Nico Huber has uploaded this change for review. ( https://review.coreboot.org/27058
Change subject: gfx_test: Use GMA.Read_GTT() instead of own GTT mapping ......................................................................
Change-Id: Iabf26cebc91ccf62711a9a83a68b6ffd2182e3fe Signed-off-by: Nico Huber nico.h@gmx.de --- M gfxtest/hw-gfx-gma-gfx_test.adb 1 file changed, 7 insertions(+), 18 deletions(-)
git pull ssh://review.coreboot.org:29418/libgfxinit refs/changes/58/27058/1
diff --git a/gfxtest/hw-gfx-gma-gfx_test.adb b/gfxtest/hw-gfx-gma-gfx_test.adb index 6839dc3..736b93d 100644 --- a/gfxtest/hw-gfx-gma-gfx_test.adb +++ b/gfxtest/hw-gfx-gma-gfx_test.adb @@ -28,21 +28,17 @@
package Dev is new PCI.Dev (PCI.Address'(0, 2, 0));
- type GTT_PTE_Type is mod 2 ** (Config.GTT_PTE_Size * 8); - type GTT_Registers_Type is array (GTT_Range) of GTT_PTE_Type; - package GTT is new MMIO_Range - (Base_Addr => 0, - Element_T => GTT_PTE_Type, - Index_T => GTT_Range, - Array_T => GTT_Registers_Type); - - GTT_Backup : GTT_Registers_Type; + type GTT_Entry is record + Addr : GTT_Address_Type; + Valid : Boolean; + end record; + GTT_Backup : array (GTT_Range) of GTT_Entry;
procedure Backup_GTT is begin for Idx in GTT_Range loop - GTT.Read (GTT_Backup (Idx), Idx); + Read_GTT (GTT_Backup (Idx).Addr, GTT_Backup (Idx).Valid, Idx); end loop; end Backup_GTT;
@@ -50,7 +46,7 @@ is begin for Idx in GTT_Range loop - GTT.Write (Idx, GTT_Backup (Idx)); + Write_GTT (Idx, GTT_Backup (Idx).Addr, GTT_Backup (Idx).Valid); end loop; end Restore_GTT;
@@ -574,13 +570,6 @@ return; end if;
- Dev.Map (Res_Addr, PCI.Res0, Offset => Config.GTT_Offset); - if Res_Addr = 0 then - Debug.Put_Line ("Failed to map PCI resource0."); - return; - end if; - GTT.Set_Base_Address (Res_Addr); - Dev.Map (Res_Addr, PCI.Res2, WC => True); if Res_Addr = 0 then Debug.Put_Line ("Failed to map PCI resource2.");
