Paul Ma has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/41161 )
Change subject: mb/google/kukui: add dsi flag MIPI_DSI_MODE_EOT_PACKET for anx7625 ......................................................................
MIPI_DSI_MODE_EOT_PACKET is required for anx7625 to work correctly.
BUG=b:144824303 TEST=boot damu board, edp panel with anx7625 as bridge boot up normally.
Signed-off-by: Paul Ma magf@bitland.corp-partner.google.com Change-Id: Iad651202bde2a40024af8c12153143ada2ce2439 --- M src/mainboard/google/kukui/mainboard.c 1 file changed, 2 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/61/41161/1
diff --git a/src/mainboard/google/kukui/mainboard.c b/src/mainboard/google/kukui/mainboard.c index bb36d90..efcd49e 100644 --- a/src/mainboard/google/kukui/mainboard.c +++ b/src/mainboard/google/kukui/mainboard.c @@ -154,6 +154,8 @@ u32 mipi_dsi_flags = (MIPI_DSI_MODE_VIDEO | MIPI_DSI_MODE_VIDEO_SYNC_PULSE | MIPI_DSI_MODE_LPM); + if (CONFIG(DRIVER_ANALOGIX_ANX7625)) + mipi_dsi_flags |= MIPI_DSI_MODE_EOT_PACKET; if (mtk_dsi_init(mipi_dsi_flags, MIPI_DSI_FMT_RGB888, 4, edid, panel->s->init) < 0) { printk(BIOS_ERR, "%s: Failed in DSI init.\n", __func__);
Paul Ma has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/41161 )
Patch Set 1:
Add MIPI_DSI_MODE_EOT_PACKET flag for anx7625 as kernel does. Please help review, this CL help to fix 12" panel scrolling issue. thanks,
Hung-Te Lin has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/41161 )
Patch Set 1:
(3 comments)
https://review.coreboot.org/c/coreboot/+/41161/1//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/41161/1//COMMIT_MSG@7 PS1, Line 7: add dsi flag MIPI_DSI_MODE_EOT_PACKET for anx7625 Please explain what you're fixing instead of 'how' here.
For example "fix screen scrolling on devices using anx7625" (not sure if this is the right issue you've fixed by this flag)
https://review.coreboot.org/c/coreboot/+/41161/1//COMMIT_MSG@9 PS1, Line 9: work correctly maybe you can explain what may happen if the flag isn't set.
https://review.coreboot.org/c/coreboot/+/41161/1//COMMIT_MSG@11 PS1, Line 11: BUG Please add BRANCH=kukui so we'll know this should be cherry-picked into fw branch
Patch Set 1:
if you have an equivalent change in kernel side, please also include that reference in commit message.
Hello Hung-Te Lin, build bot (Jenkins), Jitao Shi, Yu-Ping Wu,
Change subject: mb/google/kukui: fix screen scrolling on devices using anx7625 ......................................................................
anx7625 enable MIPI receiver to check EOTP packet as default. If MIPI_DSI_MODE_EOT_PACKET not set in flags, soc dsi will not send out EOTP packet and some panels will display abnormal such as scrolling.
BUG=b:144824303 BRANCH=kukui TEST=boot damu board, edp panel with anx7625 as bridge boot up normally.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/61/41161/2
Patch Set 2:
(3 comments)
Patch Set 1:
Kernel has had this flags set already, no kernel change this time.
Please explain what you're fixing instead of 'how' here. […]
Done
Done
Done
Paul Menzel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/41161 )
Patch Set 2:
(5 comments)
https://review.coreboot.org/c/coreboot/+/41161/2//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/41161/2//COMMIT_MSG@9 PS2, Line 9: enable enables
https://review.coreboot.org/c/coreboot/+/41161/2//COMMIT_MSG@10 PS2, Line 10: not set is not set
https://review.coreboot.org/c/coreboot/+/41161/2//COMMIT_MSG@11 PS2, Line 11: some panels Is that random, or certain production batches?
Is that a board design limitation? If it’s a general problem, can’t it be fixed in the driver, and not on a mainboard basis?
https://review.coreboot.org/c/coreboot/+/41161/2//COMMIT_MSG@12 PS2, Line 12: as scrolling. Only during boot-up, or the whole time, that means when the OS is running?
https://review.coreboot.org/c/coreboot/+/41161/2//COMMIT_MSG@16 PS2, Line 16: boot boots
anx7625 enables MIPI receiver to check EOTP packet as default. If MIPI_DSI_MODE_EOT_PACKET is not set in flags, soc dsi will not send out EOTP packet and some panel models will display abnormal such as scrolling all the time.
BUG=b:144824303 BRANCH=kukui TEST=boot damu board, edp panel with anx7625 as bridge boots up without scrolling.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/61/41161/3
Patch Set 3:
(5 comments)
enables
Done
is not set
Done
Is that random, or certain production batches? […]
Some panel model will have this issue. Some kukui derived projects such as tablets do not use anx7625 as bridge. projects derived from jacuzzi use anx7625 and all these project will define DRIVER_ANALOGIX_ANX7625, so referring to it should be OK.
The whole time display will abnormal (scrolling), even in the process of OS booting and OS UI.
boots
Done
Yu-Ping Wu has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/41161 )
Patch Set 3: Code-Review+1
Patch Set 3: Code-Review+2
Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/41161 )
Signed-off-by: Paul Ma magf@bitland.corp-partner.google.com Change-Id: Iad651202bde2a40024af8c12153143ada2ce2439 Reviewed-on: https://review.coreboot.org/c/coreboot/+/41161 Reviewed-by: Yu-Ping Wu yupingso@google.com Reviewed-by: Hung-Te Lin hungte@chromium.org Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/mainboard/google/kukui/mainboard.c 1 file changed, 2 insertions(+), 0 deletions(-)
Approvals: build bot (Jenkins): Verified Hung-Te Lin: Looks good to me, approved Yu-Ping Wu: Looks good to me, but someone else must approve
