Attention is currently required from: Jason Glenesk, Martin Roth, Marshall Dawson, Kangheui Won, Julius Werner, Felix Held. Hello build bot (Jenkins), Jason Glenesk, Raul Rangel, Martin Roth, Marshall Dawson, Julius Werner, Felix Held,
https://review.coreboot.org/c/coreboot/+/54711
Change subject: soc/amd/picasso: fix MCACHE on psp_verstage RO boot ......................................................................
On RW boot path psp_verstage call cbfs_map which calls chain of _cbfs_alloc, cbfs_boot_lookup and cbfs_get_boot_device. Then cbfs_get_boot_device initializes MCACHE which is used later.
However on RO boot path psp_verstage doesn't try to find anything in the CBFS which results RO MCACHE not to be initialized. Add cbfs_get_boot_device(true) to explicitly initialize MCACHE on recovery boot.
BUG=b:177091575 BRANCH=none TEST=build and boot jelboz
Signed-off-by: Kangheui Won khwon@chromium.org Change-Id: I6c4b522fef5a4affd215faa122bdf6b53190cf3d --- M src/soc/amd/common/psp_verstage/psp_verstage.c M src/soc/amd/picasso/Kconfig 2 files changed, 10 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/11/54711/5
