Andrey Petrov (andrey.petrov@intel.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/14253
commit ec882a9104d29f1349255dd6713500705eccee8f Author: Shaunak Saha shaunak.saha@intel.com Date: Mon Apr 4 16:38:46 2016 -0700
soc/intel/apollolake: Enabling using of MRC data when available
Change-Id: Iee30a6efb8dcdd04affd5d1105a254781287e9e4 Signed-off-by: Andrey Petrov andrey.petrov@intel.com --- src/soc/intel/apollolake/romstage.c | 26 ++++++++++++++++++++++++++ 1 file changed, 26 insertions(+)
diff --git a/src/soc/intel/apollolake/romstage.c b/src/soc/intel/apollolake/romstage.c index d24cdf8..291e2a8 100644 --- a/src/soc/intel/apollolake/romstage.c +++ b/src/soc/intel/apollolake/romstage.c @@ -23,6 +23,7 @@ #include <device/resource.h> #include <string.h> #include <soc/iomap.h> +#include <soc/intel/common/mrc_cache.h> #include <soc/pci_devs.h> #include <soc/northbridge.h> #include <soc/romstage.h> @@ -82,6 +83,8 @@ asmlinkage void car_stage_entry(void) struct range_entry fsp_mem; struct range_entry reg_car; struct postcar_frame pcf; + const void *mrc_data; + size_t mrc_data_size;
printk(BIOS_DEBUG, "Starting romstage...\n");
@@ -111,6 +114,14 @@ asmlinkage void car_stage_entry(void) /* Now that CBMEM is up, save the list so ramstage can use it */ fsp_save_hob_list(hob_list_ptr);
+ /* Save MRC Data to CBMEM */ + if (IS_ENABLED(CONFIG_CACHE_MRC_SETTINGS)) + { + if ((mrc_data = fsp_find_nv_storage_data(&mrc_data_size)) && + mrc_cache_stash_data(mrc_data, mrc_data_size) < 0) + printk(BIOS_ERR, "Failed to stash MRC data\n"); + } + if (postcar_frame_init(&pcf, 1*KiB)) die("Unable to initialize postcar frame.\n");
@@ -134,6 +145,9 @@ static void fill_console_params(struct FSPM_UPD *mupd)
void platform_fsp_memory_init_params_cb(struct FSPM_UPD *mupd) { + const struct mrc_saved_data *mrc_cache; + struct FSP_M_ARCH_UPD *arch_upd = &mupd->FspmArchUpd; + fill_console_params(mupd); mainboard_memory_init_params(mupd);
@@ -154,6 +168,18 @@ void platform_fsp_memory_init_params_cb(struct FSPM_UPD *mupd) */ mupd->FspmArchUpd.StackBase = _car_region_end - mupd->FspmArchUpd.StackSize; + + arch_upd->Bootmode = FSP_BOOT_WITH_FULL_CONFIGURATION; + + if (IS_ENABLED(CONFIG_CACHE_MRC_SETTINGS)) { + if (!mrc_cache_get_current_with_version(&mrc_cache, 0)) { + /* MRC cache found */ + arch_upd->NvsBufferPtr = (void *)mrc_cache->data; + arch_upd->Bootmode = FSP_BOOT_ASSUMING_NO_CONFIGURATION_CHANGES; + printk(BIOS_DEBUG, "MRC cache found, size %x\n", mrc_cache->size); + } else + printk(BIOS_DEBUG, "MRC cache was not found\n"); + } }
__attribute__ ((weak))
