Alexandru Gagniuc (mr.nuke.me@gmail.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/13399
commit 23a8c4f6277434792c5959600daf617f30c4a443 Author: Zhao, Lijian lijian.zhao@intel.com Date: Wed Dec 16 14:46:42 2015 -0800
drivers/intel/fsp2_0: Update FspVpdUpd.h header
FSP ABI is still changing (not finalized). We expect the ABI to be updated several times in the future before a "stable" release.
Change-Id: I9e000cddfac5485f77a1d6af405728f17198a6e8 Signed-off-by: Alexandru Gagniuc alexandrux.gagniuc@intel.com --- src/drivers/intel/fsp2_0/include/fsp/FspUpdVpd.h | 379 +++++++++++++++++------ 1 file changed, 292 insertions(+), 87 deletions(-)
diff --git a/src/drivers/intel/fsp2_0/include/fsp/FspUpdVpd.h b/src/drivers/intel/fsp2_0/include/fsp/FspUpdVpd.h index 23ae434..4b49f61 100644 --- a/src/drivers/intel/fsp2_0/include/fsp/FspUpdVpd.h +++ b/src/drivers/intel/fsp2_0/include/fsp/FspUpdVpd.h @@ -1,6 +1,6 @@ /** @file
-Copyright (c) 2015, Intel Corporation. All rights reserved.<BR> +Copyright (c) 2016, Intel Corporation. All rights reserved.<BR>
Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met: @@ -79,217 +79,229 @@ struct BL_GPIO_PAD_INIT { wchar_t *PadName; } __attribute__((packed));
+struct BL_HDA_VERB_TABLE_HEADER { + uint32_t VendorDeviceId; ///< Codec Vendor/Device ID + uint8_t RevisionId; ///< Revision ID of the codec. 0xFF matches any revision. + uint8_t SdiNo; ///< SDI number, 0xFF matches any SDI. + uint16_t DataDwords; ///< Number of data DWORDs following the header. + uint8_t FrontPanelSupport; + uint8_t Padding[3]; +} __attribute__((packed)); + +struct BL_HDAUDIO_VERB_TABLE { + struct BL_HDA_VERB_TABLE_HEADER VerbTableHeader; + uint32_t VerbTableData[]; +} __attribute__((packed)); +
#define FSP_TEMP_RAM_INIT_UPD_SIGNATURE 0x4450555F54505346 /* 'FSPT_UPD' */ #define FSP_MEMORY_INIT_UPD_SIGNATURE 0x4450555F4D505346 /* 'FSPM_UPD' */ #define FSP_SILICON_INIT_UPD_SIGNATURE 0x4450555F53505346 /* 'FSPS_UPD' */ +#define FSP_IMAGE_ID 0x245053464C504124 /* '$APLFSP$' */ +#define FSP_IMAGE_REV 0x00060000
struct DRAM_CONFIG { -/** Offset 0x0000 +/** Offset 0x00A0 Package NOTE: First option is CoPOP if LPDDR3/LPDDR4 is being used. It is SODIMM if DDR3L is being used. **/ uint8_t Package; -/** Offset 0x0001 +/** Offset 0x00A1 Profile Profile list **/ uint8_t Profile; -/** Offset 0x0002 +/** Offset 0x00A2 MemoryDown Memory Down. **/ uint8_t MemoryDown; -/** Offset 0x0003 +/** Offset 0x00A3 DDR3LPageSize NOTE: Only for memory down or downgrade DDR3L frequency. **/ uint8_t DDR3LPageSize; -/** Offset 0x0004 +/** Offset 0x00A4 DDR3LASR NOTE: Only for memory down. **/ uint8_t DDR3LASR; -/** Offset 0x0005 +/** Offset 0x00A5 ScramblerSupport Scrambler Support. **/ uint8_t ScramblerSupport; -/** Offset 0x0006 +/** Offset 0x00A6 ChannelHashMask Channel Hash Mask. **/ uint16_t ChannelHashMask; -/** Offset 0x0008 +/** Offset 0x00A8 SliceHashMask Slice Hash Mask. **/ uint16_t SliceHashMask; -/** Offset 0x000A +/** Offset 0x00AA InterleavedMode Interleaved Mode. **/ uint8_t InterleavedMode; -/** Offset 0x000B +/** Offset 0x00AB ChannelsSlicesEnable Channels Slices Enable. **/ uint8_t ChannelsSlicesEnable; -/** Offset 0x000C +/** Offset 0x00AC MinRefRate2xEnable Provided as a means to defend against Row-Hammer attacks. **/ uint8_t MinRefRate2xEnable; -/** Offset 0x000D +/** Offset 0x00AD DualRankSupportEnable Dual Rank Support Enable. **/ uint8_t DualRankSupportEnable; -/** Offset 0x000E +/** Offset 0x00AE DisableFastBoot 00: Disabled; Used saved training data (if valid)\n01: Enabled; Full re-train of memory. **/ uint8_t DisableFastBoot; -/** Offset 0x000F +/** Offset 0x00AF RmtMode Rank Margin Tool Mode. **/ uint8_t RmtMode; -/** Offset 0x0010 +/** Offset 0x00B0 MemorySizeLimit Memory Size Limit: This value is used to restrict the total amount of memory and the calculations based on it. Value is in MB\nExample encodings are: 0x400 = 1GB, 0x800 = 2GB, 0x1000 = 4GB, 0x2000 8GB. **/ uint16_t MemorySizeLimit; -/** Offset 0x0012 +/** Offset 0x00B2 LowMemoryMaxValue Low Memory Max Value: This value is used to restrict the amount of memory below 4GB and the calculations based on it. Value is in MB\nExample encodings are: 0x400 = 1GB, 0x800 = 2GB, 0x1000 = 4GB, 0x2000 8GB. **/ uint16_t LowMemoryMaxValue; -/** Offset 0x0014 +/** Offset 0x00B4 HighMemoryMaxValue High Memory Max Value: This value is used to restrict the amount of memory above 4GB and the calculations based on it. Value is in MB\nExample encodings are: 0x400 = 1GB, 0x800 = 2GB, 0x1000 = 4GB, 0x2000 8GB. **/ uint16_t HighMemoryMaxValue; -/** Offset 0x0016 +/** Offset 0x00B6 DIMM0SPDAddress DIMM0 SPD Address (NOTE: Only for DDR3L only. Please put 0 for MemoryDown. **/ uint8_t DIMM0SPDAddress; -/** Offset 0x0017 +/** Offset 0x00B7 DIMM1SPDAddress DIMM1 SPD Address (NOTE: Only for DDR3L only. Please put 0 for MemoryDown. **/ uint8_t DIMM1SPDAddress; -/** Offset 0x0018 +/** Offset 0x00B8 Ch0_RankEnable NOTE: Only for memory down\n[0] Enable Rank 0: Must be set to 1 to enable use of this rank.\n[1] Enable Rank 1: Must be set to 1 to enable use of this rank. **/ uint8_t Ch0_RankEnable; -/** Offset 0x0019 +/** Offset 0x00B9 Ch0_DeviceWidth NOTE: Only for memory down\nDRAM Device Data Width populated on Ranks 0 and 1. **/ uint8_t Ch0_DeviceWidth; -/** Offset 0x001A +/** Offset 0x00BA Ch0_DramDensity NOTE: Only for memory down\nDRAM Device Density populated on Ranks 0 and 1. **/ uint8_t Ch0_DramDensity; -/** Offset 0x001B +/** Offset 0x00BB Ch0_Option [0] Rank Select Interleaving Enable. See Address Mapping section for full description.\n0 - Rank Select Interleaving disabled\n1 - Rank Select Interleaving enabled\n[1] Bank Address Hashing Enable. See Address Mapping section for full description.\n0 - Bank Address Hashing disabled\n1 - Bank Address Hashing enabled\n[3:2] Reserved\n[5:4] This register specifies the address mapping to be used:\n00 - 1KB (A)\n01 - 2KB (B). **/ uint8_t Ch0_Option; -/** Offset 0x001C +/** Offset 0x00BC Ch1_RankEnable NOTE: Only for memory down\n[0] Enable Rank 0: Must be set to 1 to enable use of this rank.\n[1] Enable Rank 1: Must be set to 1 to enable use of this rank. **/ uint8_t Ch1_RankEnable; -/** Offset 0x001D +/** Offset 0x00BD Ch1_DeviceWidth NOTE: Only for memory down\nDRAM Device Data Width populated on Ranks 0 and 1. **/ uint8_t Ch1_DeviceWidth; -/** Offset 0x001E +/** Offset 0x00BE Ch1_DramDensity NOTE: Only for memory down\nDRAM Device Density populated on Ranks 0 and 1. **/ uint8_t Ch1_DramDensity; -/** Offset 0x001F +/** Offset 0x00BF Ch1_Option [0] Rank Select Interleaving Enable. See Address Mapping section for full description.\n0 - Rank Select Interleaving disabled\n1 - Rank Select Interleaving enabled\n[1] Bank Address Hashing Enable. See Address Mapping section for full description.\n0 - Bank Address Hashing disabled\n1 - Bank Address Hashing enabled\n[3:2] Reserved\n[5:4] This register specifies the address mapping to be used:\n00 - 1KB (A)\n01 - 2KB (B). **/ uint8_t Ch1_Option; -/** Offset 0x0020 +/** Offset 0x00C0 Ch2_RankEnable NOTE: Only for memory down\n[0] Enable Rank 0: Must be set to 1 to enable use of this rank.\n[1] Enable Rank 1: Must be set to 1 to enable use of this rank. **/ uint8_t Ch2_RankEnable; -/** Offset 0x0021 +/** Offset 0x00C1 Ch2_DeviceWidth NOTE: Only for memory down\nDRAM Device Data Width populated on Ranks 0 and 1. **/ uint8_t Ch2_DeviceWidth; -/** Offset 0x0022 +/** Offset 0x00C2 Ch2_DramDensity NOTE: Only for memory down\nDRAM Device Density populated on Ranks 0 and 1. **/ uint8_t Ch2_DramDensity; -/** Offset 0x0023 +/** Offset 0x00C3 Ch2_Option [0] Rank Select Interleaving Enable. See Address Mapping section for full description.\n0 - Rank Select Interleaving disabled\n1 - Rank Select Interleaving enabled\n[1] Bank Address Hashing Enable. See Address Mapping section for full description.\n0 - Bank Address Hashing disabled\n1 - Bank Address Hashing enabled\n[3:2] Reserved\n[5:4] This register specifies the address mapping to be used:\n00 - 1KB (A)\n01 - 2KB (B). **/ uint8_t Ch2_Option; -/** Offset 0x0024 +/** Offset 0x00C4 Ch3_RankEnable NOTE: Only for memory down\n[0] Enable Rank 0: Must be set to 1 to enable use of this rank.\n[1] Enable Rank 1: Must be set to 1 to enable use of this rank. **/ uint8_t Ch3_RankEnable; -/** Offset 0x0025 +/** Offset 0x00C5 Ch3_DeviceWidth NOTE: Only for memory down\nDRAM Device Data Width populated on Ranks 0 and 1. **/ uint8_t Ch3_DeviceWidth; -/** Offset 0x0026 +/** Offset 0x00C6 Ch3_DramDensity NOTE: Only for memory down\nDRAM Device Density populated on Ranks 0 and 1. **/ uint8_t Ch3_DramDensity; -/** Offset 0x0027 +/** Offset 0x00C7 Ch3_Option [0] Rank Select Interleaving Enable. See Address Mapping section for full description.\n0 - Rank Select Interleaving disabled\n1 - Rank Select Interleaving enabled\n[1] Bank Address Hashing Enable. See Address Mapping section for full description.\n0 - Bank Address Hashing disabled\n1 - Bank Address Hashing enabled\n[3:2] Reserved\n[5:4] This register specifies the address mapping to be used:\n00 - 1KB (A)\n01 - 2KB (B). **/ uint8_t Ch3_Option; -/** Offset 0x0028 +/** Offset 0x00C8 Ch0_Bit_swizzling Channel 0 PHY to DUnit DQ mapping (only used if not 1-1 mapping)Range: 0-32. **/ uint8_t Ch0_Bit_swizzling[32]; -/** Offset 0x0048 +/** Offset 0x00E8 Ch1_Bit_swizzling Channel 1 PHY to DUnit DQ mapping (only used if not 1-1 mapping)Range: 0-32. **/ uint8_t Ch1_Bit_swizzling[32]; -/** Offset 0x0068 +/** Offset 0x0108 Ch2_Bit_swizzling Channel 2 PHY to DUnit DQ mapping (only used if not 1-1 mapping)Range: 0-32. **/ uint8_t Ch2_Bit_swizzling[32]; -/** Offset 0x0088 +/** Offset 0x0128 Ch3_Bit_swizzling Channel 3 PHY to DUnit DQ mapping (only used if not 1-1 mapping)Range: 0-32. **/ uint8_t Ch3_Bit_swizzling[32]; -/** Offset 0x00A8 +/** Offset 0x0148 **/ uint8_t DramReserved; } __attribute__((packed));
-#define FSP_IMAGE_ID 0x245053464C504124 /* '$APLFSP$' */ -#define FSP_IMAGE_REV 0x00060000 - -
struct TEMP_RAM_INIT_UPD { /** Offset 0x0000 @@ -306,6 +318,7 @@ struct TEMP_RAM_INIT_UPD { uint32_t ReservedTempRamInitUpd; } __attribute__((packed));
+ struct MEMORY_INIT_UPD { /** Offset 0x0000 **/ @@ -373,49 +386,40 @@ struct MEMORY_INIT_UPD { **/ uint8_t PrimaryVideoAdaptor; /** Offset 0x0095 - GT PM Support - Enable/Disable GT power management support. -**/ - uint8_t PmSupport; -/** Offset 0x0096 - RC6(Render Standby) - Enable/Disable render standby support. **/ - uint8_t EnableRenderStandby; -/** Offset 0x0097 - PAVP Enable - Enable/Disable Protected Audio Visual Path (PAVP). -**/ - uint8_t PavpEnable; -/** Offset 0x0098 -**/ - uint64_t UnusedUpdSpace3; -/** Offset 0x0000 + uint8_t UnusedUpdSpace3[11]; +/** Offset 0x00A0 **/ struct DRAM_CONFIG DramConfig; -/** Offset 0x01B9 +/** Offset 0x0149 +**/ + uint8_t UnusedUpdSpace4[31]; +/** Offset 0x0168 + FIT Table Pointer + FIT table pointer. **/ - uint8_t UnusedUpdSpace6[35]; -/** Offset 0x01DC + uint32_t FitTablePtr; +/** Offset 0x016C OEM File Loading Address Determine the memory base address to load a specified file from CSE file system after memory is available. **/ uint32_t OemLoadingBase; -/** Offset 0x01E0 +/** Offset 0x0170 OEM File Name to Load Specify a file name to load from CSE file system after memory is available. Empty indicates no file needs to be loaded. **/ uint8_t OemFileName[16]; -/** Offset 0x01F0 +/** Offset 0x0180 GPIO Table Pointer GPIO table pointer to a BL_GPIO_PAD_INIT structure. **/ struct BL_GPIO_PAD_INIT* GpioPadInitTablePtr; -/** Offset 0x01F4 +/** Offset 0x0184 **/ uint32_t ReservedMemoryInitUpd; } __attribute__((packed));
+ struct SILICON_INIT_UPD { /** Offset 0x0000 **/ @@ -427,23 +431,129 @@ struct SILICON_INIT_UPD { **/ uint8_t UnusedUpdSpace0[23]; /** Offset 0x0020 + ActiveProcessorCores + Number of active cores. +**/ + uint8_t ActiveProcessorCores; +/** Offset 0x0021 + Disable Core1 + Disable/Enable Core1. +**/ + uint8_t DisableCore1; +/** Offset 0x0022 + Disable Core2 + Disable/Enable Core2. +**/ + uint8_t DisableCore2; +/** Offset 0x0023 + Disable Core3 + Disable/Enable Core3. +**/ + uint8_t DisableCore3; +/** Offset 0x0024 + VMX Enable + Enable or Disable VMX. +**/ + uint8_t VmxEnable; +/** Offset 0x0025 + Memory region allocation for Processor Trace + Memory region allocation for Processor Trace, allowed range is from 4K (0x0) to 128MB (0xF); <b>0xFF: Disable. +**/ + uint8_t ProcTraceMemSize; +/** Offset 0x0026 + Enable Processor Trace + Enable or Disable Processor Trace feature. +**/ + uint8_t ProcTraceEnable; +/** Offset 0x0027 + Eist + Enable or Disable Intel SpeedStep Technology. +**/ + uint8_t Eist; +/** Offset 0x0028 + Boot PState + Boot PState with HFM or LFM. 0: HFM; 1: LFM. +**/ + uint8_t BootPState; +/** Offset 0x0029 + CPU power states (C-states) + Enable or Disable CPU power states (C-states). 0: Disable; 1: Enable. +**/ + uint8_t EnableCx; +/** Offset 0x002A + Enhanced C-states + Enable or Disable Enhanced C-states. 0: Disable; 1: Enable. +**/ + uint8_t C1e; +/** Offset 0x002B + Bi-Directional PROCHOT# + Enable or Disable Bi-Directional PROCHOT#; 0: Disable; 1: Enable. +**/ + uint8_t BiProcHot; +/** Offset 0x002C + Max Pkg Cstate + Max Pkg Cstate. 0:PkgC0C1; 1:PkgC2; 2:PkgC3; 3:PkgC6; 4:PkgC7; 5:PkgC7s; 6:PkgC8; 7:PkgC9; 8:PkgC10; 9:PkgCMax; 254:PkgCpuDefault; 255:PkgAuto. +**/ + uint8_t PkgCStateLimit; +/** Offset 0x002D +**/ + uint8_t UnusedUpdSpace1; +/** Offset 0x002E + C-State auto-demotion + C-State Auto Demotion. 0:Disable C1 and C3 Auto-demotion; 1:Enable C3/C6/C7 Auto-demotion to C1; 2:Enable C6/C7 Auto-demotion to C3; 3:Enable C6/C7 Auto-demotion to C1 and C3. +**/ + uint8_t CStateAutoDemotion; +/** Offset 0x002F + C-State un-demotion + C-State un-demotion. 0:Disable C1 and C3 Un-demotion; 1:Enable C1 Un-demotion; 2:Enable C3 Un-demotion; 3:Enable C1 and C3 Un-demotion. +**/ + uint8_t CStateUnDemotion; +/** Offset 0x0030 + Max Core C-State + Max Core C-State. 0:Unlimited;1:C1;2:C3;3:C6;4:C7;5:C8;6:C9;7:C10;8:CCx. +**/ + uint8_t MaxCoreCState; +/** Offset 0x0031 + Package C-State Demotion + Enable or Disable Package Cstate Demotion. 0:Disable; 1: Enable. +**/ + uint8_t PkgCStateDemotion; +/** Offset 0x0032 + Package C-State Un-demotion + Enable or Disable Package Cstate UnDemotion. 0:Disable; 1: Enable. +**/ + uint8_t PkgCStateUnDemotion; +/** Offset 0x0033 + Turbo Mode + Enable or Disable long duration Turbo Mode. 0:Disable; 1: Enable. +**/ + uint8_t TurboMode; +/** Offset 0x0034 +**/ + uint8_t UnusedUpdSpace2[12]; +/** Offset 0x0040 + HD-Audio I/O Buffer Ownership + Set HD-Audio I/O Buffer Ownership. +**/ + uint8_t HdAudioIoBufferOwnership; +/** Offset 0x0041 +**/ + uint8_t UnusedUpdSpace3[60]; +/** Offset 0x007D Enable SD controller Enable/disable SD Card controller. **/ uint8_t SdcardEnabled; -/** Offset 0x0021 +/** Offset 0x007E Enable SDIO controller Enable/disable SDIO controller. **/ uint8_t SdioEnabled; -/** Offset 0x0022 +/** Offset 0x007F Enable eMMC controller Enable/disable eMMC controller. **/ uint8_t eMMCEnabled; -/** Offset 0x0023 -**/ - uint8_t UnusedUpdSpace1[93]; /** Offset 0x0080 Enable SATA Enable/disable SATA controller. @@ -473,7 +583,7 @@ struct SILICON_INIT_UPD { Enable PCIE RP Enable/disable PCIE Root Ports. 0: disable, 1: enable. One byte for each port, byte0 for port1, byte1 for port2, and so on. **/ - uint8_t PcieRpEnable[6]; + uint8_t PcieRootPortEn[6]; /** Offset 0x008D Configure CLKREQ Number Configure Root Port CLKREQ Number if CLKREQ is supported. Each value in array can be between 0-6. One byte for each port, byte0 for port1, byte1 for port2, and so on. @@ -490,26 +600,91 @@ struct SILICON_INIT_UPD { **/ uint8_t PortUsb30Enable[6]; /** Offset 0x00A1 - Enable XHCI SSIC Eanble - Enable/disable XHCI SSIC port. + Enable XHCI SSIC ports + Enable/disable XHCI SSIC ports. One byte for each port, byte0 for port0, byte1 for port1. **/ - uint8_t SsicPortEnable; -/** Offset 0x00A2 + uint8_t SsicPortEnable[2]; +/** Offset 0x00A3 Enable SMBus Enable/disable SMBus controller. **/ uint8_t SmbusEnable; -/** Offset 0x00A3 +/** Offset 0x00A4 + High Definition Audio Verb Table Pointer + High Definition Audio Verb Table structure for initialization. **/ - uint8_t UnusedUpdSpace2[13]; -/** Offset 0x00B0 + struct BL_HDAUDIO_VERB_TABLE* HdaVerbTablePtr; +/** Offset 0x00A8 + Enable/Disable P2SB device hidden. + Enable/Disable P2SB device hidden. +**/ + uint8_t HideP2sb; +/** Offset 0x00A9 +**/ + uint8_t UnusedUpdSpace4[52]; +/** Offset 0x00DD + Ufs Enable/Disable + Enable/Disable Ufs. +**/ + uint8_t UfsEnabled; +/** Offset 0x00DE IPU Enable/Disable Enable/Disable IPU Device. **/ uint8_t IpuEn; -/** Offset 0x00B1 -**/ - uint8_t UnusedUpdSpace3[303]; +/** Offset 0x00DF + IMGU ACPI mode selection + 0=Auto, 1(Default)=IGFX Child device, 2=ACPI device +**/ + uint8_t IpuAcpiMode; +/** Offset 0x00E0 + ResetSelect + ResetSelect. 0x6:warm reset; 0xE:cold reset +**/ + uint8_t ResetSelect; +/** Offset 0x00E1 + CRIDSettings + PMC CRID setting. 0:Disable;1:CRID_1;2:CRID_2;3:CRID_3 +**/ + uint8_t CRIDSettings; +/** Offset 0x00E2 + Enable HPET + Enable/disable HPET. +**/ + uint8_t Hpet; +/** Offset 0x00E3 + Enable PCIE Clock Gating + Enable/disable PCIE Clock Gating.0:Enable;1:Disable +**/ + uint8_t PcieClockGatingDisabled; +/** Offset 0x00E4 + Enable PCIE Root Port 8xh Decode + Enable/disable PCIE Root Port 8xh Decode.0:Disable;1:Enable +**/ + uint8_t PcieRootPort8xhDecode; +/** Offset 0x00E5 + PCIE 8xh Decode Port Index + PCIE 8xh Decode Port Index. +**/ + uint8_t Pcie8xhDecodePortIndex; +/** Offset 0x00E6 + Enable PCIE Root Port Peer Memory Write + Enable/disable PCIE root port peer memory write.0:Disable;1:Enable +**/ + uint8_t PcieRootPortPeerMemoryWriteEnable; +/** Offset 0x00E7 + Enable SC Gaussian Mixture Models + Enable/disable SC Gaussian Mixture Models.0:Disable;1:Enable +**/ + uint8_t Gmm; +/** Offset 0x00E8 + Enable S0ix + Enable/disable S0ix.0:Disable;1:Enable +**/ + uint8_t S0ix; +/** Offset 0x00E9 +**/ + uint8_t UnusedUpdSpace5[247]; /** Offset 0x01E0 BMP Logo Data Size BMP logo data buffer size. @@ -526,11 +701,41 @@ struct SILICON_INIT_UPD { **/ uint32_t GraphicsConfigPtr; /** Offset 0x01EC + GT PM Support + Enable/Disable GT power management support. +**/ + uint8_t PmSupport; +/** Offset 0x01ED + RC6(Render Standby) + Enable/Disable render standby support. +**/ + uint8_t EnableRenderStandby; +/** Offset 0x01EE + PAVP Enable + Enable/Disable Protected Audio Visual Path (PAVP). +**/ + uint8_t PavpEnable; +/** Offset 0x01EF + PAVP PR3 + Enable/Disable PAVP PR3 +**/ + uint8_t PavpPr3; +/** Offset 0x01F0 + CdClock Frequency selection + 0: 144 Mhz, 1: 288 Mhz, 2: 384 Mhz, 3: 576 Mhz, 4(Default): 624 Mhz +**/ + uint8_t CdClock; +/** Offset 0x01F1 + Enable/Disable PeiGraphicsPeimInit + Enable(Default): Enable PeiGraphicsPeimInit, Disable: Disable PeiGraphicsPeimInit +**/ + uint8_t PeiGraphicsPeimInit; +/** Offset 0x01F2 **/ - uint8_t UnusedUpdSpace4[12]; -/** Offset 0x01F8 + uint8_t UnusedUpdSpace6[11]; +/** Offset 0x01FD **/ - uint32_t ReservedSiliconInitUpd; + uint8_t ReservedSiliconInitUpd; } __attribute__((packed));
#endif
