Angel Pons has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/43120 )
Change subject: haswell: Factor out `max_ddr3_freq` ......................................................................
All mainboards choose the maximum speed of DDR3-1600.
Change-Id: I8863f9d1df950b924f596689ebf1bfda5d317e06 Signed-off-by: Angel Pons th3fanbus@gmail.com --- M src/mainboard/asrock/b85m_pro4/romstage.c M src/mainboard/asrock/h81m-hds/romstage.c M src/mainboard/google/beltino/romstage.c M src/mainboard/google/slippy/romstage.c M src/mainboard/intel/baskingridge/romstage.c M src/mainboard/lenovo/t440p/romstage.c M src/mainboard/supermicro/x10slm-f/romstage.c M src/northbridge/intel/haswell/romstage.c 8 files changed, 1 insertion(+), 7 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/20/43120/1
diff --git a/src/mainboard/asrock/b85m_pro4/romstage.c b/src/mainboard/asrock/b85m_pro4/romstage.c index c9dd8d4..c9eb981 100644 --- a/src/mainboard/asrock/b85m_pro4/romstage.c +++ b/src/mainboard/asrock/b85m_pro4/romstage.c @@ -29,7 +29,6 @@ pei_data->spd_addresses[3] = 0xa6; pei_data->ec_present = 0; pei_data->gbe_enable = 1; - pei_data->max_ddr3_freq = 1600;
struct usb2_port_setting usb2_ports[MAX_USB2_PORTS] = { /* Length, Enable, OCn#, Location */ diff --git a/src/mainboard/asrock/h81m-hds/romstage.c b/src/mainboard/asrock/h81m-hds/romstage.c index febaa63..f29bd70 100644 --- a/src/mainboard/asrock/h81m-hds/romstage.c +++ b/src/mainboard/asrock/h81m-hds/romstage.c @@ -26,7 +26,6 @@ pei_data->spd_addresses[0] = 0xa0; pei_data->spd_addresses[2] = 0xa4; pei_data->ec_present = 0; - pei_data->max_ddr3_freq = 1600;
struct usb2_port_setting usb2_ports[MAX_USB2_PORTS] = { /* Length, Enable, OCn#, Location */ diff --git a/src/mainboard/google/beltino/romstage.c b/src/mainboard/google/beltino/romstage.c index fe3275e..525edf4 100644 --- a/src/mainboard/google/beltino/romstage.c +++ b/src/mainboard/google/beltino/romstage.c @@ -51,7 +51,6 @@ /* Enable 2x refresh mode */ pei_data->ddr_refresh_2x = 1; pei_data->dq_pins_interleaved = 1; - pei_data->max_ddr3_freq = 1600; pei_data->usb_xhci_on_resume = 1;
struct usb2_port_setting usb2_ports[MAX_USB2_PORTS] = { diff --git a/src/mainboard/google/slippy/romstage.c b/src/mainboard/google/slippy/romstage.c index ea95853..6145432 100644 --- a/src/mainboard/google/slippy/romstage.c +++ b/src/mainboard/google/slippy/romstage.c @@ -48,7 +48,6 @@ pei_data->spd_addresses[0] = 0xff; pei_data->spd_addresses[2] = 0xff; pei_data->ec_present = 1; - pei_data->max_ddr3_freq = 1600; pei_data->usb_xhci_on_resume = 1;
variant_romstage_entry(pei_data); diff --git a/src/mainboard/intel/baskingridge/romstage.c b/src/mainboard/intel/baskingridge/romstage.c index a156095..6b2dfa7 100644 --- a/src/mainboard/intel/baskingridge/romstage.c +++ b/src/mainboard/intel/baskingridge/romstage.c @@ -52,7 +52,6 @@ pei_data->spd_addresses[2] = 0xa4; pei_data->spd_addresses[3] = 0xa6; pei_data->ec_present = 0; - pei_data->max_ddr3_freq = 1600;
struct usb2_port_setting usb2_ports[MAX_USB2_PORTS] = { /* Length, Enable, OCn#, Location */ diff --git a/src/mainboard/lenovo/t440p/romstage.c b/src/mainboard/lenovo/t440p/romstage.c index e101794..7b09df4 100644 --- a/src/mainboard/lenovo/t440p/romstage.c +++ b/src/mainboard/lenovo/t440p/romstage.c @@ -49,7 +49,6 @@ pei_data->spd_addresses[2] = 0xa2; pei_data->ec_present = 1; pei_data->gbe_enable = 1; - pei_data->max_ddr3_freq = 1600;
struct usb2_port_setting usb2_ports[MAX_USB2_PORTS] = { /* Length, Enable, OCn#, Location */ diff --git a/src/mainboard/supermicro/x10slm-f/romstage.c b/src/mainboard/supermicro/x10slm-f/romstage.c index 1606d5f..64d6981 100644 --- a/src/mainboard/supermicro/x10slm-f/romstage.c +++ b/src/mainboard/supermicro/x10slm-f/romstage.c @@ -28,7 +28,6 @@ pei_data->spd_addresses[3] = 0xa6; pei_data->ec_present = 0; pei_data->ddr_refresh_2x = 1; - pei_data->max_ddr3_freq = 1600;
struct usb2_port_setting usb2_ports[MAX_USB2_PORTS] = { /* Length, Enable, OCn#, Location */ diff --git a/src/northbridge/intel/haswell/romstage.c b/src/northbridge/intel/haswell/romstage.c index 6231452..59e3c32 100644 --- a/src/northbridge/intel/haswell/romstage.c +++ b/src/northbridge/intel/haswell/romstage.c @@ -52,6 +52,7 @@ .gpiobase = DEFAULT_GPIOBASE, .temp_mmio_base = 0xfed08000, .tseg_size = CONFIG_SMM_TSEG_SIZE, + .max_ddr3_freq = 1600, };
mainboard_fill_pei_data(&pei_data);
Hello build bot (Jenkins), Tristan Corrick, Alexander Couzens, Patrick Rudolph,
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/20/43120/3
Patrick Rudolph has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43120 )
Patch Set 3: Code-Review+2
Tristan Corrick has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43120 )
Michael Niewöhner has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43120 )
Angel Pons has submitted this change. ( https://review.coreboot.org/c/coreboot/+/43120 )
Change-Id: I8863f9d1df950b924f596689ebf1bfda5d317e06 Signed-off-by: Angel Pons th3fanbus@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/43120 Reviewed-by: Patrick Rudolph siro@das-labor.org Reviewed-by: Tristan Corrick tristan@corrick.kiwi Reviewed-by: Michael Niewöhner Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/mainboard/asrock/b85m_pro4/romstage.c M src/mainboard/asrock/h81m-hds/romstage.c M src/mainboard/google/beltino/romstage.c M src/mainboard/google/slippy/romstage.c M src/mainboard/intel/baskingridge/romstage.c M src/mainboard/lenovo/t440p/romstage.c M src/mainboard/supermicro/x10slm-f/romstage.c M src/northbridge/intel/haswell/romstage.c 8 files changed, 1 insertion(+), 7 deletions(-)
Approvals: build bot (Jenkins): Verified Patrick Rudolph: Looks good to me, approved Tristan Corrick: Looks good to me, approved Michael Niewöhner: Looks good to me, approved
diff --git a/src/mainboard/asrock/b85m_pro4/romstage.c b/src/mainboard/asrock/b85m_pro4/romstage.c index 3a3b087..c9c12df 100644 --- a/src/mainboard/asrock/b85m_pro4/romstage.c +++ b/src/mainboard/asrock/b85m_pro4/romstage.c @@ -30,7 +30,6 @@ pei_data->spd_addresses[3] = 0xa6; pei_data->ec_present = 0; pei_data->gbe_enable = 1; - pei_data->max_ddr3_freq = 1600;
struct usb2_port_setting usb2_ports[MAX_USB2_PORTS] = { /* Length, Enable, OCn#, Location */ diff --git a/src/mainboard/asrock/h81m-hds/romstage.c b/src/mainboard/asrock/h81m-hds/romstage.c index 16f7d0d..6847ff2 100644 --- a/src/mainboard/asrock/h81m-hds/romstage.c +++ b/src/mainboard/asrock/h81m-hds/romstage.c @@ -27,7 +27,6 @@ pei_data->spd_addresses[0] = 0xa0; pei_data->spd_addresses[2] = 0xa4; pei_data->ec_present = 0; - pei_data->max_ddr3_freq = 1600;
struct usb2_port_setting usb2_ports[MAX_USB2_PORTS] = { /* Length, Enable, OCn#, Location */ diff --git a/src/mainboard/lenovo/t440p/romstage.c b/src/mainboard/lenovo/t440p/romstage.c index 53088d6..23a12aa 100644 --- a/src/mainboard/lenovo/t440p/romstage.c +++ b/src/mainboard/lenovo/t440p/romstage.c @@ -50,7 +50,6 @@ pei_data->spd_addresses[2] = 0xa2; pei_data->ec_present = 1; pei_data->gbe_enable = 1; - pei_data->max_ddr3_freq = 1600;
struct usb2_port_setting usb2_ports[MAX_USB2_PORTS] = { /* Length, Enable, OCn#, Location */ diff --git a/src/mainboard/supermicro/x10slm-f/romstage.c b/src/mainboard/supermicro/x10slm-f/romstage.c index ce8f888..09e8df1 100644 --- a/src/mainboard/supermicro/x10slm-f/romstage.c +++ b/src/mainboard/supermicro/x10slm-f/romstage.c @@ -29,7 +29,6 @@ pei_data->spd_addresses[3] = 0xa6; pei_data->ec_present = 0; pei_data->ddr_refresh_2x = 1; - pei_data->max_ddr3_freq = 1600;
struct usb2_port_setting usb2_ports[MAX_USB2_PORTS] = { /* Length, Enable, OCn#, Location */ diff --git a/src/northbridge/intel/haswell/romstage.c b/src/northbridge/intel/haswell/romstage.c index 7c27827..ca94813 100644 --- a/src/northbridge/intel/haswell/romstage.c +++ b/src/northbridge/intel/haswell/romstage.c @@ -52,6 +52,7 @@ .gpiobase = DEFAULT_GPIOBASE, .temp_mmio_base = 0xfed08000, .tseg_size = CONFIG_SMM_TSEG_SIZE, + .max_ddr3_freq = 1600, };
