Attention is currently required from: Hung-Te Lin, Yu-Ping Wu.
Hello Hung-Te Lin, Yu-Ping Wu,
https://review.coreboot.org/c/coreboot/+/79990?usp=email
Change subject: soc/mediatek: Add EARLY_INIT_MMU kconfig option ......................................................................
Accessing RAM before mmu initialized is time consuming. During mmu initialization, `mmu_init()` and `mmu_config_range()` write logs to the console buffer and contribue the extra boot time.
This patch adds a kconfig option to move `mtk_mmu_init()` to `bootblock_soc_early_init()`. When `EARLY_INIT_MMU` is enabled, mmu is initialized before `console_init()` ready. So `mmu_init()` and `mmu_config_range()` won't write logs to the console buffer and save the boot time.
It saves about 65ms on Geralt with EARLY_INIT_MMU enabled.
Before: 0:1st timestamp 239,841 (0) 11:start of bootblock 239,920 (79) 12:end of bootblock 323,191 (83,271)
After: 0:1st timestamp 239,804 (0) 11:start of bootblock 239,884 (80) 12:end of bootblock 258,846 (18,962)
BUG=b:320381143 TEST=check timestamps in cbmem
Change-Id: I7f4c3c6c836f7276119698c6de362794cf4222a6 Signed-off-by: Yidi Lin yidilin@chromium.org --- M src/soc/mediatek/common/Kconfig A src/soc/mediatek/common/bootblock.c M src/soc/mediatek/common/mmu_operations.c M src/soc/mediatek/mt8188/Makefile.inc 4 files changed, 24 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/90/79990/2
