Attention is currently required from: Hung-Te Lin.
Liju-Clr Chen has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/69088 )
Change subject: soc/mediatek/mt8188: Allow MCUPM to access the secure registers ......................................................................
This patch fixes AP hanging issue after boot to login shell. DEVAPC enables sideband to allow MCUPM to access the secure registers. Also DEVAPC only allow DOMAIN 0 to access all the non secure registers by default, remove the DOMAIN 2 setting.
BUG=none TEST=It works well after boot to login shell.
Change-Id: I67b08c38a31a7eae1bc59543a5148a78b61456d6 Signed-off-by: Liju-Clr Chen liju-clr.chen@mediatek.com --- M src/soc/mediatek/mt8188/devapc.c 1 file changed, 18 insertions(+), 3 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/88/69088/1
diff --git a/src/soc/mediatek/mt8188/devapc.c b/src/soc/mediatek/mt8188/devapc.c index 260b9ff..a9b7762 100644 --- a/src/soc/mediatek/mt8188/devapc.c +++ b/src/soc/mediatek/mt8188/devapc.c @@ -1553,9 +1553,6 @@ /* Side band */ SET32_BITFIELDS(getreg(base, MAS_SEC_0), MCUPM_SEC, SECURE_TRANS);
- /* Master domain */ - SET32_BITFIELDS(getreg(base, MAS_DOM_0), SCP_SSPM_DOM, DOMAIN_2, MCUPM_DOM, DOMAIN_2); - /* Default APC setting */ set_infra_ao_apc(base); }
