Hello Paul Menzel, build bot (Jenkins),
https://review.coreboot.org/19033
Change subject: util/abuild: Save checksums of build files ......................................................................
- Add --checksum command line parameter to specify a base path and filename for the checksums to be saved into. - Save checksums of each platform into the specified file appended with "_platform" - Save a sha256 checksum of the sorted config.h into the base file appended with "_config"
Change-Id: Id24dc4b10afbd35cdb8750f75b934419e6e80290 Signed-off-by: Martin Roth gaumless@gmail.com --- M util/abuild/abuild 1 file changed, 11 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/33/19033/4
