Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/51268 )
Change subject: soc/amd/cezanne: select common APOB NV cache code ......................................................................
BUG=b:181766974
Signed-off-by: Felix Held felix-coreboot@felixheld.de Change-Id: I660f19d18810c35dafcd75bcd1993216b7b09644 Reviewed-on: https://review.coreboot.org/c/coreboot/+/51268 Reviewed-by: Raul Rangel rrangel@chromium.org Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/soc/amd/cezanne/Kconfig M src/soc/amd/cezanne/romstage.c 2 files changed, 5 insertions(+), 0 deletions(-)
Approvals: build bot (Jenkins): Verified Raul Rangel: Looks good to me, approved
diff --git a/src/soc/amd/cezanne/Kconfig b/src/soc/amd/cezanne/Kconfig index d491da4..290fc22 100644 --- a/src/soc/amd/cezanne/Kconfig +++ b/src/soc/amd/cezanne/Kconfig @@ -31,6 +31,7 @@ select SOC_AMD_COMMON_BLOCK_ACPI select SOC_AMD_COMMON_BLOCK_ACPIMMIO select SOC_AMD_COMMON_BLOCK_AOAC + select SOC_AMD_COMMON_BLOCK_APOB select SOC_AMD_COMMON_BLOCK_BANKED_GPIOS select SOC_AMD_COMMON_BLOCK_DATA_FABRIC select SOC_AMD_COMMON_BLOCK_HAS_ESPI diff --git a/src/soc/amd/cezanne/romstage.c b/src/soc/amd/cezanne/romstage.c index b35e6a5..17c7d75 100644 --- a/src/soc/amd/cezanne/romstage.c +++ b/src/soc/amd/cezanne/romstage.c @@ -2,6 +2,7 @@
#include <acpi/acpi.h> #include <amdblocks/acpimmio.h> +#include <amdblocks/apob_cache.h> #include <amdblocks/memmap.h> #include <arch/cpu.h> #include <console/console.h> @@ -13,6 +14,8 @@ { FSP_M_CONFIG *mcfg = &mupd->FspmConfig;
+ mupd->FspmArchUpd.NvsBufferPtr = (uintptr_t)soc_fill_apob_cache(); + mcfg->pci_express_base_addr = CONFIG_MMCONF_BASE_ADDRESS; mcfg->tseg_size = CONFIG_SMM_TSEG_SIZE; mcfg->bert_size = CONFIG_ACPI_BERT_SIZE; @@ -31,6 +34,7 @@ post_code(0x41);
fsp_memory_init(acpi_is_wakeup_s3()); + soc_update_apob_cache();
/* Fixup settings FSP-M should not be changing */ fch_disable_legacy_dma_io();
