Lean Sheng Tan has submitted this change. ( https://review.coreboot.org/c/coreboot/+/68892 )
23 is the latest approved patch-set. No files were changed between the latest approved patch-set and the submitted one. )Change subject: cpu/mp_init.c: Only enable CPUs once they execute code ......................................................................
On some systems the BSP cannot know how many CPUs are present in the system. A typical use case is a multi socket system. Setting the enable flag only on CPUs that actually exist makes it more flexible.
Change-Id: I6c8042b4d6127239175924f996f735bf9c83c6e8 Signed-off-by: Arthur Heymans arthur@aheymans.xyz Reviewed-on: https://review.coreboot.org/c/coreboot/+/68892 Reviewed-by: Angel Pons th3fanbus@gmail.com Reviewed-by: Patrick Rudolph siro@das-labor.org Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/cpu/x86/mp_init.c 1 file changed, 20 insertions(+), 0 deletions(-)
Approvals: build bot (Jenkins): Verified Patrick Rudolph: Looks good to me, approved Angel Pons: Looks good to me, but someone else must approve
diff --git a/src/cpu/x86/mp_init.c b/src/cpu/x86/mp_init.c index df6bc4b..a5d2ae6 100644 --- a/src/cpu/x86/mp_init.c +++ b/src/cpu/x86/mp_init.c @@ -201,6 +201,7 @@ /* Fix up APIC id with reality. */ dev->path.apic.apic_id = lapicid(); dev->path.apic.initial_lapicid = initial_lapicid(); + dev->enabled = 1;
if (cpu_is_intel()) printk(BIOS_INFO, "AP: slot %u apic_id %x, MCU rev: 0x%08x\n", index, @@ -387,6 +388,7 @@ continue; } new->name = processor_name; + new->enabled = 0; /* Runtime will enable it */ }
return max_cpus;
