Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/60831 )
Change subject: util/scripts: Add options to update_submodules ......................................................................
This extends and adds various options to the update_submodules script.
Extensions: - Add help text - Add all options, but specifically allow a single repo to be specified, along with a minimum number of changes instead of being fixed at 10. - Make it a more formal script with main() and functions - Show changes in commit message, unless there are > 65 commits.
Options: -c | --changes <#> Specify the minimum number of changes to update a repo -h | --help Print usage and exit -R | --repo <dir> Specify a single repo directory to update -s | --skipsync Assume that repos are already synced -V | --version Print the version and exit
This does not fix style issues in the original, which will be fixed in a follow-on commit.
Signed-off-by: Martin Roth gaumless@gmail.com Change-Id: I222103babff7d5f4f8eb02869c598a4e06748a17 Reviewed-on: https://review.coreboot.org/c/coreboot/+/60831 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Raul Rangel rrangel@chromium.org --- M util/scripts/update_submodules 1 file changed, 135 insertions(+), 38 deletions(-)
Approvals: build bot (Jenkins): Verified Raul Rangel: Looks good to me, approved
diff --git a/util/scripts/update_submodules b/util/scripts/update_submodules index 854a943..6b8eb09 100755 --- a/util/scripts/update_submodules +++ b/util/scripts/update_submodules @@ -7,55 +7,152 @@ # number of changes, create a commit to update the submodule to the # new version.
+set -eu -o pipefail + +VERSION="1.01" +PROGRAM=$0 +PROGNAME="$(basename "${PROGRAM}")" + export LANG=C export LC_ALL=C export TZ=UTC0
min_commits=10 - TOP=${PWD} SUBMODULES_WITH_UPDATES=0 -submodule_dirs=$(git submodule foreach pwd | grep -v Entering) +submodule_dirs=() +skip_sync="" +max_commits_to_list=65
-( -echo "Checking submodules..." -for submodule in $submodule_dirs; do - cd "$submodule" || exit 1 - initial_commit_id="$(git log --pretty='%h' -n 1)" - initial_commit_description="$(git log --pretty='%ci - (%s)' -n 1)" - git fetch 2>/dev/null - updated_commit_id="$(git log --pretty='%h' -n 1 origin/master)" - updated_commit_description="$(git log --pretty='%ci - (%s)' -n 1 "${updated_commit_id}")" - if [ "${initial_commit_id}" = "${updated_commit_id}" ]; then - # echo "No updates for ${submodule}" - continue +show_version() { + echo "${PROGNAME} version ${VERSION}" + echo +} + +usage() { + echo "Usage: ${PROGNAME} [options]" + echo + echo "Options:" + echo " -c | --changes <#> Specify the minimum number of changes to update a repo" + echo " -h | --help Print usage and exit" + echo " -R | --repo <dir> Specify a single repo directory to update" + echo " -s | --skipsync Assume that repos are already synced" + echo " -V | --version Print the version and exit" + echo +} + +get_args() { + args=$(getopt -l changes:,help,repo:,skipsync,version -o c:hR:sV -- "$@") + getopt_ret=$? + eval set -- "${args}" + + if [ ${getopt_ret} != 0 ]; then + usage + exit 1 fi - SUBMODULES_WITH_UPDATES+=1 - update_count="$(git log --oneline "${initial_commit_id}..${updated_commit_id}" | wc -l)" - echo "${update_count} new commits for ${submodule}" - if [ "${update_count}" -ge "${min_commits}" ]; then - echo "Creating commit to update ${submodule##*/} submodule" - git checkout "${updated_commit_id}" > /dev/null 2>&1 - cd "${TOP}" || exit 1 - sleep 1 - git add "${submodule}" > /dev/null 2>&1 || exit 1 - sleep 1 - git commit -s -F- > /dev/null 2>&1 <<EOF -Update ${submodule##*/} submodule to upstream master
-Updating from commit id ${initial_commit_id}: -$initial_commit_description + while true; do + local opt + opt="$1" + shift + case "${opt}" in + -c | --changes) + min_commits="${1}" + shift + ;; + -h | --help) + usage + exit 0 + ;; + -R | --repo) + submodule_dirs=("$(readlink -f "${1}")") + shift + if [[ ! -d "${submodule_dirs[0]}" ]]; then + echo "Error: ${submodule_dirs[0]} is not valid." + usage + exit 1 + fi + ;; + -s | --skipsync) + skip_sync=1 + ;; + -V | --version) + exit 0 + ;; + *) + break + ;; + esac + done +}
-to commit id ${updated_commit_id}: -${updated_commit_description}
-This brings in ${update_count} new commits. -EOF - sleep 1 +main() { + show_version + get_args "$@" + + if (( ${#submodule_dirs[@]} == 0 )); then + readarray -t submodule_dirs < <(git submodule foreach pwd | grep -v "Entering") fi -done
-if [ "${SUBMODULES_WITH_UPDATES}" = "0" ]; then - echo "No submodules with any updates." -fi -) + for submodule in "${submodule_dirs[@]}"; do + echo "Checking submodule ${submodule}" + if ! cd "$submodule"; then + echo "Error: could not cd to $submodule" + exit 1 + fi + + initial_commit_id="$(git log --pretty='%h' -n 1)" + initial_commit_description="$(git log --pretty='%ci - (%s)' -n 1)" + if [[ ${skip_sync} != "1" ]]; then + git fetch 2>/dev/null + fi + + if git branch -a | grep -q "origin/main"; then + branch_name="origin/main" + else + branch_name="origin/master" + fi + + updated_commit_id="$(git log --pretty='%h' -n 1 "${branch_name}" -- )" + updated_commit_description="$(git log --pretty='%ci - (%s)' -n 1 "${updated_commit_id}")" + if [ "${initial_commit_id}" = "${updated_commit_id}" ]; then + echo "No updates for ${submodule}" + continue + fi + SUBMODULES_WITH_UPDATES+=1 + update_log="$(git log --oneline "${initial_commit_id}..${updated_commit_id}")" + update_count="$(echo "${update_log}" | wc -l)" + if [[ "${update_count}" -gt "${max_commits_to_list}" ]]; then + update_log="" + new_commit_terminator="." + else + new_commit_terminator=":" + fi + echo "${update_count} new commits for ${submodule}" + if [ "${update_count}" -ge "${min_commits}" ]; then + echo "Creating commit to update ${submodule##*/} submodule" + git checkout "${updated_commit_id}" > /dev/null 2>&1 + cd "${TOP}" || exit 1 + git add "${submodule}" > /dev/null 2>&1 || exit 1 + git commit -s -F- > /dev/null 2>&1 <<-EOF + Update ${submodule##*/} submodule to upstream master + + Updating from commit id ${initial_commit_id}: + $initial_commit_description + + to commit id ${updated_commit_id}: + ${updated_commit_description} + + This brings in ${update_count} new commits${new_commit_terminator} + ${update_log} + EOF + fi + done + + if [ "${SUBMODULES_WITH_UPDATES}" = "0" ]; then + echo "No submodules with any updates." + fi +} + +main "$@"
