Werner Zeh has submitted this change. ( https://review.coreboot.org/c/coreboot/+/55215 )
Change subject: cpu/intel/model_206ax/acpi.c: Do not report P_BLK ......................................................................
IO MWAIT redirection is disabled, which means reads to the P_LVL2 and P_LVL3 "registers" will never produce any C-state transition requests. Moreover, the register resource descriptors for all reported C-states use the FFixedHW address space, not I/O.
Change-Id: I026835dd24d7ac1e1bae2d851e011e1670abaad4 Signed-off-by: Angel Pons th3fanbus@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/55215 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Patrick Rudolph siro@das-labor.org --- M src/cpu/intel/model_206ax/acpi.c 1 file changed, 2 insertions(+), 8 deletions(-)
Approvals: build bot (Jenkins): Verified Patrick Rudolph: Looks good to me, approved
diff --git a/src/cpu/intel/model_206ax/acpi.c b/src/cpu/intel/model_206ax/acpi.c index 526a6d4..f1d03c8 100644 --- a/src/cpu/intel/model_206ax/acpi.c +++ b/src/cpu/intel/model_206ax/acpi.c @@ -306,7 +306,7 @@
void generate_cpu_entries(const struct device *device) { - int coreID, cpuID, pcontrol_blk = PMB0_BASE, plen = 6; + int coreID, cpuID; int totalcores = dev_count_cpu(); int cores_per_package = get_logical_cores_per_package(); int numcpus = totalcores/cores_per_package; @@ -316,15 +316,9 @@
for (cpuID = 1; cpuID <= numcpus; cpuID++) { for (coreID = 1; coreID <= cores_per_package; coreID++) { - if (coreID > 1) { - pcontrol_blk = 0; - plen = 0; - } - /* Generate processor _SB.CPUx */ acpigen_write_processor( - (cpuID-1)*cores_per_package+coreID-1, - pcontrol_blk, plen); + (cpuID-1)*cores_per_package+coreID-1, 0, 0);
/* Generate P-state tables */ generate_P_state_entries(
