Attention is currently required from: Jason Glenesk, Raul Rangel, Marshall Dawson, Paul Menzel, Tim Wawrzynczak, Angel Pons, Patrick Rudolph, Felix Held. Hello Jason Glenesk, build bot (Jenkins), Raul Rangel, Furquan Shaikh, Marshall Dawson, Paul Menzel, Tim Wawrzynczak, Angel Pons, Patrick Rudolph, Felix Held,
https://review.coreboot.org/c/coreboot/+/56628
Change subject: arch/x86: Refactor the SMBIOS type 17 write function ......................................................................
List of changes: 1. Create Module Type macros as per Memory Type (i.e. DDR2/DDR3/DDR4/DDR5/LPDDR4/LPDDR5) and fix compilation issue due to renaming of existing macros due to scoping the Memory Type. 2. Skip fixed module type to form factor conversion using DDR2 SPD4 specification (inside dimm_info_fill()). 3. Use dedicated Memory Type and Module type for `Form Factor` conversion using `get_spd_info()` function. 4. Use dedicated Memory Type and Module type for `TypeDetail` conversion using `get_spd_info()` function. 5. Create a new API (convert_form_factor_to_module_type()) for `Form Factor` to 'Module type' conversion as per `Memory Type`. 6. Add DDR5 and LPDDR5 memory technology into the SMBIOS Memory Type table. 7. Add new argument as `Memory Type` smbios_form_factor_to_spd_mod_type(). 8. smbios_form_factor_to_spd_mod_type() internally calls convert_form_factor_to_module_type() for `Module Type` conversion.
Refer to datasheet SPD4.1.2.M-1 for LPDDRx and SPD4.1.2.L-3 for DDRx.
BUG=b:194659789 TEST=Refer to dmidecode -t 17 output as below: Without this code change:
Handle 0x0012, DMI type 17, 40 bytes Memory Device Array Handle: 0x000A Error Information Handle: Not Provided Total Width: 16 bits Data Width: 16 bits Size: 2048 MB Form Factor: Unknown ....
With this code change:
Handle 0x0012, DMI type 17, 40 bytes Memory Device Array Handle: 0x000A Error Information Handle: Not Provided Total Width: 16 bits Data Width: 16 bits Size: 2048 MB Form Factor: Row Of Chips ....
Change-Id: Ia337ac8f50b61ae78d86a07c7a86aa9c248bad50 Signed-off-by: Subrata Banik subrata.banik@intel.com --- M src/arch/x86/smbios.c M src/device/dram/ddr3.c M src/device/dram/ddr4.c M src/device/dram/spd.c M src/include/device/dram/spd.h M src/include/dimm_info_util.h M src/include/smbios.h M src/include/spd.h M src/lib/dimm_info_util.c M src/soc/amd/common/block/pi/amd_late_init.c M src/soc/amd/common/fsp/dmi.c M src/soc/intel/common/smbios.c 12 files changed, 324 insertions(+), 92 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/28/56628/9
