Martin L Roth has submitted this change. ( https://review.coreboot.org/c/coreboot/+/81287?usp=email )
Change subject: libpayload: Make GPL commonlib includes available to payloads and tests ......................................................................
CB:77968 made some non-BSD commonlib files part of libpayload when CONFIG_LP_GPL is set. This patch exports those headers to the payload (again only when CONFIG_LP_GPL is set) so that payloads can also call the functions in them directly.
Also make those includes available to tests so that their functions can be tested. There's no menuconfig for unit tests, so they are included unconditionally, but this should be fine since the tests are standalone and won't have to link with any proprietary third-party code.
Change-Id: Ifc3e52ee5c3e51520f7b7d44b483bfcb0e8380f8 Signed-off-by: Julius Werner jwerner@chromium.org Reviewed-on: https://review.coreboot.org/c/coreboot/+/81287 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Maximilian Brune maximilian.brune@9elements.com --- M payloads/libpayload/Makefile.mk M payloads/libpayload/bin/lpgcc M payloads/libpayload/tests/Makefile.mk 3 files changed, 8 insertions(+), 0 deletions(-)
Approvals: Maximilian Brune: Looks good to me, approved build bot (Jenkins): Verified
diff --git a/payloads/libpayload/Makefile.mk b/payloads/libpayload/Makefile.mk index e000868..afaa06d 100644 --- a/payloads/libpayload/Makefile.mk +++ b/payloads/libpayload/Makefile.mk @@ -133,6 +133,10 @@ find include -type f -exec install -m644 {} $(DESTDIR)/libpayload/{} ; cd $(coreboottop)/src/commonlib/bsd && find include -type d -exec install -m755 -d $(abspath $(DESTDIR))/libpayload/{} ; cd $(coreboottop)/src/commonlib/bsd && find include -type f -exec install -m644 {} $(abspath $(DESTDIR))/libpayload/{} ; +ifeq ($(CONFIG_LP_GPL),y) + cd $(coreboottop)/src/commonlib && find include -type d -exec install -m755 -d $(abspath $(DESTDIR))/libpayload/{} ; + cd $(coreboottop)/src/commonlib && find include -type f -exec install -m644 {} $(abspath $(DESTDIR))/libpayload/{} ; +endif install -m 644 $(obj)/libpayload-config.h $(DESTDIR)/libpayload/include $(foreach item,$(includes), \ install -m 755 -d $(DESTDIR)/libpayload/include/$(call extract_nth,2,$(item)); \ diff --git a/payloads/libpayload/bin/lpgcc b/payloads/libpayload/bin/lpgcc index 35fa558..bdc1518 100755 --- a/payloads/libpayload/bin/lpgcc +++ b/payloads/libpayload/bin/lpgcc @@ -170,6 +170,9 @@
_CFLAGS="$_CFLAGS -include $BASE/../../../src/commonlib/bsd/include/commonlib/bsd/compiler.h" _CFLAGS="$_CFLAGS -I$BASE/../../../src/commonlib/bsd/include" + if [ "$CONFIG_LP_GPL" = y ]; then + _CFLAGS="$_CFLAGS -I$BASE/../../../src/commonlib/include" + fi _CFLAGS="$_CFLAGS -I$BASE/../../../3rdparty/vboot/firmware/include" else _CFLAGS="$_CFLAGS -include $BASE/../include/commonlib/bsd/compiler.h" diff --git a/payloads/libpayload/tests/Makefile.mk b/payloads/libpayload/tests/Makefile.mk index 9bac9e6..7118906 100644 --- a/payloads/libpayload/tests/Makefile.mk +++ b/payloads/libpayload/tests/Makefile.mk @@ -34,6 +34,7 @@ TEST_CFLAGS += -include $(coreboottop)/src/commonlib/bsd/include/commonlib/bsd/compiler.h TEST_CFLAGS += -Iinclude -Iinclude/mock TEST_CFLAGS += -I$(coreboottop)/src/commonlib/bsd/include +TEST_CFLAGS += -I$(coreboottop)/src/commonlib/include TEST_CFLAGS += -I$(dir $(TEST_KCONFIG_AUTOHEADER)) TEST_CFLAGS += -I$(VBOOT_SOURCE)/firmware/include
