Ravishankar Sarawadi has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/37928 )
Change subject: [WIP]mb/intel/tglrvp: Add correct memory SPD settings ......................................................................
Add Tigerlake RVP supported SPDs and update FSP-M UPDs for MRC boot config.
BUG=none BRANCH=none TEST=Build and boot tigerlake rvp board
Signed-off-by: Ravi Sarawadi ravishankar.sarawadi@intel.com Change-Id: Id3fd54b051effb9eb2303e0db2217dd28f857368 --- M src/mainboard/intel/tglrvp/romstage_fsp_params.c A src/mainboard/intel/tglrvp/spd/Hynix-H9HKNNNEBMAV-4267.spd.hex M src/mainboard/intel/tglrvp/spd/Makefile.inc A src/mainboard/intel/tglrvp/spd/Micron-MT53D1G64D8SQ-046.spd.hex A src/mainboard/intel/tglrvp/spd/Samsung-K4UBE3D4AA-MGCL.spd.hex M src/mainboard/intel/tglrvp/spd/spd.h M src/mainboard/intel/tglrvp/variants/tglrvp_up3/Makefile.inc M src/mainboard/intel/tglrvp/variants/tglrvp_up3/devicetree.cb 8 files changed, 312 insertions(+), 289 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/28/37928/1
diff --git a/src/mainboard/intel/tglrvp/romstage_fsp_params.c b/src/mainboard/intel/tglrvp/romstage_fsp_params.c index 0ab1f48..303f70a 100644 --- a/src/mainboard/intel/tglrvp/romstage_fsp_params.c +++ b/src/mainboard/intel/tglrvp/romstage_fsp_params.c @@ -12,11 +12,91 @@ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU General Public License for more details. */ - +#include <assert.h> +#include <console/console.h> #include <fsp/api.h> #include <soc/romstage.h> +#include <spd_bin.h> +#include <string.h> + +/* DQ byte map */ +static const u8 dq_map[8][2][8] = { + //Controller 0 + { { 0, 1, 6, 7, 3, 2, 5, 4 }, // Byte 0 + { 15, 8, 9, 14, 12, 11, 10, 13 } }, // Byte 1 + { { 11, 12, 8, 15, 9, 14, 10, 13 }, // Byte 2 + { 3, 4, 7, 0, 6, 1, 5, 2 } }, // Byte 3 + { { 4, 5, 3, 2, 7, 1, 0, 6 }, // Byte 4 + { 11, 10, 12, 13, 8, 9, 14, 15 } }, // Byte 5 + { { 12, 11, 8, 13, 14, 15, 9, 10 }, // Byte 6 + { 4, 7, 3, 2, 1, 6, 0, 5 } }, // Byte 7 + //Controller 1 + { { 11, 10, 9, 8, 12, 13, 15, 14 }, // Byte 0 ChB! + { 4, 5, 6, 7, 3, 2, 0, 1 } }, // Byte 1 ChB! + { { 0, 7, 1, 6, 3, 5, 2, 4 }, // Byte 2 + { 9, 8, 10, 11, 14, 15, 13, 12 } }, // Byte 3 + { { 4, 5, 6, 1, 3, 2, 7, 0 }, // Byte 4 + { 10, 13, 12, 11, 14, 9, 15, 8 } }, // Byte 5 + { { 10, 12, 9, 15, 8, 11, 13, 14 }, // Byte 6 + { 3, 4, 1, 2, 6, 0, 5, 7 } } // Byte 7 + }; + +/* DQS CPU<>DRAM map */ +static const u8 dqs_map[8][2] = { + // Ch 0 1 2 3 + { 0, 1 }, { 1, 0 }, { 0, 1 }, { 1, 0 }, // Controller 0 + { 1, 0 }, { 0, 1 }, { 0, 1 }, { 1, 0 } // Controller 1 + }; + +/* Rcomp resistor */ +static const u16 rcomp_resistor = 100; + +/* Rcomp target */ +static const u16 RcompTarget[] = { 60, 40, 40, 40, 30 };
void mainboard_memory_init_params(FSPM_UPD *mupd) { - /* ToDo : Fill FSP-M memory params */ + FSP_M_CONFIG *mem_cfg = &mupd->FspmConfig; + u8 spd_index = 1;//get_spd_index(); + + if (spd_index > 0 && spd_index != 2) { + struct region_device spd_rdev; + uintptr_t spd_ptr; + + if (get_spd_cbfs_rdev(&spd_rdev, spd_index) < 0) + die("spd.bin not found\n"); + + mem_cfg->MemorySpdDataLen = region_device_sz(&spd_rdev); + spd_ptr = (uintptr_t)rdev_mmap_full(&spd_rdev); +#if 0 + mem_cfg->MemorySpdPtr00 = spd_ptr; + mem_cfg->MemorySpdPtr02 = spd_ptr; + mem_cfg->MemorySpdPtr04 = spd_ptr; + mem_cfg->MemorySpdPtr06 = spd_ptr; +#endif + mem_cfg->MemorySpdPtr08 = spd_ptr; + mem_cfg->MemorySpdPtr10 = spd_ptr; + mem_cfg->MemorySpdPtr12 = spd_ptr; + mem_cfg->MemorySpdPtr14 = spd_ptr; + + mem_cfg->SpdAddressTable[0] = 0x0; + mem_cfg->SpdAddressTable[1] = 0x0; + mem_cfg->SpdAddressTable[2] = 0x0; + mem_cfg->SpdAddressTable[3] = 0x0; + } else { + mem_cfg->MemorySpdPtr00 = 0; + mem_cfg->MemorySpdPtr01 = 0; + mem_cfg->MemorySpdPtr10 = 0; + mem_cfg->MemorySpdPtr11 = 0; + + mem_cfg->SpdAddressTable[0] = 0xA0; + mem_cfg->SpdAddressTable[1] = 0xA2; + mem_cfg->SpdAddressTable[2] = 0xA4; + mem_cfg->SpdAddressTable[3] = 0xA6; + } + + memcpy(&mem_cfg->DqMapCpu2DramCh0, dq_map, sizeof(dq_map)); + memcpy(&mem_cfg->DqsMapCpu2DramCh0, dqs_map, sizeof(dqs_map)); + mem_cfg->RcompResistor = rcomp_resistor; + memcpy(&mem_cfg->RcompTarget, RcompTarget, sizeof(RcompTarget)); } diff --git a/src/mainboard/intel/tglrvp/spd/Hynix-H9HKNNNEBMAV-4267.spd.hex b/src/mainboard/intel/tglrvp/spd/Hynix-H9HKNNNEBMAV-4267.spd.hex new file mode 100644 index 0000000..6955f2c --- /dev/null +++ b/src/mainboard/intel/tglrvp/spd/Hynix-H9HKNNNEBMAV-4267.spd.hex @@ -0,0 +1,32 @@ +23 11 11 0E 1B 21 F0 08 00 40 00 00 0A 01 00 00 +00 00 05 0F 92 54 01 00 8A 00 90 A8 90 C0 08 60 +04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 92 00 A7 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 56 00 00 00 20 20 20 20 20 20 20 +20 20 20 20 20 20 20 20 20 20 20 20 20 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 diff --git a/src/mainboard/intel/tglrvp/spd/Makefile.inc b/src/mainboard/intel/tglrvp/spd/Makefile.inc index b8b059a..e24f576 100644 --- a/src/mainboard/intel/tglrvp/spd/Makefile.inc +++ b/src/mainboard/intel/tglrvp/spd/Makefile.inc @@ -13,8 +13,27 @@ ## GNU General Public License for more details. ##
-romstage-y += spd_util.c - SPD_BIN = $(obj)/spd.bin
-SPD_SOURCES = empty # 0b000 +SPD_SOURCES = empty # 0b000 +SPD_SOURCES += Micron-MT53D1G64D8SQ-046 +SPD_SOURCES += Samsung-K4UBE3D4AA-MGCL +SPD_SOURCES += Hynix-H9HKNNNEBMAV-4267 + +ifeq ($(SPD_SOURCES),) + SPD_DEPS := $(error SPD_SOURCES is not set. Variant must provide this) +else + SPD_DEPS := $(foreach f, $(SPD_SOURCES), src/mainboard/$(MAINBOARDDIR)/spd/$(f).spd.hex) +endif + +# Include spd ROM data +$(SPD_BIN): $(SPD_DEPS) + for f in $+; \ + do for c in $$(cat $$f | grep -v ^#); \ + do printf $$(printf '%o' 0x$$c); \ + done; \ + done > $@ + +cbfs-files-y += spd.bin +spd.bin-file := $(SPD_BIN) +spd.bin-type := spd diff --git a/src/mainboard/intel/tglrvp/spd/Micron-MT53D1G64D8SQ-046.spd.hex b/src/mainboard/intel/tglrvp/spd/Micron-MT53D1G64D8SQ-046.spd.hex new file mode 100644 index 0000000..40fccaa --- /dev/null +++ b/src/mainboard/intel/tglrvp/spd/Micron-MT53D1G64D8SQ-046.spd.hex @@ -0,0 +1,32 @@ +23 10 11 0E 15 19 95 08 00 40 00 00 02 21 00 00 +48 00 05 FF 92 55 00 00 8C 00 90 A8 90 90 06 D0 +02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 7F 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 55 00 00 00 20 20 20 20 20 20 20 +20 20 20 20 20 20 20 20 20 20 20 20 20 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 diff --git a/src/mainboard/intel/tglrvp/spd/Samsung-K4UBE3D4AA-MGCL.spd.hex b/src/mainboard/intel/tglrvp/spd/Samsung-K4UBE3D4AA-MGCL.spd.hex new file mode 100644 index 0000000..95a495e --- /dev/null +++ b/src/mainboard/intel/tglrvp/spd/Samsung-K4UBE3D4AA-MGCL.spd.hex @@ -0,0 +1,32 @@ +23 11 11 0E 16 21 95 08 00 40 00 00 0A 01 00 00 +48 00 04 FF 92 55 00 00 8C 00 90 A8 90 C0 08 60 +04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 7F E1 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 20 00 00 00 20 20 20 20 20 20 20 +20 20 20 20 20 20 20 20 20 20 20 20 20 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 diff --git a/src/mainboard/intel/tglrvp/spd/spd.h b/src/mainboard/intel/tglrvp/spd/spd.h index ed8b8b6..283a5c6 100644 --- a/src/mainboard/intel/tglrvp/spd/spd.h +++ b/src/mainboard/intel/tglrvp/spd/spd.h @@ -16,14 +16,17 @@ #ifndef MAINBOARD_SPD_H #define MAINBOARD_SPD_H
-#include <stdint.h> - #define RCOMP_TARGET_PARAMS 0x5
-void mainboard_fill_dq_map_ch0(u8 *dq_map_ptr); -void mainboard_fill_dq_map_ch1(u8 *dq_map_ptr); -void mainboard_fill_dqs_map_ch0(u8 *dqs_map_ptr); -void mainboard_fill_dqs_map_ch1(u8 *dqs_map_ptr); -void mainboard_fill_rcomp_res_data(u16 *rcomp_ptr); -void mainboard_fill_rcomp_strength_data(u16 *rcomp_strength_ptr); +/* SPD index definition should be matched with the order of SPD_SOURCES */ +#define SPD_ID_MICRON 0x0 +#define SPD_ID_SAMSUNG 0x1 +#define SPD_ID_HYNIX 0x2 + +void mainboard_fill_dq_map_ch0(void *dq_map_ptr); +void mainboard_fill_dq_map_ch1(void *dq_map_ptr); +void mainboard_fill_dqs_map_ch0(void *dqs_map_ptr); +void mainboard_fill_dqs_map_ch1(void *dqs_map_ptr); +void mainboard_fill_rcomp_res_data(void *rcomp_ptr); +void mainboard_fill_rcomp_strength_data(void *rcomp_strength_ptr); #endif diff --git a/src/mainboard/intel/tglrvp/variants/tglrvp_up3/Makefile.inc b/src/mainboard/intel/tglrvp/variants/tglrvp_up3/Makefile.inc index 23bf160..2baf643 100644 --- a/src/mainboard/intel/tglrvp/variants/tglrvp_up3/Makefile.inc +++ b/src/mainboard/intel/tglrvp/variants/tglrvp_up3/Makefile.inc @@ -13,6 +13,11 @@ ## GNU General Public License for more details. ##
+## Memory Options +SPD_SOURCES = Micron-MT53D1G64D8SQ-046 +SPD_SOURCES += Samsung-K4UBE3D4AA-MGCL +SPD_SOURCES += Hynix-H9HKNNNEBMAV-4267 + bootblock-y += gpio.c
ramstage-y += gpio.c diff --git a/src/mainboard/intel/tglrvp/variants/tglrvp_up3/devicetree.cb b/src/mainboard/intel/tglrvp/variants/tglrvp_up3/devicetree.cb index 76ceb30..2a1c49c 100644 --- a/src/mainboard/intel/tglrvp/variants/tglrvp_up3/devicetree.cb +++ b/src/mainboard/intel/tglrvp/variants/tglrvp_up3/devicetree.cb @@ -4,37 +4,25 @@ device lapic 0 on end end
- # GPE configuration - # Note that GPE events called out in ASL code rely on this - # route. i.e. If this route changes then the affected GPE - # offset bits also need to be changed. - register "gpe0_dw0" = "GPP_B" - register "gpe0_dw1" = "GPP_D" - register "gpe0_dw2" = "GPP_E" - # FSP configuration - register "SaGv" = "SaGv_Enabled" + register "SaGv" = "SaGv_Disabled" register "SmbusEnable" = "1" - register "ScsEmmcHs400Enabled" = "1" - register "SdCardPowerEnableActiveHigh" = "1"
- register "usb2_ports[0]" = "USB2_PORT_MID(OC0)" # USB3/2 Type A port1 - register "usb2_ports[1]" = "USB2_PORT_MID(OC_SKIP)" # USB2 WWAN - register "usb2_ports[2]" = "USB2_PORT_MID(OC_SKIP)" # USB2 Bluetooth - register "usb2_ports[3]" = "USB2_PORT_MID(OC0)" # Type-C Port1 - register "usb2_ports[4]" = "USB2_PORT_MID(OC0)" # Type-C Port2 - register "usb2_ports[5]" = "USB2_PORT_MID(OC3)" # Type-C Port3 - register "usb2_ports[6]" = "USB2_PORT_MID(OC3)" # Type-C Port4 - register "usb2_ports[7]" = "USB2_PORT_MID(OC0)" # USB3/2 Type A port2 - register "usb2_ports[8]" = "USB2_PORT_MID(OC3)" # USB2 Type A port1 - register "usb2_ports[9]" = "USB2_PORT_MID(OC3)" # USB2 Type A port2 + register "usb2_ports[0]" = "USB2_PORT_MID(OC0)" # Type-C Port1 + register "usb2_ports[1]" = "USB2_PORT_MID(OC_SKIP)" # M.2 WWAN + register "usb2_ports[2]" = "USB2_PORT_MID(OC3)" # M.2 Bluetooth + register "usb2_ports[3]" = "USB2_PORT_MID(OC0)" # USB3/2 Type A port1 + register "usb2_ports[4]" = "USB2_PORT_MID(OC0)" # Type-C Port2 + register "usb2_ports[5]" = "USB2_PORT_MID(OC3)" # Type-C Port3 + register "usb2_ports[6]" = "USB2_PORT_MID(OC3)" # Type-C Port4 + register "usb2_ports[7]" = "USB2_PORT_MID(OC0)" # USB3/2 Type A port2 + register "usb2_ports[8]" = "USB2_PORT_MID(OC3)" # USB2 Type A port3 + register "usb2_ports[9]" = "USB2_PORT_MID(OC3)" # USB2 Type A port4
register "usb3_ports[0]" = "USB3_PORT_DEFAULT(OC0)" # USB3/2 Type A port1 register "usb3_ports[1]" = "USB3_PORT_DEFAULT(OC0)" # USB3/2 Type A port2 - register "usb3_ports[2]" = "USB3_PORT_DEFAULT(OC_SKIP)" # USB3 WLAN - register "usb3_ports[3]" = "USB3_PORT_DEFAULT(OC_SKIP)" # UNUSED - register "usb3_ports[4]" = "USB3_PORT_DEFAULT(OC_SKIP)" # UNUSED - register "usb3_ports[5]" = "USB3_PORT_DEFAULT(OC_SKIP)" # UNUSED + register "usb3_ports[2]" = "USB3_PORT_EMPTY" # Not used + register "usb3_ports[3]" = "USB3_PORT_EMPTY" # USB3/USB2 Flex Connector
# Enable Pch iSCLK register "pch_isclk" = "1" @@ -45,79 +33,20 @@ # EC memory map range is 0x900-0x9ff register "gen3_dec" = "0x00fc0901"
- register "PchHdaDspEnable" = "1" - register "PchHdaAudioLinkHda" = "1" + register "PrmrrSize" = "0x10000000"
- register "PcieRpEnable[0]" = "1" - register "PcieRpEnable[1]" = "0" - register "PcieRpEnable[2]" = "0" - register "PcieRpEnable[3]" = "0" - register "PcieRpEnable[4]" = "1" - register "PcieRpEnable[5]" = "0" - register "PcieRpEnable[6]" = "0" - register "PcieRpEnable[7]" = "0" + register "PcieRpEnable[2]" = "1" + register "PcieRpEnable[3]" = "1" register "PcieRpEnable[8]" = "1" - register "PcieRpEnable[9]" = "0" - register "PcieRpEnable[10]" = "0" - register "PcieRpEnable[11]" = "0" - register "PcieRpEnable[12]" = "0" - register "PcieRpEnable[13]" = "0" - register "PcieRpEnable[14]" = "0" - register "PcieRpEnable[15]" = "0" + register "PcieRpEnable[9]" = "1"
- register "PcieClkSrcUsage[0]" = "2" - register "PcieClkSrcUsage[1]" = "8" - register "PcieClkSrcUsage[2]" = "0xC" - register "PcieClkSrcUsage[3]" = "0x70" - register "PcieClkSrcUsage[4]" = "4" - register "PcieClkSrcUsage[5]" = "0xE" - register "PcieClkSrcUsage[6]" = "0x80" - register "PcieClkSrcUsage[7]" = "0x80" - register "PcieClkSrcUsage[8]" = "0x80" - register "PcieClkSrcUsage[9]" = "0x80" - register "PcieClkSrcUsage[10]" = "0x80" - register "PcieClkSrcUsage[11]" = "0x80" - register "PcieClkSrcUsage[12]" = "0x80" - register "PcieClkSrcUsage[13]" = "0x80" - register "PcieClkSrcUsage[14]" = "0x80" - register "PcieClkSrcUsage[15]" = "0x80" - - register "PcieClkSrcClkReq[0]" = "0" register "PcieClkSrcClkReq[1]" = "1" register "PcieClkSrcClkReq[2]" = "2" register "PcieClkSrcClkReq[3]" = "3" - register "PcieClkSrcClkReq[4]" = "4" - register "PcieClkSrcClkReq[5]" = "5" - register "PcieClkSrcClkReq[6]" = "6" - register "PcieClkSrcClkReq[7]" = "7" - register "PcieClkSrcClkReq[8]" = "8" - register "PcieClkSrcClkReq[9]" = "9" - register "PcieClkSrcClkReq[10]" = "10" - register "PcieClkSrcClkReq[11]" = "11" - register "PcieClkSrcClkReq[12]" = "12" - register "PcieClkSrcClkReq[13]" = "13" - register "PcieClkSrcClkReq[14]" = "14" - register "PcieClkSrcClkReq[15]" = "15"
- register "SataEnable" = "1" - register "SataSalpSupport" = "1" - register "SataPortsEnable[0]" = "1" - register "SataPortsEnable[1]" = "1" - register "SataPortsEnable[2]" = "1" - register "SataPortsEnable[3]" = "1" - register "SataPortsEnable[4]" = "1" - register "SataPortsEnable[5]" = "1" - register "SataPortsEnable[6]" = "1" - register "SataPortsEnable[7]" = "1" - - register "SataPortsDevSlp[0]" = "1" - register "SataPortsDevSlp[1]" = "1" - register "SataPortsDevSlp[2]" = "1" - register "SataPortsDevSlp[3]" = "1" - register "SataPortsDevSlp[4]" = "1" - register "SataPortsDevSlp[5]" = "1" - register "SataPortsDevSlp[6]" = "1" - register "SataPortsDevSlp[7]" = "1" + register "PcieClkSrcUsage[1]" = "0x2" + register "PcieClkSrcUsage[2]" = "0x3" + register "PcieClkSrcUsage[3]" = "0x8"
register "SerialIoI2cMode" = "{ [PchSerialIoIndexI2C0] = PchSerialIoPci, @@ -130,208 +59,99 @@
register "SerialIoGSpiMode" = "{ [PchSerialIoIndexGSPI0] = PchSerialIoDisabled, - [PchSerialIoIndexGSPI1] = PchSerialIoPci, + [PchSerialIoIndexGSPI1] = PchSerialIoDisabled, [PchSerialIoIndexGSPI2] = PchSerialIoDisabled, + [PchSerialIoIndexGSPI3] = PchSerialIoDisabled, }"
register "SerialIoGSpiCsMode" = "{ - [PchSerialIoIndexGSPI0] = 1, - [PchSerialIoIndexGSPI1] = 1, - [PchSerialIoIndexGSPI2] = 1, + [PchSerialIoIndexGSPI0] = 0, + [PchSerialIoIndexGSPI1] = 0, + [PchSerialIoIndexGSPI2] = 0, + [PchSerialIoIndexGSPI3] = 0, }"
register "SerialIoGSpiCsState" = "{ [PchSerialIoIndexGSPI0] = 0, [PchSerialIoIndexGSPI1] = 0, [PchSerialIoIndexGSPI2] = 0, + [PchSerialIoIndexGSPI3] = 0, }"
register "SerialIoUartMode" = "{ [PchSerialIoIndexUART0] = PchSerialIoDisabled, [PchSerialIoIndexUART1] = PchSerialIoDisabled, - [PchSerialIoIndexUART2] = PchSerialIoSkipInit, - }" - - # Enable "Intel Speed Shift Technology" - register "speed_shift_enable" = "1" - - # Enable DPTF - register "dptf_enable" = "1" - - # GPIO for SD card detect - register "sdcard_cd_gpio" = "GPP_G5" - - # Enable S0ix - register "s0ix_enable" = "0" - - register "common_soc_config" = "{ - .chipset_lockdown = CHIPSET_LOCKDOWN_COREBOOT, - .gspi[1] = { - .speed_mhz = 1, - .early_init = 1, - }, + [PchSerialIoIndexUART2] = PchSerialIoPci, }"
device domain 0 on - device pci 00.0 on end # Host Bridge - device pci 02.0 on end # Integrated Graphics Device - device pci 04.0 off end # SA Thermal device - device pci 12.0 off end # Thermal Subsystem - device pci 12.5 off end # UFS SCS - device pci 12.6 off end # GSPI #2 - device pci 14.0 on - chip drivers/usb/acpi - register "desc" = ""Root Hub"" - register "type" = "UPC_TYPE_HUB" - device usb 0.0 on - chip drivers/usb/acpi - register "desc" = ""USB3/2 Type-A Left Lower"" - register "type" = "UPC_TYPE_A" - device usb 2.0 on end - end - chip drivers/usb/acpi - register "desc" = ""WWAN"" - register "type" = "UPC_TYPE_INTERNAL" - device usb 2.1 on end - end - chip drivers/usb/acpi - register "desc" = ""Bluetooth"" - register "type" = "UPC_TYPE_INTERNAL" - device usb 2.2 on end - end - chip drivers/usb/acpi - register "desc" = ""USB C Connector 1"" - register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" - device usb 2.3 on end - end - chip drivers/usb/acpi - register "desc" = ""USB C Connector 2"" - register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" - device usb 2.4 on end - end - chip drivers/usb/acpi - register "desc" = ""USB C Connector 3"" - register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" - device usb 2.5 on end - end - chip drivers/usb/acpi - register "desc" = ""USB C Connector 4"" - register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" - device usb 2.6 on end - end - chip drivers/usb/acpi - register "desc" = ""USB3/2 Type-A Left Upper"" - register "type" = "UPC_TYPE_A" - device usb 2.7 on end - end - chip drivers/usb/acpi - register "desc" = ""USB2 Type-A Right Lower"" - register "type" = "UPC_TYPE_A" - device usb 2.8 on end - end - chip drivers/usb/acpi - register "desc" = ""USB2 Type-A Right Upper"" - register "type" = "UPC_TYPE_A" - device usb 2.9 on end - end - chip drivers/usb/acpi - register "desc" = ""USB3/2 Type-A Left Lower"" - register "type" = "UPC_TYPE_A" - device usb 3.0 on end - end - chip drivers/usb/acpi - register "desc" = ""USB3/2 Type-A Left Upper"" - register "type" = "UPC_TYPE_A" - device usb 3.1 on end - end - chip drivers/usb/acpi - register "desc" = ""WLAN"" - register "type" = "UPC_TYPE_INTERNAL" - device usb 3.2 on end - end - chip drivers/usb/acpi - register "desc" = ""USB3 Port Unused1"" - register "type" = "UPC_TYPE_INTERNAL" - device usb 3.3 on end - end - chip drivers/usb/acpi - register "desc" = ""USB3 Port Unused2"" - register "type" = "UPC_TYPE_INTERNAL" - device usb 3.4 on end - end - chip drivers/usb/acpi - register "desc" = ""USB3 Port Unused3"" - register "type" = "UPC_TYPE_INTERNAL" - device usb 3.5 on end - end - end - end - end # USB xHCI - device pci 14.1 off end # USB xDCI (OTG) - device pci 14.2 off end # PMC SRAM - chip drivers/intel/wifi - register "wake" = "GPE0_PME_B0" - device pci 14.3 on end # CNVi wifi - end - device pci 14.5 on end # SDCard - device pci 15.0 on - chip drivers/i2c/hid - register "generic.hid" = ""ALPS0000"" - register "generic.desc" = ""Touchpad"" - register "generic.irq" = "ACPI_IRQ_LEVEL_LOW(GPP_C8_IRQ)" - register "hid_desc_reg_offset" = "0x20" - device i2c 2c on end - end - end # I2C 0 - device pci 15.1 on end # I2C #1 - device pci 15.2 on end # I2C #2 - device pci 15.3 on end # I2C #3 - device pci 16.0 on end # Management Engine Interface 1 - device pci 16.1 off end # Management Engine Interface 2 - device pci 16.2 off end # Management Engine IDE-R - device pci 16.3 off end # Management Engine KT Redirection - device pci 16.4 off end # Management Engine Interface 3 - device pci 16.5 off end # Management Engine Interface 4 - device pci 17.0 on end # SATA - device pci 19.0 on end # I2C #4 - device pci 19.1 off end # I2C #5 - device pci 19.2 on end # UART #2 - device pci 1a.0 on end # eMMC - device pci 1c.0 on - chip drivers/intel/wifi - register "wake" = "GPE0_PCI_EXP" - device pci 00.0 on end - end - end # PCI Express Port 1 x4 SLOT1 - device pci 1c.4 on end # PCI Express Port 5 x1 SLOT2/LAN - device pci 1c.5 off end # PCI Express Port 6 - device pci 1c.6 off end # PCI Express Port 7 - device pci 1c.7 off end # PCI Express Port 8 - device pci 1d.0 on end # PCI Express Port 9 - device pci 1d.1 off end # PCI Express Port 10 - device pci 1d.2 off end # PCI Express Port 11 - device pci 1d.3 off end # PCI Express Port 12 - device pci 1d.4 off end # PCI Express Port 13 - device pci 1d.5 off end # PCI Express Port 14 - device pci 1d.6 off end # PCI Express Port 15 - device pci 1d.7 off end # PCI Express Port 16 - device pci 1e.0 on end # UART #0 - device pci 1e.1 off end # UART #1 - device pci 1e.2 off end # GSPI #0 - device pci 1e.3 on - chip drivers/spi/acpi - register "hid" = "ACPI_DT_NAMESPACE_HID" - register "compat_string" = ""google,cr50"" - register "irq" = "ACPI_IRQ_EDGE_LOW(GPP_D16_IRQ)" - device spi 0 on end - end - end # GSPI #1 - device pci 1f.0 on end # eSPI Interface - device pci 1f.1 on end # P2SB - device pci 1f.2 on end # Power Management Controller - device pci 1f.3 on end # Intel HDA - device pci 1f.4 on end # SMBus - device pci 1f.5 on end # PCH SPI - device pci 1f.6 off end # GbE + #From EDS(575683) + device pci 00.0 on end # Host Bridge 0x9A14:U/0x9A12:Y + device pci 02.0 on end # Graphics + device pci 04.0 on end # DPTF 0x9A03 + device pci 05.0 on end # IPU 0x9A19 + device pci 06.0 on end # PEG60 0x9A09 + device pci 07.0 off end # TBT_PCIe0 0x9A23 + device pci 07.1 off end # TBT_PCIe1 0x9A25 + device pci 07.2 off end # TBT_PCIe2 0x9A27 + device pci 07.3 off end # TBT_PCIe3 0x9A29 + device pci 08.0 off end # GNA 0x9A11 + device pci 09.0 off end # NPK 0x9A33 + device pci 0a.0 off end # Crash-log SRAM 0x9A0D + device pci 0d.0 on end # USB xHCI 0x9A13 + device pci 0d.1 on end # USB xDCI (OTG) 0x9A15 + device pci 0d.2 off end # TBT DMA0 0x9A1B + device pci 0d.3 off end # TBT DMA1 0x9A1D + device pci 0e.0 on end # VMD 0x9A0B + + # From PCH EDS(576591) + device pci 10.2 off end # CNVi: BT 0xA0F5 - A0F7 + device pci 10.6 off end # THC0 0xA0D0 + device pci 10.7 off end # THC1 0xA0D1 + device pci 12.0 off end # SensorHUB 0xA0FC + device pci 12.6 off end # GSPI2 0x34FB + device pci 13.0 off end # GSPI3 0xA0FD + device pci 14.0 on end # USB3.1 xHCI 0xA0ED + device pci 14.1 on end # USB3.1 xDCI 0xA0EE + device pci 14.2 on end # Shared RAM 0xA0EF + device pci 14.3 off end # CNVi: WiFi 0xA0F0 - A0F3 + device pci 15.0 on end # I2C0 0xA0E8 + device pci 15.1 on end # I2C1 0xA0E9 + device pci 15.2 on end # I2C2 0xA0EA + device pci 15.3 on end # I2C3 0xA0EB + device pci 16.0 on end # HECI1 0xA0E0 + device pci 16.1 off end # HECI2 0xA0E1 + device pci 16.2 off end # CSME 0xA0E2 + device pci 16.3 off end # CSME 0xA0E3 + device pci 16.4 off end # HECI3 0xA0E4 + device pci 16.5 off end # HECI4 0xA0E5 + device pci 17.0 off end # SATA 0xA0D3 + device pci 19.0 off end # I2C4 0xA0C5 + device pci 19.1 on end # I2C5 0xA0C6 + device pci 19.2 on end # UART2 0xA0C7 + device pci 1c.0 off end # RP1 0xA0B8 + device pci 1c.1 off end # RP2 0xA0B9 + device pci 1c.2 on end # RP3 0xA0BA + device pci 1c.3 on end # RP4 0xA0BB + device pci 1c.4 off end # RP5 0xA0BC + device pci 1c.5 off end # RP6 0xA0BD + device pci 1c.6 off end # RP7 0xA0BE + device pci 1c.7 off end # RP8 0xA0BF + device pci 1d.0 on end # RP9 0xA0B0 + device pci 1d.1 off end # RP10 0xA0B1 + device pci 1d.2 on end # RP11 0xA0B2 + device pci 1d.3 off end # RP12 0xA0B3 + device pci 1e.0 off end # UART0 0xA0A8 + device pci 1e.1 off end # UART1 0xA0A9 + device pci 1e.2 off end # GSPI0 0xA0AA + device pci 1e.3 off end # GSPI1 0xA0AB + device pci 1f.0 on end # eSPI 0xA080 - A09F + device pci 1f.1 on end # P2SB 0xA0A0 + device pci 1f.2 on end # PMC 0xA0A1 + device pci 1f.3 on end # Intel HD audio 0xA0C8-A0CF + device pci 1f.4 on end # SMBus 0xA0A3 + device pci 1f.5 on end # SPI 0xA0A4 + device pci 1f.6 off end # GbE 0x15E1/0x15E2 + device pci 1f.7 off end # TH 0xA0A6 end end
Wonkyu Kim has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/37928 )
Patch Set 2:
(2 comments)
https://review.coreboot.org/c/coreboot/+/37928/2/src/mainboard/intel/tglrvp/... File src/mainboard/intel/tglrvp/romstage_fsp_params.c:
https://review.coreboot.org/c/coreboot/+/37928/2/src/mainboard/intel/tglrvp/... PS2, Line 23: static const u8 dq_map[8][2][8] = { : //Controller 0 : { { 0, 1, 6, 7, 3, 2, 5, 4 }, // Byte 0 : { 15, 8, 9, 14, 12, 11, 10, 13 } }, // Byte 1 : { { 11, 12, 8, 15, 9, 14, 10, 13 }, // Byte 2 : { 3, 4, 7, 0, 6, 1, 5, 2 } }, // Byte 3 : { { 4, 5, 3, 2, 7, 1, 0, 6 }, // Byte 4 : { 11, 10, 12, 13, 8, 9, 14, 15 } }, // Byte 5 : { { 12, 11, 8, 13, 14, 15, 9, 10 }, // Byte 6 : { 4, 7, 3, 2, 1, 6, 0, 5 } }, // Byte 7 : //Controller 1 : { { 11, 10, 9, 8, 12, 13, 15, 14 }, // Byte 0 ChB! : { 4, 5, 6, 7, 3, 2, 0, 1 } }, // Byte 1 ChB! : { { 0, 7, 1, 6, 3, 5, 2, 4 }, // Byte 2 : { 9, 8, 10, 11, 14, 15, 13, 12 } }, // Byte 3 : { { 4, 5, 6, 1, 3, 2, 7, 0 }, // Byte 4 : { 10, 13, 12, 11, 14, 9, 15, 8 } }, // Byte 5 : { { 10, 12, 9, 15, 8, 11, 13, 14 }, // Byte 6 : { 3, 4, 1, 2, 6, 0, 5, 7 } } // Byte 7 : }; : : /* DQS CPU<>DRAM map */ : static const u8 dqs_map[8][2] = { : // Ch 0 1 2 3 : { 0, 1 }, { 1, 0 }, { 0, 1 }, { 1, 0 }, // Controller 0 : { 1, 0 }, { 0, 1 }, { 0, 1 }, { 1, 0 } // Controller 1 : }; is this for LPDDR4? Can we use memory.c for this data? And we need to support DDR4 with mainboard config
https://review.coreboot.org/c/coreboot/+/37928/2/src/mainboard/intel/tglrvp/... PS2, Line 71: #if 0 : mem_cfg->MemorySpdPtr00 = spd_ptr; : mem_cfg->MemorySpdPtr02 = spd_ptr; : mem_cfg->MemorySpdPtr04 = spd_ptr; : mem_cfg->MemorySpdPtr06 = spd_ptr; : #endif : mem_cfg->MemorySpdPtr08 = spd_ptr; : mem_cfg->MemorySpdPtr10 = spd_ptr; : mem_cfg->MemorySpdPtr12 = spd_ptr; : mem_cfg->MemorySpdPtr14 = spd_ptr; : : mem_cfg->SpdAddressTable[0] = 0x0; : mem_cfg->SpdAddressTable[1] = 0x0; : mem_cfg->SpdAddressTable[2] = 0x0; : mem_cfg->SpdAddressTable[3] = 0x0; : } else { : mem_cfg->MemorySpdPtr00 = 0; : mem_cfg->MemorySpdPtr01 = 0; : mem_cfg->MemorySpdPtr10 = 0; : mem_cfg->MemorySpdPtr11 = 0; : : mem_cfg->SpdAddressTable[0] = 0xA0; : mem_cfg->SpdAddressTable[1] = 0xA2; : mem_cfg->SpdAddressTable[2] = 0xA4; : mem_cfg->SpdAddressTable[3] = 0xA6; : } Need to support DDR4 case
Paul Menzel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/37928 )
Patch Set 2:
(6 comments)
https://review.coreboot.org/c/coreboot/+/37928/2//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/37928/2//COMMIT_MSG@6 PS2, Line 6: : [WIP] There is a WIP label in Gerrit.
https://review.coreboot.org/c/coreboot/+/37928/2//COMMIT_MSG@9 PS2, Line 9: Tigerlake Tiger Lake
https://review.coreboot.org/c/coreboot/+/37928/2//COMMIT_MSG@10 PS2, Line 10: for MRC boot config. Fits on the line above.
https://review.coreboot.org/c/coreboot/+/37928/2//COMMIT_MSG@11 PS2, Line 11: Please elaborate a little more, how you implement this.
https://review.coreboot.org/c/coreboot/+/37928/2//COMMIT_MSG@14 PS2, Line 14: tigerlake Tiger Lake
https://review.coreboot.org/c/coreboot/+/37928/2/src/mainboard/intel/tglrvp/... File src/mainboard/intel/tglrvp/spd/Makefile.inc:
https://review.coreboot.org/c/coreboot/+/37928/2/src/mainboard/intel/tglrvp/... PS2, Line 18: One space?
Srinidhi N Kaushik has uploaded a new patch set (#3) to the change originally created by Ravishankar Sarawadi. ( https://review.coreboot.org/c/coreboot/+/37928 )
Signed-off-by: Ravi Sarawadi ravishankar.sarawadi@intel.com Change-Id: Id3fd54b051effb9eb2303e0db2217dd28f857368 --- M src/mainboard/intel/tglrvp/romstage_fsp_params.c A src/mainboard/intel/tglrvp/spd/Hynix-H9HKNNNEBMAV-4267.spd.hex M src/mainboard/intel/tglrvp/spd/Makefile.inc A src/mainboard/intel/tglrvp/spd/Micron-MT53D1G64D8SQ-046.spd.hex A src/mainboard/intel/tglrvp/spd/Samsung-K4UBE3D4AA-MGCL.spd.hex M src/mainboard/intel/tglrvp/spd/spd.h M src/mainboard/intel/tglrvp/variants/tglrvp_up3/Makefile.inc 7 files changed, 220 insertions(+), 13 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/28/37928/3
Srinidhi N Kaushik has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/37928 )
Patch Set 3:
(5 comments)
Ack
Tiger Lake
Ack
Ack
Tiger Lake
Ack
One space?
Ack
Srinidhi N Kaushik has uploaded a new patch set (#4) to the change originally created by Ravishankar Sarawadi. ( https://review.coreboot.org/c/coreboot/+/37928 )
Change subject: mb/intel/tglrvp: Add correct memory SPD settings ......................................................................
Add supported SPDs for Tiger Lake RVP & update FSP-M UPDs for MRC boot config
BUG=none BRANCH=none TEST=Build and boot Tiger Lake rvp board
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/28/37928/4
Nick Vaccaro has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/37928 )
Patch Set 5:
(4 comments)
Sorry, didn't notice until I was done reviewing that the CL is marked Work In Progress until after I finished adding some review comments. I thought I would submit the comments anyway in case it helps / points out a case that you didn't know about or aren't currently working on changing. Next time I will wait until CL is no longer marked "Work in Progress" before reviewing.
https://review.coreboot.org/c/coreboot/+/37928/5/src/mainboard/intel/tglrvp/... File src/mainboard/intel/tglrvp/romstage_fsp_params.c:
https://review.coreboot.org/c/coreboot/+/37928/5/src/mainboard/intel/tglrvp/... PS5, Line 16: #include <console/console.h> Is this still needed?
https://review.coreboot.org/c/coreboot/+/37928/5/src/mainboard/intel/tglrvp/... PS5, Line 55: static const u16 RcompTarget[] = { 60, 40, 40, 40, 30 }; Are these needed? I was told Tigerlake didn't care about RCompTarget or rcomp_resistor, so volteer doesn't have them.
https://review.coreboot.org/c/coreboot/+/37928/5/src/mainboard/intel/tglrvp/... PS5, Line 71: #if 0 Please remove commented out code.
https://review.coreboot.org/c/coreboot/+/37928/5/src/mainboard/intel/tglrvp/... File src/mainboard/intel/tglrvp/spd/spd.h:
https://review.coreboot.org/c/coreboot/+/37928/5/src/mainboard/intel/tglrvp/... PS5, Line 21: /* SPD index definition should be matched with the order of SPD_SOURCES */ The strap table in tglrvp/spd/Makefile.inc has ID 0 set to empty (https://review.coreboot.org/c/coreboot/+/37928/5/src/mainboard/intel/tglrvp/...), which doesn't match these defines. I do see another SPD_SOURCES being set for tglrvp_up3 in this order. Why does tglrvp define SPD in two places? Does table in tglrvp_up3 override settings in tglrvp/spd/Makefile.inc when building for up3?
Ravishankar Sarawadi has abandoned this change. ( https://review.coreboot.org/c/coreboot/+/37928 )
Change subject: mb/intel/tglrvp: Add tigerlake memory config ......................................................................
Abandoned
Not needed.
