Patrick Rudolph has uploaded this change for review. ( https://review.coreboot.org/27104
Change subject: nb/intel/nehalem: Fix DEVEN defines ......................................................................
The DEVEN defines are wrong, but weren't used at all. Fix them as they are needed by the hybrid_graphics_driver and use the defines instead of magic values.
Tested on Lenovo T410: The IGD turns on with the correct value.
Change-Id: Idf9fc0115de5c72f7d5d88cbb09ae1d2fee0afd0 Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com --- M src/northbridge/intel/nehalem/early_init.c M src/northbridge/intel/nehalem/nehalem.h 2 files changed, 5 insertions(+), 5 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/04/27104/1
diff --git a/src/northbridge/intel/nehalem/early_init.c b/src/northbridge/intel/nehalem/early_init.c index 319d81d..1424b91 100644 --- a/src/northbridge/intel/nehalem/early_init.c +++ b/src/northbridge/intel/nehalem/early_init.c @@ -151,7 +151,8 @@ nehalem_setup_bars();
/* Device Enable */ - pci_write_config32(PCI_DEV(0, 0, 0), D0F0_DEVEN, 9 | 2); + pci_write_config32(PCI_DEV(0, 0, 0), D0F0_DEVEN, + DEVEN_IGD | DEVEN_PEG10 | DEVEN_HOST);
early_cpu_init();
diff --git a/src/northbridge/intel/nehalem/nehalem.h b/src/northbridge/intel/nehalem/nehalem.h index 33df32f..bbdd290 100644 --- a/src/northbridge/intel/nehalem/nehalem.h +++ b/src/northbridge/intel/nehalem/nehalem.h @@ -69,11 +69,10 @@ #define D0F0_MCHBAR_HI 0x4c #define D0F0_GGC 0x52 #define D0F0_DEVEN 0x54 +/* Note: Intel's datasheet is broken. Assume the following values are correct */ #define DEVEN_PEG60 (1 << 13) -#define DEVEN_IGD (1 << 4) -#define DEVEN_PEG10 (1 << 3) -#define DEVEN_PEG11 (1 << 2) -#define DEVEN_PEG12 (1 << 1) +#define DEVEN_IGD (1 << 3) +#define DEVEN_PEG10 (1 << 1) #define DEVEN_HOST (1 << 0) #define D0F0_PCIEXBAR_LO 0x60 #define D0F0_PCIEXBAR_HI 0x64
