Subrata Banik has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/39098 )
Change subject: soc/intel/tigerlake: Add Legacy 8254 timer support ......................................................................
This patch overrides required FSP-S UPDs to enable 8254 timer support for TGL.
TEST=Required to boot Tiano core payload.
Change-Id: Iaeff5c4b92691ed6ba7b71541ed4f947d5d299a8 Signed-off-by: Subrata Banik subrata.banik@intel.com --- M src/soc/intel/tigerlake/fsp_params_tgl.c 1 file changed, 4 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/98/39098/1
diff --git a/src/soc/intel/tigerlake/fsp_params_tgl.c b/src/soc/intel/tigerlake/fsp_params_tgl.c index 305748e..dbee489 100644 --- a/src/soc/intel/tigerlake/fsp_params_tgl.c +++ b/src/soc/intel/tigerlake/fsp_params_tgl.c @@ -135,6 +135,10 @@ sizeof(params->SataPortsDevSlp)); }
+ /* Legacy 8254 timer support */ + params->Enable8254ClockGating = !CONFIG_USE_LEGACY_8254_TIMER; + params->Enable8254ClockGatingOnS3 = 1; + mainboard_silicon_init_params(params); }
Paul Menzel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/39098 )
Patch Set 1: Code-Review+1
(3 comments)
https://review.coreboot.org/c/coreboot/+/39098/1//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/39098/1//COMMIT_MSG@7 PS1, Line 7: Add Integrate
https://review.coreboot.org/c/coreboot/+/39098/1//COMMIT_MSG@10 PS1, Line 10: support for TGL. … if the config option is selected.
https://review.coreboot.org/c/coreboot/+/39098/1//COMMIT_MSG@12 PS1, Line 12: Tiano core TianoCore
Hello Patrick Rudolph, Sugnan Prabhu S, Paul Menzel, build bot (Jenkins),
Change subject: soc/intel/tigerlake: Integrate Legacy 8254 timer support ......................................................................
This patch overrides required FSP-S UPDs to enable 8254 timer support for TGL if CONFIG_USE_LEGACY_8254_TIMER is selected.
TEST=Required to boot TianoCore payload.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/98/39098/2
Subrata Banik has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/39098 )
Patch Set 1:
(3 comments)
Integrate
Ack
Ack
TianoCore
Ack
Duncan Laurie has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/39098 )
Patch Set 2:
(2 comments)
https://review.coreboot.org/c/coreboot/+/39098/2/src/soc/intel/tigerlake/fsp... File src/soc/intel/tigerlake/fsp_params_tgl.c:
https://review.coreboot.org/c/coreboot/+/39098/2/src/soc/intel/tigerlake/fsp... PS2, Line 139: Enable8254ClockGating Looks like these are reserved in the stripped FSP headers, it will need to be added back for this to compile. (why was this particular UPD sanitized in the first place?)
https://review.coreboot.org/c/coreboot/+/39098/2/src/soc/intel/tigerlake/fsp... PS2, Line 140: 1 It looks like if Enable8254ClockGating==0 but ..OnS3==1 then it will end up setting the clock gating bit on resume (from ItssLib.c). Should these both depend on the config option?
Patch Set 2:
(2 comments)
Looks like these are reserved in the stripped FSP headers, it will need to be added back for this to […]
we will update FSP header by EOD.
It looks like if Enable8254ClockGating==0 but .. […]
yes, make sense, will clean for other SOC as well at once
Hello Patrick Rudolph, Nick Vaccaro, Sugnan Prabhu S, Tim Wawrzynczak, Paul Menzel, Shelley Chen, build bot (Jenkins),
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/98/39098/3
Patch Set 3:
(2 comments)
Ack
Ack
Wonkyu Kim has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/39098 )
Patch Set 4: Code-Review+1
Tim Wawrzynczak has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/39098 )
Patch Set 5: Code-Review+2
Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/39098 )
Change-Id: Iaeff5c4b92691ed6ba7b71541ed4f947d5d299a8 Signed-off-by: Subrata Banik subrata.banik@intel.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/39098 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Tim Wawrzynczak twawrzynczak@chromium.org Reviewed-by: Wonkyu Kim wonkyu.kim@intel.com --- M src/soc/intel/tigerlake/fsp_params_tgl.c 1 file changed, 4 insertions(+), 0 deletions(-)
Approvals: build bot (Jenkins): Verified Wonkyu Kim: Looks good to me, but someone else must approve Tim Wawrzynczak: Looks good to me, approved
diff --git a/src/soc/intel/tigerlake/fsp_params_tgl.c b/src/soc/intel/tigerlake/fsp_params_tgl.c index 305748e..d22cde0 100644 --- a/src/soc/intel/tigerlake/fsp_params_tgl.c +++ b/src/soc/intel/tigerlake/fsp_params_tgl.c @@ -135,6 +135,10 @@ sizeof(params->SataPortsDevSlp)); }
+ /* Legacy 8254 timer support */ + params->Enable8254ClockGating = !CONFIG_USE_LEGACY_8254_TIMER; + params->Enable8254ClockGatingOnS3 = !CONFIG_USE_LEGACY_8254_TIMER; + mainboard_silicon_init_params(params); }
