Angel Pons has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/55224 )
Change subject: soc/intel/skylake: Auto-configure SerialIoDevMode UPD ......................................................................
Introduce the `DERIVE_SERIALIO_CFG_FROM_DEV_STATE` Kconfig symbol, which allows omitting the `SerialIoDevMode` setting from devicetrees where the SerialIO settings can be derived from the PCI devices' state. Also, when the `INTEL_LPSS_UART_FOR_CONSOLE` option is selected, configure the UART specified by `UART_FOR_CONSOLE` to have FSP skip initialisation for it.
Also, as an example, transform hp/280_g2 to make use of this code.
Change-Id: I59ec760e4dcc6b64e40c6ebd402642070f1de33a Signed-off-by: Angel Pons th3fanbus@gmail.com --- M src/mainboard/hp/280_g2/Kconfig M src/mainboard/hp/280_g2/devicetree.cb M src/soc/intel/skylake/Kconfig M src/soc/intel/skylake/chip.c 4 files changed, 51 insertions(+), 7 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/24/55224/1
diff --git a/src/mainboard/hp/280_g2/Kconfig b/src/mainboard/hp/280_g2/Kconfig index 10f6828..4f18548 100644 --- a/src/mainboard/hp/280_g2/Kconfig +++ b/src/mainboard/hp/280_g2/Kconfig @@ -5,6 +5,7 @@ config BOARD_SPECIFIC_OPTIONS def_bool y select BOARD_ROMSIZE_KB_8192 + select DERIVE_SERIALIO_CFG_FROM_DEV_STATE select HAVE_ACPI_RESUME select HAVE_ACPI_TABLES select INTEL_GMA_HAVE_VBT diff --git a/src/mainboard/hp/280_g2/devicetree.cb b/src/mainboard/hp/280_g2/devicetree.cb index 98fccc9..aefebf1 100644 --- a/src/mainboard/hp/280_g2/devicetree.cb +++ b/src/mainboard/hp/280_g2/devicetree.cb @@ -5,10 +5,6 @@ .chipset_lockdown = CHIPSET_LOCKDOWN_COREBOOT, }"
- register "SerialIoDevMode" = "{ - [PchSerialIoIndexUart2] = PchSerialIoSkipInit, /* Routed to debug header */ - }" - register "eist_enable" = "1"
device cpu_cluster 0 on @@ -76,7 +72,7 @@ }" # DevSlp not supported end - device pci 19.0 on end # UART #2 + device pci 19.0 on end # UART #2 (routed to debug header) device pci 1c.0 off end # RP #1 device pci 1c.1 off end # RP #2 device pci 1c.2 off end # RP #3 diff --git a/src/soc/intel/skylake/Kconfig b/src/soc/intel/skylake/Kconfig index 3f02974..1fbdc39 100644 --- a/src/soc/intel/skylake/Kconfig +++ b/src/soc/intel/skylake/Kconfig @@ -177,6 +177,14 @@ string default "8086,0406"
+config DERIVE_SERIALIO_CFG_FROM_DEV_STATE + bool + help + Selected by mainboards where the values for the `SerialIoDevMode` FSP + UPD can be derived from the PCI devices' state in the devicetree, and + the INTEL_LPSS_UART_FOR_CONSOLE and UART_FOR_CONSOLE Kconfig settings. + When enabled, the `SerialIoDevMode` setting in chip config is useless. + config SKYLAKE_SOC_PCH_H bool default n diff --git a/src/soc/intel/skylake/chip.c b/src/soc/intel/skylake/chip.c index d4e8341..48b9c0b 100644 --- a/src/soc/intel/skylake/chip.c +++ b/src/soc/intel/skylake/chip.c @@ -1,5 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0-only */
+#include <assert.h> #include <bootsplash.h> #include <cbmem.h> #include <fsp/api.h> @@ -220,6 +221,40 @@ .init = &soc_init_pre_device, };
+static void fsp_serialio_config(FSP_S_CONFIG *params, struct soc_intel_skylake_config *config) +{ + const unsigned int serialio_devfn[] = { + [PchSerialIoIndexI2C0] = PCH_DEVFN_I2C0, + [PchSerialIoIndexI2C1] = PCH_DEVFN_I2C1, + [PchSerialIoIndexI2C2] = PCH_DEVFN_I2C2, + [PchSerialIoIndexI2C3] = PCH_DEVFN_I2C3, + [PchSerialIoIndexI2C4] = PCH_DEVFN_I2C4, + [PchSerialIoIndexI2C5] = PCH_DEVFN_I2C5, + [PchSerialIoIndexSpi0] = PCH_DEVFN_GSPI0, + [PchSerialIoIndexSpi1] = PCH_DEVFN_GSPI1, + [PchSerialIoIndexUart0] = PCH_DEVFN_UART0, + [PchSerialIoIndexUart1] = PCH_DEVFN_UART1, + [PchSerialIoIndexUart2] = PCH_DEVFN_UART2, + }; + _Static_assert(ARRAY_SIZE(serialio_devfn) == PchSerialIoIndexMax, + "serialio_devfn array size is wrong"); + + _Static_assert(!CONFIG(INTEL_LPSS_UART_FOR_CONSOLE) || + (CONFIG_UART_FOR_CONSOLE >= 0 && CONFIG_UART_FOR_CONSOLE <= 2), + "Value for UART_FOR_CONSOLE is invalid"); + + for (size_t i = 0; i < ARRAY_SIZE(serialio_devfn); i++) { + const bool pcidev_on = is_dev_enabled(pcidev_path_on_root(serialio_devfn[i])); + params->SerialIoDevMode[i] = pcidev_on ? PchSerialIoPci : PchSerialIoDisabled; + } + + if (CONFIG(INTEL_LPSS_UART_FOR_CONSOLE)) { + const size_t i = PchSerialIoIndexUart0 + CONFIG_UART_FOR_CONSOLE; + if (params->SerialIoDevMode[i] != PchSerialIoDisabled) + params->SerialIoDevMode[i] = PchSerialIoSkipInit; + } +} + /* UPD parameters to be initialized before SiliconInit */ void platform_fsp_silicon_init_params_cb(FSPS_UPD *supd) { @@ -347,8 +382,12 @@
params->EnableTcoTimer = CONFIG(USE_PM_ACPI_TIMER);
- memcpy(params->SerialIoDevMode, config->SerialIoDevMode, - sizeof(params->SerialIoDevMode)); + if (CONFIG(DERIVE_SERIALIO_CFG_FROM_DEV_STATE)) { + fsp_serialio_config(params, config); + } else { + memcpy(params->SerialIoDevMode, config->SerialIoDevMode, + sizeof(params->SerialIoDevMode)); + }
dev = pcidev_path_on_root(PCH_DEVFN_CIO); params->PchCio2Enable = dev && dev->enabled;
