Timothy Pearson (tpearson@raptorengineering.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/18070
commit f6aabd7f3055aec576c2c76da62829ae3321d6d7 Author: Timothy Pearson tpearson@raptorengineering.com Date: Mon Jan 9 13:19:29 2017 -0600
amd/mct/ddr3: Correctly configure CsMux45
The existing logic to set up CsMux45 used an incorrect mask and comparison value due to a copy + paste editing error.
Use the correct mask and comparison value for the last two values.
Change-Id: Ic08a52977df90b9952e434e71cd12dbc6d7e1443 Found-by: Coverity Scan #1347385 Signed-off-by: Timothy Pearson tpearson@raptorengineering.com --- src/northbridge/amd/amdmct/mct_ddr3/mctproc.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/src/northbridge/amd/amdmct/mct_ddr3/mctproc.c b/src/northbridge/amd/amdmct/mct_ddr3/mctproc.c index 07bde27..48658f5 100644 --- a/src/northbridge/amd/amdmct/mct_ddr3/mctproc.c +++ b/src/northbridge/amd/amdmct/mct_ddr3/mctproc.c @@ -43,7 +43,7 @@ u32 mct_SetDramConfigMisc2(struct DCTStatStruc *pDCTstat, if ((((f2x80 & 0xf) == 0x7) || ((f2x80 & 0xf) == 0x9)) && ((f2x60 & 0x3) == 0x3)) cs_mux_45 = 1; - else if ((((f2x80 & 0xa) == 0x7) || ((f2x80 & 0xb) == 0x9)) + else if ((((f2x80 & 0xf) == 0xa) || ((f2x80 & 0xf) == 0xb)) && ((f2x60 & 0x3) > 0x1)) cs_mux_45 = 1; else
