Lean Sheng Tan has submitted this change. ( https://review.coreboot.org/c/coreboot/+/80796?usp=email )
Change subject: soc/intel/xeon_sp: Use common _CRS code generation ......................................................................
Drop SoC specific code and use generic implementation provided by pci_domain_fill_ssdt.
TEST=Booted on IBM/SBP1 to Ubuntu 22.04. TEST=intel/archercity CRB
Change-Id: I8b0bc2eb02569b5d74f8521d79e0af8fee880c80 Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/80796 Reviewed-by: Shuo Liu shuo.liu@intel.com Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Lean Sheng Tan sheng.tan@9elements.com --- M src/soc/intel/xeon_sp/chip_common.c M src/soc/intel/xeon_sp/cpx/chip.c M src/soc/intel/xeon_sp/cpx/soc_acpi.c M src/soc/intel/xeon_sp/skx/chip.c M src/soc/intel/xeon_sp/skx/soc_acpi.c M src/soc/intel/xeon_sp/spr/chip.c M src/soc/intel/xeon_sp/spr/ioat.c M src/soc/intel/xeon_sp/spr/soc_acpi.c 8 files changed, 13 insertions(+), 424 deletions(-)
Approvals: build bot (Jenkins): Verified Shuo Liu: Looks good to me, approved Lean Sheng Tan: Looks good to me, approved
diff --git a/src/soc/intel/xeon_sp/chip_common.c b/src/soc/intel/xeon_sp/chip_common.c index 853b6bf..b461f0e 100644 --- a/src/soc/intel/xeon_sp/chip_common.c +++ b/src/soc/intel/xeon_sp/chip_common.c @@ -1,5 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0-or-later */
+#include <acpi/acpigen_pci.h> #include <assert.h> #include <console/console.h> #include <device/pci.h> @@ -243,6 +244,7 @@ #if CONFIG(HAVE_ACPI_TABLES) .acpi_name = soc_acpi_name, .write_acpi_tables = northbridge_write_acpi_tables, + .acpi_fill_ssdt = pci_domain_fill_ssdt, #endif };
@@ -257,6 +259,7 @@ #if CONFIG(HAVE_ACPI_TABLES) .acpi_name = soc_acpi_name, .write_acpi_tables = northbridge_write_acpi_tables, + .acpi_fill_ssdt = pci_domain_fill_ssdt, #endif };
@@ -348,6 +351,7 @@ #if CONFIG(HAVE_ACPI_TABLES) .acpi_name = soc_acpi_name, .write_acpi_tables = northbridge_write_acpi_tables, + .acpi_fill_ssdt = pci_domain_fill_ssdt, #endif };
diff --git a/src/soc/intel/xeon_sp/cpx/chip.c b/src/soc/intel/xeon_sp/cpx/chip.c index 8a828c6..1fc9c75 100644 --- a/src/soc/intel/xeon_sp/cpx/chip.c +++ b/src/soc/intel/xeon_sp/cpx/chip.c @@ -1,5 +1,5 @@ /* SPDX-License-Identifier: GPL-2.0-only */ - +#include <acpi/acpigen_pci.h> #include <arch/ioapic.h> #include <console/console.h> #include <console/debug.h> diff --git a/src/soc/intel/xeon_sp/cpx/soc_acpi.c b/src/soc/intel/xeon_sp/cpx/soc_acpi.c index 8b24ba2..b2d6d79 100644 --- a/src/soc/intel/xeon_sp/cpx/soc_acpi.c +++ b/src/soc/intel/xeon_sp/cpx/soc_acpi.c @@ -43,72 +43,6 @@
void uncore_fill_ssdt(const struct device *device) { - struct iiostack_resource stack_info = {0}; - - /* Only add RTxx entries once. */ - if (device->upstream->secondary != 0 || device->upstream->segment_group != 0) - return; - - get_iiostack_info(&stack_info); - - for (uint8_t stack = 0; stack < stack_info.no_of_stacks; ++stack) { - const STACK_RES *ri = &stack_info.res[stack]; - char rtname[16]; - - snprintf(rtname, sizeof(rtname), "\_SB.PC%02x", stack); - acpigen_write_scope(rtname); - - acpigen_write_name("_CRS"); - printk(BIOS_DEBUG, "\tCreating ResourceTemplate %s for stack: %d\n", - rtname, stack); - - acpigen_write_resourcetemplate_header(); - - /* bus resource */ - acpigen_resource_word(2, 0xc, 0, 0, ri->BusBase, ri->BusLimit, - 0x0, (ri->BusLimit - ri->BusBase + 1)); - - /* additional io resources on socket 0 bus 0 */ - if (stack == 0) { - /* ACPI 6.4.2.5 I/O Port Descriptor */ - acpigen_write_io16(0xCF8, 0xCFF, 0x1, 0x8, 1); - - /* IO decode CF8-CFF */ - acpigen_resource_word(1, 0xc, 0x3, 0, 0x0000, 0x03AF, 0, 0x03B0); - acpigen_resource_word(1, 0xc, 0x3, 0, 0x03E0, 0x0CF7, 0, 0x0918); - acpigen_resource_word(1, 0xc, 0x3, 0, 0x03B0, 0x03BB, 0, 0x000C); - acpigen_resource_word(1, 0xc, 0x3, 0, 0x03C0, 0x03DF, 0, 0x0020); - } - - /* IO resource */ - acpigen_resource_word(1, 0xc, 0x3, 0, ri->PciResourceIoBase, - ri->PciResourceIoLimit, 0x0, - (ri->PciResourceIoLimit - ri->PciResourceIoBase + 1)); - - /* additional mem32 resources on socket 0 bus 0 */ - if (stack == 0) { - acpigen_resource_dword(0, 0xc, 3, 0, VGA_MMIO_BASE, - VGA_MMIO_LIMIT, 0x0, VGA_MMIO_SIZE); - acpigen_resource_dword(0, 0xc, 1, 0, SPI_BASE_ADDRESS, - (SPI_BASE_ADDRESS + SPI_BASE_SIZE - 1), 0x0, - SPI_BASE_SIZE); - } - - /* Mem32 resource */ - acpigen_resource_dword(0, 0xc, 1, 0, ri->PciResourceMem32Base, - ri->PciResourceMem32Limit, 0x0, - (ri->PciResourceMem32Limit - ri->PciResourceMem32Base + 1)); - - /* Mem64 resource */ - acpigen_resource_qword(0, 0xc, 1, 0, ri->PciResourceMem64Base, - ri->PciResourceMem64Limit, 0x0, - (ri->PciResourceMem64Limit - ri->PciResourceMem64Base + 1)); - - acpigen_write_resourcetemplate_footer(); - - /* Scope */ - acpigen_pop_len(); - } }
/* TODO: See if we can use the common generate_p_state_entries */ diff --git a/src/soc/intel/xeon_sp/skx/chip.c b/src/soc/intel/xeon_sp/skx/chip.c index 1911e06..d8b3161 100644 --- a/src/soc/intel/xeon_sp/skx/chip.c +++ b/src/soc/intel/xeon_sp/skx/chip.c @@ -1,5 +1,5 @@ /* SPDX-License-Identifier: GPL-2.0-or-later */ - +#include <acpi/acpigen_pci.h> #include <cbfs.h> #include <console/console.h> #include <device/pci.h> diff --git a/src/soc/intel/xeon_sp/skx/soc_acpi.c b/src/soc/intel/xeon_sp/skx/soc_acpi.c index 2e2b14a..b98e998 100644 --- a/src/soc/intel/xeon_sp/skx/soc_acpi.c +++ b/src/soc/intel/xeon_sp/skx/soc_acpi.c @@ -56,82 +56,6 @@
void uncore_fill_ssdt(const struct device *device) { - const IIO_UDS *hob = get_iio_uds(); - - /* Only add RTxx entries once. */ - if (device->upstream->secondary != 0) - return; - - for (int socket = 0, iio = 0; iio < hob->PlatformData.numofIIO; ++socket) { - if (!soc_cpu_is_enabled(socket)) - continue; - iio++; - IIO_RESOURCE_INSTANCE iio_resource = - hob->PlatformData.IIO_resource[socket]; - for (int stack = 0; stack <= PSTACK2; ++stack) { - const STACK_RES *ri = &iio_resource.StackRes[stack]; - char rtname[16]; - - snprintf(rtname, sizeof(rtname), "\_SB.PC%02x", socket * MAX_IIO_STACK + stack); - acpigen_write_scope(rtname); - - acpigen_write_name("_CRS"); - - printk(BIOS_DEBUG, "\tCreating ResourceTemplate %s for socket: %d, stack: %d\n", - rtname, socket, stack); - - acpigen_write_resourcetemplate_header(); - - /* bus resource */ - acpigen_resource_word(2, 0xc, 0, 0, ri->BusBase, ri->BusLimit, - 0x0, (ri->BusLimit - ri->BusBase + 1)); - - // additional io resources on socket 0 bus 0 - if (socket == 0 && stack == 0) { - /* ACPI 6.4.2.5 I/O Port Descriptor */ - acpigen_write_io16(0xCF8, 0xCFF, 0x1, 0x8, 1); - - /* IO decode CF8-CFF */ - acpigen_resource_word(1, 0xc, 0x3, 0, 0x0000, 0x03AF, - 0, 0x03B0); - acpigen_resource_word(1, 0xc, 0x3, 0, 0x03E0, 0x0CF7, - 0, 0x0918); - acpigen_resource_word(1, 0xc, 0x3, 0, 0x03B0, 0x03BB, - 0, 0x000C); - acpigen_resource_word(1, 0xc, 0x3, 0, 0x03C0, 0x03DF, - 0, 0x0020); - } - - /* IO resource */ - acpigen_resource_word(1, 0xc, 0x3, 0, ri->PciResourceIoBase, - ri->PciResourceIoLimit, 0x0, - (ri->PciResourceIoLimit - ri->PciResourceIoBase + 1)); - - // additional mem32 resources on socket 0 bus 0 - if (socket == 0 && stack == 0) { - acpigen_resource_dword(0, 0xc, 3, 0, VGA_MMIO_BASE, - VGA_MMIO_LIMIT, 0x0, VGA_MMIO_SIZE); - acpigen_resource_dword(0, 0xc, 1, 0, SPI_BASE_ADDRESS, - (SPI_BASE_ADDRESS + SPI_BASE_SIZE - 1), 0x0, - SPI_BASE_SIZE); - } - - /* Mem32 resource */ - acpigen_resource_dword(0, 0xc, 1, 0, ri->PciResourceMem32Base, - ri->PciResourceMem32Limit, 0x0, - (ri->PciResourceMem32Limit - ri->PciResourceMem32Base + 1)); - - /* Mem64 resource */ - acpigen_resource_qword(0, 0xc, 1, 0, ri->PciResourceMem64Base, - ri->PciResourceMem64Limit, 0x0, - (ri->PciResourceMem64Limit - ri->PciResourceMem64Base + 1)); - - acpigen_write_resourcetemplate_footer(); - - /* Scope */ - acpigen_pop_len(); - } - } }
void soc_power_states_generation(int core, int cores_per_package) diff --git a/src/soc/intel/xeon_sp/spr/chip.c b/src/soc/intel/xeon_sp/spr/chip.c index a9387f4..7b934ba 100644 --- a/src/soc/intel/xeon_sp/spr/chip.c +++ b/src/soc/intel/xeon_sp/spr/chip.c @@ -1,5 +1,5 @@ /* SPDX-License-Identifier: GPL-2.0-only */ - +#include <acpi/acpigen_pci.h> #include <arch/ioapic.h> #include <console/console.h> #include <console/debug.h> diff --git a/src/soc/intel/xeon_sp/spr/ioat.c b/src/soc/intel/xeon_sp/spr/ioat.c index 2b6aafa..2e3baa3 100644 --- a/src/soc/intel/xeon_sp/spr/ioat.c +++ b/src/soc/intel/xeon_sp/spr/ioat.c @@ -1,5 +1,5 @@ /* SPDX-License-Identifier: GPL-2.0-only */ - +#include <acpi/acpigen_pci.h> #include <stdbool.h>
#include <console/console.h> @@ -26,6 +26,7 @@ #if CONFIG(HAVE_ACPI_TABLES) .acpi_name = soc_acpi_name, .write_acpi_tables = northbridge_write_acpi_tables, + .acpi_fill_ssdt = pci_domain_fill_ssdt, #endif };
diff --git a/src/soc/intel/xeon_sp/spr/soc_acpi.c b/src/soc/intel/xeon_sp/spr/soc_acpi.c index ca1cdf9..0b6e491 100644 --- a/src/soc/intel/xeon_sp/spr/soc_acpi.c +++ b/src/soc/intel/xeon_sp/spr/soc_acpi.c @@ -53,279 +53,11 @@ fill_fadt_extended_pm_io(fadt); }
-static void create_dsdt_iou_pci_resource(uint8_t socket, uint8_t stack, const STACK_RES *ri, - bool stack_enabled) -{ - /* - Stacks 0 (TYPE_UBOX_IIO) - Scope: PC<socket><stack>, ResourceTemplate: P0RS - Stacks 1 .. 5 (TYPE_UBOX_IIO) - Scope: PC<socket><stack>, ResourceTemplate: RBRS - */ - /* write _CRS scope */ - char tres[16]; - snprintf(tres, sizeof(tres), "\_SB.PC%d%X", socket, stack); - acpigen_write_scope(tres); - acpigen_write_name("_CRS"); - - printk(BIOS_DEBUG, "\tCreating ResourceTemplate %s for socket: %d, stack: %d\n", tres, - socket, stack); - - acpigen_write_resourcetemplate_header(); - - /* Bus Resource */ - if (stack_enabled) { - /* For stack with CXL device, the PCIe bus resource is BusBase only. */ - if (is_iio_cxl_stack_res(ri)) - acpigen_resource_word(2, 0xc, 0, 0, ri->BusBase, ri->BusBase, 0x0, 1); - else - acpigen_resource_word(2, 0xc, 0, 0, ri->BusBase, ri->BusLimit, 0x0, - (ri->BusLimit - ri->BusBase + 1)); - } else { - acpigen_resource_word(2, 0, 0, 0, 0, 0, 0, 0); - } - - /* Additional IO resources on socket 0 bus 0 */ - if (socket == 0 && stack == 0) { - /* ACPI 6.4.2.5 I/O Port Descriptor */ - acpigen_write_io16(0xCF8, 0xCFF, 0x1, 0x8, 1); - - /* IO decode CF8-CFF */ - acpigen_resource_word(1, 0xc, 0x3, 0, 0x0000, 0x03AF, 0, 0x03B0); - acpigen_resource_word(1, 0xc, 0x3, 0, 0x03E0, 0x0CF7, 0, 0x0918); - acpigen_resource_word(1, 0xc, 0x3, 0, 0x03B0, 0x03BB, 0, 0x000C); - acpigen_resource_word(1, 0xc, 0x3, 0, 0x03C0, 0x03DF, 0, 0x0020); - } - - /* IO resource */ - if (stack_enabled) { - acpigen_resource_word(1, 0xc, 0x3, 0, ri->PciResourceIoBase, - ri->PciResourceIoLimit, 0x0, - (ri->PciResourceIoLimit - ri->PciResourceIoBase + 1)); - - /* Additional Mem32 resources on socket 0 bus 0 */ - if (socket == 0 && stack == 0) { - acpigen_resource_dword(0, 0xc, 3, 0, VGA_MMIO_BASE, - VGA_MMIO_LIMIT, 0x0, VGA_MMIO_SIZE); - acpigen_resource_dword(0, 0xc, 1, 0, SPI_BASE_ADDRESS, - (SPI_BASE_ADDRESS + SPI_BASE_SIZE - 1), 0x0, - SPI_BASE_SIZE); - } - - /* Mem32 resource */ - acpigen_resource_dword( - 0, 0xc, 1, 0, ri->PciResourceMem32Base, ri->PciResourceMem32Limit, 0x0, - (ri->PciResourceMem32Limit - ri->PciResourceMem32Base + 1)); - - /* Mem64 resource */ - acpigen_resource_qword( - 0, 0xc, 1, 0, ri->PciResourceMem64Base, ri->PciResourceMem64Limit, 0x0, - (ri->PciResourceMem64Limit - ri->PciResourceMem64Base + 1)); - } else { - /* Zeroed IO resource */ - acpigen_resource_word(1, 0, 3, 0, 0, 0, 0, 0); - - /* Zeroed Mem32 resource */ - acpigen_resource_dword(0, 0, 1, 0, 0, 0, 0, 0); - - /* Zeroed Mem64 resource */ - acpigen_resource_dword(0, 0, 1, 0, 0, 0, 0, 0); - } - - acpigen_write_resourcetemplate_footer(); - acpigen_pop_len(); -} - -static void create_dsdt_iou_cxl_resource(uint8_t socket, uint8_t stack, const STACK_RES *ri, bool stack_enabled) -{ - /* - Stacks 1 .. 5 (TYPE_UBOX_IIO) - Scope: CX<socket><stack>, ResourceTemplate: RBRS - */ - /* write _CRS scope */ - char tres[16]; - snprintf(tres, sizeof(tres), "\_SB.CX%d%X", socket, stack); - acpigen_write_scope(tres); - acpigen_write_name("_CRS"); - - printk(BIOS_DEBUG, "\tCreating ResourceTemplate %s for socket: %d, stack: %d\n", tres, - socket, stack); - - acpigen_write_resourcetemplate_header(); - - if (stack_enabled) { - /* bus resource, from (BusBase + 1) to BusLimit */ - acpigen_resource_word(2, 0xc, 0, 0, ri->BusBase + 1, ri->BusLimit, 0x0, - (ri->BusLimit - ri->BusBase)); - - /* IO resource */ - acpigen_resource_word(1, 0xc, 0x3, 0, ri->IoBase, ri->PciResourceIoBase - 1, - 0x0, ri->PciResourceIoBase - ri->IoBase); - - /* Mem32 resource */ - acpigen_resource_dword(0, 0xc, 1, 0, ri->Mmio32Base, - ri->PciResourceMem32Base - 1, 0x0, - ri->PciResourceMem32Base - ri->Mmio32Base); - - /* Mem64 resource */ - acpigen_resource_qword(0, 0xc, 1, 0, ri->Mmio64Base, - ri->PciResourceMem64Base - 1, 0x0, - ri->PciResourceMem64Base - ri->Mmio64Base); - } else { - /* bus resource, from (BusBase + 1) to BusLimit */ - acpigen_resource_word(2, 0, 0, 0, 0, 0, 0, 0); - - /* IO resource */ - acpigen_resource_word(1, 0, 3, 0, 0, 0, 0, 0); - - /* Mem32 resource */ - acpigen_resource_dword(0, 0, 1, 0, 0, 0, 0, 0); - - /* Mem64 resource */ - acpigen_resource_qword(0, 0, 1, 0, 0, 0, 0, 0); - } - - acpigen_write_resourcetemplate_footer(); - acpigen_pop_len(); -} - -static void create_dsdt_ioat_resource(uint8_t socket, uint8_t stack, const STACK_RES *ri, bool stack_enabled) -{ - if (!stack_enabled) - return; - - /* - Stacks 8 .. B (TYPE_DINO) - Scope: DI<socket><stack> for DINO, ResourceTemplate: DT - Scope: CP<socket><stack> for CPM (i.e., QAT), ResourceTemplate: MT - Scope: HQ<socket><stack> for HQM (i.e., DLB), ResourceTemplate: HT - */ - - enum { - DSDT_DINO = 0, - DSDT_CPM, - DSDT_HQM, - DSDT_CPM1, - DSDT_HQM1 - }; - uint8_t rlist[] = {DSDT_DINO, DSDT_CPM, DSDT_HQM, DSDT_CPM1, DSDT_HQM1}; - - for (int i = 0; i < ARRAY_SIZE(rlist); ++i) { - uint8_t bus_base, bus_limit; - uint64_t mem64_base, mem64_limit; - char tres[16]; - - /* Note, This allocates the resources in a different order than - * coreboot (DINO base is last). This causes the kernel to - * reallocate the DINO BARs. - * TODO: Use the resource settings from coreboot */ - if (rlist[i] == DSDT_DINO) { - bus_base = ri->BusBase; - bus_limit = ri->BusBase; - mem64_base = ri->PciResourceMem64Base + CPM_MMIO_SIZE + HQM_MMIO_SIZE - + CPM_MMIO_SIZE + HQM_MMIO_SIZE; - mem64_limit = ri->PciResourceMem64Limit; - snprintf(tres, sizeof(tres), "\_SB.DI%d%X", socket, stack); - } else if (rlist[i] == DSDT_CPM) { - bus_base = ri->BusBase + CPM_BUS_OFFSET; - bus_limit = bus_base + CPM_RESERVED_BUS; - mem64_base = ri->PciResourceMem64Base; - mem64_limit = mem64_base + CPM_MMIO_SIZE - 1; - snprintf(tres, sizeof(tres), "\_SB.PM%d%X", socket, stack); - } else if (rlist[i] == DSDT_HQM) { - bus_base = ri->BusBase + HQM_BUS_OFFSET; - bus_limit = bus_base + HQM_RESERVED_BUS; - mem64_base = ri->PciResourceMem64Base + CPM_MMIO_SIZE; - mem64_limit = mem64_base + HQM_MMIO_SIZE - 1; - snprintf(tres, sizeof(tres), "\_SB.HQ%d%X", socket, stack); - } else if (rlist[i] == DSDT_CPM1) { - bus_base = ri->BusBase + CPM1_BUS_OFFSET; - bus_limit = bus_base + CPM_RESERVED_BUS; - mem64_base = ri->PciResourceMem64Base + CPM_MMIO_SIZE + HQM_MMIO_SIZE; - mem64_limit = mem64_base + CPM_MMIO_SIZE - 1; - snprintf(tres, sizeof(tres), "\_SB.PN%d%X", socket, stack); - } else { - bus_base = ri->BusBase + HQM1_BUS_OFFSET; - bus_limit = bus_base + HQM_RESERVED_BUS; - mem64_base = ri->PciResourceMem64Base + CPM_MMIO_SIZE + HQM_MMIO_SIZE - + CPM_MMIO_SIZE; - mem64_limit = mem64_base + HQM_MMIO_SIZE - 1; - snprintf(tres, sizeof(tres), "\_SB.HR%d%X", socket, stack); - } - - /* Note, some SKU doesn't provide CPM1 and HQM1 and owns smaller bus ranges - accordingly*/ - if (bus_limit > ri->BusLimit) - continue; - - printk(BIOS_DEBUG, - "\tCreating Dino ResourceTemplate %s for socket: %d, " - "stack: %d\n bus_base:0x%x, bus_limit:0x%x\n", - tres, socket, stack, bus_base, bus_limit); - - acpigen_write_scope(tres); - acpigen_write_name("_CRS"); - acpigen_write_resourcetemplate_header(); - - acpigen_resource_word(2, 0xc, 0, 0, bus_base, bus_limit, 0x0, - (bus_limit - bus_base + 1)); - - /* Mem32 resource */ - if (rlist[i] == DSDT_DINO) - acpigen_resource_dword(0, 0xc, 1, 0, ri->PciResourceMem32Base, - ri->PciResourceMem32Limit, 0x0, - (ri->PciResourceMem32Limit - - ri->PciResourceMem32Base + 1)); - - /* Mem64 resource */ - acpigen_resource_qword(0, 0xc, 1, 0, mem64_base, mem64_limit, 0, - (mem64_limit - mem64_base + 1)); - - acpigen_write_resourcetemplate_footer(); - acpigen_pop_len(); - } -} - -static void create_dsdt_ubox_resource(uint8_t socket, uint8_t stack, const STACK_RES *ri, bool stack_enabled) -{ - /* - Stacks D .. E (TYPE_UBOX) - Scope: UC/UD<socket><0..1> for UBOX[1-2], ResourceTemplate: UT/UU - */ - for (int i = 0; i < 2; ++i) { - char tres[16]; - /* write _CRS scope */ - if (i == 0) - snprintf(tres, sizeof(tres), "\_SB.UC%d%X", socket, stack); - else - snprintf(tres, sizeof(tres), "\_SB.UD%d%X", socket, stack); - - printk(BIOS_DEBUG, "\tCreating ResourceTemplate %s for socket: %d, stack: %d\n", - tres, socket, stack); - - acpigen_write_scope(tres); - acpigen_write_name("_CRS"); - acpigen_write_resourcetemplate_header(); - - if (!stack_enabled) - acpigen_resource_word(2, 0, 0, 0, 0, 0, 0, 0); - else if (i == 0) - acpigen_resource_word(2, 0xc, 0, 0, ri->BusBase, ri->BusBase, 0x0, 1); - else - acpigen_resource_word(2, 0xc, 0, 0, ri->BusBase + 1, ri->BusBase + 1, - 0x0, 1); - - acpigen_write_resourcetemplate_footer(); - acpigen_pop_len(); - } -} - - /* * Add a DSDT ACPI Name field for STACK enable setting. * This is retrieved by the device _STA defined in iiostack.asl */ -static void create_dsdt_stack_sta(uint8_t socket, uint8_t stack, const STACK_RES *ri, bool stack_enabled) +static void create_dsdt_stack_sta(uint8_t socket, uint8_t stack, bool stack_enabled) { char stack_sta[16]; snprintf(stack_sta, sizeof(stack_sta), "ST%d%X", socket, stack); @@ -375,17 +107,11 @@ __func__, socket, stack, ri->Personality);
if (stack <= IioStack5) { // TYPE_UBOX_IIO - create_dsdt_iou_pci_resource(socket, stack, ri, stack_enabled); - if (is_iio_cxl_stack_res(ri)) - create_dsdt_iou_cxl_resource(socket, stack, ri, - stack_enabled); - create_dsdt_stack_sta(socket, stack, ri, stack_enabled); + create_dsdt_stack_sta(socket, stack, stack_enabled); } else if (stack >= IioStack8 && stack <= IioStack11) { // TYPE_DINO - create_dsdt_ioat_resource(socket, stack, ri, stack_enabled); - create_dsdt_stack_sta(socket, stack, ri, stack_enabled); + create_dsdt_stack_sta(socket, stack, stack_enabled); } else if (stack == IioStack13) { // TYPE_UBOX - create_dsdt_ubox_resource(socket, stack, ri, stack_enabled); - create_dsdt_stack_sta(socket, stack, ri, stack_enabled); + create_dsdt_stack_sta(socket, stack, stack_enabled); } } }
