Richard Spiegel has uploaded this change for review. ( https://review.coreboot.org/25192
Change subject: soc/amd/stoneyridge/southbridge.c: Upgrade UART GPIO programming ......................................................................
Procedure configure_stoneyridge_uart() uses direct GPIO mux programming. Replace old style direct mux GPIO programming with a GPIO table and a call to centralized GPIO programming.
BUG=b:74258015 TEST=Build and boot kahlee, observing serial output does not changes from previous serial output.
Change-Id: Ie67051d7b90fa294090f6bfc518c6c074d98cc98 Signed-off-by: Richard Spiegel richard.spiegel@silverbackltd.com --- M src/soc/amd/stoneyridge/southbridge.c 1 file changed, 8 insertions(+), 4 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/92/25192/1
diff --git a/src/soc/amd/stoneyridge/southbridge.c b/src/soc/amd/stoneyridge/southbridge.c index a41ad1b..cce87e3 100644 --- a/src/soc/amd/stoneyridge/southbridge.c +++ b/src/soc/amd/stoneyridge/southbridge.c @@ -331,13 +331,17 @@ } while (!status); }
+const static struct soc_amd_stoneyridge_gpio uart_gpio[] = { + PAD_NF(GPIO_137, UART0_RTS_L, PULL_NONE), + PAD_NF(GPIO_138, UART0_TXD, PULL_NONE), + PAD_NF(GPIO_142, UART1_RTS_L, PULL_NONE), + PAD_NF(GPIO_143, UART1_TXD, PULL_NONE) +}; + void configure_stoneyridge_uart(void) { /* Set the GPIO mux to UART */ - write8((void *)FCH_IOMUXx89_UART0_RTS_L_EGPIO137, 0); - write8((void *)FCH_IOMUXx8A_UART0_TXD_EGPIO138, 0); - write8((void *)FCH_IOMUXx8E_UART1_RTS_L_EGPIO142, 0); - write8((void *)FCH_IOMUXx8F_UART1_TXD_EGPIO143, 0); + sb_program_gpios(uart_gpio, ARRAY_SIZE(uart_gpio)); }
void sb_pci_port80(void)
