Attention is currently required from: Martin Roth, Julius Werner, Arthur Heymans, Yu-Ping Wu. Arthur Heymans has uploaded a new patch set (#9) to the change originally created by Arthur Heymans. ( https://review.coreboot.org/c/coreboot/+/59132 )
Change subject: Makefile.inc: Generate master header and pointer as C structs ......................................................................
The makefiles don't like cbfs file names with spaces in them so update the file name with '_' instead of spaces. To keep the master header at the top of cbfs, add a placeholder.
This removes the need to handle the cbfs master header in cbfstool. This functionality will be dropped in a later CL.
On x86 reserve some space in the linker script to add the pointer. On non-x86 generate a pointer inside a C struct file.
As a bonus this would actually fix the master header pointer mechanism on Intel/APL as only the bootblock inside IFWI gets memory mapped.
Change-Id: I3ba01be7da1f09a8cac287751497c18cda97d293 Signed-off-by: Arthur Heymans arthur@aheymans.xyz --- M Makefile.inc M src/arch/x86/bootblock.ld M src/lib/Makefile.inc A src/lib/cbfs_master_header.c A src/lib/master_header_pointer.c M src/security/vboot/Makefile.inc 6 files changed, 65 insertions(+), 13 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/32/59132/9
