Stefan Reinauer (stefan.reinauer@coreboot.org) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/10586
commit 3f8af07886c6f1fe94d2be502be0c6bff02bd985 Author: Stefan Reinauer stefan.reinauer@coreboot.org Date: Thu Jun 18 01:23:48 2015 -0700
x86: Port x86 over to compile cleanly with x86-64
Change-Id: I26f1bbf027435be593f11bce4780111dcaf7cb86 Signed-off-by: Stefan Reinauer stefan.reinauer@coreboot.org Signed-off-by: Scott Duplichan scott@notabs.org --- src/arch/x86/Makefile.inc | 4 + src/arch/x86/boot/boot.c | 68 ++++++++++++-- src/arch/x86/boot/gdt.c | 8 +- src/arch/x86/boot/mpspec.c | 5 +- src/arch/x86/boot/wakeup.S | 5 ++ src/arch/x86/include/arch/cpu.h | 8 +- src/arch/x86/include/arch/rom_segs.h | 1 + src/arch/x86/include/arch/stages.h | 4 + src/arch/x86/lib/c_start.S | 170 +++++++++++++++++++++++++++-------- src/arch/x86/lib/cpu.c | 4 + src/arch/x86/lib/cpu_common.c | 9 ++ src/arch/x86/lib/ebda.c | 4 +- src/arch/x86/lib/exception.c | 6 +- src/arch/x86/lib/pci_ops_mmconf.c | 2 +- 14 files changed, 242 insertions(+), 56 deletions(-)
diff --git a/src/arch/x86/Makefile.inc b/src/arch/x86/Makefile.inc index 4c00162..7e10acb 100644 --- a/src/arch/x86/Makefile.inc +++ b/src/arch/x86/Makefile.inc @@ -125,7 +125,11 @@ $(objgenerated)/bootblock.inc: $(src)/arch/x86/init/$(subst ",,$(CONFIG_BOOTBLOC
$(objcbfs)/bootblock.debug: $(objgenerated)/bootblock.o $(objgenerated)/bootblock.ld @printf " LINK $(subst $(obj)/,,$(@))\n" +ifeq ($(CONFIG_ARCH_BOOTBLOCK_X86_32),y) $(LD_bootblock) -m elf_i386 -static -o $@ -L$(obj) $< -T $(objgenerated)/bootblock.ld +else + $(LD_bootblock) -m elf_x86_64 -static -o $@ -L$(obj) $< -T $(objgenerated)/bootblock.ld +endif
endif # CONFIG_ARCH_BOOTBLOCK_X86_32 / CONFIG_ARCH_BOOTBLOCK_X86_64 diff --git a/src/arch/x86/boot/boot.c b/src/arch/x86/boot/boot.c index d86a6c3..8600471 100644 --- a/src/arch/x86/boot/boot.c +++ b/src/arch/x86/boot/boot.c @@ -39,17 +39,64 @@ static void jmp_payload(void *entry, unsigned long buffer, unsigned long size) /* Jump to kernel */ __asm__ __volatile__( " cld \n\t" +#ifdef __x86_64__ + /* switch back to 32-bit mode */ + " push %4\n\t" + " push %3\n\t" + " push %2\n\t" + " push %1\n\t" + " push %0\n\t" + + ".intel_syntax noprefix\n\t" + /* use iret to switch to 32-bit code segment */ + " xor rax,rax\n\t" + " mov ax, ss\n\t" + " push rax\n\t" + " mov rax, rsp\n\t" + " add rax, 8\n\t" + " push rax\n\t" + " pushfq\n\t" + " push 0x10\n\t" + " lea rax,[rip+3]\n\t" + " push rax\n\t" + " iretq\n\t" + ".code32\n\t" + /* disable paging */ + " mov eax, cr0\n\t" + " btc eax, 31\n\t" + " mov cr0, eax\n\t" + /* disable long mode */ + " mov ecx, 0xC0000080\n\t" + " rdmsr\n\t" + " btc eax, 8\n\t" + " wrmsr\n\t" + + " pop eax\n\t" + " add esp, 4\n\t" + " pop ebx\n\t" + " add esp, 4\n\t" + " pop ecx\n\t" + + " add esp, 4\n\t" + " pop edx\n\t" + " add esp, 4\n\t" + " pop esi\n\t" + " add esp, 4\n\t" + + ".att_syntax prefix\n\t" +#endif + /* Save the callee save registers... */ " pushl %%esi\n\t" " pushl %%edi\n\t" " pushl %%ebx\n\t" /* Save the parameters I was passed */ - " pushl $0\n\t" /* 20 adjust */ - " pushl %0\n\t" /* 16 lb_start */ - " pushl %1\n\t" /* 12 buffer */ - " pushl %2\n\t" /* 8 lb_size */ - " pushl %3\n\t" /* 4 entry */ - " pushl %4\n\t" /* 0 elf_boot_notes */ + " pushl $0\n\t" /* 20 adjust */ + " pushl %%eax\n\t" /* 16 lb_start */ + " pushl %%ebx\n\t" /* 12 buffer */ + " pushl %%ecx\n\t" /* 8 lb_size */ + " pushl %%edx\n\t" /* 4 entry */ + " pushl %%esi\n\t" /* 0 elf_boot_notes */ /* Compute the adjustment */ " xorl %%eax, %%eax\n\t" " subl 16(%%esp), %%eax\n\t" @@ -115,7 +162,9 @@ static void jmp_payload(void *entry, unsigned long buffer, unsigned long size) " popl %%ebx\n\t" " popl %%edi\n\t" " popl %%esi\n\t" - +#ifdef __x86_64__ + ".code64\n\t" +#endif :: "ri" (lb_start), "ri" (buffer), "ri" (lb_size), "ri" (entry), @@ -140,7 +189,12 @@ void arch_prog_run(struct prog *prog) if (ENV_RAMSTAGE) try_payload(prog); __asm__ volatile ( +#ifdef __x86_64__ + "jmp *%%rdi\n" +#else "jmp *%%edi\n" +#endif + :: "D"(prog_entry(prog)) ); } diff --git a/src/arch/x86/boot/gdt.c b/src/arch/x86/boot/gdt.c index 44156ea..a21fab2 100644 --- a/src/arch/x86/boot/gdt.c +++ b/src/arch/x86/boot/gdt.c @@ -26,7 +26,11 @@ /* i386 lgdt argument */ struct gdtarg { u16 limit; +#ifdef __x86_64__ + u64 base; +#else u32 base; +#endif } __attribute__((packed));
/* Copy GDT to new location and reload it. @@ -35,7 +39,7 @@ struct gdtarg { static void move_gdt(int is_recovery) { void *newgdt; - u16 num_gdt_bytes = (u32)&gdt_end - (u32)&gdt; + u16 num_gdt_bytes = (uintptr_t)&gdt_end - (uintptr_t)&gdt; struct gdtarg gdtarg;
newgdt = cbmem_find(CBMEM_ID_GDT); @@ -49,7 +53,7 @@ static void move_gdt(int is_recovery) memcpy((void*)newgdt, &gdt, num_gdt_bytes); }
- gdtarg.base = (u32)newgdt; + gdtarg.base = (uintptr_t)newgdt; gdtarg.limit = num_gdt_bytes - 1;
__asm__ __volatile__ ("lgdt %0\n\t" : : "m" (gdtarg)); diff --git a/src/arch/x86/boot/mpspec.c b/src/arch/x86/boot/mpspec.c index 4474d7c..1a0ac31 100644 --- a/src/arch/x86/boot/mpspec.c +++ b/src/arch/x86/boot/mpspec.c @@ -73,7 +73,7 @@ static unsigned char smp_compute_checksum(void *v, int len) return checksum; }
-static void *smp_write_floating_table_physaddr(u32 addr, u32 mpf_physptr, unsigned int virtualwire) +static void *smp_write_floating_table_physaddr(uintptr_t addr, uintptr_t mpf_physptr, unsigned int virtualwire) { struct intel_mp_floating *mf; void *v; @@ -591,6 +591,7 @@ unsigned long __attribute__((weak)) write_smp_table(unsigned long addr)
mptable_lintsrc(mc, isa_bus); tmp = mptable_finalize(mc); - printk(BIOS_INFO, "MPTABLE len: %d\n", (unsigned int)tmp - (unsigned int)v); + printk(BIOS_INFO, "MPTABLE len: %d\n", (unsigned int)((uintptr_t)tmp - + (uintptr_t)v)); return (unsigned long)tmp; } diff --git a/src/arch/x86/boot/wakeup.S b/src/arch/x86/boot/wakeup.S index a614b55..38d6ea4 100644 --- a/src/arch/x86/boot/wakeup.S +++ b/src/arch/x86/boot/wakeup.S @@ -24,7 +24,12 @@ /* CR0 bits */ #define PE (1 << 0)
+#ifdef __x86_64__ + .code64 +#else .code32 +#endif + .globl __wakeup __wakeup: /* First prepare the jmp to the resume vector */ diff --git a/src/arch/x86/include/arch/cpu.h b/src/arch/x86/include/arch/cpu.h index 851b58d..5c371d9 100644 --- a/src/arch/x86/include/arch/cpu.h +++ b/src/arch/x86/include/arch/cpu.h @@ -179,8 +179,14 @@ struct cpu_info { static inline struct cpu_info *cpu_info(void) { struct cpu_info *ci; - __asm__("andl %%esp,%0; " + __asm__( +#ifdef __x86_64__ + "and %%rsp,%0; " + "or %2, %0 " +#else + "andl %%esp,%0; " "orl %2, %0 " +#endif :"=r" (ci) : "0" (~(CONFIG_STACK_SIZE - 1)), "r" (CONFIG_STACK_SIZE - sizeof(struct cpu_info)) diff --git a/src/arch/x86/include/arch/rom_segs.h b/src/arch/x86/include/arch/rom_segs.h index 8c00eb3..3b3711b 100644 --- a/src/arch/x86/include/arch/rom_segs.h +++ b/src/arch/x86/include/arch/rom_segs.h @@ -3,5 +3,6 @@
#define ROM_CODE_SEG 0x08 #define ROM_DATA_SEG 0x10 +#define ROM_CODE_SEG64 0x18
#endif /* ROM_SEGS_H */ diff --git a/src/arch/x86/include/arch/stages.h b/src/arch/x86/include/arch/stages.h index 80df8e2..dfdb592 100644 --- a/src/arch/x86/include/arch/stages.h +++ b/src/arch/x86/include/arch/stages.h @@ -27,7 +27,11 @@ void asmlinkage copy_and_run(void); static inline void stage_exit(void *entry) { __asm__ volatile ( +#ifdef __x86_64__ + "jmp *%%rdi\n" +#else "jmp *%%edi\n" +#endif :: "D"(entry) ); } diff --git a/src/arch/x86/lib/c_start.S b/src/arch/x86/lib/c_start.S index dbed123..e2c0d82 100644 --- a/src/arch/x86/lib/c_start.S +++ b/src/arch/x86/lib/c_start.S @@ -17,20 +17,30 @@ thread_stacks: #endif
.section ".text._start", "ax", @progbits +#ifdef __x86_64__ + .code64 +#else .code32 +#endif .globl _start .globl __rmodule_entry __rmodule_entry: _start: cli lgdt %cs:gdtaddr +#ifndef __x86_64__ ljmp $0x10, $1f +#endif 1: movl $0x18, %eax movl %eax, %ds movl %eax, %es movl %eax, %ss movl %eax, %fs movl %eax, %gs +#ifdef __x86_64__ + mov $0x48, %ecx + call SetCodeSelector +#endif
post_code(POST_ENTRY_C_START) /* post 13 */
@@ -54,11 +64,11 @@ _start:
#if CONFIG_COOP_MULTITASKING /* Push the thread pointer. */ - pushl $0 + push $0 #endif /* Push the cpu index and struct cpu */ - pushl $0 - pushl $0 + push $0 + push $0
/* Initialize the Interrupt Descriptor table */ leal _idt, %edi @@ -76,7 +86,11 @@ _start: jne 1b
/* Load the Interrupt descriptor table */ +#ifndef __x86_64__ lidt idtarg +#else + // FIXME port table to x64 - lidt idtarg +#endif
/* * Now we are finished. Memory is up, data is copied and @@ -97,122 +111,150 @@ _start: jmp .Lhlt
vec0: - pushl $0 /* error code */ - pushl $0 /* vector */ + push $0 /* error code */ + push $0 /* vector */ jmp int_hand vec1: - pushl $0 /* error code */ - pushl $1 /* vector */ + push $0 /* error code */ + push $1 /* vector */ jmp int_hand
vec2: - pushl $0 /* error code */ - pushl $2 /* vector */ + push $0 /* error code */ + push $2 /* vector */ jmp int_hand
vec3: - pushl $0 /* error code */ - pushl $3 /* vector */ + push $0 /* error code */ + push $3 /* vector */ jmp int_hand
vec4: - pushl $0 /* error code */ - pushl $4 /* vector */ + push $0 /* error code */ + push $4 /* vector */ jmp int_hand
vec5: - pushl $0 /* error code */ - pushl $5 /* vector */ + push $0 /* error code */ + push $5 /* vector */ jmp int_hand
vec6: - pushl $0 /* error code */ - pushl $6 /* vector */ + push $0 /* error code */ + push $6 /* vector */ jmp int_hand
vec7: - pushl $0 /* error code */ - pushl $7 /* vector */ + push $0 /* error code */ + push $7 /* vector */ jmp int_hand
vec8: /* error code */ - pushl $8 /* vector */ + push $8 /* vector */ jmp int_hand .word 0x9090
vec9: - pushl $0 /* error code */ - pushl $9 /* vector */ + push $0 /* error code */ + push $9 /* vector */ jmp int_hand
vec10: /* error code */ - pushl $10 /* vector */ + push $10 /* vector */ jmp int_hand .word 0x9090
vec11: /* error code */ - pushl $11 /* vector */ + push $11 /* vector */ jmp int_hand .word 0x9090
vec12: /* error code */ - pushl $12 /* vector */ + push $12 /* vector */ jmp int_hand .word 0x9090
vec13: /* error code */ - pushl $13 /* vector */ + push $13 /* vector */ jmp int_hand .word 0x9090
vec14: /* error code */ - pushl $14 /* vector */ + push $14 /* vector */ jmp int_hand .word 0x9090
vec15: - pushl $0 /* error code */ - pushl $15 /* vector */ + push $0 /* error code */ + push $15 /* vector */ jmp int_hand
vec16: - pushl $0 /* error code */ - pushl $16 /* vector */ + push $0 /* error code */ + push $16 /* vector */ jmp int_hand
vec17: /* error code */ - pushl $17 /* vector */ + push $17 /* vector */ jmp int_hand .word 0x9090
vec18: - pushl $0 /* error code */ - pushl $18 /* vector */ + push $0 /* error code */ + push $18 /* vector */ jmp int_hand
vec19: - pushl $0 /* error code */ - pushl $19 /* vector */ + push $0 /* error code */ + push $19 /* vector */ jmp int_hand
int_hand: - /* At this point on the stack there is: + /* At this point, on x86-32, on the stack there is: * 0(%esp) vector * 4(%esp) error code * 8(%esp) eip * 12(%esp) cs * 16(%esp) eflags */ +#ifdef __x86_64__ + push %rdi + push %rsi + push %rbp + /* Original stack pointer */ + lea 32(%rsp), %rbp + push %rbp + push %rbx + push %rdx + push %rcx + push %rax + + push %rsp /* Pointer to structure on the stack */ + call x86_exception + pop %rax /* Drop the pointer */ + + pop %rax + pop %rcx + pop %rdx + pop %rbx + pop %rbp /* Ignore saved %rsp value */ + pop %rbp + pop %rsi + pop %rdi + + add $8, %rsp /* pop of the vector and error code */ +#else pushl %edi pushl %esi pushl %ebp + /* Original stack pointer */ leal 32(%esp), %ebp pushl %ebp @@ -235,6 +277,7 @@ int_hand: popl %edi
addl $8, %esp /* pop of the vector and error code */ +#endif
iret
@@ -242,21 +285,33 @@ int_hand:
.globl gdb_stub_breakpoint gdb_stub_breakpoint: +#ifdef __x86_64__ + pop %rax /* Return address */ + pushfl + push %cs + push %rax /* Return address */ + push $0 /* No error code */ + push $32 /* vector 32 is user defined */ +#else popl %eax /* Return address */ pushfl pushl %cs pushl %eax /* Return address */ pushl $0 /* No error code */ pushl $32 /* vector 32 is user defined */ +#endif jmp int_hand - #endif
.globl gdt, gdt_end, idtarg
gdtaddr: .word gdt_end - gdt - 1 +#ifdef __x86_64__ + .quad gdt +#else .long gdt /* we know the offset */ +#endif
.data
@@ -287,7 +342,11 @@ gdt:
/* selgdt 0x18, flat data segment */ .word 0xffff, 0x0000 +#ifdef __x86_64__ + .byte 0x00, 0x92, 0xcf, 0x00 +#else .byte 0x00, 0x93, 0xcf, 0x00 +#endif
/* selgdt 0x20, unused */ .word 0x0000, 0x0000 /* dummy */ @@ -312,6 +371,12 @@ gdt: /* selgdt 0x40, flat code segment 16 bit */ .word 0xffff, 0x0000 .byte 0x00, 0x9b, 0x8f, 0x00 /* G=1 and 0x0f, So we get 4Gbytes for limit */ + +#ifdef __x86_64__ + /* selgdt 0x48, flat x64 code segment */ + .word 0xffff, 0x0000 + .byte 0x00, 0x9b, 0xaf, 0x00 +#endif gdt_end:
idtarg: @@ -322,5 +387,34 @@ _idt: .fill 20, 8, 0 # idt is uninitialized _idt_end:
+SetCodeSelector: +.intel_syntax noprefix + + # save rsp because iret will align it to a 16 byte boundary + mov rdx, rsp + + # use iret to jump to a 64-bit offset in a new code segment + # iret will pop cs:rip, flags, then ss:rsp + mov ax, ss # need to push ss.. + push rax # push ss instuction not valid in x64 mode, so use ax + push rsp + pushfq + push rcx # cx is code segment selector from caller + mov rax, offset setCodeSelectorLongJump + push rax + + # the iret will continue at next instruction, with the new cs value loaded + iretq + +setCodeSelectorLongJump: + # restore rsp, it might not have been 16-byte aligned on entry + mov rsp, rdx + ret +.att_syntax prefix + .previous +#ifdef __x86_64__ +.code64 +#else .code32 +#endif diff --git a/src/arch/x86/lib/cpu.c b/src/arch/x86/lib/cpu.c index db72695..3eb7b94 100644 --- a/src/arch/x86/lib/cpu.c +++ b/src/arch/x86/lib/cpu.c @@ -10,6 +10,7 @@ #include <device/device.h> #include <smp/spinlock.h>
+#ifndef __x86_64__ /* Standard macro to see if a specific flag is changeable */ static inline int flag_is_changeable_p(uint32_t flag) { @@ -78,6 +79,7 @@ static int deep_magic_nexgen_probe(void) : "=a" (ret) : : "cx", "dx" ); return ret; } +#endif
/* List of cpu vendor strings along with their normalized * id values. @@ -131,6 +133,7 @@ static void identify_cpu(struct device *cpu)
vendor_name[0] = '\0'; /* Unset */
+#ifndef __x86_64__ /* Find the id and vendor_name */ if (!cpu_have_cpuid()) { /* Its a 486 if we can modify the AC flag */ @@ -148,6 +151,7 @@ static void identify_cpu(struct device *cpu) memcpy(vendor_name, "NexGenDriven", 13); } } +#endif if (cpu_have_cpuid()) { int cpuid_level; struct cpuid_result result; diff --git a/src/arch/x86/lib/cpu_common.c b/src/arch/x86/lib/cpu_common.c index 6c5561d..af0ab2a 100644 --- a/src/arch/x86/lib/cpu_common.c +++ b/src/arch/x86/lib/cpu_common.c @@ -10,6 +10,7 @@ #include <device/device.h> #include <smp/spinlock.h>
+#ifndef __x86_64__ /* Standard macro to see if a specific flag is changeable */ static inline int flag_is_changeable_p(uint32_t flag) { @@ -37,6 +38,14 @@ int cpu_have_cpuid(void) return flag_is_changeable_p(X86_EFLAGS_ID); }
+#else + +int cpu_have_cpuid(void) +{ + return 1; +} +#endif + int cpu_cpuid_extended_level(void) { return cpuid_eax(0x80000000); diff --git a/src/arch/x86/lib/ebda.c b/src/arch/x86/lib/ebda.c index 6089578..47dfbdb 100644 --- a/src/arch/x86/lib/ebda.c +++ b/src/arch/x86/lib/ebda.c @@ -40,8 +40,8 @@ void setup_ebda(u32 low_memory_size, u16 ebda_segment, u16 ebda_size) write16(X86_EBDA_SEGMENT, ebda_segment);
/* Set up EBDA */ - memset((void *)(ebda_segment << 4), 0, ebda_size); - write16((void*)(ebda_segment << 4), (ebda_size >> 10)); + memset((void *)((uintptr_t)ebda_segment << 4), 0, ebda_size); + write16((void*)((uintptr_t)ebda_segment << 4), (ebda_size >> 10)); }
void setup_default_ebda(void) diff --git a/src/arch/x86/lib/exception.c b/src/arch/x86/lib/exception.c index f64b2e7..65181e2 100644 --- a/src/arch/x86/lib/exception.c +++ b/src/arch/x86/lib/exception.c @@ -494,16 +494,16 @@ void x86_exception(struct eregs *info) info->error_code, info->eflags, info->eax, info->ebx, info->ecx, info->edx, info->edi, info->esi, info->ebp, info->esp); - u8 *code = (u8*)((u32)info->eip - (MDUMP_SIZE >>1)); + u8 *code = (u8*)((uintptr_t)info->eip - (MDUMP_SIZE >>1)); /* Align to 8-byte boundary please, and print eight bytes per row. * This is done to make DRAM burst timing/reordering errors more * evident from the looking at the dump */ - code = (u8*)((u32)code & ~0x7); + code = (u8*)((uintptr_t)code & ~0x7); int i; for(i = 0; i < MDUMP_SIZE; i++) { if( (i & 0x07) == 0 ) - printk(BIOS_EMERG, "\n%.8x:\t", (int)code + i ); + printk(BIOS_EMERG, "\n%p:\t", code + i); printk(BIOS_EMERG, "%.2x ", code[i]); } die(""); diff --git a/src/arch/x86/lib/pci_ops_mmconf.c b/src/arch/x86/lib/pci_ops_mmconf.c index 4853f6b..e4fa128 100644 --- a/src/arch/x86/lib/pci_ops_mmconf.c +++ b/src/arch/x86/lib/pci_ops_mmconf.c @@ -10,7 +10,7 @@ */
#define PCI_MMIO_ADDR(SEGBUS, DEVFN, WHERE, MASK) \ - ((void *)((CONFIG_MMCONF_BASE_ADDRESS |\ + ((void *)(((uintptr_t)CONFIG_MMCONF_BASE_ADDRESS |\ (((SEGBUS) & 0xFFF) << 20) |\ (((DEVFN) & 0xFF) << 12) |\ ((WHERE) & 0xFFF)) & ~MASK))
