Aaron Durbin (adurbin@chromium.org) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/13475
commit 490d26b67de224c5a7e3e4734e0f34e7d94480c4 Author: Aaron Durbin adurbin@chromium.org Date: Tue Jan 26 15:35:34 2016 -0600
util/cbfstool: add machine parseable print
In order to more easily process the output of 'cbfstool print' with other tools provide a -k option which spits out the tab-separated header and fields:
Name Offset Type Metadata Size Data Size Total Size
ALIGN_UP(Offset + Total Size, 64) would be the start of the next entry. Also, one can analzye the overhead and offsets of each file more easily.
Example output (note: tabs aren't in here):
$ ./coreboot-builds/sharedutils/cbfstool/cbfstool test.serial.bin print -r FW_MAIN_A -k Performing operation on 'FW_MAIN_A' region... Name Offset Type Metadata Size Data Size Total Size cmos_layout.bin 0x0 cmos_layout 0x38 0x48c 0x4c4 dmic-2ch-48khz-16b.bin 0x500 raw 0x48 0xb68 0xbb0 dmic-2ch-48khz-32b.bin 0x10c0 raw 0x48 0xb68 0xbb0 nau88l25-2ch-48khz-24b.bin 0x1c80 raw 0x48 0x54 0x9c ssm4567-render-2ch-48khz-24b.bin 0x1d40 raw 0x58 0x54 0xac ssm4567-capture-4ch-48khz-32b.bin 0x1e00 raw 0x58 0x54 0xac vbt.bin 0x1ec0 optionrom 0x38 0x1000 0x1038 spd.bin 0x2f00 spd 0x38 0x600 0x638 config 0x3540 raw 0x38 0x1ab7 0x1aef revision 0x5040 raw 0x38 0x25e 0x296 font.bin 0x5300 raw 0x38 0x77f 0x7b7 vbgfx.bin 0x5ac0 raw 0x38 0x32f8 0x3330 locales 0x8e00 raw 0x28 0x2 0x2a locale_en.bin 0x8e40 raw 0x38 0x29f6 0x2a2e u-boot.dtb 0xb880 mrc_cache 0x38 0xff1 0x1029 (empty) 0xc8c0 null 0x64 0xadf4 0xae58 fallback/ramstage 0x17740 stage 0x38 0x15245 0x1527d (empty) 0x2c9c0 null 0x64 0xd324 0xd388 fallback/payload 0x39d80 payload 0x38 0x12245 0x1227d cpu_microcode_blob.bin 0x4c000 microcode 0x60 0x17000 0x17060 (empty) 0x63080 null 0x28 0x37cf18 0x37cf40
Change-Id: I1c5f8c1b5f2f980033d6c954c9840299c6268431 Signed-off-by: Aaron Durbin adurbin@chromium.org --- util/cbfstool/cbfs_image.c | 55 ++++++++++++++++++++++++++++++++++++++++++++++ util/cbfstool/cbfs_image.h | 1 + util/cbfstool/cbfstool.c | 13 ++++++++--- 3 files changed, 66 insertions(+), 3 deletions(-)
diff --git a/util/cbfstool/cbfs_image.c b/util/cbfstool/cbfs_image.c index 2d7a6f0..8425095 100644 --- a/util/cbfstool/cbfs_image.c +++ b/util/cbfstool/cbfs_image.c @@ -1075,6 +1075,41 @@ int cbfs_print_entry_info(struct cbfs_image *image, struct cbfs_file *entry, return 0; }
+static int cbfs_print_parseable_entry_info(struct cbfs_image *image, + struct cbfs_file *entry, void *arg) +{ + FILE *fp = (FILE *)arg; + const char *name; + const char *type; + size_t offset; + size_t metadata_size; + size_t data_size; + const char *sep = "\t"; + + if (!cbfs_is_valid_entry(image, entry)) { + ERROR("cbfs_print_entry_info: Invalid entry at 0x%x\n", + cbfs_get_entry_addr(image, entry)); + return -1; + } + + name = entry->filename; + if (*name == '\0') + name = "(empty)"; + type = get_cbfs_entry_type_name(ntohl(entry->type)), + metadata_size = ntohl(entry->offset); + data_size = ntohl(entry->len); + offset = cbfs_get_entry_addr(image, entry); + + fprintf(fp, "%s%s", name, sep); + fprintf(fp, "0x%zx%s", offset, sep); + fprintf(fp, "%s%s", type, sep); + fprintf(fp, "0x%zx%s", metadata_size, sep); + fprintf(fp, "0x%zx%s", data_size, sep); + fprintf(fp, "0x%zx\n", metadata_size + data_size); + + return 0; +} + int cbfs_print_directory(struct cbfs_image *image) { if (cbfs_is_legacy_cbfs(image)) @@ -1084,6 +1119,26 @@ int cbfs_print_directory(struct cbfs_image *image) return 0; }
+int cbfs_print_parseable_directory(struct cbfs_image *image) +{ + int i; + const char *header[] = { + "Name", + "Offset", + "Type", + "Metadata Size", + "Data Size", + "Total Size", + }; + const char *sep = "\t"; + + for (i = 0; i < ARRAY_SIZE(header); i++) + fprintf(stdout, "%s%s", header[i], sep); + fprintf(stdout, "\n"); + cbfs_walk(image, cbfs_print_parseable_entry_info, stdout); + return 0; +} + int cbfs_merge_empty_entry(struct cbfs_image *image, struct cbfs_file *entry, unused void *arg) { diff --git a/util/cbfstool/cbfs_image.h b/util/cbfstool/cbfs_image.h index 00adcc8..38510d2 100644 --- a/util/cbfstool/cbfs_image.h +++ b/util/cbfstool/cbfs_image.h @@ -158,6 +158,7 @@ int cbfs_is_valid_entry(struct cbfs_image *image, struct cbfs_file *entry);
/* Print CBFS component information. */ int cbfs_print_directory(struct cbfs_image *image); +int cbfs_print_parseable_directory(struct cbfs_image *image); int cbfs_print_header_info(struct cbfs_image *image); int cbfs_print_entry_info(struct cbfs_image *image, struct cbfs_file *entry, void *arg); diff --git a/util/cbfstool/cbfstool.c b/util/cbfstool/cbfstool.c index 23787d8..13a9956 100644 --- a/util/cbfstool/cbfstool.c +++ b/util/cbfstool/cbfstool.c @@ -75,6 +75,7 @@ static struct param { bool show_immutable; bool stage_xip; bool autogen_attr; + bool machine_parseable; int fit_empty_entries; enum comp_algo compression; enum vb2_hash_algorithm hash; @@ -838,8 +839,10 @@ static int cbfs_print(void) if (cbfs_image_from_buffer(&image, param.image_region, param.headeroffset)) return 1; - cbfs_print_directory(&image); - return 0; + if (param.machine_parseable) + return cbfs_print_parseable_directory(&image); + else + return cbfs_print_directory(&image); }
/* Forward declared so there aren't type collisions with cbfstool proper @@ -1066,7 +1069,7 @@ static const struct command commands[] = { {"hashcbfs", "r:R:A:vh?", cbfs_hash, true, true}, {"extract", "H:r:m:n:f:vh?", cbfs_extract, true, false}, {"layout", "wvh?", cbfs_layout, false, false}, - {"print", "H:r:vh?", cbfs_print, true, false}, + {"print", "H:r:vkh?", cbfs_print, true, false}, {"read", "r:f:vh?", cbfs_read, true, false}, {"remove", "H:r:n:vh?", cbfs_remove, true, true}, {"update-fit", "H:r:n:x:vh?", cbfs_update_fit, true, true}, @@ -1105,6 +1108,7 @@ static struct option long_options[] = { {"with-readonly", no_argument, 0, 'w' }, {"xip", no_argument, 0, 'y' }, {"gen-attribute", no_argument, 0, 'g' }, + {"mach-parseable",no_argument, 0, 'k' }, {NULL, 0, 0, 0 } };
@@ -1407,6 +1411,9 @@ int main(int argc, char **argv) case 'g': param.autogen_attr = true; break; + case 'k': + param.machine_parseable = true; + break; case 'h': case '?': usage(argv[0]);
