY (1<<15) -#define ADPA_SETS_HVPOLARITY 0 -#define ADPA_VSYNC_CNTL_DISABLE (1<<11) -#define ADPA_VSYNC_CNTL_ENABLE 0 -#define ADPA_HSYNC_CNTL_DISABLE (1<<10) -#define ADPA_HSYNC_CNTL_ENABLE 0 -#define ADPA_VSYNC_ACTIVE_HIGH (1<<4) -#define ADPA_VSYNC_ACTIVE_LOW 0 -#define ADPA_HSYNC_ACTIVE_HIGH (1<<3) -#define ADPA_HSYNC_ACTIVE_LOW 0 -#define ADPA_DPMS_MASK (~(3<<10)) -#define ADPA_DPMS_ON (0<<10) -#define ADPA_DPMS_SUSPEND (1<<10) -#define ADPA_DPMS_STANDBY (2<<10) -#define ADPA_DPMS_OFF (3<<10) +#define ADPA_DAC_ENABLE (1<<31) +#define ADPA_DAC_DISABLE 0 +#define ADPA_PIPE_SELECT_MASK (1<<30) +#define ADPA_PIPE_A_SELECT 0 +#define ADPA_PIPE_B_SELECT (1<<30) +#define ADPA_PIPE_SELECT(pipe) ((pipe) << 30) +#define ADPA_USE_VGA_HVPOLARITY (1<<15) +#define ADPA_SETS_HVPOLARITY 0 +#define ADPA_VSYNC_CNTL_DISABLE (1<<11) +#define ADPA_VSYNC_CNTL_ENABLE 0 +#define ADPA_HSYNC_CNTL_DISABLE (1<<10) +#define ADPA_HSYNC_CNTL_ENABLE 0 +#define ADPA_VSYNC_ACTIVE_HIGH (1<<4) +#define ADPA_VSYNC_ACTIVE_LOW 0 +#define ADPA_HSYNC_ACTIVE_HIGH (1<<3) +#define ADPA_HSYNC_ACTIVE_LOW 0 +#define ADPA_DPMS_MASK (~(3<<10)) +#define ADPA_DPMS_ON (0<<10) +#define ADPA_DPMS_SUSPEND (1<<10) +#define ADPA_DPMS_STANDBY (2<<10) +#define ADPA_DPMS_OFF (3<<10)
/* Hotplug control (945+ only) */ #define PORT_HOTPLUG_EN 0x61110 -#define HDMIB_HOTPLUG_INT_EN (1 << 29) -#define DPB_HOTPLUG_INT_EN (1 << 29) -#define HDMIC_HOTPLUG_INT_EN (1 << 28) -#define DPC_HOTPLUG_INT_EN (1 << 28) -#define HDMID_HOTPLUG_INT_EN (1 << 27) -#define DPD_HOTPLUG_INT_EN (1 << 27) -#define SDVOB_HOTPLUG_INT_EN (1 << 26) -#define SDVOC_HOTPLUG_INT_EN (1 << 25) -#define TV_HOTPLUG_INT_EN (1 << 18) -#define CRT_HOTPLUG_INT_EN (1 << 9) -#define CRT_HOTPLUG_FORCE_DETECT (1 << 3) +#define HDMIB_HOTPLUG_INT_EN (1 << 29) +#define DPB_HOTPLUG_INT_EN (1 << 29) +#define HDMIC_HOTPLUG_INT_EN (1 << 28) +#define DPC_HOTPLUG_INT_EN (1 << 28) +#define HDMID_HOTPLUG_INT_EN (1 << 27) +#define DPD_HOTPLUG_INT_EN (1 << 27) +#define SDVOB_HOTPLUG_INT_EN (1 << 26) +#define SDVOC_HOTPLUG_INT_EN (1 << 25) +#define TV_HOTPLUG_INT_EN (1 << 18) +#define CRT_HOTPLUG_INT_EN (1 << 9) +#define CRT_HOTPLUG_FORCE_DETECT (1 << 3) #define CRT_HOTPLUG_ACTIVATION_PERIOD_32 (0 << 8) /* must use period 64 on GM45 according to docs */ #define CRT_HOTPLUG_ACTIVATION_PERIOD_64 (1 << 8) @@ -1467,28 +1467,28 @@ #define CRT_HOTPLUG_DETECT_VOLTAGE_475MV (1 << 2)
#define PORT_HOTPLUG_STAT 0x61114 -#define HDMIB_HOTPLUG_INT_STATUS (1 << 29) -#define DPB_HOTPLUG_INT_STATUS (1 << 29) -#define HDMIC_HOTPLUG_INT_STATUS (1 << 28) -#define DPC_HOTPLUG_INT_STATUS (1 << 28) -#define HDMID_HOTPLUG_INT_STATUS (1 << 27) -#define DPD_HOTPLUG_INT_STATUS (1 << 27) -#define CRT_HOTPLUG_INT_STATUS (1 << 11) -#define TV_HOTPLUG_INT_STATUS (1 << 10) -#define CRT_HOTPLUG_MONITOR_MASK (3 << 8) -#define CRT_HOTPLUG_MONITOR_COLOR (3 << 8) -#define CRT_HOTPLUG_MONITOR_MONO (2 << 8) -#define CRT_HOTPLUG_MONITOR_NONE (0 << 8) -#define SDVOC_HOTPLUG_INT_STATUS (1 << 7) -#define SDVOB_HOTPLUG_INT_STATUS (1 << 6) +#define HDMIB_HOTPLUG_INT_STATUS (1 << 29) +#define DPB_HOTPLUG_INT_STATUS (1 << 29) +#define HDMIC_HOTPLUG_INT_STATUS (1 << 28) +#define DPC_HOTPLUG_INT_STATUS (1 << 28) +#define HDMID_HOTPLUG_INT_STATUS (1 << 27) +#define DPD_HOTPLUG_INT_STATUS (1 << 27) +#define CRT_HOTPLUG_INT_STATUS (1 << 11) +#define TV_HOTPLUG_INT_STATUS (1 << 10) +#define CRT_HOTPLUG_MONITOR_MASK (3 << 8) +#define CRT_HOTPLUG_MONITOR_COLOR (3 << 8) +#define CRT_HOTPLUG_MONITOR_MONO (2 << 8) +#define CRT_HOTPLUG_MONITOR_NONE (0 << 8) +#define SDVOC_HOTPLUG_INT_STATUS (1 << 7) +#define SDVOB_HOTPLUG_INT_STATUS (1 << 6)
/* SDVO port control */ #define SDVOB 0x61140 #define SDVOC 0x61160 -#define SDVO_ENABLE (1 << 31) -#define SDVO_PIPE_B_SELECT (1 << 30) -#define SDVO_STALL_SELECT (1 << 29) -#define SDVO_INTERRUPT_ENABLE (1 << 26) +#define SDVO_ENABLE (1 << 31) +#define SDVO_PIPE_B_SELECT (1 << 30) +#define SDVO_STALL_SELECT (1 << 29) +#define SDVO_INTERRUPT_ENABLE (1 << 26) /** * 915G/GM SDVO pixel multiplier. * @@ -1496,62 +1496,62 @@ * * \sa DPLL_MD_UDI_MULTIPLIER_MASK */ -#define SDVO_PORT_MULTIPLY_MASK (7 << 23) -#define SDVO_PORT_MULTIPLY_SHIFT 23 -#define SDVO_PHASE_SELECT_MASK (15 << 19) -#define SDVO_PHASE_SELECT_DEFAULT (6 << 19) -#define SDVO_CLOCK_OUTPUT_INVERT (1 << 18) -#define SDVOC_GANG_MODE (1 << 16) -#define SDVO_ENCODING_SDVO (0x0 << 10) -#define SDVO_ENCODING_HDMI (0x2 << 10) +#define SDVO_PORT_MULTIPLY_MASK (7 << 23) +#define SDVO_PORT_MULTIPLY_SHIFT 23 +#define SDVO_PHASE_SELECT_MASK (15 << 19) +#define SDVO_PHASE_SELECT_DEFAULT (6 << 19) +#define SDVO_CLOCK_OUTPUT_INVERT (1 << 18) +#define SDVOC_GANG_MODE (1 << 16) +#define SDVO_ENCODING_SDVO (0x0 << 10) +#define SDVO_ENCODING_HDMI (0x2 << 10) /** Requird for HDMI operation */ -#define SDVO_NULL_PACKETS_DURING_VSYNC (1 << 9) -#define SDVO_COLOR_RANGE_16_235 (1 << 8) -#define SDVO_BORDER_ENABLE (1 << 7) -#define SDVO_AUDIO_ENABLE (1 << 6) +#define SDVO_NULL_PACKETS_DURING_VSYNC (1 << 9) +#define SDVO_COLOR_RANGE_16_235 (1 << 8) +#define SDVO_BORDER_ENABLE (1 << 7) +#define SDVO_AUDIO_ENABLE (1 << 6) /** New with 965, default is to be set */ -#define SDVO_VSYNC_ACTIVE_HIGH (1 << 4) +#define SDVO_VSYNC_ACTIVE_HIGH (1 << 4) /** New with 965, default is to be set */ -#define SDVO_HSYNC_ACTIVE_HIGH (1 << 3) -#define SDVOB_PCIE_CONCURRENCY (1 << 3) -#define SDVO_DETECTED (1 << 2) +#define SDVO_HSYNC_ACTIVE_HIGH (1 << 3) +#define SDVOB_PCIE_CONCURRENCY (1 << 3) +#define SDVO_DETECTED (1 << 2) /* Bits to be preserved when writing */ -#define SDVOB_PRESERVE_MASK ((1 << 17) | (1 << 16) | (1 << 14) | (1 << 26)) -#define SDVOC_PRESERVE_MASK ((1 << 17) | (1 << 26)) +#define SDVOB_PRESERVE_MASK ((1 << 17) | (1 << 16) | (1 << 14) | (1 << 26)) +#define SDVOC_PRESERVE_MASK ((1 << 17) | (1 << 26))
/* DVO port control */ #define DVOA 0x61120 #define DVOB 0x61140 #define DVOC 0x61160 -#define DVO_ENABLE (1 << 31) -#define DVO_PIPE_B_SELECT (1 << 30) -#define DVO_PIPE_STALL_UNUSED (0 << 28) -#define DVO_PIPE_STALL (1 << 28) -#define DVO_PIPE_STALL_TV (2 << 28) -#define DVO_PIPE_STALL_MASK (3 << 28) -#define DVO_USE_VGA_SYNC (1 << 15) -#define DVO_DATA_ORDER_I740 (0 << 14) -#define DVO_DATA_ORDER_FP (1 << 14) -#define DVO_VSYNC_DISABLE (1 << 11) -#define DVO_HSYNC_DISABLE (1 << 10) -#define DVO_VSYNC_TRISTATE (1 << 9) -#define DVO_HSYNC_TRISTATE (1 << 8) -#define DVO_BORDER_ENABLE (1 << 7) -#define DVO_DATA_ORDER_GBRG (1 << 6) -#define DVO_DATA_ORDER_RGGB (0 << 6) -#define DVO_DATA_ORDER_GBRG_ERRATA (0 << 6) -#define DVO_DATA_ORDER_RGGB_ERRATA (1 << 6) -#define DVO_VSYNC_ACTIVE_HIGH (1 << 4) -#define DVO_HSYNC_ACTIVE_HIGH (1 << 3) -#define DVO_BLANK_ACTIVE_HIGH (1 << 2) -#define DVO_OUTPUT_CSTATE_PIXELS (1 << 1) /* SDG only */ -#define DVO_OUTPUT_SOURCE_SIZE_PIXELS (1 << 0) /* SDG only */ -#define DVO_PRESERVE_MASK (0x7<<24) +#define DVO_ENABLE (1 << 31) +#define DVO_PIPE_B_SELECT (1 << 30) +#define DVO_PIPE_STALL_UNUSED (0 << 28) +#define DVO_PIPE_STALL (1 << 28) +#define DVO_PIPE_STALL_TV (2 << 28) +#define DVO_PIPE_STALL_MASK (3 << 28) +#define DVO_USE_VGA_SYNC (1 << 15) +#define DVO_DATA_ORDER_I740 (0 << 14) +#define DVO_DATA_ORDER_FP (1 << 14) +#define DVO_VSYNC_DISABLE (1 << 11) +#define DVO_HSYNC_DISABLE (1 << 10) +#define DVO_VSYNC_TRISTATE (1 << 9) +#define DVO_HSYNC_TRISTATE (1 << 8) +#define DVO_BORDER_ENABLE (1 << 7) +#define DVO_DATA_ORDER_GBRG (1 << 6) +#define DVO_DATA_ORDER_RGGB (0 << 6) +#define DVO_DATA_ORDER_GBRG_ERRATA (0 << 6) +#define DVO_DATA_ORDER_RGGB_ERRATA (1 << 6) +#define DVO_VSYNC_ACTIVE_HIGH (1 << 4) +#define DVO_HSYNC_ACTIVE_HIGH (1 << 3) +#define DVO_BLANK_ACTIVE_HIGH (1 << 2) +#define DVO_OUTPUT_CSTATE_PIXELS (1 << 1) /* SDG only */ +#define DVO_OUTPUT_SOURCE_SIZE_PIXELS (1 << 0) /* SDG only */ +#define DVO_PRESERVE_MASK (0x7<<24) #define DVOA_SRCDIM 0x61124 #define DVOB_SRCDIM 0x61144 #define DVOC_SRCDIM 0x61164 -#define DVO_SRCDIM_HORIZONTAL_SHIFT 12 -#define DVO_SRCDIM_VERTICAL_SHIFT 0 +#define DVO_SRCDIM_HORIZONTAL_SHIFT 12 +#define DVO_SRCDIM_VERTICAL_SHIFT 0
/* LVDS port control */ #define LVDS 0x61180 @@ -1559,70 +1559,70 @@ * Enables the LVDS port. This bit must be set before DPLLs are enabled, as * the DPLL semantics change when the LVDS is assigned to that pipe. */ -#define LVDS_PORT_EN (1 << 31) +#define LVDS_PORT_EN (1 << 31) /* Selects pipe B for LVDS data. Must be set on pre-965. */ -#define LVDS_PIPEB_SELECT (1 << 30) -#define LVDS_PIPE_MASK (1 << 30) -#define LVDS_PIPE(pipe) ((pipe) << 30) +#define LVDS_PIPEB_SELECT (1 << 30) +#define LVDS_PIPE_MASK (1 << 30) +#define LVDS_PIPE(pipe) ((pipe) << 30) /* LVDS dithering flag on 965/g4x platform */ -#define LVDS_ENABLE_DITHER (1 << 25) +#define LVDS_ENABLE_DITHER (1 << 25) /* LVDS sync polarity flags. Set to invert (i.e. negative) */ -#define LVDS_VSYNC_POLARITY (1 << 21) -#define LVDS_HSYNC_POLARITY (1 << 20) +#define LVDS_VSYNC_POLARITY (1 << 21) +#define LVDS_HSYNC_POLARITY (1 << 20)
/* Enable border for unscaled (or aspect-scaled) display */ -#define LVDS_BORDER_ENABLE (1 << 15) +#define LVDS_BORDER_ENABLE (1 << 15) /* * Enables the A0-A2 data pairs and CLKA, containing 18 bits of color data per * pixel. */ -#define LVDS_A0A2_CLKA_POWER_MASK (3 << 8) -#define LVDS_A0A2_CLKA_POWER_DOWN (0 << 8) -#define LVDS_A0A2_CLKA_POWER_UP (3 << 8) +#define LVDS_A0A2_CLKA_POWER_MASK (3 << 8) +#define LVDS_A0A2_CLKA_POWER_DOWN (0 << 8) +#define LVDS_A0A2_CLKA_POWER_UP (3 << 8) /* * Controls the A3 data pair, which contains the additional LSBs for 24 bit * mode. Only enabled if LVDS_A0A2_CLKA_POWER_UP also indicates it should be * on. */ -#define LVDS_A3_POWER_MASK (3 << 6) -#define LVDS_A3_POWER_DOWN (0 << 6) -#define LVDS_A3_POWER_UP (3 << 6) +#define LVDS_A3_POWER_MASK (3 << 6) +#define LVDS_A3_POWER_DOWN (0 << 6) +#define LVDS_A3_POWER_UP (3 << 6) /* * Controls the CLKB pair. This should only be set when LVDS_B0B3_POWER_UP * is set. */ -#define LVDS_CLKB_POWER_MASK (3 << 4) -#define LVDS_CLKB_POWER_DOWN (0 << 4) -#define LVDS_CLKB_POWER_UP (3 << 4) +#define LVDS_CLKB_POWER_MASK (3 << 4) +#define LVDS_CLKB_POWER_DOWN (0 << 4) +#define LVDS_CLKB_POWER_UP (3 << 4) /* * Controls the B0-B3 data pairs. This must be set to match the DPLL p2 * setting for whether we are in dual-channel mode. The B3 pair will * additionally only be powered up when LVDS_A3_POWER_UP is set. */ -#define LVDS_B0B3_POWER_MASK (3 << 2) -#define LVDS_B0B3_POWER_DOWN (0 << 2) -#define LVDS_B0B3_POWER_UP (3 << 2) +#define LVDS_B0B3_POWER_MASK (3 << 2) +#define LVDS_B0B3_POWER_DOWN (0 << 2) +#define LVDS_B0B3_POWER_UP (3 << 2)
/* Video Data Island Packet control */ #define VIDEO_DIP_DATA 0x61178 #define VIDEO_DIP_CTL 0x61170 -#define VIDEO_DIP_ENABLE (1 << 31) -#define VIDEO_DIP_PORT_B (1 << 29) -#define VIDEO_DIP_PORT_C (2 << 29) -#define VIDEO_DIP_ENABLE_AVI (1 << 21) -#define VIDEO_DIP_ENABLE_VENDOR (2 << 21) -#define VIDEO_DIP_ENABLE_SPD (8 << 21) -#define VIDEO_DIP_SELECT_AVI (0 << 19) -#define VIDEO_DIP_SELECT_VENDOR (1 << 19) -#define VIDEO_DIP_SELECT_SPD (3 << 19) -#define VIDEO_DIP_SELECT_MASK (3 << 19) -#define VIDEO_DIP_FREQ_ONCE (0 << 16) -#define VIDEO_DIP_FREQ_VSYNC (1 << 16) -#define VIDEO_DIP_FREQ_2VSYNC (2 << 16) +#define VIDEO_DIP_ENABLE (1 << 31) +#define VIDEO_DIP_PORT_B (1 << 29) +#define VIDEO_DIP_PORT_C (2 << 29) +#define VIDEO_DIP_ENABLE_AVI (1 << 21) +#define VIDEO_DIP_ENABLE_VENDOR (2 << 21) +#define VIDEO_DIP_ENABLE_SPD (8 << 21) +#define VIDEO_DIP_SELECT_AVI (0 << 19) +#define VIDEO_DIP_SELECT_VENDOR (1 << 19) +#define VIDEO_DIP_SELECT_SPD (3 << 19) +#define VIDEO_DIP_SELECT_MASK (3 << 19) +#define VIDEO_DIP_FREQ_ONCE (0 << 16) +#define VIDEO_DIP_FREQ_VSYNC (1 << 16) +#define VIDEO_DIP_FREQ_2VSYNC (2 << 16)
/* Panel power sequencing */ #define PP_STATUS 0x61200 -#define PP_ON (1 << 31) +#define PP_ON (1 << 31) /* * Indicates that all dependencies of the panel are on: * @@ -1630,51 +1630,51 @@ * - pipe enabled * - LVDS/DVOB/DVOC on */ -#define PP_READY (1 << 30) -#define PP_SEQUENCE_NONE (0 << 28) -#define PP_SEQUENCE_POWER_UP (1 << 28) -#define PP_SEQUENCE_POWER_DOWN (2 << 28) -#define PP_SEQUENCE_MASK (3 << 28) -#define PP_SEQUENCE_SHIFT 28 -#define PP_CYCLE_DELAY_ACTIVE (1 << 27) -#define PP_SEQUENCE_STATE_MASK 0x0000000f -#define PP_SEQUENCE_STATE_OFF_IDLE (0x0 << 0) -#define PP_SEQUENCE_STATE_OFF_S0_1 (0x1 << 0) -#define PP_SEQUENCE_STATE_OFF_S0_2 (0x2 << 0) -#define PP_SEQUENCE_STATE_OFF_S0_3 (0x3 << 0) -#define PP_SEQUENCE_STATE_ON_IDLE (0x8 << 0) -#define PP_SEQUENCE_STATE_ON_S1_0 (0x9 << 0) -#define PP_SEQUENCE_STATE_ON_S1_2 (0xa << 0) -#define PP_SEQUENCE_STATE_ON_S1_3 (0xb << 0) -#define PP_SEQUENCE_STATE_RESET (0xf << 0) +#define PP_READY (1 << 30) +#define PP_SEQUENCE_NONE (0 << 28) +#define PP_SEQUENCE_POWER_UP (1 << 28) +#define PP_SEQUENCE_POWER_DOWN (2 << 28) +#define PP_SEQUENCE_MASK (3 << 28) +#define PP_SEQUENCE_SHIFT 28 +#define PP_CYCLE_DELAY_ACTIVE (1 << 27) +#define PP_SEQUENCE_STATE_MASK 0x0000000f +#define PP_SEQUENCE_STATE_OFF_IDLE (0x0 << 0) +#define PP_SEQUENCE_STATE_OFF_S0_1 (0x1 << 0) +#define PP_SEQUENCE_STATE_OFF_S0_2 (0x2 << 0) +#define PP_SEQUENCE_STATE_OFF_S0_3 (0x3 << 0) +#define PP_SEQUENCE_STATE_ON_IDLE (0x8 << 0) +#define PP_SEQUENCE_STATE_ON_S1_0 (0x9 << 0) +#define PP_SEQUENCE_STATE_ON_S1_2 (0xa << 0) +#define PP_SEQUENCE_STATE_ON_S1_3 (0xb << 0) +#define PP_SEQUENCE_STATE_RESET (0xf << 0) #define PP_CONTROL 0x61204 -#define POWER_TARGET_ON (1 << 0) +#define POWER_TARGET_ON (1 << 0) #define PP_ON_DELAYS 0x61208 #define PP_OFF_DELAYS 0x6120c #define PP_DIVISOR 0x61210
/* Panel fitting */ #define PFIT_CONTROL 0x61230 -#define PFIT_ENABLE (1 << 31) -#define PFIT_PIPE_MASK (3 << 29) -#define PFIT_PIPE_SHIFT 29 -#define VERT_INTERP_DISABLE (0 << 10) -#define VERT_INTERP_BILINEAR (1 << 10) -#define VERT_INTERP_MASK (3 << 10) -#define VERT_AUTO_SCALE (1 << 9) -#define HORIZ_INTERP_DISABLE (0 << 6) -#define HORIZ_INTERP_BILINEAR (1 << 6) -#define HORIZ_INTERP_MASK (3 << 6) -#define HORIZ_AUTO_SCALE (1 << 5) -#define PANEL_8TO6_DITHER_ENABLE (1 << 3) -#define PFIT_FILTER_FUZZY (0 << 24) -#define PFIT_SCALING_AUTO (0 << 26) -#define PFIT_SCALING_PROGRAMMED (1 << 26) -#define PFIT_SCALING_PILLAR (2 << 26) -#define PFIT_SCALING_LETTER (3 << 26) +#define PFIT_ENABLE (1 << 31) +#define PFIT_PIPE_MASK (3 << 29) +#define PFIT_PIPE_SHIFT 29 +#define VERT_INTERP_DISABLE (0 << 10) +#define VERT_INTERP_BILINEAR (1 << 10) +#define VERT_INTERP_MASK (3 << 10) +#define VERT_AUTO_SCALE (1 << 9) +#define HORIZ_INTERP_DISABLE (0 << 6) +#define HORIZ_INTERP_BILINEAR (1 << 6) +#define HORIZ_INTERP_MASK (3 << 6) +#define HORIZ_AUTO_SCALE (1 << 5) +#define PANEL_8TO6_DITHER_ENABLE (1 << 3) +#define PFIT_FILTER_FUZZY (0 << 24) +#define PFIT_SCALING_AUTO (0 << 26) +#define PFIT_SCALING_PROGRAMMED (1 << 26) +#define PFIT_SCALING_PILLAR (2 << 26) +#define PFIT_SCALING_LETTER (3 << 26) #define PFIT_PGM_RATIOS 0x61234 -#define PFIT_VERT_SCALE_MASK 0xfff00000 -#define PFIT_HORIZ_SCALE_MASK 0x0000fff0 +#define PFIT_VERT_SCALE_MASK 0xfff00000 +#define PFIT_HORIZ_SCALE_MASK 0x0000fff0 /* Pre-965 */ #define PFIT_VERT_SCALE_SHIFT 20 #define PFIT_VERT_SCALE_MASK 0xfff00000 @@ -1690,17 +1690,17 @@
/* Backlight control */ #define BLC_PWM_CTL 0x61254 -#define BACKLIGHT_MODULATION_FREQ_SHIFT (17) +#define BACKLIGHT_MODULATION_FREQ_SHIFT (17) #define BLC_PWM_CTL2 0x61250 /* 965+ only */ -#define BLM_COMBINATION_MODE (1 << 30) +#define BLM_COMBINATION_MODE (1 << 30) /* * This is the most significant 15 bits of the number of backlight cycles in a * complete cycle of the modulated backlight control. * * The actual value is this field multiplied by two. */ -#define BACKLIGHT_MODULATION_FREQ_MASK (0x7fff << 17) -#define BLM_LEGACY_MODE (1 << 16) +#define BACKLIGHT_MODULATION_FREQ_MASK (0x7fff << 17) +#define BLM_LEGACY_MODE (1 << 16) /* * This is the number of cycles out of the backlight modulation cycle for which * the backlight is on. @@ -1708,8 +1708,8 @@ * This field must be no greater than the number of cycles in the complete * backlight modulation cycle. */ -#define BACKLIGHT_DUTY_CYCLE_SHIFT (0) -#define BACKLIGHT_DUTY_CYCLE_MASK (0xffff) +#define BACKLIGHT_DUTY_CYCLE_SHIFT (0) +#define BACKLIGHT_DUTY_CYCLE_MASK (0xffff)
#define BLC_HIST_CTL 0x61260
@@ -2199,82 +2199,82 @@ #define DP_C 0x64200 #define DP_D 0x64300
-#define DP_PORT_EN (1 << 31) -#define DP_PIPEB_SELECT (1 << 30) -#define DP_PIPE_MASK (1 << 30) +#define DP_PORT_EN (1 << 31) +#define DP_PIPEB_SELECT (1 << 30) +#define DP_PIPE_MASK (1 << 30)
/* Link training mode - select a suitable mode for each stage */ -#define DP_LINK_TRAIN_PAT_1 (0 << 28) -#define DP_LINK_TRAIN_PAT_2 (1 << 28) -#define DP_LINK_TRAIN_PAT_IDLE (2 << 28) -#define DP_LINK_TRAIN_OFF (3 << 28) -#define DP_LINK_TRAIN_MASK (3 << 28) -#define DP_LINK_TRAIN_SHIFT 28 +#define DP_LINK_TRAIN_PAT_1 (0 << 28) +#define DP_LINK_TRAIN_PAT_2 (1 << 28) +#define DP_LINK_TRAIN_PAT_IDLE (2 << 28) +#define DP_LINK_TRAIN_OFF (3 << 28) +#define DP_LINK_TRAIN_MASK (3 << 28) +#define DP_LINK_TRAIN_SHIFT 28
/* CPT Link training mode */ -#define DP_LINK_TRAIN_PAT_1_CPT (0 << 8) -#define DP_LINK_TRAIN_PAT_2_CPT (1 << 8) -#define DP_LINK_TRAIN_PAT_IDLE_CPT (2 << 8) -#define DP_LINK_TRAIN_OFF_CPT (3 << 8) -#define DP_LINK_TRAIN_MASK_CPT (7 << 8) -#define DP_LINK_TRAIN_SHIFT_CPT 8 +#define DP_LINK_TRAIN_PAT_1_CPT (0 << 8) +#define DP_LINK_TRAIN_PAT_2_CPT (1 << 8) +#define DP_LINK_TRAIN_PAT_IDLE_CPT (2 << 8) +#define DP_LINK_TRAIN_OFF_CPT (3 << 8) +#define DP_LINK_TRAIN_MASK_CPT (7 << 8) +#define DP_LINK_TRAIN_SHIFT_CPT 8
/* Signal voltages. These are mostly controlled by the other end */ -#define DP_VOLTAGE_0_4 (0 << 25) -#define DP_VOLTAGE_0_6 (1 << 25) -#define DP_VOLTAGE_0_8 (2 << 25) -#define DP_VOLTAGE_1_2 (3 << 25) -#define DP_VOLTAGE_MASK (7 << 25) -#define DP_VOLTAGE_SHIFT 25 +#define DP_VOLTAGE_0_4 (0 << 25) +#define DP_VOLTAGE_0_6 (1 << 25) +#define DP_VOLTAGE_0_8 (2 << 25) +#define DP_VOLTAGE_1_2 (3 << 25) +#define DP_VOLTAGE_MASK (7 << 25) +#define DP_VOLTAGE_SHIFT 25
/* Signal pre-emphasis levels, like voltages, the other end tells us what * they want */ -#define DP_PRE_EMPHASIS_0 (0 << 22) -#define DP_PRE_EMPHASIS_3_5 (1 << 22) -#define DP_PRE_EMPHASIS_6 (2 << 22) -#define DP_PRE_EMPHASIS_9_5 (3 << 22) -#define DP_PRE_EMPHASIS_MASK (7 << 22) -#define DP_PRE_EMPHASIS_SHIFT 22 +#define DP_PRE_EMPHASIS_0 (0 << 22) +#define DP_PRE_EMPHASIS_3_5 (1 << 22) +#define DP_PRE_EMPHASIS_6 (2 << 22) +#define DP_PRE_EMPHASIS_9_5 (3 << 22) +#define DP_PRE_EMPHASIS_MASK (7 << 22) +#define DP_PRE_EMPHASIS_SHIFT 22
/* How many wires to use. I guess 3 was too hard */ -#define DP_PORT_WIDTH_1 (0 << 19) -#define DP_PORT_WIDTH_2 (1 << 19) -#define DP_PORT_WIDTH_4 (3 << 19) -#define DP_PORT_WIDTH_MASK (7 << 19) +#define DP_PORT_WIDTH_1 (0 << 19) +#define DP_PORT_WIDTH_2 (1 << 19) +#define DP_PORT_WIDTH_4 (3 << 19) +#define DP_PORT_WIDTH_MASK (7 << 19)
/* Mystic DPCD version 1.1 special mode */ -#define DP_ENHANCED_FRAMING (1 << 18) +#define DP_ENHANCED_FRAMING (1 << 18)
/* eDP */ -#define DP_PLL_FREQ_270MHZ (0 << 16) -#define DP_PLL_FREQ_160MHZ (1 << 16) -#define DP_PLL_FREQ_MASK (3 << 16) +#define DP_PLL_FREQ_270MHZ (0 << 16) +#define DP_PLL_FREQ_160MHZ (1 << 16) +#define DP_PLL_FREQ_MASK (3 << 16)
/** locked once port is enabled */ -#define DP_PORT_REVERSAL (1 << 15) +#define DP_PORT_REVERSAL (1 << 15)
/* eDP */ -#define DP_PLL_ENABLE (1 << 14) +#define DP_PLL_ENABLE (1 << 14)
/** sends the clock on lane 15 of the PEG for debug */ -#define DP_CLOCK_OUTPUT_ENABLE (1 << 13) +#define DP_CLOCK_OUTPUT_ENABLE (1 << 13)
-#define DP_SCRAMBLING_DISABLE (1 << 12) -#define DP_SCRAMBLING_DISABLE_IRONLAKE (1 << 7) +#define DP_SCRAMBLING_DISABLE (1 << 12) +#define DP_SCRAMBLING_DISABLE_IRONLAKE (1 << 7)
/** limit RGB values to avoid confusing TVs */ -#define DP_COLOR_RANGE_16_235 (1 << 8) +#define DP_COLOR_RANGE_16_235 (1 << 8)
/** Turn on the audio link */ -#define DP_AUDIO_OUTPUT_ENABLE (1 << 6) +#define DP_AUDIO_OUTPUT_ENABLE (1 << 6)
/** vs and hs sync polarity */ -#define DP_SYNC_VS_HIGH (1 << 4) -#define DP_SYNC_HS_HIGH (1 << 3) +#define DP_SYNC_VS_HIGH (1 << 4) +#define DP_SYNC_HS_HIGH (1 << 3)
/** A fantasy */ -#define DP_DETECTED (1 << 2) +#define DP_DETECTED (1 << 2)
/** The aux channel provides a way to talk to the * signal sink for DDC etc. Max packet size supported @@ -2309,27 +2309,27 @@ #define DPD_AUX_CH_DATA4 0x64320 #define DPD_AUX_CH_DATA5 0x64324
-#define DP_AUX_CH_CTL_SEND_BUSY (1 << 31) -#define DP_AUX_CH_CTL_DONE (1 << 30) -#define DP_AUX_CH_CTL_INTERRUPT (1 << 29) -#define DP_AUX_CH_CTL_TIME_OUT_ERROR (1 << 28) -#define DP_AUX_CH_CTL_TIME_OUT_400us (0 << 26) -#define DP_AUX_CH_CTL_TIME_OUT_600us (1 << 26) -#define DP_AUX_CH_CTL_TIME_OUT_800us (2 << 26) -#define DP_AUX_CH_CTL_TIME_OUT_1600us (3 << 26) -#define DP_AUX_CH_CTL_TIME_OUT_MASK (3 << 26) -#define DP_AUX_CH_CTL_RECEIVE_ERROR (1 << 25) -#define DP_AUX_CH_CTL_MESSAGE_SIZE_MASK (0x1f << 20) -#define DP_AUX_CH_CTL_MESSAGE_SIZE_SHIFT 20 -#define DP_AUX_CH_CTL_PRECHARGE_2US_MASK (0xf << 16) -#define DP_AUX_CH_CTL_PRECHARGE_2US_SHIFT 16 -#define DP_AUX_CH_CTL_AUX_AKSV_SELECT (1 << 15) -#define DP_AUX_CH_CTL_MANCHESTER_TEST (1 << 14) -#define DP_AUX_CH_CTL_SYNC_TEST (1 << 13) -#define DP_AUX_CH_CTL_DEGLITCH_TEST (1 << 12) -#define DP_AUX_CH_CTL_PRECHARGE_TEST (1 << 11) -#define DP_AUX_CH_CTL_BIT_CLOCK_2X_MASK (0x7ff) -#define DP_AUX_CH_CTL_BIT_CLOCK_2X_SHIFT 0 +#define DP_AUX_CH_CTL_SEND_BUSY (1 << 31) +#define DP_AUX_CH_CTL_DONE (1 << 30) +#define DP_AUX_CH_CTL_INTERRUPT (1 << 29) +#define DP_AUX_CH_CTL_TIME_OUT_ERROR (1 << 28) +#define DP_AUX_CH_CTL_TIME_OUT_400us (0 << 26) +#define DP_AUX_CH_CTL_TIME_OUT_600us (1 << 26) +#define DP_AUX_CH_CTL_TIME_OUT_800us (2 << 26) +#define DP_AUX_CH_CTL_TIME_OUT_1600us (3 << 26) +#define DP_AUX_CH_CTL_TIME_OUT_MASK (3 << 26) +#define DP_AUX_CH_CTL_RECEIVE_ERROR (1 << 25) +#define DP_AUX_CH_CTL_MESSAGE_SIZE_MASK (0x1f << 20) +#define DP_AUX_CH_CTL_MESSAGE_SIZE_SHIFT 20 +#define DP_AUX_CH_CTL_PRECHARGE_2US_MASK (0xf << 16) +#define DP_AUX_CH_CTL_PRECHARGE_2US_SHIFT 16 +#define DP_AUX_CH_CTL_AUX_AKSV_SELECT (1 << 15) +#define DP_AUX_CH_CTL_MANCHESTER_TEST (1 << 14) +#define DP_AUX_CH_CTL_SYNC_TEST (1 << 13) +#define DP_AUX_CH_CTL_DEGLITCH_TEST (1 << 12) +#define DP_AUX_CH_CTL_PRECHARGE_TEST (1 << 11) +#define DP_AUX_CH_CTL_BIT_CLOCK_2X_MASK (0x7ff) +#define DP_AUX_CH_CTL_BIT_CLOCK_2X_SHIFT 0
/* * Computing GMCH M and N values for the Display Port link @@ -2348,14 +2348,14 @@ #define _PIPEB_GMCH_DATA_M 0x71050
/* Transfer unit size for display port - 1, default is 0x3f (for TU size 64) */ -#define PIPE_GMCH_DATA_M_TU_SIZE_MASK (0x3f << 25) -#define PIPE_GMCH_DATA_M_TU_SIZE_SHIFT 25 +#define PIPE_GMCH_DATA_M_TU_SIZE_MASK (0x3f << 25) +#define PIPE_GMCH_DATA_M_TU_SIZE_SHIFT 25
-#define PIPE_GMCH_DATA_M_MASK (0xffffff) +#define PIPE_GMCH_DATA_M_MASK (0xffffff)
#define _PIPEA_GMCH_DATA_N 0x70054 #define _PIPEB_GMCH_DATA_N 0x71054 -#define PIPE_GMCH_DATA_N_MASK (0xffffff) +#define PIPE_GMCH_DATA_N_MASK (0xffffff)
/* * Computing Link M and N values for the Display Port link @@ -2370,11 +2370,11 @@
#define _PIPEA_DP_LINK_M 0x70060 #define _PIPEB_DP_LINK_M 0x71060 -#define PIPEA_DP_LINK_M_MASK (0xffffff) +#define PIPEA_DP_LINK_M_MASK (0xffffff)
#define _PIPEA_DP_LINK_N 0x70064 #define _PIPEB_DP_LINK_N 0x71064 -#define PIPEA_DP_LINK_N_MASK (0xffffff) +#define PIPEA_DP_LINK_N_MASK (0xffffff)
#define PIPE_GMCH_DATA_M(pipe) _PIPE(pipe, _PIPEA_GMCH_DATA_M, _PIPEB_GMCH_DATA_M) #define PIPE_GMCH_DATA_N(pipe) _PIPE(pipe, _PIPEA_GMCH_DATA_N, _PIPEB_GMCH_DATA_N) @@ -2385,81 +2385,81 @@
/* Pipe A */ #define _PIPEADSL 0x70000 -#define DSL_LINEMASK 0x00000fff +#define DSL_LINEMASK 0x00000fff #define _PIPEACONF 0x70008 -#define PIPECONF_ENABLE (1<<31) -#define PIPECONF_DISABLE 0 -#define PIPECONF_DOUBLE_WIDE (1<<30) -#define I965_PIPECONF_ACTIVE (1<<30) -#define PIPECONF_FRAME_START_DELAY_MASK (3<<27) -#define PIPECONF_SINGLE_WIDE 0 -#define PIPECONF_PIPE_UNLOCKED 0 -#define PIPECONF_PIPE_LOCKED (1<<25) -#define PIPECONF_PALETTE 0 -#define PIPECONF_GAMMA (1<<24) -#define PIPECONF_FORCE_BORDER (1<<25) -#define PIPECONF_INTERLACE_MASK (7 << 21) +#define PIPECONF_ENABLE (1<<31) +#define PIPECONF_DISABLE 0 +#define PIPECONF_DOUBLE_WIDE (1<<30) +#define I965_PIPECONF_ACTIVE (1<<30) +#define PIPECONF_FRAME_START_DELAY_MASK (3<<27) +#define PIPECONF_SINGLE_WIDE 0 +#define PIPECONF_PIPE_UNLOCKED 0 +#define PIPECONF_PIPE_LOCKED (1<<25) +#define PIPECONF_PALETTE 0 +#define PIPECONF_GAMMA (1<<24) +#define PIPECONF_FORCE_BORDER (1<<25) +#define PIPECONF_INTERLACE_MASK (7 << 21) /* Note that pre-gen3 does not support interlaced display directly. Panel * fitting must be disabled on pre-ilk for interlaced. */ -#define PIPECONF_PROGRESSIVE (0 << 21) -#define PIPECONF_INTERLACE_W_SYNC_SHIFT_PANEL (4 << 21) /* gen4 only */ -#define PIPECONF_INTERLACE_W_SYNC_SHIFT (5 << 21) /* gen4 only */ -#define PIPECONF_INTERLACE_W_FIELD_INDICATION (6 << 21) -#define PIPECONF_INTERLACE_FIELD_0_ONLY (7 << 21) /* gen3 only */ +#define PIPECONF_PROGRESSIVE (0 << 21) +#define PIPECONF_INTERLACE_W_SYNC_SHIFT_PANEL (4 << 21) /* gen4 only */ +#define PIPECONF_INTERLACE_W_SYNC_SHIFT (5 << 21) /* gen4 only */ +#define PIPECONF_INTERLACE_W_FIELD_INDICATION (6 << 21) +#define PIPECONF_INTERLACE_FIELD_0_ONLY (7 << 21) /* gen3 only */ /* Ironlake and later have a complete new set of values for interlaced. PFIT * means panel fitter required, PF means progressive fetch, DBL means power * saving pixel doubling. */ -#define PIPECONF_PFIT_PF_INTERLACED_ILK (1 << 21) -#define PIPECONF_INTERLACED_ILK (3 << 21) -#define PIPECONF_INTERLACED_DBL_ILK (4 << 21) /* ilk/snb only */ -#define PIPECONF_PFIT_PF_INTERLACED_DBL_ILK (5 << 21) /* ilk/snb only */ -#define PIPECONF_CXSR_DOWNCLOCK (1<<16) -#define PIPECONF_BPP_MASK (0x000000e0) -#define PIPECONF_BPP_8 (0<<5) -#define PIPECONF_BPP_10 (1<<5) -#define PIPECONF_BPP_6 (2<<5) -#define PIPECONF_BPP_12 (3<<5) -#define PIPECONF_DITHER_EN (1<<4) -#define PIPECONF_DITHER_TYPE_MASK (0x0000000c) -#define PIPECONF_DITHER_TYPE_SP (0<<2) -#define PIPECONF_DITHER_TYPE_ST1 (1<<2) -#define PIPECONF_DITHER_TYPE_ST2 (2<<2) -#define PIPECONF_DITHER_TYPE_TEMP (3<<2) +#define PIPECONF_PFIT_PF_INTERLACED_ILK (1 << 21) +#define PIPECONF_INTERLACED_ILK (3 << 21) +#define PIPECONF_INTERLACED_DBL_ILK (4 << 21) /* ilk/snb only */ +#define PIPECONF_PFIT_PF_INTERLACED_DBL_ILK (5 << 21) /* ilk/snb only */ +#define PIPECONF_CXSR_DOWNCLOCK (1<<16) +#define PIPECONF_BPP_MASK (0x000000e0) +#define PIPECONF_BPP_8 (0<<5) +#define PIPECONF_BPP_10 (1<<5) +#define PIPECONF_BPP_6 (2<<5) +#define PIPECONF_BPP_12 (3<<5) +#define PIPECONF_DITHER_EN (1<<4) +#define PIPECONF_DITHER_TYPE_MASK (0x0000000c) +#define PIPECONF_DITHER_TYPE_SP (0<<2) +#define PIPECONF_DITHER_TYPE_ST1 (1<<2) +#define PIPECONF_DITHER_TYPE_ST2 (2<<2) +#define PIPECONF_DITHER_TYPE_TEMP (3<<2) #define _PIPEASTAT 0x70024 -#define PIPE_FIFO_UNDERRUN_STATUS (1UL<<31) -#define PIPE_CRC_ERROR_ENABLE (1UL<<29) -#define PIPE_CRC_DONE_ENABLE (1UL<<28) -#define PIPE_GMBUS_EVENT_ENABLE (1UL<<27) -#define PIPE_HOTPLUG_INTERRUPT_ENABLE (1UL<<26) -#define PIPE_VSYNC_INTERRUPT_ENABLE (1UL<<25) -#define PIPE_DISPLAY_LINE_COMPARE_ENABLE (1UL<<24) -#define PIPE_DPST_EVENT_ENABLE (1UL<<23) -#define PIPE_LEGACY_BLC_EVENT_ENABLE (1UL<<22) -#define PIPE_ODD_FIELD_INTERRUPT_ENABLE (1UL<<21) -#define PIPE_EVEN_FIELD_INTERRUPT_ENABLE (1UL<<20) -#define PIPE_HOTPLUG_TV_INTERRUPT_ENABLE (1UL<<18) /* pre-965 */ -#define PIPE_START_VBLANK_INTERRUPT_ENABLE (1UL<<18) /* 965 or later */ -#define PIPE_VBLANK_INTERRUPT_ENABLE (1UL<<17) -#define PIPE_OVERLAY_UPDATED_ENABLE (1UL<<16) -#define PIPE_CRC_ERROR_INTERRUPT_STATUS (1UL<<13) -#define PIPE_CRC_DONE_INTERRUPT_STATUS (1UL<<12) -#define PIPE_GMBUS_INTERRUPT_STATUS (1UL<<11) -#define PIPE_HOTPLUG_INTERRUPT_STATUS (1UL<<10) -#define PIPE_VSYNC_INTERRUPT_STATUS (1UL<<9) -#define PIPE_DISPLAY_LINE_COMPARE_STATUS (1UL<<8) -#define PIPE_DPST_EVENT_STATUS (1UL<<7) -#define PIPE_LEGACY_BLC_EVENT_STATUS (1UL<<6) -#define PIPE_ODD_FIELD_INTERRUPT_STATUS (1UL<<5) -#define PIPE_EVEN_FIELD_INTERRUPT_STATUS (1UL<<4) -#define PIPE_HOTPLUG_TV_INTERRUPT_STATUS (1UL<<2) /* pre-965 */ -#define PIPE_START_VBLANK_INTERRUPT_STATUS (1UL<<2) /* 965 or later */ -#define PIPE_VBLANK_INTERRUPT_STATUS (1UL<<1) -#define PIPE_OVERLAY_UPDATED_STATUS (1UL<<0) -#define PIPE_BPC_MASK (7 << 5) /* Ironlake */ -#define PIPE_8BPC (0 << 5) -#define PIPE_10BPC (1 << 5) -#define PIPE_6BPC (2 << 5) -#define PIPE_12BPC (3 << 5) +#define PIPE_FIFO_UNDERRUN_STATUS (1UL<<31) +#define PIPE_CRC_ERROR_ENABLE (1UL<<29) +#define PIPE_CRC_DONE_ENABLE (1UL<<28) +#define PIPE_GMBUS_EVENT_ENABLE (1UL<<27) +#define PIPE_HOTPLUG_INTERRUPT_ENABLE (1UL<<26) +#define PIPE_VSYNC_INTERRUPT_ENABLE (1UL<<25) +#define PIPE_DISPLAY_LINE_COMPARE_ENABLE (1UL<<24) +#define PIPE_DPST_EVENT_ENABLE (1UL<<23) +#define PIPE_LEGACY_BLC_EVENT_ENABLE (1UL<<22) +#define PIPE_ODD_FIELD_INTERRUPT_ENABLE (1UL<<21) +#define PIPE_EVEN_FIELD_INTERRUPT_ENABLE (1UL<<20) +#define PIPE_HOTPLUG_TV_INTERRUPT_ENABLE (1UL<<18) /* pre-965 */ +#define PIPE_START_VBLANK_INTERRUPT_ENABLE (1UL<<18) /* 965 or later */ +#define PIPE_VBLANK_INTERRUPT_ENABLE (1UL<<17) +#define PIPE_OVERLAY_UPDATED_ENABLE (1UL<<16) +#define PIPE_CRC_ERROR_INTERRUPT_STATUS (1UL<<13) +#define PIPE_CRC_DONE_INTERRUPT_STATUS (1UL<<12) +#define PIPE_GMBUS_INTERRUPT_STATUS (1UL<<11) +#define PIPE_HOTPLUG_INTERRUPT_STATUS (1UL<<10) +#define PIPE_VSYNC_INTERRUPT_STATUS (1UL<<9) +#define PIPE_DISPLAY_LINE_COMPARE_STATUS (1UL<<8) +#define PIPE_DPST_EVENT_STATUS (1UL<<7) +#define PIPE_LEGACY_BLC_EVENT_STATUS (1UL<<6) +#define PIPE_ODD_FIELD_INTERRUPT_STATUS (1UL<<5) +#define PIPE_EVEN_FIELD_INTERRUPT_STATUS (1UL<<4) +#define PIPE_HOTPLUG_TV_INTERRUPT_STATUS (1UL<<2) /* pre-965 */ +#define PIPE_START_VBLANK_INTERRUPT_STATUS (1UL<<2) /* 965 or later */ +#define PIPE_VBLANK_INTERRUPT_STATUS (1UL<<1) +#define PIPE_OVERLAY_UPDATED_STATUS (1UL<<0) +#define PIPE_BPC_MASK (7 << 5) /* Ironlake */ +#define PIPE_8BPC (0 << 5) +#define PIPE_10BPC (1 << 5) +#define PIPE_6BPC (2 << 5) +#define PIPE_12BPC (3 << 5)
#define PIPESRC(pipe) _PIPE(pipe, _PIPEASRC, _PIPEBSRC) #define PIPECONF(pipe) _PIPE(pipe, _PIPEACONF, _PIPEBCONF) @@ -2469,33 +2469,33 @@ #define PIPESTAT(pipe) _PIPE(pipe, _PIPEASTAT, _PIPEBSTAT)
#define DSPARB 0x70030 -#define DSPARB_CSTART_MASK (0x7f << 7) -#define DSPARB_CSTART_SHIFT 7 -#define DSPARB_BSTART_MASK (0x7f) -#define DSPARB_BSTART_SHIFT 0 -#define DSPARB_BEND_SHIFT 9 /* on 855 */ -#define DSPARB_AEND_SHIFT 0 +#define DSPARB_CSTART_MASK (0x7f << 7) +#define DSPARB_CSTART_SHIFT 7 +#define DSPARB_BSTART_MASK (0x7f) +#define DSPARB_BSTART_SHIFT 0 +#define DSPARB_BEND_SHIFT 9 /* on 855 */ +#define DSPARB_AEND_SHIFT 0
#define DSPFW1 0x70034 -#define DSPFW_SR_SHIFT 23 -#define DSPFW_SR_MASK (0x1ff<<23) -#define DSPFW_CURSORB_SHIFT 16 -#define DSPFW_CURSORB_MASK (0x3f<<16) -#define DSPFW_PLANEB_SHIFT 8 -#define DSPFW_PLANEB_MASK (0x7f<<8) -#define DSPFW_PLANEA_MASK (0x7f) +#define DSPFW_SR_SHIFT 23 +#define DSPFW_SR_MASK (0x1ff<<23) +#define DSPFW_CURSORB_SHIFT 16 +#define DSPFW_CURSORB_MASK (0x3f<<16) +#define DSPFW_PLANEB_SHIFT 8 +#define DSPFW_PLANEB_MASK (0x7f<<8) +#define DSPFW_PLANEA_MASK (0x7f) #define DSPFW2 0x70038 -#define DSPFW_CURSORA_MASK 0x00003f00 -#define DSPFW_CURSORA_SHIFT 8 -#define DSPFW_PLANEC_MASK (0x7f) +#define DSPFW_CURSORA_MASK 0x00003f00 +#define DSPFW_CURSORA_SHIFT 8 +#define DSPFW_PLANEC_MASK (0x7f) #define DSPFW3 0x7003c -#define DSPFW_HPLL_SR_EN (1<<31) -#define DSPFW_CURSOR_SR_SHIFT 24 -#define PINEVIEW_SELF_REFRESH_EN (1<<30) -#define DSPFW_CURSOR_SR_MASK (0x3f<<24) -#define DSPFW_HPLL_CURSOR_SHIFT 16 -#define DSPFW_HPLL_CURSOR_MASK (0x3f<<16) -#define DSPFW_HPLL_SR_MASK (0x1ff) +#define DSPFW_HPLL_SR_EN (1<<31) +#define DSPFW_CURSOR_SR_SHIFT 24 +#define PINEVIEW_SELF_REFRESH_EN (1<<30) +#define DSPFW_CURSOR_SR_MASK (0x3f<<24) +#define DSPFW_HPLL_CURSOR_SHIFT 16 +#define DSPFW_HPLL_CURSOR_MASK (0x3f<<16) +#define DSPFW_HPLL_SR_MASK (0x1ff)
/* FIFO watermark sizes etc */ #define G4X_FIFO_LINE_SIZE 64 @@ -2529,38 +2529,38 @@
/* define the Watermark register on Ironlake */ #define WM0_PIPEA_ILK 0x45100 -#define WM0_PIPE_PLANE_MASK (0x7f<<16) -#define WM0_PIPE_PLANE_SHIFT 16 -#define WM0_PIPE_SPRITE_MASK (0x3f<<8) -#define WM0_PIPE_SPRITE_SHIFT 8 -#define WM0_PIPE_CURSOR_MASK (0x1f) +#define WM0_PIPE_PLANE_MASK (0x7f<<16) +#define WM0_PIPE_PLANE_SHIFT 16 +#define WM0_PIPE_SPRITE_MASK (0x3f<<8) +#define WM0_PIPE_SPRITE_SHIFT 8 +#define WM0_PIPE_CURSOR_MASK (0x1f)
#define WM0_PIPEB_ILK 0x45104 #define WM0_PIPEC_IVB 0x45200 #define WM1_LP_ILK 0x45108 -#define WM1_LP_SR_EN (1<<31) -#define WM1_LP_LATENCY_SHIFT 24 -#define WM1_LP_LATENCY_MASK (0x7f<<24) -#define WM1_LP_FBC_MASK (0xf<<20) -#define WM1_LP_FBC_SHIFT 20 -#define WM1_LP_SR_MASK (0x1ff<<8) -#define WM1_LP_SR_SHIFT 8 -#define WM1_LP_CURSOR_MASK (0x3f) +#define WM1_LP_SR_EN (1<<31) +#define WM1_LP_LATENCY_SHIFT 24 +#define WM1_LP_LATENCY_MASK (0x7f<<24) +#define WM1_LP_FBC_MASK (0xf<<20) +#define WM1_LP_FBC_SHIFT 20 +#define WM1_LP_SR_MASK (0x1ff<<8) +#define WM1_LP_SR_SHIFT 8 +#define WM1_LP_CURSOR_MASK (0x3f) #define WM2_LP_ILK 0x4510c -#define WM2_LP_EN (1<<31) +#define WM2_LP_EN (1<<31) #define WM3_LP_ILK 0x45110 -#define WM3_LP_EN (1<<31) +#define WM3_LP_EN (1<<31) #define WM1S_LP_ILK 0x45120 #define WM2S_LP_IVB 0x45124 #define WM3S_LP_IVB 0x45128 -#define WM1S_LP_EN (1<<31) +#define WM1S_LP_EN (1<<31)
/* Memory latency timer register */ #define MLTR_ILK 0x11222 -#define MLTR_WM1_SHIFT 0 -#define MLTR_WM2_SHIFT 8 +#define MLTR_WM1_SHIFT 0 +#define MLTR_WM2_SHIFT 8 /* the unit of memory self-refresh latency time is 0.5us */ -#define ILK_SRLT_MASK 0x3f +#define ILK_SRLT_MASK 0x3f #define ILK_LATENCY(shift) (I915_READ(MLTR_ILK) >> (shift) & ILK_SRLT_MASK) #define ILK_READ_WM1_LATENCY() ILK_LATENCY(MLTR_WM1_SHIFT) #define ILK_READ_WM2_LATENCY() ILK_LATENCY(MLTR_WM2_SHIFT) @@ -2632,13 +2632,13 @@ * frame = (high1 << 8) | low1; */ #define _PIPEAFRAMEHIGH 0x70040 -#define PIPE_FRAME_HIGH_MASK 0x0000ffff -#define PIPE_FRAME_HIGH_SHIFT 0 +#define PIPE_FRAME_HIGH_MASK 0x0000ffff +#define PIPE_FRAME_HIGH_SHIFT 0 #define _PIPEAFRAMEPIXEL 0x70044 -#define PIPE_FRAME_LOW_MASK 0xff000000 -#define PIPE_FRAME_LOW_SHIFT 24 -#define PIPE_PIXEL_MASK 0x00ffffff -#define PIPE_PIXEL_SHIFT 0 +#define PIPE_FRAME_LOW_MASK 0xff000000 +#define PIPE_FRAME_LOW_SHIFT 24 +#define PIPE_PIXEL_MASK 0x00ffffff +#define PIPE_PIXEL_SHIFT 0 /* GM45+ just has to be different */ #define _PIPEA_FRMCOUNT_GM45 0x70040 #define _PIPEA_FLIPCOUNT_GM45 0x70044 @@ -2647,31 +2647,31 @@ /* Cursor A & B regs */ #define _CURACNTR 0x70080 /* Old style CUR*CNTR flags (desktop 8xx) */ -#define CURSOR_ENABLE 0x80000000 -#define CURSOR_GAMMA_ENABLE 0x40000000 -#define CURSOR_STRIDE_MASK 0x30000000 -#define CURSOR_FORMAT_SHIFT 24 -#define CURSOR_FORMAT_MASK (0x07 << CURSOR_FORMAT_SHIFT) -#define CURSOR_FORMAT_2C (0x00 << CURSOR_FORMAT_SHIFT) -#define CURSOR_FORMAT_3C (0x01 << CURSOR_FORMAT_SHIFT) -#define CURSOR_FORMAT_4C (0x02 << CURSOR_FORMAT_SHIFT) -#define CURSOR_FORMAT_ARGB (0x04 << CURSOR_FORMAT_SHIFT) -#define CURSOR_FORMAT_XRGB (0x05 << CURSOR_FORMAT_SHIFT) +#define CURSOR_ENABLE 0x80000000 +#define CURSOR_GAMMA_ENABLE 0x40000000 +#define CURSOR_STRIDE_MASK 0x30000000 +#define CURSOR_FORMAT_SHIFT 24 +#define CURSOR_FORMAT_MASK (0x07 << CURSOR_FORMAT_SHIFT) +#define CURSOR_FORMAT_2C (0x00 << CURSOR_FORMAT_SHIFT) +#define CURSOR_FORMAT_3C (0x01 << CURSOR_FORMAT_SHIFT) +#define CURSOR_FORMAT_4C (0x02 << CURSOR_FORMAT_SHIFT) +#define CURSOR_FORMAT_ARGB (0x04 << CURSOR_FORMAT_SHIFT) +#define CURSOR_FORMAT_XRGB (0x05 << CURSOR_FORMAT_SHIFT) /* New style CUR*CNTR flags */ -#define CURSOR_MODE 0x27 -#define CURSOR_MODE_DISABLE 0x00 -#define CURSOR_MODE_64_32B_AX 0x07 -#define CURSOR_MODE_64_ARGB_AX ((1 << 5) | CURSOR_MODE_64_32B_AX) -#define MCURSOR_PIPE_SELECT (1 << 28) -#define MCURSOR_PIPE_A 0x00 -#define MCURSOR_PIPE_B (1 << 28) -#define MCURSOR_GAMMA_ENABLE (1 << 26) +#define CURSOR_MODE 0x27 +#define CURSOR_MODE_DISABLE 0x00 +#define CURSOR_MODE_64_32B_AX 0x07 +#define CURSOR_MODE_64_ARGB_AX ((1 << 5) | CURSOR_MODE_64_32B_AX) +#define MCURSOR_PIPE_SELECT (1 << 28) +#define MCURSOR_PIPE_A 0x00 +#define MCURSOR_PIPE_B (1 << 28) +#define MCURSOR_GAMMA_ENABLE (1 << 26) #define _CURABASE 0x70084 #define _CURAPOS 0x70088 -#define CURSOR_POS_MASK 0x007FF -#define CURSOR_POS_SIGN 0x8000 -#define CURSOR_X_SHIFT 0 -#define CURSOR_Y_SHIFT 16 +#define CURSOR_POS_MASK 0x007FF +#define CURSOR_POS_SIGN 0x8000 +#define CURSOR_X_SHIFT 0 +#define CURSOR_Y_SHIFT 16 #define CURSIZE 0x700a0 #define _CURBCNTR 0x700c0 #define _CURBBASE 0x700c4 @@ -2691,31 +2691,31 @@
/* Display A control */ #define _DSPACNTR 0x70180 -#define DISPLAY_PLANE_ENABLE (1<<31) -#define DISPLAY_PLANE_DISABLE 0 -#define DISPPLANE_GAMMA_ENABLE (1<<30) -#define DISPPLANE_GAMMA_DISABLE 0 -#define DISPPLANE_PIXFORMAT_MASK (0xf<<26) -#define DISPPLANE_8BPP (0x2<<26) -#define DISPPLANE_15_16BPP (0x4<<26) -#define DISPPLANE_16BPP (0x5<<26) -#define DISPPLANE_32BPP_NO_ALPHA (0x6<<26) -#define DISPPLANE_32BPP (0x7<<26) -#define DISPPLANE_32BPP_30BIT_NO_ALPHA (0xa<<26) -#define DISPPLANE_STEREO_ENABLE (1<<25) -#define DISPPLANE_STEREO_DISABLE 0 -#define DISPPLANE_SEL_PIPE_SHIFT 24 -#define DISPPLANE_SEL_PIPE_MASK (3<<DISPPLANE_SEL_PIPE_SHIFT) -#define DISPPLANE_SEL_PIPE_A 0 -#define DISPPLANE_SEL_PIPE_B (1<<DISPPLANE_SEL_PIPE_SHIFT) -#define DISPPLANE_SRC_KEY_ENABLE (1<<22) -#define DISPPLANE_SRC_KEY_DISABLE 0 -#define DISPPLANE_LINE_DOUBLE (1<<20) -#define DISPPLANE_NO_LINE_DOUBLE 0 -#define DISPPLANE_STEREO_POLARITY_FIRST 0 -#define DISPPLANE_STEREO_POLARITY_SECOND (1<<18) -#define DISPPLANE_TRICKLE_FEED_DISABLE (1<<14) /* Ironlake */ -#define DISPPLANE_TILED (1<<10) +#define DISPLAY_PLANE_ENABLE (1<<31) +#define DISPLAY_PLANE_DISABLE 0 +#define DISPPLANE_GAMMA_ENABLE (1<<30) +#define DISPPLANE_GAMMA_DISABLE 0 +#define DISPPLANE_PIXFORMAT_MASK (0xf<<26) +#define DISPPLANE_8BPP (0x2<<26) +#define DISPPLANE_15_16BPP (0x4<<26) +#define DISPPLANE_16BPP (0x5<<26) +#define DISPPLANE_32BPP_NO_ALPHA (0x6<<26) +#define DISPPLANE_32BPP (0x7<<26) +#define DISPPLANE_32BPP_30BIT_NO_ALPHA (0xa<<26) +#define DISPPLANE_STEREO_ENABLE (1<<25) +#define DISPPLANE_STEREO_DISABLE 0 +#define DISPPLANE_SEL_PIPE_SHIFT 24 +#define DISPPLANE_SEL_PIPE_MASK (3<<DISPPLANE_SEL_PIPE_SHIFT) +#define DISPPLANE_SEL_PIPE_A 0 +#define DISPPLANE_SEL_PIPE_B (1<<DISPPLANE_SEL_PIPE_SHIFT) +#define DISPPLANE_SRC_KEY_ENABLE (1<<22) +#define DISPPLANE_SRC_KEY_DISABLE 0 +#define DISPPLANE_LINE_DOUBLE (1<<20) +#define DISPPLANE_NO_LINE_DOUBLE 0 +#define DISPPLANE_STEREO_POLARITY_FIRST 0 +#define DISPPLANE_STEREO_POLARITY_SECOND (1<<18) +#define DISPPLANE_TRICKLE_FEED_DISABLE (1<<14) /* Ironlake */ +#define DISPPLANE_TILED (1<<10) #define _DSPAADDR 0x70184 #define _DSPASTRIDE 0x70188 #define _DSPAPOS 0x7018C /* reserved */ @@ -2758,10 +2758,10 @@
/* Display B control */ #define _DSPBCNTR 0x71180 -#define DISPPLANE_ALPHA_TRANS_ENABLE (1<<15) -#define DISPPLANE_ALPHA_TRANS_DISABLE 0 -#define DISPPLANE_SPRITE_ABOVE_DISPLAY 0 -#define DISPPLANE_SPRITE_ABOVE_OVERLAY (1) +#define DISPPLANE_ALPHA_TRANS_ENABLE (1<<15) +#define DISPPLANE_ALPHA_TRANS_DISABLE 0 +#define DISPPLANE_SPRITE_ABOVE_DISPLAY 0 +#define DISPPLANE_SPRITE_ABOVE_OVERLAY (1) #define _DSPBADDR 0x71184 #define _DSPBSTRIDE 0x71188 #define _DSPBPOS 0x7118C @@ -2771,23 +2771,23 @@
/* Sprite A control */ #define _DVSACNTR 0x72180 -#define DVS_ENABLE (1<<31) -#define DVS_GAMMA_ENABLE (1<<30) -#define DVS_PIXFORMAT_MASK (3<<25) -#define DVS_FORMAT_YUV422 (0<<25) -#define DVS_FORMAT_RGBX101010 (1<<25) -#define DVS_FORMAT_RGBX888 (2<<25) -#define DVS_FORMAT_RGBX161616 (3<<25) -#define DVS_SOURCE_KEY (1<<22) -#define DVS_RGB_ORDER_XBGR (1<<20) -#define DVS_YUV_BYTE_ORDER_MASK (3<<16) -#define DVS_YUV_ORDER_YUYV (0<<16) -#define DVS_YUV_ORDER_UYVY (1<<16) -#define DVS_YUV_ORDER_YVYU (2<<16) -#define DVS_YUV_ORDER_VYUY (3<<16) -#define DVS_DEST_KEY (1<<2) -#define DVS_TRICKLE_FEED_DISABLE (1<<14) -#define DVS_TILED (1<<10) +#define DVS_ENABLE (1<<31) +#define DVS_GAMMA_ENABLE (1<<30) +#define DVS_PIXFORMAT_MASK (3<<25) +#define DVS_FORMAT_YUV422 (0<<25) +#define DVS_FORMAT_RGBX101010 (1<<25) +#define DVS_FORMAT_RGBX888 (2<<25) +#define DVS_FORMAT_RGBX161616 (3<<25) +#define DVS_SOURCE_KEY (1<<22) +#define DVS_RGB_ORDER_XBGR (1<<20) +#define DVS_YUV_BYTE_ORDER_MASK (3<<16) +#define DVS_YUV_ORDER_YUYV (0<<16) +#define DVS_YUV_ORDER_UYVY (1<<16) +#define DVS_YUV_ORDER_YVYU (2<<16) +#define DVS_YUV_ORDER_VYUY (3<<16) +#define DVS_DEST_KEY (1<<2) +#define DVS_TRICKLE_FEED_DISABLE (1<<14) +#define DVS_TILED (1<<10) #define _DVSALINOFF 0x72184 #define _DVSASTRIDE 0x72188 #define _DVSAPOS 0x7218c @@ -2799,13 +2799,13 @@ #define _DVSATILEOFF 0x721a4 #define _DVSASURFLIVE 0x721ac #define _DVSASCALE 0x72204 -#define DVS_SCALE_ENABLE (1<<31) -#define DVS_FILTER_MASK (3<<29) -#define DVS_FILTER_MEDIUM (0<<29) -#define DVS_FILTER_ENHANCING (1<<29) -#define DVS_FILTER_SOFTENING (2<<29) -#define DVS_VERTICAL_OFFSET_HALF (1<<28) /* must be enabled below */ -#define DVS_VERTICAL_OFFSET_ENABLE (1<<27) +#define DVS_SCALE_ENABLE (1<<31) +#define DVS_FILTER_MASK (3<<29) +#define DVS_FILTER_MEDIUM (0<<29) +#define DVS_FILTER_ENHANCING (1<<29) +#define DVS_FILTER_SOFTENING (2<<29) +#define DVS_VERTICAL_OFFSET_HALF (1<<28) /* must be enabled below */ +#define DVS_VERTICAL_OFFSET_ENABLE (1<<27) #define _DVSAGAMC 0x72300
#define _DVSBCNTR 0x73180 @@ -2835,29 +2835,29 @@ #define DVSKEYMSK(pipe) _PIPE(pipe, _DVSAKEYMSK, _DVSBKEYMSK)
#define _SPRA_CTL 0x70280 -#define SPRITE_ENABLE (1<<31) -#define SPRITE_GAMMA_ENABLE (1<<30) -#define SPRITE_PIXFORMAT_MASK (7<<25) -#define SPRITE_FORMAT_YUV422 (0<<25) -#define SPRITE_FORMAT_RGBX101010 (1<<25) -#define SPRITE_FORMAT_RGBX888 (2<<25) -#define SPRITE_FORMAT_RGBX161616 (3<<25) -#define SPRITE_FORMAT_YUV444 (4<<25) -#define SPRITE_FORMAT_XR_BGR101010 (5<<25) /* Extended range */ -#define SPRITE_CSC_ENABLE (1<<24) -#define SPRITE_SOURCE_KEY (1<<22) -#define SPRITE_RGB_ORDER_RGBX (1<<20) /* only for 888 and 161616 */ -#define SPRITE_YUV_TO_RGB_CSC_DISABLE (1<<19) -#define SPRITE_YUV_CSC_FORMAT_BT709 (1<<18) /* 0 is BT601 */ -#define SPRITE_YUV_BYTE_ORDER_MASK (3<<16) -#define SPRITE_YUV_ORDER_YUYV (0<<16) -#define SPRITE_YUV_ORDER_UYVY (1<<16) -#define SPRITE_YUV_ORDER_YVYU (2<<16) -#define SPRITE_YUV_ORDER_VYUY (3<<16) -#define SPRITE_TRICKLE_FEED_DISABLE (1<<14) -#define SPRITE_INT_GAMMA_ENABLE (1<<13) -#define SPRITE_TILED (1<<10) -#define SPRITE_DEST_KEY (1<<2) +#define SPRITE_ENABLE (1<<31) +#define SPRITE_GAMMA_ENABLE (1<<30) +#define SPRITE_PIXFORMAT_MASK (7<<25) +#define SPRITE_FORMAT_YUV422 (0<<25) +#define SPRITE_FORMAT_RGBX101010 (1<<25) +#define SPRITE_FORMAT_RGBX888 (2<<25) +#define SPRITE_FORMAT_RGBX161616 (3<<25) +#define SPRITE_FORMAT_YUV444 (4<<25) +#define SPRITE_FORMAT_XR_BGR101010 (5<<25) /* Extended range */ +#define SPRITE_CSC_ENABLE (1<<24) +#define SPRITE_SOURCE_KEY (1<<22) +#define SPRITE_RGB_ORDER_RGBX (1<<20) /* only for 888 and 161616 */ +#define SPRITE_YUV_TO_RGB_CSC_DISABLE (1<<19) +#define SPRITE_YUV_CSC_FORMAT_BT709 (1<<18) /* 0 is BT601 */ +#define SPRITE_YUV_BYTE_ORDER_MASK (3<<16) +#define SPRITE_YUV_ORDER_YUYV (0<<16) +#define SPRITE_YUV_ORDER_UYVY (1<<16) +#define SPRITE_YUV_ORDER_YVYU (2<<16) +#define SPRITE_YUV_ORDER_VYUY (3<<16) +#define SPRITE_TRICKLE_FEED_DISABLE (1<<14) +#define SPRITE_INT_GAMMA_ENABLE (1<<13) +#define SPRITE_TILED (1<<10) +#define SPRITE_DEST_KEY (1<<2) #define _SPRA_LINOFF 0x70284 #define _SPRA_STRIDE 0x70288 #define _SPRA_POS 0x7028c @@ -2868,13 +2868,13 @@ #define _SPRA_KEYMAX 0x702a0 #define _SPRA_TILEOFF 0x702a4 #define _SPRA_SCALE 0x70304 -#define SPRITE_SCALE_ENABLE (1<<31) -#define SPRITE_FILTER_MASK (3<<29) -#define SPRITE_FILTER_MEDIUM (0<<29) -#define SPRITE_FILTER_ENHANCING (1<<29) -#define SPRITE_FILTER_SOFTENING (2<<29) -#define SPRITE_VERTICAL_OFFSET_HALF (1<<28) /* must be enabled below */ -#define SPRITE_VERTICAL_OFFSET_ENABLE (1<<27) +#define SPRITE_SCALE_ENABLE (1<<31) +#define SPRITE_FILTER_MASK (3<<29) +#define SPRITE_FILTER_MEDIUM (0<<29) +#define SPRITE_FILTER_ENHANCING (1<<29) +#define SPRITE_FILTER_SOFTENING (2<<29) +#define SPRITE_VERTICAL_OFFSET_HALF (1<<28) /* must be enabled below */ +#define SPRITE_VERTICAL_OFFSET_ENABLE (1<<27) #define _SPRA_GAMC 0x70400
#define _SPRB_CTL 0x71280 @@ -2914,22 +2914,22 @@ #define CPU_VGACNTRL 0x41000
#define DIGITAL_PORT_HOTPLUG_CNTRL 0x44030 -#define DIGITAL_PORTA_HOTPLUG_ENABLE (1 << 4) -#define DIGITAL_PORTA_SHORT_PULSE_2MS (0 << 2) -#define DIGITAL_PORTA_SHORT_PULSE_4_5MS (1 << 2) -#define DIGITAL_PORTA_SHORT_PULSE_6MS (2 << 2) -#define DIGITAL_PORTA_SHORT_PULSE_100MS (3 << 2) -#define DIGITAL_PORTA_NO_DETECT (0 << 0) -#define DIGITAL_PORTA_LONG_PULSE_DETECT_MASK (1 << 1) -#define DIGITAL_PORTA_SHORT_PULSE_DETECT_MASK (1 << 0) +#define DIGITAL_PORTA_HOTPLUG_ENABLE (1 << 4) +#define DIGITAL_PORTA_SHORT_PULSE_2MS (0 << 2) +#define DIGITAL_PORTA_SHORT_PULSE_4_5MS (1 << 2) +#define DIGITAL_PORTA_SHORT_PULSE_6MS (2 << 2) +#define DIGITAL_PORTA_SHORT_PULSE_100MS (3 << 2) +#define DIGITAL_PORTA_NO_DETECT (0 << 0) +#define DIGITAL_PORTA_LONG_PULSE_DETECT_MASK (1 << 1) +#define DIGITAL_PORTA_SHORT_PULSE_DETECT_MASK (1 << 0)
/* refresh rate hardware control */ #define RR_HW_CTL 0x45300 -#define RR_HW_LOW_POWER_FRAMES_MASK 0xff -#define RR_HW_HIGH_POWER_FRAMES_MASK 0xff00 +#define RR_HW_LOW_POWER_FRAMES_MASK 0xff +#define RR_HW_HIGH_POWER_FRAMES_MASK 0xff00
#define FDI_PLL_BIOS_0 0x46000 -#define FDI_PLL_FB_CLOCK_MASK 0xff +#define FDI_PLL_FB_CLOCK_MASK 0xff #define FDI_PLL_BIOS_1 0x46004 #define FDI_PLL_BIOS_2 0x46008 #define DISPLAY_PORT_PLL_BIOS_0 0x4600c @@ -2950,32 +2950,32 @@ # define VFMUNIT_CLOCK_GATE_DISABLE (1 << 11)
#define FDI_PLL_FREQ_CTL 0x46030 -#define FDI_PLL_FREQ_CHANGE_REQUEST (1<<24) -#define FDI_PLL_FREQ_LOCK_LIMIT_MASK 0xfff00 -#define FDI_PLL_FREQ_DISABLE_COUNT_LIMIT_MASK 0xff +#define FDI_PLL_FREQ_CHANGE_REQUEST (1<<24) +#define FDI_PLL_FREQ_LOCK_LIMIT_MASK 0xfff00 +#define FDI_PLL_FREQ_DISABLE_COUNT_LIMIT_MASK 0xff
#define _PIPEA_DATA_M1 0x60030 -#define TU_SIZE(x) (((x)-1) << 25) /* default size 64 */ -#define TU_SIZE_MASK 0x7e000000 -#define PIPE_DATA_M1_OFFSET 0 +#define TU_SIZE(x) (((x)-1) << 25) /* default size 64 */ +#define TU_SIZE_MASK 0x7e000000 +#define PIPE_DATA_M1_OFFSET 0 #define _PIPEA_DATA_N1 0x60034 -#define PIPE_DATA_N1_OFFSET 0 +#define PIPE_DATA_N1_OFFSET 0
#define _PIPEA_DATA_M2 0x60038 -#define PIPE_DATA_M2_OFFSET 0 +#define PIPE_DATA_M2_OFFSET 0 #define _PIPEA_DATA_N2 0x6003c -#define PIPE_DATA_N2_OFFSET 0 +#define PIPE_DATA_N2_OFFSET 0
#define _PIPEA_LINK_M1 0x60040 -#define PIPE_LINK_M1_OFFSET 0 +#define PIPE_LINK_M1_OFFSET 0 #define _PIPEA_LINK_N1 0x60044 -#define PIPE_LINK_N1_OFFSET 0 +#define PIPE_LINK_N1_OFFSET 0
#define _PIPEA_LINK_M2 0x60048 -#define PIPE_LINK_M2_OFFSET 0 +#define PIPE_LINK_M2_OFFSET 0 #define _PIPEA_LINK_N2 0x6004c -#define PIPE_LINK_N2_OFFSET 0 +#define PIPE_LINK_N2_OFFSET 0
/* PIPEB timing regs are same start from 0x61000 */
@@ -3004,12 +3004,12 @@ /* IVB+ has 3 fitters, 0 is 7x5 capable, the other two only 3x3 */ #define _PFA_CTL_1 0x68080 #define _PFB_CTL_1 0x68880 -#define PF_ENABLE (1<<31) -#define PF_FILTER_MASK (3<<23) -#define PF_FILTER_PROGRAMMED (0<<23) -#define PF_FILTER_MED_3x3 (1<<23) -#define PF_FILTER_EDGE_ENHANCE (2<<23) -#define PF_FILTER_EDGE_SOFTEN (3<<23) +#define PF_ENABLE (1<<31) +#define PF_FILTER_MASK (3<<23) +#define PF_FILTER_PROGRAMMED (0<<23) +#define PF_FILTER_MED_3x3 (1<<23) +#define PF_FILTER_EDGE_ENHANCE (2<<23) +#define PF_FILTER_EDGE_SOFTEN (3<<23) #define _PFA_WIN_SZ 0x68074 #define _PFB_WIN_SZ 0x68874 #define _PFA_WIN_POS 0x68070 @@ -3090,47 +3090,47 @@
#define ILK_DISPLAY_CHICKEN2 0x42004 /* Required on all Ironlake and Sandybridge according to the B-Spec. */ -#define ILK_ELPIN_409_SELECT (1 << 25) -#define ILK_DPARB_GATE (1<<22) -#define ILK_VSDPFD_FULL (1<<21) +#define ILK_ELPIN_409_SELECT (1 << 25) +#define ILK_DPARB_GATE (1<<22) +#define ILK_VSDPFD_FULL (1<<21) #define ILK_DISPLAY_CHICKEN_FUSES 0x42014 -#define ILK_INTERNAL_GRAPHICS_DISABLE (1<<31) -#define ILK_INTERNAL_DISPLAY_DISABLE (1<<30) -#define ILK_DISPLAY_DEBUG_DISABLE (1<<29) -#define ILK_HDCP_DISABLE (1<<25) -#define ILK_eDP_A_DISABLE (1<<24) -#define ILK_DESKTOP (1<<23) +#define ILK_INTERNAL_GRAPHICS_DISABLE (1<<31) +#define ILK_INTERNAL_DISPLAY_DISABLE (1<<30) +#define ILK_DISPLAY_DEBUG_DISABLE (1<<29) +#define ILK_HDCP_DISABLE (1<<25) +#define ILK_eDP_A_DISABLE (1<<24) +#define ILK_DESKTOP (1<<23) #define ILK_DSPCLK_GATE 0x42020 -#define IVB_VRHUNIT_CLK_GATE (1<<28) -#define ILK_DPARB_CLK_GATE (1<<5) -#define ILK_DPFD_CLK_GATE (1<<7) +#define IVB_VRHUNIT_CLK_GATE (1<<28) +#define ILK_DPARB_CLK_GATE (1<<5) +#define ILK_DPFD_CLK_GATE (1<<7)
/* According to spec this bit 7/8/9 of 0x42020 should be set to enable FBC */ -#define ILK_CLK_FBC (1<<7) -#define ILK_DPFC_DIS1 (1<<8) -#define ILK_DPFC_DIS2 (1<<9) +#define ILK_CLK_FBC (1<<7) +#define ILK_DPFC_DIS1 (1<<8) +#define ILK_DPFC_DIS2 (1<<9)
#define IVB_CHICKEN3 0x4200c # define CHICKEN3_DGMG_REQ_OUT_FIX_DISABLE (1 << 5) # define CHICKEN3_DGMG_DONE_FIX_DISABLE (1 << 2)
#define DISP_ARB_CTL 0x45000 -#define DISP_TILE_SURFACE_SWIZZLING (1<<13) -#define DISP_FBC_WM_DIS (1<<15) +#define DISP_TILE_SURFACE_SWIZZLING (1<<13) +#define DISP_FBC_WM_DIS (1<<15)
/* GEN7 chicken */ #define GEN7_COMMON_SLICE_CHICKEN1 0x7010 # define GEN7_CSC1_RHWO_OPT_DISABLE_IN_RCC ((1<<10) | (1<<26))
#define GEN7_L3CNTLREG1 0xB01C -#define GEN7_WA_FOR_GEN7_L3_CONTROL 0x3C4FFF8C +#define GEN7_WA_FOR_GEN7_L3_CONTROL 0x3C4FFF8C
#define GEN7_L3_CHICKEN_MODE_REGISTER 0xB030 -#define GEN7_WA_L3_CHICKEN_MODE 0x20000000 +#define GEN7_WA_L3_CHICKEN_MODE 0x20000000
/* WaCatErrorRejectionIssue */ #define GEN7_SQ_CHICKEN_MBCUNIT_CONFIG 0x9030 -#define GEN7_SQ_CHICKEN_MBCUNIT_SQINTMOB (1<<11) +#define GEN7_SQ_CHICKEN_MBCUNIT_SQINTMOB (1<<11)
/* PCH */
@@ -3234,7 +3234,7 @@ #define PCH_DPLL(pipe) (pipe == 0 ? _PCH_DPLL_A : _PCH_DPLL_B)
#define _PCH_FPA0 0xc6040 -#define FP_CB_TUNE (0x3<<22) +#define FP_CB_TUNE (0x3<<22) #define _PCH_FPA1 0xc6044 #define _PCH_FPB0 0xc6048 #define _PCH_FPB1 0xc604c @@ -3244,34 +3244,34 @@ #define PCH_DPLL_TEST 0xc606c
#define PCH_DREF_CONTROL 0xC6200 -#define DREF_CONTROL_MASK 0x7fc3 -#define DREF_CPU_SOURCE_OUTPUT_DISABLE (0<<13) -#define DREF_CPU_SOURCE_OUTPUT_DOWNSPREAD (2<<13) -#define DREF_CPU_SOURCE_OUTPUT_NONSPREAD (3<<13) -#define DREF_CPU_SOURCE_OUTPUT_MASK (3<<13) -#define DREF_SSC_SOURCE_DISABLE (0<<11) -#define DREF_SSC_SOURCE_ENABLE (2<<11) -#define DREF_SSC_SOURCE_MASK (3<<11) -#define DREF_NONSPREAD_SOURCE_DISABLE (0<<9) -#define DREF_NONSPREAD_CK505_ENABLE (1<<9) -#define DREF_NONSPREAD_SOURCE_ENABLE (2<<9) -#define DREF_NONSPREAD_SOURCE_MASK (3<<9) -#define DREF_SUPERSPREAD_SOURCE_DISABLE (0<<7) -#define DREF_SUPERSPREAD_SOURCE_ENABLE (2<<7) -#define DREF_SUPERSPREAD_SOURCE_MASK (3<<7) -#define DREF_SSC4_DOWNSPREAD (0<<6) -#define DREF_SSC4_CENTERSPREAD (1<<6) -#define DREF_SSC1_DISABLE (0<<1) -#define DREF_SSC1_ENABLE (1<<1) -#define DREF_SSC4_DISABLE (0) -#define DREF_SSC4_ENABLE (1) +#define DREF_CONTROL_MASK 0x7fc3 +#define DREF_CPU_SOURCE_OUTPUT_DISABLE (0<<13) +#define DREF_CPU_SOURCE_OUTPUT_DOWNSPREAD (2<<13) +#define DREF_CPU_SOURCE_OUTPUT_NONSPREAD (3<<13) +#define DREF_CPU_SOURCE_OUTPUT_MASK (3<<13) +#define DREF_SSC_SOURCE_DISABLE (0<<11) +#define DREF_SSC_SOURCE_ENABLE (2<<11) +#define DREF_SSC_SOURCE_MASK (3<<11) +#define DREF_NONSPREAD_SOURCE_DISABLE (0<<9) +#define DREF_NONSPREAD_CK505_ENABLE (1<<9) +#define DREF_NONSPREAD_SOURCE_ENABLE (2<<9) +#define DREF_NONSPREAD_SOURCE_MASK (3<<9) +#define DREF_SUPERSPREAD_SOURCE_DISABLE (0<<7) +#define DREF_SUPERSPREAD_SOURCE_ENABLE (2<<7) +#define DREF_SUPERSPREAD_SOURCE_MASK (3<<7) +#define DREF_SSC4_DOWNSPREAD (0<<6) +#define DREF_SSC4_CENTERSPREAD (1<<6) +#define DREF_SSC1_DISABLE (0<<1) +#define DREF_SSC1_ENABLE (1<<1) +#define DREF_SSC4_DISABLE (0) +#define DREF_SSC4_ENABLE (1)
#define PCH_RAWCLK_FREQ 0xc6204 -#define FDL_TP1_TIMER_SHIFT 12 -#define FDL_TP1_TIMER_MASK (3<<12) -#define FDL_TP2_TIMER_SHIFT 10 -#define FDL_TP2_TIMER_MASK (3<<10) -#define RAWCLK_FREQ_MASK 0x3ff +#define FDL_TP1_TIMER_SHIFT 12 +#define FDL_TP1_TIMER_MASK (3<<12) +#define FDL_TP2_TIMER_SHIFT 10 +#define FDL_TP2_TIMER_MASK (3<<10) +#define RAWCLK_FREQ_MASK 0x3ff
#define PCH_DPLL_TMR_CFG 0xc6208
@@ -3279,36 +3279,36 @@ #define PCH_SSC4_AUX_PARMS 0xc6214
#define PCH_DPLL_SEL 0xc7000 -#define TRANSA_DPLL_ENABLE (1<<3) +#define TRANSA_DPLL_ENABLE (1<<3) #define TRANSA_DPLLB_SEL (1<<0) #define TRANSA_DPLLA_SEL 0 -#define TRANSB_DPLL_ENABLE (1<<7) +#define TRANSB_DPLL_ENABLE (1<<7) #define TRANSB_DPLLB_SEL (1<<4) #define TRANSB_DPLLA_SEL (0) -#define TRANSC_DPLL_ENABLE (1<<11) +#define TRANSC_DPLL_ENABLE (1<<11) #define TRANSC_DPLLB_SEL (1<<8) #define TRANSC_DPLLA_SEL (0)
/* transcoder */
#define _TRANS_HTOTAL_A 0xe0000 -#define TRANS_HTOTAL_SHIFT 16 -#define TRANS_HACTIVE_SHIFT 0 +#define TRANS_HTOTAL_SHIFT 16 +#define TRANS_HACTIVE_SHIFT 0 #define _TRANS_HBLANK_A 0xe0004 -#define TRANS_HBLANK_END_SHIFT 16 -#define TRANS_HBLANK_START_SHIFT 0 +#define TRANS_HBLANK_END_SHIFT 16 +#define TRANS_HBLANK_START_SHIFT 0 #define _TRANS_HSYNC_A 0xe0008 -#define TRANS_HSYNC_END_SHIFT 16 -#define TRANS_HSYNC_START_SHIFT 0 +#define TRANS_HSYNC_END_SHIFT 16 +#define TRANS_HSYNC_START_SHIFT 0 #define _TRANS_VTOTAL_A 0xe000c -#define TRANS_VTOTAL_SHIFT 16 -#define TRANS_VACTIVE_SHIFT 0 +#define TRANS_VTOTAL_SHIFT 16 +#define TRANS_VACTIVE_SHIFT 0 #define _TRANS_VBLANK_A 0xe0010 -#define TRANS_VBLANK_END_SHIFT 16 -#define TRANS_VBLANK_START_SHIFT 0 +#define TRANS_VBLANK_END_SHIFT 16 +#define TRANS_VBLANK_START_SHIFT 0 #define _TRANS_VSYNC_A 0xe0014 -#define TRANS_VSYNC_END_SHIFT 16 -#define TRANS_VSYNC_START_SHIFT 0 +#define TRANS_VSYNC_END_SHIFT 16 +#define TRANS_VSYNC_START_SHIFT 0 #define _TRANS_VSYNCSHIFT_A 0xe0028
#define _TRANSA_DATA_M1 0xe0030 @@ -3372,128 +3372,128 @@ #define _TRANSACONF 0xf0008 #define _TRANSBCONF 0xf1008 #define TRANSCONF(plane) _PIPE(plane, _TRANSACONF, _TRANSBCONF) -#define TRANS_DISABLE (0<<31) -#define TRANS_ENABLE (1<<31) -#define TRANS_STATE_MASK (1<<30) -#define TRANS_STATE_DISABLE (0<<30) -#define TRANS_STATE_ENABLE (1<<30) -#define TRANS_FSYNC_DELAY_HB1 (0<<27) -#define TRANS_FSYNC_DELAY_HB2 (1<<27) -#define TRANS_FSYNC_DELAY_HB3 (2<<27) -#define TRANS_FSYNC_DELAY_HB4 (3<<27) -#define TRANS_DP_AUDIO_ONLY (1<<26) -#define TRANS_DP_VIDEO_AUDIO (0<<26) -#define TRANS_INTERLACE_MASK (7<<21) -#define TRANS_PROGRESSIVE (0<<21) -#define TRANS_INTERLACED (3<<21) -#define TRANS_LEGACY_INTERLACED_ILK (2<<21) -#define TRANS_8BPC (0<<5) -#define TRANS_10BPC (1<<5) -#define TRANS_6BPC (2<<5) -#define TRANS_12BPC (3<<5) +#define TRANS_DISABLE (0<<31) +#define TRANS_ENABLE (1<<31) +#define TRANS_STATE_MASK (1<<30) +#define TRANS_STATE_DISABLE (0<<30) +#define TRANS_STATE_ENABLE (1<<30) +#define TRANS_FSYNC_DELAY_HB1 (0<<27) +#define TRANS_FSYNC_DELAY_HB2 (1<<27) +#define TRANS_FSYNC_DELAY_HB3 (2<<27) +#define TRANS_FSYNC_DELAY_HB4 (3<<27) +#define TRANS_DP_AUDIO_ONLY (1<<26) +#define TRANS_DP_VIDEO_AUDIO (0<<26) +#define TRANS_INTERLACE_MASK (7<<21) +#define TRANS_PROGRESSIVE (0<<21) +#define TRANS_INTERLACED (3<<21) +#define TRANS_LEGACY_INTERLACED_ILK (2<<21) +#define TRANS_8BPC (0<<5) +#define TRANS_10BPC (1<<5) +#define TRANS_6BPC (2<<5) +#define TRANS_12BPC (3<<5)
#define _TRANSA_CHICKEN2 0xf0064 #define _TRANSB_CHICKEN2 0xf1064 #define TRANS_CHICKEN2(pipe) _PIPE(pipe, _TRANSA_CHICKEN2, _TRANSB_CHICKEN2) -#define TRANS_AUTOTRAIN_GEN_STALL_DIS (1<<31) +#define TRANS_AUTOTRAIN_GEN_STALL_DIS (1<<31)
#define SOUTH_CHICKEN1 0xc2000 -#define FDIA_PHASE_SYNC_SHIFT_OVR 19 -#define FDIA_PHASE_SYNC_SHIFT_EN 18 +#define FDIA_PHASE_SYNC_SHIFT_OVR 19 +#define FDIA_PHASE_SYNC_SHIFT_EN 18 #define FDI_PHASE_SYNC_OVR(pipe) (1<<(FDIA_PHASE_SYNC_SHIFT_OVR - ((pipe) * 2))) #define FDI_PHASE_SYNC_EN(pipe) (1<<(FDIA_PHASE_SYNC_SHIFT_EN - ((pipe) * 2))) #define SOUTH_CHICKEN2 0xc2004 -#define DPLS_EDP_PPS_FIX_DIS (1<<0) +#define DPLS_EDP_PPS_FIX_DIS (1<<0)
#define _FDI_RXA_CHICKEN 0xc200c #define _FDI_RXB_CHICKEN 0xc2010 -#define FDI_RX_PHASE_SYNC_POINTER_OVR (1<<1) -#define FDI_RX_PHASE_SYNC_POINTER_EN (1<<0) +#define FDI_RX_PHASE_SYNC_POINTER_OVR (1<<1) +#define FDI_RX_PHASE_SYNC_POINTER_EN (1<<0) #define FDI_RX_CHICKEN(pipe) _PIPE(pipe, _FDI_RXA_CHICKEN, _FDI_RXB_CHICKEN)
#define SOUTH_DSPCLK_GATE_D 0xc2020 -#define PCH_DPLSUNIT_CLOCK_GATE_DISABLE (1<<29) +#define PCH_DPLSUNIT_CLOCK_GATE_DISABLE (1<<29)
/* CPU: FDI_TX */ #define _FDI_TXA_CTL 0x60100 #define _FDI_TXB_CTL 0x61100 #define FDI_TX_CTL(pipe) _PIPE(pipe, _FDI_TXA_CTL, _FDI_TXB_CTL) -#define FDI_TX_DISABLE (0<<31) -#define FDI_TX_ENABLE (1<<31) -#define FDI_LINK_TRAIN_PATTERN_1 (0<<28) -#define FDI_LINK_TRAIN_PATTERN_2 (1<<28) -#define FDI_LINK_TRAIN_PATTERN_IDLE (2<<28) -#define FDI_LINK_TRAIN_NONE (3<<28) -#define FDI_LINK_TRAIN_VOLTAGE_0_4V (0<<25) -#define FDI_LINK_TRAIN_VOLTAGE_0_6V (1<<25) -#define FDI_LINK_TRAIN_VOLTAGE_0_8V (2<<25) -#define FDI_LINK_TRAIN_VOLTAGE_1_2V (3<<25) -#define FDI_LINK_TRAIN_PRE_EMPHASIS_NONE (0<<22) -#define FDI_LINK_TRAIN_PRE_EMPHASIS_1_5X (1<<22) -#define FDI_LINK_TRAIN_PRE_EMPHASIS_2X (2<<22) -#define FDI_LINK_TRAIN_PRE_EMPHASIS_3X (3<<22) +#define FDI_TX_DISABLE (0<<31) +#define FDI_TX_ENABLE (1<<31) +#define FDI_LINK_TRAIN_PATTERN_1 (0<<28) +#define FDI_LINK_TRAIN_PATTERN_2 (1<<28) +#define FDI_LINK_TRAIN_PATTERN_IDLE (2<<28) +#define FDI_LINK_TRAIN_NONE (3<<28) +#define FDI_LINK_TRAIN_VOLTAGE_0_4V (0<<25) +#define FDI_LINK_TRAIN_VOLTAGE_0_6V (1<<25) +#define FDI_LINK_TRAIN_VOLTAGE_0_8V (2<<25) +#define FDI_LINK_TRAIN_VOLTAGE_1_2V (3<<25) +#define FDI_LINK_TRAIN_PRE_EMPHASIS_NONE (0<<22) +#define FDI_LINK_TRAIN_PRE_EMPHASIS_1_5X (1<<22) +#define FDI_LINK_TRAIN_PRE_EMPHASIS_2X (2<<22) +#define FDI_LINK_TRAIN_PRE_EMPHASIS_3X (3<<22) /* ILK always use 400mV 0dB for voltage swing and pre-emphasis level. SNB has different settings. */ /* SNB A-stepping */ -#define FDI_LINK_TRAIN_400MV_0DB_SNB_A (0x38<<22) -#define FDI_LINK_TRAIN_400MV_6DB_SNB_A (0x02<<22) -#define FDI_LINK_TRAIN_600MV_3_5DB_SNB_A (0x01<<22) -#define FDI_LINK_TRAIN_800MV_0DB_SNB_A (0x0<<22) +#define FDI_LINK_TRAIN_400MV_0DB_SNB_A (0x38<<22) +#define FDI_LINK_TRAIN_400MV_6DB_SNB_A (0x02<<22) +#define FDI_LINK_TRAIN_600MV_3_5DB_SNB_A (0x01<<22) +#define FDI_LINK_TRAIN_800MV_0DB_SNB_A (0x0<<22) /* SNB B-stepping */ -#define FDI_LINK_TRAIN_400MV_0DB_SNB_B (0x0<<22) -#define FDI_LINK_TRAIN_400MV_6DB_SNB_B (0x3a<<22) -#define FDI_LINK_TRAIN_600MV_3_5DB_SNB_B (0x39<<22) -#define FDI_LINK_TRAIN_800MV_0DB_SNB_B (0x38<<22) -#define FDI_LINK_TRAIN_VOL_EMP_MASK (0x3f<<22) -#define FDI_DP_PORT_WIDTH_X1 (0<<19) -#define FDI_DP_PORT_WIDTH_X2 (1<<19) -#define FDI_DP_PORT_WIDTH_X3 (2<<19) -#define FDI_DP_PORT_WIDTH_X4 (3<<19) -#define FDI_TX_ENHANCE_FRAME_ENABLE (1<<18) +#define FDI_LINK_TRAIN_400MV_0DB_SNB_B (0x0<<22) +#define FDI_LINK_TRAIN_400MV_6DB_SNB_B (0x3a<<22) +#define FDI_LINK_TRAIN_600MV_3_5DB_SNB_B (0x39<<22) +#define FDI_LINK_TRAIN_800MV_0DB_SNB_B (0x38<<22) +#define FDI_LINK_TRAIN_VOL_EMP_MASK (0x3f<<22) +#define FDI_DP_PORT_WIDTH_X1 (0<<19) +#define FDI_DP_PORT_WIDTH_X2 (1<<19) +#define FDI_DP_PORT_WIDTH_X3 (2<<19) +#define FDI_DP_PORT_WIDTH_X4 (3<<19) +#define FDI_TX_ENHANCE_FRAME_ENABLE (1<<18) /* Ironlake: hardwired to 1 */ -#define FDI_TX_PLL_ENABLE (1<<14) +#define FDI_TX_PLL_ENABLE (1<<14)
/* Ivybridge has different bits for lolz */ -#define FDI_LINK_TRAIN_PATTERN_1_IVB (0<<8) -#define FDI_LINK_TRAIN_PATTERN_2_IVB (1<<8) -#define FDI_LINK_TRAIN_PATTERN_IDLE_IVB (2<<8) -#define FDI_LINK_TRAIN_NONE_IVB (3<<8) +#define FDI_LINK_TRAIN_PATTERN_1_IVB (0<<8) +#define FDI_LINK_TRAIN_PATTERN_2_IVB (1<<8) +#define FDI_LINK_TRAIN_PATTERN_IDLE_IVB (2<<8) +#define FDI_LINK_TRAIN_NONE_IVB (3<<8)
/* both Tx and Rx */ -#define FDI_COMPOSITE_SYNC (1<<11) -#define FDI_LINK_TRAIN_AUTO (1<<10) -#define FDI_SCRAMBLING_ENABLE (0<<7) -#define FDI_SCRAMBLING_DISABLE (1<<7) +#define FDI_COMPOSITE_SYNC (1<<11) +#define FDI_LINK_TRAIN_AUTO (1<<10) +#define FDI_SCRAMBLING_ENABLE (0<<7) +#define FDI_SCRAMBLING_DISABLE (1<<7)
/* FDI_RX, FDI_X is hard-wired to Transcoder_X */ #define _FDI_RXA_CTL 0xf000c #define _FDI_RXB_CTL 0xf100c #define FDI_RX_CTL(pipe) _PIPE(pipe, _FDI_RXA_CTL, _FDI_RXB_CTL) -#define FDI_RX_ENABLE (1<<31) +#define FDI_RX_ENABLE (1<<31) /* train, dp width same as FDI_TX */ -#define FDI_FS_ERRC_ENABLE (1<<27) -#define FDI_FE_ERRC_ENABLE (1<<26) -#define FDI_DP_PORT_WIDTH_X8 (7<<19) -#define FDI_8BPC (0<<16) -#define FDI_10BPC (1<<16) -#define FDI_6BPC (2<<16) -#define FDI_12BPC (3<<16) -#define FDI_LINK_REVERSE_OVERWRITE (1<<15) -#define FDI_DMI_LINK_REVERSE_MASK (1<<14) -#define FDI_RX_PLL_ENABLE (1<<13) -#define FDI_FS_ERR_CORRECT_ENABLE (1<<11) -#define FDI_FE_ERR_CORRECT_ENABLE (1<<10) -#define FDI_FS_ERR_REPORT_ENABLE (1<<9) -#define FDI_FE_ERR_REPORT_ENABLE (1<<8) -#define FDI_RX_ENHANCE_FRAME_ENABLE (1<<6) -#define FDI_PCDCLK (1<<4) +#define FDI_FS_ERRC_ENABLE (1<<27) +#define FDI_FE_ERRC_ENABLE (1<<26) +#define FDI_DP_PORT_WIDTH_X8 (7<<19) +#define FDI_8BPC (0<<16) +#define FDI_10BPC (1<<16) +#define FDI_6BPC (2<<16) +#define FDI_12BPC (3<<16) +#define FDI_LINK_REVERSE_OVERWRITE (1<<15) +#define FDI_DMI_LINK_REVERSE_MASK (1<<14) +#define FDI_RX_PLL_ENABLE (1<<13) +#define FDI_FS_ERR_CORRECT_ENABLE (1<<11) +#define FDI_FE_ERR_CORRECT_ENABLE (1<<10) +#define FDI_FS_ERR_REPORT_ENABLE (1<<9) +#define FDI_FE_ERR_REPORT_ENABLE (1<<8) +#define FDI_RX_ENHANCE_FRAME_ENABLE (1<<6) +#define FDI_PCDCLK (1<<4) /* CPT */ -#define FDI_AUTO_TRAINING (1<<10) -#define FDI_LINK_TRAIN_PATTERN_1_CPT (0<<8) -#define FDI_LINK_TRAIN_PATTERN_2_CPT (1<<8) -#define FDI_LINK_TRAIN_PATTERN_IDLE_CPT (2<<8) -#define FDI_LINK_TRAIN_NORMAL_CPT (3<<8) -#define FDI_LINK_TRAIN_PATTERN_MASK_CPT (3<<8) +#define FDI_AUTO_TRAINING (1<<10) +#define FDI_LINK_TRAIN_PATTERN_1_CPT (0<<8) +#define FDI_LINK_TRAIN_PATTERN_2_CPT (1<<8) +#define FDI_LINK_TRAIN_PATTERN_IDLE_CPT (2<<8) +#define FDI_LINK_TRAIN_NORMAL_CPT (3<<8) +#define FDI_LINK_TRAIN_PATTERN_MASK_CPT (3<<8)
#define _FDI_RXA_MISC 0xf0010 #define _FDI_RXB_MISC 0xf1010 @@ -3530,50 +3530,50 @@
/* CRT */ #define PCH_ADPA 0xe1100 -#define ADPA_TRANS_SELECT_MASK (1<<30) -#define ADPA_TRANS_A_SELECT 0 -#define ADPA_TRANS_B_SELECT (1<<30) -#define ADPA_CRT_HOTPLUG_MASK 0x03ff0000 /* bit 25-16 */ -#define ADPA_CRT_HOTPLUG_MONITOR_NONE (0<<24) -#define ADPA_CRT_HOTPLUG_MONITOR_MASK (3<<24) -#define ADPA_CRT_HOTPLUG_MONITOR_COLOR (3<<24) -#define ADPA_CRT_HOTPLUG_MONITOR_MONO (2<<24) -#define ADPA_CRT_HOTPLUG_ENABLE (1<<23) -#define ADPA_CRT_HOTPLUG_PERIOD_64 (0<<22) -#define ADPA_CRT_HOTPLUG_PERIOD_128 (1<<22) -#define ADPA_CRT_HOTPLUG_WARMUP_5MS (0<<21) -#define ADPA_CRT_HOTPLUG_WARMUP_10MS (1<<21) -#define ADPA_CRT_HOTPLUG_SAMPLE_2S (0<<20) -#define ADPA_CRT_HOTPLUG_SAMPLE_4S (1<<20) -#define ADPA_CRT_HOTPLUG_VOLTAGE_40 (0<<18) -#define ADPA_CRT_HOTPLUG_VOLTAGE_50 (1<<18) -#define ADPA_CRT_HOTPLUG_VOLTAGE_60 (2<<18) -#define ADPA_CRT_HOTPLUG_VOLTAGE_70 (3<<18) -#define ADPA_CRT_HOTPLUG_VOLREF_325MV (0<<17) -#define ADPA_CRT_HOTPLUG_VOLREF_475MV (1<<17) -#define ADPA_CRT_HOTPLUG_FORCE_TRIGGER (1<<16) +#define ADPA_TRANS_SELECT_MASK (1<<30) +#define ADPA_TRANS_A_SELECT 0 +#define ADPA_TRANS_B_SELECT (1<<30) +#define ADPA_CRT_HOTPLUG_MASK 0x03ff0000 /* bit 25-16 */ +#define ADPA_CRT_HOTPLUG_MONITOR_NONE (0<<24) +#define ADPA_CRT_HOTPLUG_MONITOR_MASK (3<<24) +#define ADPA_CRT_HOTPLUG_MONITOR_COLOR (3<<24) +#define ADPA_CRT_HOTPLUG_MONITOR_MONO (2<<24) +#define ADPA_CRT_HOTPLUG_ENABLE (1<<23) +#define ADPA_CRT_HOTPLUG_PERIOD_64 (0<<22) +#define ADPA_CRT_HOTPLUG_PERIOD_128 (1<<22) +#define ADPA_CRT_HOTPLUG_WARMUP_5MS (0<<21) +#define ADPA_CRT_HOTPLUG_WARMUP_10MS (1<<21) +#define ADPA_CRT_HOTPLUG_SAMPLE_2S (0<<20) +#define ADPA_CRT_HOTPLUG_SAMPLE_4S (1<<20) +#define ADPA_CRT_HOTPLUG_VOLTAGE_40 (0<<18) +#define ADPA_CRT_HOTPLUG_VOLTAGE_50 (1<<18) +#define ADPA_CRT_HOTPLUG_VOLTAGE_60 (2<<18) +#define ADPA_CRT_HOTPLUG_VOLTAGE_70 (3<<18) +#define ADPA_CRT_HOTPLUG_VOLREF_325MV (0<<17) +#define ADPA_CRT_HOTPLUG_VOLREF_475MV (1<<17) +#define ADPA_CRT_HOTPLUG_FORCE_TRIGGER (1<<16)
/* or SDVOB */ #define HDMIB 0xe1140 -#define PORT_ENABLE (1 << 31) -#define TRANSCODER(pipe) ((pipe) << 30) -#define TRANSCODER_CPT(pipe) ((pipe) << 29) -#define TRANSCODER_MASK (1 << 30) -#define TRANSCODER_MASK_CPT (3 << 29) -#define COLOR_FORMAT_8bpc (0) -#define COLOR_FORMAT_12bpc (3 << 26) -#define SDVOB_HOTPLUG_ENABLE (1 << 23) -#define SDVO_ENCODING (0) -#define TMDS_ENCODING (2 << 10) -#define NULL_PACKET_VSYNC_ENABLE (1 << 9) +#define PORT_ENABLE (1 << 31) +#define TRANSCODER(pipe) ((pipe) << 30) +#define TRANSCODER_CPT(pipe) ((pipe) << 29) +#define TRANSCODER_MASK (1 << 30) +#define TRANSCODER_MASK_CPT (3 << 29) +#define COLOR_FORMAT_8bpc (0) +#define COLOR_FORMAT_12bpc (3 << 26) +#define SDVOB_HOTPLUG_ENABLE (1 << 23) +#define SDVO_ENCODING (0) +#define TMDS_ENCODING (2 << 10) +#define NULL_PACKET_VSYNC_ENABLE (1 << 9) /* CPT */ -#define HDMI_MODE_SELECT (1 << 9) -#define DVI_MODE_SELECT (0) -#define SDVOB_BORDER_ENABLE (1 << 7) -#define AUDIO_ENABLE (1 << 6) -#define VSYNC_ACTIVE_HIGH (1 << 4) -#define HSYNC_ACTIVE_HIGH (1 << 3) -#define PORT_DETECTED (1 << 2) +#define HDMI_MODE_SELECT (1 << 9) +#define DVI_MODE_SELECT (0) +#define SDVOB_BORDER_ENABLE (1 << 7) +#define AUDIO_ENABLE (1 << 6) +#define VSYNC_ACTIVE_HIGH (1 << 4) +#define HSYNC_ACTIVE_HIGH (1 << 3) +#define PORT_DETECTED (1 << 2)
/* PCH SDVOB multiplex with HDMIB */ #define PCH_SDVOB HDMIB @@ -3582,55 +3582,55 @@ #define HDMID 0xe1160
#define PCH_LVDS 0xe1180 -#define LVDS_DETECTED (1 << 1) +#define LVDS_DETECTED (1 << 1)
#define BLC_PWM_CPU_CTL2 0x48250 -#define PWM_ENABLE (1 << 31) -#define PWM_PIPE_A (0 << 29) -#define PWM_PIPE_B (1 << 29) +#define PWM_ENABLE (1 << 31) +#define PWM_PIPE_A (0 << 29) +#define PWM_PIPE_B (1 << 29) #define BLC_PWM_CPU_CTL 0x48254
#define BLC_PWM_PCH_CTL1 0xc8250 -#define PWM_PCH_ENABLE (1 << 31) -#define PWM_POLARITY_ACTIVE_LOW (1 << 29) -#define PWM_POLARITY_ACTIVE_HIGH (0 << 29) -#define PWM_POLARITY_ACTIVE_LOW2 (1 << 28) -#define PWM_POLARITY_ACTIVE_HIGH2 (0 << 28) +#define PWM_PCH_ENABLE (1 << 31) +#define PWM_POLARITY_ACTIVE_LOW (1 << 29) +#define PWM_POLARITY_ACTIVE_HIGH (0 << 29) +#define PWM_POLARITY_ACTIVE_LOW2 (1 << 28) +#define PWM_POLARITY_ACTIVE_HIGH2 (0 << 28)
#define BLC_PWM_PCH_CTL2 0xc8254
#define PCH_PP_STATUS 0xc7200 #define PCH_PP_CONTROL 0xc7204 -#define PANEL_UNLOCK_REGS (0xabcd << 16) -#define PANEL_UNLOCK_MASK (0xffff << 16) -#define EDP_FORCE_VDD (1 << 3) -#define EDP_BLC_ENABLE (1 << 2) -#define PANEL_POWER_RESET (1 << 1) -#define PANEL_POWER_OFF (0 << 0) -#define PANEL_POWER_ON (1 << 0) +#define PANEL_UNLOCK_REGS (0xabcd << 16) +#define PANEL_UNLOCK_MASK (0xffff << 16) +#define EDP_FORCE_VDD (1 << 3) +#define EDP_BLC_ENABLE (1 << 2) +#define PANEL_POWER_RESET (1 << 1) +#define PANEL_POWER_OFF (0 << 0) +#define PANEL_POWER_ON (1 << 0) #define PCH_PP_ON_DELAYS 0xc7208 -#define PANEL_PORT_SELECT_MASK (3 << 30) -#define PANEL_PORT_SELECT_LVDS (0 << 30) -#define PANEL_PORT_SELECT_DPA (1 << 30) -#define EDP_PANEL (1 << 30) -#define PANEL_PORT_SELECT_DPC (2 << 30) -#define PANEL_PORT_SELECT_DPD (3 << 30) -#define PANEL_POWER_UP_DELAY_MASK (0x1fff0000) -#define PANEL_POWER_UP_DELAY_SHIFT 16 -#define PANEL_LIGHT_ON_DELAY_MASK (0x1fff) -#define PANEL_LIGHT_ON_DELAY_SHIFT 0 +#define PANEL_PORT_SELECT_MASK (3 << 30) +#define PANEL_PORT_SELECT_LVDS (0 << 30) +#define PANEL_PORT_SELECT_DPA (1 << 30) +#define EDP_PANEL (1 << 30) +#define PANEL_PORT_SELECT_DPC (2 << 30) +#define PANEL_PORT_SELECT_DPD (3 << 30) +#define PANEL_POWER_UP_DELAY_MASK (0x1fff0000) +#define PANEL_POWER_UP_DELAY_SHIFT 16 +#define PANEL_LIGHT_ON_DELAY_MASK (0x1fff) +#define PANEL_LIGHT_ON_DELAY_SHIFT 0
#define PCH_PP_OFF_DELAYS 0xc720c -#define PANEL_POWER_DOWN_DELAY_MASK (0x1fff0000) -#define PANEL_POWER_DOWN_DELAY_SHIFT 16 -#define PANEL_LIGHT_OFF_DELAY_MASK (0x1fff) -#define PANEL_LIGHT_OFF_DELAY_SHIFT 0 +#define PANEL_POWER_DOWN_DELAY_MASK (0x1fff0000) +#define PANEL_POWER_DOWN_DELAY_SHIFT 16 +#define PANEL_LIGHT_OFF_DELAY_MASK (0x1fff) +#define PANEL_LIGHT_OFF_DELAY_SHIFT 0
#define PCH_PP_DIVISOR 0xc7210 -#define PP_REFERENCE_DIVIDER_MASK (0xffffff00) -#define PP_REFERENCE_DIVIDER_SHIFT 8 -#define PANEL_POWER_CYCLE_DELAY_MASK (0x1f) -#define PANEL_POWER_CYCLE_DELAY_SHIFT 0 +#define PP_REFERENCE_DIVIDER_MASK (0xffffff00) +#define PP_REFERENCE_DIVIDER_SHIFT 8 +#define PANEL_POWER_CYCLE_DELAY_MASK (0x1f) +#define PANEL_POWER_CYCLE_DELAY_SHIFT 0
#define PCH_DP_B 0xe4100 #define PCH_DPB_AUX_CH_CTL 0xe4110 @@ -3657,48 +3657,48 @@ #define PCH_DPD_AUX_CH_DATA5 0xe4324
/* CPT */ -#define PORT_TRANS_A_SEL_CPT 0 -#define PORT_TRANS_B_SEL_CPT (1<<29) -#define PORT_TRANS_C_SEL_CPT (2<<29) -#define PORT_TRANS_SEL_MASK (3<<29) -#define PORT_TRANS_SEL_CPT(pipe) ((pipe) << 29) +#define PORT_TRANS_A_SEL_CPT 0 +#define PORT_TRANS_B_SEL_CPT (1<<29) +#define PORT_TRANS_C_SEL_CPT (2<<29) +#define PORT_TRANS_SEL_MASK (3<<29) +#define PORT_TRANS_SEL_CPT(pipe) ((pipe) << 29)
#define TRANS_DP_CTL_A 0xe0300 #define TRANS_DP_CTL_B 0xe1300 #define TRANS_DP_CTL_C 0xe2300 #define TRANS_DP_CTL(pipe) (TRANS_DP_CTL_A + (pipe) * 0x01000) -#define TRANS_DP_OUTPUT_ENABLE (1<<31) -#define TRANS_DP_PORT_SEL_B (0<<29) -#define TRANS_DP_PORT_SEL_C (1<<29) -#define TRANS_DP_PORT_SEL_D (2<<29) -#define TRANS_DP_PORT_SEL_NONE (3<<29) -#define TRANS_DP_PORT_SEL_MASK (3<<29) -#define TRANS_DP_AUDIO_ONLY (1<<26) -#define TRANS_DP_ENH_FRAMING (1<<18) -#define TRANS_DP_8BPC (0<<9) -#define TRANS_DP_10BPC (1<<9) -#define TRANS_DP_6BPC (2<<9) -#define TRANS_DP_12BPC (3<<9) -#define TRANS_DP_BPC_MASK (3<<9) -#define TRANS_DP_VSYNC_ACTIVE_HIGH (1<<4) -#define TRANS_DP_VSYNC_ACTIVE_LOW 0 -#define TRANS_DP_HSYNC_ACTIVE_HIGH (1<<3) -#define TRANS_DP_HSYNC_ACTIVE_LOW 0 -#define TRANS_DP_SYNC_MASK (3<<3) +#define TRANS_DP_OUTPUT_ENABLE (1<<31) +#define TRANS_DP_PORT_SEL_B (0<<29) +#define TRANS_DP_PORT_SEL_C (1<<29) +#define TRANS_DP_PORT_SEL_D (2<<29) +#define TRANS_DP_PORT_SEL_NONE (3<<29) +#define TRANS_DP_PORT_SEL_MASK (3<<29) +#define TRANS_DP_AUDIO_ONLY (1<<26) +#define TRANS_DP_ENH_FRAMING (1<<18) +#define TRANS_DP_8BPC (0<<9) +#define TRANS_DP_10BPC (1<<9) +#define TRANS_DP_6BPC (2<<9) +#define TRANS_DP_12BPC (3<<9) +#define TRANS_DP_BPC_MASK (3<<9) +#define TRANS_DP_VSYNC_ACTIVE_HIGH (1<<4) +#define TRANS_DP_VSYNC_ACTIVE_LOW 0 +#define TRANS_DP_HSYNC_ACTIVE_HIGH (1<<3) +#define TRANS_DP_HSYNC_ACTIVE_LOW 0 +#define TRANS_DP_SYNC_MASK (3<<3)
/* SNB eDP training params */ /* SNB A-stepping */ -#define EDP_LINK_TRAIN_400MV_0DB_SNB_A (0x38<<22) -#define EDP_LINK_TRAIN_400MV_6DB_SNB_A (0x02<<22) -#define EDP_LINK_TRAIN_600MV_3_5DB_SNB_A (0x01<<22) -#define EDP_LINK_TRAIN_800MV_0DB_SNB_A (0x0<<22) +#define EDP_LINK_TRAIN_400MV_0DB_SNB_A (0x38<<22) +#define EDP_LINK_TRAIN_400MV_6DB_SNB_A (0x02<<22) +#define EDP_LINK_TRAIN_600MV_3_5DB_SNB_A (0x01<<22) +#define EDP_LINK_TRAIN_800MV_0DB_SNB_A (0x0<<22) /* SNB B-stepping */ -#define EDP_LINK_TRAIN_400_600MV_0DB_SNB_B (0x0<<22) -#define EDP_LINK_TRAIN_400MV_3_5DB_SNB_B (0x1<<22) -#define EDP_LINK_TRAIN_400_600MV_6DB_SNB_B (0x3a<<22) -#define EDP_LINK_TRAIN_600_800MV_3_5DB_SNB_B (0x39<<22) -#define EDP_LINK_TRAIN_800_1200MV_0DB_SNB_B (0x38<<22) -#define EDP_LINK_TRAIN_VOL_EMP_MASK_SNB (0x3f<<22) +#define EDP_LINK_TRAIN_400_600MV_0DB_SNB_B (0x0<<22) +#define EDP_LINK_TRAIN_400MV_3_5DB_SNB_B (0x1<<22) +#define EDP_LINK_TRAIN_400_600MV_6DB_SNB_B (0x3a<<22) +#define EDP_LINK_TRAIN_600_800MV_3_5DB_SNB_B (0x39<<22) +#define EDP_LINK_TRAIN_800_1200MV_0DB_SNB_B (0x38<<22) +#define EDP_LINK_TRAIN_VOL_EMP_MASK_SNB (0x3f<<22)
/* IVB */ #define EDP_LINK_TRAIN_400MV_0DB_IVB (0x24 <<22) @@ -3716,23 +3716,23 @@ #define EDP_LINK_TRAIN_1000MV_3_5DB_IVB (0x22 <<22) #define EDP_LINK_TRAIN_1000MV_6DB_IVB (0x23 <<22)
-#define EDP_LINK_TRAIN_VOL_EMP_MASK_IVB (0x3f<<22) +#define EDP_LINK_TRAIN_VOL_EMP_MASK_IVB (0x3f<<22)
-#define FORCEWAKE 0xA18C -#define FORCEWAKE_ACK 0x130090 -#define FORCEWAKE_MT 0xa188 /* multi-threaded */ -#define FORCEWAKE_MT_ACK 0x130040 -#define ECOBUS 0xa180 -#define FORCEWAKE_MT_ENABLE (1<<5) +#define FORCEWAKE 0xA18C +#define FORCEWAKE_ACK 0x130090 +#define FORCEWAKE_MT 0xa188 /* multi-threaded */ +#define FORCEWAKE_MT_ACK 0x130040 +#define ECOBUS 0xa180 +#define FORCEWAKE_MT_ENABLE (1<<5)
-#define GTFIFODBG 0x120000 -#define GT_FIFO_CPU_ERROR_MASK 7 -#define GT_FIFO_OVFERR (1<<2) -#define GT_FIFO_IAWRERR (1<<1) -#define GT_FIFO_IARDERR (1<<0) +#define GTFIFODBG 0x120000 +#define GT_FIFO_CPU_ERROR_MASK 7 +#define GT_FIFO_OVFERR (1<<2) +#define GT_FIFO_IAWRERR (1<<1) +#define GT_FIFO_IARDERR (1<<0)
-#define GT_FIFO_FREE_ENTRIES 0x120008 -#define GT_FIFO_NUM_RESERVED_ENTRIES 20 +#define GT_FIFO_FREE_ENTRIES 0x120008 +#define GT_FIFO_NUM_RESERVED_ENTRIES 20
#define GEN6_UCGCTL1 0x9400 # define GEN6_BLBUNIT_CLOCK_GATE_DISABLE (1 << 5) @@ -3743,46 +3743,46 @@ # define GEN6_RCCUNIT_CLOCK_GATE_DISABLE (1 << 11)
#define GEN6_RPNSWREQ 0xA008 -#define GEN6_TURBO_DISABLE (1<<31) -#define GEN6_FREQUENCY(x) ((x)<<25) -#define GEN6_OFFSET(x) ((x)<<19) -#define GEN6_AGGRESSIVE_TURBO (0<<15) +#define GEN6_TURBO_DISABLE (1<<31) +#define GEN6_FREQUENCY(x) ((x)<<25) +#define GEN6_OFFSET(x) ((x)<<19) +#define GEN6_AGGRESSIVE_TURBO (0<<15) #define GEN6_RC_VIDEO_FREQ 0xA00C #define GEN6_RC_CONTROL 0xA090 -#define GEN6_RC_CTL_RC6pp_ENABLE (1<<16) -#define GEN6_RC_CTL_RC6p_ENABLE (1<<17) -#define GEN6_RC_CTL_RC6_ENABLE (1<<18) -#define GEN6_RC_CTL_RC1e_ENABLE (1<<20) -#define GEN6_RC_CTL_RC7_ENABLE (1<<22) -#define GEN6_RC_CTL_EI_MODE(x) ((x)<<27) -#define GEN6_RC_CTL_HW_ENABLE (1<<31) +#define GEN6_RC_CTL_RC6pp_ENABLE (1<<16) +#define GEN6_RC_CTL_RC6p_ENABLE (1<<17) +#define GEN6_RC_CTL_RC6_ENABLE (1<<18) +#define GEN6_RC_CTL_RC1e_ENABLE (1<<20) +#define GEN6_RC_CTL_RC7_ENABLE (1<<22) +#define GEN6_RC_CTL_EI_MODE(x) ((x)<<27) +#define GEN6_RC_CTL_HW_ENABLE (1<<31) #define GEN6_RP_DOWN_TIMEOUT 0xA010 #define GEN6_RP_INTERRUPT_LIMITS 0xA014 #define GEN6_RPSTAT1 0xA01C -#define GEN6_CAGF_SHIFT 8 -#define GEN6_CAGF_MASK (0x7f << GEN6_CAGF_SHIFT) +#define GEN6_CAGF_SHIFT 8 +#define GEN6_CAGF_MASK (0x7f << GEN6_CAGF_SHIFT) #define GEN6_RP_CONTROL 0xA024 -#define GEN6_RP_MEDIA_TURBO (1<<11) -#define GEN6_RP_MEDIA_MODE_MASK (3<<9) -#define GEN6_RP_MEDIA_HW_TURBO_MODE (3<<9) -#define GEN6_RP_MEDIA_HW_NORMAL_MODE (2<<9) -#define GEN6_RP_MEDIA_HW_MODE (1<<9) -#define GEN6_RP_MEDIA_SW_MODE (0<<9) -#define GEN6_RP_MEDIA_IS_GFX (1<<8) -#define GEN6_RP_ENABLE (1<<7) -#define GEN6_RP_UP_IDLE_MIN (0x1<<3) -#define GEN6_RP_UP_BUSY_AVG (0x2<<3) -#define GEN6_RP_UP_BUSY_CONT (0x4<<3) -#define GEN6_RP_DOWN_IDLE_CONT (0x1<<0) +#define GEN6_RP_MEDIA_TURBO (1<<11) +#define GEN6_RP_MEDIA_MODE_MASK (3<<9) +#define GEN6_RP_MEDIA_HW_TURBO_MODE (3<<9) +#define GEN6_RP_MEDIA_HW_NORMAL_MODE (2<<9) +#define GEN6_RP_MEDIA_HW_MODE (1<<9) +#define GEN6_RP_MEDIA_SW_MODE (0<<9) +#define GEN6_RP_MEDIA_IS_GFX (1<<8) +#define GEN6_RP_ENABLE (1<<7) +#define GEN6_RP_UP_IDLE_MIN (0x1<<3) +#define GEN6_RP_UP_BUSY_AVG (0x2<<3) +#define GEN6_RP_UP_BUSY_CONT (0x4<<3) +#define GEN6_RP_DOWN_IDLE_CONT (0x1<<0) #define GEN6_RP_UP_THRESHOLD 0xA02C #define GEN6_RP_DOWN_THRESHOLD 0xA030 #define GEN6_RP_CUR_UP_EI 0xA050 -#define GEN6_CURICONT_MASK 0xffffff +#define GEN6_CURICONT_MASK 0xffffff #define GEN6_RP_CUR_UP 0xA054 -#define GEN6_CURBSYTAVG_MASK 0xffffff +#define GEN6_CURBSYTAVG_MASK 0xffffff #define GEN6_RP_PREV_UP 0xA058 #define GEN6_RP_CUR_DOWN_EI 0xA05C -#define GEN6_CURIAVG_MASK 0xffffff +#define GEN6_CURIAVG_MASK 0xffffff #define GEN6_RP_CUR_DOWN 0xA060 #define GEN6_RP_PREV_DOWN 0xA064 #define GEN6_RP_UP_EI 0xA068 @@ -3805,32 +3805,32 @@ #define GEN6_PMIMR 0x44024 /* rps_lock */ #define GEN6_PMIIR 0x44028 #define GEN6_PMIER 0x4402C -#define GEN6_PM_MBOX_EVENT (1<<25) -#define GEN6_PM_THERMAL_EVENT (1<<24) -#define GEN6_PM_RP_DOWN_TIMEOUT (1<<6) -#define GEN6_PM_RP_UP_THRESHOLD (1<<5) -#define GEN6_PM_RP_DOWN_THRESHOLD (1<<4) -#define GEN6_PM_RP_UP_EI_EXPIRED (1<<2) -#define GEN6_PM_RP_DOWN_EI_EXPIRED (1<<1) -#define GEN6_PM_DEFERRED_EVENTS (GEN6_PM_RP_UP_THRESHOLD | \ +#define GEN6_PM_MBOX_EVENT (1<<25) +#define GEN6_PM_THERMAL_EVENT (1<<24) +#define GEN6_PM_RP_DOWN_TIMEOUT (1<<6) +#define GEN6_PM_RP_UP_THRESHOLD (1<<5) +#define GEN6_PM_RP_DOWN_THRESHOLD (1<<4) +#define GEN6_PM_RP_UP_EI_EXPIRED (1<<2) +#define GEN6_PM_RP_DOWN_EI_EXPIRED (1<<1) +#define GEN6_PM_DEFERRED_EVENTS (GEN6_PM_RP_UP_THRESHOLD | \ GEN6_PM_RP_DOWN_THRESHOLD | \ GEN6_PM_RP_DOWN_TIMEOUT)
#define GEN6_PCODE_MAILBOX 0x138124 -#define GEN6_PCODE_READY (1<<31) -#define GEN6_READ_OC_PARAMS 0xc -#define GEN6_PCODE_WRITE_MIN_FREQ_TABLE 0x8 -#define GEN6_PCODE_READ_MIN_FREQ_TABLE 0x9 +#define GEN6_PCODE_READY (1<<31) +#define GEN6_READ_OC_PARAMS 0xc +#define GEN6_PCODE_WRITE_MIN_FREQ_TABLE 0x8 +#define GEN6_PCODE_READ_MIN_FREQ_TABLE 0x9 #define GEN6_PCODE_DATA 0x138128 -#define GEN6_PCODE_FREQ_IA_RATIO_SHIFT 8 +#define GEN6_PCODE_FREQ_IA_RATIO_SHIFT 8
#define GEN6_GT_CORE_STATUS 0x138060 -#define GEN6_CORE_CPD_STATE_MASK (7<<4) -#define GEN6_RCn_MASK 7 -#define GEN6_RC0 0 -#define GEN6_RC3 2 -#define GEN6_RC6 3 -#define GEN6_RC7 4 +#define GEN6_CORE_CPD_STATE_MASK (7<<4) +#define GEN6_RCn_MASK 7 +#define GEN6_RC0 0 +#define GEN6_RC3 2 +#define GEN6_RC6 3 +#define GEN6_RC7 4
#define G4X_AUD_VID_DID 0x62020 #define INTEL_AUDIO_DEVCL 0x808629FB @@ -3865,14 +3865,14 @@
#define IBX_AUD_CONFIG_A 0xe2000 #define CPT_AUD_CONFIG_A 0xe5000 -#define AUD_CONFIG_N_VALUE_INDEX (1 << 29) -#define AUD_CONFIG_N_PROG_ENABLE (1 << 28) -#define AUD_CONFIG_UPPER_N_SHIFT 20 -#define AUD_CONFIG_UPPER_N_VALUE (0xff << 20) -#define AUD_CONFIG_LOWER_N_SHIFT 4 -#define AUD_CONFIG_LOWER_N_VALUE (0xfff << 4) -#define AUD_CONFIG_PIXEL_CLOCK_HDMI_SHIFT 16 -#define AUD_CONFIG_PIXEL_CLOCK_HDMI (0xf << 16) -#define AUD_CONFIG_DISABLE_NCTS (1 << 3) +#define AUD_CONFIG_N_VALUE_INDEX (1 << 29) +#define AUD_CONFIG_N_PROG_ENABLE (1 << 28) +#define AUD_CONFIG_UPPER_N_SHIFT 20 +#define AUD_CONFIG_UPPER_N_VALUE (0xff << 20) +#define AUD_CONFIG_LOWER_N_SHIFT 4 +#define AUD_CONFIG_LOWER_N_VALUE (0xfff << 4) +#define AUD_CONFIG_PIXEL_CLOCK_HDMI_SHIFT 16 +#define AUD_CONFIG_PIXEL_CLOCK_HDMI (0xf << 16) +#define AUD_CONFIG_DISABLE_NCTS (1 << 3)
#endif /* _I915_REG_H_ */
