Stefan Reinauer (stefan.reinauer@coreboot.org) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/12378
commit 090874984469a3ce2469eca2423c8812ebb13958 Author: Stefan Reinauer stefan.reinauer@coreboot.org Date: Tue Nov 10 11:32:33 2015 -0800
[REMOVAL] tyan/s2881
As announced in http://permalink.gmane.org/gmane.linux.bios/81918 I am removing all boards older than 10 years from the tree.
Change-Id: Idfec80ce79c906717e679d6576dc94e71da994c9 Signed-off-by: Stefan Reinauer stefan.reinauer@coreboot.org --- src/mainboard/tyan/s2881/Kconfig | 52 ------- src/mainboard/tyan/s2881/Kconfig.name | 2 - src/mainboard/tyan/s2881/board_info.txt | 5 - src/mainboard/tyan/s2881/cmos.layout | 60 -------- src/mainboard/tyan/s2881/devicetree.cb | 129 ---------------- src/mainboard/tyan/s2881/get_bus_conf.c | 114 -------------- src/mainboard/tyan/s2881/irq_tables.c | 101 ------------ src/mainboard/tyan/s2881/mptable.c | 111 -------------- src/mainboard/tyan/s2881/resourcemap.c | 263 -------------------------------- src/mainboard/tyan/s2881/romstage.c | 125 --------------- 10 files changed, 962 deletions(-)
diff --git a/src/mainboard/tyan/s2881/Kconfig b/src/mainboard/tyan/s2881/Kconfig deleted file mode 100644 index de641cd..0000000 --- a/src/mainboard/tyan/s2881/Kconfig +++ /dev/null @@ -1,52 +0,0 @@ -if BOARD_TYAN_S2881 - -config BOARD_SPECIFIC_OPTIONS # dummy - def_bool y - select CPU_AMD_SOCKET_940 - select NORTHBRIDGE_AMD_AMDK8 - select SOUTHBRIDGE_AMD_AMD8131 - select SOUTHBRIDGE_AMD_AMD8111 - select HT_CHAIN_DISTRIBUTE - select SUPERIO_WINBOND_W83627HF - select HAVE_OPTION_TABLE - select HAVE_PIRQ_TABLE - select HAVE_MP_TABLE - select BOARD_ROMSIZE_KB_512 - select SB_HT_CHAIN_UNITID_OFFSET_ONLY - select DRIVERS_SIL_3114 - select QRANK_DIMM_SUPPORT - select DRIVERS_I2C_ADT7463 - -config MAINBOARD_DIR - string - default tyan/s2881 - -config APIC_ID_OFFSET - hex - default 0x0 - -config MAINBOARD_PART_NUMBER - string - default "S2881" - -config MAX_CPUS - int - default 4 - -config MAX_PHYSICAL_CPUS - int - default 2 - -config HT_CHAIN_UNITID_BASE - hex - default 0xa - -config HT_CHAIN_END_UNITID_BASE - hex - default 0x6 - -config IRQ_SLOT_COUNT - int - default 9 - -endif # BOARD_TYAN_S2881 diff --git a/src/mainboard/tyan/s2881/Kconfig.name b/src/mainboard/tyan/s2881/Kconfig.name deleted file mode 100644 index 475323e..0000000 --- a/src/mainboard/tyan/s2881/Kconfig.name +++ /dev/null @@ -1,2 +0,0 @@ -config BOARD_TYAN_S2881 - bool "S2881 (Thunder K8SR)" diff --git a/src/mainboard/tyan/s2881/board_info.txt b/src/mainboard/tyan/s2881/board_info.txt deleted file mode 100644 index 951f4ff..0000000 --- a/src/mainboard/tyan/s2881/board_info.txt +++ /dev/null @@ -1,5 +0,0 @@ -Board name: Thunder K8SR (S2881) -Category: server -Board URL: http://www.tyan.com/archive/products/html/thunderk8sr.html -Flashrom support: y -Release year: 2004 diff --git a/src/mainboard/tyan/s2881/cmos.layout b/src/mainboard/tyan/s2881/cmos.layout deleted file mode 100644 index 4e081ea..0000000 --- a/src/mainboard/tyan/s2881/cmos.layout +++ /dev/null @@ -1,60 +0,0 @@ -entries - -0 384 r 0 reserved_memory -384 1 e 4 boot_option -388 4 r 0 reboot_bits -392 3 e 5 baud_rate -395 1 e 1 hw_scrubber -396 1 e 1 interleave_chip_selects -397 2 e 8 max_mem_clock -399 1 e 2 multi_core -400 1 e 1 power_on_after_fail -412 4 e 6 debug_level -440 4 e 9 slow_cpu -444 1 e 1 nmi -445 1 e 1 iommu -456 1 e 1 ECC_memory -728 256 h 0 user_data -984 16 h 0 check_sum -# Reserve the extended AMD configuration registers -1000 24 r 0 amd_reserved - - - -enumerations - -#ID value text -1 0 Disable -1 1 Enable -2 0 Enable -2 1 Disable -4 0 Fallback -4 1 Normal -5 0 115200 -5 1 57600 -5 2 38400 -5 3 19200 -5 4 9600 -5 5 4800 -5 6 2400 -5 7 1200 -6 6 Notice -6 7 Info -6 8 Debug -6 9 Spew -8 0 DDR400 -8 1 DDR333 -8 2 DDR266 -8 3 DDR200 -9 0 off -9 1 87.5% -9 2 75.0% -9 3 62.5% -9 4 50.0% -9 5 37.5% -9 6 25.0% -9 7 12.5% - -checksums - -checksum 392 983 984 diff --git a/src/mainboard/tyan/s2881/devicetree.cb b/src/mainboard/tyan/s2881/devicetree.cb deleted file mode 100644 index 7d0ed5e..0000000 --- a/src/mainboard/tyan/s2881/devicetree.cb +++ /dev/null @@ -1,129 +0,0 @@ -chip northbridge/amd/amdk8/root_complex - device cpu_cluster 0 on - chip cpu/amd/socket_940 - device lapic 0 on end - end - end - device domain 0 on - subsystemid 0x10f1 0x2881 inherit - chip northbridge/amd/amdk8 - device pci 18.0 on end # link 0 - device pci 18.0 on end # link 1 - device pci 18.0 on # link 2 - chip southbridge/amd/amd8131 - # the on/off keyword is mandatory - device pci 0.0 on - device pci 9.0 on end # Broadcom 5704 - device pci 9.1 on end - device pci a.0 on end # Adaptic - device pci a.1 on end - end - device pci 0.1 on end - device pci 1.0 on end - device pci 1.1 on end - end - chip southbridge/amd/amd8111 - # this "device pci 0.0" is the parent the next one - # PCI bridge - device pci 0.0 on - device pci 0.0 on end - device pci 0.1 on end - device pci 0.2 off end - device pci 1.0 off end - device pci 5.0 on end # SiI - device pci 6.0 on end - end - device pci 1.0 on - chip superio/winbond/w83627hf - device pnp 2e.0 on # Floppy - io 0x60 = 0x3f0 - irq 0x70 = 6 - drq 0x74 = 2 - end - device pnp 2e.1 off # Parallel Port - io 0x60 = 0x378 - irq 0x70 = 7 - end - device pnp 2e.2 on # Com1 - io 0x60 = 0x3f8 - irq 0x70 = 4 - end - device pnp 2e.3 off # Com2 - io 0x60 = 0x2f8 - irq 0x70 = 3 - end - device pnp 2e.5 on # Keyboard - io 0x60 = 0x60 - io 0x62 = 0x64 - irq 0x70 = 1 - irq 0x72 = 12 - end - device pnp 2e.6 off # CIR - io 0x60 = 0x100 - end - device pnp 2e.7 off # GAME_MIDI_GIPO1 - io 0x60 = 0x220 - io 0x62 = 0x300 - irq 0x70 = 9 - end - device pnp 2e.8 off end # GPIO2 - device pnp 2e.9 off end # GPIO3 - device pnp 2e.a off end # ACPI - device pnp 2e.b on # HW Monitor - io 0x60 = 0x290 - irq 0x70 = 5 - end - end - end - device pci 1.1 on end - device pci 1.2 on end - device pci 1.3 on - chip drivers/generic/generic #dimm 0-0-0 - device i2c 50 on end - end - chip drivers/generic/generic #dimm 0-0-1 - device i2c 51 on end - end - chip drivers/generic/generic #dimm 0-1-0 - device i2c 52 on end - end - chip drivers/generic/generic #dimm 0-1-1 - device i2c 53 on end - end - chip drivers/generic/generic #dimm 1-0-0 - device i2c 54 on end - end - chip drivers/generic/generic #dimm 1-0-1 - device i2c 55 on end - end - chip drivers/generic/generic #dimm 1-1-0 - device i2c 56 on end - end - chip drivers/generic/generic #dimm 1-1-1 - device i2c 57 on end - end - chip drivers/i2c/adt7463 # CPU0/1 temp, CPU1 vid, SYS FAN 1/2/3 - device i2c 2d on end - end - chip drivers/generic/generic # Winbond HWM 0x54 CPU0/1 VRM temp, SYSFAN 4,CPU0 vid, CPU0/1 FAN - device i2c 2a on end - end - chip drivers/generic/generic # Winbond HWM 0x92 - device i2c 49 on end - end - chip drivers/generic/generic # Winbond HWM 0x94 - device i2c 4a on end - end - end # acpi - device pci 1.5 off end - device pci 1.6 off end - register "ide0_enable" = "1" - register "ide1_enable" = "1" - end - end # device pci 18.0 - device pci 18.1 on end - device pci 18.2 on end - device pci 18.3 on end - end - end -end diff --git a/src/mainboard/tyan/s2881/get_bus_conf.c b/src/mainboard/tyan/s2881/get_bus_conf.c deleted file mode 100644 index 5bedef6..0000000 --- a/src/mainboard/tyan/s2881/get_bus_conf.c +++ /dev/null @@ -1,114 +0,0 @@ -#include <console/console.h> -#include <device/pci.h> -#include <device/pci_ids.h> -#include <string.h> -#include <stdint.h> -#include <cpu/amd/multicore.h> - -#include <cpu/amd/amdk8_sysconf.h> -#include <stdlib.h> - -// Global variables for MB layouts and these will be shared by irqtable mptable and acpi_tables -//busnum is default -unsigned char bus_8131_0 = 1; -unsigned char bus_8131_1 = 2; -unsigned char bus_8131_2 = 3; -unsigned char bus_8111_0 = 1; -unsigned char bus_8111_1 = 4; -unsigned apicid_8111; -unsigned apicid_8131_1; -unsigned apicid_8131_2; - -unsigned pci1234x[] = { //Here you only need to set value in pci1234 for HT-IO that could be installed or not - //You may need to preset pci1234 for HTIO board, please refer to src/northbridge/amd/amdk8/get_sblk_pci1234.c for detail - 0x0000ff0, -// 0x0000ff0, -// 0x0000ff0, -// 0x0000ff0, -// 0x0000ff0, -// 0x0000ff0, -// 0x0000ff0, -// 0x0000ff0 -}; - -unsigned hcdnx[] = { //HT Chain device num, actually it is unit id base of every ht device in chain, assume every chain only have 4 ht device at most - 0x20202020, -// 0x20202020, -// 0x20202020, -// 0x20202020, -// 0x20202020, -// 0x20202020, -// 0x20202020, -// 0x20202020, -}; - -unsigned sbdn3; - -static unsigned get_bus_conf_done = 0; - -void get_bus_conf(void) -{ - - unsigned apicid_base; - - device_t dev; - int i; - - if (get_bus_conf_done == 1) - return; //do it only once - - get_bus_conf_done = 1; - - sysconf.hc_possible_num = ARRAY_SIZE(pci1234x); - for (i = 0; i < sysconf.hc_possible_num; i++) { - sysconf.pci1234[i] = pci1234x[i]; - sysconf.hcdn[i] = hcdnx[i]; - } - - get_sblk_pci1234(); - - sysconf.sbdn = (sysconf.hcdn[0] >> 8) & 0xff; - sbdn3 = sysconf.hcdn[0] & 0xff; - - bus_8131_0 = (sysconf.pci1234[0] >> 16) & 0xff; - bus_8111_0 = bus_8131_0; - - /* 8111 */ - dev = dev_find_slot(bus_8111_0, PCI_DEVFN(sysconf.sbdn, 0)); - if (dev) { - bus_8111_1 = pci_read_config8(dev, PCI_SECONDARY_BUS); - } else { - printk(BIOS_DEBUG, - "ERROR - could not find PCI %02x:03.0, using defaults\n", - bus_8111_0); - } - - /* 8131-1 */ - dev = dev_find_slot(bus_8131_0, PCI_DEVFN(sbdn3, 0)); - if (dev) { - bus_8131_1 = pci_read_config8(dev, PCI_SECONDARY_BUS); - } else { - printk(BIOS_DEBUG, - "ERROR - could not find PCI %02x:01.0, using defaults\n", - bus_8131_0); - } - - /* 8132-2 */ - dev = dev_find_slot(bus_8131_0, PCI_DEVFN(sbdn3 + 1, 0)); - if (dev) { - bus_8131_2 = pci_read_config8(dev, PCI_SECONDARY_BUS); - } else { - printk(BIOS_DEBUG, - "ERROR - could not find PCI %02x:02.0, using defaults\n", - bus_8131_0); - } - -/*I/O APICs: APIC ID Version State Address*/ - if (IS_ENABLED(CONFIG_LOGICAL_CPUS)) - apicid_base = get_apicid_base(3); - else - apicid_base = CONFIG_MAX_PHYSICAL_CPUS; - apicid_8111 = apicid_base + 0; - apicid_8131_1 = apicid_base + 1; - apicid_8131_2 = apicid_base + 2; -} diff --git a/src/mainboard/tyan/s2881/irq_tables.c b/src/mainboard/tyan/s2881/irq_tables.c deleted file mode 100644 index 6a45658..0000000 --- a/src/mainboard/tyan/s2881/irq_tables.c +++ /dev/null @@ -1,101 +0,0 @@ -#include <console/console.h> -#include <device/pci.h> -#include <string.h> -#include <stdint.h> -#include <arch/pirq_routing.h> - -#include <cpu/amd/amdk8_sysconf.h> - -static void write_pirq_info(struct irq_info *pirq_info, uint8_t bus, uint8_t devfn, uint8_t link0, uint16_t bitmap0, - uint8_t link1, uint16_t bitmap1, uint8_t link2, uint16_t bitmap2,uint8_t link3, uint16_t bitmap3, - uint8_t slot, uint8_t rfu) -{ - pirq_info->bus = bus; - pirq_info->devfn = devfn; - pirq_info->irq[0].link = link0; - pirq_info->irq[0].bitmap = bitmap0; - pirq_info->irq[1].link = link1; - pirq_info->irq[1].bitmap = bitmap1; - pirq_info->irq[2].link = link2; - pirq_info->irq[2].bitmap = bitmap2; - pirq_info->irq[3].link = link3; - pirq_info->irq[3].bitmap = bitmap3; - pirq_info->slot = slot; - pirq_info->rfu = rfu; -} - -extern unsigned char bus_8131_0; -extern unsigned char bus_8131_1; -extern unsigned char bus_8131_2; -extern unsigned char bus_8111_0; -extern unsigned char bus_8111_1; - -extern unsigned sbdn3; - - - -unsigned long write_pirq_routing_table(unsigned long addr) -{ - - struct irq_routing_table *pirq; - struct irq_info *pirq_info; - unsigned slot_num; - uint8_t *v; - - uint8_t sum=0; - int i; - - get_bus_conf(); // it will find out all bus num and apic that share with mptable.c and mptable.c and acpi_tables.c - - /* Align the table to be 16 byte aligned. */ - addr += 15; - addr &= ~15; - - /* This table must be between 0xf0000 & 0x100000 */ - printk(BIOS_INFO, "Writing IRQ routing tables to 0x%lx...", addr); - - pirq = (void *)(addr); - v = (uint8_t *)(addr); - - pirq->signature = PIRQ_SIGNATURE; - pirq->version = PIRQ_VERSION; - - pirq->rtr_bus = bus_8111_0; - pirq->rtr_devfn = ((sysconf.sbdn+1)<<3)|0; - - pirq->exclusive_irqs = 0; - - pirq->rtr_vendor = 0x1022; - pirq->rtr_device = 0x746b; - - pirq->miniport_data = 0; - - memset(pirq->rfu, 0, sizeof(pirq->rfu)); - - pirq_info = (void *) ( &pirq->checksum + 1); - slot_num = 0; -//pci bridge - write_pirq_info(pirq_info, bus_8111_0, ((sysconf.sbdn+1)<<3)|0, 0x1, 0xdef8, 0x2, 0xdef8, 0x3, 0xdef8, 0x4, 0xdef8, 0, 0); - pirq_info++; slot_num++; -//pcix bridge -// write_pirq_info(pirq_info, bus_8131_0, (sbdn3<<3)|0, 0x1, 0xdef8, 0x2, 0xdef8, 0x3, 0xdef8, 0x4, 0xdef8, 0, 0); -// pirq_info++; slot_num++; - - pirq_info++; slot_num++; - - pirq->size = 32 + 16 * slot_num; - - for (i = 0; i < pirq->size; i++) - sum += v[i]; - - sum = pirq->checksum - sum; - - if (sum != pirq->checksum) { - pirq->checksum = sum; - } - - printk(BIOS_INFO, "done.\n"); - - return (unsigned long) pirq_info; - -} diff --git a/src/mainboard/tyan/s2881/mptable.c b/src/mainboard/tyan/s2881/mptable.c deleted file mode 100644 index 8948b7c..0000000 --- a/src/mainboard/tyan/s2881/mptable.c +++ /dev/null @@ -1,111 +0,0 @@ -#include <console/console.h> -#include <arch/smp/mpspec.h> -#include <arch/ioapic.h> -#include <device/pci.h> -#include <string.h> -#include <stdint.h> -#include <cpu/amd/amdk8_sysconf.h> - -extern unsigned char bus_8131_0; -extern unsigned char bus_8131_1; -extern unsigned char bus_8131_2; -extern unsigned char bus_8111_0; -extern unsigned char bus_8111_1; -extern unsigned apicid_8111; -extern unsigned apicid_8131_1; -extern unsigned apicid_8131_2; - -extern unsigned sbdn3; - -static void *smp_write_config_table(void *v) -{ - struct mp_config_table *mc; - int i, bus_isa; - - mc = (void *)(((char *)v) + SMP_FLOATING_TABLE_LEN); - - mptable_init(mc, LOCAL_APIC_ADDR); - - smp_write_processors(mc); - - get_bus_conf(); - - mptable_write_buses(mc, NULL, &bus_isa); - -/*I/O APICs: APIC ID Version State Address*/ - smp_write_ioapic(mc, apicid_8111, 0x11, VIO_APIC_VADDR); - { - device_t dev; - struct resource *res; - dev = dev_find_slot(bus_8131_0, PCI_DEVFN(sbdn3,1)); - if (dev) { - res = find_resource(dev, PCI_BASE_ADDRESS_0); - if (res) { - smp_write_ioapic(mc, apicid_8131_1, 0x11, - res2mmio(res, 0, 0)); - } - } - dev = dev_find_slot(bus_8131_0, PCI_DEVFN(sbdn3+1,1)); - if (dev) { - res = find_resource(dev, PCI_BASE_ADDRESS_0); - if (res) { - smp_write_ioapic(mc, apicid_8131_2, 0x11, - res2mmio(res, 0, 0)); - } - } - - } - - mptable_add_isa_interrupts(mc, bus_isa, apicid_8111, 0); - -/*I/O Ints: Type Polarity Trigger Bus ID IRQ APIC ID PIN# */ -//8111 LPC ???? - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8111_0, ((sysconf.sbdn+1)<<2)|0, apicid_8111, 0x13); - -//On Board AMD USB ??? - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8111_1, (0<<2)|3, apicid_8111, 0x13); - -//On Board ATI Display Adapter - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8111_1, (6<<2)|0, apicid_8111, 0x12); - -//On Board SI Serial ATA - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8111_1, (5<<2)|0, apicid_8111, 0x11); - -//Slot 3 PCIX 100/66 - for(i=0;i<4;i++) { - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8131_1, (8<<2)|i, apicid_8131_1, (3+i)%4); //27 - } - -//On Board NIC and adaptec scsi - for(i=0;i<2;i++) { - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8131_1, (9<<2)|i, apicid_8131_1, (0+i)%4); //24 - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8131_1, (0xa<<2)|i, apicid_8131_1, (0+i)%4); //24 - } - -//Slot 1 PCI-X 133/100/66 or Side 1 on raiser card - for(i=0;i<4;i++) { - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8131_2, (3<<2)|i, apicid_8131_2, (0+i)%4); //28 - } - - //Slot 1 PCI-X 133/100/66, Side 2 on raiser card - //Fix ME, IRQ Pins? - for(i=0;i<4;i++) { - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8131_2, (4<<2)|i, apicid_8131_2, (1+i)%4); //28 - } - - - -/*Local Ints: Type Polarity Trigger Bus ID IRQ APIC ID PIN#*/ - mptable_lintsrc(mc, bus_isa); - /* There is no extension information... */ - - /* Compute the checksums */ - return mptable_finalize(mc); -} - -unsigned long write_smp_table(unsigned long addr) -{ - void *v; - v = smp_write_floating_table(addr, 0); - return (unsigned long)smp_write_config_table(v); -} diff --git a/src/mainboard/tyan/s2881/resourcemap.c b/src/mainboard/tyan/s2881/resourcemap.c deleted file mode 100644 index c699b59..0000000 --- a/src/mainboard/tyan/s2881/resourcemap.c +++ /dev/null @@ -1,263 +0,0 @@ -/* - * Tyan S2881 needs a different resource map - * - */ - -static void setup_s2881_resource_map(void) -{ - static const unsigned int register_values[] = { - /* Careful set limit registers before base registers which contain the enables */ - /* DRAM Limit i Registers - * F1:0x44 i = 0 - * F1:0x4C i = 1 - * F1:0x54 i = 2 - * F1:0x5C i = 3 - * F1:0x64 i = 4 - * F1:0x6C i = 5 - * F1:0x74 i = 6 - * F1:0x7C i = 7 - * [ 2: 0] Destination Node ID - * 000 = Node 0 - * 001 = Node 1 - * 010 = Node 2 - * 011 = Node 3 - * 100 = Node 4 - * 101 = Node 5 - * 110 = Node 6 - * 111 = Node 7 - * [ 7: 3] Reserved - * [10: 8] Interleave select - * specifies the values of A[14:12] to use with interleave enable. - * [15:11] Reserved - * [31:16] DRAM Limit Address i Bits 39-24 - * This field defines the upper address bits of a 40 bit address - * that define the end of the DRAM region. - */ - PCI_ADDR(0, 0x18, 1, 0x44), 0x0000f8f8, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0x4C), 0x0000f8f8, 0x00000001, - PCI_ADDR(0, 0x18, 1, 0x54), 0x0000f8f8, 0x00000002, - PCI_ADDR(0, 0x18, 1, 0x5C), 0x0000f8f8, 0x00000003, - PCI_ADDR(0, 0x18, 1, 0x64), 0x0000f8f8, 0x00000004, - PCI_ADDR(0, 0x18, 1, 0x6C), 0x0000f8f8, 0x00000005, - PCI_ADDR(0, 0x18, 1, 0x74), 0x0000f8f8, 0x00000006, - PCI_ADDR(0, 0x18, 1, 0x7C), 0x0000f8f8, 0x00000007, - /* DRAM Base i Registers - * F1:0x40 i = 0 - * F1:0x48 i = 1 - * F1:0x50 i = 2 - * F1:0x58 i = 3 - * F1:0x60 i = 4 - * F1:0x68 i = 5 - * F1:0x70 i = 6 - * F1:0x78 i = 7 - * [ 0: 0] Read Enable - * 0 = Reads Disabled - * 1 = Reads Enabled - * [ 1: 1] Write Enable - * 0 = Writes Disabled - * 1 = Writes Enabled - * [ 7: 2] Reserved - * [10: 8] Interleave Enable - * 000 = No interleave - * 001 = Interleave on A[12] (2 nodes) - * 010 = reserved - * 011 = Interleave on A[12] and A[14] (4 nodes) - * 100 = reserved - * 101 = reserved - * 110 = reserved - * 111 = Interleve on A[12] and A[13] and A[14] (8 nodes) - * [15:11] Reserved - * [13:16] DRAM Base Address i Bits 39-24 - * This field defines the upper address bits of a 40-bit address - * that define the start of the DRAM region. - */ - PCI_ADDR(0, 0x18, 1, 0x40), 0x0000f8fc, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0x48), 0x0000f8fc, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0x50), 0x0000f8fc, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0x58), 0x0000f8fc, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0x60), 0x0000f8fc, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0x68), 0x0000f8fc, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0x70), 0x0000f8fc, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0x78), 0x0000f8fc, 0x00000000, - - /* Memory-Mapped I/O Limit i Registers - * F1:0x84 i = 0 - * F1:0x8C i = 1 - * F1:0x94 i = 2 - * F1:0x9C i = 3 - * F1:0xA4 i = 4 - * F1:0xAC i = 5 - * F1:0xB4 i = 6 - * F1:0xBC i = 7 - * [ 2: 0] Destination Node ID - * 000 = Node 0 - * 001 = Node 1 - * 010 = Node 2 - * 011 = Node 3 - * 100 = Node 4 - * 101 = Node 5 - * 110 = Node 6 - * 111 = Node 7 - * [ 3: 3] Reserved - * [ 5: 4] Destination Link ID - * 00 = Link 0 - * 01 = Link 1 - * 10 = Link 2 - * 11 = Reserved - * [ 6: 6] Reserved - * [ 7: 7] Non-Posted - * 0 = CPU writes may be posted - * 1 = CPU writes must be non-posted - * [31: 8] Memory-Mapped I/O Limit Address i (39-16) - * This field defines the upp adddress bits of a 40-bit address that - * defines the end of a memory-mapped I/O region n - */ - PCI_ADDR(0, 0x18, 1, 0x84), 0x00000048, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0x8C), 0x00000048, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0x94), 0x00000048, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0x9C), 0x00000048, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0xA4), 0x00000048, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0xAC), 0x00000048, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0xB4), 0x00000048, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0xBC), 0x00000048, 0x00ffff20, - - /* Memory-Mapped I/O Base i Registers - * F1:0x80 i = 0 - * F1:0x88 i = 1 - * F1:0x90 i = 2 - * F1:0x98 i = 3 - * F1:0xA0 i = 4 - * F1:0xA8 i = 5 - * F1:0xB0 i = 6 - * F1:0xB8 i = 7 - * [ 0: 0] Read Enable - * 0 = Reads disabled - * 1 = Reads Enabled - * [ 1: 1] Write Enable - * 0 = Writes disabled - * 1 = Writes Enabled - * [ 2: 2] Cpu Disable - * 0 = Cpu can use this I/O range - * 1 = Cpu requests do not use this I/O range - * [ 3: 3] Lock - * 0 = base/limit registers i are read/write - * 1 = base/limit registers i are read-only - * [ 7: 4] Reserved - * [31: 8] Memory-Mapped I/O Base Address i (39-16) - * This field defines the upper address bits of a 40bit address - * that defines the start of memory-mapped I/O region i - */ - PCI_ADDR(0, 0x18, 1, 0x80), 0x000000f0, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0x88), 0x000000f0, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0x90), 0x000000f0, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0x98), 0x000000f0, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0xA0), 0x000000f0, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0xA8), 0x000000f0, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0xB0), 0x000000f0, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0xB8), 0x000000f0, 0x00fc0003, - - /* PCI I/O Limit i Registers - * F1:0xC4 i = 0 - * F1:0xCC i = 1 - * F1:0xD4 i = 2 - * F1:0xDC i = 3 - * [ 2: 0] Destination Node ID - * 000 = Node 0 - * 001 = Node 1 - * 010 = Node 2 - * 011 = Node 3 - * 100 = Node 4 - * 101 = Node 5 - * 110 = Node 6 - * 111 = Node 7 - * [ 3: 3] Reserved - * [ 5: 4] Destination Link ID - * 00 = Link 0 - * 01 = Link 1 - * 10 = Link 2 - * 11 = reserved - * [11: 6] Reserved - * [24:12] PCI I/O Limit Address i - * This field defines the end of PCI I/O region n - * [31:25] Reserved - */ - PCI_ADDR(0, 0x18, 1, 0xC4), 0xFE000FC8, 0x01fff020, - PCI_ADDR(0, 0x18, 1, 0xCC), 0xFE000FC8, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0xD4), 0xFE000FC8, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0xDC), 0xFE000FC8, 0x00000000, - - /* PCI I/O Base i Registers - * F1:0xC0 i = 0 - * F1:0xC8 i = 1 - * F1:0xD0 i = 2 - * F1:0xD8 i = 3 - * [ 0: 0] Read Enable - * 0 = Reads Disabled - * 1 = Reads Enabled - * [ 1: 1] Write Enable - * 0 = Writes Disabled - * 1 = Writes Enabled - * [ 3: 2] Reserved - * [ 4: 4] VGA Enable - * 0 = VGA matches Disabled - * 1 = matches all address < 64K and where A[9:0] is in the - * range 3B0-3BB or 3C0-3DF independen of the base & limit registers - * [ 5: 5] ISA Enable - * 0 = ISA matches Disabled - * 1 = Blocks address < 64K and in the last 768 bytes of eack 1K block - * from matching agains this base/limit pair - * [11: 6] Reserved - * [24:12] PCI I/O Base i - * This field defines the start of PCI I/O region n - * [31:25] Reserved - */ - PCI_ADDR(0, 0x18, 1, 0xC0), 0xFE000FCC, 0x00000003, - PCI_ADDR(0, 0x18, 1, 0xC8), 0xFE000FCC, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0xD0), 0xFE000FCC, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0xD8), 0xFE000FCC, 0x00000000, - - /* Config Base and Limit i Registers - * F1:0xE0 i = 0 - * F1:0xE4 i = 1 - * F1:0xE8 i = 2 - * F1:0xEC i = 3 - * [ 0: 0] Read Enable - * 0 = Reads Disabled - * 1 = Reads Enabled - * [ 1: 1] Write Enable - * 0 = Writes Disabled - * 1 = Writes Enabled - * [ 2: 2] Device Number Compare Enable - * 0 = The ranges are based on bus number - * 1 = The ranges are ranges of devices on bus 0 - * [ 3: 3] Reserved - * [ 6: 4] Destination Node - * 000 = Node 0 - * 001 = Node 1 - * 010 = Node 2 - * 011 = Node 3 - * 100 = Node 4 - * 101 = Node 5 - * 110 = Node 6 - * 111 = Node 7 - * [ 7: 7] Reserved - * [ 9: 8] Destination Link - * 00 = Link 0 - * 01 = Link 1 - * 10 = Link 2 - * 11 - Reserved - * [15:10] Reserved - * [23:16] Bus Number Base i - * This field defines the lowest bus number in configuration region i - * [31:24] Bus Number Limit i - * This field defines the highest bus number in configuration regin i - */ -// PCI_ADDR(0, 0x18, 1, 0xE0), 0x0000FC88, 0xff000203, -// PCI_ADDR(0, 0x18, 1, 0xE4), 0x0000FC88, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0xE8), 0x0000FC88, 0x00000000, - PCI_ADDR(0, 0x18, 1, 0xEC), 0x0000FC88, 0x00000000, - }; - int max; - max = ARRAY_SIZE(register_values); - setup_resource_map(register_values, max); -} diff --git a/src/mainboard/tyan/s2881/romstage.c b/src/mainboard/tyan/s2881/romstage.c deleted file mode 100644 index b97ba18..0000000 --- a/src/mainboard/tyan/s2881/romstage.c +++ /dev/null @@ -1,125 +0,0 @@ -#include <stdint.h> -#include <string.h> -#include <device/pci_def.h> -#include <arch/io.h> -#include <device/pnp_def.h> -#include <pc80/mc146818rtc.h> -#include <console/console.h> -#include <lib.h> -#include <spd.h> -#include <cpu/amd/model_fxx_rev.h> -#include "northbridge/amd/amdk8/incoherent_ht.c" -#include "southbridge/amd/amd8111/early_smbus.c" -#include <northbridge/amd/amdk8/raminit.h> -#include <delay.h> -#include "northbridge/amd/amdk8/reset_test.c" -#include "northbridge/amd/amdk8/debug.c" -#include <superio/winbond/common/winbond.h> -#include <superio/winbond/w83627hf/w83627hf.h> -#include <cpu/x86/bist.h> -#include "northbridge/amd/amdk8/setup_resource_map.c" -#include "southbridge/amd/amd8111/early_ctrl.c" - -#define SERIAL_DEV PNP_DEV(0x2e, W83627HF_SP1) - -static void memreset_setup(void) -{ - if (is_cpu_pre_c0()) - outb((1<<2)|(0<<0), SMBUS_IO_BASE + 0xc0 + 16); //REVC_MEMRST_EN=0 - else - outb((1<<2)|(1<<0), SMBUS_IO_BASE + 0xc0 + 16); //REVC_MEMRST_EN=1 - outb((1<<2)|(0<<0), SMBUS_IO_BASE + 0xc0 + 17); -} - -static void memreset(int controllers, const struct mem_controller *ctrl) -{ - if (is_cpu_pre_c0()) { - udelay(800); - outb((1<<2)|(1<<0), SMBUS_IO_BASE + 0xc0 + 17); //REVB_MEMRST_L=1 - udelay(90); - } -} - -static void activate_spd_rom(const struct mem_controller *ctrl) { } - -static inline int spd_read_byte(unsigned device, unsigned address) -{ - return smbus_read_byte(device, address); -} - -#include "northbridge/amd/amdk8/raminit.c" -#include "resourcemap.c" -#include "northbridge/amd/amdk8/coherent_ht.c" -#include "lib/generic_sdram.c" -#include "cpu/amd/dualcore/dualcore.c" -#include "cpu/amd/model_fxx/init_cpus.c" - -void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) -{ - static const uint16_t spd_addr [] = { - DIMM0, DIMM2, 0, 0, - DIMM1, DIMM3, 0, 0, -#if CONFIG_MAX_PHYSICAL_CPUS > 1 - DIMM4, DIMM6, 0, 0, - DIMM5, DIMM7, 0, 0, -#endif - }; - - int needs_reset; - unsigned bsp_apicid = 0, nodes; - struct mem_controller ctrl[8]; - - if (bist == 0) - bsp_apicid = init_cpus(cpu_init_detectedx); - -// post_code(0x32); - - winbond_enable_serial(SERIAL_DEV, CONFIG_TTYS0_BASE); - console_init(); - - /* Halt if there was a built in self test failure */ - report_bist_failure(bist); - - setup_s2881_resource_map(); -#if 0 - dump_pci_device(PCI_DEV(0, 0x18, 0)); - dump_pci_device(PCI_DEV(0, 0x19, 0)); -#endif - - needs_reset = setup_coherent_ht_domain(); - - wait_all_core0_started(); -#if CONFIG_LOGICAL_CPUS - // It is said that we should start core1 after all core0 launched - start_other_cores(); - wait_all_other_cores_started(bsp_apicid); -#endif - - needs_reset |= ht_setup_chains_x(); - - if (needs_reset) { - printk(BIOS_INFO, "ht reset -\n"); - soft_reset(); - } - - enable_smbus(); -#if 0 - dump_spd_registers(&cpu[0]); - dump_smbus_registers(); -#endif - - allow_all_aps_stop(bsp_apicid); - - nodes = get_nodes(); - //It's the time to set ctrl now; - fill_mem_ctrl(nodes, ctrl, spd_addr); - - memreset_setup(); - sdram_initialize(nodes, ctrl); - -#if 0 - dump_pci_devices(); -#endif - - post_cache_as_ram(); -}
