Attention is currently required from: Paul Menzel, Rocky Phagura, Arthur Heymans. Hello build bot (Jenkins), Rocky Phagura, Rocky Phagura, Arthur Heymans,
https://review.coreboot.org/c/coreboot/+/54342
Change subject: cpu/x86/smm: Fix size_t type mismatch in print statement ......................................................................
The 64-bit compiler x86_64-linux-gnu-gcc-10 aborts the build with the format warning below:
CC ramstage/cpu/x86/smm/smm_module_loader.o src/cpu/x86/smm/smm_module_loader.c: In function 'smm_module_setup_stub': src/cpu/x86/smm/smm_module_loader.c:360:70: error: format '%lx' expects argument of type 'long unsigned int', but argument 5 has type 'unsigned int' [-Werror=format=] 360 | printk(BIOS_ERR, "%s: state save size: %zx : smm_entry_offset -> %lx\n", | ~~^ | | | long unsigned int | %x
As `size_t` is defined as `long unsigned int` in i386-elf (32-bit), the length modifier `l` matches there. With x86_64-elf/x86_64-linux-gnu (64-bit) and `-m32` `size_t` is defined as `unsigned int` resulting in a type mismatch. So, use the correct length modifier `z` for the type `size_t`.
Found-by: x86_64-linux-gnu-gcc-10 (Debian 10.2.1-6) 10.2.1 20210110 Fixes: afb7a814 ("cpu/x86/smm: Introduce SMM module loader version 2") Signed-off-by: Paul Menzel pmenzel@molgen.mpg.de Change-Id: I4172e0f4dc40437250da89b7720a5c1e5fbab709 --- M src/cpu/x86/smm/smm_module_loader.c 1 file changed, 1 insertion(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/42/54342/2
