Raul Rangel has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/50451 )
Change subject: soc/amd/cezanne: Add PCI IRQ Router definitions ......................................................................
These definitions were identical to picasso. The only thing I changed was that I renamed Misc1 and Misc2 to HPET_L and HPET_H.
This change still doesn't write the PCI_IRQ register for all the PCI devices. We need to refactor the picasso pci_gpp code first.
TEST=Boot majolica and see FCH IRQs being programmed.
Signed-off-by: Raul E Rangel rrangel@chromium.org Change-Id: Ic7e637f234d3af426959a9bbd82a0dcf25bb3c8e --- M src/soc/amd/cezanne/Kconfig M src/soc/amd/cezanne/fch.c A src/soc/amd/cezanne/include/soc/amd_pci_int_defs.h 3 files changed, 140 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/51/50451/1
diff --git a/src/soc/amd/cezanne/Kconfig b/src/soc/amd/cezanne/Kconfig index a881ef8..25d703a 100644 --- a/src/soc/amd/cezanne/Kconfig +++ b/src/soc/amd/cezanne/Kconfig @@ -26,6 +26,7 @@ select SOC_AMD_COMMON_BLOCK_BANKED_GPIOS select SOC_AMD_COMMON_BLOCK_LPC select SOC_AMD_COMMON_BLOCK_NONCAR + select SOC_AMD_COMMON_BLOCK_PCI select SOC_AMD_COMMON_BLOCK_PCI_MMCONF select SOC_AMD_COMMON_BLOCK_PSP_GEN2 select SOC_AMD_COMMON_BLOCK_SMBUS diff --git a/src/soc/amd/cezanne/fch.c b/src/soc/amd/cezanne/fch.c index 5fb4f0a..c945982 100644 --- a/src/soc/amd/cezanne/fch.c +++ b/src/soc/amd/cezanne/fch.c @@ -1,10 +1,72 @@ /* SPDX-License-Identifier: GPL-2.0-only */
#include <amdblocks/acpimmio.h> +#include <amdblocks/amd_pci_util.h> #include <assert.h> +#include <bootstate.h> +#include <soc/amd_pci_int_defs.h> #include <soc/iomap.h> #include <soc/southbridge.h>
+/* + * Table of APIC register index and associated IRQ name. Using IDX_XXX_NAME + * provides a visible association with the index, therefore helping + * maintainability of table. If a new index/name is defined in + * amd_pci_int_defs.h, just add the pair at the end of this table. + * Order is not important. + */ +const static struct irq_idx_name irq_association[] = { + { PIRQ_A, "INTA#" }, + { PIRQ_B, "INTB#" }, + { PIRQ_C, "INTC#" }, + { PIRQ_D, "INTD#" }, + { PIRQ_E, "INTE#" }, + { PIRQ_F, "INTF#/GENINT2" }, + { PIRQ_G, "INTG#" }, + { PIRQ_H, "INTH#" }, + { PIRQ_MISC, "Misc" }, + { PIRQ_MISC0, "Misc0" }, + { PIRQ_HPET_L, "HPET_L" }, + { PIRQ_HPET_H, "HPET_H" }, + { PIRQ_SIRQA, "Ser IRQ INTA" }, + { PIRQ_SIRQB, "Ser IRQ INTB" }, + { PIRQ_SIRQC, "Ser IRQ INTC" }, + { PIRQ_SIRQD, "Ser IRQ INTD" }, + { PIRQ_SCI, "SCI" }, + { PIRQ_SMBUS, "SMBUS" }, + { PIRQ_ASF, "ASF" }, + { PIRQ_PMON, "PerMon" }, + { PIRQ_SD, "SD" }, + { PIRQ_SDIO, "SDIO" }, + { PIRQ_CIR, "CIR" }, + { PIRQ_GPIOA, "GPIOa" }, + { PIRQ_GPIOB, "GPIOb" }, + { PIRQ_GPIOC, "GPIOc" }, + { PIRQ_SATA, "SATA" }, + { PIRQ_EMMC, "eMMC" }, + { PIRQ_GPP0, "GPP0" }, + { PIRQ_GPP1, "GPP1" }, + { PIRQ_GPP2, "GPP2" }, + { PIRQ_GPP3, "GPP3" }, + { PIRQ_GPIO, "GPIO" }, + { PIRQ_I2C0, "I2C0" }, + { PIRQ_I2C1, "I2C1" }, + { PIRQ_I2C2, "I2C2" }, + { PIRQ_I2C3, "I2C3" }, + { PIRQ_UART0, "UART0" }, + { PIRQ_UART1, "UART1" }, + { PIRQ_I2C4, "I2C4" }, + { PIRQ_I2C5, "I2C5" }, + { PIRQ_UART2, "UART2" }, + { PIRQ_UART3, "UART3" }, +}; + +const struct irq_idx_name *sb_get_apic_reg_association(size_t *size) +{ + *size = ARRAY_SIZE(irq_association); + return irq_association; +} + static void fch_init_acpi_ports(void) { /* We use some of these ports in SMM regardless of whether or not @@ -38,3 +100,15 @@ void fch_final(void *chip_info) { } + +static void set_pci_irqs(void *unused) +{ + /* Write PCI_INTR regs 0xC00/0xC01 */ + write_pci_int_table(); +} + +/* + * Hook this function into the PCI state machine + * on entry into BS_DEV_ENABLE. + */ +BOOT_STATE_INIT_ENTRY(BS_DEV_ENABLE, BS_ON_ENTRY, set_pci_irqs, NULL); diff --git a/src/soc/amd/cezanne/include/soc/amd_pci_int_defs.h b/src/soc/amd/cezanne/include/soc/amd_pci_int_defs.h new file mode 100644 index 0000000..c0c4cd1 --- /dev/null +++ b/src/soc/amd/cezanne/include/soc/amd_pci_int_defs.h @@ -0,0 +1,65 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#ifndef AMD_CEZANNE_AMD_PCI_INT_DEFS_H +#define AMD_CEZANNE_AMD_PCI_INT_DEFS_H + +/* + * PIRQ and device routing - these define the index into the + * FCH PCI_INTR 0xC00/0xC01 interrupt routing table. + */ + +#define PIRQ_NC 0x1f /* Not Used */ +#define PIRQ_A 0x00 /* INT A */ +#define PIRQ_B 0x01 /* INT B */ +#define PIRQ_C 0x02 /* INT C */ +#define PIRQ_D 0x03 /* INT D */ +#define PIRQ_E 0x04 /* INT E */ +#define PIRQ_F 0x05 /* INT F */ +#define PIRQ_G 0x06 /* INT G */ +#define PIRQ_H 0x07 /* INT H */ +#define PIRQ_MISC 0x08 /* Miscellaneous IRQ Settings */ +#define PIRQ_MISC0 0x09 /* Miscellaneous0 IRQ Settings */ +#define PIRQ_HPET_L 0x0a /* HPET CONF_CAP_H[0:7] */ +#define PIRQ_HPET_H 0x0b /* HPET CONF_CAP_H[15:8] */ +#define PIRQ_SIRQA 0x0c /* Serial IRQ INTA */ +#define PIRQ_SIRQB 0x0d /* Serial IRQ INTB */ +#define PIRQ_SIRQC 0x0e /* Serial IRQ INTC */ +#define PIRQ_SIRQD 0x0f /* Serial IRQ INTD */ +#define PIRQ_SCI 0x10 /* SCI IRQ */ +#define PIRQ_SMBUS 0x11 /* SMBUS */ +#define PIRQ_ASF 0x12 /* ASF */ +/* 0x13-0x15 reserved */ +#define PIRQ_PMON 0x16 /* Performance Monitor */ +#define PIRQ_SD 0x17 /* SD */ +/* 0x18-0x19 reserved */ +#define PIRQ_SDIO 0x1a /* SDIO */ +/* 0x1b-0x1f reserved */ +#define PIRQ_CIR 0x20 /* CIR, no IRQ connected */ +#define PIRQ_GPIOA 0x21 /* GPIOa from PAD_FANIN0 */ +#define PIRQ_GPIOB 0x22 /* GPIOb from PAD_FANOUT0 */ +#define PIRQ_GPIOC 0x23 /* GPIOc no IRQ connected */ +/* 0x24-0x40 reserved */ +#define PIRQ_SATA 0x41 /* SATA */ +/* 0x42 reserved */ +#define PIRQ_EMMC 0x43 /* eMMC */ +/* 0x44-0x4f reserved */ +#define PIRQ_GPP0 0x50 /* GPPInt0 */ +#define PIRQ_GPP1 0x51 /* GPPInt1 */ +#define PIRQ_GPP2 0x52 /* GPPInt2 */ +#define PIRQ_GPP3 0x53 /* GPPInt3 */ +/* 0x54-0x61 reserved */ +#define PIRQ_GPIO 0x62 /* GPIO Controller Interrupt */ +/* 0x63-0x6f reserved */ +#define PIRQ_I2C0 0x70 /* I2C0 */ +#define PIRQ_I2C1 0x71 /* I2C1 */ +#define PIRQ_I2C2 0x72 /* I2C2 */ +#define PIRQ_I2C3 0x73 /* I2C3 */ +#define PIRQ_UART0 0x74 /* UART0 */ +#define PIRQ_UART1 0x75 /* UART1 */ +#define PIRQ_I2C4 0x76 /* I2C4 */ +#define PIRQ_I2C5 0x77 /* I2C5 */ +#define PIRQ_UART2 0x78 /* UART2 */ +#define PIRQ_UART3 0x79 /* UART3 */ +/* 0x7a-0x7f reserved */ + +#endif /* AMD_CEZANNE_AMD_PCI_INT_DEFS_H */
