Stefan Reinauer (stefan.reinauer@coreboot.org) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/11089
commit 0bd1d50e82ee350d73cc9435f03a20438f520954 Author: Stefan Reinauer reinauer@chromium.org Date: Thu Jul 30 16:28:44 2015 -0700
smm: 64bit fixes
Change-Id: I35dab4e66514948aafa912d993fb8d42c5a520a0 Signed-off-by: Stefan Reinauer stefan.reinauer@coreboot.org --- src/cpu/x86/smm/Makefile.inc | 8 ++++++++ src/cpu/x86/smm/smihandler.c | 2 +- 2 files changed, 9 insertions(+), 1 deletion(-)
diff --git a/src/cpu/x86/smm/Makefile.inc b/src/cpu/x86/smm/Makefile.inc index 239689e..2e61018 100644 --- a/src/cpu/x86/smm/Makefile.inc +++ b/src/cpu/x86/smm/Makefile.inc @@ -61,14 +61,22 @@ $(obj)/cpu/x86/smm/smmstub.o: $$(smmstub-objs) $(CC_smmstub) $(CFLAGS_smmstub) -nostdlib -r -o $@ $^
# Link the SMM stub module with a 0-byte heap. +ifeq ($(CONFIG_ARCH_RAMSTAGE_X86_32),y) $(eval $(call rmodule_link,$(obj)/cpu/x86/smm/smmstub.elf, $(obj)/cpu/x86/smm/smmstub.o, 0,x86_32)) +else +$(eval $(call rmodule_link,$(obj)/cpu/x86/smm/smmstub.elf, $(obj)/cpu/x86/smm/smmstub.o, 0,x86_64)) +endif
$(obj)/cpu/x86/smm/smmstub: $(obj)/cpu/x86/smm/smmstub.elf.rmod $(OBJCOPY_smmstub) -O binary $< $@
$(obj)/cpu/x86/smm/smmstub.ramstage.manual: $(obj)/cpu/x86/smm/smmstub @printf " OBJCOPY $(subst $(obj)/,,$(@))\n" +ifeq ($(CONFIG_ARCH_RAMSTAGE_X86_32),y) cd $(dir $@); $(OBJCOPY_smmstub) -I binary $(notdir $<) -O elf32-i386 -B i386 $(notdir $@) +else + cd $(dir $@); $(OBJCOPY_smmstub) -I binary $(notdir $<) -O elf64-x86_64 -B x86_64 $(notdir $@) +endif
# C-based SMM handler.
diff --git a/src/cpu/x86/smm/smihandler.c b/src/cpu/x86/smm/smihandler.c index 9c282c3..295e5a8 100644 --- a/src/cpu/x86/smm/smihandler.c +++ b/src/cpu/x86/smm/smihandler.c @@ -109,7 +109,7 @@ static void smi_restore_pci_address(void) outl(pci_orig, 0xcf8); }
-static inline void *smm_save_state(u32 base, int arch_offset, int node) +static inline void *smm_save_state(uintptr_t base, int arch_offset, int node) { base += SMM_SAVE_STATE_BEGIN(arch_offset) - (node * 0x400); return (void *)base;
