Timothy Pearson (tpearson@raptorengineering.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/18074
commit ca319c536629a4075ab3c8b73386ccfd9184668f Author: Timothy Pearson tpearson@raptorengineering.com Date: Mon Jan 9 14:54:24 2017 -0600
amd/mct/ddr3: Free malloced resources in failure branches
Malloced resources were not freed in failure branches during S3 parameter save. Clean up Coverity warnings by freeing resources in failure branches.
Found-by: Coverity Scan #1347344 Change-Id: I5f119874e52ef2090ca1579db170a49a2a6a0a2a Signed-off-by: Timothy Pearson tpearson@raptorengineering.com --- src/northbridge/amd/amdmct/mct_ddr3/s3utils.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/src/northbridge/amd/amdmct/mct_ddr3/s3utils.c b/src/northbridge/amd/amdmct/mct_ddr3/s3utils.c index 4013c2e..f69b6c4 100644 --- a/src/northbridge/amd/amdmct/mct_ddr3/s3utils.c +++ b/src/northbridge/amd/amdmct/mct_ddr3/s3utils.c @@ -1123,13 +1123,16 @@ int8_t save_mct_information_to_nvram(void) set_option("allow_spd_nvram_cache_restore", &nvram);
printk(BIOS_DEBUG, "Hardware configuration unchanged since last boot; skipping write\n"); + free(persistent_data); return 0; }
/* Obtain CBFS file offset */ s3nv_offset = get_s3nv_file_offset(); - if (s3nv_offset == -1) + if (s3nv_offset == -1) { + free(persistent_data); return -1; + }
/* Align flash pointer to nearest boundary */ s3nv_offset &= ~(CONFIG_S3_DATA_SIZE-1);
