Patrick Georgi (pgeorgi@google.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/8731
commit 558a0faffe9ca750ba6b54148c145940a19a313d Author: Furquan Shaikh furquan@google.com Date: Sun Aug 24 22:47:20 2014 -0700
libpayload: Add support for memory barriers
Add support for memory barriers in arch {arm,arm64,x86}. This is required to force strict CPU ordering. Definitions are based on FREEBSD atomic.h definitions.
BUG=chrome-os-partner:31533 BRANCH=None TEST=Memory barriers tested with ehci driver on arm64
Change-Id: I50060b0f33a6bd6cb95e829df079df379b2ff2a5 Signed-off-by: Patrick Georgi pgeorgi@chromium.org Original-Commit-Id: 937d66cdab92a8521ede8307f5af8f5c20d3e552 Original-Change-Id: Ie51e3452f7a254b24111000da5dbe8714ac22223 Original-Signed-off-by: Furquan Shaikh furquan@google.com Original-Reviewed-on: https://chromium-review.googlesource.com/213916 Original-Tested-by: Furquan Shaikh furquan@chromium.org Original-Reviewed-by: Julius Werner jwerner@chromium.org Original-Reviewed-by: Aaron Durbin adurbin@chromium.org Original-Commit-Queue: Furquan Shaikh furquan@chromium.org --- payloads/libpayload/include/arm/arch/barrier.h | 66 ++++++++++++++++++++++ payloads/libpayload/include/arm/arch/cache.h | 18 +----- payloads/libpayload/include/arm64/arch/barrier.h | 70 ++++++++++++++++++++++++ payloads/libpayload/include/arm64/arch/cache.h | 22 +++----- payloads/libpayload/include/x86/arch/barrier.h | 38 +++++++++++++ 5 files changed, 184 insertions(+), 30 deletions(-)
diff --git a/payloads/libpayload/include/arm/arch/barrier.h b/payloads/libpayload/include/arm/arch/barrier.h new file mode 100644 index 0000000..fde55fa --- /dev/null +++ b/payloads/libpayload/include/arm/arch/barrier.h @@ -0,0 +1,66 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2014 Google Inc. + * Copyright (C) 2003-2004 Olivier Houchard + * Copyright (C) 1994-1997 Mark Brinicombe + * Copyright (C) 1994 Brini + * All rights reserved. + * + * This code is derived from software written for Brini by Mark Brinicombe + * + * Redistribution and use in source and binary forms, with or without + * modification, are permitted provided that the following conditions + * are met: + * 1. Redistributions of source code must retain the above copyright + * notice, this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright + * notice, this list of conditions and the following disclaimer in the + * documentation and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE + * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF + * SUCH DAMAGE. + * + */ + +#ifndef __ARCH_BARRIER_H_ +#define __ARCH_BARRIER_H__ + +#include <arch/cache.h> + +/* + * Description of different memory barriers introduced: + * + * Memory barrier(mb) - Guarantees that all memory accesses specified before the + * barrier will happen before all memory accesses specified after the barrier + * + * Read memory barrier (rmb) - Guarantees that all read memory accesses + * specified before the barrier will happen before all read memory accesses + * specified after the barrier + * + * Write memory barrier (wmb) - Guarantees that all write memory accesses + * specified before the barrier will happen before all write memory accesses + * specified after the barrier + */ + +/* + * According to ARM Reference Manual (ARMv7-A), by default dmb ensures: + * Full system is the required shareability domain + * Reads and writes are the required access types. + */ +#define mb() dmb() +#define rmb() dmb() +#define wmb() dmb() + +#endif /* __ARCH_BARRIER_H__ */ diff --git a/payloads/libpayload/include/arm/arch/cache.h b/payloads/libpayload/include/arm/arch/cache.h index 647ec42..67f6fd4 100644 --- a/payloads/libpayload/include/arm/arch/cache.h +++ b/payloads/libpayload/include/arm/arch/cache.h @@ -70,24 +70,12 @@ /* * Sync primitives */ - /* data memory barrier */ -static inline void dmb(void) -{ - asm volatile ("dmb" : : : "memory"); -} - +#define dmb() asm volatile ("dmb" : : : "memory") /* data sync barrier */ -static inline void dsb(void) -{ - asm volatile ("dsb" : : : "memory"); -} - +#define dsb() asm volatile ("dsb" : : : "memory") /* instruction sync barrier */ -static inline void isb(void) -{ - asm volatile ("isb" : : : "memory"); -} +#define isb() asm volatile ("isb" : : : "memory")
/* * Low-level TLB maintenance operations diff --git a/payloads/libpayload/include/arm64/arch/barrier.h b/payloads/libpayload/include/arm64/arch/barrier.h new file mode 100644 index 0000000..de1b165 --- /dev/null +++ b/payloads/libpayload/include/arm64/arch/barrier.h @@ -0,0 +1,70 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2014 Google Inc. + * Copyright (C) 2003-2004 Olivier Houchard + * Copyright (C) 1994-1997 Mark Brinicombe + * Copyright (C) 1994 Brini + * All rights reserved. + * + * This code is derived from software written for Brini by Mark Brinicombe + * + * Redistribution and use in source and binary forms, with or without + * modification, are permitted provided that the following conditions + * are met: + * 1. Redistributions of source code must retain the above copyright + * notice, this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright + * notice, this list of conditions and the following disclaimer in the + * documentation and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE + * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF + * SUCH DAMAGE. + * + */ + +#ifndef __ARCH_BARRIER_H_ +#define __ARCH_BARRIER_H__ + +#include <arch/cache.h> + +/* + * Description of different memory barriers introduced: + * + * Memory barrier(mb) - Guarantees that all memory accesses specified before the + * barrier will happen before all memory accesses specified after the barrier + * + * Read memory barrier (rmb) - Guarantees that all read memory accesses + * specified before the barrier will happen before all read memory accesses + * specified after the barrier + * + * Write memory barrier (wmb) - Guarantees that all write memory accesses + * specified before the barrier will happen before all write memory accesses + * specified after the barrier + */ + +/* + * According to ARMv8 Instruction Set Overview: + * Options specified to dmb instruction have the following meaning: + * Option Ordered accesses + * sy any-any + * ld load-load, load-store + * st store-store + */ + +#define mb() dmb_opt(sy) +#define rmb() dmb_opt(ld) +#define wmb() dmb_opt(st) + +#endif /* __ARCH_BARRIER_H__ */ diff --git a/payloads/libpayload/include/arm64/arch/cache.h b/payloads/libpayload/include/arm64/arch/cache.h index 2d3175e..f03d09b 100644 --- a/payloads/libpayload/include/arm64/arch/cache.h +++ b/payloads/libpayload/include/arm64/arch/cache.h @@ -70,24 +70,16 @@ /* * Sync primitives */ - /* data memory barrier */ -static inline void dmb(void) -{ - asm volatile ("dmb sy" : : : "memory"); -} - +#define dmb_opt(opt) asm volatile ("dmb " #opt : : : "memory") /* data sync barrier */ -static inline void dsb(void) -{ - asm volatile ("dsb sy" : : : "memory"); -} - +#define dsb_opt(opt) asm volatile ("dsb " #opt : : : "memory") /* instruction sync barrier */ -static inline void isb(void) -{ - asm volatile ("isb" : : : "memory"); -} +#define isb_opt(opt) asm volatile ("isb " #opt : : : "memory") + +#define dmb() dmb_opt(sy) +#define dsb() dsb_opt(sy) +#define isb() isb_opt()
/* * Low-level TLB maintenance operations diff --git a/payloads/libpayload/include/x86/arch/barrier.h b/payloads/libpayload/include/x86/arch/barrier.h new file mode 100644 index 0000000..5e2cfec --- /dev/null +++ b/payloads/libpayload/include/x86/arch/barrier.h @@ -0,0 +1,38 @@ +/* + * This file is part of the coreboot project. + * + * Copyright 2014 Google Inc. + * + * Redistribution and use in source and binary forms, with or without + * modification, are permitted provided that the following conditions + * are met: + * 1. Redistributions of source code must retain the above copyright + * notice, this list of conditions and the following disclaimer. + * 2. Redistributions in binary form must reproduce the above copyright + * notice, this list of conditions and the following disclaimer in the + * documentation and/or other materials provided with the distribution. + * 3. The name of the author may not be used to endorse or promote products + * derived from this software without specific prior written permission. + * + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE + * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF + * SUCH DAMAGE. + * + */ + +#ifndef __ARCH_BARRIER_H_ +#define __ARCH_BARRIER_H__ + +#define mb() +#define rmb() +#define wmb() + +#endif /* __ARCH_BARRIER_H__ */
