Andrey Petrov (andrey.petrov@intel.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/14245
commit 13dd34824dc7bc1467c2dc86423a911196f1fc0e Author: Andrey Petrov andrey.petrov@intel.com Date: Mon Apr 4 16:10:40 2016 -0700
soc/intel/apollolake: Reserve IMRs (Isolated Memory Regions)
Certain security features on the platform use IMRs. Unfortunately this memory is unusable for OS or firware. This patch marks IMR regions as unusable.
Change-Id: I4803c41c699a9cb3349de2b7e0910a0a37cf8e59 Signed-off-by: Andrey Petrov andrey.petrov@intel.com --- src/soc/intel/apollolake/include/soc/northbridge.h | 7 ++++ src/soc/intel/apollolake/northbridge.c | 43 +++++++++++++++++++++- 2 files changed, 49 insertions(+), 1 deletion(-)
diff --git a/src/soc/intel/apollolake/include/soc/northbridge.h b/src/soc/intel/apollolake/include/soc/northbridge.h index 4a071cb..b68bc93 100644 --- a/src/soc/intel/apollolake/include/soc/northbridge.h +++ b/src/soc/intel/apollolake/include/soc/northbridge.h @@ -23,4 +23,11 @@ #define TOLUD 0xbc /* Top of Low Used Memory */ #define TOUUD 0xa8 /* Top of Upper Usable DRAM */
+/* IMR registers are found under MCHBAR. */ +#define MCHBAR_IMR0BASE 0x6870 +#define MCHBAR_IMR0MASK 0x6874 +#define MCH_IMR_PITCH 0x20 +#define MCH_NUM_IMRS 20 + + #endif /* _SOC_APOLLOLAKE_NORTHBRIDGE_H_ */ diff --git a/src/soc/intel/apollolake/northbridge.c b/src/soc/intel/apollolake/northbridge.c index 35c36c8..15ff541 100644 --- a/src/soc/intel/apollolake/northbridge.c +++ b/src/soc/intel/apollolake/northbridge.c @@ -41,6 +41,43 @@ static int mc_add_fixed_mmio_resources(device_t dev, int index) return index; }
+static bool is_imr_enabled(uint32_t imr_base_reg) +{ + return !!(imr_base_reg & (1 << 31)); +} + +static void imr_resource(device_t dev, int idx, uint32_t base, uint32_t mask) +{ + uint32_t base_k, size_k; + /* Bits 28:0 encode the base address bits 38:10, hence the KiB unit. */ + base_k = (base & 0x0fffffff); + /* Bits 28:0 encode the AND mask used for comparison, in KiB. */ + size_k = ((~mask & 0x0fffffff) + 1); + /* Cacheable, but not usable (reserved). */ + reserved_ram_resource(dev, idx, base_k, size_k); +} + +static int mc_add_imr_resources(device_t dev, int index) +{ + uint8_t *mchbar; + size_t i, imr_offset; + uint32_t base, mask; + + mchbar = (void *)(ALIGN_DOWN(get_bar(dev, MCHBAR), 32*KiB)); + + for (i = 0; i < MCH_NUM_IMRS; i ++) { + imr_offset = i * MCH_IMR_PITCH; + base = read32(mchbar + imr_offset + MCHBAR_IMR0BASE); + mask = read32(mchbar + imr_offset + MCHBAR_IMR0MASK); + + if (is_imr_enabled(base)) { + imr_resource(dev, index++, base, mask); + } + } + + return index; +} +
static int mc_add_dram_resources(device_t dev, int index) { @@ -97,7 +134,11 @@ static void northbridge_read_resources(device_t dev) index = mc_add_fixed_mmio_resources(dev, index);
/* Calculate and add DRAM resources. */ - mc_add_dram_resources(dev, index); + index = mc_add_dram_resources(dev, index); + + /* Add the isolated memory ranges (IMRs). */ + mc_add_imr_resources(dev, index); + }
static struct device_operations northbridge_ops = {
