Vladimir Serbinenko (phcoder@gmail.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/7087
commit 7ac3b947455c1382940edc7c96c060dcbb5277c9 Author: Vladimir Serbinenko phcoder@gmail.com Date: Thu Oct 16 12:48:19 2014 +0200
i945: Consolidate FADT code
Change-Id: I076cba7d21926cabf90d485de50268ae40c435f3 Signed-off-by: Vladimir Serbinenko phcoder@gmail.com --- src/Kconfig | 4 + src/arch/x86/boot/acpi.c | 36 +++++++++ src/arch/x86/include/arch/acpi.h | 4 + src/mainboard/apple/macbook21/Kconfig | 1 + src/mainboard/apple/macbook21/fadt.c | 133 +-------------------------------- src/mainboard/getac/p470/fadt.c | 135 +--------------------------------- src/mainboard/ibase/mb899/fadt.c | 127 +------------------------------- src/mainboard/intel/d945gclf/fadt.c | 131 +-------------------------------- src/mainboard/kontron/986lcd-m/fadt.c | 129 +------------------------------- src/mainboard/lenovo/t60/fadt.c | 135 +--------------------------------- src/mainboard/lenovo/x60/fadt.c | 135 +--------------------------------- src/mainboard/roda/rk886ex/fadt.c | 130 +------------------------------- src/southbridge/intel/bd82x6x/lpc.c | 109 +++++++++++++++++++++++++++ 13 files changed, 170 insertions(+), 1039 deletions(-)
diff --git a/src/Kconfig b/src/Kconfig index c08fd27..0eef361 100644 --- a/src/Kconfig +++ b/src/Kconfig @@ -474,6 +474,10 @@ config PER_DEVICE_ACPI_TABLES bool default n
+config COMMON_FADT + bool + default n + #These Options are here to avoid "undefined" warnings. #The actual selection and help texts are in the following menu.
diff --git a/src/arch/x86/boot/acpi.c b/src/arch/x86/boot/acpi.c index b9fbc81..3859bc1 100644 --- a/src/arch/x86/boot/acpi.c +++ b/src/arch/x86/boot/acpi.c @@ -652,6 +652,42 @@ void acpi_write_hest(acpi_hest_t *hest) header->checksum = acpi_checksum((void *)hest, header->length); }
+#if IS_ENABLED(CONFIG_COMMON_FADT) +void acpi_create_fadt(acpi_fadt_t *fadt,acpi_facs_t *facs, void *dsdt) +{ + acpi_header_t *header = &(fadt->header); + + memset((void *) fadt, 0, sizeof(acpi_fadt_t)); + memcpy(header->signature, "FACP", 4); + header->length = sizeof(acpi_fadt_t); + header->revision = 3; + memcpy(header->oem_id, OEM_ID, 6); + memcpy(header->oem_table_id, ACPI_TABLE_CREATOR, 8); + memcpy(header->asl_compiler_id, ASLC, 4); + header->asl_compiler_revision = 0; + + fadt->firmware_ctrl = (unsigned long) facs; + fadt->dsdt = (unsigned long) dsdt; + + fadt->x_firmware_ctl_l = (unsigned long)facs; + fadt->x_firmware_ctl_h = 0; + fadt->x_dsdt_l = (unsigned long)dsdt; + fadt->x_dsdt_h = 0; + + if(IS_ENABLED(CONFIG_SYSTEM_TYPE_LAPTOP)) { + fadt->preferred_pm_profile = PM_MOBILE; + } else { + fadt->preferred_pm_profile = PM_DESKTOP; + } + + southbridge_fill_fadt(fadt); + mainboard_fill_fadt(fadt); + + header->checksum = + acpi_checksum((void *) fadt, header->length); +} +#endif + #if IS_ENABLED(CONFIG_PER_DEVICE_ACPI_TABLES)
extern const unsigned char AmlCode[]; diff --git a/src/arch/x86/include/arch/acpi.h b/src/arch/x86/include/arch/acpi.h index 34e777d..f00d5f4 100644 --- a/src/arch/x86/include/arch/acpi.h +++ b/src/arch/x86/include/arch/acpi.h @@ -494,6 +494,10 @@ unsigned long acpi_fill_ssdt_generator(unsigned long current, #endif void acpi_create_ssdt_generator(acpi_header_t *ssdt, const char *oem_table_id); void acpi_create_fadt(acpi_fadt_t *fadt,acpi_facs_t *facs, void *dsdt); +#if IS_ENABLED(CONFIG_COMMON_FADT) +void southbridge_fill_fadt(acpi_fadt_t * fadt); +void mainboard_fill_fadt(acpi_fadt_t * fadt); +#endif
void update_ssdt(void *ssdt); void update_ssdtx(void *ssdtx, int i); diff --git a/src/mainboard/apple/macbook21/Kconfig b/src/mainboard/apple/macbook21/Kconfig index 1a491ec..a336efc 100644 --- a/src/mainboard/apple/macbook21/Kconfig +++ b/src/mainboard/apple/macbook21/Kconfig @@ -24,6 +24,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy select MAINBOARD_DO_EDID select EARLY_CBMEM_INIT select INTEL_EDID + select COMMON_FADT
config MAINBOARD_DIR string diff --git a/src/mainboard/apple/macbook21/fadt.c b/src/mainboard/apple/macbook21/fadt.c index 06b0346..314153d 100644 --- a/src/mainboard/apple/macbook21/fadt.c +++ b/src/mainboard/apple/macbook21/fadt.c @@ -19,140 +19,9 @@ * MA 02110-1301 USA */
-#include <string.h> -#include <device/pci.h> #include <arch/acpi.h> -#include <cpu/x86/smm.h>
-/* FIXME: This needs to go into a separate .h file - * to be included by the ich7 smi handler, ich7 smi init - * code and the mainboard fadt. - */ - -void acpi_create_fadt(acpi_fadt_t * fadt, acpi_facs_t * facs, void *dsdt) +void mainboard_fill_fadt(acpi_fadt_t * fadt) { - acpi_header_t *header = &(fadt->header); - u16 pmbase = pci_read_config16(dev_find_slot(0, PCI_DEVFN(0x1f,0)), 0x40) & 0xfffe; - - memset((void *) fadt, 0, sizeof(acpi_fadt_t)); - memcpy(header->signature, "FACP", 4); - header->length = sizeof(acpi_fadt_t); - header->revision = 3; - memcpy(header->oem_id, OEM_ID, 6); - memcpy(header->oem_table_id, ACPI_TABLE_CREATOR, 8); - memcpy(header->asl_compiler_id, ASLC, 4); - header->asl_compiler_revision = 0; - - fadt->firmware_ctrl = (unsigned long) facs; - fadt->dsdt = (unsigned long) dsdt; - fadt->model = 0x00; - fadt->preferred_pm_profile = PM_MOBILE; - fadt->sci_int = 0x9; - fadt->smi_cmd = APM_CNT; - fadt->acpi_enable = APM_CNT_ACPI_ENABLE; - fadt->acpi_disable = APM_CNT_ACPI_DISABLE; - fadt->s4bios_req = 0x0; - fadt->pstate_cnt = APM_CNT_PST_CONTROL; - - fadt->pm1a_evt_blk = pmbase; - fadt->pm1b_evt_blk = 0x0; - fadt->pm1a_cnt_blk = pmbase + 0x4; - fadt->pm1b_cnt_blk = 0x0; - fadt->pm2_cnt_blk = pmbase + 0x20; - fadt->pm_tmr_blk = pmbase + 0x8; - fadt->gpe0_blk = pmbase + 0x28; - fadt->gpe1_blk = 0; - - fadt->pm1_evt_len = 4; - fadt->pm1_cnt_len = 2; - fadt->pm2_cnt_len = 1; - fadt->pm_tmr_len = 4; - fadt->gpe0_blk_len = 8; - fadt->gpe1_blk_len = 0; - fadt->gpe1_base = 0; - fadt->cst_cnt = APM_CNT_CST_CONTROL; - fadt->p_lvl2_lat = 1; fadt->p_lvl3_lat = 0x23; - fadt->flush_size = 0; - fadt->flush_stride = 0; - fadt->duty_offset = 1; - fadt->duty_width = 3; - fadt->day_alrm = 0xd; - fadt->mon_alrm = 0x00; - fadt->century = 0x32; - fadt->iapc_boot_arch = 0x00; - fadt->flags = ACPI_FADT_WBINVD | ACPI_FADT_C1_SUPPORTED | - ACPI_FADT_SLEEP_BUTTON | ACPI_FADT_S4_RTC_WAKE; - - fadt->reset_reg.space_id = 0; - fadt->reset_reg.bit_width = 0; - fadt->reset_reg.bit_offset = 0; - fadt->reset_reg.resv = 0; - fadt->reset_reg.addrl = 0x0; - fadt->reset_reg.addrh = 0x0; - - fadt->reset_value = 0; - fadt->x_firmware_ctl_l = (unsigned long)facs; - fadt->x_firmware_ctl_h = 0; - fadt->x_dsdt_l = (unsigned long)dsdt; - fadt->x_dsdt_h = 0; - - fadt->x_pm1a_evt_blk.space_id = 1; - fadt->x_pm1a_evt_blk.bit_width = 32; - fadt->x_pm1a_evt_blk.bit_offset = 0; - fadt->x_pm1a_evt_blk.resv = 0; - fadt->x_pm1a_evt_blk.addrl = pmbase; - fadt->x_pm1a_evt_blk.addrh = 0x0; - - fadt->x_pm1b_evt_blk.space_id = 0; - fadt->x_pm1b_evt_blk.bit_width = 0; - fadt->x_pm1b_evt_blk.bit_offset = 0; - fadt->x_pm1b_evt_blk.resv = 0; - fadt->x_pm1b_evt_blk.addrl = 0x0; - fadt->x_pm1b_evt_blk.addrh = 0x0; - - fadt->x_pm1a_cnt_blk.space_id = 1; - fadt->x_pm1a_cnt_blk.bit_width = 16; - fadt->x_pm1a_cnt_blk.bit_offset = 0; - fadt->x_pm1a_cnt_blk.resv = 0; - fadt->x_pm1a_cnt_blk.addrl = pmbase + 0x4; - fadt->x_pm1a_cnt_blk.addrh = 0x0; - - fadt->x_pm1b_cnt_blk.space_id = 0; - fadt->x_pm1b_cnt_blk.bit_width = 0; - fadt->x_pm1b_cnt_blk.bit_offset = 0; - fadt->x_pm1b_cnt_blk.resv = 0; - fadt->x_pm1b_cnt_blk.addrl = 0x0; - fadt->x_pm1b_cnt_blk.addrh = 0x0; - - fadt->x_pm2_cnt_blk.space_id = 1; - fadt->x_pm2_cnt_blk.bit_width = 8; - fadt->x_pm2_cnt_blk.bit_offset = 0; - fadt->x_pm2_cnt_blk.resv = 0; - fadt->x_pm2_cnt_blk.addrl = pmbase + 0x20; - fadt->x_pm2_cnt_blk.addrh = 0x0; - - fadt->x_pm_tmr_blk.space_id = 1; - fadt->x_pm_tmr_blk.bit_width = 32; - fadt->x_pm_tmr_blk.bit_offset = 0; - fadt->x_pm_tmr_blk.resv = 0; - fadt->x_pm_tmr_blk.addrl = pmbase + 0x8; - fadt->x_pm_tmr_blk.addrh = 0x0; - - fadt->x_gpe0_blk.space_id = 1; - fadt->x_gpe0_blk.bit_width = 64; - fadt->x_gpe0_blk.bit_offset = 0; - fadt->x_gpe0_blk.resv = 0; - fadt->x_gpe0_blk.addrl = pmbase + 0x28; - fadt->x_gpe0_blk.addrh = 0x0; - - fadt->x_gpe1_blk.space_id = 0; - fadt->x_gpe1_blk.bit_width = 0; - fadt->x_gpe1_blk.bit_offset = 0; - fadt->x_gpe1_blk.resv = 0; - fadt->x_gpe1_blk.addrl = 0x0; - fadt->x_gpe1_blk.addrh = 0x0; - - header->checksum = - acpi_checksum((void *) fadt, header->length); } diff --git a/src/mainboard/getac/p470/fadt.c b/src/mainboard/getac/p470/fadt.c index 98d7f41..8722743 100644 --- a/src/mainboard/getac/p470/fadt.c +++ b/src/mainboard/getac/p470/fadt.c @@ -19,141 +19,10 @@ * MA 02110-1301 USA */
-/* FIXME: This needs to go into a separate .h file - * to be included by the ich7 smi handler, ich7 smi init - * code and the mainboard fadt. - */ - -void acpi_create_fadt(acpi_fadt_t * fadt, acpi_facs_t * facs, void *dsdt) +void mainboard_fill_fadt(acpi_fadt_t * fadt) { - acpi_header_t *header = &(fadt->header); - u16 pmbase = pci_read_config16(dev_find_slot(0, PCI_DEVFN(0x1f,0)), 0x40) & 0xfffe; - - memset((void *) fadt, 0, sizeof(acpi_fadt_t)); - memcpy(header->signature, "FACP", 4); - header->length = sizeof(acpi_fadt_t); - header->revision = 3; - memcpy(header->oem_id, OEM_ID, 6); - memcpy(header->oem_table_id, ACPI_TABLE_CREATOR, 8); - memcpy(header->asl_compiler_id, ASLC, 4); - header->asl_compiler_revision = 1; - - fadt->firmware_ctrl = (unsigned long) facs; - fadt->dsdt = (unsigned long) dsdt; - fadt->preferred_pm_profile = PM_MOBILE; - - fadt->sci_int = 0x9; - fadt->smi_cmd = APM_CNT; - fadt->acpi_enable = APM_CNT_ACPI_ENABLE; - fadt->acpi_disable = APM_CNT_ACPI_DISABLE; - fadt->s4bios_req = 0x0; // S4 command disabled - fadt->pstate_cnt = APM_CNT_PST_CONTROL; - - fadt->pm1a_evt_blk = pmbase; - fadt->pm1b_evt_blk = 0x0; - fadt->pm1a_cnt_blk = pmbase + 0x4; - fadt->pm1b_cnt_blk = 0x0; - fadt->pm2_cnt_blk = pmbase + 0x20; - fadt->pm_tmr_blk = pmbase + 0x8; - fadt->gpe0_blk = pmbase + 0x28; - fadt->gpe1_blk = 0; - - fadt->pm1_evt_len = 4; - fadt->pm1_cnt_len = 2; - fadt->pm2_cnt_len = 1; - fadt->pm_tmr_len = 4; - fadt->gpe0_blk_len = 8; - fadt->gpe1_blk_len = 0; - fadt->gpe1_base = 0; - fadt->cst_cnt = APM_CNT_CST_CONTROL; - fadt->p_lvl2_lat = 1; fadt->p_lvl3_lat = 85; - fadt->flush_size = 1024; - fadt->flush_stride = 16; - fadt->duty_offset = 1; - fadt->duty_width = 3; - fadt->day_alrm = 0xd; - fadt->mon_alrm = 0x00; - fadt->century = 0x00; - fadt->iapc_boot_arch = 0x00; - fadt->flags = ACPI_FADT_WBINVD | ACPI_FADT_C1_SUPPORTED | - ACPI_FADT_SLEEP_BUTTON | ACPI_FADT_S4_RTC_WAKE | - ACPI_FADT_DOCKING_SUPPORTED; - - fadt->reset_reg.space_id = 0; - fadt->reset_reg.bit_width = 0; - fadt->reset_reg.bit_offset = 0; - fadt->reset_reg.resv = 0; - fadt->reset_reg.addrl = 0x0; - fadt->reset_reg.addrh = 0x0; - - fadt->reset_value = 0; - fadt->x_firmware_ctl_l = (unsigned long)facs; - fadt->x_firmware_ctl_h = 0; - fadt->x_dsdt_l = (unsigned long)dsdt; - fadt->x_dsdt_h = 0; - - fadt->x_pm1a_evt_blk.space_id = 1; - fadt->x_pm1a_evt_blk.bit_width = 32; - fadt->x_pm1a_evt_blk.bit_offset = 0; - fadt->x_pm1a_evt_blk.resv = 0; - fadt->x_pm1a_evt_blk.addrl = pmbase; - fadt->x_pm1a_evt_blk.addrh = 0x0; - - fadt->x_pm1b_evt_blk.space_id = 1; - fadt->x_pm1b_evt_blk.bit_width = 0; - fadt->x_pm1b_evt_blk.bit_offset = 0; - fadt->x_pm1b_evt_blk.resv = 0; - fadt->x_pm1b_evt_blk.addrl = 0x0; - fadt->x_pm1b_evt_blk.addrh = 0x0; - - fadt->x_pm1a_cnt_blk.space_id = 1; - fadt->x_pm1a_cnt_blk.bit_width = 16; - fadt->x_pm1a_cnt_blk.bit_offset = 0; - fadt->x_pm1a_cnt_blk.resv = 0; - fadt->x_pm1a_cnt_blk.addrl = pmbase + 0x4; - fadt->x_pm1a_cnt_blk.addrh = 0x0; - - fadt->x_pm1b_cnt_blk.space_id = 1; - fadt->x_pm1b_cnt_blk.bit_width = 0; - fadt->x_pm1b_cnt_blk.bit_offset = 0; - fadt->x_pm1b_cnt_blk.resv = 0; - fadt->x_pm1b_cnt_blk.addrl = 0x0; - fadt->x_pm1b_cnt_blk.addrh = 0x0; - - fadt->x_pm2_cnt_blk.space_id = 1; - fadt->x_pm2_cnt_blk.bit_width = 8; - fadt->x_pm2_cnt_blk.bit_offset = 0; - fadt->x_pm2_cnt_blk.resv = 0; - fadt->x_pm2_cnt_blk.addrl = pmbase + 0x20; - fadt->x_pm2_cnt_blk.addrh = 0x0; - - fadt->x_pm_tmr_blk.space_id = 1; - fadt->x_pm_tmr_blk.bit_width = 32; - fadt->x_pm_tmr_blk.bit_offset = 0; - fadt->x_pm_tmr_blk.resv = 0; - fadt->x_pm_tmr_blk.addrl = pmbase + 0x8; - fadt->x_pm_tmr_blk.addrh = 0x0; - - fadt->x_gpe0_blk.space_id = 1; - fadt->x_gpe0_blk.bit_width = 64; - fadt->x_gpe0_blk.bit_offset = 0; - fadt->x_gpe0_blk.resv = 0; - fadt->x_gpe0_blk.addrl = pmbase + 0x28; - fadt->x_gpe0_blk.addrh = 0x0; - - fadt->x_gpe1_blk.space_id = 1; - fadt->x_gpe1_blk.bit_width = 0; - fadt->x_gpe1_blk.bit_offset = 0; - fadt->x_gpe1_blk.resv = 0; - fadt->x_gpe1_blk.addrl = 0x0; - fadt->x_gpe1_blk.addrh = 0x0; - - header->checksum = - acpi_checksum((void *) fadt, header->length); + fadt->flags |= ACPI_FADT_DOCKING_SUPPORTED; } diff --git a/src/mainboard/ibase/mb899/fadt.c b/src/mainboard/ibase/mb899/fadt.c index b55f628..f2770a5 100644 --- a/src/mainboard/ibase/mb899/fadt.c +++ b/src/mainboard/ibase/mb899/fadt.c @@ -22,134 +22,11 @@ #include <arch/acpi.h> #include <cpu/x86/smm.h>
-void acpi_create_fadt(acpi_fadt_t * fadt, acpi_facs_t * facs, void *dsdt) +void mainboard_fill_fadt(acpi_fadt_t * fadt) { - acpi_header_t *header = &(fadt->header); - u16 pmbase = pci_read_config16(dev_find_slot(0, PCI_DEVFN(0x1f,0)), 0x40) & 0xfffe; - - memset((void *) fadt, 0, sizeof(acpi_fadt_t)); - memcpy(header->signature, "FACP", 4); - header->length = sizeof(acpi_fadt_t); - header->revision = 3; - memcpy(header->oem_id, OEM_ID, 6); - memcpy(header->oem_table_id, ACPI_TABLE_CREATOR, 8); - memcpy(header->asl_compiler_id, ASLC, 4); - header->asl_compiler_revision = 1; - - fadt->firmware_ctrl = (unsigned long) facs; - fadt->dsdt = (unsigned long) dsdt; - fadt->model = 1; - fadt->preferred_pm_profile = PM_MOBILE; - - fadt->sci_int = 0x9; - fadt->smi_cmd = APM_CNT; - fadt->acpi_enable = APM_CNT_ACPI_ENABLE; - fadt->acpi_disable = APM_CNT_ACPI_DISABLE; - fadt->s4bios_req = 0x0; - fadt->pstate_cnt = APM_CNT_PST_CONTROL; - - fadt->pm1a_evt_blk = pmbase; - fadt->pm1b_evt_blk = 0x0; - fadt->pm1a_cnt_blk = pmbase + 0x4; - fadt->pm1b_cnt_blk = 0x0; - fadt->pm2_cnt_blk = pmbase + 0x20; - fadt->pm_tmr_blk = pmbase + 0x8; - fadt->gpe0_blk = pmbase + 0x28; - fadt->gpe1_blk = 0; - - fadt->pm1_evt_len = 4; - fadt->pm1_cnt_len = 2; - // XXX: pm2_cnt_len is probably wrong. find out right value (hint: it's != 0) - fadt->pm2_cnt_len = 2; - fadt->pm_tmr_len = 4; - fadt->gpe0_blk_len = 8; - fadt->gpe1_blk_len = 0; - fadt->gpe1_base = 0; - fadt->cst_cnt = APM_CNT_CST_CONTROL; - fadt->p_lvl2_lat = 1; fadt->p_lvl3_lat = 85; - fadt->flush_size = 1024; - fadt->flush_stride = 16; - fadt->duty_offset = 1; fadt->duty_width = 0; - fadt->day_alrm = 0xd; - fadt->mon_alrm = 0x00; - fadt->century = 0x00; fadt->iapc_boot_arch = 0x03;
- fadt->flags = ACPI_FADT_WBINVD | ACPI_FADT_C1_SUPPORTED | - ACPI_FADT_C2_MP_SUPPORTED | ACPI_FADT_SLEEP_BUTTON | - ACPI_FADT_S4_RTC_WAKE | ACPI_FADT_PLATFORM_CLOCK; - - fadt->reset_reg.space_id = 0; - fadt->reset_reg.bit_width = 0; - fadt->reset_reg.bit_offset = 0; - fadt->reset_reg.resv = 0; - fadt->reset_reg.addrl = 0x0; - fadt->reset_reg.addrh = 0x0; - - fadt->reset_value = 0; - fadt->x_firmware_ctl_l = (unsigned long)facs; - fadt->x_firmware_ctl_h = 0; - fadt->x_dsdt_l = (unsigned long)dsdt; - fadt->x_dsdt_h = 0; - - fadt->x_pm1a_evt_blk.space_id = 1; - fadt->x_pm1a_evt_blk.bit_width = 32; - fadt->x_pm1a_evt_blk.bit_offset = 0; - fadt->x_pm1a_evt_blk.resv = 0; - fadt->x_pm1a_evt_blk.addrl = pmbase; - fadt->x_pm1a_evt_blk.addrh = 0x0; - - fadt->x_pm1b_evt_blk.space_id = 1; - fadt->x_pm1b_evt_blk.bit_width = 0; - fadt->x_pm1b_evt_blk.bit_offset = 0; - fadt->x_pm1b_evt_blk.resv = 0; - fadt->x_pm1b_evt_blk.addrl = 0x0; - fadt->x_pm1b_evt_blk.addrh = 0x0; - - fadt->x_pm1a_cnt_blk.space_id = 1; - fadt->x_pm1a_cnt_blk.bit_width = 16; - fadt->x_pm1a_cnt_blk.bit_offset = 0; - fadt->x_pm1a_cnt_blk.resv = 0; - fadt->x_pm1a_cnt_blk.addrl = pmbase + 0x4; - fadt->x_pm1a_cnt_blk.addrh = 0x0; - - fadt->x_pm1b_cnt_blk.space_id = 1; - fadt->x_pm1b_cnt_blk.bit_width = 0; - fadt->x_pm1b_cnt_blk.bit_offset = 0; - fadt->x_pm1b_cnt_blk.resv = 0; - fadt->x_pm1b_cnt_blk.addrl = 0x0; - fadt->x_pm1b_cnt_blk.addrh = 0x0; - - fadt->x_pm2_cnt_blk.space_id = 1; - fadt->x_pm2_cnt_blk.bit_width = 8; - fadt->x_pm2_cnt_blk.bit_offset = 0; - fadt->x_pm2_cnt_blk.resv = 0; - fadt->x_pm2_cnt_blk.addrl = pmbase + 0x20; - fadt->x_pm2_cnt_blk.addrh = 0x0; - - fadt->x_pm_tmr_blk.space_id = 1; - fadt->x_pm_tmr_blk.bit_width = 32; - fadt->x_pm_tmr_blk.bit_offset = 0; - fadt->x_pm_tmr_blk.resv = 0; - fadt->x_pm_tmr_blk.addrl = pmbase + 0x8; - fadt->x_pm_tmr_blk.addrh = 0x0; - - fadt->x_gpe0_blk.space_id = 1; - fadt->x_gpe0_blk.bit_width = 64; - fadt->x_gpe0_blk.bit_offset = 0; - fadt->x_gpe0_blk.resv = 0; - fadt->x_gpe0_blk.addrl = pmbase + 0x28; - fadt->x_gpe0_blk.addrh = 0x0; - - fadt->x_gpe1_blk.space_id = 1; - fadt->x_gpe1_blk.bit_width = 0; - fadt->x_gpe1_blk.bit_offset = 0; - fadt->x_gpe1_blk.resv = 0; - fadt->x_gpe1_blk.addrl = 0x0; - fadt->x_gpe1_blk.addrh = 0x0; - - header->checksum = - acpi_checksum((void *) fadt, header->length); + fadt->flags |= ACPI_FADT_C2_MP_SUPPORTED | ACPI_FADT_PLATFORM_CLOCK; } diff --git a/src/mainboard/intel/d945gclf/fadt.c b/src/mainboard/intel/d945gclf/fadt.c index bf379cb..74a0e7e 100644 --- a/src/mainboard/intel/d945gclf/fadt.c +++ b/src/mainboard/intel/d945gclf/fadt.c @@ -17,139 +17,12 @@ * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA */
-void acpi_create_fadt(acpi_fadt_t * fadt, acpi_facs_t * facs, void *dsdt) +void mainboard_fill_fadt(acpi_fadt_t * fadt) { - acpi_header_t *header = &(fadt->header); - u16 pmbase = pci_read_config16(dev_find_slot(0, PCI_DEVFN(0x1f,0)), 0x40) & 0xfffe; - - memset((void *) fadt, 0, sizeof(acpi_fadt_t)); - memcpy(header->signature, "FACP", 4); - header->length = sizeof(acpi_fadt_t); - header->revision = 3; - memcpy(header->oem_id, OEM_ID, 6); - memcpy(header->oem_table_id, ACPI_TABLE_CREATOR, 8); - memcpy(header->asl_compiler_id, ASLC, 4); - header->asl_compiler_revision = 1; - - fadt->firmware_ctrl = (unsigned long) facs; - fadt->dsdt = (unsigned long) dsdt; - fadt->model = 1; - fadt->preferred_pm_profile = PM_MOBILE; - - fadt->sci_int = 0x9; - fadt->smi_cmd = APM_CNT; - fadt->acpi_enable = APM_CNT_ACPI_ENABLE; - fadt->acpi_disable = APM_CNT_ACPI_DISABLE; - fadt->s4bios_req = 0x0; - fadt->pstate_cnt = APM_CNT_PST_CONTROL; - - fadt->pm1a_evt_blk = pmbase; - fadt->pm1b_evt_blk = 0x0; - fadt->pm1a_cnt_blk = pmbase + 0x4; - fadt->pm1b_cnt_blk = 0x0; - fadt->pm2_cnt_blk = pmbase + 0x20; - fadt->pm_tmr_blk = pmbase + 0x8; - fadt->gpe0_blk = pmbase + 0x28; - fadt->gpe1_blk = 0; - - fadt->pm1_evt_len = 4; - fadt->pm1_cnt_len = 2; - // XXX: pm2_cnt_len is probably wrong. find out right value (hint: it's != 0) - fadt->pm2_cnt_len = 2; - fadt->pm_tmr_len = 4; - fadt->gpe0_blk_len = 8; - fadt->gpe1_blk_len = 0; - fadt->gpe1_base = 0; - fadt->cst_cnt = APM_CNT_CST_CONTROL; - fadt->p_lvl2_lat = 1; fadt->p_lvl3_lat = 85; - fadt->flush_size = 1024; - fadt->flush_stride = 16; - fadt->duty_offset = 1; fadt->duty_width = 0; - fadt->day_alrm = 0xd; - fadt->mon_alrm = 0x00; - fadt->century = 0x00; fadt->iapc_boot_arch = 0x03; - - fadt->flags = ACPI_FADT_WBINVD | ACPI_FADT_C1_SUPPORTED | - ACPI_FADT_C2_MP_SUPPORTED | ACPI_FADT_SLEEP_BUTTON | - ACPI_FADT_S4_RTC_WAKE | ACPI_FADT_PLATFORM_CLOCK; - - fadt->reset_reg.space_id = 0; - fadt->reset_reg.bit_width = 0; - fadt->reset_reg.bit_offset = 0; - fadt->reset_reg.resv = 0; - fadt->reset_reg.addrl = 0x0; - fadt->reset_reg.addrh = 0x0; - - fadt->reset_value = 0; - fadt->x_firmware_ctl_l = (unsigned long)facs; - fadt->x_firmware_ctl_h = 0; - fadt->x_dsdt_l = (unsigned long)dsdt; - fadt->x_dsdt_h = 0; - - fadt->x_pm1a_evt_blk.space_id = 1; - fadt->x_pm1a_evt_blk.bit_width = 32; - fadt->x_pm1a_evt_blk.bit_offset = 0; - fadt->x_pm1a_evt_blk.resv = 0; - fadt->x_pm1a_evt_blk.addrl = pmbase; - fadt->x_pm1a_evt_blk.addrh = 0x0; - - fadt->x_pm1b_evt_blk.space_id = 1; - fadt->x_pm1b_evt_blk.bit_width = 0; - fadt->x_pm1b_evt_blk.bit_offset = 0; - fadt->x_pm1b_evt_blk.resv = 0; - fadt->x_pm1b_evt_blk.addrl = 0x0; - fadt->x_pm1b_evt_blk.addrh = 0x0; - - fadt->x_pm1a_cnt_blk.space_id = 1; - fadt->x_pm1a_cnt_blk.bit_width = 16; - fadt->x_pm1a_cnt_blk.bit_offset = 0; - fadt->x_pm1a_cnt_blk.resv = 0; - fadt->x_pm1a_cnt_blk.addrl = pmbase + 0x4; - fadt->x_pm1a_cnt_blk.addrh = 0x0; - - fadt->x_pm1b_cnt_blk.space_id = 1; - fadt->x_pm1b_cnt_blk.bit_width = 0; - fadt->x_pm1b_cnt_blk.bit_offset = 0; - fadt->x_pm1b_cnt_blk.resv = 0; - fadt->x_pm1b_cnt_blk.addrl = 0x0; - fadt->x_pm1b_cnt_blk.addrh = 0x0; - - fadt->x_pm2_cnt_blk.space_id = 1; - fadt->x_pm2_cnt_blk.bit_width = 8; - fadt->x_pm2_cnt_blk.bit_offset = 0; - fadt->x_pm2_cnt_blk.resv = 0; - fadt->x_pm2_cnt_blk.addrl = pmbase + 0x20; - fadt->x_pm2_cnt_blk.addrh = 0x0; - - fadt->x_pm_tmr_blk.space_id = 1; - fadt->x_pm_tmr_blk.bit_width = 32; - fadt->x_pm_tmr_blk.bit_offset = 0; - fadt->x_pm_tmr_blk.resv = 0; - fadt->x_pm_tmr_blk.addrl = pmbase + 0x8; - fadt->x_pm_tmr_blk.addrh = 0x0; - - fadt->x_gpe0_blk.space_id = 1; - fadt->x_gpe0_blk.bit_width = 64; - fadt->x_gpe0_blk.bit_offset = 0; - fadt->x_gpe0_blk.resv = 0; - fadt->x_gpe0_blk.addrl = pmbase + 0x28; - fadt->x_gpe0_blk.addrh = 0x0; - - fadt->x_gpe1_blk.space_id = 1; - fadt->x_gpe1_blk.bit_width = 0; - fadt->x_gpe1_blk.bit_offset = 0; - fadt->x_gpe1_blk.resv = 0; - fadt->x_gpe1_blk.addrl = 0x0; - fadt->x_gpe1_blk.addrh = 0x0; - - header->checksum = - acpi_checksum((void *) fadt, header->length); + fadt->flags |= ACPI_FADT_C2_MP_SUPPORTED | ACPI_FADT_PLATFORM_CLOCK; } diff --git a/src/mainboard/kontron/986lcd-m/fadt.c b/src/mainboard/kontron/986lcd-m/fadt.c index c7227bf..92bf647 100644 --- a/src/mainboard/kontron/986lcd-m/fadt.c +++ b/src/mainboard/kontron/986lcd-m/fadt.c @@ -22,135 +22,12 @@ #include <arch/acpi.h> #include <cpu/x86/smm.h>
- fadt->flags = ACPI_FADT_WBINVD | ACPI_FADT_C1_SUPPORTED | - ACPI_FADT_C2_MP_SUPPORTED | ACPI_FADT_SLEEP_BUTTON | - ACPI_FADT_RESET_REGISTER | - ACPI_FADT_S4_RTC_WAKE | ACPI_FADT_PLATFORM_CLOCK; - - fadt->reset_reg.space_id = 1; - fadt->reset_reg.bit_width = 8; - fadt->reset_reg.bit_offset = 0; - fadt->reset_reg.resv = 0; - fadt->reset_reg.addrl = 0xcf9; - fadt->reset_reg.addrh = 0; - - fadt->reset_value = 6; - fadt->x_firmware_ctl_l = (unsigned long)facs; - fadt->x_firmware_ctl_h = 0; - fadt->x_dsdt_l = (unsigned long)dsdt; - fadt->x_dsdt_h = 0; - - fadt->x_pm1a_evt_blk.space_id = 1; - fadt->x_pm1a_evt_blk.bit_width = 32; - fadt->x_pm1a_evt_blk.bit_offset = 0; - fadt->x_pm1a_evt_blk.resv = 0; - fadt->x_pm1a_evt_blk.addrl = pmbase; - fadt->x_pm1a_evt_blk.addrh = 0x0; - - fadt->x_pm1b_evt_blk.space_id = 1; - fadt->x_pm1b_evt_blk.bit_width = 0; - fadt->x_pm1b_evt_blk.bit_offset = 0; - fadt->x_pm1b_evt_blk.resv = 0; - fadt->x_pm1b_evt_blk.addrl = 0x0; - fadt->x_pm1b_evt_blk.addrh = 0x0; - - fadt->x_pm1a_cnt_blk.space_id = 1; - fadt->x_pm1a_cnt_blk.bit_width = 16; - fadt->x_pm1a_cnt_blk.bit_offset = 0; - fadt->x_pm1a_cnt_blk.resv = 0; - fadt->x_pm1a_cnt_blk.addrl = pmbase + 0x4; - fadt->x_pm1a_cnt_blk.addrh = 0x0; - - fadt->x_pm1b_cnt_blk.space_id = 1; - fadt->x_pm1b_cnt_blk.bit_width = 0; - fadt->x_pm1b_cnt_blk.bit_offset = 0; - fadt->x_pm1b_cnt_blk.resv = 0; - fadt->x_pm1b_cnt_blk.addrl = 0x0; - fadt->x_pm1b_cnt_blk.addrh = 0x0; - - fadt->x_pm2_cnt_blk.space_id = 1; - fadt->x_pm2_cnt_blk.bit_width = 8; - fadt->x_pm2_cnt_blk.bit_offset = 0; - fadt->x_pm2_cnt_blk.resv = 0; - fadt->x_pm2_cnt_blk.addrl = pmbase + 0x20; - fadt->x_pm2_cnt_blk.addrh = 0x0; - - fadt->x_pm_tmr_blk.space_id = 1; - fadt->x_pm_tmr_blk.bit_width = 32; - fadt->x_pm_tmr_blk.bit_offset = 0; - fadt->x_pm_tmr_blk.resv = 0; - fadt->x_pm_tmr_blk.addrl = pmbase + 0x8; - fadt->x_pm_tmr_blk.addrh = 0x0; - - fadt->x_gpe0_blk.space_id = 1; - fadt->x_gpe0_blk.bit_width = 64; - fadt->x_gpe0_blk.bit_offset = 0; - fadt->x_gpe0_blk.resv = 0; - fadt->x_gpe0_blk.addrl = pmbase + 0x28; - fadt->x_gpe0_blk.addrh = 0x0; - - fadt->x_gpe1_blk.space_id = 1; - fadt->x_gpe1_blk.bit_width = 0; - fadt->x_gpe1_blk.bit_offset = 0; - fadt->x_gpe1_blk.resv = 0; - fadt->x_gpe1_blk.addrl = 0x0; - fadt->x_gpe1_blk.addrh = 0x0; - - header->checksum = - acpi_checksum((void *) fadt, header->length); + fadt->flags |= ACPI_FADT_C2_MP_SUPPORTED + | ACPI_FADT_RESET_REGISTER |ACPI_FADT_PLATFORM_CLOCK; } diff --git a/src/mainboard/lenovo/t60/fadt.c b/src/mainboard/lenovo/t60/fadt.c index 3a984b1..96767bd 100644 --- a/src/mainboard/lenovo/t60/fadt.c +++ b/src/mainboard/lenovo/t60/fadt.c @@ -19,141 +19,10 @@ * MA 02110-1301 USA */
-/* FIXME: This needs to go into a separate .h file - * to be included by the ich7 smi handler, ich7 smi init - * code and the mainboard fadt. - */ - -void acpi_create_fadt(acpi_fadt_t * fadt, acpi_facs_t * facs, void *dsdt) +void mainboard_fill_fadt(acpi_fadt_t * fadt) { - acpi_header_t *header = &(fadt->header); - u16 pmbase = pci_read_config16(dev_find_slot(0, PCI_DEVFN(0x1f,0)), 0x40) & 0xfffe; - - memset((void *) fadt, 0, sizeof(acpi_fadt_t)); - memcpy(header->signature, "FACP", 4); - header->length = sizeof(acpi_fadt_t); - header->revision = 3; - memcpy(header->oem_id, OEM_ID, 6); - memcpy(header->oem_table_id, ACPI_TABLE_CREATOR, 8); - memcpy(header->asl_compiler_id, ASLC, 4); - header->asl_compiler_revision = 0; - - fadt->firmware_ctrl = (unsigned long) facs; - fadt->dsdt = (unsigned long) dsdt; - fadt->model = 0x00; - fadt->preferred_pm_profile = PM_MOBILE; - fadt->sci_int = 0x9; - fadt->smi_cmd = APM_CNT; - fadt->acpi_enable = APM_CNT_ACPI_ENABLE; - fadt->acpi_disable = APM_CNT_ACPI_DISABLE; - fadt->s4bios_req = 0x0; - fadt->pstate_cnt = APM_CNT_PST_CONTROL; - - fadt->pm1a_evt_blk = pmbase; - fadt->pm1b_evt_blk = 0x0; - fadt->pm1a_cnt_blk = pmbase + 0x4; - fadt->pm1b_cnt_blk = 0x0; - fadt->pm2_cnt_blk = pmbase + 0x20; - fadt->pm_tmr_blk = pmbase + 0x8; - fadt->gpe0_blk = pmbase + 0x28; - fadt->gpe1_blk = 0; - - fadt->pm1_evt_len = 4; - fadt->pm1_cnt_len = 2; - fadt->pm2_cnt_len = 1; - fadt->pm_tmr_len = 4; - fadt->gpe0_blk_len = 8; - fadt->gpe1_blk_len = 0; - fadt->gpe1_base = 0; - fadt->cst_cnt = APM_CNT_CST_CONTROL; - fadt->p_lvl2_lat = 1; fadt->p_lvl3_lat = 0x23; - fadt->flush_size = 0; - fadt->flush_stride = 0; - fadt->duty_offset = 1; - fadt->duty_width = 3; - fadt->day_alrm = 0xd; - fadt->mon_alrm = 0x00; - fadt->century = 0x32; - fadt->iapc_boot_arch = 0x00; - fadt->flags = ACPI_FADT_WBINVD | ACPI_FADT_C1_SUPPORTED | - ACPI_FADT_SLEEP_BUTTON | ACPI_FADT_S4_RTC_WAKE | - ACPI_FADT_DOCKING_SUPPORTED; - - fadt->reset_reg.space_id = 0; - fadt->reset_reg.bit_width = 0; - fadt->reset_reg.bit_offset = 0; - fadt->reset_reg.resv = 0; - fadt->reset_reg.addrl = 0x0; - fadt->reset_reg.addrh = 0x0; - - fadt->reset_value = 0; - fadt->x_firmware_ctl_l = (unsigned long)facs; - fadt->x_firmware_ctl_h = 0; - fadt->x_dsdt_l = (unsigned long)dsdt; - fadt->x_dsdt_h = 0; - - fadt->x_pm1a_evt_blk.space_id = 1; - fadt->x_pm1a_evt_blk.bit_width = 32; - fadt->x_pm1a_evt_blk.bit_offset = 0; - fadt->x_pm1a_evt_blk.resv = 0; - fadt->x_pm1a_evt_blk.addrl = pmbase; - fadt->x_pm1a_evt_blk.addrh = 0x0; - - fadt->x_pm1b_evt_blk.space_id = 0; - fadt->x_pm1b_evt_blk.bit_width = 0; - fadt->x_pm1b_evt_blk.bit_offset = 0; - fadt->x_pm1b_evt_blk.resv = 0; - fadt->x_pm1b_evt_blk.addrl = 0x0; - fadt->x_pm1b_evt_blk.addrh = 0x0; - - fadt->x_pm1a_cnt_blk.space_id = 1; - fadt->x_pm1a_cnt_blk.bit_width = 16; - fadt->x_pm1a_cnt_blk.bit_offset = 0; - fadt->x_pm1a_cnt_blk.resv = 0; - fadt->x_pm1a_cnt_blk.addrl = pmbase + 0x4; - fadt->x_pm1a_cnt_blk.addrh = 0x0; - - fadt->x_pm1b_cnt_blk.space_id = 0; - fadt->x_pm1b_cnt_blk.bit_width = 0; - fadt->x_pm1b_cnt_blk.bit_offset = 0; - fadt->x_pm1b_cnt_blk.resv = 0; - fadt->x_pm1b_cnt_blk.addrl = 0x0; - fadt->x_pm1b_cnt_blk.addrh = 0x0; - - fadt->x_pm2_cnt_blk.space_id = 1; - fadt->x_pm2_cnt_blk.bit_width = 8; - fadt->x_pm2_cnt_blk.bit_offset = 0; - fadt->x_pm2_cnt_blk.resv = 0; - fadt->x_pm2_cnt_blk.addrl = pmbase + 0x20; - fadt->x_pm2_cnt_blk.addrh = 0x0; - - fadt->x_pm_tmr_blk.space_id = 1; - fadt->x_pm_tmr_blk.bit_width = 32; - fadt->x_pm_tmr_blk.bit_offset = 0; - fadt->x_pm_tmr_blk.resv = 0; - fadt->x_pm_tmr_blk.addrl = pmbase + 0x8; - fadt->x_pm_tmr_blk.addrh = 0x0; - - fadt->x_gpe0_blk.space_id = 1; - fadt->x_gpe0_blk.bit_width = 64; - fadt->x_gpe0_blk.bit_offset = 0; - fadt->x_gpe0_blk.resv = 0; - fadt->x_gpe0_blk.addrl = pmbase + 0x28; - fadt->x_gpe0_blk.addrh = 0x0; - - fadt->x_gpe1_blk.space_id = 0; - fadt->x_gpe1_blk.bit_width = 0; - fadt->x_gpe1_blk.bit_offset = 0; - fadt->x_gpe1_blk.resv = 0; - fadt->x_gpe1_blk.addrl = 0x0; - fadt->x_gpe1_blk.addrh = 0x0; - - header->checksum = - acpi_checksum((void *) fadt, header->length); + fadt->flags |= ACPI_FADT_DOCKING_SUPPORTED; } diff --git a/src/mainboard/lenovo/x60/fadt.c b/src/mainboard/lenovo/x60/fadt.c index 3a984b1..96767bd 100644 --- a/src/mainboard/lenovo/x60/fadt.c +++ b/src/mainboard/lenovo/x60/fadt.c @@ -19,141 +19,10 @@ * MA 02110-1301 USA */
-/* FIXME: This needs to go into a separate .h file - * to be included by the ich7 smi handler, ich7 smi init - * code and the mainboard fadt. - */ - -void acpi_create_fadt(acpi_fadt_t * fadt, acpi_facs_t * facs, void *dsdt) +void mainboard_fill_fadt(acpi_fadt_t * fadt) { - acpi_header_t *header = &(fadt->header); - u16 pmbase = pci_read_config16(dev_find_slot(0, PCI_DEVFN(0x1f,0)), 0x40) & 0xfffe; - - memset((void *) fadt, 0, sizeof(acpi_fadt_t)); - memcpy(header->signature, "FACP", 4); - header->length = sizeof(acpi_fadt_t); - header->revision = 3; - memcpy(header->oem_id, OEM_ID, 6); - memcpy(header->oem_table_id, ACPI_TABLE_CREATOR, 8); - memcpy(header->asl_compiler_id, ASLC, 4); - header->asl_compiler_revision = 0; - - fadt->firmware_ctrl = (unsigned long) facs; - fadt->dsdt = (unsigned long) dsdt; - fadt->model = 0x00; - fadt->preferred_pm_profile = PM_MOBILE; - fadt->sci_int = 0x9; - fadt->smi_cmd = APM_CNT; - fadt->acpi_enable = APM_CNT_ACPI_ENABLE; - fadt->acpi_disable = APM_CNT_ACPI_DISABLE; - fadt->s4bios_req = 0x0; - fadt->pstate_cnt = APM_CNT_PST_CONTROL; - - fadt->pm1a_evt_blk = pmbase; - fadt->pm1b_evt_blk = 0x0; - fadt->pm1a_cnt_blk = pmbase + 0x4; - fadt->pm1b_cnt_blk = 0x0; - fadt->pm2_cnt_blk = pmbase + 0x20; - fadt->pm_tmr_blk = pmbase + 0x8; - fadt->gpe0_blk = pmbase + 0x28; - fadt->gpe1_blk = 0; - - fadt->pm1_evt_len = 4; - fadt->pm1_cnt_len = 2; - fadt->pm2_cnt_len = 1; - fadt->pm_tmr_len = 4; - fadt->gpe0_blk_len = 8; - fadt->gpe1_blk_len = 0; - fadt->gpe1_base = 0; - fadt->cst_cnt = APM_CNT_CST_CONTROL; - fadt->p_lvl2_lat = 1; fadt->p_lvl3_lat = 0x23; - fadt->flush_size = 0; - fadt->flush_stride = 0; - fadt->duty_offset = 1; - fadt->duty_width = 3; - fadt->day_alrm = 0xd; - fadt->mon_alrm = 0x00; - fadt->century = 0x32; - fadt->iapc_boot_arch = 0x00; - fadt->flags = ACPI_FADT_WBINVD | ACPI_FADT_C1_SUPPORTED | - ACPI_FADT_SLEEP_BUTTON | ACPI_FADT_S4_RTC_WAKE | - ACPI_FADT_DOCKING_SUPPORTED; - - fadt->reset_reg.space_id = 0; - fadt->reset_reg.bit_width = 0; - fadt->reset_reg.bit_offset = 0; - fadt->reset_reg.resv = 0; - fadt->reset_reg.addrl = 0x0; - fadt->reset_reg.addrh = 0x0; - - fadt->reset_value = 0; - fadt->x_firmware_ctl_l = (unsigned long)facs; - fadt->x_firmware_ctl_h = 0; - fadt->x_dsdt_l = (unsigned long)dsdt; - fadt->x_dsdt_h = 0; - - fadt->x_pm1a_evt_blk.space_id = 1; - fadt->x_pm1a_evt_blk.bit_width = 32; - fadt->x_pm1a_evt_blk.bit_offset = 0; - fadt->x_pm1a_evt_blk.resv = 0; - fadt->x_pm1a_evt_blk.addrl = pmbase; - fadt->x_pm1a_evt_blk.addrh = 0x0; - - fadt->x_pm1b_evt_blk.space_id = 0; - fadt->x_pm1b_evt_blk.bit_width = 0; - fadt->x_pm1b_evt_blk.bit_offset = 0; - fadt->x_pm1b_evt_blk.resv = 0; - fadt->x_pm1b_evt_blk.addrl = 0x0; - fadt->x_pm1b_evt_blk.addrh = 0x0; - - fadt->x_pm1a_cnt_blk.space_id = 1; - fadt->x_pm1a_cnt_blk.bit_width = 16; - fadt->x_pm1a_cnt_blk.bit_offset = 0; - fadt->x_pm1a_cnt_blk.resv = 0; - fadt->x_pm1a_cnt_blk.addrl = pmbase + 0x4; - fadt->x_pm1a_cnt_blk.addrh = 0x0; - - fadt->x_pm1b_cnt_blk.space_id = 0; - fadt->x_pm1b_cnt_blk.bit_width = 0; - fadt->x_pm1b_cnt_blk.bit_offset = 0; - fadt->x_pm1b_cnt_blk.resv = 0; - fadt->x_pm1b_cnt_blk.addrl = 0x0; - fadt->x_pm1b_cnt_blk.addrh = 0x0; - - fadt->x_pm2_cnt_blk.space_id = 1; - fadt->x_pm2_cnt_blk.bit_width = 8; - fadt->x_pm2_cnt_blk.bit_offset = 0; - fadt->x_pm2_cnt_blk.resv = 0; - fadt->x_pm2_cnt_blk.addrl = pmbase + 0x20; - fadt->x_pm2_cnt_blk.addrh = 0x0; - - fadt->x_pm_tmr_blk.space_id = 1; - fadt->x_pm_tmr_blk.bit_width = 32; - fadt->x_pm_tmr_blk.bit_offset = 0; - fadt->x_pm_tmr_blk.resv = 0; - fadt->x_pm_tmr_blk.addrl = pmbase + 0x8; - fadt->x_pm_tmr_blk.addrh = 0x0; - - fadt->x_gpe0_blk.space_id = 1; - fadt->x_gpe0_blk.bit_width = 64; - fadt->x_gpe0_blk.bit_offset = 0; - fadt->x_gpe0_blk.resv = 0; - fadt->x_gpe0_blk.addrl = pmbase + 0x28; - fadt->x_gpe0_blk.addrh = 0x0; - - fadt->x_gpe1_blk.space_id = 0; - fadt->x_gpe1_blk.bit_width = 0; - fadt->x_gpe1_blk.bit_offset = 0; - fadt->x_gpe1_blk.resv = 0; - fadt->x_gpe1_blk.addrl = 0x0; - fadt->x_gpe1_blk.addrh = 0x0; - - header->checksum = - acpi_checksum((void *) fadt, header->length); + fadt->flags |= ACPI_FADT_DOCKING_SUPPORTED; } diff --git a/src/mainboard/roda/rk886ex/fadt.c b/src/mainboard/roda/rk886ex/fadt.c index 07b50d8..96767bd 100644 --- a/src/mainboard/roda/rk886ex/fadt.c +++ b/src/mainboard/roda/rk886ex/fadt.c @@ -19,136 +19,10 @@ * MA 02110-1301 USA */
-void acpi_create_fadt(acpi_fadt_t * fadt, acpi_facs_t * facs, void *dsdt) +void mainboard_fill_fadt(acpi_fadt_t * fadt) { - acpi_header_t *header = &(fadt->header); - u16 pmbase = pci_read_config16(dev_find_slot(0, PCI_DEVFN(0x1f,0)), 0x40) & 0xfffe; - - memset((void *) fadt, 0, sizeof(acpi_fadt_t)); - memcpy(header->signature, "FACP", 4); - header->length = sizeof(acpi_fadt_t); - header->revision = 3; - memcpy(header->oem_id, OEM_ID, 6); - memcpy(header->oem_table_id, ACPI_TABLE_CREATOR, 8); - memcpy(header->asl_compiler_id, ASLC, 4); - header->asl_compiler_revision = 0; - - fadt->firmware_ctrl = (unsigned long) facs; - fadt->dsdt = (unsigned long) dsdt; - fadt->model = 0x00; - fadt->preferred_pm_profile = PM_MOBILE; - fadt->sci_int = 0x9; - fadt->smi_cmd = APM_CNT; - fadt->acpi_enable = APM_CNT_ACPI_ENABLE; - fadt->acpi_disable = APM_CNT_ACPI_DISABLE; - fadt->s4bios_req = 0x0; - fadt->pstate_cnt = APM_CNT_PST_CONTROL; - - fadt->pm1a_evt_blk = pmbase; - fadt->pm1b_evt_blk = 0x0; - fadt->pm1a_cnt_blk = pmbase + 0x4; - fadt->pm1b_cnt_blk = 0x0; - fadt->pm2_cnt_blk = pmbase + 0x20; - fadt->pm_tmr_blk = pmbase + 0x8; - fadt->gpe0_blk = pmbase + 0x28; - fadt->gpe1_blk = 0; - - fadt->pm1_evt_len = 4; - fadt->pm1_cnt_len = 2; - fadt->pm2_cnt_len = 1; - fadt->pm_tmr_len = 4; - fadt->gpe0_blk_len = 8; - fadt->gpe1_blk_len = 0; - fadt->gpe1_base = 0; - fadt->cst_cnt = APM_CNT_CST_CONTROL; - fadt->p_lvl2_lat = 1; fadt->p_lvl3_lat = 0x23; - fadt->flush_size = 0; - fadt->flush_stride = 0; - fadt->duty_offset = 1; - fadt->duty_width = 3; - fadt->day_alrm = 0xd; - fadt->mon_alrm = 0x00; - fadt->century = 0x32; - fadt->iapc_boot_arch = 0x00; - fadt->flags = ACPI_FADT_WBINVD | ACPI_FADT_C1_SUPPORTED | - ACPI_FADT_SLEEP_BUTTON | ACPI_FADT_S4_RTC_WAKE | - ACPI_FADT_DOCKING_SUPPORTED; - - fadt->reset_reg.space_id = 0; - fadt->reset_reg.bit_width = 0; - fadt->reset_reg.bit_offset = 0; - fadt->reset_reg.resv = 0; - fadt->reset_reg.addrl = 0x0; - fadt->reset_reg.addrh = 0x0; - - fadt->reset_value = 0; - fadt->x_firmware_ctl_l = (unsigned long)facs; - fadt->x_firmware_ctl_h = 0; - fadt->x_dsdt_l = (unsigned long)dsdt; - fadt->x_dsdt_h = 0; - - fadt->x_pm1a_evt_blk.space_id = 1; - fadt->x_pm1a_evt_blk.bit_width = 32; - fadt->x_pm1a_evt_blk.bit_offset = 0; - fadt->x_pm1a_evt_blk.resv = 0; - fadt->x_pm1a_evt_blk.addrl = pmbase; - fadt->x_pm1a_evt_blk.addrh = 0x0; - - fadt->x_pm1b_evt_blk.space_id = 0; - fadt->x_pm1b_evt_blk.bit_width = 0; - fadt->x_pm1b_evt_blk.bit_offset = 0; - fadt->x_pm1b_evt_blk.resv = 0; - fadt->x_pm1b_evt_blk.addrl = 0x0; - fadt->x_pm1b_evt_blk.addrh = 0x0; - - fadt->x_pm1a_cnt_blk.space_id = 1; - fadt->x_pm1a_cnt_blk.bit_width = 16; - fadt->x_pm1a_cnt_blk.bit_offset = 0; - fadt->x_pm1a_cnt_blk.resv = 0; - fadt->x_pm1a_cnt_blk.addrl = pmbase + 0x4; - fadt->x_pm1a_cnt_blk.addrh = 0x0; - - fadt->x_pm1b_cnt_blk.space_id = 0; - fadt->x_pm1b_cnt_blk.bit_width = 0; - fadt->x_pm1b_cnt_blk.bit_offset = 0; - fadt->x_pm1b_cnt_blk.resv = 0; - fadt->x_pm1b_cnt_blk.addrl = 0x0; - fadt->x_pm1b_cnt_blk.addrh = 0x0; - - fadt->x_pm2_cnt_blk.space_id = 1; - fadt->x_pm2_cnt_blk.bit_width = 8; - fadt->x_pm2_cnt_blk.bit_offset = 0; - fadt->x_pm2_cnt_blk.resv = 0; - fadt->x_pm2_cnt_blk.addrl = pmbase + 0x20; - fadt->x_pm2_cnt_blk.addrh = 0x0; - - fadt->x_pm_tmr_blk.space_id = 1; - fadt->x_pm_tmr_blk.bit_width = 32; - fadt->x_pm_tmr_blk.bit_offset = 0; - fadt->x_pm_tmr_blk.resv = 0; - fadt->x_pm_tmr_blk.addrl = pmbase + 0x8; - fadt->x_pm_tmr_blk.addrh = 0x0; - - fadt->x_gpe0_blk.space_id = 1; - fadt->x_gpe0_blk.bit_width = 64; - fadt->x_gpe0_blk.bit_offset = 0; - fadt->x_gpe0_blk.resv = 0; - fadt->x_gpe0_blk.addrl = pmbase + 0x28; - fadt->x_gpe0_blk.addrh = 0x0; - - fadt->x_gpe1_blk.space_id = 0; - fadt->x_gpe1_blk.bit_width = 0; - fadt->x_gpe1_blk.bit_offset = 0; - fadt->x_gpe1_blk.resv = 0; - fadt->x_gpe1_blk.addrl = 0x0; - fadt->x_gpe1_blk.addrh = 0x0; - - header->checksum = - acpi_checksum((void *) fadt, header->length); + fadt->flags |= ACPI_FADT_DOCKING_SUPPORTED; } diff --git a/src/southbridge/intel/bd82x6x/lpc.c b/src/southbridge/intel/bd82x6x/lpc.c index 6218874..b5b1587 100644 --- a/src/southbridge/intel/bd82x6x/lpc.c +++ b/src/southbridge/intel/bd82x6x/lpc.c @@ -671,6 +671,115 @@ static void set_subsystem(device_t dev, unsigned vendor, unsigned device) } }
+void southbridge_fill_fadt(acpi_fadt_t * fadt) +{ + u16 pmbase = pci_read_config16(dev_find_slot(0, PCI_DEVFN(0x1f,0)), 0x40) & 0xfffe; + + fadt->pm1a_evt_blk = pmbase; + fadt->pm1b_evt_blk = 0x0; + fadt->pm1a_cnt_blk = pmbase + 0x4; + fadt->pm1b_cnt_blk = 0x0; + fadt->pm2_cnt_blk = pmbase + 0x20; + fadt->pm_tmr_blk = pmbase + 0x8; + fadt->gpe0_blk = pmbase + 0x28; + fadt->gpe1_blk = 0; + + fadt->pm1_evt_len = 4; + fadt->pm1_cnt_len = 2; + fadt->pm2_cnt_len = 1; + fadt->pm_tmr_len = 4; + fadt->gpe0_blk_len = 8; + fadt->gpe1_blk_len = 0; + fadt->gpe1_base = 0; + + fadt->reset_reg.space_id = 1; + fadt->reset_reg.bit_width = 8; + fadt->reset_reg.bit_offset = 0; + fadt->reset_reg.resv = 0; + fadt->reset_reg.addrl = 0xcf9; + fadt->reset_reg.addrh = 0; + + fadt->reset_value = 6; + + fadt->x_pm1a_evt_blk.space_id = 1; + fadt->x_pm1a_evt_blk.bit_width = 32; + fadt->x_pm1a_evt_blk.bit_offset = 0; + fadt->x_pm1a_evt_blk.resv = 0; + fadt->x_pm1a_evt_blk.addrl = pmbase; + fadt->x_pm1a_evt_blk.addrh = 0x0; + + fadt->x_pm1b_evt_blk.space_id = 0; + fadt->x_pm1b_evt_blk.bit_width = 0; + fadt->x_pm1b_evt_blk.bit_offset = 0; + fadt->x_pm1b_evt_blk.resv = 0; + fadt->x_pm1b_evt_blk.addrl = 0x0; + fadt->x_pm1b_evt_blk.addrh = 0x0; + + fadt->x_pm1a_cnt_blk.space_id = 1; + fadt->x_pm1a_cnt_blk.bit_width = 16; + fadt->x_pm1a_cnt_blk.bit_offset = 0; + fadt->x_pm1a_cnt_blk.resv = 0; + fadt->x_pm1a_cnt_blk.addrl = pmbase + 0x4; + fadt->x_pm1a_cnt_blk.addrh = 0x0; + + fadt->x_pm1b_cnt_blk.space_id = 0; + fadt->x_pm1b_cnt_blk.bit_width = 0; + fadt->x_pm1b_cnt_blk.bit_offset = 0; + fadt->x_pm1b_cnt_blk.resv = 0; + fadt->x_pm1b_cnt_blk.addrl = 0x0; + fadt->x_pm1b_cnt_blk.addrh = 0x0; + + fadt->x_pm2_cnt_blk.space_id = 1; + fadt->x_pm2_cnt_blk.bit_width = 8; + fadt->x_pm2_cnt_blk.bit_offset = 0; + fadt->x_pm2_cnt_blk.resv = 0; + fadt->x_pm2_cnt_blk.addrl = pmbase + 0x20; + fadt->x_pm2_cnt_blk.addrh = 0x0; + + fadt->x_pm_tmr_blk.space_id = 1; + fadt->x_pm_tmr_blk.bit_width = 32; + fadt->x_pm_tmr_blk.bit_offset = 0; + fadt->x_pm_tmr_blk.resv = 0; + fadt->x_pm_tmr_blk.addrl = pmbase + 0x8; + fadt->x_pm_tmr_blk.addrh = 0x0; + + fadt->x_gpe0_blk.space_id = 1; + fadt->x_gpe0_blk.bit_width = 64; + fadt->x_gpe0_blk.bit_offset = 0; + fadt->x_gpe0_blk.resv = 0; + fadt->x_gpe0_blk.addrl = pmbase + 0x28; + fadt->x_gpe0_blk.addrh = 0x0; + + fadt->x_gpe1_blk.space_id = 0; + fadt->x_gpe1_blk.bit_width = 0; + fadt->x_gpe1_blk.bit_offset = 0; + fadt->x_gpe1_blk.resv = 0; + fadt->x_gpe1_blk.addrl = 0x0; + fadt->x_gpe1_blk.addrh = 0x0; + fadt->day_alrm = 0xd; + fadt->mon_alrm = 0x00; + fadt->century = 0x32; + + fadt->model = 1; + fadt->sci_int = 0x9; + fadt->smi_cmd = APM_CNT; + fadt->acpi_enable = APM_CNT_ACPI_ENABLE; + fadt->acpi_disable = APM_CNT_ACPI_DISABLE; + fadt->s4bios_req = 0x0; + fadt->pstate_cnt = APM_CNT_PST_CONTROL; + + fadt->cst_cnt = APM_CNT_CST_CONTROL; + fadt->p_lvl2_lat = 1; + fadt->p_lvl3_lat = 0x23; + fadt->flush_size = 0; + fadt->flush_stride = 0; + fadt->duty_offset = 1; + fadt->duty_width = 3; + fadt->iapc_boot_arch = 0x00; + fadt->flags = ACPI_FADT_WBINVD | ACPI_FADT_C1_SUPPORTED | + ACPI_FADT_SLEEP_BUTTON | ACPI_FADT_S4_RTC_WAKE; +} + static void southbridge_inject_dsdt(void) { global_nvs_t *gnvs = cbmem_add (CBMEM_ID_ACPI_GNVS, sizeof (*gnvs));
