Stefan Reinauer (stefan.reinauer@coreboot.org) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/7856
commit e015bcf5389b7a0dea97d0d31e100bdb22179764 Author: Stefan Reinauer reinauer@chromium.org Date: Mon Jan 5 12:59:54 2015 -0800
northbridge: Drop print_ implementation from non-romcc boards
Because we have no stack on romcc boards, we had a separate, not as powerful clone of printk: print_*. Back in the day, like more than half a decade ago, we migrated a lot of boards to printk, but we never cleaned up the existing code to be consistent. instead, we worked around the problem with a very messy console.h (nowadays the mess is hidden in romstage_console.c and early_print.h) This patch cleans up the northbridge code to use printk() on all non-ROMCC boards.
Change-Id: I4a36cd965c58aae65d74ce1e697dc0d0f58f47a1 Signed-off-by: Stefan Reinauer stefan.reinauer@coreboot.org --- src/northbridge/amd/amdfam10/amdfam10.h | 7 +- src/northbridge/amd/amdfam10/debug.c | 26 ++-- src/northbridge/amd/amdfam10/raminit_amdmct.c | 6 +- src/northbridge/amd/amdfam10/setup_resource_map.c | 20 +-- src/northbridge/amd/amdk8/coherent_ht.c | 32 ++-- src/northbridge/amd/amdk8/debug.c | 22 +-- src/northbridge/amd/amdk8/f.h | 7 +- src/northbridge/amd/amdk8/incoherent_ht.c | 10 +- src/northbridge/amd/amdk8/raminit_test.c | 29 +--- src/northbridge/amd/amdmct/mct/mct_d.c | 2 +- src/northbridge/amd/amdmct/mct/mctdqs_d.c | 14 +- src/northbridge/amd/amdmct/mct/mctsrc.c | 20 +-- src/northbridge/amd/amdmct/mct/mcttmrl.c | 7 +- src/northbridge/amd/amdmct/mct_ddr3/mctdqs_d.c | 14 +- src/northbridge/amd/amdmct/mct_ddr3/mcttmrl.c | 7 +- src/northbridge/amd/gx2/raminit.c | 2 +- src/northbridge/amd/lx/raminit.c | 30 ++-- src/northbridge/dmp/vortex86ex/raminit.c | 12 +- src/northbridge/intel/e7501/debug.c | 135 +++------------- src/northbridge/intel/e7501/raminit.c | 18 +-- src/northbridge/intel/e7505/debug.c | 135 +++------------- src/northbridge/intel/e7505/raminit.c | 18 +-- src/northbridge/intel/i3100/raminit.c | 27 ++-- src/northbridge/intel/i3100/raminit_ep80579.c | 180 ++++++---------------- src/northbridge/intel/i440bx/debug.c | 26 +--- src/northbridge/intel/i440bx/raminit.c | 8 +- src/northbridge/intel/i440lx/raminit.c | 8 +- src/northbridge/intel/i82810/debug.c | 47 ++---- src/northbridge/intel/i855/debug.c | 66 +++----- src/northbridge/intel/i855/raminit.c | 24 +-- src/northbridge/intel/i945/debug.c | 4 +- src/northbridge/via/cn700/raminit.c | 8 +- src/northbridge/via/cn700/vga.c | 2 +- src/northbridge/via/cx700/early_smbus.c | 38 ++--- src/northbridge/via/cx700/raminit.c | 36 ++--- src/northbridge/via/vx800/early_smbus.c | 50 +++--- src/northbridge/via/vx800/raminit.c | 8 +- src/northbridge/via/vx900/chrome9hd.c | 6 +- src/northbridge/via/vx900/early_smbus.c | 6 +- src/northbridge/via/vx900/early_vx900.c | 6 +- src/northbridge/via/vx900/lpc.c | 2 +- src/northbridge/via/vx900/northbridge.c | 12 +- src/northbridge/via/vx900/pcie.c | 4 +- src/northbridge/via/vx900/raminit_ddr3.c | 2 +- src/northbridge/via/vx900/sata.c | 47 +++--- 45 files changed, 387 insertions(+), 803 deletions(-)
diff --git a/src/northbridge/amd/amdfam10/amdfam10.h b/src/northbridge/amd/amdfam10/amdfam10.h index d292306..ab4b42e 100644 --- a/src/northbridge/amd/amdfam10/amdfam10.h +++ b/src/northbridge/amd/amdfam10/amdfam10.h @@ -1147,11 +1147,7 @@ static void wait_all_core0_mem_trained(struct sys_info *sysinfo) }
for(i=0; i<sysinfo->nodes; i++) { -#ifdef __PRE_RAM__ - print_debug("mem_trained["); print_debug_hex8(i); print_debug("]="); print_debug_hex8(sysinfo->mem_trained[i]); print_debug("\n"); -#else printk(BIOS_DEBUG, "mem_trained[%02x]=%02x\n", i, sysinfo->mem_trained[i]); -#endif switch(sysinfo->mem_trained[i]) { case 0: //don't need train case 1: //trained @@ -1164,11 +1160,10 @@ static void wait_all_core0_mem_trained(struct sys_info *sysinfo) } } if(needs_reset) { + printk(BIOS_DEBUG, "mem trained failed\n"); #ifdef __PRE_RAM__ - print_debug("mem trained failed\n"); soft_reset(); #else - printk(BIOS_DEBUG, "mem trained failed\n"); hard_reset(); #endif } diff --git a/src/northbridge/amd/amdfam10/debug.c b/src/northbridge/amd/amdfam10/debug.c index 7d00af7..d1fdaf8 100644 --- a/src/northbridge/amd/amdfam10/debug.c +++ b/src/northbridge/amd/amdfam10/debug.c @@ -108,7 +108,7 @@ static void dump_pci_device_range(u32 dev, u32 start_reg, u32 size) val >>= 8; } } - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); }
static void dump_pci_device(u32 dev) @@ -122,7 +122,7 @@ static void dump_pci_device_index_wait_range(u32 dev, u32 index_reg, u32 start, int i; int end = start + size; print_debug_pci_dev(dev); - print_debug(" -- index_reg="); print_debug_hex32(index_reg); + printk(BIOS_DEBUG, " -- index_reg=%08x", index_reg);
for(i = start; i < end; i++) { u32 val; @@ -135,7 +135,7 @@ static void dump_pci_device_index_wait_range(u32 dev, u32 index_reg, u32 start, }
static inline void dump_pci_device_index_wait(u32 dev, u32 index_reg) @@ -151,7 +151,7 @@ static inline void dump_pci_device_index(u32 dev, u32 index_reg, u32 type, u32 l int i; print_debug_pci_dev(dev);
- print_debug(" index reg: "); print_debug_hex16(index_reg); print_debug(" type: "); print_debug_hex8(type); + printk(BIOS_DEBUG, " index reg: %04x type: %02x", index_reg, type);
type<<=28;
@@ -163,7 +163,7 @@ static inline void dump_pci_device_index(u32 dev, u32 index_reg, u32 type, u32 l val = pci_read_config32_index(dev, index_reg, i|type); printk(BIOS_DEBUG, " %08x", val); } - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); }
static inline void dump_pci_devices(void) @@ -221,7 +221,7 @@ static inline void dump_pci_devices_on_bus(u32 busn) static void dump_spd_registers(const struct mem_controller *ctrl) { int i; - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); for(i = 0; i < DIMM_SOCKETS; i++) { u32 device; device = ctrl->spd_addr[i]; @@ -241,7 +241,7 @@ static void dump_spd_registers(const struct mem_controller *ctrl) byte = status & 0xff; printk(BIOS_DEBUG, "%02x ", byte); } - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); } device = ctrl->spd_addr[i+DIMM_SOCKETS]; if (device) { @@ -260,14 +260,14 @@ static void dump_spd_registers(const struct mem_controller *ctrl) byte = status & 0xff; printk(BIOS_DEBUG, "%02x ", byte); } - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); } } } static void dump_smbus_registers(void) { u32 device; - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); for(device = 1; device < 0x80; device++) { int j; if( smbus_read_byte(device, 0) < 0 ) continue; @@ -285,7 +285,7 @@ static void dump_smbus_registers(void) byte = status & 0xff; printk(BIOS_DEBUG, "%02x ", byte); } - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); } } #endif @@ -303,7 +303,7 @@ static inline void dump_io_resources(u32 port) val = inb(port); printk(BIOS_DEBUG, " %02x",val); if ((i & 0x0f) == 0x0f) { - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); } port++; } @@ -312,12 +312,12 @@ static inline void dump_io_resources(u32 port) static inline void dump_mem(u32 start, u32 end) { u32 i; - print_debug("dump_mem:"); + printk(BIOS_DEBUG, "dump_mem:"); for(i=start;i<end;i++) { if((i & 0xf)==0) { printk(BIOS_DEBUG, "\n%08x:", i); } printk(BIOS_DEBUG, " %02x", (u8)*((u8 *)i)); } - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); } diff --git a/src/northbridge/amd/amdfam10/raminit_amdmct.c b/src/northbridge/amd/amdfam10/raminit_amdmct.c index e5c18a8..6b02209 100644 --- a/src/northbridge/amd/amdfam10/raminit_amdmct.c +++ b/src/northbridge/amd/amdfam10/raminit_amdmct.c @@ -219,7 +219,7 @@ u32 mctGetLogicalCPUID(u32 Node) break; default: /* FIXME: mabe we should die() here. */ - print_err("FIXME! CPU Version unknown or not supported! \n"); + printk(BIOS_ERR, "FIXME! CPU Version unknown or not supported! \n"); ret = 0; }
@@ -237,9 +237,9 @@ static void raminit_amdmct(struct sys_info *sysinfo) struct MCTStatStruc *pMCTstat = &(sysinfo->MCTstat); struct DCTStatStruc *pDCTstatA = sysinfo->DCTstatA;
- print_debug("raminit_amdmct begin:\n"); + printk(BIOS_DEBUG, "raminit_amdmct begin:\n");
mctAutoInitMCT_D(pMCTstat, pDCTstatA);
- print_debug("raminit_amdmct end:\n"); + printk(BIOS_DEBUG, "raminit_amdmct end:\n"); } diff --git a/src/northbridge/amd/amdfam10/setup_resource_map.c b/src/northbridge/amd/amdfam10/setup_resource_map.c index 2eeca44..ca7f964 100644 --- a/src/northbridge/amd/amdfam10/setup_resource_map.c +++ b/src/northbridge/amd/amdfam10/setup_resource_map.c @@ -23,7 +23,7 @@ static void setup_resource_map(const u32 *register_values, u32 max) { u32 i; -// print_debug("setting up resource map...."); +// printk(BIOS_DEBUG, "setting up resource map....");
for(i = 0; i < max; i += 3) { device_t dev; @@ -37,14 +37,14 @@ static void setup_resource_map(const u32 *register_values, u32 max) reg |= register_values[i+2]; pci_write_config32(dev, where, reg); } -// print_debug("done.\n"); +// printk(BIOS_DEBUG, "done.\n"); }
void setup_resource_map_offset(const u32 *register_values, u32 max, u32 offset_pci_dev, u32 offset_io_base) { u32 i; -// print_debug("setting up resource map offset...."); +// printk(BIOS_DEBUG, "setting up resource map offset...."); for(i = 0; i < max; i += 3) { device_t dev; u32 where; @@ -56,7 +56,7 @@ void setup_resource_map_offset(const u32 *register_values, u32 max, u32 offset_p reg |= register_values[i+2] + offset_io_base; pci_write_config32(dev, where, reg); } -// print_debug("done.\n"); +// printk(BIOS_DEBUG, "done.\n"); }
#define RES_PCI_IO 0x10 @@ -69,12 +69,12 @@ void setup_resource_map_x_offset(const u32 *register_values, u32 max, u32 offset u32 i;
#if RES_DEBUG - print_debug("setting up resource map ex offset...."); + printk(BIOS_DEBUG, "setting up resource map ex offset....");
#endif
#if RES_DEBUG - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); #endif for(i = 0; i < max; i += 4) { #if RES_DEBUG @@ -127,7 +127,7 @@ void setup_resource_map_x_offset(const u32 *register_values, u32 max, u32 offset }
#if RES_DEBUG - print_debug("done.\n"); + printk(BIOS_DEBUG, "done.\n"); #endif }
@@ -136,11 +136,11 @@ void setup_resource_map_x(const u32 *register_values, u32 max) u32 i;
#if RES_DEBUG - print_debug("setting up resource map ex offset...."); + printk(BIOS_DEBUG, "setting up resource map ex offset...."); #endif
#if RES_DEBUG - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); #endif for(i = 0; i < max; i += 4) { #if RES_DEBUG @@ -189,7 +189,7 @@ void setup_resource_map_x(const u32 *register_values, u32 max) }
diff --git a/src/northbridge/amd/amdk8/coherent_ht.c b/src/northbridge/amd/amdk8/coherent_ht.c index 8abb31f..a8d8700 100644 --- a/src/northbridge/amd/amdk8/coherent_ht.c +++ b/src/northbridge/amd/amdk8/coherent_ht.c @@ -145,7 +145,7 @@ static void disable_probes(void)
u32 val;
- print_spew("Disabling read/write/fill probes for UP... "); + printk(BIOS_SPEW, "Disabling read/write/fill probes for UP... ");
val=pci_read_config32(NODE_HT(0), HT_TRANSACTION_CONTROL); val |= HTTC_DIS_FILL_P | HTTC_DIS_RMT_MEM_C | HTTC_DIS_P_MEM_C | @@ -153,7 +153,7 @@ static void disable_probes(void) HTTC_DIS_RD_DW_P | HTTC_DIS_RD_B_P; pci_write_config32(NODE_HT(0), HT_TRANSACTION_CONTROL, val);
- print_spew("done.\n"); + printk(BIOS_SPEW, "done.\n");
@@ -199,14 +199,13 @@ static void enable_routing(u8 node) */
/* Enable routing table */ - print_spew("Enabling routing table for node "); - print_spew_hex8(node); + printk(BIOS_SPEW, "Enabling routing table for node %d", node);
val=pci_read_config32(NODE_HT(node), 0x6c); val &= ~((1<<1)|(1<<0)); pci_write_config32(NODE_HT(node), 0x6c, val);
- print_spew(" done.\n"); + printk(BIOS_SPEW, " done.\n"); }
#if CONFIG_MAX_PHYSICAL_CPUS > 1 @@ -230,7 +229,7 @@ static u8 link_to_register(int ldt) if (ldt&0x02) return 0x00;
/* we should never get here */ - print_spew("Unknown Link\n"); + printk(BIOS_SPEW, "Unknown Link\n"); return 0; }
@@ -248,15 +247,14 @@ static void rename_temp_node(u8 node) { uint32_t val;
- print_spew("Renaming current temporary node to "); - print_spew_hex8(node); + printk(BIOS_SPEW, "Renaming current temporary node to %d", node);
val=pci_read_config32(NODE_HT(7), 0x60); val &= (~7); /* clear low bits. */ val |= node; /* new node */ pci_write_config32(NODE_HT(7), 0x60, val);
static int verify_connection(u8 dest) @@ -514,7 +512,7 @@ static void setup_remote_node(u8 node) }; int i;
- print_spew("setup_remote_node: "); + printk(BIOS_SPEW, "setup_remote_node: ");
/* copy the default resource map from node 0 */ for(i = 0; i < ARRAY_SIZE(pci_reg); i++) { @@ -525,7 +523,7 @@ static void setup_remote_node(u8 node) pci_write_config32(NODE_MP(7), reg, value);
} - print_spew("done\n"); + printk(BIOS_SPEW, "done\n"); }
#endif /* CONFIG_MAX_PHYSICAL_CPUS > 1*/ @@ -664,7 +662,7 @@ static void setup_remote_row_indirect_group(const u8 *conn, int num)
static void setup_uniprocessor(void) { - print_spew("Enabling UP settings\n"); + printk(BIOS_SPEW, "Enabling UP settings\n"); #if CONFIG_LOGICAL_CPUS unsigned tmp = (pci_read_config32(NODE_MC(0), 0xe8) >> 12) & 3; if (tmp>0) return; @@ -1491,7 +1489,7 @@ static unsigned setup_smp(void) { unsigned nodes;
- print_spew("Enabling SMP settings\n"); + printk(BIOS_SPEW, "Enabling SMP settings\n");
nodes = setup_smp2(); #if CONFIG_MAX_PHYSICAL_CPUS > 2 @@ -1528,14 +1526,14 @@ static unsigned verify_mp_capabilities(unsigned nodes) #if CONFIG_MAX_PHYSICAL_CPUS > 2 case 0x02: /* MPCap */ if(nodes > 2) { - print_err("Going back to DP\n"); + printk(BIOS_ERR, "Going back to DP\n"); return 2; } break; #endif case 0x00: /* Non SMP */ if(nodes >1 ) { - print_err("Going back to UP\n"); + printk(BIOS_ERR, "Going back to UP\n"); return 1; } break; @@ -1613,7 +1611,7 @@ static void coherent_ht_finalize(unsigned nodes) * registers on Hammer A0 revision. */
- print_spew("coherent_ht_finalize\n"); + printk(BIOS_SPEW, "coherent_ht_finalize\n"); #if !CONFIG_K8_REV_F_SUPPORT rev_a0 = is_cpu_rev_a0(); #endif @@ -1654,7 +1652,7 @@ static void coherent_ht_finalize(unsigned nodes) #endif }
static int apply_cpu_errata_fixes(unsigned nodes) diff --git a/src/northbridge/amd/amdk8/debug.c b/src/northbridge/amd/amdk8/debug.c index 4f9d8ca..c1021e5 100644 --- a/src/northbridge/amd/amdk8/debug.c +++ b/src/northbridge/amd/amdk8/debug.c @@ -54,7 +54,7 @@ static void dump_pci_device(unsigned dev) val = pci_read_config8(dev, i); printk(BIOS_DEBUG, " %02x", val); } - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); }
#if CONFIG_K8_REV_F_SUPPORT @@ -63,7 +63,7 @@ static inline void dump_pci_device_index_wait(unsigned dev, uint32_t index_reg) { int i; print_debug_pci_dev(dev); - print_debug(" -- index_reg="); print_debug_hex32(index_reg); + printk(BIOS_DEBUG, " -- index_reg=%08x", index_reg);
for(i = 0; i < 0x40; i++) { uint32_t val; @@ -76,7 +76,7 @@ static inline void dump_pci_device_index_wait(unsigned dev, uint32_t index_reg) }
} - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); } #endif
@@ -135,7 +135,7 @@ static inline void dump_pci_devices_on_bus(unsigned busn) static void dump_spd_registers(const struct mem_controller *ctrl) { int i; - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); for(i = 0; i < 4; i++) { unsigned device; device = ctrl->channel0[i]; @@ -155,7 +155,7 @@ static void dump_spd_registers(const struct mem_controller *ctrl) byte = status & 0xff; printk(BIOS_DEBUG, "%02x ", byte); } - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); } device = ctrl->channel1[i]; if (device) { @@ -174,14 +174,14 @@ static void dump_spd_registers(const struct mem_controller *ctrl) byte = status & 0xff; printk(BIOS_DEBUG, "%02x ", byte); } - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); } } } static void dump_smbus_registers(void) { unsigned device; - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); for(device = 1; device < 0x80; device++) { int j; if( smbus_read_byte(device, 0) < 0 ) continue; @@ -199,7 +199,7 @@ static void dump_smbus_registers(void) byte = status & 0xff; printk(BIOS_DEBUG, "%02x ", byte); } - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); } } #endif @@ -218,7 +218,7 @@ static inline void dump_io_resources(unsigned port) val = inb(port); printk(BIOS_DEBUG, " %02x",val); if ((i & 0x0f) == 0x0f) { - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); } port++; } @@ -227,13 +227,13 @@ static inline void dump_io_resources(unsigned port) static inline void dump_mem(unsigned start, unsigned end) { unsigned i; - print_debug("dump_mem:"); + printk(BIOS_DEBUG, "dump_mem:"); for(i=start;i<end;i++) { if((i & 0xf)==0) { printk(BIOS_DEBUG, "\n%08x:", i); } printk(BIOS_DEBUG, " %02x", (unsigned char)*((unsigned char *)i)); } - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); } #endif diff --git a/src/northbridge/amd/amdk8/f.h b/src/northbridge/amd/amdk8/f.h index bfeee0e..4f958c5 100644 --- a/src/northbridge/amd/amdk8/f.h +++ b/src/northbridge/amd/amdk8/f.h @@ -564,11 +564,7 @@ static inline void wait_all_core0_mem_trained(struct sys_info *sysinfo) }
for(i=0; i<sysinfo->nodes; i++) { -#ifdef __PRE_RAM__ - print_debug("mem_trained["); print_debug_hex8(i); print_debug("]="); print_debug_hex8(sysinfo->mem_trained[i]); print_debug("\n"); -#else printk(BIOS_DEBUG, "mem_trained[%02x]=%02x\n", i, sysinfo->mem_trained[i]); -#endif switch(sysinfo->mem_trained[i]) { case 0: //don't need train case 1: //trained @@ -581,11 +577,10 @@ static inline void wait_all_core0_mem_trained(struct sys_info *sysinfo) } } if(needs_reset) { + printk(BIOS_DEBUG, "mem trained failed\n"); #ifdef __PRE_RAM__ - print_debug("mem trained failed\n"); soft_reset(); #else - printk(BIOS_DEBUG, "mem trained failed\n"); hard_reset(); #endif } diff --git a/src/northbridge/amd/amdk8/incoherent_ht.c b/src/northbridge/amd/amdk8/incoherent_ht.c index cf8ad52..3c6cf33 100644 --- a/src/northbridge/amd/amdk8/incoherent_ht.c +++ b/src/northbridge/amd/amdk8/incoherent_ht.c @@ -342,7 +342,7 @@ static int ht_setup_chainx(device_t udev, uint8_t upos, uint8_t bus, unsigned of pci_write_config16(udev, upos + LINK_CTRL(uoffs), ctrl); ctrl = pci_read_config16(udev, upos + LINK_CTRL(uoffs)); if (ctrl & ((1 << 4) | (1 << 8))) { - print_err("Detected error on Hypertransport Link\n"); + printk(BIOS_ERR, "Detected error on Hypertransport Link\n"); break; } } @@ -362,10 +362,10 @@ static int ht_setup_chainx(device_t udev, uint8_t upos, uint8_t bus, unsigned of
pos = ht_lookup_slave_capability(dev); if (!pos) { - print_err("udev="); print_err_hex32(udev); - print_err("\tupos="); print_err_hex32(upos); - print_err("\tuoffs="); print_err_hex32(uoffs); - print_err("\tHT link capability not found\n"); + printk(BIOS_ERR, "udev=%08x", udev); + printk(BIOS_ERR, "\tupos=%08x", upos); + printk(BIOS_ERR, "\tuoffs=%08x", uoffs); + printk(BIOS_ERR, "\tHT link capability not found\n"); break; }
diff --git a/src/northbridge/amd/amdk8/raminit_test.c b/src/northbridge/amd/amdk8/raminit_test.c index fd2107c..be46f27 100644 --- a/src/northbridge/amd/amdk8/raminit_test.c +++ b/src/northbridge/amd/amdk8/raminit_test.c @@ -57,11 +57,7 @@ static uint32_t pci_read_config32(device_t dev, unsigned where) (pci_register[addr + 3] << 24);
#if 0 - print_debug("pcir32("); - print_debug_hex32(addr); - print_debug("):"); - print_debug_hex32(value); - print_debug("\n"); + printk(BIOS_DEBUG, "pcir32(%08x): %08x\n", addr, value); #endif return value;
@@ -92,11 +88,7 @@ static void pci_write_config32(device_t dev, unsigned where, uint32_t value) pci_register[addr + 3] = (value >> 24) & 0xff;
#if 0 - print_debug("pciw32("); - print_debug_hex32(addr); - print_debug(", "); - print_debug_hex32(value); - print_debug(")\n"); + printk(BIOS_DEBUG, "pciw32(%08x, %08x)\n", addr, value); #endif }
@@ -285,13 +277,8 @@ static int spd_read_byte(unsigned device, unsigned address) } } #if 0 - print_debug("spd_read_byte("); - print_debug_hex32(device); - print_debug(", "); - print_debug_hex32(address); - print_debug(") -> "); - print_debug_hex32(result); - print_debug("\n"); + printk(BIOS_DEBUG, "spd_read_byte(%08x, %08x) -> %08x\n", + device, address, result); #endif if (spd_count >= spd_fail_count) { result = -1; @@ -392,9 +379,7 @@ static void test1(void) raminit_main();
#if 0 - print_debug("spd_count: "); - print_debug_hex32(spd_count); - print_debug("\n"); + printk(BIOS_DEBUG, "spd_count: %d\n", spd_count); #endif
} @@ -410,9 +395,7 @@ static void do_test2(int i) reset_tests(); spd_fail_count = i;
- print_debug("\nSPD will fail after: "); - print_debug_hex32(spd_fail_count); - print_debug(" accesses.\n"); + printk(BIOS_DEBUG, "\nSPD will fail after: %d accesses.\n", %d);
memcpy(&spd_data[0*256], spd_micron_512MB_DDR333, 256); memcpy(&spd_data[1*256], spd_micron_512MB_DDR333, 256); diff --git a/src/northbridge/amd/amdmct/mct/mct_d.c b/src/northbridge/amd/amdmct/mct/mct_d.c index 924c5fb..7c7550d 100644 --- a/src/northbridge/amd/amdmct/mct/mct_d.c +++ b/src/northbridge/amd/amdmct/mct/mct_d.c @@ -262,7 +262,7 @@ restartinit: node_sys_base += (pDCTstat->NodeSysLimit + 2) & ~0x0F; } if (NodesWmem == 0) { - print_debug("No Nodes?!\n"); + printk(BIOS_DEBUG, "No Nodes?!\n"); goto fatalexit; }
diff --git a/src/northbridge/amd/amdmct/mct/mctdqs_d.c b/src/northbridge/amd/amdmct/mct/mctdqs_d.c index 17fb289..d7fd738 100644 --- a/src/northbridge/amd/amdmct/mct/mctdqs_d.c +++ b/src/northbridge/amd/amdmct/mct/mctdqs_d.c @@ -357,22 +357,20 @@ static void TrainDQSRdWrPos_D(struct MCTStatStruc *pMCTstat,
for (Dir = 0; Dir < 2; Dir++) { if (Dir == 0) { - print_debug("TrainDQSRdWrPos: CH_D_DIR_B_DQS WR:\n"); + printk(BIOS_DEBUG, "TrainDQSRdWrPos: CH_D_DIR_B_DQS WR:\n"); } else { - print_debug("TrainDQSRdWrPos: CH_D_DIR_B_DQS RD:\n"); + printk(BIOS_DEBUG, "TrainDQSRdWrPos: CH_D_DIR_B_DQS RD:\n"); } for (Channel = 0; Channel < 2; Channel++) { - print_debug("Channel:"); print_debug_hex8(Channel); print_debug("\n"); + printk(BIOS_DEBUG, "Channel: %02x\n", Channel); for (Receiver = cs_start; Receiver < (cs_start + 2); Receiver += 2) { - print_debug("\t\tReceiver:"); print_debug_hex8(Receiver); + printk(BIOS_DEBUG, "\t\tReceiver: %02x: ", Receiver); p = pDCTstat->CH_D_DIR_B_DQS[Channel][Receiver >> 1][Dir]; - print_debug(": "); for (i=0;i<8; i++) { val = p[i]; - print_debug_hex8(val); - print_debug(" "); + printk(BIOS_DEBUG, "%02x ", val); } - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); } } } diff --git a/src/northbridge/amd/amdmct/mct/mctsrc.c b/src/northbridge/amd/amdmct/mct/mctsrc.c index feb4170..9c1324d 100644 --- a/src/northbridge/amd/amdmct/mct/mctsrc.c +++ b/src/northbridge/amd/amdmct/mct/mctsrc.c @@ -459,12 +459,9 @@ static void dqsTrainRcvrEn_SW(struct MCTStatStruc *pMCTstat, #if DQS_TRAIN_DEBUG > 0 { u8 Channel; - print_debug("TrainRcvrEn: CH_MaxRdLat:\n"); + printk(BIOS_DEBUG, "TrainRcvrEn: CH_MaxRdLat:\n"); for(Channel = 0; Channel<2; Channel++) { - print_debug("Channel:"); print_debug_hex8(Channel); - print_debug(": "); - print_debug_hex8( pDCTstat->CH_MaxRdLat[Channel] ); - print_debug("\n"); + printk(BIOS_DEBUG, "Channel: %02x: %02x\n", Channel, pDCTstat->CH_MaxRdLat[Channel]); } } #endif @@ -476,20 +473,17 @@ static void dqsTrainRcvrEn_SW(struct MCTStatStruc *pMCTstat, u8 i; u8 *p;
- print_debug("TrainRcvrEn: CH_D_B_RCVRDLY:\n"); + printk(BIOS_DEBUG, "TrainRcvrEn: CH_D_B_RCVRDLY:\n"); for(Channel = 0; Channel < 2; Channel++) { - print_debug("Channel:"); print_debug_hex8(Channel); print_debug("\n"); + printk(BIOS_DEBUG, "Channel: %02x\n", Channel); for(Receiver = 0; Receiver<8; Receiver+=2) { - print_debug("\t\tReceiver:"); - print_debug_hex8(Receiver); + printk(BIOS_DEBUG, "\t\tReceiver: %02x: ", Receiver); p = pDCTstat->CH_D_B_RCVRDLY[Channel][Receiver>>1]; - print_debug(": "); for (i=0;i<8; i++) { val = p[i]; - print_debug_hex8(val); - print_debug(" "); + printk(BIOS_DEBUG, "%02x ", val); } - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); } } } diff --git a/src/northbridge/amd/amdmct/mct/mcttmrl.c b/src/northbridge/amd/amdmct/mct/mcttmrl.c index 03ebf97..d31e744 100644 --- a/src/northbridge/amd/amdmct/mct/mcttmrl.c +++ b/src/northbridge/amd/amdmct/mct/mcttmrl.c @@ -198,12 +198,9 @@ static void maxRdLatencyTrain_D(struct MCTStatStruc *pMCTstat, #if DQS_TRAIN_DEBUG > 0 { u8 Channel; - print_debug("maxRdLatencyTrain: CH_MaxRdLat:\n"); + printk(BIOS_DEBUG, "maxRdLatencyTrain: CH_MaxRdLat:\n"); for(Channel = 0; Channel<2; Channel++) { - print_debug("Channel:"); print_debug_hex8(Channel); - print_debug(": "); - print_debug_hex8( pDCTstat->CH_MaxRdLat[Channel] ); - print_debug("\n"); + printk(BIOS_DEBUG, "Channel: %02x: %02x\n", Channel, pDCTstat->CH_MaxRdLat[Channel]); } } #endif diff --git a/src/northbridge/amd/amdmct/mct_ddr3/mctdqs_d.c b/src/northbridge/amd/amdmct/mct_ddr3/mctdqs_d.c index d7084ad..6a9b921 100644 --- a/src/northbridge/amd/amdmct/mct_ddr3/mctdqs_d.c +++ b/src/northbridge/amd/amdmct/mct_ddr3/mctdqs_d.c @@ -371,22 +371,20 @@ static void TrainDQSRdWrPos_D(struct MCTStatStruc *pMCTstat,
for (Dir = 0; Dir < 2; Dir++) { if (Dir == 1) { - print_debug("TrainDQSRdWrPos: CH_D_DIR_B_DQS WR:\n"); + printk(BIOS_DEBUG, "TrainDQSRdWrPos: CH_D_DIR_B_DQS WR:\n"); } else { - print_debug("TrainDQSRdWrPos: CH_D_DIR_B_DQS RD:\n"); + printk(BIOS_DEBUG, "TrainDQSRdWrPos: CH_D_DIR_B_DQS RD:\n"); } for (Channel = 0; Channel < 2; Channel++) { - print_debug("Channel:"); print_debug_hex8(Channel); print_debug("\n"); + printk(BIOS_DEBUG, "Channel: %02x\n", Channel); for (Receiver = cs_start; Receiver < (cs_start + 2); Receiver += 2) { - print_debug("\t\tReceiver:"); print_debug_hex8(Receiver); + printk(BIOS_DEBUG, "\t\tReceiver: %02x: ", Receiver); p = pDCTstat->CH_D_DIR_B_DQS[Channel][Receiver >> 1][Dir]; - print_debug(": "); for (i=0;i<8; i++) { val = p[i]; - print_debug_hex8(val); - print_debug(" "); + printk(BIOS_DEBUG, "%02x ", val); } - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); } } } diff --git a/src/northbridge/amd/amdmct/mct_ddr3/mcttmrl.c b/src/northbridge/amd/amdmct/mct_ddr3/mcttmrl.c index c7e1352..ec8df9a 100644 --- a/src/northbridge/amd/amdmct/mct_ddr3/mcttmrl.c +++ b/src/northbridge/amd/amdmct/mct_ddr3/mcttmrl.c @@ -192,12 +192,9 @@ static void maxRdLatencyTrain_D(struct MCTStatStruc *pMCTstat, #if DQS_TRAIN_DEBUG > 0 { u8 Channel; - print_debug("maxRdLatencyTrain: CH_MaxRdLat:\n"); + printk(BIOS_DEBUG, "maxRdLatencyTrain: CH_MaxRdLat:\n"); for(Channel = 0; Channel<2; Channel++) { - print_debug("Channel:"); print_debug_hex8(Channel); - print_debug(": "); - print_debug_hex8( pDCTstat->CH_MaxRdLat[Channel] ); - print_debug("\n"); + printk(BIOS_DEBUG, "Channel: %02x: %02x\n", Channel, pDCTstat->CH_MaxRdLat[Channel]); } } #endif diff --git a/src/northbridge/amd/gx2/raminit.c b/src/northbridge/amd/gx2/raminit.c index d9af161..fd872b3 100644 --- a/src/northbridge/amd/gx2/raminit.c +++ b/src/northbridge/amd/gx2/raminit.c @@ -606,6 +606,6 @@ static void sdram_enable(int controllers, const struct mem_controller *ctrl) *ptr = (unsigned long)i; }
- print_info("RAM DLL lock\n"); + printk(BIOS_INFO, "RAM DLL lock\n");
} diff --git a/src/northbridge/amd/lx/raminit.c b/src/northbridge/amd/lx/raminit.c index 7c95ab4..d8515c6 100644 --- a/src/northbridge/amd/lx/raminit.c +++ b/src/northbridge/amd/lx/raminit.c @@ -38,13 +38,13 @@ static void banner(const char *s)
static void __attribute__((noreturn)) hcf(void) { - print_emerg("DIE\n"); + printk(BIOS_EMERG, "DIE\n"); /* this guarantees we flush the UART fifos (if any) and also * ensures that things, in general, keep going so no debug output * is lost */ while (1) - print_emerg_char(0); + printk(BIOS_EMERG, "%c", 0); }
static void auto_size_dimm(unsigned int dimm) @@ -67,7 +67,7 @@ static void auto_size_dimm(unsigned int dimm) /* EEPROM byte usage: (5) Number of DIMM Banks */ spd_byte = spd_read_byte(dimm, SPD_NUM_DIMM_BANKS); if ((MIN_MOD_BANKS > spd_byte) || (spd_byte > MAX_MOD_BANKS)) { - print_emerg("Number of module banks not compatible\n"); + printk(BIOS_EMERG, "Number of module banks not compatible\n"); post_code(ERROR_BANK_SET); hcf(); } @@ -78,7 +78,7 @@ static void auto_size_dimm(unsigned int dimm) /* EEPROM byte usage: (17) Number of Banks on SDRAM Device */ spd_byte = spd_read_byte(dimm, SPD_NUM_BANKS_PER_SDRAM); if ((MIN_DEV_BANKS > spd_byte) || (spd_byte > MAX_DEV_BANKS)) { - print_emerg("Number of device banks not compatible\n"); + printk(BIOS_EMERG, "Number of device banks not compatible\n"); post_code(ERROR_BANK_SET); hcf(); } @@ -94,7 +94,7 @@ static void auto_size_dimm(unsigned int dimm) */ if ((spd_read_byte(dimm, SPD_NUM_ROWS) & 0xF0) || (spd_read_byte(dimm, SPD_NUM_COLUMNS) & 0xF0)) { - print_emerg("Assymetirc DIMM not compatible\n"); + printk(BIOS_EMERG, "Assymetirc DIMM not compatible\n"); post_code(ERROR_UNSUPPORTED_DIMM); hcf(); } @@ -111,7 +111,7 @@ static void auto_size_dimm(unsigned int dimm) dimm_size = __builtin_ctz(dimm_size); banner("TEST DIMM SIZE>8"); if (dimm_size > 8) { /* 8 is 1GB only support 1GB per DIMM */ - print_emerg("Only support up to 1 GB per DIMM\n"); + printk(BIOS_EMERG, "Only support up to 1 GB per DIMM\n"); post_code(ERROR_DENSITY_DIMM); hcf(); } @@ -144,7 +144,7 @@ static void auto_size_dimm(unsigned int dimm) spd_byte = NumColAddr[spd_read_byte(dimm, SPD_NUM_COLUMNS) & 0xF]; banner("MAXCOLADDR"); if (spd_byte > MAX_COL_ADDR) { - print_emerg("DIMM page size not compatible\n"); + printk(BIOS_EMERG, "DIMM page size not compatible\n"); post_code(ERROR_SET_PAGE); hcf(); } @@ -186,7 +186,7 @@ static void checkDDRMax(void)
/* I don't think you need this check. if (spd_byte0 >= 0xA0 || spd_byte1 >= 0xA0){ - print_emerg("DIMM overclocked. Check GeodeLink Speed\n"); + printk(BIOS_EMERG, "DIMM overclocked. Check GeodeLink Speed\n"); post_code(POST_PLL_MEM_FAIL); hcf(); } */ @@ -201,7 +201,7 @@ static void checkDDRMax(void)
/* current speed > max speed? */ if (GeodeLinkSpeed() > speed) { - print_emerg("DIMM overclocked. Check GeodeLink Speed\n"); + printk(BIOS_EMERG, "DIMM overclocked. Check GeodeLink Speed\n"); post_code(POST_PLL_MEM_FAIL); hcf(); } @@ -319,7 +319,7 @@ static void setCAS(void) } else if ((casmap0 &= casmap1)) { spd_byte = CASDDR[__builtin_ctz(casmap0)]; } else { - print_emerg("DIMM CAS Latencies not compatible\n"); + printk(BIOS_EMERG, "DIMM CAS Latencies not compatible\n"); post_code(ERROR_DIFF_DIMMS); hcf(); } @@ -513,7 +513,7 @@ static void EnableMTest(void) msr.lo |= CFCLK_LOWER_TRISTATE_DIS_SET; wrmsr(MC_CFCLK_DBUG, msr);
- print_info("Enabled MTest for TLA debug\n"); + printk(BIOS_INFO, "Enabled MTest for TLA debug\n"); } #endif
@@ -558,14 +558,14 @@ void sdram_set_spd_registers(const struct mem_controller *ctrl) banner("Check DIMM 0"); /* Check DIMM is not Register and not Buffered DIMMs. */ if ((spd_byte != 0xFF) && (spd_byte & 3)) { - print_emerg("DIMM0 NOT COMPATIBLE\n"); + printk(BIOS_EMERG, "DIMM0 NOT COMPATIBLE\n"); post_code(ERROR_UNSUPPORTED_DIMM); hcf(); } banner("Check DIMM 1"); spd_byte = spd_read_byte(DIMM1, SPD_MODULE_ATTRIBUTES); if ((spd_byte != 0xFF) && (spd_byte & 3)) { - print_emerg("DIMM1 NOT COMPATIBLE\n"); + printk(BIOS_EMERG, "DIMM1 NOT COMPATIBLE\n"); post_code(ERROR_UNSUPPORTED_DIMM); hcf(); } @@ -633,7 +633,7 @@ void sdram_enable(int controllers, const struct mem_controller *ctrl) msr = rdmsr(MC_CF07_DATA); if ((msr.hi & ((7 << CF07_UPPER_D1_PSZ_SHIFT) | (7 << CF07_UPPER_D0_PSZ_SHIFT))) == ((7 << CF07_UPPER_D1_PSZ_SHIFT) | (7 << CF07_UPPER_D0_PSZ_SHIFT))) { - print_emerg("No memory in the system\n"); + printk(BIOS_EMERG, "No memory in the system\n"); post_code(ERROR_NO_DIMMS); hcf(); } @@ -775,6 +775,6 @@ void sdram_enable(int controllers, const struct mem_controller *ctrl) msr.lo |= 1; wrmsr(msrnum, msr); } - print_info("RAM DLL lock\n"); + printk(BIOS_INFO, "RAM DLL lock\n");
} diff --git a/src/northbridge/dmp/vortex86ex/raminit.c b/src/northbridge/dmp/vortex86ex/raminit.c index 2382fe2..227b376 100644 --- a/src/northbridge/dmp/vortex86ex/raminit.c +++ b/src/northbridge/dmp/vortex86ex/raminit.c @@ -258,17 +258,17 @@ static u8 detect_ddr3_dram_size(void) static void print_ddr3_memory_setup(void) { #if CONFIG_DEBUG_RAM_SETUP - print_debug("DDR3 Timing Reg 0-3:\n"); - print_debug("NB 6e : "); + printk(BIOS_DEBUG, "DDR3 Timing Reg 0-3:\n"); + printk(BIOS_DEBUG, "NB 6e : "); print_debug_hex16(pci_read_config16(NB, 0x6e)); - print_debug("\nNB 74 : "); + printk(BIOS_DEBUG, "\nNB 74 : "); print_debug_hex32(pci_read_config32(NB, 0x74)); - print_debug("\nNB 78 : "); + printk(BIOS_DEBUG, "\nNB 78 : "); print_debug_hex32(pci_read_config32(NB, 0x78)); - print_debug("\nNB 7c : "); + printk(BIOS_DEBUG, "\nNB 7c : "); print_debug_hex32(pci_read_config32(NB, 0x7c)); u16 mbr = pci_read_config16(NB, 0x6c); - print_debug("\nNB 6c(MBR) : "); + printk(BIOS_DEBUG, "\nNB 6c(MBR) : "); print_debug_hex16(mbr); const char *s; u8 col = get_ddr3_mem_reg_col(mbr); diff --git a/src/northbridge/intel/e7501/debug.c b/src/northbridge/intel/e7501/debug.c index 07f1596..32a1428 100644 --- a/src/northbridge/intel/e7501/debug.c +++ b/src/northbridge/intel/e7501/debug.c @@ -5,12 +5,8 @@ #if 1 static void print_debug_pci_dev(unsigned dev) { - print_debug("PCI: "); - print_debug_hex8((dev >> 16) & 0xff); - print_debug_char(':'); - print_debug_hex8((dev >> 11) & 0x1f); - print_debug_char('.'); - print_debug_hex8((dev >> 8) & 7); + printk(BIOS_DEBUG, "PCI: %02x:%02x.%x", + (dev >> 16) & 0xff, (dev >> 11) & 0x1f, (dev >> 8) & 7); }
static inline void print_pci_devices(void) @@ -27,7 +23,7 @@ static inline void print_pci_devices(void) continue; } print_debug_pci_dev(dev); - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); } }
@@ -38,24 +34,12 @@ static void dump_pci_device(unsigned dev)
for(i = 0; i < 256; i++) { unsigned char val; - if ((i & 0x0f) == 0) { -#if !defined(__ROMCC__) + if ((i & 0x0f) == 0) printk(BIOS_DEBUG, "\n%02x:",i); -#else - print_debug("\n"); - print_debug_hex8(i); - print_debug_char(':'); -#endif - } val = pci_read_config8(dev, i); -#if !defined(__ROMCC__) printk(BIOS_DEBUG, " %02x", val); -#else - print_debug_char(' '); - print_debug_hex8(val); -#endif } - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); }
static inline void dump_pci_devices(void) @@ -95,98 +79,55 @@ static inline void dump_pci_devices_on_bus(unsigned busn) static inline void dump_spd_registers(const struct mem_controller *ctrl) { int i; - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); for(i = 0; i < 4; i++) { unsigned device; device = ctrl->channel0[i]; if (device) { int j; -#if !defined(__ROMCC__) printk(BIOS_DEBUG, "dimm: %02x.0: %02x", i, device); -#else - print_debug("dimm: "); - print_debug_hex8(i); - print_debug(".0: "); - print_debug_hex8(device); -#endif for(j = 0; j < 128; j++) { int status; unsigned char byte; - if ((j & 0xf) == 0) { -#if !defined(__ROMCC__) + if ((j & 0xf) == 0) printk(BIOS_DEBUG, "\n%02x: ", j); -#else - print_debug("\n"); - print_debug_hex8(j); - print_debug(": "); -#endif - } status = smbus_read_byte(device, j); if (status < 0) { break; } byte = status & 0xff; -#if !defined(__ROMCC__) printk(BIOS_DEBUG, "%02x ", byte); -#else - print_debug_hex8(byte); - print_debug_char(' '); -#endif } - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); } device = ctrl->channel1[i]; if (device) { int j; -#if !defined(__ROMCC__) printk(BIOS_DEBUG, "dimm: %02x.1: %02x", i, device); -#else - print_debug("dimm: "); - print_debug_hex8(i); - print_debug(".1: "); - print_debug_hex8(device); -#endif for(j = 0; j < 128; j++) { int status; unsigned char byte; - if ((j & 0xf) == 0) { -#if !defined(__ROMCC__) + if ((j & 0xf) == 0) printk(BIOS_DEBUG, "\n%02x: ", j); -#else - print_debug("\n"); - print_debug_hex8(j); - print_debug(": "); -#endif - } status = smbus_read_byte(device, j); if (status < 0) { break; } byte = status & 0xff; -#if !defined(__ROMCC__) printk(BIOS_DEBUG, "%02x ", byte); -#else - print_debug_hex8(byte); - print_debug_char(' '); -#endif } - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); } } } static inline void dump_smbus_registers(void) { unsigned device; - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); for(device = 1; device < 0x80; device++) { int j; if( smbus_read_byte(device, 0) < 0 ) continue; -#if !defined(__ROMCC__) printk(BIOS_DEBUG, "smbus: %02x", device); -#else - print_debug("smbus: "); - print_debug_hex8(device); -#endif for(j = 0; j < 256; j++) { int status; unsigned char byte; @@ -194,24 +135,12 @@ static inline void dump_smbus_registers(void) if (status < 0) { break; } - if ((j & 0xf) == 0) { -#if !defined(__ROMCC__) + if ((j & 0xf) == 0) printk(BIOS_DEBUG, "\n%02x: ",j); -#else - print_debug("\n"); - print_debug_hex8(j); - print_debug(": "); -#endif - } byte = status & 0xff; -#if !defined(__ROMCC__) printk(BIOS_DEBUG, "%02x ", byte); -#else - print_debug_hex8(byte); - print_debug_char(' '); -#endif } - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); } }
@@ -219,31 +148,15 @@ static inline void dump_io_resources(unsigned port) {
int i; -#if !defined(__ROMCC__) printk(BIOS_DEBUG, "%04x:\n", port); -#else - print_debug_hex16(port); - print_debug(":\n"); -#endif for(i=0;i<256;i++) { uint8_t val; - if ((i & 0x0f) == 0) { -#if !defined(__ROMCC__) + if ((i & 0x0f) == 0) printk(BIOS_DEBUG, "%02x:", i); -#else - print_debug_hex8(i); - print_debug_char(':'); -#endif - } val = inb(port); -#if !defined(__ROMCC__) printk(BIOS_DEBUG, " %02x",val); -#else - print_debug_char(' '); - print_debug_hex8(val); -#endif if ((i & 0x0f) == 0x0f) { - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); } port++; } @@ -252,24 +165,12 @@ static inline void dump_io_resources(unsigned port) static inline void dump_mem(unsigned start, unsigned end) { unsigned i; - print_debug("dump_mem:"); + printk(BIOS_DEBUG, "dump_mem:"); for(i=start;i<end;i++) { - if((i & 0xf)==0) { -#if !defined(__ROMCC__) + if((i & 0xf)==0) printk(BIOS_DEBUG, "\n%08x:", i); -#else - print_debug("\n"); - print_debug_hex32(i); - print_debug(":"); -#endif - } -#if !defined(__ROMCC__) printk(BIOS_DEBUG, " %02x", (unsigned char)*((unsigned char *)i)); -#else - print_debug(" "); - print_debug_hex8((unsigned char)*((unsigned char *)i)); -#endif } - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); } #endif diff --git a/src/northbridge/intel/e7501/raminit.c b/src/northbridge/intel/e7501/raminit.c index 2247a25..22d1bbc 100644 --- a/src/northbridge/intel/e7501/raminit.c +++ b/src/northbridge/intel/e7501/raminit.c @@ -27,9 +27,9 @@ Definitions: //#define VALIDATE_DIMM_COMPATIBILITY
#if CONFIG_DEBUG_RAM_SETUP -#define RAM_DEBUG_MESSAGE(x) print_debug(x) -#define RAM_DEBUG_HEX32(x) print_debug_hex32(x) -#define RAM_DEBUG_HEX8(x) print_debug_hex8(x) +#define RAM_DEBUG_MESSAGE(x) printk(BIOS_DEBUG, x) +#define RAM_DEBUG_HEX32(x) printk(BIOS_DEBUG, "%08x", x) +#define RAM_DEBUG_HEX8(x) printk(BIOS_DEBUG, "%02x", x) #define DUMPNORTH() dump_pci_device(PCI_DEV(0, 0, 0)) #else #define RAM_DEBUG_MESSAGE(x) @@ -784,7 +784,7 @@ static uint8_t spd_get_supported_dimms(const struct mem_controller *ctrl) spd_read_byte(channel1_dimm, SPD_MODULE_ATTRIBUTES); if (!(spd_value & MODULE_REGISTERED) || (spd_value < 0)) {
- print_debug("Skipping un-matched DIMMs - only dual-channel operation supported\n"); + printk(BIOS_DEBUG, "Skipping un-matched DIMMs - only dual-channel operation supported\n"); continue; } #ifdef VALIDATE_DIMM_COMPATIBILITY @@ -812,11 +812,11 @@ static uint8_t spd_get_supported_dimms(const struct mem_controller *ctrl) // Made it through all the checks, this DIMM pair is usable dimm_mask |= ((1 << i) | (1 << (MAX_DIMM_SOCKETS_PER_CHANNEL + i))); } else - print_debug("Skipping un-matched DIMMs - only dual-channel operation supported\n"); + printk(BIOS_DEBUG, "Skipping un-matched DIMMs - only dual-channel operation supported\n"); #else switch (bDualChannel) { case 0: - print_debug("Skipping un-matched DIMMs - only dual-channel operation supported\n"); + printk(BIOS_DEBUG, "Skipping un-matched DIMMs - only dual-channel operation supported\n"); break;
default: @@ -1523,13 +1523,13 @@ static void configure_e7501_dram_controller_mode(const struct die_on_spd_error(value); value &= 0x7f; // Mask off self-refresh bit if (value > MAX_SPD_REFRESH_RATE) { - print_err("unsupported refresh rate\n"); + printk(BIOS_ERR, "unsupported refresh rate\n"); continue; } // Get the appropriate E7501 refresh mode for this DIMM dimm_refresh_mode = refresh_rate_map[value]; if (dimm_refresh_mode > 7) { - print_err("unsupported refresh rate\n"); + printk(BIOS_ERR, "unsupported refresh rate\n"); continue; } // If this DIMM requires more frequent refresh than others, @@ -1961,7 +1961,7 @@ static void sdram_set_spd_registers(const struct mem_controller *ctrl) dimm_mask = spd_get_supported_dimms(ctrl);
if (dimm_mask == 0) { - print_debug("No usable memory for this controller\n"); + printk(BIOS_DEBUG, "No usable memory for this controller\n"); } else { enable_e7501_clocks(dimm_mask);
diff --git a/src/northbridge/intel/e7505/debug.c b/src/northbridge/intel/e7505/debug.c index 3d6ca2a..cdf6e7e 100644 --- a/src/northbridge/intel/e7505/debug.c +++ b/src/northbridge/intel/e7505/debug.c @@ -15,12 +15,8 @@
void print_pci_devices(void) @@ -37,7 +33,7 @@ void print_pci_devices(void) continue; } print_debug_pci_dev(dev); - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); } }
@@ -48,24 +44,12 @@ void dump_pci_device(unsigned dev)
void dump_pci_devices(void) @@ -105,98 +89,55 @@ void dump_pci_devices_on_bus(unsigned busn) void dump_spd_registers(const struct mem_controller *ctrl) { int i; - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); for(i = 0; i < 4; i++) { unsigned device; device = ctrl->channel0[i]; if (device) { int j; -#if !defined(__ROMCC__) printk(BIOS_DEBUG, "dimm: %02x.0: %02x", i, device); -#else - print_debug("dimm: "); - print_debug_hex8(i); - print_debug(".0: "); - print_debug_hex8(device); -#endif for(j = 0; j < 128; j++) { int status; unsigned char byte; - if ((j & 0xf) == 0) { -#if !defined(__ROMCC__) + if ((j & 0xf) == 0) printk(BIOS_DEBUG, "\n%02x: ", j); -#else - print_debug("\n"); - print_debug_hex8(j); - print_debug(": "); -#endif - } status = spd_read_byte(device, j); if (status < 0) { break; } byte = status & 0xff; -#if !defined(__ROMCC__) printk(BIOS_DEBUG, "%02x ", byte); -#else - print_debug_hex8(byte); - print_debug_char(' '); -#endif } - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); } device = ctrl->channel1[i]; if (device) { int j; -#if !defined(__ROMCC__) printk(BIOS_DEBUG, "dimm: %02x.1: %02x", i, device); -#else - print_debug("dimm: "); - print_debug_hex8(i); - print_debug(".1: "); - print_debug_hex8(device); -#endif for(j = 0; j < 128; j++) { int status; unsigned char byte; - if ((j & 0xf) == 0) { -#if !defined(__ROMCC__) + if ((j & 0xf) == 0) printk(BIOS_DEBUG, "\n%02x: ", j); -#else - print_debug("\n"); - print_debug_hex8(j); - print_debug(": "); -#endif - } status = spd_read_byte(device, j); if (status < 0) { break; } byte = status & 0xff; -#if !defined(__ROMCC__) printk(BIOS_DEBUG, "%02x ", byte); -#else - print_debug_hex8(byte); - print_debug_char(' '); -#endif } - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); } } } void dump_smbus_registers(void) { unsigned device; - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); for(device = 1; device < 0x80; device++) { int j; if( spd_read_byte(device, 0) < 0 ) continue; -#if !defined(__ROMCC__) printk(BIOS_DEBUG, "smbus: %02x", device); -#else - print_debug("smbus: "); - print_debug_hex8(device); -#endif for(j = 0; j < 256; j++) { int status; unsigned char byte; @@ -204,24 +145,12 @@ void dump_smbus_registers(void) if (status < 0) { break; } - if ((j & 0xf) == 0) { -#if !defined(__ROMCC__) + if ((j & 0xf) == 0) printk(BIOS_DEBUG, "\n%02x: ",j); -#else - print_debug("\n"); - print_debug_hex8(j); - print_debug(": "); -#endif - } byte = status & 0xff; -#if !defined(__ROMCC__) printk(BIOS_DEBUG, "%02x ", byte); -#else - print_debug_hex8(byte); - print_debug_char(' '); -#endif } - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); } }
@@ -229,31 +158,15 @@ void dump_io_resources(unsigned port) {
int i; -#if !defined(__ROMCC__) printk(BIOS_DEBUG, "%04x:\n", port); -#else - print_debug_hex16(port); - print_debug(":\n"); -#endif for(i=0;i<256;i++) { uint8_t val; - if ((i & 0x0f) == 0) { -#if !defined(__ROMCC__) + if ((i & 0x0f) == 0) printk(BIOS_DEBUG, "%02x:", i); -#else - print_debug_hex8(i); - print_debug_char(':'); -#endif - } val = inb(port); -#if !defined(__ROMCC__) printk(BIOS_DEBUG, " %02x",val); -#else - print_debug_char(' '); - print_debug_hex8(val); -#endif if ((i & 0x0f) == 0x0f) { - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); } port++; } @@ -262,23 +175,11 @@ void dump_io_resources(unsigned port) void dump_mem(unsigned start, unsigned end) { unsigned i; - print_debug("dump_mem:"); + printk(BIOS_DEBUG, "dump_mem:"); for(i=start;i<end;i++) { - if((i & 0xf)==0) { -#if !defined(__ROMCC__) + if((i & 0xf)==0) printk(BIOS_DEBUG, "\n%08x:", i); -#else - print_debug("\n"); - print_debug_hex32(i); - print_debug(":"); -#endif - } -#if !defined(__ROMCC__) printk(BIOS_DEBUG, " %02x", (unsigned char)*((unsigned char *)i)); -#else - print_debug(" "); - print_debug_hex8((unsigned char)*((unsigned char *)i)); -#endif } - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); } diff --git a/src/northbridge/intel/e7505/raminit.c b/src/northbridge/intel/e7505/raminit.c index 909e740..b758c61 100644 --- a/src/northbridge/intel/e7505/raminit.c +++ b/src/northbridge/intel/e7505/raminit.c @@ -42,9 +42,9 @@ Definitions: //#define VALIDATE_DIMM_COMPATIBILITY
#if CONFIG_DEBUG_RAM_SETUP -#define RAM_DEBUG_MESSAGE(x) print_debug(x) -#define RAM_DEBUG_HEX32(x) print_debug_hex32(x) -#define RAM_DEBUG_HEX8(x) print_debug_hex8(x) +#define RAM_DEBUG_MESSAGE(x) printk(BIOS_DEBUG, x) +#define RAM_DEBUG_HEX32(x) printk(BIOS_DEBUG, "%08x", x) +#define RAM_DEBUG_HEX8(x) printk(BIOS_DEBUG, "%02x", x) #define DUMPNORTH() dump_pci_device(MCHDEV) #else #define RAM_DEBUG_MESSAGE(x) @@ -605,7 +605,7 @@ static uint8_t spd_get_supported_dimms(const struct mem_controller *ctrl) spd_read_byte(channel1_dimm, SPD_MODULE_ATTRIBUTES); if (!(spd_value & MODULE_REGISTERED) || (spd_value < 0)) {
- print_debug("Skipping un-matched DIMMs - only dual-channel operation supported\n"); + printk(BIOS_DEBUG, "Skipping un-matched DIMMs - only dual-channel operation supported\n"); continue; } #ifdef VALIDATE_DIMM_COMPATIBILITY @@ -633,11 +633,11 @@ static uint8_t spd_get_supported_dimms(const struct mem_controller *ctrl) // Made it through all the checks, this DIMM pair is usable dimm_mask |= ((1 << i) | (1 << (MAX_DIMM_SOCKETS_PER_CHANNEL + i))); } else - print_debug("Skipping un-matched DIMMs - only dual-channel operation supported\n"); + printk(BIOS_DEBUG, "Skipping un-matched DIMMs - only dual-channel operation supported\n"); #else switch (bDualChannel) { case 0: - print_debug("Skipping un-matched DIMMs - only dual-channel operation supported\n"); + printk(BIOS_DEBUG, "Skipping un-matched DIMMs - only dual-channel operation supported\n"); break;
default: @@ -1379,13 +1379,13 @@ static void configure_e7501_dram_controller_mode(const struct die_on_spd_error(value); value &= 0x7f; // Mask off self-refresh bit if (value > MAX_SPD_REFRESH_RATE) { - print_err("unsupported refresh rate\n"); + printk(BIOS_ERR, "unsupported refresh rate\n"); continue; } // Get the appropriate E7501 refresh mode for this DIMM dimm_refresh_mode = refresh_rate_map[value]; if (dimm_refresh_mode > 7) { - print_err("unsupported refresh rate\n"); + printk(BIOS_ERR, "unsupported refresh rate\n"); continue; } // If this DIMM requires more frequent refresh than others, @@ -1767,7 +1767,7 @@ static void sdram_set_spd_registers(const struct mem_controller *ctrl) dimm_mask = spd_get_supported_dimms(ctrl);
diff --git a/src/northbridge/intel/i3100/raminit.c b/src/northbridge/intel/i3100/raminit.c index 4f5a989..ebe137b 100644 --- a/src/northbridge/intel/i3100/raminit.c +++ b/src/northbridge/intel/i3100/raminit.c @@ -78,7 +78,7 @@ static void sdram_set_registers(const struct mem_controller *ctrl) reg |= register_values[i+2]; pci_write_config32(dev, where, reg); } - print_spew("done.\n"); + printk(BIOS_SPEW, "done.\n"); }
struct dimm_size { @@ -610,7 +610,7 @@ static void sdram_set_spd_registers(const struct mem_controller *ctrl) /* Test if we can read the spd and if ram is ddr or ddr2 */ dimm_mask = spd_detect_dimms(ctrl); if (!(dimm_mask & ((1 << DIMM_SOCKETS) - 1))) { - print_err("No memory for this cpu\n"); + printk(BIOS_ERR, "No memory for this cpu\n"); return; } return; @@ -686,9 +686,7 @@ static void set_on_dimm_termination_enable(const struct mem_controller *ctrl) die("Error - First dimm slot empty\n"); }
- print_debug("ODT Value = "); - print_debug_hex32(data32); - print_debug("\n"); + printk(BIOS_DEBUG, "ODT Value = %08x\n", data32);
pci_write_config32(ctrl->f0, DDR2ODTC, data32);
@@ -916,11 +914,8 @@ static void set_receive_enable(const struct mem_controller *ctrl) } }
- print_debug("Receive enable A = "); - print_debug_hex32(recena); - print_debug(", Receive enable B = "); - print_debug_hex32(recenb); - print_debug("\n"); + printk(BIOS_DEBUG, "Receive enable A = %08x, Receive enable B = %08x\n", + recena, recenb);
/* clear out the calibration area */ write32(MCBAR+DCALDATA+(16*4), 0x00000000); @@ -972,7 +967,7 @@ static void sdram_enable(int controllers, const struct mem_controller *ctrl) 0xffffffff, 0xffffffff, 0x000000ff};
mask = spd_detect_dimms(ctrl); - print_debug("Starting SDRAM Enable\n"); + printk(BIOS_DEBUG, "Starting SDRAM Enable\n");
/* 0x80 */ pci_write_config32(ctrl->f0, DRM, @@ -1013,9 +1008,7 @@ static void sdram_enable(int controllers, const struct mem_controller *ctrl) cas_latency = spd_set_drt_attributes(ctrl, mask, drc);
for(i=0;i<8;i+=2) { /* loop through each dimm to test */ - print_debug("DIMM "); - print_debug_hex8(i); - print_debug("\n"); + printk(BIOS_DEBUG, "DIMM %08x\n", i); /* Apply NOP */ do_delay();
@@ -1158,7 +1151,7 @@ static void sdram_enable(int controllers, const struct mem_controller *ctrl) write32(MCBAR+DCALCSR, 0x0008000f);
/* clear memory and init ECC */ - print_debug("Clearing memory\n"); + printk(BIOS_DEBUG, "Clearing memory\n"); for(i=0;i<64;i+=4) { write32(MCBAR+DCALDATA+i, 0x00000000); } @@ -1174,13 +1167,13 @@ static void sdram_enable(int controllers, const struct mem_controller *ctrl) data32 |= (1 << 31); pci_write_config32(ctrl->f0, 0x98, data32); /* wait for completion */ - print_debug("Waiting for mem complete\n"); + printk(BIOS_DEBUG, "Waiting for mem complete\n"); while(1) { data32 = pci_read_config32(ctrl->f0, 0x98); if( (data32 & (1<<31)) == 0) break; } - print_debug("Done\n"); + printk(BIOS_DEBUG, "Done\n");
/* Set initialization complete */ /* 0x7c DRC */ diff --git a/src/northbridge/intel/i3100/raminit_ep80579.c b/src/northbridge/intel/i3100/raminit_ep80579.c index cff7879..b2858e4 100644 --- a/src/northbridge/intel/i3100/raminit_ep80579.c +++ b/src/northbridge/intel/i3100/raminit_ep80579.c @@ -128,13 +128,7 @@ static struct dimm_size spd_get_dimm_size(u16 device) sz.side1 = 0; sz.side2 = 0; out: - print_debug("dimm "); - print_debug_hex8(device); - print_debug(" size = "); - print_debug_hex8(sz.side1); - print_debug("."); - print_debug_hex8(sz.side2); - print_debug("\n"); + printk(BIOS_DEBUG, "dimm %02x size = %02x.%02x\n", device, sz.side1, sz.side2); return sz;
} @@ -165,25 +159,19 @@ static long spd_set_ram_size(const struct mem_controller *ctrl, u8 dimm_mask) pci_write_config8(ctrl->f0, DRB+1 + (i*2), cum); } } - print_debug("DRB = "); - print_debug_hex32(pci_read_config32(ctrl->f0, DRB)); - print_debug("\n"); + printk(BIOS_DEBUG, "DRB = %08x\n", pci_read_config32(ctrl->f0, DRB));
cum >>= 1; /* set TOM top of memory */ pci_write_config16(ctrl->f0, TOM, cum); - print_debug("TOM = "); - print_debug_hex16(cum); - print_debug("\n"); + printk(BIOS_DEBUG, "TOM = %04x\n", cum); /* set TOLM top of low memory */ if (cum > 0x18) { cum = 0x18; } cum <<= 11; pci_write_config16(ctrl->f0, TOLM, cum); - print_debug("TOLM = "); - print_debug_hex16(cum); - print_debug("\n"); + printk(BIOS_DEBUG, "TOLM = %04x\n", cum); return 0; }
@@ -198,11 +186,7 @@ static u8 spd_detect_dimms(const struct mem_controller *ctrl) device = ctrl->channel0[i]; if (device) { byte = spd_read_byte(device, SPD_MEMORY_TYPE); - print_debug("spd "); - print_debug_hex8(device); - print_debug(" = "); - print_debug_hex8(byte); - print_debug("\n"); + printk(BIOS_DEBUG, "spd %02x = %02x\n", device, byte); if (byte == 8) { dimm_mask |= (1 << i); } @@ -245,11 +229,7 @@ static int spd_set_row_attributes(const struct mem_controller *ctrl, if ((value & 0xff) == 0) die("Invalid # of banks\n"); reg += log2(value & 0xff);
- print_debug("dimm "); - print_debug_hex8(i); - print_debug(" reg = "); - print_debug_hex8(reg); - print_debug("\n"); + printk(BIOS_DEBUG, "dimm %02x reg = %02x\n", i, reg);
/* set device density */ dra |= ((31-reg)); @@ -266,11 +246,7 @@ static int spd_set_row_attributes(const struct mem_controller *ctrl, value = spd_read_byte(ctrl->channel0[i], SPD_NUM_DIMM_BANKS); dra |= ((value & 0x1) << 17);
- print_debug("DRA"); - print_debug_hex8(i); - print_debug(" = "); - print_debug_hex32(dra); - print_debug("\n"); + printk(BIOS_DEBUG, "DRA%02x = %08x\n", i, dra);
pci_write_config32(ctrl->f0, DRA + (i*4), dra); } @@ -321,9 +297,7 @@ static u32 spd_set_drt_attributes(const struct mem_controller *ctrl, cl = 6; else die("CAS latency mismatch\n"); - print_debug("cl = "); - print_debug_hex8(cl); - print_debug("\n"); + printk(BIOS_DEBUG, "cl = %02x\n", cl);
ci = cycle[index];
@@ -347,12 +321,8 @@ static u32 spd_set_drt_attributes(const struct mem_controller *ctrl, if (trfc < val) trfc = val; } - print_debug("trc = "); - print_debug_hex8(trc); - print_debug("\n"); - print_debug("trfc = "); - print_debug_hex8(trfc); - print_debug("\n"); + printk(BIOS_DEBUG, "trc = %02x\n", trc); + printk(BIOS_DEBUG, "trfc = %02x\n", trfc);
/* Tras, Trtp, Twtr in cycles */ for (i = 0; i < DIMM_SOCKETS; i++) { @@ -372,40 +342,26 @@ static u32 spd_set_drt_attributes(const struct mem_controller *ctrl, if (twtr < val) twtr = val; } - print_debug("tras = "); - print_debug_hex8(tras); - print_debug("\n"); - print_debug("trtp = "); - print_debug_hex8(trtp); - print_debug("\n"); - print_debug("twtr = "); - print_debug_hex8(twtr); - print_debug("\n"); + printk(BIOS_DEBUG, "tras = %02x\n", tras); + printk(BIOS_DEBUG, "trtp = %02x\n", trtp); + printk(BIOS_DEBUG, "twtr = %02x\n", twtr);
val = (drt0[index] | ((trc - 11) << 12) | ((cl - 3) << 9) | ((cl - 3) << 6) | ((cl - 3) << 3)); - print_debug("drt0 = "); - print_debug_hex32(val); - print_debug("\n"); + printk(BIOS_DEBUG, "drt0 = %08x\n", val); pci_write_config32(ctrl->f0, DRT0, val);
val = (drt1[index] | ((tras - 8) << 28) | ((trtp - 2) << 25) | (twtr << 15)); - print_debug("drt1 = "); - print_debug_hex32(val); - print_debug("\n"); + printk(BIOS_DEBUG, "drt1 = %08x\n", val); pci_write_config32(ctrl->f0, DRT1, val);
val = (magic[index]); - print_debug("magic = "); - print_debug_hex32(val); - print_debug("\n"); + printk(BIOS_DEBUG, "magic = %08x\n", val); pci_write_config32(PCI_DEV(0, 0x08, 0), 0xcc, val);
val = (mrs[index] | (cl << 20)); - print_debug("mrs = "); - print_debug_hex32(val); - print_debug("\n"); + printk(BIOS_DEBUG, "mrs = %08x\n", val); return val; }
@@ -432,9 +388,7 @@ static int spd_set_dram_controller_mode(const struct mem_controller *ctrl, if (value > cycle) cycle = value; } - print_debug("cycle = "); - print_debug_hex8(cycle); - print_debug("\n"); + printk(BIOS_DEBUG, "cycle = %02x\n", cycle);
drc |= (1 << 20); /* enable ECC */ drc |= (3 << 30); /* enable CKE on each DIMM */ @@ -443,45 +397,40 @@ static int spd_set_dram_controller_mode(const struct mem_controller *ctrl, /* TODO check: */ /* set front side bus speed */ msr = rdmsr(MSR_FSB_FREQ); /* returns 0 on Pentium M 90nm */ - print_debug("MSR FSB_FREQ(0xcd) = "); - print_debug_hex32(msr.hi); - print_debug_hex32(msr.lo); - print_debug("\n"); + printk(BIOS_DEBUG, "MSR FSB_FREQ(0xcd) = %08x%08x\n", msr.hi, msr.lo);
/* TODO check that this msr really indicates fsb speed! */ if (msr.lo & 0x07) { - print_info("533 MHz FSB\n"); + printk(BIOS_INFO, "533 MHz FSB\n"); if (cycle <= 0x25) { drc |= 0x5; - print_info("400 MHz DDR\n"); + printk(BIOS_INFO, "400 MHz DDR\n"); } else if (cycle <= 0x30) { drc |= 0x7; - print_info("333 MHz DDR\n"); + printk(BIOS_INFO, "333 MHz DDR\n"); } else if (cycle <= 0x3d) { drc |= 0x4; - print_info("266 MHz DDR\n"); + printk(BIOS_INFO, "266 MHz DDR\n"); } else { drc |= 0x2; - print_info("200 MHz DDR\n"); + printk(BIOS_INFO, "200 MHz DDR\n"); } } else { - print_info("400 MHz FSB\n"); + printk(BIOS_INFO, "400 MHz FSB\n"); if (cycle <= 0x30) { drc |= 0x7; - print_info("333 MHz DDR\n"); + printk(BIOS_INFO, "333 MHz DDR\n"); } else if (cycle <= 0x3d) { drc |= 0x0; - print_info("266 MHz DDR\n"); + printk(BIOS_INFO, "266 MHz DDR\n"); } else { drc |= 0x2; - print_info("200 MHz DDR\n"); + printk(BIOS_INFO, "200 MHz DDR\n"); } }
- print_debug("DRC = "); - print_debug_hex32(drc); - print_debug("\n"); + printk(BIOS_DEBUG, "DRC = %08x\n", drc);
return drc; } @@ -493,7 +442,7 @@ static void sdram_set_spd_registers(const struct mem_controller *ctrl) /* Test if we can read the SPD */ dimm_mask = spd_detect_dimms(ctrl); if (!(dimm_mask & ((1 << DIMM_SOCKETS) - 1))) { - print_err("No memory for this cpu\n"); + printk(BIOS_ERR, "No memory for this cpu\n"); return; } return; @@ -520,16 +469,12 @@ static void set_on_dimm_termination_enable(const struct mem_controller *ctrl) data32 = 0x00002010; }
for (i = 0; i < 2; i++) { - print_debug("ODT CS"); - print_debug_hex8(i); - print_debug("\n"); + printk(BIOS_DEBUG, "ODT CS%d\n", i);
write32(BAR+DCALADDR, 0x0b840001); write32(BAR+DCALCSR, 0x80000003 | ((i+1)<<21)); @@ -544,14 +489,11 @@ static void dump_dcal_regs(void) int i; for (i = 0x0; i < 0x2a0; i += 4) { if ((i % 16) == 0) { - print_debug("\n"); - print_debug_hex16(i); - print_debug(": "); + printk(BIOS_DEBUG, "\n%04x: ", i); } - print_debug_hex32(read32(BAR+i)); - print_debug(" "); + printk(BIOS_DEBUG, "%08x ", read32(BAR+i)); } - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); }
@@ -565,7 +507,7 @@ static void sdram_enable(int controllers, const struct mem_controller *ctrl) u32 mode_reg;
/* Set DRAM type and Front Side Bus frequency */ drc = spd_set_dram_controller_mode(ctrl, mask); @@ -593,9 +535,7 @@ static void sdram_enable(int controllers, const struct mem_controller *ctrl)
/* Apply NOP */ for (cs = 0; cs < 2; cs++) { - print_debug("NOP CS"); - print_debug_hex8(cs); - print_debug("\n"); + printk(BIOS_DEBUG, "NOP CS%d\n", cs); udelay(16); write32(BAR+DCALCSR, (0x00000000 | ((cs+1)<<21))); write32(BAR+DCALCSR, (0x80000000 | ((cs+1)<<21))); @@ -606,9 +546,7 @@ static void sdram_enable(int controllers, const struct mem_controller *ctrl) /* Apply NOP */ udelay(16); for (cs = 0; cs < 2; cs++) { - print_debug("NOP CS"); - print_debug_hex8(cs); - print_debug("\n"); + printk(BIOS_DEBUG, "NOP CS%d\n", cs); write32(BAR + DCALCSR, (0x80000000 | ((cs+1)<<21))); do data32 = read32(BAR+DCALCSR); while (data32 & 0x80000000); @@ -617,9 +555,7 @@ static void sdram_enable(int controllers, const struct mem_controller *ctrl) /* Precharge all banks */ udelay(16); for (cs = 0; cs < 2; cs++) { - print_debug("Precharge CS"); - print_debug_hex8(cs); - print_debug("\n"); + printk(BIOS_DEBUG, "Precharge CS%d\n", cs); write32(BAR+DCALADDR, 0x04000000); write32(BAR+DCALCSR, (0x80000002 | ((cs+1)<<21))); do data32 = read32(BAR+DCALCSR); @@ -629,9 +565,7 @@ static void sdram_enable(int controllers, const struct mem_controller *ctrl) /* EMRS: Enable DLLs, set OCD calibration mode to default */ udelay(16); for (cs = 0; cs < 2; cs++) { - print_debug("EMRS CS"); - print_debug_hex8(cs); - print_debug("\n"); + printk(BIOS_DEBUG, "EMRS CS%d\n", cs); write32(BAR+DCALADDR, 0x0b840001); write32(BAR+DCALCSR, (0x80000003 | ((cs+1)<<21))); do data32 = read32(BAR+DCALCSR); @@ -640,9 +574,7 @@ static void sdram_enable(int controllers, const struct mem_controller *ctrl) /* MRS: Reset DLLs */ udelay(16); for (cs = 0; cs < 2; cs++) { - print_debug("MRS CS"); - print_debug_hex8(cs); - print_debug("\n"); + printk(BIOS_DEBUG, "MRS CS%d\n", cs); write32(BAR+DCALADDR, mode_reg); write32(BAR+DCALCSR, (0x80000003 | ((cs+1)<<21))); do data32 = read32(BAR+DCALCSR); @@ -652,9 +584,7 @@ static void sdram_enable(int controllers, const struct mem_controller *ctrl) /* Precharge all banks */ udelay(48); for (cs = 0; cs < 2; cs++) { - print_debug("Precharge CS"); - print_debug_hex8(cs); - print_debug("\n"); + printk(BIOS_DEBUG, "Precharge CS%d\n", cs); write32(BAR+DCALADDR, 0x04000000); write32(BAR+DCALCSR, (0x80000002 | ((cs+1)<<21))); do data32 = read32(BAR+DCALCSR); @@ -665,9 +595,7 @@ static void sdram_enable(int controllers, const struct mem_controller *ctrl) for (i = 0; i < 2; i++) { udelay(16); for (cs = 0; cs < 2; cs++) { - print_debug("Refresh CS"); - print_debug_hex8(cs); - print_debug("\n"); + printk(BIOS_DEBUG, "Refresh CS%d\n", cs); write32(BAR+DCALCSR, (0x80000001 | ((cs+1)<<21))); do data32 = read32(BAR+DCALCSR); while (data32 & 0x80000000); @@ -677,9 +605,7 @@ static void sdram_enable(int controllers, const struct mem_controller *ctrl) /* MRS: Set DLLs to normal */ udelay(16); for (cs = 0; cs < 2; cs++) { - print_debug("MRS CS"); - print_debug_hex8(cs); - print_debug("\n"); + printk(BIOS_DEBUG, "MRS CS%d\n", cs); write32(BAR+DCALADDR, (mode_reg & ~(1<<24))); write32(BAR+DCALCSR, (0x80000003 | ((cs+1)<<21))); do data32 = read32(BAR+DCALCSR); @@ -689,9 +615,7 @@ static void sdram_enable(int controllers, const struct mem_controller *ctrl) /* EMRS: Enable DLLs */ udelay(16); for (cs = 0; cs < 2; cs++) { - print_debug("EMRS CS"); - print_debug_hex8(cs); - print_debug("\n"); + printk(BIOS_DEBUG, "EMRS CS%d\n", cs); write32(BAR+DCALADDR, 0x0b840001); write32(BAR+DCALCSR, (0x80000003 | ((cs+1)<<21))); do data32 = read32(BAR+DCALCSR); @@ -712,9 +636,7 @@ static void sdram_enable(int controllers, const struct mem_controller *ctrl) /* Receive enable calibration */ udelay(16); for (cs = 0; cs < 1; cs++) { - print_debug("receive enable calibration CS"); - print_debug_hex8(cs); - print_debug("\n"); + printk(BIOS_DEBUG, "receive enable calibration CS%d\n", cs); write32(BAR+DCALCSR, (0x8000000c | ((cs+1)<<21))); do data32 = read32(BAR+DCALCSR); while (data32 & 0x80000000); @@ -738,18 +660,16 @@ static void sdram_enable(int controllers, const struct mem_controller *ctrl) for (cs = 0; cs < 2; cs++) { if (!(mask & (1<<cs))) continue; - print_debug("clear memory CS"); - print_debug_hex8(cs); - print_debug("\n"); + printk(BIOS_DEBUG, "clear memory CS%d\n", cs); write32(BAR+MBCSR, 0xa00000f0 | ((cs+1)<<20) | (0<<16)); do data32 = read32(BAR+MBCSR); while (data32 & 0x80000000); if (data32 & 0x40000000) - print_debug("failed!\n"); + printk(BIOS_DEBUG, "failed!\n"); }
/* Clear read/write FIFO pointers */ - print_debug("clear read/write fifo pointers\n"); + printk(BIOS_DEBUG, "clear read/write fifo pointers\n"); write32(BAR+DDRIOMC2, read32(BAR+DDRIOMC2) | (1<<15)); udelay(16); write32(BAR+DDRIOMC2, read32(BAR+DDRIOMC2) & ~(1<<15)); @@ -757,7 +677,7 @@ static void sdram_enable(int controllers, const struct mem_controller *ctrl)
dump_dcal_regs();
/* Set initialization complete */ drc |= (1 << 29); diff --git a/src/northbridge/intel/i440bx/debug.c b/src/northbridge/intel/i440bx/debug.c index ef9d513..efd4326 100644 --- a/src/northbridge/intel/i440bx/debug.c +++ b/src/northbridge/intel/i440bx/debug.c @@ -35,34 +35,18 @@ void dump_spd_registers(void) } }
-static void print_debug_pci_dev(unsigned dev) -{ - print_debug("PCI: "); - print_debug_hex8((dev >> 16) & 0xff); - print_debug_char(':'); - print_debug_hex8((dev >> 11) & 0x1f); - print_debug_char('.'); - print_debug_hex8((dev >> 8) & 7); -} - void dump_pci_device(unsigned dev) { int i; - print_debug_pci_dev(dev); - print_debug("\n"); + printk(BIOS_DEBUG, "PCI: %02x:%02x.%02x\n", (dev >> 20) & 0xff, (dev >> 15) & 0x1f, (dev >> 12) & 7);
for (i = 0; i <= 255; i++) { unsigned char val; - if ((i & 0x0f) == 0) { - print_debug_hex8(i); - print_debug_char(':'); - } val = pci_read_config8(dev, i); - print_debug_char(' '); - print_debug_hex8(val); - if ((i & 0x0f) == 0x0f) { - print_debug("\n"); - } + if ((i & 0x0f) == 0) + printk(BIOS_DEBUG, "%02x: %02x", i, val); + if ((i & 0x0f) == 0x0f) + printk(BIOS_DEBUG, "\n"); } } #endif diff --git a/src/northbridge/intel/i440bx/raminit.c b/src/northbridge/intel/i440bx/raminit.c index e3cfbdf..f191abe 100644 --- a/src/northbridge/intel/i440bx/raminit.c +++ b/src/northbridge/intel/i440bx/raminit.c @@ -752,7 +752,7 @@ static void set_dram_row_attributes(void) PRINT_DEBUG("Found DIMM in slot %d\n", i);
if (edo && sd) { - print_err("Mixing EDO/SDRAM unsupported!\n"); + printk(BIOS_ERR, "Mixing EDO/SDRAM unsupported!\n"); die("HALT\n"); }
@@ -857,11 +857,11 @@ static void set_dram_row_attributes(void) if (col == 4) bpr |= 0xc0; } else { - print_err("# of banks of DIMM unsupported!\n"); + printk(BIOS_ERR, "# of banks of DIMM unsupported!\n"); die("HALT\n"); } if (dra == -1) { - print_err("Page size not supported\n"); + printk(BIOS_ERR, "Page size not supported\n"); die("HALT\n"); }
@@ -872,7 +872,7 @@ static void set_dram_row_attributes(void) */ struct dimm_size sz = spd_get_dimm_size(device); if ((sz.side1 < 8)) { - print_err("DIMMs smaller than 8MB per side\n" + printk(BIOS_ERR, "DIMMs smaller than 8MB per side\n" "are not supported on this NB.\n"); die("HALT\n"); } diff --git a/src/northbridge/intel/i440lx/raminit.c b/src/northbridge/intel/i440lx/raminit.c index 7d283a1..ddabf25 100644 --- a/src/northbridge/intel/i440lx/raminit.c +++ b/src/northbridge/intel/i440lx/raminit.c @@ -32,10 +32,10 @@ Macros and definitions.
/* Debugging macros. */ #if CONFIG_DEBUG_RAM_SETUP -#define PRINT_DEBUG(x) print_debug(x) -#define PRINT_DEBUG_HEX8(x) print_debug_hex8(x) -#define PRINT_DEBUG_HEX16(x) print_debug_hex16(x) -#define PRINT_DEBUG_HEX32(x) print_debug_hex32(x) +#define PRINT_DEBUG(x) printk(BIOS_DEBUG, x) +#define PRINT_DEBUG_HEX8(x) printk(BIOS_DEBUG, "%02x", x) +#define PRINT_DEBUG_HEX16(x) printk(BIOS_DEBUG, "%04x", x) +#define PRINT_DEBUG_HEX32(x) printk(BIOS_DEBUG, "%08x", x) #define DUMPNORTH() dump_pci_device(PCI_DEV(0, 0, 0)) #else #define PRINT_DEBUG(x) diff --git a/src/northbridge/intel/i82810/debug.c b/src/northbridge/intel/i82810/debug.c index c3e4fb9..b74bb36 100644 --- a/src/northbridge/intel/i82810/debug.c +++ b/src/northbridge/intel/i82810/debug.c @@ -1,73 +1,52 @@ #include <console/console.h> #include <arch/io.h> #include <spd.h> -#include "i82810.h" #include "raminit.h" +#include <spd.h> +#include <console/console.h>
#if CONFIG_DEBUG_RAM_SETUP void dump_spd_registers(void) { int i; - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); for(i = 0; i < DIMM_SOCKETS; i++) { unsigned device; device = DIMM0 + i; if (device) { int j; - print_debug("dimm: "); - print_debug_hex8(i); - print_debug(".0: "); - print_debug_hex8(device); + printk(BIOS_DEBUG, "DIMM %d: %02x", i, device); for(j = 0; j < 256; j++) { int status; unsigned char byte; if ((j & 0xf) == 0) { - print_debug("\n"); - print_debug_hex8(j); - print_debug(": "); + printk(BIOS_DEBUG, "\n%02x: ", j); } status = smbus_read_byte(device, j); if (status < 0) { - print_debug("bad device\n"); + printk(BIOS_DEBUG, "bad device\n"); break; } byte = status & 0xff; - print_debug_hex8(byte); - print_debug_char(' '); + printk(BIOS_DEBUG, "%02x ", byte); } - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); } } }
for (i = 0; i <= 255; i++) { unsigned char val; - if ((i & 0x0f) == 0) { - print_debug_hex8(i); - print_debug_char(':'); - } val = pci_read_config8(dev, i); - print_debug_char(' '); - print_debug_hex8(val); - if ((i & 0x0f) == 0x0f) { - print_debug("\n"); - } + if ((i & 0x0f) == 0) + printk(BIOS_DEBUG, "%02x: %02x", i, val); + if ((i & 0x0f) == 0x0f) + printk(BIOS_DEBUG, "\n"); } } #endif diff --git a/src/northbridge/intel/i855/debug.c b/src/northbridge/intel/i855/debug.c index 327f47d..ed26fad 100644 --- a/src/northbridge/intel/i855/debug.c +++ b/src/northbridge/intel/i855/debug.c @@ -22,12 +22,8 @@
static void print_debug_pci_dev(unsigned dev) { - print_debug("PCI: "); - print_debug_hex8((dev >> 20) & 0xff); - print_debug_char(':'); - print_debug_hex8((dev >> 15) & 0x1f); - print_debug_char('.'); - print_debug_hex8((dev >> 12) & 0x07); + printk(BIOS_DEBUG, "PCI: %02x:%02x.%x", + (dev >> 20) & 0xff, (dev >> 15) & 0x1f, (dev >> 12) & 0x07); }
static inline void print_pci_devices(void) @@ -44,7 +40,7 @@ static inline void print_pci_devices(void) continue; } print_debug_pci_dev(dev); - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); } }
@@ -52,20 +48,16 @@ static void dump_pci_device(unsigned dev) { int i; print_debug_pci_dev(dev); - print_debug("\n"); + printk(BIOS_DEBUG, "\n");
for(i = 0; i <= 255; i++) { unsigned char val; - if ((i & 0x0f) == 0) { - print_debug_hex8(i); - print_debug_char(':'); - } + if ((i & 0x0f) == 0) + printk(BIOS_DEBUG, "%02x:", i); val = pci_read_config8(dev, i); - print_debug_char(' '); - print_debug_hex8(val); - if ((i & 0x0f) == 0x0f) { - print_debug("\n"); - } + printk(BIOS_DEBUG, " %02x", val); + if ((i & 0x0f) == 0x0f) + printk(BIOS_DEBUG, "\n"); } }
@@ -89,34 +81,27 @@ static inline void dump_pci_devices(void) static inline void dump_spd_registers(void) { int i; - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); for(i = 0; i < 2; i++) { unsigned device; device = DIMM0 + i; if (device) { int j; - print_debug("dimm: "); - print_debug_hex8(i); - print_debug(".0: "); - print_debug_hex8(device); + printk(BIOS_DEBUG, "dimm: %02x.0: %02x", i, device); for(j = 0; j < 256; j++) { int status; unsigned char byte; - if ((j & 0xf) == 0) { - print_debug("\n"); - print_debug_hex8(j); - print_debug(": "); - } + if ((j & 0xf) == 0) + printk(BIOS_DEBUG, "\n%02x: ", j); status = smbus_read_byte(device, j); if (status < 0) { - print_debug("bad device\n"); + printk(BIOS_DEBUG, "bad device\n"); break; } byte = status & 0xff; - print_debug_hex8(byte); - print_debug_char(' '); + printk(BIOS_DEBUG, "%02x ", byte); } - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); } } } @@ -124,30 +109,25 @@ static inline void dump_spd_registers(void) static inline void dump_smbus_registers(void) { int i; - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); for(i = 1; i < 0x80; i++) { unsigned device; device = i; int j; - print_debug("smbus: "); - print_debug_hex8(device); + printk(BIOS_DEBUG, "smbus: %02x", device); for(j = 0; j < 256; j++) { int status; unsigned char byte; - if ((j & 0xf) == 0) { - print_debug("\n"); - print_debug_hex8(j); - print_debug(": "); - } + if ((j & 0xf) == 0) + printk(BIOS_DEBUG, "\n%02x: ", j); status = smbus_read_byte(device, j); if (status < 0) { - print_debug("bad device\n"); + printk(BIOS_DEBUG, "bad device\n"); break; } byte = status & 0xff; - print_debug_hex8(byte); - print_debug_char(' '); + printk(BIOS_DEBUG, "%02x ", byte); } - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); } } diff --git a/src/northbridge/intel/i855/raminit.c b/src/northbridge/intel/i855/raminit.c index 0ab4d38..39e12d2 100644 --- a/src/northbridge/intel/i855/raminit.c +++ b/src/northbridge/intel/i855/raminit.c @@ -415,7 +415,7 @@ static void sdram_enable(void) { int i;
- print_debug("Ram enable 1\n"); + printk(BIOS_DEBUG, "Ram enable 1\n"); delay(); delay();
@@ -433,16 +433,16 @@ static void sdram_enable(void) delay(); delay();
- print_debug("Ram enable 4\n"); + printk(BIOS_DEBUG, "Ram enable 4\n"); do_ram_command(RAM_COMMAND_EMRS, SDRAM_EXTMODE_DLL_ENABLE); delay(); delay(); delay();
- print_debug("Ram enable 5\n"); + printk(BIOS_DEBUG, "Ram enable 5\n"); do_ram_command(RAM_COMMAND_MRS, VG85X_MODE | SDRAM_MODE_DLL_RESET);
- print_debug("Ram enable 6\n"); + printk(BIOS_DEBUG, "Ram enable 6\n"); do_ram_command(RAM_COMMAND_PRECHARGE, 0); delay(); delay(); @@ -457,7 +457,7 @@ static void sdram_enable(void) delay(); }
- print_debug("Ram enable 8\n"); + printk(BIOS_DEBUG, "Ram enable 8\n"); do_ram_command(RAM_COMMAND_MRS, VG85X_MODE | SDRAM_MODE_NORMAL);
/* Set GME-M Mode Select bits back to NORMAL operation mode */ @@ -467,7 +467,7 @@ static void sdram_enable(void) delay(); delay();
- print_debug("Ram enable 9\n"); + printk(BIOS_DEBUG, "Ram enable 9\n"); set_initialize_complete();
delay(); @@ -476,11 +476,11 @@ static void sdram_enable(void) delay(); delay();
- print_debug("After configuration:\n"); + printk(BIOS_DEBUG, "After configuration:\n"); /* dump_pci_devices(); */
/* - print_debug("\n\n***** RAM TEST *****\n"); + printk(BIOS_DEBUG, "\n\n***** RAM TEST *****\n"); ram_check(0, 0xa0000); ram_check(0x100000, 0x40000000); */ @@ -497,7 +497,7 @@ DIMM-independant configuration functions: static void sdram_set_registers(void) { /* - print_debug("Before configuration:\n"); + printk(BIOS_DEBUG, "Before configuration:\n"); dump_pci_devices(); */ } @@ -572,13 +572,13 @@ static void spd_set_dram_controller_mode(uint8_t dimm_mask) die_on_spd_error(value); value &= 0x7f; // Mask off self-refresh bit if (value > MAX_SPD_REFRESH_RATE) { - print_err("unsupported refresh rate\n"); + printk(BIOS_ERR, "unsupported refresh rate\n"); continue; } // Get the appropriate i855 refresh mode for this DIMM dimm_refresh_mode = refresh_rate_map[value]; if (dimm_refresh_mode > 7) { - print_err("unsupported refresh rate\n"); + printk(BIOS_ERR, "unsupported refresh rate\n"); continue; } // If this DIMM requires more frequent refresh than others, @@ -965,7 +965,7 @@ static void sdram_set_spd_registers(void) dimm_mask = spd_get_supported_dimms();
if (dimm_mask == 0) { - print_debug("No usable memory for this controller\n"); + printk(BIOS_DEBUG, "No usable memory for this controller\n"); } else { PRINTK_DEBUG("DIMM MASK: %02x\n", dimm_mask);
diff --git a/src/northbridge/intel/i945/debug.c b/src/northbridge/intel/i945/debug.c index e47f762..397bd4b 100644 --- a/src/northbridge/intel/i945/debug.c +++ b/src/northbridge/intel/i945/debug.c @@ -109,12 +109,12 @@ void dump_spd_registers(void) void dump_mem(unsigned start, unsigned end) { unsigned i; - print_debug("dump_mem:"); + printk(BIOS_DEBUG, "dump_mem:"); for(i=start;i<end;i++) { if((i & 0xf)==0) { printk(BIOS_DEBUG, "\n%08x:", i); } printk(BIOS_DEBUG, " %02x", (unsigned char)*((unsigned char *)i)); } - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); } diff --git a/src/northbridge/via/cn700/raminit.c b/src/northbridge/via/cn700/raminit.c index 0103c4f..747cbfd 100644 --- a/src/northbridge/via/cn700/raminit.c +++ b/src/northbridge/via/cn700/raminit.c @@ -25,10 +25,10 @@ #include "cn700.h"
#if CONFIG_DEBUG_RAM_SETUP -#define PRINT_DEBUG_MEM(x) print_debug(x) -#define PRINT_DEBUG_MEM_HEX8(x) print_debug_hex8(x) -#define PRINT_DEBUG_MEM_HEX16(x) print_debug_hex16(x) -#define PRINT_DEBUG_MEM_HEX32(x) print_debug_hex32(x) +#define PRINT_DEBUG_MEM(x) printk(BIOS_DEBUG, x) +#define PRINT_DEBUG_MEM_HEX8(x) printk(BIOS_DEBUG, "%02x", x) +#define PRINT_DEBUG_MEM_HEX16(x) printk(BIOS_DEBUG, "%04x", x) +#define PRINT_DEBUG_MEM_HEX32(x) printk(BIOS_DEBUG, "%08x", x) #define DUMPNORTH() dump_pci_device(PCI_DEV(0, 0, 0)) #else #define PRINT_DEBUG_MEM(x) diff --git a/src/northbridge/via/cn700/vga.c b/src/northbridge/via/cn700/vga.c index 4434e57..4826fcf 100644 --- a/src/northbridge/via/cn700/vga.c +++ b/src/northbridge/via/cn700/vga.c @@ -84,7 +84,7 @@ static void vga_init(device_t dev)
#undef OLD_BOCHS_METHOD #ifdef OLD_BOCHS_METHOD - print_debug("Copying BOCHS BIOS to 0xf000\n"); + printk(BIOS_DEBUG, "Copying BOCHS BIOS to 0xf000\n"); /* * Copy BOCHS BIOS from 4G-CONFIG_ROM_SIZE-64k (in flash) to 0xf0000 (in RAM) * This is for compatibility with the VGA ROM's BIOS callbacks. diff --git a/src/northbridge/via/cx700/early_smbus.c b/src/northbridge/via/cx700/early_smbus.c index 7c77bff..39e1753 100644 --- a/src/northbridge/via/cx700/early_smbus.c +++ b/src/northbridge/via/cx700/early_smbus.c @@ -46,15 +46,6 @@
#define SMBUS_DELAY() outb(0x80, 0x80)
-/* Debugging macros. */ -#if CONFIG_DEBUG_SMBUS -#define PRINT_DEBUG(x) print_debug(x) -#define PRINT_DEBUG_HEX16(x) print_debug_hex16(x) -#else -#define PRINT_DEBUG(x) -#define PRINT_DEBUG_HEX16(x) -#endif - /* Internal functions */ #if CONFIG_DEBUG_SMBUS static void smbus_print_error(unsigned char host_status_register, int loops) @@ -63,28 +54,26 @@ static void smbus_print_error(unsigned char host_status_register, int loops) if (host_status_register == 0x00 || host_status_register == 0x40 || host_status_register == 0x42) return; - print_err("SMBus Error: "); - print_err_hex8(host_status_register); + printk(BIOS_ERR, "SMBus Error: %02x\n", host_status_register);
- print_err("\n"); if (loops >= SMBUS_TIMEOUT) { - print_err("SMBus Timout\n"); + printk(BIOS_ERR, "SMBus Timout\n"); } if (host_status_register & (1 << 4)) { - print_err("Interrup/SMI# was Failed Bus Transaction\n"); + printk(BIOS_ERR, "Interrup/SMI# was Failed Bus Transaction\n"); } if (host_status_register & (1 << 3)) { - print_err("Bus Error\n"); + printk(BIOS_ERR, "Bus Error\n"); } if (host_status_register & (1 << 2)) { - print_err("Device Error\n"); + printk(BIOS_ERR, "Device Error\n"); } if (host_status_register & (1 << 1)) { /* This isn't a real error... */ - print_debug("Interrupt/SMI# was Successful Completion\n"); + printk(BIOS_DEBUG, "Interrupt/SMI# was Successful Completion\n"); } if (host_status_register & (1 << 0)) { - print_err("Host Busy\n"); + printk(BIOS_ERR, "Host Busy\n"); } } #endif @@ -239,9 +228,7 @@ static void dump_spd_data(const struct mem_controller *ctrl) unsigned int val;
for (dimm = 0; dimm < DIMM_SOCKETS; dimm++) { - print_debug("SPD Data for DIMM "); - print_debug_hex8(dimm); - print_debug("\n"); + printk(BIOS_DEBUG, "SPD Data for DIMM %02x\n", dimm);
val = get_spd_data(ctrl, dimm, 0); if (val == 0xff) { @@ -249,15 +236,12 @@ static void dump_spd_data(const struct mem_controller *ctrl) } else if (val == 0x80) { regs = 128; } else { - print_debug("No DIMM present\n"); + printk(BIOS_DEBUG, "No DIMM present\n"); regs = 0; } for (offset = 0; offset < regs; offset++) { - print_debug(" Offset "); - print_debug_hex8(offset); - print_debug(" = 0x"); - print_debug_hex8(get_spd_data(ctrl, dimm, offset)); - print_debug("\n"); + printk(BIOS_DEBUG, " Offset %02x = 0x%02x\n", + offset, get_spd_data(ctrl, dimm, offset)); } } } diff --git a/src/northbridge/via/cx700/raminit.c b/src/northbridge/via/cx700/raminit.c index a2e6dad..32be1ea 100644 --- a/src/northbridge/via/cx700/raminit.c +++ b/src/northbridge/via/cx700/raminit.c @@ -972,7 +972,7 @@ static void step_20_21(const struct mem_controller *ctrl) read32(0x102020);
/* Step 21. Normal operation */ - print_spew("RAM Enable 5: Normal operation\n"); + printk(BIOS_SPEW, "RAM Enable 5: Normal operation\n"); do_ram_command(ctrl, RAM_COMMAND_NORMAL); udelay(3); } @@ -988,58 +988,58 @@ static void step_2_19(const struct mem_controller *ctrl) pci_write_config8(MEMCTRL, 0x69, val);
/* Step 3 Apply NOP. */ - print_spew("RAM Enable 1: Apply NOP\n"); + printk(BIOS_SPEW, "RAM Enable 1: Apply NOP\n"); do_ram_command(ctrl, RAM_COMMAND_NOP);
udelay(15);
// Step 4 - print_spew("SEND: "); + printk(BIOS_SPEW, "SEND: "); read32(0); - print_spew("OK\n"); + printk(BIOS_SPEW, "OK\n");
// Step 5 udelay(400);
/* 6. Precharge all. Wait tRP. */ - print_spew("RAM Enable 2: Precharge all\n"); + printk(BIOS_SPEW, "RAM Enable 2: Precharge all\n"); do_ram_command(ctrl, RAM_COMMAND_PRECHARGE);
// Step 7 - print_spew("SEND: "); + printk(BIOS_SPEW, "SEND: "); read32(0); - print_spew("OK\n"); + printk(BIOS_SPEW, "OK\n");
/* Step 8. Mode register set. */ - print_spew("RAM Enable 4: Mode register set\n"); + printk(BIOS_SPEW, "RAM Enable 4: Mode register set\n"); do_ram_command(ctrl, RAM_COMMAND_MRS); //enable dll
// Step 9 - print_spew("SEND: "); + printk(BIOS_SPEW, "SEND: ");
val = pci_read_config8(PCI_DEV(0, 0, 4), SCRATCH_DRAM_NB_ODT); if (val & DDR2_ODT_150ohm) read32(0x102200); //DDR2_ODT_150ohm else read32(0x102020); - print_spew("OK\n"); + printk(BIOS_SPEW, "OK\n");
// Step 10 - print_spew("SEND: "); + printk(BIOS_SPEW, "SEND: "); read32(0x800); - print_spew("OK\n"); + printk(BIOS_SPEW, "OK\n");
/* Step 11. Precharge all. Wait tRP. */ - print_spew("RAM Enable 2: Precharge all\n"); + printk(BIOS_SPEW, "RAM Enable 2: Precharge all\n"); do_ram_command(ctrl, RAM_COMMAND_PRECHARGE);
// Step 12 - print_spew("SEND: "); + printk(BIOS_SPEW, "SEND: "); read32(0x0); - print_spew("OK\n"); + printk(BIOS_SPEW, "OK\n");
/* Step 13. Perform 8 refresh cycles. Wait tRC each time. */ - print_spew("RAM Enable 3: CBR\n"); + printk(BIOS_SPEW, "RAM Enable 3: CBR\n"); do_ram_command(ctrl, RAM_COMMAND_CBR);
/* JEDEC says only twice, do 8 times for posterity */ @@ -1047,14 +1047,14 @@ static void step_2_19(const struct mem_controller *ctrl) for (i = 0; i < 8; i++) { // Step 14 read32(0); - print_spew("."); + printk(BIOS_SPEW, ".");
// Step 15 udelay(100); }
/* Step 17. Mode register set. Wait 200us. */ - print_spew("\nRAM Enable 4: Mode register set\n"); + printk(BIOS_SPEW, "\nRAM Enable 4: Mode register set\n");
//safe value for now, BL=8, WR=4, CAS=4 do_ram_command(ctrl, RAM_COMMAND_MRS); diff --git a/src/northbridge/via/vx800/early_smbus.c b/src/northbridge/via/vx800/early_smbus.c index f9b13eb..da2a559 100644 --- a/src/northbridge/via/vx800/early_smbus.c +++ b/src/northbridge/via/vx800/early_smbus.c @@ -50,42 +50,38 @@ #define SMBUS_DELAY() outb(0x80, 0x80)
#if CONFIG_DEBUG_SMBUS -#define PRINT_DEBUG(x) print_debug(x) -#define PRINT_DEBUG_HEX16(x) print_debug_hex16(x) +#define DEBUG(x...) printk(BIOS_DEBUG, x) #else -#define PRINT_DEBUG(x) -#define PRINT_DEBUG_HEX16(x) +#define DEBUG(x...) while (0) { } #endif
/* Internal functions */ static void smbus_print_error(unsigned char host_status_register, int loops) { -// print_err("some i2c error\n"); +// printk(BIOS_ERR, "some i2c error\n"); /* Check if there actually was an error */ if (host_status_register == 0x00 || host_status_register == 0x40 || host_status_register == 0x42) return; - print_err("smbus_error: "); - print_err_hex8(host_status_register); - print_err("\n"); + printk(BIOS_ERR, "smbus_error: %02x\n", host_status_register); if (loops >= SMBUS_TIMEOUT) { - print_err("SMBus Timout\n"); + printk(BIOS_ERR, "SMBus Timout\n"); } if (host_status_register & (1 << 4)) { - print_err("Interrup/SMI# was Failed Bus Transaction\n"); + printk(BIOS_ERR, "Interrup/SMI# was Failed Bus Transaction\n"); } if (host_status_register & (1 << 3)) { - print_err("Bus Error\n"); + printk(BIOS_ERR, "Bus Error\n"); } if (host_status_register & (1 << 2)) { - print_err("Device Error\n"); + printk(BIOS_ERR, "Device Error\n"); } if (host_status_register & (1 << 1)) { /* This isn't a real error... */ - print_debug("Interrupt/SMI# was Successful Completion\n"); + printk(BIOS_DEBUG, "Interrupt/SMI# was Successful Completion\n"); } if (host_status_register & (1 << 0)) { - print_err("Host Busy\n"); + printk(BIOS_ERR, "Host Busy\n"); } }
@@ -185,11 +181,11 @@ void smbus_fixup(const struct mem_controller *mem_ctrl)
ram_slots = ARRAY_SIZE(mem_ctrl->channel0); if (!ram_slots) { - print_err("smbus_fixup() thinks there are no RAM slots!\n"); + printk(BIOS_ERR, "smbus_fixup() thinks there are no RAM slots!\n"); return; }
- PRINT_DEBUG("Waiting for SMBus to warm up"); + DEBUG("Waiting for SMBus to warm up");
/* * Bad SPD data should be either 0 or 0xff, but YMMV. So we look for @@ -207,13 +203,13 @@ void smbus_fixup(const struct mem_controller *mem_ctrl) result = get_spd_data(mem_ctrl->channel0[current_slot], SPD_MEMORY_TYPE); current_slot++; - PRINT_DEBUG("."); + DEBUG("."); }
if (i >= SMBUS_TIMEOUT) - print_err("SMBus timed out while warming up\n"); + printk(BIOS_ERR, "SMBus timed out while warming up\n"); else - PRINT_DEBUG("Done\n"); + DEBUG("Done\n"); }
/* Debugging Function */ @@ -224,9 +220,7 @@ static void dump_spd_data(void) unsigned int val;
for (dimm = 0; dimm < 8; dimm++) { - print_debug("SPD Data for DIMM "); - print_debug_hex8(dimm); - print_debug("\n"); + printk(BIOS_DEBUG, "SPD Data for DIMM %02x\n", dimm);
val = get_spd_data(dimm, 0); if (val == 0xff) { @@ -234,16 +228,12 @@ static void dump_spd_data(void) } else if (val == 0x80) { regs = 128; } else { - print_debug("No DIMM present\n"); + printk(BIOS_DEBUG, "No DIMM present\n"); regs = 0; } - for (offset = 0; offset < regs; offset++) { - print_debug(" Offset "); - print_debug_hex8(offset); - print_debug(" = 0x"); - print_debug_hex8(get_spd_data(dimm, offset)); - print_debug("\n"); - } + for (offset = 0; offset < regs; offset++) + printk(BIOS_DEBUG, " Offset %02x = 0x%02x\n", + offset, get_spd_data(dimm, offset)); } } #else diff --git a/src/northbridge/via/vx800/raminit.c b/src/northbridge/via/vx800/raminit.c index 6d58f78..a7a5757 100644 --- a/src/northbridge/via/vx800/raminit.c +++ b/src/northbridge/via/vx800/raminit.c @@ -29,10 +29,10 @@ #endif
#if CONFIG_DEBUG_RAM_SETUP -#define PRINT_DEBUG_MEM(x) print_debug(x) -#define PRINT_DEBUG_MEM_HEX8(x) print_debug_hex8(x) -#define PRINT_DEBUG_MEM_HEX16(x) print_debug_hex16(x) -#define PRINT_DEBUG_MEM_HEX32(x) print_debug_hex32(x) +#define PRINT_DEBUG_MEM(x) printk(BIOS_DEBUG, x) +#define PRINT_DEBUG_MEM_HEX8(x) printk(BIOS_DEBUG, "%02x", x) +#define PRINT_DEBUG_MEM_HEX16(x) printk(BIOS_DEBUG, "%04x", x) +#define PRINT_DEBUG_MEM_HEX32(x) printk(BIOS_DEBUG, "%08x", x) #define DUMPNORTH() dump_pci_device(PCI_DEV(0, 0, 0)) #else #define PRINT_DEBUG_MEM(x) diff --git a/src/northbridge/via/vx900/chrome9hd.c b/src/northbridge/via/vx900/chrome9hd.c index b9fed6f..78a1a88 100644 --- a/src/northbridge/via/vx900/chrome9hd.c +++ b/src/northbridge/via/vx900/chrome9hd.c @@ -296,9 +296,9 @@ static void chrome9hd_biosguide_init_seq(device_t dev)
static void chrome9hd_init(device_t dev) { - print_debug("======================================================\n"); - print_debug("== Chrome9 HD INIT\n"); - print_debug("======================================================\n"); + printk(BIOS_DEBUG, "======================================================\n"); + printk(BIOS_DEBUG, "== Chrome9 HD INIT\n"); + printk(BIOS_DEBUG, "======================================================\n");
chrome9hd_biosguide_init_seq(dev);
diff --git a/src/northbridge/via/vx900/early_smbus.c b/src/northbridge/via/vx900/early_smbus.c index f006ce4..e796d8d 100644 --- a/src/northbridge/via/vx900/early_smbus.c +++ b/src/northbridge/via/vx900/early_smbus.c @@ -182,13 +182,13 @@ void dump_spd_data(spd_raw_data spd) * I originally saw this way to present SPD data in code from VIA. I * really liked the idea, so here it goes. */ - print_debug(" 00 01 02 03 04 05 06 07 07 09 0A 0B 0C 0D 0E 0F\n"); - print_debug("---+------------------------------------------------"); + printk(BIOS_DEBUG, " 00 01 02 03 04 05 06 07 07 09 0A 0B 0C 0D 0E 0F\n"); + printk(BIOS_DEBUG, "---+------------------------------------------------"); for (i = 0; i < len; i++) { reg = spd[i]; if ((i & 0x0f) == 0) printk(BIOS_DEBUG, "\n%.2x |", i); printk(BIOS_DEBUG, " %.2x", reg); } - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); } diff --git a/src/northbridge/via/vx900/early_vx900.c b/src/northbridge/via/vx900/early_vx900.c index 2896680..425fe77 100644 --- a/src/northbridge/via/vx900/early_vx900.c +++ b/src/northbridge/via/vx900/early_vx900.c @@ -69,7 +69,7 @@ void vx900_print_strapping_info(void) { u8 strap = pci_read_config8(SNMIC, 0x56);
- print_debug("VX900 strapping pins indicate that:\n"); + printk(BIOS_DEBUG, "VX900 strapping pins indicate that:\n"); printk(BIOS_DEBUG, " ROM is on %s bus\n", (strap & (1 << 0)) ? "SPI" : "LPC"); printk(BIOS_DEBUG, " Auto reset is %s\n", @@ -92,13 +92,13 @@ void vx900_print_strapping_info(void) void vx900_disable_auto_reboot(void) { if (pci_read_config8(SNMIC, 0x56) & (1 << 1)) { - print_debug("Auto-reboot is disabled in hardware\n"); + printk(BIOS_DEBUG, "Auto-reboot is disabled in hardware\n"); return; } /* Disable the GP3 timer, which is the root of all evil */ pci_write_config8(LPC, 0x98, 0); /* Yep, that's all it takes */ - print_debug("GP3 timer disabled." + printk(BIOS_DEBUG, "GP3 timer disabled." " Auto-reboot should not give you any more trouble.\n"); }
diff --git a/src/northbridge/via/vx900/lpc.c b/src/northbridge/via/vx900/lpc.c index ac5e4c8..bb2f1b2 100644 --- a/src/northbridge/via/vx900/lpc.c +++ b/src/northbridge/via/vx900/lpc.c @@ -146,7 +146,7 @@ static void vx900_lpc_ioapic_setup(device_t dev) return; }
- print_debug("VX900 LPC: Setting up the south module IOAPIC.\n"); + printk(BIOS_DEBUG, "VX900 LPC: Setting up the south module IOAPIC.\n"); /* Enable IOAPIC * So much work for one line of code. Talk about bloat :) * The 8259 PIC should still work even if the IOAPIC is enabled, so diff --git a/src/northbridge/via/vx900/northbridge.c b/src/northbridge/via/vx900/northbridge.c index f9c225d..e1f744c 100644 --- a/src/northbridge/via/vx900/northbridge.c +++ b/src/northbridge/via/vx900/northbridge.c @@ -80,7 +80,7 @@ static u64 vx900_get_top_of_ram(device_t mcu) static void killme_debug_4g_remap_reg(u32 reg32) { if (reg32 & (1 << 0)) - print_debug("Mem remapping enabled\n"); + printk(BIOS_DEBUG, "Mem remapping enabled\n"); u64 remapstart = (reg32 >> 2) & 0x3ff; u64 remapend = (reg32 >> 14) & 0x3ff; remapstart <<= 26; @@ -122,7 +122,7 @@ static u64 vx900_remap_above_4g(device_t mcu, u32 tolm) * becomes accessible at "to" to "until" */ if (tolm >= vx900_get_top_of_ram(mcu)) { - print_debug("Nothing to remap\n"); + printk(BIOS_DEBUG, "Nothing to remap\n"); }
/* This is how the Vendor BIOS. Keep it for comparison for now */ @@ -220,11 +220,11 @@ static void vx900_set_resources(device_t dev) { u32 pci_tolm, tomk, vx900_tolm, full_tolmk, fbufk, tolmk;
- print_debug("========================================" + printk(BIOS_DEBUG, "========================================" "========================================\n"); - print_debug("============= VX900 memory sizing & Co. " + printk(BIOS_DEBUG, "============= VX900 memory sizing & Co. " "========================================\n"); - print_debug("========================================" + printk(BIOS_DEBUG, "========================================" "========================================\n");
int idx = 10; @@ -282,7 +282,7 @@ static void vx900_set_resources(device_t dev)
set_top_of_ram(tolmk << 10);
- print_debug("======================================================\n"); + printk(BIOS_DEBUG, "======================================================\n"); assign_resources(dev->link_list); }
diff --git a/src/northbridge/via/vx900/pcie.c b/src/northbridge/via/vx900/pcie.c index 109e5c9..b748c39 100644 --- a/src/northbridge/via/vx900/pcie.c +++ b/src/northbridge/via/vx900/pcie.c @@ -72,11 +72,11 @@ static void vx900_pcie_link_init(device_t dev)
pci_write_config8(dev, 0xa4, 0xff); if (pci_read_config8(dev, 0x4a) & (1 << 3)) - print_debug("Unsupported request detected.\n"); + printk(BIOS_DEBUG, "Unsupported request detected.\n");
pci_write_config8(dev, 0x15a, 0xff); if (pci_read_config8(dev, 0x15a) & (1 << 1)) - print_debug("Negotiation pending.\n"); + printk(BIOS_DEBUG, "Negotiation pending.\n");
/* Step 4: Read vendor ID */ /* FIXME: Do we want to run through the whole sequence and delay boot diff --git a/src/northbridge/via/vx900/raminit_ddr3.c b/src/northbridge/via/vx900/raminit_ddr3.c index e6dace3..d1b2beb 100644 --- a/src/northbridge/via/vx900/raminit_ddr3.c +++ b/src/northbridge/via/vx900/raminit_ddr3.c @@ -1512,7 +1512,7 @@ static void vx900_dram_range(ramctr_timing * ctrl, rank_layout * ranks) /* vvvvvvvvvv FIXME: Fix odd rank init vvvvvvvvvv */ if ((i & 1)) { printk(BIOS_EMERG, "I cannot initialize rank %zu\n", i); - print_emerg("I have to disable it\n"); + printk(BIOS_EMERG, "I have to disable it\n"); continue; } /* ^^^^^^^^^^ FIXME: Fix odd rank init ^^^^^^^^^^ */ diff --git a/src/northbridge/via/vx900/sata.c b/src/northbridge/via/vx900/sata.c index 63295e5..c5f36a8 100644 --- a/src/northbridge/via/vx900/sata.c +++ b/src/northbridge/via/vx900/sata.c @@ -44,47 +44,47 @@ static void vx900_print_sata_errors(u32 flags) (flags & (1 << 27)) ? "detected" : "not detected"); /* Errors */ if (flags & (1 << 0)) - print_debug("\tRecovered data integrity ERROR\n"); + printk(BIOS_DEBUG, "\tRecovered data integrity ERROR\n"); if (flags & (1 << 1)) - print_debug("\tRecovered data communication ERROR\n"); + printk(BIOS_DEBUG, "\tRecovered data communication ERROR\n"); if (flags & (1 << 8)) - print_debug("\tNon-recovered Transient Data Integrity ERROR\n"); + printk(BIOS_DEBUG, "\tNon-recovered Transient Data Integrity ERROR\n"); if (flags & (1 << 9)) - print_debug("\tNon-recovered Persistent Communication or" + printk(BIOS_DEBUG, "\tNon-recovered Persistent Communication or" "\tData Integrity ERROR\n"); if (flags & (1 << 10)) - print_debug("\tProtocol ERROR\n"); + printk(BIOS_DEBUG, "\tProtocol ERROR\n"); if (flags & (1 << 11)) - print_debug("\tInternal ERROR\n"); + printk(BIOS_DEBUG, "\tInternal ERROR\n"); if (flags & (1 << 17)) - print_debug("\tPHY Internal ERROR\n"); + printk(BIOS_DEBUG, "\tPHY Internal ERROR\n"); if (flags & (1 << 19)) - print_debug("\t10B to 8B Decode ERROR\n"); + printk(BIOS_DEBUG, "\t10B to 8B Decode ERROR\n"); if (flags & (1 << 20)) - print_debug("\tDisparity ERROR\n"); + printk(BIOS_DEBUG, "\tDisparity ERROR\n"); if (flags & (1 << 21)) - print_debug("\tCRC ERROR\n"); + printk(BIOS_DEBUG, "\tCRC ERROR\n"); if (flags & (1 << 22)) - print_debug("\tHandshake ERROR\n"); + printk(BIOS_DEBUG, "\tHandshake ERROR\n"); if (flags & (1 << 23)) - print_debug("\tLink Sequence ERROR\n"); + printk(BIOS_DEBUG, "\tLink Sequence ERROR\n"); if (flags & (1 << 24)) - print_debug("\tTransport State Transition ERROR\n"); + printk(BIOS_DEBUG, "\tTransport State Transition ERROR\n"); if (flags & (1 << 25)) - print_debug("\tUNRECOGNIZED FIS type\n"); + printk(BIOS_DEBUG, "\tUNRECOGNIZED FIS type\n"); }
static void vx900_dbg_sata_errors(device_t dev) { /* Port 0 */ if (pci_read_config8(dev, 0xa0) & (1 << 0)) { - print_debug("Device detected in SATA port 0.\n"); + printk(BIOS_DEBUG, "Device detected in SATA port 0.\n"); u32 flags = pci_read_config32(dev, 0xa8); vx900_print_sata_errors(flags); }; /* Port 1 */ if (pci_read_config8(dev, 0xa1) & (1 << 0)) { - print_debug("Device detected in SATA port 1.\n"); + printk(BIOS_DEBUG, "Device detected in SATA port 1.\n"); u32 flags = pci_read_config32(dev, 0xac); vx900_print_sata_errors(flags); }; @@ -147,21 +147,18 @@ static void vx900_sata_write_phy_config(device_t dev, sata_phy_config cfg)
static void vx900_sata_dump_phy_config(sata_phy_config cfg) { - print_debug("SATA PHY config:\n"); + printk(BIOS_DEBUG, "SATA PHY config:\n"); int i; for (i = 0; i < sizeof(sata_phy_config); i++) { unsigned char val; - if ((i & 0x0f) == 0) { - print_debug_hex8(i); - print_debug_char(':'); - } + if ((i & 0x0f) == 0) + printk(BIOS_DEBUG, "%02x:", i); val = cfg[i]; if ((i & 7) == 0) - print_debug(" |"); - print_debug_char(' '); - print_debug_hex8(val); + printk(BIOS_DEBUG, " |"); + printk(BIOS_DEBUG, " %02x", val); if ((i & 0x0f) == 0x0f) { - print_debug("\n"); + printk(BIOS_DEBUG, "\n"); } } }
